IS31FL3801-QFLS3-TR
IS31FL3801-QFLS3-TR
    LUMISSIL
    WFQFN60
    IC 16X8/15X9 W/ 11 TOUCH KEY I2C
IS31FL3801-QFLS3-TR 数据手册
IS31FL3801 Smart Integrated Matrix LED Driver with Touch Key Controller GENERAL DESCRIPTION FEATURES The IS31FL3801 is a general purpose 16×8 or 15×9 LED Matrix programmed via 1MHz I2C compatible interface. Each LED can be dimmed individually with 8-bit PWM data, and each CSx has 8-bit DC scaling (Color Calibration) data which allowing 256 steps of linear PWM dimming for each dot and 256 steps of DC current adjustable level for each CSx.  Matrix LED Driver  Supply voltage range: 2.7V to 5.5V  16 current sinks  Support 16×n (n=1~8), 15×9 LED matrix configurations  Individual 256 PWM control steps  256 DC current steps for each CSx  64 global current steps  SDB rising edge reset I2C module  32kHz PWM frequency  1MHz I2C-compatible interface  Individual open and short error detect function  PWM 180 degree phase shift  Spread spectrum  De-ghost  Capacitive Touch Sensor  Capacitive touch controller with readable key value through shared GPIO  Individual sensitivity threshold setting for each touch key  Optional multiple-key function  Press and hold function  Automatic calibration  Individual key calibration  Interrupt output with auto-clear and repeating  Auto sleep mode for extremely low power  Key wake up from sleep mode  400kHz fast-mode I²C interface  Provides Spread  Operating temperature between -40°C ~ +105°C  QFN-60 package Additionally each LED open and short state can be detected, IS31FL3801 store the open or short information in Open-Short Registers. The Open-Short Registers allowing MCU to read out via I2C compatible interface. Inform MCU whether there are LEDs open or short and the locations of open or short LEDs. An eleven-channel capacitive touch controller is integrated with on-chip calibration logic which continuously monitors the environment and automatically adjusts the threshold levels to prevent false triggers. An on-chip I²C slave controller with 400kHz capability and programmable slave addresses serves as the communication port for the host MCU. An interrupt, INTB, can be configured so it is generated when a trigger event (touched or released) occurs. Trigger or clear condition can be configured by setting the interrupt register. IS31FL3801 is available in RoHS compliant package QFN-60 (7mm×7mm). It operates from 2.7V to 5.5V over the temperature range of -40°C to +105°C. APPLICATIONS     Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 Home appliance touch control keys Industrial applications Gaming devices IoT devices 1 IS31FL3801 BLOCK DIAGRAM Block Diagram of IS31FL3801 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 2 IS31FL3801 PACKAGE TYPE Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 3 IS31FL3801 PIN CONFIGURATION No. Pin Description 23 ISET An external resistor to ground is required for setting the LED current 1-3, 5-8, 52, 54-60 CS1-CS15 Current sinks for LED matrix 4, 14, 21, 22, 26, 33, 34, 41, 44-47, 53 VSS Ground connection 19, 20, 24, 49 VDD 25 INTB Power supply. Typical decoupling capacitors of 0.1uF and 10uF should be connected between VDD and VSS Interrupt output, active low. 27 AD I2C address setting. 28-32,37-40,42-43 KEY0-KEY10 Input sense channel 0 -10 35 SDA I2C data, need to pull up with 4.7K resistor 36 SCL 48 VDDC 50 RSTN 51 CREF I2C clock, need to pull up with 4.7K resistor Internal regulator output around 1.8V. Typical decoupling capacitors of 0.1uF and 10uF should be connected between VDDC and VSS Low active. A resistor to VDD and a capacitor to VSS are typically connected. RSTN is pulled low when LVR occurs. The threshold of RSTN is set at 0.3VDD. RSTN is also used for special test mode and writer mode entry. External capacitor must be connected for touch key controller. 10-13, 15-18 SW8-SW1 Power SW. 9 CS16/SW9 Current sinks for LED matrix CS16 or power switch SW9 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 4 IS31FL3801 ORDERING INFORMATION Industrial Range: -40°C to +105°C Order Part No. Package QTY IS31FL3801-QFLS3-TR QFN-60, Lead-free 2500 Copyright © 2020 Lumissil Microsystems. All rights reserved. Lumissil Microsystems reserves the right to make changes to this specification and its products at any time without notice. Lumissil Microsystems assumes no liability arising out of the application or use of any information, products or services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and before placing orders for products. Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that: a.) the risk of injury or damage has been minimized; b.) the user assume all such risks; and c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 5 IS31FL3801 TYPICAL APPLICATION CIRCUIT (QFN-60) Figure 1 Typical Application Circuit (QFN-60) Note 1: The chip should be placed far away from the noise points in order to prevent the EMI. Note 2: The RS and CS should place as close to the chip as possible to reduce EMI. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 6 IS31FL3801 1. DETAILED DESCRIPTION 1.1 IS31FL3801 GUI IS31FL3801 GUI is a windows-based Integrated Design Environment (IDE). User can use it to develop touch key applications without firmware coding. With the GUI user can design the touch key system easily. With the GUI you can: 1. Monitor the Key value 2. Set touch threshold and enable keys 3. Switch the operating modes 4. Tune System parameters 5. Touch Key and GPIO Configuration 6. Matrix LED demo 7. Set Slider Electrodes Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 7 IS31FL3801 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 8 IS31FL3801 Please refer to the User’s Guide for other details. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 9 IS31FL3801 ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC (for LED driving) -0.3V ~ +6.0V Supply voltage, VDD +5.5V Voltage at any input pin -0.3V ~ VCC+0.3V Maximum junction temperature, TJMAX +150°C Storage temperature range, TSTG -65°C ~ +150°C Operating temperature range, TA=TJ -40°C ~ +105°C Junction Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA 35°C/W ESD (HBM) ±2kV ESD (CDM) ±750V Note 4: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 1.2 ELECTRICAL CHARACTERISTICS TA = 25°C, VDD = 2.7V ~ 5.5V, unless otherwise noted. Typical value are T A = 25°C, VDD = 5V. Symbol Parameter Condition Min. Typ. 2.7 Max. Unit 5.5 V VDD Supply voltage IOUT Maximum constant current of CSy RISET =10kΩ, GCC=0xFF SL=0xFF 34.5 mA IDD, stop Quiescent power supply current VDD = 5.5V 2.5 mA mA Electrical Characteristics (LED Driver) Average current on each LED ILED = IOUT(PEAK)/Duty(4.14) RISET =10kΩ, GCC=0xFF SL=0xFF 4.22 Current switch headroom voltage SWx ISWITCH=612mA RISET =10kΩ, GCC=0xFF, SL=0xFF 450 Current sink headroom voltage CSy ISINK=34mA, RISET =10kΩ, GCC=0xFF, SL=0xFF 250 tSCAN Period of scanning (Note 5) 33 µs tNOL1 Non-overlap blanking time during scan, the SWx and CSy are all off during this time 0.83 µs tNOL2 Delay total time for CS1 to CS 18, during this time, the SWx is on but CSy is not all turned on 0.3 µs ILED VHR (Note 6) mV Electrical Characteristics (Touch Key) ∆CS Normal detectable capacitance 40 pF tscan, TK Period of scanning for 11 Touch Key channels 55 mS Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 10 IS31FL3801 1.3 I2C SWITCHING CHARACTERISTICS Symbol fSCL tBUF tHD, STA tSU, STA tSU, STO tHD, DAT tSU, DAT tLOW tHIGH tR tF IOL Parameter Serial-Clock frequency Bus free time between a STOP and a START condition Hold time (repeated) START condition Repeated START condition setup time STOP condition setup time Data hold time Data setup time SCL clock low period SCL clock high period Rise time of both SDA and SCL signals, receiving Fall time of both SDA and SCL signals, receiving Low level sink current Condition Min. Typ. Max. Unit 400 kHz 1.3 μs 0.6 μs 0.6 μs 0.6 0.9 100 1.3 0.7 (Note 7) (Note 7) 20+0. 1Cb 20+0. 1Cb 10 μs μs ns μs μs 300 ns 300 Ns mA VIH Logic “0” input voltage VDD = 5.5V 1.4 V VIL Logic “0” input voltage VDD = 2.7V 0.4 V Note 5: The period of SWx is turned on. Note 6: Guaranteed by design. Note 7: Cb = total capacitance of one bus line in pF. ISINK ≤ 6mA. tR and tF measured between 0.3 × VDD and 0.7 × VDD. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 11 IS31FL3801 1.4 I2C INTERFACE IS31FL3801 uses a serial bus, which conforms to the I2C protocol, to control the chip’s functions with two wires: SCL and SDA. IS31FL3801 has a 7-bit slave address (A7:A1), followed by the R/W bit, A0. Set A0 to “0” for a write command and set A0 to “1” for a read command. The value of bits A1 and A2 are determined by the connection of the AD pin, to GND, 1/3 VDD, 2/3VDD, and VDD. The complete slave address is: Bit A7:A3 A2:A1 A0 Value 01101 AD 1/0 AD connected to GND, AD = 00; AD connected to 1/3VDD, AD = 01; AD connected to 2/3VDD = 10; AD connected to VDD = 11; AD pin can also be configured as a Touch Key channel. When then AD pin is used for a Touch Key channel, A2: A1 = 00. The SCL and SDA are open-drain IO so an external pull-up resistor (typically 4.7kΩ) is required. The maximum clock frequency specified by the I2C standard is 400kHz. In this discussion, the master is the host microcontroller and the slave is IS31FL3801. The timing diagram for the I2C is shown in Figure 2. When there is no interface activity, both the SDA and SCL should be held high. The “START” signal is generated by lowering the SDA signal while the SCL signal is high. The start signal will alert all devices attached to the I2C bus to check the incoming address against their own chip address. The 8-bit chip address is sent next, most significant bit first. Each address bit must be stable while the SCL level is high. After the last bit of the chip address is sent, the master checks for IS31FL3801’s acknowledge. The master releases the SDA line which gets pulled to high (through a pull-up resistor). Then the master sends an SCL pulse. If IS31FL3801 has received the address correctly, it holds the SDA line low during the SCL pulse. If the SDA line is not low, the master should send a “STOP” signal (discussed later) and abort the transfer. Following acknowledge of IS31FL3801, the header byte is sent, most significant bit first. IS31FL3801 must generate another acknowledge indicating that the header has been received. Following acknowledge of IS31FL3801, the commands or register address byte is sent, most significant bit first. IS31FL3801 must generate another acknowledge indicating that the register address has been received. Then 8-bit of data byte are sent next, most significant bit first. Each data bit should be valid while the SCL level is stable high. After the data byte is sent, IS31FL3801 must generate another acknowledge to indicate that the data was received. The “STOP” signal ends the transfer. To signal “STOP”, the SDA signal goes high while the SCL signal is high. SDA tSU,DAT tLOW SCL tHD,DAT S tHIGH tSU,STA tHD,STA R tSU,STO tBUF P tHD,STA tR tF Start Condition Restart Condition Stop Condition Start Condition Figure 2 Interface Timing 1.5 READING PORT REGISTERS ____ To read the device data, the bus master must first send to IS31FL3801’s address with the R/ W bit set to “0”, followed by the header byte. The address of the register of interest is then specified. And then the bus master must then send ____ to IS31FL3801’s address with the R/W bit set to “1”. Data from the register defined by the command byte is then sent from IS31FL3801 to the master. