IS32LT3123-ZLA3-TR
IS32LT3123-ZLA3-TR
    LUMISSIL
    TSSOP24
    IC 4-CH 40V HIGH CURRENT LED DRI
IS32LT3123-ZLA3-TR 数据手册
IS32LT3123 QUAD CHANNEL EXTERNAL NMOS FET HIGH CURRENT AUTOMOTIVE LED CONTROLLER WITH INTERNAL PWM DIMMING May 2020 GENERAL DESCRIPTION FEATURES The IS32LT3123 is a quad channel linear controller capable of accurately regulating LED current with external NMOS FETs. It integrates PWM dimming for two LED brightness levels for RCL (Rear Combination Lamp) or DRL (Daytime Running Lamp) applications. It is fully programmable with two LED brightness levels for the different intensity requirements, such as “Stop” (full brightness) and “Tail” dim (PWM dimming). A logic level at the PWMB pin is used to switch between the two brightness levels. A logic high provides the highest intensity output, while a logic low utilizes an internally generated PWM signal to reduce the intensity of the LEDs’ light output.        Multiple devices also can be connected in parallel in a master-slave structure for larger lighting applications. For added system reliability, the IS32LT3123 integrates fault detection circuitry for LED open/short circuit, input over voltage and over temperature conditions. The FAULTB pin is dedicated to the fault conditions reporting and the MODE pin can control the action of the device in case of a fault condition.   The device also supports the NTC resister to monitor the LED string temperature. In case of the temperature exceeds the setting threshold, the device will reduce the drive current to protect the LED string. The device package is an eTSSOP-24 with exposed pad for enhanced thermal dissipation.   Low side external NMOS FETs support high output current with independent current setting One resistor to simultaneously adjust all channels for LED binning 200mV reference feedback voltage for high efficiency ±4% current accuracy over -40°C ~125°C 5.0V to 40V supply voltage PWMB voltage input to select between full brightness and PWM dimming Flexible LED PWM dimming options - Internal PWM dimming set by resistors  Programmable duty cycle, 5%~95%  Programmable frequency, 100Hz~1kHz - External PWM signal input dimming - Analog voltage input for PWM dimming PWM slew rate control on each output to optimize EMI performance Robust fault protection - Fault reporting  LED string open/short  Thermal shutdown - LED string over temperature thermal rolloff - Input over voltage current derating - Controller junction over temperature thermal rolloff Multiple parallel IC operation for higher number of strings with fault condition and PWM dimming sync AEC-Q100 Qualified APPLICATIONS       Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 Automotive and avionic lighting Rear combination light (STOP/TAIL lights) Center high mounted stop light Position light Daytime running light (DRL) Turn light 1 IS32LT3123 TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit of Internal PWM Dimming Figure 2 Typical Application Circuit of External PWM Dimming Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 2 IS32LT3123 Figure 3 Typical Application Circuit of Analog Input PWM Dimming Connected to VIN of other slaves D1 Power Supply -1 (PWM Dimming) D2 Power Supply -2 (Full Brightness) CVCC 1µF RPWM1 12 11 12 VIN PWMB DET1 GATE1 RPWM2 CVDD 1µF 2 RTAIL1 RTH1 FB1 VDD Connected to master device PWMB pin 24 23 Q1 22 RTH2 VTH DET4 5 RTAIL2 CTAIL 1nF RNTC NTC CNTC 1nF MODE FAULTB CADJR 10nF 6 RADJR FB4 MASTER 4 *Placed close to LED GATE4 TAIL 7 ADJR PWMOUT PWMIN Connected to master device VTH pin 13 14 1 10 VDD PWMB VTH 5 Connected to master device NTC pin IS32LT3123 GATE4 TAIL NTC FB4 13 14 7 MODE PWMOUT GND Q4 15 RFB4 CNTC 1nF ADJR Q1 22 RFB1 PWMIN RADJR RFPWM 24 23 SLAVE #1 4 CADJR 