ASNT2110C-KMF
ASNT2110C-KMF
    ADSANTEC(先进科技)
    CFlatPack64
    34G CDR DMUX W/ PAM4 CLOCK REC.
ASNT2110C-KMF 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT2110C-KMF Programmable CDR DMUX 1-to-2 1:2 demultiplexer (DMUX) with integrated selectable full-rate CDR  Input data range from DC to 34.0Gb/s  Digital operational mode with DC to 34GHz external clock  CDR locking range from 25.2Gb/s to 32.5Gb/s  RZ and NRZ input data formats  Adjustable time of data sampling point for optimum BER performance  CML compliant differential input and output high-speed data and clock interfaces  LVDS compliant input reference clock interface  Full rate clock and retimed data output for 1:1 CDR operation  Half rate data outputs with toggle synchronization functionality  Signal inversion and muting capabilities in all output buffers  Single +3.3V or -3.3V power supply  Low power consumption of 1.6W at the maximum operational speed  Industrial temperature range  Custom CQFP 64-pin package vee vcc dop vcc don vcc ondo pol tog onco vcc c2p vcc c2n vcc vee  ASNT2110D ASNT2110C vee vcc q0p vcc q0n vcc ond2o lolp icph icpl vcc q1p vcc q1n vcc vee vee vcc cep vcc cen vcc vcos1 ftr rngcrl/is vcos0 vcc c32p vcc c32n vcc vee vee vee pkdtp pkdtn dcinp vcc vcc dp vcc dn vcc vcc dcinn phshft vee vee Rev. 1.1.2 1 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION ondo ce ond2o d dcinp dcinn pkdtp pkdtn c32 HS CIB DOB D Data IB DMX 1:2 CDR CLK IB do D2OB x2 q1 C2 lolp fltp phshft icph icpl rngcrl/is q0 COB c2 vcos0 vcos1 tog pol onco Fig. 1. Functional Block Diagram ASNT2110C-KMF is a 1:2 demultiplexer (DMUX) with full-rate integrated clock and data recovery (CDR). The IC shown in Fig. 1 can function in either CDR mode covering a wide range of input data rates (fbit) by utilizing its three on-chip VCOs (voltage-controlled oscillators), or in a broadband digital mode. Selection of the desired working data rate and mode is accomplished through pins vcos0 and vcos1 (see Table 1). An external low speed system clock c32p/c32n running at 1/32 the frequency of the active VCO must be applied to the low-speed LVDS clock input buffer (CLK IB) in CDR mode. An external full-rate clock cep/cen must be applied to the high speed CML clock input buffer (HS CIB) for digital operation. The main function of the chip is to convert a RZ or NRZ input data signal dp/dn with a bit rate of fbit accepted by CML buffer (Data IB) into 2 parallel NRZ data signals q0p/q0n and q1p/q1n running at bit rates of fbit/2 and delivered to the outputs by CML data output buffers (D2OBx2). The clock and data are recovered from the input data stream by the CDR. The phase of the clock recovered by the CDR can be adjusted externally through pin phshft to locate the optimum data sampling point and achieve the lowest system bit error rate (BER). A full rate retimed NRZ data output signal dop/don is also available through the CML data output buffer (DOB) allowing the part to be used as a 1:1 CDR. Half rate clock c2p/c2n delivered through the CML clock output buffer (COB) has a tight phase alignment to the demultiplexed data output signals q0p/q0n and q1p/q1n. Rev. 1.1.2 2 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Data IB can operate with either differential or single-ended input signals. It includes tuning pins dcinp/dcinn for DC offset of the input signals in case of AC termination. When the buffer is operating with a DC-terminated single ended input signal, a correct threshold voltage should be applied to the unused input pin. A peak detector is also included to provide means of demodulating AM components carried by the input data with frequency ranges of up to a few hundred KHz. The peak detector’s output signal is delivered to the differential port pkdtp/pkdtn. All CML I/Os provide on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). Output buffers DOB, COB, and D2OBx2 can be individually disabled through pins ondo, onco, and ond2o to save power. Utilizing pin pol, the deserializer can invert the polarity of the three output data signals. Pin tog flips the order of q0p/q0n and q1p/q1n signals thus simplifying the interface between the DMUX and a following ASIC. It also allows for synchronization of the bit order of two or more DMUXes working in parallel. A loss of lock CMOS alarm signal lolp is generated by the CDR to indicate its locking state. An off chip passive filter is required by the CDR, and should be connected to pin ftr (see CDR). The deserializer is characterized for operation from 0°C to 125°C of junction temperature. The