C11JG160A-140A
C11JG160A-140A
    SENSATA(森萨塔)
    Cylinder
    THERMOSTAT 71DEG C SPST-NO CYL
C11JG160A-140A 数据手册
5011 | SERIES 1/2” DISC, HERMETICALLY SEALED THERMOSTAT Introduction Designed to meet demanding shock and vibration requirements, the 5011 series thermostat is a RoHS compliant, positive snap action, single pole / single throw, hermetically sealed unit. Normally supplied with a grounded case construction, an additional terminal can be provided on the case for a positive ground lead or as an isolated device when the unit is insulated from ground. The 5011 series can be used for temperature warning or protection. Calibration is factory set and is tamperproof. Features • Hermetic glass seal • Ideal for surface and immersion sensing • Multiple mounting and terminations available • Case isolated and case grounded versions Applications • Printed circuit board protections • Air or water cooled engines and transmissions • Fluid sensing SPECIFICATIONS Contact Ratings Contact Operations Cycles 100,000 100,000 100,000 Voltage 120 120 32 Amps 3 (resistive) 2 (inductive) 3 (resistive) Case Type Ground / Insolated case Isolated case Grounded case Either close on rise (make) or open on rise (break), SPST (Single Pole, Single Throw) Operating Temperature +140ºF to 480ºF (+60ºC to 249ºC) Temperature Tolerance Standard of ±5°F with nominal operating temperature settings in 5°F increments Long Term Exposure Limit -65°F to 625°F (-53.8°C to 329.4°C) Note: Please consult the factory if lead wire/terminal exposure temperatures are expected to exceed 220°F. (Refer to inside notes B & C ) Dielectric Strength Insulated Resistance Thermal Shock Materials 1000 Vrms 60Hz (isolated case) terminals to case (contacts open) 50 meghoms at 500 Vdc MIL-STD-202, Method 107 Test Condition B Cold-rolled steel, nickel plated enclosure with a glass seal. Applications up to 300°F have a Mylar® sleeve with an epoxy fill, those above 300°F have a Nomex® sleeve and a high temperature epoxy fill. *Exposure limited should be kept to within 100°F of the operating temperature. Consult factory if conditions require otherwise. Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com CONTACT OPERATION CODE DESCRIPTION O Letter “O” = Open on Rise C Letter “C” = Close on Rise TERMINAL SELECTION A D Pan Head Screw Terminal, #8-32 Grounded Case Only J Quick Connect Terminal, Grounded Case Only (15.88) 0.625 K 2 Pan Head Screw Terminals, #8-32 Isolated Case Only 2 QC Terminals, Isolated Case Only M Same as terminal selection “L” 2 Leads, Isolated Case Only See note 1 for lead specifications Except 2 Leads (304.80 ± 25.40) 12.00 ± 1.00 See note 1 for lead specifications (18.16) 0.715 (15.88) 0.625 L (18.16) 0.715 (18.16) 0.715 N Same as terminal selection “L” #8-32 Pan Head Screw #7 Lock Washer (Packaged in plastic bag) (6.35) 0.250 Quick Connect Except 2 Leads #8-32 Pan Head Screw (x2) #7 Lock Washer (x2) (Packaged in plastic bag) 2 Quick Connects (6.35) 0.250 2 Leads (152.40 ± 25.40) 6.000 ± 1.00 45º ± 10º 45º ± 10º (6.35) Strip .250 See note 1 for lead specifications P Same as terminal selection “L” Encapsulated (23.80) REF 0.937 (13.84) REF 0.545 (26.97) REF 1.062 (13.84) REF 0.545 (23.80) REF 0.937 (15.75) REF 0.620 (26.97) REF 1.062 (15.75) REF 0.620 Except 2 Leads Mounting Encapsulated Encapsulated Encapsulated (1219.20 ± 25.40) 48.00 ± 1.00 See note 1 for lead specifications (15.75) REF 0.620 Z Mounting Mounting (609.60 ± 25.40) 24.00 ± 1.00 Mounting Mounting Encapsulated Encapsulated Special Requirements Customer to Specify TEMPERATURE CODES AND TOLERANCE Temperature Scale Fahrenheit Celsius Fahrenheit Celsius Fahrenheit Celsius Top Temperature Settings 140˚F to 250˚F 60˚C to 121.1˚C 251˚F to 400˚F 121.7˚C to 204.4˚C 401˚F to 