IS32FL3265B- ZLA3-TR
    LUMISSIL
    TSSOP28
    18 HIGH VOLTAGE(40V) CONSTANT CU
IS32FL3265B- ZLA3-TR 数据手册
IS32FL3265B HIGH-VOLTAGE, 18-CHANNEL LED DRIVER July 2020 GENERAL DESCRIPTION FEATURES The IS32FL3265B is an LED driver with 18 high voltage (40V) constant current channels. Each channel can be pulse width modulated (PWM) by 8 bits for smooth LED brightness control. In addition, each channel has an 8-bit output current control register which allows fine tuning of the channel current for rich RGB color mixing, e.g., a pure white color LED application. The maximum output current of each channel is designed to be 60mA, which can be adjusted by one 32 steps global control register. Proprietary algorithms are used in IS32FL3265B to minimize audible noise caused by the MLCC decoupling capacitor. All registers can be programmed via 12MHz SPI interface.   The IS32FL3265B can be configured to a minimum current consumption mode by either pulling the SDB pin low or by using the software shutdown feature. The IS32FL3265B is available in eTSSOP-28 package. It operates from 3.0V to 5.5V over the temperature range of -40°C to +125°C. APPLICATIONS  Car display panel  Ambient lighting  Roof lighting  Functional lighting Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020               3V to 5.5V operating supply Output current capability and number of outputs: 60mA × 18 outputs, tolerance voltage 40V 12MHz SPI with automatic address increment Programmable H/L logic: 1.4V/0.4V, 2.4V/0.6V Accurate Color Rendition - 32 steps Global current adjust - 8-bit Dot correction for each channel - 8-bit PWM for each channel Selectable PWM method (200Hz or 25kHz) 256-Step group blink with frequency programmable from 24Hz to 10.66s and duty cycle from 0% to 99.6% Clock IO pin for multi-chip synchronization Fault report (open detect/thermal roll off /thermal shutdown) Thermal roll-off programmable set point SDB rising edge resets SPI interface EMI reduction technology - Spread spectrum - Selectable 9 phase delay Operating temperature range, -40°C ~ +125°C Package: eTSSOP-28 AEC-Q100 Qualified Current accuracy (All output on) - Bit to bit: < ±6% - Device to device: < ±6% 1 IS32FL3265B TYPICAL APPLICATION CIRCUIT * Note 1, 2 5V 28 * Note 1 VCC * Note 3 1 F 0.1 F OUT1 * Note 2 5V * Note 2 OUT2 5V 100k 5 INTB 3 SCK 2 8 82R IS32FL3265B CS 26 SDB OUT16 OUT17 0.1 F *Note 4 82R MISO 1 100k 7 MOSI 4 Micro Controller OUT3 VLED+ = 12V 6 200R 25 ISET OUT18 GND CLKIO 21 200R 22 82R 23 82R RISET 20k 24 Figure 1 27 Typical Application Circuit Note 1: VCC pin should not be higher than 5.5V, VLED+ can be higher than VCC. Note 2: VIH is the high level voltage for IS32FL3265B’s INTB, which is usually same as VCC pin and VCC of Micro Controller, e.g. if VCC of Micro Controller is 3.3V, VCC(IS32FL3265B)=VIH=3.3V, if VCC of Micro Controller is 5V, VCC(IS32FL3265B)=VIH=5V, but VCC(IS32FL3265B) should not be lower than 3V. 2 Note 3: These resistors are for offloading the thermal dissipation (I R) away from the IS32FL3265B. Note 4: The maximum global output current is set by external resistor, RISET. Please refer to the application information in RISET section. Note 5: The IC and LED string should be placed far away from any local antenna in order to prevent EMI contamination. Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 2 IS32FL3265B TYPICAL APPLICATION CIRCUIT (CONTINUED) CS8 CS2 Micro Controller MOSI SCK MOSI MOSI SCK SCK CS1 MISO SDB CS2 CS MISO MISO SDB SDB MOSI MOSI SCK SCK CS3 CS MISO MISO SDB SDB MOSI MOSI SCK SCK CS4 CS MISO MISO SDB SDB MOSI SCK CS MISO SDB 100k CLKIO CLKIO Master CLKIO MOSI SCK CS5 MISO SDB CLKIO Slave 1 CLKIO MOSI MOSI SCK SCK CS6 CS MISO MISO SDB SDB Slave 4 Figure 2 CLKIO Slave 2 CLKIO MOSI MOSI SCK SCK CS7 CS MISO MISO SDB SDB Slave 5 Slave 3 CLKIO MOSI MOSI SCK SCK CS8 CS MISO MISO SDB SDB Slave 6 MOSI SCK CS MISO SDB Slave 7 Typical Application Circuit (Eight Device Synchronization) Note 6: One system should contain only one master, all slave parts should be configured as slave mode before the master is configured as master mode. Master or slave mode is specified by the Configuration Register. The master will output a master clock (CLKIO), and all the other devices configured as slaves will synchronize their CLKIO inputs to the master clock. Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 3 IS32FL3265B PIN CONFIGURATION Package Pin Configuration (Top View) eTSSOP-28 PIN DESCRIPTION No. Pin Description 1 CS CS of SPI. 2 MISO MISO of SPI. 3 MOSI MOSI of SPI. 4 SCK SPI clock. 5 INTB Interrupt output pin. Register 14h can set the function of the INTB pin and active low when the interrupt event happens. Can be NC (float) if interrupt function is not used. 6~23 OUT1~OUT18 Output LED current sink channels 1~18. 24 GND GND pin for control logic. 25 ISET Input terminal used to connect an external resistor. This regulates the global output current. 26 SDB Shutdown the chip when pulled low. 27 CLKIO Cascade connection pin. 28 VCC Power supply. Thermal Pad Need to connect to GND. Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 4 IS32FL3265B ORDERING INFORMATION Automotive Range: -40°C to +125°C Order Part No. Package QTY/Reel IS32FL3265B-ZLA3-TR eTSSOP-28, Lead-free 2500 Copyright  ©  2020  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 5 IS32FL3265B ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at CS, SCK, MISO, MOSI, CLKIO, SDB, INTB Voltage at OUT1 to OUT18 Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JESD 51-2A), θJP ESD (HBM) ESD (CDM) -0.3V ~ 6.0V -0.3V ~ VCC+0.3V +40V +150°C -65°C ~ +150°C -40°C ~ +150°C 33.8°C/W 11.08°C/W ±2kV ±750V Note 7: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS VCC= 5V, TA= TJ= -40°C ~ +125°C, Typical values are at TJ= 25°C, unless otherwise noted. Symbol VCC Parameter Condition Supply voltage Typ. 3 Maximum output current RISET= 6.8kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF, VOUT= 0.8V (Note 8) Output current RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF ∆IMAT IOUT mismatch(bit to bit) ∆IOUT IOUT Min. Max. Unit 5.5 V 60 20.4 21.8 mA RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF (Note 9) ±2 ±6 % IOUT accuracy(device to device) RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF (Note 10) ±2 ±6 % VHR Headroom voltage RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF 0.3 0.5 V RISET= 20kΩ, GCC= 0xFF, Scaling= 0xFF, PWM= 0 7.5 9 mA ICC Quiescent power supply current VCC= 3.6V, RISET= 20kΩ, GCC= 0xFF, Scaling= 0xFF, PWM= 0 7.2 8.5 mA RISET= 20kΩ, VSDB= 0V or software shutdown 4 20 μA VCC= 3.6V, RISET= 20kΩ, VSDB= 0V or software shutdown 1 12 μA 1.02 V ISD Shutdown current 19 mA VISET ISET voltage RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF 0.98 1.0 VOD OUTx pin open detect threshold RISET=20kΩ, GCC= 0x20, Scaling= 0xFF, PWM=0xFF, measured at OUTx 100 150 IOZ Output leakage current VSDB= 0V or software shutdown, VOUT= 40V fOUT PWM frequency of output Frequency setting=25kHz TSD Thermal shutdown 165 °C TSD_HYS Thermal shutdown hysteresis 20 °C Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 22 25 mV 1 μA 28 kHz 6 IS32FL3265B ELECTRICAL CHARACTERISTICS (CONTINUED) VCC= 5V, TA= TJ = -40°C ~ +125°C, Typical values are at TJ= 25°C, unless otherwise noted. Symbol Parameter Condition Min. Typ. Max. Unit 0.4 V Logic Electrical Characteristics (SCK, MISO, MOSI, CS, SDB, CLKIO) VIL Logic “0” input voltage VCC= 2.7V~5.5V, LGC=0 VIH Logic “1” input voltage VCC= 2.7V~5.5V, LGC=0 VIL Logic “0” input voltage VCC= 2.7V~5.5V, LGC=1 VIH Logic “1” input voltage VCC= 2.7V~5.5V, LGC=1 VOH H level MISO and CLKIO pin IOH= -8mA output voltage VCC-0.4V VCC V VOL L level MISO and CLKIO pin IOL= 8mA output voltage 0 0.4 V 1.4 V 0.6 2.4 V V IIL Logic “0” input current VINPUT= 0V (Note 11) 5 nA IIH Logic “1” input current VINPUT= VCC (Note 11) 5 nA DIGITAL INPUT SPI SWITCHING CHARACTERISTICS (NOTE 11) Symbol fC Parameter Clock frequency Min. Typ. Max. Units 12 MHz tSLCH CS active set-up time 34 tSHCH CS not active set-up time 17 ns tSHSL CS detect time 167 ns tCHSH CS active hold time 34 ns tCHSL CS not active hold time 17 ns tCH Clock high time 34 ns tCL Clock low time 34 ns tCLCH Clock rise time 9 ns tCHCL Clock fall time 9 ns tDVCH Data in set-up time 7 ns tCHDX Data in hold time 9 ns tSHQZ Output disable time 34 ns tCLQV Clock low to output valid 39 ns tCLQX Output hold time tQLQH Output rise time 17 ns tQLQH Output fall time 17 ns ns 0 ns Note 8: The recommended minimum value of RISET is 6.8kΩ. Note 9: IOUT mismatch (bit to bit) is calculated: I MAT     I OUTn (n  1 ~ 18)    1  100%   I OUT1  I OUT 2  ...  