S-13A1H30-U5T1U3
S-13A1H30-U5T1U3
    ABLIC(艾普凌科)
    SOT89-5
    IC REG LINEAR 3V 1A SOT89-5
S-13A1H30-U5T1U3 数据手册
S-13A1 Series www.ablic.com 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR Rev.2.2_00 © ABLIC Inc., 2011-2018 The S-13A1 Series is a positive voltage regulator with a low dropout voltage, high-accuracy output voltage, and low current consumption developed based on CMOS technology. A 2.2 μF small ceramic capacitor can be used, and the very small dropout voltage and the large output current due to the built-in transistor with low on-resistance are provided. The S-13A1 Series includes a load current protection circuit that prevents the output current from exceeding the current capacity of the output transistor and a thermal shutdown circuit that prevents damage due to overheating. In addition to the types in which output voltage is set inside the IC, a type for which output voltage can be set via an external resistor is added to a lineup. Also, the S-13A1 Series includes an inrush current limit circuit to limit the excess inrush current generated at power-on or at the time when the ON / OFF pin is set to ON. High heat radiation HSOP-8A and HSOP-6 or small SOT-89-5 and HSNT-6A packages realize high-density mounting.  Features • Output voltage (internally set): • Output voltage (externally set): • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Input and output capacitors: • Ripple rejection: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in inrush current limit circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free *1. *2. 1.0 V to 3.5 V, selectable in 0.05 V step 1.05 V to 5.0 V, settable via external resistor (HSOP-8A, HSOP-6 and SOT-89-5 only) 1.5 V to 5.5 V ±1.0% (internally set, 1.0 V to 1.45 V output product: ±15 mV) 70 mV typ. (3.0 V output product, IOUT = 300 mA) During operation: 60 μA typ., 90 μA max. During power-off: 0.1 μA typ., 1.0 μA max. *1 Possible to output 1000 mA (VIN ≥ VOUT(S) + 1.0 V) A ceramic capacitor of 2.2 μF or more can be used. 70 dB typ. (f = 1.0 kHz) Limits overcurrent of output transistor. Prevents damage caused by heat. Limits excessive inrush current generated at power-on or at the time when the ON / OFF pin is set to ON. For types in which output voltage is internally set of HSOP-8A, HSOP-6 and SOT-89-5 inrush current limit time can be changed via an external capacitor (CSS). Inrush current limit time 0.7 ms typ. (types in which output voltage is internally set of HSOP-8A, HSOP-6 SOT-89-5, CSS = 1.0 nF) Inrush current limit time 0.4 ms typ. (types in which output voltage is internally set of HSOP-8A, HSOP-6, SOT-89-5, SSC pin = open) Inrush current limit time 0.4 ms typ. (types in which output voltage is externally set of HSOP-8A, HSOP-6, SOT-89-5, types in which output voltage is internally set of HSNT-6A*2) Ensures long battery life. Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. Ta = −40°C to +85°C Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large. Types in which output voltage is externally set are unavailable.  Applications • Constant-voltage power supply for battery-powered device • Constant-voltage power supply for TV, notebook PC and home electric appliance • Constant-voltage power supply for portable equipment  Packages • HSOP-8A • HSOP-6 • SOT-89-5 • HSNT-6A 1 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Block Diagrams 1. Types in which output voltage is internally set 1. 1 S-13A1 Series A type (S-13A1Axx) *1 VIN VOUT Overcurrent protection circuit Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active "H" Available Available Thermal shutdown circuit ON / OFF ON / OFF circuit + − Inrush current limit circuit Reference voltage circuit *1 *2 SSC VSS *1. *2. Parasitic diode HSOP-8A, HSOP-6, SOT-89-5 only. Figure 1 1. 2 S-13A1 Series B type (S-13A1Bxx) *1 VIN VOUT Overcurrent protection circuit Thermal shutdown circuit ON / OFF ON / OFF circuit Reference voltage circuit + − Inrush current limit circuit *2 SSC VSS *1. *2. Parasitic diode HSOP-8A, HSOP-6, SOT-89-5 only. Figure 2 2 *1 Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active "H" Available Unavailable 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 1. 3 S-13A1 Series C type (S-13A1Cxx) *1 VIN VOUT Overcurrent protection circuit Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active "H" Unavailable Available Thermal shutdown circuit ON / OFF ON / OFF circuit + − Inrush current limit circuit Reference voltage circuit *2 SSC VSS *1. *2. Parasitic diode HSOP-8A, HSOP-6, SOT-89-5 only. Figure 3 1. 4 S-13A1 Series D type (S-13A1Dxx) *1 VIN VOUT Overcurrent protection circuit Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active "H" Unavailable Unavailable Thermal shutdown circuit ON / OFF ON / OFF circuit Reference voltage circuit + − Inrush current limit circuit *2 SSC VSS *1. *2. Parasitic diode HSOP-8A, HSOP-6, SOT-89-5 only. Figure 4 3 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 2. Rev.2.2_00 Types in which output voltage is externally set (HSOP-8A, HSOP-6 and SOT-89-5 only) 2. 1 S-13A1 Series A type (S-13A1A00) *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit Status Active "H" Available Available VADJ Thermal shutdown circuit ON / OFF Function ON / OFF logic Discharge shunt function Pull-down resistor + − Inrush current limit circuit Reference voltage circuit *1 VSS *1. Parasitic diode Figure 5 2. 2 S-13A1 Series B type (S-13A1B00) *1 VIN VOUT Overcurrent protection circuit VADJ Thermal shutdown circuit ON / OFF ON / OFF circuit Reference voltage circuit + − Inrush current limit circuit VSS *1. Parasitic diode Figure 6 4 *1 Function ON / OFF logic Discharge shunt function Pull-down resistor Status Active "H" Available Unavailable 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 2. 3 S-13A1 Series C type (S-13A1C00) *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit Status Active "H" Unavailable Available VADJ Thermal shutdown circuit ON / OFF Function ON / OFF logic Discharge shunt function Pull-down resistor + − Inrush current limit circuit Reference voltage circuit VSS *1. Parasitic diode Figure 7 2. 4 S-13A1 Series D type (S-13A1D00) *1 VIN VOUT Overcurrent protection circuit ON / OFF circuit Reference voltage circuit Status Active "H" Unavailable Unavailable VADJ Thermal shutdown circuit ON / OFF Function ON / OFF logic Discharge shunt function Pull-down resistor + − Inrush current limit circuit VSS *1. Parasitic diode Figure 8 5 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Product Name Structure Users can select the product type, output voltage, and package type for the S-13A1 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product type" regarding the product type, "3. Packages" regarding the package drawings, "4. Product name list" regarding details of the product name. 1. Product name 1. 1 HSOP-8A, HSOP-6, SOT-89-5 S-13A1 x xx - xxxx U 3 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications E8T1: HSOP-8A, Tape E6T1: HSOP-6, Tape U5T1: SOT-89-5, Tape *1 Output voltage*2 00: Externally set 10 to 35: Internally set (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Product type*3 A to D *1. *2. *3. 1. 2 Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to "2. Function list of product type". HSNT-6A S-13A1 x xx - A6T1 U 3 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 A6T1: HSNT-6A, Tape Output voltage*2 10 to 35: Internally set*3 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) *4 Product type A to D *1. *2. *3. *4. 6 Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Types in which output voltage is externally set are unavailable. Refer to "2. Function list of product type". 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 2. Function list of product type Table 1 Discharge Product Type ON / OFF Logic Shunt Function Pull-down Resistor Output Voltage Inrush Current Limit Time Internally set A B C D Active "H" Active "H" Active "H" Active "H" Available Fixed to 0.4 ms typ.