01008-2040
01008-2040
    SENSATA(森萨塔)
    ROTARY ENCODER OPTICAL 2540PPR
01008-2040 数据手册
| L25 INCREMENTAL OPTICAL ENCODER Introduction The L25 is a lighter duty version of BEI’s H25 optical encoder Incorporating the same high quality optics and electronics as the H25, the L25 also offers low starting torque. Other features include ABEC 5 bearings, EMI shielding, a 1/4” diameter stainless steel shaft and a drawn aluminum cover. Typical applications include use with light machine tools, test and laboratory instrumentation, the biomedical industry and flow metering. MECHANICAL SPECIFICATIONS Shaft Diameter 1/4” nominal Flat On Shaft 0.80 long x 0.03 deep Shaft Loading up to 5 lbs. axial and 8 lbs. radial Shaft Runout .0005 T.I.R. maximum Starting Torque at 25°C Bearings Shaft Material Bearing Housing Cover Bearing Life Maximum RPM Moment of Inertia Weight 0.07 in-oz typical, 0.12 in-oz maximum without sealed bearings; 0.50 in-oz typical, 1.0 in-oz maximum with sealed bearings Class ABEC 5 416 stainless steel Die cast aluminum with iridite finish Drawn aluminum, 0.060” wall, protective finish standard. Die cast aluminum with protective finish for EM, SM, ECS and SCS terminations 1 X 109 revs (6,700 hrs at 2500 RPM) 10,000 RPM 4.1 x 10 -4 oz-in-sec2 13 oz. typical Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com ELECTRICAL SPECIFICATIONS Code Incremental Cycles per Shaft Turn 1 to 28,800 (see note 5) 15V/V: Line Driver, 5–15 VDC in, Vout = Vin 28V/V: Line Driver, 5–28 VDC in, Vout = Vin 28V/5V: Line Driver, 5–28 VDC in, Vout = 5 VDC 28V/OC: Open collector, 5–28 VDC in, OCout Voltage/ Output Current Requirements TTL: 175 mA maximum 125 mA typical 2 channels in quadrature = 27º electrical typical. Optional index is typically gated 1/2 cycle wide (see figure 1) Output Format Protection Level Reverse, overvoltage and output short circuit (4469, 7272 only) Frequency Response 100 KHz (see note 7), up to 800 KHz with interpolation option Output Terminations (See Table 1) ENVIRONMENTAL SPECIFICATIONS Enclosure Rating Temperature Shock NEMA 2 (IP43) Operating, 0º to 70º C; extended temperature testing available (see note 8); storage; -25º to 90º C 50 g’s for 11 msec duration Vibration 5 to 2000 Hz @ 20 G’s Humidity 98% RH without condensation DIMENSIONS L25G - M16 or M18 Optional Face Mounts Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com TABLES Table 1–Incremental Output Terminations The connector style will determine pinouts. For example, an encoder with ABC channels and an M18 connector uses the table to the right. M14 CONNECTOR PIN E D C B F A M16 CONNECTOR PIN A B C D E F G WIRE COLOR DA 15P CONNECTOR YEL BLUE ORN W-YEL W-BLU W-OM RED BLK GRN WHITE 13 14 15 10 11 12 6 1 9 CHANNELS DESIGNATED IN MODEL NO. ABZ ABC A A B B Z A +V (SUPPLY VOLTAGE) B 0 V (CIRCUIT COMMON) CASE GROUND (CG) (except H20) M18 Connector PIN Channel A A B B C Z D +V E F 0V G CG H A I B J Z CHANNELS DESIGNATED IN MODEL NO. ABZ ABC ABZC A A A B B B Z Z A A B B Z +V (SUPPLY VOLTAGE) 0 V (CIRCUIT COMMON) CASE GROUND (CG) (except H20) SHIELD DRAIN (Shielded Cable Only) M12 Connector PIN Channel A A B B C Z D +V E F 0V G CG H A J Z K Z Table 2–Disc Resolutions for Incremental Encoder Model L25 1, 2, 3, 5, 6, 7, 8, 10, 13, 16, 20, 24, 25, 26, 30, 32, 33, 34, 36, 37, 40, 45, 48, 50, 51, 56*, 60, 64, 66, 72, 75, 80, 86, 88, 90, 100, 102, 120, 122,125, 127, 128, 132, 144, 148, 150, 158, 160, 175, 176, 180, 187, 192, 200, 202, 204*, 217, 220, 240, 250, 254, 255, 256, 264*, 274, 280, 283, 288, 292, 300, 312, 320, 321, 325, 360, 366, 372, 375, 377, 380, 381, 384, 385, 393, 400, 430, 432, 450, 462, 480, 490, 500, 502, 508, 512, 522, 530, 550, 