IS32LT3129A-ZLA3-TR
IS32LT3129A-ZLA3-TR
    LUMISSIL
    TSSOP20
    UP TO 150MA TRIPLE CHANNEL LED D
IS32LT3129A-ZLA3-TR 数据手册
IS32LT3129A TRIPLE CHANNEL LINEAR LED DRIVER WITH I2C INTERFACE AND FADE ON/OFF February 2020 GENERAL DESCRIPTION FEATURES The IS32LT3129A is a programmable triple channel linear current regulator; two channels of up to 150mA each for LED lighting and a single channel of up to 30mA for illuminating switches. The device operates as a fully configurable theatrical dimming LED driver; External resistors will program the current levels as well as the LED fade ON/OFF ramp rate.    In additional, the I2C interface supports writing/reading function for MCU to select switch type (momentary contact or latched), individually configure the output current levels and fade on/off ramp rate, or get the state of device and the fault flag of open/short circuit and thermal shutdown. An integrated debounce and latch circuit on the channel enable pin (EN1/2) is enabled when the device is configured for a momentary contact switch interface. The other option is to configure the EN pins to accept a static level signal for operation with latched switches. If configured for Internal-PWM-Dimming mode, the integrated PWM source will be triggered by an I2C command. This enables LED dimming without the need for an external PWM input. The I2C command input has a higher priority and will override EN inputs. See Figure 63~69 for the details. The device integrates a 63 step fade ON/OFF algorithm (Gamma correction) which causes the output LED brightness to gradually ramp up to the full source value after the EN1/2 pins are triggered or send I2C commands (when configured for Internal-PWM-Dimming mode). The same controller causes the LED brightness to gradually ramp down to zero if the EN1/2 pins are triggered or send I2C commands (when configured for Internal-PWM-Dimming mode) while the output channel is ON. The fade ramp can be interrupted mid-cycle before completion of the ramp cycle. The IS32LT3129A is targeted at the automotive market with end applications to include map and dome lighting as well as exterior accent lighting. For 12V automotive applications the low dropout driver can support 1 to 3 LEDs per channel. It is offered in a small thermally enhanced eTSSOP-20 package. Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020       Operating voltage range, 5V to 42V 1MHz I2C-compatible interface Dual channel current sources - Individual programmable current via a single external resistor and I2C - Configurable from 20mA to 150mA Single channel 30mA (Max.) current source for switch illumination EN input supports either momentary contact or latched switch - Input is debounced and latched - Lower priority than I2C input - Gamma corrected Fade ON/OFF algorithm - Pull down resistors or I2C set independent fade ON and OFF ramp time Selectable internal PWM source - Internal 220Hz PWM source with Gamma corrected algorithm for automatic dimming the current source Fault Protection: - Fault Reporting  LED strings short  LED strings open  Over temperature thermal shutdown - ISET pin shorted to GND - Over temperature current roll off Operating temperature range from -40°C ~ +125°C AEC-Q100 Qualified APPLICATIONS  Automotive Interior: - Map/Dome light - Puddle lamp in doors - Glove box light - Vanity mirror light 1 IS32LT3129A TYPICAL APPLICATION CIRCUIT VBattery 18 VCC OUT1 OUT2 10 F 8 1 F 47k 2k 2k 470 9 470 10 Micro Controller 7 2 11 Momentary Contact S1 4 S2 3 6,17 Figure 1 OUT3 VIO 1 SCL SDA Backlight LED IS32LT3129A FAULTB EN3 ISET1 AD ISET2 EN1 ISET3 EN2 TSET_UP GND TSET_DN 18 VCC OUT1 OUT2 10 F 8 47k 20 12 RISET1 13 RISET2 14 RISET3 15 RTSET_UP 16 RTSET_DN Typical Application Circuit with Momentary Contact Switch VBattery 1 F 19 2k 2k 470 9 470 10 Micro Controller 7 2 VCC S1 Latched Switch S2 VIO 11 4 3 6,17 Figure 2 OUT3 VIO SCL SDA 19 20 1 Backlight LED