051AAA225A-205Y
051AAA225A-205Y
    SENSATA(森萨塔)
    Cylinder
    THERMOSTAT 107DEG C SPST-NC CYL
051AAA225A-205Y 数据手册
5100 | SERIES HERMETICALLY SEALED THERMOSTAT PROBE Introduction The 5100 series is a single pole, single throw, snap-action, hermetically sealed temperature control designed for applications requiring high vibrational resistance in an isolated case. The snap-action disc is located in the very tip of the probe,assuring rapid and true response to temperature. The welded construction of this sealed thermostat ensures meeting thermal shock specifications of MIL-STD-202, method 107, test condition B. In addition,the tube will withstand a pressure exposure limit of 1500 PSI. Features • Hermetic glass seal, isolated-case only • Ideal for immersion sensing • Multiple mounting and terminations available • UL and CSA recognized component Applications • Hydraulic Systems • Degreasers • Industrial and Portable Compressors • Refrigeration Systems • Generator Sets • Chemical Baths • Engine Coolant • Oil and Transmission Protection SPECIFICATIONS Contact Ratings Contact Operations Operating Temperature Dielectric Strength Insulation Resistance Vibration Shock Pressure Exposure Limit Approvals Material Cycles Voltage Amps Case Type 100,000 120VAC / 32 VDC 3 (resistive) isolated case 100,000 125VAC pilot duty to 240VAC 1.5 (resistive) isolated case 6,000 240VAC 2.5 (resistive) isolated case Either close on rise (make) or open on rise (break), SPST (Single Pole, Single Throw) +35ºF to 480ºF (+1.67ºC to 249ºC) 1800 Vrms, 60Hz terminals to case 60 megaohms at 500 VDC .06DA, 10-55 Hz, 20G 20-2000 Hz .75G 6ms duration (sawtooth) Standard tube will withstand 1500 psi max UL E36687 and E66685, CSA LR25561-6 and LR25561-8 Stainless steel body and tube, compression glass seal, Mylar® sleeve, epoxy fill potting, stainless or plated steel terminals, fine silver contacts Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com CONTACT OPERATION CODE DESCRIPTION O Letter “O” = Open on Rise C Letter “C” = Close on Rise TERMINAL SELECTION A B C #8-32 Pan Head Screw (x2) #7 Lock Washers (Packaged in plastic bag) (6.35) 0.250 Quick Connects (x2) 30º to 45º Lead Wire (152.40 ± 6.35) 6.000 ± .250 30º (6.35) Strip .250 (22.23) REF .875 (12.70 ± .38) 0.500 ± .015 D (13.84 ± .38) 0.545 ± .015 (22.23) REF .875 (12.70 ± .38) 0.500 ± .015 Mounting Mounting Mounting Encapsulated Encapsulated Encapsulated E Same as terminal selection “C” Except 2 Leads F Same as terminal selection “C” (304.80 ± 25.40) 12.00 ± 1.00 Except 2 Leads See note 1 for lead specifications (609.60 ± 25.40) 24.00 ± 1.00 Same as terminal selection “C” Except 2 Leads See note 1 for lead specifications (1219.20 ± 25.40) 48.00 ± 1.00 See note 1 for lead specifications 1. The standard lead wire (materials) for different temperature ranges are as follows: A. Up to 220°F (104.4°C) = # 18 AWG standed. UL Style 1015/CSA approved. (PVC insulation, color black) B. 221°F to 350°F (105°C to 176.6°C) = #18 AWG stranded. UL Style 1199/CSA approved. (Teflon® TFE insulation, color black) C. 351°F (177.2°C) and above = #18 AWG stranded. UL style 5288/CSA approved. (Composite of Teflon®, ceramic + glass braid, color brown) 2. The marking information on each thermostat will include either the name Sensata, contact operation (CLR) close on rise, (OPR) open on rise, top temperature and date code. MOUNTING THREAD SELECTION A B (17.45) HEX 11/16 C (22.23) HEX 7/8 (5.72 ± .13) 0.225 ± .005 (5.72 ± .13 0.225 ± .005 (12.83 ± .25) .505 ± .010 Taper Pipe Thread 3/8-18 Dryseal PTF-SAE Short ) (16.66 ± .25) .656 ± .010 Taper Pipe Thread 1/2-14 Dryseal PTF-SAE Short E (25.4) 1.00 Taper Pipe Thread 1/2-14 Dryseal PTF-SAE Short HEX F Taper Pipe Thread 1/2-14 Dryseal PTF-Special Short (9.53 ± .25) .375 ± .010 (16.66 ± .25) .656 ± .010 (8.76 ± .13) .345 ± .005 (10.26) REF 3/4-16 UNF-2A .404 with ‘O’ Ring Groove (5.72 ± .13) 0.225 ± .005 (5.72 ± .13) 0.225 ± .005 (16.66 ± .25) .656 ± .010 (16.66 ± .25) .656 ± .010 Taper