*1 Available Available Externally set Fixed to 0.4 ms typ.*1 Internally set Adjustable via an external capacitor (CSS) Fixed to 0.4 ms typ.*1 Unavailable Unavailable Externally set Fixed to 0.4 ms typ.*1 Internally set Adjustable via an external capacitor (CSS) Fixed to 0.4 ms typ.*1 Available Unavailable Externally set Fixed to 0.4 ms typ.*1 Internally set Adjustable via an external capacitor (CSS) Fixed to 0.4 ms typ.*1 Unavailable Externally set *1. Adjustable via an external capacitor (CSS) Fixed to 0.4 ms typ.*1 Package HSOP-8A, HSOP-6, SOT-89-5 HSNT-6A HSOP-8A, HSOP-6, SOT-89-5 HSOP-8A, HSOP-6, SOT-89-5 HSNT-6A HSOP-8A, HSOP-6, SOT-89-5 HSOP-8A, HSOP-6, SOT-89-5 HSNT-6A HSOP-8A, HSOP-6, SOT-89-5 HSOP-8A, HSOP-6, SOT-89-5 HSNT-6A HSOP-8A, HSOP-6, SOT-89-5 Inrush current limit time is fixed to 0.4 ms typ. that can not be changed. 3. Packages Table 2 Package Name HSOP-8A HSOP-6 SOT-89-5 HSNT-6A Dimension FH008-Z-P-SD FH008-Z-P-S1 FH006-A-P-SD UP005-A-P-SD PJ006-A-P-SD Package Drawing Codes Tape FH008-Z-C-SD FH008-Z-C-S1 FH006-A-C-SD UP005-A-C-SD PJ006-A-C-SD Reel Land Stencil Opening FH008-Z-R-SD FH008-Z-L-SD − FH006-A-R-S1 UP005-A-R-SD PJ006-A-R-SD FH006-A-L-SD − PJ006-A-LM-SD − − PJ006-A-LM-SD 7 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 4. Product name list 4. 1 S-13A1 Series A type ON / OFF logic: Discharge shunt function: Output Voltage Externally set 1.0 V ± 15 mV 1.1 V ± 15 mV 1.2 V ± 15 mV 1.25 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% Remark 8 Rev.2.2_00 Active "H" Available HSOP-8A S-13A1A00-E8T1U3 S-13A1A10-E8T1U3 S-13A1A11-E8T1U3 S-13A1A12-E8T1U3 S-13A1A1C-E8T1U3 S-13A1A13-E8T1U3 S-13A1A14-E8T1U3 S-13A1A15-E8T1U3 S-13A1A16-E8T1U3 S-13A1A17-E8T1U3 S-13A1A18-E8T1U3 S-13A1A1J-E8T1U3 S-13A1A19-E8T1U3 S-13A1A20-E8T1U3 S-13A1A21-E8T1U3 S-13A1A22-E8T1U3 S-13A1A23-E8T1U3 S-13A1A24-E8T1U3 S-13A1A25-E8T1U3 S-13A1A26-E8T1U3 S-13A1A27-E8T1U3 S-13A1A28-E8T1U3 S-13A1A2J-E8T1U3 S-13A1A29-E8T1U3 S-13A1A30-E8T1U3 S-13A1A31-E8T1U3 S-13A1A32-E8T1U3 S-13A1A33-E8T1U3 S-13A1A34-E8T1U3 S-13A1A35-E8T1U3 Pull-down resistor: Table 3 HSOP-6 S-13A1A00-E6T1U3 S-13A1A10-E6T1U3 S-13A1A11-E6T1U3 S-13A1A12-E6T1U3 S-13A1A1C-E6T1U3 S-13A1A13-E6T1U3 S-13A1A14-E6T1U3 S-13A1A15-E6T1U3 S-13A1A16-E6T1U3 S-13A1A17-E6T1U3 S-13A1A18-E6T1U3 S-13A1A1J-E6T1U3 S-13A1A19-E6T1U3 S-13A1A20-E6T1U3 S-13A1A21-E6T1U3 S-13A1A22-E6T1U3 S-13A1A23-E6T1U3 S-13A1A24-E6T1U3 S-13A1A25-E6T1U3 S-13A1A26-E6T1U3 S-13A1A27-E6T1U3 S-13A1A28-E6T1U3 S-13A1A2J-E6T1U3 S-13A1A29-E6T1U3 S-13A1A30-E6T1U3 S-13A1A31-E6T1U3 S-13A1A32-E6T1U3 S-13A1A33-E6T1U3 S-13A1A34-E6T1U3 S-13A1A35-E6T1U3 Available SOT-89-5 S-13A1A00-U5T1U3 S-13A1A10-U5T1U3 S-13A1A11-U5T1U3 S-13A1A12-U5T1U3 S-13A1A1C-U5T1U3 S-13A1A13-U5T1U3 S-13A1A14-U5T1U3 S-13A1A15-U5T1U3 S-13A1A16-U5T1U3 S-13A1A17-U5T1U3 S-13A1A18-U5T1U3 S-13A1A1J-U5T1U3 S-13A1A19-U5T1U3 S-13A1A20-U5T1U3 S-13A1A21-U5T1U3 S-13A1A22-U5T1U3 S-13A1A23-U5T1U3 S-13A1A24-U5T1U3 S-13A1A25-U5T1U3 S-13A1A26-U5T1U3 S-13A1A27-U5T1U3 S-13A1A28-U5T1U3 S-13A1A2J-U5T1U3 S-13A1A29-U5T1U3 S-13A1A30-U5T1U3 S-13A1A31-U5T1U3 S-13A1A32-U5T1U3 S-13A1A33-U5T1U3 S-13A1A34-U5T1U3 S-13A1A35-U5T1U3 Please contact our sales office for products with specifications other than the above. HSNT-6A − S-13A1A10-A6T1U3 S-13A1A11-A6T1U3 S-13A1A12-A6T1U3 S-13A1A1C-A6T1U3 S-13A1A13-A6T1U3 S-13A1A14-A6T1U3 S-13A1A15-A6T1U3 S-13A1A16-A6T1U3 S-13A1A17-A6T1U3 S-13A1A18-A6T1U3 S-13A1A1J-A6T1U3 S-13A1A19-A6T1U3 S-13A1A20-A6T1U3 S-13A1A21-A6T1U3 S-13A1A22-A6T1U3 S-13A1A23-A6T1U3 S-13A1A24-A6T1U3 S-13A1A25-A6T1U3 S-13A1A26-A6T1U3 S-13A1A27-A6T1U3 S-13A1A28-A6T1U3 S-13A1A2J-A6T1U3 S-13A1A29-A6T1U3 S-13A1A30-A6T1U3 S-13A1A31-A6T1U3 S-13A1A32-A6T1U3 S-13A1A33-A6T1U3 S-13A1A34-A6T1U3 S-13A1A35-A6T1U3 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 4. 2 S-13A1 Series B type ON / OFF logic: Active "H" Discharge shunt function: Available Output Voltage Externally set 1.0 V ± 15 mV 1.1 V ± 15 mV 1.2 V ± 15 mV 1.25 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% Remark HSOP-8A S-13A1B00-E8T1U3 S-13A1B10-E8T1U3 S-13A1B11-E8T1U3 S-13A1B12-E8T1U3 S-13A1B1C-E8T1U3 S-13A1B13-E8T1U3 S-13A1B14-E8T1U3 S-13A1B15-E8T1U3 S-13A1B16-E8T1U3 S-13A1B17-E8T1U3 S-13A1B18-E8T1U3 S-13A1B1J-E8T1U3 S-13A1B19-E8T1U3 S-13A1B20-E8T1U3 S-13A1B21-E8T1U3 S-13A1B22-E8T1U3 S-13A1B23-E8T1U3 S-13A1B24-E8T1U3 S-13A1B25-E8T1U3 S-13A1B26-E8T1U3 S-13A1B27-E8T1U3 S-13A1B28-E8T1U3 S-13A1B2J-E8T1U3 S-13A1B29-E8T1U3 S-13A1B30-E8T1U3 S-13A1B31-E8T1U3 S-13A1B32-E8T1U3 S-13A1B33-E8T1U3 S-13A1B34-E8T1U3 S-13A1B35-E8T1U3 Pull-down resistor: Table 4 HSOP-6 S-13A1B00-E6T1U3 S-13A1B10-E6T1U3 S-13A1B11-E6T1U3 S-13A1B12-E6T1U3 S-13A1B1C-E6T1U3 S-13A1B13-E6T1U3 S-13A1B14-E6T1U3 S-13A1B15-E6T1U3 S-13A1B16-E6T1U3 S-13A1B17-E6T1U3 S-13A1B18-E6T1U3 S-13A1B1J-E6T1U3 S-13A1B19-E6T1U3 S-13A1B20-E6T1U3 S-13A1B21-E6T1U3 S-13A1B22-E6T1U3 S-13A1B23-E6T1U3 S-13A1B24-E6T1U3 S-13A1B25-E6T1U3 S-13A1B26-E6T1U3 S-13A1B27-E6T1U3 S-13A1B28-E6T1U3 S-13A1B2J-E6T1U3 S-13A1B29-E6T1U3 S-13A1B30-E6T1U3 S-13A1B31-E6T1U3 S-13A1B32-E6T1U3 S-13A1B33-E6T1U3 S-13A1B34-E6T1U3 S-13A1B35-E6T1U3 Unavailable SOT-89-5 S-13A1B00-U5T1U3 S-13A1B10-U5T1U3 S-13A1B11-U5T1U3 S-13A1B12-U5T1U3 S-13A1B1C-U5T1U3 S-13A1B13-U5T1U3 S-13A1B14-U5T1U3 S-13A1B15-U5T1U3 S-13A1B16-U5T1U3 S-13A1B17-U5T1U3 S-13A1B18-U5T1U3 S-13A1B1J-U5T1U3 S-13A1B19-U5T1U3 S-13A1B20-U5T1U3 S-13A1B21-U5T1U3 S-13A1B22-U5T1U3 S-13A1B23-U5T1U3 S-13A1B24-U5T1U3 S-13A1B25-U5T1U3 S-13A1B26-U5T1U3 S-13A1B27-U5T1U3 S-13A1B28-U5T1U3 S-13A1B2J-U5T1U3 S-13A1B29-U5T1U3 S-13A1B30-U5T1U3 S-13A1B31-U5T1U3 S-13A1B32-U5T1U3 S-13A1B33-U5T1U3 S-13A1B34-U5T1U3 S-13A1B35-U5T1U3 HSNT-6A − S-13A1B10-A6T1U3 S-13A1B11-A6T1U3 S-13A1B12-A6T1U3 S-13A1B1C-A6T1U3 S-13A1B13-A6T1U3 S-13A1B14-A6T1U3 S-13A1B15-A6T1U3 S-13A1B16-A6T1U3 S-13A1B17-A6T1U3 S-13A1B18-A6T1U3 S-13A1B1J-A6T1U3 S-13A1B19-A6T1U3 S-13A1B20-A6T1U3 S-13A1B21-A6T1U3 S-13A1B22-A6T1U3 S-13A1B23-A6T1U3 S-13A1B24-A6T1U3 S-13A1B25-A6T1U3 S-13A1B26-A6T1U3 S-13A1B27-A6T1U3 S-13A1B28-A6T1U3 S-13A1B2J-A6T1U3 S-13A1B29-A6T1U3 S-13A1B30-A6T1U3 S-13A1B31-A6T1U3 S-13A1B32-A6T1U3 S-13A1B33-A6T1U3 S-13A1B34-A6T1U3 S-13A1B35-A6T1U3 Please contact our sales office for products with specifications other than the above. 9 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 4. 3 S-13A1 Series C type ON / OFF logic: Active "H" Discharge shunt function: Unavailable Output Voltage Externally set 1.0 V ± 15 mV 1.1 V ± 15 mV 1.2 V ± 15 mV 1.25 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% Remark 10 Rev.2.2_00 HSOP-8A S-13A1C00-E8T1U3 S-13A1C10-E8T1U3 S-13A1C11-E8T1U3 S-13A1C12-E8T1U3 S-13A1C1C-E8T1U3 S-13A1C13-E8T1U3 S-13A1C14-E8T1U3 S-13A1C15-E8T1U3 S-13A1C16-E8T1U3 S-13A1C17-E8T1U3 S-13A1C18-E8T1U3 S-13A1C1J-E8T1U3 S-13A1C19-E8T1U3 S-13A1C20-E8T1U3 S-13A1C21-E8T1U3 S-13A1C22-E8T1U3 S-13A1C23-E8T1U3 S-13A1C24-E8T1U3 S-13A1C25-E8T1U3 S-13A1C26-E8T1U3 S-13A1C27-E8T1U3 S-13A1C28-E8T1U3 S-13A1C2J-E8T1U3 S-13A1C29-E8T1U3 S-13A1C30-E8T1U3 S-13A1C31-E8T1U3 S-13A1C32-E8T1U3 S-13A1C33-E8T1U3 S-13A1C34-E8T1U3 S-13A1C35-E8T1U3 Pull-down resistor: Table 5 HSOP-6 S-13A1C00-E6T1U3 S-13A1C10-E6T1U3 S-13A1C11-E6T1U3 S-13A1C12-E6T1U3 S-13A1C1C-E6T1U3 S-13A1C13-E6T1U3 S-13A1C14-E6T1U3 S-13A1C15-E6T1U3 S-13A1C16-E6T1U3 S-13A1C17-E6T1U3 S-13A1C18-E6T1U3 S-13A1C1J-E6T1U3 S-13A1C19-E6T1U3 S-13A1C20-E6T1U3 S-13A1C21-E6T1U3 S-13A1C22-E6T1U3 S-13A1C23-E6T1U3 S-13A1C24-E6T1U3 S-13A1C25-E6T1U3 S-13A1C26-E6T1U3 S-13A1C27-E6T1U3 S-13A1C28-E6T1U3 S-13A1C2J-E6T1U3 S-13A1C29-E6T1U3 S-13A1C30-E6T1U3 S-13A1C31-E6T1U3 S-13A1C32-E6T1U3 S-13A1C33-E6T1U3 S-13A1C34-E6T1U3 S-13A1C35-E6T1U3 Available SOT-89-5 S-13A1C00-U5T1U3 S-13A1C10-U5T1U3 S-13A1C11-U5T1U3 S-13A1C12-U5T1U3 S-13A1C1C-U5T1U3 S-13A1C13-U5T1U3 S-13A1C14-U5T1U3 S-13A1C15-U5T1U3 S-13A1C16-U5T1U3 S-13A1C17-U5T1U3 S-13A1C18-U5T1U3 S-13A1C1J-U5T1U3 S-13A1C19-U5T1U3 S-13A1C20-U5T1U3 S-13A1C21-U5T1U3 S-13A1C22-U5T1U3 S-13A1C23-U5T1U3 S-13A1C24-U5T1U3 S-13A1C25-U5T1U3 S-13A1C26-U5T1U3 S-13A1C27-U5T1U3 S-13A1C28-U5T1U3 S-13A1C2J-U5T1U3 S-13A1C29-U5T1U3 S-13A1C30-U5T1U3 S-13A1C31-U5T1U3 S-13A1C32-U5T1U3 S-13A1C33-U5T1U3 S-13A1C34-U5T1U3 S-13A1C35-U5T1U3 Please contact our sales office for products with specifications other than the above. HSNT-6A − S-13A1C10-A6T1U3 S-13A1C11-A6T1U3 S-13A1C12-A6T1U3 S-13A1C1C-A6T1U3 S-13A1C13-A6T1U3 S-13A1C14-A6T1U3 S-13A1C15-A6T1U3 S-13A1C16-A6T1U3 S-13A1C17-A6T1U3 S-13A1C18-A6T1U3 S-13A1C1J-A6T1U3 S-13A1C19-A6T1U3 S-13A1C20-A6T1U3 S-13A1C21-A6T1U3 S-13A1C22-A6T1U3 S-13A1C23-A6T1U3 S-13A1C24-A6T1U3 S-13A1C25-A6T1U3 S-13A1C26-A6T1U3 S-13A1C27-A6T1U3 S-13A1C28-A6T1U3 S-13A1C2J-A6T1U3 S-13A1C29-A6T1U3 S-13A1C30-A6T1U3 S-13A1C31-A6T1U3 S-13A1C32-A6T1U3 S-13A1C33-A6T1U3 S-13A1C34-A6T1U3 S-13A1C35-A6T1U3 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 4. 