LV5027M-TLM-H
LV5027M-TLM-H
    SANYODENKI
    LSOP10
    LED DRIVER IC
LV5027M-TLM-H 数据手册
Ordering number : ENA**** Bi-CMOS IC LV5027M LED Driver IC Overview LV5027M is a High Voltage LED drive controller which drives LED current up to 3A with external MOSFET. LV5027M is realized very simple LED circuits with a few external parts. Functions  High Voltage LED Controller  Low noise switching system - 5 stages skip mode Frequency - Soft driving  Built-in Reference voltage circuit (internal 0.605V)  Built-in circuit of detection of overvoltage of CS pin.  Short Protection Circuit Specifications Maximum Ratings at Ta = 25C Parameter Maximum Input voltage Symbol VIN max CS pin OUT pin VOUT_abs Allowable power dissipation Pd max Junction temperature Tjmax Operating temperature Storage temperature Conditions With specified board* Ratings -0.3 to 42 Unit V -0.3 to 7 -0.3 to 42 V V 1.0 W 150 C Topr -30 to +125 C Tstg -40 to +150 C *Specified board: 58.0×54.0×1.6mm (glass epoxy board) Any and all SANYO Semiconductor Co.,Ltd. products described or contained herein are, with regard to "standard application", intended for the use as general electronics equipment (home appliances, AV equipment, communication device, office equipment, industrial equipment etc.). The products mentioned herein shall not be intended for use for any "special application" (medical equipment whose purpose is to sustain life, aerospace instrument, nuclear control device, burning appliances, transportation machine, traffic signal system, safety equipment etc.) that shall require extremely high level of reliability and can directly threaten human lives in case of failure or malfunction of the product or may cause harm to human bodies, nor shall they grant any guarantee thereof. If you should intend to use our products for applications outside the standard applications of our customer who is considering such use and/or outside the scope of our intended standard applications, please consult with us prior to the intended use. If there is no consultation or inquiry before the intended use, our customer shall be solely responsible for the use. Specifications of any and all SANYO Semiconductor Co.,Ltd. products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer's products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer' s products or equipment. 41311 SY 20110330-S00004 No.A1950-1/12 LV5027M Recommended Operating Conditions at Ta = 25C Parameter Input voltage Symbol Conditions Ratings VIN Unit 8.5 to 24 V Electrical Characteristics at Ta  25C, VIN = 12V, unless otherwise specified. Parameter Symbol Conditions Ratings min typ 0.585 0.605 Unit max Reference Voltage block Built-in Reference Voltage VREF VREF VIN line regulation VREF_LN VIN = 8.5 to 24V 0.625 ±0.5 V % Under Voltage Lockout Operation Start Input Voltage Operation Stop Input Voltage Hysteresis Voltage UVLOON UVLOOFF 8 9 10 V 6.3 7.3 8.3 V UVLOH 1.7 V Oscillation Frequency FOSC Maximum ON duty MAXDuty 40 50 93 VIO_VR 1 60 kHz % Comparator Input offset Voltage (Between CS and VREF) Input current IIOCS 10 160 IIOREF mV nA 80 nA CS pin max voltage VOM 1 malfunction prevention mask time Thermal protection Circuit TMSK Thermal shutdown temperature Thermal shutdown hysteresis Drive Circuit TSD TSD OUT sink current I OI OUT source current I OO 120 Minimum On time TMIN 200 300 120 V 150 ns *Design guarantee 165 C *Design guarantee 30 C 1000 mA 500 mA ns VIN current UVLO mode VIN current ICCOFF VINUVLOON 80 Normal mode VIN current ICCON VIN>UVLOON, OUT = OPEN 0.6 A mA VIN Over Voltage Protection Circuit VIN over voltage protection voltage VIN Current at OVP VINOVP IINOVP VIN=30V 24 27 30 V 0.7 1.0 1.5 mA CS terminal abnormal sensing circuit Abnormal sensing voltage CSOCP 1.9 V *: Design guarantee (value