IS32LT3124A-ZLA3-TR
IS32LT3124A-ZLA3-TR
    LUMISSIL
    TSSOP16
    QUAD CHANNEL, LINEAR LED DRIVER
IS32LT3124A-ZLA3-TR 数据手册
IS32LT3124A/B/C/D/E/F QUAD CHANNEL, LINEAR LED DRIVER WITH FAULT REPORTING AND DYNAMIC HEADROOM CONTROL (DHC) January 2019 GENERAL DESCRIPTION FEATURES The IS32LT3124 is a linear programmable current regulator consisting of 4 output channels capable of up to 150mA each. Individual external resistors set the maximum current level for each channel. The outputs can be combined to provide a higher current drive capability up to 600mA (Max.).  The IS32LT3124 features Dynamic Headroom Control (DHC) with an optional external PMOS FET to minimize IC thermal stress when the supply voltage exceeds the LED string forward voltage. It includes two modes for different output power: Shunt Regulator mode and Series Regulator mode. It can operate with power supply modulation (PSM) for applications requiring dimming without use of the EN pin. For added system reliability, the IS32LT3124 integrates fault detection circuitry for open/short circuit and over temperature conditions. The fault pins (FLTB) can all be tied together to disable the device and other IS32LT3124 devices on the same parallel circuit. To handle all these different fault detection and reporting features, the IS32LT3124 has six different versions: A, B, C, D, E and F. All of them can support the above features. See table 1 for the major difference. In IS32LT3124A/B/D/E, if any fault condition occurs, all output currents will be disabled. In IS32LT3124B/C/E/F, individual ISET pin for each LED channel is redefined as individual PWM dimming control, thus ISET open detection function is removed. The EN pin of IS32LT3124B/C/E/F is featured as the enable signal of the internal fault reporting block. See Table 4 for complete fault listing. The IS32LT3124 is targeted at the automotive market such as interior accent lighting and exterior tail lighting. It is offered in a thermally enhanced eTSSOP-16 package. APPLICATIONS             5.0V to 28V input supply voltage range - Withstand 42V load dump Four output channels can source up to 150mA each - Four current set resistors - ±5% output current accuracy - Low dropout voltage of 1V (Max.) at 100mA - Combined for higher current capability with same current accuracy PWM dimming and shutdown control input - 100Hz~300Hz power supply modulation (PSM) - 100Hz~1kHz individual dimming via resistors of ISETx pins (IS32LT3124B/C/E/F only) Optional Dynamic Headroom Control (DHC) with an external PMOS FET to minimize IC thermal stress - Shunt regulator mode for heavy load - Series regulator mode for light load Additional external UVLO (Under Voltage Lockout Threshold) is programmable via EN pin (IS32LT3124A/D only) Fault protection and reporting - Externally enable/disable fault reporting (IS32LT3124B/C/E/F only) - Programmable fault reporting output delay time Fault condition disables all output (IS32LT3124A/B/D/E only) - Parallel fault connection (one-fail-all-fail) - LED string open/short - Single LED short (Conditional, IS32LT3124B/C/D only) - ISET pin short - ISET pin open (IS32LT3124A/D only) - Over temperature AEC-Q100 Qualified Operating temperature range (-40°C ~ +125°C) Automotive LED driver RGBW automotive ambient lighting Tail light Turn light Daytime running light Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 1 IS32LT3124A/B/C/D/E/F Table 1 Major Difference Of Different Versions Outx Pin Short To GND Threshold VSCD Support LED String Voltage IS32LT3124A PSM dimming or Simultaneous dimming by EN pin Typ. 1.22V ≥1 LED(s) IS32LT3124B PSM dimming or Individual dimming by ISET resistors Typ. 4.8V IS32LT3124C PSM dimming or Individual dimming by ISET resistors Typ. 4.8V Version Dimming Fault Protection Action (See Table 4 For More Details) One channel fails all channels off One channel fails all channels off > (VSCD_MAX+VSCD_HY) One channel fails all channels on IS32LT3124D PSM dimming or Simultaneous dimming by EN pin Typ. 4.8V IS32LT3124E PSM dimming or Individual dimming by ISET resistors Typ. 1.22V ≥1 LED(s) One channel fails all channels off One channel fails all channels off IS32LT3124F PSM dimming or Individual dimming by ISET resistors Typ. 1.22V ≥1 LED(s) One channel fails all channels on TYPICAL APPLICATION CIRCUIT VBattery D1 4 CVCC VCC CVICC 0.1µF 16 VICC REN1 R1 RHR 1 HRSET EN 2 REN2 RFLTD 10 RISET1 5 RISET2 6 RISET3 7 RISET4 8 IS32LT3124 FLTB 15 OUT1 14 OUT2 FLTD 13 OUT3 ISET1 C1 22nF 3 ERC 11 Q1 12 OUT4 ISET2 ISET3 ISET4 9 GND Figure 1 Typical Application Circuit VBattery 4 D1 CVCC_1 Connected to VCC and VICC pins of next device CVCC_2 1 REN1_1 VCC VICC EN HRSET REN2_1 ERC RFLTD_1 10 RISET1_1 5 RISET2_1 6 RISET3_1 7 8 11 IS32LT3124 FLTD ISET1 ISET2 OUT1 OUT2 OUT3 CVICC 0.1µF 16 2 RHR_1 3 15 14 13 FLTB Q1 C1 22nF 4 REN1_2 GND OUT4 9 12 1 VCC EN VICC HRSET REN2_2 ERC RFLTD_2 10 RISET1_2 RISET2_2 RISET3_2 ISET3 ISET4 R1 5 6 7 8 11 IS32LT3124 FLTD ISET1 ISET2 OUT1 OUT2 OUT3 16 2 RHR_2 3 15 14 13 ISET3 ISET4 FLTB GND OUT4 9 12 Connected to HRSET pin of next device Connected to FLTB pin of next device Figure 2 Typical Application Circuit (Several Devices in Parallel Share One External PMOS FET) Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 2 IS32LT3124A/B/C/D/E/F VBattery 4 D1 CVCC_1 1 REN1_1 VCC VICC EN HRSET REN2_1 ERC RFLTD_1 10 RISET1_1 5 RISET2_1 6 RISET3_1 7 RISET4_1 8 11 IS32LT3124 FLTD OUT1 OUT2 ISET1 OUT3 ISET2 OUT4 ISET3 CVCC_2 16 4 REN1_2 2 1 Figure 3 EN HRSET ERC RFLTD_2 10 15 14 RISET1_2 5 13 RISET2_2 6 12 RISET3_2 7 ISET4 GND VICC REN2_2 3 RISET4_2 8 FLTB VCC 9 11 IS32LT3124 OUT1 FLTD OUT2 ISET1 OUT3 ISET2 OUT4 ISET3 16 2 3 15 14 13 12 ISET4 FLTB GND 9 Typical Application Circuit (Several Devices in Parallel without External PMOS FET) VBattery 4 RHR EN HRSET ERC 11 RFLTD 10 RISET1 5 RISET2 6 RISET3 7 RISET4 8 Q2 Q3 Q4 Q5 Figure 4 IS32LT3124B/C/E/F FLTB FLTD ISET1 OUT1 OUT2 OUT3 OUT4 2 3 Q1 C1 22nF 15 14 13 12 ISET2 ISET3 ISET4 GND 9 RLED1 1 REN2 PWM Input R1 RLED2 REN1 VICC CVICC 0.1µF RLED3 CVCC VCC 16 RLED4 D1 * RLED1~RLED4 are necessary for IS32LT3124E/F If PWM dimming is required Typical Application Circuit with Additional Switches driving RISET Individual PWM Dimming (IS32LT3124B/C/E/F only) When PWM Generator is Far Away from Device Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 3 IS32LT3124A/B/C/D/E/F VBattery 4 RHR EN HRSET ERC 11 RFLTD 10 MCU RISET1 5 RISET2 6 RISET3 7 RISET4 8 IS32LT3124B/C/E/F FLTB FLTD ISET1 OUT1 OUT2 OUT3 OUT4 2 3 Q1 C1 22nF 15 14 13 12 ISET2 ISET3 ISET4 GND 9 RLED1 1 REN2 Open Drain I/O R1 RLED2 REN1 VICC CVICC 0.1µF RLED3 CVCC VCC 16 RLED4 D1 * RLED1~RLED4 are necessary for IS32LT3124E/F If PWM dimming is required Figure 5 Typical Application Circuit With Open Drain I/O driving RISET Individual PWM Dimming (IS32LT3124B/C/E/F only) When PWM Generator is Close to Device Note 1: The C1 and CVICC are fixed value. Note 2: For PSM dimming application, high CVCC capacitor value will affect the dimming accuracy. To get better dimming performance, recommend 0.1µF for it. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 4 IS32LT3124A/B/C/D/E/F PIN CONFIGURATION Package Pin Configuration (Top View) eTSSOP-16 PIN DESCRIPTION No. Pin Description IS32LT3124A/D Device enable pin. Pull low to disable all the outputs. Input a PWM signal will achieve all channels simultaneous dimming. 1 EN 2 HRSET With the external PMOS FET, connect a resistor to VICC pin to set the maximum working headroom for the current sources. 3 ERC Gate driver of external PMOS FET to achieve dynamic headroom control. 4 VCC Raw supply voltage. Internal fault flag report enable pin. Pull it low to disable IS32LT3124B/C/E/F fault reporting, the output currents and the response to a fault remain functional except FLTB is not pulled low. IS32LT3124A~F Resistor on this pin to GND sets the maximum output current for channel OUT1~OUT4. 5~8 ISET1~ISET4 The internal ISET open detection is removed. Therefore, PWM dimming and current adjust via the resistors of ISETx IS32LT3124B/C/E/F pins is feasible. Float the ground terminal of the resistor to turn off the corresponding output and ground to turn on. 9 GND Ground pin. 10 FLTD Resistor on this pin to GND sets the fault reporting output delay time. 11 FLTB Fault reporting output pin. Active low. Internally pulled up to 4.5V by a resistor. It is also an input pin (IS32LT3124A/B/D/E only). Pulling it low will disable all output currents. 12~15 OUT4~OUT1 Output current source for Channel 4~Channel 1. 16 VICC Regulated LED string voltage from external PMOS FET. Thermal Pad Must be connected to GND with sufficient copper plate for heat sink. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 5 IS32LT3124A/B/C/D/E/F ORDERING INFORMATION Automotive Range: -40°C to +125°C Order Part No. Package QTY/Reel IS32LT3124A-ZLA3-TR IS32LT3124B-ZLA3-TR IS32LT3124C-ZLA3-TR IS32LT3124D-ZLA3-TR IS32LT3124E-ZLA3-TR IS32LT3124F-ZLA3-TR eTSSOP-16, Lead-free 2500 Copyright  ©  2019  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 6 IS32LT3124A/B/C/D/E/F ABSOLUTE MAXIMUM RATINGS VCC, VICC, EN, ERC, HRSET OUT1~ OUT4 ISET1~ISET4, FLTD, FLTB Operating junction temperature, TA=TJ Maximum continuous junction temperature, TJ(MAX) Storage temperature range, TSTG Power dissipation, PD(MAX) Junction Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JESD 51-8), θJP ESD (HBM) ESD (CDM) -0.3V ~ +42V (Note 3) -0.3V ~ VVICC+0.3V -0.3V ~ +7.0V -40°C ~ +125°C +150°C -65°C ~ +150°C 2.12W 47.1°C/W 1.62°C/W ±2kV ±750V Note 3: The device can operate at 42V continuously subject only to thermal dissipation limit. Note 4: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS Valid are at VCC= 12V, TJ= -40°C ~ +125°C, typical value at 25°C, unless otherwise noted. Symbol Parameter Conditions Min. Typ. Max. Unit 28 V Power Up Parameter VCC Supply voltage range 5 ICC VCC supply current RISETx= 20kΩ, VHR= 1V VUVLO VCC supply threshold voltage (when device logic is enabled) Voltage rising VUVLO_HY VCC supply voltage hysteresis 8 10 12 mA 4.3 4.5 4.7 V 0.2 0.25 0.3 V Shutdown current in normal mode (IS32LT3124A/D only) VCC= VICC= 12V, RFLTD= 20kΩ, EN= Low, TA= 25°C 0.8 1.1 1.3 mA Shutdown current as FAULTB pin externally pulled low (IS32LT3124A/B/D/E only) VCC= VICC= 12V, EN= High, FLTB= Low, RFLTD= 20kΩ, TA= 25°C 1.0 1.35 1.5 mA tON Startup turn on time (IS32LT3124A/D only) IOUT= -150mA, VCC= VICC= 12V, VEN> 1.23V (Note 5) 20 μs tSD The low time of EN pin to shutdown the IC (IS32LT3124A/D only) 60 ms tPC Power cycle ON (minimum) 0.1 ms ISD ISD_FLT 20 38 (Note 5) Channel Parameter VISETx VISET_SC VISET_SCHY The ISETx voltage 1 V ISETx pin short circuit detection Voltage falling threshold 100 200 250 mV ISETx pin short circuit detection threshold hysteresis 50 100 150 mV -105 -100 -95 mA -10 mA -160 mA IOUT Output current per channel IOUT_R Output current per channel range -150 IOUT_L Output limit current -220 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 RISETx= 20kΩ, VHR= 1V -190 7 IS32LT3124A/B/C/D/E/F ELECTRICAL CHARACTERISTICS (CONTINUE) Valid are at VCC= 12V, TJ= -40°C ~ +125°C, typical value at 25°C, unless otherwise noted. Symbol Parameter Conditions ∆IS/IS Channel current matching RISETx= 20kΩ ILEAK Leakage current per channel (IS32LT3124A/D only) EN= Low, VOUT= 0V, VCC= 28V VHRSET_MAX The maximum headroom set VHRSET -3 (Note 5) Headroom voltage set accuracy RHR= 2kΩ (Note 6) VHR Minimum headroom voltage IERC ERC pin current capability Min. Typ. Max. Unit 0.8 1.0 3 % 1 μA 3.0 V 1.2 V RISETx= 20kΩ (Note 6) 1.0 RISETx= 13.3kΩ (Note 6) 1.3 (Note 5) V 40 μA 1.23 V Fault Protect Parameter VFLTD Fault delay pin voltage tFLTD Fault delay time RFLTD= 20kΩ RFLT FLTB pull up resistor (Note 5) 50 VFAULTB FAULTB pin voltage Sink current = 1mA 0.4 VFAULTB_H FAULTB pin high enable threshold (IS32LT3124A/B/D/E only) Voltage rising VFAULTB_L FAULTB pin low disable threshold (IS32LT3124A/B/D/E only) Voltage falling Fault deglitch time Fault must be present at least this long to trigger the fault detect VSCD OUTx pin short to GND threshold Measured at OUTx IS32LT3124A/E/F voltage falling IS32LT3124B/C/D VSCD_HY OUTx pin short to GND hysteresis Measured at OUTx VOD OUTx pin open threshold VOD_HY tFD 9 9.6 10.5 kΩ 0.6 2.5 20 ms V V 40 1 V 60 μs 1.15 1.22 1.30 V 4.5 4.8 5.0 IS32LT3124A/E/F 150 250 350 IS32LT3124B/C/D 150 200 250 Measured at (VICC-VOUTx) decreasing 150 220 300 mV OUTx pin open hysteresis Measured at (VICC-VOUTx) 50 120 200 mV TSD Thermal shutdown threshold (Note 5) 165 °C THY Over-temperature hysteresis (Note 5) 25 °C 1.18 1.23 1.28 V mV Logic Input EN VEN_TH Input enable voltage threshold VHY Input hysteresis fPWM PWM frequency Voltage rising 20 40 70 mV 1 kHz tISET_DLY1 ISET PWM dimming turn on The time between RISET grounding and delay time (IS32LT3124B/C/E/F output current reaching 90% maximum only) (Note 5) 3 7 11 μs tISET_DLY2 ISET PWM dimming turn off The time between RISET floating and delay time (IS32LT3124B/C/E/F output current reaching 10% maximum only) (Note 5) 0.4 4 7 μs Note 5: Guarantee by design. Note 6: It is a recommended value to ensure a better line regulation. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 8 IS32LT3124A/B/C/D/E/F FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 9 IS32LT3124A/B/C/D/E/F TYPICAL PERFORMANCE CHARACTERISTICS 102 103 RISET = 20kΩ Output Current (mA) 102.5 Output Current (mA) VCC = 12V RISET = 20kΩ 101.9 TJ = 125°C 102 TJ = 25°C 101.5 TJ = -40°C 101 TJ = 125°C 101.8 TJ = 25°C 101.7 101.6 101.5 101.4 TJ = -40°C 101.3 101.2 100.5 101.1 100 5 8 11 14 17 101 20 2 4 6 Supply Voltage (V) 140 RISET = 20kΩ 120 100 80 60 40 140 RISET = 20kΩ 120 100 80 60 40 RISET = 200kΩ 20 0 RISET = 13kΩ VCC = 12V TJ = 25°C 160 Output Current (mA) Output Current (mA) Figure 7 IOUT vs. VOUT 180 RISET = 13kΩ VCC = 12V TJ = -40°C 160 RISET = 200kΩ 20 0.1 1 2 3 4 5 6 7 8 9 0 10 0.1 1 2 3 Headroom Voltage (V) 160 140 RISET = 20kΩ 120 6 7 180 Output Current (mA) Output Current (mA) 160 5 8 9 10 110 125 Figure 9 IOUT vs. VHR RISET = 13kΩ VCC = 12V TJ = 125°C 4 Headroom Voltage (V) Figure 8 IOUT vs. VHR 180 100 80 60 40 RISET = 13kΩ VCC = 12V 140 120 RISET = 20kΩ 100 80 60 40 RISET = 200kΩ 20 0 10 Output Voltage (V) Figure 6 IOUT vs. VCC 180 8 RISET = 200kΩ 20 0.1 1 2 3 4 5 6 7 Headroom Voltage (V) Figure 10 IOUT vs. VHR Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 8 9 10 0 -40 -25 -10 5 20 35 50 65 80 95 Temperature (°C) Figure 11 IOUT vs. TJ 10 IS32LT3124A/B/C/D/E/F 200 1.08 VCC = 12V VHR = 2V RISET = 5kΩ OUT1 190 OUT3 185 VCC = 12V RHR = 2kΩ TJ = -40°C 1.07 Headroom Voltage (V) Output Current (mA) 195 OUT2 180 OUT4 175 170 1.06 RISET = 20kΩ 1.05 1.04 1.03 RISET = 200kΩ 1.02 1.01 1.0 165 0.99 160 -40 -25 -10 5 20 35 50 65 80 95 110 0.98 125 5 6 7 10 11 1.08 VCC = 12V RHR = 2kΩ TJ = 25°C 1.06 RISET = 20kΩ 1.05 1.04 RISET = 13kΩ RISET = 200kΩ 1.03 1.02 1.01 1.06 1.02 1.01 0.99 0.98 8 9 10 RISET = 200kΩ 1.03 0.99 7 RISET = 13kΩ 1.04 1.0 6 RISET = 20kΩ 1.05 1.0 5 VCC = 12V RHR = 2kΩ TJ = 125°C 1.07 Headroom Voltage (V) 1.07 Headroom Voltage (V) 9 Figure 13 VHR vs. VOUT Figure 12 IOUT_L vs. TJ 1.08 11 5 6 7 8 9 10 11 Output Voltage (V) Output Voltage (V) Figure 15 VHR vs. VOUT Figure 14 VHR vs. VOUT 15 VOUT = 4V RHR = 2kΩ RISET = 100kΩ 1.08 HR3 HR1 1.06 1.04 HR2 HR4 1.02 1 Supply Current (mA) 1.1 Headroom Volrage (V) 8 Output Voltage (V) Temperature (°C) 0.98 RISET = 13kΩ VOUT = 4V RISET = 20kΩ RFLTD = 20kΩ 12 9 6 3 0.98 0.96 5 10 15 20 25 30 Supply Voltage (V) Figure 16 VHR vs. VCC Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 35 40 42 0 5 10 15 20 25 30 35 40 42 Supply Voltage (V) Figure 17 ICC vs. VCC 11 IS32LT3124A/B/C/D/E/F 1.8 RFLTD = 20kΩ EN = Low 1.2 RFLTD = 20kΩ EN = High FLTD = Low 1.6 Shutdown Current (mA) Shutdown Current (mA) 1.4 1 0.8 0.6 0.4 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0.2 5 10 15 20 25 30 0 40 42 35 5 10 15 Supply Voltage (V) Figure 18 ISD vs. VCC for IS32LT3124A/D Shutdown Current (mA) Shutdown Current (mA) VCC = 12V RFLTD = 20kΩ EN = Low 0.3 -25 -10 5 20 35 50 65 80 95 110 1.2 0.9 0.6 VCC = 12V RFLTD = 20kΩ EN = High FLTD = Low 0.3 0 -40 125 -25 -10 5 Temperature (°C) 20 35 50 65 80 95 110 125 110 125 Temperature (°C) Figure 20 ISD vs. TJ for IS32LT3124A/D Figure 21 ISD_FLT vs. TJ for IS32LT3124A/B/D/E 1.05 14 VCC = 12V RISET = 20kΩ RFLTD = 20kΩ 1.04 VCC = 12V 1.03 10 1.02 VISET (V) Supply Current (mA) 40 42 35 Figure 19 ISD_FLT vs. VCC for IS32LT3124A/B/D/E 0.6 12 30 1.5 0.9 0 -40 25 Supply Voltage (V) 1.5 1.2 20 8 6 1.01 VISET1,VISET3,VISET4 1 0.99 VISET2 0.98 4 0.97 2 0 -40 0.96 -25 -10 5 20 35 50 65 80 Temperature (°C) Figure 22 ICC vs. TJ Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 95 110 125 0.95 -40 -25 -10 5 20 35 50 65 80 95 Temperature (°C) Figure 23 VISET vs. TJ 12 IS32LT3124A/B/C/D/E/F 4.6 1.25 VCC = 12V VCC = 12V EN_H 1.23 UVLO_H 4.5 VUVLO (V) VEN (V) 4.4 1.21 EN_L 1.19 4.3 UVLO_L 4.2 1.17 4.1 1.15 -40 -25 -10 5 20 35 50 65 80 95 110 4 -40 125 -25 -10 Temperature (°C) Figure 24 VEN_TH vs. TJ 90 Output Current (mA) 1.24 EN_H VEN (V) 1.22 1.21 1.2 EN_L 10 25 30 35 0 40 42 0 20 Supply Voltage (V) Figure 26 VEN_TH vs. VCC 40 60 80 100 80 100 Figure 27 PWM Dimming at 100Hz 100 VCC = 12V RISET = 20kΩ PWM Dimming 500Hz TJ = -40°C, 25°C, 125°C 80 70 60 50 40 80 70 60 50 40 30 30 20 20 10 10 0 20 VCC = 12V RISET = 20kΩ PWM Dimming 1kHz TJ = -40°C, 25°C, 125°C 90 Output Current (mA) 90 Output Current (mA) 125 PWM Duty Cycle (%) 100 0 110 40 1.16 20 95 50 20 15 80 60 1.17 10 65 70 30 5 50 VCC = 12V RISET = 20kΩ PWM Dimming 100Hz TJ = -40°C, 25°C, 125°C 80 1.18 1.15 35 Figure 25 VUVLO vs. TJ 100 1.19 20 Temperature (°C) 1.25 1.23 5 40 60 PWM Duty Cycle (%) Figure 28 PWM Dimming at 500Hz Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 80 100 0 0 20 40 60 PWM Duty Cycle (%) Figure 29 PWM Dimming at 1kHz 13 IS32LT3124A/B/C/D/E/F 100 80 70 60 50 40 80 70 60 50 40 30 30 20 20 10 10 0 0 20 PSM = 12V, 300Hz RISET = 20kΩ TJ = -40°C, 25°C, 125°C 90 Output Current (mA) 90 Output Current (mA) 100 PSM = 12V, 100Hz RISET = 20kΩ TJ = -40°C, 25°C, 125°C 40 60 80 100 0 0 20 40 PSM Duty Cycle (%) VCC = 12V RFLTD = 20kΩ TJ = -40°C LED Open Fault 100 Figure 31 PSM Dimming at 300Hz VFLTB 5V/Div VOUT 5V/Div VOUT 5V/Div IOUT 50mA/Div IOUT 50mA/Div Time (4ms/Div) VCC = 12V RFLTD = 20kΩ TJ = 25°C LED Open Fault Time (4ms/Div) Figure 32 tFLTD VFLTB 5V/Div 80 PSM Duty Cycle (%) Figure 30 PSM Dimming at 100Hz VFLTB 5V/Div 60 VCC = 12V RFLTD = 20kΩ TJ = 125°C LED Open Fault VOUT 5V/Div Figure 33 tFLTD VCC = 12V RFLTD = 0Ω TJ = -40°C LED Open Fault Recover VFLTB 2V/Div VOUT 5V/Div IOUT 50mA/Div IOUT 50mA/Div Time (4ms/Div) Time (20µs/Div) Figure 34 tFLTD Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 Figure 35 tFD 14 IS32LT3124A/B/C/D/E/F VCC = 12V RFLTD = 0Ω TJ = 25°C LED Open Fault Recover VCC = 12V RFLTD = 0Ω TJ = 125°C LED Open Fault Recover VFLTB 2V/Div VFLTB 2V/Div VOUT 5V/Div VOUT 5V/Div IOUT 50mA/Div IOUT 50mA/Div Time (20µs/Div) Time (20µs/Div) Figure 36 tFD Figure 37 tFD VCC = 12V RISET = 20kΩ TJ = -40°C VCC = 12V RISET = 20kΩ TJ = -40°C VEN 1V/Div VEN 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (2µs/Div) Figure 38 PWM Off Delay Time for IS32LT3124A/D Time (2µs/Div) Figure 39 PWM On Delay Time for IS32LT3124A/D VCC = 12V RISET = 20kΩ TJ = 25°C VCC = 12V RISET = 20kΩ TJ = 25°C VEN 1V/Div VEN 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (2µs/Div) Figure 40 PWM Off Delay Time for IS32LT3124A/D Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 Time (2µs/Div) Figure 41 PWM On Delay Time for IS32LT3124A/D 15 IS32LT3124A/B/C/D/E/F VCC = 12V RISET = 20kΩ TJ = 125°C VCC = 12V RISET = 20kΩ TJ = 125°C VEN 1V/Div VEN 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (2µs/Div) Time (2µs/Div) Figure 42 PWM Off Delay Time for IS32LT3124A/D Figure 43 PWM On Delay Time for IS32LT3124A/D VCC = 12V RISET = 20kΩ TJ = -40°C VCC = 12V RISET = 20kΩ TJ = -40°C Floating RISET Ground Terminal 1V/Div Floating RISET Ground Terminal 1V/Div Grounded Grounded IOUT 50mA/Div IOUT 50mA/Div Time (4µs/Div) Time (4µs/Div) Figure 44 ISET PWM Off Delay Time for IS32LT3124B/C/E/F Figure 45 ISET PWM On Delay Time for IS32LT3124B/C/E/F Note: Reference Figure 4 and 5 Note: Reference Figure 4 and 5 VCC = 12V RISET = 20kΩ TJ = 25°C VCC = 12V RISET = 20kΩ TJ = 25°C Floating Floating RISET Ground Terminal 1V/Div Grounded IOUT 50mA/Div RISET Ground Terminal 1V/Div Grounded IOUT 50mA/Div Time (4µs/Div) Time (4µs/Div) Figure 46 ISET PWM Off Delay Time for IS32LT3124B/C/E/F Figure 47 ISET PWM On Delay Time for IS32LT3124B/C/E/F Note: Reference Figure 4 and 5 Note: Reference Figure 4 and 5 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 16 IS32LT3124A/B/C/D/E/F VCC = 12V RISET = 20kΩ TJ = 125°C VCC = 12V RISET = 20kΩ TJ = 125°C Floating Floating RISET Ground Terminal 1V/Div Grounded IOUT 50mA/Div RISET Ground Terminal 1V/Div Grounded IOUT 50mA/Div Time (4µs/Div) Time (4µs/Div) Figure 48 ISET PWM Off Delay Time for IS32LT3124B/C/E/F Figure 49 ISET PWM On Delay Time for IS32LT3124B/C/E/F Note: Reference Figure 4 and 5 Note: Reference Figure 4 and 5 RISET = 20kΩ PSM = 12V, 100Hz TJ = -40°C Without PMOS PSM 5V/Div PSM 5V/Div VOUT 10V/Div VOUT 10V/Div VISET 1V/Div VISET 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (10µs/Div) Time (10µs/Div) Figure 50 PSM On Figure 51 PSM On RISET = 20kΩ PSM = 12V, 100Hz TJ = 25°C Without PMOS RISET = 20kΩ PSM = 12V, 100Hz TJ = 25°C With PMOS PSM 5V/Div PSM 5V/Div VOUT 10V/Div VOUT 10V/Div VISET 1V/Div VISET 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (10µs/Div) Figure 52 PSM On Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 RISET = 20kΩ PSM = 12V, 100Hz TJ = -40°C With PMOS Time (40µs/Div) Figure 53 PSM On 17 IS32LT3124A/B/C/D/E/F RISET = 20kΩ PSM = 12V, 100Hz TJ = 125°C With PMOS PSM 5V/Div PSM 5V/Div VOUT 10V/Div VOUT 10V/Div VISET 1V/Div VISET 1V/Div IOUT 50mA/Div Time (10µs/Div) RISET = 20kΩ PSM = 12V, 100Hz TJ = 125°C Without PMOS IOUT 50mA/Div Time (20µs/Div) Figure 54 PSM On PSM 5V/Div RISET = 20kΩ PSM = 12V, 100Hz TJ = -40°C Without PMOS Figure 55 PSM On PSM 5V/Div VOUT 10V/Div VOUT 10V/Div VISET 1V/Div VISET 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (40µs/Div) Time (40µs/Div) Figure 57 PSM Off Figure 56 PSM Off PSM 5V/Div RISET = 20kΩ PSM = 12V, 100Hz TJ = 25°C Without PMOS PSM 5V/Div VOUT 10V/Div VOUT 10V/Div VISET 1V/Div VISET 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (40µs/Div) Figure 58 PSM Off Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 RISET = 20kΩ PSM = 12V, 100Hz TJ = -40°C With PMOS RISET = 20kΩ PSM = 12V, 100Hz TJ = 25°C With PMOS Time (40µs/Div) Figure 59 PSM Off 18 IS32LT3124A/B/C/D/E/F PSM 5V/Div RISET = 20kΩ PSM = 12V, 100Hz TJ = 125°C Without PMOS PSM 5V/Div VOUT 10V/Div VOUT 10V/Div VISET 1V/Div VISET 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time (40µs/Div) RISET = 20kΩ PSM = 12V, 100Hz TJ = 125°C With PMOS Time (40µs/Div) Figure 60 PSM Off VEN 2V/Div VCC = 12V RISET = 20kΩ TJ = -40°C Figure 61 PSM Off VEN 2V/Div VISET 1V/Div VISET 1V/Div VFLTB 2V/Div VFLTB 2V/Div IOUT 50mA/Div IOUT 50mA/Div Time (10ms/Div) Figure 62 tSD for IS32LT3124A/D VEN 2V/Div VCC = 12V RISET = 20kΩ TJ = 25°C Time (10ms/Div) Figure 63 tSD for IS32LT3124A/D VCC = 12V RISET = 20kΩ TJ = 125°C VISET 1V/Div VFLTB 2V/Div IOUT 50mA/Div Time (10ms/Div) Figure 64 tSD for IS32LT3124A/D Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 19 IS32LT3124A/B/C/D/E/F APPLICATION INFORMATION The IS32LT3124 is a 4-channel linear constant current regulator capable of sourcing 150mA per channel. The device integrates one EN input control and four output currents with individual current set resistors; one for each of the four output current channels. The device can operate with a Power Supply Modulation (PSM) input at the VCC pin input. To minimize device thermal stress, an optional external shunt resistor and PMOS FET can be driven by the IS32LT3124 to share the power dissipation. FLTB pin can be used in a parallel combination to disable multiple IS32LT3124A/B/D/E devices once a fault condition is detected by any one of the devices (One-Fail-All-Fail). the ISET open fault will be ignored and the channel will be recognized as unused. UNDER VOLTAGE LOCKOUT (UVLO) EN PIN OPERATION IS32LT3124 features an under voltage lockout (UVLO) function for the VCC pin. This is an internally fixed value and cannot be adjusted. The device is enabled when the VCC voltage rises to exceed VUVLO (Typ. 4.5V), and disabled when the VCC voltage falls below (VUVLO-VUVLO_HY) (Typ. 4.25V). For the IS32LT3124A/D, the EN pin can be used to set additional UVLO via a resistor divider. Please refer to the EN PIN OPERATION section for more details. IS32LT3124A/D: OUTPUT CURRENT SETTING The regulated LED current (up to 150mA) from each channel is individually set by its corresponding reference resistor (RISETx). The programming resistors may be computed using the following Equation (1): RISET V  ISET  2000 I OUT (1) (13.3kΩ≤RISET≤200kΩ) and VISET=1V (Typ.) It is recommend that RISETx be a 1% accuracy resistor with good temperature characteristic to ensure stable output current. The current outputs can be connected in parallel for a combined 600mA or can be left unused as required. Several channels combined in parallel will have the same current accuracy as the independent channel. In case of some channels are unused, please follow Table 2 to configure the corresponding ISETx and OUTx pins. RISET1 RISET2 RISET3 5 6 7 8 OUT1 ISET1 OUT2 ISET2 OUT3 ISET3 OUT4 ISET4 15 14 13 12 IS32LT3124B/C/E/F GND Figure 65 9 IS32LT3124B/C/E/F Unused Channel Configuration (OUT4 Unused) EN is the device enable pin. The EN voltage must be higher than VEN_TH to enable all outputs and lower than (VEN_TH-VHY) to disable them. The EN pin of the IS32LT3124A/D can accept a PWM signal to implement simultaneous dimming of all LED strings. The average LED current for each channel can be computed using the following Equation (2). I LED  DPWM  VISET  2000 RISET (2) DPWM is PWM duty cycle and VISET=1V (Typ.). So as to guarantee a reasonably good dimming effect, the recommended PWM frequency range is 100Hz ~ 1kHz. Driving the EN pin with a PWM signal can effectively adjust the LED intensity. The PWM signal voltage levels must meet the EN pin input voltage