I OUT18      18    Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 7 IS32FL3265B Note 10: IOUT accuracy (device to device) is calculated: I OUT   I OUT1  I OUT 2  ...  I OUT18  I OUT ( IDEAL) )  ( 18   100%  I OUT ( IDEAL)       Where IOUT(IDEAL)= 20.4mA (RISET= 20kΩ, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF). Note 11: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 8 IS32FL3265B DETAILED DESCRIPTION SPI INTERFACE ADDRESS AUTO INCREMENT IS32FL3265B uses a SPI protocol to control the chip’s function with four wires: CS, SCK, MOSI and MISO. SPI transfer starts form CS pin from high to low controlled by Master (Microcontroller), and IS32FL3265B latches data when clock rising. To write multiple bytes of data into IS32FL3265B, load the address of the data register that the first data byte is intended for. During the 8th rising edge of receiving the data byte, the internal address pointer will increment by one. The next data byte sent to IS32FL3265B will be placed in the new address, and so on. The auto increment of the address will continue as long as data continues to be written to IS32FL3265B (Figure 6). SPI data format is 8-bit length. The register byte must be sent first, and is followed by register address byte then the register data. If the R/W bit is “0”, it will be write operation and Master (Micro-controller) can write the register data into the register. The maximum SCK IS32FL3265B is 12MHz. frequency supported All of the registers can be read (Table 1). To read the registers, the D7 of the register byte needs to be set to “1”. If read one register, as shown in Figure 7, read the MISO data after sending the command byte and register address. If read more registers, as shown in Figure 8, the register address will auto increase during the 8th rising edge of receiving the last bit of the previous register data. Figure 3 Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 in READING OPERATION SPI Input Timing 9 IS32FL3265B Figure 4 MOSI 1 2 3 4 5 A7 A6 A5 A4 A3 SPI Input Timing 6 7 8 A2 A1 A0 1 2 D7 D6 3 4 5 6 7 D5 D4 D3 D2 D1 8 D0 SCK Register Address Byte CS Figure 5 MOSI Data Byte SPI writing to IS32FL3265B (Typical) 1 2 3 4 5 A7 A6 A5 A4 A3 6 7 8 A2 A1 A0 1 2 D7 D6 3 4 5 6 7 D5 D4 D3 D2 D1 8 D0 SCK Register Address Byte CS MOSI 1 2 3 4 5 A7 A6 A5 A4 A3 6 7 8 A2 A1 A0 Data 1 Byte 1 2 D7 D6 3 4 5 6 7 D5 D4 D3 D2 D1 8 D0 SCK Data (n-1) Byte CS Figure 6 Data n Byte SPI writing to IS32FL3265B (Automatic Address Increment) Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 10 IS32FL3265B 1 2 D7 D6 MISO MOSI 1 2 3 4 5 A7 A6 A5 A4 A3 6 7 8 A2 A1 A0 1 2 3 4 5 6 7 D5 D4 D3 D2 D1 3 4 5 6 7 8 D0 8 SCK Register Address Byte CS Figure 7 Data Byte SPI Reading From IS32FL3265B (Typical) 1 2 D7 D6 MISO MOSI 1 2 3 4 5 A7 A6 A5 A4 A3 6 7 8 A2 A1 A0 1 2 3 4 5 6 7 D5 D4 D3 D2 D1 3 4 5 6 7 8 D0 8 SCK Register Address Byte CS MISO 1 2 D7 D6 1 2 3 4 5 6 7 D5 D4 D3 D2 D1 3 4 5 6 7 Data 1 Byte 1 2 8 D0 D7 D6 8 1 2 3 4 5 6 7 D5 D4 D3 D2 D1 3 4 5 6 7 8 D0 8 MOSI SCK Data (n-1) Byte CS Figure 8 Data n Byte SPI Reading From IS32FL3265B (Automatic Address Increment) Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 11 IS32FL3265B REGISTER DEFINITIONS Table 1 Register Function Address Name Function Table Default 2 0000 0000 3 0011 1111 Control each channel’s DC current 4 1111 1111 Open Detect Enable Register Open detect enable 5 0000 0011 LED Open Status Register (Read Only) Open information 6 0000 0000 Write Read 00h 80h Configuration Register 01h 