SN74LS640, SN74LS641,
SN74LS642, SN74LS645
Octal Bus Transceivers
These octal bus transceivers are designed for asynchronous
two-way communication between data buses. Control function
implementation minimizes external timing requirements. These
circuits allow data transmission from the A bus to B or from the B bus
to A bus depending upon the logic level of the direction control (DIR)
input. Enable input (G) can disable the device so that the buses are
effectively isolated.
DEVICE
LS640
LS641
LS642
LS645
OUTPUT
3-State
Open-Collector
Open-Collector
3-State
http://onsemi.com
LOW
POWER
SCHOTTKY
LOGIC
Inverting
True
Inverting
True
MARKING
DIAGRAMS
SN74LS64xN
AWLYYWW
FUNCTION TABLE
CONTROL
INPUTS
1
OPERATION
G
DIR
LS640
LS642
LS641
LS645
L
L
B data to A bus
B data to A bus
L
H
A data to B bus
A data to B bus
H
X
Isolation
Isolation
PDIP−20
N SUFFIX
CASE 738
LS64y
AWLYYWW
H = HIGH Level, L = LOW Level, X = Irrelevant
1
1
GUARANTEED OPERATING RANGES (SN74LS640, SN74LS645)
Symbol
VCC
Parameter
Supply Voltage
TA
Operating Ambient
Temperature Range
IOH
Output Current − High
IOL
Min
Typ
Max
Unit
4.75
5.0
5.25
V
70
°C
−3.0
mA
−15
mA
24
mA
Output Current − Low
GUARANTEED OPERATING RANGES (SN74LS641, SN74LS642)
Symbol
VCC
Parameter
Supply Voltage
Min
Typ
Max
Unit
4.75
5.0
5.25
V
70
°C
TA
Operating Ambient
Temperature Range
VOH
Output Voltage − High
5.5
V
IOL
24
mA
SOIC−20
DW SUFFIX
CASE 751D
74LS64y
AWLYWW
1
1
SOEIAJ−20
M SUFFIX
CASE 967
x
= 0, 1, 2, or 5
y
= 0, 1, or 2
A
= Assembly Location
WL = Wafer Lot
Y, YY= Year
WW = Work Week
ORDERING INFORMATION
See detailed ordering and shipping information in the package
dimensions section on page 5 of this data sheet.
© Semiconductor Components Industries, LLC, 2006
July, 2006 − Rev. 11
1
Publication Order Number:
SN74LS640/D
SN74LS640, SN74LS641, SN74LS642, SN74LS645
CONNECTION DIAGRAMS DIP (TOP VIEW)
ENABLE
B1
G
20 19 18
B2
B3
B4
B5
B6
B7
B8
17
16
15
14
13
12
11
1
DIR
4
A3
5
A4
6
A5
7
A6
8
A7
9
A8
10
GND
VCC
2
A1
3
A2
ENABLE
VCC G
B1
20 19 18
B2
B3
B4
B5
B6
B7
B8
17
16
15
14
13
12
11
1
DIR
4
A3
5
A4
6
A5
7
A6
8
A7
9
A8
10
GND
Figure 1. SN74LS640
SN74LS642
2
A1
3
A2
Figure 2. SN74LS641
SN74LS645
http://onsemi.com
2
SN74LS640 • SN74LS645
DC CHARACTERISTICS OVER OPERATING TEMPERATURE RANGE (unless otherwise specified)
Limits
Symbol
VIH
Input HIGH Voltage
VIL
Input LOW Voltage
VIK
Input Clamp Diode Voltage
VOH
Min
Parameter
Typ
Max
2.0
0.6
−0.65
2.4
Output HIGH Voltage
−1.5
3.4
2.0
Unit
Test Conditions
V
Guaranteed Input HIGH Voltage for
All Inputs
V
Guaranteed Input LOW Voltage for
All Inputs
V
VCC = MIN, IIN = − 18 mA
V
VCC = MIN, IOH = 3.0 mA
V
VCC = MIN, IOH = MAX
0.25
0.4
V
IOL = 12 mA
0.35
0.5
V
IOL = 24 mA
VCC = VCC MIN,
VIN = VIL or VIH
per Truth Table
VOL
Output LOW Voltage
IOZH
Output Off Current HIGH
μA
VCC = MAX, VOUT = 2.7 V
IOZL
Output Off Current LOW
−400
μA
VCC = MAX, VOUT = 0.4 V
IIH
Input HIGH Current
A or B, DIR or G
μA
VCC = MAX, VIN = 2.7 V
DIR or G
0.1
mA
VCC = MAX, VIN = 7.0 V
A or B
0.1
mA
VCC = MAX, VIN = 5.5 V
−0.4
mA
VCC = MAX, VIN = 0.4 V
−225
mA
VCC = MAX
mA
VCC = MAX
IIL
Input LOW Current
IOS
Output Short Circuit Current (Note 1)
