S-1142DA9I-E6T1U
S-1142DA9I-E6T1U
    ABLIC(艾普凌科)
    SOIC6
    IC REG LINEAR 10.9V 200MA 6HSOP
S-1142DA9I-E6T1U 数据手册
S-1142C/D Series www.ablic.com HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 © ABLIC Inc., 2012-2019 The S-1142C/D Series, developed by using high-withstand voltage CMOS technology, is a positive voltage regulator with a high-withstand voltage, low current consumption, and high-accuracy output voltage. The S-1142C/D Series operates at a high maximum operating voltage of 50 V and a low current consumption of 4.0 μA typ. In addition to a built-in low on-resistance transistor which provides a very small dropout voltage and a large output current, this voltage regulator also has a built-in ON / OFF circuit. An overcurrent protection circuit prevents the load current from exceeding the current capacity of the output transistor, and a built-in thermal shutdown circuit prevents damage caused by heat. A high heat radiation HSOP-6 package enables high-density mounting.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Current consumption: • Output current: • Input and output capacitors: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free 2.0 V to 15.0 V, selectable in 0.1 V step 3.0 V to 50 V ±1.0% (Tj = +25°C) ±3.0% (Tj = −40°C to +105°C) During operation: 4.0 μA typ., 9.0 μA max. (Ta = −40°C to +85°C) During power-off: 0.1 μA typ., 1.0 μA max. (Ta = −40°C to +85°C) Possible to output 200 mA (VIN ≥ VOUT(S) + 2.0 V)*1 A ceramic capacitor of 0.1 μF or more can be used. Limits overcurrent of output transistor. Prevents damage caused by heat. Ensures long battery life. Ta = −40°C to +85°C *1. Attention should be paid to the power dissipation of the package when the output current is large.  Application • Constant-voltage power supply for home electric appliance  Package • HSOP-6 1 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00  Block Diagram *1 VIN VOUT Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit ON / OFF Reference voltage circuit VSS *1. Parasitic diode Figure 1 2 + − HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series  Product Name Structure Users can select the product type and output voltage for the S-1142C/D Series. Refer to "1. Product name" regarding the contents of product name, "2. Package" regarding the package drawings and "3. Product name list" for details of product names. 1. Product name S-1142 x xx I - E6T1 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications E6T1: HSOP-6, Tape *1 Operation temperature I: Ta = −40°C to +85°C Output voltage 20 to F0 (e.g., when the output voltage is 2.0 V, it is expressed as 20. when the output voltage is 10 V, it is expressed as A0. when the output voltage is 11 V, it is expressed as B0. when the output voltage is 12 V, it is expressed as C0. • • • when the output voltage is 15 V, it is expressed as F0.) *2 Product type C: ON / OFF pin negative logic D: ON / OFF pin positive logic *1. *2. 