MC68HC908GR4CFA
MC68HC908GR4CFA
    ROCHESTER(罗切斯特)
    LQFP32
    IC MCU 8BIT 4KB FLASH 32LQFP
MC68HC908GR4CFA 数据手册
MC68HC908GR8 MC68HC908GR4 Technical Data M68HC08 Microcontrollers MC68HC908GR8/D Rev. 4, 6/2002 WWW.MOTOROLA.COM/SEMICONDUCTORS MC68HC908GR8 MC68HC908GR4 Technical Data — Rev 4.0 Motorola reserves the right to make changes without further notice to any products herein. Motorola makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Motorola assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation consequential or incidental damages. "Typical" parameters which may be provided in Motorola data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including "Typicals" must be validated for each customer application by customer’s technical experts. Motorola does not convey any license under its patent rights nor the rights of others. Motorola products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the Motorola product could create a situation where personal injury or death may occur. Should Buyer purchase or use Motorola products for any such unintended or unauthorized application, Buyer shall indemnify and hold Motorola and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that Motorola was negligent regarding the design or manufacture of the part. Motorola, Inc. is an Equal Opportunity/Affirmative Action Employer. Motorola and are registered trademarks of Motorola, Inc. DigitalDNA is a trademark of Motorola, Inc. MC68HC908GR8 — Rev 4.0 MOTOROLA © Motorola, Inc., 2002 Technical Data 3 Technical Data 4 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data — MC68HC908GR8 List of Paragraphs List of Paragraphs. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Table of Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 List of Tables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 List of Figures . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Section 1. General Description . . . . . . . . . . . . . . . . . . . . 25 Section 2. Memory Map . . . . . . . . . . . . . . . . . . . . . . . . . . 35 Section 3. Low Power Modes. . . . . . . . . . . . . . . . . . . . . . 49 Section 4. Resets and Interrupts . . . . . . . . . . . . . . . . . . . 61 Section 5. Analog-to-Digital Converter (ADC) . . . . . . . . 79 Section 6. Break Module (BRK) . . . . . . . . . . . . . . . . . . . . 91 Section 7. Clock Generator Module (CGMC) . . . . . . . . . 99 Section 8. Configuration Register (CONFIG) . . . . . . . . 129 Section 9. Computer Operating Properly (COP) . . . . . 133 Section 10. Central Processing Unit (CPU) . . . . . . . . . 139 Section 11. Flash Memory . . . . . . . . . . . . . . . . . . . . . . . 157 Section 12. External Interrupt (IRQ) . . . . . . . . . . . . . . . 167 Section 13. Keyboard Interrupt (KBI) . . . . . . . . . . . . . . 175 Section 14. Low-Voltage Inhibit (LVI) . . . . . . . . . . . . . . 183 Section 15. Monitor ROM (MON) . . . . . . . . . . . . . . . . . . 189 Section 16. Input/Output Ports (I/O) . . . . . . . . . . . . . . . 205 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data List of Paragraphs 5 List of Paragraphs Section 17. RAM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 229 Section 18. Serial Communications Interface (SCI) . . . 231 Section 19. System Integration Module (SIM) . . . . . . . 271 Section 20. Serial Peripheral Interface (SPI). . . . . . . . . 297 Section 21. Timebase Module (TBM) . . . . . . . . . . . . . . . 329 Section 22. Timer Interface Module (TIM) . . . . . . . . . . . 335 Section 23. Electrical Specifications. . . . . . . . . . . . . . . 361 Section 24. Mechanical Specifications . . . . . . . . . . . . . 387 Section 25. Ordering Information . . . . . . . . . . . . . . . . . 391 Glossary. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 395 Revision History . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 405 Technical Data 6 MC68HC908GR8 — Rev 4.0 List of Paragraphs MOTOROLA Technical Data — MC68HC908GR8 Table of Contents List of Paragraphs Table of Contents List of Tables List of Figures Section 1. General Description 1.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 1.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 1.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 1.4 MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 1.5 Pin Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 1.6 Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 Section 2. Memory Map 2.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 2.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 2.3 Unimplemented Memory Locations . . . . . . . . . . . . . . . . . . . . . . 35 2.4 Reserved Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . 36 2.5 Input/Output (I/O) Section. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Table of Contents 7 Table of Contents Section 3. Low Power Modes 3.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 49 3.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 49 3.3 Analog-to-Digital Converter (ADC) . . . . . . . . . . . . . . . . . . . . . . 50 3.4 Break Module (BRK). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 51 3.5 Central Processor Unit (CPU). . . . . . . . . . . . . . . . . . . . . . . . . . 51 3.6 Clock Generator Module (CGM) . . . . . . . . . . . . . . . . . . . . . . . . 52 3.7 Computer Operating Properly Module (COP). . . . . . . . . . . . . . 52 3.8 External Interrupt Module (IRQ) . . . . . . . . . . . . . . . . . . . . . . . . 53 3.9 Keyboard Interrupt Module (KBI) . . . . . . . . . . . . . . . . . . . . . . . 53 3.10 Low-Voltage Inhibit Module (LVI) . . . . . . . . . . . . . . . . . . . . . . . 54 3.11 Serial Communications Interface Module (SCI) . . . . . . . . . . . . 54 3.12 Serial Peripheral Interface Module (SPI) . . . . . . . . . . . . . . . . . 55 3.13 Timer Interface Module (TIM1 and TIM2) . . . . . . . . . . . . . . . . . 55 3.14 Timebase Module (TBM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 56 3.15 Exiting Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 57 3.16 Exiting Stop Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 58 Section 4. Resets and Interrupts 4.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61 4.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61 4.3 Resets. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .61 4.4 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 66 Section 5. Analog-to-Digital Converter (ADC) 5.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79 5.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79 Technical Data 8 MC68HC908GR8 — Rev 4.0 Table of Contents MOTOROLA Table of Contents 5.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 5.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 5.5 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 5.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .83 5.7 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 5.8 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 Section 6. Break Module (BRK) 6.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 6.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 6.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 6.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 92 6.5 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .94 6.6 Break Module Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .94 Section 7. Clock Generator Module (CGMC) 7.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99 7.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99 7.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 7.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 7.5 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 112 7.6 CGMC Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 114 7.7 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 7.8 Special Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 7.9 Acquisition/Lock Time Specifications . . . . . . . . . . . . . . . . . . .125 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Table of Contents 9 Table of Contents Section 8. Configuration Register (CONFIG) 8.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 8.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 8.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 Section 9. Computer Operating Properly (COP) 9.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 9.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 9.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 9.4 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135 9.5 COP Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136 9.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136 9.7 Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 137 9.8 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .137 9.9 COP Module During Break Mode . . . . . . . . . . . . . . . . . . . . . .137 Section 10. Central Processing Unit (CPU) 10.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 10.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 10.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 10.4 CPU registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 10.5 Arithmetic/logic unit (ALU) . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 10.6 Low-power modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .145 10.7 CPU during break interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 146 10.8 Instruction Set Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147 10.9 Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154 Technical Data 10 MC68HC908GR8 — Rev 4.0 Table of Contents MOTOROLA Table of Contents Section 11. Flash Memory 11.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 11.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 11.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 11.4 FLASH Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159 11.5 FLASH Page Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . 160 11.6 FLASH Mass Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . 161 11.7 FLASH Program/Read Operation . . . . . . . . . . . . . . . . . . . . . .162 11.8 FLASH Block Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . .163 11.9 Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166 11.10 STOP Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166 Section 12. External Interrupt (IRQ) 12.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167 12.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167 12.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167 12.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 168 12.5 IRQ1 Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 170 12.6 IRQ Module During Break Interrupts . . . . . . . . . . . . . . . . . . .171 12.7 IRQ Status and Control Register . . . . . . . . . . . . . . . . . . . . . . 172 Section 13. Keyboard Interrupt (KBI) 13.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 13.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 13.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 13.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 176 13.5 Keyboard Initialization. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 179 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Table of Contents 11 Table of Contents 13.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .180 13.7 Keyboard Module During Break Interrupts . . . . . . . . . . . . . . .180 13.8 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 181 Section 14. Low-Voltage Inhibit (LVI) 14.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183 14.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183 14.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183 14.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 184 14.5 LVI Status Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187 14.6 LVI Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 188 14.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .188 Section 15. Monitor ROM (MON) 15.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 189 15.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 189 15.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 189 15.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 190 15.5 Security. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 202 Section 16. Input/Output Ports (I/O) 16.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205 16.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205 16.3 Port A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 209 16.4 Port B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 213 16.5 Port C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216 16.6 Port D . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 220 Technical Data 12 MC68HC908GR8 — Rev 4.0 Table of Contents MOTOROLA Table of Contents 16.7 Port E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225 Section 17. RAM 17.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 229 17.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 229 17.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 229 Section 18. Serial Communications Interface (SCI) 18.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 231 18.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 231 18.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 232 18.4 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 233 18.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 233 18.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .250 18.7 SCI During Break Module Interrupts. . . . . . . . . . . . . . . . . . . . 251 18.8 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 251 18.9 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 252 Section 19. System Integration Module (SIM) 19.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 271 19.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 271 19.3 SIM Bus Clock Control and Generation . . . . . . . . . . . . . . . . . 275 19.4 Reset and System Initialization. . . . . . . . . . . . . . . . . . . . . . . . 276 19.5 SIM Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 281 19.6 Exception Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 282 19.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .290 19.8 SIM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Table of Contents 13 Table of Contents Section 20. Serial Peripheral Interface (SPI) 20.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 297 20.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 297 20.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 298 20.4 Pin Name Conventions and I/O Register Addresses . . . . . . . 298 20.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299 20.6 Transmission Formats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 303 20.7 Queuing Transmission Data . . . . . . . . . . . . . . . . . . . . . . . . . . 309 20.8 Error Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 310 20.9 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314 20.10 Resetting the SPI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 316 20.11 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .317 20.12 SPI During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . .318 20.13 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 318 20.14 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 322 Section 21. Timebase Module (TBM) 21.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 329 21.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 329 21.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 329 21.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 330 21.5 Timebase Register Description. . . . . . . . . . . . . . . . . . . . . . . . 331 21.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 332 21.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .333 Section 22. Timer Interface Module (TIM) 22.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335 Technical Data 14 MC68HC908GR8 — Rev 4.0 Table of Contents MOTOROLA Table of Contents 22.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335 22.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 336 22.4 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 336 22.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 337 22.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 346 22.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .347 22.8 TIM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 348 22.9 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 348 22.10 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 349 Section 23. Electrical Specifications 23.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 361 23.2 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . .362 23.3 Functional Operating Range. . . . . . . . . . . . . . . . . . . . . . . . . . 363 23.4 Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 363 23.5 5.0 V DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . 364 23.6 3.0 V DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . 366 23.7 5.0 V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 368 23.8 3.0 V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 369 23.9 Output High-Voltage Characteristics . . . . . . . . . . . . . . . . . . .370 23.10 Output Low-Voltage Characteristics . . . . . . . . . . . . . . . . . . . . 373 23.11 Typical Supply Currents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 376 23.12 ADC Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 378 23.13 5.0 V SPI Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . 379 23.14 3.0 V SPI Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . 380 23.15 Timer Interface Module Characteristics . . . . . . . . . . . . . . . . . 383 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Table of Contents 15 Table of Contents 23.16 Clock Generation Module Characteristics . . . . . . . . . . . . . . . 383 23.17 Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 385 Section 24. Mechanical Specifications 24.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 387 24.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 387 24.3 32-Pin LQFP (Case #873A) . . . . . . . . . . . . . . . . . . . . . . . . . .388 24.4 28-Pin PDIP (Case #710) . . . . . . . . . . . . . . . . . . . . . . . . . . . . 389 24.5 28-Pin SOIC (Case #751F). . . . . . . . . . . . . . . . . . . . . . . . . . . 390 Section 25. Ordering Information 25.1 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 391 25.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 391 25.3 MC Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 392 25.4 Development Tools. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 393 Glossary Revision History Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 405 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 405 Changes from Rev 3.0 published in February 2002 to Rev 4.0 published in June 2002. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 405 Changes from Rev 2.0 published in January 2002 to Rev 3.0 published in February 2002 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 406 Changes from Rev 1.0 published in April 2001 to Rev 2.0 published in December 2001 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 406 Technical Data 16 MC68HC908GR8 — Rev 4.0 Table of Contents MOTOROLA Technical Data — MC68HC908GR8 List of Tables Table 2-1 4-1 4-2 5-1 5-2 7-1 7-2 7-3 10-1 10-2 11-1 14-1 15-1 15-2 15-3 15-4 15-5 15-6 15-7 15-8 15-9 16-1 16-2 16-3 16-4 16-5 16-6 18-1 18-2 Title Vector Addresses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 47 Interrupt Sources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 Interrupt Source Flags . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 Mux Channel Select . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 ADC Clock Divide Ratio . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 Numeric Example . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 109 PRE 1 and PRE0 Programming . . . . . . . . . . . . . . . . . . . . . . . 117 VPR1 and VPR0 Programming . . . . . . . . . . . . . . . . . . . . . . . 117 Instruction Set Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147 Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 155 Examples of protect start address: . . . . . . . . . . . . . . . . . . . . . 166 LVIOUT Bit Indication . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187 Monitor Mode Signal Requirements and Options . . . . . . . . . . 193 Mode Differences . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 196 Monitor Baud Rate Selection . . . . . . . . . . . . . . . . . . . . . . . . . 197 READ (Read Memory) Command . . . . . . . . . . . . . . . . . . . . . 199 WRITE (Write Memory) Command. . . . . . . . . . . . . . . . . . . . . 199 IREAD (Indexed Read) Command . . . . . . . . . . . . . . . . . . . . . 200 IWRITE (Indexed Write) Command . . . . . . . . . . . . . . . . . . . . 200 READSP (Read Stack Pointer) Command . . . . . . . . . . . . . . .201 RUN (Run User Program) Command . . . . . . . . . . . . . . . . . . . 201 Port Control Register Bits Summary. . . . . . . . . . . . . . . . . . . . 208 Port A Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 211 Port B Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 215 Port C Pin Functions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 218 Port D Pin Functions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 223 Port E Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 227 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 233 Start Bit Verification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 244 MC68HC908GR8 — Rev 4.0 MOTOROLA Page Technical Data List of Tables 17 List of Tables 18-3 18-4 18-5 18-6 18-7 18-8 19-1 19-2 19-3 19-4 20-1 20-2 20-3 20-4 21-1 22-1 22-2 22-3 23-1 23-2 23-3 23-4 23-5 23-6 23-7 23-8 23-9 25-1 25-2 25-3 Data Bit Recovery. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 244 Stop Bit Recovery . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 245 Character Format Selection . . . . . . . . . . . . . . . . . . . . . . . . . .255 SCI Baud Rate Prescaling . . . . . . . . . . . . . . . . . . . . . . . . . . . 266 SCI Baud Rate Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . 266 SCI Baud Rate Selection Examples . . . . . . . . . . . . . . . . . . . . 268 Signal Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . 273 PIN Bit Set Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .277 Interrupt Sources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 286 SIM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299 SPI Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314 SPI Configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 321 SPI Master Baud Rate Selection . . . . . . . . . . . . . . . . . . . . . . 327 Timebase Rate Selection for OSC1 = 32.768 kHz . . . . . . . . . 331 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 336 Prescaler Selection. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 351 Mode, Edge, and Level Selection . . . . . . . . . . . . . . . . . . . . . .358 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . .362 Functional Operation Range. . . . . . . . . . . . . . . . . . . . . . . . . . 363 Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 363 5.0V DC Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . 364 3.0 V DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . 366 5.0 V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 368 3.0 V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 369 Timer Interface Module Characteristics . . . . . . . . . . . . . . . . . 383 CGM Component Specifications. . . . . . . . . . . . . . . . . . . . . . . 383 MC Order Numbers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 392 Development Tool Kits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 393 Development Tool Components . . . . . . . . . . . . . . . . . . . . . . . 393 Technical Data 18 MC68HC908GR8 — Rev 4.0 List of Tables MOTOROLA Technical Data — MC68HC908GR8 List of Figures Figure 1-1 1-2 1-3 1-4 2-1 2-2 4-1 4-2 4-3 4-4 4-5 4-6 4-7 4-8 4-9 5-1 5-2 5-3 5-4 6-1 6-2 6-3 6-4 6-5 6-6 6-7 7-1 7-2 7-3 Title MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 QFP Pin Assignments. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 DIP And SOIC Pin Assignments. . . . . . . . . . . . . . . . . . . . . . . . 31 Power Supply Bypassing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 Memory Map. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 37 Control, Status, and Data Registers . . . . . . . . . . . . . . . . . . . . . 39 Internal Reset Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 62 Power-On Reset Recovery . . . . . . . . . . . . . . . . . . . . . . . . . . . . 63 SIM Reset Status Register (SRSR) . . . . . . . . . . . . . . . . . . . . . 65 Interrupt Stacking Order . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .67 Interrupt Recognition Example . . . . . . . . . . . . . . . . . . . . . . . . . 68 Interrupt Processing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 69 Interrupt Status Register 1 (INT1). . . . . . . . . . . . . . . . . . . . . . .76 Interrupt Status Register 2 (INT2). . . . . . . . . . . . . . . . . . . . . . .76 Interrupt Status Register 3 (INT3). . . . . . . . . . . . . . . . . . . . . . .77 ADC Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 81 ADC Status and Control Register (ADSCR) . . . . . . . . . . . . . . . 85 ADC Data Register (ADR) . . . . . . . . . . . . . . . . . . . . . . . . . . . . 87 ADC Clock Register (ADCLK) . . . . . . . . . . . . . . . . . . . . . . . . . 88 Break Module Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . 92 I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 93 Break Status and Control Register (BRKSCR). . . . . . . . . . . . . 95 Break Address Register High (BRKH) . . . . . . . . . . . . . . . . . . . 96 Break Address Register Low (BRKL) . . . . . . . . . . . . . . . . . . . . 96 SIM Break Status Register (SBSR) . . . . . . . . . . . . . . . . . . . . . 96 SIM Break Flag Control Register (SBFCR) . . . . . . . . . . . . . . . 98 CGMC Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101 CGMC External Connections . . . . . . . . . . . . . . . . . . . . . . . . . 111 CGMC I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . 114 MC68HC908GR8 — Rev 4.0 MOTOROLA Page Technical Data List of Figures 19 List of Figures 7-4 7-5 7-6 7-7 7-8 7-9 7-10 8-1 8-2 9-1 9-2 10-1 10-2 10-3 10-4 10-5 10-6 11-1 11-2 11-3 11-4 12-1 12-2 12-3 13-1 13-2 13-3 13-4 14-1 14-2 14-3 15-1 15-2 15-3 15-4 15-5 15-6 15-7 PLL Control Register (PCTL) . . . . . . . . . . . . . . . . . . . . . . . . . 115 PLL Bandwidth Control Register (PBWC) . . . . . . . . . . . . . . . 118 PLL Multiplier Select Register High (PMSH) . . . . . . . . . . . . . 119 PLL Multiplier Select Register Low (PMSL) . . . . . . . . . . . . . . 120 PLL VCO Range Select Register (PMRS) . . . . . . . . . . . . . . . 121 PLL Reference Divider Select Register (PMDS) . . . . . . . . . . 122 PLL Filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .127 Configuration Register 2 (CONFIG2) . . . . . . . . . . . . . . . . . . .130 Configuration Register 1 (CONFIG1) . . . . . . . . . . . . . . . . . . .130 COP Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 134 COP Control Register (COPCTL) . . . . . . . . . . . . . . . . . . . . . .136 CPU registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 Accumulator (A) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 141 Index register (H:X). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 141 Stack pointer (SP). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 142 Program counter (PC). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 143 Condition code register (CCR) . . . . . . . . . . . . . . . . . . . . . . . . 143 FLASH Control Register (FLCR) . . . . . . . . . . . . . . . . . . . . . . 159 FLASH Programming Flowchart . . . . . . . . . . . . . . . . . . . . . . . 164 FLASH Block Protect Register (FLBPR). . . . . . . . . . . . . . . . . 165 FLASH Block Protect Start Address . . . . . . . . . . . . . . . . . . . . 165 IRQ Module Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . .169 IRQ I/O Register Summary. . . . . . . . . . . . . . . . . . . . . . . . . . . 169 IRQ Status and Control Register (INTSCR) . . . . . . . . . . . . . . 172 Keyboard Module Block Diagram . . . . . . . . . . . . . . . . . . . . . .177 I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 177 Keyboard Status and Control Register (INTKBSCR) . . . . . . . 181 Keyboard Interrupt Enable Register (INTKBIER) . . . . . . . . . . 182 LVI Module Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . 185 LVI I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 186 LVI Status Register (LVISR) . . . . . . . . . . . . . . . . . . . . . . . . . . 187 Monitor Mode Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 191 Low-Voltage Monitor Mode Entry Flowchart. . . . . . . . . . . . . . 195 Monitor Data Format. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 196 Break Transaction. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 196 Read Transaction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 198 Write Transaction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 198 Stack Pointer at Monitor Mode Entry . . . . . . . . . . . . . . . . . . .202 Technical Data 20 MC68HC908GR8 — Rev 4.0 List of Figures MOTOROLA List of Figures 15-8 16-1 16-2 16-3 16-4 16-5 16-6 16-7 16-8 16-9 16-10 16-11 16-12 16-13 16-14 16-15 16-16 16-17 16-18 16-19 18-1 18-2 18-3 18-4 18-5 18-6 18-7 18-8 18-9 18-10 18-11 18-12 18-13 18-14 18-15 18-16 19-1 19-2 Monitor Mode Entry Timing. . . . . . . . . . . . . . . . . . . . . . . . . . . 203 I/O Port Register Summary. . . . . . . . . . . . . . . . . . . . . . . . . . . 206 Port A Data Register (PTA) . . . . . . . . . . . . . . . . . . . . . . . . . .209 Data Direction Register A (DDRA) . . . . . . . . . . . . . . . . . . . . . 210 Port A I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 211 Port A Input Pullup Enable Register (PTAPUE) . . . . . . . . . . . 212 Port B Data Register (PTB) . . . . . . . . . . . . . . . . . . . . . . . . . .213 Data Direction Register B (DDRB) . . . . . . . . . . . . . . . . . . . . . 214 Port B I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 215 Port C Data Register (PTC) . . . . . . . . . . . . . . . . . . . . . . . . . .216 Data Direction Register C (DDRC) . . . . . . . . . . . . . . . . . . . . . 217 Port C I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 218 Port C Input Pullup Enable Register (PTCPUE) . . . . . . . . . . . 219 Port D Data Register (PTD) . . . . . . . . . . . . . . . . . . . . . . . . . .220 Data Direction Register D (DDRD) . . . . . . . . . . . . . . . . . . . . . 222 Port D I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 223 Port D Input Pullup Enable Register (PTDPUE) . . . . . . . . . . . 224 Port E Data Register (PTE) . . . . . . . . . . . . . . . . . . . . . . . . . .225 Data Direction Register E (DDRE) . . . . . . . . . . . . . . . . . . . . . 226 Port E I/O Circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 227 SCI Module Block Diagram. . . . . . . . . . . . . . . . . . . . . . . . . . . 234 SCI I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 235 SCI Data Formats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 236 SCI Transmitter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .237 SCI Receiver Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . 242 Receiver Data Sampling . . . . . . . . . . . . . . . . . . . . . . . . . . . . .243 Slow Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 246 Fast Data . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .247 SCI Control Register 1 (SCC1). . . . . . . . . . . . . . . . . . . . . . . . 253 SCI Control Register 2 (SCC2). . . . . . . . . . . . . . . . . . . . . . . . 256 SCI Control Register 3 (SCC3). . . . . . . . . . . . . . . . . . . . . . . . 258 SCI Status Register 1 (SCS1) . . . . . . . . . . . . . . . . . . . . . . . . 260 Flag Clearing Sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . .263 SCI Status Register 2 (SCS2) . . . . . . . . . . . . . . . . . . . . . . . . 264 SCI Data Register (SCDR) . . . . . . . . . . . . . . . . . . . . . . . . . . . 265 SCI Baud Rate Register (SCBR) . . . . . . . . . . . . . . . . . . . . . . 265 SIM Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 272 SIM I/O Register Summary. . . . . . . . . . . . . . . . . . . . . . . . . . . 274 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data List of Figures 21 List of Figures 19-3 19-4 19-5 19-6 19-7 19-8 19-9 19-10 19-11 19-12 19-13 19-14 19-15 19-16 19-17 19-18 19-19 19-20 19-21 19-22 20-1 20-2 20-3 20-4 20-5 20-6 20-7 20-8 20-9 20-10 20-11 20-12 20-13 20-14 20-15 21-1 21-2 22-1 CGM Clock Signals. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 275 External Reset Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 277 Internal Reset Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 278 Sources of Internal Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . 278 POR Recovery . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 279 Interrupt Entry Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 283 Interrupt Recovery Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . 283 Interrupt Processing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 284 Interrupt Recognition Example . . . . . . . . . . . . . . . . . . . . . . . . 285 Interrupt Status Register 1 (INT1). . . . . . . . . . . . . . . . . . . . . .288 Interrupt Status Register 2 (INT2). . . . . . . . . . . . . . . . . . . . . .288 Interrupt Status Register 3 (INT3). . . . . . . . . . . . . . . . . . . . . .289 Wait Mode Entry Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . .291 Wait Recovery from Interrupt or Break . . . . . . . . . . . . . . . . . . 291 Wait Recovery from Internal Reset. . . . . . . . . . . . . . . . . . . . . 292 Stop Mode Entry Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . .293 Stop Mode Recovery from Interrupt or Break . . . . . . . . . . . . . 293 SIM Break Status Register (SBSR) . . . . . . . . . . . . . . . . . . . . 294 SIM Reset Status Register (SRSR) . . . . . . . . . . . . . . . . . . . . 295 SIM Break Flag Control Register (SBFCR) . . . . . . . . . . . . . . 296 SPI I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 299 SPI Module Block Diagram. . . . . . . . . . . . . . . . . . . . . . . . . . . 300 Full-Duplex Master-Slave Connections . . . . . . . . . . . . . . . . . 301 Transmission Format (CPHA = 0) . . . . . . . . . . . . . . . . . . . . . 305 CPHA/SS Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 305 Transmission Format (CPHA = 1) . . . . . . . . . . . . . . . . . . . . . 306 Transmission Start Delay (Master) . . . . . . . . . . . . . . . . . . . . . 308 .SPRF/SPTE CPU Interrupt Timing . . . . . . . . . . . . . . . . . . . . 309 Missed Read of Overflow Condition . . . . . . . . . . . . . . . . . . . . 311 Clearing SPRF When OVRF Interrupt Is Not Enabled . . . . . . 312 SPI Interrupt Request Generation . . . . . . . . . . . . . . . . . . . . . 315 CPHA/SS Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 320 SPI Control Register (SPCR) . . . . . . . . . . . . . . . . . . . . . . . . . 322 SPI Status and Control Register (SPSCR) . . . . . . . . . . . . . . .325 SPI Data Register (SPDR) . . . . . . . . . . . . . . . . . . . . . . . . . . . 328 Timebase Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . 330 Timebase Control Register (TBCR) . . . . . . . . . . . . . . . . . . . . 331 TIM Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 338 Technical Data 22 MC68HC908GR8 — Rev 4.0 List of Figures MOTOROLA List of Figures 22-2 22-3 22-4 22-5 22-6 22-7 22-8 22-9 22-10 22-11 22-12 22-13 22-14 22-15 22-16 22-17 23-1 23-2 23-3 23-4 23-5 23-6 23-7 23-8 23-9 23-10 23-11 TIM I/O Register Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . 339 PWM Period and Pulse Width . . . . . . . . . . . . . . . . . . . . . . . . 343 TIM Status and Control Register (TSC) . . . . . . . . . . . . . . . . . 349 TIM Counter Registers High (TCNTH) . . . . . . . . . . . . . . . . . . 352 TIM Counter Registers Low (TCNTL) . . . . . . . . . . . . . . . . . . . 352 TIM Counter Modulo Register High (TMODH) . . . . . . . . . . . .353 TIM Counter Modulo Register Low (TMODL) . . . . . . . . . . . . . 353 TIM Counter Register High (TCNTH) . . . . . . . . . . . . . . . . . . . 354 TIM Counter Register Low (TCNTL). . . . . . . . . . . . . . . . . . . . 354 TIM Channel 0 Status and Control Register (TSC0) . . . . . . . 355 TIM Channel 1 Status and Control Register (TSC1) . . . . . . . 355 CHxMAX Latency . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 359 TIM Channel 0 Register High (TCH0H) . . . . . . . . . . . . . . . . . 360 TIM Channel 0 Register Low (TCH0L) . . . . . . . . . . . . . . . . . . 360 TIM Channel 1 Register High (TCH1H) . . . . . . . . . . . . . . . . . 360 TIM Channel 1 Register Low (TCH1L) . . . . . . . . . . . . . . . . . . 360 Typical High-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 4.5 Vdc) . . . . . . . . . . . . . . . . . . . . . 370 Typical High-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 2.7 Vdc) . . . . . . . . . . . . . . . . . . . . . 370 Typical High-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 4.5 Vdc) . . . . . . . . . . . . . . . . . . . . . 371 Typical High-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 2.7 Vdc) . . . . . . . . . . . . . . . . . . . . . 371 Typical High-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 5.5 Vdc) . . . . . . . . . . 372 Typical High-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 2.7 Vdc) . . . . . . . . . . 372 Typical Low-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 5.5 Vdc) . . . . . . . . . . . . . . . . . . . . . 373 Typical Low-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 2.7 Vdc) . . . . . . . . . . . . . . . . . . . . . 373 Typical Low-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 4.5 Vdc) . . . . . . . . . . . . . . . . . . . . . 374 Typical Low-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 2.7 Vdc) . . . . . . . . . . . . . . . . . . . . . 374 Typical Low-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 5.5 Vdc) . . . . . . . . . . 375 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data List of Figures 23 List of Figures 23-12 Typical Low-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 2.7 Vdc) . . . . . . . . . . 375 23-13 Typical Operating IDD, with All Modules Turned On (–40 °C to 125 °C) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .376 23-14 Typical Wait Mode IDD, with all Modules Disabled (–40 °C to 125 °C) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .376 23-15 Typical Stop Mode IDD, with all Modules Disabled (–40 °C to 125 °C) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .377 23-16 SPI Master Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .381 23-17 SPI Slave Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 382 Technical Data 24 MC68HC908GR8 — Rev 4.0 List of Figures MOTOROLA Technical Data — MC68HC908GR8 Section 1. General Description 1.1 Contents 1.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 1.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 1.4 MCU Block Diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 1.5 Pin Assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 1.6 Pin Functions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 1.2 Introduction The MC68HC908GR8 is a member of the low-cost, high-performance M68HC08 Family of 8-bit microcontroller units (MCUs). All MCUs in the family use the enhanced M68HC08 central processor unit (CPU08) and are available with a variety of modules, memory sizes and types, and package types. This document also describes the MC68HC908GR4. The MC68HC908GR4 is a device identical to the MC68HC908GR8 except that it has less Flash memory. Only when there are differences from the MC68HC908GR8 is the MC68HC908GR4 specifically mentioned in the text. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data General Description 25 General Description 1.3 Features For convenience, features have been organized to reflect: • Standard features of the MC68HC908GR8 • Features of the CPU08 1.3.1 Standard Features of the MC68HC908GR8 • High-performance M68HC08 architecture optimized for Ccompilers • Fully upward-compatible object code with M6805, M146805, and M68HC05 Families • 8-MHz internal bus frequency • FLASH program memory security(1) • On-chip programming firmware for use with host personal computer which does not require high voltage for entry • In-system programming • System protection features: – Optional computer operating properly (COP) reset – Low-voltage detection with optional reset and selectable trip points for 3.0 V and 5.0 V operation – Illegal opcode detection with reset – Illegal address detection with reset • Low-power design; fully static with stop and wait modes • Standard low-power modes of operation: – Wait mode – Stop mode • Master reset pin and power-on reset (POR) 1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or copying the FLASH difficult for unauthorized users. Technical Data 26 MC68HC908GR8 — Rev 4.0 General Description MOTOROLA General Description Features • 7680 bytes of on-chip FLASH memory on the MC68HC908GR8 and 4096 bytes of on-chip FLASH memory on the MC68HC908GR4 with in-circuit programming capabilities of FLASH program memory • 384 bytes of on-chip random-access memory (RAM) • Serial peripheral interface module (SPI) • Serial communications interface module (SCI) • One 16-bit, 2-channel timer (TIM1) and one 16-bit, 1-channel timer (TIM2) interface modules with selectable input capture, output compare, and PWM capability on each channel • 6-channel, 8-bit successive approximation analog-to-digital converter (ADC) • BREAK module (BRK) to allow single breakpoint setting during incircuit debugging • Internal pullups on IRQ and RST to reduce customer system cost • Clock generator module with on-chip 32-kHz crystal compatible PLL (phase-lock loop) • Up to 21 general-purpose input/output (I/O) pins, including: – 19 shared-function I/O pins – Up to two dedicated I/O pins, depending on package choice • Selectable pullups on inputs only on ports A, C, and D. Selection is on an individual port bit basis. During output mode, pullups are disengaged. • High current 10-mA sink/10-mA source capability on all port pins • Higher current 15-mA sink/source capability on PTC0–PTC1 • Timebase module with clock prescaler circuitry for eight user selectable periodic real-time interrupts with optional active clock source during stop mode for periodic wakeup from stop using an external 32-kHz crystal • Oscillator stop mode enable bit (OSCSTOPENB) in the CONFIG register to allow user selection of having the oscillator enabled or disabled during stop mode MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data General Description 27 General Description • 4-bit keyboard wakeup port • 32-pin quad flat pack (QFP) or 28-pin plastic dual-in-line package (DIP) or 28-pin small outline integrated circuit (SOIC) • Specific features of the MC68HC908GR8 in 28-pin DIP and 28-pin SOIC are: – Port B is only 4 bits: PTB0–PTB3; 4-channel ADC module – No Port C bits 1.3.2 Features of the CPU08 Features of the CPU08 include: • Enhanced HC05 programming model • Extensive loop control functions • 16 addressing modes (eight more than the HC05) • 16-bit index register and stack pointer • Memory-to-memory data transfers • Fast 8 × 8 multiply instruction • Fast 16/8 divide instruction • Binary-coded decimal (BCD) instructions • Optimization for controller applications • Efficient C language support 1.4 MCU Block Diagram Figure 1-1 shows the structure of the MC68HC908GR8. Technical Data 28 MC68HC908GR8 — Rev 4.0 General Description MOTOROLA MC68HC908GR8 — Rev 4.0 PORTA PORTB PTC1–PTC0 † ‡ PTD6/T2CH0 † PTD5/T1CH1 † PTD4/T1CH0 † PTD3/SPSCK † PTD2/MOSI † PTD1/MISO † PTD0/SS † DUAL V. LOW-VOLTAGE INHIBIT MODULE 4-BIT KEYBOARD INTERRUPT MODULE FLASH PROGRAMMING (BURN-IN) ROM — 544 BYTES 2-CHANNEL TIMER INTERFACE MODULE 1 USER FLASH VECTOR SPACE — 36 BYTES 1-CHANNEL TIMER INTERFACE MODULE 2 CLOCK GENERATOR MODULE OSC1 OSC2 CGMXFC 32-kHz OSCILLATOR PHASE-LOCKED LOOP PORTE MONITOR ROM — 310 BYTES DDRD Figure 1-1. MCU Block Diagram General Description PTB5/AD5–PTB0/AD0 PORTC USER RAM — 384 BYTES PTA3/KBD3–PTA0/KBD0 † PORTD MC68HC908GR8 USER FLASH — 7680 BYTES MC68HC908GR4 USER FLASH — 4096BYTES SINGLE BRKPT BREAK MODULE DDRA CONTROL AND STATUS REGISTERS — 64 BYTES PROGR. TIMEBASE MODULE DDRB ARITHMETIC/LOGIC UNIT (ALU) DDRC CPU REGISTERS DDRE MOTOROLA INTERNAL BUS M68HC08 CPU PTE1/RxD PTE0/TxD SERIAL COMMUNICATIONS INTERFACE MODULE COMPUTER OPERATING PROPERLY MODULE SERIAL PERIPHERAL INTERFACE MODULE * RST 24 INTR SYSTEM INTEGRATION MODULE * IRQ SINGLE EXTERNAL IRQ MODULE MONITOR MODULE VDDAD / VREFH VSSAD / VREFL 8-BIT ANALOG-TO-DIGITAL CONVERTER MODULE POWER † Ports are software configurable with pullup device if input port. ‡ Higher current drive port pins * Pin contains integrated pullup device MEMORY MAP MODULE MASK OPTION REGISTER1 MODULE MASK OPTION REGISTER2 MODULE POWER-ON RESET MODULE SECURITY MODULE MONITOR MODE ENTRY MODULE General Description MCU Block Diagram 29 Technical Data VDD VSS VDDA VSSA DATA BUS SWITCH MODULE General Description CGMXFC VSSA VDDA PTC1 PTC0 PTA3/KBD3 30 29 28 27 26 25 1 OSC2 RST 31 32 OSC1 1.5 Pin Assignments 24 PTA2/KBD2 PTD1/MISO 6 19 PTB5/AD5 PTD2/MOSI 7 18 PTB4/AD4 PTD3/SPSCK 8 17 PTB3/AD3 16 VDDAD/VREFH PTB2/AD2 20 15 5 PTB1/AD1 PTD0/SS 14 VSSAD/VREFL PTB0/AD0 21 13 4 PTD6/T2CH0 IRQ 12 PTA0/KBD0 PTD5/T1CH1 22 11 3 PTD4/T1CH0 PTE1/RxD 10 PTA1/KBD1 VDD 23 9 2 VSS PTE0/TxD NOTE: Ports PTB4, PTB5, PTC0, and PTC1 are available only with the QFP. Figure 1-2. QFP Pin Assignments Technical Data 30 MC68HC908GR8 — Rev 4.0 General Description MOTOROLA General Description Pin Functions CGMXFC 1 28 VSSA OSC2 2 27 VDDA OSC1 3 26 PTA3/KBD3 RST 4 25 PTA2/KBD2 PTE0/TxD 5 24 PTA1/KBD1 PTE1/RxD 6 23 PTA0/KBD0 IRQ 7 22 VSSAD/VREFL PTD0/SS 8 21 VDDAD/VREFH PTD1/MISO 9 20 PTB3/AD3 PTD2/MOSI 10 19 PTB2/AD2 PTD3/SPSCK 11 18 PTB1/AD1 VSS 12 17 PTB0/AD0 VDD 13 16 PTD6/T2CH0 PTD4/T1CH0 14 15 PTD5/T1CH1 NOTE: Ports PTB4, PTB5, PTC0, and PTC1 are available only with the QFP. Figure 1-3. DIP And SOIC Pin Assignments 1.6 Pin Functions Descriptions of the pin functions are provided here. 1.6.1 Power Supply Pins (VDD and VSS) VDD and VSS are the power supply and ground pins. The MCU operates from a single power supply. Fast signal transitions on MCU pins place high, short-duration current demands on the power supply. To prevent noise problems, take special care to provide power supply bypassing at the MCU as Figure 1-4 shows. Place the C1 bypass capacitor as close to the MCU as possible. Use a high-frequency-response ceramic capacitor for C1. C2 is an optional bulk current bypass capacitor for use in applications that require the port pins to source high current levels. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data General Description 31 General Description MCU VDD VSS C1 0.1 µF + C2 VDD NOTE: Component values shown represent typical applications. Figure 1-4. Power Supply Bypassing 1.6.2 Oscillator Pins (OSC1 and OSC2) The OSC1 and OSC2 pins are the connections for the on-chip oscillator circuit. See Clock Generator Module (CGMC). 1.6.3 External Reset Pin (RST) A logic 0 on the RST pin forces the MCU to a known startup state. RST is bidirectional, allowing a reset of the entire system. It is driven low when any internal reset source is asserted. This pin contains an internal pullup resistor that is always activated, even when the reset pin is pulled low. See Resets and Interrupts. 1.6.4 External Interrupt Pin (IRQ) IRQ is an asynchronous external interrupt pin. This pin contains an internal pullup resistor that is always activated, even when the reset pin is pulled low. See External Interrupt (IRQ). 1.6.5 CGM Power Supply Pins (VDDA and VSSA) VDDA and VSSA are the power supply pins for the analog portion of the clock generator module (CGM). Decoupling of these pins should be as per the digital supply. See Clock Generator Module (CGMC). Technical Data 32 MC68HC908GR8 — Rev 4.0 General Description MOTOROLA General Description Pin Functions 1.6.6 External Filter Capacitor Pin (CGMXFC) CGMXFC is an external filter capacitor connection for the CGM. See Clock Generator Module (CGMC). 1.6.7 Analog Power Supply/Reference Pins (VDDAD/VREFH and VSSAD/VREFL) VDDAD and VSSAD are the power supply pins for the analog-to-digital converter. Decoupling of these pins should be as per the digital supply. NOTE: VREFH is the high reference supply for the ADC. The VREFH signal is internally connected with VDDAD and have the same potential as VDDAD. VDDAD should be tied to the same potential as VDD via separate traces. VREFL is the low reference supply for the ADC. The VREFL pin is internally connected with VSSAD and has the same potential as VSSAD. VSSAD should be tied to the same potential as VSS via separate traces. See Analog-to-Digital Converter (ADC). 1.6.8 Port A Input/Output (I/O) Pins (PTA3/KBD3–PTA0/KBD0) PTA3–PTA0 are special-function, bidirectional I/O port pins. Any or all of the port A pins can be programmed to serve as keyboard interrupt pins. See Input/Output Ports (I/O) and External Interrupt (IRQ). These port pins also have selectable pullups when configured for input mode. The pullups are disengaged when configured for output mode. The pullups are selectable on an individual port bit basis. When the port pins are configured for special-function mode (KBI), pullups will be automatically engaged. As long as the port pins are in special-function mode, the pullups will always be on. 1.6.9 Port B I/O Pins (PTB5/AD5–PTB0/AD0) PTB5–PTB0 are special-function, bidirectional I/O port pins that can also be used for analog-to-digital converter (ADC) inputs. See Input/Output Ports (I/O) and Analog-to-Digital Converter (ADC). There are no pullups associated with this port. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data General Description 33 General Description 1.6.10 Port C I/O Pins (PTC1–PTC0) PTC1–PTC0 are general-purpose, bidirectional I/O port pins. See Input/Output Ports (I/O). PTC0 and PTC1 are only available on 32-pin QFP packages. These port pins also have selectable pullups when configured for input mode. The pullups are disengaged when configured for output mode. The pullups are selectable on an individual port bit basis. 1.6.11 Port D I/O Pins (PTD6/T2CH0–PTD0/SS) PTD6–PTD0 are special-function, bidirectional I/O port pins. PTD3–PTD0 can be programmed to be serial peripheral interface (SPI) pins, while PTD6–PTD4 can be individually programmed to be timer interface module (TIM1 and TIM2) pins. See Timer Interface Module (TIM), Serial Peripheral Interface (SPI), and Input/Output Ports (I/O). These port pins also have selectable pullups when configured for input mode. The pullups are disengaged when configured for output mode. The pullups are selectable on an individual port bit basis. When the port pins are configured for special-function mode (SPI, TIM1, TIM2), pullups can be selectable on an individual port pin basis. 1.6.12 Port E I/O Pins (PTE1/RxD–PTE0/TxD) PTE1–PTE0 are special-function, bidirectional I/O port pins. These pins can also be programmed to be serial communications interface (SCI) pins. See Serial Communications Interface (SCI) and Input/Output Ports (I/O). NOTE: Any unused inputs and I/O ports should be tied to an appropriate logic level (either VDD or VSS). Although the I/O ports of the MC68HC908GR8 do not require termination, termination is recommended to reduce the possibility of electro-static discharge damage. Technical Data 34 MC68HC908GR8 — Rev 4.0 General Description MOTOROLA Technical Data — MC68HC908GR8 Section 2. Memory Map 2.1 Contents 2.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 2.3 Unimplemented Memory Locations . . . . . . . . . . . . . . . . . . . . . . 35 2.4 Reserved Memory Locations . . . . . . . . . . . . . . . . . . . . . . . . . . 36 2.5 Input/Output (I/O) Section. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 2.2 Introduction The CPU08 can address 64K bytes of memory space. The memory map, shown in Figure 2-1, includes: • 8K bytes of FLASH memory, 7680 bytes of user space on the MC68HC908GR8 or 4K bytes of FLASH memory, 4096 bytes of user space on the MC68HC908GR4 • 384 bytes of random-access memory (RAM) • 36 bytes of user-defined vectors • 310 bytes of monitor routines in read-only memory (ROM) • 544 bytes of integrated FLASH burn-in routines in ROM 2.3 Unimplemented Memory Locations Accessing an unimplemented location can cause an illegal address reset if illegal address resets are enabled. In the memory map (Figure 21) and in register figures in this document, unimplemented locations are shaded. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Memory Map 35 Memory Map 2.4 Reserved Memory Locations Accessing a reserved location can have unpredictable effects on MCU operation. In the Figure 2-1 and in register figures in this document, reserved locations are marked with the word Reserved or with the letter R. 2.5 Input/Output (I/O) Section Most of the control, status, and data registers are in the zero page area of $0000–$003F. Additional I/O registers have these addresses: • $FE00; SIM break status register, SBSR • $FE01; SIM reset status register, SRSR • $FE03; SIM break flag control register, SBFCR • $FE09; interrupt status register 1, INT1 • $FE0A; interrupt status register 2, INT2 • $FE0B; interrupt status register 3, INT3 • $FE07; reserved FLASH test control register, FLTCR • $FE08; FLASH control register, FLCR • $FE09; break address register high, BRKH • $FE0A; break address register low, BRKL • $FE0B; break status and control register, BRKSCR • $FE0C; LVI status register, LVISR • $FF7E; FLASH block protect register, FLBPR Data registers are shown in Figure 2-2, and Table 2-1 is a list of vector locations. Technical Data 36 MC68HC908GR8 — Rev 4.0 Memory Map MOTOROLA Memory Map Input/Output (I/O) Section $0000 I/O Registers 64 Bytes ↓ $003F $0040 RAM 384 Bytes ↓ $01BF $01C0 Unimplemented 6720 Bytes ↓ $1BFF $1C00 ↓ Reserved for Integrated FLASH Burn-in Routines 544 Bytes $1E1F $1E20 Unimplemented 49,632 Bytes ↓ $DFFF $E000 MC68HC908GR4 Unimplemented 3584 Bytes ↓ $EDFF $EE00 MC68HC908GR8 FLASH Memory 7680 Bytes MC68HC908GR4 FLASH Memory 4096 Bytes ↓ $FDFF $FE00 SIM Break Status Register (SBSR) $FE01 SIM Reset Status Register (SRSR) $FE02 Reserved $FE03 SIM Break Flag Control Register (SBFCR) $FE09 Interrupt Status Register 1 (INT1) $FE0A Interrupt Status Register 2 (INT2) $FE0B Interrupt Status Register 3 (INT3) $FE07 Reserved for FLASH Test Control Register (FLTCR) Figure 2-1. Memory Map MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Memory Map 37 Memory Map $FE08 FLASH Control Register (FLCR) $FE09 Break Address Register High (BRKH) $FE0A Break Address Register Low (BRKL) $FE0B Break Status and Control Register (BRKSCR) $FE0C LVI Status Register (LVISR) $FE0D Reserved 3 Bytes ↓ $FE0F $FE10 ↓ $FE1F Unimplemented 16 Bytes Reserved for Compatibility with Monitor Code for A-Family Parts $FE20 Monitor ROM 310 Bytes ↓ $FF55 $FF56 Unimplemented 40 Bytes ↓ $FF7D $FF7E FLASH Block Protect Register (FLBPR) $FF7F Unimplemented 93 Bytes ↓ $FFDB Note: $FFF6–$FFFD contains 8 security bytes $FFDC ↓ FLASH Vectors (36 Bytes inluding $FFFF) $FFFE $FFFF Low byte of reset vector when read COP Control Register (COPCTL) Figure 2-1. Memory Map (Continued) Technical Data 38 MC68HC908GR8 — Rev 4.0 Memory Map MOTOROLA Memory Map Input/Output (I/O) Section Addr. Bit 7 6 5 4 Read: Port A Data Register Write: (PTA) Reset: 0 0 0 0 Read: Port B Data Register Write: (PTB) Reset: 0 Read: Port C Data Register Write: (PTC) Reset: 0 Read: Port D Data Register Write: (PTD) Reset: 0 Read: Data Direction Register A $0004 Write: (DDRA) Reset: 0 0 0 0 0 0 0 Read: Data Direction Register B $0005 Write: (DDRB) Reset: 0 0 0 Read: Data Direction Register C $0006 Write: (DDRC) Reset: Read: Data Direction Register D $0007 Write: (DDRD) Reset: 0 $0000 $0001 $0002 $0003 $0008 Register Name Read: Port E Data Register Write: (PTE) Reset: 3 2 1 Bit 0 PTA3 PTA2 PTA1 PTA0 PTB2 PTB1 PTB0 PTC1 PTC0 PTD2 PTD1 PTD0 DDRA3 DDRA2 DDRA1 DDRA0 0 0 0 0 0 DDRB5 DDRB4 DDRB3 DDRB2 DDRB1 DDRB0 0 0 0 0 0 0 0 0 0 0 0 0 0 DDRC1 DDRC0 0 0 0 0 0 0 0 0 DDRD6 DDRD5 DDRD4 DDRD3 DDRD2 DDRD1 DDRD0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 PTE1 PTE0 0 0 Unaffected by reset 0 PTB5 PTB4 PTB3 Unaffected by reset 0 0 0 0 0 Unaffected by reset PTD6 PTD5 PTD4 PTD3 Unaffected by reset Unaffected by reset Read: $0009 Unimplemented Write: Reset: 0 0 0 = Unimplemented 0 R = Reserved 0 0 U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 1 of 8) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Memory Map 39 Memory Map Addr. Register Name Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Reset: 0 0 0 0 0 0 0 0 Read: Data Direction Register E $000C Write: (DDRE) Reset: 0 0 0 0 0 0 DDRE1 DDRE0 0 0 0 0 0 0 0 0 Read: Port A Input Pullup Enable $000D Write: Register (PTAPUE) Reset: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Read: Unimplemented Write: $000A Reset: Read: $000B Unimplemented Write: Read: Port C Input Pullup Enable $000E Write: Register (PTCPUE) Reset: Read: Port D Input Pullup Enable $000F Write: Register (PTDPUE) Reset: $0010 $0011 $0012 $0013 Read: SPI Control Register Write: (SPCR) Reset: Read: SPI Status and Control Write: Register (SPSCR) Reset: Read: SPI Data Register Write: (SPDR) Reset: 0 0 SPRIE 0 SPRF PTAPUE3 PTAPUE2 PTAPUE1 PTAPUE0 0 0 PTCPUE1 PTCPUE0 0 0 PTDPUE6 PTDPUE5 PTDPUE4 PTDPUE3 PTDPUE2 PTDPUE1 PTDPUE0 0 DMAS 0 ERRIE 0 0 0 0 0 0 SPMSTR CPOL CPHA SPWOM SPE SPTIE 1 0 1 0 0 0 OVRF MODF SPTE MODFEN SPR1 SPR0 0 0 0 0 1 0 0 0 R7 R6 R5 R4 R3 R2 R1 R0 T7 T6 T5 T4 T3 T2 T1 T0 Read: LOOPS SCI Control Register 1 Write: (SCC1) Reset: 0 Unaffected by reset ENSCI TXINV M WAKE ILTY PEN PTY 0 0 0 0 0 0 0 = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 2 of 8) Technical Data 40 MC68HC908GR8 — Rev 4.0 Memory Map MOTOROLA Memory Map Input/Output (I/O) Section Addr. Register Name $0014 Read: SCI Control Register 2 Write: (SCC2) Reset: $0015 $0016 $0017 $001A 6 5 4 3 2 1 Bit 0 SCTIE TCIE SCRIE ILIE TE RE RWU SBK 0 0 0 0 0 0 0 0 T8 DMARE DMATE ORIE NEIE FEIE PEIE Read: SCI Control Register 3 Write: (SCC3) Reset: R8 U U 0 0 0 0 0 0 Read: SCI Status Register 1 Write: (SCS1) Reset: SCTE TC SCRF IDLE OR NF FE PE 1 1 0 0 0 0 0 0 BKF RPF Read: SCI Status Register 2 Write: (SCS2) Reset: Read: SCI Data Register Write: (SCDR) Reset: $0018 $0019 Bit 7 Read: SCI Baud Rate Register Write: (SCBR) Reset: Read: Keyboard Status and Control Register Write: (INTKBSCR) Reset: 0 0 0 0 0 0 0 0 R7 R6 R5 R4 R3 R2 R1 R0 T7 T6 T5 T4 T3 T2 T1 T0 Unaffected by reset SCP1 SCP0 R SCR2 SCR1 SCR0 0 0 IMASKK MODEK 0 0 0 0 0 0 0 0 0 0 KEYF 0 ACKK 0 0 0 0 Read: Keyboard Interrupt Enable $001B Write: Register (INTKBIER) Reset: Read: Time Base Module Control $001C Write: Register (TBCR) Reset: $001D Read: IRQ Status and Control Write: Register (INTSCR) Reset: TBIF 0 0 0 0 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 TBIE TBON R 0 0 IMASK1 MODE1 0 0 0 TBR2 TBR1 TBR0 0 0 0 0 0 0 0 0 0 0 IRQF1 0 TACK ACK1 0 0 0 = Unimplemented 0 R = Reserved 0 0 U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 3 of 8) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Memory Map 41 Memory Map Addr. $001E $001F Register Name Bit 7 6 5 4 3 2 Read: Configuration Register 2 (CONFIG2)† Write: 0 0 0 0 0 0 Reset: 0 0 0 0 0 0 0 0 SSREC STOP COPD 0 0 0 PS2 PS1 PS0 Read: COPRS Configuration Register 1 Write: (CONFIG1)† Reset: 0 LVISTOP LVIRSTD LVIPWRD LVI5OR3† 0 0 TOIE TSTOP 0 0 0 0 1 Bit 0 OSCSCIBDSTOPENB SRC Read: Timer 1 Status and Control $0020 Write: Register (T1SC) Reset: TOF 0 0 1 0 0 0 0 0 Read: Timer 1 Counter Register $0021 Write: High (T1CNTH) Reset: Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 Read: Timer 1 Counter Register $0022 Write: Low (T1CNTL) Reset: Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 1 1 1 1 1 1 1 1 Bit 7 6 5 4 3 2 1 Bit 0 1 1 1 1 1 1 1 1 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 2 1 Bit 0 Read: Timer 1 Counter Modulo $0023 Write: Register High (T1MODH) Reset: $0024 Read: Timer 1 Counter Modulo Write: Register Low (T1MODL) Reset: Read: Timer 1 Channel 0 Status $0025 and Control Register Write: (T1SC0) Reset: $0026 $0027 Read: Timer 1 Channel 0 Write: Register High (T1CH0H) Reset: Read: Timer 1 Channel 0 Write: Register Low (T1CH0L) Reset: 0 CH0F 0 TRST Indeterminate after reset Bit 7 6 5 4 3 Indeterminate after reset † One-time writeable register after each reset, except LVI5OR3 bit. LVI5OR3 bit is only reset via POR (power-on reset). = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 4 of 8) Technical Data 42 MC68HC908GR8 — Rev 4.0 Memory Map MOTOROLA Memory Map Input/Output (I/O) Section Addr. Register Name Bit 7 Read: Timer 1 Channel 1 Status $0028 and Control Register Write: (T1SC1) Reset: CH1F $0029 $002A Read: Timer 1 Channel 1 Write: Register High (T1CH1H) Reset: Read: Timer 1 Channel 1 Write: Register Low (T1CH1L) Reset: 0 6 CH1IE 5 0 4 3 2 1 Bit 0 MS1A ELS1B ELS1A TOV1 CH1MAX 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 2 1 Bit 0 PS2 PS1 PS0 Indeterminate after reset Bit 7 6 5 4 3 Indeterminate after reset Read: Timer 2 Status and Control $002B Write: Register (T2SC) Reset: TOF 0 0 TOIE TSTOP 0 0 1 0 0 0 0 0 Read: Timer 2 Counter Register $002C Write: High (T2CNTH) Reset: Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 Read: Timer 2 Counter Register $002D Write: Low (T2CNTL) Reset: Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 1 1 1 1 1 1 1 1 Bit 7 6 5 4 3 2 1 Bit 0 1 1 1 1 1 1 1 1 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 Read: Timer 2 Counter Modulo $002E Write: Register High (T2MODH) Reset: $002F Read: Timer 2 Counter Modulo Write: Register Low (T2MODL) Reset: Read: Timer 2 Channel 0 Status $0030 and Control Register Write: (T2SC0) Reset: $0031 Read: Timer 2 Channel 0 Write: Register High (T2CH0H) Reset: 0 CH0F 0 TRST Indeterminate after reset = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 5 of 8) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Memory Map 43 Memory Map Addr. $0032 Register Name Read: Timer 2 Channel 0 Write: Register Low (T2CH0L) Reset: Unimplemented $0033 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 Indeterminate after reset Read: Write: Reset: 0 0 0 0 0 Read: $0034 Unimplemented Write: Reset: Indeterminate after reset Read: $0035 Unimplemented Write: Reset: $0036 $0037 Read: PLL Control Register Write: (PCTL) Reset: Read: PLL Bandwidth Control Write: Register (PBWC) Reset: Read: PLL Multiplier Select High $0038 Write: Register (PMSH) Reset: Read: PLL Multiplier Select Low $0039 Write: Register (PMSL) Reset: $003A $003B Read: PLL VCO Select Range Write: Register (PMRS) Reset: Read: PLL Reference Divider Write: Select Register (PMDS) Reset: Indeterminate after reset PLLIE 0 AUTO PLLF 0 LOCK PLLON BCS PRE1 PRE0 VPR1 VPR0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 MUL11 MUL10 MUL9 MUL8 ACQ R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 MUL7 MUL6 MUL5 MUL4 MUL3 MUL2 MUL1 MUL0 0 1 0 0 0 0 0 0 VRS7 VRS6 VRS5 VRS4 VRS3 VRS2 VRS1 VRS0 0 1 0 0 0 0 0 0 0 0 0 0 RDS3 RDS2 RDS1 RDS0 0 0 0 0 0 0 0 1 = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 6 of 8) Technical Data 44 MC68HC908GR8 — Rev 4.0 Memory Map MOTOROLA Memory Map Input/Output (I/O) Section Addr. $003C $003D $003E Register Name Bit 7 Read: Analog-to-Digital Status and Control Register Write: (ADSCR) Reset: Read: Analog-to-Digital Data Write: Register (ADR) Reset: Read: Analog-to-Digital Input Write: Clock Register (ADCLK) Reset: 6 5 4 3 2 1 Bit 0 AIEN ADCO ADCH4 ADCH3 ADCH2 ADCH1 ADCH0 0 0 0 1 1 1 1 1 AD7 AD6 AD5 AD4 AD3 AD2 AD1 AD0 R R R R R R R R 0 0 0 0 R R R R 0 0 COCO R Indeterminate after reset ADIV2 ADIV1 ADIV0 ADICLK 0 0 0 0 0 0 R R R R R R 0 0 0 0 0 0 0 0 POR PIN COP ILOP ILAD MODRST LVI 0 1 0 0 0 0 0 0 0 BCFE R R R R R R R Read: $003F Unimplemented Write: Reset: Read: SIM Break Status Register $FE00 Write: (SBSR) Reset: SBSW NOTE R Note: Writing a logic 0 clears SBSW. Read: SIM Reset Status Register $FE01 Write: (SRSR) POR: Read: $FE02 Unimplemented Write: Reset: $FE03 Read: SIM Break Flag Control Write: Register (SBFCR) Reset: 0 Read: Interrupt Status Register 1 $FE09 Write: (INT1) Reset: IF6 IF5 IF4 IF3 IF2 IF1 0 0 R R R R R R R R 0 0 0 0 0 0 0 0 Read: Interrupt Status Register 2 $FE0A Write: (INT2) Reset: IF14 IF13 IF12 IF11 IF10 IF9 IF8 IF7 R R R R R R R R 0 0 0 0 0 0 0 0 = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 7 of 8) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Memory Map 45 Memory Map Addr. Register Name Bit 7 6 5 4 3 2 1 Bit 0 Read: Interrupt Status Register 3 $FE0B Write: (INT3) Reset: 0 0 0 0 0 0 IF16 IF15 R R R R R R R R 0 0 0 0 0 0 0 0 R R R R R R R R 0 0 0 0 0 0 0 0 0 0 0 0 HVEN MASS ERASE PGM 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 BRKE BRKA 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 BPR7 BPR6 BPR5 BPR4 BPR3 BPR2 BPR1 BPR0 U U U U U U U U $FE07 $FE08 $FE09 $FE0A Read: FLASH Test Control Write: Register (FLTCR) Reset: Read: FLASH Control Register Write: (FLCR) Reset: Read: Break Address Register Write: High (BRKH) Reset: Read: Break Address Register Write: Low (BRKL) Reset: Read: Break Status and Control $FE0B Write: Register (BRKSCR) Reset: $FE0C $FF7E $FFFF Read: LVIOUT LVI Status Register Write: (LVISR) Reset: 0 Read: FLASH Block Protect Write: Register (FLBPR)† Reset: Read: COP Control Register Write: (COPCTL) Reset: Low byte of reset vector Writing clears COP counter (any value) Unaffected by reset † Non-volatile FLASH register = Unimplemented R = Reserved U = Unaffected Figure 2-2. Control, Status, and Data Registers (Sheet 8 of 8) Technical Data 46 MC68HC908GR8 — Rev 4.0 Memory Map MOTOROLA Memory Map Input/Output (I/O) Section . Table 2-1. Vector Addresses Vector Priority Lowest Vector IF16 IF15 IF14 IF13 IF12 IF11 IF10 IF9 IF8 IF7 IF6 IF5 IF4 IF3 IF2 IF1 — Highest — Address $FFDC Timebase Vector (High) $FFDD Timebase Vector (Low) $FFDE ADC Conversion Complete Vector (High) $FFDF ADC Conversion Complete Vector (Low) $FFE0 Keyboard Vector (High) $FFE1 Keyboard Vector (Low) $FFE2 SCI Transmit Vector (High) $FFE3 SCI Transmit Vector (Low) $FFE4 SCI Receive Vector (High) $FFE5 SCI Receive Vector (Low) $FFE6 SCI Error Vector (High) $FFE7 SCI Error Vector (Low) $FFE8 SPI Transmit Vector (High) $FFE9 SPI Transmit Vector (Low) $FFEA SPI Receive Vector (High) $FFEB SPI Receive Vector (Low) $FFEC TIM2 Overflow Vector (High) $FFED TIM2 Overflow Vector (Low) $FFEE Reserved $FFEF Reserved $FFF0 TIM2 Channel 0 Vector (High) $FFF1 TIM2 Channel 0 Vector (Low) $FFF2 TIM1 Overflow Vector (High) $FFF3 TIM1 Overflow Vector (Low) $FFF4 TIM1 Channel 1 Vector (High) $FFF5 TIM1 Channel 1 Vector (Low) $FFF6 TIM1 Channel 0 Vector (High) $FFF7 TIM1 Channel 0 Vector (Low) $FFF8 PLL Vector (High) $FFF9 PLL Vector (Low) $FFFA IRQ Vector (High) $FFFB IRQ Vector (Low) $FFFC SWI Vector (High) $FFFD SWI Vector (Low) $FFFE Reset Vector (High) $FFFF Reset Vector (Low) MC68HC908GR8 — Rev 4.0 MOTOROLA Vector Technical Data Memory Map 47 Memory Map Technical Data 48 MC68HC908GR8 — Rev 4.0 Memory Map MOTOROLA Technical Data — MC68HC908GR8 Section 3. Low Power Modes 3.1 Contents 3.