IS32LT3129A FAULTB EN3 ISET1 AD ISET2 EN1 ISET3 EN2 TSET_UP GND TSET_DN 12 RISET1 13 RISET2 14 RISET3 15 RTSET_UP 16 RTSET_DN Typical Application Circuit with Latched Switch Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 2 IS32LT3129A PIN CONFIGURATION Package Pin Configuration (Top View) eTSSOP-20 Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 3 IS32LT3129A PIN DESCRIPTION No. Pin Description 1 OUT3 Maximum 30mA output current source for switch backlight LEDs. 2 EN3 Internally deglitch input pin for control of OUT3 current. Pull high (>VIH) to enable OUT3 current. Pull low ( 6V to IOUT< -5mA (Note 3) OUT1/2 limit current (Note 4) VHR= 2V, OUT1/2 sourcing current, VISET1/2= GND -240 -205 -160 OUT3 limit current (Note 4) VHR= 2V, OUT3 sourcing current, VISET3= GND -48 -40 -32 OUT1/2 output current RISET1/2= 15kΩ, VHR= 1V, -40°C< TJ< +125°C (Note 4) -105 -100 -95 OUT3 output current (Note 4) RISET3= 15kΩ, VHR= 1V, -40°C< TJ< +125°C -22 -20 -18 -50mA≤ IOUT1/2≤ -20mA, VHR= 1V, -40°C< TJ< +125°C -8 8 % -150mA≤ IOUT1/2< -50mA, VHR= 1V, -40°C< TJ< +125°C -6 6 % 4 % 6 % 100 μs OUT1/2 absolute current accuracy (Note 4) 400 mA mA OUT1/2 current IOUT1/2= -100mA, VHR= 1V, TJ= 25°C matching in case of the same RISET1/2 value IOUT1/2= -100mA, VHR= 1V, -40°C< TJ< +125°C (Note 4,5) Current slew time μs Current rise/fall between 0%~100%, VTSET= GND Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 45 75 6 IS32LT3129A ELECTRICAL CHARACTERISTICS (CONTINUE) TJ= -40°C ~ +125°C, VCC= 12V, the detail refer to each condition description. Typical values are at TJ= 25°C. Symbol fINTPWM tSW UVLO Parameter Condition Min. Internal PWM frequency Typ. Max. 220 Input pin debounce time (EN1/2 pins and I2C command latency in internal PWM mode) Unit Hz 25 37 50 ms Release from under voltage lock out VCC voltage VCC rising release from UVLO 4.4 4.6 4.8 V Into under voltage lock out VCC voltage VCC falling into UVLO 4.2 4.5 4.7 V TSET_UP, TSET_DN and VIO VTSET Voltage reference of TSET_UP and TSET_DN TACC Fade timing accuracy VIO VIO pin output voltage 1 *Neglecting the RTSET Tolerance* RTSET_UP= 100kΩ, TJ= 25°C -5 V 5 4.3 % V Logic Input EN1/2/3 VIL Input low voltage VIH Input high voltage VIN_HY IPU IPD 0.8 2 Input hysteresis (Note 3) EN1/2 internal pull-up current 150 V V 350 mV EN_M bit= 1, VEN1/2= GND 67 μA EN1/2 internal pull-down current EN_M bit= 0, VEN1/2= 12V 50 μA EN3 internal pull-down current VEN3= 12V 28 μA Protection VSCD OUTx pins short detect voltage Measured at OUTx, voltage falling VSCD_HY OUTx pins short detect voltage hysteresis (Note 3) 220 mV OUTx pins open threshold Measured at (VCC-VOUTx), voltage rising 200 mV Measured at (VCC-VOUTx) (Note 3) 130 mV 110 µs 5 ms VOCD VOCD_HY OUTx pins open hysteresis tFD_OC Open fault detect persistence time DELAY bits= 0001 (Default) tFD_SC Short fault detect persistence time VFAULTB FAULTB pin voltage 1.2 1.8 Sink current= 5mA 22 80 V mV TRO Thermal roll off threshold (Note 3) 145 °C TSD Thermal shutdown threshold Temperature increasing (Note 3) 175 °C THY Thermal shutdown hysteresis Recovery = TSD - THY (Note 3) 30 °C Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 7 IS32LT3129A ELECTRICAL CHARACTERISTICS (CONTINUE) TJ= -40°C ~ +125°C, VCC= 12V, the detail refer to each condition description. Typical values are at TJ= 25°C. Symbol Parameter Condition Min. Typ. Max. Unit 0.8 V I2C Logic Electrical Characteristics (SDA, SCL, AD) VIL Logic “0” input voltage (Note 3) VIH Logic “1” input voltage (Note 3) 2 Input schmitt trigger hysteresis (Note 3) 150 IIL Logic “0” input current IIH Logic “1” input current VHYS V 350 mV VINPUT= 0V (Note 3) 5 nA VINPUT= VIO (Note 3) 5 nA DIGITAL INPUT SWITCHING CHARACTERISTICS (NOTE 3) Symbol Parameter Fast Mode Min. Typ. Fast Mode Plus Typ. Max. Units Max. Min. - 400 - 1000 kHz fSCL Serial-clock frequency tBUF Bus free time between a STOP and a START condition 1.3 - 0.5 - μs