4 S-13A1 Series D type ON / OFF logic: Active "H" Discharge shunt function: Unavailable Output Voltage Externally set 1.0 V ± 15 mV 1.1 V ± 15 mV 1.2 V ± 15 mV 1.25 V ± 15 mV 1.3 V ± 15 mV 1.4 V ± 15 mV 1.5 V ± 1.0% 1.6 V ± 1.0% 1.7 V ± 1.0% 1.8 V ± 1.0% 1.85 V ± 1.0% 1.9 V ± 1.0% 2.0 V ± 1.0% 2.1 V ± 1.0% 2.2 V ± 1.0% 2.3 V ± 1.0% 2.4 V ± 1.0% 2.5 V ± 1.0% 2.6 V ± 1.0% 2.7 V ± 1.0% 2.8 V ± 1.0% 2.85 V ± 1.0% 2.9 V ± 1.0% 3.0 V ± 1.0% 3.1 V ± 1.0% 3.2 V ± 1.0% 3.3 V ± 1.0% 3.4 V ± 1.0% 3.5 V ± 1.0% Remark HSOP-8A S-13A1D00-E8T1U3 S-13A1D10-E8T1U3 S-13A1D11-E8T1U3 S-13A1D12-E8T1U3 S-13A1D1C-E8T1U3 S-13A1D13-E8T1U3 S-13A1D14-E8T1U3 S-13A1D15-E8T1U3 S-13A1D16-E8T1U3 S-13A1D17-E8T1U3 S-13A1D18-E8T1U3 S-13A1D1J-E8T1U3 S-13A1D19-E8T1U3 S-13A1D20-E8T1U3 S-13A1D21-E8T1U3 S-13A1D22-E8T1U3 S-13A1D23-E8T1U3 S-13A1D24-E8T1U3 S-13A1D25-E8T1U3 S-13A1D26-E8T1U3 S-13A1D27-E8T1U3 S-13A1D28-E8T1U3 S-13A1D2J-E8T1U3 S-13A1D29-E8T1U3 S-13A1D30-E8T1U3 S-13A1D31-E8T1U3 S-13A1D32-E8T1U3 S-13A1D33-E8T1U3 S-13A1D34-E8T1U3 S-13A1D35-E8T1U3 Pull-down resistor: Table 6 HSOP-6 S-13A1D00-E6T1U3 S-13A1D10-E6T1U3 S-13A1D11-E6T1U3 S-13A1D12-E6T1U3 S-13A1D1C-E6T1U3 S-13A1D13-E6T1U3 S-13A1D14-E6T1U3 S-13A1D15-E6T1U3 S-13A1D16-E6T1U3 S-13A1D17-E6T1U3 S-13A1D18-E6T1U3 S-13A1D1J-E6T1U3 S-13A1D19-E6T1U3 S-13A1D20-E6T1U3 S-13A1D21-E6T1U3 S-13A1D22-E6T1U3 S-13A1D23-E6T1U3 S-13A1D24-E6T1U3 S-13A1D25-E6T1U3 S-13A1D26-E6T1U3 S-13A1D27-E6T1U3 S-13A1D28-E6T1U3 S-13A1D2J-E6T1U3 S-13A1D29-E6T1U3 S-13A1D30-E6T1U3 S-13A1D31-E6T1U3 S-13A1D32-E6T1U3 S-13A1D33-E6T1U3 S-13A1D34-E6T1U3 S-13A1D35-E6T1U3 Unavailable SOT-89-5 S-13A1D00-U5T1U3 S-13A1D10-U5T1U3 S-13A1D11-U5T1U3 S-13A1D12-U5T1U3 S-13A1D1C-U5T1U3 S-13A1D13-U5T1U3 S-13A1D14-U5T1U3 S-13A1D15-U5T1U3 S-13A1D16-U5T1U3 S-13A1D17-U5T1U3 S-13A1D18-U5T1U3 S-13A1D1J-U5T1U3 S-13A1D19-U5T1U3 S-13A1D20-U5T1U3 S-13A1D21-U5T1U3 S-13A1D22-U5T1U3 S-13A1D23-U5T1U3 S-13A1D24-U5T1U3 S-13A1D25-U5T1U3 S-13A1D26-U5T1U3 S-13A1D27-U5T1U3 S-13A1D28-U5T1U3 S-13A1D2J-U5T1U3 S-13A1D29-U5T1U3 S-13A1D30-U5T1U3 S-13A1D31-U5T1U3 S-13A1D32-U5T1U3 S-13A1D33-U5T1U3 S-13A1D34-U5T1U3 S-13A1D35-U5T1U3 HSNT-6A − S-13A1D10-A6T1U3 S-13A1D11-A6T1U3 S-13A1D12-A6T1U3 S-13A1D1C-A6T1U3 S-13A1D13-A6T1U3 S-13A1D14-A6T1U3 S-13A1D15-A6T1U3 S-13A1D16-A6T1U3 S-13A1D17-A6T1U3 S-13A1D18-A6T1U3 S-13A1D1J-A6T1U3 S-13A1D19-A6T1U3 S-13A1D20-A6T1U3 S-13A1D21-A6T1U3 S-13A1D22-A6T1U3 S-13A1D23-A6T1U3 S-13A1D24-A6T1U3 S-13A1D25-A6T1U3 S-13A1D26-A6T1U3 S-13A1D27-A6T1U3 S-13A1D28-A6T1U3 S-13A1D2J-A6T1U3 S-13A1D29-A6T1U3 S-13A1D30-A6T1U3 S-13A1D31-A6T1U3 S-13A1D32-A6T1U3 S-13A1D33-A6T1U3 S-13A1D34-A6T1U3 S-13A1D35-A6T1U3 Please contact our sales office for products with specifications other than the above. 11 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Pin Configurations 1. HSOP-8A Table 7 Types in Which Output Voltage is Internally Set Pin No. Symbol Description Top view 1 8 2 7 3 6 5 4 Bottom view 8 1 7 2 6 3 5 4 *1 Figure 9 *1. *2. *3. 12 1 VOUT Output voltage pin 2 ON / OFF ON / OFF pin 3 NC*2 No connection 4 VSS 5 SSC*3 GND pin Inrush current limit pin 6 NC*2 No connection 7 NC*2 8 VIN No connection Input voltage pin . Table 8 Types in Which Output Voltage is Externally Set Pin No. Symbol Description Output voltage pin VOUT 1 2 VADJ *2 Output voltage adjustment pin 3 NC No connection 4 5 VSS ON / OFF GND pin ON / OFF pin 6 NC*2 No connection 7 8 *2 NC VIN No connection Input voltage pin Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. Connect a capacitor between the SSC pin and the VSS pin. The inrush current limit time of the VOUT pin at power-on or at the time when the ON / OFF pin is set to ON can be adjusted according to the capacitance. Moreover, the SSC pin is available even when it is open. For details, refer to " Selection of Capacitor for Inrush Current Limit (CSS) (Types in Which Output Voltage is Internally Set of HSOP-8A, HSOP-6, SOT-89-5)". 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 2. HSOP-6 Top view 6 1 5 2 Figure 10 4 Table 9 Symbol Description 1 2 3 4 5 6 VOUT VSS ON / OFF SSC*1 VSS VIN Output voltage pin GND pin ON / OFF pin Inrush current limit pin GND pin Input voltage pin 3 Table 10 Pin No. 1 2 3 4 5 6 *1. Types in Which Output Voltage is Internally Set Pin No. Types in Which Output Voltage is Externally Set Symbol VOUT VSS VADJ ON / OFF VSS VIN Description Output voltage pin GND pin Output voltage adjustment pin ON / OFF pin GND pin Input voltage pin Connect a capacitor between the SSC pin and the VSS pin. The inrush current limit time of the VOUT pin at power-on or at the time when the ON / OFF pin is set to ON can be adjusted according to the capacitance. Moreover, the SSC pin is available even when it is open. For details, refer to " Selection of Capacitor for Inrush Current Limit (CSS) (Types in Which Output Voltage is Internally Set of HSOP-8A, HSOP-6, SOT-89-5)". 13 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 3. Rev.2.2_00 SOT-89-5 Top view 5 1 4 2 3 Table 11 Pin No. 1 2 3 4 5 Types in Which Output Voltage is Internally Set Symbol ON / OFF VSS SSC*1 VIN VOUT Description ON / OFF pin GND pin Inrush current limit pin Input voltage pin Output voltage pin Figure 11 Table 12 Pin No. 1 2 3 4 5 *1. 14 Types in Which Output Voltage is Externally Set Symbol VADJ VSS ON / OFF VIN VOUT Description Output voltage adjustment pin GND pin ON / OFF pin Input voltage pin Output voltage pin Connect a capacitor between the SSC pin and the VSS pin. The inrush current limit time of the VOUT pin at power-on or at the time when the ON / OFF pin is set to ON can be adjusted according to the capacitance. Moreover, the SSC pin is available even when it is open. For details, refer to " Selection of Capacitor for Inrush Current Limit (CSS) (Types in Which Output Voltage is Internally Set of HSOP-8A, HSOP-6, SOT-89-5)". 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 4. HSNT-6A Top view 1 2 3 6 5 4 Bottom view 6 5 4 1 2 3 Table 13 Pin No. 1 2 3 4 5 6 *2 Types in Which Output Voltage is Internally Set Symbol Description *3 Output voltage pin VOUT *3 Output voltage pin VOUT ON / OFF ON / OFF pin VSS GND pin *4 Input voltage pin VIN *4 Input voltage pin VIN *1 Figure 12 *1. *2. *3. *4. Connect the heatsink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. Types in which output voltage is externally set are unavailable. Although pins of number 1 and 2 are connected internally, be sure to short-circuit them nearest in use. Although pins of number 5 and 6 are connected internally, be sure to short-circuit them nearest in use. 15 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Absolute Maximum Ratings Table 14 Item (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit Symbol VSS − 0.3 to VSS + 6.0 V VIN VON / OFF VSS − 0.3 to VSS + 6.0 V Input voltage VSSC VSS − 0.3 to VIN + 0.3 V VVADJ VSS − 0.3 to VSS + 6.0 V Output voltage VOUT VSS − 0.3 to VIN + 0.3 V Output current IOUT 1000 mA Operation ambient temperature Topr −40 to +85 °C Storage temperature Tstg −40 to +125 °C Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 15 Item Condition Board A Board B HSOP-8A Board C Board D Board E Board