2. Refer to the tape drawing. Refer to "3. ON / OFF pin" in " Operation". Package Table 1 Package Name HSOP-6 Package Drawing Codes Dimension Tape Reel Land FH006-A-P-SD FH006-A-C-SD FH006-A-R-SD FH006-A-L-SD 3 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00 3. Product name list Table 2 Output Voltage 2.0 V ± 1.0% 2.5 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 3.0 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.5 V ± 1.0% 3.7 V ± 1.0% 3.9 V ± 1.0% 4.0 V ± 1.0% 5.0 V ± 1.0% 8.0 V ± 1.0% 11.5 V ± 1.0% 12.5 V ± 1.0% 15.0 V ± 1.0% Remark 4 HSOP-6 S-1142D20I-E6T1U S-1142D25I-E6T1U S-1142D27I-E6T1U S-1142D28I-E6T1U S-1142D2JI-E6T1U S-1142D30I-E6T1U S-1142D32I-E6T1U S-1142D33I-E6T1U S-1142D35I-E6T1U S-1142D37I-E6T1U S-1142D39I-E6T1U S-1142D40I-E6T1U S-1142D50I-E6T1U S-1142D80I-E6T1U S-1142DB5I-E6T1U S-1142DC5I-E6T1U S-1142DF0I-E6T1U Please contact our sales office for products with an output voltage other than those listed above or type C products. HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series  Pin Configuration 1. HSOP-6 Top view 6 1 5 2 Figure 2 Table 3 4 3 Pin No. Symbol Description 1 VOUT Output voltage pin 2 VSS GND pin 3 ON / OFF ON / OFF pin 4 NC*1 No connection 5 VSS GND pin 6 VIN Input voltage pin *1. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. 5 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00  Absolute Maximum Ratings Table 4 (Ta = +25°C unless otherwise specified) Item Symbol Absolute Maximum Rating VSS − 0.3 to VSS + 60 Unit VON / OFF VSS − 0.3 to VIN + 0.3 V Output voltage VOUT VSS − 0.3 to VIN + 0.3 V Power dissipation PD 1900*1 mW Junction temperature Tj −40 to +125 °C Operation ambient temperature Topr −40 to +85 °C Storage temperature Tstg −40 to +125 °C VIN Input voltage *1. When mounted on board [Mounted board] (1) Board size: (2) Board material: (3) Wiring ratio: (4) Test conditions: (5) Land pattern: V 50 mm × 50 mm × t1.6 mm Glass epoxy resin (two layers) 50% When mounted on board (wind speed: 0 m/s) Refer to the recommended land pattern (drawing code: FH006-A-L-SD) Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Power dissipation (PD) [mW] 2400 2000 1600 1200 800 400 0 Figure 3 150 100 50 Ambient temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) Condition HSOP-6 (When mounted on board) 6 0 Table 5 Power Dissipation Thermal Resistance Value (θj − a) 1900 mW 53°C/W HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series Power dissipation of HSOP-6 (reference) Package power dissipation differs depending on the mounting conditions. The power dissipation characteristics under the following test conditions should be taken as reference values only. [Mounted board] (1) Board size: (2) Board material: (3) Wiring ratio: (4) Test conditions: (5) Land pattern: 50 mm × 50 mm × t1.6 mm Glass epoxy resin (two layers) 90% When mounted on board (wind speed: 0 m/s) Refer to the recommended land pattern (drawing code: FH006-A-L-SD) Power dissipation (PD) [mW] 2400 2000 1600 1200 800 400 0 Figure 4 0 150 100 50 Ambient temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) Condition HSOP-6 (When mounted on board) Table 6 Power Dissipation (Reference) Thermal Resistance Value (θj − a) 2000 mW 50°C/W 7 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00  Electrical Characteristics Item Symbol Output voltage*1 VOUT(E) Output current*2 IOUT Table 7 (Tj = −40°C to +125°C, Ta = −40°C to +85°C unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) VIN = VOUT(S) + 1.0 V, VOUT(S) V 1 × 0.97 × 1.03 IOUT = 30 mA, −40°C ≤ Tj ≤ +105°C VIN ≥ VOUT(S) + 2.0 V IOUT = 100 mA Ta = +25°C Dropout voltage*3 Vdrop IOUT = 200 mA Ta = +25°C Line regulation Load regulation Current consumption during operation Current consumption during power-off Input voltage ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" ON / OFF pin input current "H" ON / OFF pin input current "L" ΔVOUT1 ΔVIN • VOUT ΔVOUT2 ISS1 ISS2 VIN VSH VSL 2.0 V ≤ VOUT(S) < 2.2 V 2.2 V ≤ VOUT(S) < 2.4 V 2.4 V ≤ VOUT(S) < 2.6 V 2.6 V ≤ VOUT(S) < 3.0 V 3.0 V ≤ VOUT(S) < 3.5 V 3.5 V ≤ VOUT(S) < 4.0 V 4.0 V ≤ VOUT(S) < 5.0 V 5.0 V ≤ VOUT(S) < 7.0 V 7.0 V ≤ VOUT(S) < 9.0 V 9.0 V ≤ VOUT(S) ≤ 15.0 V 2.0 V ≤ VOUT(S) < 2.2 V 2.2 V ≤ VOUT(S) < 2.4 V 2.4 V ≤ VOUT(S) < 2.6 V 2.6 V ≤ VOUT(S) < 3.0 V 3.0 V ≤ VOUT(S) < 3.5 V 3.5 V ≤ VOUT(S) < 4.0 V 4.0 V ≤ VOUT(S) < 5.0 V 5.0 V ≤ VOUT(S) < 7.0 V 7.0 V ≤ VOUT(S) < 9.0 V 9.0 V ≤ VOUT(S) ≤ 15.0 V VOUT(S) + 1.0 V ≤ VIN ≤ 30 V, IOUT = 30 mA VIN = VOUT(S) + 1.0 V, 2.0 V ≤ VOUT(S) < 5.1 V, 0.1 mA ≤ IOUT ≤ 40 mA VIN = VOUT(S) + 1.0 V, 5.1 V ≤ VOUT(S) < 12.1 V, 0.1 mA ≤ IOUT ≤ 40 mA VIN = VOUT(S) + 1.0 V, 12.1 V≤ VOUT(S) ≤ 15.0 V, 0.1 mA ≤ IOUT ≤ 40 mA VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ, determined by VOUT output level 200*4 − − − − − − − − − − − − − − − − − − − − − 1.0 0.8 0.6 0.45 0.35 0.3 0.27 0.23 0.2 0.18 1.12 1.02 0.92 0.82 0.72 0.62 0.55 0.5 0.45 0.4 − − − − − − − − − − − − − − − − − − − − − mA V V V V V V V V V V V V V V V V V V V V 3 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 − 0.05 0.3 %/V 1 − 20 40 mV 1 − 20 60 mV 1 − 20 80 mV 1 − 4.0 9.0 μA 2 − 0.1 1.0 μA 2 3.0 − 50 V − 1.5 − − V 4 − − 0.3 V 4 ISH VIN = VOUT(S) + 1.0 V, VON / OFF = VOUT(S) + 1.0 V −0.1 − 0.1 μA 4 ISL VIN = VOUT(S) + 1.0 V, VON / OFF = 0 V −0.1 − 0.1 μA 4 Ripple rejection |RR| VIN = VOUT(S) + 1.0 V, f = 100 Hz, ΔVrip = 0.5 Vrms, IOUT = 30 mA, Ta = +25°C − − − − − 50 45 40 35 30 − − − − − dB dB dB dB dB 5 5 5 5 5 Short-circuit current Ishort 2.0 V ≤ VOUT(S) < 2.3 V 2.3 V ≤ VOUT(S) < 3.6 V 3.6 V ≤ VOUT(S) < 6.1 V 6.1 V ≤ VOUT(S) < 10.1 V 10.1 V ≤ VOUT(S) ≤ 15.0 V VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V, Ta = +25°C − 80 − mA 3 TSD Junction temperature − 150 − °C − TSR Junction temperature − 125 − °C − Thermal shutdown detection temperature Thermal shutdown release temperature 8 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series *1. *2. *3. *4. VOUT(S): Set output voltage VOUT(E): Actual output voltage The output voltage when fixing IOUT (= 30 mA) and inputting VOUT(S) + 1.0 V The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 2.0 V, and IOUT = 100 mA or 200 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. The output current can be at least this value. Due to limitation of the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. 9 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00  Test Circuits VIN + VOUT ON / OFF V VSS A + Set to ON Figure 5 + A VIN Test Circuit 1 VOUT ON / OFF VSS Set to VIN or GND Figure 6 VIN Test Circuit 2 VOUT + ON / OFF VSS A V + Set to ON Figure 7 VIN + A Test Circuit 3 VOUT ON / OFF VSS Figure 8 VIN RL VOUT VSS Set to ON 10 + Test Circuit 4 ON / OFF Figure 9 V Test Circuit 5 V + RL HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series  Standard Circuit Input Output VOUT VIN CIN *1 ON / OFF VSS Single GND CL *2 GND *1. CIN is a capacitor for stabilizing the input. *2. A ceramic capacitor of 0.1 μF or more can be used as CL. Figure 10 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using an actual application to set the constants.  