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 12 IS31FL3801 1.6 I2C Command Format In the I2C bus, some devices are masters, and they have to generate the bus clock and initiate communication. To select the IS31FL3801 device, they must choose the right slave address and follow it by a header. If the header is 55h, the commands and data that follows are for the matrix LED driver. If the header is AAh, the commands and data that follows are for the Touch Key controller. If the header is A5h, IS31FL3801 will immediately save the current data in the registers. Saved data will become the default value of IS31FL3801. First byte Second byte Slave address Header 55h Bit Value Other bytes Ending Matrix LED Commands and data Stop signal A7:A3 A2:A1 A0 01101 AD SCL High 1/0 SDA Rising edge AAh Touch Key Commands and data Stop signal A5h A special header is no following bytes. It is used for saving parameters Stop signal Two examples for the I2C Command are as follows: The waveforms of Touch Key Commands for Write data. The waveforms of Touch Key Commands for Read data. 1.7 Matrix LED Operation Register Definition Address Name Function Table R/W Default 01h~8Fh PWM Register Set PWM value for LED 6 W 0000 0000 90h~9Fh Scaling Register Control the DC output current of each CSy 7 W 0000 0000 A0h Configuration Register Configure the operation mode 8 W 0000 0000 A1h Global Current Control Register Set the global current 9 W 0000 0000 B0h Pull Down/Up Resistor Selection Register Set the pull down resistor for SWx and pull up resistor for CSy 10 W 0011 0011 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 13 IS31FL3801 B1h Spread Spectrum Register Spread spectrum function enable 11 W 0000 0000 B2h PWM Frequency Register Set the PWM frequency 12 W 0000 0001 Open/Short Register Store the open or short information 13 W 0000 0000 Reset Register Reset all register to POR state - W 0000 0000 B3h~C4h CFh PWM Register PWM Register 16x8 PWM Register 15x9 Figure 3 PWM Register Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 14 IS31FL3801 01h ~ 8Fh PWM Register Bit D7:D0 Name Default PWM 0000 0000 Each dot has a byte to modulate the PWM duty in 256 steps. The value of the PWM Registers decides the average current of each LED noted ILED. ILED computed by Formula (1): I LED  PWM  I OUT ( PEAK )  Duty (1) 256 Where Duty is the duty cycle of SWx, Duty  30s 1 1   30s  0.8s  0.27 s  9 9.32 (2) IOUT is the output current of CSy (y=1~16), I OUT ( PEAK )  342 GCC SL   RISET 64 256 (3) GCC is the Global Current Control Register (A1h) value, SL is the Scaling Register value as below and RISET is the external resistor of ISET pin. D[n] stands for the individual bit value, 1 or 0, in location n. For example: if D7:D0=1011 0101 (0xB5, 181), GCC= 100 0000, RISET=10kΩ, SL=1111 1111: I LED  342 64 255 1 181     10k 64 256 9.32 256 Scaling Register Figure 4 Scaling Register Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 15 IS31FL3801 90h ~ 9Fh Scaling Register Bit D7:D0 Name SL Default 0000 0000 Scaling register control the DC output current of each dot. Each dot has a byte to modulate the scaling in 256 steps. The value of the Scaling Register decides the peak current of each LED noted I OUT(PEAK). IOUT(PEAK) computed by Formula (3). A0h Configuration Register Bit D7:D4 D3 D2:D1 D0 Name SWS LGC OSDE SSD Default 0001 0 00 0 The Configuration Register sets operating mode of IS31FL3801. SSD 0 1 Software Shutdown Control Software shutdown Normal operation OSDE Open Short Detection Enable 00 Disable open/short detection 01/11 Enable open detection 10 Enable short detection LGC 0 1 H/L logic 1.4V/0.4V 2.4V/0.6V SWS 0000 0001 0010 0011 0100 0101 0110 0111 1000 Others SWx Setting n=9, SW1~SW9, 9SW×15CS matrix n=8, SW1~SW8, 8SW×16CS matrix n=7, SW1~SW7, 7SW×16CS matrix, SW8 no-active n=6, SW1~SW6, 6SW×16CS matrix, SW7~SW8 no-active n=5, SW1~SW5, 5SW×16CS matrix, SW6~SW8 no-active n=4, SW1~SW4, 4SW×16CS matrix, SW5~SW8 no-active n=3, SW1~SW3, 3SW×16CS matrix, SW4~SW8 no-active n=2, SW1~SW2, 2SW×16CS matrix, SW3~SW8 no-active SW1~SW9 with same phase, all on. SW1~SW9, SW1~SW9, 9SW×15CS matrix When OSDE set to “01”, open detection will be trigger once, the user could trigger open detection again by set OSDE from “00” to “01”. When OSDE set “10”, short detection will be trigger once, the user could trigger short detection again by set OSDE from “00” to “10”. When SSD is “0”, IS31FL3801 works in software shutdown mode and to normal operate the SSD bit should set to “1”. SWS control the duty cycle of the SWx, default mode is 1/8. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 16 IS31FL3801 A1h Global Current Control Register Bit D7 D6:D0 Name - GCC Default 0 000 0000 The Global Current Control Register modulates all CSy (y=1~16) DC current which is noted as IOUT in 65 steps, maximum GCC is “100 0000’, if GCC> “1000000”, GCC= “100 0000”. IOUT is computed by the Formula (3): I OUT ( PEAK )  342 GCC SL   RISET 64 256 7 GCC   D[n]  2 n n 0 Where D[n] stands for the individual bit value, 1 or 0, in location n. B0h Pull Down/Up Resistor Selection Register Bit D7 D6:D4 D3 D2:D0 Name PHC SWPDR - CSPUR Default 0 011 0 011 Set pull down resistor for SWx and pull up resistor for CSy. PHC 0 1 Phase choice 0 degree phase delay 180 degree phase delay SWPDR 000 001 010 011 100 101 110 111 SWx Pull down Resistor Selection Bit No pull down resistor 0.5kΩ only in SWx off time 1.0kΩ only in SWx off time 2.0kΩ only in SWx off time 1.0kΩ all the time 2.0kΩ all the time 4.0kΩ all the time 8.0kΩ all the time CSPUR CSy Pull up Resistor Selection Bit 000 No pull up