A Board B HSOP-6 Board C Board D Board E Junction-to-ambient thermal resistance*1 θJA Board A Board B SOT-89-5 Board C Board D Board E Board A Board B HSNT-6A Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 16 Symbol Refer to " Power Dissipation" and "Test Board" for details. Min. − − − − − − − − − − − − − − − − − − − − Typ. 104 74 39 37 31 96 74 − 44 41 119 84 − 46 35 195 157 − − − Max. − − − − − − − − − − − − − − − − − − − − Unit °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W °C/W 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Electrical Characteristics 1. Types in which output voltage is internally set (S-13A1x10 to S-13A1x35) Table 16 (1 / 2) Item Output voltage *1 Output current*2 Symbol VOUT(E) IOUT Condition VIN = VOUT(S) + 1.0 V, IOUT = 100 mA Vdrop IOUT = 1000 mA Line regulation ΔVOUT1 ΔVIN• VOUT ΔVOUT2 ΔVOUT ΔTa • VOUT Load regulation Output voltage temperature *4 coefficient Current consumption during operation ISS1 Current consumption during power-off ISS2 Input voltage VIN ON / OFF pin input voltage "H" VSH ON / OFF pin input voltage "L" VSL ON / OFF pin input current "H" ISH ON / OFF pin input current "L" ISL Ripple rejection Short-circuit current Thermal shutdown detection temperature Thermal shutdown release temperature RR 1.0 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) ≤ 3.5 V VIN ≥ VOUT(S) + 1.0 V IOUT = 300 mA Dropout voltage*3 (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 2.6 V 2.6 V ≤ VOUT(S) ≤ 3.5 V 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 2.0 V 2.0 V ≤ VOUT(S) < 2.6 V 2.6 V ≤ VOUT(S) ≤ 3.5 V VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 100 mA 1 1 3 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 − 0.05 0.2 %/V 1 −20 −3 20 1 − ±100 − − − 1.5 60 0.1 − 90 1.0 5.5 mV ppm/ °C μA μA V 1.0 − − V 4 − − 0.3 V 4 −0.1 1.0 −0.1 − 2.5 − 0.1 5.0 0.1 μA μA μA 4 4 4 1.0 V ≤ VOUT(S) < 1.2 V − 70 − dB 5 1.2 V ≤ VOUT(S) < 3.0 V − 65 − dB 5 3.0 V ≤ VOUT(S) ≤ 3.5 V − 60 − dB 5 VIN = VOUT(S) + 1.0 V, 1 mA ≤ IOUT ≤ 300 mA VIN = VOUT(S) + 1.0 V, IOUT = 100 mA, −40°C ≤ Ta ≤ +85°C VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level B / D type (without pull-down resistor) VIN = 5.5 V, VON / OFF = 5.5 V A / C type (with pull-down resistor) VIN = 5.5 V, VON / OFF = 0 V VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 100 mA VOUT(S) VOUT(S) V V − 0.015 OUT(S) + 0.015 VOUT(S) VOUT(S) VOUT(S) V × 0.99 × 1.01 1000*5 − − mA 0.50 0.54 0.58 V − 0.44 0.48 V − 0.34 0.38 V − 0.24 0.28 V − 0.14 0.18 V − 0.10 0.15 V − 0.07 0.10 V − 0.90 − V − 0.80 − V − 0.70 − V − 0.60 − V − 0.50 − V − 0.40 − V − 0.32 − V − 0.23 − V 1 2 2 − Ishort VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V − 200 − mA 3 TSD Junction temperature − 150 − °C − TSR Junction temperature − 120 − °C − 17 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 Table 16 (2 / 2) Item Inrush current limit time Symbol tRUSH Condition HSOP-8A, HSOP-6, SOT-89-5 HSNT-6A Discharge shunt resistance during power-off RLOW Power-off pull-down resistance RPD VIN = 5.5 V, VOUT = 0.1 V − (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, IOUT = 1000 mA, CSS = 1.0 nF VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, IOUT = 1000 mA, CSS = 0 nF VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, IOUT = 1000 mA A / B type (with discharge shunt function) A / C type (with pull-down resistor) − 0.7 − ms 6 − 0.4 − ms 6 − 0.4 − ms 6 − 35 − Ω 3 1.1 2.2 5.5 MΩ 4 *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 100 mA) and inputting VOUT(S) + 1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 300 mA, 1000 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. The change in temperature [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of the output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to limitation of the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 18 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 2. Types in which output voltage is externally set (S-13A1x00, HSOP-8A, HSOP-6, SOT-89-5 only) Table 17 Item Symbol Output voltage of adjust pin*1 Output voltage range Internal resistance value of adjust pin Output current*2 VVADJ VROUT RVADJ IOUT Dropout voltage*3 Vdrop Line regulation ΔVOUT1 ΔVIN• VOUT Load regulation ΔVOUT2 Output voltage temperature *4 coefficient ΔVOUT ΔTa • VOUT Current consumption during operation ISS1 Current consumption during power-off ISS2 Input voltage VIN ON / OFF pin input voltage "H" VSH ON / OFF pin input voltage "L" VSL ON / OFF pin input current "H" ISH ON / OFF pin input current "L" ISL Condition (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit Short-circuit current Thermal shutdown detection temperature Thermal shutdown release temperature Ishort VVADJ = VOUT, VIN = VOUT(S) + 1.0 V, IOUT = 100 mA − − VIN ≥ VOUT(S) + 1.0 V VVADJ = VOUT, IOUT = 300 mA, VOUT(S) = 1.0 V VVADJ = VOUT, IOUT = 1000 mA, VOUT(S) = 1.0 V VVADJ = VOUT, VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 100 mA VVADJ = VOUT, VIN = VOUT(S) + 1.0 V, 1 mA ≤ IOUT ≤ 300 mA VIN = VOUT(S) + 1.0 V, IOUT = 100 mA, −40°C ≤ Ta ≤ +85°C VVADJ = VOUT, VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load VVADJ = VOUT, VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ determined by VOUT output level B / D type (without pull-down resistor) VIN = 5.5 V, VON / OFF = 5.5 V A / C type (with pull-down resistor) VIN = 5.5 V, VON / OFF = 0 V VVADJ = VOUT, VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 100 mA, VOUT = 1.0 V VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V TSD Junction temperature − 150 − °C − TSR Junction temperature − 120 − °C − Inrush current limit time tRUSH − 0.4 − ms 12 Discharge shunt resistance during power-off RLOW − 35 − Ω 9 Power-off pull-down resistor RPD 1.1 2.2 5.5 MΩ 10 Ripple rejection RR VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, IOUT = 1000 mA VIN = 5.5 V, A / B type VOUT = 0.1 V (with discharge shunt function) A / C type − (with pull-down resistor) 0.985 1.05 − 1000*5 0.50 − 1.0 − 400 − 0.54 0.90 1.015 5.00 − − 0.58 − V V kΩ mA V V 7 13 − 9 7 7 − 0.05 0.2 %/V 7 −20 −3 20 mV 7 − ±100 − ppm/°C 7 − 60 90 μA 8 − 0.1 1.0 μA 8 1.5 − 5.5 V − 1.0 − − V 10 − − 0.3 V 10 −0.1 1.0 −0.1 − 2.5 − 0.1 5.0 0.1 μA μA μA 10 10 10 − 70 − dB 11 − 200 − mA 9 19 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 *1. VOUT(S): Set output voltage ( = 1.0 V) *2. The output current at which the output voltage becomes 95% of VVADJ after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 300 mA, 1000 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. The change in temperature [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of the output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to limitation of the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 20 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Test Circuits 1. Types in which output voltage is internally set (S-13A1x10 to S-13A1x35) + VOUT VIN ON / OFF SSC *1 VSS V A + Set to ON Figure 13 + A VIN Test Circuit 1 VOUT ON / OFF SSC *1 VSS Set to VIN or GND Figure 14 VIN Test Circuit 2 VOUT ON / OFF SSC A *1 V + VSS Set to VIN or GND Figure 15 VIN + A Test Circuit 3 VOUT ON / OFF SSC *1 VSS Figure 16 *1. V + RL Test Circuit 4 HSOP-8A, HSOP-6, SOT-89-5 only. 21 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series VIN Rev.2.2_00 VOUT *1 ON / OFF SSC V + VSS RL Set to ON Figure 17 VIN Test Circuit 5 VOUT ON / OFF SSC *1 VSS Set to ON Figure 18 *1. 