Condition of Application Input capacitor (CIN): Output capacitor (CL): 0.1 μF or more 0.1 μF or more Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL) The S-1142C/D Series requires an output capacitor between the VOUT pin and the VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 0.1 μF or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 0.1 μF or more. The values of output overshoot and undershoot, which are transient response characteristics, vary depending on the value of the output capacitor. The required value of capacitance for the input capacitor differs depending on the application. Set the value for input capacitor (CIN) and output capacitor (CL) as follows. CIN ≥ 0.1 μF CL ≥ 0.1 μF Caution Define the capacitance of C IN and C L by sufficient evaluation including the temperature characteristics under the actual usage conditions. 11 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±3.0% under specified conditions of fixed input voltage*1, fixed output current, and fixed temperature. *1. Differs depending on the product. Caution If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to " Electrical Characteristics" and " Characteristics (Typical Data)" for details. 3. ΔVOUT1  ΔVIN • VOUT  Line regulation  Indicates the dependency of the output voltage against the input voltage. That is, the value shows how much the output voltage changes due to a change in the input voltage after fixing output current constant. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage against the output current. That is, the value shows how much the output voltage changes due to a change in the output current after fixing input voltage constant. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 2.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 12 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series  Operation 1. Basic operation Figure 11 shows the block diagram of the S-1142C/D Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − + Rf Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 11 2. Output transistor In the S-1142C/D Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 13 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00 3. ON / OFF pin This pin starts and stops the regulator. When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. The VOUT pin is set to the VSS level by the internal dividing resistor of several MΩ between the VOUT pin and the VSS pin. Note that the current consumption increases when a voltage of 0.3 V to VIN − 0.3 V is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figure 12. Since the ON / OFF pin is neither pulled down nor pulled up internally, do not use it in the floating status. When not using the ON / OFF pin, connect it to the VSS pin in the product C type, and connect it to the VIN pin in the D type. Product Type C C D D ON / OFF Pin Table 8 Internal Circuit VOUT Pin Voltage Current Consumption "L": ON "H": OFF "L": OFF "H": ON Operate Stop Stop Operate ISS1 ISS2 ISS2 ISS1 Set value VSS level VSS level Set value VIN ON / OFF VSS Figure 12 4. Overcurrent protection circuit The S-1142C/D Series includes an overcurrent protection circuit having the characteristics shown in "1. Output voltage vs. Output current (When load current increases) (Ta = +25°C)" in " Characteristics (Typical Data)", in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and the VSS pin. The current when the output pin is short-circuited (Ishort) is internally set at approx. 