ICC
−40
Power Supply Current
Total Output HIGH
70
Total, Output LOW
90
95
Total at HIGH Z
1. Not more than one output should be shorted at a time, nor for more than 1 second.
AC CHARACTERISTICS (TA = 25°C, VCC = 5.0 V)
Limits
LS640
Min
LS645
Typ
Max
Min
Typ
Max
Unit
6.0
8.0
10
15
8.0
11
15
15
ns
tPLH
tPHL
Parameter
Propagation Delay
A to B
tPLH
tPHL
Propagation Delay
B to A
6.0
8.0
10
15
8.0
11
15
15
ns
tPZL
tPZH
Output Enable Time
G, DIR to A
31
23
40
40
31
26
40
40
ns
tPZL
tPZH
Output Enable Time
G, DIR to B
31
23
40
40
31
26
40
40
ns
tPLZ
tPHZ
Output Disable Time
G, DIR to A
15
15
25
25
15
15
25
25
ns
tPLZ
tPHZ
Output Disable Time
G, DIR to B
15
15
25
25
15
15
25
25
ns
Symbol
http://onsemi.com
3
Test Conditions
CL = 45 pF,
RL = 667 Ω
CL = 5.0 pF
SN74LS641 • SN74LS642
Limits
Symbol
VIH
Input HIGH Voltage
VIL
Input LOW Voltage
VIK
IOH
Output HIGH Current
VOL
Output LOW Voltage
IIH
Input HIGH Current
IIL
Input LOW Current
ICC
Min
Parameter
Typ
Max
Unit
Test Conditions
V
All Inputs
V
All Inputs
−1.5
V
100
μA
VCC = MIN, VOH = MAX
0.25
0.4
V
IOL = 12 mA
0.35
0.5
V
IOL = 24 mA
μA
−0.1
mA
−0.4
mA
mA
VCC = MAX
2.0
0.6
−0.65
Total, Output HIGH
70
Total, Output LOW
90
Total at HIGH Z
95
VCC = VCC MIN,
VIN = VIL or VIH
per Truth Table
Limits
LS641
Symbol
Parameter
Min
LS642
Typ
Max
Min
Typ
Max
Unit
tPLH
tPHL
Propagation Delay,
A to B
17
16
25
25
19
14
25
25
ns
tPLH
tPHL
Propagation Delay,
B to A
17
16
25
25
19
14
25
25
ns
tPLH
tPHL
Propagation Delay,
G, DIR to A
23
34
40
50
26
43
40
60
ns
tPLH
tPHL
Propagation Delay,
G, DIR to B
25
37
40
50
28
39
40
60
ns
http://onsemi.com
4
Test Conditions
CL = 45 pF,
RL = 667 Ω
DEVICE ORDERING INFORMATION
Device Order Number
Package Type
Tape and Reel Size
PDIP−20
1440 Units/Box
SN74LS640DW
SOIC−WIDE
2500/Tape and Reel
SN74LS640DWR2
SOIC−WIDE
2500/Tape and Reel
SN74LS640M
SOEIAJ−20
See Note 2
SN74LS640MEL
SOEIAJ−20
See Note 2
PDIP−20
1440 Units/Box
SN74LS641DW
SOIC−WIDE
2500/Tape and Reel
SN74LS641DWR2
SOIC−WIDE
2500/Tape and Reel
SN74LS641M
SOEIAJ−20
See Note 2
SN74LS641MEL
SOEIAJ−20
See Note 2
PDIP−20
1440 Units/Box
SN74LS642DW
SOIC−WIDE
2500/Tape and Reel
SN74LS642DWR2
SOIC−WIDE
2500/Tape and Reel
SN74LS642M
SOEIAJ−20
See Note 2
SN74LS642MEL
SOEIAJ−20
See Note 2
PDIP−20
1440 Units/Box
SN74LS640N
SN74LS641N
SN74LS642N
SN74LS645N
2. For ordering information on the EIAJ version of the SOIC package, please contact your local ON Semiconductor representative.
http://onsemi.com
5
PACKAGE DIMENSIONS
N SUFFIX
PLASTIC PACKAGE
CASE 738−03
ISSUE E
−A−
1
10
NOTES:
1. DIMENSIONING AND TOLERANCING PER ANSI
Y14.5M, 1982.
2. CONTROLLING DIMENSION: INCH.
3. DIMENSION L TO CENTER OF LEAD WHEN
FORMED PARALLEL.
4. DIMENSION B DOES NOT INCLUDE MOLD
FLASH.