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 49 3.3 Analog-to-Digital Converter (ADC) . . . . . . . . . . . . . . . . . . . . . . 50 3.4 Break Module (BRK). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 51 3.5 Central Processor Unit (CPU). . . . . . . . . . . . . . . . . . . . . . . . . . 51 3.6 Clock Generator Module (CGM) . . . . . . . . . . . . . . . . . . . . . . . . 52 3.7 Computer Operating Properly Module (COP). . . . . . . . . . . . . . 52 3.8 External Interrupt Module (IRQ) . . . . . . . . . . . . . . . . . . . . . . . . 53 3.9 Keyboard Interrupt Module (KBI) . . . . . . . . . . . . . . . . . . . . . . . 53 3.10 Low-Voltage Inhibit Module (LVI) . . . . . . . . . . . . . . . . . . . . . . . 54 3.11 Serial Communications Interface Module (SCI) . . . . . . . . . . . . 54 3.12 Serial Peripheral Interface Module (SPI) . . . . . . . . . . . . . . . . . 55 3.13 Timer Interface Module (TIM1 and TIM2) . . . . . . . . . . . . . . . . . 55 3.14 Timebase Module (TBM) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 56 3.15 Exiting Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 57 3.16 Exiting Stop Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 58 3.2 Introduction The MCU may enter two low-power modes: wait mode and stop mode. They are common to all HC08 MCUs and are entered through instruction execution. This section describes how each module acts in the lowpower modes. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low Power Modes 49 Low Power Modes 3.2.1 Wait Mode The WAIT instruction puts the MCU in a low-power standby mode in which the CPU clock is disabled but the bus clock continues to run. Power consumption can be further reduced by disabling the LVI module and/or the timebase module through bits in the CONFIG register. (See Configuration Register (CONFIG).) 3.2.2 Stop Mode Stop mode is entered when a STOP instruction is executed. The CPU clock is disabled and the bus clock is disabled if the OSCSTOPENB bit in the CONFIG register is at a logic 0. (See Configuration Register (CONFIG).) 3.3 Analog-to-Digital Converter (ADC) 3.3.1 Wait Mode The ADC continues normal operation during wait mode. Any enabled CPU interrupt request from the ADC can bring the MCU out of wait mode. If the ADC is not required to bring the MCU out of wait mode, power down the ADC by setting ADCH4–ADCH0 bits in the ADC status and control register before executing the WAIT instruction. 3.3.2 Stop Mode The ADC module is inactive after the execution of a STOP instruction. Any pending conversion is aborted. ADC conversions resume when the MCU exits stop mode after an external interrupt. Allow one conversion cycle to stabilize the analog circuitry. Technical Data 50 MC68HC908GR8 — Rev 4.0 Low Power Modes MOTOROLA Low Power Modes Break Module (BRK) 3.4 Break Module (BRK) 3.4.1 Wait Mode If enabled, the break module is active in wait mode. In the break routine, the user can subtract one from the return address on the stack if the BW bit in the break status register is set. 3.4.2 Stop Mode The break module is inactive in stop mode. A break interrupt causes exit from stop mode and sets the BW bit in the break status register. The STOP instruction does not affect break module register states. 3.5 Central Processor Unit (CPU) 3.5.1 Wait Mode The WAIT instruction: • Clears the interrupt mask (I bit) in the condition code register, enabling interrupts. After exit from wait mode by interrupt, the I bit remains clear. After exit by reset, the I bit is set. • Disables the CPU clock 3.5.2 Stop Mode The STOP instruction: • Clears the interrupt mask (I bit) in the condition code register, enabling external interrupts. After exit from stop mode by external interrupt, the I bit remains clear. After exit by reset, the I bit is set. • Disables the CPU clock After exiting stop mode, the CPU clock begins running after the oscillator stabilization delay. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low Power Modes 51 Low Power Modes 3.6 Clock Generator Module (CGM) 3.6.1 Wait Mode The CGM remains active in wait mode. Before entering wait mode, software can disengage and turn off the PLL by clearing the BCS and PLLON bits in the PLL control register (PCTL). Less power-sensitive applications can disengage the PLL without turning it off. Applications that require the PLL to wake the MCU from wait mode also can deselect the PLL output without turning off the PLL. 3.6.2 Stop Mode If the OSCSTOPEN bit in the CONFIG register is cleared (default), then the STOP instruction disables the CGM (oscillator and phase-locked loop) and holds low all CGM outputs (CGMXCLK, CGMOUT, and CGMINT). If the STOP instruction is executed with the VCO clock, CGMVCLK, divided by two driving CGMOUT, the PLL automatically clears the BCS bit in the PLL control register (PCTL), thereby selecting the crystal clock, CGMXCLK, divided by two as the source of CGMOUT. When the MCU recovers from STOP, the crystal clock divided by two drives CGMOUT and BCS remains clear. If the OSCSTOPEN bit in the CONFIG register is set, then the phase locked loop is shut off, but the oscillator will continue to operate in stop mode. 3.7 Computer Operating Properly Module (COP) 3.7.1 Wait Mode The COP remains active in wait mode. To prevent a COP reset during wait mode, periodically clear the COP counter in a CPU interrupt routine or a DMA service routine. Technical Data 52 MC68HC908GR8 — Rev 4.0 Low Power Modes MOTOROLA Low Power Modes External Interrupt Module (IRQ) 3.7.2 Stop Mode Stop mode turns off the CGMXCLK input to the COP and clears the COP prescaler. Service the COP immediately before entering or after exiting stop mode to ensure a full COP timeout period after entering or exiting stop mode. The STOP bit in the configuration register (CONFIG) enables the STOP instruction. To prevent inadvertently turning off the COP with a STOP instruction, disable the STOP instruction by clearing the STOP bit. 3.8 External Interrupt Module (IRQ) 3.8.1 Wait Mode The IRQ module remains active in wait mode. Clearing the IMASK1 bit in the IRQ status and control register enables IRQ CPU interrupt requests to bring the MCU out of wait mode. 3.8.2 Stop Mode The IRQ module remains active in stop mode. Clearing the IMASK1 bit in the IRQ status and control register enables IRQ CPU interrupt requests to bring the MCU out of stop mode. 3.9 Keyboard Interrupt Module (KBI) 3.9.1 Wait Mode The keyboard module remains active in wait mode. Clearing the IMASKK bit in the keyboard status and control register enables keyboard interrupt requests to bring the MCU out of wait mode. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low Power Modes 53 Low Power Modes 3.9.2 Stop Mode The keyboard module remains active in stop mode. Clearing the IMASKK bit in the keyboard status and control register enables keyboard interrupt requests to bring the MCU out of stop mode. 3.10 Low-Voltage Inhibit Module (LVI) 3.10.1 Wait Mode If enabled, the LVI module remains active in wait mode. If enabled to generate resets, the LVI module can generate a reset and bring the MCU out of wait mode. 3.10.2 Stop Mode If enabled, the LVI module remains active in stop mode. If enabled to generate resets, the LVI module can generate a reset and bring the MCU out of stop mode. 3.11 Serial Communications Interface Module (SCI) 3.11.1 Wait Mode The SCI module remains active in wait mode. Any enabled CPU interrupt request from the SCI module can bring the MCU out of wait mode. If SCI module functions are not required during wait mode, reduce power consumption by disabling the module before executing the WAIT instruction. Technical Data 54 MC68HC908GR8 — Rev 4.0 Low Power Modes MOTOROLA Low Power Modes Serial Peripheral Interface Module (SPI) 3.11.2 Stop Mode The SCI module is inactive in stop mode. The STOP instruction does not affect SCI register states. SCI module operation resumes after the MCU exits stop mode. Because the internal clock is inactive during stop mode, entering stop mode during an SCI transmission or reception results in invalid data. 3.12 Serial Peripheral Interface Module (SPI) 3.12.1 Wait Mode The SPI module remains active in wait mode. Any enabled CPU interrupt request from the SPI module can bring the MCU out of wait mode. If SPI module functions are not required during wait mode, reduce power consumption by disabling the SPI module before executing the WAIT instruction. 3.12.2 Stop Mode The SPI module is inactive in stop mode. The STOP instruction does not affect SPI register states. SPI operation resumes after an external interrupt. If stop mode is exited by reset, any transfer in progress is aborted, and the SPI is reset. 3.13 Timer Interface Module (TIM1 and TIM2) 3.13.1 Wait Mode The TIM remains active in wait mode. Any enabled CPU interrupt request from the TIM can bring the MCU out of wait mode. If TIM functions are not required during wait mode, reduce power consumption by stopping the TIM before executing the WAIT instruction. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low Power Modes 55 Low Power Modes 3.13.2 Stop Mode The TIM is inactive in stop mode. The STOP instruction does not affect register states or the state of the TIM counter. TIM operation resumes when the MCU exits stop mode after an external interrupt. 3.14 Timebase Module (TBM) 3.14.1 Wait Mode The timebase module remains active after execution of the WAIT instruction. In wait mode, the timebase register is not accessible by the CPU. If the timebase functions are not required during wait mode, reduce the power consumption by stopping the timebase before enabling the WAIT instruction. 3.14.2 Stop Mode The timebase module may remain active after execution of the STOP instruction if the oscillator has been enabled to operate during stop mode through the OSCSTOPEN bit in the CONFIG register. The timebase module can be used in this mode to generate a periodic wakeup from stop mode. If the oscillator has not been enabled to operate in stop mode, the timebase module will not be active during stop mode. In stop mode, the timebase register is not accessible by the CPU. If the timebase functions are not required during stop mode, reduce the power consumption by stopping the timebase before enabling the STOP instruction. Technical Data 56 MC68HC908GR8 — Rev 4.0 Low Power Modes MOTOROLA Low Power Modes Exiting Wait Mode 3.15 Exiting Wait Mode These events restart the CPU clock and load the program counter with the reset vector or with an interrupt vector: • External reset — A logic 0 on the RST pin resets the MCU and loads the program counter with the contents of locations $FFFE and $FFFF. • External interrupt — A high-to-low transition on an external interrupt pin (IRQ pin) loads the program counter with the contents of locations: $FFFA and $FFFB; IRQ pin. • Break interrupt — A break interrupt loads the program counter with the contents of $FFFC and $FFFD. • Computer operating properly module (COP) reset — A timeout of the COP counter resets the MCU and loads the program counter with the contents of $FFFE and $FFFF. • Low-voltage inhibit module (LVI) reset — A power supply voltage below the Vtripf voltage resets the MCU and loads the program counter with the contents of locations $FFFE and $FFFF. • Clock generator module (CGM) interrupt — A CPU interrupt request from the phase-locked loop (PLL) loads the program counter with the contents of $FFF8 and $FFF9. • Keyboard module (KBI) interrupt — A CPU interrupt request from the KBI module loads the program counter with the contents of $FFDE and $FFDF. • Timer 1 interface module (TIM1) interrupt — A CPU interrupt request from the TIM1 loads the program counter with the contents of: – $FFF2 and $FFF3; TIM1 overflow – $FFF4 and $FFF5; TIM1 channel 1 – $FFF6 and $FFF7; TIM1 channel 0 • Timer 2 interface module (TIM2) interrupt — A CPU interrupt request from the TIM2 loads the program counter with the contents of: MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low Power Modes 57 Low Power Modes – $FFEC and $FFED; TIM2 overflow – $FFF0 and $FFF1; TIM2 channel 0 • Serial peripheral interface module (SPI) interrupt — A CPU interrupt request from the SPI loads the program counter with the contents of: – $FFE8 and $FFE9; SPI transmitter – $FFEA and $FFEB; SPI receiver • Serial communications interface module (SCI) interrupt — A CPU interrupt request from the SCI loads the program counter with the contents of: – $FFE2 and $FFE3; SCI transmitter – $FFE4 and $FFE5; SCI receiver – $FFE6 and $FFE7; SCI receiver error • Analog-to-digital converter module (ADC) interrupt — A CPU interrupt request from the ADC loads the program counter with the contents of: $FFDE and $FFDF; ADC conversion complete. • Timebase module (TBM) interrupt — A CPU interrupt request from the TBM loads the program counter with the contents of: $FFDC and $FFDD; TBM interrupt. 3.16 Exiting Stop Mode These events restart the system clocks and load the program counter with the reset vector or with an interrupt vector: • External reset — A logic 0 on the RST pin resets the MCU and loads the program counter with the contents of locations $FFFE and $FFFF. • External interrupt — A high-to-low transition on an external interrupt pin loads the program counter with the contents of locations: – $FFFA and $FFFB; IRQ pin – $FFDE and $FFDF; keyboard interrupt pins Technical Data 58 MC68HC908GR8 — Rev 4.0 Low Power Modes MOTOROLA Low Power Modes • Low-voltage inhibit (LVI) reset — A power supply voltage below the LVItripf voltage resets the MCU and loads the program counter with the contents of locations $FFFE and $FFFF. • Break interrupt — A break interrupt loads the program counter with the contents of locations $FFFC and $FFFD. • Timebase module (TBM) interrupt — A TBM interrupt loads the program counter with the contents of locations $FFDC and $FFDD when the timebase counter has rolled over. This allows the TBM to generate a periodic wakeup from stop mode. Upon exit from stop mode, the system clocks begin running after an oscillator stabilization delay. A 12-bit stop recovery counter inhibits the system clocks for 4096 CGMXCLK cycles after the reset or external interrupt. The short stop recovery bit, SSREC, in the configuration register controls the oscillator stabilization delay during stop recovery. Setting SSREC reduces stop recovery time from 4096 CGMXCLK cycles to 32 CGMXCLK cycles. NOTE: Use the full stop recovery time (SSREC = 0) in applications that use an external crystal. Technical Data 59 MC68HC908GR8 — Rev 4.0 Low Power Modes MOTOROLA Low Power Modes Technical Data 60 MC68HC908GR8 — Rev 4.0 Low Power Modes MOTOROLA Technical Data — MC68HC908GR8 Section 4. Resets and Interrupts 4.1 Contents 4.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 61 4.3 Resets. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .61 4.4 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 66 4.2 Introduction Resets and interrupts are responses to exceptional events during program execution. A reset re-initializes the MCU to its startup condition. An interrupt vectors the program counter to a service routine. 4.3 Resets A reset immediately returns the MCU to a known startup condition and begins program execution from a user-defined memory location. 4.3.1 Effects A reset: • Immediately stops the operation of the instruction being executed • Initializes certain control and status bits • Loads the program counter with a user-defined reset vector address from locations $FFFE and $FFFF • Selects CGMXCLK divided by four as the bus clock MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 61 Resets and Interrupts 4.3.2 External Reset A logic 0 applied to the RST pin for a time, tIRL, generates an external reset. An external reset sets the PIN bit in the SIM reset status register. 4.3.3 Internal Reset Sources: • Power-on reset (POR) • Computer operating properly (COP) • Low-power reset circuits • Illegal opcode • Illegal address All internal reset sources pull the RST pin low for 32 CGMXCLK cycles to allow resetting of external devices. The MCU is held in reset for an additional 32 CGMXCLK cycles after releasing the RST pin. PULLED LOW BY MCU RST PIN 32 CYCLES 32 CYCLES CGMXCLK INTERNAL RESET Figure 4-1. Internal Reset Timing 4.3.3.1 Power-On Reset A power-on reset is an internal reset caused by a positive transition on the VDD pin. VDD at the POR must go completely to 0 V to reset the MCU. This distinguishes between a reset and a POR. The POR is not a brownout detector, low-voltage detector, or glitch detector. Technical Data 62 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Resets A power-on reset: • Holds the clocks to the CPU and modules inactive for an oscillator stabilization delay of 4096 CGMXCLK cycles • Drives the RST pin low during the oscillator stabilization delay • Releases the RST pin 32 CGMXCLK cycles after the oscillator stabilization delay • Releases the CPU to begin the reset vector sequence 64 CGMXCLK cycles after the oscillator stabilization delay • Sets the POR bit in the SIM reset status register and clears all other bits in the register OSC1 PORRST(1) 4096 CYCLES 32 CYCLES 32 CYCLES CGMXCLK CGMOUT RST PIN INTERNAL RESET 1. PORRST is an internally generated power-on reset pulse. Figure 4-2. Power-On Reset Recovery 4.3.3.2 COP Reset A COP reset is an internal reset caused by an overflow of the COP counter. A COP reset sets the COP bit in the system integration module (SIM) reset status register. To clear the COP counter and prevent a COP reset, write any value to the COP control register at location $FFFF. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 63 Resets and Interrupts 4.3.3.3 Low-Voltage Inhibit Reset A low-voltage inhibit (LVI) reset is an internal reset caused by a drop in the power supply voltage to the LVI trip voltage, VTRIPF. An LVI reset: • Holds the clocks to the CPU and modules inactive for an oscillator stabilization delay of 4096 CGMXCLK cycles after the power supply voltage rises to VTRIPF • Drives the RST pin low for as long as VDD is below VTRIPF and during the oscillator stabilization delay • Releases the RST pin 32 CGMXCLK cycles after the oscillator stabilization delay • Releases the CPU to begin the reset vector sequence 64 CGMXCLK cycles after the oscillator stabilization delay • Sets the LVI bit in the SIM reset status register 4.3.3.4 Illegal Opcode Reset An illegal opcode reset is an internal reset caused by an opcode that is not in the instruction set. An illegal opcode reset sets the ILOP bit in the SIM reset status register. If the stop enable bit, STOP, in the mask option register is a logic 0, the STOP instruction causes an illegal opcode reset. 4.3.3.5 Illegal Address Reset An illegal address reset is an internal reset caused by opcode fetch from an unmapped address. An illegal address reset sets the ILAD bit in the SIM reset status register. A data fetch from an unmapped address does not generate a reset. Technical Data 64 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Resets 4.3.4 SIM Reset Status Register This read-only register contains flags to show reset sources. All flag bits are automatically cleared following a read of the register. Reset service can read the SIM reset status register to clear the register after poweron reset and to determine the source of any subsequent reset. The register is initialized on powerup as shown with the POR bit set and all other bits cleared. During a POR or any other internal reset, the RST pin is pulled low. After the pin is released, it will be sampled 32 XCLK cycles later. If the pin is not above a VIH at that time, then the PIN bit in the SRSR may be set in addition to whatever other bits are set. NOTE: Only a read of the SIM reset status register clears all reset flags. After multiple resets from different sources without reading the register, multiple flags remain set. Address: Read: $FE01 Bit 7 6 5 4 3 2 1 Bit 0 POR PIN COP ILOP ILAD 0 LVI 0 1 0 0 0 0 0 0 0 Write: POR: = Unimplemented Figure 4-3. SIM Reset Status Register (SRSR) POR — Power-On Reset Flag 1 = Power-on reset since last read of SRSR 0 = Read of SRSR since last power-on reset PIN — External Reset Flag 1 = External reset via RST pin since last read of SRSR 0 = POR or read of SRSR since last external reset COP — Computer Operating Properly Reset Bit 1 = Last reset caused by timeout of COP counter 0 = POR or read of SRSR MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 65 Resets and Interrupts ILOP — Illegal Opcode Reset Bit 1 = Last reset caused by an illegal opcode 0 = POR or read of SRSR ILAD — Illegal Address Reset Bit 1 = Last reset caused by an opcode fetch from an illegal address 0 = POR or read of SRSR LVI — Low-Voltage Inhibit Reset Bit 1 = Last reset caused by low-power supply voltage 0 = POR or read of SRSR 4.4 Interrupts An interrupt temporarily changes the sequence of program execution to respond to a particular event. An interrupt does not stop the operation of the instruction being executed, but begins when the current instruction completes its operation. 4.4.1 Effects An interrupt: • Saves the CPU registers on the stack. At the end of the interrupt, the RTI instruction recovers the CPU registers from the stack so that normal processing can resume. • Sets the interrupt mask (I bit) to prevent additional interrupts. Once an interrupt is latched, no other interrupt can take precedence, regardless of its priority. • Loads the program counter with a user-defined vector address Technical Data 66 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Interrupts • • • 5 CONDITION CODE REGISTER 1 4 ACCUMULATOR 2 INDEX REGISTER (LOW BYTE)* STACKING 3 ORDER 2 PROGRAM COUNTER (HIGH BYTE) 3 UNSTACKING ORDER 4 1 PROGRAM COUNTER (LOW BYTE) 5 • • • $00FF DEFAULT ADDRESS ON RESET *High byte of index register is not stacked. Figure 4-4. Interrupt Stacking Order After every instruction, the CPU checks all pending interrupts if the I bit is not set. If more than one interrupt is pending when an instruction is done, the highest priority interrupt is serviced first. In the example shown in Figure 4-5, if an interrupt is pending upon exit from the interrupt service routine, the pending interrupt is serviced before the LDA instruction is executed. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 67 Resets and Interrupts CLI BACKGROUND ROUTINE LDA #$FF INT1 PSHH INT1 INTERRUPT SERVICE ROUTINE PULH RTI INT2 PSHH INT2 INTERRUPT SERVICE ROUTINE PULH RTI Figure 4-5. Interrupt Recognition Example The LDA opcode is prefetched by both the INT1 and INT2 RTI instructions. However, in the case of the INT1 RTI prefetch, this is a redundant operation. NOTE: To maintain compatibility with the M6805 Family, the H register is not pushed on the stack during interrupt entry. If the interrupt service routine modifies the H register or uses the indexed addressing mode, save the H register and then restore it prior to exiting the routine. Technical Data 68 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Interrupts FROM RESET BREAK INTERRUPT ? NO YES YES BIT SET? SET? II BIT NO IRQ INTERRUPT ? YES NO CGM INTERRUPT ? NO YES OTHER INTERRUPTS ? YES NO STACK CPU REGISTERS SET I BIT LOAD PC WITH INTERRUPT VECTOR FETCH NEXT INSTRUCTION SWI YES INSTRUCTION ? NO RTI YES INSTRUCTION ? UNSTACK CPU REGISTERS NO EXECUTE INSTRUCTION Figure 4-6. Interrupt Processing MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 69 Resets and Interrupts 4.4.2 Sources The sources in Table 4-1 can generate CPU interrupt requests. Table 4-1. Interrupt Sources Flag Mask(1) INT Register Flag Priority(2) Vector Address Reset None None None 0 $FFFE–$FFFF SWI instruction None None None 0 $FFFC–$FFFD IRQ pin IRQF IMASK1 IF1 1 $FFFA–$FFFB CGM (PLL) PLLF PLLIE IF2 2 $FFF8–$FFF9 TIM1 channel 0 CH0F CH0IE IF3 3 $FFF6–$FFF7 TIM1 channel 1 CH1F CH1IE IF4 4 $FFF4–$FFF5 TOF TOIE IF5 5 $FFF2–$FFF3 CH0F CH0IE IF6 6 $FFF0–$FFF1 TOF TOIE IF8 8 $FFEC–$FFED SPI receiver full SPRF SPRIE SPI overflow OVRF ERRIE IF9 9 $FFEA–$FFEB SPI mode fault MODF ERRIE SPI transmitter empty SPTE SPTIE IF10 10 $FFE8–$FFE9 SCI receiver overrun OR ORIE SCI noise fag NF NEIE SCI framing error FE FEIE IF11 11 $FFE6–$FFE7 SCI parity error PE PEIE SCI receiver full SCRF SCRIE SCI input idle IDLE ILIE IF12 12 $FFE4–$FFE5 SCI transmitter empty SCTE SCTIE TC TCIE IF13 13 $FFE2–$FFE3 Keyboard pin KEYF IMASKK IF14 14 $FFDE–$FFDF ADC conversion complete COCO AIEN IF15 15 $FFDE–$FFDF TBIF TBIE IF16 16 $FFDC–$FFDD Source TIM1 overflow TIM2 channel 0 TIM2 overflow SCI transmission complete Timebase Note: 1. The I bit in the condition code register is a global mask for all interrupt sources except the SWI instruction. 2. 0 = highest priority Technical Data 70 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Interrupts 4.4.2.1 SWI Instruction The software interrupt instruction (SWI) causes a non-maskable interrupt. NOTE: A software interrupt pushes PC onto the stack. An SWI does not push PC – 1, as a hardware interrupt does. 4.4.2.2 Break Interrupt The break module causes the CPU to execute an SWI instruction at a software-programmable break point. 4.4.2.3 IRQ Pin A logic 0 on the IRQ1 pin latches an external interrupt request. 4.4.2.4 CGM The CGM can generate a CPU interrupt request every time the phaselocked loop circuit (PLL) enters or leaves the locked state. When the LOCK bit changes state, the PLL flag (PLLF) is set. The PLL interrupt enable bit (PLLIE) enables PLLF CPU interrupt requests. LOCK is in the PLL bandwidth control register. PLLF is in the PLL control register. 4.4.2.5 TIM1 TIM1 CPU interrupt sources: • TIM1 overflow flag (TOF) — The TOF bit is set when the TIM1 counter value rolls over to $0000 after matching the value in the TIM1 counter modulo registers. The TIM1 overflow interrupt enable bit, TOIE, enables TIM1 overflow CPU interrupt requests. TOF and TOIE are in the TIM1 status and control register. • TIM1 channel flags (CH1F–CH0F) — The CHxF bit is set when an input capture or output compare occurs on channel x. The channel x interrupt enable bit, CHxIE, enables channel x TIM1 CPU interrupt requests. CHxF and CHxIE are in the TIM1 channel x status and control register. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 71 Resets and Interrupts 4.4.2.6 TIM2 TIM2 CPU interrupt sources: • TIM2 overflow flag (TOF) — The TOF bit is set when the TIM2 counter value rolls over to $0000 after matching the value in the TIM2 counter modulo registers. The TIM2 overflow interrupt enable bit, TOIE, enables TIM2 overflow CPU interrupt requests. TOF and TOIE are in the TIM2 status and control register. • TIM2 channel flag (CH0F) — The CH0F bit is set when an input capture or output compare occurs on channel 0. The channel 0 interrupt enable bit, CH0IE, enables channel 0 TIM2 CPU interrupt requests. CH0F and CH0IE are in the TIM2 channel 0 status and control register. 4.4.2.7 SPI SPI CPU interrupt sources: • SPI receiver full bit (SPRF) — The SPRF bit is set every time a byte transfers from the shift register to the receive data register. The SPI receiver interrupt enable bit, SPRIE, enables SPRF CPU interrupt requests. SPRF is in the SPI status and control register and SPRIE is in the SPI control register. • SPI transmitter empty (SPTE) — The SPTE bit is set every time a byte transfers from the transmit data register to the shift register. The SPI transmit interrupt enable bit, SPTIE, enables SPTE CPU interrupt requests. SPTE is in the SPI status and control register and SPTIE is in the SPI control register. • Mode fault bit (MODF) — The MODF bit is set in a slave SPI if the SS pin goes high during a transmission with the mode fault enable bit (MODFEN) set. In a master SPI, the MODF bit is set if the SS pin goes low at any time with the MODFEN bit set. The error interrupt enable bit, ERRIE, enables MODF CPU interrupt requests. MODF, MODFEN, and ERRIE are in the SPI status and control register. Technical Data 72 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Interrupts • Overflow bit (OVRF) — The OVRF bit is set if software does not read the byte in the receive data register before the next full byte enters the shift register. The error interrupt enable bit, ERRIE, enables OVRF CPU interrupt requests. OVRF and ERRIE are in the SPI status and control register. 4.4.2.8 SCI SCI CPU interrupt sources: • SCI transmitter empty bit (SCTE) — SCTE is set when the SCI data register transfers a character to the transmit shift register. The SCI transmit interrupt enable bit, SCTIE, enables transmitter CPU interrupt requests. SCTE is in SCI status register 1. SCTIE is in SCI control register 2. • Transmission complete bit (TC) — TC is set when the transmit shift register and the SCI data register are empty and no break or idle character has been generated. The transmission complete interrupt enable bit, TCIE, enables transmitter CPU interrupt requests. TC is in SCI status register 1. TCIE is in SCI control register 2. • SCI receiver full bit (SCRF) — SCRF is set when the receive shift register transfers a character to the SCI data register. The SCI receive interrupt enable bit, SCRIE, enables receiver CPU interrupts. SCRF is in SCI status register 1. SCRIE is in SCI control register 2. • Idle input bit (IDLE) — IDLE is set when 10 or 11 consecutive logic 1s shift in from the RxD pin. The idle line interrupt enable bit, ILIE, enables IDLE CPU interrupt requests. IDLE is in SCI status register 1. ILIE is in SCI control register 2. • Receiver overrun bit (OR) — OR is set when the receive shift register shifts in a new character before the previous character was read from the SCI data register. The overrun interrupt enable bit, ORIE, enables OR to generate SCI error CPU interrupt requests. OR is in SCI status register 1. ORIE is in SCI control register 3. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 73 Resets and Interrupts • Noise flag (NF) — NF is set when the SCI detects noise on incoming data or break characters, including start, data, and stop bits. The noise error interrupt enable bit, NEIE, enables NF to generate SCI error CPU interrupt requests. NF is in SCI status register 1. NEIE is in SCI control register 3. • Framing error bit (FE) — FE is set when a logic 0 occurs where the receiver expects a stop bit. The framing error interrupt enable bit, FEIE, enables FE to generate SCI error CPU interrupt requests. FE is in SCI status register 1. FEIE is in SCI control register 3. • Parity error bit (PE) — PE is set when the SCI detects a parity error in incoming data. The parity error interrupt enable bit, PEIE, enables PE to generate SCI error CPU interrupt requests. PE is in SCI status register 1. PEIE is in SCI control register 3. 4.4.2.9 KBD0–KBD4 Pins A logic 0 on a keyboard interrupt pin latches an external interrupt request. 4.4.2.10 ADC (Analog-to-Digital Converter) When the AIEN bit is set, the ADC module is capable of generating a CPU interrupt after each ADC conversion. The COCO/IDMAS bit is not used as a conversion complete flag when interrupts are enabled. 4.4.2.11 TBM (Timebase Module) The timebase module can interrupt the CPU on a regular basis with a rate defined by TBR2–TBR0. When the timebase counter chain rolls over, the TBIF flag is set. If the TBIE bit is set, enabling the timebase interrupt, the counter chain overflow will generate a CPU interrupt request. Interrupts must be acknowledged by writing a logic 1 to the TACK bit. Technical Data 74 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Interrupts 4.4.3 Interrupt Status Registers The flags in the interrupt status registers identify maskable interrupt sources. Table 4-2 summarizes the interrupt sources and the interrupt status register flags that they set. The interrupt status registers can be useful for debugging. Table 4-2. Interrupt Source Flags Interrupt Source Reset — SWI instruction — IRQ pin IF1 CGM (PLL) IF2 TIM1 channel 0 IF3 TIM1 channel 1 IF4 TIM1 overflow IF5 TIM2 channel 0 IF6 Reserved IF7 TIM2 overflow IF8 SPI receive IF9 SPI transmit IF10 SCI error IF11 SCI receive IF12 SCI transmit IF13 Keyboard IF14 ADC conversion complete IF15 Timebase IF16 MC68HC908GR8 — Rev 4.0 MOTOROLA Interrupt Status Register Flag Technical Data Resets and Interrupts 75 Resets and Interrupts 4.4.3.1 Interrupt Status Register 1 Address: $FE04 Bit 7 6 5 4 3 2 1 Bit 0 Read: IF6 IF5 IF4 IF3 IF2 IF1 0 0 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved Figure 4-7. Interrupt Status Register 1 (INT1) IF6–IF1 — Interrupt Flags 6–1 These flags indicate the presence of interrupt requests from the sources shown in Table 4-2. 1 = Interrupt request present 0 = No interrupt request present Bit 1 and Bit 0 — Always read 0 4.4.3.2 Interrupt Status Register 2 Address: $FE05 Bit 7 6 5 4 3 2 1 Bit 0 Read: IF14 IF13 IF12 IF11 IF10 IF9 IF8 IF7 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved Figure 4-8. Interrupt Status Register 2 (INT2) IF14–IF7 — Interrupt Flags 14–7 These flags indicate the presence of interrupt requests from the sources shown in Table 4-2. 1 = Interrupt request present 0 = No interrupt request present Technical Data 76 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Resets and Interrupts Interrupts 4.4.3.3 Interrupt Status Register 3 Address: $FE06 Bit 7 6 5 4 3 2 1 Bit 0 Read: 0 0 0 0 0 0 IF16 IF15 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved Figure 4-9. Interrupt Status Register 3 (INT3) IF16–IF15 — Interrupt Flags 16–15 This flag indicates the presence of an interrupt request from the source shown in Table 4-2. 1 = Interrupt request present 0 = No interrupt request present Bits 7–2 — Always read 0 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Resets and Interrupts 77 Resets and Interrupts Technical Data 78 MC68HC908GR8 — Rev 4.0 Resets and Interrupts MOTOROLA Technical Data — MC68HC908GR8 Section 5. Analog-to-Digital Converter (ADC) 5.1 Contents 5.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 79 5.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 5.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80 5.5 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 5.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .83 5.7 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 83 5.8 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 5.2 Introduction This section describes the 8-bit analog-to-digital converter (ADC). For further information regarding analog-to-digital converters on Motorola microcontrollers, please consult the HC08 ADC Reference Manual, ADCRM/AD. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter (ADC) 79 Analog-to-Digital Converter (ADC) 5.3 Features Features of the ADC module include: • Six channels with multiplexed input • Linear successive approximation with monotonicity • 8-bit resolution • Single or continuous conversion • Conversion complete flag or conversion complete interrupt • Selectable ADC clock 5.4 Functional Description The ADC provides six pins for sampling external sources at pins PTB5/ATD5–PTB0/ATD0. An analog multiplexer allows the single ADC converter to select one of six ADC channels as ADC voltage in (VADIN). VADIN is converted by the successive approximation register-based analog-to-digital converter. When the conversion is completed, ADC places the result in the ADC data register and sets a flag or generates an interrupt. See Figure 5-1. NOTE: References to DMA (direct-memory access) and associated functions are only valid if the MCU has a DMA module. If the MCU has no DMA, any DMA-related register bits should be left in their reset state for expected MCU operation. Technical Data 80 MC68HC908GR8 — Rev 4.0 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) Functional Description INTERNAL DATA BUS READ DDRBx WRITE DDRBx DISABLE DDRBx RESET WRITE PTBx PTBx PTBx ADC CHANNEL x READ PTBx ADC DATA REGISTER CONVERSION INTERRUPT COMPLETE LOGIC AIEN ADC DISABLE ADC VOLTAGE IN ADCH4–ADCH0 (VADIN) CHANNEL SELECT ADC CLOCK COCO CGMXCLK BUS CLOCK CLOCK GENERATOR ADIV2–ADIV0 ADICLK Figure 5-1. ADC Block Diagram 5.4.1 ADC Port I/O Pins PTB5/ATD5–PTB0/ATD0 are general-purpose I/O (input/output) pins that share with the ADC channels. The channel select bits define which ADC channel/port pin will be used as the input signal. The ADC overrides the port I/O logic by forcing that pin as input to the ADC. The remaining ADC channels/port pins are controlled by the port I/O logic and can be used as general-purpose I/O. Writes to the port register or DDR will not have any affect on the port pin that is selected by the ADC. Read of a port pin in use by the ADC will return a logic 0. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter (ADC) 81 Analog-to-Digital Converter (ADC) 5.4.2 Voltage Conversion When the input voltage to the ADC equals VREFH, the ADC converts the signal to $FF (full scale). If the input voltage equals VREFL, the ADC converts it to $00. Input voltages between VREFH and VREFL are a straight-line linear conversion. All other input voltages will result in $FF, if greater than VREFH. NOTE: Inside the ADC module, the reference voltage, VREFH is connected to the ADC analog power VDDAD; and VREFL is connected to the ADC analog ground VDDAD. Therefore, the ADC input voltage should not exceed the analog supply voltages For operation, VDDAD should be tied to the same potential as VDD via separate traces 5.4.3 Conversion Time Conversion starts after a write to the ADSCR. One conversion will take between 16 and 17 ADC clock cycles. The ADIVx and ADICLK bits should be set to provide a 1 MHz ADC clock frequency. Conversion time = 16 to17 ADC cycles ADC frequency Number of bus cycles = conversion time x bus frequency 5.4.4 Conversion In continuous conversion mode, the ADC data register will be filled with new data after each conversion. Data from the previous conversion will be overwritten whether that data has been read or not. Conversions will continue until the ADCO bit is cleared. The COCO/IDMAS bit is set after the first conversion and will stay set until the next write of the ADC status and control register or the next read of the ADC data register. In single conversion mode, conversion begins with a write to the ADSCR. Only one conversion occurs between writes to the ADSCR. Technical Data 82 MC68HC908GR8 — Rev 4.0 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) Interrupts 5.4.5 Accuracy and Precision The conversion process is monotonic and has no missing codes. 5.5 Interrupts When the AIEN bit is set, the ADC module is capable of generating CPU interrupts after each ADC conversion. A CPU interrupt is generated if the COCO/IDMAS bit is at logic 0. If COCO/IDMAS bit is set, a DMA interrupt is generated. The COCO/IDMAS bit is not used as a conversion complete flag when interrupts are enabled. 5.6 Low-Power Modes The WAIT and STOP instruction can put the MCU in low powerconsumption standby modes. 5.6.1 Wait Mode The ADC continues normal operation during wait mode. Any enabled CPU interrupt request from the ADC can bring the MCU out of wait mode. If the ADC is not required to bring the MCU out of wait mode, power down the ADC by setting ADCH4–ADCH0 bits in the ADC status and control register before executing the WAIT instruction. 5.6.2 Stop Mode The ADC module is inactive after the execution of a STOP instruction. Any pending conversion is aborted. ADC conversions resume when the MCU exits stop mode after an external interrupt. Allow one conversion cycle to stabilize the analog circuitry. 5.7 I/O Signals The ADC module has six pins shared with port B, PTB5/AD5–PTB0/ATD0. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter (ADC) 83 Analog-to-Digital Converter (ADC) 5.7.1 ADC Analog Power Pin (VDDAD)/ADC Voltage Reference High Pin (VREFH) The ADC analog portion uses VDDAD as its power pin. Connect the VDDAD pin to the same voltage potential as VDD. External filtering may be necessary to ensure clean VDDAD for good results. NOTE: For maximum noise immunity, route VDDAD carefully and place bypass capacitors as close as possible to the package. 5.7.2 ADC Analog Ground Pin (VSSAD)/ADC Voltage Reference Low Pin (VREFL) The ADC analog portion uses VSSAD as its ground pin. Connect the VSSAD pin to the same voltage potential as VSS. NOTE: Route VSSAD cleanly to avoid any offset errors. 5.7.3 ADC Voltage In (VADIN) VADIN is the input voltage signal from one of the six ADC channels to the ADC module. Technical Data 84 MC68HC908GR8 — Rev 4.0 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) I/O Registers 5.8 I/O Registers These I/O registers control and monitor ADC operation: • ADC status and control register (ADSCR) • ADC data register (ADR) • ADC clock register (ADCLK) 5.8.1 ADC Status and Control Register Function of the ADC status and control register (ADSCR) is described here. Address: $0003C Bit 7 6 5 4 3 2 1 Bit 0 AIEN ADCO ADCH4 ADCH3 ADCH2 ADCH1 ADCH0 Write: COCO/ IDMAS Reset: 0 0 0 1 1 1 1 1 Read: Figure 5-2. ADC Status and Control Register (ADSCR) COCO/IDMAS — Conversions Complete/Interrupt DMA Select Bit When the AIEN bit is a logic 0, the COCO/IDMAS is a read-only bit which is set each time a conversion is completed except in the continuous conversion mode where it is set after the first conversion. This bit is cleared whenever the ADSCR is written or whenever the ADR is read. If the AIEN bit is a logic 1, the COCO/IDMAS is a read/write bit which selects either CPU or DMA to service the ADC interrupt request. Reset clears this bit. 1 = Conversion completed (AIEN = 0)/DMA interrupt (AIEN = 1) 0 = Conversion not completed (AIEN = 0)/CPU interrupt (AIEN = 1) CAUTION: Because the MC68HC908GR8 does NOT have a DMA module, the IDMAS bit should NEVER be set when AIEN is set. Doing so will mask ADC interrupts and cause unwanted results. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter (ADC) 85 Analog-to-Digital Converter (ADC) AIEN — ADC Interrupt Enable Bit When this bit is set, an interrupt is generated at the end of an ADC conversion. The interrupt signal is cleared when the data register is read or the status/control register is written. Reset clears the AIEN bit. 1 = ADC interrupt enabled 0 = ADC interrupt disabled ADCO — ADC Continuous Conversion Bit When this bit is set, the ADC will convert samples continuously and update the ADR register at the end of each conversion. Only one conversion is completed between writes to the ADSCR when this bit is cleared. Reset clears the ADCO bit. 1 = Continuous ADC conversion 0 = One ADC conversion ADCH4–ADCH0 — ADC Channel Select Bits ADCH4–ADCH0 form a 5-bit field which is used to select one of 16 ADC channels. Only six channels, AD5–AD0, are available on this MCU. The channels are detailed in Table 5-1. Care should be taken when using a port pin as both an analog and digital input simultaneously to prevent switching noise from corrupting the analog signal. See Table 5-1. The ADC subsystem is turned off when the channel select bits are all set to 1. This feature allows for reduced power consumption for the MCU when the ADC is not being used. NOTE: Recovery from the disabled state requires one conversion cycle to stabilize. The voltage levels supplied from internal reference nodes, as specified in Table 5-1, are used to verify the operation of the ADC converter both in production test and for user applications. Table 5-1. Mux Channel Select ADCH4 ADCH3 ADCH2 ADCH1 ADCH0 Input Select 0 0 0 0 0 PTB0/ATD0 0 0 0 0 1 PTB1/ATD1 0 0 0 1 0 PTB2/ATD2 Technical Data 86 MC68HC908GR8 — Rev 4.0 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) I/O Registers Table 5-1. Mux Channel Select ADCH4 ADCH3 ADCH2 ADCH1 ADCH0 Input Select 0 0 0 1 1 PTB3/ATD3 0 0 1 0 0 PTB4/ATD4 0 0 1 0 1 PTB5/ATD5 0 0 1 1 0 Reserved 0 0 1 1 1 Reserved ↓ ↓ ↓ ↓ ↓ Reserved 1 1 0 1 1 Reserved 1 1 1 0 0 Reserved 1 1 1 0 1 VREFH 1 1 1 1 0 VREFL 1 1 1 1 1 ADC power off NOTE: If an unknown channel is selected it should be made clear what value the user will read from the ADC Data Register, unknown or reserved is not specific enough. 5.8.2 ADC Data Register One 8-bit result register, ADC data register (ADR), is provided. This register is updated each time an ADC conversion completes. Address: Read: $0003D Bit 7 6 5 4 3 2 1 Bit 0 AD7 AD6 AD5 AD4 AD3 AD2 AD1 AD0 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 5-3. ADC Data Register (ADR) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter (ADC) 87 Analog-to-Digital Converter (ADC) 5.8.3 ADC Clock Register The ADC clock register (ADCLK) selects the clock frequency for the ADC. Address: $0003E Bit 7 6 5 4 ADIV2 ADIV1 ADIV0 ADICLK 0 0 0 0 Read: 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 5-4. ADC Clock Register (ADCLK) ADIV2–ADIV0 — ADC Clock Prescaler Bits ADIV2–ADIV0 form a 3-bit field which selects the divide ratio used by the ADC to generate the internal ADC clock. Table 5-2 shows the available clock configurations. The ADC clock should be set to approximately 1 MHz. Table 5-2. ADC Clock Divide Ratio ADIV2 ADIV1 ADIV0 ADC Clock Rate 0 0 0 ADC input clock ÷ 1 0 0 1 ADC input clock ÷ 2 0 1 0 ADC input clock ÷ 4 0 1 1 ADC input clock ÷ 8 1 X X ADC input clock ÷ 16 X = don’t care ADICLK — ADC Input Clock Select Bit ADICLK selects either the bus clock or CGMXCLK as the input clock source to generate the internal ADC clock. Reset selects CGMXCLK as the ADC clock source. Technical Data 88 MC68HC908GR8 — Rev 4.0 Analog-to-Digital Converter (ADC) MOTOROLA Analog-to-Digital Converter (ADC) I/O Registers If the external clock (CGMXCLK) is equal to or greater than 1 MHz, CGMXCLK can be used as the clock source for the ADC. If CGMXCLK is less than 1 MHz, use the PLL-generated bus clock as the clock source. As long as the internal ADC clock is at approximately 1 MHz, correct operation can be guaranteed. 1 = Internal bus clock 0 = External clock (CGMXCLK) ADC input clock frequency ----------------------------------------------------------------------- = 1MHz ADIV2 –ADIV0 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Analog-to-Digital Converter (ADC) 89 Analog-to-Digital Converter (ADC) Technical Data 90 MC68HC908GR8 — Rev 4.0 Analog-to-Digital Converter (ADC) MOTOROLA Technical Data — MC68HC908GR8 Section 6. Break Module (BRK) 6.1 Contents 6.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 6.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 91 6.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 92 6.5 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .94 6.6 Break Module Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .94 6.2 Introduction This section describes the break module. The break module can generate a break interrupt that stops normal program flow at a defined address to enter a background program. 6.3 Features Features of the break module include: • Accessible input/output (I/O) registers during the break interrupt • CPU-generated break interrupts • Software-generated break interrupts • COP disabling during break interrupts MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Break Module (BRK) 91 Break Module (BRK) 6.4 Functional Description When the internal address bus matches the value written in the break address registers, the break module issues a breakpoint signal to the CPU. The CPU then loads the instruction register with a software interrupt instruction (SWI) after completion of the current CPU instruction. The program counter vectors to $FFFC and $FFFD ($FEFC and $FEFD in monitor mode). The following events can cause a break interrupt to occur: • A CPU-generated address (the address in the program counter) matches the contents of the break address registers. • Software writes a logic 1 to the BRKA bit in the break status and control register. When a CPU-generated address matches the contents of the break address registers, the break interrupt begins after the CPU completes its current instruction. A return-from-interrupt instruction (RTI) in the break routine ends the break interrupt and returns the MCU to normal operation. Figure 6-1 shows the structure of the break module. IAB15–IAB8 BREAK ADDRESS REGISTER HIGH 8-BIT COMPARATOR IAB15–IAB0 CONTROL BREAK 8-BIT COMPARATOR BREAK ADDRESS REGISTER LOW IAB7–IAB0 Figure 6-1. Break Module Block Diagram Technical Data 92 MC68HC908GR8 — Rev 4.0 Break Module (BRK) MOTOROLA Break Module (BRK) Functional Description Addr. Register Name Bit 7 6 5 4 3 2 1 Bit 0 Read: SIM Break Status Register $FE00 Write: (SBSR) Reset: 0 0 0 1 0 0 BW 0 R R R R R R NOTE R 0 0 0 1 0 0 0 0 BCFE R R R R R R R Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 BRKE BRKA 0 0 0 0 0 0 0 0 0 0 0 0 0 0 R = Reserved $FE03 $FE09 $FE0A Read: SIM Break Flag Control Write: Register (SBFCR) Reset: Read: Break Address Register Write: High (BRKH) Reset: Read: Break Address Register Write: Low (BRKL) Reset: Read: Break Status and Control $FE0B Write: Register (BRKSCR) Reset: 0 Note: Writing a logic 0 clears BW. = Unimplemented Figure 6-2. I/O Register Summary 6.4.1 Flag Protection During Break Interrupts The BCFE bit in the SIM break flag control register (SBFCR) enables software to clear status bits during the break state. 6.4.2 CPU During Break Interrupts The CPU starts a break interrupt by: • Loading the instruction register with the SWI instruction • Loading the program counter with $FFFC and $FFFD ($FEFC and $FEFD in monitor mode) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Break Module (BRK) 93 Break Module (BRK) The break interrupt begins after completion of the CPU instruction in progress. If the break address register match occurs on the last cycle of a CPU instruction, the break interrupt begins immediately. 6.4.3 TIMI and TIM2 During Break Interrupts A break interrupt stops the timer counters. 6.4.4 COP During Break Interrupts The COP is disabled during a break interrupt when VTST is present on the RST pin. 6.5 Low-Power Modes The WAIT and STOP instructions put the MCU in low powerconsumption standby modes. 6.5.1 Wait Mode If enabled, the break module is active in wait mode. In the break routine, the user can subtract one from the return address on the stack if SBSW is set. See Low Power Modes. Clear the BW bit by writing logic 0 to it. 6.5.2 Stop Mode A break interrupt causes exit from stop mode and sets the SBSW bit in the break status register. 6.6 Break Module Registers These registers control and monitor operation of the break module: • Break status and control register (BRKSCR) • Break address register high (BRKH) Technical Data 94 MC68HC908GR8 — Rev 4.0 Break Module (BRK) MOTOROLA Break Module (BRK) Break Module Registers • Break address register low (BRKL) • SIM break status register (SBSR) • SIM break flag control register (SBFCR) 6.6.1 Break Status and Control Register The break status and control register (BRKSCR) contains break module enable and status bits. Address: $FE0E Bit 7 6 BRKE BRKA 0 0 Read: 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 6-3. Break Status and Control Register (BRKSCR) BRKE — Break Enable Bit This read/write bit enables breaks on break address register matches. Clear BRKE by writing a logic 0 to bit 7. Reset clears the BRKE bit. 1 = Breaks enabled on 16-bit address match 0 = Breaks disabled on 16-bit address match BRKA — Break Active Bit This read/write status and control bit is set when a break address match occurs. Writing a logic 1 to BRKA generates a break interrupt. Clear BRKA by writing a logic 0 to it before exiting the break routine. Reset clears the BRKA bit. 1 = (When read) Break address match 0 = (When read) No break address match MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Break Module (BRK) 95 Break Module (BRK) 6.6.2 Break Address Registers The break address registers (BRKH and BRKL) contain the high and low bytes of the desired breakpoint address. Reset clears the break address registers. Address: $FE09 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 Read: Write: Reset: Figure 6-4. Break Address Register High (BRKH) Address: $FE0A Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Read: Write: Reset: Figure 6-5. Break Address Register Low (BRKL) 6.6.3 Break Status Register The break status register (SBSR) contains a flag to indicate that a break caused an exit from wait mode. The flag is useful in applications requiring a return to wait mode after exiting from a break interrupt. Address: $FE00 Bit 7 6 5 4 3 2 1 Bit 0 Read: 0 0 0 1 0 0 BW 0 Write: R R R R R R NOTE R Reset: 0 0 0 1 0 0 0 0 R = Reserved Note: Writing a logic 0 clears BW. Figure 6-6. SIM Break Status Register (SBSR) Technical Data 96 MC68HC908GR8 — Rev 4.0 Break Module (BRK) MOTOROLA Break Module (BRK) Break Module Registers BW — Break Wait Bit This read/write bit is set when a break interrupt causes an exit from wait mode. Clear BW by writing a logic 0 to it. Reset clears BW. 1 = Break interrupt during wait mode 0 = No break interrupt during wait mode BW can be read within the break interrupt routine. The user can modify the return address on the stack by subtracting 1 from it. The following code is an example. This code works if the H register was stacked in the break interrupt routine. Execute this code at the end of the break interrupt routine. HIBYTE EQU 5 LOBYTE EQU 6 ; If not BW, do RTI BRCLR BW,BSR, RETURN ; See if wait mode or stop mode ; was exited by break. TST LOBYTE,SP ; If RETURNLO is not 0, BNE DOLO ; then just decrement low byte. DEC HIBYTE,SP ; Else deal with high byte also. DOLO DEC LOBYTE,SP ; Point to WAIT/STOP opcode. RETURN PULH RTI ; Restore H register. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Break Module (BRK) 97 Break Module (BRK) 6.6.4 Break Flag Control Register The break flag control register (SBFCR) contains a bit that enables software to clear status bits while the MCU is in a break state. Address: $FE03 Bit 7 6 5 4 3 2 1 Bit 0 BCFE R R R R R R R Read: Write: Reset: 0 R = Reserved Figure 6-7. SIM Break Flag Control Register (SBFCR) BCFE — Break Clear Flag Enable Bit This read/write bit enables software to clear status bits by accessing status registers while the MCU is in a break state. To clear status bits during the break state, the BCFE bit must be set. 1 = Status bits clearable during break 0 = Status bits not clearable during break Technical Data 98 MC68HC908GR8 — Rev 4.0 Break Module (BRK) MOTOROLA Technical Data — MC68HC908GR8 Section 7. Clock Generator Module (CGMC) 7.1 Contents 7.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99 7.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 7.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 7.5 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 112 7.6 CGMC Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 114 7.7 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 7.8 Special Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 123 7.9 Acquisition/Lock Time Specifications . . . . . . . . . . . . . . . . . . .125 7.2 Introduction This section describes the clock generator module. The CGMC generates the crystal clock signal, CGMXCLK, which operates at the frequency of the crystal. The CGMC also generates the base clock signal, CGMOUT, which is based on either the crystal clock divided by two or the phase-locked loop (PLL) clock, CGMVCLK, divided by two. In user mode, CGMOUT is the clock from which the SIM derives the system clocks, including the bus clock, which is at a frequency of CGMOUT/2. In monitor mode, PTC3 determines the bus clock. The PLL is a fully functional frequency generator designed for use with crystals or ceramic resonators. The PLL can generate an 8-MHz bus frequency using a 32-kHz crystal. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 99 Clock Generator Module (CGMC) 7.3 Features Features of the CGMC include: • Phase-locked loop with output frequency in integer multiples of an integer dividend of the crystal reference • Low-frequency crystal operation with low-power operation and high-output frequency resolution • Programmable prescaler for power-of-two increases in frequency • Programmable hardware voltage-controlled oscillator (VCO) for low-jitter operation • Automatic bandwidth control mode for low-jitter operation • Automatic frequency lock detector • CPU interrupt on entry or exit from locked condition • Configuration register bit to allow oscillator operation during stop mode 7.4 Functional Description The CGMC consists of three major submodules: • Crystal oscillator circuit — The crystal oscillator circuit generates the constant crystal frequency clock, CGMXCLK. • Phase-locked loop (PLL) — The PLL generates the programmable VCO frequency clock, CGMVCLK. • Base clock selector circuit — This software-controlled circuit selects either CGMXCLK divided by two or the VCO clock, CGMVCLK, divided by two as the base clock, CGMOUT. The SIM derives the system clocks from either CGMOUT or CGMXCLK. Figure 7-1 shows the structure of the CGMC. Technical Data 100 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Functional Description OSCILLATOR (OSC) OSC2 CGMXCLK (TO: SIM, TIMTB15A, ADC) OSC1 SIMOSCEN (FROM SIM) OSCSTOPENB (FROM CONFIG) PHASE-LOCKED LOOP (PLL) CGMRDV REFERENCE DIVIDER CGMRCLK CLOCK SELECT CIRCUIT BCS RDS3–RDS0 VDDA CGMXFC ÷2 CGMOUT (TO SIM) VSSA VPR1–VPR0 VRS7–VRS0 PHASE DETECTOR VOLTAGE CONTROLLED OSCILLATOR LOOP FILTER CGMVCLK PLL ANALOG LOCK DETECTOR LOCK CGMVDV AUTOMATIC MODE CONTROL AUTO ACQ INTERRUPT CONTROL PLLIE MUL11–MUL0 PRE1–PRE0 FREQUENCY DIVIDER FREQUENCY DIVIDER PLLIREQ (TO SIM) PLLF Figure 7-1. CGMC Block Diagram MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 101 Clock Generator Module (CGMC) 7.4.1 Crystal Oscillator Circuit The crystal oscillator circuit consists of an inverting amplifier and an external crystal. The OSC1 pin is the input to the amplifier and the OSC2 pin is the output. The SIMOSCEN signal from the system integration module (SIM) or the OSCSTOPENB bit in the CONFIG register enable the crystal oscillator circuit. The CGMXCLK signal is the output of the crystal oscillator circuit and runs at a rate equal to the crystal frequency. CGMXCLK is then buffered to produce CGMRCLK, the PLL reference clock. CGMXCLK can be used by other modules which require precise timing for operation. The duty cycle of CGMXCLK is not guaranteed to be 50% and depends on external factors, including the crystal and related external components. An externally generated clock also can feed the OSC1 pin of the crystal oscillator circuit. Connect the external clock to the OSC1 pin and let the OSC2 pin float. 