480˚F 205˚C to 248.9˚C Standard Top Temperature Tolerance (code) ±5˚F (A) ±2.8˚C (A) ±10˚F (C) ±5.6˚C (C) ±25˚F (N) ±13.9˚C (N) Nominal Temperature Differential 25˚F 13.9˚C 35˚F 19.4˚C 40˚F 22.2˚C Note • Select any temperature in the range of 140°F to 480°F. Standard choices fall on the 5°F increments, for example 140°F, 145°F, 150°F, 155° F... up to 475°F or 480°F • Specify the °F temperature in the part numbering scheme as a three digit code without the ‘°F’ in the part numbe r. For example, for 200°F, put in code ‘200’ • Bottom Temperature in °F” equals the “Top Temperature in °F” minus “Nominal Differential in °F”. For example 310°F - 30°F = 280°F Tolerance Code A C N Y ( Bottom Temp Only) ±˚F ±5˚F ±10˚F ±25˚F Minimum ±˚C ±2.8˚C ±5.6˚C ±13.9˚C Minimum Note • The standard tolerance for the top temperature is based on the temperature range the top temperature falls in, please refer to the temperature setting chart, and select the appropriate code for a standard top temperature tolerance • For bottom temperature tolerance a “Y” = minimum trip, which indicates the “reset” trip occurs at or above the lower temperature set point. Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com MOUNTING AND ENCLOSURE SELECTION C E (22.23) 0.875 (0.38) 0.015 (30.68) 1.208 (5.72) 0.225 (16.66) 0.656 (0.38) 0.015 (22.23) 0.875 (51.56) 2.030 (19.05) 0.750 (41.28) 1.625 (50.93) REF 2.005 (40.46) 1.593 2 mounting holes (6.35 ± .51) 0.250 ± .020 (3.56 + 0.13 – 0.00 ) (.140 + 0.05 – 0.00 ) DIA 2 mounting holes (4.75) (6.35) by (.187) (.250) Grounded Case Only H G (19.05) 0.750 (19.05) 0.750 Terminal Encapsulation Omitted (See Note 2) (17.45 ± .51) DIA 0.687 ± .020 F (0.21) 0.011 RR * SS * (19.05) 0.750 (19.05) 0.750 2 mounting holes (4.75) TYP .187 (8.71) RAD 0.343 (9.04) RAD 0.356 (15.88) 0.625 (9.78 ± .13) DIA 0.385 ± .005 (18.03) 0.710 (6.35) 0.250 (5.72) REF 0.225 (9.53) REF 0.375 1/4-20 UNC-2A Thread Isolated or Grounded Case (16.26) REF 0.640 Q.C. Terminal (6.13 ± .13) / .250 ± .005 Dia. X (0.81 ± .08) / .032 ± .003 Thick (13.11) 0.516 (3.18) 0.125 (11.89) 0.468 (36.80) REF 1.449 (9.53 ± .38) 0.375 ± .015 (4.22 ± .25) 0.166 ± .010 1. The standard lead wire (materials) for different temperature ranges are as follows: A. Up to 220°F (104.4°C) = # 18 AWG standed. UL Style 1015/CSA approved. (PVC insulation, color black) B. 221°F to 350°F (105°C to 176.6°C) = #18 AWG stranded. UL Style 1199/CSA approved. (Teflon® TFE insulation, color black) C. 351°F (177.2°C) and above = #18 AWG stranded. UL style 5288/CSA approved. (Composite of Teflon®, ceramic + glass braid, color brown) 2. For mounting code “C” only, encapsulation above the hex is omitted and terminal height is reduced by the amount of encapsulation. 3. The marking information on each thermostat will include either the name Sensata, contact operation (CLR) close on rise, (OPR) open on rise, top temperature and date code. *If you require either of the terminal selections “RR” or “SS”, it will require the use of both position 3 (terminal selection). and position 4 (mounting and enclosure selection) in your part number building code. For example: C11RR285C-250Y Page 3 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com ORDERING OPTIONS Example : C11AD285C-250Y Close contacts on temperature rise, 5011 series, grounded case 8-32” screw terminal, mounting bracket with two 0.187” x 0.250” mounting slots, 285°F top temperature with a ±10°F standard top tolerance and a standard 35°F differential between top and bottom temperature for temperature range of 251°F to 400°F, differential helps calculate a bottom temperature of 250°F with a standard minimum reset for contacts to close at or above the bottom temperature set point. C 11 A F 2 8 5 C - 2 5 0 Y Contact