tHD, STA Hold time (repeated) START condition 0.6 - 0.26 - μs tSU, STA Repeated START condition setup time 0.6 - 0.26 - μs tSU, STO STOP condition setup time 0.6 - 0.26 - μs tHD, DAT Data hold time - - - - μs tSU, DAT Data setup time 100 - 50 - ns tLOW SCL clock low period 1.3 - 0.5 - μs tHIGH SCL clock high period 0.7 - 0.26 - μs tR Rise time of both SDA and SCL signals, receiving - 300 - 120 ns tF Fall time of both SDA and SCL signals, receiving - 300 - 120 ns Note 2: IOUT output current in case of VCC-VOUT=VHR called IOUT_VHR. IOUT output current in case of VCC-VOUT=2V called IOUT_VHR2V, VHR accuracy is computed as |IOUT_VHR-IOUT_VHR2V|/IOUT_VHR2VVIH) and keep it at high level, after a period of time that exceeds the debounce time (Typ. 37ms) that will cause the corresponding output to be toggled from the OFF condition to the current source condition. When this happens, the corresponding output current gradually ramps up from zero mA to the programmed value (set by RISET1/2 and 05h/06h register) over the time set by the resistor (RTSET_UP) attached to the TSET_UP pin or 03h register. Conversely, if ENx is already kept in high level and the output is in the source condition, the ENx pin is pulled to low level, then the corresponding output current will begin to ramp down towards zero mA in the time period as programmed by the resistor (RTSET_DN) attached to the TSET_DN pin or 04h register. So a regular latched switch can be used in this mode. Debounce – Output control is provided by a debounced switch input, providing an ON/OFF toggle action for various switch or button characteristics. An internal debounce circuit will condition the EN input signal so a single press of the mechanical switch Figure 60 doesn’t appear like multiple presses. The EN input is debounced by typically 37ms. Note: The debounce time applies to both falling and rising edges of the EN signal. EN3 PIN OPERATION The EN3 pin or EN3 bit of 02h register is the enable control of OUT3. There is no fade ON/OFF function as with the EN1/2 pins. EN3 pin is internally pulled down by a 100kΩ resistor to ground. The latency time from EN3 pin pull high over VIH to OUT3 output current rise to 10% is 6µs (Typ.). Float or pull down EN3 to ground to disable OUT3. An external PWM signal driving EN3 pin can implement OUT3 dimming by modulating PWM duty cycle. The recommended PWM signal frequency range is 50Hz-300Hz. The duty cycle can be 0~100%. The output current of the PWM dimming is given by Equation (3): I OUT 3 _ PWM  300  DPWM RISET 3 (3) Where, DPWM is the duty cycle of the PWM. In the meantime, the OUT3_C bits of 02h register can be used to adjust the OUT3 current in 8 steps based on above resistor setting. EN1/2 in Low Pulse Mode (Momentory Contact Switch) Figure 61 EN1/2 in Level Control Mode (Latched Switch) Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 25 IS32LT3129A FADE ON AND FADE OFF DIMMING The OUT1/2 LED fade function can be accomplished in one of two methods; 1) by I2C refreshing the PWM_E bit, or 2) when the EN1/2 pin is toggled. I2C Dimming The PWM_E bit in 07h register will simultaneously control the both OUT1/2 channels. There are two kinds of dimming modes via I2C: External-PWM-dimming and Internal-PWM-Dimming. The different mode is chosen by PWM_M bit in 01h register. PWM_M=1 for External-PWM-dimming mode and PWM_M=0 for Internal-PWM-Dimming mode. External-PWM-dimming (PWM_M=1): In this mode, the OUT1/2 can be driven by an external I2C signal refreshing PWM_E bit to accomplish both channels simultaneously dimming. The integrated gamma correction and fade ON/OFF ramp functions are disabled when actively driving this bit. To get better dimming ratio, the recommended refreshing PWM_E bit frequency range is 50Hz-300Hz. The duty cycle can be 0-100%. The output current of the PWM dimming is given by Equation (4): Figure 62 I OUT 1/ 2  1500  DPWM RISET 1/ 2 (4) Where, DPWM