guaranteed by design and not tested before shipment) No.A1950-2/12 LV5027M TYPICAL CHARACTARISTICS No.A1950-3/12 LV5027M TYPICAL CHARACTARISTICS TYPICAL CHARACTARISTICS Block Diagram VIN Built-in REGULATOR TSD 0.605V UVLO OVP REFERENCE VOLTAGE OSCILLATOR CS S + Q CONTROL LOGIC R - OUT Current Limit Comparater Short Protection Circuit GND Sample Application Circuit Non isolation Isolation F1 F1 1m AC INPUT 1m AC INPUT C2 D1 R4 C2 D1 D7 R4 L1 NP D3 C13 NS LED D3 L LV5027M U1 VIN ND U1 LV5027M VIN R2 R2 Q1 OUT Q1 OUT CS CS R1 GND R1 GND R3 R3 No.A1950-4/12 LV5027M Package Dimensions unit: mm (typ) 3086B Pin Assignment NC GND NC NC NC LV5027M MFP10S VIN CS OUT NC GND Lp (Np) a blockdiagram in outline Ls (Ns) (TOP VIEW) Pin Functions pin No Pin Name 1 NC R1 CLK Q Equivalent Circuit Pin Function Vz No connection REF_IN + - CS 2 3 NC NC No connection OUT RESET VREF (0.605Vtyp) RT Lp (Np) R2 No connection Rcs a blockdiagram in outline 4 CS LED current sensing in. If this terminal voltage exceeds VREF, external FET is OFF. And if the voltage of the terminal exceeds 1.9V, LV5027M turns to latch-off mode. R1 CLK Vz + - CS REF_IN + - CS VREF (0.605Vtyp) 5 NC GND GND pin. 7 OUT Driving the external FET Gate Pin. 8 VIN Power supply pin. Operation : VIN>UVLOON Stop: VIN<UVLOOFF Switching Stop : VIN>VINOVP VCC R1 Vz 1kΩ No connection 10 GND GND pin. OUT 0.605V (internal Voltage) Lp RT (Np) GND Rcs a blockdiagram in outline 6 NC Q RESET R2 No connection 9 Ls (Ns) VIN + - Ls (Ns) CLK VINQ REF_IN CS + VREF (0.605Vtyp) RESET OUT OUT RTGND R2 Rcs VCC VIN 1kΩ + - OUT GND No.A1950-5/12 LV5027M Relation ship beween VREF and CS pin voltage The output current value is the average of the current value that flows during one cycle. The current value that flows into coil is a triangular wave shown in the figure below. Make sure to set Ipk so that (average of current value at one cycle) is a blockdiagrambetween in outline VREF(internal reference voltage) voltage and Rcs equal to (LED current value).Ipk is set by the relationship voltage. Vac2 Vac1 (FET current=Vcs/Rcs) L CLK VREF (0.605Vtyp) + Vac LED current OUT Q RESET a blockdiagram in outline REF_IN CS Vdcmin FET current (primary side) REF_IN VREF(0.605Vtyp) Rcs Ipk(=VREF/Rcs) under drawing T FET gate voltage ON FET OFF Ton TRIAC dimmer,OFF Dummy load,ON(OUT2;high) T Ipk  VREF Rcs Ipk: peak inductor current VIN: AC power-supply voltage (minimum value) VREF: Built-in reference voltage (0.605V) Rcs: External sense resistor PS No.A1950-6/12 LV5027M LED current and inductance setting It is available to use both no-isolation and isolation applications. (For non-isolation application) a blockdiagram in outline The output current value is the average of the inductor current value that flows during one cycle. The current value that Vac2 Vac1 wave shown in the figure below. Make sure to set Ipk so that (average of inductor flows into inductor is a triangular (FET current=Vcs/Rcs) current value at in one cycle) is equal to (LED current value). a blockdiagram outline inductor current LED a blockdiagram in outline REF_IN L Vac Vdcmin CLK VREF (0.605Vtyp) + FET current Q side) (primary RESET REF_IN OUT VREF(0.605Vtyp) CS Ipk(=VREF/Rcs) under drawing T FET gate voltage ON Rcs FET OFF TRIAC dimmer,OFF T_c T_d T Dummy load,ON(OUT2;high) Ipk IL=(Vdcmin-Vf)/LxT Ipk=(Vdcmin-Vf)/LxT_c =Vf/LxT_d IL=Vf/LxT inductor current T_c FET_on T_d FET_off T(1cycle) Given that the period when current flows into coil is T _ c T _ d , DutyI  T 1 Ipk   ( DutyI  T ) / T  ILED 2 VREF 2  ILED (1) since Ipk  Ipk  DutyI Rcs VFET DutyI  VREF (2) Rcs   Ipk 2 ILED Ipk: peak inductor current Vf: LED forward voltage drop Vdcmin: AC power-supply voltage (Rectified minimum DC voltage) VREF: Built-in reference voltage (0.605V) Rcs: External