levels, (VEN_TH-VHY) and VEN_TH. Note: because of the 40µs (typ.) fault deglitch time tFD, the PWM on-time should be greater than 40us to avoid undetermined fault response. The IC has an internal fixed VCC UVLO set at VUVLO, 4.5V (Typ.). However, it may be desirable to externally set UVLO to track the number of LED’s used in the string. For PSM dimming application, the higher UVLO will track the PSM off time to get more accurate PSM dimming. The EN pin can be used to set a VCC under voltage lockout threshold via a resistor divider. Table 2 Unused Channel Configuration Unused ISETx Unused OUTx Device Pins Pins IS32LT3124A/D Floating Connect to VICC Connected to IS32LT3124 Floating used OUT (refer B/C/E/F to Figure 65) Note: for IS32LT3124A/D, when the ISET pin is floating and the corresponding OUT pin is tied to VICC, Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 Figure 66 EN Pin Set External UVLO The UVLO threshold voltage can be computed using the following Equation (3): 20 IS32LT3124A/B/C/D/E/F VCC _ UVLO  VEN _ TH  REN 1  REN 2 REN 2 (3) IS32LT3124B/C/E/F: The EN pin is fault reporting enable pin, when pulled low to disable fault reporting, the output currents and the internal IC fault action operate normally but no fault output is generated. The EN voltage is higher than VEN_TH to enable fault reporting (FLTB low output) and lower than (VEN_TH-VHY) to disable all fault reporting (FLTB low output). In some applications, the IS32LT3124A/B/C/D/E/F with a resistor divider from VCC as Figure 66, helps prevent false LED open detection due to the LED string losing its headroom voltage, such as when VCC rises up from zero during power up or PSM dimming. The recommended VCC_UVLO setting level is: VCC _ MIN  VCC _ UVLO  VOUT _ MAX  VHRSET VCC IS32LT3124 ERC HRSET 3 DYNAMIC HEADROOM CONTROL (DHC) AND THERMAL CONSIDERATIONS The power dissipation of a linear constant current LED driver depends on the ratio of the output and input voltages. When the input and output voltages are determined, an increase in output current will increase power dissipation on the driver IC and it can be calculated by the following Equation: (5) Where, VHR is the headroom voltage, which is the voltage drop on the OUTx pin. Due to the limited driver IC power rating, a typical linear constant current LED driver cannot be used for high current applications. To solve this power dissipation issue, IS32LT3124 features a Dynamic Headroom Control (DHC) function which splits the power dissipation among the driver IC and external components to significantly minimize the driver IC thermal. This enables the IS32LT3124 to support up to 600mA total output current with acceptable heat, independent of the output to input voltage ratio. VDROP R1 2 C1 22nF RHR Must be >5V VICC 16 VHR_MIN (4) Where, VCC_MIN is the minimum VCC voltage, VOUT_MAX is the maximum forward voltage of 4 LED strings and VHRSET is the setting minimum headroom voltage (refer to DYNAMIC HEADROOM CONTROL section). PIC  (VCC  VOUT )  I OUT  VHR  I OUT The DHC can be configured into two modes: Shunt Regulator mode and Series Regulator mode. The Series Regulator mode is recommended for the application of ≤300mA total output current and the Shunt Regulator mode is good for >300mA application. The basic circuits of both modes are the same however R1 value decides the operating mode. To optimize the stability of the PMOS FET control loop, please use the fixed value for them: C1=22nF and CVICC=0.1µF. CVICC 0.1µF OUT1 15 VOUT_MAX OUT2 14 OUT3 13 OUT4 12 GND 9 Figure 68 DHC Operating Series Regulator Mode: Choose 1kΩ value for R1 and the DHC circuit will operate in Series Regulator mode. The integrated circuit compares the minimum headroom voltage of all four output channels against the headroom setting VHRSET, which is set by the resistor RHR from the HRSET and VICC pins, and dynamically drives the external power PMOS FET to maintain this minimum headroom voltage always equal to VHRSET. As Figure 69 shows, the minimum headroom voltage will appear on the channel with the maximum LED string forward voltage. Therefore, the output voltage of the Series Regulator, VVICC, can be calculated by the Equation (6) and (7): VVICC  VOUT _ MAX  VHRSET (6)  1V  VHRSET  RHR     2000  (7) Where, VOUT_MAX is the maximum voltage of four OUTx pins. Figure 67 DHC Circuit Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 According to Equation (6), once the LED strings are determined and the input voltage is sufficient higher than VVICC, the VVICC is constant if RHR is fixed. No matter how high the input voltage is, the headroom voltage of each channel is constant all the time, so the 21 IS32LT3124A/B/C/D/E/F power dissipation on IS32LT3124 is constant as well (ICC current is negligible and ignored in following calculation). However, it can be programmed by the VHRSET setting; the higher VHRSET the larger power dissipation on IS32LT3124. The remaining power dissipation is dropped on the external PMOS FET. Their power consumption can be calculated by: splits it into two areas: constant headroom area and headroom increasing area. In the Constant Headroom Area, the DHC circuit regulates the minimum headroom voltage equal to VHRSET, same as the Series Regulator mode. So the IS32LT3124 power dissipation is constant: 4 4 P3124   (VVICC  VOUTx )  I OUTx (8) PPMOS  (VCC  VVICC )  I TOT (9) P3124   (VVICC  VOUTx )  I OUTx x 1 Where, ITOT is the total current of all output channels. While the PMOS FET and R1 share the remaining power dissipation which will vary following the input voltage. Their power dissipation in the Constant Headroom Area can be calculated by: PR1  Power Dissipation Figure 69 PPMOS  ( I TOT  (VCC  VVICC ) 2 R1 (11) VCC  VVICC )  (VCC  VVICC ) R1 (12) The power dissipation of the PMOS FET peaks at the center point of (VTR-VVICC) and decreases to zero at VTR. The transition point VTR can be adjusted by the R1 value: Power Dissipation Distribution in Series Regulator Mode Shunt Regulator Mode: In the Series Regulator mode, the headroom voltage is constant however the external PMOS FET must support any excess voltage. When the total output current exceeds 300mA, the V×I power dissipation on the PMOS FET may be excessive. To prevent thermal run away, the Shunt Regulator mode could be considered. Choose a proper value (lower than 1KΩ) for R1, DHC circuit will operate in Shunt Regulator mode which manages the power dissipation among the IS32LT3124, external PMOS FET, and the shunt resistor R1. R1 sharing the power dissipation will significantly minimize the power dissipation