is the duty cycle of the external I2C signal refreshing PWM_E bit. Please refer to Figure 35~40 for the delay time of I2C command to current change edge. Internal-PWM-Dimming (PWM_M=0): In this mode, the integrated PWM source is operational. PWM_E=1 can trigger this PWM source. When PWM_E is changed the logic state and after a period of time that exceeds the debounce time (37ms), the both output current will either gradually ramp up from zero mA to the programmed value (set by RISET1/2 and 05h/06h register) over the time set by the resistor (RTSET_UP) attached to the TSET_UP pin (or 03h register), or gradually ramp down from programmed value to zero mA over the time set by the resistor (RTSET_DN) attached to the TSET_DN pin (or 04h register). The ramping up (or down) is accomplished by the internal 220Hz PWM source digitally modulating the both output current simultaneously with 63 steps gamma correction, that will perform an extremely visual linear light to human eye. Ineternal-PWM-Dimming for OUT1/2 THE PRIORITY OF EN1/2 AND PWM DIMMING EN1/2 pins can individually control the OUT1/2 while PWM_E bit can simultaneously control the both outputs. The Figure 63~69 lists some critical priority logic of them: Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 26 IS32LT3129A PWM_E Bit Figure 63 Priority Logic 1 of EN1/2 in Low Pulse Mode Figure 64 Priority Logic 2 of EN1/2 in Low Pulse Mode Figure 65 Priority Logic 3 of EN1/2 in Low Pulse Mode PWM_E Bit PWM_E Bit PWM_E Bit Figure 66 Priority Logic 1 of EN1/2 in Level Control Mode Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 27 IS32LT3129A Figure 67 Priority Logic 2 of EN1/2 in Level Control Mode Figure 68 Priority Logic 3 of EN1/2 in Level Control Mode Figure 69 Priority Logic 4 of EN1/2 in Level Control Mode UNDERVOLTAGE LOCKOUT IS32LT3129A integrates an undervoltage lockout function to prevent mis-operation of the device during low input voltage conditions. Should the VCC pin voltage fall below 4.5V (Typ.), the device will turn OFF the current source and maintain the EN latch status as long as the VCC pin voltage remains above 4.0V (Typ.). An external capacitor (Figure 70) is necessary to help maintain the VCC pin voltage >4.0V (Typ.) and to supply current to the device status latch circuitry. However, should the voltage drop below 4.0V (Typ.), the internal latch will be reset to the power on default status (LED initial off state). Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 The current source will be turned ON when the input voltage is re-applied and the VCC pin rises above 4.6V (Typ.). Figure 70 Capacitor For Latch Status SETTING THE FADE TIME The fade time can be configured by either the external resistors or I2C register, which is decided by the FIT and FOT bit of 01h register. 28 IS32LT3129A When FIT (or FOT) bit is set to “1”, the fade time is programmed by 03h (or 04h) 8 bits register with each 7ms per step over time range of 7ms~1785ms. When FIT (or FOT) bit is set to “0”, the fade time is programmed by two external programming resistors; RTSET_UP and RTSET_DN. The RTSET_UP connected to the TSET_UP pin configures the fade ramp ON time while the RTSET_DN connected to the TSET_DN pin configures the fade ramp OFF time. The fade time (ON or OFF) is programmable by Equation (5): t  RTSET  2.5s (5) For example, RTSET=100kΩ, Fade ON/OFF time is about 0.25s. Note: In order to get the optimized effect, the recommended fading time is between 1.5s (RTSET= 600kΩ) and 0.25s (RTSET= 100kΩ). If either the TSET_UP or TSET_DN pin is tied directly to GND or 03h/04h register set to “0000 0000”, the corresponding fade function is canceled and the ramp time is about 75µs, or “instant on”. However, the debounce feature of the EN pin is not disabled. Table 2 63 Gamma Steps Correction C(0) C(1) C(2) C(3) C(4) C(5) C(6) C(7) 0 2 4 6 8 10 12 16 C(8) C(9) C(10) C(11) C(12) C(13) C(14) C(15) 20 24 