resistor 001 0.5kΩ only in CSx off time 010 1.0kΩ only in CSx off time 011 2.0kΩ only in CSx off time 100 1.0kΩ all the time 101 2.0kΩ all the time 110 4.0kΩ all the time 111 8.0kΩ all the time Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 17 IS31FL3801 B1h Spread Spectrum Register Bit D7:D6 D4 D3:D2 D1:D0 Name - SSP RNG CLT Default 00 0 00 00 When SSP enable, the spread spectrum function will be enabled and the RNG & CLT bits will adjust the range and cycle time of spread spectrum function. SSP 0 1 Spread spectrum function enable Disable Enable RNG 00 01 10 11 CLT 00 01 10 11 Spread spectrum range ±5% ±15% ±24% ±34% Spread spectrum cycle time 1980μs 1200μs 820μs 660μs B2h PWM Frequency Bit D7:D3 D2:D0 Name - PWMF Default 00000 001 Set the PWM frequency, default is 32 kHz. In order to avoid LED display flicker, it is recommended PWM frequency ÷ n is higher than 100Hz, so when PWM frequency is 0.5 kHz, n cannot be more than 4, when PWM frequency is 0.25 kHz, n cannot be more than 2. PWMF 000 001 010 011 100 101 110 111 PWM frequency setting 55kHz 32kHz 4kHz 2kHz 1kHz 0.5kHz, (n≤4) 0.25KHz, (n≤2) 80kHz Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 18 IS31FL3801 B3h~C4h Open/Short Register (Read Only) Bit D7:D0 Name CS16:CS09, CS08:CS01 Default 0000 0000 When OSDE (A0h) is set to “01”, open detection will be trigger once, and the open information will be stored at B3h~C4h. When OSDE (A0h) set to “10”, short detection will be trigger once, and the short information will be stored at B3h~C4h. Before set OSDE, the GCC should set to 0x01. Figure 5 Open/Short Register CFh Reset Register Once user writes the Reset Register with 0xAE, IS31FL3801 will reset all the IS31FL3801 registers to their default value. On initial power-up, the IS31FL3801 registers are reset to their default values for a blank display. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 19 IS31FL3801 APPLICATION INFORMATION Scanning cycle T=62.14µs((30µs+0.8µs+0.27µs)×2) (n=2) Scanning cycle T=248.56µs((30µs+0.8µs+0.27µs)×8) (n=8) SW1 SW2 SW3 SW4 SW5 SW6 SW7 SW8 SW9 CS16 CS1 tNOL2=0.27µs tSCAN=30µs tNOL1=0.8µs Scanning cycle T=279.63µs((30µs+0.8µs+0.27µs)×9) (n=9) De-Ghost time PWM Duty is variable from 0/256~255/256 I OUT  342 GCC SL   RISET 256 256 SCANNING TIMING As shown in Figure above, the SW1~SW9 is turned on by serial, LED is driven 15 by 9 within the SWx (x=1~9) on time (SWx, x=1~9 is source and it is high when LED on) , including the non-overlap blanking time during scan, the duty cycle of SWx (active high, x=1~9) is (n=9): Duty  30s 1 1   30s  0.8s  0.27 s  9 9.32 used the formula (2) Duty  30s 1 1   30s  0.8s  0.27 s  8 8.29 used the formula (2) Or (n=8): Where 30μs is tSCAN, the period of scanning and 0.8μs is tNOL1, the non-overlap time and 0.27μs is the CSx delay time. PWM CONTROL After setting the IOUT and GCC, the brightness of each LEDs (LED average current (I LED)) can be modulated with 256 steps by PWM Register, as described in Formula (1). I LED  PWM  I OUT ( PEAK )  Duty (1) 256 Where PWM is PWM Registers’ (01h~8Fh) data showing in PWM registers. For example, in Figure 1, if RISET= 10kΩ, PWM= 1011 0101 (0xB5, 181), and GCC= 100 0000, SL= 1111 1111, then, I OUT ( PEAK )  342 GCC SL 342 64 255 1 181   (n=9) I LED      RISET 64 256 10k 64 256 9.32 256 Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 20 IS31FL3801 GAMMA CORRECTION In order to perform a better visual LED breathing effect we recommend using a gamma corrected PWM value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Since the IS31FL3801 can modulate the brightness of the LEDs with 256 steps, a gamma correction function can be applied when computing each subsequent LED intensity setting such that the changes in brightness matches the human eye's brightness curve. 32 Gamma Steps with 256 PWM Steps C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 4 6 10 13 18 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 22 28 33 39 46 53 61 69 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 78 86 96 106 116 126 138 149 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 161 173 186 199 212 226 240 255 256 224 PWM Data 192 160 128 96 64 32 0 0 4 8 12 16 20 24 28 32 Intensity Steps Figure 6 Gamma Correction (32 Steps) Choosing more gamma steps provides for a more continuous looking breathing effect. This is useful for very long breathing cycles. The recommended configuration is defined by the breath cycle T. When T=1s, choose 32 gamma steps, when T=2s, choose 64 gamma steps. The user must decide the final number of gamma steps not only by the LED itself, but also based on the visual performance of the finished product. 64 Gamma Steps with 256 PWM Steps C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 1 2 3 4 5 6 7 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 8 10 12 14 16 18 20 22 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 24 26 29 32 35 38 41 44 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 47 50 53 57 61 65 69 73 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 77 81 85 89 94 99 104 109 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 21 IS31FL3801 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 114 119 124 129 134 140 146 152 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 158 164 170 176 182 188 195 202 C(56) C(57) C(58) C(59) C(60) C(61) C(62) C(63) 209 216 223 230 237 244 251 255 256 224 PWM Data 192 160 128 96 64 32 0 0 8 16 24 32 40 48 56 64 Intensity Steps Figure 7 Gamma Correction (64 Steps) Note: The data of 32 gamma steps is the standard value and the data of 64 gamma steps is the recommended value. OPERATING MODE IS31FL3801 can only operate in PWM Mode. The brightness of each LED can be modulated with 256 steps by PWM registers. For example, if the data in PWM Register is “0000 0100”, then the PWM is the fourth step. Writing new data continuously to the registers can modulate the brightness of the LEDs to achieve a breathing effect. OPEN/SHORT DETECT FUNCTION IS31FL3801 has open and short detect bit for each LED. By setting the OSDE bits of the Configuration Register (A0h) from “00” to “01” or “10”, the LED Open/short Register will start to store the open/short information and after at least 2 scanning cycles and the MCU can get the open/short information by reading the B3h~C4h, the open/short data will not get refreshed when setting the OSDE bit of the Configuration Register. The two configurations need to set before setting the OSDE bits: 1 . 