RE12
OPTICAL ENCODERS
■ FEATURES
RoHS compliant
Oφ 12 mm, High resolution up to 300 P/R
OCost effective
OTwo bearing types to choose from;
Sleeve bearing or ball bearing
OLow torque, low inertia
ORoHS compliant
■ PART NUMBER DESIGNATION
RE12 A – 100 – 100 – 1
Series name
Output connection
1:Cable wire
Bearing
A:Ball bearing
C:Sleeve bearing
Output phase “A”, Input voltage : 5 V, No AMP
Resolution (P/R)
100, 200, 300
■ LIST OF PART NUMBERS
Bearing
Ball Bearing
Sleeve Bearing
Resolution
Part number
100 P/R
RE12A-100-100-1
200 P/R
RE12A-200-100-1
300 P/R
RE12A-300-100-1
100 P/R
RE12C-100-100-1
200 P/R
RE12C-200-100-1
300 P/R
RE12C-300-100-1
※ Verify the above part numbers when placing orders.
RE12
OPTICAL ENCODERS
OMechanical characteristics
■ STANDARD SPECIFICATIONS
OELECTRICAL CHARACTERISTICS
Resolution
Item
s02
Photo-sensor maximum current
Starting
torque
02
50 mA maximum (at 25 °C)
Output wave form
0.05 mN·m {0.5 gf·cm} maximum
Sleeve bearing
0.4 mN·m {4 gf·cm} maximum
0.01 g·cm2 maximum
Inertia
Quasi-sinusoidal
Output signal
※1
150 mVp-p minimum
100 mVp-p minimum
Output signal
amplitude variation
※2
40 % maximum
50 % maximum
Light source
Ball bearing
Shaft
loading
Radial
1.96 N {200 gf} maximum
Axial
4.9 N {500 gf} maximum
Approx. 10 g
Net weight
OOutput signal level & Amplitude variation
LED
※1 : Measured at CP1 as per the Fig. A of ‘MEASUREMENT CIRCUIT’
on the following page. (3 kHz)
※2 : Measured at CP2 as per the Fig. A of ‘MEASUREMENT CIRCUIT’
OEnvironmental characteristics
Operating temp. range
−10 ~ 50 °C
Storage temp.range
−20 ~ 80 °C
S min S max
※Output signal level: 100, 200 P/R Smin ≧ 0.15 V,
Amplitude variation: 100, 200 P/R (Smax/Smin-1) × 100 ≦ 40 %
300 P/R
Protection grade
300 P/R Smin ≧ 0.10 V
IP40
(Smax/Smin-1) × 100 ≦ 50 %
■ RELIABILITY TEST
The output shall satisfy the criteria below after the following tests.
Test item
Test conditions
Vibration
Power OFF
Amplitude : 1.52 mm or 98.1 m/s2 (10 G) whichever is smaller.
10 ~ 500 Hz excursion 5 min/cycle, 1 hour each for X, Y, Z, directions.
Shock
Power OFF
1 time each in 6 directions (X, Y, Z) at 490 m/s2 (50 G), 11 ms.
Power OFF
80 °C 96 h
Power ON
50 °C 96 h
Power OFF
− 20 °C 96 h
Power ON
− 10 °C 96 h
Humidity
Power OFF
40 °C Relative humidity 90 ∼ 95 % 96 h
(To be measured after wiping out moisture and leaving samples for 1 h at normal temperature and humidity after the test.)
Thermal shock
Power OFF
To be done 10 cycles with the following condition
(To be measured after leaving samples for 1 h at normal temperature and humidity after the test.)
High temperature
exposure
Low temperature
exposure
80 °C 1 h、− 20 °C 1 h
OCriteria
s02
300 P/R
Measurement point
Output signal level
S min ≧ 0.13 V
S min ≧ 0.08 V
CP1 in ‘MEASUREMENT CIRCUIT’
Amplitude variation
(S max / S min – 1) × 100 ≦ 45 %
(S max / S min – 1) × 100 ≦ 55 %
CP2 in ‘MEASUREMENT CIRCUIT’
RE12
OPTICAL ENCODERS
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.4 (Unit : mm)
100 +200
4.8 2.4
AWG28
φ2
8.5±0.2
–0.01
φ 12
2 – M2 D = 3.0 min.
■ INTERNAL CIRCUIT
Anode
(Green)
6
12
■ MEASUREMENT CIRCUIT
Colletor
(Red)
Fig. A
+5 V
Cathode
(Black)
Emitter
(White)
180 Ω
33 kΩ
3 kΩ
CP1
0.033 μF
33 kΩ
0.1 μF
CP2
AMP
10 kΩ
0V
+2.5 V
Frequency characteristics : 3 kHz (at constant speed)
很抱歉,暂时无法提供与“RE12C-300-100-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+205.144971+26.67450