28 32 36 42 48 54 C(16) C(17) C(18) C(19) C(20) C(21) C(22) C(23) 60 66 72 80 88 96 104 112 C(24) C(25) C(26) C(27) C(28) C(29) C(30) C(31) 120 130 140 150 160 170 180 194 C(32) C(33) C(34) C(35) C(36) C(37) C(38) C(39) 208 222 236 250 264 282 300 318 C(40) C(41) C(42) C(43) C(44) C(45) C(46) C(47) 336 354 372 394 416 438 460 482 C(48) C(49) C(50) C(51) C(52) C(53) C(54) C(55) 504 534 564 594 624 654 684 722 C(56) C(57) C(58) C(59) C(60) C(61) C(62) 760 798 836 874 914 956 1000 1000 900 GAMMA CORRECTION Gamma correction, also known as gamma compression or encoding, is used to encode linear luminance to match the non-linear characteristics of display. Gamma correction will vary the step size of the current such that the fading of the light appears linear to the human eye. Even though there may be 1000 linear steps for the fading algorithm, when gamma corrected, the actual number of steps could be as low as 63. 800 LED Current Duty In order to perform a better visual LED breathing effect we recommend using a gamma corrected value to set the LED intensity. This results in a reduced number of steps for the LED intensity setting, but causes the change in intensity to appear more linear to the human eye. 700 600 500 400 300 200 100 0 0 5 10 15 20 25 30 35 40 45 50 55 60 62 Gamma Steps Figure 71 Gamma Correction (63 Steps) FAULT DETECTION When VCC voltage exceeds the voltage level which is set by F_UVLO bits in 08h register, the LED open fault detection is enabled. The intention is to prevent false fault reporting during abnormal VCC condition. Such as power up or EMS test condition. An output open circuit fault is detected if the voltage of VCC to OUTx drops below open circuit detection threshold VOCD (Typ. 200mV) and remains for tFD_OC (programmed by DELAY bits in 08h register). The channel (OUT1/2/3) will keep normal sourcing but the corresponding output open circuit flag bit in 07h register will be set to “1” to report the fault and FAULTB pin will be pulled low. When the open condition is removed, the corresponding output open circuit flag bit in 07h register will be reset to “0” and FAULTB pin will recovery to high impedance. Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 29 IS32LT3129A An output shorted to GND fault is detected if the output voltage on a channel drops below the low voltage threshold VSCD (Typ. 1.8V) and remains below the threshold for tFD_SC (Typ. 5ms). The channel (OUT1/2/3) with the short condition will reduce its output current to 4mA and set the corresponding output short circuit flag bit in 07h register to “1” and FAULTB pin will be pulled low. When the short condition is removed, the output current will recover to original value and the corresponding output short circuit flag bit in 07h register will be reset to “0” and FAULTB pin will recovery to high impedance. The FAULTB pin is an open drain structure. When a fault is asserted, the pin will change from high impedance to pull low state. If it is externally connected to a pull-up resistor, it will be at the pull-up voltage after fault is released. The detect action and FAULTB pin reporting of the open/short circuit can be disabled by 0Ah register. A FAULTB pin assertion of open detection can be delayed that can be set by DELAY bits in 08h register. When the ISET pin is shorted to GND and output current is larger than limit value, about 205mA for OUT1/2 and 40mA for OUT3, the output current will be clamped. Once the short fault condition is removed, the output current will recover to its original value. OVERTEMPERATURE PROTECTION The device features an integrated thermal rollback feature which will reduce the output current in a linear fashion if the silicon temperature exceeds 145°C (Typ.). In the event that the die temperature continues to increase, the device will enter thermal shutdown if the temperature exceeds 175°C. The FAULTB pin reporting of the thermal shutdown