ACW400-12BT-010
ACW400-12BT-010
    SENSATA(森萨塔)
    ACW4 - MAG. SINGLETURN, MODULAR,
ACW400-12BT-010 数据手册
| ACW4 IO-LINK IO-LINK ABSOLUTE SINGLE-TURN MODULAR SENSOR Introduction The ACW4 version provides a compact versatile single-turn absolute position indication. The two-part construction keeps the profile low, delivering a high degree of flexibility for tight installations. By using the IO-Link protocol, integration and set-up of sensors is greatly simplified, supporting the move to factory 4.0 and IIOT initiatives. The ACW4 IO-Link is sealed to IP65 making it suitable for even the harshest industrial environments. Features •  With its two-part design, the ACW4 IO-Link absolute single-turn position sensor offers maximum flexibility during installation •  IO-Link with COM3 transmission rate •  Easy commissioning and configuration with IO-Link •  Simple device replacement with Data Storage capability •  Universal power supply through IO-Link Master •  Robust and excellent resistance to shock and vibration •  Robust magnetic technology •  Standard IP65 protection (IP69K option) •  Extended operating temperature range from -40°C to 85°C •  Resolution : programmable 12 bits per turn •  Standard M12 connector Applications •  Factory Automation •  Process Automation SPECIFICATIONS Mechanical Terminations PUR cable with M12 5 pin connector Housing Technomelt PA638 black Weight 0,150 kg Electrical Electrical Angle 360° Output Function IO-Link V1.1, COM3 (230,4 kBaud) Minimal Cycle Time 1ms Resolution single-turn: 12 bits Accuracy +/-0.3% on 360° Repeatability +/-0.1% on 360° Supply Voltage 18 to 30 Vdc Current Requirements
ACW400-12BT-010 价格&库存
很抱歉,暂时无法提供与“ACW400-12BT-010”相匹配的价格&库存,您可以联系我们找货