0x0F≤GCC≤0x40, B0h=0x00 2 . 0x01≤GCC≤0x40, B0h=0x30 Where GCC is the Global Current Control Register (A1h) and both case 1 or two can get the correct open and short information. B0h is the Pull Down/UP Resistor Selection Register and 0x30 is to enable the SWx pull-up function. The detect action is one-off event and each time before reading out the open/short information, the OSDE bit of the Configuration Register (A0h) need to be set from “0” to “1” (clear before set operation). DE-GHOST FUNCTION The “ghost” term is used to describe the behavior of an LED that should be OFF but instead glows dimly when another LED is turned ON. A ghosting effect typically can occur when multiplexing LEDs. In matrix architecture any parasitic capacitance found in the constant-current outputs or the PCB traces to the LEDs may provide sufficient current to dimly light an LED to create a ghosting effect. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 22 IS31FL3801 To prevent this LED ghost effect, the IS31FL3801 has integrated Pull down resistors for each SWx (x=1~9) and Pull up resistors for each CSy (y=1~16). Select the right SWx Pull down resistor (B0h) and CSy Pull up resistor (B0h) which eliminates the ghost LED for a particular matrix layout configuration. Typically, selecting the 2kΩ will be sufficient to eliminate the LED ghost phenomenon. The SWx Pull down resistors and CSy Pull up resistors are active only when the CSy/SWx output working the OFF state and therefore no power is lost through these resistors. SHUTDOWN MODE Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Software Shutdown By setting SSD bit of the Configuration Register (A0h) to “0”, the IS31FL3801 will operate in software shutdown mode. When the IS31FL3801 is in software shutdown, all current sources are switched off, so that the matrix is blanked. All registers can be operated. Typical current consume is 3μA. Hardware Shutdown The chip enters hardware shutdown when the SDB pin is pulled low. All analog circuits are disabled during hardware shutdown, typical the current consume is 3μA. The chip releases hardware shutdown when the SDB pin is pulled high. During hardware shutdown state Function Register can be operated. If VCC has risk drop below 1.75V but above 0.1V during SDB pulled low, please re-initialize all Function Registers before SDB pulled high. LAYOUT As described in external resistor (RISET), the chip consumes lots of power. Please consider below factors when layout the PCB. 1. The VCC capacitors need to close to the chip and the ground side should well connected to the GND of the chip. 2. RISET should be close to the chip and the ground side should well connect to the GND of the chip. 3. The thermal pad should connect to ground pins and the PCB should have the thermal pad too, usually this pad should have 9 or 16 via thru the PCB to other side’s ground area to help radiate the heat. About the thermal pad size, please refer to the land pattern of each package. 4. The CSy pins maximum current is 35mA (RISET=10kΩ), and the SWx pins maximum current is larger, the width of the trace, SWx should have wider trace then CSy. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 23 IS31FL3801 1.8 Touch Key Operation Register Function Address Name Function Controls general power states and power dissipation 00h Main Control Register 01h INT Configuration Register Interrupt configuration 02h 03h Key Status Register 1 Key Status Register 2 04h Interrupt Enable Register 1 05h Interrupt Enable Register 2 Key0~Key7 status bits Key8~Key10 status bits Key0~key7 Enables Interrupts associated with capacitive touch sensor inputs Key8~key10 Enables Interrupts associated with capacitive touch sensor inputs 06h Key Enable Register 1 Key0~key7 sets the channels enable 07h Key Enable Register 2 Key8~key10 sets the channels enable 09h Multiple Touch Key Configure Register Auto-Clean Interrupt Register 0Ah Interrupt Repeat Time Register Set repeat cycle for pressing key interrupt 0Bh Auto-SLEEP Mode Register Set auto enter SLEEP Mode time 0Ch 0Dh Exit SLEEP Mode Register 1 Exit SLEEP Mode Register 2 Gain and Press Time Setting Register Key Touch Sampling Configure Register Set press Key0~Key7 to exit SLEEP Mode Set press Key8~Key10 to exit SLEEP Mode 08h 0Eh 0Fh Force Calibration Register 1 Force Calibration Register 2 13h Noise Threshold Register Set noise threshold value 14h Noise Indication Register 1 Key0~Key7 noise indication 15h Noise Indication Register 2 17h Negative Threshold Register Key8~key10 noise indication Set negative threshold and compel calibration threshold 18h Wake Up Threshold Register Set wake up threshold 19h Scan Voltage Register Set scanning voltage 1Ah Scan Frequency Register 1 Set the first and second scanning frequencies 1Bh Scan Frequency Register 2 Set the third and fourth scanning frequencies Keys value setting Keys threshold setting 0000 0000 0000 0000 R/W 0000 1111 0011 1111 