7.4.2 Phase-Locked Loop Circuit (PLL) The PLL is a frequency generator that can operate in either acquisition mode or tracking mode, depending on the accuracy of the output frequency. The PLL can change between acquisition and tracking modes either automatically or manually. 7.4.3 PLL Circuits The PLL consists of these circuits: • Voltage-controlled oscillator (VCO) • Reference divider • Frequency prescaler • Modulo VCO frequency divider • Phase detector • Loop filter • Lock detector Technical Data 102 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Functional Description The operating range of the VCO is programmable for a wide range of frequencies and for maximum immunity to external noise, including supply and CGM/XFC noise. The VCO frequency is bound to a range from roughly one-half to twice the center-of-range frequency, fVRS. Modulating the voltage on the CGM/XFC pin changes the frequency within this range. By design, fVRS is equal to the nominal center-of-range frequency, fNOM, (38.4 kHz) times a linear factor, L, and a power-of-two factor, E, or (L × 2E)fNOM. CGMRCLK is the PLL reference clock, a buffered version of CGMXCLK. CGMRCLK runs at a frequency, fRCLK, and is fed to the PLL through a programmable modulo reference divider, which divides fRCLK by a factor, R. The divider’s output is the final reference clock, CGMRDV, running at a frequency, fRDV = fRCLK/R. With an external crystal (30 kHz–100 kHz), always set R = 1 for specified performance. With an external high-frequency clock source, use R to divide the external frequency to between 30 kHz and 100 kHz. The VCO’s output clock, CGMVCLK, running at a frequency, fVCLK, is fed back through a programmable prescale divider and a programmable modulo divider. The prescaler divides the VCO clock by a power-of-two factor P and the modulo divider reduces the VCO clock by a factor, N. The dividers’ output is the VCO feedback clock, CGMVDV, running at a frequency, fVDV = fVCLK/(N × 2P). (See Programming the PLL for more information.) The phase detector then compares the VCO feedback clock, CGMVDV, with the final reference clock, CGMRDV. A correction pulse is generated based on the phase difference between the two signals. The loop filter then slightly alters the DC voltage on the external capacitor connected to CGM/XFC based on the width and direction of the correction pulse. The filter can make fast or slow corrections depending on its mode, described in Acquisition and Tracking Modes. The value of the external capacitor and the reference frequency determine the speed of the corrections and the stability of the PLL. The lock detector compares the frequencies of the VCO feedback clock, CGMVDV, and the final reference clock, CGMRDV. Therefore, the speed of the lock detector is directly proportional to the final reference MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 103 Clock Generator Module (CGMC) frequency, fRDV. The circuit determines the mode of the PLL and the lock condition based on this comparison. 7.4.4 Acquisition and Tracking Modes The PLL filter is manually or automatically configurable into one of two operating modes: • Acquisition mode — In acquisition mode, the filter can make large frequency corrections to the VCO. This mode is used at PLL startup or when the PLL has suffered a severe noise hit and the VCO frequency is far off the desired frequency. When in acquisition mode, the ACQ bit is clear in the PLL bandwidth control register. (See PLL Bandwidth Control Register.) • Tracking mode — In tracking mode, the filter makes only small corrections to the frequency of the VCO. PLL jitter is much lower in tracking mode, but the response to noise is also slower. The PLL enters tracking mode when the VCO frequency is nearly correct, such as when the PLL is selected as the base clock source. (See Base Clock Selector Circuit.) The PLL is automatically in tracking mode when not in acquisition mode or when the ACQ bit is set. 7.4.5 Manual and Automatic PLL Bandwidth Modes The PLL can change the bandwidth or operational mode of the loop filter manually or automatically. Automatic mode is recommended for most users. In automatic bandwidth control mode (AUTO = 1), the lock detector automatically switches between acquisition and tracking modes. Automatic bandwidth control mode also is used to determine when the VCO clock, CGMVCLK, is safe to use as the source for the base clock, CGMOUT. (See PLL Bandwidth Control Register.) If PLL interrupts are enabled, the software can wait for a PLL interrupt request and then check the LOCK bit. If interrupts are disabled, software can poll the LOCK bit continuously (during PLL startup, usually) or at periodic intervals. In either case, when the LOCK bit is set, the VCO clock is safe Technical Data 104 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Functional Description to use as the source for the base clock. (See Base Clock Selector Circuit.) If the VCO is selected as the source for the base clock and the LOCK bit is clear, the PLL has suffered a severe noise hit and the software must take appropriate action, depending on the application. (See Interrupts for information and precautions on using interrupts.) The following conditions apply when the PLL is in automatic bandwidth control mode: • The ACQ bit (see PLL Bandwidth Control Register) is a read-only indicator of the mode of the filter. (See Acquisition and Tracking Modes.) • The ACQ bit is set when the VCO frequency is within a certain tolerance and is cleared when the VCO frequency is out of a certain tolerance. (See Acquisition/Lock Time Specifications for more information.) • The LOCK bit is a read-only indicator of the locked state of the PLL. • The LOCK bit is set when the VCO frequency is within a certain tolerance and is cleared when the VCO frequency is out of a certain tolerance. (See Acquisition/Lock Time Specifications for more information.) • CPU interrupts can occur if enabled (PLLIE = 1) when the PLL’s lock condition changes, toggling the LOCK bit. (See PLL Control Register.) The PLL also may operate in manual mode (AUTO = 0). Manual mode is used by systems that do not require an indicator of the lock condition for proper operation. Such systems typically operate well below fBUSMAX. The following conditions apply when in manual mode: • ACQ is a writable control bit that controls the mode of the filter. Before turning on the PLL in manual mode, the ACQ bit must be clear. • Before entering tracking mode (ACQ = 1), software must wait a given time, tACQ (see Acquisition/Lock Time Specifications), after turning on the PLL by setting PLLON in the PLL control register (PCTL). MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 105 Clock Generator Module (CGMC) • Software must wait a given time, tAL, after entering tracking mode before selecting the PLL as the clock source to CGMOUT (BCS = 1). • The LOCK bit is disabled. • CPU interrupts from the CGMC are disabled. 7.4.6 Programming the PLL The following procedure shows how to program the PLL. NOTE: The round function in the following equations means that the real number should be rounded to the nearest integer number. 1. Choose the desired bus frequency, fBUSDES. 2. Calculate the desired VCO frequency (four times the desired bus frequency). f VCLKDES = 4 × f BUSDES 3. Choose a practical PLL (crystal) reference frequency, fRCLK, and the reference clock divider, R. Typically, the reference crystal is 32.768 kHz and R = 1. Frequency errors to the PLL are corrected at a rate of fRCLK/R. For stability and lock time reduction, this rate must be as fast as possible. The VCO frequency must be an integer multiple of this rate. The relationship between the VCO frequency, fVCLK, and the reference frequency, fRCLK, is P 2 N f VCLK = ----------- ( f RCLK ) R P, the power of two multiplier, and N, the range multiplier, are integers. In cases where desired bus frequency has some tolerance, choose fRCLK to a value determined either by other module requirements (such as modules which are clocked by CGMXCLK), cost requirements, or ideally, as high as the specified range Technical Data 106 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Functional Description allows. See Electrical Specifications. Choose the reference divider, R = 1. After choosing N and P, the actual bus frequency can be determined using equation in 2 above. When the tolerance on the bus frequency is tight, choose fRCLK to an integer divisor of fBUSDES, and R = 1. If fRCLK cannot meet this requirement, use the following equation to solve for R with practical choices of fRCLK, and choose the fRCLK that gives the lowest R.  f VCLKDES    f VCLKDES R = round R MAX ×   -------------------------- – integer  --------------------------   f RCLK     f RCLK  4. Select a VCO frequency multiplier, N.  R × fVCLKDES N = round  ------------------------------------- f RCLK   Reduce N/R to the lowest possible R. 5. If N is < Nmax, use P = 0. If N > Nmax, choose P using this table: Current N Value P 0 < N ≤ N max 0 N max < N ≤ N max × 2 1 N max × 2 < N ≤ N max × 4 2 N max × 4 < N ≤ N max × 8 3 Then recalculate N:  R × f VCLKDES N = round  ------------------------------------- P  f ×2  RCLK 6. Calculate and verify the adequacy of the VCO and bus frequencies fVCLK and fBUS. P f VCLK = ( 2 × N ⁄ R ) × f RCLK f BUS = ( f VCLK ) ⁄ 4 7. Select the VCO’s power-of-two range multiplier E, according to MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 107 Clock Generator Module (CGMC) this table: Frequency Range E 0 < fVCLK < 9,830,400 0 9,830,400 ≤ fVCLK < 19,660,800 1 19,660,800 ≤ fVCLK < 39,321,600 2 NOTE: Do not program E to a value of 3. 8. Select a VCO linear range multiplier, L, where fNOM = 38.4 kHz  f VCLK  L = round  --------------------------  2E × f  NOM 9. Calculate and verify the adequacy of the VCO programmed center-of-range frequency, fVRS. The center-of-range frequency is the midpoint between the minimum and maximum frequencies attainable by the PLL. E f VRS = ( L × 2 ) f NOM For proper operation, E f NOM × 2 f VRS – f VCLK ≤ -------------------------2 10. Verify the choice of P, R, N, E, and L by comparing fVCLK to fVRS and fVCLKDES. For proper operation, fVCLK must be within the application’s tolerance of fVCLKDES, and fVRS must be as close as possible to fVCLK. NOTE: Exceeding the recommended maximum bus frequency or VCO frequency can crash the MCU. 11. Program the PLL registers accordingly: a. In the PRE bits of the PLL control register (PCTL), program the binary equivalent of P. b. In the VPR bits of the PLL control register (PCTL), program the binary equivalent of E. Technical Data 108 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Functional Description c. In the PLL multiplier select register low (PMSL) and the PLL multiplier select register high (PMSH), program the binary equivalent of N. d. In the PLL VCO range select register (PMRS), program the binary coded equivalent of L. e. In the PLL reference divider select register (PMDS), program the binary coded equivalent of R. Table 7-1 provides numeric examples (numbers are in hexadecimal notation): Table 7-1. Numeric Example fBUS fRCLK R N P E L 2.0 MHz 32.768 kHz 1 F5 0 0 D1 2.4576 MHz 32.768 kHz 1 12C 0 1 80 2.5 MHz 32.768 kHz 1 132 0 1 83 4.0 MHz 32.768 kHz 1 1E9 0 1 D1 4.9152 MHz 32.768 kHz 1 258 0 2 80 5.0 MHz 32.768 kHz 1 263 0 2 82 7.3728 MHz 32.768 kHz 1 384 0 2 C0 8.0 MHz 32.768 kHz 1 3D1 0 2 D0 7.4.7 Special Programming Exceptions The programming method described in Programming the PLL does not account for three possible exceptions. A value of 0 for R, N, or L is meaningless when used in the equations given. To account for these exceptions: • A 0 value for R or N is interpreted exactly the same as a value of 1. • A 0 value for L disables the PLL and prevents its selection as the source for the base clock. (See Base Clock Selector Circuit.) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 109 Clock Generator Module (CGMC) 7.4.8 Base Clock Selector Circuit This circuit is used to select either the crystal clock, CGMXCLK, or the VCO clock, CGMVCLK, as the source of the base clock, CGMOUT. The two input clocks go through a transition control circuit that waits up to three CGMXCLK cycles and three CGMVCLK cycles to change from one clock source to the other. During this time, CGMOUT is held in stasis. The output of the transition control circuit is then divided by two to correct the duty cycle. Therefore, the bus clock frequency, which is one-half of the base clock frequency, is one-fourth the frequency of the selected clock (CGMXCLK or CGMVCLK). The BCS bit in the PLL control register (PCTL) selects which clock drives CGMOUT. The VCO clock cannot be selected as the base clock source if the PLL is not turned on. The PLL cannot be turned off if the VCO clock is selected. The PLL cannot be turned on or off simultaneously with the selection or deselection of the VCO clock. The VCO clock also cannot be selected as the base clock source if the factor L is programmed to a 0. This value would set up a condition inconsistent with the operation of the PLL, so that the PLL would be disabled and the crystal clock would be forced as the source of the base clock. 7.4.9 CGMC External Connections In its typical configuration, the CGMC requires up to nine external components. Five of these are for the crystal oscillator and two or four are for the PLL. The crystal oscillator is normally connected in a Pierce oscillator configuration, as shown in Figure 7-2. Figure 7-2 shows only the logical representation of the internal components and may not represent actual circuitry. The oscillator configuration uses five components: • Crystal, X1 • Fixed capacitor, C1 • Tuning capacitor, C2 (can also be a fixed capacitor) • Feedback resistor, RB • Series resistor, RS Technical Data 110 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Functional Description The series resistor (RS) is included in the diagram to follow strict Pierce oscillator guidelines. Refer to the crystal manufacturer’s data for more information regarding values for C1 and C2. Figure 7-2 also shows the external components for the PLL: • Bypass capacitor, CBYP • Filter network Routing should be done with great care to minimize signal cross talk and noise. See CGM Component Specifications for capacitor and resistor values. SIMOSCEN OSCSTOPENB (FROM CONFIG) CGMXCLK OSC1 CGMXFC OSC2 VSSA VDDA VDD RB 10 k RS 0.01 µF CBYP 0.1 µF 0.033 µF X1 C1 C2 Note: Filter network in box can be replaced with a 0.47 µF capacitor, but will degrade stability. Figure 7-2. CGMC External Connections MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 111 Clock Generator Module (CGMC) 7.5 I/O Signals The following paragraphs describe the CGMC I/O signals. 7.5.1 Crystal Amplifier Input Pin (OSC1) The OSC1 pin is an input to the crystal oscillator amplifier. 7.5.2 Crystal Amplifier Output Pin (OSC2) The OSC2 pin is the output of the crystal oscillator inverting amplifier. 7.5.3 External Filter Capacitor Pin (CGMXFC) The CGMXFC pin is required by the loop filter to filter out phase corrections. An external filter network is connected to this pin. (See Figure 7-2.) NOTE: To prevent noise problems, the filter network should be placed as close to the CGMXFC pin as possible, with minimum routing distances and no routing of other signals across the network. 7.5.4 PLL Analog Power Pin (VDDA) VDDA is a power pin used by the analog portions of the PLL. Connect the VDDA pin to the same voltage potential as the VDD pin. NOTE: Route VDDA carefully for maximum noise immunity and place bypass capacitors as close as possible to the package. 7.5.5 PLL Analog Ground Pin (VSSA) VSSA is a ground pin used by the analog portions of the PLL. Connect the VSSA pin to the same voltage potential as the VSS pin. NOTE: Route VSSA carefully for maximum noise immunity and place bypass capacitors as close as possible to the package. Technical Data 112 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) I/O Signals 7.5.6 Oscillator Enable Signal (SIMOSCEN) The SIMOSCEN signal comes from the system integration module (SIM) and enables the oscillator and PLL. 7.5.7 Oscillator Stop Mode Enable Bit (OSCSTOPENB) OSCSTOPENB is a bit in the CONFIG register that enables the oscillator to continue operating during stop mode. If this bit is set, the Oscillator continues running during stop mode. If this bit is not set (default), the oscillator is controlled by the SIMOSCEN signal which will disable the oscillator during stop mode. 7.5.8 Crystal Output Frequency Signal (CGMXCLK) CGMXCLK is the crystal oscillator output signal. It runs at the full speed of the crystal (fXCLK) and comes directly from the crystal oscillator circuit. Figure 7-2 shows only the logical relation of CGMXCLK to OSC1 and OSC2 and may not represent the actual circuitry. The duty cycle of CGMXCLK is unknown and may depend on the crystal and other external factors. Also, the frequency and amplitude of CGMXCLK can be unstable at startup. 7.5.9 CGMC Base Clock Output (CGMOUT) CGMOUT is the clock output of the CGMC. This signal goes to the SIM, which generates the MCU clocks. CGMOUT is a 50 percent duty cycle clock running at twice the bus frequency. CGMOUT is software programmable to be either the oscillator output, CGMXCLK, divided by two or the VCO clock, CGMVCLK, divided by two. 7.5.10 CGMC CPU Interrupt (CGMINT) CGMINT is the interrupt signal generated by the PLL lock detector. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 113 Clock Generator Module (CGMC) 7.6 CGMC Registers These registers control and monitor operation of the CGMC: • PLL control register (PCTL) (See PLL Control Register.) • PLL bandwidth control register (PBWC) (See PLL Bandwidth Control Register.) • PLL multiplier select register high (PMSH) (See PLL Multiplier Select Register High.) • PLL multiplier select register low (PMSL) (See PLL Multiplier Select Register Low.) • PLL VCO range select register (PMRS) (See PLL VCO Range Select Register.) • PLL reference divider select register (PMDS) (See PLL Reference Divider Select Register.) Figure 7-3 is a summary of the CGMC registers. Addr. $0036 $0037 Register Name Bit 7 Read: PLL Control Register Write: (PCTL) Reset: Read: PLL Bandwidth Control Write: Register (PBWC) Reset: Read: PLL Multiplier Select High $0038 Write: Register (PMSH) Reset: Read: PLL Multiplier Select Low $0039 Write: Register (PMSL) Reset: PLLIE 0 AUTO 6 PLLF 0 LOCK 5 4 3 2 1 Bit 0 PLLON BCS PRE1 PRE0 VPR1 VPR0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 MUL11 MUL10 MUL9 MUL8 ACQ R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 MUL7 MUL6 MUL5 MUL4 MUL3 MUL2 MUL1 MUL0 0 1 0 0 0 0 0 0 Figure 7-3. CGMC I/O Register Summary Technical Data 114 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) CGMC Registers $003A $003B Read: PLL VCO Select Range Write: Register (PMRS) Reset: Read: PLL Reference Divider Write: Select Register (PMDS) Reset: VRS7 VRS6 VRS5 VRS4 VRS3 VRS2 VRS1 VRS0 0 1 0 0 0 0 0 0 0 0 0 0 RDS3 RDS2 RDS1 RDS0 0 0 0 0 0 0 0 1 = Unimplemented R = Reserved NOTES: 1. When AUTO = 0, PLLIE is forced clear and is read-only. 2. When AUTO = 0, PLLF and LOCK read as clear. 3. When AUTO = 1, ACQ is read-only. 4. When PLLON = 0 or VRS7:VRS0 = $0, BCS is forced clear and is read-only. 5. When PLLON = 1, the PLL programming register is read-only. 6. When BCS = 1, PLLON is forced set and is read-only. Figure 7-3. CGMC I/O Register Summary 7.6.1 PLL Control Register The PLL control register (PCTL) contains the interrupt enable and flag bits, the on/off switch, the base clock selector bit, the prescaler bits, and the VCO power-of-two range selector bits. Address: $0036 Bit 7 Read: 6 5 4 3 2 1 Bit 0 PLLON BCS PRE1 PRE0 VPR1 VPR0 1 0 0 0 0 0 PLLF PLLIE Write: Reset: 0 0 = Unimplemented Figure 7-4. PLL Control Register (PCTL) PLLIE — PLL Interrupt Enable Bit This read/write bit enables the PLL to generate an interrupt request when the LOCK bit toggles, setting the PLL flag, PLLF. When the AUTO bit in the PLL bandwidth control register (PBWC) is clear, PLLIE cannot be written and reads as logic 0. Reset clears the PLLIE bit. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 115 Clock Generator Module (CGMC) 1 = PLL interrupts enabled 0 = PLL interrupts disabled PLLF — PLL Interrupt Flag Bit This read-only bit is set whenever the LOCK bit toggles. PLLF generates an interrupt request if the PLLIE bit also is set. PLLF always reads as logic 0 when the AUTO bit in the PLL bandwidth control register (PBWC) is clear. Clear the PLLF bit by reading the PLL control register. Reset clears the PLLF bit. 1 = Change in lock condition 0 = No change in lock condition NOTE: Do not inadvertently clear the PLLF bit. Any read or read-modify-write operation on the PLL control register clears the PLLF bit. PLLON — PLL On Bit This read/write bit activates the PLL and enables the VCO clock, CGMVCLK. PLLON cannot be cleared if the VCO clock is driving the base clock, CGMOUT (BCS = 1). (See Base Clock Selector Circuit.) Reset sets this bit so that the loop can stabilize as the MCU is powering up. 1 = PLL on 0 = PLL off BCS — Base Clock Select Bit This read/write bit selects either the crystal oscillator output, CGMXCLK, or the VCO clock, CGMVCLK, as the source of the CGMC output, CGMOUT. CGMOUT frequency is one-half the frequency of the selected clock. BCS cannot be set while the PLLON bit is clear. After toggling BCS, it may take up to three CGMXCLK and three CGMVCLK cycles to complete the transition from one source clock to the other. During the transition, CGMOUT is held in stasis. (See Base Clock Selector Circuit.) Reset clears the BCS bit. 1 = CGMVCLK divided by two drives CGMOUT 0 = CGMXCLK divided by two drives CGMOUT NOTE: PLLON and BCS have built-in protection that prevents the base clock selector circuit from selecting the VCO clock as the source of the base clock if the PLL is off. Therefore, PLLON cannot be cleared when BCS Technical Data 116 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) CGMC Registers is set, and BCS cannot be set when PLLON is clear. If the PLL is off (PLLON = 0), selecting CGMVCLK requires two writes to the PLL control register. (See Base Clock Selector Circuit.) PRE1 and PRE0 — Prescaler Program Bits These read/write bits control a prescaler that selects the prescaler power-of-two multiplier, P. (See PLL Circuits and Programming the PLL.) PRE1 and PRE0 cannot be written when the PLLON bit is set. Reset clears these bits. NOTE: The value of P is normally 0 when using a 32.768-kHz crystal as the reference. Table 7-2. PRE 1 and PRE0 Programming PRE1 and PRE0 P Prescaler Multiplier 00 0 1 01 1 2 10 2 4 11 3 8 VPR1 and 0 — VCO Power-of-Two Range Select Bits These read/write bits control the VCO’s hardware power-of-two range multiplier E that, in conjunction with L (See PLL Circuits, Programming the PLL, and PLL VCO Range Select Register.) controls the hardware center-of-range frequency, fVRS. VPR1:VPR0 cannot be written when the PLLON bit is set. Reset clears these bits. Table 7-3. VPR1 and VPR0 Programming VPR1 and VPR0 E VCO Power-of-Two Range Multiplier 00 0 1 01 1 2 10 2 4 11 3(1) 8 1. Do not program E to a value of 3. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 117 Clock Generator Module (CGMC) 7.6.2 PLL Bandwidth Control Register The PLL bandwidth control register (PBWC): • Selects automatic or manual (software-controlled) bandwidth control mode • Indicates when the PLL is locked • In automatic bandwidth control mode, indicates when the PLL is in acquisition or tracking mode • In manual operation, forces the PLL into acquisition or tracking mode Address: $0037 Bit 7 Read: 6 5 LOCK AUTO 4 3 2 1 0 0 0 0 Bit 0 ACQ R Write: Reset: 0 0 0 0 = Unimplemented R 0 0 0 0 = Reserved Figure 7-5. PLL Bandwidth Control Register (PBWC) AUTO — Automatic Bandwidth Control Bit This read/write bit selects automatic or manual bandwidth control. When initializing the PLL for manual operation (AUTO = 0), clear the ACQ bit before turning on the PLL. Reset clears the AUTO bit. 1 = Automatic bandwidth control 0 = Manual bandwidth control LOCK — Lock Indicator Bit When the AUTO bit is set, LOCK is a read-only bit that becomes set when the VCO clock, CGMVCLK, is locked (running at the programmed frequency). When the AUTO bit is clear, LOCK reads as logic 0 and has no meaning. The write one function of this bit is reserved for test, so this bit must always be written a 0. Reset clears the LOCK bit. Technical Data 118 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) CGMC Registers 1 = VCO frequency correct or locked 0 = VCO frequency incorrect or unlocked ACQ — Acquisition Mode Bit When the AUTO bit is set, ACQ is a read-only bit that indicates whether the PLL is in acquisition mode or tracking mode. When the AUTO bit is clear, ACQ is a read/write bit that controls whether the PLL is in acquisition or tracking mode. In automatic bandwidth control mode (AUTO = 1), the last-written value from manual operation is stored in a temporary location and is recovered when manual operation resumes. Reset clears this bit, enabling acquisition mode. 1 = Tracking mode 0 = Acquisition mode 7.6.3 PLL Multiplier Select Register High The PLL multiplier select register high (PMSH) contains the programming information for the high byte of the modulo feedback divider. Address: Read: $0038 Bit 7 6 5 4 0 0 0 0 3 2 1 Bit 0 MUL11 MUL10 MUL9 MUL8 0 0 0 0 Write: Reset: 0 0 0 0 = Unimplemented Figure 7-6. PLL Multiplier Select Register High (PMSH) MUL11–MUL8 — Multiplier Select Bits These read/write bits control the high byte of the modulo feedback divider that selects the VCO frequency multiplier N. (See PLL Circuits and Programming the PLL.) A value of $0000 in the multiplier select registers configures the modulo feedback divider the same as a value of $0001. Reset initializes the registers to $0040 for a default multiply value of 64. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 119 Clock Generator Module (CGMC) NOTE: The multiplier select bits have built-in protection such that they cannot be written when the PLL is on (PLLON = 1). PMSH[7:4] — Unimplemented Bits These bits have no function and always read as logic 0s. 7.6.4 PLL Multiplier Select Register Low The PLL multiplier select register low (PMSL) contains the programming information for the low byte of the modulo feedback divider. Address: $0038 Bit 7 6 5 4 3 2 1 Bit 0 MUL7 MUL6 MUL5 MUL4 MUL3 MUL2 MUL1 MUL0 0 1 0 0 0 0 0 0 Read: Write: Reset: Figure 7-7. PLL Multiplier Select Register Low (PMSL) MUL7–MUL0 — Multiplier Select Bits These read/write bits control the low byte of the modulo feedback divider that selects the VCO frequency multiplier, N. (See PLL Circuits and Programming the PLL.) MUL7–MUL0 cannot be written when the PLLON bit in the PCTL is set. A value of $0000 in the multiplier select registers configures the modulo feedback divider the same as a value of $0001. Reset initializes the register to $40 for a default multiply value of 64. NOTE: The multiplier select bits have built-in protection such that they cannot be written when the PLL is on (PLLON = 1). Technical Data 120 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) CGMC Registers 7.6.5 PLL VCO Range Select Register NOTE: PMRS may be called PVRS on other HC08 derivatives. The PLL VCO range select register (PMRS) contains the programming information required for the hardware configuration of the VCO. Address: $003A Bit 7 6 5 4 3 2 1 Bit 0 VRS7 VRS6 VRS5 VRS4 VRS3 VRS2 VRS1 VRS0 0 1 0 0 0 0 0 0 Read: Write: Reset: Figure 7-8. PLL VCO Range Select Register (PMRS) VRS7–VRS0 — VCO Range Select Bits These read/write bits control the hardware center-of-range linear multiplier L which, in conjunction with E (see PLL Circuits, Programming the PLL, and PLL Control Register), controls the hardware center-of-range frequency, fVRS. VRS7–VRS0 cannot be written when the PLLON bit in the PCTL is set. (See Special Programming Exceptions.) A value of $00 in the VCO range select register disables the PLL and clears the BCS bit in the PLL control register (PCTL). (See Base Clock Selector Circuit and Special Programming Exceptions.). Reset initializes the register to $40 for a default range multiply value of 64. NOTE: The VCO range select bits have built-in protection such that they cannot be written when the PLL is on (PLLON = 1) and such that the VCO clock cannot be selected as the source of the base clock (BCS = 1) if the VCO range select bits are all clear. The PLL VCO range select register must be programmed correctly. Incorrect programming can result in failure of the PLL to achieve lock. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 121 Clock Generator Module (CGMC) 7.6.6 PLL Reference Divider Select Register NOTE: PMDS may be called PRDS on other HC08 derivatives. The PLL reference divider select register (PMDS) contains the programming information for the modulo reference divider. Address: Read: $003B Bit 7 6 5 4 0 0 0 0 3 2 1 Bit 0 RDS3 RDS2 RDS1 RDS0 0 0 0 1 Write: Reset: 0 0 0 0 = Unimplemented Figure 7-9. PLL Reference Divider Select Register (PMDS) RDS3–RDS0 — Reference Divider Select Bits These read/write bits control the modulo reference divider that selects the reference division factor, R. (See PLL Circuits and Programming the PLL.) RDS7–RDS0 cannot be written when the PLLON bit in the PCTL is set. A value of $00 in the reference divider select register configures the reference divider the same as a value of $01. (See Special Programming Exceptions.) Reset initializes the register to $01 for a default divide value of 1. NOTE: The reference divider select bits have built-in protection such that they cannot be written when the PLL is on (PLLON = 1). NOTE: The default divide value of 1 is recommended for all applications. PMDS7–PMDS4 — Unimplemented Bits These bits have no function and always read as logic 0s. Technical Data 122 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Interrupts 7.7 Interrupts When the AUTO bit is set in the PLL bandwidth control register (PBWC), the PLL can generate a CPU interrupt request every time the LOCK bit changes state. The PLLIE bit in the PLL control register (PCTL) enables CPU interrupts from the PLL. PLLF, the interrupt flag in the PCTL, becomes set whether interrupts are enabled or not. When the AUTO bit is clear, CPU interrupts from the PLL are disabled and PLLF reads as logic 0. Software should read the LOCK bit after a PLL interrupt request to see if the request was due to an entry into lock or an exit from lock. When the PLL enters lock, the VCO clock, CGMVCLK, divided by two can be selected as the CGMOUT source by setting BCS in the PCTL. When the PLL exits lock, the VCO clock frequency is corrupt, and appropriate precautions should be taken. If the application is not frequency sensitive, interrupts should be disabled to prevent PLL interrupt service routines from impeding software performance or from exceeding stack limitations. NOTE: Software can select the CGMVCLK divided by two as the CGMOUT source even if the PLL is not locked (LOCK = 0). Therefore, software should make sure the PLL is locked before setting the BCS bit. 7.8 Special Modes The WAIT instruction puts the MCU in low power-consumption standby modes. 7.8.1 Wait Mode The WAIT instruction does not affect the CGMC. Before entering wait mode, software can disengage and turn off the PLL by clearing the BCS and PLLON bits in the PLL control register (PCTL) to save power. Less power-sensitive applications can disengage the PLL without turning it off, so that the PLL clock is immediately available at WAIT exit. This would be the case also when the PLL is to wake the MCU from wait MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 123 Clock Generator Module (CGMC) mode, such as when the PLL is first enabled and waiting for LOCK or LOCK is lost. 7.8.2 Stop Mode If the OSCSTOPENB bit in the CONFIG register is cleared (default), then the STOP instruction disables the CGMC (oscillator and phase locked loop) and holds low all CGMC outputs (CGMXCLK, CGMOUT, and CGMINT). If the STOP instruction is executed with the VCO clock, CGMVCLK, divided by two driving CGMOUT, the PLL automatically clears the BCS bit in the PLL control register (PCTL), thereby selecting the crystal clock, CGMXCLK, divided by two as the source of CGMOUT. When the MCU recovers from STOP, the crystal clock divided by two drives CGMOUT and BCS remains clear. If the OSCSTOPENB bit in the CONFIG register is set, then the phase locked loop is shut off but the oscillator will continue to operate in stop mode. 7.8.3 CGMC During Break Interrupts The system integration module (SIM) controls whether status bits in other modules can be cleared during the break state. The BCFE bit in the SIM break flag control register (SBFCR) enables software to clear status bits during the break state. (See SIM Break Flag Control Register.) To allow software to clear status bits during a break interrupt, write a logic 1 to the BCFE bit. If a status bit is cleared during the break state, it remains cleared when the MCU exits the break state. To protect the PLLF bit during the break state, write a logic 0 to the BCFE bit. With BCFE at logic 0 (its default state), software can read and write the PLL control register during the break state without affecting the PLLF bit. Technical Data 124 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Acquisition/Lock Time Specifications 7.9 Acquisition/Lock Time Specifications The acquisition and lock times of the PLL are, in many applications, the most critical PLL design parameters. Proper design and use of the PLL ensures the highest stability and lowest acquisition/lock times. 7.9.1 Acquisition/Lock Time Definitions Typical control systems refer to the acquisition time or lock time as the reaction time, within specified tolerances, of the system to a step input. In a PLL, the step input occurs when the PLL is turned on or when it suffers a noise hit. The tolerance is usually specified as a percentage of the step input or when the output settles to the desired value plus or minus a percentage of the frequency change. Therefore, the reaction time is constant in this definition, regardless of the size of the step input. For example, consider a system with a 5 percent acquisition time tolerance. If a command instructs the system to change from 0 Hz to 1 MHz, the acquisition time is the time taken for the frequency to reach 1 MHz ±50 kHz. Fifty kHz = 5% of the 1-MHz step input. If the system is operating at 1 MHz and suffers a –100-kHz noise hit, the acquisition time is the time taken to return from 900 kHz to 1 MHz ±5 kHz. Five kHz = 5% of the 100-kHz step input. Other systems refer to acquisition and lock times as the time the system takes to reduce the error between the actual output and the desired output to within specified tolerances. Therefore, the acquisition or lock time varies according to the original error in the output. Minor errors may not even be registered. Typical PLL applications prefer to use this definition because the system requires the output frequency to be within a certain tolerance of the desired frequency regardless of the size of the initial error. 7.9.2 Parametric Influences on Reaction Time Acquisition and lock times are designed to be as short as possible while still providing the highest possible stability. These reaction times are not constant, however. Many factors directly and indirectly affect the acquisition time. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 125 Clock Generator Module (CGMC) The most critical parameter which affects the reaction times of the PLL is the reference frequency, fRDV. This frequency is the input to the phase detector and controls how often the PLL makes corrections. For stability, the corrections must be small compared to the desired frequency, so several corrections are required to reduce the frequency error. Therefore, the slower the reference the longer it takes to make these corrections. This parameter is under user control via the choice of crystal frequency fXCLK and the R value programmed in the reference divider. (See PLL Circuits, Programming the PLL, and PLL Reference Divider Select Register.) Another critical parameter is the external filter network. The PLL modifies the voltage on the VCO by adding or subtracting charge from capacitors in this network. Therefore, the rate at which the voltage changes for a given frequency error (thus change in charge) is proportional to the capacitance. The size of the capacitor also is related to the stability of the PLL. If the capacitor is too small, the PLL cannot make small enough adjustments to the voltage and the system cannot lock. If the capacitor is too large, the PLL may not be able to adjust the voltage in a reasonable time. (See Choosing a Filter.) Also important is the operating voltage potential applied to VDDA. The power supply potential alters the characteristics of the PLL. A fixed value is best. Variable supplies, such as batteries, are acceptable if they vary within a known range at very slow speeds. Noise on the power supply is not acceptable, because it causes small frequency errors which continually change the acquisition time of the PLL. Temperature and processing also can affect acquisition time because the electrical characteristics of the PLL change. The part operates as specified as long as these influences stay within the specified limits. External factors, however, can cause drastic changes in the operation of the PLL. These factors include noise injected into the PLL through the filter capacitor, filter capacitor leakage, stray impedances on the circuit board, and even humidity or circuit board contamination. Technical Data 126 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Clock Generator Module (CGMC) Acquisition/Lock Time Specifications 7.9.3 Choosing a Filter As described in Parametric Influences on Reaction Time, the external filter network is critical to the stability and reaction time of the PLL. The PLL is also dependent on reference frequency and supply voltage. Either of the filter networks in Figure 7-10 is recommended when using a 32.768-kHz reference crystal. In low-cost applications, where stability and reaction time of the PLL is not critical, this filter network can be replaced by a single capacitor. CGMXFC 10 k 0.01 µF 0.033 µF VSSA Figure 7-10. PLL Filter MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Clock Generator Module (CGMC) 127 Clock Generator Module (CGMC) Technical Data 128 MC68HC908GR8 — Rev 4.0 Clock Generator Module (CGMC) MOTOROLA Technical Data — MC68HC908GR8 Section 8. Configuration Register (CONFIG) 8.1 Contents 8.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 8.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 129 8.2 Introduction This section describes the configuration registers, CONFIG1 and CONFIG2. The configuration registers enable or disable these options: • Stop mode recovery time (32 CGMXCLK cycles or 4096 CGMXCLK cycles) • COP timeout period (218 – 24 or 213 – 24 CGMXCLK cycles) • STOP instruction • Computer operating properly module (COP) • Low-voltage inhibit (LVI) module control and voltage trip point selection • Enable/disable the oscillator (OSC) during stop mode 8.3 Functional Description The configuration registers are used in the initialization of various options. The configuration registers can be written once after each reset. All of the configuration register bits are cleared during reset. Since the various options affect the operation of the MCU, it is recommended that these registers be written immediately after reset. The configuration registers are located at $001E and $001F. The configuration register may be read at anytime. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Configuration Register (CONFIG) 129 Configuration Register (CONFIG) NOTE: To ensure correct operation of the MCU under all operating conditions, the user must write data $1C to address $0033 immediately after reset. This is to ensure proper termination of an unused module within the MCU. NOTE: On a FLASH device, the options except LVI5OR3 are one-time writeable by the user after each reset. The LVI5OR3 bit is one-time writeable by the user only after each POR (power-on reset). The CONFIG registers are not in the FLASH memory but are special registers containing onetime writeable latches after each reset. Upon a reset, the CONFIG registers default to predetermined settings as shown in Figure 8-1 and Figure 8-2. Address: Read: $001E Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 OSCSTOPEN B SCIBDSRC 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 8-1. Configuration Register 2 (CONFIG2) Address: $001F Bit 7 6 5 Read: COPRS LVISTOP LVIRSTD Write: Reset: 0 0 0 4 3 2 1 Bit 0 LVIPWRD LVI5OR3 SSREC STOP COPD 0 See Note 0 0 0 Note: LVI5OR3 bit is only reset via POR (power-on reset) Figure 8-2. Configuration Register 1 (CONFIG1) Technical Data 130 MC68HC908GR8 — Rev 4.0 Configuration Register (CONFIG) MOTOROLA Configuration Register (CONFIG) Functional Description OSCSTOPENB— Oscillator Stop Mode Enable Bar Bit OSCSTOPENB enables the oscillator to continue operating during stop mode. Setting the OSCSTOPENB bit allows the oscillator to operate continuously even during stop mode. This is useful for driving the timebase module to allow it to generate periodic wakeup while in stop mode. (See Clock Generator Module (CGM) subsection Stop Mode.) 1 = Oscillator enabled to operate during stop mode 0 = Oscillator disabled during stop mode (default) SCIBDSRC — SCI Baud Rate Clock Source Bit SCIBDSRC controls the clock source used for the SCI. The setting of this bit affects the frequency at which the SCI operates. 1 = Internal data bus clock used as clock source for SCI 0 = External oscillator used as clock source for SCI COPRS — COP Rate Select Bit COPRS selects the COP timeout period. Reset clears COPRS. See Computer Operating Properly (COP). 1 = COP timeout period = 213 – 24 CGMXCLK cycles 0 = COP timeout period = 218 – 24 CGMXCLK cycles LVISTOP — LVI Enable in Stop Mode Bit When the LVIPWRD bit is clear, setting the LVISTOP bit enables the LVI to operate during stop mode. Reset clears LVISTOP. See Stop Mode. 1 = LVI enabled during stop mode 0 = LVI disabled during stop mode LVIRSTD — LVI Reset Disable Bit LVIRSTD disables the reset signal from the LVI module. See LowVoltage Inhibit (LVI). 1 = LVI module resets disabled 0 = LVI module resets enabled LVIPWRD — LVI Power Disable Bit LVIPWRD disables the LVI module. See Low-Voltage Inhibit (LVI). 1 = LVI module power disabled 0 = LVI module power enabled MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Configuration Register (CONFIG) 131 Configuration Register (CONFIG) LVI5OR3 — LVI 5V or 3V Operating Mode Bit LVI5OR3 selects the voltage operating mode of the LVI module. See Low-Voltage Inhibit (LVI). The voltage mode selected for the LVI should match the operating VDD. See Electrical Specifications for the LVI’s voltage trip points for each of the modes. 1 = LVI operates in 5V mode. 0 = LVI operates in 3V mode. SSREC — Short Stop Recovery Bit SSREC enables the CPU to exit stop mode with a delay of 32 CGMXCLK cycles instead of a 4096-CGMXCLK cycle delay. 1 = Stop mode recovery after 32 CGMXCLK cycles 0 = Stop mode recovery after 4096 CGMXCLKC cycles NOTE: Exiting stop mode by pulling reset will result in the long stop recovery. If using an external crystal oscillator, do not set the SSREC bit. NOTE: When the LVISTOP is enabled, the system stabilization time for power on reset and long stop recovery (both 4096 CGMXCLK cycles) gives a delay longer than the enable time for the LVI. There is no period where the MCU is not protected from a low power condition. However, when using the short stop recovery configuration option, the 32-CGMXCLK delay is less than the LVI’s turn-on time and there exists a period in startup where the LVI is not protecting the MCU. STOP — STOP Instruction Enable Bit STOP enables the STOP instruction. 1 = STOP instruction enabled 0 = STOP instruction treated as illegal opcode COPD — COP Disable Bit COPD disables the COP module. See Computer Operating Properly (COP). 1 = COP module disabled 0 = COP module enabled Technical Data 132 MC68HC908GR8 — Rev 4.0 Configuration Register (CONFIG) MOTOROLA Technical Data — MC68HC908GR8 Section 9. Computer Operating Properly (COP) 9.1 Contents 9.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 9.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 133 9.4 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 135 9.5 COP Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136 9.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 136 9.7 Monitor Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 137 9.8 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .137 9.9 COP Module During Break Mode . . . . . . . . . . . . . . . . . . . . . .137 9.2 Introduction The computer operating properly (COP) module contains a free-running counter that generates a reset if allowed to overflow. The COP module helps software recover from runaway code. Prevent a COP reset by clearing the COP counter periodically. The COP module can be disabled through the COPD bit in the CONFIG register. 9.3 Functional Description Figure 9-1 shows the structure of the COP module. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Computer Operating Properly (COP) 133 Computer Operating Properly (COP) RESET STATUS REGISTER COP TIMEOUT CLEAR STAGES 5–12 STOP INSTRUCTION INTERNAL RESET SOURCES RESET VECTOR FETCH RESET CIRCUIT 12-BIT COP PRESCALER CLEAR ALL STAGES CGMXCLK COPCTL WRITE COP CLOCK COP MODULE 6-BIT COP COUNTER COPEN (FROM SIM) COP DISABLE (FROM CONFIG) RESET COPCTL WRITE CLEAR COP COUNTER COP RATE SEL (FROM CONFIG) Figure 9-1. COP Block Diagram The COP counter is a free-running 6-bit counter preceded by a 12-bit prescaler counter. If not cleared by software, the COP counter overflows and generates an asynchronous reset after 218 – 24 or 213 – 24 CGMXCLK cycles, depending on the state of the COP rate select bit, COPRS, in the configuration register. With a 213 – 24 CGMXCLK cycle overflow option, a 32.768-kHz crystal gives a COP timeout period of 250 ms. Writing any value to location $FFFF before an overflow occurs prevents a COP reset by clearing the COP counter and stages 12 through 5 of the prescaler. NOTE: Service the COP immediately after reset and before entering or after exiting stop mode to guarantee the maximum time before the first COP counter overflow. A COP reset pulls the RST pin low for 32 CGMXCLK cycles and sets the COP bit in the reset status register (RSR). Technical Data 134 MC68HC908GR8 — Rev 4.0 Computer Operating Properly (COP) MOTOROLA Computer Operating Properly (COP) I/O Signals In monitor mode, the COP is disabled if the RST pin or the IRQ1 is held at VTST. During the break state, VTST on the RST pin disables the COP. NOTE: Place COP clearing instructions in the main program and not in an interrupt subroutine. Such an interrupt subroutine could keep the COP from generating a reset even while the main program is not working properly. 9.4 I/O Signals The following paragraphs describe the signals shown in Figure 9-1. 9.4.1 CGMXCLK CGMXCLK is the crystal oscillator output signal. CGMXCLK frequency is equal to the crystal frequency. 9.4.2 STOP Instruction The STOP instruction clears the COP prescaler. 9.4.3 COPCTL Write Writing any value to the COP control register (COPCTL) (see COP Control Register) clears the COP counter and clears bits 12 through 5 of the prescaler. Reading the COP control register returns the low byte of the reset vector. 9.4.4 Power-On Reset The power-on reset (POR) circuit clears the COP prescaler 4096 CGMXCLK cycles after power-up. 9.4.5 Internal Reset An internal reset clears the COP prescaler and the COP counter. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Computer Operating Properly (COP) 135 Computer Operating Properly (COP) 9.4.6 Reset Vector Fetch A reset vector fetch occurs when the vector address appears on the data bus. A reset vector fetch clears the COP prescaler. 9.4.7 COPD (COP Disable) The COPD signal reflects the state of the COP disable bit (COPD) in the configuration register. See Configuration Register (CONFIG). 9.4.8 COPRS (COP Rate Select) The COPRS signal reflects the state of the COP rate select bit (COPRS) in the configuration register. See Configuration Register (CONFIG). 9.5 COP Control Register The COP control register is located at address $FFFF and overlaps the reset vector. Writing any value to $FFFF clears the COP counter and starts a new timeout period. Reading location $FFFF returns the low byte of the reset vector. Address: $FFFF Bit 7 6 5 4 3 2 Read: Low byte of reset vector Write: Clear COP counter Reset: Unaffected by reset 1 Bit 0 Figure 9-2. COP Control Register (COPCTL) 9.6 Interrupts The COP does not generate CPU interrupt requests. Technical Data 136 MC68HC908GR8 — Rev 4.0 Computer Operating Properly (COP) MOTOROLA Computer Operating Properly (COP) Monitor Mode 9.7 Monitor Mode When monitor mode is entered with VTST on the IRQ pin, the COP is disabled as long as VTST remains on the IRQ pin or the RST pin. When monitor mode is entered by having blank reset vectors and not having VTST on the IRQ pin, the COP is automatically disabled until a POR occurs. 9.8 Low-Power Modes The WAIT and STOP instructions put the MCU in low powerconsumption standby modes. 9.8.1 Wait Mode The COP remains active during wait mode. To prevent a COP reset during wait mode, periodically clear the COP counter in a CPU interrupt routine. 9.8.2 Stop Mode Stop mode turns off the CGMXCLK input to the COP and clears the COP prescaler. Service the COP immediately before entering or after exiting stop mode to ensure a full COP timeout period after entering or exiting stop mode. To prevent inadvertently turning off the COP with a STOP instruction, a configuration option is available that disables the STOP instruction. When the STOP bit in the configuration register has the STOP instruction disabled, execution of a STOP instruction results in an illegal opcode reset. 9.9 COP Module During Break Mode The COP is disabled during a break interrupt when VTST is present on the RST pin. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Computer Operating Properly (COP) 137 Computer Operating Properly (COP) Technical Data 138 MC68HC908GR8 — Rev 4.0 Computer Operating Properly (COP) MOTOROLA Technical Data — MC68HC908GR8 Section 10. Central Processing Unit (CPU) 10.1 Contents 10.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 10.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 139 10.4 CPU registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 140 10.5 Arithmetic/logic unit (ALU) . . . . . . . . . . . . . . . . . . . . . . . . . . . 145 10.6 Low-power modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .145 10.7 CPU during break interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 146 10.8 Instruction Set Summary . . . . . . . . . . . . . . . . . . . . . . . . . . . . 147 10.9 Opcode Map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 154 10.2 Introduction The M68HC08 CPU (central processor unit) is an enhanced and fully object-code-compatible version of the M68HC05 CPU. The CPU08 Reference Manual (Motorola document order number CPU08RM/AD) contains a description of the CPU instruction set, addressing modes, and architecture. 10.3 Features • Object code fully upward-compatible with M68HC05 Family • 16-bit stack pointer with stack manipulation instructions • 16-bit index register with x-register manipulation instructions • 8-MHz CPU internal bus frequency MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Central Processing Unit (CPU) 139 Central Processing Unit (CPU) • 64K byte program/data memory space • 16 addressing modes • Memory-to-memory data moves without using accumulator • Fast 8-bit by 8-bit multiply and 16-bit by 8-bit divide instructions • Enhanced binary-coded decimal (BCD) data handling • Modular architecture with expandable internal bus definition for extension of addressing range beyond 64K bytes • Low-power stop and wait modes 10.4 CPU registers Figure 10-1 shows the five CPU registers. CPU registers are not part of the memory map. 0 7 ACCUMULATOR (A) 0 15 H X INDEX REGISTER (H:X) 0 15 STACK POINTER (SP) 0 15 PROGRAM COUNTER (PC) 7 0 V 1 1 H I N Z C CONDITION CODE REGISTER (CCR) CARRY/BORROW FLAG ZERO FLAG NEGATIVE FLAG INTERRUPT MASK HALF-CARRY FLAG TWO’S COMPLEMENT OVERFLOW FLAG Figure 10-1. CPU registers Technical Data 140 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Central Processing Unit (CPU) CPU registers 10.4.1 Accumulator (A) The accumulator is a general-purpose 8-bit register. The CPU uses the accumulator to hold operands and the results of arithmetic/logic operations. Bit 7 6 5 4 3 2 1 Bit 0 Read: A Write: Reset: Unaffected by reset Figure 10-2. Accumulator (A) 10.4.2 Index register (H:X) The 16-bit index register allows indexed addressing of a 64K byte memory space. H is the upper byte of the index register and X is the lower byte. H:X is the concatenated 16-bit index register. In the indexed addressing modes, the CPU uses the contents of the index register to determine the conditional address of the operand. Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 X X X X X X X X Read: H:X Write: Reset: X = Indeterminate Figure 10-3. Index register (H:X) The index register can also be used as a temporary data storage location. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Central Processing Unit (CPU) 141 Central Processing Unit (CPU) 10.4.3 Stack pointer (SP) The stack pointer is a 16-bit register that contains the address of the next location on the stack. During a reset, the stack pointer is preset to $00FF. The reset stack pointer (RSP) instruction sets the least significant byte to $FF and does not affect the most significant byte. The stack pointer decrements as data is pushed onto the stack and increments as data is pulled from the stack. In the stack pointer 8-bit offset and 16-bit offset addressing modes, the stack pointer can function as an index register to access data on the stack. The CPU uses the contents of the stack pointer to determine the conditional address of the operand. Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 Read: SP Write: Reset: Figure 10-4. Stack pointer (SP) NOTE: The location of the stack is arbitrary and may be relocated anywhere in RAM. Moving the SP out of page zero ($0000 to $00FF) frees direct address (page zero) space. For correct operation, the stack pointer must point only to RAM locations. 10.4.4 Program counter (PC) The program counter is a 16-bit register that contains the address of the next instruction or operand to be fetched. Normally, the program counter automatically increments to the next sequential memory location every time an instruction or operand is fetched. Jump, branch, and interrupt operations load the program counter with an address other than that of the next sequential location. Technical Data 142 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Central Processing Unit (CPU) CPU registers During reset, the program counter is loaded with the reset vector address located at $FFFE and $FFFF. The vector address is the address of the first instruction to be executed after exiting the reset state. Bit 15 14 13 12 11 10 9 8 7 6 5 4 3 2 Bit 0 1 Read: PC Write: Reset: Loaded with vector from $FFFE and $FFFF Figure 10-5. Program counter (PC) 10.4.5 Condition code register (CCR) The 8-bit condition code register contains the interrupt mask and five flags that indicate the results of the instruction just executed. Bits 6 and 5 are set permanently to ‘1’. The following paragraphs describe the functions of the condition code register. Bit 7 6 5 4 3 2 1 Bit 0 V 1 1 H I N Z C X 1 1 X 1 X X X Read: CCR Write: Reset: X = Indeterminate Figure 10-6. Condition code register (CCR) V — Overflow flag The CPU sets the overflow flag when a two's complement overflow occurs. The signed branch instructions BGT, BGE, BLE, and BLT use the overflow flag. 1 = Overflow 0 = No overflow H — Half-carry flag MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Central Processing Unit (CPU) 143 Central Processing Unit (CPU) The CPU sets the half-carry flag when a carry occurs between accumulator bits 3 and 4 during an ADD or ADC operation. The halfcarry flag is required for binary-coded decimal (BCD) arithmetic operations. The DAA instruction uses the states of the H and C flags to determine the appropriate correction factor. 1 = Carry between bits 3 and 4 0 = No carry between bits 3 and 4 I — Interrupt mask When the interrupt mask is set, all maskable CPU interrupts are disabled. CPU interrupts are enabled when the interrupt mask is cleared. When a CPU interrupt occurs, the interrupt mask is set automatically after the CPU registers are saved on the stack, but before the interrupt vector is fetched. 1 = Interrupts disabled 0 = Interrupts enabled NOTE: To maintain M6805 compatibility, the upper byte of the index register (H) is not stacked automatically. If the interrupt service routine modifies H, then the user must stack and unstack H using the PSHH and PULH instructions. After the I bit is cleared, the highest-priority interrupt request is serviced first. A return from interrupt (RTI) instruction pulls the CPU registers from the stack and restores the interrupt mask from the stack. After any reset, the interrupt mask is set and can only be cleared by the clear interrupt mask software instruction (CLI). Technical Data 144 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Central Processing Unit (CPU) Arithmetic/logic unit (ALU) N — Negative flag The CPU sets the negative flag when an arithmetic operation, logic operation, or data manipulation produces a negative result, setting bit 7 of the result. 1 = Negative result 0 = Non-negative result Z — Zero flag The CPU sets the zero flag when an arithmetic operation, logic operation, or data manipulation produces a result of $00. 1 = Zero result 0 = Non-zero result C — Carry/borrow flag The CPU sets the carry/borrow flag when an addition operation produces a carry out of bit 7 of the accumulator or when a subtraction operation requires a borrow. Some instructions - such as bit test and branch, shift, and rotate - also clear or set the carry/borrow flag. 1 = Carry out of bit 7 0 = No carry out of bit 7 10.5 Arithmetic/logic unit (ALU) The ALU performs the arithmetic and logic operations defined by the instruction set. Refer to the CPU08 Reference Manual (Motorola document number CPU08RM/AD) for a description of the instructions and addressing modes and more detail about CPU architecture. 10.6 Low-power modes The WAIT and STOP instructions put the MCU in low--power consumption standby modes. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Central Processing Unit (CPU) 145 Central Processing Unit (CPU) 10.6.1 WAIT mode The WAIT instruction: • clears the interrupt mask (I bit) in the condition code register, enabling interrupts. After exit from WAIT mode by interrupt, the I bit remains clear. After exit by reset, the I bit is set. • Disables the CPU clock 10.6.2 STOP mode The STOP instruction: • clears the interrupt mask (I bit) in the condition code register, enabling external interrupts. After exit from STOP mode by external interrupt, the I bit remains clear. After exit by reset, the I bit is set. • Disables the CPU clock After exiting STOP mode, the CPU clock begins running after the oscillator stabilization delay. 