sense resistor Since formula for LED current is different between on period and off period as shown above, Vdc min  Vf Vf T _ c   T _ d (3). L L Since T _ c  T _ d  DutyI  T , T _ c  DutyI  T  T _ d Vdc min  Vf Based on the result of (3) and (4), T _ d  DutyI  T  Vdc min Ipk  (4) (5) To obtain L from the equation (1), (3), (5), L Vf  DutyI Vdc min  Vf Vf 1 Vdc min  Vf 2  DutyI  T      DutyI  2  ILED Vdc min 2  ILED fosc Vdc min (6) Since LED and inductor are connected in serial in non-isolation mode, LED current flows only when AC voltage exceed VF. PS No.A1950-7/12 de current) LV5027M (for Isolation application) Using the circuit diagram below, the wave form of the current that flows intooutline NpIpand Ns isto as is proportion REFfollows. pin voltage a blockdiagram below VREF(0.605Vtyp) Vac voltage Current waveform flows to primaryLpside and secondary (Np) FET current (primary side) Ls (Ns) CLK VREF (0.605Vtyp) + Vdcmin Q OUT RESET VREF(0.605Vtyp) Vac CS Ipk_p(=VREF/Rcs) Toff Rcs FET gate voltage ON Ip(primary side) OFF VREF(0.605V)typ Ton_p T T Ls current (Secondary side) ON OFF t Ton_s Ipk_p=(Vdcmin)/LpxTon_p Ipk_p Primary Side Ip=(Vdcmin)/LpxTon_p FET_ON FET_OFF (Ton_p) T(1cycle) Ipk_s=Vf/LsxTon_s Ipk_s Secondary Side Is=Vf/LsxTon_s Iout (Ton_s) [Inductance Lp of primary side and sense resistor Rs] If a peak current flow to transformer is represented as Ipk_p, the power (Pin) charged to the transformer on primary side can be represented as: 1  Lp  ( Ipk _ p)2  fosc (11). 2 Vdc min ∵Ipk _ p  (12)  Ton _ p Lp Vdc min 2  Ton _ p 2  fosc Vdc min 2  Don _ p 2 ∴Lp  (13)  2  Pin 2  Pin  fosc Ton _ p ( Don _ p   Ton _ p  fosc) T Pin  To substitute the following to the formula below, Pout (14) Pin Vdc min 2  Ton _ p 2  fosc  Vdc min 2  Don 2  ∴Lp   2  Pout 2  Pout  fosc ∵  (15) PS No.A1950-8/12 LV5027M Sense resistor is obtained as follows. Rs  VREF VREF  Lp VREF  Lp   Ipk _ p Vdc min Ton _ p Vdc min Don _ p  T (16) [Inductance Ls of secondary side] Since output current Iout is the average value of current flows to transformer of secondary side Ton _ s Ton _ s 1 Ipk _ s  Don _ s   ( Don _ s   Ton _ s  fosc) T 2 2 T Vout Vout Don _ s (18) Ipk _ s   Ton _ s   Ls Ls fosc Vout  T  Don _ s 2 Vout  Don _ s 2 Vout 2  Don _ s 2 (19) Ls    2  Iout 2  Iout  fosc 2  Pout  fosc Iout  Ipk _ s  (17) Calculation of the ratio of transformer coil on primary side and secondary side Since ratio and inductance of transformer coil is Ns  Np Ls Lp (20) substituted equations (15), (19) for (20) ∴ Np Vdc min Don _ p    Ns Vout Don _ s (21) Calculation of transformer coil on primary side and secondary side N Vac  10 8 2  B  Ae  fosc (22) ⊿B:variation range of core flux density [Gauss] Ae:core section area [cm2] To use Al (L value at 100T), N L 10 2 Al (23) L:inductance [uH] Al: L value at 100T [uH/N2] lg (Air gap) is obtained as follows: lg   r  0 N 2 Ae 10 2 (24) L μr: relative magnetic permeability, μr=1 μ0: vacuum magnetic permeability μ0=4π*10-7 N: turn count [T] Ae: core section area [m2] L: inductance [H] PS No.A1950-9/12 LV5027M Description of operating protection function tilte outline monitor point note 1 UVLO Under Voltage Lock Out VIN voltage 2 OCP Over Current Protection CS voltage 3 OVP Over Voltage Protection VIN voltage 4 OTP (TSD) Over Temperature Protection (Thermal Shut Down)) PN Junction temperature equivalent FET current 1.UVLO(Under Voltage Lock Out) If VIN voltage is 7.3V or lower, then UVLO operates and the IC stops. When UVLO operates, the power supply current of the IC is about 80uA or lower. If VIN voltage is 9V or higher, then the IC starts switching operation. VIN voltage B UVLOON (9Vtyp) VCC voltage CSOFT* A UVLOOFF tyop (7.3Vtyp) VCC GND tyop time 2dd outputstage on off VREG (内部定電圧) on 30k 30k 2.OCP(Over Current