22 + Test Circuit 6 HSOP-8A, HSOP-6, SOT-89-5 only. V + Oscilloscope A 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 2. Types in which output voltage is externally set (S-13A1x00, HSOP-8A, HSOP-6, SOT-89-5 only) + VOUT VIN ON / OFF VADJ VSS V A + Set to ON Figure 19 + A Test Circuit 7 VOUT VIN ON / OFF VADJ VSS Set to VIN or GND Figure 20 Test Circuit 8 VOUT VIN ON / OFF VADJ A V + VSS Set to VIN or GND Figure 21 Test Circuit 9 VOUT VIN + A ON / OFF VADJ VSS Figure 22 V + RL Test Circuit 10 23 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 VOUT VIN ON / OFF VADJ V + VSS RL Set to ON Figure 23 Test Circuit 11 Oscilloscope + VOUT VIN ON / OFF VADJ VSS V A + Set to ON Figure 24 Test Circuit 12 VIN VOUT ON / OFF VADJ VSS Set to ON Figure 25 24 Test Circuit 13 + V + A 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Standard Circuits 1. Types in which output voltage is internally set (S-13A1x10 to S-13A1x35) Input Output VOUT VIN CIN*1 *4 ON / OFF SSC VSS CL CSS *3 Single GND *1. *2. *3. *4. *2 GND CIN is a capacitor for stabilizing the input. A ceramic capacitor of 2.2 μF or more can be used as CL. A ceramic capacitor of 22 nF or less can be used as CSS. HSOP-8A, HSOP-6, SOT-89-5 only. Figure 26 2. Types in which output voltage is externally set (S-13A1x00, HSOP-8A, HSOP-6, SOT-89-5 only) Input Output VOUT VIN CIN *1 Ra ON / OFF VADJ VSS Single GND *1. *2. *3. *3 CL Rb *2 *3 GND CIN is a capacitor for stabilizing the input. A ceramic capacitor of 2.2 μF or more can be used as CL. Resistor of 0.1 kΩ to 606 kΩ as Ra, 2 kΩ to 200 kΩ as Rb can be used. Figure 27 Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 25 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Condition of Application Input capacitor (CIN): Output capacitor (CL): Caution 1. 2. 2.2 μF or more 2.2 μF or more Set input capacitor (CIN) and output capacitor (CL) as CIN = CL. Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL) The S-13A1 Series requires an output capacitor between the VOUT pin and the VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 2.2 μF or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 2.2 μF or more. The values of output overshoot and undershoot, which are transient response characteristics, vary depending on the value of the output capacitor. The required capacitance for the input capacitor differs depending on the application. Set the capacitance for input capacitor (CIN) and output capacitor (CL) as follows. • CIN ≥ 2.2 μF • CL ≥ 2.2 μF • CIN = CL Caution The S-13A1 Series may oscillate if setting the capacitance as CIN ≥ 2.2 μF, CL ≥ 2.2 μF, CIN < CL. Define the values by sufficient evaluation including the temperature characteristics under the usage condition.  Selection of Capacitor for Inrush Current Limit (CSS) (Types in Which Output Voltage is Internally Set of HSOP-8A, HSOP-6, SOT-89-5) In the S-13A1 Series, the inrush current limit time (tRUSH) is adjustable by connecting a capacitor for inrush current limit (CSS) between the SSC pin and the VSS pin. The time that the output voltage rises to 99% is 0.7 ms typ. when CSS = 1.0 nF. The S-13A1 Series operates stably even with no CSS connection (in the state the SSC pin is leaved open). *1 The recommended value for CSS is 0 nF ≤ CSS ≤ 22 nF, however, define the values by sufficient evaluation including the temperature characteristics under the usage condition. *1. 26 In case the S-13A1 Series is used without CSS connection (CSS = 0 nF), be sure to leave the SSC pin open and do not connect it to the VIN pin and the VSS pin. 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input voltage*2, fixed output current, and fixed temperature. *1. *2. When VOUT < 1.5 V: ±15 mV, when VOUT ≥ 1.5 V: ±1.0% Differs depending on the product. Caution 3. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to " Electrical Characteristics" and " Characteristics (Typical Data)" for details. ΔVOUT1  Line regulation  ΔVIN•VOUT  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 27 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 6. Rev.2.2_00 ΔVOUT  Output voltage temperature coefficient  ΔTa•VOUT  The shaded area in Figure 28 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±100 ppm/°C. Example of S-13A1B30 typ. product VOUT [V] +0.30 mV/°C *1 VOUT(E) −0.30 mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 28 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 28 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Operation 1. Basic operation Figure 29 shows the block diagram of the S-13A1 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 29 2. Output transistor In the S-13A1 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 29 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 3. Rev.2.2_00 ON / OFF pin This pin starts and stops the regulator. When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Note that the current consumption increases when a voltage of 0.3 V to VIN − 0.3 V is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figure 30 and Figure 31. 3. 1 S-13A1 Series A / C type The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. 3. 2 S-13A1 Series B / D type The ON / OFF pin is not internally pulled down to the VSS pin, so do not use these types with the ON / OFF pin in the floating status. When not using the ON / OFF pin, connect the pin to the VIN pin. Table 18 Product Type ON / OFF Pin Internal Circuit VOUT Pin Voltage Current Consumption *1 A/B/C/D "H": ON Operate Set value ISS1 A/B/C/D "L": OFF Stop VSS level ISS2 *1. Note that the IC's current consumption increases as much as current flows into the pull-down resistor of 2.5 MΩ typ. when the ON / OFF pin is connected to the VIN pin and the S-13A1 Series A / C type is operating (refer to Figure 30). VIN VIN ON / OFF ON / OFF VSS Figure 30 30 S-13A1 Series A / C type VSS Figure 31 S-13A1 Series B / D type 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 4. Discharge shunt function (S-13A1 Series A / B type) The S-13A1 Series A / B type has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. Since the S-13A1 Series C / D type does not have a discharge shunt circuit, the VOUT pin is set to the VSS level through several hundred kΩ internal divided resistors between the VOUT pin and the VSS pin. The S-13A1 Series A / B type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt circuit. S-13A1 Series Output transistor: OFF *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF pin: OFF Current flow GND VSS *1. Parasitic diode Figure 32 5. Pull-down resistor (S-13A1 Series A / C type) The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC's current consumption increases as much as current flows into the pull-down resistor of 2.5 MΩ typ. when the ON / OFF pin is connected to the VIN pin and the S-13A1 Series A / C type is operating. 31 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 6. Rev.2.2_00 Overcurrent protection circuit The S-13A1 Series includes an overcurrent protection circuit having the characteristics shown in "1. Output Voltage vs. Output Current (When load current increases) (Ta = +25°C)" in " Characteristics (Typical Data)", in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and the VSS pin. The current when the output pin is short-circuited (Ishort) is internally set at approx. 200 mA typ., and the normal value is restored for the output voltage, if releasing a short circuit once. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. 7. Thermal shutdown circuit The S-13A1 Series has a thermal shutdown circuit to protect the device from damage due to overheat. When the junction temperature rises to 150°C typ., the thermal shutdown circuit operates to stop regulating. When the junction temperature drops to 120°C typ., the thermal shutdown circuit is released to restart regulating. Due to self-heating of the S-13A1 Series, if the thermal shutdown circuit starts operating, it stops regulating so that the output voltage drops. When regulation stops, the S-13A1 does not itself generate heat so that the IC’s temperature drops. When the temperature drops, the thermal shutdown circuit is released to restart regulating, thus the S-13A1 Series generates heat again. Repeating this procedure makes waveform of the output voltage pulse-like form. Stop or restart of regulation continues unless decreasing either or both of the input voltage and the output voltage in order to reduce the internal power consumption, or decreasing the ambient temperature. Table 19 Thermal Shutdown Circuit Operation: 150°C typ. Release: 120°C typ. *1. 