ASNT1140-KMA
ASNT1140-KMA
    ADSANTEC(先进科技)
    CQFP100
    16:1 BROADBAND DIG. MULTIPLEXER
ASNT1140-KMA 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT1140-KMA DC-to-50Gbps Programmable DDR Multiplexer 16:1 / Serializer 76 vcc 77 d05p 78 d05n 79 vcc 80 d06p 81 d06n 82 vcc 83 d07p 84 d07n 85 vcc 86 d08p 87 d08n 88 vcc 89 d09p 90 d09n 91 vcc 92 d10p 93 d10n 94 vcc 95 d11p 96 d11n 97 vcc 98 d12p 99 d12n 100 vcc Rev. 1.8.2 vee 75 vecl 74 d04n 73 d04p 72 vcc 71 d03n 70 d03p 69 vcc 68 d02n 67 d02p 66 vcc 65 d01n 64 d01p 63 vcc 62 d00n 61 d00p 60 bitorder 59 vee 58 phs1 57 phs2 56 vcc 55 nc 54 nc 53 vee 52 vee 51 Programmable digital serializer 16-to-1 Supports data rates from DC to 50Gb/s in DDR clocking mode Programmable LVDS/CML/ECL input data buffers CML input clock buffer Switchable forwarded DDR clock output phase-aligned with output data LVDS output full-rate sampling clock with a selectable phase to synchronize input data External reset for synchronization of multiple devices Single +3.3V power supply Industrial temperature range Power consumption of 1520mW at maximum speed Custom 100-pin CQFP package (13mm x 13mm) ASNT 1140 vee 50 clop 49 clon 48 ampadj 47 rstp 46 rstn 45 vcc 44 nc 43 nc 42 vcc 41 qp 40 qn 39 vcc 38 cdcadj 37 vee 36 vcc 35 c2op 34 c2on 33 vcc 32 vtrm 31 vtrm 30 vcc 29 c2ip 28 c2in 27 vcc 26 1 vee 2 vecl 3 d13p 4 d13n 5 vcc 6 d14p 7 d14n 8 vcc 9 d15p 10 d15n 11 vcc 12 nc 13 nc 14 offecl 15 vee 16 nc 17 vee 18 offcho 19 nc 20 nc 21 nc 22 cdccn 23 vee 24 cdccp 25 vcc            1 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION bitorder d00p/d00n d15p/d15n offecl vecl rstp/rstn vtrm cdccp cdccn cdcadj c2ip/c2in DIB x16 16 Data OB MUX 16:1 C16 CLK Proc HS CIB LVDS COB qp/qn clop/clon phs1 phs2 /8 C2 ampadj HS COB offcho c2op/c2on Fig. 1. Functional Block Diagram ASNT1140-KMA is a high-speed DDR (dual data rate) digital 16-to-1 multiplexer (MUX) / serializer. The IC shown in Fig. 1 functions seamlessly over the specified range of data rates (fbit). The main function of the IC is to multiplex 16 parallel data channels running at a bit rate of fbit/16 into a high-speed serial bit stream running at fbit. It provides a high-speed output data channel for point-to-point data transmission over a controlled impedance media of 50Ohm. The transmission media can be a printed circuit board or copper coaxial cables. The functional distance of the data transfer is dependent upon the attenuation characteristics of the transportation media and the degree of noise coupling to the signaling environment. During normal operation, the serializer’s data input buffer (DIBx16) accepts external 16-bit wide parallel data words d00p/d00n-d15p/d15n through 16 differential LVDS inputs and delivers them to the multiplexer’s core (MUX16:1) for serialization. A half-rate CML clock (a full-rate clock divided by 2) must be provided by an external source to the inputs c2ip/c2in of the high-speed clock input buffer (HS CIB) where it is routed to both the high-speed clock output buffer (HS COB) and the internal divider-by-8 (/8). The high-speed CML clock input buffer provides on-chip 50Ohm termination and is designed to be driven by devices with 50Ohm source impedance. The duty cycle of the internal clock c2 can be adjusted either through a single ended control pin cdcadj or through a dual control port cdccp/cdccn. The clock input buffer uses a separate positive supply vtrm for additional common mode voltage adjustment. The divider provides signaling for MUX16:1 and produces a divided-by-16 full-rate sampling clock C16 for the low-speed LVDS-compliant clock output buffer (LVDS COB). The divider can be preset to a certain initial state using external CML signals rstp/rstn. The phase of the low-speed output sampling clock clop/clon can be modified in 90° increments by utilizing pins phs1 and phs2 and the clock processing block (CLK Proc). By utilizing the pin bitorder, the serializer can designate either d00p/d00n or d15p/d15n as the MSB (most significant bit that is delivered first to the serial interface), thus simplifying the interface between the multiplexer and a preceding device. Rev. 1.8.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The serialized words are transmitted as a differential signal qp/qn by a CML output buffer (Data OB). A DDR mode forwarded CML clock c2op/c2on is transmitted by HS COB in parallel with the high-speed data. The clock and data outputs are well phase matched to each other resulting in very little relative skew over the operating temperature range of the device. Both output stages are back terminated with on-chip 50Ohm resistors. An example of a differential output eye at 28Gb/s is shown in Fig. 2. Fig. 2. 