0000 0000 0010 1100 0010 0100 0011 0000 Set sampling times and cycle time 11h 12h Default 0000 0000 0000 1000 1111 1111 0000 0111 1111 1111 0000 0111 Set gain and pressing trigger time Set auto-calibration cycle and negative value trigger setting Key0~Key7 calibration enable forcibly Key8~Key10 calibration enable forcibly Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 R Set auto-clean interrupt time and enable Calibration Configure Register KEY0~KEY10 Variation Value Register KEY0~KEY10 Threshold Set 30h~3Ah Register R/W Multiple touch key function setting 10h 20h~2Ah R/W 0000 0000 0011 0010 R R/W R R/W 0000 0000 0000 1001 0000 0101 0111 0000 0111 0011 1011 1000 0000 0000 0011 0000 24 IS31FL3801 40h,42h … 52h,54h 41h,43h … 53h,55h 60h 61h KEY0~KEY10 Calibration Low Bit Register Internal calibration low 8-bit for KEY0~KEY10 R KEY0~KEY10 Calibration High Bit Register Internal calibration high 8-bit for KEY0~KEY10 GPIO Enable Register 1 GPIO Enable Register 2 Key0~key7 sets the GPIO enable Key8~key10 sets the GPIO enable 62h 63h GPIO Value Register 1 GPIO Value Register 2 Key0~key7 set the GPIO values Key8~key10 set the GPIO values 64h Slider Enable Register 1 Key0~key7 sets the slider enable 65h Slider Enable Register 2 Key8~key10 sets the slider enable 66h 67h Slider Status Register1 Slider Status Register2 Slider status reply1 Slider status reply2 68h Slider Status Register3 Slider status reply3 69h Key position 1-2 of Slider1 Shows the position of Slider1 0000 0000 R/W 1110 0000 0000 0111 R R/W 6Ah Key position 3-4 of Slider1 Shows the position of Slider1 6Bh Key position 5-6 of Slider1 Shows the position of Slider1 6Fh Version Control Register Shows the firmware version 70h~75h Slider Calibration Register 1-6 76h 0000 0000 R Slider calibration from the first Key to the sixth Key Spread Spectrum Configuration Spread spectrum setting R/W 0000 0000 1000 0000 0101 0110 0111 1000 1001 1010 0100 0000 0001 0101 0000 0000 00h Main Control Register (Write Only) Bit Name Default SR 0 1 SDM 0 1 SP 0 1 D7 D6 SR 0 0 System Reset Normal Mode System Reset Shutdown Mode Normal Mode Shutdown Mode Sleep Mode Normal Mode SLEEP Mode D5 D4 D3 D2:D0 SDM 0 SP 0 0 000 00h Main Control Register (Read Only) Bit Name Default PID Default D7:D0 PID 0X31 Product ID, It is read only. User cannot modify the value. 0X31 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 25 IS31FL3801 01h Interrupt Configuration Register Bit D7:D4 D3 D2 INM 0 D1 D0 Name MDEND INE Default 0000 1 0 0 MDEN Maximum Duration Time Enable 0 Disable 1 Enable Maximum press function is used to prevent key pressing all the time by accident. When maximum press function is enabled, once key keep pressing at programmed time the key calibration value will be updated. INM Interrupt Mode 0 Interrupt Mode 0(Touch key trigger once interrupt) 1 Interrupt Mode 1(Touch key trigger repeated interrupt) INM bit sets interrupt time for once or multiple. Multiple interrupt is used for key pressing detection. INE 0 1 Interrupt Function Enable Disable Enable 02h Key Status Register 1 (Read only) Bit D7:D0 Name KS[7:0] Default 0000 0000 03h Key Status Register 2 (Read only) Bit D7:D3 D2:D0 0000 0 Name KS[10:8] Default 000 KS[10:0] Key0~Key10 Status 0 No action 1 Press or release keys If the value of KSx is detected over programmed threshold, the corresponding bit will be set to “1”. 04h Interrupt Enable Register 1 Bit D7:D0 Name Default KINT[7:0] 1111 1111 05h Interrupt Enable Register 2 Bit D7:D3 D2:D0 Name - KINT[10:8] Default 0000 0 111 The Interrupt Enable Register determines whether a sensor pad touch or release (if enabled) causes the interrupt pin to be asserted. KINT[10:0] Key Interrupt Enable 0 Disable 1 Enable The default value for Interrupt Enable Registers is interrupt enable. Only set INE bit of Interrupt Configuration Register (01h) to “0”, INTB pin will generate interrupt signal. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 26 IS31FL3801 06h Key Enable Register 1 Bit D7:D0 Name Default KEN[7:0] 1111 1111 07h Key Enable Register 2 Bit D7:D3 D2:D0 Name - KEN[10:8] Default KEN[10:0] 0 1 0000 0 Touch Key Enable Setting Disable Enable 111 08h Multiple Touch Key Configure Register Bit D7:D3 Name Default MKEN 0 1 0000 0 Multi- Key Enable Disable Enable MTK[1:0] 01 10 11 Multi -Key Selection Allow one key triggered at same time Allow two keys triggered at same time Allow three keys triggered at same time D2 D1:D0 MKEN 0 MTK[1:0] 00 D3 D2:D0 ACEN 0 ACT[2:0] 000 09h Auto-Clear Interrupt Register Bit Name Default ACEN 0 1 D7:D4 0000 Auto-Clear Interrupt Enable Disable Enable ACT[2:0] Auto-Clear Interrupt Time 000 10ms 001 20ms 010 30ms 011 40ms 100 50ms 101 100ms 110 150ms 111 200ms When ACEN=0, the INTB will keep low until MCU read 02h and 03h registers. When ACEN=1, if MCU don’t read 02h and 03h registers within programmed time (ACT=10ms~200ms), INTB pin will be release automatically. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 27 IS31FL3801 0Ah Interrupt Repeat Time Register Bit D7:D4 D3:D0 Name INTRT[3:0] MPT[3:0] Default INTRT[3:0] 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 0000 Interrupt Repeat Time Close 50ms 100ms 150ms 200ms 250ms 300ms 350ms 400ms 450ms 500ms 600ms 700ms 800ms 900ms 1s 1111 MPT[3:0] Multi-key Press Time 0000 Close 0001 50ms 0010 100ms 0011 150ms 0100 200ms 0101 250ms 0110 300ms 0111 350ms 1000 400ms 1001 450ms 1010 500ms 1011 600ms 1100 700ms 1101 800ms 1110 900ms 1111 1s When set the INM as 1 and several keys are pressed, it will generate the second interrupt until M_PRESS_TIME after the first interrupt. Then wait for INT_RPT_TIME to trigger the third interrupt. After all of these if the keys are still pressing, wait for INT_RPT_TIME to trigger others interrupt until keys release. 