32 *1 *1 Junction temperature VOUT Pin Voltage VSS level Set value 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 8. Inrush current limit circuit The S-13A1 Series has a built-in inrush current limit circuit to limit the inrush current and the overshoot of the output voltage generated at power-on or at the time when the ON / OFF pin is set to ON. The inrush current is limited to 500 mA typ. The inrush current limit circuit starts to operate from the following times. • Immediately after power-on • At the time when the ON / OFF pin is set to ON tRUSH [ms] Figure 33 shows the relation between the inrush current limit time (tRUSH) and the inrush current limit capacitor (CSS). 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 Ta = +25°C Max. Typ. Min. 0 0.5 1 CSS [nF] 1.5 2 Figure 33 (1) CSS = 0 nF tRUSH is determined by the internal capacitor (about 20 pF) and the time constant of the built-in constant current (about 0.04 μA). tRUSH value is 0.28 ms min., 0.40 ms typ., 0.52 ms max. (2) CSS ≥ 1 nF tRUSH can be adjusted by the CSS which is connected externally between the SSC pin*1 and the VSS pin. It is calculated by the following formula depending on the built-in constant (about 1 μA) and the CSS time constant. The inrush current limit coefficient is 0.49 min., 0.7 typ., 0.91 max. at Ta = +25°C. tRUSH [ms] = the inrush current limit coefficient × CSS [nF] (3) 0 nF < CSS < 1 nF Since the internal capacitor, the built-in constant current and CSS have a variation each, tRUSH is the one of following (a) and (b) in which the time is longer. (a) The time determined by the internal capacitor (about 20 pF) and the time constant of the built-in constant current (about 0.04 μA). (b) The time determined by CSS connected externally between the SSC pin*1 and the VSS pin and the built-in constant current (about 1 μA). When 0 nF < CSS< 1 nF, tRUSH is the range of the shaded area shown in Figure 33. *1. Types in which output voltage is internally set of HSOP-8A, HSOP-6, SOT-89-5 only. 33 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 9. Rev.2.2_00 Externally setting output voltage (HSOP-8A, HSOP-6, SOT-89-5 only) The S-13A1 Series provides the types in which output voltage can be set via the external resistor. The output voltage can be set by connecting a resistor (Ra) between the VOUT pin and the VADJ pin, and a resistor (Rb) between the VADJ pin and the VSS pin. The output voltage is determined by the following formulas. VOUT = 1.0 + Ra × la ······················ (1) By substituting Ia = IVADJ + 1.0 / Rb to above formula (1), VOUT = 1.0 + Ra × (IVADJ + 1.0 / Rb) = 1.0 × (1.0 + Ra / Rb) + Ra × IVADJ ········· (2) In above formula (2), Ra × IVADJ is a factor for the output voltage error. Whether the output voltage error is minute is judged depending on the following (3) formula. By substituting IVADJ = 1.0 / RVADJ to Ra × IVADJ VOUT = 1.0 × (1.0 + Ra / Rb) + 1.0 × Ra / RVADJ ···················(3) If RVADJ is sufficiently larger than Ra, the error is judged as minute. VOUT Ia VIN IVADJ VADJ RVADJ Ra VOUT 1.0 V Ib Rb VSS Figure 34 The following expression is in order to determine output voltage VOUT = 3.0 V. If resistance Rb = 2 kΩ, substitute RVADJ = 400 kΩ typ. into (3), Resistance Ra = (3.0 / 1.0 − 1) × ((2 k × 400 k) / (2 k + 400 k)) ≅ 4.0 kΩ Caution The above connection diagrams and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants. 34 Rev.2.2_00 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL), a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), and a capacitor for limiting the inrush current between the SSC pin and the VSS pin (CSS), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. • Note that the output voltage may increase due to the leakage current from an output driver even if the ON / OFF pin is at OFF level when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-13A1 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to "6. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C)" in " Reference Data" for the equivalent series resistance (RESR) of the output capacitor. Input capacitor (CIN): Output capacitor (CL): 2.2 μF or more 2.2 μF or more • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • If the output capacitance is small, power supply's fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage's fluctuation with the actual device. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 16 and Table 17 in " Electrical Characteristics" and footnote *5 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 35 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Characteristics (Typical Data) Output voltage vs. Output current (When load current increases) (Ta = +25°C) VOUT [V] 1. 1 VOUT [V] 1. 3 2. VOUT = 1.0 V 1.6 1.4 2.0 V 1.2 3.0 V 1.0 0.8 VIN = 1.5 V 0.6 0.4 0.2 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 IOUT [A] VOUT = 3.5 V 4.0 3.5 3.0 VIN = 4.0 V 2.5 4.5 V 2.0 5.5 V 1.5 1.0 0.5 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 IOUT [A] 1. 2 VIN = 3.0 V 3.5 V 4.5 V 1.5 1.0 0.5 0 0 Remark VOUT = 1.0 V 1.2 2. 2 1.0 VOUT [V] VOUT [V] 1.1 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 0.9 0.8 0.7 0.6 0.6 2. 3 VOUT [V] 2.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 IOUT [A] In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 of Table 16 and Table 17 in " Electrical Characteristics" 2. The power dissipation Output voltage vs. Input voltage (Ta = +25°C) 2. 1 36 VOUT = 2.5 V 3.0 2.5 VOUT [V] 1. 1.0 VOUT = 3.5 V 3.7 3.6 3.5 3.4 3.3 3.2 3.1 3.0 3.0 3.5 1.4 1.8 VIN [V] 2.2 2.6 5.0 5.5 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 4.0 4.5 VIN [V] VOUT = 2.5 V 2.7 2.6 2.5 2.4 2.3 2.2 2.1 2.0 2.0 2.5 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 3.0 3.5 VIN [V] 4.0 4.5 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 Dropout voltage vs. Output current Vdrop [V] 3. 1 VOUT = 1.0 V 0.7 0.6 Ta = +85°C 0.5 Ta = +25°C 0.4 Ta = −40°C 0.3 0.2 0.1 0 0 200 400 600 800 IOUT [mA] 3. 2 VOUT = 2.5 V 0.35 0.30 Ta = +85°C 0.25 Ta = +25°C 0.20 Ta = −40°C 0.15 0.10 0.05 0 0 200 400 600 800 IOUT [mA] Vdrop [V] 3. 1000 1200 1000 1200 3. 3 VOUT = 3.5 V 0.30 Vdrop [V] 0.25 Ta = +85°C Ta = +25°C Ta = −40°C 0.20 0.15 0.10 0.05 0 0 4. 200 600 800 IOUT [mA] 1000 1200 Dropout voltage vs. Set output voltage 0.6 IOUT = 1000 mA IOUT = 500 mA IOUT = 300 mA IOUT = 10 mA 0.5 Vdrop [V] 400 0.4 0.3 0.2 0.1 0 1.0 1.5 2.0 2.5 VOUT(S) [V] 3.0 3.5 37 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 5. Rev.2.2_00 Output voltage vs. Ambient temperature 5. 1 VOUT = 1.0 V 1.10 5. 2 2.6 VOUT [V] VOUT [V] 1.05 1.00 0.95 0.90 5. 3 VOUT = 2.5 V 2.7 2.5 2.4 −40 −25 2.3 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 −40 −25 0 25 Ta [°C] 75 85 50 VOUT = 3.5 V 3.8 3.7 VOUT [V] 3.6 3.5 3.4 3.3 3.2 Current consumption vs. Input voltage ISS1 [μA] 6. 1 ISS1 [μA] 6. 3 38 VOUT = 1.0 V 80 70 60 50 40 30 20 10 0 0 1 VOUT = 3.5 V 80 70 60 50 40 30 20 10 0 0 1 6. 2 Ta = +85°C ISS1 [μA] 6. −40 −25 +25°C −40°C 2 3 VIN [V] 4 5 6 4 5 6 Ta = +85°C +25°C −40°C 2 3 VIN [V] VOUT = 2.5 V 80 70 60 50 40 30 20 10 0 0 1 Ta = +85°C +25°C −40°C 2 3 VIN [V] 4 5 6 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 7. Ripple rejection (Ta = +25°C) 7. 1 VOUT = 1.0 V 7. 2 VOUT = 2.5 V IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 10 7. 3 100 1k 10k 100k Frequency [Hz] VIN = 3.5 V, CL = 2.2 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.0 V, CL = 2.2 μF 100 90 80 70 60 50 40 30 20 10 0 1M 100 90 80 70 60 50 40 30 20 10 0 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 10 100 1k 10k 100k Frequency [Hz] 1M VOUT = 3.5 V Ripple Rejection [dB] VIN = 4.5 V, CL = 2.2 μF 100 90 80 70 60 50 40 30 20 10 0 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 10 100 1k 10k 100k Frequency [Hz] 1M 39 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Reference Data Transient response characteristics when input (Ta = +25°C) 1. 