ACW400-12BT-005
ACW400-12BT-005
    SENSATA(森萨塔)
    ACW4 MOD 5-30V SSI EVEN PARITY B
ACW400-12BT-005 数据手册
| ACW4 CANopen CANOPEN ABSOLUTE SINGLE TURN MODULAR SENSOR Sensata-BEI Sensors' ACW4 sensors provide absolute single turn measurement with a CANopen output in an over-molded, two-part package that offers design flexibility & protection from the environment. Features •  With its two-part design, the ACW4 CANopen absolute single-turn offers maximum flexibility for installation •  Rugged and excellent resistance to shock and vibration •  Robust, proven magnetic technology •  Environmentally resistant, IP 67 standard (IP69K option) •  Extended operating range from -30° C to 85° C •  Uses universal supply 5 to 30 VDC – CAN open output •  Available Resolution up to 12 bits per revolution •  Variety of magnet holders available •  Standard PVC cable with SUBD9 connector Applications •  Factory Automation •  Process Automation SPECIFICATIONS Mechanical Terminations PVC Cable with SUBD9 connector Housing Macromelt PA638 Weight 0,150 kg Electrical Electrical Angle 360° Output Function CANopen Minimal Cycle Time < 400µs Resolution Single –turn, 12 bits Accuracy +/-0.3% on 360° Repeatability +/-0.1% on 360° Supply Voltage 5 to 30 Vdc Start-up
ACW400-12BT-005 价格&库存
很抱歉,暂时无法提供与“ACW400-12BT-005”相匹配的价格&库存,您可以联系我们找货
