IS32LT3126-ZLA3-TR
IS32LT3126-ZLA3-TR
    LUMISSIL
    TSSOP16
    IC AEC-Q100 150MA DUAL CHANNEL L
IS32LT3126-ZLA3-TR 数据手册
IS32LT3126 150MA DUAL CHANNEL LED DRIVER WITH FAULT DETECTION May 2018 GENERAL DESCRIPTION FEATURES The IS32LT3126 is a dual linear programmable current regulator consisting of 2 independently controlled output channels; each channel is capable of sourcing 150mA. Both channels can be combined to provide a total of 300mA. It supports PWM dimming of both channels via power supply modulation (PSM). It also features ENx pins to individually PWM dim and independently adjust the average output current for each channel. The max current for each channel is set with its corresponding external resistor.  The UVx pins set the VCC under voltage lockout of each channel to match the LED stack for high side PWM dimming operation. In addition, the IC integrates fault protection for LED open/short, ISETx pin open/short and over temperature condition for robust operation. Detection of these failures is reported by FAULTB pin. When a fault is detected the device will disable itself and output an open drain low signal. Multiple devices can have their FAULTB pins connected to create a “one-fail-all-fail” condition. For multiple LED string applications, the device can detect a single LED short. The single LED short detection is set by a resistor divider on the STx pins. A single LED short failure is reported by the separate FAULTB_S pin. The IS32LT3126 is targeted at the automotive market with end applications to include interior and exterior lighting. For 12V automotive applications the low dropout driver can support one to several LEDs on the output channels. It is offered in a small thermally enhanced eTSSOP-16 package.           Dual channel: each channel can source up to 150mA and the two channels combined to source up to 300mA External resistors individually set source current 4% channel to channel current matching Individually programmable VCC under voltage lockout to match the LED stack for PSM operation Individual PWM dimming Shared fault flag for multiple devices operation Fault protection with flag reporting: - Single LED short (optional to turn off all LEDs) - LED string open/short - OUTx pins short to VCC/GND - ISETx pins open/short - Over temperature current rollback (no reporting) - Thermal shutdown External CSTOR capacitor keeps fault status during start/stop operation eTSSOP-16 package Operating temperature range from -40°C ~ +125°C AEC-Q100 qualification APPLICATIONS  Automotive interior/exterior lighting: - Turn signal light TYPICAL APPLICATION CIRCUIT Figure 1 Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 Typical Application Circuit 1 IS32LT3126 Figure 2 Typical Application Circuit (Several Devices In Parallel with FAULTB Interlinkage) Note 1: For PSM dimming application, high CVCC capacitor value will affect the dimming accuracy. To get better dimming performance, recommend 0.1µF for it. Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 2 IS32LT3126 PIN CONFIGURATION Package Pin Configuration (Top View) eTSSOP-16 PIN DESCRIPTION No. Pin Description 1 GND Ground. 2 CSTOR Keep-alive capacitor to maintain the deglitch timer and fault latch status with collapsing VCC. 3 ISET1 Output current setting for channel 1. Connect a resistor between this pin and GND to set the maximum output current. 4 ISET2 Output current setting for channel 2. Connect a resistor between this pin and GND to set the maximum output current. 5 FAULTB_S Open drain fault reporting output with internal pull up to 4.5V. Indicate the fault condition of single LED short. 6 FAULTB Open drain fault reporting output with internal pull up to 4.5V. Indicate the fault conditions except single LED short. This pin is also an input pin. Pulling this pin low will shutdown the device. 7 ST1 LED string voltage monitor pin of OUT1 to achieve single LED short detection. 8 OUT1 Output current source channel 1. 9 OUT2 Output current source channel 2. 10 ST2 LED string voltage monitor pin of OUT2 to achieve single LED short detection. 11 NC Not connect. 12 VCC Power supply input pin. 13 UV1 External under voltage lockout threshold detection pin for OUT1. 14 EN1 Enable pin of OUT1. It can be used to set OUT1 current by PWM. 15 UV2 External under voltage lockout threshold detection pin for OUT2. 16 EN2 Enable pin of OUT2. It can be used to set OUT2 current by PWM. Thermal Pad Must be electrically connected to GND plane for better thermal dissipation. Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 3 IS32LT3126 ORDERING INFORMATION Automotive Range: -40°C to +125°C Order Part No. Package QTY/Reel IS32LT3126-ZLA3-TR eTSSOP-16, Lead-free 2500 Copyright  ©  2018  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 4 IS32LT3126 ABSOLUTE MAXIMUM RATINGS VCC, OUT1, OUT2, EN1, EN2, UV1, UV2, ST1, ST2 ISET1, ISET2, CTSOR, FAULTB, FAULTB_S Ambient operating temperature, TA=TJ Maximum continuous junction temperature, TJ(MAX) Storage temperature range, TSTG Maximum power dissipation, PDMAX Package thermal resistance, junction to ambient (4 layer standard test PCB based on JEDEC standard), θJA Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JEDEC standard), θJP ESD (HBM) ESD (CDM) -0.3V ~ +45V -0.3V ~ +7.0V -40°C ~ +125°C +150°C -65°C ~ +150°C 2.15W 46.5°C/W 1.617°C/W ±2kV ±750V Note 2: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS TJ = -40°C ~ +125°C, VCC=12V, the detail refer to each condition description. Typical values are at TJ = 25°C. Symbol Parameter Conditions Min. Typ. Max. Unit 42 V 4.8 V Power Up Parameter VCC Supply voltage range VUVLO VCC under voltage lockout threshold voltage VUVLO_HY VCC under voltage lockout voltage hysteresis 5 Voltage falling 4.2 4.5 200 ICC VCC supply current VENx= High, RISETx= 20kΩ ISD Shutdown current in normal mode VENx= Low, TJ= 25°C ISD_FLT Shutdown current in fault mode VENx= High, FAULTB= Low TJ= 25°C tSD Both of EN pins low time for IC power shutdown tON EN high time for IC power up 3 40 mV 5.5 mA 1 2 mA 1 2 mA 48 55 ms 40 μs IOUT= -150mA, VCC= 12V VENx= High (Note 3) Channel Parameter VISETx IOUT VHR The ISETx voltage Output current per channel (Note 4) Minimum headroom voltage Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 1 V RISETx= 80kΩ, VHR= 1V -27.5 -25 -22.5 RISETx= 20kΩ, VHR= 1V -106 -100 -94 RISETx= 13.3kΩ, VHR= 1V -159 -150 -141 VCC - VOUT, IOUT= -150mA 1100 VCC - VOUT, IOUT= -100mA 800 mA mV 5 IS32LT3126 ELECTRICAL CHARACTERISTICS (CONTINUE) TJ = -40°C ~ +125°C, VCC=12V, the detail refer to each condition description. Typical values are at TJ = 25°C. Symbol Parameter Conditions Min. IOUT_R Output current per channel range RISETx= 80kΩ, IOUT=-25mA RISETx= 13.33kΩ, IOUT=-150mA -150 IOUT_L Output limit current per channel RISETx=5kΩ -290 ∆IOUT Current matching RISETx=20kΩ -4 tSL Current slew time Enable by ENx pin, current rise/fall between 0%~100% Leakage current per channel VENx=Low, VOUT=0V, VCC=42V ILEAK Typ. -230 Max. Unit -25 mA -170 mA 4 % 4 μs 1 μA Fault Protect Parameter Fault deglitch time Fault must be present at least this long to trigger the fault