on the PMOS FET. VTR  VVICC  R1  I TOT (13) Beyond the transition line VTR is the Headroom Increasing Area. DHC is no longer effective since the PMOS FET is off. PMOS FET has no power dissipation anymore and the power dissipation is solely shared by IS32LT3124 and R1. The power dissipation of R1 becomes constant while the power dissipation of the IS32LT3124 starts to increase following the input voltage. Their power dissipation in the Headroom Increasing Area can be calculated by: 4 P3124   (VCC  I TOT  R1  VOUTx )  I OUTx (14) x 1 2 PR1  I TOT  R1 PPMOS  0 (15) (16) In the Headroom Increasing Area, the system relies on the thermal shutdown protection feature of the IS32LT3124. Select a proper R1 value so the Constant Headroom Area covers the desired operating voltage range. For instance, the required operating voltage range is 9V~16V. The VICC should be set below 9V and set VTR above 16V. Power Dissipation Figure 70 (10) x 1 Power Dissipation Distribution in Shunt Regulator mode As Figure 70 shows, the power dissipation has different distribution in different areas. When the input voltage is higher than VVICC, the transition line (VTR) Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 Lumissil has a downloadable Excel spread sheet to calculate the power dissipation of these key components: IS32LT3124, PMOS FET and shunt resistor. In the Shunt Regulator mode, the shunt resistor R1 sustains plenty of power dissipation at high input voltage. Please make sure the R1 has sufficient power rating to avoid thermal stress of the resistor. 22 IS32LT3124A/B/C/D/E/F Several large package resistors in parallel should be used for R1. EXTERNAL PMOS FET SELECT (OPTIONAL) The PMOS FET must be chosen with its drain voltage rating VDS greater than the Transient Voltage Suppressor (TVS) clamp voltage of the load dump protection. The IS32LT3124 integrates a 15V overvoltage protect circuit to clamp the voltage between VCC and ERC pins for PMOS FET gate protection purpose. So the gate to source maximum voltage rating VGS of the PMOS FET should be greater than 15V to avoid accidental damage. And its current rating should be greater than the total current of all channels. Moreover, the static drain to source on resistance (RDS_ON) of the PMOS FET should be considered. It affects the minimum voltage drop across VCC to VICC: VDROP _ MIN  VCC _ MIN  VVICC (17) VDROP_ MIN  RDS_ON IOUT1  IOUT2  IOUT3  IOUT4  (18) Where, VCC_MIN is the minimum input voltage. In addition, because the PMOS FET doesn’t have an over temperature protection mechanism, the power rating of the PMOS FET should be carefully considered to sustain the maximum power dissipation on it. A PMOS FET with a big thermal PAD and low thermal resistance is preferred, such as a D-PAK or SOT-223 package. When several devices are connected in parallel to share one PMOS FET (as Figure 2), all the output currents of those devices without PMOS FET should be calculated together as the total current thru the PMOS FET.  1V  RHR     VOUT _ MAX  5V  2000  (20) Therefore in low LED string voltage application, e.g. one RED LED with around 2V forward voltage, some appropriate value power resistors in series with LED strings should be used to increase the maximum voltage of four OUTx pins. The power resistor value RP can be calculated by: VVICC  VOUT _ MAX I OUT _ X  RP  5V  VOUT _ MAX I OUT _ X (21) Where, VOUT_MAX is the maximum voltage of four OUTx pins without any power resistor and IOUT_X is the current of this channel. Note: the approach of adding the series power resistor is only available for IS32LT3124A/E/F versions. The IS32LT3124B/C/D using the series power resistor would falsely trigger short fault protection and latched all outputs off. So IS32LT3124B/C/D only can drive the LED string with the forward voltage > (VSCD_MAX+VSCD_HY). DYNAMIC HEADROOM CONTROL (DHC) SHARING The DHC function is not necessary for the IS32LT3124 in low current applications. Such as when the total output current is much lower than 300mA. If not used, the external PMOS FET can be omitted and VICC should be tied to VCC pin, and leave HRSET and ERC pins floating (as Figure 3). To save the cost and PCB space in some application, several devices can be connected in parallel to share one PMOS FET (as Figure 2). This scheme is available for both the Series Regulator and the Shunt Regulator modes. The IC connected to system voltage (Supervisor) must connect one output channel (with its ISET pin left floating) to the HRSET pin of the next device (with ECR pin floating and same value RHR as the supervisor). The supervisor IC’s DHC circuit will manage the power dissipation of the devices without PMOS FET along with itself. In this way, the power dissipation on the PMOS FET and R1 should be carefully considered to make sure its junction temperature won’t exceed its maximum rating in extreme ambient temperature. This approach is suitable for applications with low per channel current. HEADROOM SETTING POWER SUPPLY MODULATION (PSM) DIMMING As previously stated, the headroom voltage is set by the resistor RHR from the HRSET and VICC pins: The IS32LT3124 can support Power Supply Modulation (PSM), which implements LED dimming by pulse width modulated on the power supply rail. The IS32LT3124 closed loop stability is not affected by PSM operation with or without an external PMOS FET. The HRSET and ERC controls can respond within the tPC period when the supply VCC threshold voltage to properly drive and bias the PMOS FET in a linear fashion. To get better dimming linearity, the recommended PSM frequency should be in the range of 100Hz to 300Hz (200Hz Typ.) and the input capacitor, CVCC, should be low value (0.1uF typical) to ensure rapid discharge during PSM low period.  1V  VHRSET  RHR     2000  (19) The IS32LT3124 internally limits the maximum VHRSET to 3.0V (typical) to ensure reasonable thermal on the IS32LT3124. A headroom voltage setting of 1.5V~2.5V is recommended for most application. To maintain the normal operation of the internal detection circuit and the dynamic head room control, the VICC voltage must be set above 5V, otherwise the DHC circuit will be abnormal and the VHR_MIN cannot be maintained at set value. