3NT | SERIES
FIXED TEMPERATURE THERMOSTATS
Introduction
Automatic reset thermostat designed to meet your specific application requirements. Its patented and tamper proof snap action bi-metal disc provides reliable and
repeatable switch actuation. The 3NT is suitable for electrical loads ranging from dry circuits to 10A @ 240 VAC.
The core of the 3NT is the proven 1NT thermostat. Recognized by UL/CSA and KEMA/ENEC agencies, hundreds of millions of the 1NT device are in the field today used
in a variety of HVAC, appliance, automotive and specialty applications.
Manufactured at ISO 9001 certified manufacturing sites, its dry seal allows direct integration of the thermostat into a wire harness eliminating the need for extra
connections.
Features
• Automatic reset
• Small and easy to mount
• Fast thermal response
• Innovative dry seal design - protects from moisture and dust
• Reliable 100K cycle life
• High temperature - to 275ºF (135ºC)
Applications
• HVAC
• Commercial
• Dehumidifiers
• Freezers
• Heat pumps
• Ice makers
• Refrigerators
• Condensing or moist environments
SPECIFICATIONS
Agency
UL
(USA, Canada)
Electrical Ratings
ENEC (Europe)
Operating Temperature
Ambient Temperature
Temperature rating
Minimum Nominal Temperature
Differential
Dielectric Strength
Standard Wire Leads
Cycles
x1000
Volts
FLA
LRA
100
100
30
30
100
120 Vac
240 Vac
120 Vac
240 Vac
30 Vdc
5.8
2.9
10.0
10.0
34.8
17.4
40.0
40.0
30
240 Vac
Amps
(resistive)
VA
10
10
125
125
1
16
-20 to 135ºC (-4 to 275ºF)
-40ºC to maximum wire lead insulation
PVC - 105ºC
XLP - 125ºC
(Allow 15ºC de-rating below wire insulation rating at maximum 10A current)
8ºC (15ºF)
750 Vrms
1500 Vrms terminals to case
18 AWG (1/32” or 1/16” wall thickness in either 105°C PVC or 125°C XLPE)
16 AWG (1/32” wall thickness in 105°C PVC)
Page 1
Copyright © 2018 Sensata Technologies, Inc.
www.sensata.com
3NT DRY SEAL DESIGN
HOUSING
LOCKING CONNECTORS
O-RING
WIRE LEAD ASSEMBLY
1NT THERMOSTAT
3NT CUP
Important Notice: The 3NT is not hermetically sealed, and should not be submerged in liquid. For such applications, please contact Sensata.
STANDARD TEMPERATURES AND TOLERANCES
Nominal Top Temperature
(1)
Nominal Differential
Open Temperature
Close Temperature
˚F
˚C
˚F
˚C
˚F
˚C
˚F
˚C
32 to 80
0 to 27
20 - 29
30 - 38
39 - 60
11 - 16
17 - 21
22 - 33
±5.5
±5.5
±5.5
±3
±3
±3
±7.5
±8.5
±10
±4
±4.5
±5.5
81 to 167
28 to 75
20 - 23
24 - 29
30- 59
11 -13
14 -16
17 -33
±5.5
±5.5
±5.5
±3
±3
±3
±7.5
±8.5
±10
±4
±4.5
±5.5
168 to 199(1)
76 to 93(1)
20 -23
24 - 29
30 - 59
11 -13
14 -16
17 -33
±5.5
±5.5
±5.5
±3
±3
±3
±7.5
±8.5
±9
±4
±4.5
±5
200 to 249 (1)
94 to 121(1)
20 - 29
30 - 38
39 - 59
60 - 99
11 - 16
17 - 21
22 - 33
34 - 55
±6.5
±6.5
±6.5
±10
±3.5
±3.5
±3.5
±5.5
±8.5
±10
±12
±20
±4.5
±5.5
±6.5
±11
250 to 275
122 to 135
24 - 38
39 - 59
60 - 99
14 - 21
22 - 33
34 - 55
±7.5
±7.5
±10
±4
±4
±5.5
±10
±14.5
±20
±5.5
±8
±11
Minimum bottom temperature of 50ºC (122ºF)
Page 2
www.sensata.com
TYPICAL PHYSICAL CHARACTERISTICS
Dimensions in mm (inches)
Basic 3NT Dimensions
Open Tube Mount Clip (3/8 Inch Shown at 90º CCW
Rotation) 90° and 180° CW Rotations Available
Additional Clips Available for [1/4], [5/16],
[1/2], [5/8] tubes
Surface Mount Clip
Snap Tube Mount Clip
For 5/8 Inch and 1/2 Inch Tubes
Locking Tube Mount Clip (3/8 Inch Shown)
[1/2], [5/8] t ubes
Additional Clips Available for [3/4], [7/8] tubes
Page 3
www.sensata.com
ORDERING OPTIONS
Part Number
Temperature Code
3NT
01
L
H
XXXX
L
50
F
30
Family
L: Limit
F: Fan
Nominal Opening
Temperature
Temp. Code
C: Celsius
F: Fahrenheit
3NT
Contact Material
01: Silver
11: Gold
很抱歉,暂时无法提供与“3NT01L-H7901”相匹配的价格&库存,您可以联系我们找货