package temperature resistance is 15°C /W. Data IB The Data Input Buffer (Data IB) can process an input CML data signal dp/dn in either RZ or NRZ format due to its high analog bandwidth. It provides on-chip single-ended termination of 50Ohm to vcc for each input line. The buffer can also accept a single-ended signal to one of its input ports dp or dn with a threshold voltage applied to the unused pin in case of DC termination. In case of AC termination, tuning pins dcinp/dcinn allow for data common mode adjustment. The tuning pins have 1KOhm terminations to vcc and allow the user to change the slicing level before the data is sampled by the recovered clock. Tuning voltages from vcc to vee deliver 150mV of DC voltage shift. Also included in Data IB is an input signal peak detector that delivers its response through the output differential signal pkdtp/pkdetn. The detector can demodulate AM component(s) carried by the input data with frequency ranges of up to a few hundred KHz. The detector’s output impedance is 4KOhm single ended to vcc. HS CIB The High-Speed Clock Input Buffer (HS CIB) can process either differential or single-ended external CML clock signals cep/cen. In single-ended mode, the clock is applied to one of the pins together with a threshold voltage applied to the unused pin. The buffer utilizes on-chip single-ended termination of 50Ohm to vcc for each input line. CLK IB The Clock Input Buffer (CLK IB) consists of a proprietary universal input buffer (UIB) that exceeds LVDS standards IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995. UIB is designed to accept differential signals with a speed up to 1Gb/s, DC common mode voltage variation between vcc and vee, Rev. 1.1.2 3 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com AC common mode noise with a frequency up to 5MHz, and voltage levels ranging from 0 to 2.4V. It can also receive a DC-terminated single-ended signal with a threshold voltage between vcc and vee applied to the unused pin. The input termination impedance is set to 100Ohm differential. CDR The Clock and Data Recovery Block (CDR) contains both a phase and frequency acquisition loop. The frequency loop works in concert with low-speed clock c32p/c32n while the phase loop utilizes data signal dp/dn. The CDR requires a single off-chip filter shown in Fig. 2 to be connected to pin ftr. 66Ohm ftr 390pF 22nF Fig. 2. External Loop Filter The main function of the CDR is to frequency-lock the selected on-chip VCO to the input data signal (clock recovery) while phase-aligning it to latch in the incoming data with minimal error (data recovery). By default, the CDR aligns the recovered clock’s working edge in the middle of the incoming data bits. A DC voltage from vee to vcc applied to pin phshft can be utilized to shift this position from one edge of the data bit to the other in order to locate the optimum sampling point which provides the lowest system BER. The recovered clock is divided down in frequency by two (C2) and utilized by DMX 1:2 for demultiplexation of the recovered data. By utilizing the 2.5V CMOS control pins vcos0 and vcos1, the desired working frequency of the CDR can be selected in accordance with Table 1 below. Table 1. CDR Mode Selection (Case Temperature from 0 to 90°C) vcos0 vcos1 VCO Operation Frequency (GHz) “0” (0V) “0” (0V) fmin≤25.2, fmax≥27.4 “0” (0V) ”1” (2.5V) fmin≤26.3, fmax≥30.0 ”1” (2.5V) “0” (0V) fmin≤29.9, fmax≥32.5 ”1” (2.5V) ”1” (2.5V) Digital Mode, default state The loop gain can be adjusted by two 2.5V CMOS control pins icph and icpl that control the charge pump current as shown in Table 2. Table 2. Charge Pump Current Control icph icpl Charge Pump current, mA “0” (0V) “0” (0V) Imax “0” (0V) ”1” (2.5V) Imax-0.04 ”1” (2.5V) “0” (0V) Imax-0.27 ”1” (2.5V) ”1” (2.5V) Imax-0.31 By utilizing the analog control pin rngcrl/is, locking frequency ranges of the three VCOs can be adjusted. Fig. 3, Fig. 4, and Fig. 5 present locking ranges of low-frequency, middle-frequency, and high-frequency Rev. 1.1.2 4 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com VCOs respectively. Each plot shows the dependence of minimum and maximum locking frequencies (in GHz) on the voltage (in V above vee) of the control pin rangecrl/is. The lock detect circuitry signals an alarm through the 2.5V CMOS signal lolp when a frequency difference exists between an applied system reference clock c32p/c32n and a recovered full rate clock divided-by-32 that is greater than ±1000ppm. Fig. 3. Locking Range of Low-Frequency VCO vs. Control rngcrl/is Fig. 