ASNT1121-KMM
ASNT1121-KMM
    ADSANTEC(先进科技)
    CQFP44
    4:1 BROADBAND DIG. MULTIPLEXER
ASNT1121-KMM 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT1121-KMM DC-50Gbps Broadband Digital 4:1 Multiplexer  Differential CML I/O data and clock buffers  Quarter-rate clock output  Single +3.3V or -3.3V power supply  Power consumption: 960mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 44-pin package vcc vee vcc d1p vcc d1n vcc vcc n/c vcc qp ASNT1123-KMM ASNT1121 d2p vcc d2n vcc vcc qn vcc 1 cep vcc cen vcc vcc d3n vcc n/c vcc vee vcc vcc vee vcc d3p Rev. 1.8.2 vee vcc Exhibits low jitter and limited temperature variation over industrial temperature range vcc c4op vcc  d0n vcc d0p vcc c4on High speed broadband 4:1 Multiplexer (MUX) vcc  January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION vcc d0p d0n d1p d1n vcc qp qn d2p d2n d3p d3n vcc cep cen DIV c4op c4on Fig. 1. Functional Block Diagram The ASNT1121-KMM SiGe IC is a low power and high-speed digital 4-to-1 serializer-multiplexer (MUX) that functions seamlessly over data rates (fbit) ranging from DC to its maximum frequency. The main function of the part shown in Fig. 1 is to multiplex 4 parallel differential CML data signals d0p/d0n, d1p/d1n, d2p/d2n, d3p/d3n running at a bit rate of fbit/4 into a high speed serial bit stream qp/qn running at a bit rate of fbit. Differential or single-ended full-rate clock cep/cen must be provided by an external source for the part to function properly. The serialized data words qp/qn and the clock divided-by-4 signal c4op/c4on are transmitted through CML output interfaces. The clock and data outputs are phase-matched to each other resulting in a very little relative skew over the operating temperature range of the device. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.3V), or positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. Rev. 1.8.2 2 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground. Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Rev. 1.8.2 Min -40 10 10 3 Max -3.6 1.1 1.4 +100 +100 98 98 Units V W V ºC ºC % % January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL FUNCTIONS TERMINAL Name No. Type d0p d0n d1p d1n d2p d2n d3p d3n c4op c4on cep cen qp qn Name vcc vee n/c Rev. 1.8.2 DESCRIPTION Low-Speed I/Os Differential quarter-rate data inputs with internal SE 50Ohm termination to vcc Differential quarter-rate data inputs with internal SE 50Ohm termination to vcc Differential quarter-rate data inputs with internal SE 50Ohm termination to vcc Differential quarter-rate data inputs with internal SE 50Ohm termination to vcc Differential quater-rate clock outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc High-Speed I/Os 8 CML Differential full-rate clock input signals with internal 50Ohm input termination to vcc 10 19 CML Differential full-rate data outputs with internal SE 50Ohm output termination to vcc. Require external SE 50Ohm termination to vcc 17 Supply and Termination Voltages Description Pin Number Positive power supply 1, 3, 5, 7, 9, 11, 12, 14, 16, 18, 20, 22, 23, 25, 27, 29, (+3.3V or 0) 31, 33, 34, 36, 38, 40, 42, 44 Negative power supply 2, 13, 24, 35 (0V or -3.3V) Not connected pins 15, 21 30 32 37 39 41 43 4 6 26 28 CML input CML input CML input CML input CML output 4 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% vee 0.0 V External ground vcc Ivee 290 mA Power consumption 960 mW Junction temperature -40 25 125 °C LS Input Data (d0p/d0n, d1p/d1n, d2p/d2n, d3p/d3n) Data Rate DC 10 12.5 Gbps Swing 0.2 0.8 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs HS Input Clock (cep/cen) Frequency DC 40 50 GHz Swing 0.2 0.8 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs Duty Cycle 40 50 60 % HS Output Data (qp/qn) Data Rate DC 40 50 Gb/s Logic “1” level V vcc Logic “0” level vcc-0.6 V With external 50Ohm DC termination Output Jitter 3 ps Peak-to-peak at 40Gb/s LS Output Clock (c4op/c4on) Frequency DC 10 12.5 GHz Logic “1” level V vcc Logic “0” level vcc-0.6 V With external 50Ohm DC termination Duty Cycle 50 % Output Jitter 2 ps Peak-to-peak at 10GHz PACKAGE INFORMATION The chip die is housed in a custom 44-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT1121-KMM. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. Rev. 1.8.2 5 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Fig. 2. CQFP 44-Pin Package Drawing (All Dimensions in mm) Rev. 1.8.2 6 January 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.8.2 1.7.2 1.7.1 1.6.1 1.5.1 Date 01-2020 07-2019 05-2019 05-2015 02-2013 1.4.1 01-2013 1.3.1 1.3 1.2 12-2011 11-2011 05-2011 1.1 01-2011 1.0 12-2010 Rev. 1.8.2 Changes Updated Package Information Updated Letterhead Corrected cep/cen description in Terminal Function table Updated Package Information section Title correction Corrected description Corrected Terminal Functions table Corrected Electrical Characteristics Updated Package Information Corrected block diagram Updated Package Information Updated Description Format Correction Corrected Terminal Functions table Added Absolute Maximums Rating table Added packaging information Added RoHS compliancy Added revision history table First release 7 January 2020
ASNT1121-KMM 价格&库存
很抱歉,暂时无法提供与“ASNT1121-KMM”相匹配的价格&库存,您可以联系我们找货