protection can be disabled by TSDREN bit in 0Ah register. THERMAL CONSIDERATIONS The package thermal resistance, θJA, determines the amount of heat that can pass from the silicon die to the surrounding ambient environment. The θJA is a measure of the temperature rise created by power dissipation and is usually measured in degree Celsius per watt (°C/W). The junction temperature, TJ, can be calculated by the rise of the silicon temperature, ∆T, the power dissipation, PD, and the package thermal resistance, θJA, as in Equation (6): 3 PD  VCC  I CC   (VCC  VLEDx )  I OUTx and, TJ  TA  T  TA  PD   JA When operating the chip at high ambient temperatures, or when driving maximum load current, care must be taken to avoid exceeding the package power dissipation limits. The maximum power dissipation can be calculated using the following Equation (8): PD  PD ( MAX )  THERMAL SHUTDOWN In the event that the die temperature exceeds 175°C, the output channel will go to the “OFF” state and TSD bit in 07h register will be set to “1” and FAULTB pin will be pulled low. At this point, the IC presumably begins to cool off. Any attempt to toggle the channel back to the source condition before the IC cooled to < 145°C will be blocked and the IC will not be allowed to restart. Once restart, the TSD bit in 07h register will be reset to “0” and FAULTB pin will recovery to high impedance. 125C  25C (8)  JA So, PD  125C  25C  2.94W 34C / W Figure 72, shows the power derating of the IS32LT3129A on a JEDEC board (in accordance with JESD 51-5 and JESD 51-7) standing in still air. 3.5 eTSSOP-20 Power Dissipation (W) The thermal rolloff function can be disabled by the TEN bit in 01h register. (7) Where ICC is the IC quiescent current, VCC is the supply voltage, VLED is the voltage across VCC to OUT and TA is the ambient temperature. THERMAL ROLLOFF The output current will be equal to the set value as long as the die temperature of the IC remains below 145°C (Typ.). If the die temperature exceeds this threshold, the output current of the device will begin to reduce at a rate of 3.8%/°C until 5% of IOUT and turn off after this current level. (6) x 1 3 2.5 2 1.5 1 0.5 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 Temperature (°C) Figure 72 Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 Dissipation Curve 30 IS32LT3129A The thermal resistance is achieved by mounting the IS32LT3129A on a standard FR4 double-sided printed circuit board (PCB) with a copper area of a few square inches on each side of the board under the IS32LT3129A. Multiple thermal vias, as shown in Figure 73, help to conduct the heat from the exposed pad of the IS32LT3129A to the copper on each side of the board. The thermal resistance can be reduced by using a metal substrate or by adding a heatsink or thicker copper plane. 1.2mm 0.3mm Figure 73 Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 Board Via Layout For Thermal Dissipation 31 IS32LT3129A CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 74 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 32 IS32LT3129A PACKAGE INFORMATION eTSSOP-20 Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 33 IS32LT3129A RECOMMENDED LAND PATTERN eTSSOP-20 Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. user’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 34 IS32LT3129A REVISION HISTORY Revision A Detail Information Initial release Lumissil Microsystems – www.lumissil.com Rev. A, 01/14/2020 Date 2020.01.07 35
IS32LT3129A-ZLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32LT3129A-ZLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32LT3129A-ZLA3-TR
  • 1+20.259301+2.62599
  • 10+14.9739910+1.94092
  • 25+13.6634225+1.77104
  • 100+12.21907100+1.58383
  • 250+11.53059250+1.49459
  • 500+11.18582500+1.44990
库存:2493
IS32LT3129A-ZLA3-TR
  • 2500+10.413772500+1.34983
  • 5000+10.196495000+1.32166
  • 7500+10.087717500+1.30756
库存:2493