0Bh Auto-SLEEP Set Register Bit D7 D6:D4 D3:D0 Name ASEN OSCD[2:0] AST[3:0] Default 0 011 1111 ASEN 0 1 Auto-SLEEP Enable Disable Enable OSCD[2:0] 000 Auto-Sleep Oscillator Division 1 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 28 IS31FL3801 001 010 011 100 101 110 111 2 4 8 16 32 64 128 AST[3:0] Auto-SLEEP Time 0000 0.5s 0001 1s 0010 1.5s 0011 2s 0100 2.5s 0101 3s 0110 3.5s 0111 4s 1000 5s 1001 6s 1010 7s 1011 8s 1100 9s 1101 10s 1110 11s 1111 12s When ASEN=1 and no actions on touch key and I2C interface, the IC will enter into SLEEP Mode after programmed time (AST). 0Ch Exit SLEEP Mode Register 1 Bit D7:D1 Name ESMEN[7:0] Default 0000 0000 0Dh Exit SLEEP Mode Register 2 Bit D7:D3 D2:D0 Name ESMEN[10:8] Default 0000 0 000 ESMEN[10:0] Exit Sleep Mode Enable 0 Touch key can’t trigger exiting SLEEP Mode 1 Touch key trigger exiting SLEEP Mode When IC is in Normal Mode and ASEN=1, set ESMENx=1 will exit from SLEEP Mode by pressing the corresponding key. 0Eh Gain and Press Time Setting Register Bit D7:D4 D3:D0 Name GAIN[3:0] MDT[3:0] Default 0010 1100 GAIN[3:0] 0000 0001 0010 0011 Gain Control 1X 2X 3X 4X Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 29 IS31FL3801 0100 5X 0101 6X 0110 7X 0111 8X 1000 9X 1001 10X 1010 11X 1011 12X 1100 13X 1101 14X 1110 15X 1111 16X The GAIN bits are used to set the gain factor. Internal count will count the final value and put it into KEYx_ΔCOUNT. MDT[3:0] Max Duration Time 0000 0.5s 0001 1s 0010 2s 0011 3s 0100 4s 0101 5s 0110 6s 0111 7s 1000 8s 1001 9s 1010 10s 1011 11s 1100 12s 1101 13s 1110 14s 1111 15s MPT bits set the pressing time. When key pressed continue over the programmed time (MDT), system will force to calibrate the pressed key. Set MDEN to “1” will enable this function. 0Fh Key Touch Sampling Configure Register Bit D7:D4 D3:D2 D1:D0 Name SC[3:0] ST[1:0] CDS[1:0] 01 00 Default SC[3:0] 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 0010 Touch Key Sampling Count Setting 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 30 IS31FL3801 SC is used to set average sampling times for each channel. Higher SC value will increase stability and antiinterference ability, but decrease reaction speed. ST[1:0] 00 01 10 11 Sampling Time (Single Channel) 1 2 4 8 CDS[1:0] Cycle Delay Time 00 0ms 01 10ms 10 20ms 11 30ms Sampling 16 channels is for one cycle. 10h Calibration Configure Register Bit D7 D6:D4 D3:D2 D1:D0 Name - CSC[2:0] - NDC[1:0] Default 0 011 00 00 CSC[2:0] Calibrate Sample Count 000 2 001 4 010 8 011 16 100 32 101 64 110 128 111 256 If there is no action on keys, environmental capacitance will be calibrated after CSC times. NDC[1:0] Negative Delta Count 00 4 01 8 10 16 11 32 If channel detects the value over negative threshold (NDTH) for NDC times, it will be calibrated forcibly. 11h Force Calibration Register 1 Bit D7:D0 Name FCK[7:0] Default 0000 0000 12h Force Calibration Register 2 Bit D7:D3 D2:D0 Name - FCK[10:8] Default 0000 0 000 FCK[10:0] Individual Force Calibrate Key 0 Close 1 Enable When enable FCKx, the corresponding bit will be set to “0”. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 31 IS31FL3801 13h Noise Threshold Register Bit D7:D0 Name NTH Default 0011 0010 The noise threshold is from 0~127. It is invalid if NTH>127. If difference value between samplings is over the programmed threshold, the corresponding noise bit will be set to “1”. 14h Noise Indication Register 1 (Read Only) Bit D7:D0 Name NK[7:0] Default 0000 0000 15h Noise Indication Register 2 (Read Only) Bit D7:D3 D2:D0 Name - NK[10:8] Default NK[10:0] 0 1 0000 0 000 Noise Indication No noise Noise 17h Negative Threshold Register Bit D7:D4 D3:D0 Name NCTH[3:0] NDTH[3:0] Default 0000 1001 NCTH[3:0] 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Negative Calibrate Threshold Setting Disabled -10 -20 -30 -40 -50 -60 -70 -80 -90 -100 -110 -120 Not available Not available Not available NDTH[3:0] 0000 0001 0010 0011 0100 0101 0110 Negative Delta Threshold Setting -1 -2 -3 -4 -5 -6 -7 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 32 IS31FL3801 0111 -8 1000 -9 1001 -10 1010 -11 1011 -12 1100 -13 1101 -14 1110 -15 1111 -16 When negative value is over the programmed threshold (NCTH), the channel will be calibrated forcibly. If negative value is detected over threshold for NDTH times continually, the channel will be calibrated forcibly. 18h Wake Up Threshold Register Bit D7 D6:D0 Name - WTH[6:0] Default 0 Wake up threshold, the range is 0 – 127 000 0101 19h Scan Voltage Register Bit D7 D6:D4 D3 D2:D0 Name VTH ZERO_Time [2:0] REFSEL - Default 0 111 0 000 VTH If REFSEL = 0 0 1 If REFSEL = 1 0 1 Scan Voltage CREF charges to 0.9V CREF charges to 1.35V CREF charges to VDDH/2 CREF charges to VDDH*3/4 ZERO_Time [2:0] Discharge time of CREF 000 8 us 001 16 us 010 24 us 011 32 us 100 40 us 101 48 us 110 56 us 111 64 us REFSEL 0 1 CREF charges source selection The CREF charging source is 1.8V The CREF charging source is VDDH 1Ah Scan Frequency Register 1 Bit D7:D4 D3:D0 Name SSF[3:0] FSF[3:0] Default 0111 0011 FSF[3:0] 0000 0001 First scan frequency 8 MHZ 4 MHZ Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 33 IS31FL3801 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 2.67 MHZ 2 MHZ 1.6 MHZ 1.33 MHZ 1.14 MHZ 1 MHZ 0.89 MHZ 0.8 MHZ 0.73 MHZ 0.67 MHZ 0.62 MHZ 0.57 MHZ 0.53 MHZ 0.5M HZ SSF[3:0] 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Second scan frequency 8 MHZ 4 MHZ 2.67 MHZ 2 MHZ 1.6 MHZ 1.33 MHZ 1.14 MHZ 1 MHZ 0.89 MHZ 0.8 MHZ 0.73 MHZ 0.67 MHZ 0.62 MHZ 0.57 MHZ 0.53 MHZ 0.5M HZ 1Bh Scan Frequency Register 2 Bit D7:D4 D3:D0 Name OSF[3:0] TSF[3:0] Default 1011 1000 TSF[3:0] 