ACW400-0180-005
ACW400-0180-005
    SENSATA(森萨塔)
    ACW4 MOD 5-30V ANALOG RADIAL CAB
ACW400-0180-005 数据手册
| ACW4 ANALOG ANALOG ABSOLUTE SINGLE TURN MODULAR SENSOR Sensata-BEI Sensors' ACW4 sensors provide absolute single turn measurement with an analog output in an over-molded, modular design that offers flexibility and protection from the environment. Features •  With its two-part design, the ACW4 absolute single-turn offers maximum flexibility for installation •  Rugged and excellent resistance to shock and vibration •  Robust, proven magnetic technology •  Environmentally resistant, IP 67 standard (IP69K option) •  Extended operating range from -40° C to 85° C •  Uses universal supply 5 to 30 VDC – Analog output •  Available Resolution up to 12 bits per revolution •  Variety of magnet holders available Applications •  Factory Automation •  Process Automation SPECIFICATIONS Mechanical Terminations PVC cable Housing Macromelt PA638 Weight 0,150 kg Electrical Electrical Angle 360° Output Function 0– 10 Vdc, 0.5 to 4.5 Vdc, or 4 – 20 mA Minimal Cycle Time 1ms Resolution Single –turn, 12 bits Accuracy +/-0.3% on 360° Repeatability +/-0.1% on 360° Supply Voltage 5Vdc, 11 to 30 Vdc, or 15 to 30 Vdc Start-up < 1s Response time < 10 ms (5L2 and 3L1 electronics), 10 kOhms (voltage out), 500 Ohms (current out) Current Requirements < 40mA Protection Overvoltage Protection: Yes Reverse Polarity Protection: Yes Short Circuit Protection: Yes EMC IEC 61000-4-2 Electrostatic discharge (ESD) 4 kV, 8 kV IEC 61000-4-3 Electromagnetic fields 10 V/m (80MHz - 1GHz), 3V/m (1.4GHz - 2GHz), 1V/m (2GHz - 2.7GHz) IEC 61000-4-4 Electrical fast transients (burst) 1 kV IEC 61000-4-6 Conducted disturbances, induced by RF-fields 10 Veff. Page 1 Copyright © 2020 Sensata Technologies, Inc. www.sensata.com Analog Output Output High Output 50% Output Low Minimum Range +/-15 degrees Maximum Range +/-180 degrees DIMENSIONS All Dimensions are in millimeters. Shaft system with magnet to be ordered separately (see Accessories). Clockwise direction jn A 50 38 8,6
ACW400-0180-005
物料型号:ACW4
器件简介: - Sensata-BEI Sensors的ACW4传感器提供模拟输出的绝对单圈测量,采用注塑成型的模块化设计,提供灵活性和环境防护。
引脚分配: - 功能 | 颜色 - Vcc | 棕色(Brown BN) - OV | 白色(White WH) - Analog Out | 绿色(Green GN) - Ground | 屏蔽(Shield)
参数特性: - 电气角度:360° - 输出功能:0-10Vdc, 0.5至4.5Vdc, 或4-20mA - 最小周期时间:1ms - 分辨率:单圈,12位 - 精度:±0.3%在360° - 重复性:±0.1%在360° - 供电电压:5Vdc, 11至30Vdc, 或15至30Vdc - 启动时间:<1秒 - 响应时间:<10ms(5L2和3L1电子),<1ms(所有其他电子) - 推荐负载:>10kΩ(电压输出),500Ω(电流输出) - 电流需求:<40mA - 保护:过压保护、反极性保护、短路保护 - EMC:符合IEC 61000-4-2、IEC 61000-4-3、IEC 61000-4-4标准
功能详解: - 传感器具有模拟输出,输出范围可调,最小范围±15度,最大范围±180度。
应用信息: - 适用于工厂自动化和过程自动化。
封装信息: - 机械尺寸:所有尺寸单位为毫米,轴系统和磁铁需单独订购(见附件)。 - 重量:0.150kg - 连接方式:3线PVC电缆
订购选项: - 示例:ACW4_00//3L11//00360//L3R020(联系工厂以获取特殊版本,例如尺寸、连接...)
附件: - 女性磁铁支撑+磁铁8810/013,订购型号:M9105/Kxx - 前部磁铁支撑+磁铁8810/013,订购型号:M9105/F26 - 男性磁铁支撑+磁铁8810/013,订购型号:M9105/M10-01
版权信息: - Sensata Technologies, Inc. 版权所有,2020年。
ACW400-0180-005 价格&库存
很抱歉,暂时无法提供与“ACW400-0180-005”相匹配的价格&库存,您可以联系我们找货