10.7 CPU during break interrupts If the break module is enabled, a break interrupt causes the CPU to execute the software interrupt instruction (SWI) at the completion of the current CPU instruction. See Break Module (BRK). The program counter vectors to $FFFC–$FFFD ($FEFC–$FEFD in monitor mode). A return-from-interrupt instruction (RTI) in the break routine ends the break interrupt and returns the MCU to normal operation if the break interrupt has been deasserted. Technical Data 146 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Central Processing Unit (CPU) Instruction Set Summary 10.8 Instruction Set Summary Table 10-1 provides a summary of the M68HC08 instruction set. V H I N Z C ADC #opr ADC opr ADC opr ADC opr,X ADC opr,X ADC ,X ADC opr,SP ADC opr,SP A ← (A) + (M) + (C) Add with Carry IMM DIR EXT ↕ ↕ – ↕ ↕ ↕ IX2 IX1 IX SP1 SP2 A9 B9 C9 D9 E9 F9 9EE9 9ED9 ii dd hh ll ee ff ff IMM DIR EXT IX2 ↕ ↕ – ↕ ↕ ↕ IX1 IX SP1 SP2 AB BB CB DB EB FB 9EEB 9EDB ii dd hh ll ee ff ff ff ee ff A7 ii 2 – – – – – – IMM AF ii 2 IMM DIR EXT IX2 0 – – ↕ ↕ – IX1 IX SP1 SP2 A4 B4 C4 D4 E4 F4 9EE4 9ED4 ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 0 DIR INH INH ↕ – – ↕ ↕ ↕ IX1 IX SP1 38 dd 48 58 68 ff 78 9E68 ff 4 1 1 4 3 5 C DIR INH INH ↕ – – ↕ ↕ ↕ IX1 IX SP1 37 dd 47 57 67 ff 77 9E67 ff 4 1 1 4 3 5 Add without Carry AIS #opr Add Immediate Value (Signed) to SP SP ← (SP) + (16 « M) – – – – – – IMM AIX #opr Add Immediate Value (Signed) to H:X H:X ← (H:X) + (16 « M) A ← (A) & (M) ASL opr ASLA ASLX ASL opr,X ASL ,X ASL opr,SP A ← (A) + (M) Logical AND Arithmetic Shift Left (Same as LSL) ASR opr ASRA ASRX ASR opr,X ASR opr,X ASR opr,SP Arithmetic Shift Right BCC rel Branch if Carry Bit Clear C b7 b7 b0 b0 PC ← (PC) + 2 + rel ? (C) = 0 MC68HC908GR8 — Rev 4.0 MOTOROLA 2 3 4 4 3 2 4 5 2 3 4 4 3 2 4 5 ADD #opr ADD opr ADD opr ADD opr,X ADD opr,X ADD ,X ADD opr,SP ADD opr,SP AND #opr AND opr AND opr AND opr,X AND opr,X AND ,X AND opr,SP AND opr,SP ff ee ff Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary – – – – – – REL 24 ff ee ff rr 3 Technical Data Central Processing Unit (CPU) 147 Central Processing Unit (CPU) V H I N Z C Mn ← 0 Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary (Continued) DIR (b0) DIR (b1) DIR (b2) DIR (b3) – – – – – – DIR (b4) DIR (b5) DIR (b6) DIR (b7) 11 13 15 17 19 1B 1D 1F dd dd dd dd dd dd dd dd 4 4 4 4 4 4 4 4 BCLR n, opr Clear Bit n in M BCS rel Branch if Carry Bit Set (Same as BLO) PC ← (PC) + 2 + rel ? (C) = 1 – – – – – – REL 25 rr 3 BEQ rel Branch if Equal PC ← (PC) + 2 + rel ? (Z) = 1 – – – – – – REL 27 rr 3 BGE opr Branch if Greater Than or Equal To (Signed Operands) PC ← (PC) + 2 + rel ? (N ⊕ V) = 0 – – – – – – REL 90 rr 3 BGT opr Branch if Greater Than (Signed Operands) PC ← (PC) + 2 + rel ? (Z) | (N ⊕ V) = 0 – – – – – – REL 92 rr 3 BHCC rel Branch if Half Carry Bit Clear PC ← (PC) + 2 + rel ? (H) = 0 – – – – – – REL 28 rr 3 BHCS rel Branch if Half Carry Bit Set PC ← (PC) + 2 + rel ? (H) = 1 – – – – – – REL 29 rr BHI rel Branch if Higher PC ← (PC) + 2 + rel ? (C) | (Z) = 0 – – – – – – REL 22 rr 3 BHS rel Branch if Higher or Same (Same as BCC) PC ← (PC) + 2 + rel ? (C) = 0 – – – – – – REL 24 rr 3 BIH rel Branch if IRQ Pin High PC ← (PC) + 2 + rel ? IRQ = 1 – – – – – – REL 2F rr 3 BIL rel Branch if IRQ Pin Low PC ← (PC) + 2 + rel ? IRQ = 0 – – – – – – REL 2E rr 3 (A) & (M) IMM DIR EXT 0 – – ↕ ↕ – IX2 IX1 IX SP1 SP2 A5 B5 C5 D5 E5 F5 9EE5 9ED5 ii dd hh ll ee ff ff ff ee ff 2 3 4 4 3 2 4 5 93 rr 3 BIT #opr BIT opr BIT opr BIT opr,X BIT opr,X BIT ,X BIT opr,SP BIT opr,SP Bit Test BLE opr Branch if Less Than or Equal To (Signed Operands) BLO rel Branch if Lower (Same as BCS) BLS rel PC ← (PC) + 2 + rel ? (Z) | (N ⊕ V) = 1 – – – – – – REL 3 PC ← (PC) + 2 + rel ? (C) = 1 – – – – – – REL 25 rr 3 Branch if Lower or Same PC ← (PC) + 2 + rel ? (C) | (Z) = 1 – – – – – – REL 23 rr 3 BLT opr Branch if Less Than (Signed Operands) PC ← (PC) + 2 + rel ? (N ⊕ V) =1 – – – – – – REL 91 rr 3 BMC rel Branch if Interrupt Mask Clear PC ← (PC) + 2 + rel ? (I) = 0 – – – – – – REL 2C rr 3 BMI rel Branch if Minus PC ← (PC) + 2 + rel ? (N) = 1 – – – – – – REL 2B rr 3 BMS rel Branch if Interrupt Mask Set PC ← (PC) + 2 + rel ? (I) = 1 – – – – – – REL 2D rr 3 Technical Data 148 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Central Processing Unit (CPU) Instruction Set Summary V H I N Z C Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary (Continued) BNE rel Branch if Not Equal PC ← (PC) + 2 + rel ? (Z) = 0 – – – – – – REL 26 rr 3 BPL rel Branch if Plus PC ← (PC) + 2 + rel ? (N) = 0 – – – – – – REL 2A rr 3 BRA rel Branch Always PC ← (PC) + 2 + rel – – – – – – REL 20 rr 3 DIR (b0) DIR (b1) DIR (b2) DIR (b3) – – – – – ↕ DIR (b4) DIR (b5) DIR (b6) DIR (b7) 01 03 05 07 09 0B 0D 0F dd rr dd rr dd rr dd rr dd rr dd rr dd rr dd rr 5 5 5 5 5 5 5 5 – – – – – – REL 21 rr 3 PC ← (PC) + 3 + rel ? (Mn) = 1 DIR (b0) DIR (b1) DIR (b2) – – – – – ↕ DIR (b3) DIR (b4) DIR (b5) DIR (b6) DIR (b7) 00 02 04 06 08 0A 0C 0E dd rr dd rr dd rr dd rr dd rr dd rr dd rr dd rr 5 5 5 5 5 5 5 5 Mn ← 1 DIR (b0) DIR (b1) DIR (b2) – – – – – – DIR (b3) DIR (b4) DIR (b5) DIR (b6) DIR (b7) 10 12 14 16 18 1A 1C 1E dd dd dd dd dd dd dd dd 4 4 4 4 4 4 4 4 – – – – – – REL AD rr 4 DIR IMM IMM – – – – – – IX1+ IX+ SP1 31 41 51 61 71 9E61 dd rr ii rr ii rr ff rr rr ff rr 5 4 4 5 4 6 BRCLR n,opr,rel Branch if Bit n in M Clear BRN rel PC ← (PC) + 3 + rel ? (Mn) = 0 PC ← (PC) + 2 Branch Never BRSET n,opr,rel Branch if Bit n in M Set BSET n,opr Set Bit n in M BSR rel Branch to Subroutine CBEQ opr,rel CBEQA #opr,rel CBEQX #opr,rel Compare and Branch if Equal CBEQ opr,X+,rel CBEQ X+,rel CBEQ opr,SP,rel PC ← (PC) + 2; push (PCL) SP ← (SP) – 1; push (PCH) SP ← (SP) – 1 PC ← (PC) + rel PC ← PC ← PC ← PC ← PC ← PC ← (PC) + 3 + rel ? (A) – (M) = $00 (PC) + 3 + rel ? (A) – (M) = $00 (PC) + 3 + rel ? (X) – (M) = $00 (PC) + 3 + rel ? (A) – (M) = $00 (PC) + 2 + rel ? (A) – (M) = $00 (PC) + 4 + rel ? (A) – (M) = $00 CLC Clear Carry Bit C←0 – – – – – 0 INH 98 1 CLI Clear Interrupt Mask I←0 – – 0 – – – INH 9A 2 M ← $00 A ← $00 X ← $00 H ← $00 M ← $00 M ← $00 M ← $00 DIR INH INH 0 – – 0 1 – INH IX1 IX SP1 CLR opr CLRA CLRX CLRH CLR opr,X CLR ,X CLR opr,SP Clear MC68HC908GR8 — Rev 4.0 MOTOROLA 3F dd 4F 5F 8C 6F ff 7F 9E6F ff 3 1 1 1 3 2 4 Technical Data Central Processing Unit (CPU) 149 Central Processing Unit (CPU) V H I N Z C CMP #opr CMP opr CMP opr CMP opr,X CMP opr,X CMP ,X CMP opr,SP CMP opr,SP Compare A with M COM opr COMA COMX COM opr,X COM ,X COM opr,SP Complement (One’s Complement) CPHX #opr CPHX opr Compare H:X with M CPX #opr CPX opr CPX opr CPX ,X CPX opr,X CPX opr,X CPX opr,SP CPX opr,SP Compare X with M DAA Decimal Adjust A Decrement DIV Divide EOR #opr EOR opr EOR opr EOR opr,X EOR opr,X EOR ,X EOR opr,SP EOR opr,SP Exclusive OR M with A A1 B1 C1 D1 E1 F1 9EE1 9ED1 M ← (M) = $FF – (M) A ← (A) = $FF – (M) X ← (X) = $FF – (M) M ← (M) = $FF – (M) M ← (M) = $FF – (M) M ← (M) = $FF – (M) DIR INH INH 0 – – ↕ ↕ 1 IX1 IX SP1 33 dd 43 53 63 ff 73 9E63 ff (H:X) – (M:M + 1) IMM ↕ – – ↕ ↕ ↕ DIR 65 75 ii ii+1 dd 3 4 (X) – (M) IMM DIR EXT ↕ – – ↕ ↕ ↕ IX2 IX1 IX SP1 SP2 A3 B3 C3 D3 E3 F3 9EE3 9ED3 ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 U – – ↕ ↕ ↕ INH 72 (A)10 DBNZ opr,rel DBNZA rel DBNZX rel Decrement and Branch if Not Zero DBNZ opr,X,rel DBNZ X,rel DBNZ opr,SP,rel DEC opr DECA DECX DEC opr,X DEC ,X DEC opr,SP IMM DIR EXT IX2 ↕ – – ↕ ↕ ↕ IX1 IX SP1 SP2 (A) – (M) A ← (A) – 1 or M ← (M) – 1 or X ← (X) – 1 DIR PC ← (PC) + 3 + rel ? (result) ≠ 0 INH PC ← (PC) + 2 + rel ? (result) ≠ 0 PC ← (PC) + 2 + rel ? (result) ≠ 0 – – – – – – INH IX1 PC ← (PC) + 3 + rel ? (result) ≠ 0 IX PC ← (PC) + 2 + rel ? (result) ≠ 0 PC ← (PC) + 4 + rel ? (result) ≠ 0 SP1 M ← (M) – 1 A ← (A) – 1 X ← (X) – 1 M ← (M) – 1 M ← (M) – 1 M ← (M) – 1 DIR INH INH ↕ – – ↕ ↕ – IX1 IX SP1 A ← (H:A)/(X) H ← Remainder – – – – ↕ ↕ INH 52 A ← (A ⊕ M) IMM DIR EXT IX2 0 – – ↕ ↕ – IX1 IX SP1 SP2 A8 B8 C8 D8 E8 F8 9EE8 9ED8 Technical Data 150 3B 4B 5B 6B 7B 9E6B ii dd hh ll ee ff ff Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary (Continued) ff ee ff ff ee ff 2 3 4 4 3 2 4 5 4 1 1 4 3 5 2 dd rr rr rr ff rr rr ff rr 3A dd 4A 5A 6A ff 7A 9E6A ff 5 3 3 5 4 6 4 1 1 4 3 5 7 ii dd hh ll ee ff ff ff ee ff 2 3 4 4 3 2 4 5 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Central Processing Unit (CPU) Instruction Set Summary V H I N Z C INC opr INCA INCX INC opr,X INC ,X INC opr,SP JMP opr JMP opr JMP opr,X JMP opr,X JMP ,X JSR opr JSR opr JSR opr,X JSR opr,X JSR ,X Increment Jump to Subroutine Load A from M LDHX #opr LDHX opr Load H:X from M LSL opr LSLA LSLX LSL opr,X LSL ,X LSL opr,SP LSR opr LSRA LSRX LSR opr,X LSR ,X LSR opr,SP Logical Shift Right MOV opr,opr MOV opr,X+ MOV #opr,opr MOV X+,opr Move MUL Unsigned multiply 4 1 1 4 3 5 PC ← Jump Address dd hh ll ee ff ff 2 3 4 3 2 PC ← (PC) + n (n = 1, 2, or 3) Push (PCL); SP ← (SP) – 1 Push (PCH); SP ← (SP) – 1 PC ← Unconditional Address DIR EXT – – – – – – IX2 IX1 IX BD CD DD ED FD dd hh ll ee ff ff 4 5 6 5 4 A ← (M) IMM DIR EXT 0 – – ↕ ↕ – IX2 IX1 IX SP1 SP2 A6 B6 C6 D6 E6 F6 9EE6 9ED6 ii dd hh ll ee ff ff ff ee ff 2 3 4 4 3 2 4 5 H:X ← (M:M + 1) 0 – – ↕ ↕ – IMM DIR 45 55 ii jj dd 3 4 X ← (M) IMM DIR EXT IX2 0 – – ↕ ↕ – IX1 IX SP1 SP2 AE BE CE DE EE FE 9EEE 9EDE ii dd hh ll ee ff ff 2 3 4 4 3 2 4 5 0 DIR INH INH ↕ – – ↕ ↕ ↕ IX1 IX SP1 38 dd 48 58 68 ff 78 9E68 ff 4 1 1 4 3 5 C DIR INH INH ↕ – – 0 ↕ ↕ IX1 IX SP1 34 dd 44 54 64 ff 74 9E64 ff 4 1 1 4 3 5 C b7 b0 0 b7 b0 (M)Destination ← (M)Source H:X ← (H:X) + 1 (IX+D, DIX+) X:A ← (X) × (A) MC68HC908GR8 — Rev 4.0 MOTOROLA 3C dd 4C 5C 6C ff 7C 9E6C ff BC CC DC EC FC Load X from M Logical Shift Left (Same as ASL) DIR INH INH ↕ – – ↕ ↕ – IX1 IX SP1 (M) + 1 (A) + 1 (X) + 1 (M) + 1 (M) + 1 (M) + 1 DIR EXT – – – – – – IX2 IX1 IX Jump LDA #opr LDA opr LDA opr LDA opr,X LDA opr,X LDA ,X LDA opr,SP LDA opr,SP LDX #opr LDX opr LDX opr LDX opr,X LDX opr,X LDX ,X LDX opr,SP LDX opr,SP M← A← X← M← M← M← Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary (Continued) 0 – – ↕ ↕ – DD DIX+ IMD IX+D – 0 – – – 0 INH 4E 5E 6E 7E 42 ff ee ff dd dd dd ii dd dd 5 4 4 4 5 Technical Data Central Processing Unit (CPU) 151 Central Processing Unit (CPU) V H I N Z C NEG opr NEGA NEGX NEG opr,X NEG ,X NEG opr,SP Negate (Two’s Complement) NOP No Operation NSA Nibble Swap A 30 dd 40 50 60 ff 70 9E60 ff Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary (Continued) M ← –(M) = $00 – (M) A ← –(A) = $00 – (A) X ← –(X) = $00 – (X) M ← –(M) = $00 – (M) M ← –(M) = $00 – (M) DIR INH INH ↕ – – ↕ ↕ ↕ IX1 IX SP1 None – – – – – – INH 9D 1 A ← (A[3:0]:A[7:4]) – – – – – – INH 62 3 A ← (A) | (M) IMM DIR EXT 0 – – ↕ ↕ – IX2 IX1 IX SP1 SP2 AA BA CA DA EA FA 9EEA 9EDA 4 1 1 4 3 5 ORA #opr ORA opr ORA opr ORA opr,X ORA opr,X ORA ,X ORA opr,SP ORA opr,SP Inclusive OR A and M PSHA Push A onto Stack Push (A); SP ← (SP) – 1 – – – – – – INH 87 2 PSHH Push H onto Stack Push (H); SP ← (SP) – 1 – – – – – – INH 8B 2 PSHX Push X onto Stack Push (X); SP ← (SP) – 1 – – – – – – INH 89 2 PULA Pull A from Stack SP ← (SP + 1); Pull (A) – – – – – – INH 86 2 PULH Pull H from Stack SP ← (SP + 1); Pull (H) – – – – – – INH 8A 2 PULX Pull X from Stack SP ← (SP + 1); Pull (X) – – – – – – INH 88 2 C DIR INH INH ↕ – – ↕ ↕ ↕ IX1 IX SP1 39 dd 49 59 69 ff 79 9E69 ff 4 1 1 4 3 5 DIR INH INH ↕ – – ↕ ↕ ↕ IX1 IX SP1 36 dd 46 56 66 ff 76 9E66 ff 4 1 1 4 3 5 ROL opr ROLA ROLX ROL opr,X ROL ,X ROL opr,SP Rotate Left through Carry b7 b0 ii dd hh ll ee ff ff ff ee ff 2 3 4 4 3 2 4 5 ROR opr RORA RORX ROR opr,X ROR ,X ROR opr,SP Rotate Right through Carry RSP Reset Stack Pointer SP ← $FF – – – – – – INH 9C 1 RTI Return from Interrupt SP ← (SP) + 1; Pull (CCR) SP ← (SP) + 1; Pull (A) SP ← (SP) + 1; Pull (X) SP ← (SP) + 1; Pull (PCH) SP ← (SP) + 1; Pull (PCL) ↕ ↕ ↕ ↕ ↕ ↕ INH 80 7 RTS Return from Subroutine SP ← SP + 1; Pull (PCH) SP ← SP + 1; Pull (PCL) – – – – – – INH 81 4 C b7 b0 Technical Data 152 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Central Processing Unit (CPU) Instruction Set Summary V H I N Z C SBC #opr SBC opr SBC opr SBC opr,X SBC opr,X SBC ,X SBC opr,SP SBC opr,SP Subtract with Carry SEC Set Carry Bit SEI Set Interrupt Mask STA opr STA opr STA opr,X STA opr,X STA ,X STA opr,SP STA opr,SP Store A in M STHX opr Store H:X in M STOP Enable IRQ Pin; Stop Oscillator STX opr STX opr STX opr,X STX opr,X STX ,X STX opr,SP STX opr,SP SUB #opr SUB opr SUB opr SUB opr,X SUB opr,X SUB ,X SUB opr,SP SUB opr,SP Store X in M Subtract ii dd hh ll ee ff ff Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary (Continued) 2 3 4 4 3 2 4 5 IMM DIR EXT IX2 ↕ – – ↕ ↕ ↕ IX1 IX SP1 SP2 A2 B2 C2 D2 E2 F2 9EE2 9ED2 C←1 – – – – – 1 INH 99 1 I←1 – – 1 – – – INH 9B 2 M ← (A) DIR EXT IX2 0 – – ↕ ↕ – IX1 IX SP1 SP2 B7 C7 D7 E7 F7 9EE7 9ED7 (M:M + 1) ← (H:X) 0 – – ↕ ↕ – DIR 35 I ← 0; Stop Oscillator – – 0 – – – INH 8E M ← (X) DIR EXT IX2 0 – – ↕ ↕ – IX1 IX SP1 SP2 BF CF DF EF FF 9EEF 9EDF dd hh ll ee ff ff IMM DIR EXT ↕ – – ↕ ↕ ↕ IX2 IX1 IX SP1 SP2 A0 B0 C0 D0 E0 F0 9EE0 9ED0 ii dd hh ll ee ff ff – – 1 – – – INH 83 9 A ← (A) – (M) – (C) A ← (A) – (M) ff ee ff dd hh ll ee ff ff ff ee ff 3 4 4 3 2 4 5 dd 4 1 ff ee ff ff ee ff 3 4 4 3 2 4 5 2 3 4 4 3 2 4 5 SWI Software Interrupt PC ← (PC) + 1; Push (PCL) SP ← (SP) – 1; Push (PCH) SP ← (SP) – 1; Push (X) SP ← (SP) – 1; Push (A) SP ← (SP) – 1; Push (CCR) SP ← (SP) – 1; I ← 1 PCH ← Interrupt Vector High Byte PCL ← Interrupt Vector Low Byte TAP Transfer A to CCR CCR ← (A) ↕ ↕ ↕ ↕ ↕ ↕ INH 84 2 TAX Transfer A to X X ← (A) – – – – – – INH 97 1 TPA Transfer CCR to A A ← (CCR) – – – – – – INH 85 1 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Central Processing Unit (CPU) 153 Central Processing Unit (CPU) V H I N Z C TST opr TSTA TSTX TST opr,X TST ,X TST opr,SP Test for Negative or Zero TSX Transfer SP to H:X TXA Transfer X to A TXS Transfer H:X to SP (A) – $00 or (X) – $00 or (M) – $00 DIR INH INH 0 – – ↕ ↕ – IX1 IX SP1 H:X ← (SP) + 1 – – – – – – INH 95 2 A ← (X) – – – – – – INH 9F 1 (SP) ← (H:X) – 1 – – – – – – INH 94 2 A Accumulatorn C Carry/borrow bitopr CCRCondition code registerPC ddDirect address of operandPCH dd rrDirect address of operand and relative offset of branch instructionPCL DDDirect to direct addressing modeREL DIRDirect addressing moderel DIX+Direct to indexed with post increment addressing moderr ee ffHigh and low bytes of offset in indexed, 16-bit offset addressingSP1 EXTExtended addressing modeSP2 ff Offset byte in indexed, 8-bit offset addressingSP H Half-carry bitU H Index register high byteV hh llHigh and low bytes of operand address in extended addressingX I Interrupt maskZ ii Immediate operand byte& IMDImmediate source to direct destination addressing mode| IMMImmediate addressing mode⊕ INHInherent addressing mode( ) IXIndexed, no offset addressing mode–( ) IX+Indexed, no offset, post increment addressing mode# IX+DIndexed with post increment to direct addressing mode« IX1Indexed, 8-bit offset addressing mode← IX1+Indexed, 8-bit offset, post increment addressing mode? IX2Indexed, 16-bit offset addressing mode: MMemory location↕ N Negative bit— 3D dd 4D 5D 6D ff 7D 9E6D ff Cycles Description Operand Operation Effect on CCR Opcode Source Form Address Mode Table 10-1. Instruction Set Summary (Continued) 3 1 1 3 2 4 Any bit Operand (one or two bytes) Program counter Program counter high byte Program counter low byte Relative addressing mode Relative program counter offset byte Relative program counter offset byte Stack pointer, 8-bit offset addressing mode Stack pointer 16-bit offset addressing mode Stack pointer Undefined Overflow bit Index register low byte Zero bit Logical AND Logical OR Logical EXCLUSIVE OR Contents of Negation (two’s complement) Immediate value Sign extend Loaded with If Concatenated with Set or cleared Not affected 10.9 Opcode Map See Table 10-2. Technical Data 154 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA MSB Branch REL DIR INH 3 4 0 2 3 4 5 6 7 8 9 A B C D MOTOROLA MC68HC908GR8 — Rev 4.0 1 2 5 BRSET0 3 DIR 5 BRCLR0 3 DIR 5 BRSET1 3 DIR 5 BRCLR1 3 DIR 5 BRSET2 3 DIR 5 BRCLR2 3 DIR 5 BRSET3 3 DIR 5 BRCLR3 3 DIR 5 BRSET4 3 DIR 5 BRCLR4 3 DIR 5 BRSET5 3 DIR 5 BRCLR5 3 DIR 5 BRSET6 3 DIR 5 BRCLR6 3 DIR 5 BRSET7 3 DIR 5 BRCLR7 3 DIR 4 BSET0 2 DIR 4 BCLR0 2 DIR 4 BSET1 2 DIR 4 BCLR1 2 DIR 4 BSET2 2 DIR 4 BCLR2 2 DIR 4 BSET3 2 DIR 4 BCLR3 2 DIR 4 BSET4 2 DIR 4 BCLR4 2 DIR 4 BSET5 2 DIR 4 BCLR5 2 DIR 4 BSET6 2 DIR 4 BCLR6 2 DIR 4 BSET7 2 DIR 4 BCLR7 2 DIR 3 BRA REL 3 BRN 2 REL 3 BHI 2 REL 3 BLS 2 REL 3 BCC 2 REL 3 BCS 2 REL 3 BNE 2 REL 3 BEQ 2 REL 3 BHCC 2 REL 3 BHCS 2 REL 3 BPL 2 REL 3 BMI 2 REL 3 BMC 2 REL 3 BMS 2 REL 3 BIL 2 REL 3 BIH 2 REL 5 6 1 NEGX 1 INH 4 CBEQX 3 IMM 7 DIV 1 INH 1 COMX 1 INH 1 LSRX 1 INH 4 LDHX 2 DIR 1 RORX 1 INH 1 ASRX 1 INH 1 LSLX 1 INH 1 ROLX 1 INH 1 DECX 1 INH 3 DBNZX 2 INH 1 INCX 1 INH 1 TSTX 1 INH 4 MOV 2 DIX+ 1 CLRX 1 INH 4 NEG IX1 5 CBEQ 3 IX1+ 3 NSA 1 INH 4 COM 2 IX1 4 LSR 2 IX1 3 CPHX 3 IMM 4 ROR 2 IX1 4 ASR 2 IX1 4 LSL 2 IX1 4 ROL 2 IX1 4 DEC 2 IX1 5 DBNZ 3 IX1 4 INC 2 IX1 3 TST 2 IX1 4 MOV 3 IMD 3 CLR 2 IX1 SP1 IX 9E6 7 Control INH INH 8 9 Register/Memory IX2 SP2 IMM DIR EXT A B C D 9ED 4 SUB EXT 4 CMP 3 EXT 4 SBC 3 EXT 4 CPX 3 EXT 4 AND 3 EXT 4 BIT 3 EXT 4 LDA 3 EXT 4 STA 3 EXT 4 EOR 3 EXT 4 ADC 3 EXT 4 ORA 3 EXT 4 ADD 3 EXT 3 JMP 3 EXT 5 JSR 3 EXT 4 LDX 3 EXT 4 STX 3 EXT 4 SUB IX2 4 CMP 3 IX2 4 SBC 3 IX2 4 CPX 3 IX2 4 AND 3 IX2 4 BIT 3 IX2 4 LDA 3 IX2 4 STA 3 IX2 4 EOR 3 IX2 4 ADC 3 IX2 4 ORA 3 IX2 4 ADD 3 IX2 4 JMP 3 IX2 6 JSR 3 IX2 4 LDX 3 IX2 4 STX 3 IX2 5 SUB SP2 5 CMP 4 SP2 5 SBC 4 SP2 5 CPX 4 SP2 5 AND 4 SP2 5 BIT 4 SP2 5 LDA 4 SP2 5 STA 4 SP2 5 EOR 4 SP2 5 ADC 4 SP2 5 ORA 4 SP2 5 ADD 4 SP2 IX1 SP1 IX E 9EE F LSB 1 Central Processing Unit (CPU) 0 Read-Modify-Write INH IX1 E F 2 4 1 NEG NEGA DIR 1 INH 5 4 CBEQ CBEQA 3 DIR 3 IMM 5 MUL 1 INH 4 1 COM COMA 2 DIR 1 INH 4 1 LSR LSRA 2 DIR 1 INH 4 3 STHX LDHX 2 DIR 3 IMM 4 1 ROR RORA 2 DIR 1 INH 4 1 ASR ASRA 2 DIR 1 INH 4 1 LSL LSLA 2 DIR 1 INH 4 1 ROL ROLA 2 DIR 1 INH 4 1 DEC DECA 2 DIR 1 INH 5 3 DBNZ DBNZA 3 DIR 2 INH 4 1 INC INCA 2 DIR 1 INH 3 1 TST TSTA 2 DIR 1 INH 5 MOV 3 DD 3 1 CLR CLRA 2 DIR 1 INH 2 INH Inherent REL Relative IMM Immediate IX Indexed, No Offset DIR Direct IX1 Indexed, 8-Bit Offset EXT Extended IX2 Indexed, 16-Bit Offset DD Direct-Direct IMD Immediate-Direct IX+D Indexed-Direct DIX+ Direct-Indexed *Pre-byte for stack pointer indexed instructions 2 5 3 NEG NEG SP1 1 IX 6 4 CBEQ CBEQ 4 SP1 2 IX+ 2 DAA 1 INH 5 3 COM COM 3 SP1 1 IX 5 3 LSR LSR 3 SP1 1 IX 4 CPHX 2 DIR 5 3 ROR ROR 3 SP1 1 IX 5 3 ASR ASR 3 SP1 1 IX 5 3 LSL LSL 3 SP1 1 IX 5 3 ROL ROL 3 SP1 1 IX 5 3 DEC DEC 3 SP1 1 IX 6 4 DBNZ DBNZ 4 SP1 2 IX 5 3 INC INC 3 SP1 1 IX 4 2 TST TST 3 SP1 1 IX 4 MOV 2 IX+D 4 2 CLR CLR 3 SP1 1 IX 3 SP1 Stack Pointer, 8-Bit Offset SP2 Stack Pointer, 16-Bit Offset IX+ Indexed, No Offset with Post Increment IX1+ Indexed, 1-Byte Offset with Post Increment 7 3 RTI BGE INH 2 REL 4 3 RTS BLT 1 INH 2 REL 3 BGT 2 REL 9 3 SWI BLE 1 INH 2 REL 2 2 TAP TXS 1 INH 1 INH 1 2 TPA TSX 1 INH 1 INH 2 PULA 1 INH 2 1 PSHA TAX 1 INH 1 INH 2 1 PULX CLC 1 INH 1 INH 2 1 PSHX SEC 1 INH 1 INH 2 2 PULH CLI 1 INH 1 INH 2 2 PSHH SEI 1 INH 1 INH 1 1 CLRH RSP 1 INH 1 INH 1 NOP 1 INH 1 STOP * 1 INH 1 1 WAIT TXA 1 INH 1 INH 1 2 SUB IMM 2 CMP 2 IMM 2 SBC 2 IMM 2 CPX 2 IMM 2 AND 2 IMM 2 BIT 2 IMM 2 LDA 2 IMM 2 AIS 2 IMM 2 EOR 2 IMM 2 ADC 2 IMM 2 ORA 2 IMM 2 ADD 2 IMM 2 2 2 2 2 2 2 2 2 2 2 2 2 2 4 BSR 2 REL 2 2 LDX 2 IMM 2 2 AIX 2 IMM 2 3 SUB DIR 3 CMP DIR 3 SBC DIR 3 CPX DIR 3 AND DIR 3 BIT DIR 3 LDA DIR 3 STA DIR 3 EOR DIR 3 ADC DIR 3 ORA DIR 3 ADD DIR 2 JMP DIR 4 JSR DIR 3 LDX DIR 3 STX DIR MSB 3 0 3 3 SUB IX1 3 CMP 2 IX1 3 SBC 2 IX1 3 CPX 2 IX1 3 AND 2 IX1 3 BIT 2 IX1 3 LDA 2 IX1 3 STA 2 IX1 3 EOR 2 IX1 3 ADC 2 IX1 3 ORA 2 IX1 3 ADD 2 IX1 3 JMP 2 IX1 5 JSR 2 IX1 5 3 LDX LDX 4 SP2 2 IX1 5 3 STX STX 4 SP2 2 IX1 4 2 3 3 3 3 3 3 3 3 3 3 3 3 4 SUB SP1 4 CMP SP1 4 SBC SP1 4 CPX SP1 4 AND SP1 4 BIT SP1 4 LDA SP1 4 STA SP1 4 EOR SP1 4 ADC SP1 4 ORA SP1 4 ADD SP1 Table 10-2. Opcode Map 0 1 1 1 1 1 1 1 1 1 1 1 1 1 4 LDX 3 SP1 1 4 STX 3 SP1 1 High Byte of Opcode in Hexadecimal LSB Low Byte of Opcode in Hexadecimal 1 5 Cycles BRSET0 Opcode Mnemonic 3 DIR Number of Bytes / Addressing Mode 2 SUB IX 2 CMP IX 2 SBC IX 2 CPX IX 2 AND IX 2 BIT IX 2 LDA IX 2 STA IX 2 EOR IX 2 ADC IX 2 ORA IX 2 ADD IX 2 JMP IX 4 JSR IX 2 LDX IX 2 STX IX Central Processing Unit (CPU) Technical Data 155 Bit Manipulation DIR DIR Central Processing Unit (CPU) Technical Data 156 MC68HC908GR8 — Rev 4.0 Central Processing Unit (CPU) MOTOROLA Technical Data — MC68HC908GR8 Section 11. Flash Memory 11.1 Contents 11.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 11.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 157 11.4 FLASH Control Register . . . . . . . . . . . . . . . . . . . . . . . . . . . . .159 11.5 FLASH Page Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . 160 11.6 FLASH Mass Erase Operation . . . . . . . . . . . . . . . . . . . . . . . . 161 11.7 FLASH Program/Read Operation . . . . . . . . . . . . . . . . . . . . . .162 11.8 FLASH Block Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . .163 11.9 Wait Mode. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166 11.10 STOP Mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 166 11.2 Introduction This section describes the operation of the embedded FLASH memory. This memory can be read, programmed, and erased from a single external supply. The program, erase, and read operations are enabled through the use of an internal charge pump. 11.3 Functional Description The FLASH memory is an array of 7,680 bytes for the MC68HC908GR8 or 4,096 bytes for the MC68HC908GR4 with an additional 36 bytes of user vectors and one byte used for block protection. An erased bit reads as logic 1 and a programmed bit reads as a logic 0. The program and erase operations are facilitated through control bits in the Flash Control MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Flash Memory 157 Flash Memory Register (FLCR). Details for these operations appear later in this section. The FLASH is organized internally as a 8192-word by 8-bit CMOS page erase, byte (8-bit) program Embedded Flash Memory. Each page consists of 64 bytes. The page erase operation erases all words within a page. A page is composed of two adjacent rows. The address ranges for the user memory and vectors are as follows: • $E000–$FDFF; user memory for the MC68HC908GR8 $EE00–$FDFF; user memory for the MC68HC908GR4. • $FF7E; FLASH block protect register. • $FE08; FLASH control register. • $FFDC–$FFFF; these locations are reserved for user-defined interrupt and reset vectors. Programming tools are available from Motorola. Contact your local Motorola representative for more information. NOTE: A security feature prevents viewing of the FLASH contents.(1) 1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or copying the FLASH difficult for unauthorized users. Technical Data 158 MC68HC908GR8 — Rev 4.0 Flash Memory MOTOROLA Flash Memory FLASH Control Register 11.4 FLASH Control Register The FLASH control register (FLCR) controls FLASH program and erase operations. Address: Read: $FE08 Bit 7 6 5 4 0 0 0 0 3 2 1 Bit 0 HVEN MASS ERASE PGM 0 0 0 0 Write: Reset: 0 0 0 0 Figure 11-1. FLASH Control Register (FLCR) HVEN — High-Voltage Enable Bit This read/write bit enables the charge pump to drive high voltages for program and erase operations in the array. HVEN can only be set if either PGM = 1 or ERASE = 1 and the proper sequence for program or erase is followed. 1 = High voltage enabled to array and charge pump on 0 = High voltage disabled to array and charge pump off MASS — Mass Erase Control Bit Setting this read/write bit configures the 8K byte FLASH array for mass erase operation. 1 = MASS erase operation selected 0 = MASS erase operation unselected ERASE — Erase Control Bit This read/write bit configures the memory for erase operation. ERASE is interlocked with the PGM bit such that both bits cannot be equal to 1 or set to 1 at the same time. 1 = Erase operation selected 0 = Erase operation unselected MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Flash Memory 159 Flash Memory PGM — Program Control Bit This read/write bit configures the memory for program operation. PGM is interlocked with the ERASE bit such that both bits cannot be equal to 1 or set to 1 at the same time. 1 = Program operation selected 0 = Program operation unselected 11.5 FLASH Page Erase Operation Use this step-by-step procedure to erase a page (64 bytes) of FLASH memory to read as logic 1: 1. Set the ERASE bit, and clear the MASS bit in the FLASH control register. 2. Read the FLASH block protect register. 3. Write any data to any FLASH address within the page address range desired. 4. Wait for a time, tnvs (min. 10µs) 5. Set the HVEN bit. 6. Wait for a time, tErase (min. 1ms) 7. Clear the ERASE bit. 8. Wait for a time, tnvh (min. 5µs) 9. Clear the HVEN bit. 10. After a time, trcv (typ. 1µs), the memory can be accessed again in read mode. NOTE: While these operations must be performed in the order shown, other unrelated operations may occur between the steps. Technical Data 160 MC68HC908GR8 — Rev 4.0 Flash Memory MOTOROLA Flash Memory FLASH Mass Erase Operation 11.6 FLASH Mass Erase Operation Use this step-by-step procedure to erase entire FLASH memory to read as logic 1: 1. Set both the ERASE bit, and the MASS bit in the FLASH control register. 2. Read from the FLASH block protect register. 3. Write any data to any FLASH address* within the FLASH memory address range. 4. Wait for a time, tnvs (min. 10µs) 5. Set the HVEN bit. 6. Wait for a time, tMErase (min. 4ms) 7. Clear the ERASE bit. 8. Wait for a time, tnvhl (min. 100µs) 9. Clear the HVEN bit. 10. After a time, trcv (min. 1µs), the memory can be accessed again in read mode. * When in Monitor mode, with security sequence failed Monitor ROM (MON), write to the FLASH block protect register instead of any FLASH address. NOTE: Programming and erasing of FLASH locations cannot be performed by code being executed from the FLASH memory. While these operations must be performed in the order shown, other unrelated operations may occur between the steps. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Flash Memory 161 Flash Memory 11.7 FLASH Program/Read Operation Programming of the FLASH memory is done on a row basis. A row consists of 32 consecutive bytes starting from addresses $XX00, $XX20, $XX40, $XX60, $XX80, $XXA0, $XXC0, and $XXE0. Use this step-by-step procedure to program a row of FLASH memory (Figure 112 is a flowchart representation): 1. Set the PGM bit. This configures the memory for program operation and enables the latching of address and data for programming. 2. Read from the FLASH block protect register. 3. Write any data to any FLASH address within the row address range desired. 4. Wait for a time, tnvs (min. 10µs). 5. Set the HVEN bit. 6. Wait for a time, tpgs (min. 5µs). 7. Write data to the FLASH address to be programmed.* 8. Wait for a time, tPROG (min. 30µs). 9. Repeat step 7 and 8 until all the bytes within the row are programmed. 10. Clear the PGM bit.* 11. Wait for a time, tnvh (min. 5µs). 12. Clear the HVEN bit. 13. After time, trcv (min. 1µs), the memory can be accessed in read mode again. * The time between each FLASH address change, or the time between the last FLASH address programmed to clearing PGM bit, must not exceed the maximum programming time, tPROG max. This program sequence is repeated throughout the memory until all data is programmed. Technical Data 162 MC68HC908GR8 — Rev 4.0 Flash Memory MOTOROLA Flash Memory FLASH Block Protection NOTE: Programming and erasing of FLASH locations cannot be performed by code being executed from the FLASH memory. While these operations must be performed in the order shown, other unrelated operations may occur between the steps. Do not exceed tPROG maximum. See Memory Characteristics. 11.8 FLASH Block Protection Due to the ability of the on-board charge pump to erase and program the FLASH memory in the target application, provision is made for protecting a block of memory from unintentional erase or program operations due to system malfunction. This protection is done by using of a FLASH Block Protect Register (FLBPR). The FLBPR determines the range of the FLASH memory which is to be protected. The range of the protected area starts from a location defined by FLBPR and ends at the bottom of the FLASH memory ($FFFF). When the memory is protected, the HVEN bit cannot be set in either ERASE or PROGRAM operations. NOTE: In performing a program or erase operation, the FLASH block protect register must be read after setting the PGM or ERASE bit and before asserting the HVEN bit When the FLBPR is programmed with all 0s, the entire memory is protected from being programmed and erased. When all the bits are erased (all 1s), the entire memory is accessible for program and erase. When bits within the FLBPR are programmed, they lock a block of memory with address ranges as shown in FLASH Block Protect Register. Once the FLBPR is programmed with a value other than $FF, any erase or program of the FLBPR or the protected block of FLASH memory is prohibited. The FLBPR itself can be erased or programmed only with an external voltage, VTST, present on the IRQ pin. This voltage also allows entry from reset into the monitor mode. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Flash Memory 163 Flash Memory 1 Algorithm for programming a row (32 bytes) of FLASH memory Set PGM bit 2 Read the FLASH block protect register 3 Write any data to any FLASH address within the row address range desired 4 Wait for a time, tnvs 5 Set HVEN bit 6 Wait for a time, tpgs 7 Write data to the FLASH address to be programmed 8 Wait for a time, tPROG Completed programming this row? Y N NOTE: The time between each FLASH address change (step 7 to step 7), or the time between the last FLASH address programmed to clearing PGM bit (step 7 to step 10) must not exceed the maximum programming time, tPROG max. 10 Clear PGM bit 11 Wait for a time, tnvh 12 Clear HVEN bit 13 Wait for a time, trcv This row program algorithm assumes the row/s to be programmed are initially erased. End of programming Figure 11-2. FLASH Programming Flowchart Technical Data 164 MC68HC908GR8 — Rev 4.0 Flash Memory MOTOROLA Flash Memory FLASH Block Protection 11.8.1 FLASH Block Protect Register The FLASH block protect register (FLBPR) is implemented as a byte within the FLASH memory, and therefore can only be written during a programming sequence of the FLASH memory. The value in this register determines the starting location of the protected range within the FLASH memory. Address: $FF7E Bit 7 6 5 4 3 2 1 Bit 0 BPR7 BPR6 BPR5 BPR4 BPR3 BPR2 BPR1 BPR0 U U U U U U U U Read: Write: Reset: U = Unaffected by reset. Initial value from factory is 1. Write to this register is by a programming sequence to the FLASH memory. Figure 11-3. FLASH Block Protect Register (FLBPR) BPR[7:0] — FLASH Block Protect Bits These eight bits represent bits [13:6] of a 16-bit memory address. Bits [15:14] are logic 1s and bits [5:0] are logic 0s. The resultant 16-bit address is used for specifying the start address of the FLASH memory for block protection. The FLASH is protected from this start address to the end of FLASH memory, at $FFFF. With this mechanism, the protect start address can be $XX00, $XX40, $XX80, and $XXC0 (64 bytes page boundaries) within the FLASH memory. 16-bit memory address Start address of FLASH block protect 1 1 FLBPR value 0 0 0 0 0 0 Figure 11-4. FLASH Block Protect Start Address MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Flash Memory 165 Flash Memory Examples of protect start address: Table 11-1. Examples of protect start address: BPR[7:0] Start of Address of Protect Range $80 The entire FLASH memory is protected. $81 (1000 0001) $E040 (1110 0000 0100 0000) $82 (1000 0010) $E080 (1110 0000 1000 0000) and so on... $FE (1111 1110) $FF80 (1111 1111 1000 0000) $FF The entire FLASH memory is not protected. Note: The end address of the protected range is always $FFFF. 11.9 Wait Mode Putting the MCU into wait mode while the FLASH is in read mode does not affect the operation of the FLASH memory directly, but there will not be any memory activity since the CPU is inactive. The WAIT instruction should not be executed while performing a program or erase operation on the FLASH, otherwise the operation will discontinue, and the FLASH will be on Standby Mode. 11.10 STOP Mode Putting the MCU into stop mode while the FLASH is in read mode does not affect the operation of the FLASH memory directly, but there will not be any memory activity since the CPU is inactive. The STOP instruction should not be executed while performing a program or erase operation on the FLASH, otherwise the operation will discontinue, and the FLASH will be on Standby Mode NOTE: Standby Mode is the power saving mode of the FLASH module in which all internal control signals to the FLASH are inactive and the current consumption of the FLASH is at a minimum. Technical Data 166 MC68HC908GR8 — Rev 4.0 Flash Memory MOTOROLA Technical Data — MC68HC908GR8 Section 12. External Interrupt (IRQ) 12.1 Contents 12.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167 12.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 167 12.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 168 12.5 IRQ1 Pin . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 170 12.6 IRQ Module During Break Interrupts . . . . . . . . . . . . . . . . . . .171 12.7 IRQ Status and Control Register . . . . . . . . . . . . . . . . . . . . . . 172 12.2 Introduction The IRQ (external interrupt) module provides a maskable interrupt input. 12.3 Features Features of the IRQ module include: • A dedicated external interrupt pin (IRQ1) • IRQ interrupt control bits • Hysteresis buffer • Programmable edge-only or edge and level interrupt sensitivity • Automatic interrupt acknowledge • Internal pullup resistor MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data External Interrupt (IRQ) 167 External Interrupt (IRQ) 12.4 Functional Description A logic 0 applied to the external interrupt pin can latch a CPU interrupt request. Figure 12-1 shows the structure of the IRQ module. Interrupt signals on the IRQ1 pin are latched into the IRQ latch. An interrupt latch remains set until one of the following actions occurs: • Vector fetch — A vector fetch automatically generates an interrupt acknowledge signal that clears the latch that caused the vector fetch. • Software clear — Software can clear an interrupt latch by writing to the appropriate acknowledge bit in the interrupt status and control register (INTSCR). Writing a logic 1 to the ACK bit clears the IRQ latch. • Reset — A reset automatically clears the interrupt latch. The external interrupt pin is falling-edge-triggered and is softwareconfigurable to be either falling-edge or falling-edge and low-leveltriggered. The MODE bit in the INTSCR controls the triggering sensitivity of the IRQ1 pin. When an interrupt pin is edge-triggered only, the interrupt remains set until a vector fetch, software clear, or reset occurs. When an interrupt pin is both falling-edge and low-level-triggered, the interrupt remains set until both of the following occur: • Vector fetch or software clear • Return of the interrupt pin to logic 1 The vector fetch or software clear may occur before or after the interrupt pin returns to logic 1. As long as the pin is low, the interrupt request remains pending. A reset will clear the latch and the MODE control bit, thereby clearing the interrupt even if the pin stays low. When set, the IMASK bit in the INTSCR mask all external interrupt requests. A latched interrupt request is not presented to the interrupt priority logic unless the IMASK bit is clear. Technical Data 168 MC68HC908GR8 — Rev 4.0 External Interrupt (IRQ) MOTOROLA External Interrupt (IRQ) Functional Description NOTE: The interrupt mask (I) in the condition code register (CCR) masks all interrupt requests, including external interrupt requests. INTERNAL ADDRESS BUS ACK RESET TO CPU FOR BIL/BIH INSTRUCTIONS VECTOR FETCH DECODER VDD INTERNAL PULLUP DEVICE VDD IRQF D IRQ1 CLR Q SYNCHRONIZER CK IRQ INTERRUPT REQUEST IRQ FF IMASK MODE TO MODE SELECT LOGIC HIGH VOLTAGE DETECT Figure 12-1. IRQ Module Block Diagram Addr. Register Name $001D Read: IRQ Status and Control Write: Register (INTSCR) Reset: Bit 7 6 5 4 3 2 0 0 0 0 IRQF 0 ACK 0 0 0 0 0 0 1 Bit 0 IMASK MODE 0 0 = Unimplemented Figure 12-2. IRQ I/O Register Summary MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data External Interrupt (IRQ) 169 External Interrupt (IRQ) 12.5 IRQ1 Pin A logic 0 on the IRQ1 pin can latch an interrupt request into the IRQ latch. A vector fetch, software clear, or reset clears the IRQ latch. If the MODE bit is set, the IRQ1 pin is both falling-edge-sensitive and low-level-sensitive. With MODE set, both of the following actions must occur to clear IRQ: • Vector fetch or software clear — A vector fetch generates an interrupt acknowledge signal to clear the latch. Software may generate the interrupt acknowledge signal by writing a logic 1 to the ACK bit in the interrupt status and control register (INTSCR). The ACK bit is useful in applications that poll the IRQ1 pin and require software to clear the IRQ latch. Writing to the ACK bit prior to leaving an interrupt service routine can also prevent spurious interrupts due to noise. Setting ACK does not affect subsequent transitions on the IRQ1 pin. A falling edge that occurs after writing to the ACK bit another interrupt request. If the IRQ mask bit, IMASK, is clear, the CPU loads the program counter with the vector address at locations $FFFA and $FFFB. • Return of the IRQ1 pin to logic 1 — As long as the IRQ1 pin is at logic 0, IRQ remains active. The vector fetch or software clear and the return of the IRQ1 pin to logic 1 may occur in any order. The interrupt request remains pending as long as the IRQ1 pin is at logic 0. A reset will clear the latch and the MODE control bit, thereby clearing the interrupt even if the pin stays low. If the MODE bit is clear, the IRQ1 pin is falling-edge-sensitive only. With MODE clear, a vector fetch or software clear immediately clears the IRQ latch. Technical Data 170 MC68HC908GR8 — Rev 4.0 External Interrupt (IRQ) MOTOROLA External Interrupt (IRQ) IRQ Module During Break Interrupts The IRQF bit in the INTSCR register can be used to check for pending interrupts. The IRQF bit is not affected by the IMASK bit, which makes it useful in applications where polling is preferred. Use the BIH or BIL instruction to read the logic level on the IRQ1 pin. NOTE: When using the level-sensitive interrupt trigger, avoid false interrupts by masking interrupt requests in the interrupt routine. 12.6 IRQ Module During Break Interrupts The BCFE bit in the SIM break flag control register (SBFCR) enables software to clear the latch during the break state. See Break Module (BRK). To allow software to clear the IRQ latch during a break interrupt, write a logic 1 to the BCFE bit. If a latch is cleared during the break state, it remains cleared when the MCU exits the break state. To protect CPU interrupt flags during the break state, write a logic 0 to the BCFE bit. With BCFE at logic 0 (its default state), writing to the ACK bit in the IRQ status and control register during the break state has no effect on the IRQ interrupt flags. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data External Interrupt (IRQ) 171 External Interrupt (IRQ) 12.7 IRQ Status and Control Register The IRQ status and control register (INTSCR) controls and monitors operation of the IRQ module. The INTSCR: • Shows the state of the IRQ flag • Clears the IRQ latch • Masks IRQ interrupt request • Controls triggering sensitivity of the IRQ1 interrupt pin Address: $001D Bit 7 6 5 4 Read: 3 2 IRQF 0 Write: Reset: 1 Bit 0 IMASK MODE 0 0 ACK 0 0 0 0 0 0 = Unimplemented Figure 12-3. IRQ Status and Control Register (INTSCR) IRQF — IRQ Flag Bit This read-only status bit is high when the IRQ interrupt is pending. 1 = IRQ interrupt pending 0 = IRQ interrupt not pending ACK — IRQ Interrupt Request Acknowledge Bit Writing a logic 1 to this write-only bit clears the IRQ latch. ACK always reads as logic 0. Reset clears ACK. IMASK — IRQ Interrupt Mask Bit Writing a logic 1 to this read/write bit disables IRQ interrupt requests. Reset clears IMASK. 1 = IRQ interrupt requests disabled 0 = IRQ interrupt requests enabled Technical Data 172 MC68HC908GR8 — Rev 4.0 External Interrupt (IRQ) MOTOROLA External Interrupt (IRQ) IRQ Status and Control Register MODE — IRQ Edge/Level Select Bit This read/write bit controls the triggering sensitivity of the IRQ1 pin. Reset clears MODE. 1 = IRQ1 interrupt requests on falling edges and low levels 0 = IRQ1 interrupt requests on falling edges only MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data External Interrupt (IRQ) 173 External Interrupt (IRQ) Technical Data 174 MC68HC908GR8 — Rev 4.0 External Interrupt (IRQ) MOTOROLA Technical Data — MC68HC908GR8 Section 13. Keyboard Interrupt (KBI) 13.1 Contents 13.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 13.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 175 13.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 176 13.5 Keyboard Initialization. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 179 13.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .180 13.7 Keyboard Module During Break Interrupts . . . . . . . . . . . . . . .180 13.8 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 181 13.2 Introduction The keyboard interrupt module (KBI) provides four independently maskable external interrupts. 13.3 Features • Four keyboard interrupt pins with separate keyboard interrupt enable bits and one keyboard interrupt mask • Hysteresis buffers • Programmable edge-only or edge- and level- interrupt sensitivity • Exit from low-power modes • I/O (input/output) port bit(s) software configurable with pullup device(s) if configured as input port bit(s) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Keyboard Interrupt (KBI) 175 Keyboard Interrupt (KBI) 13.4 Functional Description Writing to the KBIE3–KBIE0 bits in the keyboard interrupt enable register independently enables or disables each port A pin as a keyboard interrupt pin. Enabling a keyboard interrupt pin also enables its internal pullup device. A logic 0 applied to an enabled keyboard interrupt pin latches a keyboard interrupt request. A keyboard interrupt is latched when one or more keyboard pins goes low after all were high. The MODEK bit in the keyboard status and control register controls the triggering mode of the keyboard interrupt. • If the keyboard interrupt is edge-sensitive only, a falling edge on a keyboard pin does not latch an interrupt request if another keyboard pin is already low. To prevent losing an interrupt request on one pin because another pin is still low, software can disable the latter pin while it is low. • If the keyboard interrupt is falling-edge and low-level sensitive, an interrupt request is present as long as any keyboard interrupt pin is low and the pin is keyboard interrupt enabled. Technical Data 176 MC68HC908GR8 — Rev 4.0 Keyboard Interrupt (KBI) MOTOROLA Keyboard Interrupt (KBI) Functional Description INTERNAL BUS KBD0 ACKK VDD VECTOR FETCH DECODER KEYF RESET . TO PULLUP ENABLE D CLR Q SYNCHRONIZER . CK KB0IE KEYBOARD INTERRUPT REQUEST . KEYBOARD INTERRUPT FF KBD3 IMASKK MODEK TO PULLUP ENABLE KB3IE Figure 13-1. Keyboard Module Block Diagram Addr. $001A Register Name Read: Keyboard Status and Control Register Write: (INTKBSCR) Reset: Bit 7 6 5 4 3 2 0 0 0 0 KEYF 0 1 Bit 0 IMASKK MODEK ACKK 0 0 0 0 0 0 0 0 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 Read: $001B Keyboard Interrupt Enable Write: Register (INTKBIER) Reset: = Unimplemented Figure 13-2. I/O Register Summary MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Keyboard Interrupt (KBI) 177 Keyboard Interrupt (KBI) If the MODEK bit is set, the keyboard interrupt pins are both falling edgeand low-level sensitive, and both of the following actions must occur to clear a keyboard interrupt request: • Vector fetch or software clear — A vector fetch generates an interrupt acknowledge signal to clear the interrupt request. Software may generate the interrupt acknowledge signal by writing a logic 1 to the ACKK bit in the keyboard status and control register (INTKBSCR). The ACKK bit is useful in applications that poll the keyboard interrupt pins and require software to clear the keyboard interrupt request. Writing to the ACKK bit prior to leaving an interrupt service routine can also prevent spurious interrupts due to noise. Setting ACKK does not affect subsequent transitions on the keyboard interrupt pins. A falling edge that occurs after writing to the ACKK bit latches another interrupt request. If the keyboard interrupt mask bit, IMASKK, is clear, the CPU loads the program counter with the vector address at locations $FFDE and $FFDF. • Return of all enabled keyboard interrupt pins to logic 1 — As long as any enabled keyboard interrupt pin is at logic 0, the keyboard interrupt remains set. The vector fetch or software clear and the return of all enabled keyboard interrupt pins to logic 1 may occur in any order. If the MODEK bit is clear, the keyboard interrupt pin is falling-edgesensitive only. With MODEK clear, a vector fetch or software clear immediately clears the keyboard interrupt request. Reset clears the keyboard interrupt request and the MODEK bit, clearing the interrupt request even if a keyboard interrupt pin stays at logic 0. The keyboard flag bit (KEYF) in the keyboard status and control register can be used to see if a pending interrupt exists. The KEYF bit is not affected by the keyboard interrupt mask bit (IMASKK) which makes it useful in applications where polling is preferred. To determine the logic level on a keyboard interrupt pin, use the data direction register to configure the pin as an input and read the data register. Technical Data 178 MC68HC908GR8 — Rev 4.0 Keyboard Interrupt (KBI) MOTOROLA Keyboard Interrupt (KBI) Keyboard Initialization NOTE: Setting a keyboard interrupt enable bit (KBIEx) forces the corresponding keyboard interrupt pin to be an input, overriding the data direction register. However, the data direction register bit must be a logic 0 for software to read the pin. 13.5 Keyboard Initialization When a keyboard interrupt pin is enabled, it takes time for the internal pullup to reach a logic 1. Therefore, a false interrupt can occur as soon as the pin is enabled. To prevent a false interrupt on keyboard initialization: 1. Mask keyboard interrupts by setting the IMASKK bit in the keyboard status and control register. 2. Enable the KBI pins by setting the appropriate KBIEx bits in the keyboard interrupt enable register. 3. Write to the ACKK bit in the keyboard status and control register to clear any false interrupts. 4. Clear the IMASKK bit. An interrupt signal on an edge-triggered pin can be acknowledged immediately after enabling the pin. An interrupt signal on an edge- and level-triggered interrupt pin must be acknowledged after a delay that depends on the external load. Another way to avoid a false interrupt is: 1. Configure the keyboard pins as outputs by setting the appropriate DDRA bits in data direction register A. 2. Write logic 1s to the appropriate port A data register bits. 3. Enable the KBI pins by setting the appropriate KBIEx bits in the keyboard interrupt enable register. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Keyboard Interrupt (KBI) 179 Keyboard Interrupt (KBI) 13.6 Low-Power Modes The WAIT and STOP instructions put the MCU in low powerconsumption standby modes. 13.6.1 Wait Mode The keyboard module remains active in wait mode. Clearing the IMASKK bit in the keyboard status and control register enables keyboard interrupt requests to bring the MCU out of wait mode. 13.6.2 Stop Mode The keyboard module remains active in stop mode. Clearing the IMASKK bit in the keyboard status and control register enables keyboard interrupt requests to bring the MCU out of stop mode. 13.7 Keyboard Module During Break Interrupts The system integration module (SIM) controls whether the keyboard interrupt latch can be cleared during the break state. The BCFE bit in the SIM break flag control register (SBFCR) enables software to clear status bits during the break state. To allow software to clear the keyboard interrupt latch during a break interrupt, write a logic 1 to the BCFE bit. If a latch is cleared during the break state, it remains cleared when the MCU exits the break state. To protect the latch during the break state, write a logic 0 to the BCFE bit. With BCFE at logic 0 (its default state), writing to the keyboard acknowledge bit (ACKK) in the keyboard status and control register during the break state has no effect. See Keyboard Status and Control Register. Technical Data 180 MC68HC908GR8 — Rev 4.0 Keyboard Interrupt (KBI) MOTOROLA Keyboard Interrupt (KBI) I/O Registers 13.8 I/O Registers These registers control and monitor operation of the keyboard module: • Keyboard status and control register (INTKBSCR) • Keyboard interrupt enable register (INTKBIER) 13.8.1 Keyboard Status and Control Register The keyboard status and control register: • Flags keyboard interrupt requests • Acknowledges keyboard interrupt requests • Masks keyboard interrupt requests • Controls keyboard interrupt triggering sensitivity Address: $001A Read: Bit 7 6 5 4 3 2 0 0 0 0 KEYF 0 Write: Reset: 1 Bit 0 IMASKK MODEK 0 0 ACKK 0 0 0 0 0 0 = Unimplemented Figure 13-3. Keyboard Status and Control Register (INTKBSCR) Bits 7–4 — Not used These read-only bits always read as logic 0s. KEYF — Keyboard Flag Bit This read-only bit is set when a keyboard interrupt is pending. Reset clears the KEYF bit. 1 = Keyboard interrupt pending 0 = No keyboard interrupt pending MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Keyboard Interrupt (KBI) 181 Keyboard Interrupt (KBI) ACKK — Keyboard Acknowledge Bit Writing a logic 1 to this write-only bit clears the keyboard interrupt request. ACKK always reads as logic 0. Reset clears ACKK. IMASKK — Keyboard Interrupt Mask Bit Writing a logic 1 to this read/write bit prevents the output of the keyboard interrupt mask from generating interrupt requests. Reset clears the IMASKK bit. 1 = Keyboard interrupt requests masked 0 = Keyboard interrupt requests not masked MODEK — Keyboard Triggering Sensitivity Bit This read/write bit controls the triggering sensitivity of the keyboard interrupt pins. Reset clears MODEK. 1 = Keyboard interrupt requests on falling edges and low levels 0 = Keyboard interrupt requests on falling edges only 13.8.2 Keyboard Interrupt Enable Register The keyboard interrupt enable register enables or disables each port A pin to operate as a keyboard interrupt pin. Address: $001B Bit 7 6 5 4 3 2 1 Bit 0 KBIE3 KBIE2 KBIE1 KBIE0 0 0 0 0 Read: Write: Reset: Figure 13-4. Keyboard Interrupt Enable Register (INTKBIER) KBIE3–KBIE0 — Keyboard Interrupt Enable Bits Each of these read/write bits enables the corresponding keyboard interrupt pin to latch interrupt requests. Reset clears the keyboard interrupt enable register. 1 = PTAx pin enabled as keyboard interrupt pin 0 = PTAx pin not enabled as keyboard interrupt pin Technical Data 182 MC68HC908GR8 — Rev 4.0 Keyboard Interrupt (KBI) MOTOROLA Technical Data — MC68HC908GR8 Section 14. Low-Voltage Inhibit (LVI) 14.1 Contents 14.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183 14.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 183 14.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 184 14.5 LVI Status Register. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 187 14.6 LVI Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 188 14.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .188 14.2 Introduction This section describes the low-voltage inhibit (LVI) module, which monitors the voltage on the VDD pin and can force a reset when the VDD voltage falls below the LVI trip falling voltage, VTRIPF. 14.3 Features Features of the LVI module include: • Programmable LVI reset • Selectable LVI trip voltage • Programmable stop mode operation MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low-Voltage Inhibit (LVI) 183 Low-Voltage Inhibit (LVI) 14.4 Functional Description Figure 14-1 shows the structure of the LVI module. The LVI is enabled out of reset. The LVI module contains a bandgap reference circuit and comparator. Clearing the LVI power disable bit, LVIPWRD, enables the LVI to monitor VDD voltage. Clearing the LVI reset disable bit, LVIRSTD, enables the LVI module to generate a reset when VDD falls below the trip point voltage, VTRIPF. Setting the LVI enable in stop mode bit, LVISTOP, enables the LVI to operate in stop mode. Setting the LVI 5V or 3V trip point bit, LVI5OR3, enables VTRIPF to be configured for 5V operation. Clearing the LVI5OR3 bit enables VTRIPF to be configured for 3V operation. The actual trip points are shown in Electrical Specifications. NOTE: After a power-on reset (POR) the LVI’s default mode of operation is 3 V. If a 5V system is used, the user must set the LVI5OR3 bit to raise the trip point to 5V operation. Note that this must be done after every POR since the default will revert back to 3V mode after each POR. If the VDD supply is below the 5V mode trip voltage but above the 3V mode trip voltage when POR is released, the part will operate because VTRIPF defaults to 3V mode after a POR. So, in a 5V system care must be taken to ensure that VDD is above the 5V mode trip voltage after POR is released. NOTE: If the user requires 5V mode and sets the LVI5OR3 bit after a POR while the VDD supply is not above the VTRIPR for 5V mode, the MCU will immediately go into reset. The LVI in this case will hold the part in reset until either VDD goes above the rising 5V trip point, VTRIPR, which will release reset or VDD decreases to approximately 0 V which will re-trigger the POR and reset the trip point to 3V operation. Technical Data 184 MC68HC908GR8 — Rev 4.0 Low-Voltage Inhibit (LVI) MOTOROLA Low-Voltage Inhibit (LVI) Functional Description LVISTOP, LVIPWRD, LVI5OR3, and LVIRSTD are in the configuration register (MOR1). See Configuration Register (CONFIG) for details of the LVI’s configuration bits. Once an LVI reset occurs, the MCU remains in reset until VDD rises above a voltage, VTRIPR, which causes the MCU to exit reset. See Low-Voltage Inhibit (LVI) Reset for details of the interaction between the SIM and the LVI. The output of the comparator controls the state of the LVIOUT flag in the LVI status register (LVISR). An LVI reset also drives the RST pin low to provide low-voltage protection to external peripheral devices. VDD STOP INSTRUCTION LVISTOP FROM CONFIG FROM CONFIG LVIRSTD LVIPWRD FROM CONFIG LOW VDD DETECTOR VDD > LVITrip = 0 LVI RESET VDD ≤ LVITrip = 1 LVIOUT LVI5OR3 FROM CONFIG Figure 14-1. LVI Module Block Diagram MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low-Voltage Inhibit (LVI) 185 Low-Voltage Inhibit (LVI) Addr. $FE0C Register Name Bit 7 Read: LVIOUT LVI Status Register Write: (LVISR) Reset: 0 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 = Unimplemented Figure 14-2. LVI I/O Register Summary 14.4.1 Polled LVI Operation In applications that can operate at VDD levels below the VTRIPF level, software can monitor VDD by polling the LVIOUT bit. In the configuration register, the LVIPWRD bit must be at logic 0 to enable the LVI module, and the LVIRSTD bit must be at logic 1 to disable LVI resets. 14.4.2 Forced Reset Operation In applications that require VDD to remain above the VTRIPF level, enabling LVI resets allows the LVI module to reset the MCU when VDD falls below the VTRIPF level. In the configuration register, the LVIPWRD and LVIRSTD bits must be at logic 0 to enable the LVI module and to enable LVI resets. 14.4.3 Voltage Hysteresis Protection Once the LVI has triggered (by having VDD fall below VTRIPF), the LVI will maintain a reset condition until VDD rises above the rising trip point voltage, VTRIPR. This prevents a condition in which the MCU is continually entering and exiting reset if VDD is approximately equal to VTRIPF. VTRIPR is greater than VTRIPF by the hysteresis voltage, VHYS. Technical Data 186 MC68HC908GR8 — Rev 4.0 Low-Voltage Inhibit (LVI) MOTOROLA Low-Voltage Inhibit (LVI) LVI Status Register 14.4.4 LVI Trip Selection The LVI5OR3 bit in the configuration register selects whether the LVI is configured for 5V or 3V protection. NOTE: The microcontroller is guaranteed to operate at a minimum supply voltage. The trip point (VTRIPF [5 V] or VTRIPF [3 V]) may be lower than this. (See Electrical Specifications for the actual trip point voltages.) 14.5 LVI Status Register The LVI status register (LVISR) indicates if the VDD voltage was detected below the VTRIPF level. Address: $FE0C Bit 7 Read: LVIOUT 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Write: Reset: 0 = Unimplemented Figure 14-3. LVI Status Register (LVISR) LVIOUT — LVI Output Bit This read-only flag becomes set when the VDD voltage falls below the VTRIPF trip voltage. See Table 14-1. Reset clears the LVIOUT bit. Table 14-1. LVIOUT Bit Indication VDD LVIOUT VDD > VTRIPR 0 VDD < VTRIPF 1 VTRIPF < VDD < VTRIPR Previous value MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Low-Voltage Inhibit (LVI) 187 Low-Voltage Inhibit (LVI) 14.6 LVI Interrupts The LVI module does not generate interrupt requests. 14.7 Low-Power Modes The STOP and WAIT instructions put the MCU in low powerconsumption standby modes. 14.7.1 Wait Mode If enabled, the LVI module remains active in wait mode. If enabled to generate resets, the LVI module can generate a reset and bring the MCU out of wait mode. 14.7.2 Stop Mode If enabled in stop mode (LVISTOP set), the LVI module remains active in stop mode. If enabled to generate resets, the LVI module can generate a reset and bring the MCU out of stop mode. Technical Data 188 MC68HC908GR8 — Rev 4.0 Low-Voltage Inhibit (LVI) MOTOROLA Technical Data — MC68HC908GR8 Section 15. Monitor ROM (MON) 15.1 Contents 15.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 189 15.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 189 15.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 190 15.5 Security. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 202 15.2 Introduction This section describes the monitor ROM (MON) and the monitor mode entry methods. The monitor ROM allows complete testing of the MCU through a single-wire interface with a host computer. Monitor mode entry can be achieved without use of the higher test voltage, VTST, as long as vector addresses $FFFE and $FFFF are blank, thus reducing the hardware requirements for in-circuit programming. 15.3 Features Features of the monitor ROM include: • Normal user-mode pin functionality • One pin dedicated to serial communication between monitor ROM and host computer • Standard mark/space non-return-to-zero (NRZ) communication with host computer • Execution of code in RAM or FLASH MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 189 Monitor ROM (MON) • FLASH memory security feature(1) • FLASH memory programming interface • Enhanced PLL (phase-locked loop) option to allow use of external 32.768-kHz crystal to generate internal frequency of 2.4576 MHz • 310 byte monitor ROM code size ($FE20 to $FF55) • Monitor mode entry without high voltage, VTST, if reset vector is blank ($FFFE and $FFFF contain $FF) • Standard monitor mode entry if high voltage, VTST, is applied to IRQ 15.4 Functional Description The monitor ROM receives and executes commands from a host computer. Figure 15-1 shows an example circuit used to enter monitor mode and communicate with a host computer via a standard RS-232 interface. Simple monitor commands can access any memory address. In monitor mode, the MCU can execute code downloaded into RAM by a host computer while most MCU pins retain normal operating mode functions. All communication between the host computer and the MCU is through the PTA0 pin. A level-shifting and multiplexing interface is required between PTA0 and the host computer. PTA0 is used in a wired-OR configuration and requires a pullup resistor. 1. No security feature is absolutely secure. However, Motorola’s strategy is to make reading or copying the FLASH difficult for unauthorized users. Technical Data 190 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Monitor ROM (MON) Functional Description 68HC08 RST 0.1 µF VTST (SEE NOTE 3) RESET VECTORS $FFFE 10 kΩ (SEE NOTES 2 SW2 AND 3) C VDDA D $FFFF IRQ VDDA 0.033 µF SW3 (SEE NOTE 2) C 10 µF + MC145407 3 20 + D 10 MΩ 1 6–30 pF 10 µF 18 C 32.768 kHz XTAL 4 10 µF 17 330 kΩ + + 2 19 DB-25 2 5 16 3 6 15 10 µF VDD D SW4 (SEE NOTE 2) 0.01 µF CGMXFC 10 k OSC1 OSC2 PTA1 10 kΩ VSS 6–30 pF VSSAD/VREFL VSSA VDD VDD VDDAD/VREFH 0.1 µF 7 VDD 1 MC74HC125 14 2 3 6 5 VDD 10 kΩ PTA0 4 VDD 7 10 kΩ PTB0 PTB1 10 kΩ Notes: 1. SW2, SW3, and SW4: Position C — Enter monitor mode using external oscillator. SW2, SW3, and SW4: Position D — Enter monitor mode using external XTAL and internal PLL. 2. See . Monitor Mode Signal Requirements and Options for IRQ voltage level requirements. Figure 15-1. Monitor Mode Circuit MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 191 Monitor ROM (MON) The monitor code has been updated from previous versions to allow enabling the PLL to generate the internal clock, provided the reset vector is blank, when the device is being clocked by a low-frequency crystal. This addition, which is enabled when IRQ is held low out of rest, is intended to support serial communication/ programming at 9600 baud in monitor mode by stepping up the external frequency (assumed to be 32.768 kHz) by a fixed amount to generate the desired internal frequency (2.4576 MHz). Since this feature is enabled only when IRQ is held low out of reset, it cannot be used when the reset vector is not blank because entry into monitor mode in this case requires VTST on IRQ. 15.4.1 Entering Monitor Mode Table 15-1 shows the pin conditions for entering monitor mode. As specified in the table, monitor mode may be entered after a power-on reset (POR) and will allow communication at 9600 baud provided one of the following sets of conditions is met: 1. If $FFFE and $FFFF contain values not cared: – The external clock is 9.8304 MHz – IRQ = VTST (PLL off) 2. If $FFFE and $FFFF contain $FF, blank state: – The external clock is 9.8304 MHz – IRQ = VDD (this can be implemented through the internal IRQ pullup; PLL off) 3. If $FFFE and $FFFF contain $FF, blank state: – The external clock is 32.768 kHz (crystal) – IRQ = VSS (this setting initiates the PLL to boost the external 32.768 kHz to an internal bus frequency of 2.4576 MHz) Technical Data 192 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Monitor ROM (MON) Functional Description Table 15-1. Monitor Mode Signal Requirements and Options IRQ RESET $FFFE/ $FFFF X GND X VTST VDD or VTST X VDD VDD $FFFF GND VDD $FFFF PLL PTB0 PTB1 X X OFF 1 OFF X ON X External CGMOUT Clock(1) For Serial Communication Bus Freq COP 0 Disabled X X 0 0 9.8304 MHz 4.9152 MHz 2.4576 Disabled MHz 9.8304 MHz 4.9152 MHz 2.4576 Disabled MHz 32.768 kHz 4.9152 MHz 2.4576 Disabled MHz X X Baud PTA0 PTA1 Rate(2) (3) X X 0 1 0 9600 X 1 DNA 1 0 9600 X 1 DNA 1 0 9600 X 1 DNA Comment No operation until reset goes high PTB0 and PTB1 voltages only required if IRQ = VTST External frequency always divided by 4 PLL enabled (BCS set) in monitor code VDD or GND VTST $FFFF OFF X X X — — Enabled X X — Enters user mode — will encounter an illegal address reset VDD or GND VDD or VTST Not $FFFF OFF X X X — — Enabled X X — Enters user mode Notes: 1. External clock is derived by a 32.768 kHz crystal or a 9.8304 MHz off-chip oscillator 2. PTA0 = 1 if serial communication; PTA0 = X if parallel communication 3. PTA1 = 0 → serial, PTA1 = 1 → parallel communication for security code entry 4. DNA = does not apply, X = don’t care If entering monitor mode with VTST applied on IRQ (condition set 1), the CGMOUT frequency is equal to the CGMXCLK frequency and the OSC1 input directly generates internal bus clocks. In this case, the OSC1 signal must have a 50% duty cycle at maximum bus frequency. If entering monitor mode without high voltage applied on IRQ (condition set 2 or 3, where applied voltage is either VDD or VSS), then all port B pin MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 193 Monitor ROM (MON) requirements and conditions, are not in effect. This is to reduce circuit requirements when performing in-circuit programming. NOTE: If the reset vector is blank and monitor mode is entered, the chip will see an additional reset cycle after the initial POR reset. Once the part has been programmed, the traditional method of applying a voltage, VTST, to IRQ must be used to enter monitor mode. The COP module is disabled in monitor mode based on these conditions: • If monitor mode was entered as a result of the reset vector being blank (condition set 2 or 3), the COP is always disabled regardless of the state of IRQ or RST. • If monitor mode was entered with VTST on IRQ (condition set 1), then the COP is disabled as long as VTST is applied to either IRQ or RST. The second condition states that as long as VTST is maintained on the IRQ pin after entering monitor mode, or if VTST is applied to RST after the initial reset to get into monitor mode (when VTST was applied to IRQ), then the COP will be disabled. In the latter situation, after VTST is applied to the RST pin, VTST can be removed from the IRQ pin in the interest of freeing the IRQ for normal functionality in monitor mode. Figure 15-2 shows a simplified diagram of the monitor mode entry when the reset vector is blank and just 1 x VDD voltage is applied to the IRQ pin. An external oscillator of 9.8304 MHz is required for a baud rate of 9600, as the internal bus frequency is automatically set to the external frequency divided by four. Technical Data 194 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Monitor ROM (MON) Functional Description POR RESET IS VECTOR BLANK? NO NORMAL USER MODE YES MONITOR MODE EXECUTE MONITOR CODE POR TRIGGERED? NO YES Figure 15-2. Low-Voltage Monitor Mode Entry Flowchart Enter monitor mode with pin configuration shown in Figure 15-1 by pulling RST low and then high. The rising edge of RST latches monitor mode. Once monitor mode is latched, the values on the specified pins can change. Once out of reset, the MCU waits for the host to send eight security bytes. (See Security.) After the security bytes, the MCU sends a break signal (10 consecutive logic 0s) to the host, indicating that it is ready to receive a command. NOTE: The PTA1 pin must remain at logic 0 for 24 bus cycles after the RST pin goes high to enter monitor mode properly. In monitor mode, the MCU uses different vectors for reset, SWI (software interrupt), and break interrupt than those for user mode. The alternate vectors are in the $FE page instead of the $FF page and allow code execution from the internal monitor firmware instead of user code. NOTE: Exiting monitor mode after it has been initiated by having a blank reset vector requires a power-on reset. Pulling RST low will not exit monitor mode in this situation. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 195 Monitor ROM (MON) Table 15-2 summarizes the differences between user mode and monitor mode. Table 15-2. Mode Differences Functions Modes Reset Vector High Reset Vector Low Break Vector High Break Vector Low SWI Vector High SWI Vector Low User $FFFE $FFFF $FFFC $FFFD $FFFC $FFFD Monitor $FEFE $FEFF $FEFC $FEFD $FEFC $FEFD 15.4.2 Data Format Communication with the monitor ROM is in standard non-return-to-zero (NRZ) mark/space data format. Transmit and receive baud rates must be identical. START BIT 0 BIT BIT 1 BIT 2 BIT 3 BIT 4 BIT 5 BIT 6 BIT 7 NEXT START STOP BIT BIT Figure 15-3. Monitor Data Format 15.4.3 Break Signal A start bit (logic 0) followed by nine logic 0 bits is a break signal. When the monitor receives a break signal, it drives the PTA0 pin high for the duration of two bits and then echoes back the break signal. MISSING STOP BIT 2-STOP BIT DELAY BEFORE ZERO ECHO 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 Figure 15-4. Break Transaction Technical Data 196 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Monitor ROM (MON) Functional Description 15.4.4 Baud Rate The communication baud rate is controlled by the crystal frequency upon entry into monitor mode. The divide by ratio is 1024. If monitor mode was entered with VDD on IRQ, then the divide by ratio is also set at 1024. If monitor mode was entered with VSS on IRQ, then the internal PLL steps up the external frequency, presumed to be 32.768 kHz, to 2.4576 MHz. These latter two conditions for monitor mode entry require that the reset vector is blank. Table 15-3 lists external frequencies required to achieve a standard baud rate of 9600 BPS. Other standard baud rates can be accomplished using proportionally higher or lower frequency generators. If using a crystal as the clock source, be aware of the upper frequency limit that the internal clock module can handle. See 5.0 V Control Timing and 3.0 V Control Timing for this limit. Table 15-3. Monitor Baud Rate Selection External Frequency IRQ Internal Frequency Baud Rate (BPS) 9.8304 MHz VTST 2.4576 MHz 9600 9.8304 MHz VDD 2.4576 MHz 9600 32.768 kHz VSS 2.4576 MHz 9600 15.4.5 Commands The monitor ROM firmware uses these commands: • READ (read memory) • WRITE (write memory) • IREAD (indexed read) • IWRITE (indexed write) • READSP (read stack pointer) • RUN (run user program) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 197 Monitor ROM (MON) The monitor ROM firmware echoes each received byte back to the PTA0 pin for error checking. An 11-bit delay at the end of each command allows the host to send a break character to cancel the command. A delay of two bit times occurs before each echo and before READ, IREAD, or READSP data is returned. The data returned by a read command appears after the echo of the last byte of the command. NOTE: Wait one bit time after each echo before sending the next byte. FROM HOST READ 4 ADDRESS HIGH READ 4 1 ADDRESS HIGH 1 ADDRESS LOW 4 ADDRESS LOW DATA 1 3, 2 4 ECHO RETURN Notes: 1 = Echo delay, 2 bit times 2 = Data return delay, 2 bit times 3 = Cancel command delay, 11 bit times 4 = Wait 1 bit time before sending next byte. Figure 15-5. Read Transaction FROM HOST 3 ADDRESS HIGH WRITE WRITE 1 3 ADDRESS HIGH 1 ADDRESS LOW 3 ADDRESS LOW 1 DATA DATA 3 1 2, 3 ECHO Notes: 1 = Echo delay, 2 bit times 2 = Cancel command delay, 11 bit times 3 = Wait 1 bit time before sending next byte. Figure 15-6. Write Transaction Technical Data 198 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Monitor ROM (MON) Functional Description A brief description of each monitor mode command is given in Table 154 through Table 15-9. Table 15-4. READ (Read Memory) Command Description Read byte from memory Operand 2-byte address in high-byte:low-byte order Data Returned Returns contents of specified address Opcode $4A Command Sequence SENT TO MONITOR READ ADDRESS HIGH READ ADDRESS HIGH ADDRESS LOW ADDRESS LOW DATA ECHO RETURN Table 15-5. WRITE (Write Memory) Command Description Write byte to memory Operand 2-byte address in high-byte:low-byte order; low byte followed by data byte Data Returned None Opcode $49 Command Sequence FROM HOST WRITE WRITE ADDRESS HIGH ADDRESS HIGH ADDRESS LOW ADDRESS LOW DATA DATA ECHO MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 199 Monitor ROM (MON) Table 15-6. IREAD (Indexed Read) Command Description Read next 2 bytes in memory from last address accessed Operand 2-byte address in high byte:low byte order Data Returned Returns contents of next two addresses Opcode $1A Command Sequence FROM HOST IREAD IREAD DATA ECHO DATA RETURN Table 15-7. IWRITE (Indexed Write) Command Description Write to last address accessed + 1 Operand Single data byte Data Returned None Opcode $19 Command Sequence FROM HOST IWRITE IWRITE DATA DATA ECHO Technical Data 200 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Monitor ROM (MON) Functional Description A sequence of IREAD or IWRITE commands can access a block of memory sequentially over the full 64K byte memory map. Table 15-8. READSP (Read Stack Pointer) Command Description Reads stack pointer Operand None Data Returned Returns incremented stack pointer value (SP + 1) in high-byte:lowbyte order Opcode $0C Command Sequence FROM HOST READSP SP HIGH READSP ECHO SP LOW RETURN Table 15-9. RUN (Run User Program) Command Description Executes PULH and RTI instructions Operand None Data Returned None Opcode $28 Command Sequence FROM HOST RUN RUN ECHO MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 201 Monitor ROM (MON) The MCU executes the SWI and PSHH instructions when it enters monitor mode. The RUN command tells the MCU to execute the PULH and RTI instructions. Before sending the RUN command, the host can modify the stacked CPU registers to prepare to run the host program. The READSP command returns the incremented stack pointer value, SP + 1. The high and low bytes of the program counter are at addresses SP + 5 and SP + 6. SP HIGH BYTE OF INDEX REGISTER SP + 1 CONDITION CODE REGISTER SP + 2 ACCUMULATOR SP + 3 LOW BYTE OF INDEX REGISTER SP + 4 HIGH BYTE OF PROGRAM COUNTER SP + 5 LOW BYTE OF PROGRAM COUNTER SP + 6 SP + 7 Figure 15-7. Stack Pointer at Monitor Mode Entry 15.5 Security A security feature discourages unauthorized reading of FLASH locations while in monitor mode. The host can bypass the security feature at monitor mode entry by sending eight security bytes that match the bytes at locations $FFF6–$FFFD. Locations $FFF6–$FFFD contain userdefined data. NOTE: Do not leave locations $FFF6–$FFFD blank. For security reasons, they should be programmed even if they are not used for vectors. During monitor mode entry, the MCU waits after the power-on reset for the host to send the eight security bytes on pin PTA0. If the received bytes match those at locations $FFF6–$FFFD, the host bypasses the security feature and can read all FLASH locations and execute code from FLASH. Security remains bypassed until a power-on reset occurs. If the reset was not a power-on reset, security remains bypassed and security code entry is not required. (See Figure 15-8.) Technical Data 202 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Monitor ROM (MON) Security VDD 4096 + 32 CGMXCLK CYCLES RST 24 BUS CYCLES COMMAND PA1 BYTE 8 BYTE 2 BYTE 1 256 BUS CYCLES (MINIMUM) FROM HOST PA0 4 BREAK 2 NOTES: 1 = Echo delay, 2 bit times 2 = Data return delay, 2 bit times 4 = Wait 1 bit time before sending next byte. 1 COMMAND ECHO 1 BYTE 8 ECHO BYTE 1 ECHO FROM MCU 1 BYTE 2 ECHO 4 1 Figure 15-8. Monitor Mode Entry Timing Upon power-on reset, if the received bytes of the security code do not match the data at locations $FFF6–$FFFD, the host fails to bypass the security feature. The MCU remains in monitor mode, but reading a FLASH location returns an invalid value and trying to execute code from FLASH causes an illegal address reset. After receiving the eight security bytes from the host, the MCU transmits a break character, signifying that it is ready to receive a command. NOTE: The MCU does not transmit a break character until after the host sends the eight security bytes. To determine whether the security code entered is correct, check to see if bit 6 of RAM address $40 is set. If it is, then the correct security code has been entered and FLASH can be accessed. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Monitor ROM (MON) 203 Monitor ROM (MON) If the security sequence fails, the device can be reset and brought up in monitor mode to attempt another entry. After failing the security sequence, the FLASH mode can also be bulk erased by executing an erase routine that was downloaded into internal RAM. The bulk erase operation clears the security code locations so that all eight security bytes become $FF (blank). Technical Data 204 MC68HC908GR8 — Rev 4.0 Monitor ROM (MON) MOTOROLA Technical Data — MC68HC908GR8 Section 16. Input/Output Ports (I/O) 16.1 Contents 16.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 205 16.3 Port A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 209 16.4 Port B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 213 16.5 Port C . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 216 16.6 Port D . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 220 16.7 Port E . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 225 16.2 Introduction Twenty one (21) bidirectional input-output (I/O) pins form five parallel ports. All I/O pins are programmable as inputs or outputs. All individual bits within port A, port C, and port D are software configurable with pullup devices if configured as input port bits. The pullup devices are automatically and dynamically disabled when a port bit is switched to output mode. NOTE: Connect any unused I/O pins to an appropriate logic level, either VDD or VSS. Although the I/O ports do not require termination for proper operation, termination reduces excess current consumption and the possibility of electrostatic damage. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 205 Input/Output Ports (I/O) Addr. Bit 7 6 5 4 Read: Port A Data Register Write: (PTA) Reset: 0 0 0 0 Read: Port B Data Register Write: (PTB) Reset: 0 Read: Port C Data Register Write: (PTC) Reset: 0 Read: Port D Data Register Write: (PTD) Reset: 0 Read: Data Direction Register A $0004 Write: (DDRA) Reset: 0 0 0 Read: Data Direction Register B $0005 Write: (DDRB) Reset: 0 0 $0000 $0001 $0002 $0003 Register Name 3 2 1 Bit 0 PTA3 PTA2 PTA1 PTA0 PTB2 PTB1 PTB0 PTC1 PTC0 PTD2 PTD1 PTD0 DDRA3 DDRA2 DDRA1 DDRA0 Unaffected by reset 0 PTB5 PTB4 PTB3 Unaffected by reset 0 0 0 0 0 Unaffected by reset PTD6 PTD5 PTD4 PTD3 Unaffected by reset 0 0 0 0 0 0 0 0 0 DDRB5 DDRB4 DDRB3 DDRB2 DDRB1 DDRB0 0 0 DDRC1 DDRC0 0 0 0 0 0 0 Read: Data Direction Register C $0006 Write: (DDRC) Reset: 0 0 0 0 0 0 Read: Data Direction Register D $0007 Write: (DDRD) Reset: 0 0 0 0 0 0 0 0 0 0 DDRD6 DDRD5 DDRD4 DDRD3 DDRD2 DDRD1 DDRD0 0 0 0 0 0 0 0 = Unimplemented Figure 16-1. I/O Port Register Summary Technical Data 206 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Introduction Addr. Register Name Read: $0008 $000D $000E $000F 6 5 4 3 2 0 0 0 0 0 0 Port E Data Register Write: (PTE) Reset: Read: $000C Bit 7 Bit 0 PTE1 PTE0 DDRE1 DDRE0 0 0 Unaffected by reset 0 0 0 0 Data Direction Register E Write: (DDRE) Reset: 0 0 0 0 Read: 0 0 0 0 0 0 0 0 PTAPUE3 PTAPUE2 PTAPUE1 PTAPUE0 Port A Input Pullup Enable Write: Register (PTAPUE) Reset: 0 0 0 0 0 0 Read: 0 0 0 0 0 0 0 0 PTCPUE1 PTCPUE0 Port C Input Pullup Enable Write: Register (PTCPUE) Reset: 0 Read: 0 Port D Input Pullup Enable Write: Register (PTDPUE) Reset: 1 0 0 0 0 0 0 0 PTDPUE6 PTDPUE5 PTDPUE4 PTDPUE3 PTDPUE2 PTDPUE1 PTDPUE0 0 0 0 0 0 0 0 0 = Unimplemented Figure 16-1. I/O Port Register Summary (Continued) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 207 Input/Output Ports (I/O) Table 16-1. Port Control Register Bits Summary Port A B C D E Bit DDR Module Control 0 DDRA0 KBIE0 PTA0/KBD0 1 DDRA1 KBIE1 PTA1/KBD1 2 DDRA2 KBIE2 PTA2/KBD2 3 DDRA3 KBIE3 PTA3/KBD3 - -- - -- - -- - -- - -- - -- - -- - -- 0 DDRB0 CH0 PTB0/ATD0 1 DDRB1 CH1 PTB1/ATD1 2 DDRB2 CH2 PTB2/ATD2 3 DDRB3 CH3 PTB3/ATD3 4 DDRB4 CH4 PTB4/ATD4 5 DDRB5 CH5 PTB5/ATD5 - -- - -- - -- - -- 0 DDRC0 PTC0 1 DDRC1 PTC1 - -- -- - -- -- - -- -- - -- -- - -- -- 0 DDRD0 PTD0/SS 1 DDRD1 2 DDRD2 3 DDRD3 4 DDRD4 5 DDRD5 6 DDRD6 - -- 0 DDRE0 1 DDRE1 KBD ADC SPI PTD1/MISO PTD2/MOSI PTD3/SPSCK TIM1 TIM2 SCI Technical Data 208 Pin PTD4/T1CH0 PTD5/T1CH1 PTD6/T2CH0 -PTE0/TxD PTE1/RxD MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port A 16.3 Port A Port A is an 4-bit special-function port that shares all four of its pins with the keyboard interrupt (KBI) module. Port A also has software configurable pullup devices if configured as an input port. 16.3.1 Port A Data Register The port A data register (PTA) contains a data latch for each of the four port A pins. Address: Read: $0000 Bit 7 6 5 4 0 0 0 0 3 2 1 Bit 0 PTA3 PTA2 PTA1 PTA0 KBD2 KBD1 KBD0 Write: Reset: Unaffected by reset Alternate Function: KBD3 Figure 16-2. Port A Data Register (PTA) PTA3–PTA0 — Port A Data Bits These read/write bits are software programmable. Data direction of each port A pin is under the control of the corresponding bit in data direction register A. Reset has no effect on port A data. KBD3–KBD0 — Keyboard Inputs The keyboard interrupt enable bits, KBIE3–KBIE0, in the keyboard interrupt control register (KBICR) enable the port A pins as external interrupt pins. See Keyboard Interrupt (KBI). MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 209 Input/Output Ports (I/O) 16.3.2 Data Direction Register A Data direction register A (DDRA) determines whether each port A pin is an input or an output. Writing a logic 1 to a DDRA bit enables the output buffer for the corresponding port A pin; a logic 0 disables the output buffer. Address: Read: $0004 Bit 7 6 5 4 0 0 0 0 3 2 1 Bit 0 DDRA3 DDRA2 DDRA1 DDRA0 0 0 0 0 Write: Reset: 0 0 0 0 Figure 16-3. Data Direction Register A (DDRA) DDRA3–DDRA0 — Data Direction Register A Bits These read/write bits control port A data direction. Reset clears DDRA3–DDRA0, configuring all port A pins as inputs. 1 = Corresponding port A pin configured as output 0 = Corresponding port A pin configured as input NOTE: Avoid glitches on port A pins by writing to the port A data register before changing data direction register A bits from 0 to 1. Figure 16-4 shows the port A I/O logic. Technical Data 210 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port A READ DDRA ($0004) INTERNAL DATA BUS WRITE DDRA ($0004) DDRAx RESET WRITE PTA ($0000) PTAx PTAx VDD PTAPUEx READ PTA ($0000) INTERNAL PULLUP DEVICE Figure 16-4. Port A I/O Circuit When bit DDRAx is a logic 1, reading address $0000 reads the PTAx data latch. When bit DDRAx is a logic 0, reading address $0000 reads the voltage level on the pin. The data latch can always be written, regardless of the state of its data direction bit. Table 16-2 summarizes the operation of the port A pins. Table 16-2. Port A Pin Functions Accesses to DDRA PTAPUE Bit DDRA Bit PTA Bit Accesses to PTA I/O Pin Mode Read/Write Read Write 1 0 X(1) Input, VDD(4) DDRA3–DDRA0 Pin PTA3–PTA0(3 0 0 X Input, Hi-Z(2) DDRA3–DDRA0 Pin PTA3–PTA0(3 X 1 X Output DDRA3–DDRA0 PTA3–PTA0 PTA3–PTA0 ) ) NOTES: 1. X = Don’t care 2. Hi-Z = High impedance 3. Writing affects data register, but does not affect input. 4. I/O pin pulled up to VDD by internal pullup device MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 211 Input/Output Ports (I/O) 16.3.3 Port A Input Pullup Enable Register The port A input pullup enable register (PTAPUE) contains a software configurable pullup device for each of the four port A pins. Each bit is individually configurable and requires that the data direction register, DDRA, bit be configured as an input. Each pullup is automatically and dynamically disabled when a port bit’s DDRA is configured for output mode. Address: Read: $000D Bit 7 6 5 4 0 0 0 0 3 2 1 Bit 0 PTAPUE3 PTAPUE2 PTAPUE1 PTAPUE0 Write: Reset: 0 0 0 0 0 0 0 0 Figure 16-5. Port A Input Pullup Enable Register (PTAPUE) PTAPUE3–PTAPUE0 — Port A Input Pullup Enable Bits These writeable bits are software programmable to enable pullup devices on an input port bit. 1 = Corresponding port A pin configured to have internal pullup 0 = Corresponding port A pin has internal pullup disconnected Technical Data 212 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port B 16.4 Port B Port B is an 6-bit special-function port that shares all six of its pins with the analog-to-digital converter (ADC) module. 16.4.1 Port B Data Register The port B data register (PTB) contains a data latch for each of the six port pins. Address: Read: Write: $0001 Bit 7 6 0 0 5 4 3 2 1 Bit 0 PTB5 PTB4 PTB3 PTB2 PTB1 PTB0 AD2 AD1 AD0 Reset: Alternate Function: Unaffected by reset AD5 AD4 AD3 Figure 16-6. Port B Data Register (PTB) PTB5–PTB0 — Port B Data Bits These read/write bits are software-programmable. Data direction of each port B pin is under the control of the corresponding bit in data direction register B. Reset has no effect on port B data. AD5–AD0 — Analog-to-Digital Input Bits AD5–AD0 are pins used for the input channels to the analog-to-digital converter module. The channel select bits in the ADC status and control register define which port B pin will be used as an ADC input and overrides any control from the port I/O logic by forcing that pin as the input to the analog circuitry. NOTE: Care must be taken when reading port B while applying analog voltages to AD5–AD0 pins. If the appropriate ADC channel is not enabled, excessive current drain may occur if analog voltages are applied to the PTBx/ADx pin, while PTB is read as a digital input. Those ports not selected as analog input channels are considered digital I/O ports. NOTE: PTB4 and 5 are not available in a 28-pin DIP and SOIC package MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 213 Input/Output Ports (I/O) 16.4.2 Data Direction Register B Data direction register B (DDRB) determines whether each port B pin is an input or an output. Writing a logic 1 to a DDRB bit enables the output buffer for the corresponding port B pin; a logic 0 disables the output buffer. Address: Read: $0005 Bit 7 6 0 0 5 4 3 2 1 Bit 0 DDRB5 DDRB4 DDRB3 DDRB2 DDRB1 DDRB0 0 0 0 0 0 0 Write: Reset: 0 0 Figure 16-7. Data Direction Register B (DDRB) DDRB5–DDRB0 — Data Direction Register B Bits These read/write bits control port B data direction. Reset clears DDRB5–DDRB0], configuring all port B pins as inputs. 1 = Corresponding port B pin configured as output 0 = Corresponding port B pin configured as input NOTE: Avoid glitches on port B pins by writing to the port B data register before changing data direction register B bits from 0 to 1. NOTE: For those devices packaged in a 28-pin DIP and SOIC package, PTB5,4 are not connected. Set DDRB5,4 to a 1 to configure PTB5,4 as outputs. Figure 16-8 shows the port B I/O logic. Technical Data 214 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port B INTERNAL DATA BUS READ DDRB ($0005) WRITE DDRB ($0005) RESET DDRBx WRITE PTB ($0001) PTBx PTBx READ PTB ($0001) Figure 16-8. Port B I/O Circuit When bit DDRBx is a logic 1, reading address $0001 reads the PTBx data latch. When bit DDRBx is a logic 0, reading address $0001 reads the voltage level on the pin. The data latch can always be written, regardless of the state of its data direction bit. Table 16-3 summarizes the operation of the port B pins. Table 16-3. Port B Pin Functions DDRB Bit PTB Bit I/O Pin Mode Accesses to DDRB Accesses to PTB Read/Write Read Write 0 X(1) Input, Hi-Z(2) DDRB5–DDRB0 Pin PTB5–PTB0(3) 1 X Output DDRB5–DDRB0 PTB5–PTB0 PTB5–PTB0 Notes: 1. X = Don’t care 2. Hi-Z = High impedance 3. Writing affects data register, but does not affect input. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 215 Input/Output Ports (I/O) 16.5 Port C Port C is a 2-bit, general-purpose bidirectional I/O port. Port C also has software configurable pullup devices if configured as an input port. 16.5.1 Port C Data Register The port C data register (PTC) contains a data latch for each of the two port C pins. Address: Read: $0002 Bit 7 6 5 4 3 2 0 0 0 0 0 0 1 Bit 0 PTC1 PTC0 Write: Reset: Unaffected by reset = Unimplemented Figure 16-9. Port C Data Register (PTC) PTC1–PTC0 — Port C Data Bits These read/write bits are software-programmable. Data direction of each port C pin is under the control of the corresponding bit in data direction register C. Reset has no effect on port C data. NOTE: PTC is not available in a 28-pin DIP and SOIC package Technical Data 216 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port C 16.5.2 Data Direction Register C Data direction register C (DDRC) determines whether each port C pin is an input or an output. Writing a logic 1 to a DDRC bit enables the output buffer for the corresponding port C pin; a logic 0 disables the output buffer. Address: Read: $0006 Bit 7 6 5 4 3 2 0 0 0 0 0 0 1 Bit 0 DDRC1 DDRC0 0 0 Write: Reset: 0 0 0 0 0 0 = Unimplemented Figure 16-10. Data Direction Register C (DDRC) DDRC1–DDRC0 — Data Direction Register C Bits These read/write bits control port C data direction. Reset clears DDRC1–DDRC0, configuring all port C pins as inputs. 1 = Corresponding port C pin configured as output 0 = Corresponding port C pin configured as input NOTE: Avoid glitches on port C pins by writing to the port C data register before changing data direction register C bits from 0 to 1. Figure 16-11 shows the port C I/O logic. NOTE: For those devices packaged in a 28-pin DIP and SOIC package, PTC1,0 are not connected. Set DDRC1,0 to a 1 to configure PTC1,0 as outputs. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 217 Input/Output Ports (I/O) READ DDRC ($0006) INTERNAL DATA BUS WRITE DDRC ($0006) DDRCx RESET WRITE PTC ($0002) PTCx PTCx VDD PTCPUEx READ PTC ($0002) INTERNAL PULLUP DEVICE Figure 16-11. Port C I/O Circuit When bit DDRCx is a logic 1, reading address $0002 reads the PTCx data latch. When bit DDRCx is a logic 0, reading address $0002 reads the voltage level on the pin. The data latch can always be written, regardless of the state of its data direction bit. Table 16-4 summarizes the operation of the port C pins. Table 16-4. Port C Pin Functions Accesses to DDRC PTCPUE Bit DDRC Bit PTC Bit Accesses to PTC I/O Pin Mode Read/Write Read Write 1 0 X(1) Input, VDD(4) DDRC1–DDRC0 Pin PTC1–PTC0(3) 0 0 X Input, Hi-Z(2) DDRC1–DDRC0 Pin PTC1–PTC0(3) X 1 X Output DDRC1–DDRC0 PTC1–PTC0 PTC1–PTC0 Notes: 1. X = Don’t care 2. Hi-Z = High impedance 3. Writing affects data register, but does not affect input. 4. I/O pin pulled up to VDD by internal pullup device. Technical Data 218 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port C 16.5.3 Port C Input Pullup Enable Register The port C input pullup enable register (PTCPUE) contains a software configurable pullup device for each of the two port C pins. Each bit is individually configurable and requires that the data direction register, DDRC, bit be configured as an input. Each pullup is automatically and dynamically disabled when a port bit’s DDRC is configured for output mode. Address: Read: $000E Bit 7 6 5 4 3 2 0 0 0 0 0 0 1 Bit 0 PTCPUE1 PTCPUE0 Write: Reset: 0 0 0 0 0 0 0 0 = Unimplemented Figure 16-12. Port C Input Pullup Enable Register (PTCPUE) PTCPUE1–PTCPUE0 — Port C Input Pullup Enable Bits These writeable bits are software programmable to enable pullup devices on an input port bit. 1 = Corresponding port C pin configured to have internal pullup 0 = Corresponding port C pin internal pullup disconnected MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 219 Input/Output Ports (I/O) 16.6 Port D Port D is an 7-bit special-function port that shares four of its pins with the serial peripheral interface (SPI) module and three of its pins with two timer interface (TIM1 and TIM2) modules. Port D also has software configurable pullup devices if configured as an input port. 16.6.1 Port D Data Register The port D data register (PTD) contains a data latch for each of the seven port D pins. . Address: $0003 Bit 7 Read: 6 5 4 3 2 1 Bit 0 PTD6 PTD5 PTD4 PTD3 PTD2 PTD1 PTD0 MOSI MISO SS 0 Write: Reset: Alternate Function: Unaffected by reset T2CH0 T1CH1 T1CH0 SPSCK Figure 16-13. Port D Data Register (PTD) PTD6–PTD0 — Port D Data Bits These read/write bits are software-programmable. Data direction of each port D pin is under the control of the corresponding bit in data direction register D. Reset has no effect on port D data. T2CH0 — Timer 2 Channel I/O Bits The PTD6/T2CH0 pin is the TIM2 input capture/output compare pin. The edge/level select bits, ELSxB:ELSxA, determine whether the PTD6/T2CH0 pin is a timer channel I/O pin or a general-purpose I/O pin. See Timer Interface Module (TIM). Technical Data 220 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port D T1CH1 and T1CH0 — Timer 1 Channel I/O Bits The PTD5/T1CH1–PTD4/T1CH0 pins are the TIM1 input capture/output compare pins. The edge/level select bits, ELSxB and ELSxA, determine whether the PTD5/T1CH1–PTD4/T1CH0 pins are timer channel I/O pins or general-purpose I/O pins. See Timer Interface Module (TIM). SPSCK — SPI Serial Clock The PTD3/SPSCK pin is the serial clock input of the SPI module. When the SPE bit is clear, the PTD3/SPSCK pin is available for general-purpose I/O. MOSI — Master Out/Slave In The PTD2/MOSI pin is the master out/slave in terminal of the SPI module. When the SPE bit is clear, the PTD2/MOSI pin is available for general-purpose I/O. MISO — Master In/Slave Out The PTD1/MISO pin is the master in/slave out terminal of the SPI module. When the SPI enable bit, SPE, is clear, the SPI module is disabled, and the PTD0/SS pin is available for general-purpose I/O. Data direction register D (DDRD) does not affect the data direction of port D pins that are being used by the SPI module. However, the DDRD bits always determine whether reading port D returns the states of the latches or the states of the pins. See Table 16-5. SS — Slave Select The PTD0/SS pin is the slave select input of the SPI module. When the SPE bit is clear, or when the SPI master bit, SPMSTR, is set, the PTD0/SS pin is available for general-purpose I/O. When the SPI is enabled, the DDRB0 bit in data direction register B (DDRB) has no effect on the PTD0/SS pin. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 221 Input/Output Ports (I/O) 16.6.2 Data Direction Register D Data direction register D (DDRD) determines whether each port D pin is an input or an output. Writing a logic 1 to a DDRD bit enables the output buffer for the corresponding port D pin; a logic 0 disables the output buffer. Address: $0007 Bit 7 Read: 6 5 4 3 2 1 Bit 0 DDRD6 DDRD5 DDRD4 DDRD3 DDRD2 DDRD1 DDRD0 0 0 0 0 0 0 0 0 Write: Reset: 0 Figure 16-14. Data Direction Register D (DDRD) DDRD6–DDRD0 — Data Direction Register D Bits These read/write bits control port D data direction. Reset clears DDRD6–DDRD0, configuring all port D pins as inputs. 1 = Corresponding port D pin configured as output 0 = Corresponding port D pin configured as input NOTE: Avoid glitches on port D pins by writing to the port D data register before changing data direction register D bits from 0 to 1. Figure 16-15 shows the port D I/O logic. Technical Data 222 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port D READ DDRD ($0007) INTERNAL DATA BUS WRITE DDRD ($0007) DDRDx RESET WRITE PTD ($0003) PTDx PTDx VDD PTDPUEx READ PTD ($0003) INTERNAL PULLUP DEVICE Figure 16-15. Port D I/O Circuit When bit DDRDx is a logic 1, reading address $0003 reads the PTDx data latch. When bit DDRDx is a logic 0, reading address $0003 reads the voltage level on the pin. The data latch can always be written, regardless of the state of its data direction bit. Table 16-5 summarizes the operation of the port D pins. Table 16-5. Port D Pin Functions Accesses to DDRD PTDPUE Bit DDRD Bit PTD Bit Accesses to PTD I/O Pin Mode Read/Write Read Write 1 0 X(1) Input, VDD(4) DDRD6–DDRD0 Pin PTD6–PTD0(3) 0 0 X Input, Hi-Z(2) DDRD6–DDRD0 Pin PTD6–PTD0(3) X 1 X Output DDRD6–DDRD0 PTD6–PTD0 PTD6–PTD0 Notes: 1. X = Don’t care 2. Hi-Z = High impedance 3. Writing affects data register, but does not affect input. 4. I/O pin pulled up to VDD by internal pullup device. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 223 Input/Output Ports (I/O) 16.6.3 Port D Input Pullup Enable Register The port D input pullup enable register (PTDPUE) contains a software configurable pullup device for each of the seven port D pins. Each bit is individually configurable and requires that the data direction register, DDRD, bit be configured as an input. Each pullup is automatically and dynamically disabled when a port bit’s DDRD is configured for output mode. Address: $000F Bit 7 Read: 6 5 4 3 2 1 Bit 0 0 PTDPUE6 PTDPUE5 PTDPUE4 PTDPUE3 PTDPUE2 PTDPUE1 PTDPUE0 Write: Reset: 0 0 0 0 0 0 0 0 Figure 16-16. Port D Input Pullup Enable Register (PTDPUE) PTDPUE6–PTDPUE0 — Port D Input Pullup Enable Bits These writeable bits are software programmable to enable pullup devices on an input port bit. 1 = Corresponding port D pin configured to have internal pullup 0 = Corresponding port D pin has internal pullup disconnected Technical Data 224 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port E 16.7 Port E Port E is a 2-bit special-function port that shares two of its pins with the serial communications interface (SCI) module. 16.7.1 Port E Data Register The port E data register contains a data latch for each of the two port E pins. Address: Read: $0008 Bit 7 6 5 4 3 2 0 0 0 0 0 0 1 Bit 0 PTE1 PTE0 RxD TxD Write: Reset: Unaffected by reset Alternate Function: = Unimplemented Figure 16-17. Port E Data Register (PTE) PTE1 and PTE0 — Port E Data Bits PTE1 and PTE0 are read/write, software programmable bits. Data direction of each port E pin is under the control of the corresponding bit in data direction register E. NOTE: Data direction register E (DDRE) does not affect the data direction of port E pins that are being used by the SCI module. However, the DDRE bits always determine whether reading port E returns the states of the latches or the states of the pins. See Table 16-6. RxD — SCI Receive Data Input The PTE1/RxD pin is the receive data input for the SCI module. When the enable SCI bit, ENSCI, is clear, the SCI module is disabled, and the PTE1/RxD pin is available for general-purpose I/O. See Serial Communications Interface (SCI). MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 225 Input/Output Ports (I/O) TxD — SCI Transmit Data Output The PTE0/TxD pin is the transmit data output for the SCI module. When the enable SCI bit, ENSCI, is clear, the SCI module is disabled, and the PTE0/TxD pin is available for general-purpose I/O. See Serial Communications Interface (SCI). 16.7.2 Data Direction Register E Data direction register E (DDRE) determines whether each port E pin is an input or an output. Writing a logic 1 to a DDRE bit enables the output buffer for the corresponding port E pin; a logic 0 disables the output buffer. Address: Read: $000C Bit 7 6 5 4 3 2 0 0 0 0 0 0 1 Bit 0 DDRE1 DDRE0 0 0 Write: Reset: 0 0 0 0 0 0 = Unimplemented Figure 16-18. Data Direction Register E (DDRE) DDRE1 and DDRE0 — Data Direction Register E Bits These read/write bits control port E data direction. Reset clears DDRE1 and DDRE0, configuring all port E pins as inputs. 1 = Corresponding port E pin configured as output 0 = Corresponding port E pin configured as input NOTE: Avoid glitches on port E pins by writing to the port E data register before changing data direction register E bits from 0 to 1. Figure 16-19 shows the port E I/O logic. Technical Data 226 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Input/Output Ports (I/O) Port E INTERNAL DATA BUS READ DDRE ($000C) WRITE DDRE ($000C) RESET DDREx WRITE PTE ($0008) PTEx PTEx READ PTE ($0008) Figure 16-19. Port E I/O Circuit When bit DDREx is a logic 1, reading address $0008 reads the PTEx data latch. When bit DDREx is a logic 0, reading address $0008 reads the voltage level on the pin. The data latch can always be written, regardless of the state of its data direction bit. Table 16-6 summarizes the operation of the port E pins. Table 16-6. Port E Pin Functions Accesses to DDRE DDRE Bit PTE Bit Accesses to PTE I/O Pin Mode Read/Write Read Write 0 X(1) Input, Hi-Z(2) DDRE1–DDRE0 Pin PTE1–PTE0(3) 1 X Output DDRE1–DDRE0] PTE1–PTE0 PTE1–PTE0 Notes: 1. X = Don’t care 2. Hi-Z = High impedance 3. Writing affects data register, but does not affect input. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Input/Output Ports (I/O) 227 Input/Output Ports (I/O) Technical Data 228 MC68HC908GR8 — Rev 4.0 Input/Output Ports (I/O) MOTOROLA Technical Data — MC68HC908GR8 Section 17. RAM 17.1 Contents 17.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 229 17.3 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 229 17.2 Introduction This section describes the 384 bytes of RAM (random-access memory). 17.3 Functional Description Addresses $0040 through $01BF are RAM locations. The location of the stack RAM is programmable. The 16-bit stack pointer allows the stack to be anywhere in the 64K byte memory space. NOTE: For correct operation, the stack pointer must point only to RAM locations. Within page zero are 192 bytes of RAM. Because the location of the stack RAM is programmable, all page zero RAM locations can be used for I/O control and user data or code. When the stack pointer is moved from its reset location at $00FF out of page zero, direct addressing mode instructions can efficiently access all page zero RAM locations. Page zero RAM, therefore, provides ideal locations for frequently accessed global variables. Before processing an interrupt, the CPU uses five bytes of the stack to save the contents of the CPU registers. NOTE: For M6805 compatibility, the H register is not stacked. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data RAM 229 RAM During a subroutine call, the CPU uses two bytes of the stack to store the return address. The stack pointer decrements during pushes and increments during pulls. NOTE: Be careful when using nested subroutines. The CPU may overwrite data in the RAM during a subroutine or during the interrupt stacking operation. Technical Data 230 MC68HC908GR8 — Rev 4.0 RAM MOTOROLA Technical Data — MC68HC908GR8 Section 18. Serial Communications Interface (SCI) 18.1 Contents 18.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 231 18.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 232 18.4 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 233 18.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 233 18.6 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .250 18.7 SCI During Break Module Interrupts. . . . . . . . . . . . . . . . . . . . 251 18.8 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 251 18.9 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 252 18.2 Introduction This section describes the serial communications interface (SCI) module, which allows high-speed asynchronous communications with peripheral devices and other MCUs. NOTE: References to DMA (direct-memory access) and associated functions are only valid if the MCU has a DMA module. This MCU does not have the DMA function. Any DMA-related register bits should be left in their reset state for normal MCU operation. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 231 Serial Communications Interface (SCI) 18.3 Features Features of the SCI module include: • Full-duplex operation • Standard mark/space non-return-to-zero (NRZ) format • 32 programmable baud rates • Programmable 8-bit or 9-bit character length • Separately enabled transmitter and receiver • Separate receiver and transmitter CPU interrupt requests • Programmable transmitter output polarity • Two receiver wakeup methods: – Idle line wakeup – Address mark wakeup • Interrupt-driven operation with eight interrupt flags: – Transmitter empty – Transmission complete – Receiver full – Idle receiver input – Receiver overrun – Noise error – Framing error – Parity error • Receiver framing error detection • Hardware parity checking • 1/16 bit-time noise detection • Configuration register bit, SCIBDSRC, to allow selection of baud rate clock source Technical Data 232 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Pin Name Conventions 18.4 Pin Name Conventions The generic names of the SCI I/O pins are: • RxD (receive data) • TxD (transmit data) SCI I/O (input/output) lines are implemented by sharing parallel I/O port pins. The full name of an SCI input or output reflects the name of the shared port pin. Table 18-1 shows the full names and the generic names of the SCI I/O pins. The generic pin names appear in the text of this section. Table 18-1. Pin Name Conventions Generic Pin Names: RxD TxD Full Pin Names: PE1/RxD PE0/TxD 18.5 Functional Description Figure 18-1 shows the structure of the SCI module. The SCI allows fullduplex, asynchronous, NRZ serial communication among the MCU and remote devices, including other MCUs. The transmitter and receiver of the SCI operate independently, although they use the same baud rate generator. During normal operation, the CPU monitors the status of the SCI, writes the data to be transmitted, and processes received data. The baud rate clock source for the SCI can be selected via the configuration bit, SCIBDSRC, of the CONFIG2 register ($001E). Source selection values are shown in Figure 18-1. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 233 Serial Communications Interface (SCI) INTERNAL BUS SCI DATA REGISTER ERROR INTERRUPT CONTROL RECEIVER INTERRUPT CONTROL DMA INTERRUPT CONTROL RECEIVE SHIFT REGISTER PE1/RxD TRANSMITTER INTERRUPT CONTROL SCI DATA REGISTER TRANSMIT SHIFT REGISTER PE2/TxD TXINV SCTIE R8 TCIE T8 SCRIE ILIE DMARE TE SCTE RE DMATE TC RWU SBK SCRF OR ORIE IDLE NF NEIE FE FEIE PE PEIE LOOPS LOOPS WAKEUP CONTROL SCIBDSRC FROM CONFIG RECEIVE CONTROL ENSCI ENSCI TRANSMIT CONTROL FLAG CONTROL BKF M RPF WAKE ILTY SL A CGMXCLK X B IT12 SL = 0 => X = A SL = 1 => X = B ÷4 PRESCALER BAUD DIVIDER ∏ ÷ 16 PEN PTY DATA SELECTION CONTROL Figure 18-1. SCI Module Block Diagram Technical Data 234 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description Addr. $0013 $0014 $0015 $0016 $0017 Register Name 6 5 4 3 2 1 Bit 0 ENSCI TXINV M WAKE ILTY PEN PTY 0 0 0 0 0 0 0 SCTIE TCIE SCRIE ILIE TE RE RWU SBK 0 0 0 0 0 0 0 0 T8 DMARE DMATE ORIE NEIE FEIE PEIE Read: LOOPS SCI Control Register 1 Write: (SCC1) Reset: 0 Read: SCI Control Register 2 Write: (SCC2) Reset: Read: SCI Control Register 3 Write: (SCC3) Reset: R8 U U 0 0 0 0 0 0 Read: SCI Status Register 1 Write: (SCS1) Reset: SCTE TC SCRF IDLE OR NF FE PE 1 1 0 0 0 0 0 0 BKF RPF Read: SCI Status Register 2 Write: (SCS2) Reset: Read: SCI Data Register Write: (SCDR) Reset: $0018 $0019 Bit 7 Read: SCI Baud Rate Register Write: (SCBR) Reset: 0 0 0 0 0 0 0 0 R7 R6 R5 R4 R3 R2 R1 R0 T7 T6 T5 T4 T3 T2 T1 T0 Unaffected by reset 0 0 SCP1 SCP0 R SCR2 SCR1 SCR0 0 0 0 0 0 0 = Unimplemented R = Reserved U = Unaffected Figure 18-2. SCI I/O Register Summary MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 235 Serial Communications Interface (SCI) 18.5.1 Data Format The SCI uses the standard non-return-to-zero mark/space data format illustrated in Figure 18-3. 8-BIT DATA FORMAT BIT M IN SCC1 CLEAR START BIT BIT 0 BIT 1 BIT 2 BIT 3 BIT 4 BIT 5 PARITY BIT BIT 6 BIT 7 9-BIT DATA FORMAT BIT M IN SCC1 SET START BIT BIT 0 BIT 1 BIT 2 BIT 3 BIT 4 BIT 5 STOP BIT NEXT START BIT PARITY BIT BIT 6 BIT 7 BIT 8 STOP BIT NEXT START BIT Figure 18-3. SCI Data Formats 18.5.2 Transmitter Figure 18-4 shows the structure of the SCI transmitter. The baud rate clock source for the SCI can be selected via the configuration bit, SCIBDSRC. Source selection values are shown in Figure 18-4. Technical Data 236 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description SCIBDSRC FROM CONFIG2 SL A CGMXCLK X B IT12 SL = 0 => X = A SL = 1 => X = B INTERNAL BUS BAUD DIVIDER ÷ 16 SCI DATA REGISTER SCP1 11-BIT TRANSMIT SHIFT REGISTER STOP SCP0 SCR1 H SCR2 8 7 6 5 4 3 2 START PRESCALER ÷4 1 0 L PE2/TxD MSB TXINV PARITY GENERATION T8 DMATE DMATE SCTIE SCTE DMATE SCTE SCTIE TC TCIE BREAK ALL 0s PTY PREAMBLE ALL 1s PEN SHIFT ENABLE M LOAD FROM SCDR TRANSMITTER DMA SERVICE REQUEST TRANSMITTER CPU INTERRUPT REQUEST SCR0 TRANSMITTER CONTROL LOGIC SCTE SBK LOOPS SCTIE ENSCI TC TE TCIE Figure 18-4. SCI Transmitter 18.5.2.1 Character Length The transmitter can accommodate either 8-bit or 9-bit data. The state of the M bit in SCI control register 1 (SCC1) determines character length. When transmitting 9-bit data, bit T8 in SCI control register 3 (SCC3) is the ninth bit (bit 8). MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 237 Serial Communications Interface (SCI) 18.5.2.2 Character Transmission During an SCI transmission, the transmit shift register shifts a character out to the PE2/TxD pin. The SCI data register (SCDR) is the write-only buffer between the internal data bus and the transmit shift register. To initiate an SCI transmission: 1. Enable the SCI by writing a logic 1 to the enable SCI bit (ENSCI) in SCI control register 1 (SCC1). 2. Enable the transmitter by writing a logic 1 to the transmitter enable bit (TE) in SCI control register 2 (SCC2). 3. Clear the SCI transmitter empty bit by first reading SCI status register 1 (SCS1) and then writing to the SCDR. 4. Repeat step 3 for each subsequent transmission. At the start of a transmission, transmitter control logic automatically loads the transmit shift register with a preamble of logic 1s. After the preamble shifts out, control logic transfers the SCDR data into the transmit shift register. A logic 0 start bit automatically goes into the least significant bit position of the transmit shift register. A logic 1 stop bit goes into the most significant bit position. The SCI transmitter empty bit, SCTE, in SCS1 becomes set when the SCDR transfers a byte to the transmit shift register. The SCTE bit indicates that the SCDR can accept new data from the internal data bus. If the SCI transmit interrupt enable bit, SCTIE, in SCC2 is also set, the SCTE bit generates a transmitter CPU interrupt request. When the transmit shift register is not transmitting a character, the PE2/TxD pin goes to the idle condition, logic 1. If at any time software clears the ENSCI bit in SCI control register 1 (SCC1), the transmitter and receiver relinquish control of the port E pins. 18.5.2.3 Break Characters Writing a logic 1 to the send break bit, SBK, in SCC2 loads the transmit shift register with a break character. A break character contains all logic 0s and has no start, stop, or parity bit. Break character length depends on the M bit in SCC1. As long as SBK is at logic 1, transmitter logic Technical Data 238 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description continuously loads break characters into the transmit shift register. After software clears the SBK bit, the shift register finishes transmitting the last break character and then transmits at least one logic 1. The automatic logic 1 at the end of a break character guarantees the recognition of the start bit of the next character. The SCI recognizes a break character when a start bit is followed by eight or nine logic 0 data bits and a logic 0 where the stop bit should be. Receiving a break character has these effects on SCI registers: • Sets the framing error bit (FE) in SCS1 • Sets the SCI receiver full bit (SCRF) in SCS1 • Clears the SCI data register (SCDR) • Clears the R8 bit in SCC3 • Sets the break flag bit (BKF) in SCS2 • May set the overrun (OR), noise flag (NF), parity error (PE), or reception in progress flag (RPF) bits 18.5.2.4 Idle Characters An idle character contains all logic 1s and has no start, stop, or parity bit. Idle character length depends on the M bit in SCC1. The preamble is a synchronizing idle character that begins every transmission. If the TE bit is cleared during a transmission, the PE2/TxD pin becomes idle after completion of the transmission in progress. Clearing and then setting the TE bit during a transmission queues an idle character to be sent after the character currently being transmitted. NOTE: When queueing an idle character, return the TE bit to logic 1 before the stop bit of the current character shifts out to the TxD pin. Setting TE after the stop bit appears on TxD causes data previously written to the SCDR to be lost. Toggle the TE bit for a queued idle character when the SCTE bit becomes set and just before writing the next byte to the SCDR. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 239 Serial Communications Interface (SCI) 18.5.2.5 Inversion of Transmitted Output The transmit inversion bit (TXINV) in SCI control register 1 (SCC1) reverses the polarity of transmitted data. All transmitted values, including idle, break, start, and stop bits, are inverted when TXINV is at logic 1. See SCI Control Register 1. 18.5.2.6 Transmitter Interrupts These conditions can generate CPU interrupt requests from the SCI transmitter: • SCI transmitter empty (SCTE) — The SCTE bit in SCS1 indicates that the SCDR has transferred a character to the transmit shift register. SCTE can generate a transmitter CPU interrupt request. Setting the SCI transmit interrupt enable bit, SCTIE, in SCC2 enables the SCTE bit to generate transmitter CPU interrupt requests. • Transmission complete (TC) — The TC bit in SCS1 indicates that the transmit shift register and the SCDR are empty and that no break or idle character has been generated. The transmission complete interrupt enable bit, TCIE, in SCC2 enables the TC bit to generate transmitter CPU interrupt requests. 18.5.3 Receiver Figure 18-5 shows the structure of the SCI receiver. 18.5.3.1 Character Length The receiver can accommodate either 8-bit or 9-bit data. The state of the M bit in SCI control register 1 (SCC1) determines character length. When receiving 9-bit data, bit R8 in SCI control register 2 (SCC2) is the ninth bit (bit 8). When receiving 8-bit data, bit R8 is a copy of the eighth bit (bit 7). Technical Data 240 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description 18.5.3.2 Character Reception During an SCI reception, the receive shift register shifts characters in from the PE1/RxD pin. The SCI data register (SCDR) is the read-only buffer between the internal data bus and the receive shift register. After a complete character shifts into the receive shift register, the data portion of the character transfers to the SCDR. The SCI receiver full bit, SCRF, in SCI status register 1 (SCS1) becomes set, indicating that the received byte can be read. If the SCI receive interrupt enable bit, SCRIE, in SCC2 is also set, the SCRF bit generates a receiver CPU interrupt request. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 241 Serial Communications Interface (SCI) INTERNAL BUS SCIBDSRC FROM CONFIG2 SCR1 SCR0 PRESCALER BAUD DIVIDER ÷ 16 DATA RECOVERY PE1/RxD CPU INTERRUPT REQUEST 11-BIT RECEIVE SHIFT REGISTER 8 7 6 5 M WAKE ILTY PEN PTY 4 3 2 1 0 L ALL 0s RPF ERROR CPU INTERRUPT REQUEST DMA SERVICE REQUEST H ALL 1s BKF STOP ÷4 SCI DATA REGISTER START SCR2 SCP0 MSB SL CGMXCLK A X B IT12 SL = 0 => X = A SL = 1 => X = B SCP1 SCRF WAKEUP LOGIC PARITY CHECKING IDLE ILIE DMARE SCRF SCRIE DMARE SCRF SCRIE DMARE OR ORIE NF NEIE FE FEIE PE PEIE RWU IDLE R8 ILIE SCRIE DMARE OR ORIE NF NEIE FE FEIE PE PEIE Figure 18-5. SCI Receiver Block Diagram Technical Data 242 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description 18.5.3.3 Data Sampling The receiver samples the PE1/RxD pin at the RT clock rate. The RT clock is an internal signal with a frequency 16 times the baud rate. To adjust for baud rate mismatch, the RT clock is resynchronized at the following times (see Figure 18-6): • After every start bit • After the receiver detects a data bit change from logic 1 to logic 0 (after the majority of data bit samples at RT8, RT9, and RT10 returns a valid logic 1 and the majority of the next RT8, RT9, and RT10 samples returns a valid logic 0) To locate the start bit, data recovery logic does an asynchronous search for a logic 0 preceded by three logic 1s. When the falling edge of a possible start bit occurs, the RT clock begins to count to 16. START BIT LSB START BIT VERIFICATION DATA SAMPLING RT8 START BIT QUALIFICATION SAMPLES RT3 PE1/RxD RT4 RT3 RT2 RT1 RT16 RT15 RT14 RT13 RT12 RT11 RT10 RT9 RT7 RT6 RT5 RT4 RT2 RT1 RT1 RT1 RT1 RT1 RT1 RT1 RT1 RT CLOCK STATE RT1 RT CLOCK RT CLOCK RESET Figure 18-6. Receiver Data Sampling To verify the start bit and to detect noise, data recovery logic takes samples at RT3, RT5, and RT7. Table 18-2 summarizes the results of the start bit verification samples. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 243 Serial Communications Interface (SCI) Table 18-2. Start Bit Verification RT3, RT5, and RT7 Samples Start Bit Verification Noise Flag 000 Yes 0 001 Yes 1 010 Yes 1 011 No 0 100 Yes 1 101 No 0 110 No 0 111 No 0 Start bit verification is not successful if any two of the three verification samples are logic 1s. If start bit verification is not successful, the RT clock is reset and a new search for a start bit begins. To determine the value of a data bit and to detect noise, recovery logic takes samples at RT8, RT9, and RT10. Table 18-3 summarizes the results of the data bit samples. Table 18-3. Data Bit Recovery RT8, RT9, and RT10 Samples Data Bit Determination Noise Flag 000 0 0 001 0 1 010 0 1 011 1 1 100 0 1 101 1 1 110 1 1 111 1 0 Technical Data 244 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description NOTE: The RT8, RT9, and RT10 samples do not affect start bit verification. If any or all of the RT8, RT9, and RT10 start bit samples are logic 1s following a successful start bit verification, the noise flag (NF) is set and the receiver assumes that the bit is a start bit. To verify a stop bit and to detect noise, recovery logic takes samples at RT8, RT9, and RT10. Table 18-4 summarizes the results of the stop bit samples. Table 18-4. Stop Bit Recovery RT8, RT9, and RT10 Samples Framing Error Flag Noise Flag 000 1 0 001 1 1 010 1 1 011 0 1 100 1 1 101 0 1 110 0 1 111 0 0 18.5.3.4 Framing Errors If the data recovery logic does not detect a logic 1 where the stop bit should be in an incoming character, it sets the framing error bit, FE, in SCS1. A break character also sets the FE bit because a break character has no stop bit. The FE bit is set at the same time that the SCRF bit is set. 18.5.3.5 Baud Rate Tolerance A transmitting device may be operating at a baud rate below or above the receiver baud rate. Accumulated bit time misalignment can cause one of the three stop bit data samples to fall outside the actual stop bit. Then a noise error occurs. If more than one of the samples is outside the stop bit, a framing error occurs. In most applications, the baud rate MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 245 Serial Communications Interface (SCI) tolerance is much more than the degree of misalignment that is likely to occur. As the receiver samples an incoming character, it resynchronizes the RT clock on any valid falling edge within the character. Resynchronization within characters corrects misalignments between transmitter bit times and receiver bit times. 18.5.3.6 Slow Data Tolerance Figure 18-7 shows how much a slow received character can be misaligned without causing a noise error or a framing error. The slow stop bit begins at RT8 instead of RT1 but arrives in time for the stop bit data samples at RT8, RT9, and RT10. RT16 RT15 RT14 RT13 RT12 RT11 RT10 RT9 RT8 RT7 RT6 STOP RT5 RT4 RT3 RT2 RECEIVER RT CLOCK RT1 MSB DATA SAMPLES Figure 18-7. Slow Data For an 8-bit character, data sampling of the stop bit takes the receiver 9 bit times × 16 RT cycles + 10 RT cycles = 154 RT cycles. With the misaligned character shown in Figure 18-7, the receiver counts 154 RT cycles at the point when the count of the transmitting device is 9 bit times × 16 RT cycles + 3 RT cycles = 147 RT cycles. The maximum percent difference between the receiver count and the transmitter count of a slow 8-bit character with no errors is 154 – 147 × 100 = 4.54% -------------------------154 For a 9-bit character, data sampling of the stop bit takes the receiver 10 bit times × 16 RT cycles + 10 RT cycles = 170 RT cycles. Technical Data 246 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description With the misaligned character shown in Figure 18-7, the receiver counts 170 RT cycles at the point when the count of the transmitting device is 10 bit times × 16 RT cycles + 3 RT cycles = 163 RT cycles. The maximum percent difference between the receiver count and the transmitter count of a slow 9-bit character with no errors is 170 – 163 × 100 = 4.12% -------------------------170 18.5.3.7 Fast Data Tolerance Figure 18-8 shows how much a fast received character can be misaligned without causing a noise error or a framing error. The fast stop bit ends at RT10 instead of RT16 but is still there for the stop bit data samples at RT8, RT9, and RT10. RT16 RT15 RT14 RT13 RT12 RT11 RT10 RT9 RT8 RT7 IDLE OR NEXT CHARACTER RT6 RT5 RT4 RT3 RT2 RECEIVER RT CLOCK RT1 STOP DATA SAMPLES Figure 18-8. Fast Data For an 8-bit character, data sampling of the stop bit takes the receiver 9 bit times × 16 RT cycles + 10 RT cycles = 154 RT cycles. With the misaligned character shown in Figure 18-8, the receiver counts 154 RT cycles at the point when the count of the transmitting device is 10 bit times × 16 RT cycles = 160 RT cycles. The maximum percent difference between the receiver count and the transmitter count of a fast 8-bit character with no errors is · 154 – 160 × 100 = 3.90% -------------------------154 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 247 Serial Communications Interface (SCI) For a 9-bit character, data sampling of the stop bit takes the receiver 10 bit times × 16 RT cycles + 10 RT cycles = 170 RT cycles. With the misaligned character shown in Figure 18-8, the receiver counts 170 RT cycles at the point when the count of the transmitting device is 11 bit times × 16 RT cycles = 176 RT cycles. The maximum percent difference between the receiver count and the transmitter count of a fast 9-bit character with no errors is 170 – 176 × 100 = 3.53% -------------------------170 18.5.3.8 Receiver Wakeup So that the MCU can ignore transmissions intended only for other receivers in multiple-receiver systems, the receiver can be put into a standby state. Setting the receiver wakeup bit, RWU, in SCC2 puts the receiver into a standby state during which receiver interrupts are disabled. Depending on the state of the WAKE bit in SCC1, either of two conditions on the PE1/RxD pin can bring the receiver out of the standby state: • Address mark — An address mark is a logic 1 in the most significant bit position of a received character. When the WAKE bit is set, an address mark wakes the receiver from the standby state by clearing the RWU bit. The address mark also sets the SCI receiver full bit, SCRF. Software can then compare the character containing the address mark to the user-defined address of the receiver. If they are the same, the receiver remains awake and processes the characters that follow. If they are not the same, software can set the RWU bit and put the receiver back into the standby state. • Idle input line condition — When the WAKE bit is clear, an idle character on the PE1/RxD pin wakes the receiver from the standby state by clearing the RWU bit. The idle character that wakes the receiver does not set the receiver idle bit, IDLE, or the Technical Data 248 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Functional Description SCI receiver full bit, SCRF. The idle line type bit, ILTY, determines whether the receiver begins counting logic 1s as idle character bits after the start bit or after the stop bit. NOTE: With the WAKE bit clear, setting the RWU bit after the RxD pin has been idle may cause the receiver to wake up immediately. 18.5.3.9 Receiver Interrupts The following sources can generate CPU interrupt requests from the SCI receiver: • SCI receiver full (SCRF) — The SCRF bit in SCS1 indicates that the receive shift register has transferred a character to the SCDR. SCRF can generate a receiver CPU interrupt request. Setting the SCI receive interrupt enable bit, SCRIE, in SCC2 enables the SCRF bit to generate receiver CPU interrupts. • Idle input (IDLE) — The IDLE bit in SCS1 indicates that 10 or 11 consecutive logic 1s shifted in from the PE1/RxD pin. The idle line interrupt enable bit, ILIE, in SCC2 enables the IDLE bit to generate CPU interrupt requests. 18.5.3.10 Error Interrupts The following receiver error flags in SCS1 can generate CPU interrupt requests: • Receiver overrun (OR) — The OR bit indicates that the receive shift register shifted in a new character before the previous character was read from the SCDR. The previous character remains in the SCDR, and the new character is lost. The overrun interrupt enable bit, ORIE, in SCC3 enables OR to generate SCI error CPU interrupt requests. • Noise flag (NF) — The NF bit is set when the SCI detects noise on incoming data or break characters, including start, data, and stop bits. The noise error interrupt enable bit, NEIE, in SCC3 enables NF to generate SCI error CPU interrupt requests. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 249 Serial Communications Interface (SCI) • Framing error (FE) — The FE bit in SCS1 is set when a logic 0 occurs where the receiver expects a stop bit. The framing error interrupt enable bit, FEIE, in SCC3 enables FE to generate SCI error CPU interrupt requests. • Parity error (PE) — The PE bit in SCS1 is set when the SCI detects a parity error in incoming data. The parity error interrupt enable bit, PEIE, in SCC3 enables PE to generate SCI error CPU interrupt requests. 18.6 Low-Power Modes The WAIT and STOP instructions put the MCU in low powerconsumption standby modes. 