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Third scan frequency 8 MHZ 4 MHZ 2.67 MHZ 2 MHZ 1.6 MHZ 1.33 MHZ 1.14 MHZ 1 MHZ 0.89 MHZ 0.8 MHZ 0.73 MHZ 0.67 MHZ 0.62 MHZ 0.57 MHZ 0.53 MHZ 0.5M HZ Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 34 IS31FL3801 OSF[3:0] 0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111 Fourth scan frequency 8 MHZ 4 MHZ 2.67 MHZ 2 MHZ 1.6 MHZ 1.33 MHZ 1.14 MHZ 1 MHZ 0.89 MHZ 0.8 MHZ 0.73 MHZ 0.67 MHZ 0.62 MHZ 0.57 MHZ 0.53 MHZ 0.5M HZ 20h~2Ah KEY0~KEY10 Variation Value Register (Read Only) Bit D7 D6:D0 Name SIGN KEYx_ΔCOUNT[6:0] Default 0 000 0000 SIGB 0 1 KEYx_ΔCOUNT[6:0] Sign bit Positive Negative Key Value Count 30h~3Ah KEY0~KEY10 Threshold Set Register Bit D7 D6:D0 Name - KEYx_TH[6:0] 0 011 0000 Default KEYx_TH[6:0] 0~127 Key Threshold 40h, 42h … 52h, 54h KEY0~KEY10 Calibration Low Byte Register (Read Only) Bit D7:D0 Name KEY0_CAL_L Default 0000 0000 41h, 43h … 53h, 55h KEY0~KEY10 Calibration High Byte Register (Read only) Bit D7:D0 Name KEY0_CAL_H Default 0000 0000 60h GPIO Enable Register 1 Bit D7:D0 Name GPIOEN[7:0] Default 0000 0000 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 35 IS31FL3801 61h GPIO Enable Register 2 Bit Name Default GPIOEN[10:0] 0 1 D7:D3 D2:D0 GPIOEN[10:8] 0000 0 000 Enable KEY0~KEY10 GPIO Mode Disable Touch key channel enter GPIO Mode Enable Touch key channel enter GPIO Mode; A channel cannot be a Touch key or Slider sensor while it’s was set to be a GPIO. 62h GPIO Value Register 1 Bit D7:D0 Name GPV[7:0] Default 0000 0000 63h GPIO Value Register 2 Bit Name Default GPV[10:0] 0 1 D7:D3 D2:D0 0000 0 62h and 63h registers define the KEY0~KEY10 GPIO values. GPIO = 0, if the related Enable GPIO Register 1/2 is enabled. GPIO = 1, if the related Enable GPIO Register 1/2 is enabled. GPV[10:8] 000 64h Slider Enable Register 1 Bit D7:D0 Name SLEN[7:0] Default 1110 0000 65h Slider Enable Register 2 Bit D7:D3 D2:D0 Name Default SLEN[10:0] 0 1 SLEN[10:8] 0000 0 111 Enable KEY0~KEY10 Slider Mode Disable Touch key channel enter Slider Mode Enable Touch key channel enter Slider Mode; A channel cannot be a Touch key sensor or GPIO while it’s was set to be a Slider. A slider is composed of six Touch Key sensors. Users can use a GUI to select certain Touch Key sensors. 66h Slider Status Register1 (Read Only) Bit Name Default ACT 0 1 Initial position[6:0] D7 ACT 0 Indicator. No action Activated The initial position of slider Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 D6:D0 Initial position[6:0] 000 0000 36 IS31FL3801 67h Slider Status Register2 (Read Only) Bit D7 Name Default Direction 0 1 End position[6:0] D6:D0 Direction 0 Direction of slider. Rotated to left. Rotated to right The end position of slider End position[6:0] 000 0000 68h Slider Status Register3 Bit D7 D6:D0 Name STA Duration[6:0] Default STA 0 1 Duration[6:0] 1 Status of slider. Wheel mode Slider mode Duration from initial position to end position 000 0000 69h Key position 1-2 of Slider1 Bit Name Default S1Kx[3:0] D7:D4 D3:D0 S1K1[3:0] S1K2[3:0] 0101 0110 This register shows which Key represents Slider1 the first Key, S1K1, and the second Key S1K2. 6Ah Key position 3-4 of Slider1 Bit Name Default S1Kx[3:0] D7:D4 D3:D0 S1K3[3:0] S1K4[3:0] 0111 1000 This register shows which Key represents Slider1 the third Key S1K3, and the fourth key S1K4. 6Bh Key position 5-6 of Slider1 Bit D7:D4 D3:D0 Name S1K5[3:0] S1K6[3:0] Default S1Kx[3:0] 1001 1010 This register shows which Key represents Slider1 the fifth Key S1K5, and the sixth key S1K6. 6Fh Version Control Register (Read Only) Bit Name Default VCRx VCR1[1:0] VCR2[2:0] VCR3[2:0] D7:D6 D5:D3 D2:D0 VCR1[1:0] VCR2[2:0] VCR3[2:0] 01 000 000 This register shows the firmware version. The major modification that cannot compatible with previous version Added functions and the functions should be backward compatible. Shows the bug modification and the revision should be backward compatible. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 37 IS31FL3801 70h~75h Slider Calibration Register 1-6 Bit Name Default SCRKx[3:0] D7:D0 SCRKx 0001 0101 These registers are used for slider calibration. The slider is composed of six touch keys. The range of x is from 1 to 6 which means as key 1 to key 6. 76h Spread Spectrum Configuration Register Bit D7:D4 D3:D2 D1:D0 Name Default SSC SSR[3:0] SSA[1:0] 0000 00 Spread spectrum configuration register. Spread spectrum is a technique by which electromagnetic energy produced over a particular bandwidth is spread in the frequency domain. Two parameters are listed as follows: SSR[3:0] SSR[3:0] defines the spread spectrum sweep rate. If the SCR[3:0] = 0, then spread spectrum is disabled. SSA[1:0] SSA[1:0] defines the amplitude of spread spectrum frequency change. The frequency is changed by adding SSA[1:0] range to the actual internal OSC control register. +/- 32 +/- 16 +/- 8 +/- 4 11 10 01 00 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 38 IS31FL3801 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 8 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 39 IS31FL3801 PACKAGE INFORMATION QFN-60 RECOMMENDED LAND PATTERN Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 40 IS31FL3801 POD NOTE: 1. CONTROLLING DIMENSION: MM 2. REFERENCE DOCUMENT: JEDEC MO-220 3. THE PIN’S SHARP AND THERMAL PAD SHOWS DIFFERENT SHAPE AMONG DIFFERENT FACTORIES determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 41 IS31FL3801 REVISION HISTORY Revision Detail Information Date 0A Initial version. Modified it from IS31FL3800. 2020.05.26 0B Modified 0B version from IS31FL3800 version C. 2020.08.10 Lumissil Microsystems – www.lumissil.com Rev. 0B, 08/14/2020 42
IS31FL3801-QFLS3-TR 价格&库存
很抱歉,暂时无法提供与“IS31FL3801-QFLS3-TR”相匹配的价格&库存,您可以联系我们找货