Protection) The CS pin sense the current through the MOS FET switch and the primary side of the transformer.This provides an additional level of protection in the event of a fault. If the voltage of the CS pin exceeds VCSOCP(1.9Vtyp)(A), the iternal comparator will detect the event and turn off the MOSFET. The peak switch current is calculated Io(peak) [A] = VSOCP[V]/Rsense[ohm] The VIN pin is pulled down to fixed level, keeping the controller lached off.The lach reset occurs when the user VCC disconnects LED from VAC and lets the VIN falls below voltage the VIN reset voltage,UVLOOFF(7.3Vtyp)(B). Then VIN rise UVLOON(9Vtyp)(C),restart the switching. CS voltage A C CSOCP(1.9Vtyp) CSOFT* time VIN voltage VCC B GND OCP rerset tyop 9Vtyp 7.3Vtyp 2dd time outputstage 30k on off VREG (内部定電圧) 30k on PS No.A1950-10/12 LV5027M 3.OVP(Over Voltage Protection) If the voltage of VIN pin is higher than the internal reference voltage VINOVP(27Vtyp),switching operation is stopped. The stopping operation is kept until the voltage of VIN is lower than 7.3V. If the voltage of VIN pin is higher than 9V, the switching operation is restated. VIN voltage A B OVP reset OVP C operation start 27Vtyp UVLOOFF (7.3Vtyp) 9Vtyp 7.3Vtyp time tyop outputstage on off on 4.TSD(thermal Shut Down protection The thermal shutdown function works when the junction temperature of IC is 165°C (typ) (A), and the IC switching stops. The IC starts switching operation again when the junction temperature is 135°Ctyp (B) or lower. Tj (Junction Tmperature) A TSD(design target) B Time outputstage on off on Skip frequency function LV5027M contains the skip frequency function for reduction of the peak value of conduction noise. This function changes the frequency as follows. Switching frequency is changed as follows. … 0.9  1.1  1.05  1  0.95  0.9  1.1 … It’s repeated by this loop. PS No.A1950-11/12 LV5027M SANYO Semiconductor Co.,Ltd. assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all SANYO Semiconductor Co.,Ltd. products described or contained herein. SANYO Semiconductor Co.,Ltd. strives to supply high-quality high-reliability products, however, any and all semiconductor products fail or malfunction with some probability. It is possible that these probabilistic failures or malfunction could give rise to accidents or events that could endanger human lives, trouble that could give rise to smoke or fire, or accidents that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. In the event that any or all SANYO Semiconductor Co.,Ltd. products described or contained herein are controlled under any of applicable local export control laws and regulations, such products may require the export license from the authorities concerned in accordance with the above law. No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written consent of SANYO Semiconductor Co.,Ltd. Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the SANYO Semiconductor Co.,Ltd. product that you intend to use. Information (including circuit diagrams and circuit parameters) herein is for example only; it is not guaranteed for volume production. Upon using the technical information or products described herein, neither warranty nor license shall be granted with regard to intellectual property rights or any other rights of SANYO Semiconductor Co.,Ltd. or any third party. SANYO Semiconductor Co.,Ltd. shall not be liable for any claim or suits with regard to a third party's intellctual property rights which has resulted from the use of the technical information and products mentioned above. This catalog provides information as of March, 2011. Specifications and information herein are subject to change without notice. PS No.A1950-12/12
LV5027M-TLM-H 价格&库存
很抱歉,暂时无法提供与“LV5027M-TLM-H”相匹配的价格&库存,您可以联系我们找货