80 mA typ., and the normal value is restored for the output voltage, if releasing a short circuit once. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. 14 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series 5. Thermal shutdown circuit The S-1142C/D Series has a thermal shutdown circuit to protect the device from damage due to overheat. When the junction temperature rises to 150°C typ., the thermal shutdown circuit operates to stop regulating. When the junction temperature drops to 125°C typ., the thermal shutdown circuit is released to restart regulating. Due to self-heating of the S-1142C/D Series, if the thermal shutdown circuit starts operating, it stops regulating so that the output voltage drops. When regulation stops, the S-1142C/D Series does not itself generate heat and the IC’s temperature drops. When the temperature drops, the thermal shutdown circuit is released to restart regulating, thus this IC generates heat again. Repeating this procedure makes the waveform of the output voltage into a pulse-like form. Stop or restart of regulation continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Table 9 Thermal Shutdown Circuit Operate: 150°C typ.*1 Release: 125°C typ.*1 *1. VOUT Pin Voltage VSS level Set value Junction temperature 15 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00 6. Overshoot of output voltage Overshoot of output voltage occurs depending on the condition such as the rising speed of input voltage (VIN). Overshoot voltage is the difference between the maximum value of output voltage generated by the fluctuation of VIN and the actual output voltage (VOUT(E)) value. 6. 1 At normal operation As shown in Figure 13, Vgs is the voltage difference between VIN and gate voltage of output driver. The error amplifier controls Vgs in order to keep the output voltage constant depending on the fluctuation of VIN and the output load. VIN Vref Vgs − Output driver + Output voltage Output capacitance Output load Figure 13 6. 2 Circuit Diagram Occurrence of overshoot If VIN voltage rises at a fast speed, Vgs may become large when gate voltage of output driver can not follow the speed of VIN. When Vgs becomes large, the current supplied from output driver is increased transiently. Thereby, output voltage rises, and then overshoot occurs. Note that overshoot voltage is greatly affected by the following use conditions or temperature, etc. • When VIN rises in the range of 2.0 V to VOUT(E). • When the rising speed of VIN is fast. • When the output capacitance is small. • When the output load is small. Input voltage (VIN) Rising speed of VIN = ΔV t ΔV VIN = 2.0 V to VOUT(E) Output voltage (VOUT(E)) Overshoot voltage VOUT(E) VIN = 2.0 V to VOUT(E) Rising time (t) Figure 14 Caution 16 VIN and Overshoot Voltage Under the following conditions, overshoot voltage tends to become larger especially. • When VIN rises from around 98% of VOUT(E). • When the rising speed of VIN is 200 mV/μs or more. HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL) and a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (0.1 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. • Note that the output voltage may increase due to the leakage current from an output driver even if the ON / OFF pin is at OFF level when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-1142C/D Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to "6. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C)" in " Reference Data" for the equivalent series resistance (RESR) of the output capacitor. Input capacitor (CIN): Output capacitor (CL): 0.1 μF or more 0.1 μF or more • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • Sufficiently evaluate the output voltage fluctuations caused by the power supply or the load fluctuations with the actual device. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 7 in " Electrical Characteristics" and footnote *4 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 17 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00  Characteristics (Typical Data) 1. Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 1 VOUT = 2.0 V 2.5 1. 2 13.5 V 1.5 VIN = 3.0 V 1.0 4.0 V 0.5 0 VOUT [V] 1. 3 VIN = 5.5 V 3 6.0 V 2 0 0 100 200 300 400 500 600 700 800 IOUT [mA] 0 100 200 300 400 500 600 700 800 IOUT [mA] VOUT = 12.0 V 14 12 10 8 6 4 2 0 13.5 V VIN = 12.5 V 13.0 V 0 Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *4 of Table 7 in " Electrical Characteristics" 2. Power dissipation of the package 100 200 300 400 500 600 700 800 IOUT [mA] Output voltage vs. Input voltage (Ta = +25°C) VOUT [V] 2. 1 VOUT [V] 2. 3 18 7.0 V 4 1 VOUT = 2.0 V 2.2 2.1 2.0 1.9 1.8 1.7 1.6 1.5 2. 2 VOUT [V] 2. 13.5 V 5 VOUT [V] VOUT [V] 2.0 VOUT = 5.0 V 6 IOUT = 1 mA 30 mA 50 mA 0 5 10 15 VIN [V] 20 25 30 VOUT = 12.0 V 12.4 12.2 12.0 11.8 11.6 11.4 11.2 11.0 IOUT = 1 mA 30 mA 50 mA 10 15 20 VIN [V] 25 30 VOUT = 5.0 V 5.2 5.1 5.0 4.9 4.8 4.7 4.6 4.5 IOUT = 1 mA 30 mA 50 mA 0 5 10 15 VIN [V] 20 25 30 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series Dropout voltage vs. Output current Vdrop [V] 3. 3 4. VOUT = 2.0 V 1.6 1.4 Tj = +125C 1.2 1.0 +25C 0.8 0.6 40C 0.4 0.2 0 0 50 100 150 200 IOUT [mA] VOUT = 12.0 V 0.50 0.45 0.40 Tj = 125C 0.35 0.30 25C 0.25 0.20 0.15 40C 0.10 0.05 0 0 50 100 150 200 IOUT [mA] 3. 2 Vdrop [V] Vdrop [V] 3. 1 250 VOUT = 5.0 V 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 Tj = 125C 25C 40C 0 50 100 150 IOUT [mA] 200 250 250 Dropout voltage vs. Temperature Vdrop [V] 4. 1 4. 3 VOUT = 2.0 V 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 40 25 4. 2 IOUT = 100 mA 10 mA 0 25 50 Tj [C] 75 100 125 Vdrop [V] 3. VOUT = 5.0 V 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 40 25 IOUT = 100 mA 10 mA 0 25 50 Tj [C] 75 100 125 VOUT = 12.0 V 0.30 Vdrop [V] 0.25 0.20 0.15 IOUT = 100 mA 0.10 10 mA 0.05 0 40 25 0 25 50 Tj [C] 75 100 125 19 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00 5. Dropout voltage vs. Set output voltage (Tj = +25°C) 1.2 IOUT = 200 mA 100 mA 30 mA 10 mA 1 mA Vdrop [V] 1.0 0.8 0.6 0.4 0.2 0 6. 0 2 4 6 8 VOUT(S) [V] 10 12 14 Output voltage vs. Temperature 6. 1 VOUT = 2.0 V 6. 2 VOUT = 5.0 V 5.2 2.02 5.1 2.00 1.98 1.96 40 25 6. 3 0 25 50 Tj [C] 75 100 125 VOUT = 12.0 V VIN = 13.0 V VOUT [V] 12.2 12.0 11.8 11.6 40 25 5.0 4.9 12.4 20 VIN = 6.0 V 2.04 VOUT [V] VOUT [V] VIN = 3.0 V 0 25 50 Tj [C] 75 100 125 4.8 40 25 0 25 50 Tj [C] 75 100 125 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series Current consumption during operation vs. Input voltage (When ON / OFF pin is ON, no load) ISS1 [A] 7. 1 ISS1 [A] 7. 3 8. VOUT = 2.0 V 16 14 12 10 8 6 4 2 0 0 5 7. 2 Tj = 125C 25C 40C 10 VOUT = 12.0 V 16 14 12 10 8 6 4 2 0 0 5 15 VIN [V] ISS1 [A] 7. 