1 VOUT = 1.0 V 1. 2 IOUT = 100 mA, CIN = CL = 2.2 μF, VIN = 3.5 V ↔ 4.5 V, tr = tf = 5.0 μs 6.00 5.25 4.50 3.75 3.00 2.25 1.50 0.75 0 VOUT = 3.5 V VOUT [V] IOUT = 100 mA, CIN = CL = 2.2 μF, VIN = 4.5 V ↔ 5.5 V, tr = tf = 5.0 μs 3.80 3.75 3.70 3.65 3.60 3.55 3.50 3.45 VIN VOUT −200 40 0 200 400 600 800 1000 1200 t [μs] VOUT [V] VIN [V] 1. 3 200 400 600 800 1000 1200 t [μs] 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 −0.5 VIN [V] VOUT [V] IOUT = 100 mA, CIN = CL = 2.2 μF, VIN = 2.0 V ↔ 3.0 V, tr = tf = 5.0 μs 1.30 1.25 1.20 VIN 1.15 1.10 VOUT 1.05 1.00 0.95 0.90 −200 0 VOUT = 2.5 V 2.80 2.75 VIN 2.70 2.65 2.60 VOUT 2.55 2.50 2.45 2.40 −200 0 5.25 4.50 3.75 3.00 2.25 1.50 0.75 0 −0.75 VIN [V] 1. 200 400 600 800 1000 1200 t [μs] 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 Transient response characteristics of load (Ta = +25°C) VOUT = 1.0 V VIN = 2.0 V, CIN = CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA 2. 2 50 1.2 −50 0.95 0 400 0 VOUT 0.90 −200 1.3 200 400 600 800 1000 1200 t [μs] 2.48 −150 0.8 −200 0 200 400 600 800 1000 1200 t [μs] 600 100 2.8 400 50 2.7 0 2.5 −200 VOUT −100 2.4 −150 2.3 −200 0 −400 200 400 600 800 1000 1200 t [μs] −600 IOUT 150 3.9 600 100 3.8 400 50 3.7 0 −50 VOUT 3.47 3.45 −200 0 200 400 600 800 1000 1200 t [μs] VIN = 4.5 V, CIN = CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA IOUT [mA] VOUT [V] 200 IOUT 2.6 VOUT = 3.5 V 3.51 3.49 −600 2.9 −50 VOUT 3.57 3.53 200 400 600 800 1000 1200 t [μs] VIN = 3.5 V, CIN = CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA VIN = 4.5 V, CIN = CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA 3.55 0 −400 150 0 2.46 −200 2. 3 −200 VOUT 0.9 IOUT [mA] VOUT [V] IOUT 2.52 2.50 1.0 VOUT = 2.5 V 2.58 2.54 0 −100 VIN = 3.5 V, CIN = CL = 2.2 μF, IOUT = 50 mA ↔ 100 mA 2.56 200 IOUT 1.1 IOUT [mA] 1.00 100 IOUT [mA] 1.05 600 200 IOUT 0 3.6 3.5 −200 VOUT −100 3.4 −150 3.3 −200 0 IOUT [mA] 1.10 IOUT 1.4 VOUT [V] VOUT [V] 1.15 150 IOUT [mA] 1.20 VIN = 2.0 V, CIN = CL = 2.2 μF, IOUT = 100 mA ↔ 500 mA VOUT [V] 2. 1 VOUT [V] 2. −400 200 400 600 800 1000 1200 t [μs] −600 41 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Transient response characteristics of ON / OFF pin (Ta = +25°C) 3. 1 VOUT = 1.0 V 3. 2 VIN = 2.0 V, CIN = CL = 2.2 μF, IOUT = 100 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs VOUT [V] 3 2 8 0 VOUT 1 −500 0 500 1000 t [μs] 1500 2000 −3 −2 0 VOUT 2 −2 −4 0 −2 42 −500 0 500 1000 t [μs] 1500 2000 −6 VON / OFF [V] VOUT [V] 2 4 0 VOUT −4 4 VON / OFF 4 0 6 6 2 −2 VIN = 4.5 V, CIN = CL = 2.2 μF, IOUT = 100 mA, VON / OFF = 0 V → 4.5 V, tr = 1.0 μs 8 4 6 −2 VOUT = 3.5 V 10 6 VON / OFF 2 −1 0 3. 3 10 1 2 −1 3 VOUT [V] VON / OFF 4 VIN = 3.5 V, CIN = CL = 2.2 μF, IOUT = 100 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs VON / OFF [V] 5 VOUT = 2.5 V −500 0 500 1000 t [μs] 1500 2000 −6 VON / OFF [V] 3. Rev.2.2_00 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 Characteristics of inrush current (Ta = +25°C) VOUT = 1.0 V 4. 2 VOUT IOUT −50 0 50 100 t [μs] 150 200 VOUT IOUT −50 0 50 100 t [μs] 150 200 −500 0 IOUT 500 1000 t [μs] 1500 2000 VON / OFF VOUT IOUT −500 0 500 1000 t [μs] 1500 2000 2.8 2.4 2.0 1.6 1.2 0.8 0.4 0 −0.4 VOUT = 3.5 V VON / OFF VOUT IOUT −50 0 50 100 t [μs] 150 200 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 −0.2 VON / OFF / VOUT [V] VIN = 4.5 V, CIN = CL = 2.2 μF, CSS = 0 nF, IOUT = 1000 mA, VON / OFF = 0 V → 4.5 V, tr = 1.0 μs IOUT [A] VON / OFF / VOUT [V] 8 6 4 2 0 −2 −4 −6 −8 VON / OFF / VOUT [V] VON / OFF 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 −0.2 VIN = 4.5 V, CIN = CL = 2.2 μF, CSS = 0 nF, IOUT = 100 mA, VON / OFF = 0 V → 4.5 V, tr = 1.0 μs 8 6 4 2 0 −2 −4 −6 −8 VOUT VIN = 3.5 V, CIN = CL = 2.2 μF, CSS = 0 nF, IOUT = 1000 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs IOUT [A] VON / OFF / VOUT [V] 4. 3 VON / OFF 2.8 2.4 2.0 1.6 1.2 0.8 0.4 0 −0.4 VOUT = 2.5 V VIN = 3.5 V, CIN = CL = 2.2 μF, CSS = 0 nF, IOUT = 100 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs 8 6 4 2 0 −2 −4 −6 −8 8 6 4 2 0 −2 −4 −6 −8 IOUT [A] VON / OFF 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0 −0.2 VON / OFF / VOUT [V] 8 6 4 2 0 −2 −4 −6 −8 VIN = 2.0 V, CIN = CL = 2.2 μF, CSS = 0 nF, IOUT = 1000 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs IOUT [A] VON / OFF / VOUT [V] VIN = 2.0 V, CIN = CL = 2.2 μF, CSS = 0 nF, IOUT = 100 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs IOUT [A] 4. 1 8 6 4 2 0 −2 −4 −6 −8 VON / OFF VOUT IOUT −500 0 500 1000 t [μs] 1500 2000 2.8 2.4 2.0 1.6 1.2 0.8 0.4 0 −0.4 43 IOUT [A] 4. 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 Output capacitance vs. Characteristics of discharge time (Ta = +25°C) 5. VIN = VOUT + 1.0 V, IOUT = no load VON / OFF = VOUT + 1.0 V → VSS, tf = 1 μs 1 μs VON / OFF 2.5 tDSC [ms] 2.0 VOUT(S) = 1.0 V 2.5 V 3.5 V 1.5 1.0 VSS tDSC VOUT 0.5 0 0 2 4 6 CL [μF] 8 10 12 VOUT × 10% VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 35 S-13A1 Series A / B type (with discharge shunt function) 6. Figure 36 Measurement Condition of Discharge Time Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) CIN = CL = 2.2 μF VIN 100 VOUT RESR [Ω] CIN Stable ON / OFF 0 0.1 1000 IOUT [mA] Figure 37 44 *1. *2. S-13A1 Series SSC VSS CSS CL *1 *2 RESR CL: TDK Corporation C3225X8R1E225K (2.2 μF) CSS: Murata Manufacturing Co., Ltd. GRM1882C1H102JA01 (1.0 nF) Figure 38 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Marking Specifications 1. HSOP-8A Top view 8 7 6 5 (1) to (5): (6): (7) and (8): (9) to (16): Product name: S13A1 (Fixed) Product type Value of output voltage Lot number (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) 1 2 3 4 45 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 2. HSOP-6 Top view 6 5 4 (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) 1 46 2 3 (1) to (5): (6): (7) and (8): (9) to (16): Product name: S13A1 (Fixed) Product type Value of output voltage Lot number Rev.2.2_00 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 3. SOT-89-5 Top view 1 (1) to (3): (4) to (6): Product code (Refer to Product name vs. Product code) Lot number (4) (5) (6) 4 (1) (2) (3) 5 2 3 Product name vs. Product code 3. 1 S-13A1 Series A type Product Name S-13A1A00-U5T1U3 S-13A1A10-U5T1U3 S-13A1A11-U5T1U3 S-13A1A12-U5T1U3 S-13A1A1C-U5T1U3 S-13A1A13-U5T1U3 S-13A1A14-U5T1U3 S-13A1A15-U5T1U3 S-13A1A16-U5T1U3 S-13A1A17-U5T1U3 S-13A1A18-U5T1U3 S-13A1A1J-U5T1U3 S-13A1A19-U5T1U3 S-13A1A20-U5T1U3 S-13A1A21-U5T1U3 S-13A1A22-U5T1U3 S-13A1A23-U5T1U3 S-13A1A24-U5T1U3 S-13A1A25-U5T1U3 S-13A1A26-U5T1U3 S-13A1A27-U5T1U3 S-13A1A28-U5T1U3 S-13A1A2J-U5T1U3 S-13A1A29-U5T1U3 S-13A1A30-U5T1U3 S-13A1A31-U5T1U3 S-13A1A32-U5T1U3 S-13A1A33-U5T1U3 S-13A1A34-U5T1U3 S-13A1A35-U5T1U3 3. 2 Product Code (1) (2) (3) W R A W R B W R C W R D W R 5 W R E W R F W R G W R H W R I W R J W R K W R L W R M W R N W R O W R P W R Q W R R W R S W R T W R U W R V W R W W R X W R Y W R Z W R 2 W R 3 W R 4 S-13A1 Series B type Product Name S-13A1B00-U5T1U3 S-13A1B10-U5T1U3 S-13A1B11-U5T1U3 S-13A1B12-U5T1U3 S-13A1B1C-U5T1U3 S-13A1B13-U5T1U3 S-13A1B14-U5T1U3 S-13A1B15-U5T1U3 S-13A1B16-U5T1U3 S-13A1B17-U5T1U3 S-13A1B18-U5T1U3 S-13A1B1J-U5T1U3 S-13A1B19-U5T1U3 S-13A1B20-U5T1U3 S-13A1B21-U5T1U3 S-13A1B22-U5T1U3 S-13A1B23-U5T1U3 S-13A1B24-U5T1U3 S-13A1B25-U5T1U3 S-13A1B26-U5T1U3 S-13A1B27-U5T1U3 S-13A1B28-U5T1U3 S-13A1B2J-U5T1U3 S-13A1B29-U5T1U3 S-13A1B30-U5T1U3 S-13A1B31-U5T1U3 S-13A1B32-U5T1U3 S-13A1B33-U5T1U3 S-13A1B34-U5T1U3 S-13A1B35-U5T1U3 (1) W W W W W W W W W W W W W W W W W W W W W W W W W W W W W W Product Code (2) (3) S A S B S C S D S 5 S E S F S G S H S I S J S K S L S M S N S O S P S Q S R S S S T S U S V S W S X S Y S Z S 2 S 3 S 4 47 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 3. 