Operation O, C See Contact Operation Table Family 5011 Series Terminal Selection A, D, J, K, L, M, N, P, Z See Terminal Selection Table Mounting & Enclosure C, E, F, G, H, RR*, SS* See Mounting and Enclosure Selection Table Top Temperature (in °F) See Temperature Codes and Tolerance Table (Available in Increments of 5°F) Top Temperature Tolerance Code A, C, N See Temperature Codes and Tolerance Table Bottom Temperature (in °F) See Temperature Codes and Tolerance Table Bottom Temperature Tolerance Code A, C, N, Y See Temperature Codes and Tolerance Table WARNINGS RISK OF MATERIAL DAMAGE AND HOT ENCLOSURE • The product’s side panels may be hot, allow the product to cool before touching • Follow proper mounting instructions including torque values • Do not allow liquids or foreign objects to enter this product Failure to follow these instructions can result in serious injury, or equipment damage. HAZARD OF ELECTRIC SHOCK, EXPLOSION OR ARC FLASH • Disconnect all power before installing or working with this equipment • Verify all connections and replace all covers before turning on power Failure to follow these instructions will result in death or serious injury Page 4 Sensata Technologies, Inc. (“Sensata”) data sheets are solely intended to assist designers (“Buyers”) who are developing systems that incorporate Sensata products (also referred to herein as “components”). Buyer understands and agrees that Buyer remains responsible for using its independent analysis, evaluation and judgment in designing Buyer’s systems and products. Sensata data sheets have been created using standard laboratory conditions and engineering practices. Sensata has not conducted any testing other than that specifically described in the published documentation for a particular data sheet. Sensata may make corrections, enhancements, improvements and other changes to its data sheets or components without notice. Buyers are authorized to use Sensata data sheets with the Sensata component(s) identified in each particular data sheet. HOWEVER, NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER SENSATA INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY THIRD PARTY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT, IS GRANTED HEREIN. SENSATA DATA SHEETS ARE PROVIDED “AS IS”. SENSATA MAKES NO WARRANTIES OR REPRESENTATIONS WITH REGARD TO THE DATA SHEETS OR USE OF THE DATA SHEETS, EXPRESS, IMPLIED OR STATUTORY, INCLUDING ACCURACY OR COMPLETENESS. SENSATA DISCLAIMS ANY WARRANTY OF TITLE AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, QUIET ENJOYMENT, QUIET POSSESSION, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS WITH REGARD TO SENSATA DATA SHEETS OR USE THEREOF. All products are sold subject to Sensata’s terms and conditions of sale supplied at www.sensata.com SENSATA ASSUMES NO LIABILITY FOR APPLICATIONS ASSISTANCE OR THE DESIGN OF BUYERS’ PRODUCTS. BUYER ACKNOWLEDGES AND AGREES THAT IT IS SOLELY RESPONSIBLE FOR COMPLIANCE WITH ALL LEGAL, REGULATORY AND SAFETY-RELATED REQUIREMENTS CONCERNING ITS PRODUCTS, AND ANY USE OF SENSATA COMPONENTS IN ITS APPLICATIONS, NOTWITHSTANDING ANY APPLICATIONS-RELATED INFORMATION OR SUPPORT THAT MAY BE PROVIDED BY SENSATA. Mailing Address: Sensata Technologies, Inc., 529 Pleasant Street, Attleboro, MA 02703, USA. Copyright © 2018 Sensata Technologies, Inc. Rev:02/02/18 CONTACT US Americas +1 (888) 438 2214 sensors@sensata.com Europe, Middle East & Africa +359 (2) 804 7165 temperature-info.eu@sensata.com Asia Pacific sales.isasia@list.sensata.com China +86 (21) 2306 1500 Japan +81 (45) 277 7117 Korea +82-10-9218-1179 India +91 (80) 67920890 Rest of Asia +886 (2) 27602006 ext 2808 www.sensata.com
C11JG160A-140A 价格&库存
很抱歉,暂时无法提供与“C11JG160A-140A”相匹配的价格&库存,您可以联系我们找货