20 25 30 VOUT = 5.0 V 16 14 12 10 8 6 4 2 0 0 5 Tj = 125C 25C 40C 10 15 VIN [V] 20 25 30 Tj = 125C 25C 40C 10 15 VIN [V] 20 25 30 Current consumption during operation vs. Temperature 8. 1 VOUT = 2.0 V 8. 2 VOUT = 5.0 V 8. 3 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 40 25 VIN = 6.0 V ISS1 [A] ISS1 [A] VIN = 3.0 V 0 25 50 Tj [C] 75 100 125 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 40 25 0 25 50 Tj [C] 75 100 125 VOUT = 12.0 V ISS1 [A] VIN = 13.0 V 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 40 25 0 25 50 Tj [C] 75 100 125 21 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00 Current consumption during operation vs. Output current (Ta = +25°C) 9. 3 ISS1 [A] VOUT = 12.0 V 160 140 120 100 80 60 40 20 0 0 25 10. 9. 2 VIN = 13.5 V ISS1 [A] VOUT = 2.0 V 160 140 120 100 80 60 40 20 0 0 25 ISS1 [A] 9. 1 3.0 V 50 75 100 IOUT [mA] 125 150 VIN = 13.5 V 6.0 V 50 75 100 IOUT [mA] 125 150 13.0 V 50 75 100 IOUT [mA] 125 150 Output current vs. Input voltage*1 10. 1 VOUT = 3.3 V 250 10. 2 +25C IOUT [mA] 200 150 Ta = +85C 100 50 0 VOUT = 5.0 V 250 +25C 200 150 Ta = +85C 100 50 0 10 *1. When mounted on board [Mounted board] (1) Board size: (2) Board material: (3) Wiring ratio: (4) Through hole: 22 VOUT = 5.0 V 160 140 120 100 80 60 40 20 0 0 25 VIN = 20.0 V IOUT [mA] 9. 20 30 VIN [V] 40 50 0 0 50 mm × 50 mm × t1.6 mm Glass epoxy resin (two layers) Surface approx. 75%, reverse side approx. 90% Diameter 0.5 mm × 24 10 20 30 VIN [V] 40 50 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series 11. Ripple rejection (Ta = +25°C) 11. 1 11. 2 VOUT = 2.0 V VOUT = 5.0 V 11. 3 80 70 60 50 40 30 20 10 0 IOUT = 1 mA 30 mA 100 mA 10 100 1k 10k Frequency [Hz] 100k VIN = 13.5 V, CL = 0.1 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 13.5 V, CL = 0.1 μF 1M 70 60 50 40 30 20 10 0 IOUT = 1 mA 30 mA 100 mA 10 100 1k 10k Frequency [Hz] 100k 1M VOUT = 12.0 V Ripple Rejection [dB] VIN = 13.5 V, CL = 0.1 μF 60 50 IOUT = 1 mA 30 mA 100 mA 40 30 20 10 0 10 100 1k 10k Frequency [Hz] 100k 1M 23 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00  Reference Data Characteristics of input transient response (Ta = +25°C) 2.3 2.2 2.1 VIN VOUT CL = 10 μF 22 μF 13 5.8 12 5.6 11 10 VIN [V] VOUT [V] 2.4 1. 2 VOUT = 5.0 V IOUT = 30 mA, CIN = 0.1 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 6.0 14 5.4 5.2 13 VIN 12 VOUT CL = 10 μF 22 μF 11 10 2.0 9 5.0 9 1.9 200 8 4.8 200 8 0 200 400 600 800 1000 1200 t [μs] 0 200 400 600 800 1000 1200 t [μs] VIN [V] 1. 1 VOUT = 2.0 V IOUT = 30 mA, CIN = 0.1 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 14 2.5 VOUT [V] 1. Characteristics of load transient response (Ta = +25°C) 2.2 2.1 2.0 IOUT VOUT 1.9 1.8 200 CL = 10 μF 22 μF 0 100 5.6 50 5.4 0 50 IOUT [mA] VOUT [V] 2.3 100 150 200 400 600 800 1000 1200 t [μs] 2. 3 VOUT = 12.0 V VIN = 13.5 V, CIN = 0.1 μF, IOUT = 50 mA ↔ 100 mA 14.0 150 13.0 12.5 12.0 100 IOUT 50 VOUT 11.5 11.0 200 24 CL = 22 μF 10 μF 0 0 50 IOUT [mA] VOUT [V] 13.5 2. 2 VOUT = 5.0 V VIN = 13.5 V, CIN = 0.1 μF, IOUT = 50 mA ↔ 100 mA 5.8 150 100 150 200 400 600 800 1000 1200 t [μs] 5.2 5.0 100 IOUT 50 VOUT 4.8 4.6 200 CL = 10 μF 22 μF 0 0 50 IOUT [mA] 2. 1 VOUT = 2.0 V VIN = 13.5 V, CIN = 0.1 μF, IOUT = 50 mA ↔ 100 mA 2.4 150 VOUT [V] 2. VIN [V] VOUT [V] 1. 