81h Global Current Control Register Control Global DC current 02h~13h Power control register 82h~93h Scaling Register 14h 94h 15h~17h 95h~97h 18h 98h Temperature Sensor Register Temperature information 7 0000 0000 19h 99h Spread Spectrum Register Spread spectrum control register 8 0000 0000 Disable PWM function 9 0000 0000 Phase Delay and Clock Phase 10 0000 0000 1Ah~1Ch 9Ah~9Ch DC PWM Register 1Dh~1Eh 9Dh~9Eh Phase Delay and Clock Phase Register 1Fh~30h 9Fh~B0h PWM Register Channel [18:1] PWM register byte 11 0000 0000 31h~33h B1h~B3h Blinking Enable Register Enable Blinking state for each LED 12 0000 0000 34h B4h Blinking Frequency Register Blinking frequency setting 13 0000 0000 35h B5h Blinking Duty Cycle Register Blinking duty cycle setting 14 0000 0000 36h B6h Scaling Update Register Update the scaling registers - 0000 0000 37h B7h Update Register Update the PWM and blinking registers - 0000 0000 3Fh BFh Reset Register Reset all registers - 0000 0000 Table 2 00h Configuration Register Bit D7 Name - Default 0 D6 D5 D4 D3 LGC CM PFS 0 0 0 D2:D1 D0 - SYNC SSD 0 00 0 The Configuration Register sets high/low logic, current multiplier, PWM frequency, synchronization mode and software shutdown mode for the IS32FL3265B. When SSD bit is “0”, the IS32FL3265B is in software shutdown mode. For normal operation the SSD bit should be set to “1”. SYNC bits configure the device into Master or Slave mode. The CLKIO pin has an internal weak pulldown resistor. When the SYNC bits are “10”, the CLKIO pin is configured as the master and will output a clock signal for distribution to the slave configured devices. To be configured as a slave device and accept an external clock input the slave device’s SYNC bits must be set to “11”. The CLKIO clock is only used synchronizing the blink function, and CLKIO frequency is same as blinking setting from 24Hz to 10.66s. There should only be one master and all other CLKIO connected devices should first be configured in slave mode before the master is configured as master mode. Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 The PFS bit sets the operating PWM frequency, default PWM frequency is 25kHz, when PFS is set to “1”, the PWM frequency will change to 200Hz. CM bit is a current multiplier of all output’s current. When CM= “0”, IOUT(MAX) follow the formula below or refer to RISET section in Application Information. I OUT ( MAX )  x V ISET R ISET (1) x = 408, VISET = 1V. When CM= “1”, the output current will become 1/8 of above setting, which is: I OUT ( MAX )  x V ISET  8 R ISET (1) x = 408, VISET = 1V. For applications of IOUT(MAX)=6mA~60mA, CM should be set to “0”. For applications of IOUT(MAX)=0~7.5mA, recommend to set CM to “1” to ensure good ∆IMAT and ∆IOUT. When LGC bit is set to “1”, the high/low logic will change to 2.4V/0.6V. 12 IS32FL3265B Software Shutdown Control Software shutdown Normal operation SSD 0 1 Table 4 02h~13h Scaling Register 11 Master or Slave Mode no function, CLKIO pull-low Master and CLKIO has square wave output, CLKIO frequency is same as blinking frequency Slave and CLKIO is clock input PFS 0 1 PWM Frequency Setting 25kHz 200Hz CM 0 1 Current Multiplier 6~60mA 1~10mA LGC 0 1 H/L Logic 1.4V/0.4V 2.4V/0.6V SYNC 00/11 10 Bit D7:D6 D5:D0 Name - GCC Default 00 11 1111 GCC and SL control the IOUT as shown in Formula (2). GCC SL  )  32 256 ( MAX (2) If GCC ≤ 31 (“01 1111”), GCC  5  D [n ]  2 n (3) n0 If GCC ≥ 32 (“10 0000”), GCC= 32. Where IOUT(MAX) is the maximum output current decided by RISET (Check RISET section for more information) The IOUT of each channel is set by the SL bits of LED Scaling Register (02h~13h). Please refer to the detail information in Table 5. If GCC= 0x05, SL= 0xFF, GCC≤ 31 so GCC= 5, I OUT  I OUT ( MAX )  5 255  32 256 (2) If GCC=0x2F, SL=0xFF, GCC ≥ 32 so GCC=32, I OUT  I OUT ( MAX )  D7:D0 Name SL[7:0] Default 1111 1111 Each output has 8 bits to modulate DC current in 256 steps. The value of the SL Registers scales the IOUT current of each output channel. IOUT computed by Formula (2): I OUT  I OUT