10nF 6 8 FB1 DET4 RFB4 RFAULTB DET1 VDD CVTH 1nF Q4 9 GND 3 VDD 15 VIN GATE1 RFB1 IS32LT3123 11 CVDD 1µF 2 RTRO 3 CVCC 1µF FAULTB 1 VDD 9 8 10 Connected to FAULTB of other slaves Connected to PWMIN of other slaves Figure 4 Typical Application Circuit of Several Devices in Parallel (one master with several slaves) Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 3 IS32LT3123 PIN CONFIGURATION Package Pin Configuration (Top View) eTSSOP-24 Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 4 IS32LT3123 PIN DESCRIPTION No. Pin Function 1 MODE MODE pin decides the fault mode. Tie to VDD or GND. Do not leave unconnected. 2 VDD Internal LDO output. Connect to GND through a 1µF X7R capacitor which should be placed as close to VDD pin as possible. It is capable to drive external circuitry with minimum 14mA current capability. 3 VTH Voltage at this pin sets the VIN over voltage current derating threshold and the VIN threshold for open LED fault detect. 4 NTC Connect the NTC resistor divider to set the temperature threshold for the LED string temperature monitor. As long as the temperature exceeds the threshold, the reference voltage will be derated linearly according to NTC pin voltage. 5 TAIL Connect to an external DC voltage below 3.7V for internal PWM mode to adjust operating duty cycle. Connect TAIL pin to VDD for external PWM mode. PWM duty cycle is controlled by the PWM signal on PWMIN pin. 6 ADJR Connect a proper value resistor from this pin to GND to set the Internal reference voltage. 7 GND Ground pin. 8 PWMIN In internal PWM mode (TAIL pin voltage < 3.7V), the frequency of PWM is set by a resistor from PWMIN to GND. In external PWM mode (TAIL pin is connected to VDD), PWM frequency and duty cycle are determined by external PWM signal on PWMIN pin. 9 PWMOUT PWM signal output pin. In internal PWM mode, the output PWM signal is internal PWM generator. In external PWM mode, the output PWM signal is sync with PWMIN pin. FAULTB Open drain I/O diagnostic pin. Active low output driven by the device when it detects a fault condition. As an input (MODE pin high), this pin will accept an externally generated FAULTB signal to disable the device output to satisfy the “One-Fail-All-Fail” function. Note this pin requires an external pull up resistor (RFAULTB). 11 PWMB Full brightness mode select input. When PWMB pin is low, the device is in PWM dimming mode and the output is dimming by the internal or external PWM signal. When PWMB pin is high, the device is in full brightness mode, NMOS FET current 100% duty cycle operation. And the internal and external PWM signal are overridden. 12 VIN Power input for the IC. 24,19,18,13 DET1/2/3/4 Detect NMOS FET drain voltage for channel 1/2/3/4 LED string open/short faults. If any channel is unused, connect its DET pin to used DET pin. For example, if channel 1/2 are used and channel 3/4 are not used. DET1/2 is connected to the drain of their NMOS FETs. DET3/4 can be connected to DET1 or DET2. 23,20,17,14 GATE1/2/3/4 Gate driver for external NMOS FET1/2/3/4. 22,21,16,15 FB1/2/3/4 Current sense for channel 1/2/3/4. Connect sense resistors to independently set current level of channel 1/2/3/4. Thermal Pad Must be connected to GND with sufficient copper plate for heat sink. 10 Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 5 IS32LT3123 ORDERING INFORMATION Automotive Range: -40°C to +125°C Order Part No. Package QTY/Reel IS32LT3123-ZLA3-TR eTSSOP-24, Lead-free 2500 Copyright  ©  2020  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 6 IS32LT3123 ABSOLUTE MAXIMUM RATINGS (Note 1) Voltage at VIN Voltage at PWMB, FAULTB, DET1~4, PWMIN Voltage at GATE1~4, FB1~4, PWMOUT Voltage at VDD, VTH, ADJR, NTC, TAIL, MODE Operating temperature, TA=TJ Storage temperature, TSTG Junction temperature, TJMAX Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JESD 51-8), θJP ESD (HBM) ESD (CDM) -0.3V ~ +42V -0.3V ~ +VIN+0.3V -0.3V ~ +20V -0.3V ~ +7V -40°C ~ +150°C -65°C ~ +150°C +150°C 28.1°C/W 8.55°C/W ±2kV ±750V Note 1: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS Valid at VIN= 7V ~ 19V “●” symbol indicates specifications across the full operating temperature range with TA= TJ= -40°C to +125°C, other specifications are at TA= TJ= 25°C; unless noted otherwise. Symbol Parameter Conditions Min. Typ. Max. Unit 40 V Input Supply VIN Operating input voltage range ● 5.0 VIN_UV VIN undervoltage release VIN rising 4.5 V VIN_UVHY VIN undervoltage lockout hysteresis IC disabled 0.15 V IIN VIN operational current VNTC=VVTH=VTAIL=VDD, PWMB=High tON Startup time VIN>7V, CVDD= 10μF, VFB= 20mV, PWMB=High ● 13 200 mA µs Current Regulation VREFMAX Maximum reference voltage on FB pins VVTH=VNTC=VADJR=VDD VREFDR VIN over voltage derating for reference voltage VVTH= 2V, VNTC=VADJR=VDD VIN≥ 26V ErrVREF Matching between FB voltage (Note 2) VVTH=VNTC=VADJR=VDD VREFADJR Reference voltage adjusted by ADJR pin VVTH=VNTC=VDD, RADJR=2kΩ ● 122 VDD pin voltage output IVDD= 10mA ● 5.0 ● 14 VDD IDD_LIM VDD pin output current limit Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 ● VVTH=VNTC=VADJR=VDD 192 200 208 194 200 206 51 mV % 2 % 132 142 mV 5.25 5.5 V mA 7 IS32LT3123 ELECTRICAL CHARACTERISTICS (CONTINUE) Valid at VIN= 7V ~ 19V “●” symbol indicates specifications across the full operating temperature range with TA= TJ= -40°C to +125°C, other specifications are at TA= TJ= 25°C; unless noted otherwise. Symbol Parameter Conditions Min. Typ. Max. Unit 8 V 0.2 V Gate Driver VGATEH GATE high-level output VIN= 12V, PWMIN=High, VFB= 150mV, VTAIL= VDD VGATEL GATE low-level output PWMIN= Low, PWMB=Low VGATED GATE driver dropout VIN= 7V, VFB= 150mV, measured as (VIN - VGATE) 1.65 V IGPU Gate pull-up current VFB= 180mV, VGATE= 0V, VIN= 7V -0.92 mA IGPD Gate pull-down current VFB= 220mV, VGATE= 7V, VIN= 7V 8.8 mA CGISS External NMOS FET gate capacitance range (Note 5) For stable operation tPD Propagation delay (Note 5) Delay from PWMIN to PWMOUT pin, TAIL connected to VDD Internal PWM signal frequency External RFPWM= 30kΩ, across PWMIN to GND fPWM DPWM7 PWM duty cycle DPWM90 tDPWM 6 250 2000 0.1 ● pF µs 180 200 220 VTAIL driven by resistor divider from VDD, VTAIL/VDD= 0.093, RFPWM= 30kΩ 6.3 7 7.7 VTAIL driven by resistor divider from VDD, VTAIL/VDD= 0.612, RFPWM= 30kΩ 87 Hz % Delay time between PWMIN rising Delay time between PWM edge to 20% of FB rising edge to 20% of FB 90 93 23 us tSR Current slew time FB rising from 20% to 90% levels, for internal reference ramp 49 70 91 µs tSF Current slew time FB falling from 90% to 20% levels, for internal reference ramp 49 70 91 µs Rise time and fall time mismatch between four strings (Note 3,4) Rise and fall time mismatch between 20% and 90% levels in all strings 5 % tSRMS Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 8 IS32LT3123 ELECTRICAL CHARACTERISTICS (CONTINUE) Valid at VIN= 7V ~ 19V “●” symbol indicates specifications across the full operating temperature range with TA= TJ= -40°C to +125°C, other specifications are at TA= TJ= 25°C; unless noted otherwise. Symbol Parameter Conditions Min. Typ. Max. Unit 0.8 V Logic Pins VIL MODE, PWMIN, FAULTB pins input low voltage Below VIL level, input voltage considered as logic LOW ● VIH MODE, PWMIN, FAULTB pins input high voltage Above VIH level, input voltage considered as logic HIGH ● VOL FAULTB, PWMOUT pins output low voltage IOL= 1mA ● VOH PWMOUT pin output high voltage IOH= –1mA VILF PWMB pin input low voltage VIHF PWMB pin input high voltage 2 V 0.4 V ● 4 V