LS9100X-S
LS9100X-S
    LSI/CSI
    ESOP-8
    IC LED DRV AC/DC TRIAC 50MA 8SOP
LS9100X-S 数据手册
LS9100 Dimmable High Voltage LED Archimedes Series Direct AC Driver Features • • • • • • • • • Integrated Bridge Rectifier and MOSFET Driver Wide AC input range up to 310 Vac 50/60Hz 50mA DC output current Ultra simple circuit solution. Requires Only One R passive component Thermal Turndown Protections Voltage Shutdown Protections Thermal Enhanced SOP-8 and Heat Sink PAD package TRIAC Dimmable (Leading/Trailing Edge) Programmable LED Current with an external sense resistor Applications • • • • L1 1 8 L2 RS0 2 7 HS RS1 3 6 LS1 RS2 4 5 LS0 LED Driver Current Source limiter General Illumination Commercial and Industrial Lighting Description The LS9100 is a High Voltage full-bridge rectifier combined with a current limiter source circuit and protection circuit. Its rugged design is optimized for driving LED banks directly from the main utility line eliminating external components by merging them into a monolithic package, drastically reducing the board space and cost. The thermal turndown located in the center of the IC protects itself from operating in atypical conditions. The voltage shutdown protection circuit safeguards the IC and the system’s LEDs from voltage surges that can overstress the system. Ordering Information Part Number Description LS9100X-S LS9100X-STR SOP-8: Tape and Reel (1000/Reel) LS9100-170306-A-1 © 2016 LSI Computer Systems, Inc. PIN Configuration L1 1 8 L2 RS0 2 7 HS RS1 3 6 LS1 RS2 4 5 LS0 Top View PIN # Name Description 1 L1 Input 1 AC 2 RS0 Current sense resistor input 0 3 RS1 Current sense resistor input 1 4 RS2 Current sense resistor input 2 5 LS0 Low Side input 0 6 LS1 Low Side input 1 7 HS High side output 8 L2 Input 2 AC PAD xPAD Current sense resistor input 0 Block Diagram HS 7 LS0 5 High Voltage Protection Ckt L1 1 Current Control Ckt Bridge Rectifier Ckt L2 8 LS9100 LS9100-170306-2 LS1 6 Thermal Turndown Ckt RS0 2 RS1 3 RS2 4 Maximum Rating And Electrical Characteristics Rating at 25°C ambient temperature unless otherwise specified (Note). Parameter Symbol Min Typ Max Unit Repetitive peak reverse voltage (Input L1-L2) Vrrm 500 V DC Blocking voltage (Input L1-L2) Vdc 500 V RMS Voltage (Input L1-L2) Vrms 310 V Instantaneous forward voltage (L1-2/HV) Vf Average forward current (L1-2/HV) Iav 50 mA Peak Forward surge current (Note 2) Ifsm 80 mA DC reverse current @TA=25°C @TA=100°C Ir .5 1.00 uA Low Side peak voltage (Input LS0-1) Vls 100 350 V 130 145 V 50 140 mA Low Side Voltage Shutdown Protection (Input LS0-1) Vshdw 0.75 115 Total Low Side Current (Input LS0-1) V Package Power Dissipation (Note 3) PDpkd 2500 mW Typical Thermal resistance (Note 3) Rɵja 45 °C/W Typical Junction capacitance (PIN 1,8) Cj Operating Junction Temperature Tj Current Thermal turndown Itdw Storage temperature Tstrg Junction Temperature Lead Temperature (10 second soldering) 45 -40 pF +125 -0.32 -55 %A/°C +125 °C Tjmax +150 °C Tsld +300 °C Notes: 1. Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. 2. 1msec half sine wave superimposed on rated load 3. Power dissipated from junction to lead PCB mounted on suggested PAD Layout. Derate 20mW/°C when the ambient temperature is above 25 °C. Special care of the thermal dissipation in the PCB design must be taken. 4. ESD protection. HBM : 1kV at all Pins. LS9100-170306-3 °C Electrostatic Discharge Sensitivity This integrated circuit can be damaged by ESD. LSI/CSI recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. 7 6 5 HS LS1 LS0 RS0 RS1 RS2 2 3 4 L 8 N L2 Surge Protection CKT L1 110VAC 60HZ 1 Typical Application Rsns DANGER!: THE READER IS WARNED THAT CAUTION MUST BE USED IN THE CONSTRUCTION, TESTING AND USE OF THIS CIRCUIT. LETHAL HIGH VOLTAGE POTENTIALS ARE PRESENT IN THIS CIRCUIT. EXTREME CAUTION MUST BE USED IN WORKING WITH, AND MAKING CONNECTIONS TO, THIS CIRCUIT. USE CAUTION. LS9100-170306-4 Typical Characteristics At Tamb = + 25, unless otherwise noted. Output Current (Icsns) vs. External Resistor (Rcsns) Tj,+125°C Tj,+85°C 100 Tj,+25°C Tj, 0°C Rcsns (Ω) Tj,-40°C 10 1 1 10 100 Icsns (mA) Total Power Dissipation (mW) vs. Ambient Temperature (Ta) 3000 Power Dissipation (mW) 2500 2000 1500 1000 500 0 0 20 40 60 Ambient Temperature (°C) LS9100-170306-5 80 100 120 Package Information 8-Lead SOP Exposed Pad Plastic Package Notes: A. All linear dimension are in inches. B. The thermal pad is design to be solder on the PCB. C. This drawing is subject to change without notice. LS9100-170306-6 Package Mounting The figure below provides the minimum recommended PCB layout for the LS9100 device. For lowest overall thermal resistance, it is best to solder the heat sink Pad directly to the circuit board. Adding more area to the heat sink improves heat dissipation. 0.05 0.600 Solder mask over copper 0.112 Top Side 0.096 0.05 0.05 0.600 0.022 10x 0.012 Via Plated holes 0.132 Bottom Side 0.600 Notes: A. All linear dimension are in inches (not to scale). B. This drawing is subject to change without notice. C. This package mounting is a guideline example and does not cover all applications. D. Conformal Coating material must be applied to act as protection against moisture and harsh environments. LS9100-170306-7 IMPORTANT NOTICE The information included herein is believed to be accurate and reliable. However, LSI Computer Systems, Inc. assumes no responsibilities for inaccuracies, nor for any infringements of patent rights of others which may result from its use. LSI Computer Systems reserves the right to change circuitry and specifications at any time without notification to the customer. LSI Computer Systems assumes no liability for applications assistance or the design of Buyers’ products. Buyers are the only responsible for their products and applications using LSI Computer Systems components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. LS9100-170306-8
LS9100X-S 价格&库存
很抱歉,暂时无法提供与“LS9100X-S”相匹配的价格&库存,您可以联系我们找货