Table 3 01h Global Current Control Register I OUT  I OUT Bit 255 256 Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 ( MAX )  GCC SL  32 256 (2) Where IOUT(MAX) is the maximum output current set by RISET. GCC (D5~D0) are the global current setting bits. SL D7~D0=0xFF is the default value, resulting in no LED current, for LEDs to function need to program these bits to a value from 0x01 to 0xFF. Scaling Registers 02h~13h must be updated by writing to the Scaling Update Register 36h. For DC mode (PWM disabled), each register will be updated immediately when it is written. For PWM mode, each register will be updated at the PWM falling edge, except not on the first PWM cycle. Table 5 14h Open Detect Enable Register Bit D7:D2 D1 D0 Name - ODF ODE Default 00000 1 1 ODE enables Open LED detection and stores this open information in LED Open status registers 15h~17h. The open information will continue updating until detection is disabled by writing “0” to ODE. Writing a “1” to ODF bit enables reporting of the open information on the INTB pin. When ODF is “1”, any detected open LED condition on OUT1~OUT18 will cause the INTB pin to go logic low. ODE 0 1 Open Detect Enable Detect disable Detect enable ODF 0 1 Open Report Enable Report disable Report enable (2) 13 IS32FL3265B Table 6-1 15h LED Open Status Register 1 Bit D7 D6:D4 D3 D2:D0 Name - OP[6:4] - OP[3:1] Default 0 000 0 000 Table 6-2 16h LED Open Status Register 2 Bit D7 D6:D4 D3 D2:D0 Name - OP[12:10] - OP[9:7] Default 0 000 0 000 Table 6-3 17h LED Open Status Register 3 Bit D7 D6:D4 D3 D2:D0 Name - OP[18:16] - OP[15:13] Default 0 000 0 000 Open status registers 15~17h are updated if there is an open LED condition and if bit ODE of register 14h was set to “1”. Register 15~17h will be cleared upon reading the register. Open Information of OUT18:OUT1 No LED open detected LED open detected OPx 0 1 D7 D6 D5 Name TSDDE TRDE TSDF Default 0 0 0 D4 D3:D2 D1:D0 TF TROF 0 00 TS 00 01 10 11 TS 00 01 10 11 TSDF 0 1 Thermal Shutdown Flag No thermal shutdown happens Thermal shutdown happens TRDE 0 Thermal roll off Detect Enable Disable the thermal roll off detect, thermal roll off information will not store in TF Enable the thermal roll off detect, thermal roll off information stored in TF 1 TSDDE 0 1 Thermal Shutdown Detect Enable Disable thermal shutdown detect, thermal shutdown information will not be stored in TSDF Enable thermal shutdown detect thermal shutdown information will be stored in TSDF Bit D7:D5 D4 D3:D2 D1:D0 Name - SSP RNG CLT Default 000 0 00 00 This register enable the spread spectrum function, adjust the cycle time and range. 00 This register stores the temperature point of the IC. When TF=1, the IC die temperature has exceeded the temperature point. When thermal shutdown happens, the TSDF will set to “1” to flag the thermal shutdown has occurred. Write 18h with C0h to enable read back if die temperature has or has not exceeded the set point. TROF Temperature Flag Set point not reached Reached the set point Table 8 19h Spread Spectrum Register Table 7 18h Temperature Status Register Bit TF 0 1 Percentage of output current before thermal shutdown happens 100% 75% 55% 30% SSP 0 1 Spread Spectrum Enable Disable Enable CLT 00 01 10 11 Spread Spectrum Cycle Time 1980μs 1200μs 820μs 660μs RNG 00 01 10 11 Spread Spectrum Range ±5% ±15% ±24% ±34% Temperature Point, Thermal roll-off start point 140°C 120°C 100°C 90°C Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 14 IS32FL3265B Table 9-1 1Ah DC PWM Register (PWM=256/256) Table 11 1Fh~30h PWM Register Bit D7 D6:D4 D3 D2:D0 Bit D7:D0 Name - DP[6:4] - DP[3:1] Name PWM Default 0 000 0 000 Default 0000 0000 Table 9-2 1Bh DC PWM Register (PWM=256/256) Bit D7 D6:D4 D3 D2:D0 Name - DP[12:10] - DP[9:7] Default 0 000 0 000 Each OUTx has 1 byte to modulate the PWM duty cycle in 256 steps. The value of the PWM Registers decides the average current of each OUTx LED noted ILED. ILED computed by Formula (4): Table 9-3 1Ch DC PWM Register (PWM=256/256) Bit D7 D6:D4 D3 D2:D0 Name - DP[18:16] - DP[15:13] Default 0 000 0 000 I LED  PWM  I OUT 256 (4) 7 n 0 When DPx bit is set to 1, the associated OUTx PWM will become 256/256, the OUTx current is a DC value, not PWM controlled. DPx 0 1 DC PWM command of OUT18:OUT1 PWM decided by Registers 1Fh-30h no PWM, DC output Table 10-1 1Dh Phase Delay and Clock Phase Register 1 Bit D7 D6:D4 D3:D1 D0 Name - PS[3:1] - PDE Default 0 000 000 0 Table 10-2 1Eh Phase Delay and Clock Phase Register 2 Bit D7 D6:D4 D3 D2:D0 Name - PS[9:7] - PS[6:4] Default 0 000 0 000 IS32FL3265B features a 9 phase delay function enabled by PDE bit. PDE 0 1 Phase Delay Enable Phase delay disable Phase delay enable PSx 0 Phase select OUTx x2 Phase delay 0D, PS1 is for OUT1 &OUT2, PS2 is for OUT3 & OUT4… OUTx x2 Phase delay 180D, PS1 is for OUT1 &OUT2, PS2 is for OUT3 & OUT4… 1 Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 PWM   D[n]  2 n I OUT  I OUT ( MAX )  (5) GCC SL  32 256 (2) Where IOUT(MAX) is the maximum output current decided by RISET, GCC is the global current setting(GCC), and SL is the 8-bit scaling of each output. For example, if the data in OUT1 PWM register is “0000 0100”, then the associated PWM is the fourth step (4/256). Table 12-1 31h Blinking Enable Register Bit D7 D6:D4 D3 D2:D0 Name - BP[6:4] - BP[3:1] Default 0 000 0 000 Table 12-2 32h Blinking Enable Register Bit D7 D6:D4 D3 D2:D0 Name - BP[12:10] - BP[9:7] Default 0 000 0 000 Table 12-3 33h Blinking Enable Register Bit D7 D6:D4 D3 D2:D0 Name - BP[18:16] - BP[15:13] Default 0 000 0 000 The Blinking Enable Registers store the Blinking mode enable bit of each OUTx channel. The data sent to the registers will be stored in temporary registers only, a write operation of “0000 0000” value to the Update Blinking Register (37h) is required to update it. BPx 0 1 Blinking Enable Bit PWM Mode Blinking Mode 15 IS32FL3265B Table 13 34h Blinking Frequency Register Bit D7:D0 Name BLF Default 0000 0000 The Blinking Frequency Register stores the blinking frequency of the outputs. The blinking period is controlled through 256 linear steps from 00h (41 ms, frequency 24 Hz) to FFh (10.66 s). Blinking frequency is computed by: Blinking frequency (Hz) = 24/(BLF[7:0] + 1) The data sent to the Blinking Frequency Register will be stored in temporary bits, a write operation of “0000 0000” value to the Update Register (37h) is required to update it. Table 14 35h Blinking Duty Cycle Register Bit D7:D0 Name BLD Default 0000 0000 36h Scaling Update Register A Write of 00h to the Scaling Update Register is required to update the Scaling Registers (02h~13h) values. 37h Update Register A Write of 00h to Update Register is required to update the PWM Registers and Blinking Frequency Register/ Blinking Duty Cycle Register (1Fh~30h, 34h~35h) values. 3Fh Reset Register A write of 0xAE to the Reset Register will reset all the IS32FL3265B registers to their default values. On initial power-up, the IS32FL3265B registers are reset to their default values for a blank display. A write of “1” to the SSD bit in the Configuration Register 00h is required to enable the IS32FL3265B since the SSD default value is “0” or software shutdown. The Blinking Duty Cycle Register stores blinking duty cycle information (ON/OFF ratio in %). The blinking duty cycle can be linearly programmed from 0% (BLD=0x00) to 99.6% (BLD=0xFF). Blinking duty cycle computed by: Blinking duty cycle = BLD[7:0] / 256 The data sent to the Blinking Duty Cycle Register will be stored in temporary bits, a write operation of “0000 0000” value to the Update Register (37h) is required to update it. Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 16 IS32FL3265B APPLICATION INFORMATION RISET The maximum output current IOUT(MAX) of OUT1~OUT18 can be adjusted by external resistor, RISET, as described in Formula (1). I OUT ( MAX )  x V ISET R ISET (1) x = 408, VISET = 1V. Registers can also be referred to as white balance registers. PWM CONTROL The 18 PWM Registers (1Fh~30h) can modulate the average LED brightness of each 18 channels with 256 steps. For example, if the data in OUT1 PWM register is “0000 0100”, then the associated PWM is the fourth step (4/256). The max IOUT result is based on register setting as below(CM is D5 of Configuration Register(00h)): Continuously updating new values to the PWM registers will modulate the brightness of the LEDs to achieve a breathing effect. When CM= “0”, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF PWM FREQUENCY SELECT The recommended minimum value of RISET is 6.8kΩ. When RISET=20kΩ, IOUT(MAX)=20.4mA. When RISET=6.8kΩ, IOUT(MAX)=60mA. When CM= “1”, GCC= 0x20, Scaling= 0xFF, PWM= 0xFF The output current will become 1/8 of above setting, which is: I OUT ( MAX )  x V ISET  8 R ISET (1) x = 408, VISET = 1V. When RISET=20kΩ, IOUT(MAX)=2.55mA. The IS32FL3265B output channels operate with a default 8 bit PWM resolution and a PWM frequency of 200Hz or 25kHz (register selectable). Because all the OUTx channels are synchronized, the DC power supply mau experience large instantaneous current surges when the OUTx channels turn ON. These current surges will generate an AC ripple on the power supply which cause stress to the decoupling capacitors. When the AC ripple is applied to a monolithic ceramic capacitor chip (MLCC) it will expand and contract causing the PCB to flex and generate audible hum in the PWM frequency range. To avoid this hum, there are many countermeasures, such as selecting the capacitor type and value which will not cause the PCB to flex and contract. RISET should be close to pin 25 and the ground side should connected to a nearby GND plane. An additional option for avoiding audible hum is to set the IS32FL3265B’s output PWM frequency above/below the audible range. The Control Register (00h) can be used to set the switching frequency to 200Hz or 25kHz, to avoid the audible range. CURRENT SETTING OPEN DETECT FUNCTION The maximum output current is set by the external resistor RISET. The current of each output can be adjusted with the SL 8 bits of LED Scaling Register (02h~13h). IS32FL3265B has open detect bit for each LED. When RISET=6.8kΩ, IOUT(MAX)=7.5mA. Some applications may require the IOUT of each channel to be adjusted independently. For example, if OUT1 drives 1 LED and OUT2 drives 2 parallel LEDs, and they should have the same average current of 10mA, we can set RISET=20kΩ for IOUT of 20.4mA, and configure the following registers 01h=0x20 (GCC= 32), 02h=0x80 (Scaling OUT1), and 03h=0xFF (Scaling OUT2). The result is OUT1 sinks 10mA and OUT2 sinks 20.4mA which will be shared by the two LEDs in parallel (10mA each). Another example, for an RGB LED, OUT1 is Red, OUT2 is Green and OUT 3 is Blue, with the same GCC (01h) SL (02h~13h) bits and PWM value, the LED may looks a pinkish, or not so white. In this case, the SL bits can be used to adjust the current of the RGB IOUTx to create a pure white color. These Scaling Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 By setting the ODE bit of Open Detect Enable Register (14h) from “0” to “1” (store open information), the LED Open Register will store the open LED information so the MCU can read LED status from registers 95h~97h. The open information will continue updating until ODE is set to “0”. The ODF bit can be set to “1” to enable reporting of open LED information on the INTB pin. When ODF is “0”, the open LED information will not be reported on the INTB pin. When ODF is “1”, any OUTx with a detected open LED will cause the INTB pin to go logic LOW. The Global Current Control Register (01h) needs to set to a value in the range of 0x10~0x48 in order to correctly detect an open LED. SPREAD SPECTRUM FUNCTION PWM current switching of LED outputs can be particularly troublesome Electromagnetic Interference (EMI) is of concern. To optimize EMI performance, the 17 IS32FL3265B IS32FL3265B spread spectrum function can be enabled. By setting the RNG bit of the Spread Spectrum Register (19h), a Spread Spectrum range can be selected from ±5% /±15% /±24% /±34%. Spread spectrum can spread the total electromagnetic emitting energy into a wider