18.6.1 Wait Mode The SCI module remains active after the execution of a WAIT instruction. In wait mode, the SCI module registers are not accessible by the CPU. Any enabled CPU interrupt request from the SCI module can bring the MCU out of wait mode. If SCI module functions are not required during wait mode, reduce power consumption by disabling the module before executing the WAIT instruction. Refer to Low Power Modes for information on exiting wait mode. 18.6.2 Stop Mode The SCI module is inactive after the execution of a STOP instruction. The STOP instruction does not affect SCI register states. SCI module operation resumes after an external interrupt. Because the internal clock is inactive during stop mode, entering stop mode during an SCI transmission or reception results in invalid data. Refer to Low Power Modes for information on exiting stop mode. Technical Data 250 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) SCI During Break Module Interrupts 18.7 SCI During Break Module Interrupts The system integration module (SIM) controls whether status bits in other modules can be cleared during the break state. The BCFE bit in the SIM break flag control register (SBFCR) enables software to clear status bits during the break state. To allow software to clear status bits during a break interrupt, write a logic 1 to the BCFE bit. If a status bit is cleared during the break state, it remains cleared when the MCU exits the break state. To protect status bits during the break state, write a logic 0 to the BCFE bit. With BCFE at logic 0 (its default state), software can read and write I/O registers during the break state without affecting status bits. Some status bits have a 2-step read/write clearing procedure. If software does the first step on such a bit before the break, the bit cannot change during the break state as long as BCFE is at logic 0. After the break, doing the second step clears the status bit. 18.8 I/O Signals Port E shares two of its pins with the SCI module. The two SCI I/O pins are: • PE2/TxD — Transmit data • PE1/RxD — Receive data 18.8.1 PE2/TxD (Transmit Data) The PE2/TxD pin is the serial data output from the SCI transmitter. The SCI shares the PE2/TxD pin with port E. When the SCI is enabled, the PE2/TxD pin is an output regardless of the state of the DDRE0 bit in data direction register E (DDRE). MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 251 Serial Communications Interface (SCI) 18.8.2 PE1/RxD (Receive Data) The PE1/RxD pin is the serial data input to the SCI receiver. The SCI shares the PE1/RxD pin with port E. When the SCI is enabled, the PE1/RxD pin is an input regardless of the state of the DDRE1 bit in data direction register E (DDRE). 18.9 I/O Registers These I/O registers control and monitor SCI operation: • SCI control register 1 (SCC1) • SCI control register 2 (SCC2) • SCI control register 3 (SCC3) • SCI status register 1 (SCS1) • SCI status register 2 (SCS2) • SCI data register (SCDR) • SCI baud rate register (SCBR) 18.9.1 SCI Control Register 1 SCI control register 1: • Enables loop mode operation • Enables the SCI • Controls output polarity • Controls character length • Controls SCI wakeup method • Controls idle character detection • Enables parity function • Controls parity type Technical Data 252 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers Address: $0013 Bit 7 6 5 4 3 2 1 Bit 0 LOOPS ENSCI TXINV M WAKE ILTY PEN PTY 0 0 0 0 0 0 0 0 Read: Write: Reset: Figure 18-9. SCI Control Register 1 (SCC1) LOOPS — Loop Mode Select Bit This read/write bit enables loop mode operation. In loop mode the PE1/RxD pin is disconnected from the SCI, and the transmitter output goes into the receiver input. Both the transmitter and the receiver must be enabled to use loop mode. Reset clears the LOOPS bit. 1 = Loop mode enabled 0 = Normal operation enabled ENSCI — Enable SCI Bit This read/write bit enables the SCI and the SCI baud rate generator. Clearing ENSCI sets the SCTE and TC bits in SCI status register 1 and disables transmitter interrupts. Reset clears the ENSCI bit. 1 = SCI enabled 0 = SCI disabled TXINV — Transmit Inversion Bit This read/write bit reverses the polarity of transmitted data. Reset clears the TXINV bit. 1 = Transmitter output inverted 0 = Transmitter output not inverted NOTE: Setting the TXINV bit inverts all transmitted values, including idle, break, start, and stop bits. M — Mode (Character Length) Bit This read/write bit determines whether SCI characters are eight or nine bits long. See Table 18-5. The ninth bit can serve as an extra stop bit, as a receiver wakeup signal, or as a parity bit. Reset clears the M bit. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 253 Serial Communications Interface (SCI) 1 = 9-bit SCI characters 0 = 8-bit SCI characters WAKE — Wakeup Condition Bit This read/write bit determines which condition wakes up the SCI: a logic 1 (address mark) in the most significant bit position of a received character or an idle condition on the PE1/RxD pin. Reset clears the WAKE bit. 1 = Address mark wakeup 0 = Idle line wakeup ILTY — Idle Line Type Bit This read/write bit determines when the SCI starts counting logic 1s as idle character bits. The counting begins either after the start bit or after the stop bit. If the count begins after the start bit, then a string of logic 1s preceding the stop bit may cause false recognition of an idle character. Beginning the count after the stop bit avoids false idle character recognition, but requires properly synchronized transmissions. Reset clears the ILTY bit. 1 = Idle character bit count begins after stop bit 0 = Idle character bit count begins after start bit PEN — Parity Enable Bit This read/write bit enables the SCI parity function. See Table 18-5. When enabled, the parity function inserts a parity bit in the most significant bit position. See Figure 18-3. Reset clears the PEN bit. 1 = Parity function enabled 0 = Parity function disabled PTY — Parity Bit This read/write bit determines whether the SCI generates and checks for odd parity or even parity. See Table 18-5. Reset clears the PTY bit. 1 = Odd parity 0 = Even parity Technical Data 254 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers NOTE: Changing the PTY bit in the middle of a transmission or reception can generate a parity error. Table 18-5. Character Format Selection Control Bits Character Format M PEN and PTY Start Bits Data Bits Parity Stop Bits Character Length 0 0X 1 8 None 1 10 bits 1 0X 1 9 None 1 11 bits 0 10 1 7 Even 1 10 bits 0 11 1 7 Odd 1 10 bits 1 10 1 8 Even 1 11 bits 1 11 1 8 Odd 1 11 bits 18.9.2 SCI Control Register 2 SCI control register 2: • Enables the following CPU interrupt requests: – Enables the SCTE bit to generate transmitter CPU interrupt requests – Enables the TC bit to generate transmitter CPU interrupt requests – Enables the SCRF bit to generate receiver CPU interrupt requests – Enables the IDLE bit to generate receiver CPU interrupt requests • Enables the transmitter • Enables the receiver • Enables SCI wakeup • Transmits SCI break characters MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 255 Serial Communications Interface (SCI) Address: $0014 Bit 7 6 5 4 3 2 1 Bit 0 SCTIE TCIE SCRIE ILIE TE RE RWU SBK 0 0 0 0 0 0 0 0 Read: Write: Reset: Figure 18-10. SCI Control Register 2 (SCC2) SCTIE — SCI Transmit Interrupt Enable Bit This read/write bit enables the SCTE bit to generate SCI transmitter CPU interrupt requests. Reset clears the SCTIE bit. 1 = SCTE enabled to generate CPU interrupt 0 = SCTE not enabled to generate CPU interrupt TCIE — Transmission Complete Interrupt Enable Bit This read/write bit enables the TC bit to generate SCI transmitter CPU interrupt requests. Reset clears the TCIE bit. 1 = TC enabled to generate CPU interrupt requests 0 = TC not enabled to generate CPU interrupt requests SCRIE — SCI Receive Interrupt Enable Bit This read/write bit enables the SCRF bit to generate SCI receiver CPU interrupt requests. Reset clears the SCRIE bit. 1 = SCRF enabled to generate CPU interrupt 0 = SCRF not enabled to generate CPU interrupt ILIE — Idle Line Interrupt Enable Bit This read/write bit enables the IDLE bit to generate SCI receiver CPU interrupt requests. Reset clears the ILIE bit. 1 = IDLE enabled to generate CPU interrupt requests 0 = IDLE not enabled to generate CPU interrupt requests TE — Transmitter Enable Bit Setting this read/write bit begins the transmission by sending a preamble of 10 or 11 logic 1s from the transmit shift register to the PE2/TxD pin. If software clears the TE bit, the transmitter completes any transmission in progress before the PE2/TxD returns to the idle Technical Data 256 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers condition (logic 1). Clearing and then setting TE during a transmission queues an idle character to be sent after the character currently being transmitted. Reset clears the TE bit. 1 = Transmitter enabled 0 = Transmitter disabled NOTE: Writing to the TE bit is not allowed when the enable SCI bit (ENSCI) is clear. ENSCI is in SCI control register 1. RE — Receiver Enable Bit Setting this read/write bit enables the receiver. Clearing the RE bit disables the receiver but does not affect receiver interrupt flag bits. Reset clears the RE bit. 1 = Receiver enabled 0 = Receiver disabled NOTE: Writing to the RE bit is not allowed when the enable SCI bit (ENSCI) is clear. ENSCI is in SCI control register 1. RWU — Receiver Wakeup Bit This read/write bit puts the receiver in a standby state during which receiver interrupts are disabled. The WAKE bit in SCC1 determines whether an idle input or an address mark brings the receiver out of the standby state and clears the RWU bit. Reset clears the RWU bit. 1 = Standby state 0 = Normal operation SBK — Send Break Bit Setting and then clearing this read/write bit transmits a break character followed by a logic 1. The logic 1 after the break character guarantees recognition of a valid start bit. If SBK remains set, the transmitter continuously transmits break characters with no logic 1s between them. Reset clears the SBK bit. 1 = Transmit break characters 0 = No break characters being transmitted NOTE: Do not toggle the SBK bit immediately after setting the SCTE bit. Toggling SBK before the preamble begins causes the SCI to send a break character instead of a preamble. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 257 Serial Communications Interface (SCI) 18.9.3 SCI Control Register 3 SCI control register 3: • Stores the ninth SCI data bit received and the ninth SCI data bit to be transmitted • Enables these interrupts: – Receiver overrun interrupts – Noise error interrupts – Framing error interrupts • Parity error interrupts Address: $0015 Bit 7 Read: 6 5 4 3 2 1 Bit 0 T8 DMARE DMATE ORIE NEIE FEIE PEIE U 0 0 0 0 0 0 R8 Write: Reset: U = Unimplemented U = Unaffected Figure 18-11. SCI Control Register 3 (SCC3) R8 — Received Bit 8 When the SCI is receiving 9-bit characters, R8 is the read-only ninth bit (bit 8) of the received character. R8 is received at the same time that the SCDR receives the other 8 bits. When the SCI is receiving 8-bit characters, R8 is a copy of the eighth bit (bit 7). Reset has no effect on the R8 bit. T8 — Transmitted Bit 8 When the SCI is transmitting 9-bit characters, T8 is the read/write ninth bit (bit 8) of the transmitted character. T8 is loaded into the transmit shift register at the same time that the SCDR is loaded into the transmit shift register. Reset has no effect on the T8 bit. Technical Data 258 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers DMARE — DMA Receive Enable Bit CAUTION: The DMA module is not included on this MCU. Writing a logic 1 to DMARE or DMATE may adversely affect MCU performance. 1 = DMA not enabled to service SCI receiver DMA service requests generated by the SCRF bit (SCI receiver CPU interrupt requests enabled) 0 = DMA not enabled to service SCI receiver DMA service requests generated by the SCRF bit (SCI receiver CPU interrupt requests enabled) DMATE — DMA Transfer Enable Bit CAUTION: The DMA module is not included on this MCU. Writing a logic 1 to DMARE or DMATE may adversely affect MCU performance. 1 = SCTE DMA service requests enabled; SCTE CPU interrupt requests disabled 0 = SCTE DMA service requests disabled; SCTE CPU interrupt requests enabled ORIE — Receiver Overrun Interrupt Enable Bit This read/write bit enables SCI error CPU interrupt requests generated by the receiver overrun bit, OR. 1 = SCI error CPU interrupt requests from OR bit enabled 0 = SCI error CPU interrupt requests from OR bit disabled NEIE — Receiver Noise Error Interrupt Enable Bit This read/write bit enables SCI error CPU interrupt requests generated by the noise error bit, NE. Reset clears NEIE. 1 = SCI error CPU interrupt requests from NE bit enabled 0 = SCI error CPU interrupt requests from NE bit disabled FEIE — Receiver Framing Error Interrupt Enable Bit This read/write bit enables SCI error CPU interrupt requests generated by the framing error bit, FE. Reset clears FEIE. 1 = SCI error CPU interrupt requests from FE bit enabled 0 = SCI error CPU interrupt requests from FE bit disabled MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 259 Serial Communications Interface (SCI) PEIE — Receiver Parity Error Interrupt Enable Bit This read/write bit enables SCI receiver CPU interrupt requests generated by the parity error bit, PE. See SCI Status Register 1. Reset clears PEIE. 1 = SCI error CPU interrupt requests from PE bit enabled 0 = SCI error CPU interrupt requests from PE bit disabled 18.9.4 SCI Status Register 1 SCI status register 1 (SCS1) contains flags to signal these conditions: • Transfer of SCDR data to transmit shift register complete • Transmission complete • Transfer of receive shift register data to SCDR complete • Receiver input idle • Receiver overrun • Noisy data • Framing error • Parity error Address: Read: $0016 Bit 7 6 5 4 3 2 1 Bit 0 SCTE TC SCRF IDLE OR NF FE PE 1 1 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 18-12. SCI Status Register 1 (SCS1) SCTE — SCI Transmitter Empty Bit This clearable, read-only bit is set when the SCDR transfers a character to the transmit shift register. SCTE can generate an SCI transmitter CPU interrupt request. When the SCTIE bit in SCC2 is set, SCTE generates an SCI transmitter CPU interrupt request. In normal Technical Data 260 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers operation, clear the SCTE bit by reading SCS1 with SCTE set and then writing to SCDR. Reset sets the SCTE bit. 1 = SCDR data transferred to transmit shift register 0 = SCDR data not transferred to transmit shift register TC — Transmission Complete Bit This read-only bit is set when the SCTE bit is set, and no data, preamble, or break character is being transmitted. TC generates an SCI transmitter CPU interrupt request if the TCIE bit in SCC2 is also set. TC is automatically cleared when data, preamble or break is queued and ready to be sent. There may be up to 1.5 transmitter clocks of latency between queueing data, preamble, and break and the transmission actually starting. Reset sets the TC bit. 1 = No transmission in progress 0 = Transmission in progress SCRF — SCI Receiver Full Bit This clearable, read-only bit is set when the data in the receive shift register transfers to the SCI data register. SCRF can generate an SCI receiver CPU interrupt request. When the SCRIE bit in SCC2 is set, SCRF generates a CPU interrupt request. In normal operation, clear the SCRF bit by reading SCS1 with SCRF set and then reading the SCDR. Reset clears SCRF. 1 = Received data available in SCDR 0 = Data not available in SCDR IDLE — Receiver Idle Bit This clearable, read-only bit is set when 10 or 11 consecutive logic 1s appear on the receiver input. IDLE generates an SCI error CPU interrupt request if the ILIE bit in SCC2 is also set. Clear the IDLE bit by reading SCS1 with IDLE set and then reading the SCDR. After the receiver is enabled, it must receive a valid character that sets the SCRF bit before an idle condition can set the IDLE bit. Also, after the IDLE bit has been cleared, a valid character must again set the SCRF bit before an idle condition can set the IDLE bit. Reset clears the IDLE bit. 1 = Receiver input idle 0 = Receiver input active (or idle since the IDLE bit was cleared) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 261 Serial Communications Interface (SCI) OR — Receiver Overrun Bit This clearable, read-only bit is set when software fails to read the SCDR before the receive shift register receives the next character. The OR bit generates an SCI error CPU interrupt request if the ORIE bit in SCC3 is also set. The data in the shift register is lost, but the data already in the SCDR is not affected. Clear the OR bit by reading SCS1 with OR set and then reading the SCDR. Reset clears the OR bit. 1 = Receive shift register full and SCRF = 1 0 = No receiver overrun Software latency may allow an overrun to occur between reads of SCS1 and SCDR in the flag-clearing sequence. Figure 18-13 shows the normal flag-clearing sequence and an example of an overrun caused by a delayed flag-clearing sequence. The delayed read of SCDR does not clear the OR bit because OR was not set when SCS1 was read. Byte 2 caused the overrun and is lost. The next flagclearing sequence reads byte 3 in the SCDR instead of byte 2. In applications that are subject to software latency or in which it is important to know which byte is lost due to an overrun, the flagclearing routine can check the OR bit in a second read of SCS1 after reading the data register. NF — Receiver Noise Flag Bit This clearable, read-only bit is set when the SCI detects noise on the PE1/RxD pin. NF generates an NF CPU interrupt request if the NEIE bit in SCC3 is also set. Clear the NF bit by reading SCS1 and then reading the SCDR. Reset clears the NF bit. 1 = Noise detected 0 = No noise detected FE — Receiver Framing Error Bit This clearable, read-only bit is set when a logic 0 is accepted as the stop bit. FE generates an SCI error CPU interrupt request if the FEIE bit in SCC3 also is set. Clear the FE bit by reading SCS1 with FE set and then reading the SCDR. Reset clears the FE bit. 1 = Framing error detected 0 = No framing error detected Technical Data 262 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers BYTE 1 BYTE 2 BYTE 3 SCRF = 0 SCRF = 1 SCRF = 0 SCRF = 1 SCRF = 0 SCRF = 1 NORMAL FLAG CLEARING SEQUENCE BYTE 4 READ SCS1 SCRF = 1 OR = 0 READ SCS1 SCRF = 1 OR = 0 READ SCS1 SCRF = 1 OR = 0 READ SCDR BYTE 1 READ SCDR BYTE 2 READ SCDR BYTE 3 BYTE 1 BYTE 2 BYTE 3 SCRF = 0 OR = 0 SCRF = 1 OR = 1 SCRF = 0 OR = 1 SCRF = 1 SCRF = 1 OR = 1 DELAYED FLAG CLEARING SEQUENCE BYTE 4 READ SCS1 SCRF = 1 OR = 0 READ SCS1 SCRF = 1 OR = 1 READ SCDR BYTE 1 READ SCDR BYTE 3 Figure 18-13. Flag Clearing Sequence PE — Receiver Parity Error Bit This clearable, read-only bit is set when the SCI detects a parity error in incoming data. PE generates a PE CPU interrupt request if the PEIE bit in SCC3 is also set. Clear the PE bit by reading SCS1 with PE set and then reading the SCDR. Reset clears the PE bit. 1 = Parity error detected 0 = No parity error detected MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 263 Serial Communications Interface (SCI) 18.9.5 SCI Status Register 2 SCI status register 2 contains flags to signal the following conditions: • Break character detected • Incoming data Address: $0017 Bit 7 6 5 4 3 2 Read: 1 Bit 0 BKF RPF 0 0 Write: Reset: 0 0 0 0 0 0 = Unimplemented Figure 18-14. SCI Status Register 2 (SCS2) BKF — Break Flag Bit This clearable, read-only bit is set when the SCI detects a break character on the PE1/RxD pin. In SCS1, the FE and SCRF bits are also set. In 9-bit character transmissions, the R8 bit in SCC3 is cleared. BKF does not generate a CPU interrupt request. Clear BKF by reading SCS2 with BKF set and then reading the SCDR. Once cleared, BKF can become set again only after logic 1s again appear on the PE1/RxD pin followed by another break character. Reset clears the BKF bit. 1 = Break character detected 0 = No break character detected RPF — Reception in Progress Flag Bit This read-only bit is set when the receiver detects a logic 0 during the RT1 time period of the start bit search. RPF does not generate an interrupt request. RPF is reset after the receiver detects false start bits (usually from noise or a baud rate mismatch) or when the receiver detects an idle character. Polling RPF before disabling the SCI module or entering stop mode can show whether a reception is in progress. 1 = Reception in progress 0 = No reception in progress Technical Data 264 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers 18.9.6 SCI Data Register The SCI data register (SCDR) is the buffer between the internal data bus and the receive and transmit shift registers. Reset has no effect on data in the SCI data register. Address: $0018 Bit 7 6 5 4 3 2 1 Bit 0 Read: R7 R6 R5 R4 R3 R2 R1 R0 Write: T7 T6 T5 T4 T3 T2 T1 T0 Reset: Unaffected by reset Figure 18-15. SCI Data Register (SCDR) R7/T7–R0/T0 — Receive/Transmit Data Bits Reading address $0018 accesses the read-only received data bits, R7:R0. Writing to address $0018 writes the data to be transmitted, T7:T0. Reset has no effect on the SCI data register. NOTE: Do not use read/modify/write instructions on the SCI data register. 18.9.7 SCI Baud Rate Register The baud rate register (SCBR) selects the baud rate for both the receiver and the transmitter. Address: $0019 Bit 7 6 5 4 3 2 1 Bit 0 SCP1 SCP0 R SCR2 SCR1 SCR0 0 0 0 0 0 0 R = Reserved Read: Write: Reset: 0 0 = Unimplemented Figure 18-16. SCI Baud Rate Register (SCBR) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 265 Serial Communications Interface (SCI) SCP1 and SCP0 — SCI Baud Rate Prescaler Bits These read/write bits select the baud rate prescaler divisor as shown in Table 18-6. Reset clears SCP1 and SCP0. Table 18-6. SCI Baud Rate Prescaling SCP1 and SCP0 Prescaler Divisor (PD) 00 1 01 3 10 4 11 13 SCR2–SCR0 — SCI Baud Rate Select Bits These read/write bits select the SCI baud rate divisor as shown in Table 18-7. Reset clears SCR2–SCR0. Table 18-7. SCI Baud Rate Selection SCR2, SCR1, and SCR0 Baud Rate Divisor (BD) 000 1 001 2 010 4 011 8 100 16 101 32 110 64 111 128 Technical Data 266 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) I/O Registers Use this formula to calculate the SCI baud rate: f BUS baud rate = -----------------------------------64 × PD × BD where: fBUS = bus frequency PD = prescaler divisor BD = baud rate divisor SCI_BDSRC is an input to the SCI. Normally it will be tied off low at the top level to select the bus clock as the clock source. This makes the formula: f BUS baud rate = -----------------------------------64 × PD × BD Table 18-8 shows the SCI baud rates that can be generated with a 4.9152-MHz bus clock. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Communications Interface (SCI) 267 Serial Communications Interface (SCI) Table 18-8. SCI Baud Rate Selection Examples SCP1 and SCP0 Prescaler Divisor (PD) SCR2, SCR1, and SCR0 Baud Rate Divisor (BD) Baud Rate (fBUS = 4.9152 MHz) 00 1 000 1 76,800 00 1 001 2 38,400 00 1 010 4 19,200 00 1 011 8 9600 00 1 100 16 4800 00 1 101 32 2400 00 1 110 64 1200 00 1 111 128 600 01 3 000 1 25,600 01 3 001 2 12,800 01 3 010 4 6400 01 3 011 8 3200 01 3 100 16 1600 01 3 101 32 800 01 3 110 64 400 01 3 111 128 200 10 4 000 1 19,200 10 4 001 2 9600 10 4 010 4 4800 10 4 011 8 2400 10 4 100 16 1200 10 4 101 32 600 10 4 110 64 300 10 4 111 128 150 11 13 000 1 5908 11 13 001 2 2954 Technical Data 268 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Table 18-8. SCI Baud Rate Selection Examples SCP1 and SCP0 Prescaler Divisor (PD) SCR2, SCR1, and SCR0 Baud Rate Divisor (BD) Baud Rate (fBUS = 4.9152 MHz) 11 13 010 4 1477 11 13 011 8 739 11 13 100 16 369 11 13 101 32 185 11 13 110 64 92 11 13 111 128 46 Technical Data 269 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Serial Communications Interface (SCI) Technical Data 270 MC68HC908GR8 — Rev 4.0 Serial Communications Interface (SCI) MOTOROLA Technical Data — MC68HC908GR8 Section 19. System Integration Module (SIM) 19.1 Contents 19.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 271 19.3 SIM Bus Clock Control and Generation . . . . . . . . . . . . . . . . . 275 19.4 Reset and System Initialization. . . . . . . . . . . . . . . . . . . . . . . . 276 19.5 SIM Counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 281 19.6 Exception Control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 282 19.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .290 19.8 SIM Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 293 19.2 Introduction This section describes the system integration module (SIM). Together with the CPU, the SIM controls all MCU activities. A block diagram of the SIM is shown in Figure 19-1. Table 19-1 is a summary of the SIM input/output (I/O) registers. The SIM is a system state controller that coordinates CPU and exception timing. The SIM is responsible for: • Bus clock generation and control for CPU and peripherals: – Stop/wait/reset/break entry and recovery – Internal clock control • Master reset control, including power-on reset (POR) and COP timeout • Interrupt control: – Acknowledge timing – Arbitration control timing MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 271 System Integration Module (SIM) – Vector address generation • CPU enable/disable timing • Modular architecture expandable to 128 interrupt sources Table 19-1 shows the internal signal names used in this section. MODULE STOP MODULE WAIT CPU STOP (FROM CPU) CPU WAIT (FROM CPU) STOP/WAIT CONTROL SIMOSCEN (TO CGM) SIM COUNTER COP CLOCK CGMXCLK (FROM CGM) CGMOUT (FROM CGM) ÷2 CLOCK CONTROL VDD CLOCK GENERATORS INTERNAL CLOCKS INTERNAL PULLUP DEVICE RESET PIN LOGIC LVI (FROM LVI MODULE) POR CONTROL MASTER RESET CONTROL RESET PIN CONTROL SIM RESET STATUS REGISTER ILLEGAL OPCODE (FROM CPU) ILLEGAL ADDRESS (FROM ADDRESS MAP DECODERS) COP (FROM COP MODULE) RESET INTERRUPT CONTROL AND PRIORITY DECODE INTERRUPT SOURCES CPU INTERFACE Figure 19-1. SIM Block Diagram Technical Data 272 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Introduction Table 19-1. Signal Name Conventions Signal Name Description CGMXCLK Buffered version of OSC1 from clock generator module (CGM) CGMVCLK PLL output CGMOUT PLL-based or OSC1-based clock output from CGM module (Bus clock = CGMOUT divided by two) IAB Internal address bus IDB Internal data bus PORRST Signal from the power-on reset module to the SIM IRST Internal reset signal R/W Read/write signal MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 273 System Integration Module (SIM) Addr. Register Name Read: SIM Break Status Register $FE00 Write: (SBSR) Reset: Bit 7 6 5 4 3 2 R R R R R R 1 Bit 0 SBSW R NOTE 0 0 0 0 0 0 0 0 POR PIN COP ILOP ILAD MODRST LVI 0 1 0 0 0 0 0 0 0 R R R R R R R R BCFE R R R R R R R Note: Writing a logic 0 clears SBSW. Read: SIM Reset Status Register $FE01 Write: (SRSR) POR: Read: SIM Upper Byte Address $FE02 Write: Register (SUBAR) Reset: $FE03 Read: SIM Break Flag Control Write: Register (SBFCR) Reset: 0 Read: Interrupt Status Register 1 $FE09 Write: (INT1) Reset: IF6 IF5 IF4 IF3 IF2 IF1 0 0 R R R R R R R R 0 0 0 0 0 0 0 0 Read: Interrupt Status Register 2 $FE0A Write: (INT2) Reset: IF14 IF13 IF12 IF11 IF10 IF9 IF8 IF7 R R R R R R R R 0 0 0 0 0 0 0 0 Read: Interrupt Status Register 3 $FE0B Write: (INT3) Reset: 0 0 0 0 0 0 IF16 IF15 R R R R R R R R 0 0 0 0 0 0 0 0 = Unimplemented Figure 19-2. SIM I/O Register Summary Technical Data 274 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) SIM Bus Clock Control and Generation 19.3 SIM Bus Clock Control and Generation The bus clock generator provides system clock signals for the CPU and peripherals on the MCU. The system clocks are generated from an incoming clock, CGMOUT, as shown in Figure 19-3. This clock can come from either an external oscillator or from the on-chip PLL. See Clock Generator Module (CGMC). OSC2 OSCILLATOR (OSC) CGMXCLK OSC1 TO TIMTB15A, ADC SIM OSCSTOPENB FROM CONFIG SIM COUNTER CGMRCLK CGMOUT ÷2 PHASE-LOCKED LOOP (PLL) BUS CLOCK GENERATORS SIMOSCEN IT12 TO REST OF CHIP IT23 TO REST OF CHIP Figure 19-3. CGM Clock Signals 19.3.1 Bus Timing In user mode, the internal bus frequency is either the crystal oscillator output (CGMXCLK) divided by four or the PLL output (CGMVCLK) divided by four. See External Interrupt (IRQ). MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 275 System Integration Module (SIM) 19.3.2 Clock Startup from POR or LVI Reset When the power-on reset module or the low-voltage inhibit module generates a reset, the clocks to the CPU and peripherals are inactive and held in an inactive phase until after the 4096 CGMXCLK cycle POR timeout has completed. The RST pin is driven low by the SIM during this entire period. The IBUS clocks start upon completion of the timeout. 19.3.3 Clocks in Stop Mode and Wait Mode Upon exit from stop mode by an interrupt, break, or reset, the SIM allows CGMXCLK to clock the SIM counter. The CPU and peripheral clocks do not become active until after the stop delay timeout. This timeout is selectable as 4096 or 32 CGMXCLK cycles. See Stop Mode. In wait mode, the CPU clocks are inactive. The SIM also produces two sets of clocks for other modules. Refer to the wait mode subsection of each module to see if the module is active or inactive in wait mode. Some modules can be programmed to be active in wait mode. 19.4 Reset and System Initialization The MCU has these reset sources: • Power-on reset module (POR) • External reset pin (RST) • Computer operating properly module (COP) • Low-voltage inhibit module (LVI) • Illegal opcode • Illegal address All of these resets produce the vector $FFFE:$FFFF ($FEFE:$FEFF in monitor mode) and assert the internal reset signal (IRST). IRST causes all registers to be returned to their default values and all modules to be returned to their reset states. Technical Data 276 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Reset and System Initialization An internal reset clears the SIM counter (see SIM Counter), but an external reset does not. Each of the resets sets a corresponding bit in the SIM reset status register (SRSR). See SIM Registers. 19.4.1 External Pin Reset The RST pin circuit includes an internal pullup device. Pulling the asynchronous RST pin low halts all processing. The PIN bit of the SIM reset status register (SRSR) is set as long as RST is held low for a minimum of 67 CGMXCLK cycles, assuming that neither the POR nor the LVI was the source of the reset. See Table 19-2 for details. Figure 19-4 shows the relative timing. Table 19-2. PIN Bit Set Timing Reset Type Number of Cycles Required to Set PIN POR/LVI 4163 (4096 + 64 + 3) All others 67 (64 + 3) CGMOUT RST IAB VECT H VECT L PC Figure 19-4. External Reset Timing 19.4.2 Active Resets from Internal Sources All internal reset sources actively pull the RST pin low for 32 CGMXCLK cycles to allow resetting of external peripherals. The internal reset signal IRST continues to be asserted for an additional 32 cycles. See Figure 19-5. An internal reset can be caused by an illegal address, illegal opcode, COP timeout, LVI, or POR. See Figure 19-6. NOTE: For LVI or POR resets, the SIM cycles through 4096 CGMXCLK cycles during which the SIM forces the RST pin low. The internal reset signal MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 277 System Integration Module (SIM) then follows the sequence from the falling edge of RST shown in Figure 19-5. IRST RST RST PULLED LOW BY MCU 32 CYCLES 32 CYCLES CGMXCLK IAB VECTOR HIGH Figure 19-5. Internal Reset Timing The COP reset is asynchronous to the bus clock. ILLEGAL ADDRESS RST ILLEGAL OPCODE RST COPRST LVI POR INTERNAL RESET Figure 19-6. Sources of Internal Reset The active reset feature allows the part to issue a reset to peripherals and other chips within a system built around the MCU. 19.4.2.1 Power-On Reset When power is first applied to the MCU, the power-on reset module (POR) generates a pulse to indicate that power-on has occurred. The external reset pin (RST) is held low while the SIM counter counts out 4096 CGMXCLK cycles. Sixty-four CGMXCLK cycles later, the CPU and memories are released from reset to allow the reset vector sequence to occur. At power-on, these events occur: • A POR pulse is generated. Technical Data 278 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Reset and System Initialization • The internal reset signal is asserted. • The SIM enables CGMOUT. • Internal clocks to the CPU and modules are held inactive for 4096 CGMXCLK cycles to allow stabilization of the oscillator. • The RST pin is driven low during the oscillator stabilization time. • The POR bit of the SIM reset status register (SRSR) is set and all other bits in the register are cleared. OSC1 PORRST 4096 CYCLES 32 CYCLES 32 CYCLES CGMXCLK CGMOUT RST $FFFE IAB $FFFF Figure 19-7. POR Recovery 19.4.2.2 Computer Operating Properly (COP) Reset An input to the SIM is reserved for the COP reset signal. The overflow of the COP counter causes an internal reset and sets the COP bit in the SIM reset status register (SRSR). The SIM actively pulls down the RST pin for all internal reset sources. To prevent a COP module timeout, write any value to location $FFFF. Writing to location $FFFF clears the COP counter and bits 12 through 4 of the SIM counter. The SIM counter output, which occurs at least every 213 – 24 CGMXCLK cycles, drives the COP counter. The COP should be serviced as soon as possible out of reset to guarantee the maximum amount of time before the first timeout. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 279 System Integration Module (SIM) The COP module is disabled if the RST pin or the IRQ pin is held at Vtst while the MCU is in monitor mode. The COP module can be disabled only through combinational logic conditioned with the high voltage signal on the RST or the IRQ pin. This prevents the COP from becoming disabled as a result of external noise. During a break state, Vtst on the RST pin disables the COP module. 19.4.2.3 Illegal Opcode Reset The SIM decodes signals from the CPU to detect illegal instructions. An illegal instruction sets the ILOP bit in the SIM reset status register (SRSR) and causes a reset. If the stop enable bit, STOP, in the mask option register is logic 0, the SIM treats the STOP instruction as an illegal opcode and causes an illegal opcode reset. The SIM actively pulls down the RST pin for all internal reset sources. 19.4.2.4 Illegal Address Reset An opcode fetch from an unmapped address generates an illegal address reset. The SIM verifies that the CPU is fetching an opcode prior to asserting the ILAD bit in the SIM reset status register (SRSR) and resetting the MCU. A data fetch from an unmapped address does not generate a reset. The SIM actively pulls down the RST pin for all internal reset sources. 19.4.2.5 Low-Voltage Inhibit (LVI) Reset The low-voltage inhibit module (LVI) asserts its output to the SIM when the VDD voltage falls to the LVITRIPF voltage. The LVI bit in the SIM reset status register (SRSR) is set, and the external reset pin (RST) is held low while the SIM counter counts out 4096 CGMXCLK cycles. Sixty-four CGMXCLK cycles later, the CPU is released from reset to allow the reset vector sequence to occur. The SIM actively pulls down the RST pin for all internal reset sources. Technical Data 280 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) SIM Counter 19.4.2.6 Monitor Mode Entry Module Reset (MODRST) The monitor mode entry module reset (MODRST) asserts its output to the SIM when monitor mode is entered in the condition where the reset vectors are blank ($00). (See Entering Monitor Mode.) When MODRST gets asserted, an internal reset occurs. The SIM actively pulls down the RST pin for all internal reset sources. 19.5 SIM Counter The SIM counter is used by the power-on reset module (POR) and in stop mode recovery to allow the oscillator time to stabilize before enabling the internal bus (IBUS) clocks. The SIM counter also serves as a prescaler for the computer operating properly module (COP). The SIM counter overflow supplies the clock for the COP module. The SIM counter is 13 bits long and is clocked by the falling edge of CGMXCLK. 19.5.1 SIM Counter During Power-On Reset The power-on reset module (POR) detects power applied to the MCU. At power-on, the POR circuit asserts the signal PORRST. Once the SIM is initialized, it enables the clock generation module (CGM) to drive the bus clock state machine. 19.5.2 SIM Counter During Stop Mode Recovery The SIM counter also is used for stop mode recovery. The STOP instruction clears the SIM counter. After an interrupt, break, or reset, the SIM senses the state of the short stop recovery bit, SSREC, in the mask option register. If the SSREC bit is a logic 1, then the stop recovery is reduced from the normal delay of 4096 CGMXCLK cycles down to 32 CGMXCLK cycles. This is ideal for applications using canned oscillators that do not require long startup times from stop mode. External crystal applications should use the full stop recovery time, that is, with SSREC cleared. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 281 System Integration Module (SIM) 19.5.3 SIM Counter and Reset States External reset has no effect on the SIM counter. (See Stop Mode for details.) The SIM counter is free-running after all reset states. (See Active Resets from Internal Sources for counter control and internal reset recovery sequences.) 19.6 Exception Control Normal, sequential program execution can be changed in three different ways: • Interrupts: – Maskable hardware CPU interrupts – Non-maskable software interrupt instruction (SWI) • Reset • Break interrupts 19.6.1 Interrupts At the beginning of an interrupt, the CPU saves the CPU register contents on the stack and sets the interrupt mask (I bit) to prevent additional interrupts. At the end of an interrupt, the RTI instruction recovers the CPU register contents from the stack so that normal processing can resume. Figure 19-8 shows interrupt entry timing. Figure 19-9 shows interrupt recovery timing. Interrupts are latched, and arbitration is performed in the SIM at the start of interrupt processing. The arbitration result is a constant that the CPU uses to determine which vector to fetch. Once an interrupt is latched by the SIM, no other interrupt can take precedence, regardless of priority, until the latched interrupt is serviced (or the I bit is cleared). See Figure 19-10. Technical Data 282 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Exception Control MODULE INTERRUPT I BIT IAB IDB SP DUMMY DUMMY SP – 1 PC – 1[7:0] SP – 2 PC–1[15:8] SP – 3 X SP – 4 A VECT H CCR VECT L V DATA H START ADDR V DATA L OPCODE R/W Figure 19-8. Interrupt Entry Timing MODULE INTERRUPT I BIT IAB SP – 4 IDB SP – 3 CCR SP – 2 A SP – 1 X SP PC – 1 [7:0] PC PC–1[15:8] PC + 1 OPCODE OPERAND R/W Figure 19-9. Interrupt Recovery Timing MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 283 System Integration Module (SIM) FROM RESET BREAK I BIT SET? INTERRUPT? YES NO YES I BIT SET? NO IRQ0 INTERRUPT? YES NO IRQ INTERRUPT? NO AS MANY INTERRUPTS AS EXIST ON CHIP YES STACK CPU REGISTERS SET I BIT LOAD PC WITH INTERRUPT VECTOR FETCH NEXT INSTRUCTION SWI INSTRUCTION? YES NO RTI INSTRUCTION? YES UNSTACK CPU REGISTERS NO EXECUTE INSTRUCTION Figure 19-10. Interrupt Processing 19.6.1.1 Hardware Interrupts A hardware interrupt does not stop the current instruction. Processing of a hardware interrupt begins after completion of the current instruction. When the current instruction is complete, the SIM checks all pending hardware interrupts. If interrupts are not masked (I bit clear in the Technical Data 284 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Exception Control condition code register) and if the corresponding interrupt enable bit is set, the SIM proceeds with interrupt processing; otherwise, the next instruction is fetched and executed. If more than one interrupt is pending at the end of an instruction execution, the highest priority interrupt is serviced first. Figure 19-11 demonstrates what happens when two interrupts are pending. If an interrupt is pending upon exit from the original interrupt service routine, the pending interrupt is serviced before the LDA instruction is executed. CLI LDA #$FF INT1 BACKGROUND ROUTINE PSHH INT1 INTERRUPT SERVICE ROUTINE PULH RTI INT2 PSHH INT2 INTERRUPT SERVICE ROUTINE PULH RTI Figure 19-11. Interrupt Recognition Example The LDA opcode is prefetched by both the INT1 and INT2 RTI instructions. However, in the case of the INT1 RTI prefetch, this is a redundant operation. NOTE: To maintain compatibility with the M6805 Family, the H register is not pushed on the stack during interrupt entry. If the interrupt service routine modifies the H register or uses the indexed addressing mode, software should save the H register and then restore it prior to exiting the routine. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 285 System Integration Module (SIM) 19.6.1.2 SWI Instruction The SWI instruction is a non-maskable instruction that causes an interrupt regardless of the state of the interrupt mask (I bit) in the condition code register. NOTE: A software interrupt pushes PC onto the stack. A software interrupt does not push PC – 1, as a hardware interrupt does. 19.6.1.3 Interrupt Status Registers The flags in the interrupt status registers identify maskable interrupt sources. Table 19-3 summarizes the interrupt sources and the interrupt status register flags that they set. The interrupt status registers can be useful for debugging. Table 19-3. Interrupt Sources Priority Interrupt Source Interrupt Status Register Flag Highest Reset — Technical Data 286 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Exception Control Table 19-3. Interrupt Sources Priority Lowest Interrupt Source Interrupt Status Register Flag SWI instruction — IRQ pin I1 PLL I2 TIM1 channel 0 I3 TIM1 channel 1 I4 TIM1 overflow I5 TIM2 channel 0 I6 Reserved I7 TIM2 overflow I8 SPI receiver full I9 SPI transmitter empty I10 SCI receive error I11 SCI receive I12 SCI transmit I13 Keyboard I14 ADC conversion complete I15 Timebase module I16 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 287 System Integration Module (SIM) 19.6.1.4 Interrupt Status Register 1 Address: $FE04 Bit 7 6 5 4 3 2 1 Bit 0 Read: I6 I5 I4 I3 I2 I1 0 0 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved Figure 19-12. Interrupt Status Register 1 (INT1) I6–I1 — Interrupt Flags 1–6 These flags indicate the presence of interrupt requests from the sources shown in Table 19-3. 1 = Interrupt request present 0 = No interrupt request present Bit 0 and Bit 1 — Always read 0 19.6.1.5 Interrupt Status Register 2 Address: $FE05 Bit 7 6 5 4 3 2 1 Bit 0 Read: I14 I13 I12 I11 I10 I9 I8 I7 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved Figure 19-13. Interrupt Status Register 2 (INT2) I14–I7 — Interrupt Flags 14–7 These flags indicate the presence of interrupt requests from the sources shown in Table 19-3. 1 = Interrupt request present 0 = No interrupt request present Technical Data 288 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Exception Control 19.6.1.6 Interrupt Status Register 3 Address: $FE06 Bit 7 6 5 4 3 2 1 Bit 0 Read: 0 0 0 0 0 0 I16 I15 Write: R R R R R R R R Reset: 0 0 0 0 0 0 0 0 R = Reserved Figure 19-14. Interrupt Status Register 3 (INT3) Bits 7–2 — Always read 0 I16–I15 — Interrupt Flags 16–15 These flags indicate the presence of an interrupt request from the source shown in Table 19-3. 1 = Interrupt request present 0 = No interrupt request present 19.6.2 Reset All reset sources always have equal and highest priority and cannot be arbitrated. 19.6.3 Break Interrupts The break module can stop normal program flow at a softwareprogrammable break point by asserting its break interrupt output. See Timer Interface Module (TIM). The SIM puts the CPU into the break state by forcing it to the SWI vector location. Refer to the break interrupt subsection of each module to see how each module is affected by the break state. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 289 System Integration Module (SIM) 19.6.4 Status Flag Protection in Break Mode The SIM controls whether status flags contained in other modules can be cleared during break mode. The user can select whether flags are protected from being cleared by properly initializing the break clear flag enable bit (BCFE) in the SIM break flag control register (SBFCR). Protecting flags in break mode ensures that set flags will not be cleared while in break mode. This protection allows registers to be freely read and written during break mode without losing status flag information. Setting the BCFE bit enables the clearing mechanisms. Once cleared in break mode, a flag remains cleared even when break mode is exited. Status flags with a 2-step clearing mechanism — for example, a read of one register followed by the read or write of another — are protected, even when the first step is accomplished prior to entering break mode. Upon leaving break mode, execution of the second step will clear the flag as normal. 19.7 Low-Power Modes Executing the WAIT or STOP instruction puts the MCU in a low powerconsumption mode for standby situations. The SIM holds the CPU in a non-clocked state. The operation of each of these modes is described in the following subsections. Both STOP and WAIT clear the interrupt mask (I) in the condition code register, allowing interrupts to occur. 19.7.1 Wait Mode In wait mode, the CPU clocks are inactive while the peripheral clocks continue to run. Figure 19-15 shows the timing for wait mode entry. A module that is active during wait mode can wake up the CPU with an interrupt if the interrupt is enabled. Stacking for the interrupt begins one cycle after the WAIT instruction during which the interrupt occurred. In wait mode, the CPU clocks are inactive. Refer to the wait mode subsection of each module to see if the module is active or inactive in Technical Data 290 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) Low-Power Modes wait mode. Some modules can be programmed to be active in wait mode. Wait mode also can be exited by a reset or break. A break interrupt during wait mode sets the SIM break stop/wait bit, SBSW, in the SIM break status register (SBSR). If the COP disable bit, COPD, in the mask option register is logic 0, then the computer operating properly module (COP) is enabled and remains active in wait mode. WAIT ADDR IAB WAIT ADDR + 1 PREVIOUS DATA IDB SAME NEXT OPCODE SAME SAME SAME R/W Note: Previous data can be operand data or the WAIT opcode, depending on the last instruction. Figure 19-15. Wait Mode Entry Timing Figure 19-16 and Figure 19-17 show the timing for WAIT recovery. IAB $6E0B $A6 IDB $A6 $6E0C $A6 $00FF $01 $0B $00FE $00FD $00FC $6E EXITSTOPWAIT Note: EXITSTOPWAIT = RST pin, CPU interrupt, or break interrupt Figure 19-16. Wait Recovery from Interrupt or Break MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 291 System Integration Module (SIM) 32 CYCLES IAB IDB 32 CYCLES $6E0B $A6 $A6 RST VCT H RST VCT L $A6 RST CGMXCLK Figure 19-17. Wait Recovery from Internal Reset 19.7.2 Stop Mode In stop mode, the SIM counter is reset and the system clocks are disabled. An interrupt request from a module can cause an exit from stop mode. Stacking for interrupts begins after the selected stop recovery time has elapsed. Reset or break also causes an exit from stop mode. The SIM disables the clock generator module outputs (CGMOUT and CGMXCLK) in stop mode, stopping the CPU and peripherals. Stop recovery time is selectable using the SSREC bit in the mask option register (MOR). If SSREC is set, stop recovery is reduced from the normal delay of 4096 CGMXCLK cycles down to 32. This is ideal for applications using canned oscillators that do not require long startup times from stop mode. NOTE: External crystal applications should use the full stop recovery time by clearing the SSREC bit. A break interrupt during stop mode sets the SIM break stop/wait bit (SBSW) in the SIM break status register (SBSR). The SIM counter is held in reset from the execution of the STOP instruction until the beginning of stop recovery. It is then used to time the recovery period. Figure 19-18 shows stop mode entry timing. NOTE: To minimize stop current, all pins configured as inputs should be driven to a logic 1 or logic 0. Technical Data 292 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) SIM Registers CPUSTOP STOP ADDR IAB STOP ADDR + 1 PREVIOUS DATA IDB SAME NEXT OPCODE SAME SAME SAME R/W Note : Previous data can be operand data or the STOP opcode, depending on the last instruction. Figure 19-18. Stop Mode Entry Timing STOP RECOVERY PERIOD CGMXCLK INT/BREAK IAB STOP + 2 STOP +1 STOP + 2 SP SP – 1 SP – 2 SP – 3 Figure 19-19. Stop Mode Recovery from Interrupt or Break 19.8 SIM Registers The SIM has three memory-mapped registers. Table 19-4 shows the mapping of these registers. Table 19-4. SIM Registers Address Register Access Mode $FE00 SBSR User $FE01 SRSR User $FE03 SBFCR User MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data System Integration Module (SIM) 293 System Integration Module (SIM) 19.8.1 SIM Break Status Register The SIM break status register (SBSR) contains a flag to indicate that a break caused an exit from stop mode or wait mode. Address: $FE00 Bit 7 6 5 4 3 2 R R R R R R 0 0 0 0 0 0 Read: Bit 0 SBSW Write: Reset: 1 R Note(1) 0 R 0 = Reserved Note: 1. Writing a logic 0 clears SBSW. Figure 19-20. SIM Break Status Register (SBSR) SBSW — SIM Break Stop/Wait This status bit is useful in applications requiring a return to wait or stop mode after exiting from a break interrupt. Clear SBSW by writing a logic 0 to it. Reset clears SBSW. 1 = Stop mode or wait mode was exited by break interrupt. 0 = Stop mode or wait mode was not exited by break interrupt. SBSW can be read within the break state SWI routine. The user can modify the return address on the stack by subtracting one from it. The following code is an example of this. Writing 0 to the SBSW bit clears it. This code works if the H register has been pushed onto the stack in the break service routine software. This code should be executed at the end of the break service routine software. HIBYTE EQU 5 ; LOBYTE EQU 6 ; If not SBSW, do RTI ; BRCLR SBSW,SBSR, RETURN ; See if wait mode or stop mode was exited by ; break. TST LOBYTE,SP ;If RETURNLO is not zero, BNE DOLO ;then just decrement low byte. Technical Data 294 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) DEC HIBYTE,SP ;Else deal with high byte, too. DOLO DEC LOBYTE,SP ;Point to WAIT/STOP opcode. RETURN PULH RTI ;Restore H register. 19.8.2 SIM Reset Status Register This register contains six flags that show the source of the last reset provided all previous reset status bits have been cleared. Clear the SIM reset status register by reading it. A power-on reset sets the POR bit and clears all other bits in the register. Address: Read: $FE01 Bit 7 6 5 4 3 2 1 Bit 0 POR PIN COP ILOP ILAD MODRST LVI 0 1 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 19-21. SIM Reset Status Register (SRSR) POR — Power-On Reset Bit 1 = Last reset caused by POR circuit 0 = Read of SRSR PIN — External Reset Bit 1 = Last reset caused by external reset pin (RST) 0 = POR or read of SRSR COP — Computer Operating Properly Reset Bit 1 = Last reset caused by COP counter 0 = POR or read of SRSR ILOP — Illegal Opcode Reset Bit 1 = Last reset caused by an illegal opcode 0 = POR or read of SRSR Technical Data 295 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA System Integration Module (SIM) ILAD — Illegal Address Reset Bit (opcode fetches only) 1 = Last reset caused by an opcode fetch from an illegal address 0 = POR or read of SRSR MODRST — Monitor Mode Entry Module Reset Bit 1 = Last reset caused by monitor mode entry when vector locations $FFFE and $FFFF are $00 after POR while IRQ = VDD 0 = POR or read of SRSR LVI — Low-Voltage Inhibit Reset Bit 1 = Last reset caused by the LVI circuit 0 = POR or read of SRSR 19.8.3 SIM Break Flag Control Register The SIM break control register contains a bit that enables software to clear status bits while the MCU is in a break state. Address: $FE03 Bit 7 6 5 4 3 2 1 Bit 0 BCFE R R R R R R R Read: Write: Reset: 0 R = Reserved Figure 19-22. SIM Break Flag Control Register (SBFCR) BCFE — Break Clear Flag Enable Bit This read/write bit enables software to clear status bits by accessing status registers while the MCU is in a break state. To clear status bits during the break state, the BCFE bit must be set. 1 = Status bits clearable during break 0 = Status bits not clearable during break Technical Data 296 MC68HC908GR8 — Rev 4.0 System Integration Module (SIM) MOTOROLA Technical Data — MC68HC908GR8 Section 20. Serial Peripheral Interface (SPI) 20.1 Contents 20.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 297 20.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 298 20.4 Pin Name Conventions and I/O Register Addresses . . . . . . . 298 20.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 299 20.6 Transmission Formats . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 303 20.7 Queuing Transmission Data . . . . . . . . . . . . . . . . . . . . . . . . . . 309 20.8 Error Conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 310 20.9 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 314 20.10 Resetting the SPI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 316 20.11 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .317 20.12 SPI During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . .318 20.13 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 318 20.14 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 322 20.2 Introduction This section describes the serial peripheral interface (SPI) module, which allows full-duplex, synchronous, serial communications with peripheral devices. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 297 Serial Peripheral Interface (SPI) 20.3 Features Features of the SPI module include: • Full-duplex operation • Master and slave modes • Double-buffered operation with separate transmit and receive registers • Four master mode frequencies (maximum = bus frequency ÷ 2) • Maximum slave mode frequency = bus frequency • Serial clock with programmable polarity and phase • Two separately enabled interrupts: – SPRF (SPI receiver full) – SPTE (SPI transmitter empty) • Mode fault error flag with CPU interrupt capability • Overflow error flag with CPU interrupt capability • Programmable wired-OR mode • I2C (inter-integrated circuit) compatibility • I/O (input/output) port bit(s) software configurable with pullup device(s) if configured as input port bit(s) 20.4 Pin Name Conventions and I/O Register Addresses The text that follows describes the SPI. The SPI I/O pin names are SS (slave select), SPSCK (SPI serial clock), CGND (clock ground), MOSI (master out slave in), and MISO (master in/slave out). The SPI shares four I/O pins with four parallel I/O ports. Technical Data 298 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Functional Description The full names of the SPI I/O pins are shown in Table 20-1. The generic pin names appear in the text that follows. Table 20-1. Pin Name Conventions SPI Generic Pin Names: Full SPI Pin Names: SPI MISO MOSI SS SPSCK CGND PTD1/ATD9 PTD2/ATD1 0 PTD0/AT D8 PTD3/ATD11 VSS 20.5 Functional Description Figure 20-1 summarizes the SPI I/O registers and Figure 20-2 shows the structure of the SPI module. Addr. $0010 $0011 Register Name Bit 7 Read: SPI Control Register Write: (SPCR) Reset: Read: SPI Status and Control Write: Register (SPSCR) Reset: $0012 Read: SPI Data Register Write: (SPDR) Reset: 6 5 4 3 2 1 Bit 0 SPMSTR CPOL CPHA SPWOM SPE SPTIE 1 0 1 0 0 0 OVRF MODF SPTE MODFEN SPR1 SPR0 DMAS SPRIE 0 0 SPRF ERRIE 0 0 0 0 1 0 0 0 R7 R6 R5 R4 R3 R2 R1 R0 T7 T6 T5 T4 T3 T2 T1 T0 Unaffected by reset = Unimplemented Figure 20-1. SPI I/O Register Summary MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 299 Serial Peripheral Interface (SPI) INTERNAL BUS TRANSMIT DATA REGISTER CGMOUT ÷ 2 FROM SIM SHIFT REGISTER 7 6 5 4 3 2 1 MISO 0 ÷2 MOSI ÷8 CLOCK DIVIDER ÷ 32 RECEIVE DATA REGISTER PIN CONTROL LOGIC ÷ 128 SPMSTR SPE CLOCK SELECT SPR1 SPSCK M CLOCK LOGIC S SS SPR0 SPMSTR RESERVED MODFEN TRANSMITTER CPU INTERRUPT REQUEST RESERVED CPHA CPOL SPWOM ERRIE SPI CONTROL SPTIE SPRIE RECEIVER/ERROR CPU INTERRUPT REQUEST DMAS SPE SPRF SPTE OVRF MODF Figure 20-2. SPI Module Block Diagram The SPI module allows full-duplex, synchronous, serial communication between the MCU and peripheral devices, including other MCUs. Software can poll the SPI status flags or SPI operation can be interruptdriven. If a port bit is configured for input, then an internal pullup device may be enabled for that port bit. See Port D Input Pullup Enable Register. Technical Data 300 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Functional Description The following paragraphs describe the operation of the SPI module. 20.5.1 Master Mode The SPI operates in master mode when the SPI master bit, SPMSTR, is set. NOTE: Configure the SPI modules as master or slave before enabling them. Enable the master SPI before enabling the slave SPI. Disable the slave SPI before disabling the master SPI. See SPI Control Register. Only a master SPI module can initiate transmissions. Software begins the transmission from a master SPI module by writing to the transmit data register. If the shift register is empty, the byte immediately transfers to the shift register, setting the SPI transmitter empty bit, SPTE. The byte begins shifting out on the MOSI pin under the control of the serial clock. See Figure 20-3. MASTER MCU SHIFT REGISTER SLAVE MCU MISO MISO MOSI MOSI SPSCK BAUD RATE GENERATOR SS SHIFT REGISTER SPSCK VDD SS Figure 20-3. Full-Duplex Master-Slave Connections MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 301 Serial Peripheral Interface (SPI) The SPR1 and SPR0 bits control the baud rate generator and determine the speed of the shift register. See SPI Status and Control Register. Through the SPSCK pin, the baud rate generator of the master also controls the shift register of the slave peripheral. As the byte shifts out on the MOSI pin of the master, another byte shifts in from the slave on the master’s MISO pin. The transmission ends when the receiver full bit, SPRF, becomes set. At the same time that SPRF becomes set, the byte from the slave transfers to the receive data register. In normal operation, SPRF signals the end of a transmission. Software clears SPRF by reading the SPI status and control register with SPRF set and then reading the SPI data register. Writing to the SPI data register clears the SPTE bit. 20.5.2 Slave Mode The SPI operates in slave mode when the SPMSTR bit is clear. In slave mode, the SPSCK pin is the input for the serial clock from the master MCU. Before a data transmission occurs, the SS pin of the slave SPI must be at logic 0. SS must remain low until the transmission is complete. See Mode Fault Error. In a slave SPI module, data enters the shift register under the control of the serial clock from the master SPI module. After a byte enters the shift register of a slave SPI, it transfers to the receive data register, and the SPRF bit is set. To prevent an overflow condition, slave software then must read the receive data register before another full byte enters the shift register. The maximum frequency of the SPSCK for an SPI configured as a slave is the bus clock speed (which is twice as fast as the fastest master SPSCK clock that can be generated). The frequency of the SPSCK for an SPI configured as a slave does not have to correspond to any SPI baud rate. The baud rate only controls the speed of the SPSCK generated by an SPI configured as a master. Therefore, the frequency of the SPSCK for an SPI configured as a slave can be any frequency less than or equal to the bus speed. Technical Data 302 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Transmission Formats When the master SPI starts a transmission, the data in the slave shift register begins shifting out on the MISO pin. The slave can load its shift register with a new byte for the next transmission by writing to its transmit data register. The slave must write to its transmit data register at least one bus cycle before the master starts the next transmission. Otherwise, the byte already in the slave shift register shifts out on the MISO pin. Data written to the slave shift register during a transmission remains in a buffer until the end of the transmission. When the clock phase bit (CPHA) is set, the first edge of SPSCK starts a transmission. When CPHA is clear, the falling edge of SS starts a transmission. See Transmission Formats. NOTE: SPSCK must be in the proper idle state before the slave is enabled to prevent SPSCK from appearing as a clock edge. 20.6 Transmission Formats During an SPI transmission, data is simultaneously transmitted (shifted out serially) and received (shifted in serially). A serial clock synchronizes shifting and sampling on the two serial data lines. A slave select line allows selection of an individual slave SPI device; slave devices that are not selected do not interfere with SPI bus activities. On a master SPI device, the slave select line can optionally be used to indicate multiplemaster bus contention. 20.6.1 Clock Phase and Polarity Controls Software can select any of four combinations of serial clock (SPSCK) phase and polarity using two bits in the SPI control register (SPCR). The clock polarity is specified by the CPOL control bit, which selects an active high or low clock and has no significant effect on the transmission format. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 303 Serial Peripheral Interface (SPI) The clock phase (CPHA) control bit selects one of two fundamentally different transmission formats. The clock phase and polarity should be identical for the master SPI device and the communicating slave device. In some cases, the phase and polarity are changed between transmissions to allow a master device to communicate with peripheral slaves having different requirements. NOTE: Before writing to the CPOL bit or the CPHA bit, disable the SPI by clearing the SPI enable bit (SPE). 