B
L
C
−T−
K
SEATING
PLANE
G
M
N
E
F
D
J
0.25 (0.010)
20 PL
0.25 (0.010)
20 PL
M
T A
M
http://onsemi.com
6
M
T B
M
DIM
A
B
C
D
E
F
G
J
K
L
M
N
INCHES
MIN
MAX
1.010
1.070
0.240
0.260
0.150
0.180
0.015
0.022
0.050 BSC
0.050
0.070
0.100 BSC
0.008
0.015
0.110
0.140
0.300 BSC
0_
15 _
0.020
0.040
MILLIMETERS
MIN
MAX
25.66
27.17
6.10
6.60
3.81
4.57
0.39
0.55
1.27 BSC
1.27
1.77
2.54 BSC
0.21
0.38
2.80
3.55
7.62 BSC
0_
15_
0.51
1.01
PACKAGE DIMENSIONS
D SUFFIX
PLASTIC SOIC PACKAGE
CASE 751D−05
ISSUE F
A
q
X 45 _
1
10
20X
B
B
0.25
M
T A
S
B
S
A
L
0.25
E
h
H
M
10X
NOTES:
1. DIMENSIONS ARE IN MILLIMETERS.
2. INTERPRET DIMENSIONS AND TOLERANCES
PER ASME Y14.5M, 1994.
3. DIMENSIONS D AND E DO NOT INCLUDE MOLD
PROTRUSION.
4. MAXIMUM MOLD PROTRUSION 0.15 PER SIDE.
5. DIMENSION B DOES NOT INCLUDE DAMBAR
PROTRUSION. ALLOWABLE PROTRUSION SHALL
BE 0.13 TOTAL IN EXCESS OF B DIMENSION AT
MAXIMUM MATERIAL CONDITION.
11
B
M
D
18X
e
A1
SEATING
PLANE
C
T
http://onsemi.com
7
DIM
A
A1
B
C
D
E
e
H
h
L
q
MILLIMETERS
MIN
MAX
2.35
2.65
0.10
0.25
0.35
0.49
0.23
0.32
12.65
12.95
7.40
7.60
1.27 BSC
10.05
10.55
0.25
0.75
0.50
0.90
0_
7_
PACKAGE DIMENSIONS
M SUFFIX
SOEIAJ PACKAGE
CASE 967−01
ISSUE O
NOTES:
Y14.5M, 1982.
2. CONTROLLING DIMENSION: MILLIMETER.
FLASH OR PROTRUSIONS AND ARE MEASURED
AT THE PARTING LINE. MOLD FLASH OR
PROTRUSIONS SHALL NOT EXCEED 0.15 (0.006)
PER SIDE.
4. TERMINAL NUMBERS ARE SHOWN FOR
REFERENCE ONLY.
5. THE LEAD WIDTH DIMENSION (b) DOES NOT
INCLUDE DAMBAR PROTRUSION. ALLOWABLE
DAMBAR PROTRUSION SHALL BE 0.08 (0.003)
TOTAL IN EXCESS OF THE LEAD WIDTH
DIMENSION AT MAXIMUM MATERIAL CONDITION.
DAMBAR CANNOT BE LOCATED ON THE LOWER
RADIUS OR THE FOOT. MINIMUM SPACE
BETWEEN PROTRUSIONS AND ADJACENT LEAD
TO BE 0.46 ( 0.018).
LE
11
Q1
E HE
1
M_
L
10
DETAIL P
Z
D
e
VIEW P
A
A1
b
0.13 (0.005)
c
M
0.10 (0.004)
DIM
A
A1
b
c
D
E
e
HE
L
LE
M
Q1
Z
MILLIMETERS
MIN
MAX
2.05
0.05
0.20
0.35
0.50
0.18
0.27
12.35
12.80
5.10
5.45
1.27 BSC
7.40
8.20
0.50
0.85
1.10
1.50
10 _
0_
0.70
0.90
0.81
INCHES
MIN
MAX
0.081
0.002
0.008
0.014
0.020
0.007
0.011
0.486
0.504
0.201
0.215
0.050 BSC
0.291
0.323
0.020
0.033
0.043
0.059
10 _
0_
0.028
0.035
0.032
ON Semiconductor and
are registered trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes without further notice
to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SCILLC assume any liability
arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
“Typical” parameters which may be provided in SCILLC data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All
operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights
nor the rights of others. SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications
intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a situation where personal injury or death may occur. Should
Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold SCILLC and its officers, employees, subsidiaries, affiliates,
and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death
associated with such unintended or unauthorized use, even if such claim alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal
Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner.
PUBLICATION ORDERING INFORMATION
LITERATURE FULFILLMENT:
Literature Distribution Center for ON Semiconductor
P.O. Box 5163, Denver, Colorado 80217 USA
Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada
Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada
Email: orderlit@onsemi.com
N. American Technical Support: 800−282−9855 Toll Free
USA/Canada
Europe, Middle East and Africa Technical Support:
Phone: 421 33 790 2910
Japan Customer Focus Center
Phone: 81−3−5773−3850
http://onsemi.com
8
ON Semiconductor Website: www.onsemi.com
Order Literature: http://www.onsemi.com/orderlit
For additional information, please contact your local
Sales Representative
SN74LS640/D