Below VILF level, input voltage on PWMB pin will disable PWM dimming mode ● 0.85 1.15 V Above VIHF level, input voltage on PWMB pin will enable PWM dimming mode ● 1.06 1.44 V 21.7 V Protection VINth(L) Input over voltage derates VFB by 10% VVTH= 2V VINthd Input over voltage derating range (VIN_180mV to VIN_120mV) VREF drops from 180mV to 120mV VSCV VIN to drain short detect voltage Measured as (VIN - VDET) ● 0.5 0.8 1.1 V VOCV Open LED fault detect voltage Measured at DET, VIN>VOCVEN ● 0.2 0.25 0.3 V VOCVEN Open LED detect enable voltage VVTH= 2V VNTC10 NTC derates VFB by 10% VNTC90 NTC derates VFB by 90% TJH Thermal rolloff activation temperature (Note 5) TJL 19.7 20.7 2.16 V 10 1.9 2.0 V 2.12 V 0.43 V VFB derated by 10% 148 °C Thermal rolloff low-current temperature (Note 5) VFB derated by 65% 163 °C TSD Over temperature shutdown (Note 5) Temperature increasing 170 °C TSDHY Over temperature hysteresis (Note 5) Recovery= TSD -TSDHY 30 °C Note 2: Reference matching is defined as: (VFB(max) – VFB(min)) / VFB(AVG) . Where VFB(AVG) is the average of all VFB. Note 3: Rise Time to Fall Time Matching is defined as the maximum difference between the rise time and the fall time of the same string. Note 4: Rise Time to Fall Time Mismatch between all strings is defined as the maximum ratio of the difference between either the rise time or the fall time to the average of the rise time or fall times between all strings. Note 5: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 9 IS32LT3123 FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 10 IS32LT3123 TYPICAL PERFORMANCE CHARACTERISTICS 12 11.5 12 VIN = 12V VNTC = VVTH = VTAIL = VDD PWMB = High VNTC = VVTH = VTAIL = VDD PWMB = High TA = 25°C 11.5 11 IIN (mA) IIN (mA) 11 10.5 10.5 10 9.5 10 9 9.5 9 -40 8.5 8 -25 -10 5 20 35 50 65 80 95 110 125 7 10 13 16 IIN vs. Temperature Figure 6 VDD (V) VDD (V) 5 4.5 34 37 40 31 34 37 40 31 34 37 40 IIN vs. Supply Voltage 5.0 4.5 -25 -10 5 20 35 50 65 80 95 110 4.0 125 7 10 13 16 Figure 7 19 22 25 28 Supply Voltage (V) Temperature (°C) VDD vs. Temperature Figure 8 VDD vs. Supply Voltage 150 150 VIN = 12V RADJR = 2kΩ VNTC = VVTH = VTAIL = VDD RADJR = 2kΩ VNTC = VVTH = VTAIL = VDD TA = 25°C 145 140 140 VREF (mV) VREF (mV) 31 5.5 5.5 135 130 135 130 125 125 120 -40 28 TA = 25°C VIN = 12V 145 25 6.0 6 4 -40 22 Supply Voltage (V) Temperature (°C) Figure 5 19 -25 -10 5 20 35 50 65 80 95 110 125 120 7 10 13 16 VREF vs. Temperature Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 22 25 28 Supply Voltage (V) Temperature (°C) Figure 9 19 Figure 10 VREF vs. Supply Voltage 11 IS32LT3123 215 215 205 200 195 190 185 -40 RADJR = 5kΩ VNTC = VVTH = VTAIL = VDD TA = 25°C 210 VREFMAX (mV) VREFMAX (mV) 210 VIN = 12V RADJR = 5kΩ VNTC = VVTH = VTAIL = VDD 205 200 195 190 -25 -10 5 20 35 50 65 80 95 110 185 125 7 10 13 16 Temperature (°C) Figure 11 VREFMAX vs. Temperature Figure 12 Duty Cycle (%) Dury Cycle (%) 31 34 37 40 34 37 40 VREFMAX vs. Supply Voltage 9 9 6 3 8 7 6 -25 -10 5 20 35 50 65 80 95 110 5 125 7 10 13 16 Temperature (°C) Figure 13 19 22 25 28 31 Supply Voltage (V) Duty Cycle vs. Temperature (Internal PWM) Figure 14 100 Duty Cycle vs. Supply Voltage (Internal PWM) 100 90 VIN = 12V VTAIL /VDD = 0.612 80 70 60 50 VTAIL /VDD = 0.362 40 60 50 40 30 20 20 10 10 -10 5 20 35 50 65 80 95 110 125 VTAIL /VDD = 0.612 70 30 -25 TA = 25°C 80 Duty Cycle (%) Duty Cycle (%) 28 VTAIL /VDD = 0.093 TA = 25°C 12 0 -40 25 10 VIN = 12V VTAIL /VDD = 0.093 90 22 Supply Voltage (V) 15 0 -40 19 0 VTAIL /VDD = 0.362 7 10 Temperature (°C) Figure 15 Duty Cycle vs. Temperature (Internal PWM) Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 13 16 19 22 25 28 31 34 37 40 Supply Voltage (V) Figure 16 Duty Cycle vs. Supply Voltage (Internal PWM) 12 IS32LT3123 220 220 RFPWM = 30kΩ TA = 25°C VIN = 12V RFPWM = 30kΩ 210 fPWM (Hz) fPWM (Hz) 210 200 190 200 190 180 -40 -25 -10 5 20 35 50 65 80 95 110 180 125 7 10 13 16 22 25 28 31 34 37 40 110 125 Supply Voltage (V) Temperature (°C) Figure 17 19 fPWM vs. Temperature (Internal PWM) fPWM vs. Supply Voltage (Internal PWM) Figure 18 5 23 VVTH = 2V 4.9 22 4.8 21 VIN_UV (V) VINth(L) (V) 4.7 20 19 18 Rising 4.6 4.5 4.4 Falling 4.3 17 4.2 16 15 -40 4.1 -25 -10 5 20 35 50 65 80 95 110 4 -40 125 -25 -10 5 Temperature (°C) Figure 19 35 50 65 80 95 Temperature (°C) VINth(L) vs. Temperature Figure 20 12.0 VIN_UV vs. Temperature 100 VVTH = 2V VIN = 12V TA = 25°C 90 11.5 80 Duty Cycle (%) 11.0 VOCVEN (V) 20 10.5 10.0 9.5 70 60 50 40 30 9.0 20 8.5 8.0 -40 10 -25 -10 5 20 35 50 65 80 95 110 125 0 0 0.5 Temperature (°C) Figure 21 VOCVEN vs. Temperature Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 1 1.5 2 2.5 3 3.5 4 VTAIL (V) Figure 22 Duty Cycle vs. VTAIL (Internal PWM) 13 IS32LT3123 12 6 TA = 25°C 11.5 5.6 VOCVEN / VVTH VINth(L) / VVTH TA = 25°C 5.8 11 10.5 10 5.4 5.2 5 4.8 4.6 4.4 9.5 4.2 9 1 1.5 2 2.5 3 3.5 4 4 1 1.5 2 2.5 VVTH (V) Figure 23 3.5 4 VVTH (V) VINth(L) /VVTH vs. VVTH Figure 24 250 VOCVEN /VVTH vs. VVTH 250 VIN = 12V RADJR = 5kΩ TA = 25°C VVTH = 2V TA = 25°C 230 210 VREF (mV) 200 VREF (mV) 3 150 100 190 170 150 130 110 50 90 70 0 0 0.5 1 1.5 2 50 2.5 16 18 20 VNTC (V) Figure 25 24 26 28 30 Supply Voltage (V) VREF vs. VNTC Figure 26 VIN OVP 250 1000 VIN = 12V VTAIL = 2V TA = 25°C 900 Output Current (mA) 800 700 fPWM (Hz) 22 600 500 400 300 200 VIN = 12V TA = 25°C External PWM =100Hz, 500Hz, 1kHz 150 100 50 200 100 0 5 15 25 35 45 55 65 75 0 0 10 20 30 RFPWM (kΩ) Figure 27 fPWM vs. RFPWM (Internal PWM) Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 40 50 60 70 80 90 100 PWM Duty Cycle (%) Figure 28 External PWM Dimming 14 IS32LT3123 250 220 VIN = 12V VNTC = VVTH = VTAIL = VDD TA = 25°C 200 VIN = 12V VNTC = VVTH = VTAIL = VDD RADJR = 5kΩ 200 180 140 150 VREF (mV) VREF (mV) 160 100 120 100 80 60 50 40 20 0 0 0.5 1 1.5 2 2.5 RADJR (kΩ) Figure 29 VREF vs. RADJR Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 3 3.5 0 125 130 140 150 160 170 180 Temperature (°C) Figure 30 Thermal Rolloff 15 IS32LT3123 APPLICATION INFORMATION The IS32LT3123 is a programmable linear controller capable of regulating high constant current in four LED strings with external NMOS FETs. A dedicated pin (PWMB) is able to switch the output current between full brightness mode (high current) and PWM dimming mode (low current) by an external logic level. In the PWM dimming mode, the PWM dimming can be either the internal PWM generator, whose duty cycle and frequency are programmed by TAIL and PWMIN pins, or an external PWM signal fed on PWMIN pin. Mounting different value resistors on ADJR pin can fine tune the output peak current for binning purpose. With a NTC resistor divider placed close to LED strings, IS32LT3123 can monitor the temperature of the LED strings and realize current derating if the temperature exceeds the setting thermal threshold, which effectively prevents the LED strings from thermal runaway damage. A settable input over voltage detection is provided to sense the input voltage and reduce the output current if the input voltage exceeds the targeted threshold. IS32LT3123 also integrates fault detection and protection circuitry for the LED string open/short and over temperature fault conditions and reports fault conditions by a dedicated pin (FAULTB). In the case of fault conditions, the MODE pin can control the action to be either “one fail all fail” or “one fail all on”. The FAULTB pins of multiple devices can be tied together for fault condition sharing to achieve