detect 25 VFAULTB FAULTB pin voltage Sink current=20mA 0.2 0.4 V RFAULTB FAULTB pin internal pull up 210 300 KΩ 2 V tFD μs VFAULTB_IH FAULTB pin input high enable threshold VFAULTB_IL FAULTB pin input low disable threshold VFAULTB_S FAULTB_S pin voltage Sink current=20mA VSCD OUTx pin short to GND threshold Measured at OUTx VSCD_HY OUTx pin short to GND hysteresis Measured at OUTx VOCD OUTx pin open threshold Measured at (VCC-VOUTx) VOCD_HY OUTx pin open hysteresis Measured at (VCC-VOUTx) ICST CSTOR pin leakage current VCSTOR=5.5V TRO Thermal rollback threshold (Note 3) 145 °C TSD Thermal shutdown threshold (Note 3) 165 °C THY Over-temperature hysteresis (Note 3) 25 °C ENx input voltage threshold Voltage rising ENx input hysteresis (Note 3) fPWM PWM frequency to ENx (Note 3) VUV UVx input voltage threshold Voltage rising 0.8 1.0 V 0.2 0.4 V 1.2 1.5 V 220 150 225 mV 300 100 5 mV mV 10 μA Logic Input VEN VENHY VUVHY VST 1.18 VSTHY STx Input hysteresis RSTPL STx pull up resistor 1.28 40 1.18 UVx input hysteresis STx input voltage threshold 1.23 1.23 mV 1 kHz 1.28 V 40 Voltage falling VST=1V 1.12 1.16 V mV 1.20 V 40 mV 500 kΩ Note 3: Guaranteed by design. Note 4: Output current accuracy is not intended to be guaranteed at output voltages less than 1.5V. Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 6 IS32LT3126 TYPICAL PERFORMANCE CHARACTERISTICS 180 110 VCC = 12V TJ = -40°C 160 Output Current (mA) Output Current (mA) VHR = 2V RISET = 20kΩ TJ = -40°C, 25°C, 125°C 105 100 95 RISET = 13kΩ 140 120 RISET = 20kΩ 100 80 RISET = 39kΩ 60 40 20 90 5 15 25 35 0 45 0 1 2 3 VCC = 12V TJ = 25°C 160 140 RISET = 20kΩ 100 80 RISET = 39kΩ 60 3 4 5 6 7 8 9 0 1 2 3 VCC = 12V VHR = 2V RISET = 20kΩ 245 Output Current (mA) Output Current (mA) 6 7 8 10 110 125 250 104 102 100 98 96 240 230 225 220 215 210 92 205 -25 -10 5 20 35 50 65 80 Temperature (°C) Figure 7 IOUT vs. TJ Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 95 110 125 VCC = 12V VHR = 2V RISET = 5.1kΩ 235 94 90 -40 5 Figure 6 IOUT vs. VHR Figure 5 IOUT vs. VHR 110 106 4 Headroom Voltage (V) Headroom Voltage (V) 108 9 RISET = 39kΩ 60 0 10 RISET = 20kΩ 80 20 2 10 100 20 1 9 RISET = 13kΩ 120 40 0 8 140 40 0 7 VCC = 12V TJ = 125°C RISET = 13kΩ Output Current (mA) Output Current (mA) 180 120 6 Figure 4 IOUT vs. VHR Figure 3 IOUT vs. VCC 160 5 Headroom Voltage (V) Supply Voltage (V) 180 4 200 -40 -25 -10 5 20 35 50 65 80 95 Temperature (°C) Figure 8 IOUT_L vs. TJ 7 IS32LT3126 180 5.5 VCC = 12V VHR = 2V RISET = 13kΩ 5.4 140 Supply Current (mA) Output Current (mA) 160 RISET = 20kΩ 120 100 80 60 40 RISET = 100kΩ 5.3 VCC = 12V RISET = 20kΩ EN = High 5.2 5.1 5 4.9 4.8 4.7 20 4.6 0 100 110 120 130 140 150 160 4.5 -40 170 -25 -10 5 Temperature (°C) 35 50 65 80 95 110 125 80 95 110 125 80 95 110 125 Temperature (°C) Figure 9 IOUT vs. TA (Thermal Rolloff) Figure 10 ICC vs. TJ 1 1.50 VCC = 12V FAULTB = Low 1.45 0.9 Supply Current (mA) Supply Current (mA) 20 0.8 0.7 VCC = 12V EN = Low 1.40 1.35 1.30 1.25 1.20 1.15 1.10 0.6 1.05 0.5 -40 -25 -10 5 20 35 50 65 80 95 110 1.00 -40 125 -25 -10 5 35 50 65 Temperature (°C) Temperature (°C) Figure 12 ISD vs. TJ Figure 11 ISD_FLT vs. TJ 1.05 1.04 20 1.25 VIH VCC = 12V VCC = 12V RISET = 20kΩ 1.03 1.23 VEN (V) VISET (V) 1.02 1.01 1.00 0.99 VIL 1.21 1.19 0.98 0.97 1.17 0.96 0.95 -40 -25 -10 5 20 35 50 65 80 Temperature (°C) Figure 13 VISET vs. TJ Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 95 110 125 1.15 -40 -25 -10 5 20 35 50 65 Temperature (°C) Figure 14 VEN vs. TJ 8 IS32LT3126 4.8 1.25 VIH VCC = 12V 1.24 VCC = 12V 4.75 1.23 