RO3501
RO3501
    IFM(易福门)
    HOLLOW SHAFT ENCODER OPEN TO ONE
RO3501 数据手册
RO3501 Incremental encoder with hollow shaft INCREMENTAL ENCODER BASIC LINE 1 M3 Product characteristics Resolution 1...10000; (parameterisable; Factory setting: 1024) resolution Communication interface IO-Link Shaft design Shaft diameter hollow shaft open to one side [mm] 12 Application Function principle incremental Detection system magnetic Electrical data Operating voltage Current consumption [V] [mA] Protection class Max. revolution electrical < 150 III Reverse polarity protection Power-on delay time 4.75...30 DC yes [s] [U/min] 0.5 12000 Outputs Electrical design Switching frequency HTL/TTL [kHz] Factory setting Output function: HTL (50 mA) Short-circuit protection Phase difference A and B 1000 yes [°] 90 Measuring/setting range Resolution 1...10000; (parameterisable; Factory setting: 1024) resolution ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — RO3501-02 — 03.08.2017 — RO3501 Incremental encoder with hollow shaft INCREMENTAL ENCODER BASIC LINE Accuracy / deviations Accuracy [°] 0.1 Software / programming Parameter setting options Resolution; direction of rotation; HTL; TTL Interfaces Communication interface IO-Link Transmission type COM2 (38,4 kBaud) IO-Link revision 1.1 SIO mode yes Min. process cycle time [ms] 2.3 Operating conditions Ambient temperature [°C] -40...80 Note on ambient temperature for flexibly laid cable: -25 °C Storage temperature [°C] -40...80 Max. relative air humidity [%] 95; (condensation not permissible) Protection IP 65; IP 66; (on the housing: IP 67; on the shaft: IP 65) Tests / approvals Shock resistance 100 g Vibration resistance MTTF 20 g [years] 292 [g] 476 Mechanical data Weight Dimensions [mm] Materials Ø 58.5 / L = 68.6 flange: aluminium; housing: stainless steel (1.4521 / 444); cable plug: PA Tightening torque [Nm] Max. revolution, mechanical [U/min] Max. starting torque Reference temperature torque < 0.7; (Mounting screw) 12000 [Nm] 2 [°C] 20 Shaft design hollow shaft open to one side Shaft diameter [mm] Shaft material 12 stainless steel Installation depth of shaft [mm] 27 Max. axial shaft misalignment [mm] 0,5 Electrical connection Cable: 2 m, Ø 4.9 mm; radial, can also be used axially; 5 x 0.14 mm² IO-Link brown L+ white not to be used blue L- grey not to be used black IO-Link Screen housing ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — RO3501-02 — 03.08.2017 — RO3501 Incremental encoder with hollow shaft INCREMENTAL ENCODER BASIC LINE encoder brown UB white A blue GND grey B black Z/0-Pulse (90 deg) Screen housing Diagrams and graphs Pulse diagram direction of rotation clockwise (looking at the shaft) ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — RO3501-02 — 03.08.2017 —
RO3501 价格&库存
很抱歉,暂时无法提供与“RO3501”相匹配的价格&库存,您可以联系我们找货