simultaneous “one fail all fail”. VREF can be controlled by ADJR resistor (RADJR), NTC thermal rolloff protection, input over voltage protection and thermal rolloff protection actions. If RADJR≥3kΩ and no protection actions, VREF is maximum value, VREFMAX (Typ. 0.2V). The feedback resistor value can be computed using the following: RFB  VREFMAX I OUT _ FULL (1) Where IOUT_FULL is output current of full brightness mode (without PWM dimming) in Amp and RFB is in Ω. It is recommend that RFB be a 1% accuracy resistor with good temperature characteristic to ensure stable and precise output current. When the desired current is high, the power rating also should be considered. The maximum power dissipation on the RFB resistor is calculated by: PRFB  VREFMAX  I OUT _ FULL (2) A single high wattage resistor or several small wattage resistors in parallel can be used to sustain the power dissipation. Driver + UNDER VOLTAGE LOCKOUT (UVLO) IS32LT3123 features an under voltage lockout (UVLO) function on the VIN pin to prevent misoperation at too low input voltages. UVLO threshold is an internally fixed value and cannot be adjusted. The device is enabled when the VIN voltage exceeds VIN_UV (Typ. 4.5V), and disabled when the VIN voltage falls below (VIN_UV-VIN_UVHY) (Typ. 4.35V). LINEAR REGULATOR VDD The device incorporates a linear regulator (VDD) output with a minimum 14mA current capability to power external circuitry. It requires a low ESR, X7R type ceramic capacitor from VDD pin to GND for proper operation; this capacitor must be placed as close to VDD pin as possible. To drive the external circuitry, the recommended capacitor value is 1µF. Figure 31 Constant Current Regulation If any channel is unused, connect its FB pin to GND and leave its GATE pin floating. To avoid false protection triggering, its DET pin must be tied to one of the used channel’s DET pin as Figure 32. FB2 GATE2 OUTPUT CURRENT SETTING The IS32LT3123 provides 4 channels of low-side current drive via 4 external NMOS FETs. The negative feedback loops drive the GATEs of NMOS FETs to maintain the current feedback voltage of FB pins equal to the internal reference voltage, VREF. All channels share the same reference voltage source. So VREF decides the output current. The regulated maximum LED current of each NMOS FET is individually set by its corresponding feedback resistor (RFB). As Figure 31. Lumissil Microsystems – www.lumissil.com Rev. A, 05/06/2020 DET2 IS32LT3123 DET1 GATE1 FB1 Figure 32 Unused Channel (CH1 Used and CH2 Unused) 16 IS32LT3123 CURRENT ADJUSTMENT BY ADJR The ADJR pin is a dedicated pin for output current fine tuning. Connecting a proper range value resistor, RADJR, from this pin to GND can adjust the output current, which can be used for LED binning or output power ranking purpose. As Figure 31, there is a precise constant current source, IADJR (typ. 1mA), inside ADJR pin. When RADJR is connected, IADJR going through this resistor creates a voltage drop on AJDR pin which is detected by the internal Reference Voltage Generator circuit to generate the internal reference voltage, VREF, for output current regulation. If RADJR value is greater than or equal to 3kΩ, the VREF is clamped at maximum value, VREFMAX (typ. 0.2V). The output current will be the maximum setting value, IOUT_FULL in Equation (1). RADJR. Once VNTC
IS32LT3123-ZLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32LT3123-ZLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32LT3123-ZLA3-TR
  • 1+11.737631+1.52534
  • 10+8.5418010+1.11003
  • 25+7.7404425+1.00589
  • 100+6.85275100+0.89054
  • 250+6.43026250+0.83563
  • 500+6.17506500+0.80247
  • 1000+5.965241000+0.77520
库存:7294
IS32LT3123-ZLA3-TR
  • 2500+6.115072500+0.79467
库存:7294