4.7 1.21 VUVLO (V) VUV (V) 1.22 VIL 1.2 1.19 VIH 4.65 4.6 4.55 VIL 1.18 4.5 1.17 4.45 1.16 1.15 -40 -25 -10 5 20 35 50 65 80 95 110 4.4 -40 125 -25 -10 Temperature (°C) Figure 15 VUV vs. TJ Output Current (mA) VST (V) 65 80 95 110 125 VIH 1.16 1.15 VIL 1.13 80 70 60 50 40 30 1.12 20 1.11 10 -25 VCC = 12V RISET = 20kΩ PSM Dimming 1kHz TJ = -40°C, 25°C, 125°C 90 1.14 -10 5 20 35 50 65 80 95 110 0 125 0 20 Temperature (°C) 40 60 80 100 PSM Duty Cycle (%) Figure 17 VST vs. TJ Figure 18 PSM Dimming at 1kHz 100 100 VCC = 12V RISET = 20kΩ PSM Dimming 500Hz TJ = -40°C, 25°C, 125°C 80 VCC = 12V RISET = 20kΩ PSM Dimming 100Hz TJ = -40°C, 25°C, 125°C 90 Output Current (mA) 90 Output Current (mA) 50 Figure 16 VUVLO vs. TJ VCC = 12V 1.17 70 60 50 40 80 70 60 50 40 30 30 20 20 10 10 0 35 100 1.18 1.10 -40 20 Temperature (°C) 1.20 1.19 5 0 0 20 40 60 PSM Duty Cycle (%) Figure 19 PSM Dimming at 500Hz Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 80 100 0 20 40 60 80 100 PSM Duty Cycle (%) Figure 20 PSM Dimming at 100Hz 9 IS32LT3126 100 100 VCC = 12V RISET = 20kΩ PWM Dimming 1kHz TJ = -40°C, 25°C, 125°C 80 70 60 50 40 80 70 60 50 40 30 30 20 20 10 10 0 0 20 VCC = 12V RISET = 20kΩ PWM Dimming 500Hz TJ = -40°C, 25°C, 125°C 90 Output Current (mA) Output Current (mA) 90 40 60 80 100 0 0 20 40 PWM Duty Cycle (%) 60 80 100 PWM Duty Cycle (%) Figure 21 PWM Dimming at 1kHz Figure 22 PWM Dimming at 500Hz 100 Output Current (mA) VCC = 12V VHR = 2V TJ = -40°C VCC = 12V RISET = 20kΩ PWM Dimming 100Hz TJ = -40°C, 25°C, 125°C 90 80 VEN 1V/Div 70 60 VISET1 1V/Div 50 40 30 VFAULTB 5V/Div 20 10 0 0 20 40 60 80 100 IOUT 50mA/Div Time (4µs/Div) PWM Duty Cycle (%) Figure 24 EN On Figure 23 PWM Dimming at 100Hz VCC = 12V VHR = 2V TJ = 125°C VCC = 12V VHR = 2V TJ = 25°C VEN 1V/Div VEN 1V/Div VISET1 1V/Div VISET1 1V/Div VFAULTB 5V/Div VFAULTB 5V/Div IOUT 50mA/Div IOUT 50mA/Div Time (4µs/Div) Figure 25 EN On Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 Time (4µs/Div) Figure 26 EN On 10 IS32LT3126 VEN 1V/Div VCC = 12V VHR = 2V TJ = -40°C VEN 1V/Div VISET1 1V/Div VISET1 1V/Div VFAULTB 5V/Div VFAULTB 5V/Div IOUT 50mA/Div IOUT 50mA/Div Time (1µs/Div) Time (1µs/Div) Figure 27 EN Off VEN 1V/Div VCC = 12V VHR = 2V TJ = 25°C VCC = 12V VHR = 2V TJ = 125°C Figure 28 EN Off VEN 2V/Div VISET1 1V/Div VCC = 12V VHR = 2V TJ = -40°C VISET1 1V/Div VISET2 1V/Div VFAULTB 5V/Div IOUT 50mA/Div IOUT 50mA/Div Time (1µs/Div) Time 8ms/Div) Figure 29 EN Off VEN 2V/Div VCC = 12V VHR = 2V TJ = 25°C Figure 30 tSD VEN 2V/Div VISET1 1V/Div VISET1 1V/Div VISET2 1V/Div VISET2 1V/Div IOUT 50mA/Div IOUT 50mA/Div Time 8ms/Div) VCC = 12V VHR = 2V TJ = 125°C Time 8ms/Div) Figure 31 tSD Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 Figure 32 tSD 11 IS32LT3126 FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 12 IS32LT3126 APPLICATION INFORMATION The IS32LT3126 is a 2-channel linear LED current source optimized to drive automotive interior or exterior LED light which can be dimmed via Power Supply Modulation (PSM) or by digitally driving the EN pin. accept a PWM signal to implement LED dimming. LED average current may be computed using the following Equation (3). Each of the 2 output channels is capable of 150mA. The output current is set by two reference resistors (RISETx); one for each channel. IMAX is computed using Equation (1) and DPWM is the duty cycle. To guarantee a reasonably good dimming effect, recommend PWM frequency in the range of 100Hz ~ 1kHz. Driving the ENx pins with a PWM signal can effectively adjust the LED intensity. The PWM signal voltage