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 23 IS32LT3124A/B/C/D/E/F FAULT REPORTING OPERATION For robust system reliability, the IS32LT3124 integrates the detection circuitry to protect various fault conditions and report the fault by the FLTB pin which can be monitored by an external host. The FLTB pin is internally pulled up to 4.5V by a resistor RFLT and so it can be left floating, or unconnected. The FLTB pin will go low when the device enables fault detection and detects a fault condition such as LED string open, short to GND, thermal shutdown, or ISET pin open/short (refer to Table 4). For IS32LT3124B/C/E/F, the fault detection and actions are always active, however the FLTB reporting is not active until EN pin voltage rise above VEN_TH. For the IS32LT3124A/D, ISET open fault detection is disabled when the voltage of the OUTx pins are not floating or grounded, unused OUTx pins should be tied to VICC for unused purpose. In PSM dimming application, with a fault condition, the fault reporting will be reset as VCC voltage goes low. So the external fault reporting monitor should checking cycle by cycle, and keep at least 100µs monitor blanking time after VCC rising up to prevent some spurious fault as shown in Figure 71. will be limited to a minimum value, 40µs. Except for being grounded, the RFLTD value must be ≥ 5kΩ. FLTB PARALLEL INTERCONNECTION FLTB is a fault reporting output pin and it also is an input pin (IS31FL3124A/B/D/E only). Externally pulling FLTB pin low will disable all the output channels. For LED lighting systems which require the complete lighting system be shutdown when a fault is detected, the FLTB pin can be used in a parallel connection with multiple IS32LT3124A/B/D/E devices as shown in Figures 2 and 3. A detected fault output by any device will pull low the FLTB pins of the other parallel connected devices and simultaneously turn them off. This satisfies the “One-Fail-All-Fail” operating requirement. LED STRING OPEN DETECTION Detection of an open-load condition occurs when the measured voltage across any one of the four OUTx pins to VICC is lower than VOD. When this condition is present for longer than the fault deglitch tFD, then IS32LT3124A/D: It turns off all of the other channels. The FLTB pin goes low after fault delay time. IS32LT3124B/E: It turns off all of the other channels. If VEN>VEN_TH, the FLTB pin goes low after fault delay time. IS32LT3124C/F: Figure 71 External Fault Reporting Monitor During PSM Dimming FAULT REPORTING DELAY TIME SETTING The IS32LT3124 supports programmable fault reporting delay time, as shown in Table 3. A fault reporting delay time is used to introduce a delay to the FLTB output signal when detecting a device fault condition. This delay is meant to avoid detecting and reporting a spurious fault. Table 3 Fault Delays It keeps all the other channels normal working. If VEN>VEN_TH, the FLTB pin goes low after fault delay time. The device recovers after deglitch time tFD as removal of the open condition and FLTB goes back high. LED STRING SHORT-CIRCUIT DETECTION The LED string short circuit is detected if the measured voltage across any of OUTx pin drops below OUTx pin short to GND threshold, VSCD. IS32LT3124B/C/D: FLTD Pin State Report Fault Delay Time GND 40µs RFLTD= 5kΩ 4.65ms RFLTD= 20kΩ 9.60ms RFLTD= 250kΩ 85.5ms Floating 340ms The delay time can be computed using the following Equation (22): t FLTD (ms )  3.3  RFLTD  10  3 4 (22) Note: When FLTD pin is grounded, the fault delay time Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 After VEN>VEN_TH, when any of OUTx pin voltage drops below VSCD (typical 4.8V) and is present for longer than the fault deglitch time tFD, IS32LT3124B/D will turn off all the other channels and reserve 4mA in faulty channel for recovery detection purpose, while all channels of IS32LT3124C will continue sourcing current. And the FLTB pin goes low after fault delay time. The channel recovers after deglitch time tFD upon removal of the short condition and FLTB goes back high. Since VSCD of IS32LT3124B/C/D is higher than one LED forward voltage, it only can drive the LED string with the forward voltage > (VSCD_MAX+VSCD_HY) then it is possible to detect both LED string short (as Figure 72-1) and single LED in multi-LEDs string short 24 IS32LT3124A/B/C/D/E/F detection with appropriate forward voltage LEDs (as Figure 72-2). VSCD=4.8V Since VSCD of IS32LT3124A/E/F is lower than one LED forward voltage, it can only detect OUTx short to GND condition, as Figure 73. OUTx VSCD=1.22V OUTx (1) IS32LT3124B/C/D Whole String Shorted VSCD=4.8V Figure 73 OUTx (2) IS32LT3124B/C/D Figure 72 IS32LT3124A/E/F Whole String Shorted IS32LT3124A/E/F LED Short Detection ISET OVER CURRENT OR SHORT DETECTION Single LED Shorted IS32LT3124B/C/D LED Short Detection To achieve single LED short detection, please ensure that a single LED short can reduce the LED string voltage below VSCD_MIN. So the LED string voltage must be set within the range of: (VSCD _ MIN  V f _ MIN )  VSTRING  VSCD _ MAX (23) Where, VSCD_MAX and VSCD_MIN is the maximum and minimum value of the OUTx short detect threshold, Vf_MIN is the minimum forward voltage of the LED. IS32LT3124A: After the device being enabled (VEN>VEN_TH), when any of OUTx pin voltage drops below VSCD (typical 1.22V) and is present for longer than the fault deglitch time tFD, it will turn off all the other channels. The FLTB pin goes low after fault delay time. The channel recovers after deglitch time tFD upon removal of the short condition and FLTB goes back high. IS32LT3124E: When any OUTx pin voltage drops below VSCD (typical 1.22V) for longer than the fault deglitch time tFD, it turns off all the other channels. If VEN>VEN_TH, the FLTB pin goes low after fault delay time. The device recovers after deglitch time tFD upon removal of the short condition and FLTB goes back high. IS32LT3124F: When any OUTx pin voltage drops below VSCD (typical 1.22V) for longer than the fault deglitch time tFD, all channels will continue sourcing current. If VEN>VEN_TH, the FLTB pin goes low after fault delay time. The channel recovers after deglitch time tFD upon removal of the short condition and FLTB goes back high. Note: An LED short will cause a larger headroom voltage on the faulty channel that may significantly increase the power dissipation on IS32LT3124F, especially in high output current applications. Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 The device is protected from an output overcurrent condition caused by ISETx pins. When a too low value resistor is connected to any ISET pin but pin voltage still is above VISET_SC (typical 0.2V), the corresponding channel current will be internally limited at 190mA (typical). If an excessive low value resistor is connected or accidental short circuit to pull ISETx pin voltage below 0.2V, the corresponding channel will be turned off with fault reporting after fault delay time tFLTD and IS32LT3124A/B/D/E will turn off the other channels as well, while IS32LT3124C/F will keep the other channels operating normally. The device recovers after deglitch time tFD upon removal of the fault condition and FLTB goes back high. ISET OPEN DETECTION AND INDIVIDUAL PWM DIMMING IS32LT3124A/D: If ISETx pin is open and VEN > VEN_TH, all output channels will be turned off and FLTB will go low after fault delay time tFLTD to report fault condition. The device recovers after deglitch time tFD upon removal of the open condition and FLTB goes back high. Due to this protection, IS32LT3124A/D cannot support individual ISETx PWM dimming. However, if the ISET pin is floating and the corresponding OUT pin is tied to VICC, the ISET open fault will be ignored and the channel will be recognized as unused. IS32LT3124B/C/E/F: In these two devices, the ISETx pin open detection is removed, then ISETx pin is able to implement the individual PWM dimming to the corresponding output channel. When ISETx pin is floating, the corresponding OUTx is turned off. Ground it via a resistor (RISETx) to enable the output source. Refer to Figure 4 and 5. When the PWM generator is far away from the device, use Figure 4 approach to prevent noise coupling due to the long trace. When the PWM generator is close to the device, use open drain structure I/O of the MCU to directly control each ISETx pin. Since Push-pull I/Os will force current into ISETx pins, only open drain structure I/Os are acceptable. With this individual PWM dimming, the LED current is inversely proportional to the source PWM duty cycle 25 IS32LT3124A/B/C/D/E/F (due to the open drain inversion). That is, when the source PWM signal is 100% duty cycle, the output current is minimum, ideally zero, and when the PWM signal is 0% duty cycle, the output current is maximum. LED current is computed using the following Equation (24). 2.5 VISET  2000 RISET (24) eTSSOP-16 Note: because of the 40µs (typ.) fault deglitch time tFD, the PWM on-time should be greater than 40us to avoid undetermined fault response. THERMAL SHUTDOWN In the event that the die temperature exceeds 165°C, all four output channels will go to the ‘OFF’ state and the FLTB pin will go low if VEN > VEN_TH. At this point, the IC should begin to cool off. Any attempt to enable one or all four of the channels before the IC has cooled to < 140°C will be ignored by the IC. 2 1.5 1 0.5 0 -40 -25 -10 THERMAL CONSIDERATIONS When operating the IS32LT3124 at high ambient temperatures, or when driving high load current, care must be taken to avoid exceeding the package power dissipation limits. The major power components are IC, PMOS FET and shunt resistor. Therefore their temperature should be carefully calculated and considered. In the application with the DHC function, the power dissipation of these three components is described in the “DYNAMIC HEADROOM CONTROL (DHC) AND THERMAL CONSIDERATIONS” section. In the application without the DHC function, the power dissipation on the IS32LT3124 can be computed by: 4 P3124  VCC  I CC   (VCC  VOUTx )  I OUTx (25) x 1 The maximum power dissipation of the IS32LT3124 and PMOS FET can be calculated using the following Equation (26): PD ( MAX )  TJ ( MAX )  TA  125C  25C  2.12W 47.1C / W Figure 74, shows the power derating of the IS32LT3124 on a JEDEC boards (in accordance with JESD 51-5 and JESD 51-7) standing in still air. Power Dissipation (W) I LED  (1  DPWM )  PD ( MAX )  5 20 35 50 65 80 95 110 125 Temperature (°C) Figure 74 IS32LT3124 Dissipation Curve The PMOS FET maximum power rating can be achieved by the same calculation method. In the Shunt Regulator mode, R1 will share quite a lot power dissipation. Its package power rating should be sufficient to prevent heat run away. When designing the Printed Circuit Board (PCB) layout, double-sided PCB with a large copper area on each side of the board directly under the IS32LT3124 (eTSSOP-16 package), PMOS FET and the shunt resistor must be used. Multiple thermal vias, as shown in Figure 75, will help to conduct heat from the exposed pad of the IS32LT3124, PMOS FET and shunt resistor to the copper on each side of the board. The thermal resistance can be further reduced by using a metal substrate or by adding a heat sink. To avoid heat buildup, these power components should be spread out on the PCB board with some distance. (26) JA Where, TJ(MAX) is the maximum operating junction temperature which can be found from their datasheets, TA is the ambient temperature, and θJA is the junction to ambient thermal resistance. P3124 should not exceed PD(MAX). For IS32LT3124, the recommended maximum operating junction temperature, TJ(MAX), is 125°C and so maximum ambient temperature is determined by the junction to ambient thermal resistance, θJA. Therefore the maximum power rating at TA= 25°C is: Figure 75 Lumissil Microsystems – www.lumissil.com Rev. A, 01/02/2019 Board Via Layout For Thermal Dissipation 26 IS32LT3124A/B/C/D/E/F Table 4 DIFFERENT FAULT ACTION OF 3 TYPES EN Voltage VEN_TH IS32LT3124A/D Fault Type Fault Condition Faulty Channel Other Channels IS32LT3124B/E FLTB Faulty Channel Other Channels IS32LT3124C/F FLTB Faulty Channel Other Channels Auto Recovery FLTB ISETx open ISETx pin current close to zero Off Enabled Off Enabled ISETx pin current goes back high ISETx short ISETx pin voltage (VISET_SC+VISET_SCHY) LED string open (VICC-VOUTx)(VOD+VOD_HY) VOUTx>(VSCD+VSCD_HY) TJ
IS32LT3124A-ZLA3-TR
物料型号:IS32LT3124A/B/C/D/E/F 器件简介:IS32LT3124是一款由Lumissil Microsystems生产的4通道线性可编程电流调节器,每个通道能够提供高达150mA的电流。
它具有5.0V至28V的输入电压范围,并且能够承受42V的负载转储。
该器件具备动态余量控制(DHC)功能,并且可以通过外部PMOS FET来最小化集成电路的热应力。
此外,它还集成了开路/短路和过温条件的故障检测电路。
引脚分配:IS32LT3124采用eTSSOP-16封装,具有16个引脚,包括设备使能引脚EN、HRSET引脚、ERC引脚、VCC引脚、4个ISET引脚、4个输出通道OUT1至OUT4、FLTB引脚、FLTD引脚和GND引脚。
参数特性:IS32LT3124的主要参数包括输出电流设置精度±5%,低 dropout 电压最大1V(100mA时),以及可编程的故障报告输出延迟时间。
此外,它还具有AEC-Q100认证,并在-40°C至+125°C的宽温度范围内工作。
功能详解:IS32LT3124具有多种功能,包括PWM调光和关闭控制输入、电源供应调制(PSM)、可选的动态余量控制(DHC)、故障保护和报告等。
它还提供了多种版本的选择,以适应不同的应用需求。
应用信息:IS32LT3124主要针对汽车市场,如车内氛围照明和外部尾灯。
它可以在汽车LED驱动RGBW汽车环境照明、尾灯、转向灯、日间行车灯等应用中使用。
封装信息:IS32LT3124提供在热增强型eTSSOP-16封装中。
IS32LT3124A-ZLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32LT3124A-ZLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32LT3124A-ZLA3-TR
  • 1+14.987891+1.93482
  • 10+10.9488410+1.41341
  • 25+9.9478725+1.28419
  • 100+8.84659100+1.14202
  • 250+8.32244250+1.07436
  • 500+8.00614500+1.03353
  • 1000+7.958011000+1.02732
库存:292
IS32LT3124A-ZLA3-TR
  • 2500+7.471022500+0.96445
  • 5000+7.305395000+0.94307
  • 7500+7.222487500+0.93237
库存:292