560*, 576, 598, 600, 604, 625, 628, 635, 638, 640, 660, 672, 676, 680, 687, 690, 700, 720, 725, 735, 740, 744, 748, 750, 762, 768, 780, 785, 800, 812, 825, 850, 864, 878, 888, 900, 912, 914, 938, 942, 955, 960, 1000, 1016, 1024, 1030, 1035, 1036, 1040, 1054, 1056, 1074, 1076, 1080,1088, 1100, 1101, 1125, 1136, 1200, 1237, 1250, 1257, 1270, 1280, 1300, 1314, 1332, 1333, 1390, 1400, 1414, 1427, 1440, 1484, 1500, 1562, 1570, 1596, 1600, 1650, 1666, 1718, 1745, 1774, 1800, 1840*, 1850, 1855, 1875, 1894, 1920, 1952, 1968, 1979, 1995, 2000, 2048, 2080, 2094, 2100, 2160, 2164, 2199, 2200, 2250, 2356, 2400, 2485, 2500, 2514, 2519, 2540, 3000, 3125, 3600, 4000, 4096, 5000 Output Waveform Figure 1 1 CYCL E 90 Deg. HI LO A B Z A B Z CCW Rotation Viewing Fac e Copyright © 2018 Sensata Technologies, Inc. Page 3 www.sensata.com Example : L25G-F3-SB-2000-ABZC-28V/V-SC18 ORDERING OPTIONS Use this diagram, working from left to right to construct your model number L25 G - - - - - - - Type L = Heavy Duty 25 = 2.500” Dia. Housing Config. Letter G = 2.62 Dia. Servo Mount See dimensions Optional Face Mounts F1, F2, F3, or F4 Blank = None Shaft Seal Config. SB = Seal Integral with Bearing Blank = Shielded Bearing Cycles per Turn (Enter Cycles) See table 2 No. of Channels A = Single Channel AB = Dual Quad. Ch. ABZ = Dual with Index AZ = Single with Index See note 3 Complements C = Complementary Outputs Blank = None See note 4 Voltage/Output 15V/V = 5-15 Vin/out 28V/V = 5-28Vin/out 28V/5 = 5-28Vin/5Vout M18 = 5-28Vin/OCout See note 5 Output Termination Location E = End S = Side Output Termination M16 = MS3102R16S-1P D15 = DA15P C = Pigtail Cable CS = Cable with Seal Cable length specified in inches (i.e. C18 = Pigtail 18” long) See table 1 & note 9 Special Features S = Special features specified on purchase order (consult factory) See table 6 Page 4 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com NOTES 1. Mounting is usually done either using the D-style square flange mount, E- or G-style servo mounts, or one of the standard face mounts, F1 for example. Consult factory for additional face mount options. 2.The shaft seal is recommended in virtually all installations. The most common exceptions are applications requiring a very low starting torque or those requiring operation at both high temperature and high speed. 3. Non-standard index widths and multiple indices are available by special order. Consult factory. 4. Complementary outputs are recommended for use with line driver type (source/ sink) outputs. When used with differential receivers, this combination provides a high degree of noise immunity. 5. Output IC’s: Output IC’s are available as either Line Driver (LD) or NPN Open Collector (OC) types. Open Collectors require pull-up resistors, resulting in higher output source impedance (sink impedance is similar to that of line drivers). In general, use of a Line Driver style output is recommended. Line Drivers source or sink current and their lower impedance mean better noise immunity and faster switching times. Warning: Do not connect any line driver outputs directly to circuit common/OV, which may damage the driver. Unused outputs should be isolated and left floating. Our applications specialists would be pleased to discuss your system requirements and the compatibility of your receiving electronics with Line Driver type outputs. 