28Gb/s Output Eye The chip uses a single +3.3V power supply and is characterized for operation from −25°C to 125°C of junction temperature. DIBx16 The Data Input Buffer (DIB) is a proprietary universal input buffer (UIB) that can run at a frequency up to 2.5GHz. The input termination impedance is controlled by 3.3V CMOS signal offecl and is set to 100Ohm differential if offecl = “1” (true LVDS mode, default state) or 50Ohm single-ended to vecl if offecl = “0” (CML mode). The value of vecl should be equal to vcc in CML mode or vcc-2V in PECL mode. In this case, the corresponding termination voltage source should be able to both sink and source up to 20mA of current. Possible input clock application schemes are detailed in Table 1, where Vcm is the commonmode voltage of the clock signal. Table 1. LS Input Clock Application Schemes Interface Clock cep signal type type Swing, mV Connection Vcm, V LVDS Diff. 70-to-500 DC 1.2±1.0 (offecl SE 140-to-900 AC = “1”) Threshold DC vee-to-vcc CML or Diff. 70-to-500 DC vcc-Swing/2 PECL AC (offecl SE 140-to-900 AC = “0”) 140-to-900 AC N/C Threshold DC vcc Swing, mV 70-to-500 Threshold 140-to-900 70-to-500 Threshold 140-to-900 140-to-900 cen signal Connection Vcm, V DC 1.2±1.0 DC vee-to-vcc AC DC vcc-Swing/2 AC Not connected DC vcc AC AC - As can be seen, UIB is designed to accept differential signals with amplitudes above 60mV peak-to-peak (p-p), DC common mode voltage variation between negative vee and positive vcc supply rails, and AC common mode noise with a frequency up to 5MHz and voltage levels ranging from 0 to 2.4V. It can also receive single-ended signals with amplitudes above 60mVp-p and threshold voltages between vee and vcc. UIB fully complies with LVDS standards IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995. Rev. 1.8.2 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com HS CIB The High-Speed Clock Input Buffer (HS CIB) can accept high-speed clock signals at its differential CML input port c2ip/c2in. It can also accept a single-ended signal with a threshold voltage applied to the unused pin. HS CIB can handle a wide range of input signal amplitudes. The buffer utilizes on-chip single-ended 50Ohm termination to vtrm for each input line. This termination voltage can be adjusted within the range from vcc to vcc-0.8V. The buffer provides two options for adjustment of its output signal duty cycle. The duty cycle can be adjusted by changing two control voltages cdccp and cdccn that affect the input signals c2ip and c2in respectively. It can also be adjusted using one control voltage cdcadj following the diagram shown in Fig. 3. Here red lines correspond to the dp input, blue lines correspond to the dn input, solid lines represent typical conditions while dotted and dashed lines represent slow and fast conditions respectively. Fig. 3. Duty Cycle Control Diagram It should be noted that only one control option should be activated at a certain time. Either cdccp/cdccn or cdcadj pins should be left not connected or AC-terminated with 50Ohm loads. Otherwise, the two internal control circuits interact and the desired result cannot be achieved. /8 The Divider-by-8 (/8) includes three divide-by-2 circuits connected in series. The half-speed clock C2 is routed internally to the first divide-by-2 circuit and outside of the block to MUX16:1. Other divided down clock signals are formed and routed to MUX16:1 in a similar fashion. C16 is passed on to LVDS COB to become the output low-speed sampling clock signal clop/clon. The divider can be preset to a “0” state using external differential CML signals rstp/rstn that have onchip 50Ohm termination to vcc. The reset circuitry can operate at high speed and features internal retiming by the falling edge of half-rate clock. The desired phase relation between the reset signal and the input clock c2ip/c2in is illustrated by Fig. 4 and specified in Table 2Error! Reference source not found.. Rev. 1.8.2 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Table 2. Input Reset to Input Low-Speed Sampling Clock Phase Delay Maximum required recovery time, ps Maximum required removal time, ps -18 33 tremoval Input c2ip trecovery Input rstp Fig. 4. Reset Timing Diagram MUX16:1 The 16-to-1 