frequency range that significantly lowers the peak radiated energy. With spread spectrum enabled and proper PCB layout, it is possible to pass EMI tests which were previously difficult to pass. Thermal Consideration The over temperature of the chip may result in deterioration of the properties of the chip. The maximum IC junction temperature should be restricted to 150°C under normal operating conditions. The maximum power dissipation can be calculated using the following equation: p D ( MAX )  SHUTDOWN MODE T J (max)  T A  JA Shutdown mode can be used as a means of reducing power consumption. During shutdown mode all registers retain their data. Where PD(MAX) is the maximum allowable power dissipation, TJ(MAX) is the maximum allowable junction temperature, TA is ambient temperature of the device Software Shutdown For example, when TA=25°C By setting the SSD bit of the Control Register (00h) to “0”, the IS32FL3265B will operate in software shutdown mode. When the IS32FL3265B is in software shutdown, all current sources are switched off, so the LEDs are OFF but all registers remain accessible. Typical current consumption is 3μA (VCC=5V). PD ( MAX )  150 C  25 C  3.7W 33 .8C / W Figure 9, shows the power derating of the IS32FL3265B on a JEDEC boards (in accordance with JESD 51-5 and JESD 51-7) standing in still air. 4 Hardware Shutdown The IS32FL3265B exits shutdown when the SDB pin is pulled high. The rising edge of SDB pin will reset the SPI module, but all the register information is retained. During hardware shutdown the registers are accessible. If the VCC supply drops below 1.75V but remains above 0.1V while the SDB pin is pulled low, all Function Registers must be re-initialized before the SDB pin is pulled high. LAYOUT The IS32FL3265B consumes lots of power so proper PCB layout will help improve itsreliability. Below are basic PCB layout factors to consider. Power Supply Lines When designing the PCB layout, the first step to consider is the power supply traces and GND connection. High current traces, digital and analog supply traces and GND traces should be separated to avoid noise contamination from the switching digital block from affecting the analog block. At least one 0.1μF capacitor, if possible in parallel with a 1μF capacitor is recommended to connect from the power supply pin of the chip directly to ground. To be effective, these capacitors must be placed close to the chip and the capacitor ground should be well connected to the GND plane. Lumissil Microsystems – www.lumissil.com Rev.B, 07/07/2020 3.5 Power Dissipation (W) The IS32FL3265B enters hardware shutdown when the SDB pin is pulled low. All current sources are disabled during hardware shutdown, typical the current consumption is 3μA (VCC=5V). eTSSOP-28 3 2.5 2 1.5 1 0.5 0 -40 -20 0 20 40 60 80 100 120 140 150 Temperature (°C) Figure 9 Dissipation Curve The thermal pad of IS32FL3265B should connect to a large copper GND net (preferably double sided PCB). Use 9 or 16 vias to connect the GND copper area directly under the IC thermal pad with a copper pad on the opposite layer (2 layer PCB). The grounded copper area should be as large area as possible to help distribute the thermal energy from the IS32FL3265B. Current Rating Example For RISET=20kΩ (IOUT(MAX)=20.4mA), the current rating for each net is as follows: • VCC pin maximum current (ICC) is 10mA when VCC=5V, the total OUTx current can as much as 20.4mA×18=367.2mA, the recommended trace width for VCC pin: 0.20mm~0.3mm, recommend trace width for VLED+ net: 0.30mm~0.5mm, 18 IS32FL3265B • Output pins=20.4mA, recommend trace width is 0.2mm~0.254mm • All other pins
IS32FL3265B- ZLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32FL3265B- ZLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32FL3265B-ZLA3-TR
  • 2500+12.269152500+1.59495
  • 5000+12.020625000+1.56265
库存:4920
IS32FL3265B-ZLA3-TR
  • 1+23.474221+3.05158
  • 10+17.4882910+2.27342
  • 25+15.9850925+2.07801
  • 100+14.33400100+1.86338
  • 250+13.54680250+1.76104
  • 500+13.23020500+1.71989
库存:4920
