3NT01L-H7919
3NT01L-H7919
    SENSATA(森萨塔)
    Module
    THERMOSTAT 40DEG C SPST-NC MODUL
3NT01L-H7919 数据手册
3NT | SERIES FIXED TEMPERATURE THERMOSTATS Introduction Automatic reset thermostat designed to meet your specific application requirements. Its patented and tamper proof snap action bi-metal disc provides reliable and repeatable switch actuation. The 3NT is suitable for electrical loads ranging from dry circuits to 10A @ 240 VAC. The core of the 3NT is the proven 1NT thermostat. Recognized by UL/CSA and KEMA/ENEC agencies, hundreds of millions of the 1NT device are in the field today used in a variety of HVAC, appliance, automotive and specialty applications. Manufactured at ISO 9001 certified manufacturing sites, its dry seal allows direct integration of the thermostat into a wire harness eliminating the need for extra connections. Features • Automatic reset • Small and easy to mount • Fast thermal response • Innovative dry seal design - protects from moisture and dust • Reliable 100K cycle life • High temperature - to 275ºF (135ºC) Applications • HVAC • Commercial • Dehumidifiers • Freezers • Heat pumps • Ice makers • Refrigerators • Condensing or moist environments SPECIFICATIONS Agency UL (USA, Canada) Electrical Ratings ENEC (Europe) Operating Temperature Ambient Temperature Temperature rating Minimum Nominal Temperature Differential Dielectric Strength Standard Wire Leads Cycles x1000 Volts FLA LRA 100 100 30 30 100 120 Vac 240 Vac 120 Vac 240 Vac 30 Vdc 5.8 2.9 10.0 10.0 34.8 17.4 40.0 40.0 30 240 Vac Amps (resistive) VA 10 10 125 125 1 16 -20 to 135ºC (-4 to 275ºF) -40ºC to maximum wire lead insulation PVC - 105ºC XLP - 125ºC (Allow 15ºC de-rating below wire insulation rating at maximum 10A current) 8ºC (15ºF) 750 Vrms 1500 Vrms terminals to case 18 AWG (1/32” or 1/16” wall thickness in either 105°C PVC or 125°C XLPE) 16 AWG (1/32” wall thickness in 105°C PVC) Page 1 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com 3NT DRY SEAL DESIGN HOUSING LOCKING CONNECTORS O-RING WIRE LEAD ASSEMBLY 1NT THERMOSTAT 3NT CUP Important Notice: The 3NT is not hermetically sealed, and should not be submerged in liquid. For such applications, please contact Sensata. STANDARD TEMPERATURES AND TOLERANCES Nominal Top Temperature (1) Nominal Differential Open Temperature Close Temperature ˚F ˚C ˚F ˚C ˚F ˚C ˚F ˚C 32 to 80 0 to 27 20 - 29 30 - 38 39 - 60 11 - 16 17 - 21 22 - 33 ±5.5 ±5.5 ±5.5 ±3 ±3 ±3 ±7.5 ±8.5 ±10 ±4 ±4.5 ±5.5 81 to 167 28 to 75 20 - 23 24 - 29 30- 59 11 -13 14 -16 17 -33 ±5.5 ±5.5 ±5.5 ±3 ±3 ±3 ±7.5 ±8.5 ±10 ±4 ±4.5 ±5.5 168 to 199(1) 76 to 93(1) 20 -23 24 - 29 30 - 59 11 -13 14 -16 17 -33 ±5.5 ±5.5 ±5.5 ±3 ±3 ±3 ±7.5 ±8.5 ±9 ±4 ±4.5 ±5 200 to 249 (1) 94 to 121(1) 20 - 29 30 - 38 39 - 59 60 - 99 11 - 16 17 - 21 22 - 33 34 - 55 ±6.5 ±6.5 ±6.5 ±10 ±3.5 ±3.5 ±3.5 ±5.5 ±8.5 ±10 ±12 ±20 ±4.5 ±5.5 ±6.5 ±11 250 to 275 122 to 135 24 - 38 39 - 59 60 - 99 14 - 21 22 - 33 34 - 55 ±7.5 ±7.5 ±10 ±4 ±4 ±5.5 ±10 ±14.5 ±20 ±5.5 ±8 ±11 Minimum bottom temperature of 50ºC (122ºF) Page 2 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com TYPICAL PHYSICAL CHARACTERISTICS Dimensions in mm (inches) Basic 3NT Dimensions Open Tube Mount Clip (3/8 Inch Shown at 90º CCW Rotation) 90° and 180° CW Rotations Available Additional Clips Available for [1/4], [5/16], [1/2], [5/8] tubes Surface Mount Clip Snap Tube Mount Clip For 5/8 Inch and 1/2 Inch Tubes Locking Tube Mount Clip (3/8 Inch Shown) Additional Clips Available for [1/4], [5/16], [1/2], [5/8] t ubes Additional Clips Available for [3/4], [7/8] tubes Page 3 Copyright © 2018 Sensata Technologies, Inc. www.sensata.com ORDERING OPTIONS Part Number Temperature Code 3NT 01 L H XXXX L 50 F 30 Operating Temperature Family L: Limit F: Fan Operating Temperature Nominal Opening Temperature Temp. Code C: Celsius F: Fahrenheit 3NT Contact Material 01: Silver 11: Gold
3NT01L-H7919 价格&库存
很抱歉,暂时无法提供与“3NT01L-H7919”相匹配的价格&库存,您可以联系我们找货