Multiplexer (MUX16:1) utilizes a tree-type architecture which latches the incoming data on the negative edge of the C16 clock signal supplied by /8. The 16-bit wide data word is subsequently multiplexed and delivered to Data OB as a single serial data stream. The latency of this circuit block is equal to roughly one period of C16. The output bit order is controlled by the 3.3V CMOS signal bitorder. The first output serial bit (MSB) corresponds to d00p/d00n when bitorder = “0” (default), or to d15p/d15n when bitorder = “1”. Data OB The Data Output Buffer (Data OB) receives high-speed serial data from MUX16:1 and converts it into a differential CML output signal qp/qn. Each buffer utilizes internal single-ended 50Ohm loads to vcc and requires single-ended 50Ohm external termination. The termination resistors can be connected from each output directly to vcc, or through DC blocks to vee. The amplitude of the output signals can be adjusted from 0 to its maximum value using the external control voltage ampadj. Higher values of the control voltage correspond to higher amplitude values as shown in Fig. 5. Fig. 5. Simulated Amplitude Control Characteristic Rev. 1.8.2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com HS COB The High Speed Clock Output Buffer (HS COB) utilizes the same termination scheme as Data OB and can operate at the maximum frequency while producing a full single-ended CML output swing. The buffer can be enabled or disabled by the external 3.3V CMOS control signal offcho. The logic “0” state provides a half-rate clock output signal c2op/c2on, while the logic “1” state disables the buffer completely. CLK Proc By utilizing the 3.3V CMOS control pins phs1 and phs2, the phase of the clop/clon signal can be altered in accordance with Table 3. Table 3. Output Clock Phase Selection phs1 phs2 clop/clon phase vee (default) vee (default) 90° 180° vee vcc 270° vcc vee 0° vcc vcc LVDS COB The LVDS Clock Output Buffer (LVDS COB) receives the divided clock C16 and converts it into a differential output signal clop/clon. The proprietary low-power LVDS output buffer utilizes a special architecture that ensures operation at high frequencies with a nominal output current of 3.5mA. The buffer satisfies all the requirements of the IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995 standards. Input Timing Reliable latching of the incoming data dXXp/dXXn requires a certain phase relation between the input data and the full-rate output sampling clock clop that is specified in Table 4 and illustrated by Fig. 6, when phs1 = “0” and phs2 = “1”. Table 4. Input Data to Output Low-Speed Sampling Clock Phase Delay Maximum required setup time, ps Maximum required hold time, ps 0 90 thold clop tsetup dp/dn Fig. 6. Input Timing Diagram Rev. 1.8.2 6 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Output Timing The phase relation between the output data qp/qn and the half-rate forwarded output clock c2op is specified in Table 5 and illustrated by Fig. 7. Table 5. Output Data to Output High-Speed Forwarded Clock Phase Delay tqc2, ps Min 3.0 Max 4.6 tqc2 c2op tqc2 qp/qn Fig. 7. Output Timing Diagram ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 6 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 6. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Rev. 1.8.2 Min -40 10 10 7 Max +3.6 1.6 1.0 +90 +100 98 98 Units V W V ºC ºC % % May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL FUNCTIONS Supply and Termination Voltages Name Description Pin Number vcc Positive power supply (+3.3V) 5, 8, 11, 25, 26, 29, 32, 35, 38, 41, 44, 55, 62, 65, 68, 71, 76, 79, 82, 85, 88, 91, 94, 97, 100 vee Negative power supply (GND 1, 15, 17, 23, 36, 50, 51, 52, 58, 75 or 0V) vecl Input termination voltage (vcc 2, 74 for CML, vcc-2V for ECL) vtrm Termination voltage for clock 30, 31 input duty cycle control circuit (default – vcc, minimum – vcc-0.8V) nc Not connected 12, 13, 16, 19, 20, 21, 42, 43, 53, 54 TERMINAL Name No. Type DESCRIPTION High-Speed I/Os Differential external clock inputs with internal SE 50Ohm termination to vcc Differential forwarded clock outputs. Require external SE 50Ohm termination to vcc. Can be disabled by offcho Differential data outputs. Require external SE 50Ohm termination to vcc Differential reset inputs with internal SE 50Ohm termination to vcc Controls LS input clock and data termination selector (active: low, CML or PECL depending on vecl connection; default: high, LVDS) HS COB