4. Locking Range of Middle-Frequency VCO vs. Control rngcrl/is Rev. 1.1.2 5 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 5. Locking Range of High-Frequency VCO vs. Control rngcrl/is Another feature included in the CDR is the ability to simultaneously invert the polarity of all three data outputs through the 2.5V CMOS input pin pol (pol = “1” (default): direct; pol = “0”: inverted). The order of the half-rate output data streams can be inverted by using the 2.5V CMOS input pin tog, which provides means to synchronize two adjacent DMUXes operating in parallel. The synchronization process may be accomplished by the “blind” toggling in one of the chips and leaving the task of recognizing the “right” position to downstream components (e.g. FEC chip). DMX1:2 The 1 to 2 Demultiplexer (DMX1:2) latches in the retimed data stream D from the CDR on both edges of the half rate clock signal C2. The high speed data signal is subsequently demultiplexed into two half rate NRZ data signals and delivered to D2OBx2 in parallel fashion as a 2-bit wide word with the order defined by the tog signal. DOB The Data Output Buffer (DOB) receives a full rate retimed serial data stream D from the CDR and converts it into a CML output signal dop/don. This CML buffer requires 50Ohm external termination resistors connected between vcc and each output. The buffer can be enabled or disabled by the external 2.5V CMOS control signal ondo (ondo = “1” (default): enabled; ondo = “0”: disabled). D2OBx2 The Half Rate Data Output Buffer (D2OBx2) receives two half rate data signals from DMX1:2 and converts them into CML output signals q0p/q0n and q1p/q1n. The buffer requires 50Ohm external termination resistors connected between vcc and each output. The buffer can be enabled or disabled by the external 2.5V CMOS control signal ond2o (ond2o = “1” (default): enabled; ond2o = “0”: disabled). Rev. 1.1.2 6 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com COB The Clock Output Buffer (COB) receives a half rate clock signal from DMX1:2 and converts it into CML output signal c2p/c2n. The buffer requires 50Ohm external termination resistors connected between vcc and each output. The buffer can be enabled or disabled by the external 2.5V CMOS control signal onco (onco = “1” (default): enabled; onco = “0”: disabled). The negative edge of the c2 signal is aligned to the half rate output data crossing points. POWER SUPPLY CONFIGURATION The ASNT2110C-KMF can operate with either a negative supply (vcc = 0.0V = ground and vee = -3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of a positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 3.3V and vee = 0V (external ground) ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 3 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only that are specified in ELECTRICAL CHARACTERISTICS. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 3. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption Input Voltage Swing (SE) Case Temperature*) Storage Temperature Operational Humidity Storage Humidity *) - Operating the part at temperatures over Min -40 10 10 Max +3.8 1.6 1.0 +90 +100 98 98 Units V W V ºC ºC % % this value could/will damage the part. Operating at this temperature or any temperatures above the recommended maximum value specified in ELECTRICAL CHARACTERISTICS does not guarantee correct functionality as is stated above. TERMINAL FUNCTIONS Name vcc vee Rev. 1.1.2 Supply and Termination Voltages Description Pin Number Positive power supply (+3.3V) 2, 4, 6, 11, 13, 15, 18, 20, 22, 27, 29, 31, 34, 36, 38, 43, 45, 47, 54, 55, 57, 59, 60 Negative power supply (GND or 0V) 1, 16, 17, 32, 33, 48, 49, 50, 63, 64 7 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL Name No. Type High-Speed I/Os CML differential full rate clock inputs with internal SE 50Ohm termination to vcc CML differential half rate data outputs. Require external SE 50Ohm termination to vcc cep cen q1p q1n q0p q0n c2p c2n dop don dp dn 3 5 21 19 30 28 37 35 46 44 56 58 c32p c32n pkdtp pkdtn 12 14 51 52 vcos1 vcos0 icpl icph ond2o Controls 7 LS In., CDR operational mode selection, see Table 1 10 2.5V CMOS 23 Charge pump current control, see Table 2 24 26 D2OBx2 control (high, default: buffer is on; low: buffer is disabled) onco 39 COB control (high, default: buffer is on; low: buffer is disabled) tog pol ondo lolp 40 41 42 25 Order inversion of output data signals (default: high) Data output signal polarity (high, default: inverted data outputs) DOB control (high, default: buffer is on; low: buffer is