Pipe Thread 1/2-14 Dryseal PTF-SAE Short Taper Pipe Thread 1/2-14 Dryseal PTF-SAE Short (22.23) HEX 7/8 (22.23) HEX 7/8 Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com TUBE LENGTH SELECTION A B (17.73 ± .51) .698 ± .020 C (28.83 ± .51) 1.135 ± .020 (13.84 ± .51) DIA 0.545 ± .020 (41.53 ± .51) 1.635 ± .020 (13.84 ± .51) DIA 0.545 ± .020 (13.84 ± .51) DIA 0.545 ± .020 TEMPERATURE CODES AND TOLERANCE Temperature Scale Fahrenheit Celsius Fahrenheit Celsius Fahrenheit Celsius Top Temperature Settings 35˚F to 250˚F 1.7˚C to 121.1˚C 251˚F to 400˚F 121.7˚C to 204.4˚C 401˚F to 480˚F 205˚C to 248.9˚C Standard Top Temperature Tolerance (code) ±5˚F (A) ±2.8˚C (A) ±10˚F (C) ±5.6˚C (C) ±25˚F (N) ±13.9˚C (N) Nominal Temperature Differential 20˚F 11.1˚C 40˚F 22.2˚C 40˚F 22.2˚C Note • Select any temperature in the range of 35°F to 480°F. Standard choices fall on the 5°F increments, for example 140°F, 145°F, 150°F, 155° F... up to 475°F or 480°F • Specify the °F temperature in the part numbering scheme as a three digit code without the ‘°F’ in the part numbe r. For example, for 200°F, put in code ‘200’ • Bottom Temperature in °F” equals the “Top Temperature in °F” minus “Nominal Differential in °F”. For example 310°F - 30°F = 280°F Tolerance Code A C N Y ( Bottom Temp Only) ±˚F ±5˚F ±10˚F ±25˚F Minimum ±˚C ±2.8˚C ±5.6˚C ±13.9˚C Minimum Note • The standard tolerance for the top temperature is based on the temperature range the top temperature falls in, please refer to the temperature setting chart, and select the appropriate code for a standard top temperature tolerance • For bottom temperature tolerance a “Y” = minimum trip, which indicates the “reset” trip occurs at or above the lower temperature set point. Page 3 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com ORDERING OPTIONS Example :C51CBA285C-245Y Close contacts on temperature rise, 5100 series, isolated case 6” flying leads, 1/2-14 PTF threads, .698” tube length, 285°F top temperature with a ±10°F standard top tolerance and a standard 40°F differential between top and bottom temperature for temperature range of 251°F to 400°F, differential helps calculate a bottom temperature of 245°F with a standard minimum reset for contacts to close at or above the bottom temperature set point. C 51 C B A 2 8 5 C - 2 4 5 Y Contact Operation O, C See Contact Operation Table Family 5100 Series Terminal Selection A, B, C, D, E, F See Terminal Selection Table Mounting Thread Selection A, B, C, E, F See Mounting Thread Selection Table Tube Length Selection A, B, C See Tube Length Table Top Temperature (in °F) See Temperature Code and Tolerance Table Top Temperature Tolerance Code A, C, N See Temperature Codes and Tolerance Table (Available in Increments of 5°F) Bottom Temperature (in °F) See Temperature Codes and Tolerance Table Bottom Temperature Tolerance Code A, C, N, Y See Temperature Codes and Tolerance Table Page 4 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com WARNINGS RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE • The product’s side panels may be hot, allow the product to cool before touching • Follow proper mounting instructions including torque values • Do not allow liquids or foreign objects to enter this product Failure to follow these instructions can result in serious injury, or equipment damage. HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARCH FLASH • Disconnect all power before installing or working with this equipment • Verify all connections and replace all covers before turning on power Failure to follow these instructions will result in death or serious injury Page 5 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. Rev:02/12/18 CONTACT US Americas +1 (888) 438 2214 sensors@sensata.com Europe, Middle East & Africa +31 (74) 357 8156 temperature-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82-10-9218-1179 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
051AAA225A-205Y 价格&库存
很抱歉,暂时无法提供与“051AAA225A-205Y”相匹配的价格&库存,您可以联系我们找货