control (active: high, buffer is disabled; default: low, half-rate output clock) Input half-rate clock duty cycle SE control with internal termination to a resistive divider Output data amplitude control voltage with internal termination to a resistive divider Input half-rate clock duty cycle differential controls with internal 200Ohm termination to the corresponding clock inputs Low-speed output sampling clock phase selection (see Table 3) c2ip c2in c2op c2on qp qn rstp rstn 28 27 34 33 40 39 46 45 CML input CML output CML output CML input offecl 14 offcho 18 cdcadj 37 ampadj 47 cdccp cdccn phs1 phs2 bitorder 24 22 57 56 59 CMOS input CMOS input Analog Input Analog Input Analog Inputs CMOS input CMOS Input bit order selection (active: high, d15p/d15n is serialized input first; default: low, d00p/d00n is serialized first) Rev. 1.8.2 8 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL Name No. Type clop clon d00p d00n d01p d01n d02p d02n d03p d03n d04p d04n d05p d05n d06p d06n d07p d07n d08p d08n d09p d09n d10p d10n d11p d11n d12p d12n d13p d13n d14p d14n d15p d15n Rev. 1.8.2 49 48 60 61 63 64 66 67 69 70 72 73 77 78 80 81 83 84 86 87 89 90 92 93 95 96 98 99 3 4 6 7 9 10 DESCRIPTION Low-Speed I/Os Output LVDS divided-by-16 full-rate sampling clock outputs Input LVDS data inputs 9 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER TYP MAX UNIT COMMENTS General Parameters +3.14 +3.3 +3.47 V ±5% vcc vcc vcc -0.8 V vtrm 0.0 V External ground vee Ivcc 460 mA Power consumption 1520 mW Junction temperature -25 50 125 °C LS Input Data (d00p/d00n-d15p/d15n) Maximum Data Rate 3.125 Gbps Minimum Data Rate Gbps Differential Swing 0.06 0.8 V Peak-to-peak CM Voltage Level V vee vcc HS Input Clock (c2ip/c2in) Maximum Frequency 25 GHz Minimum Frequency GHz Swing (Diff or SE) 0.2 1.0 V Peak-to-peak CM Voltage Level vcc-0.8 vcc V Duty Cycle 40 50 60 % HS Output Data (qp/qn) Maximum Data Rate 50 Gbps Minimum Data Rate Gbps Logic “1” level V vcc Logic “0” level vcc-0.05 V minimum ampadj vcc-1.0 vcc-1.3 V maximum ampadj Rise/fall time 4 12 ps 0.2-0.8 of the amplitude Jitter 1 2 ps Peak-to-peak at 32Gb/s HS Output Forwarded Clock (c2op/c2on) Maximum Frequency 25 GHz Minimum Frequency GHz Logic “1” level V vcc Logic “0” level vcc-0.65 V Rise/fall time 8 17 ps 0.2-0.8 of the amplitude Duty Cycle 50 % LS Output Sampling Clock (clop/clon) Maximum Frequency 3.125 GHz Minimum Frequency GHz Interface LVDS Meets the IEEE Std. CMOS Control Inputs (offecl, bitorder, offcho, phs1, phs2) Logic “1” level vcc-0.4 V Logic “0” level vee+0.4 V Rev. 1.8.2 MIN 10 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PARAMETER MIN TYP MAX UNIT COMMENTS Analog Control Inputs (ampadj, cdcadj, cdccp/cdccn) Voltage range V vee vcc ampadj termination 2.3 / 2.3 KOhm to vee / vcc cdcadj termination 22 / 5.6 KOhm to vee / vcc cdccp termination 0.95 KOhm to c2ip cdccn termination 0.95 KOhm to c2in PACKAGE INFORMATION Fig. 8. CQFP 100-Pin Package Drawing (All Dimensions in mm) Rev. 1.8.2 11 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The chip die is housed in a custom 100-pin CQFP package shown in Fig. 8. The package’s leads will be trimmed to a length of 1.0mm. After trimming, the package’s leads will be further processed as follows: 1. The lead’s gold plating will be removed per the following sections of J-STD-001D: 3.9.1 Solderability 3.2.2 Solder Purity Maintenance 3.9.2 Solderability Maintenance 3.9.3 Gold Removal 2. The leads will be tinned with Sn63Pb37 solder The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is power for a positive supply. The part’s identification label is ASNT1140-KMA. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. REVISION HISTORY Revision 1.8.2 1.7.2 1.7.1 1.6.1 Date 05-2020 07-2019 01-2019 07-2015 1.5.1 07-2015 1.4.1 05-2015 1.3.1 1.2.1 03-2015 03-2015 1.1.1 1.0.1 03-2015 03-2015 1.0.0 11-2014 Rev. 1.8.2 Changes Updated Package Information Updated Letterhead Added differential output eye Corrected pinout diagram (pins 52 and 53) Corrected Terminal Functions Updated frequency of operation Updated Electrical characteristics table Revised package information section Updated format Updated Data OB section Corrected block diagram Corrected description of vtrm function Added vtrm range Corrected Pin out Diagram Corrected power consumption based on measurements Corrected description of timing parameters Preliminary release 12 May 2020
ASNT1140-KMA 价格&库存
很抱歉,暂时无法提供与“ASNT1140-KMA”相匹配的价格&库存,您可以联系我们找货