20.6.2 Transmission Format When CPHA = 0 Figure 20-4 shows an SPI transmission in which CPHA is logic 0. The figure should not be used as a replacement for data sheet parametric information. Two waveforms are shown for SPSCK: one for CPOL = 0 and another for CPOL = 1. The diagram may be interpreted as a master or slave timing diagram since the serial clock (SPSCK), master in/slave out (MISO), and master out/slave in (MOSI) pins are directly connected between the master and the slave. The MISO signal is the output from the slave, and the MOSI signal is the output from the master. The SS line is the slave select input to the slave. The slave SPI drives its MISO output only when its slave select input (SS) is at logic 0, so that only the selected slave drives to the master. The SS pin of the master is not shown but is assumed to be inactive. The SS pin of the master must be high or must be reconfigured as general-purpose I/O not affecting the SPI. See Mode Fault Error. When CPHA = 0, the first SPSCK edge is the MSB capture strobe. Therefore, the slave must begin driving its data before the first SPSCK edge, and a falling edge on the SS pin is used to start the slave data transmission. The slave’s SS pin must be toggled back to high and then low again between each byte transmitted as shown in Figure 20-5. Technical Data 304 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Transmission Formats SPSCK CYCLE # FOR REFERENCE 1 2 3 4 5 6 7 8 MSB BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 LSB BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 LSB SPSCK; CPOL = 0 SPSCK; CPOL =1 MOSI FROM MASTER MISO FROM SLAVE MSB SS; TO SLAVE CAPTURE STROBE Figure 20-4. Transmission Format (CPHA = 0) MISO/MOSI BYTE 1 BYTE 2 BYTE 3 MASTER SS SLAVE SS CPHA = 0 SLAVE SS CPHA = 1 Figure 20-5. CPHA/SS Timing When CPHA = 0 for a slave, the falling edge of SS indicates the beginning of the transmission. This causes the SPI to leave its idle state and begin driving the MISO pin with the MSB of its data. Once the transmission begins, no new data is allowed into the shift register from the transmit data register. Therefore, the SPI data register of the slave must be loaded with transmit data before the falling edge of SS. Any data written after the falling edge is stored in the transmit data register and transferred to the shift register after the current transmission. 20.6.3 Transmission Format When CPHA = 1 Figure 20-6 shows an SPI transmission in which CPHA is logic 1. The figure should not be used as a replacement for data sheet parametric information. Two waveforms are shown for SPSCK: one for CPOL = 0 and another for CPOL = 1. The diagram may be interpreted as a master or slave timing diagram since the serial clock (SPSCK), master in/slave MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 305 Serial Peripheral Interface (SPI) out (MISO), and master out/slave in (MOSI) pins are directly connected between the master and the slave. The MISO signal is the output from the slave, and the MOSI signal is the output from the master. The SS line is the slave select input to the slave. The slave SPI drives its MISO output only when its slave select input (SS) is at logic 0, so that only the selected slave drives to the master. The SS pin of the master is not shown but is assumed to be inactive. The SS pin of the master must be high or must be reconfigured as general-purpose I/O not affecting the SPI. See Mode Fault Error. When CPHA = 1, the master begins driving its MOSI pin on the first SPSCK edge. Therefore, the slave uses the first SPSCK edge as a start transmission signal. The SS pin can remain low between transmissions. This format may be preferable in systems having only one master and only one slave driving the MISO data line. SPSCK CYCLE # FOR REFERENCE 1 2 3 4 5 6 7 8 MOSI FROM MASTER MSB BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 LSB MISO FROM SLAVE MSB BIT 6 BIT 5 BIT 4 BIT 3 BIT 2 BIT 1 SPSCK; CPOL = 0 SPSCK; CPOL =1 LSB SS; TO SLAVE CAPTURE STROBE Figure 20-6. Transmission Format (CPHA = 1) Technical Data 306 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Transmission Formats When CPHA = 1 for a slave, the first edge of the SPSCK indicates the beginning of the transmission. This causes the SPI to leave its idle state and begin driving the MISO pin with the MSB of its data. Once the transmission begins, no new data is allowed into the shift register from the transmit data register. Therefore, the SPI data register of the slave must be loaded with transmit data before the first edge of SPSCK. Any data written after the first edge is stored in the transmit data register and transferred to the shift register after the current transmission. 20.6.4 Transmission Initiation Latency When the SPI is configured as a master (SPMSTR = 1), writing to the SPDR starts a transmission. CPHA has no effect on the delay to the start of the transmission, but it does affect the initial state of the SPSCK signal. When CPHA = 0, the SPSCK signal remains inactive for the first half of the first SPSCK cycle. When CPHA = 1, the first SPSCK cycle begins with an edge on the SPSCK line from its inactive to its active level. The SPI clock rate (selected by SPR1:SPR0) affects the delay from the write to SPDR and the start of the SPI transmission. See Figure 20-7. The internal SPI clock in the master is a free-running derivative of the internal MCU clock. To conserve power, it is enabled only when both the SPE and SPMSTR bits are set. SPSCK edges occur halfway through the low time of the internal MCU clock. Since the SPI clock is freerunning, it is uncertain where the write to the SPDR occurs relative to the slower SPSCK. This uncertainty causes the variation in the initiation delay shown in Figure 20-7. This delay is no longer than a single SPI bit time. That is, the maximum delay is two MCU bus cycles for DIV2, eight MCU bus cycles for DIV8, 32 MCU bus cycles for DIV32, and 128 MCU bus cycles for DIV128. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 307 Serial Peripheral Interface (SPI) WRITE TO SPDR INITIATION DELAY BUS CLOCK MOSI MSB BIT 6 1 2 BIT 5 SPSCK CPHA = 1 SPSCK CPHA = 0 SPSCK CYCLE NUMBER 3 INITIATION DELAY FROM WRITE SPDR TO TRANSFER BEGIN         WRITE TO SPDR BUS CLOCK EARLIEST LATEST WRITE TO SPDR SPSCK = INTERNAL CLOCK ÷ 2; 2 POSSIBLE START POINTS BUS CLOCK EARLIEST WRITE TO SPDR SPSCK = INTERNAL CLOCK ÷ 8; 8 POSSIBLE START POINTS LATEST SPSCK = INTERNAL CLOCK ÷ 32; 32 POSSIBLE START POINTS LATEST SPSCK = INTERNAL CLOCK ÷ 128; 128 POSSIBLE START POINTS LATEST BUS CLOCK EARLIEST WRITE TO SPDR BUS CLOCK EARLIEST Figure 20-7. Transmission Start Delay (Master) Technical Data 308 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Queuing Transmission Data 20.7 Queuing Transmission Data The double-buffered transmit data register allows a data byte to be queued and transmitted. For an SPI configured as a master, a queued data byte is transmitted immediately after the previous transmission has completed. The SPI transmitter empty flag (SPTE) indicates when the transmit data buffer is ready to accept new data. Write to the transmit data register only when the SPTE bit is high. Figure 20-8 shows the timing associated with doing back-to-back transmissions with the SPI (SPSCK has CPHA: CPOL = 1:0). WRITE TO SPDR SPTE 1 3 8 5 2 10 SPSCK CPHA:CPOL = 1:0 MOSI MSB BIT BIT BIT BIT BIT BIT LSB MSB BIT BIT BIT BIT BIT BIT LSB MSB BIT BIT BIT 6 5 4 3 2 1 6 5 4 3 2 1 6 5 4 BYTE 1 BYTE 2 BYTE 3 9 4 SPRF 6 READ SPSCR 11 7 READ SPDR 12 1 CPU WRITES BYTE 1 TO SPDR, CLEARING SPTE BIT. 7 CPU READS SPDR, CLEARING SPRF BIT. 2 BYTE 1 TRANSFERS FROM TRANSMIT DATA REGISTER TO SHIFT REGISTER, SETTING SPTE BIT. 8 3 CPU WRITES BYTE 2 TO SPDR, QUEUEING BYTE 2 AND CLEARING SPTE BIT. FIRST INCOMING BYTE TRANSFERS FROM SHIFT REGISTER TO RECEIVE DATA REGISTER, SETTING SPRF BIT. 5 BYTE 2 TRANSFERS FROM TRANSMIT DATA REGISTER TO SHIFT REGISTER, SETTING SPTE BIT. 6 CPU READS SPSCR WITH SPRF BIT SET. 4 CPU WRITES BYTE 3 TO SPDR, QUEUEING BYTE 3 AND CLEARING SPTE BIT. 9 SECOND INCOMING BYTE TRANSFERS FROM SHIFT REGISTER TO RECEIVE DATA REGISTER, SETTING SPRF BIT. 10 BYTE 3 TRANSFERS FROM TRANSMIT DATA REGISTER TO SHIFT REGISTER, SETTING SPTE BIT. 11 CPU READS SPSCR WITH SPRF BIT SET. 12 CPU READS SPDR, CLEARING SPRF BIT. Figure 20-8. .SPRF/SPTE CPU Interrupt Timing The transmit data buffer allows back-to-back transmissions without the slave precisely timing its writes between transmissions as in a system with a single data buffer. Also, if no new data is written to the data buffer, the last value contained in the shift register is the next data word to be transmitted. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 309 Serial Peripheral Interface (SPI) For an idle master or idle slave that has no data loaded into its transmit buffer, the SPTE is set again no more than two bus cycles after the transmit buffer empties into the shift register. This allows the user to queue up a 16-bit value to send. For an already active slave, the load of the shift register cannot occur until the transmission is completed. This implies that a back-to-back write to the transmit data register is not possible. The SPTE indicates when the next write can occur. 20.8 Error Conditions The following flags signal SPI error conditions: • Overflow (OVRF) — Failing to read the SPI data register before the next full byte enters the shift register sets the OVRF bit. The new byte does not transfer to the receive data register, and the unread byte still can be read. OVRF is in the SPI status and control register. • Mode fault error (MODF) — The MODF bit indicates that the voltage on the slave select pin (SS) is inconsistent with the mode of the SPI. MODF is in the SPI status and control register. 20.8.1 Overflow Error The overflow flag (OVRF) becomes set if the receive data register still has unread data from a previous transmission when the capture strobe of bit 1 of the next transmission occurs. The bit 1 capture strobe occurs in the middle of SPSCK cycle 7. (See Figure 20-4 and Figure 20-6.) If an overflow occurs, all data received after the overflow and before the OVRF bit is cleared does not transfer to the receive data register and does not set the SPI receiver full bit (SPRF). The unread data that transferred to the receive data register before the overflow occurred can still be read. Therefore, an overflow error always indicates the loss of data. Clear the overflow flag by reading the SPI status and control register and then reading the SPI data register. OVRF generates a receiver/error CPU interrupt request if the error interrupt enable bit (ERRIE) is also set. The SPRF, MODF, and OVRF Technical Data 310 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Error Conditions interrupts share the same CPU interrupt vector. See Figure 20-11. It is not possible to enable MODF or OVRF individually to generate a receiver/error CPU interrupt request. However, leaving MODFEN low prevents MODF from being set. If the CPU SPRF interrupt is enabled and the OVRF interrupt is not, watch for an overflow condition. Figure 20-9 shows how it is possible to miss an overflow. The first part of Figure 20-9 shows how it is possible to read the SPSCR and SPDR to clear the SPRF without problems. However, as illustrated by the second transmission example, the OVRF bit can be set in between the time that SPSCR and SPDR are read. BYTE 1 BYTE 2 BYTE 3 BYTE 4 1 4 6 8 SPRF OVRF READ SPSCR 2 READ SPDR 5 3 1 BYTE 1 SETS SPRF BIT. 2 CPU READS SPSCR WITH SPRF BIT SET AND OVRF BIT CLEAR. CPU READS BYTE 1 IN SPDR, CLEARING SPRF BIT. BYTE 2 SETS SPRF BIT. 3 4 7 5 CPU READS SPSCR WITH SPRF BIT SET AND OVRF BIT CLEAR. 6 BYTE 3 SETS OVRF BIT. BYTE 3 IS LOST. 7 CPU READS BYTE 2 IN SPDR, CLEARING SPRF BIT, BUT NOT OVRF BIT. 8 BYTE 4 FAILS TO SET SPRF BIT BECAUSE OVRF BIT IS NOT CLEARED. BYTE 4 IS LOST. Figure 20-9. Missed Read of Overflow Condition In this case, an overflow can be missed easily. Since no more SPRF interrupts can be generated until this OVRF is serviced, it is not obvious that bytes are being lost as more transmissions are completed. To prevent this, either enable the OVRF interrupt or do another read of the SPSCR following the read of the SPDR. This ensures that the OVRF was not set before the SPRF was cleared and that future transmissions can set the SPRF bit. Figure 20-10 illustrates this process. Generally, to avoid this second SPSCR read, enable the OVRF to the CPU by setting the ERRIE bit. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 311 Serial Peripheral Interface (SPI) BYTE 1 SPI RECEIVE COMPLETE BYTE 2 5 1 BYTE 3 7 BYTE 4 11 SPRF OVRF READ SPSCR 2 READ SPDR 4 3 1 BYTE 1 SETS SPRF BIT. 2 CPU READS SPSCR WITH SPRF BIT SET AND OVRF BIT CLEAR. CPU READS BYTE 1 IN SPDR, CLEARING SPRF BIT. 3 6 9 8 12 14 10 13 8 CPU READS BYTE 2 IN SPDR, CLEARING SPRF BIT. 9 CPU READS SPSCR AGAIN TO CHECK OVRF BIT. 10 CPU READS BYTE 2 SPDR, CLEARING OVRF BIT. 4 CPU READS SPSCR AGAIN TO CHECK OVRF BIT. 11 BYTE 4 SETS SPRF BIT. 5 BYTE 2 SETS SPRF BIT. 12 CPU READS SPSCR. 6 CPU READS SPSCR WITH SPRF BIT SET AND OVRF BIT CLEAR. 13 CPU READS BYTE 4 IN SPDR, CLEARING SPRF BIT. 7 BYTE 3 SETS OVRF BIT. BYTE 3 IS LOST. 14 CPU READS SPSCR AGAIN TO CHECK OVRF BIT. Figure 20-10. Clearing SPRF When OVRF Interrupt Is Not Enabled 20.8.2 Mode Fault Error Setting the SPMSTR bit selects master mode and configures the SPSCK and MOSI pins as outputs and the MISO pin as an input. Clearing SPMSTR selects slave mode and configures the SPSCK and MOSI pins as inputs and the MISO pin as an output. The mode fault bit, MODF, becomes set any time the state of the slave select pin, SS, is inconsistent with the mode selected by SPMSTR. To prevent SPI pin contention and damage to the MCU, a mode fault error occurs if: • The SS pin of a slave SPI goes high during a transmission • The SS pin of a master SPI goes low at any time For the MODF flag to be set, the mode fault error enable bit (MODFEN) must be set. Clearing the MODFEN bit does not clear the MODF flag but does prevent MODF from being set again after MODF is cleared. Technical Data 312 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Error Conditions MODF generates a receiver/error CPU interrupt request if the error interrupt enable bit (ERRIE) is also set. The SPRF, MODF, and OVRF interrupts share the same CPU interrupt vector. See Figure 20-11. It is not possible to enable MODF or OVRF individually to generate a receiver/error CPU interrupt request. However, leaving MODFEN low prevents MODF from being set. In a master SPI with the mode fault enable bit (MODFEN) set, the mode fault flag (MODF) is set if SS goes to logic 0. A mode fault in a master SPI causes the following events to occur: NOTE: • If ERRIE = 1, the SPI generates an SPI receiver/error CPU interrupt request. • The SPE bit is cleared. • The SPTE bit is set. • The SPI state counter is cleared. • The data direction register of the shared I/O port regains control of port drivers. To prevent bus contention with another master SPI after a mode fault error, clear all SPI bits of the data direction register of the shared I/O port before enabling the SPI. When configured as a slave (SPMSTR = 0), the MODF flag is set if SS goes high during a transmission. When CPHA = 0, a transmission begins when SS goes low and ends once the incoming SPSCK goes back to its idle level following the shift of the eighth data bit. When CPHA = 1, the transmission begins when the SPSCK leaves its idle level and SS is already low. The transmission continues until the SPSCK returns to its idle level following the shift of the last data bit. See Transmission Formats. NOTE: Setting the MODF flag does not clear the SPMSTR bit. The SPMSTR bit has no function when SPE = 0. Reading SPMSTR when MODF = 1 shows the difference between a MODF occurring when the SPI is a master and when it is a slave. When CPHA = 0, a MODF occurs if a slave is selected (SS is at logic 0) and later unselected (SS is at logic 1) even if no SPSCK is sent to that MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 313 Serial Peripheral Interface (SPI) slave. This happens because SS at logic 0 indicates the start of the transmission (MISO driven out with the value of MSB) for CPHA = 0. When CPHA = 1, a slave can be selected and then later unselected with no transmission occurring. Therefore, MODF does not occur since a transmission was never begun. In a slave SPI (MSTR = 0), the MODF bit generates an SPI receiver/error CPU interrupt request if the ERRIE bit is set. The MODF bit does not clear the SPE bit or reset the SPI in any way. Software can abort the SPI transmission by clearing the SPE bit of the slave. NOTE: A logic 1 voltage on the SS pin of a slave SPI puts the MISO pin in a high impedance state. Also, the slave SPI ignores all incoming SPSCK clocks, even if it was already in the middle of a transmission. To clear the MODF flag, read the SPSCR with the MODF bit set and then write to the SPCR register. This entire clearing mechanism must occur with no MODF condition existing or else the flag is not cleared. 20.9 Interrupts Four SPI status flags can be enabled to generate CPU interrupt requests. Table 20-2. SPI Interrupts Flag Request SPTE Transmitter empty SPI transmitter CPU interrupt request (DMAS = 0, SPTIE = 1, SPE = 1) SPRF Receiver full SPI receiver CPU interrupt request (DMAS = 0, SPRIE = 1) OVRF Overflow SPI receiver/error interrupt request (ERRIE = 1) MODF Mode fault SPI receiver/error interrupt request (ERRIE = 1) Technical Data 314 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Interrupts Reading the SPI status and control register with SPRF set and then reading the receive data register clears SPRF. The clearing mechanism for the SPTE flag is always just a write to the transmit data register. The SPI transmitter interrupt enable bit (SPTIE) enables the SPTE flag to generate transmitter CPU interrupt requests, provided that the SPI is enabled (SPE = 1). The SPI receiver interrupt enable bit (SPRIE) enables the SPRF bit to generate receiver CPU interrupt requests, regardless of the state of the SPE bit. See Figure 20-11. The error interrupt enable bit (ERRIE) enables both the MODF and OVRF bits to generate a receiver/error CPU interrupt request. The mode fault enable bit (MODFEN) can prevent the MODF flag from being set so that only the OVRF bit is enabled by the ERRIE bit to generate receiver/error CPU interrupt requests. NOT AVAILABLE SPTE SPTIE SPE SPI TRANSMITTER CPU INTERRUPT REQUEST DMAS NOT AVAILABLE SPRIE SPRF SPI RECEIVER/ERROR CPU INTERRUPT REQUEST ERRIE MODF OVRF Figure 20-11. SPI Interrupt Request Generation MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 315 Serial Peripheral Interface (SPI) The following sources in the SPI status and control register can generate CPU interrupt requests: • SPI receiver full bit (SPRF) — The SPRF bit becomes set every time a byte transfers from the shift register to the receive data register. If the SPI receiver interrupt enable bit, SPRIE, is also set, SPRF generates an SPI receiver/error CPU interrupt request. • SPI transmitter empty (SPTE) — The SPTE bit becomes set every time a byte transfers from the transmit data register to the shift register. If the SPI transmit interrupt enable bit, SPTIE, is also set, SPTE generates an SPTE CPU interrupt request. 20.10 Resetting the SPI Any system reset completely resets the SPI. Partial resets occur whenever the SPI enable bit (SPE) is low. Whenever SPE is low, the following occurs: • The SPTE flag is set. • Any transmission currently in progress is aborted. • The shift register is cleared. • The SPI state counter is cleared, making it ready for a new complete transmission. • All the SPI port logic is defaulted back to being general-purpose I/O. These items are reset only by a system reset: • All control bits in the SPCR register • All control bits in the SPSCR register (MODFEN, ERRIE, SPR1, and SPR0) • The status flags SPRF, OVRF, and MODF By not resetting the control bits when SPE is low, the user can clear SPE between transmissions without having to set all control bits again when SPE is set back high for the next transmission. Technical Data 316 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) Low-Power Modes By not resetting the SPRF, OVRF, and MODF flags, the user can still service these interrupts after the SPI has been disabled. The user can disable the SPI by writing 0 to the SPE bit. The SPI can also be disabled by a mode fault occurring in an SPI that was configured as a master with the MODFEN bit set. 20.11 Low-Power Modes The WAIT and STOP instructions put the MCU in low powerconsumption standby modes. 20.11.1 Wait Mode The SPI module remains active after the execution of a WAIT instruction. In wait mode the SPI module registers are not accessible by the CPU. Any enabled CPU interrupt request from the SPI module can bring the MCU out of wait mode. If SPI module functions are not required during wait mode, reduce power consumption by disabling the SPI module before executing the WAIT instruction. To exit wait mode when an overflow condition occurs, enable the OVRF bit to generate CPU interrupt requests by setting the error interrupt enable bit (ERRIE). See Interrupts. 20.11.2 Stop Mode The SPI module is inactive after the execution of a STOP instruction. The STOP instruction does not affect register conditions. SPI operation resumes after an external interrupt. If stop mode is exited by reset, any transfer in progress is aborted, and the SPI is reset. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 317 Serial Peripheral Interface (SPI) 20.12 SPI During Break Interrupts The system integration module (SIM) controls whether status bits in other modules can be cleared during the break state. The BCFE bit in the SIM break flag control register (SBFCR) enables software to clear status bits during the break state. See System Integration Module (SIM). To allow software to clear status bits during a break interrupt, write a logic 1 to the BCFE bit. If a status bit is cleared during the break state, it remains cleared when the MCU exits the break state. To protect status bits during the break state, write a logic 0 to the BCFE bit. With BCFE at logic 0 (its default state), software can read and write I/O registers during the break state without affecting status bits. Some status bits have a 2-step read/write clearing procedure. If software does the first step on such a bit before the break, the bit cannot change during the break state as long as BCFE is at logic 0. After the break, doing the second step clears the status bit. Since the SPTE bit cannot be cleared during a break with the BCFE bit cleared, a write to the transmit data register in break mode does not initiate a transmission nor is this data transferred into the shift register. Therefore, a write to the SPDR in break mode with the BCFE bit cleared has no effect. 20.13 I/O Signals The SPI module has five I/O pins and shares four of them with a parallel I/O port. They are: • MISO — Data received • MOSI — Data transmitted • SPSCK — Serial clock • SS — Slave select • CGND — Clock ground (internally connected to VSS) The SPI has limited inter-integrated circuit (I2C) capability (requiring software support) as a master in a single-master environment. To Technical Data 318 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) I/O Signals communicate with I2C peripherals, MOSI becomes an open-drain output when the SPWOM bit in the SPI control register is set. In I2C communication, the MOSI and MISO pins are connected to a bidirectional pin from the I2C peripheral and through a pullup resistor to VDD. 20.13.1 MISO (Master In/Slave Out) MISO is one of the two SPI module pins that transmits serial data. In full duplex operation, the MISO pin of the master SPI module is connected to the MISO pin of the slave SPI module. The master SPI simultaneously receives data on its MISO pin and transmits data from its MOSI pin. Slave output data on the MISO pin is enabled only when the SPI is configured as a slave. The SPI is configured as a slave when its SPMSTR bit is logic 0 and its SS pin is at logic 0. To support a multipleslave system, a logic 1 on the SS pin puts the MISO pin in a highimpedance state. When enabled, the SPI controls data direction of the MISO pin regardless of the state of the data direction register of the shared I/O port. 20.13.2 MOSI (Master Out/Slave In) MOSI is one of the two SPI module pins that transmits serial data. In fullduplex operation, the MOSI pin of the master SPI module is connected to the MOSI pin of the slave SPI module. The master SPI simultaneously transmits data from its MOSI pin and receives data on its MISO pin. When enabled, the SPI controls data direction of the MOSI pin regardless of the state of the data direction register of the shared I/O port. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 319 Serial Peripheral Interface (SPI) 20.13.3 SPSCK (Serial Clock) The serial clock synchronizes data transmission between master and slave devices. In a master MCU, the SPSCK pin is the clock output. In a slave MCU, the SPSCK pin is the clock input. In full-duplex operation, the master and slave MCUs exchange a byte of data in eight serial clock cycles. When enabled, the SPI controls data direction of the SPSCK pin regardless of the state of the data direction register of the shared I/O port. 20.13.4 SS (Slave Select) The SS pin has various functions depending on the current state of the SPI. For an SPI configured as a slave, the SS is used to select a slave. For CPHA = 0, the SS is used to define the start of a transmission. See Transmission Formats. Since it is used to indicate the start of a transmission, the SS must be toggled high and low between each byte transmitted for the CPHA = 0 format. However, it can remain low between transmissions for the CPHA = 1 format. See Figure 20-12. MISO/MOSI BYTE 1 BYTE 2 BYTE 3 MASTER SS SLAVE SS CPHA = 0 SLAVE SS CPHA = 1 Figure 20-12CPHA/SS Timing When an SPI is configured as a slave, the SS pin is always configured as an input. It cannot be used as a general-purpose I/O regardless of the state of the MODFEN control bit. However, the MODFEN bit can still prevent the state of the SS from creating a MODF error. See SPI Status and Control Register. NOTE: A logic 1 voltage on the SS pin of a slave SPI puts the MISO pin in a highimpedance state. The slave SPI ignores all incoming SPSCK clocks, even if it was already in the middle of a transmission. Technical Data 320 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) I/O Signals When an SPI is configured as a master, the SS input can be used in conjunction with the MODF flag to prevent multiple masters from driving MOSI and SPSCK. See Mode Fault Error. For the state of the SS pin to set the MODF flag, the MODFEN bit in the SPSCK register must be set. If the MODFEN bit is low for an SPI master, the SS pin can be used as a general-purpose I/O under the control of the data direction register of the shared I/O port. With MODFEN high, it is an input-only pin to the SPI regardless of the state of the data direction register of the shared I/O port. The CPU can always read the state of the SS pin by configuring the appropriate pin as an input and reading the port data register. See Table 20-3. Table 20-3. SPI Configuration SPE SPMSTR MODFEN SPI Configuration State of SS Logic 0 X(1) X Not enabled General-purpose I/O; SS ignored by SPI 1 0 X Slave Input-only to SPI 1 1 0 Master without MODF General-purpose I/O; SS ignored by SPI 1 1 1 Master with MODF Input-only to SPI Note 1. X = Don’t care 20.13.5 CGND (Clock Ground) CGND is the ground return for the serial clock pin, SPSCK, and the ground for the port output buffers. It is internally connected to VSS as shown in Table 20-1. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 321 Serial Peripheral Interface (SPI) 20.14 I/O Registers Three registers control and monitor SPI operation: • SPI control register (SPCR) • SPI status and control register (SPSCR) • SPI data register (SPDR) 20.14.1 SPI Control Register The SPI control register: • Enables SPI module interrupt requests • Configures the SPI module as master or slave • Selects serial clock polarity and phase • Configures the SPSCK, MOSI, and MISO pins as open-drain outputs • Enables the SPI module Address: $0010 Bit 7 6 Read: 5 4 3 2 1 Bit 0 SPMSTR CPOL CPHA SPWOM SPE SPTIE 1 0 1 0 0 0 DMAS SPRIE Write: Reset: 0 0 = Unimplemented Figure 20-13. SPI Control Register (SPCR) Technical Data 322 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) I/O Registers SPRIE — SPI Receiver Interrupt Enable Bit This read/write bit enables CPU interrupt requests generated by the SPRF bit. The SPRF bit is set when a byte transfers from the shift register to the receive data register. Reset clears the SPRIE bit. 1 = SPRF CPU interrupt requests enabled 0 = SPRF CPU interrupt requests disabled DMAS —DMA Select Bit This read only bit has no effect on this version of the SPI. This bit always reads as a 0. 0 = SPRF DMA and SPTE DMA service requests disabled (SPRF CPU and SPTE CPU interrupt requests enabled) SPMSTR — SPI Master Bit This read/write bit selects master mode operation or slave mode operation. Reset sets the SPMSTR bit. 1 = Master mode 0 = Slave mode CPOL — Clock Polarity Bit This read/write bit determines the logic state of the SPSCK pin between transmissions. (See Figure 20-4 and Figure 20-6.) To transmit data between SPI modules, the SPI modules must have identical CPOL values. Reset clears the CPOL bit. CPHA — Clock Phase Bit This read/write bit controls the timing relationship between the serial clock and SPI data. (See Figure 20-4 and Figure 20-6.) To transmit data between SPI modules, the SPI modules must have identical CPHA values. When CPHA = 0, the SS pin of the slave SPI module must be set to logic 1 between bytes. See Figure 20-12. Reset sets the CPHA bit. SPWOM — SPI Wired-OR Mode Bit This read/write bit disables the pullup devices on pins SPSCK, MOSI, and MISO so that those pins become open-drain outputs. 1 = Wired-OR SPSCK, MOSI, and MISO pins 0 = Normal push-pull SPSCK, MOSI, and MISO pins MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 323 Serial Peripheral Interface (SPI) SPE — SPI Enable This read/write bit enables the SPI module. Clearing SPE causes a partial reset of the SPI. See Resetting the SPI. Reset clears the SPE bit. 1 = SPI module enabled 0 = SPI module disabled SPTIE— SPI Transmit Interrupt Enable This read/write bit enables CPU interrupt requests generated by the SPTE bit. SPTE is set when a byte transfers from the transmit data register to the shift register. Reset clears the SPTIE bit. 1 = SPTE CPU interrupt requests enabled 0 = SPTE CPU interrupt requests disabled 20.14.2 SPI Status and Control Register The SPI status and control register contains flags to signal these conditions: • Receive data register full • Failure to clear SPRF bit before next byte is received (overflow error) • Inconsistent logic level on SS pin (mode fault error) • Transmit data register empty The SPI status and control register also contains bits that perform these functions: • Enable error interrupts • Enable mode fault error detection • Select master SPI baud rate Technical Data 324 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) I/O Registers Address: $0011 Bit 7 Read: 6 SPRF 5 4 3 OVRF MODF SPTE ERRIE 2 1 Bit 0 MODFEN SPR1 SPR0 0 0 0 Write: Reset: 0 0 0 0 1 = Unimplemented Figure 20-14. SPI Status and Control Register (SPSCR) SPRF — SPI Receiver Full Bit This clearable, read-only flag is set each time a byte transfers from the shift register to the receive data register. SPRF generates a CPU interrupt request if the SPRIE bit in the SPI control register is set also. During an SPRF CPU interrupt, the CPU clears SPRF by reading the SPI status and control register with SPRF set and then reading the SPI data register. Reset clears the SPRF bit. 1 = Receive data register full 0 = Receive data register not full ERRIE — Error Interrupt Enable Bit This read/write bit enables the MODF and OVRF bits to generate CPU interrupt requests. Reset clears the ERRIE bit. 1 = MODF and OVRF can generate CPU interrupt requests 0 = MODF and OVRF cannot generate CPU interrupt requests OVRF — Overflow Bit This clearable, read-only flag is set if software does not read the byte in the receive data register before the next full byte enters the shift register. In an overflow condition, the byte already in the receive data register is unaffected, and the byte that shifted in last is lost. Clear the OVRF bit by reading the SPI status and control register with OVRF set and then reading the receive data register. Reset clears the OVRF bit. 1 = Overflow 0 = No overflow MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 325 Serial Peripheral Interface (SPI) MODF — Mode Fault Bit This clearable, read-only flag is set in a slave SPI if the SS pin goes high during a transmission with the MODFEN bit set. In a master SPI, the MODF flag is set if the SS pin goes low at any time with the MODFEN bit set. Clear the MODF bit by reading the SPI status and control register (SPSCR) with MODF set and then writing to the SPI control register (SPCR). Reset clears the MODF bit. 1 = SS pin at inappropriate logic level 0 = SS pin at appropriate logic level SPTE — SPI Transmitter Empty Bit This clearable, read-only flag is set each time the transmit data register transfers a byte into the shift register. SPTE generates an SPTE CPU interrupt request or an SPTE DMA service request if the SPTIE bit in the SPI control register is set also. NOTE: Do not write to the SPI data register unless the SPTE bit is high. During an SPTE CPU interrupt, the CPU clears the SPTE bit by writing to the transmit data register. Reset sets the SPTE bit. 1 = Transmit data register empty 0 = Transmit data register not empty MODFEN — Mode Fault Enable Bit This read/write bit, when set to 1, allows the MODF flag to be set. If the MODF flag is set, clearing the MODFEN does not clear the MODF flag. If the SPI is enabled as a master and the MODFEN bit is low, then the SS pin is available as a general-purpose I/O. If the MODFEN bit is set, then this pin is not available as a generalpurpose I/O. When the SPI is enabled as a slave, the SS pin is not available as a general-purpose I/O regardless of the value of MODFEN. See SS (Slave Select). If the MODFEN bit is low, the level of the SS pin does not affect the operation of an enabled SPI configured as a master. For an enabled SPI configured as a slave, having MODFEN low only prevents the MODF flag from being set. It does not affect any other part of SPI operation. See Mode Fault Error. Technical Data 326 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Serial Peripheral Interface (SPI) I/O Registers SPR1 and SPR0 — SPI Baud Rate Select Bits In master mode, these read/write bits select one of four baud rates as shown in Table 20-4. SPR1 and SPR0 have no effect in slave mode. Reset clears SPR1 and SPR0. Table 20-4. SPI Master Baud Rate Selection SPR1 and SPR0 Baud Rate Divisor (BD) 00 2 01 8 10 32 11 128 Use this formula to calculate the SPI baud rate: CGMOUT Baud rate = -------------------------2 × BD where: CGMOUT = base clock output of the clock generator module (CGM) BD = baud rate divisor MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Serial Peripheral Interface (SPI) 327 Serial Peripheral Interface (SPI) 20.14.3 SPI Data Register The SPI data register consists of the read-only receive data register and the write-only transmit data register. Writing to the SPI data register writes data into the transmit data register. Reading the SPI data register reads data from the receive data register. The transmit data and receive data registers are separate registers that can contain different values. See Figure 20-2. Address: $0012 Bit 7 6 5 4 3 2 1 Bit 0 Read: R7 R6 R5 R4 R3 R2 R1 R0 Write: T7 T6 T5 T4 T3 T2 T1 T0 Reset: Indeterminate after reset Figure 20-15. SPI Data Register (SPDR) R7–R0/T7–T0 — Receive/Transmit Data Bits NOTE: Do not use read-modify-write instructions on the SPI data register since the register read is not the same as the register written. Technical Data 328 MC68HC908GR8 — Rev 4.0 Serial Peripheral Interface (SPI) MOTOROLA Technical Data — MC68HC908GR8 Section 21. Timebase Module (TBM) 21.1 Contents 21.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 329 21.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 329 21.4 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 330 21.5 Timebase Register Description. . . . . . . . . . . . . . . . . . . . . . . . 331 21.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 332 21.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .333 21.2 Introduction This section describes the timebase module (TBM). The TBM will generate periodic interrupts at user selectable rates using a counter clocked by the external crystal clock. This TBM version uses 15 divider stages, eight of which are user selectable. For further information regarding timers on M68HC08 family devices, please consult the HC08 Timer Reference Manual, TIM08RM/AD. 21.3 Features Features of the TBM module include: • Software programmable 1 Hz, 4 Hz, 16 Hz, 256 Hz, 512 Hz, 1024 Hz, 2048 Hz, and 4096 Hz periodic interrupt using external 32.768 kHz crystal • User selectable oscillator clock source enable during stop mode to allow periodic wakeup from stop MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timebase Module (TBM) 329 Timebase Module (TBM) 21.4 Functional Description NOTE: This module is designed for a 32.768 kHz oscillator. This module can generate a periodic interrupt by dividing the crystal frequency, CGMXCLK. The counter is initialized to all 0s when TBON bit is cleared. The counter, shown in Figure 21-1, starts counting when the TBON bit is set. When the counter overflows at the tap selected by TBR2:TBR0, the TBIF bit gets set. If the TBIE bit is set, an interrupt request is sent to the CPU. The TBIF flag is cleared by writing a 1 to the TACK bit. The first time the TBIF flag is set after enabling the timebase module, the interrupt is generated at approximately half of the overflow period. Subsequent events occur at the exact period. TBON ÷2 ÷2 ÷ 128 ÷2 ÷ 64 ÷2 ÷ 32 ÷2 ÷8 ÷2 ÷ 16 ÷2 CGMXCLK ÷2 ÷2 TACK ÷2 TBR0 ÷2 TBR1 ÷2 ÷ 32,768 ÷2 ÷ 8192 ÷2 ÷ 2048 ÷2 TBR2 TBMINT TBIF 000 TBIE R 001 010 100 SEL 011 101 110 111 Figure 21-1. Timebase Block Diagram Technical Data 330 MC68HC908GR8 — Rev 4.0 Timebase Module (TBM) MOTOROLA Timebase Module (TBM) Timebase Register Description 21.5 Timebase Register Description The timebase has one register, the TBCR, which is used to enable the timebase interrupts and set the rate. Address: $001C Bit 7 Read: 6 5 4 TBR2 TBR1 TBR0 TBIF 2 1 Bit 0 TBIE TBON Reserved 0 0 0 0 Write: Reset: 3 TACK 0 0 0 0 0 = Unimplemented Figure 21-2. Timebase Control Register (TBCR) TBIF — Timebase Interrupt Flag This read-only flag bit is set when the timebase counter has rolled over. 1 = Timebase interrupt pending 0 = Timebase interrupt not pending TBR2:TBR0 — Timebase Rate Selection These read/write bits are used to select the rate of timebase interrupts as shown in Table 21-1. Table 21-1. Timebase Rate Selection for OSC1 = 32.768 kHz TBR2 TBR1 TBR0 Divider 0 0 0 0 0 0 Hz ms 32,768 1 1000 1 8192 4 250 1 0 2048 16 62.5 0 1 1 128 256 ~ 3.9 1 0 0 64 512 ~2 1 0 1 32 1024 ~1 1 1 0 16 2048 ~0.5 1 1 1 8 4096 ~0.24 MC68HC908GR8 — Rev 4.0 MOTOROLA Timebase Interrupt Rate Technical Data Timebase Module (TBM) 331 Timebase Module (TBM) NOTE: Do not change TBR2–TBR0 bits while the timebase is enabled (TBON = 1). TACK— Timebase ACKnowledge The TACK bit is a write-only bit and always reads as 0. Writing a logic 1 to this bit clears TBIF, the timebase interrupt flag bit. Writing a logic 0 to this bit has no effect. 1 = Clear timebase interrupt flag 0 = No effect TBIE — Timebase Interrupt Enabled This read/write bit enables the timebase interrupt when the TBIF bit becomes set. Reset clears the TBIE bit. 1 = Timebase interrupt enabled 0 = Timebase interrupt disabled TBON — Timebase Enabled This read/write bit enables the timebase. Timebase may be turned off to reduce power consumption when its function is not necessary. The counter can be initialized by clearing and then setting this bit. Reset clears the TBON bit. 1 = Timebase enabled 0 = Timebase disabled and the counter initialized to 0s 21.6 Interrupts The timebase module can interrupt the CPU on a regular basis with a rate defined by TBR2:TBR0. When the timebase counter chain rolls over, the TBIF flag is set. If the TBIE bit is set, enabling the timebase interrupt, the counter chain overflow will generate a CPU interrupt request. Interrupts must be acknowledged by writing a logic 1 to the TACK bit. Technical Data 332 MC68HC908GR8 — Rev 4.0 Timebase Module (TBM) MOTOROLA Timebase Module (TBM) Low-Power Modes 21.7 Low-Power Modes The WAIT and STOP instructions put the MCU in low powerconsumption standby modes. 21.7.1 Wait Mode The timebase module remains active after execution of the WAIT instruction. In wait mode, the timebase register is not accessible by the CPU. If the timebase functions are not required during wait mode, reduce the power consumption by stopping the timebase before enabling the WAIT instruction. 21.7.2 Stop Mode The timebase module may remain active after execution of the STOP instruction if the oscillator has been enabled to operate during stop mode through the OSCSTOPEN bit in the CONFIG register. The timebase module can be used in this mode to generate a periodic wakeup from stop mode. If the oscillator has not been enabled to operate in stop mode, the timebase module will not be active during STOP mode. In stop mode, the timebase register is not accessible by the CPU. If the timebase functions are not required during stop mode, reduce the power consumption by stopping the timebase before enabling the STOP instruction. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timebase Module (TBM) 333 Timebase Module (TBM) Technical Data 334 MC68HC908GR8 — Rev 4.0 Timebase Module (TBM) MOTOROLA Technical Data — MC68HC908GR8 Section 22. Timer Interface Module (TIM) 22.1 Contents 22.2 Introduction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 335 22.3 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 336 22.4 Pin Name Conventions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 336 22.5 Functional Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 337 22.6 Interrupts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 346 22.7 Low-Power Modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .347 22.8 TIM During Break Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . 348 22.9 I/O Signals . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 348 22.10 I/O Registers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 349 22.2 Introduction This section describes the timer interface (TIM) module. The TIM on this part is a 2-channel and a1-channel timer that provides a timing reference with input capture, output compare, and pulse-width-modulation functions. Figure 22-1 is a block diagram of the TIM. This particular MCU has two timer interface modules which are denoted as TIM1 and TIM2. For further information regarding timers on M68HC08 family devices, please consult the HC08 Timer Reference Manual, TIM08RM/AD. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 335 Timer Interface Module (TIM) 22.3 Features Features of the TIM include: • Three input capture/output compare channels: – Rising-edge, falling-edge, or any-edge input capture trigger – Set, clear, or toggle output compare action • Buffered and unbuffered pulse-width-modulation (PWM) signal generation • Programmable TIM clock input with 7-frequency internal bus clock prescaler selection • Free-running or modulo up-count operation • Toggle any channel pin on overflow • TIM counter stop and reset bits • I/O port bit(s) software configurable with pullup device(s) if configured as input port bit(s) 22.4 Pin Name Conventions The text that follows describes both timers, TIM1 and TIM2. The TIM input/output (I/O) pin names are T[1,2]CH0 (timer 1 channel 0, timer 2 channel 0) and T[1]CH1 (timer channel 1), where “1” is used to indicate TIM1 and “2” is used to indicate TIM2. The two TIMs share three I/O pins with three port D I/O port pins. The full names of the TIM I/O pins are listed in Table 22-1. The generic pin names appear in the text that follows. Table 22-1. Pin Name Conventions TIM Generic Pin Names: Full TIM Pin Names: T[1,2]CH0 T[1,2]CH1 TIM1 PTD4/ATD12/TBLCK PTD5/T1CH1 TIM2 PTD6/ATD14/TACLK -- Technical Data 336 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description NOTE: References to either timer 1 or timer 2 may be made in the following text by omitting the timer number. For example, TCH0 may refer generically to T1CH0 and T2CH0, and TCH1 will refer to T1CH1. NOTE: The Timer Interface Module in MC68HC908GR8 is constructed by TIM1 which is contained channel 0 and 1, and TIM2 which is contained channel 0 only. 22.5 Functional Description NOTE: References to TCLK and external TIM clock input are only valid if the MCU has an external TCLK pin. If the MCU has no external TCLK pin, the TIM module must use the internal bus clock prescaler selections. Figure 22-1 shows the structure of the TIM. The central component of the TIM is the 16-bit TIM counter that can operate as a free-running counter or a modulo up-counter. The TIM counter provides the timing reference for the input capture and output compare functions. The TIM counter modulo registers, TMODH:TMODL, control the modulo value of the TIM counter. Software can read the TIM counter value at any time without affecting the counting sequence. The TIM channels (per timer) are programmable independently as input capture or output compare channels. If a channel is configured as input capture, then an internal pullup device may be enabled for that channel. See Port D Input Pullup Enable Register. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 337 Timer Interface Module (TIM) INTERNAL TCLK PRESCALER SELECT INTERNAL BUS CLOCK PRESCALER TSTOP PS2 TRST PS1 PS0 16-BIT COUNTER TOF TOIE INTERRUPT LOGIC 16-BIT COMPARATOR TMODH:TMODL TOV0 ELS0B CHANNEL 0 ELS0A CH0MAX PORT LOGIC T[1,2]CH0 16-BIT COMPARATOR TCH0H:TCH0L CH0F 16-BIT LATCH MS0A CH0IE INTERRUPT LOGIC MS0B INTERNAL BUS TOV1 ELS1B CHANNEL 1 ELS1A CH1MAX PORT LOGIC T[1]CH1 16-BIT COMPARATOR TCH1H:TCH1L CH1F 16-BIT LATCH MS1A CH1IE INTERRUPT LOGIC Figure 22-1. TIM Block Diagram NOTE: References to either timer 1 or timer 2 may be made in the following text by omitting the timer number. For example, TSC may generically refer to both T1SC and T2SC. NOTE: In Figure 22-1, channel1 will only be available in TIM1 while channel 0 will be available in both TIM1 and TIM2 Technical Data 338 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description Figure 22-2 summarizes the timer registers. Addr. $0020 $0021 $0022 $0023 $0024 Register Name Timer 1 Status and Control Register (T1SC) Timer 1 Counter Register High (T1CNTH) Timer 1 Counter Register Low (T1CNTL) Timer 1 Counter Modulo Register High (T1MODH) Timer 1 Counter Modulo Register Low (T1MODL) Timer 1 Channel 0 Status $0025 and Control Register (T1SC0) $0026 $0027 $0028 $0029 $002A $002B $002C Timer 1 Channel 0 Register High (T1CH0H) Timer 1 Channel 0 Register Low (T1CH0L) Timer 1 Channel 1 Status and Control Register (T1SC1) Timer 1 Channel 1 Register High (T1CH1H) Timer 1 Channel 1 Register Low (T1CH1L) Timer 2 Status and Control Register (T2SC) Timer 2 Counter Register High (T2CNTH) Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Bit 7 TOF 0 0 Bit 15 6 5 1 13 4 0 TRST 0 12 TOIE TSTOP 0 14 0 Bit 7 0 6 0 5 0 0 Bit 15 3 0 2 1 Bit 0 PS2 PS1 PS0 0 11 0 10 0 9 0 Bit 8 0 4 0 3 0 2 0 1 0 Bit 0 0 0 0 0 0 0 14 13 12 11 10 9 Bit 8 1 1 1 1 1 1 1 1 Bit 7 6 5 4 3 2 1 Bit 0 1 CH0F 0 0 1 1 1 1 1 1 1 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 2 1 Bit 0 Indeterminate after reset Bit 7 6 5 4 3 Indeterminate after reset CH1F 0 0 Bit 15 CH1IE 0 MS1A ELS1B ELS1A TOV1 CH1MAX 0 0 0 0 0 0 0 14 13 12 11 10 9 Bit 8 2 1 Bit 0 PS2 PS1 PS0 0 10 0 9 0 Bit 8 0 0 0 Indeterminate after reset Bit 7 TOF 0 0 Bit 15 0 6 TOIE 0 14 5 4 3 Indeterminate after reset 0 0 TSTOP TRST 1 0 0 13 12 11 0 0 = Unimplemented 0 0 Figure 22-2. TIM I/O Register Summary (Sheet 1 of 2) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 339 Timer Interface Module (TIM) Addr. $002D $002E $002F Register Name Timer 2 Counter Register Low (T2CNTL) Timer 2 Counter Modulo Register High (T2MODH) Timer 2 Counter Modulo Register Low (T2MODL) Timer 2 Channel 0 Status $0030 and Control Register (T2SC0) $0031 $0032 Timer 2 Channel 0 Register High (T2CH0H) Timer 2 Channel 0 Register Low (T2CH0L) $0033 $0034 $0035 Unimplemented Unimplemented Unimplemented Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Read: Write: Reset: Bit 7 Bit 7 6 6 5 5 4 4 3 3 2 2 1 1 Bit 0 Bit 0 0 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 1 1 1 1 1 1 1 1 Bit 7 6 5 4 3 2 1 Bit 0 1 CH0F 0 0 1 1 1 1 1 1 1 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX 0 0 0 0 0 0 0 Bit 15 14 13 12 11 10 9 Bit 8 2 1 Bit 0 0 0 0 Indeterminate after reset Bit 7 6 5 4 3 Indeterminate after reset 0 0 0 0 0 Indeterminate after reset Indeterminate after reset = Unimplemented Figure 22-2. TIM I/O Register Summary (Sheet 2 of 2) 22.5.1 TIM Counter Prescaler The TIM clock source can be one of the seven prescaler outputs or the TIM clock pin, TCLK. The prescaler generates seven clock rates from the internal bus clock. The prescaler select bits, PS[2:0], in the TIM status and control register select the TIM clock source. Technical Data 340 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description 22.5.2 Input Capture With the input capture function, the TIM can capture the time at which an external event occurs. When an active edge occurs on the pin of an input capture channel, the TIM latches the contents of the TIM counter into the TIM channel registers, TCHxH:TCHxL. The polarity of the active edge is programmable. Input captures can generate TIM CPU interrupt requests. 22.5.3 Output Compare With the output compare function, the TIM can generate a periodic pulse with a programmable polarity, duration, and frequency. When the counter reaches the value in the registers of an output compare channel, the TIM can set, clear, or toggle the channel pin. Output compares can generate TIM CPU interrupt requests. 22.5.4 Unbuffered Output Compare Any output compare channel can generate unbuffered output compare pulses as described in Output Compare. The pulses are unbuffered because changing the output compare value requires writing the new value over the old value currently in the TIM channel registers. An unsynchronized write to the TIM channel registers to change an output compare value could cause incorrect operation for up to two counter overflow periods. For example, writing a new value before the counter reaches the old value but after the counter reaches the new value prevents any compare during that counter overflow period. Also, using a TIM overflow interrupt routine to write a new, smaller output compare value may cause the compare to be missed. The TIM may pass the new value before it is written. Use the following methods to synchronize unbuffered changes in the output compare value on channel x: MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 341 Timer Interface Module (TIM) • When changing to a smaller value, enable channel x output compare interrupts and write the new value in the output compare interrupt routine. The output compare interrupt occurs at the end of the current output compare pulse. The interrupt routine has until the end of the counter overflow period to write the new value. • When changing to a larger output compare value, enable TIM overflow interrupts and write the new value in the TIM overflow interrupt routine. The TIM overflow interrupt occurs at the end of the current counter overflow period. Writing a larger value in an output compare interrupt routine (at the end of the current pulse) could cause two output compares to occur in the same counter overflow period. 22.5.5 Buffered Output Compare Channels 0 and 1 can be linked to form a buffered output compare channel whose output appears on the TCH0 pin. The TIM channel registers of the linked pair alternately control the output. Setting the MS0B bit in TIM channel 0 status and control register (TSC0) links channel 0 and channel 1. The output compare value in the TIM channel 0 registers initially controls the output on the TCH0 pin. Writing to the TIM channel 1 registers enables the TIM channel 1 registers to synchronously control the output after the TIM overflows. At each subsequent overflow, the TIM channel registers (0 or 1) that control the output are the ones written to last. TSC0 controls and monitors the buffered output compare function, and TIM channel 1 status and control register (TSC1) is unused. While the MS0B bit is set, the channel 1 pin, TCH1, is available as a general-purpose I/O pin. NOTE: In buffered output compare operation, do not write new output compare values to the currently active channel registers. User software should track the currently active channel to prevent writing a new value to the active channel. Writing to the active channel registers is the same as generating unbuffered output compares. Technical Data 342 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description 22.5.6 Pulse Width Modulation (PWM) By using the toggle-on-overflow feature with an output compare channel, the TIM can generate a PWM signal. The value in the TIM counter modulo registers determines the period of the PWM signal. The channel pin toggles when the counter reaches the value in the TIM counter modulo registers. The time between overflows is the period of the PWM signal. As Figure 22-3 shows, the output compare value in the TIM channel registers determines the pulse width of the PWM signal. The time between overflow and output compare is the pulse width. Program the TIM to clear the channel pin on output compare if the state of the PWM pulse is logic 1. Program the TIM to set the pin if the state of the PWM pulse is logic 0. The value in the TIM counter modulo registers and the selected prescaler output determines the frequency of the PWM output. The frequency of an 8-bit PWM signal is variable in 256 increments. Writing $00FF (255) to the TIM counter modulo registers produces a PWM period of 256 times the internal bus clock period if the prescaler select value is $000. See TIM Status and Control Register. OVERFLOW OVERFLOW OVERFLOW PERIOD PULSE WIDTH PTEx/TCHx OUTPUT COMPARE OUTPUT COMPARE OUTPUT COMPARE Figure 22-3. PWM Period and Pulse Width The value in the TIM channel registers determines the pulse width of the PWM output. The pulse width of an 8-bit PWM signal is variable in 256 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 343 Timer Interface Module (TIM) increments. Writing $0080 (128) to the TIM channel registers produces a duty cycle of 128/256 or 50%. 22.5.7 Unbuffered PWM Signal Generation Any output compare channel can generate unbuffered PWM pulses as described in Pulse Width Modulation (PWM). The pulses are unbuffered because changing the pulse width requires writing the new pulse width value over the old value currently in the TIM channel registers. An unsynchronized write to the TIM channel registers to change a pulse width value could cause incorrect operation for up to two PWM periods. For example, writing a new value before the counter reaches the old value but after the counter reaches the new value prevents any compare during that PWM period. Also, using a TIM overflow interrupt routine to write a new, smaller pulse width value may cause the compare to be missed. The TIM may pass the new value before it is written. Use the following methods to synchronize unbuffered changes in the PWM pulse width on channel x: NOTE: • When changing to a shorter pulse width, enable channel x output compare interrupts and write the new value in the output compare interrupt routine. The output compare interrupt occurs at the end of the current pulse. The interrupt routine has until the end of the PWM period to write the new value. • When changing to a longer pulse width, enable TIM overflow interrupts and write the new value in the TIM overflow interrupt routine. The TIM overflow interrupt occurs at the end of the current PWM period. Writing a larger value in an output compare interrupt routine (at the end of the current pulse) could cause two output compares to occur in the same PWM period. In PWM signal generation, do not program the PWM channel to toggle on output compare. Toggling on output compare prevents reliable 0% duty cycle generation and removes the ability of the channel to selfcorrect in the event of software error or noise. Toggling on output compare also can cause incorrect PWM signal generation when changing the PWM pulse width to a new, much larger value. Technical Data 344 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Functional Description 22.5.8 Buffered PWM Signal Generation Channels 0 and 1 can be linked to form a buffered PWM channel whose output appears on the TCH0 pin. The TIM channel registers of the linked pair alternately control the pulse width of the output. Setting the MS0B bit in TIM channel 0 status and control register (TSC0) links channel 0 and channel 1. The TIM channel 0 registers initially control the pulse width on the TCH0 pin. Writing to the TIM channel 1 registers enables the TIM channel 1 registers to synchronously control the pulse width at the beginning of the next PWM period. At each subsequent overflow, the TIM channel registers (0 or 1) that control the pulse width are the ones written to last. TSC0 controls and monitors the buffered PWM function, and TIM channel 1 status and control register (TSC1) is unused. While the MS0B bit is set, the channel 1 pin, TCH1, is available as a general-purpose I/O pin. NOTE: In buffered PWM signal generation, do not write new pulse width values to the currently active channel registers. User software should track the currently active channel to prevent writing a new value to the active channel. Writing to the active channel registers is the same as generating unbuffered PWM signals. 22.5.9 PWM Initialization To ensure correct operation when generating unbuffered or buffered PWM signals, use the following initialization procedure: 1. In the TIM status and control register (TSC): a. Stop the TIM counter by setting the TIM stop bit, TSTOP. b. Reset the TIM counter and prescaler by setting the TIM reset bit, TRST. 2. In the TIM counter modulo registers (TMODH:TMODL), write the value for the required PWM period. 3. In the TIM channel x registers (TCHxH:TCHxL), write the value for the required pulse width. 4. In TIM channel x status and control register (TSCx): MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 345 Timer Interface Module (TIM) a. Write 0:1 (for unbuffered output compare or PWM signals) or 1:0 (for buffered output compare or PWM signals) to the mode select bits, MSxB:MSxA. See Table 22-3. b. Write 1 to the toggle-on-overflow bit, TOVx. c. Write 1:0 (to clear output on compare) or 1:1 (to set output on compare) to the edge/level select bits, ELSxB:ELSxA. The output action on compare must force the output to the complement of the pulse width level. (See Table 22-3.) NOTE: In PWM signal generation, do not program the PWM channel to toggle on output compare. Toggling on output compare prevents reliable 0% duty cycle generation and removes the ability of the channel to selfcorrect in the event of software error or noise. Toggling on output compare can also cause incorrect PWM signal generation when changing the PWM pulse width to a new, much larger value. 5. In the TIM status control register (TSC), clear the TIM stop bit, TSTOP. Setting MS0B links channels 0 and 1 and configures them for buffered PWM operation. The TIM channel 0 registers (TCH0H:TCH0L) initially control the buffered PWM output. TIM status control register 0 (TSCR0) controls and monitors the PWM signal from the linked channels. Clearing the toggle-on-overflow bit, TOVx, inhibits output toggles on TIM overflows. Subsequent output compares try to force the output to a state it is already in and have no effect. The result is a 0% duty cycle output. Setting the channel x maximum duty cycle bit (CHxMAX) and setting the TOVx bit generates a 100% duty cycle output. (See TIM Channel Status and Control Registers.) 22.6 Interrupts The following TIM sources can generate interrupt requests: Technical Data 346 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) Low-Power Modes • TIM overflow flag (TOF) — The TOF bit is set when the TIM counter value reaches the modulo value programmed in the TIM counter modulo registers. The TIM overflow interrupt enable bit, TOIE, enables TIM overflow CPU interrupt requests. TOF and TOIE are in the TIM status and control register. • TIM channel flags (CH1F:CH0F) — The CHxF bit is set when an input capture or output compare occurs on channel x. Channel x TIM CPU interrupt requests and TIM DMA service requests are controlled by the channel x interrupt enable bit, CHxIE. Channel x TIM CPU interrupt requests are enabled when CHxIE = 1. CHxF and CHxIE are in the TIM channel x status and control register. DMAxS is in the TIM DMA select register. 22.7 Low-Power Modes The WAIT and STOP instructions put the MCU in low powerconsumption standby modes. 22.7.1 Wait Mode The TIM remains active after the execution of a WAIT instruction. In wait mode, the TIM registers are not accessible by the CPU. Any enabled CPU interrupt request from the TIM can bring the MCU out of wait mode. If TIM functions are not required during wait mode, reduce power consumption by stopping the TIM before executing the WAIT instruction. 22.7.2 Stop Mode The TIM is inactive after the execution of a STOP instruction. The STOP instruction does not affect register conditions or the state of the TIM counter. TIM operation resumes when the MCU exits stop mode after an external interrupt. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 347 Timer Interface Module (TIM) 22.8 TIM During Break Interrupts A break interrupt stops the TIM counter. The system integration module (SIM) controls whether status bits in other modules can be cleared during the break state. The BCFE bit in the SIM break flag control register (SBFCR) enables software to clear status bits during the break state. See SIM Break Flag Control Register. To allow software to clear status bits during a break interrupt, write a logic 1 to the BCFE bit. If a status bit is cleared during the break state, it remains cleared when the MCU exits the break state. To protect status bits during the break state, write a logic 0 to the BCFE bit. With BCFE at logic 0 (its default state), software can read and write I/O registers during the break state without affecting status bits. Some status bits have a 2-step read/write clearing procedure. If software does the first step on such a bit before the break, the bit cannot change during the break state as long as BCFE is at logic 0. After the break, doing the second step clears the status bit. 22.9 I/O Signals Port D shares three of its pins with the TIM. (There is an optional TCLK which can be used as an external clock input to the TIM prescaler, but is not available on this MCU.) The three TIM channel I/O pins are T1CH0, T1CH1 and T2CH0 as described in Pin Name Conventions. Each channel I/O pin is programmable independently as an input capture pin or an output compare pin. T1CH0 and T2CH0 can be configured as buffered output compare or buffered PWM pins. Technical Data 348 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) I/O Registers 22.10 I/O Registers NOTE: References to either timer 1 or timer 2 may be made in the following text by omitting the timer number. For example, TSC may generically refer to both T1SC AND T2SC. These I/O registers control and monitor operation of the TIM: • TIM status and control register (TSC) • TIM control registers (TCNTH:TCNTL) • TIM counter modulo registers (TMODH:TMODL) • TIM channel status and control registers (TSC0, TSC1) • TIM channel registers (TCH0H:TCH0L, TCH1H:TCH1L) 22.10.1 TIM Status and Control Register The TIM status and control register (TSC): • Enables TIM overflow interrupts • Flags TIM overflows • Stops the TIM counter • Resets the TIM counter • Prescales the TIM counter clock Address: T1SC, $0020 and T2SC, $002B Bit 7 Read: 6 5 TOIE TSTOP TOF Write: 0 Reset: 0 4 3 0 0 2 1 Bit 0 PS2 PS1 PS0 0 0 0 TRST 0 1 0 0 = Unimplemented Figure 22-4. TIM Status and Control Register (TSC) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 349 Timer Interface Module (TIM) TOF — TIM Overflow Flag Bit This read/write flag is set when the TIM counter reaches the modulo value programmed in the TIM counter modulo registers. Clear TOF by reading the TIM status and control register when TOF is set and then writing a logic 0 to TOF. If another TIM overflow occurs before the clearing sequence is complete, then writing logic 0 to TOF has no effect. Therefore, a TOF interrupt request cannot be lost due to inadvertent clearing of TOF. Reset clears the TOF bit. Writing a logic 1 to TOF has no effect. 1 = TIM counter has reached modulo value 0 = TIM counter has not reached modulo value TOIE — TIM Overflow Interrupt Enable Bit This read/write bit enables TIM overflow interrupts when the TOF bit becomes set. Reset clears the TOIE bit. 1 = TIM overflow interrupts enabled 0 = TIM overflow interrupts disabled TSTOP — TIM Stop Bit This read/write bit stops the TIM counter. Counting resumes when TSTOP is cleared. Reset sets the TSTOP bit, stopping the TIM counter until software clears the TSTOP bit. 1 = TIM counter stopped 0 = TIM counter active NOTE: Do not set the TSTOP bit before entering wait mode if the TIM is required to exit wait mode. TRST — TIM Reset Bit Setting this write-only bit resets the TIM counter and the TIM prescaler. Setting TRST has no effect on any other registers. Counting resumes from $0000. TRST is cleared automatically after the TIM counter is reset and always reads as logic 0. Reset clears the TRST bit. 1 = Prescaler and TIM counter cleared 0 = No effect NOTE: Setting the TSTOP and TRST bits simultaneously stops the TIM counter at a value of $0000. Technical Data 350 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) I/O Registers PS2–PS0 — Prescaler Select Bits These read/write bits select either the TCLK pin or one of the seven prescaler outputs as the input to the TIM counter as Table 22-2 shows. Reset clears the PS[2:0] bits. Table 22-2. Prescaler Selection PS2–PS0 TIM Clock Source 000 Internal bus clock ÷1 001 Internal bus clock ÷ 2 010 Internal bus clock ÷ 4 011 Internal bus clock ÷ 8 100 Internal bus clock ÷ 16 101 Internal bus clock ÷ 32 110 Internal bus clock ÷ 64 111 Not available MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 351 Timer Interface Module (TIM) 22.10.2 TIM Counter Registers The two read-only TIM counter registers contain the high and low bytes of the value in the TIM counter. Reading the high byte (TCNTH) latches the contents of the low byte (TCNTL) into a buffer. Subsequent reads of TCNTH do not affect the latched TCNTL value until TCNTL is read. Reset clears the TIM counter registers. Setting the TIM reset bit (TRST) also clears the TIM counter registers. NOTE: If you read TCNTH during a break interrupt, be sure to unlatch TCNTL by reading TCNTL before exiting the break interrupt. Otherwise, TCNTL retains the value latched during the break. Address: T1CNTH, $0021 and T2CNTH, $002C Read: Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 22-5. TIM Counter Registers High (TCNTH) Address: T1CNTL, $0022 and T2CNTL, $002D Read: Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 22-6. TIM Counter Registers Low (TCNTL) Technical Data 352 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) I/O Registers 22.10.3 TIM Counter Modulo Registers The read/write TIM modulo registers contain the modulo value for the TIM counter. When the TIM counter reaches the modulo value, the overflow flag (TOF) becomes set, and the TIM counter resumes counting from $0000 at the next timer clock. Writing to the high byte (TMODH) inhibits the TOF bit and overflow interrupts until the low byte (TMODL) is written. Reset sets the TIM counter modulo registers. Address: T1MODH, $0023 and T2MODH, $002E Read: Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 1 1 1 1 1 1 1 1 Write: Reset: = Unimplemented Figure 22-7. TIM Counter Modulo Register High (TMODH) Address: T1MODL, $0024 and T2MODL, $002F Read: Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 1 1 1 1 1 1 1 1 Write: Reset: = Unimplemented Figure 22-8. TIM Counter Modulo Register Low (TMODL) NOTE: Reset the TIM counter before writing to the TIM counter modulo registers. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 353 Timer Interface Module (TIM) 22.10.4 TIM Counter Registers The two read-only TIM counter registers contain the high and low bytes of the value in the TIM counter. Reading the high byte (TCNTH) latches the contents of the low byte (TCNTL) into a buffer. Subsequent reads of TCNTH do not affect the latched TCNTL value until TCNTL is read. Reset clears the TIM counter registers. Setting the TIM reset bit (TRST) also clears the TIM counter registers. NOTE: If you read TCNTH during a break interrupt, be sure to unlatch TCNTL by reading TCNTL before exiting the break interrupt. Otherwise, TCNTL retains the value latched during the break. Address: T1CNTH, $0021 and T2CNTH, $002C Read: Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 22-9. TIM Counter Register High (TCNTH) Address: T1CNTL, $0022 and T2CNTL, $002D Read: Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 0 0 0 0 0 0 0 0 Write: Reset: = Unimplemented Figure 22-10. TIM Counter Register Low (TCNTL) Technical Data 354 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) I/O Registers 22.10.5 TIM Channel Status and Control Registers Each of the TIM channel status and control registers: • Flags input captures and output compares • Enables input capture and output compare interrupts • Selects input capture, output compare, or PWM operation • Selects high, low, or toggling output on output compare • Selects rising edge, falling edge, or any edge as the active input capture trigger • Selects output toggling on TIM overflow • Selects 0% and 100% PWM duty cycle • Selects buffered or unbuffered output compare/PWM operation Address: T1SC0, $0025 and T2SC0, $0030 Bit 7 Read: CH0F Write: 0 Reset: 0 6 5 4 3 2 1 Bit 0 CH0IE MS0B MS0A ELS0B ELS0A TOV0 CH0MAX 0 0 0 0 0 0 0 Figure 22-11. TIM Channel 0 Status and Control Register (TSC0) Address: T1SC1, $0028 Bit 7 Read: 6 CH1F 5 0 Reset: 0 3 2 1 Bit 0 MS1A ELS1B ELS1A TOV1 CH1MAX 0 0 0 0 0 0 CH1IE Write: 4 0 0 Figure 22-12. TIM Channel 1 Status and Control Register (TSC1) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 355 Timer Interface Module (TIM) CHxF — Channel x Flag Bit When channel x is an input capture channel, this read/write bit is set when an active edge occurs on the channel x pin. When channel x is an output compare channel, CHxF is set when the value in the TIM counter registers matches the value in the TIM channel x registers. When TIM CPU interrupt requests are enabled (CHxIE = 1), clear CHxF by reading TIM channel x status and control register with CHxF set and then writing a logic 0 to CHxF. If another interrupt request occurs before the clearing sequence is complete, then writing logic 0 to CHxF has no effect. Therefore, an interrupt request cannot be lost due to inadvertent clearing of CHxF. Reset clears the CHxF bit. Writing a logic 1 to CHxF has no effect. 1 = Input capture or output compare on channel x 0 = No input capture or output compare on channel x CHxIE — Channel x Interrupt Enable Bit This read/write bit enables TIM CPU interrupt service requests on channel x. Reset clears the CHxIE bit. 1 = Channel x CPU interrupt service requests enabled 0 = Channel x CPU interrupt service requests disabled MSxB — Mode Select Bit B This read/write bit selects buffered output compare/PWM operation. MSxB exists only in the TIM1 channel 0 and TIM2 channel 0 status and control registers. Setting MS0B disables the channel 1 status and control register and reverts TCH1 to general-purpose I/O. Reset clears the MSxB bit. 1 = Buffered output compare/PWM operation enabled 0 = Buffered output compare/PWM operation disabled MSxA — Mode Select Bit A When ELSxB:A ≠ 00, this read/write bit selects either input capture operation or unbuffered output compare/PWM operation. See Table 22-3. 1 = Unbuffered output compare/PWM operation Technical Data 356 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) I/O Registers 0 = Input capture operation When ELSxB:A = 00, this read/write bit selects the initial output level of the TCHx pin. See Table 22-3. Reset clears the MSxA bit. 1 = Initial output level low 0 = Initial output level high NOTE: Before changing a channel function by writing to the MSxB or MSxA bit, set the TSTOP and TRST bits in the TIM status and control register (TSC). ELSxB and ELSxA — Edge/Level Select Bits When channel x is an input capture channel, these read/write bits control the active edge-sensing logic on channel x. When channel x is an output compare channel, ELSxB and ELSxA control the channel x output behavior when an output compare occurs. When ELSxB and ELSxA are both clear, channel x is not connected to port D, and pin PTDx/TCHx is available as a general-purpose I/O pin. Table 22-3 shows how ELSxB and ELSxA work. Reset clears the ELSxB and ELSxA bits. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 357 Timer Interface Module (TIM) Table 22-3. Mode, Edge, and Level Selection MSxB:MSxA ELSxB:ELSxA X0 00 Mode Configuration Pin under port control; initial output level high Output preset NOTE: X1 00 Pin under port control; initial output level low 00 01 Capture on rising edge only 00 10 00 11 01 01 01 10 01 11 1X 01 1X 10 1X 11 Input capture Capture on falling edge only Capture on rising or falling edge Output compare or PWM Buffered output compare or buffered PWM Toggle output on compare Clear output on compare Set output on compare Toggle output on compare Clear output on compare Set output on compare Before enabling a TIM channel register for input capture operation, make sure that the PTD/TCHx pin is stable for at least two bus clocks. TOVx — Toggle On Overflow Bit When channel x is an output compare channel, this read/write bit controls the behavior of the channel x output when the TIM counter overflows. When channel x is an input capture channel, TOVx has no effect. Reset clears the TOVx bit. 1 = Channel x pin toggles on TIM counter overflow. 0 = Channel x pin does not toggle on TIM counter overflow. NOTE: When TOVx is set, a TIM counter overflow takes precedence over a channel x output compare if both occur at the same time. Technical Data 358 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Timer Interface Module (TIM) I/O Registers CHxMAX — Channel x Maximum Duty Cycle Bit When the TOVx bit is at logic 1, setting the CHxMAX bit forces the duty cycle of buffered and unbuffered PWM signals to 100%. As . CHxMAX Latency shows, the CHxMAX bit takes effect in the cycle after it is set or cleared. The output stays at the 100% duty cycle level until the cycle after CHxMAX is cleared. OVERFLOW OVERFLOW OVERFLOW OVERFLOW OVERFLOW PERIOD PTEx/TCHx OUTPUT COMPARE OUTPUT COMPARE OUTPUT COMPARE OUTPUT COMPARE CHxMAX Figure 22-13. CHxMAX Latency 22.10.6 TIM Channel Registers These read/write registers contain the captured TIM counter value of the input capture function or the output compare value of the output compare function. The state of the TIM channel registers after reset is unknown. In input capture mode (MSxB:MSxA = 0:0), reading the high byte of the TIM channel x registers (TCHxH) inhibits input captures until the low byte (TCHxL) is read. In output compare mode (MSxB:MSxA ≠ 0:0), writing to the high byte of the TIM channel x registers (TCHxH) inhibits output compares until the low byte (TCHxL) is written. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Timer Interface Module (TIM) 359 Timer Interface Module (TIM) Address: T1CH0H, $0026 and T2CH0H, $0031 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Read: Write: Reset: Indeterminate after reset Figure 22-14. TIM Channel 0 Register High (TCH0H) Address: T1CH0L, $0027 and T2CH0L $0032 Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 Read: Write: Reset: Indeterminate after reset Figure 22-15. TIM Channel 0 Register Low (TCH0L) Address: T1CH1H, $0029 Bit 7 6 5 4 3 2 1 Bit 0 Bit 15 14 13 12 11 10 9 Bit 8 Read: Write: Reset: Indeterminate after reset Figure 22-16. TIM Channel 1 Register High (TCH1H) Address: T1CH1L, $002A Bit 7 6 5 4 3 2 1 Bit 0 Bit 7 6 5 4 3 2 1 Bit 0 Read: Write: Reset: Indeterminate after reset Figure 22-17. TIM Channel 1 Register Low (TCH1L) Technical Data 360 MC68HC908GR8 — Rev 4.0 Timer Interface Module (TIM) MOTOROLA Technical Data — MC68HC908GR8 Section 23. Electrical Specifications 23.1 Contents 23.2 Absolute Maximum Ratings . . . . . . . . . . . . . . . . . . . . . . . . . .362 23.3 Functional Operating Range. . . . . . . . . . . . . . . . . . . . . . . . . . 363 23.4 Thermal Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 363 23.5 5.0 V DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . 364 23.6 3.0 V DC Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . 366 23.7 5.0 V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 368 23.8 3.0 V Control Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 369 23.9 Output High-Voltage Characteristics . . . . . . . . . . . . . . . . . . .370 23.10 Output Low-Voltage Characteristics . . . . . . . . . . . . . . . . . . . . 373 23.11 Typical Supply Currents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 376 23.12 ADC Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 378 23.13 5.0 V SPI Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . 379 23.14 3.0 V SPI Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . 380 23.15 Timer Interface Module Characteristics . . . . . . . . . . . . . . . . . 383 23.16 Clock Generation Module Characteristics . . . . . . . . . . . . . . . 383 23.17 Memory Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 385 MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 361 Electrical Specifications 23.2 Absolute Maximum Ratings Maximum ratings are the extreme limits to which the MCU can be exposed without permanently damaging it. NOTE: This device is not guaranteed to operate properly beyond the maximum ratings. Refer to 5.0 V DC Electrical Characteristics for guaranteed operating conditions. Table 23-1. Absolute Maximum Ratings Characteristic(1) Symbol Value Unit Supply voltage VDD –0.3 to + 5.5 V Input voltage VIn VSS – 0.3 to VDD + 0.3 V Maximum current per pin excluding VDD , VSS , and PTC0–PTC1 I ± 15 mA Maximum current for pins PTC0–PTC1 IPTC0–PTC1 ± 25 mA Maximum current into VDD Imvdd 150 mA Maximum current out of VSS Imvss 150 mA Tstg –55 to +150 °C Storage temperature Note: 1. Voltages referenced to VSS NOTE: This device contains circuitry to protect the inputs against damage due to high static voltages or electric fields; however, it is advised that normal precautions be taken to avoid application of any voltage higher than maximum-rated voltages to this high-impedance circuit. For proper operation, it is recommended that VIn and VOut be constrained to the range VSS ≤ (VIn or VOut) ≤ VDD. Reliability of operation is enhanced if unused inputs are connected to an appropriate logic voltage level (for example, either VSS or VDD). Technical Data 362 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Functional Operating Range 23.3 Functional Operating Range Table 23-2. Functional Operation Range Characteristic Symbol Value Unit TA –40 to +125 °C VDD 3.0 ±10% 5.0 ±10% V Operating temperature range Operating voltage range NOTE: To ensure correct operation of the MCU under all operating conditions, the user must write data $1C to address $0033 immediately after reset. This is to ensure proper termination of an unused module within the MCU. 23.4 Thermal Characteristics Table 23-3. Thermal Characteristics Characteristic Symbol Value Unit Thermal resistance PDIP (28-pin) SOIC (28-pin) QFP (32-pin) θJA 60 60 95 °C/W I/O pin power dissipation PI/O User-Determined W Power dissipation(1) PD PD = (IDD × VDD) + PI/O = K/(TJ + 273 °C) W Constant(2) K Average junction temperature TJ TA + (PD × θJA) °C TJM 140 °C Maximum junction temperature PD x (TA + 273 °C) + PD2 × θJA W/°C Notes: 1. Power dissipation is a function of temperature. 2. K is a constant unique to the device. K can be determined for a known TA and measured PD. With this value of K, PD and TJ can be determined for any value of TA. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 363 Electrical Specifications 23.5 5.0 V DC Electrical Characteristics Table 23-4. 5.0V DC Electrical Characteristics Symbol Min Typ(2) Max Unit VOH VOH VOH IOH1 VDD – 0.8 VDD – 1.5 VDD – 0.8 — — — — — — — — 50 V V V mA IOH2 — — 50 mA IOHT — — 100 mA VOL VOL VOL IOL1 — — — — — — — — 0.4 1.5 1.0 50 V V V mA IOL2 — — 50 mA IOLT — — 100 mA Input high voltage All ports, IRQs, RESET OSC1 VIH 0.7 x VDD 0.8 x VDD — VDD V Input low voltage All ports, IRQs, RESET, OSC1 VIL VSS — 0.2 x VDD V IDD — — 15 4 20 8 mA mA IDD — — — — 3 5 20 300 5 10 35 500 µA µA µA µA I/O ports Hi-Z leakage current(7) IIL — — ±10 µA Input current IIn — — 1 µA Characteristic(1) Output high voltage (ILoad = –2.0 mA) all I/O pins (ILoad = –10.0 mA) all I/O pins (ILoad = –10.0 mA) pins PTC0–PTC1 only Maximum combined IOH for port C, port E, port PTD0–PTD3 Maximum combined IOH for port PTD4–PTD6, port A, port B Maximum total IOH for all port pins Output low voltage (ILoad = 1.6 mA) all I/O pins (ILoad = 10 mA) all I/O pins (ILoad = 15 mA) pins PTC0–PTC1 only Maximum combined IOL for port C, port E, port PTD0–PTD3 Maximum combined IOL for port PTD4–PTD6, port A, port B Maximum total IOL for all port pins VDD supply current Run(3) Wait(4) Stop(5) (85 °C) Stop with TBM enabled(6) Stop with LVI and TBM enabled(6) Technical Data 364 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications 5.0 V DC Electrical Characteristics Table 23-4. 5.0V DC Electrical Characteristics Symbol Min Typ(2) Max Unit Pullup resistors (as input only) Ports PTA3/KBD3–PTA0/KBD0, PTC1–PTC0, PTD6/T2CH0–PTD0/SS RPU 20 45 65 kΩ Capacitance Ports (as input or output) COut CIn — — — — 12 8 pF Monitor mode entry voltage VTST VDD +2.5 — 8 V Low-voltage inhibit, trip falling voltage – target VTRIPF 3.85 4.25 4.50 V Low-voltage inhibit, trip rising voltage – target VTRIPR 3.95 4.35 4.60 V Low-voltage inhibit reset/recover hysteresis – target (VTRIPF + VHYS = VTRIPR) VHYS — 100 — mV POR rearm voltage(8) VPOR 0 — 100 mV POR reset voltage(9) VPORRST 0 700 800 mV RPOR 0.035 — — V/ms Characteristic(1) POR rise time ramp rate(10) Notes: 1. VDD = 5.0 Vdc ± 10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted 2. Typical values reflect average measurements at midpoint of voltage range, 25 °C only. 3. Run (operating) IDD measured using external square wave clock source (fosc = 32.8 MHz). All inputs 0.2 V from rail. No dc loads. Less than 100 pF on all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly affects run IDD. Measured with all modules enabled. 4. Wait IDD measured using external square wave clock source (fosc = 32.8 MHz). All inputs 0.2 V from rail. No dc loads. Less than 100 pF on all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly affects wait IDD. Measured with PLL and LVI enabled. 5. Stop IDD is measured with OSC1 = VSS. 6. Stop IDD with TBM enabled is measured using an external square wave clock source (fOSC = 32.8 KHz). All inputs 0.2 V from rail. No dc loads. Less than 100 pF on all outputs. All inputs configured as inputs. 7. Pullups and pulldowns are disabled. Port B leakage is specified in ADC Characteristics. 8. Maximum is highest voltage that POR is guaranteed. 9. Maximum is highest voltage that POR is possible. 10. If minimum VDD is not reached before the internal POR reset is released, RST must be driven low externally until minimum VDD is reached. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 365 Electrical Specifications 23.6 3.0 V DC Electrical Characteristics Table 23-5. 3.0 V DC Electrical Characteristics Symbol Min Typ(2) Max Unit VOH VOH VOH IOH1 VDD – 0.3 VDD – 1.0 VDD – 0.5 — — — — — — — — 30 V V V mA IOH2 — — 30 mA IOHT — — 60 mA VOL VOL VOL IOL1 — — — — — — — — 0.3 1.0 0.8 30 V V V mA IOL2 — — 30 mA IOLT — — 60 mA Input high voltage All ports, IRQs, RESET OSC1 VIH 0.7 x VDD 0.8 x VDD — VDD V Input low voltage All ports, IRQs, RESET OSC1 VIL VSS — 0.3 x VDD 0.2 x VDD V IDD — — 4.5 1.65 8 4 mA mA IDD — — — — 1 3 12 200 3 6 20 300 µA µA µA µA I/O ports Hi-Z leakage current(7) IIL — — ±10 µA Input current IIn — — 1 µA Characteristic(1) Output high voltage (ILoad = –0.6 mA) all I/O pins (ILoad = –4.0 mA) all I/O pins (ILoad = –4.0 mA) pins PTC0–PTC1 only Maximum combined IOH for port C, port E, port PTD0–PTD3 Maximum combined IOH for port PTD4–PTD6, port A, port B Maximum total IOH for all port pins Output low voltage (ILoad = 0.5 mA) all I/O pins (ILoad = 6.0 mA) all I/O pins (ILoad = 10.0 mA) pins PTC0–PTC1 only Maximum combined IOL for port C, port E, port PTD0–PTD3 Maximum combined IOL for port PTD4–PTD6, port A, port B Maximum total IOL for all port pins VDD supply current Run(3) Wait(4) Stop(5)(85 °C) Stop with TBM enabled(6) Stop with LVI and TBM enabled(6) Technical Data 366 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications 3.0 V DC Electrical Characteristics Table 23-5. 3.0 V DC Electrical Characteristics Symbol Min Typ(2) Max Unit Pullup resistors (as input only) Ports PTA3/KBD37–PTA0/KBD0, PTC1–PTC0, PTD6/T2CH0–PTD0/SS RPU 20 45 65 kΩ Capacitance Ports (as input or output) COut CIn — — — — 12 8 pF Monitor mode entry voltage VTST VDD +2.5 — 8 V Low-voltage inhibit, trip falling voltage – target VTRIPF 2.35 2.60 2.70 V Low-voltage inhibit, trip rising voltage – target VTRIPR 2.45 2.66 2.80 V Low-voltage inhibit reset/recover hysteresis – target (VTRIPF + VHYS = VTRIPR) VHYS — 60 — mV POR rearm voltage(8) VPOR 0 — 100 mV POR reset voltage(9) VPORRST 0 700 800 mV RPOR 0.02 — — V/ms Characteristic(1) POR rise time ramp rate(10) Notes: 1. VDD = 3.0 Vdc ± 10%, VSS = 0 Vdc, TA = TL to TH, unless otherwise noted 2. Typical values reflect average measurements at midpoint of voltage range, 25 °C only. 3. Run (operating) IDD measured using external square wave clock source (fosc = 16.4 MHz). All inputs 0.2 V from rail. No dc loads. Less than 100 pF on all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly affects run IDD. Measured with all modules enabled. 4. Wait IDD measured using external square wave clock source (fosc = 16.4 MHz). All inputs 0.2 V from rail. No dc loads. Less than 100 pF on all outputs. CL = 20 pF on OSC2. All ports configured as inputs. OSC2 capacitance linearly affects wait IDD. Measured with PLL and LVI enabled. 5. Stop IDD is measured with OSC1 = VSS. 6. Stop IDD with TBM enabled is measured using an external square wave clock source (fOSC = 32.8 KHz). All inputs 0.2 V from rail. No dc loads. Less than 100 pF on all outputs. All inputs configured as inputs. 7. Pullups and pulldowns are disabled. 8. Maximum is highest voltage that POR is guaranteed. 9. Maximum is highest voltage that POR is possible. 10. If minimum VDD is not reached before the internal POR reset is released, RST must be driven low externally until minimum VDD is reached. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 367 Electrical Specifications 23.7 5.0 V Control Timing Table 23-6. 5.0 V Control Timing Characteristic(1) Symbol Min Max Unit Frequency of operation(2) Crystal option External clock option(3) fosc 32 dc(4) 100 32.8 kHz MHz Internal operating frequency fop — 8.2 MHz Internal clock period (1/fOP) tcyc 122 — ns RESET input pulse width low(5) tIRL 50 — ns IRQ interrupt pulse width low(6) (edge-triggered) tILIH 50 — ns IRQ interrupt pulse period tILIL Note 8 — tcyc 16-bit timer(7) Input capture pulse width Input capture period tTH,tTL tTLTL Note 8 — — ns tcyc Notes: 1. VSS = 0 Vdc; timing shown with respect to 20% VDD and 70% VSS unless otherwise noted. 2. See Clock Generation Module Characteristics for more information. 3. No more than 10% duty cycle deviation from 50% 4. Some modules may require a minimum frequency greater than dc for proper operation. See appropriate table for this information. 5. Minimum pulse width reset is guaranteed to be recognized. It is possible for a smaller pulse width to cause a reset. 6. Minimum pulse width is for guaranteed interrupt. It is possible for a smaller pulse width to be recognized. 7. Minimum pulse width is for guaranteed interrupt. It is possible for a smaller pulse width to be recognized. 8. The minimum period, tILIL or tTLTL, should not be less than the number of cycles it takes to execute the interrupt service routine plus tcyc. Technical Data 368 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications 3.0 V Control Timing 23.8 3.0 V Control Timing Table 23-7. 3.0 V Control Timing Characteristic(1) Symbol Min Max Unit Frequency of operation(2) Crystal option External clock option(3) fosc 32 dc(4) 100 16.4 kHz MHz Internal operating frequency fop — 4.1 MHz Internal clock period (1/fOP) tcyc 244 — ns RESET input pulse width low(5) tIRL 125 — ns IRQ interrupt pulse width low(6) (edge-triggered) tILIH 125 — ns IRQ interrupt pulse period tILIL Note 8 — tcyc 16-bit timer(7) Input capture pulse width Input capture period tTH,tTL tTLTL Note 8 — — ns tcyc Notes: 1. VSS = 0 Vdc; timing shown with respect to 20% VDD and 70% VSS unless otherwise noted. 2. See Clock Generation Module Characteristics for more information. 3. No more than 10% duty cycle deviation from 50% 4. Some modules may require a minimum frequency greater than dc for proper operation. See appropriate table for this information. 5. Minimum pulse width reset is guaranteed to be recognized. It is possible for a smaller pulse width to cause a reset. 6. Minimum pulse width is for guaranteed interrupt. It is possible for a smaller pulse width to be recognized. 7. Minimum pulse width is for guaranteed interrupt. It is possible for a smaller pulse width to be recognized. 8. The minimum period, tILIL or tTLTL, should not be less than the number of cycles it takes to execute the interrupt service routine plus tCYC. MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 369 Electrical Specifications 23.9 Output High-Voltage Characteristics 0 –5 IOH (mA) –10 –40 0 25 85 –15 –20 –25 –30 –35 –40 3 3.2 3.4 3.6 VOH (V) 3.8 4.0 4.2 VOH > VDD –0.8 V @ IOH = –2.0 mA VOH > VDD –1.5 V @ IOH = –10.0 mA Figure 23-1. Typical High-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 4.5 Vdc) 0 IOH (mA) –5 –40 0 25 85 –10 –15 –20 –25 1.3 1.5 1.7 1.9 VOH (V) 2.1 2.3 2.5 VOH > VDD –0.3 V @ IOH = –0.6 mA VOH > VDD –1.0 V @ IOH = –4.0 mA Figure 23-2. Typical High-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 2.7 Vdc) Technical Data 370 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Output High-Voltage Characteristics 0 –5 IOH (mA) –10 –40 0 25 85 –15 –20 –25 –30 –35 –40 3 3.2 3.4 3.6 VOH (V) 3.8 4.0 4.2 VOH > VDD –0.8 V @ IOH = –10.0 mA Figure 23-3. Typical High-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 4.5 Vdc) 0 IOH (mA) –5 –40 0 25 85 –10 –15 –20 –25 1.3 1.5 1.7 1.9 VOH (V) 2.1 2.3 2.5 VOH > VDD –0.5 V @ IOH = –4.0 mA Figure 23-4. Typical High-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 2.7 Vdc) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 371 Electrical Specifications 0 –10 –20 –40 0 25 85 IOH (mA) –30 –40 –50 –60 –70 –80 –90 3 3.2 3.4 3.6 3.8 VOH (V) 4.0 4.2 4.4 4.6 VOH > VDD –0.8 V @ IOH = –2.0 mA VOH > VDD –1.5 V @ IOH = –10.0 mA Figure 23-5. Typical High-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 5.5 Vdc) 0 IOH (mA) –5 –40 0 25 85 –10 –15 –20 –25 1.3 1.5 1.7 1.9 VOH (V) 2.1 2.3 2.5 VOH > VDD –0.3 V @ IOH = –0.6 mA VOH > VDD –1.0 V @ IOH = –4.0 mA Figure 23-6. Typical High-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 2.7 Vdc) Technical Data 372 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Output Low-Voltage Characteristics 23.10 Output Low-Voltage Characteristics 35 30 –40 0 25 85 IOL (mA) 25 20 15 10 5 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 VOL (V) VOL < 0.4 V @ IOL = 1.6 mA VOL < 1.5 V @ IOL = 10.0 mA Figure 23-7. Typical Low-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 5.5 Vdc) 14 12 –40 0 25 85 IOL (mA) 10 8 6 4 2 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 VOL (V) VOL < 0.3 V @ IOL = 0.5 mA VOL < 1.0 V @ IOL = 6.0 mA Figure 23-8. Typical Low-Side Driver Characteristics – Port PTA3–PTA0 (VDD = 2.7 Vdc) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 373 Electrical Specifications 60 IOL (mA) 50 40 –40 0 25 85 30 20 10 0 0.4 0.6 0.8 1.0 1.2 1.4 1.6 VOL (V) VOL < 1.0 V @ IOL = 15 mA Figure 23-9. Typical Low-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 4.5 Vdc) 30 IOL (mA) 25 –40 0 25 85 20 15 10 5 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 VOL (V) VOL < 0.8 V @ IOL = 10 mA Figure 23-10. Typical Low-Side Driver Characteristics – Port PTC1–PTC0 (VDD = 2.7 Vdc) Technical Data 374 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Output Low-Voltage Characteristics 35 30 –40 0 25 85 IOL (mA) 25 20 15 10 5 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.6 1.4 VOL (V) VOL < 0.4 V @ IOL = 1.6 mA VOL < 1.5 V @ IOL = 10.0 mA Figure 23-11. Typical Low-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 5.5 Vdc) 14 12 –40 0 25 85 IOL (mA) 10 8 6 4 2 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 VOL (V) VOL < 0.3 V @ IOL = 0.5 mA VOL < 1.0 V @ IOL = 6.0 mA Figure 23-12. Typical Low-Side Driver Characteristics – Ports PTB5–PTB0, PTD6–PTD0, and PTE1–PTE0 (VDD = 2.7 Vdc) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 375 Electrical Specifications 23.11 Typical Supply Currents 16 14 12 IDD (mA) 10 8 6 4 5.5 V 3.6 V 2 0 0 1 2 3 4 5 fbus (MHz) 6 7 8 9 Figure 23-13. Typical Operating IDD, with All Modules Turned On (–40 °C to 125 °C) 5.0 4.5 4.0 IDD (mA) 3.5 3.0 2.5 2.0 1.5 1.0 5.5 V 3.6 V 0.5 0 0 1 2 3 4 fbus (MHz) 5 6 7 8 Figure 23-14. Typical Wait Mode IDD, with all Modules Disabled (–40 °C to 125 °C) Technical Data 376 MC68HC908GR8 — Rev 4.0 Electrical Specifications MOTOROLA Electrical Specifications Typical Supply Currents 1.35 1.30 IDD (µA) 1.25 1.20 1.15 1.10 5.5 V 3.6 V 1.05 1 0 1 2 3 4 5 fbus (MHz) 6 7 8 9 Figure 23-15. Typical Stop Mode IDD, with all Modules Disabled (–40 °C to 125 °C) MC68HC908GR8 — Rev 4.0 MOTOROLA Technical Data Electrical Specifications 377 Electrical Specifications 23.12 ADC Characteristics Characteristic(1) Symbol Min Max Unit Comments Supply voltage VDDAD 2.7 (VDD min) 5.5 (VDD max) V VDDAD should be tied to the same potential as VDD via separate traces. Input voltages VADIN 0 VDDAD V VADIN Semiconductors > 68HC908GR4 : Microcontroller Page Contents: The 68HC908GR4 is a member of the low-cost, high-performance M68HC08 Family of 8-bit microcontroller units (MCUs). All MCUs in the family use the enhanced M68HC08 central processor unit (CPU08) and are available with a variety of modules, memory sizes and types, and package types. Features Documentation Tools Rich Media Block Diagram Orderable Parts Related Links 68HC908GR4 Features Other Info: ● ● ● ● ● ● ● FAQs 3rd Party Design Help Training 3rd Party Tool Vendors M68HC08 architecture optimized for C-compiler Fully upward-compatible object code with M6805, M146805, and M68HC05 families 8MHz internal bus frequency at 85C FLASH program memory security On-chip programming firmware for use with host personal computer which does not require high voltage for entry In-system programming System protection features: ❍ Optional Computer Operating Properly (COP) reset ❍ Low-voltage detection with optional reset ❍ Illegal opcode detection with optional reset ❍ Illegal address detection with optional reset (Non-Expanded mode) Rate this Page -- - 0 + ++ Submit Care to Comment? Return to Top 68HC908GR4 Documentation Documentation Application Note ID Name AN1050_D Designing for Electromagnetic Compatibility (EMC) with HCMOS Microcontrollers AN1218/D HC05 to HC08 Optimization AN1219/D M68HC08 Integer Math Routines AN1219SW Software Files for AN1219 zipped Vendor ID Format MOTOROLA MOTOROLA MOTOROLA MOTOROLA pdf 82 0 1/01/2000 pdf 347 2 1/01/1993 pdf 177 1 1/01/1997 zip 77 0 1/01/1995 63 0 1/01/1993 55 0 1/01/1995 24 0 1/01/1993 AN1221SW Hamming Error Control Coding Techniques with the HC08 MOTOROLA pdf MCU MOTOROLA Software Files for AN1221 zipped zip AN1222/D Arithmetic Waveform Synthesis with the HC05/08 MCUs AN1221/D MOTOROLA Size Rev Date Last Order K # Modified Availability pdf file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (1 of 8) [28-Nov-03 11:19:51 AM] - - - 68HC908GR4 Product Summary Page AN1222SW AN1259/D AN1263/D Software Files for AN1222 zipped System Design and Layout Techniques for Noise Reduction in MCU-Based Systems Designing for Electromagnetic Compatibility with SingleChip Microcontrollers AN1274/D HC08 SCI Operation with Various Input Clocks AN1516/D Liquid Level Control Using a Motorola Pressure Sensor AN1705/D Noise Reduction Techniques for Microcontroller-Based Systems AN1744/D Resetting Microcontrollers During Power Transitions AN1752/D Data Structures for 8-Bit Microcontrollers AN1771/D Precision Sine-Wave Tone Synthesis Using 8-Bit MCUs AN1775/D Expanding Digital Input with an A/D Converter AN1783/D Determining MCU Oscillator Start-Up Parameters AN1818/D Software SCI Routines with the 16-Bit Timer Module AN1820/D Software I2C Communications AN1820SW Software files for AN1820 zipped AN1837/D Non-Volatile Memory Technology Overview AN1853/D Embedding Microcontrollers in Domestic Refrigeration Appliances AN2093/D Creating Efficient C Code for the MC68HC08 AN2103/D Local Interconnect Network (LIN) Demonstration AN2105/D AN2120/D AN2120SW AN2149/D AN2159/D Power-On, Clock Selection, and Noise Reduction Techniques for the Motorola MC68HC908GP32 Connecting an M68HC08 Family Microcontroller to an Internet Service Provider (ISP) Using the Point-to-Point Protocol (PPP) Software for AN2120, zip format Compressor Induction Motor Stall and Rotation Detection using Microcontrollers Digital Direct Current Ignition System Using HC08 Microcontrollers AN2159SW AN2159SW AN2262/D Wireless HC08 Modem AN2262SW Software files for application note AN2262 AN2295 Developer's Serial Bootloader for M68HC08 AN2295SW Software for AN2295 MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA zip 20 0 1/01/1995 pdf 78 0 1/01/1995 pdf 104 0 1/01/1995 pdf 47 0 1/01/1996 pdf 77 2 1/24/2003 pdf 67 0 1/01/1999 pdf 80 0 1/01/1998 pdf 213 1 5/07/2001 pdf 250 0 1/01/1998 pdf 86 1 1/01/1998 pdf 48 1 1/01/1999 pdf 84 0 1/01/1999 pdf 55 0 1/01/1999 zip 2 0 1/01/1998 pdf 116 0 3/27/2000 pdf 221 0 6/22/2000 pdf 36 0 1/01/2000 pdf 953 0 pdf 109 1 pdf 741 0 zip 31 pdf 127 0 pdf 129 0 zip 182 1 3/08/2002 1 6/18/2002 pdf 1185 31 pdf 738 11/05/2001 5/20/2001 zip 725 4.0 file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (2 of 8) [28-Nov-03 11:19:51 AM] - 5/30/2001 11/20/2001 1.1 6/25/2002 4 - 12/01/2000 1.0 7/31/2002 zip - - - 10/29/2003 10/21/2003 - 68HC908GR4 Product Summary Page AN2321/D AN2342 AN2396/D Designing for Board Level Electromagnetic Compatibility Opto Isolation Circuits For In Circuit Debugging of 68HC9(S)12 and 68HC908 Microcontrollers Servo Motor Control Application on a Local Area Interconnect Network (LIN) MOTOROLA pdf MOTOROLA MOTOROLA MOTOROLA AN2396SW Software files for AN2396 AN2438/D ADC Definitions and Specifications AN2504 On-Chip FLASH Programming API for CodeWarrior AN2504SW Software files for application note AN2504 MOTOROLA MOTOROLA MOTOROLA 1628 0 8/15/2002 pdf 155 0 9/25/2002 pdf 678 0 4/01/2003 zip 564 0 4/18/2003 pdf 297 0 2/21/2003 pdf 530 0 zip 59 0 - 10/15/2003 10/21/2003 - Brochure ID Name Vendor ID Format MOTOROLA BR68HC08FAMAM/D 68HC08 Family: High Performance and Flexibility pdf FLYREMBEDFLASH/D Embedded Flash: Changing the Technology World for MOTOROLA pdf the Better Size Rev Date Last Order K # Modified Availability 5/21/2003 57 2 68 2 5/21/2003 Data Sheets ID Name MC68HC908GR8/D MC68HC908GR8 Technical Data pdf Size Rev Date Last Order K # Modified Availability 2432 6/22/2002 4 pdf 18 Vendor ID Format MOTOROLA MC68HC908GR8AD/D Addendum to MC68HC908GR8 Technical Data Rev. 4 MOTOROLA 0 7/30/2002 Engineering Bulletin ID EB389/D EB390/D EB396/D EB398 EB608/D Name Vendor ID Format TOF Consideration when Measuring a Long Input Capture Event Porting the AN2120/D UDP/IP Code to the Avnet Evaluation Board Use of OSC2/XTAL as a Clock Output on Motorola Microcontrollers Techniques to Protect MCU Applications Against Malfunction Due to Code Run-Away Interrupt Handling Considerations When Modifying EEPROM on HC08 Microcontrollers MOTOROLA pdf MOTOROLA pdf MOTOROLA MOTOROLA MOTOROLA Size Rev Date Last Order K # Modified Availability 4/15/2002 55 1 1501 0 pdf 49 0 pdf 0 0 pdf 96 0 5/09/2002 6/19/2002 8/13/2002 8/14/2002 Fact Sheets Vendor ID Format Size K Rev # Date Last Modified ID Name 68HC908GRFAMPB/D 8-bit Microcontroller MOTOROLA pdf 53 2 5/21/2003 CWDEVSTUDFACTHC08 Development Studio MOTOROLA pdf 48 2 5/13/2002 Order Availability - Product Change Notices ID Name PCN7701 PCN7703 Size Rev K # Date Last Modified Order Availability htm 16 - 7/09/2002 - htm 14 - 7/01/2002 - Vendor ID Format QFP 10X10 ASSY MOVE FROM SHC TO BAT3 MOTOROLA LQFP 7X7 ASSY MOVE FROM SHC TO BAT3 MOTOROLA file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (3 of 8) [28-Nov-03 11:19:51 AM] 68HC908GR4 Product Summary Page Reference Manual ID Name Vendor ID Format ADCRM/AD Analog-to-Digital Reference Manual MOTOROLA pdf CPU08RM/AD CPU08RM Central Processor Unit Reference Manual MOTOROLA pdf TIM08RM/AD TIM08 Timer Interface Module Reference Manual pdf MOTOROLA Size Rev Date Last K # Modified 231 0 1/01/1996 3 4/03/2002 1.0 1/10/1996 2666 771 Order Availability Selector Guide ID Name SG1002 Analog Selector Guide - Quarter 4, 2003 SG1006 Microcontrollers Selector Guide - Quarter 4, 2003 SG1010 Sensors Selector Guide - Quarter 4, 2003 SG1011 SG2000CR SG2036 SG2037 SG2038 SG2039 SG2040 SG2044 Vendor ID Format MOTOROLA MOTOROLA MOTOROLA pdf pdf pdf Software and Development Tools Selector Guide - Quarter MOTOROLA pdf 4, 2003 MOTOROLA Application Selector Guide Index and Cross-Reference. pdf Application Summary Home Appliances - Cooking Products. Microcontrollers provide intelligent management programs delivering high precision control over the cooking process. Application Selector Guide - Home Appliances DISHWASHERS Application Summary - Home Appliances - Refrigerators and Freezers. Microcontrollers maximize appliance efficiency while supporting a variety of features in refrigerators and freezers. Application Selector Guide - Vacuum Cleaners Vacuum Cleaners Application Selector Guide - Home Applicances WASHING MACHINES Application Summary - Home Appliances. Dryers. New dryer features make this application more energy efficient and better able to meet consumer demands for improved control. MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA Size Rev Date Last Order K # Modified Availability 579 10/24/2003 0 826 219 287 0 0 0 10/24/2003 10/24/2003 10/24/2003 11/11/2003 95 3 pdf 0 1 pdf 0 2 pdf 0 1 pdf 0 0 6/17/2003 pdf 0 2 6/17/2003 pdf 0 1 12/16/2002 6/17/2003 12/16/2002 12/16/2002 Users Guide ID Name CDSWHC08QS CodeWarrior™ Development Studio for 68HC08 Quick Start Guide Vendor ID Format MOTOROLA pdf Size Rev Date Last Order K # Modified Availability 2847 9/20/2002 2.1 - Return to Top 68HC908GR4 Tools file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (4 of 8) [28-Nov-03 11:19:51 AM] 68HC908GR4 Product Summary Page Hardware Tools Emulators/Probes/Wigglers ID Name Vendor ID Format AX-6811 AX-6811 IC10000 Size Rev Order K # Availability HITEX - - - - iC1000 PowerEmulator ISYS - - - - IC20000 iC2000 PowerEmulator ISYS - - - - IC40000 iC4000 ActiveEmulator ISYS - - - - INDART-HC08/D In-Circuit, Real-Time Debugger/Programmer for Motorola 68HC08 Family (USB) SOFTEC - - - - Evaluation/Development Boards and Systems ID Name Vendor ID KITMMDS08GR Modular Development System (MMDS) Kits MOTOROLA - - - KITMMEVS08GR Modular Evaluation System (MMEVS) MOTOROLA - - - M68CBL05C Low-noise Flex Cable MOTOROLA - - - M68EML08GP32 Emulation Module MOTOROLA - - - M68ICS08GR M68ICS08GR Development Tool Kit MOTOROLA - - - M68CYCLONE08 MON08 Cyclone METROWERKS - - - M68MULTILINK08 MON08 Multilink METROWERKS - - - INDART-HC08/GZ Design Kit for Motorola MC68HC908GZ/GR (USB) SOFTEC - - - Order Availability Format Size K Rev # - - Programmers ID MP8011A Name Vendor ID SOFTEC Format Size K Rev # Order Availability Gang Programmer Base Unit - - - - POWERLAB Universal Programmer SYSGEN - - - - Software Application Software Code Examples ID Name HC08DELAYSW HC08EXSW Vendor ID Format HC08 Software Example: Subroutine that delays for a whole number of milliseconds HC08 Software Example: Library containing software examples in assembly for 68HC08 MOTOROLA MOTOROLA Size Rev Order K # Availability zip 2 - - zip 14 - - Device Drivers ID HC908SGF50NVMSSD Operating Systems ID CMX-TINY+ Name Vendor ID Format HC908 SGF NVM Standard Software Drivers Program/erase software driver for 0.5um SGF NVM (flash and EEPROM) in HC908 Name CMX-Tiny+ Vendor ID CMX MOTOROLA zip Size Rev Order K # Availability 1387 3.0.0 - Format Size K Rev # Order Availability - - - - file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (5 of 8) [28-Nov-03 11:19:51 AM] 68HC908GR4 Product Summary Page Software Tools Assemblers Size Rev Order K # Availability ID Name Vendor ID Format ADX-08 ADX-08 Macro Assembler-Linker and IDE AVOCET - - - - AX6808 AX6808 relocatable and absolute macro assembler for HC08 and HCS08 COSMIC - - - - Compilers ID CX6808S Name ICC08 ICC08 V6 STD Vendor ID Format Size K Rev # Order Availability COSMIC - CX6808 C Cross Compiler for HC08 and HCS08 IMAGE - - - - Debuggers ID Name Vendor ID Format ZAP 6808 MON08 Debugger and Flash Programmer ZAP 6808 MON08 debugger uses the 68HC08’s on-chip monitor ZAP 6808 MON08 interface to provide a real-time ANSI C and assembly source level debugger including FLASH programming, FLASH security and hardware breakpoint support. ZAP 6808 MMDS ZAP 6808 MMDS Debugger ZAP 6808 SIM AX-6811 NOICE08 MOTOROLA ZAP 6808 Simulator Debugger Size Rev Order K # Availability - - - - COSMIC - - - - COSMIC - - - - AX-6811 HITEX - - - - NoICE08 IMAGE - - - - IDE (Integrated Development Environment) ID Name CDCWSEHC08 CodeWarrior Development Studio™ for HC(S)08 Special Edition CWHC08PRO CWHC08STD CX6808LT4 IDEA08 IC-SW-OPR CodeWarrior Development Studio for Motorola HC08 Microcontrollers Professional Edition CodeWarrior Development Studio for Motorola HC08 Microcontrollers Standard Edition Format METROWERKS - - - METROWERKS - - - METROWERKS - - - COSMIC - - - - COSMIC - - - - ISYS - - - - HC08 Development Tool Suite 4K Lite (FREE) IDEA08 integrated development environment for HC08 and HCS08 winIDEA Performance and Testing ID AX-6811 Name AX-6811 Vendor ID HITEX Size Rev Order K # Availability Vendor ID - Format Size K Rev # Order Availability - - - - Return to Top Rich Media file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (6 of 8) [28-Nov-03 11:19:51 AM] 68HC908GR4 Product Summary Page Rich Media Webcast ID Name Vendor ID Format CodeWarrior Development Tools for 68HC08 and HCS12 Microcontrollers. RMWC_CODEWARRIOR MOTOROLA Listen to our webcast for an overview of some of the challenges html that developers face and an explanation of the CodeWarrior tools that help to address these challenges. 8-bit Microcontroller Overview and Q-Family of Flash Microcontrollers Listen to our companion webcasts to learn about Motorola's MOTOROLA RMWC_QFAMILY htm recent 8-bit products and services-especially the HC08 QFamily-that offer maximum design flexibility while helping you get to market fast. Size Rev Order K # Availability 4 0.0 - 5 1.1 - Return to Top Orderable Parts Information Package Info Tape and Reel Life Cycle Description (code) KMC908GR4CDW SOIC 28W No PRODUCT RAPID GROWTH(2) $2.25 more KMC908GR4CFA LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $2.25 more PDIP 28 No PRODUCT RAPID GROWTH(2) $2.25 more MC68HC908GR4CDW SOIC 28W No PRODUCT RAPID GROWTH(2) $2.25 more MC68HC908GR4CFA LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $2.25 more MC68HC908GR4CP PDIP 28 No PRODUCT RAPID GROWTH(2) $2.25 more MC908GR4CDWR2 SOIC 28W Yes PRODUCT RAPID GROWTH(2) $2.37 more MC908GR4CFAR2 LQFP 32 7*7*1.4P0.8 Yes PRODUCT RAPID GROWTH(2) - more PartNumber KMC908GR4CP Budgetary Price Additional Info Order Availability QTY 1000+ ($US) - NOTE: Are you looking for an obsolete orderable part? Click HERE to check our distributors' inventory. Return to Top Related Links Microcontrollers Motor Control Sensors file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (7 of 8) [28-Nov-03 11:19:51 AM] 68HC908GR4 Product Summary Page Return to Top http://www.motorola.com/ | Site Map | Contact Motorola | Terms of Use | Privacy Practices © Copyright 1994-2003 Motorola, Inc. All Rights Reserved. file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR8.htm (8 of 8) [28-Nov-03 11:19:51 AM] 68HC908GR8 Product Summary Page Select Country Search Advanced | Parametric | Part Number | FAQ Motorola Home | Semiconductors Home | Contact Us Semiconductors Products | Design Support | Register | Login Motorola > Semiconductors > 68HC908GR8 : Microcontroller Page Contents: The 68HC908GR8 is a member of the low-cost, high-performance M68HC08 Family of 8-bit microcontroller units (MCUs). All MCUs in the family use the enhanced M68HC08 central processor unit (CPU08) and are available with a variety of modules, memory sizes and types, and package types. Features Documentation Reference Designs Tools Rich Media Block Diagram Orderable Parts Related Links 68HC908GR8 Features ● ● ● ● ● ● ● Other Info: High-performance M68HC08 architecture optimized for C-compiler Fully upward-compatible object code with M6805, M146805, and M68HC05 families 8MHz internal bus frequency at 85°C FLASH program memory security On-chip programming firmware for use with host personal computer which does not require high voltage for entry In-system programming System protection features: ❍ Optional Computer Operating Properly (COP) reset ❍ Low-voltage detection with optional reset ❍ Illegal opcode detection with optional reset ❍ Illegal address detection with optional reset (Non-Expanded mode FAQs 3rd Party Design Help Training 3rd Party Tool Vendors Rate this Page -- - 0 + ++ Submit Care to Comment? Return to Top 68HC908GR8 Documentation Documentation Application Note ID Name AN1050_D Designing for Electromagnetic Compatibility (EMC) with HCMOS Microcontrollers AN1218/D HC05 to HC08 Optimization AN1219/D M68HC08 Integer Math Routines AN1219SW Software Files for AN1219 zipped Vendor ID Format MOTOROLA MOTOROLA MOTOROLA MOTOROLA pdf 82 0 1/01/2000 pdf 347 2 1/01/1993 pdf 177 1 1/01/1997 zip 77 0 1/01/1995 63 0 1/01/1993 55 0 1/01/1995 24 0 1/01/1993 AN1221SW Hamming Error Control Coding Techniques with the HC08 MOTOROLA pdf MCU MOTOROLA Software Files for AN1221 zipped zip AN1222/D Arithmetic Waveform Synthesis with the HC05/08 MCUs AN1221/D MOTOROLA Size Rev Date Last Order K # Modified Availability pdf file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (1 of 8) [28-Nov-03 11:23:04 AM] - - - 68HC908GR8 Product Summary Page AN1222SW AN1259/D AN1263/D Software Files for AN1222 zipped System Design and Layout Techniques for Noise Reduction in MCU-Based Systems Designing for Electromagnetic Compatibility with SingleChip Microcontrollers AN1274/D HC08 SCI Operation with Various Input Clocks AN1516/D Liquid Level Control Using a Motorola Pressure Sensor AN1705/D Noise Reduction Techniques for Microcontroller-Based Systems AN1744/D Resetting Microcontrollers During Power Transitions AN1752/D Data Structures for 8-Bit Microcontrollers AN1771/D Precision Sine-Wave Tone Synthesis Using 8-Bit MCUs AN1775/D Expanding Digital Input with an A/D Converter AN1783/D Determining MCU Oscillator Start-Up Parameters AN1818/D Software SCI Routines with the 16-Bit Timer Module AN1820/D Software I2C Communications AN1820SW Software files for AN1820 zipped AN1831/D AN1837/D Embedding Microcontrollers in Domestic Refrigeration Appliances AN2093/D Creating Efficient C Code for the MC68HC08 AN2103/D Local Interconnect Network (LIN) Demonstration AN2120/D AN2120SW AN2149/D AN2159/D MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA zip 20 0 1/01/1995 pdf 78 0 1/01/1995 pdf 104 0 1/01/1995 pdf 47 0 1/01/1996 pdf 77 2 1/24/2003 pdf 67 0 1/01/1999 pdf 80 0 1/01/1998 pdf 213 1 5/07/2001 pdf 250 0 1/01/1998 pdf 86 1 1/01/1998 pdf 48 1 1/01/1999 pdf 84 0 1/01/1999 pdf 55 0 1/01/1999 zip 2 0 1/01/1998 314 2 9/27/2001 116 0 3/27/2000 pdf 221 0 6/22/2000 pdf 36 0 1/01/2000 pdf 953 0 pdf 109 1 pdf 741 0 zip 31 pdf 127 0 pdf 129 0 zip 182 1 3/08/2002 1 6/18/2002 Using MC68HC908 On-Chip FLASH Programming Routines ROM-Resident Routines in the MC68HC908GR8, MOTOROLA pdf MC68HC908KX8, MC68HC908JL3, MC68HC908JK3, and the MC68HC908JB8 MOTOROLA Non-Volatile Memory Technology Overview pdf AN1853/D AN2105/D MOTOROLA Power-On, Clock Selection, and Noise Reduction Techniques for the Motorola MC68HC908GP32 Connecting an M68HC08 Family Microcontroller to an Internet Service Provider (ISP) Using the Point-to-Point Protocol (PPP) Software for AN2120, zip format Compressor Induction Motor Stall and Rotation Detection using Microcontrollers Digital Direct Current Ignition System Using HC08 Microcontrollers AN2159SW AN2159SW AN2262/D Wireless HC08 Modem AN2262SW Software files for application note AN2262 MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA pdf zip 1185 31 - - 12/01/2000 11/05/2001 5/20/2001 1.0 7/31/2002 - 5/30/2001 11/20/2001 1.1 6/25/2002 file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (2 of 8) [28-Nov-03 11:23:04 AM] - - 68HC908GR8 Product Summary Page AN2295 Developer's Serial Bootloader for M68HC08 AN2295SW Software for AN2295 AN2321/D Designing for Board Level Electromagnetic Compatibility AN2342 AN2396/D Opto Isolation Circuits For In Circuit Debugging of 68HC9(S)12 and 68HC908 Microcontrollers Servo Motor Control Application on a Local Area Interconnect Network (LIN) MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA pdf 738 zip 725 4.0 pdf 1628 4 8/15/2002 pdf 155 0 9/25/2002 pdf 678 0 4/01/2003 zip 564 0 4/18/2003 pdf 297 0 2/21/2003 pdf 530 0 Software files for AN2396 AN2438/D ADC Definitions and Specifications AN2504 On-Chip FLASH Programming API for CodeWarrior AN2504SW Software files for application note AN2504 zip 59 0 AN2571 Converting Demos in Standard Software Drivers for HC908 MOTOROLA pdf Derivatives 430 1 MOTOROLA MOTOROLA 10/21/2003 0 AN2396SW MOTOROLA 10/29/2003 - - 10/15/2003 10/21/2003 - 9/11/2003 Brochure ID Name BR68HC08FAMAM/D 68HC08 Family: High Performance and Flexibility Vendor ID Format MOTOROLA pdf FLYREMBEDFLASH/D Embedded Flash: Changing the Technology World for MOTOROLA pdf the Better Size Rev Date Last Order K # Modified Availability 5/21/2003 57 2 68 2 5/21/2003 Data Sheets ID Name MC68HC908GR8/D MC68HC908GR8 Technical Data pdf Size Rev Date Last Order K # Modified Availability 2432 6/22/2002 4 pdf 18 Vendor ID Format MOTOROLA MC68HC908GR8AD/D Addendum to MC68HC908GR8 Technical Data Rev. 4 MOTOROLA 0 7/30/2002 Engineering Bulletin ID EB368/D EB389/D EB390/D EB396/D EB398 EB608/D Name In-Circuit Programming of FLASH Memory Using the Monitor Mode for the MC68HC908GR8 TOF Consideration when Measuring a Long Input Capture Event Porting the AN2120/D UDP/IP Code to the Avnet Evaluation Board Use of OSC2/XTAL as a Clock Output on Motorola Microcontrollers Techniques to Protect MCU Applications Against Malfunction Due to Code Run-Away Interrupt Handling Considerations When Modifying EEPROM on HC08 Microcontrollers pdf Size Rev Date Last Order K # Modified Availability 9/10/2001 231 2 pdf 55 Vendor ID Format MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA pdf 1501 1 0 pdf 49 0 pdf 0 0 pdf 96 0 file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (3 of 8) [28-Nov-03 11:23:04 AM] 4/15/2002 5/09/2002 6/19/2002 8/13/2002 8/14/2002 68HC908GR8 Product Summary Page Fact Sheets Vendor ID Date Last Modified ID Name Format Size K Rev # 68HC908GRFAMPB/D 8-bit Microcontroller MOTOROLA pdf 53 2 5/21/2003 CWDEVSTUDFACTHC08 Development Studio MOTOROLA pdf 48 2 5/13/2002 Order Availability - Product Change Notices Size Rev K # Date Last Modified Order Availability htm 16 - 7/09/2002 - MOTOROLA htm 14 - 7/01/2002 - QUALIFICATION OF MC68HC908GR8 IN TSC6 MOTOROLA htm 5 - 7/08/2002 - CARBON FIBER ITW QFP TRAY CONVERSION MOTOROLA htm 100 0 3/31/2003 - ID Name Vendor ID Format PCN7701 QFP 10X10 ASSY MOVE FROM SHC TO BAT3 MOTOROLA PCN7703 LQFP 7X7 ASSY MOVE FROM SHC TO BAT3 PCN7726 PCN8698 Reference Manual ID Name Vendor ID Format ADCRM/AD Analog-to-Digital Reference Manual MOTOROLA pdf CPU08RM/AD CPU08RM Central Processor Unit Reference Manual MOTOROLA pdf TIM08RM/AD TIM08 Timer Interface Module Reference Manual pdf MOTOROLA Size Rev Date Last K # Modified 231 0 1/01/1996 3 4/03/2002 1.0 1/10/1996 2666 771 Order Availability Selector Guide ID Name SG1002 Analog Selector Guide - Quarter 4, 2003 SG1006 Microcontrollers Selector Guide - Quarter 4, 2003 SG1010 Sensors Selector Guide - Quarter 4, 2003 SG1011 SG2000CR SG2036 SG2037 SG2038 SG2039 SG2040 SG2044 Vendor ID Format MOTOROLA MOTOROLA MOTOROLA pdf pdf pdf Software and Development Tools Selector Guide - Quarter MOTOROLA pdf 4, 2003 MOTOROLA Application Selector Guide Index and Cross-Reference. pdf Application Summary Home Appliances - Cooking Products. Microcontrollers provide intelligent management programs delivering high precision control over the cooking process. Application Selector Guide - Home Appliances DISHWASHERS Application Summary - Home Appliances - Refrigerators and Freezers. Microcontrollers maximize appliance efficiency while supporting a variety of features in refrigerators and freezers. Application Selector Guide - Vacuum Cleaners Vacuum Cleaners Application Selector Guide - Home Applicances WASHING MACHINES Application Summary - Home Appliances. Dryers. New dryer features make this application more energy efficient and better able to meet consumer demands for improved control. MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA MOTOROLA Size Rev Date Last Order K # Modified Availability 579 10/24/2003 0 826 219 287 0 0 0 10/24/2003 10/24/2003 10/24/2003 11/11/2003 95 3 pdf 0 1 pdf 0 2 pdf 0 1 pdf 0 0 6/17/2003 pdf 0 2 6/17/2003 pdf 0 1 12/16/2002 6/17/2003 12/16/2002 12/16/2002 file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (4 of 8) [28-Nov-03 11:23:04 AM] 68HC908GR8 Product Summary Page Users Guide ID Name CDSWHC08QS CodeWarrior™ Development Studio for 68HC08 Quick Start Guide Size Rev Date Last Order K # Modified Availability 2847 9/20/2002 2.1 - Vendor ID Format MOTOROLA pdf Return to Top 68HC908GR8 Reference Designs Reference Designs ID Name RD68HC908CAN Control Area Network (CAN) Reference Design Vendor ID Format MOTOROLA RD68HC908PLKNX Konnex PL132 Over Power Line Based On Motorola's M68HC08 Family MOTOROLA Size Rev Order K # Availability - - - - - - - - Return to Top 68HC908GR8 Tools Hardware Tools Emulators/Probes/Wigglers ID Name Vendor ID Format AX-6811 AX-6811 IC10000 Size Rev Order K # Availability HITEX - - - - iC1000 PowerEmulator ISYS - - - - IC20000 iC2000 PowerEmulator ISYS - - - - IC40000 iC4000 ActiveEmulator ISYS - - - - INDART-HC08/D In-Circuit, Real-Time Debugger/Programmer for Motorola 68HC08 Family (USB) SOFTEC - - - - Evaluation/Development Boards and Systems ID Name KITMMDS08GR Size Rev # K Order Availability Vendor ID Format Modular Development System (MMDS) Kits MOTOROLA - - - KITMMEVS08GR Modular Evaluation System (MMEVS) MOTOROLA - - - M68CBL05C Low-noise Flex Cable MOTOROLA - - - M68EML08GP32 Emulation Module MOTOROLA - - - M68ICS08GR M68ICS08GR Development Tool Kit MOTOROLA - - - M68CYCLONE08 MON08 Cyclone METROWERKS - - - M68MULTILINK08 MON08 Multilink METROWERKS - - - OZTEC-08 STARTER KIT OZTEC-08 Starter Kit OZTECH - - - - INDART-HC08/GZ Design Kit for Motorola MC68HC908GZ/GR (USB) SOFTEC - - - - file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (5 of 8) [28-Nov-03 11:23:04 AM] - 68HC908GR8 Product Summary Page Programmers ID MP8011A POWERLAB Name Format Size K Rev # Order Availability Gang Programmer Base Unit Vendor ID SOFTEC - - - - Universal Programmer SYSGEN - - - - Software Application Software Code Examples ID Name HC08DELAYSW HC08EXSW Vendor ID Format HC08 Software Example: Subroutine that delays for a whole number of milliseconds HC08 Software Example: Library containing software examples in assembly for 68HC08 MOTOROLA MOTOROLA Size Rev Order K # Availability zip 2 - - zip 14 - - Device Drivers ID Name HC908SGF50NVMSSD HC908 SGF NVM Standard Software Drivers Program/erase software driver for 0.5um SGF NVM (flash and EEPROM) in HC908 Operating Systems ID CMX-TINY+ Size Rev Order K # Availability Vendor ID Format Name CMX-Tiny+ Vendor ID CMX MOTOROLA 1387 3.0.0 zip - Format Size K Rev # Order Availability - - - - Software Tools Assemblers Size Rev Order K # Availability ID Name Vendor ID Format ADX-08 ADX-08 Macro Assembler-Linker and IDE AVOCET - - - - AX6808 AX6808 relocatable and absolute macro assembler for HC08 and HCS08 COSMIC - - - - Compilers ID CX6808S Name ICC08 ICC08 V6 STD CX6808 C Cross Compiler for HC08 and HCS08 Vendor ID Format Size K Rev # Order Availability COSMIC IMAGE - - - - Debuggers ID Name ZAP 6808 MON08 Debugger and Flash Programmer ZAP 6808 MON08 debugger uses the 68HC08’s on-chip monitor ZAP 6808 MON08 interface to provide a real-time ANSI C and assembly source level debugger including FLASH programming, FLASH security and hardware breakpoint support. ZAP 6808 MMDS ZAP 6808 MMDS Debugger Vendor ID Format MOTOROLA Size Rev Order K # Availability - - - - COSMIC - - - - COSMIC - - - - ZAP 6808 SIM ZAP 6808 Simulator Debugger AX-6811 AX-6811 HITEX - - - - NOICE08 NoICE08 IMAGE - - - - file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (6 of 8) [28-Nov-03 11:23:04 AM] 68HC908GR8 Product Summary Page IDE (Integrated Development Environment) ID Name CDCWSEHC08 CodeWarrior Development Studio™ for HC(S)08 Special Edition CWHC08PRO CWHC08STD CX6808LT4 IDEA08 IC-SW-OPR CodeWarrior Development Studio for Motorola HC08 Microcontrollers Professional Edition CodeWarrior Development Studio for Motorola HC08 Microcontrollers Standard Edition Format METROWERKS - - - METROWERKS - - - METROWERKS - - - COSMIC - - - - COSMIC - - - - ISYS - - - - HC08 Development Tool Suite 4K Lite (FREE) IDEA08 integrated development environment for HC08 and HCS08 winIDEA Performance and Testing ID AX-6811 Name Vendor ID HITEX AX-6811 Size Rev Order K # Availability Vendor ID - Format Size K Rev # Order Availability - - - - Return to Top Rich Media Rich Media Webcast ID Name Vendor ID Format CodeWarrior Development Tools for 68HC08 and HCS12 Microcontrollers. RMWC_CODEWARRIOR MOTOROLA Listen to our webcast for an overview of some of the challenges html that developers face and an explanation of the CodeWarrior tools that help to address these challenges. 8-bit Microcontroller Overview and Q-Family of Flash Microcontrollers Listen to our companion webcasts to learn about Motorola's MOTOROLA RMWC_QFAMILY htm recent 8-bit products and services-especially the HC08 QFamily-that offer maximum design flexibility while helping you get to market fast. Size Rev Order K # Availability 4 0.0 - 5 1.1 - Return to Top Orderable Parts Information Package Info Tape and Reel Life Cycle Description (code) KMC908GR8CDW SOIC 28W No PRODUCT RAPID GROWTH(2) $3.30 more KMC908GR8CFA LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $3.30 more PDIP 28 No PRODUCT RAPID GROWTH(2) $3.30 more LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $5.45 more PartNumber KMC908GR8CP KMC908GR8MFA Budgetary Price Additional Info Order Availability QTY 1000+ ($US) file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (7 of 8) [28-Nov-03 11:23:04 AM] 68HC908GR8 Product Summary Page LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $5.20 more MC68HC908GR8CB PSDIP 42 No PRODUCT RAPID GROWTH(2) $3.30 more MC68HC908GR8CDW SOIC 28W No PRODUCT RAPID GROWTH(2) $3.30 more MC68HC908GR8CFA LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $3.30 more PDIP 28 No PRODUCT RAPID GROWTH(2) $3.30 more MC68HC908GR8MFA LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $4.00 more MC68HC908GR8VFA LQFP 32 7*7*1.4P0.8 No PRODUCT RAPID GROWTH(2) $3.47 more MC908GR8CDWR2 SOIC 28W Yes PRODUCT RAPID GROWTH(2) $3.38 more MC908GR8CFAR2 LQFP 32 7*7*1.4P0.8 Yes PRODUCT RAPID GROWTH(2) - more - MC908GR8MFAR2 LQFP 32 7*7*1.4P0.8 Yes PRODUCT RAPID GROWTH(2) - more - MC908GR8VFAR2 LQFP 32 7*7*1.4P0.8 Yes PRODUCT RAPID GROWTH(2) - more - KMC908GR8VFA MC68HC908GR8CP NOTE: Are you looking for an obsolete orderable part? Click HERE to check our distributors' inventory. Return to Top Related Links Microcontrollers Motor Control Sensors Return to Top http://www.motorola.com/ | Site Map | Contact Motorola | Terms of Use | Privacy Practices © Copyright 1994-2003 Motorola, Inc. All Rights Reserved. file:///F|/imaging/BITTING/CF_PROCESS/CPL/11252003/MOTO/MC68HC908GR81.htm (8 of 8) [28-Nov-03 11:23:04 AM]
MC68HC908GR4CFA 价格&库存
很抱歉,暂时无法提供与“MC68HC908GR4CFA”相匹配的价格&库存,您可以联系我们找货
