HEC4013BT,118
HEC4013BT,118
    NEXPERIA(安世)
    SOIC-14
    IC FF D-TYPE DUAL 1BIT 14SO
HEC4013BT,118 数据手册
HEF4013B Dual D-type flip-flop Rev. 10 — 23 November 2021 Product data sheet 1. General description The HEF4013B is a dual D-type flip-flop with set and reset; positive-edge trigger. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VDD. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 3.0 V to 15.0 V CMOS low power dissipation High noise immunity Tolerant of slow clock rise and fall times Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from -40 °C to +125 °C Complies with JEDEC standard JESD 13-B ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-B exceeds 200 V 3. Applications • • • Counters and dividers Registers Toggle flip-flops 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version HEF4013BT -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 HEF4013BTT -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 HEF4013B Nexperia Dual D-type flip-flop 5. Functional diagram 1SD 1D 6 5 SD D 1 Q 1Q FF1 1CP 1CD 2SD 2D 3 CP 2 Q 1Q CD 4 8 9 SD D Q 13 2Q FF2 2CP 2CD 11 10 CP Q 12 2Q CD 001aag084 Fig. 1. Functional diagram CP C C Q C C C C C C D Q C C SD CD 001aag086 Fig. 2. Logic diagram (one flip-flop) HEF4013B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 2 / 14 HEF4013B Nexperia Dual D-type flip-flop 6. Pinning information 6.1. Pinning 1Q 1 14 VDD 1Q 2 13 2Q 1CP 3 12 2Q 1CD 4 1D 5 1SD 6 9 2D VSS 7 8 2SD HEF4013B 11 2CP 10 2CD 001aag085 Fig. 3. Pin configuration for SOT108-1 (SO14) and SOT402-1 (TSSOP14) 6.2. Pin description Table 2. Pin description Symbol Pin Description 1Q, 2Q 1, 13 true output 1Q, 2Q 2, 12 complement output 1CP, 2CP 3, 11 clock input (LOW to HIGH edge-triggered) 1CD, 2CD 4, 10 asynchronous clear-direct input (active HIGH) 1D, 2D 5, 9 data input 1SD, 2SD 6, 8 asynchronous set-direct input (active HIGH) VSS 7 ground (0 V) VDD 14 supply voltage 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; ↑ = LOW-to-HIGH clock transition. Control Input Output nSD nCD nCP nD nQ nQ H L X X H L L H X X L H H H X X H H L L ↑ L L H L L ↑ H H L HEF4013B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 3 / 14 HEF4013B Nexperia Dual D-type flip-flop 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O Min Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA input/output current - ±10 mA IDD supply current - 50 mA Tstg storage temperature -65 +150 °C Tamb ambient temperature -40 +125 °C Ptot total power dissipation Tamb = -40 °C to +125 °C - 500 mW P power dissipation per output - 100 mW [1] Conditions VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V [1] V For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VDD supply voltage VI input voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate HEF4013B Product data sheet Conditions Min Max Unit 3 15 V 0 VDD V -40 +125 °C VDD = 5 V - 3.75 μs/V VDD = 10 V - 0.5 μs/V VDD = 15 V - 0.08 μs/V All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 4 / 14 HEF4013B Nexperia Dual D-type flip-flop 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA VDD Tamb = -40 °C Tamb = +25 °C Tamb = +85 °C Tamb = +125 °C Unit Min Max Min Max Min Max Min Max 3.5 - 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 5V LOW-level output voltage |IO| < 1 μA 15 V - 0.05 - 0.05 - 0.05 - 0.05 V HIGH-level output current VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 - -1.1 mA VO = 4.6 V 5V - -0.64 - -0.5 - -0.36 - -0.36 mA VO = 9.5 V 10 V - -1.6 - -1.3 - -0.9 - -0.9 mA VO = 13.5 V 15 V - -4.2 - -3.4 - -2.4 - -2.4 mA VO = 0.4 V 5V 0.64 - 0.5 - 0.36 - 0.36 - mA VO = 0.5 V 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA VO = 1.5 V 15 V 4.2 - 3.4 - 2.4 - 2.4 - mA 15 V - ±0.1 - ±0.1 - ±1.0 - ±1.0 μA 5V - 1.0 - 1.0 - 30 - 30 μA 10 V - 2.0 - 2.0 - 60 - 60 μA 15 V - 4.0 - 4.0 - 120 - 120 μA - - - - 7.5 - - - - pF LOW-level output current II input leakage current IDD supply current CI Conditions input capacitance HEF4013B Product data sheet all valid input combinations; |IO| = 0 A All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 5 / 14 HEF4013B Nexperia Dual D-type flip-flop 11. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 °C, unless otherwise specified. For test circuit see Fig. 6. Symbol Parameter Conditions VDD tPHL nCP to nQ, nQ; see Fig. 4 5V HIGH to LOW propagation delay 10 V 15 V tPLH LOW to HIGH propagation delay tsu th tW set-up time hold time pulse width 45 90 ns ns 10 V 29 + 0.23 × CL - 40 80 ns 15 V 22 + 0.16 × CL - 30 60 ns [1] 73 + 0.55 × CL - 100 200 ns 10 V 29 + 0.23 × CL - 40 80 ns 15 V 22 + 0.16 × CL - 30 60 ns [1] 68 + 0.55 × CL - 95 190 ns 10 V 29 + 0.23 × CL - 40 80 ns 15 V 22 + 0.16 × CL - 30 60 ns [1] 48 + 0.55 × CL - 75 150 ns 10 V 24 + 0.23 × CL - 35 70 ns 15 V 17 + 0.16 × CL - 25 50 ns [1] 33 + 0.55 × CL - 60 120 ns 19 + 0.23 × CL - 30 60 ns 12 + 0.16 × CL - 20 40 ns [1] 10 + 1.00 × CL - 60 120 ns 10 V 9 + 0.42 × CL - 30 60 ns 15 V 6 + 0.28 × CL - 20 40 ns 40 20 - ns 10 V 25 10 - ns 15 V 15 5 - ns 20 0 - ns 10 V 20 0 - ns 15 V 15 0 - ns 5V 60 30 - ns 10 V 30 15 - ns 15 V 20 10 - ns 5V 50 25 - ns 10 V 24 12 - ns 15 V 20 10 - ns 5V 50 25 - ns 10 V 24 12 - ns 15 V 20 10 - ns nD to nCP; see Fig. 4 5 V nCP input LOW; see Fig. 4 nCD input HIGH; see Fig. 5 Product data sheet - nD to nCP; see Fig. 4 5 V nSD input HIGH; see Fig. 5 HEF4013B 34 + 0.23 × CL 60 5V see Fig. 4 220 ns 200 ns 15 V transition time 110 30 10 V tt - 100 5V nCD to nQ [1] 83 + 0.55 × CL - 5V nSD to nQ Max Unit - 5V nCP to nQ, nQ; see Fig. 4 Typ 22 + 0.16 × CL 5V nCD to nQ Min [1] 73 + 0.55 × CL 5V nSD to nQ Extrapolation formula All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 6 / 14 HEF4013B Nexperia Dual D-type flip-flop Symbol Parameter Conditions trec nSD input; see Fig. 5 5 V recovery time VDD Extrapolation formula Min Typ +15 -5 - ns 10 V 15 0 - ns 15 V 15 0 - ns 40 25 - ns 10 V 25 10 - ns 15 V 25 10 - ns 5V 7 14 - MHz 10 V 14 28 - MHz 15 V 20 40 - MHz nCD input; see Fig. 5 5 V fclk(max) [1] maximum clock frequency see Fig. 4 Max Unit Typical values of the propagation delays and output transition times can be calculated with the extrapolation formulas (CL in pF). Table 8. Dynamic power dissipation VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol Parameter PD VDD dynamic power dissipation 5 V Typical formula Where 2 PD = 850 × fi + Σ(fo × CL) × VDD μW 2 10 V PD = 3600 × fi + Σ(fo × CL) × VDD μW 2 15 V PD = 9000 × fi + Σ(fo × CL) × VDD μW fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; Σ(fo × CL) = sum of the outputs; VDD = supply voltage in V. 11.1. Waveforms and test circuit tW 1/fclk(max) VI VM input nCP 0V tsu tsu th tf th tr VI VM input nD 0V tPLH tPHL tt VOH output nQ VOL tt VY VM VX 001aah016 Set-up and hold times are shown as positive values but may be specified as negative values. The shaded areas indicate when the input is permitted to change for predictable output performance. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Measurement points are given in Table 9. Fig. 4. Set-up time, hold time, minimum clock pulse width, propagation delays and transition times HEF4013B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 7 / 14 HEF4013B Nexperia Dual D-type flip-flop VI input nCP VM 0V trec VI input nSD trec VM 0V tW VI VM input nCD 0V tW VOH output nQ 001aag088 VOL Recovery times are shown as positive values but may be specified as negative values. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Measurement points are given in Table 9. Fig. 5. nSD, nCD recovery time and pulse width Table 9. Measurement points Supply voltage Input Output VDD VM VM VX VY 5 V to 15 V 0.5VDD 0.5VDD 0.1VDD 0.9VDD VDD G VI VO DUT CL RT 001aag182 Test and measurement data is given in Table 10; Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Fig. 6. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI tr, tf CL 5 V to 15 V VSS or VDD ≤ 20 ns 50 pF HEF4013B Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 8 / 14 HEF4013B Nexperia Dual D-type flip-flop 12. Application information D D Q D FF 1 Q D FF 2 CP Q CP Q FF n Q CP Q clock Fig. 7. 001aag089 N-stage shift register D Q D FF 1 clock Q D FF 2 CP Q CP Q Q FF n Q CP Q T-type flip-flop Fig. 8. Q 001aag090 n Binary ripple up-counter; divide-by-2 D Q FF 1 CP D Q FF 2 Q CP D Q Q FF n Q CP Q clock 001aag091 Fig. 9. Modified ring counter; divide-by-(n + 1) HEF4013B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 9 / 14 HEF4013B Nexperia Dual D-type flip-flop 13. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 10. Package outline SOT108-1 (SO14) HEF4013B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 10 / 14 HEF4013B Nexperia Dual D-type flip-flop TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 11. Package outline SOT402-1 (TSSOP14) HEF4013B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 11 / 14 HEF4013B Nexperia Dual D-type flip-flop 14. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 15. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4013B v.10 20211123 Product data sheet - HEF4013B v.9 Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 and Section 2 updated. Table 4: Derating values for Ptot total power dissipation updated. HEF4013B v.9 20151210 Modifications: • HEF4013B v.8 20111121 Modifications: • • HEF4013B v.7 20110913 Product data sheet - HEF4013B v.6 HEF4013B v.6 20091027 Product data sheet - HEF4013B v.5 HEF4013B v.5 20090619 Product data sheet - HEF4013B v.4 HEF4013B v.4 20080515 Product data sheet - HEF4013B_CNV v.3 HEF4013B_CNV v.3 19950101 Product specification - HEF4013B_CNV v.2 HEF4013B_CNV v.2 19950101 Product specification - - HEF4013B Product data sheet Product data sheet - HEF4013B v.8 Type number HEF4013BP (SOT27-1) removed. Product data sheet - HEF4013B v.7 Legal pages updated. Changes in "General description", "Features and benefits" and "Applications". All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 12 / 14 HEF4013B Nexperia Dual D-type flip-flop 16. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal HEF4013B Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 13 / 14 HEF4013B Nexperia Dual D-type flip-flop Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................3 6.1. Pinning.........................................................................3 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 4 9. Recommended operating conditions..........................4 10. Static characteristics..................................................5 11. Dynamic characteristics.............................................6 11.1. Waveforms and test circuit........................................ 7 12. Application information............................................. 9 13. Package outline........................................................ 10 14. Abbreviations............................................................ 12 15. Revision history........................................................12 16. Legal information......................................................13 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 November 2021 HEF4013B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 23 November 2021 © Nexperia B.V. 2021. All rights reserved 14 / 14
HEC4013BT,118 价格&库存
很抱歉,暂时无法提供与“HEC4013BT,118”相匹配的价格&库存,您可以联系我们找货
HEC4013BT,118