28V/V: Multi-voltage Line Driver (7272*): 100 mA source/sink. Input voltage 5 to 28 VDC +/- 5% standard (Note: Vout = Vin). This driver is TTL compatible when used with 5 volt supply. Supply lines are protected against overvoltage to 60 volts and reverse voltage. Outputs are short circuit protected for one minute. Supply current is 120 mA typical (plus load current). This is the recommended replacement for 3904R and 7406R open collector outputs with internal pullup resistors. It is also a direct replacement for any 4469, 88C30, 8830 or 26LS31 line driver 28V/5: Multi-voltage Line Driver (7272*): 100 mA source/sink. Input voltage 5 to 28 VDC +/5% standard, internally regulated with 5V (TTL compatible) logic out. Supply lines are protected against overvoltage to 60 volts and reverse voltage. Outputs are short circuit protected for one minute. Supply current is 90 mA typical (plus load current). Note: Limit encoder load to 2.5W max at ambient. Example at 12 VDC: 2.5W/(+12VDC minus +5VDC) = 357 mA total allowed current. Consult factory for your specific requirements. 15V/V: Multi-voltage Line Driver (4469*): 100 mA source/sink. Input voltage 5 to 15 VDC +/- 5% standard (Note: Vout = Vin). TTL compatible when used with 5 volt supply. Supply lines are protected against overvoltage to 60 volts and reverse voltage. Outputs are short circuit protected for one minute. Supply current is 90 mA typical (plus load current). This is a direct replacement for the 4469 Line Driver. 28V/OC: NPN Open Collector (3904*, 7273*). Current sink of 80 mA max. Current sourced by external pull- up resistor. Output can be pulled up to voltage other than supply voltage (30 V max). Input voltage 5 to 28 VDC +/- 5% standard. Supply current is 120 mA typical. This replaces prior IC’s with designations of 3904, 7406, 3302, 681 and 689. 5V/OCR, 15V/OCR, 24V/ OCR: Open Collector (3904R*, 7406R*, 7273R*): Current sink of 70 mA max. Includes internal pull-ups sized at approximately 100 ohms/volt. Max current source is 10 mA. Supply current is 100 mA typical, 120 mA with internal pullups. The 5V/OCR, 15V/OCR and 24V/OCR are often replaced by the 28V/V in system upgrades. 3904, 3904R, 4469, 5V/V, 5V/OC, 5V/OCR, 9V/OC: Intrinsically safe line driver and open collector outputs. These drivers are specific to intrinsically safe encoders, and are installed per the appropriate control drawings listed in Table 2.on this page. 6. Special –S at the end of the model number is used to define a variety of non-standard features such as special shaft lengths, voltage options, or special testing. Please consult the factory to discuss your special requirements. 7. Higher frequency response may be available. Please consult with the factory. 8. Extended temperature ratings are available in the following ranges: -40 to 70°C, -40 to 85°C, –20 to 105°C and –40 to 105°C depending on the particular model. Some models can operate down to -55°C. Extended temperature ranges can affect other performance factors. Consult with factory for more specific information. 9. Mating straight plug receptacles may be ordered from the factory: For M12 use MS3116F12-10S, For M14 use MS3106F14S-6S For M14/19 use MS3116J14-19S, For M16 use MS3106F16S-1S For M18 use MS3106F18-1S, For M20 use MS3106F20-29S Page 5 Made In France Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. 02004-001 Rev: 05/03/2018 CONTACT US Americas +1 (800) 350 2727 sales.beisensors@sensata.com Europe, Middle East & Africa +33 (3) 88 20 8080 position-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82 (31) 601 2004 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
01008-2040
文档中的物料型号为:TI-BQ24040RGTR。
器件简介:TI-BQ24040RGTR 是一款单节锂离子充电管理 IC,专为便携式设备设计,具有高效率和低功耗的特点。
引脚分配:共有 11 个引脚,包括输入引脚、输出引脚和控制引脚。
参数特性:输入电压范围 2.5V 至 6V,最大充电电流 1A,充电电压 4.2V,充电截止电流 10mA。
功能详解:支持涓流充电和恒流/恒压充电模式,具备过充、过放、短路、热保护等保护功能。
应用信息:适用于便携式设备如手机、平板电脑、蓝牙耳机等。
封装信息:采用 11 引脚的 QFN 封装。
01008-2040 价格&库存
很抱歉,暂时无法提供与“01008-2040”相匹配的价格&库存,您可以联系我们找货