disabled) CDR lock indicator (high: no lock; low: locked) dcinp dcinn phshft rngcrl/is ftr Rev. 1.1.2 Input DESCRIPTION Output Output Output Input Input Output CML differential half rate clock outputs. Require external SE 50Ohm termination to vcc CML differential full rate data outputs. Require external SE 50Ohm termination to vcc CML differential data inputs with internal SE 50Ohm termination to vcc Low-Speed I/Os LVDS clock input with internal differential 100Ohm termination Peak detector outputs LS out, 2.5V CMOS 53 LS IN Input data common mode voltage adjustment 61 62 LS IN CDR sampling point adjustment 9 LS IN VCO frequency range adjustment control with internal 107kOhm termination to vcc and 213kOhm termination to vee 8 I/O External CDR filter connection 8 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER TYP MAX UNIT COMMENTS General Parameters +3.0 +3.3 +3.6 V ±9% vcc 0.0 V vee Ivcc 490 mA All functions active Power Consumption 1.6 W Junction Temperature -25 50 125 °C Case temperature 75 °C Recommended value HS Input Data (dp/dn) DC 34 Gbps Digital mode Data Rate 25.2 32.5 Gbps CDR mode Swing p-p (Diff or SE) 0.05 0.6 V at 34Gbps CM Voltage Level vcc-0.8 vcc V LS Input Reference Clock (c32p/c32n) Frequency 787.5 1015.625 MHz Swing p-p (Diff or SE) 0.06 0.8 V CM Voltage Level V vee vcc Duty Cycle 40 50 60 % HS Output Full Rate Data (dop/don) DC 34 Gbps Digital mode Data Rate 25.2 32.5 Gbps CDR mode Logic “1” level V vcc Logic “0” level vcc -0.4 vcc -0.3 V Jitter 7 8 ps HS Output Half Rate Data (q0p/q0n, q1p/q1n) DC 17 Gbps NRZ, Digital mode Data Rate 12.6 16.25 Gbps NRZ, CDR mode Logic “1” level V vcc Logic “0” level vcc -0.4 V Jitter 7 ps HS Output Half Rate Clock (c2p/c2n) DC 17.0 GHz Digital mode Clock Rate 12.6 16.25 GHz CDR mode Logic “1” level V vcc Logic “0” level vcc -0.4 vcc -0.15 V Jitter 5 8 ps Input Data Common Mode Control (dcinp/dcinn) Input DC Voltage V vee vcc Input Data Voltage Shift 0 -150 mV Referenced to vcc Output of Peak Detector (pkdtp/pkdtn) Swing p-p (Diff) -1 1 V Over full input range CM Voltage Level vcc -1.0 V Data Sampling Point Adjustment (phshft) Rev. 1.1.2 MIN 9 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PARAMETER Input DC Voltage Phase Shift Shift Stability Bandwidth Control voltage level Logic “1” level Logic “0” level MIN TYP MAX UNIT vcc -1.0 NC vcc V -15 0 +15 ps -2 2 ps 0.0 100 MHz Locking Range Control (rangecrl/is) vee + 0.7 vee + 1.7 V CMOS Control Inputs/Outputs 2.1 2.5 V vee +0.4 V Timing Parameters c2p/c2n to q0p/q0n & q1p/q1n delay variation 2 ps COMMENTS NC=Not Connected From 0°C to 125°C Do not exceed vee+2.5V Over the full temperature range PACKAGE INFORMATION The chip die is housed in a custom 64-pin CQFP package. The dimensioned drawings are shown in Fig. 6. The package’s leads will be trimmed to a length of 1.0mm. After trimming, the package’s leads will be further processed as follows: 1. The lead’s gold plating will be removed per the following sections of J-STD-001D: 3.9.1 Solderability 3.2.2 Solder Purity Maintenance 3.9.2 Solderability Maintenance 3.9.3 Gold Removal 2. The leads will be tinned with Sn63Pb37 solder The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT2110C-KMF. The first 9 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with Commission Delegated Directive (EU) 2015/863 of 4 June 2015 amending Annex II to Directive 2011/65/EU of the European Parliament and of the Council as regards the list of restricted substances (Text with EEA relevance) on the restriction of the use of certain hazardous substances in electrical and electronics equipment (RoHS Directive) in accordance with the definitions set forth in the directives for all ten substances. Rev. 1.1.2 10 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 6. CQFP 64-Pin Package Drawing (All Dimensions in mm) Rev. 1.1.2 11 February 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.1.2 Date 02-2021 1.0.2 10-2020 0.2.2 04-2020 0.1.2 0.0.2 04-2020 04-2020 Rev. 1.1.2 Changes Corrected the description of the control rangecrl/is in the CDR section Corrected Terminal Functions table Corrected Electrical Characteristics table Corrected Power Supply Configuration section Corrected frequency range Corrected short description (bullets) Corrected filter schematic Corrected Electrical Characteristics table Corrected main features Corrected VCO upper frequency limit Corrected Electrical Characteristics Corrected data rate and clock frequency Preliminary release 12 February 2021
ASNT2110C-KMF 价格&库存
很抱歉,暂时无法提供与“ASNT2110C-KMF”相匹配的价格&库存,您可以联系我们找货