levels must meet the ENx pins input voltage levels, VEN. Tie them to VCC pin via a 10KΩ resistor when ENx pins are unused; do not leave them floating. OUTPUT CURRENT SETTING A single resistor (RISETx) controls the maximum output current for each channel. The resistor value for a specific current level is calculated using the following Equation (1): RISET  2000 I SET (1) (13.33kΩ≤RISET≤80kΩ) RISET need to be chosen 1% accuracy resistor with good temperature characteristic to ensure stable output current. The device is protected from an output overcurrent condition caused by a too low value RISETx, by internally limiting the maximum current to IOUT_L. If only one channel is used, the EN pin of the unused channel should be tied to GND to prevent unwanted fault reporting. I LED  I MAX  DPWM (3) UVx PINS OPERATION The IC has an internal VCC UVLO set at VUVLO. However, it may be desirable to externally set an UVLO to track the number of LED’s used in the string. For PSM dimming application, the higher UVLO will track the PSM off time to a pre-determined VCC level. In addition, it is necessary to prevent false LED open detection due to the LED string losing its headroom voltage, such as when VCC rises up from zero during power up or PSM dimming. The UVx pin can be used to independently set a VCC under voltage lockout threshold via a resistor divider for each channel. VBattery POWER SUPPLY MODULATION DIMMING The IS32LT3126 can operate with Power Supply Modulation (PSM) where the device’s power supply is pulse width modulated to achieve LED dimming. The IS32LT3126 stability is not affected by operation with PSM. To get better dimming linearity, the recommended PSM frequency can be in the range of 100Hz to 300Hz, (200Hz Typ.) and input capacitor, CVCC, should be low value (0.1µF Typ.) to ensure rapid discharge during PSM low period. CSTOR OPERATION To keep the IC operating normally during condition of PSM when VCC goes to zero, CSTOR capacitor provides the keep-alive current needed to power the digital counter and the fault flag circuits. A capacitor value of 2.2µF is recommended. The keep-alive time could be roughly calculated by the following Equation (2): t alive  2.5V  C STOR I CST (2) ENx PINS OPERATION The voltage at the ENx pins must be higher than VEN to enable the channel and below (VEN-VENHY) to disable the channel. The ENx pins of the IS32LT3126 can Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 VCC PSM R1 UVx IS32LT3126 R2 Figure 33 UVx Pins Operation This external UVLO threshold voltage can be computed using the following Equation (4): VCC _ UVLO  VUV  R1  R2 R2 (4) Any unused UVLO pin must be tied to VCC pin via a 10kΩ resistor; do not leave it floating. To prevent false open detection, the external UVLO threshold voltage should be set at Equation (5): VCC _ UVLO  VLED _ MAX  VOCD (5) Where VLED_MAX is the maximum LED string forward voltage on the output channel. 13 IS32LT3126 STx PINS OPERATION IS32LT3126 device features single LED short detection using a resistor divider on the STx pins. In the case of any single LED short will result in that the STx pin voltage to drop below the threshold voltage VST and remains for tFD, the FAULTB_S pin pulls low to report the failure to host and all channels continue sourcing current. If FAULTB_S pin is tied to FAULTB pin, the FAULTB_S pin pulls down the FAULTB pin together that turns off the no fault condition channel but keep 4mA sourcing on fault channel for recovery detection. In multiple LEDs per string application, set the detection threshold voltage