3 VOUT = 12.0 V IOUT = 30 mA, CIN = 0.1 μF, VIN = 13.5 V ↔ 15.5 V, tr = tf = 5.0 μs 13.2 16 13.0 VIN 15 12.8 14 12.6 13 CL = 10 μF VOUT 12.4 12 22 μF 12.2 11 12.0 10 9 11.8 200 0 200 400 600 800 1000 1200 t [μs] 100 150 200 400 600 800 1000 1200 t [μs] HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series Transient response characteristics of ON / OFF pin (Ta = +25°C) 12 VOUT [V] 12 9 6 VON/OFF 6 0 3 6 VOUT 0 3 500 4. 3. 2 500 1000 t [μs] 1500 18 2000 6 0 3 6 VOUT 3 500 12 0 500 1000 t [μs] 1500 18 2000 Overshoot [V] 0.4 VIN = 13.5 V, CIN = 0.1 μF, IOUT = 100 mA → 50 mA 0.5 0.3 0.2 0.1 0 20 40 60 CL [μF] 80 0.4 0.3 0.2 0.1 0 100 0 20 40 60 CL [μF] 80 100 Input transient response characteristics dependent on capacitance (Ta = +25°C) 5. 1 VOUT = 5.0 V VIN = 7.0 V → 12.0 V, tr = 5.0 μs, CIN = 0.1 μF, IOUT = 30 mA 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 0 20 40 60 80 100 CL [μF] VIN = 12.0 V → 7.0 V, tr = 5.0 μs, CIN = 0.1 μF, IOUT = 30 mA 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 0 20 40 60 80 100 CL [μF] Undershoot [V] Undershoot [V] 6 VON/OFF Load transient response characteristics dependent on capacitance (Ta = +25°C) 0 Overshoot [V] 9 0 4. 1 VOUT = 5.0 V VIN = 13.5 V, CIN = 0.1 μF, IOUT = 50 mA → 100 mA 0.5 5. 12 12 12 0 VOUT = 5.0 V VIN = 13.5 V, CL = 10 μF, CIN = 0.1 μF, IOUT = 100 mA, VON / OFF = 0 V → 13.5 V 18 15 VON/OFF [V] VOUT = 3.3 V VIN = 13.5 V, CL = 10 μF, CIN = 0.1 μF, IOUT = 100 mA, VON / OFF = 0 V → 13.5 V 18 15 VOUT [V] 3. 1 VON/OFF [V] 3. 25 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR S-1142C/D Series Rev.1.3_00 6. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 0.1 μF 100 RESR [Ω] VIN CIN Stable 0 S-1142 C/D Series ON / OFF 0.1 VSS 200 VOUT CL *1 RESR IOUT [mA] *1. Figure 15 26 CL: TDK Corporation C3216X8R2A104K (0.1 μF) Figure 16 HIGH-WITHSTAND VOLTAGE LOW CURRENT CONSUMPTION LOW DROPOUT CMOS VOLTAGE REGULATOR Rev.1.3_00 S-1142C/D Series  Marking Specification 1. HSOP-6 Top view 6 5 4 (1) to (5): (6): (7), (8): (9): (10) to (16): Product name: S1142 (Fixed) Product type Value of output voltage Operation temperature Lot number (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) 1 2 3 27 5.02±0.2 6 1 0.4±0.05 5 4 2 3 0.20±0.05 1.67±0.05 1.91 1.91 No. FH006-A-P-SD-2.1 TITLE HSOP6-A-PKG Dimensions No. FH006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.55±0.05 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 6 3 4 Feed direction No. FH006-A-C-SD-2.0 TITLE HSOP6-A-Carrier Tape No. FH006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 60° 2±0.5 13.5±0.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FH006-A-R-SD-1.0 TITLE HSOP6-A-Reel No. FH006-A-R-SD-1.0 ANGLE QTY. UNIT mm ABLIC Inc. 2,000 2.03 0.76 1.91 1.91 No. FH006-A-L-SD-2.0 TITLE HSOP6-A -Land Recommendation No. FH006-A-L-SD-2.0 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-1142DA9I-E6T1U
物料型号:S-1142C/D Series,由ABLIC公司开发,是一款利用高耐压CMOS技术制造的正电压调节器。
器件简介:S-1142C/D系列具有高耐压、低电流消耗和高精度输出电压的特点。它在高达50V的最大工作电压下运行,典型电流消耗仅为4.0μA。内置低导通电阻晶体管,提供非常小的压降和大输出电流,同时还有内置的ON/OFF电路。
引脚分配:HSOP-6封装,共有6个引脚,包括输出电压引脚(VOUT)、地引脚(VSS)、ON/OFF控制引脚(ON/OFF)、空脚(NC)和输入电压引脚(VIN)。
参数特性: - 输出电压:2.0V至15.0V,以0.1V步进可调。 - 输入电压:3.0V至50V。 - 输出电压精度:在+25°C时±1.0%,在-40°C至+105°C时±3.0%。 - 工作时电流消耗:典型值4.0μA,最大值9.0μA。 - 关闭电源时电流消耗:典型值0.1μA,最大值1.0μA。 - 输出电流:可输出200mA(VIN ≥ VOUT(S) + 2.0V)。 - 内置过流保护电路和热关断电路。
功能详解:包括基本操作、输出晶体管、ON/OFF控制、过流保护、热关断等。
应用信息:适用于家用电器的恒压电源。
封装信息:HSOP-6封装,具有高散热性能,适用于高密度安装。
S-1142DA9I-E6T1U 价格&库存
很抱歉,暂时无法提供与“S-1142DA9I-E6T1U”相匹配的价格&库存,您可以联系我们找货