VDT into below voltage range: ( N  1)  VF _ max  VDT  N  VF _ min (6) Where, N is the number of LEDs in the string. VF_max and VF_min are the maximum and minimum forward voltage of a single LED. Figure 35 OUTx Pins Short Operation In the event the LED channel is open circuited, the OUTx pin voltage will go up close to VCC. If VCC to OUTx drop voltage remains below the threshold VOCD for tFD, the fault channel will change to source a 4mA current for recovery detection and the another channel will turn off. The FAULTB pin will be pulled low to indicate the fault condition. The state will recover after the open condition is removed. If the ISETx pin is either short or open, the FAULTB pin will pull low to assert the fault and the both channels will turn off. The state will recover after the fault condition is removed. FAULTB PARALLEL INTERCONNECTION Figure 34 STx Pins Operation The detection threshold voltage VDT is calculated by the following Equation (7): VDT  VST  RST 1  RST 2 RST 2 THERMAL ROLLBACK OF OUTPUT CURRENT (7) If single LED short detection is unused, the unused STx pin should be tied to its corresponding OUTx pin. OUTPUT STATE DIAGNOSTIC DETECTION AND FAULT IS32LT3126 offers a fault diagnostic function. Output short to GND/VCC, LED string open/short, ISET pins short/open and over temperature shutdown will trigger this function. An output short to GND or VCC is detected as a fault if the OUTx pin voltage drops below the short detect voltage threshold VSCD or VCC to OUTx drop voltage is lower than VOCD and remains below the threshold for tFD. Then the fault channel will change to source a 4mA current for recovery detection and the other channel will turn off. The FAULTB pin will be pulled low to indicate the fault condition. This state will recover after the fault condition is removed. Lumissil Microsystems – www.lumissil.com Rev. A, 05/08/2018 For LED lighting systems which require the complete lighting system be shut down when a fault is detected, the FAULTB pin can be used in a parallel connection with multiple IS32LT3126 devices as shown in Figure 2. A detected fault output by one device will pull low the FAULTB pins of the other parallel connected devices and simultaneously turn them off. This satisfies the “One-Fail-All-Fail” operating requirement. To protect the IC from damage due to high power dissipation, the temperature of the die is monitored. When the temperature of the die is below the thermal rollback start threshold of 145°C (Typ.), the dual output current maximum is the value set by the selection of RISETx. When the die temperature is between the thermal rollback start threshold 145°C (Typ.) and the over temperature shutdown threshold 165°C (Typ.), the output current decreases linearly from the maximum value. During the rollback, the FAULTB pin will not assert this as a fault. The rollback is related to RISET value: I OUT _ RO  I OUT  K  (TJ  145C ) RISET (8) Where 145°C ≤TJ≤165°C and K=49. 14 IS32LT3126 Any attempt to enable one or both of the channels back to the source condition before the IC cooled to TJTRO Output current linearly decreases following TJ High High TJTSD Off Low High TJ
IS32LT3126-ZLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32LT3126-ZLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32LT3126-ZLA3-TR
  • 1+11.266611+1.40990
  • 10+8.1935110+1.02534
  • 25+7.4162125+0.92806
  • 100+6.56150100+0.82111
  • 250+6.15397250+0.77011
  • 500+5.90815500+0.73935
  • 1000+5.705831000+0.71403
库存:17193
IS32LT3126-ZLA3-TR
  • 2500+4.882722500+0.61102
库存:17193