3 S-13A1 Series C type Product Name S-13A1C00-U5T1U3 S-13A1C10-U5T1U3 S-13A1C11-U5T1U3 S-13A1C12-U5T1U3 S-13A1C1C-U5T1U3 S-13A1C13-U5T1U3 S-13A1C14-U5T1U3 S-13A1C15-U5T1U3 S-13A1C16-U5T1U3 S-13A1C17-U5T1U3 S-13A1C18-U5T1U3 S-13A1C1J-U5T1U3 S-13A1C19-U5T1U3 S-13A1C20-U5T1U3 S-13A1C21-U5T1U3 S-13A1C22-U5T1U3 S-13A1C23-U5T1U3 S-13A1C24-U5T1U3 S-13A1C25-U5T1U3 S-13A1C26-U5T1U3 S-13A1C27-U5T1U3 S-13A1C28-U5T1U3 S-13A1C2J-U5T1U3 S-13A1C29-U5T1U3 S-13A1C30-U5T1U3 S-13A1C31-U5T1U3 S-13A1C32-U5T1U3 S-13A1C33-U5T1U3 S-13A1C34-U5T1U3 S-13A1C35-U5T1U3 48 Rev.2.2_00 3. 4 Product Code (1) (2) (3) W T A W T B W T C W T D W T 5 W T E W T F W T G W T H W T I W T J W T K W T L W T M W T N W T O W T P W T Q W T R W T S W T T W T U W T V W T W W T X W T Y W T Z W T 2 W T 3 W T 4 S-13A1 Series D type Product Name S-13A1D00-U5T1U3 S-13A1D10-U5T1U3 S-13A1D11-U5T1U3 S-13A1D12-U5T1U3 S-13A1D1C-U5T1U3 S-13A1D13-U5T1U3 S-13A1D14-U5T1U3 S-13A1D15-U5T1U3 S-13A1D16-U5T1U3 S-13A1D17-U5T1U3 S-13A1D18-U5T1U3 S-13A1D1J-U5T1U3 S-13A1D19-U5T1U3 S-13A1D20-U5T1U3 S-13A1D21-U5T1U3 S-13A1D22-U5T1U3 S-13A1D23-U5T1U3 S-13A1D24-U5T1U3 S-13A1D25-U5T1U3 S-13A1D26-U5T1U3 S-13A1D27-U5T1U3 S-13A1D28-U5T1U3 S-13A1D2J-U5T1U3 S-13A1D29-U5T1U3 S-13A1D30-U5T1U3 S-13A1D31-U5T1U3 S-13A1D32-U5T1U3 S-13A1D33-U5T1U3 S-13A1D34-U5T1U3 S-13A1D35-U5T1U3 Product Code (1) (2) (3) W U A W U B W U C W U D W U 5 W U E W U F W U G W U H W U I W U J W U K W U L W U M W U N W U O W U P W U Q W U R W U S W U T W U U W U V W U W W U X W U Y W U Z W U 2 W U 3 W U 4 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00 4. HSNT-6A Top view 6 5 4 (1) (2) (3) (1) to (3): (4): (5) to (9): Product code (Refer to Product name vs. Product code) Blank Lot number (4) (5) (6) (7) (8) (9) 1 2 3 Product name vs. Product code 4. 1 S-13A1 Series A type Product Name S-13A1A10-A6T1U3 S-13A1A11-A6T1U3 S-13A1A12-A6T1U3 S-13A1A1C-A6T1U3 S-13A1A13-A6T1U3 S-13A1A14-A6T1U3 S-13A1A15-A6T1U3 S-13A1A16-A6T1U3 S-13A1A17-A6T1U3 S-13A1A18-A6T1U3 S-13A1A1J-A6T1U3 S-13A1A19-A6T1U3 S-13A1A20-A6T1U3 S-13A1A21-A6T1U3 S-13A1A22-A6T1U3 S-13A1A23-A6T1U3 S-13A1A24-A6T1U3 S-13A1A25-A6T1U3 S-13A1A26-A6T1U3 S-13A1A27-A6T1U3 S-13A1A28-A6T1U3 S-13A1A2J-A6T1U3 S-13A1A29-A6T1U3 S-13A1A30-A6T1U3 S-13A1A31-A6T1U3 S-13A1A32-A6T1U3 S-13A1A33-A6T1U3 S-13A1A34-A6T1U3 S-13A1A35-A6T1U3 4. 2 Product Code (1) (2) (3) W R B W R C W R D W R 5 W R E W R F W R G W R H W R I W R J W R K W R L W R M W R N W R O W R P W R Q W R R W R S W R T W R U W R V W R W W R X W R Y W R Z W R 2 W R 3 W R 4 S-13A1 Series B type Product Name S-13A1B10-A6T1U3 S-13A1B11-A6T1U3 S-13A1B12-A6T1U3 S-13A1B1C-A6T1U3 S-13A1B13-A6T1U3 S-13A1B14-A6T1U3 S-13A1B15-A6T1U3 S-13A1B16-A6T1U3 S-13A1B17-A6T1U3 S-13A1B18-A6T1U3 S-13A1B1J-A6T1U3 S-13A1B19-A6T1U3 S-13A1B20-A6T1U3 S-13A1B21-A6T1U3 S-13A1B22-A6T1U3 S-13A1B23-A6T1U3 S-13A1B24-A6T1U3 S-13A1B25-A6T1U3 S-13A1B26-A6T1U3 S-13A1B27-A6T1U3 S-13A1B28-A6T1U3 S-13A1B2J-A6T1U3 S-13A1B29-A6T1U3 S-13A1B30-A6T1U3 S-13A1B31-A6T1U3 S-13A1B32-A6T1U3 S-13A1B33-A6T1U3 S-13A1B34-A6T1U3 S-13A1B35-A6T1U3 Product Code (1) (2) (3) W S B W S C W S D W S 5 W S E W S F W S G W S H W S I W S J W S K W S L W S M W S N W S O W S P W S Q W S R W S S W S T W S U W S V W S W W S X W S Y W S Z W S 2 W S 3 W S 4 49 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series 4. 3 S-13A1 Series C type Product Name S-13A1C10-A6T1U3 S-13A1C11-A6T1U3 S-13A1C12-A6T1U3 S-13A1C1C-A6T1U3 S-13A1C13-A6T1U3 S-13A1C14-A6T1U3 S-13A1C15-A6T1U3 S-13A1C16-A6T1U3 S-13A1C17-A6T1U3 S-13A1C18-A6T1U3 S-13A1C1J-A6T1U3 S-13A1C19-A6T1U3 S-13A1C20-A6T1U3 S-13A1C21-A6T1U3 S-13A1C22-A6T1U3 S-13A1C23-A6T1U3 S-13A1C24-A6T1U3 S-13A1C25-A6T1U3 S-13A1C26-A6T1U3 S-13A1C27-A6T1U3 S-13A1C28-A6T1U3 S-13A1C2J-A6T1U3 S-13A1C29-A6T1U3 S-13A1C30-A6T1U3 S-13A1C31-A6T1U3 S-13A1C32-A6T1U3 S-13A1C33-A6T1U3 S-13A1C34-A6T1U3 S-13A1C35-A6T1U3 50 Rev.2.2_00 4. 4 Product Code (1) (2) (3) W T B W T C W T D W T 5 W T E W T F W T G W T H W T I W T J W T K W T L W T M W T N W T O W T P W T Q W T R W T S W T T W T U W T V W T W W T X W T Y W T Z W T 2 W T 3 W T 4 S-13A1 Series D type Product Name S-13A1D10-A6T1U3 S-13A1D11-A6T1U3 S-13A1D12-A6T1U3 S-13A1D1C-A6T1U3 S-13A1D13-A6T1U3 S-13A1D14-A6T1U3 S-13A1D15-A6T1U3 S-13A1D16-A6T1U3 S-13A1D17-A6T1U3 S-13A1D18-A6T1U3 S-13A1D1J-A6T1U3 S-13A1D19-A6T1U3 S-13A1D20-A6T1U3 S-13A1D21-A6T1U3 S-13A1D22-A6T1U3 S-13A1D23-A6T1U3 S-13A1D24-A6T1U3 S-13A1D25-A6T1U3 S-13A1D26-A6T1U3 S-13A1D27-A6T1U3 S-13A1D28-A6T1U3 S-13A1D2J-A6T1U3 S-13A1D29-A6T1U3 S-13A1D30-A6T1U3 S-13A1D31-A6T1U3 S-13A1D32-A6T1U3 S-13A1D33-A6T1U3 S-13A1D34-A6T1U3 S-13A1D35-A6T1U3 Product Code (1) (2) (3) W U B W U C W U D W U 5 W U E W U F W U G W U H W U I W U J W U K W U L W U M W U N W U O W U P W U Q W U R W U S W U T W U U W U V W U W W U X W U Y W U Z W U 2 W U 3 W U 4 5.5 V INPUT, 1000 mA VOLTAGE REGULATOR S-13A1 Series Rev.2.2_00  Power Dissipation HSOP-8A HSOP-6 Tj = 125C max. 4 E 3 D C 2 B 1 0 A 0 25 50 75 100 125 150 Tj = 125C max. 5 Power dissipation (PD) [W] Power dissipation (PD) [W] 5 4 3 2 D B 1 0 175 E A 0 25 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 0.96 W 1.35 W 2.56 W 2.70 W 3.23 W 100 125 150 175 Board A B C D E Power Dissipation (PD) 1.04 W 1.35 W − 2.27 W 2.44 W HSNT-6A Tj = 125C max. 4 E 3 2 D B 1 Tj = 125C max. 5 Power dissipation (PD) [W] 5 Power dissipation (PD) [W] 75 Ambient temperature (Ta) [C] SOT-89-5 4 3 2 1 B A 0 50 0 25 50 75 100 125 150 175 0 A 0 25 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 0.84 W 1.19 W − 2.17 W 2.86 W 50 75 100 125 150 175 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 0.51 W 0.64 W − − − 51 HSOP-8A Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSOP8A-A-Board-SD-1.0 ABLIC Inc. HSOP-8A Test Board (4) Board D IC Mount Area Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm (5) Board E Thermal via enlarged view No. HSOP8A-A-Board-SD-1.0 ABLIC Inc. HSOP-6 Test Board IC Mount Area (1) Board A Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 2 Copper foil layer [mm] 1 Land pattern and wiring for testing: t0.070 2 3 4 74.2 x 74.2 x t0.070 Thermal via - (2) Board B Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 4 Land pattern and wiring for testing: t0.070 1 74.2 x 74.2 x t0.035 2 Copper foil layer [mm] 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.070 4 Thermal via - (3) Board D Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 4 Copper foil layer [mm] 1 2 3 4 Thermal via Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (4) Board E Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. HSOP6-A-Board-SD-1.0 enlarged view ABLIC Inc. SOT-89-5 Test Board IC Mount Area (1) Board A Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] 2 1 Land pattern and wiring for testing: t0.070 2 - 3 4 74.2 x 74.2 x t0.070 Thermal via - (2) Board B Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer 4 Copper foil layer [mm] 1 Land pattern and wiring for testing: t0.070 2 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 Thermal via - (3) Board D Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] 4 2 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 1 Thermal via - (4) Board E Item Specification Size [mm] 114.3 x 76.2 x t1.6 Material FR-4 Number of copper foil layer Copper foil layer [mm] Thermal via 4 1 Pattern for heat radiation: 2000mm2 t0.070 2 74.2 x 74.2 x t0.035 3 74.2 x 74.2 x t0.035 4 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. SOT895-A-Board-SD-1.0 enlarged view ABLIC Inc. HSNT-6A Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. HSNT6A-A-Board-SD-1.0 ABLIC Inc. +0.20 5.02 -0.35 8 5 1 4 1.27 1 0.20±0.05 3.0 8 4 5 +0.12 0.4 -0.07 No. FH008-Z-P-SD-2.0 TITLE HSOP8A-Z-PKG Dimensions No. FH008-Z-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. +0.20 5.02 -0.35 8 5 1 4 1.27 2.14 0.20±0.05 1 4 8 5 +0.12 0.4 -0.07 No. FH008-Z-P-S1-2.0 TITLE HSOP8A-Z-PKG Dimensions No. FH008-Z-P-S1-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.5 +0.1 -0.0 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 8 4 5 Feed direction No. FH008-Z-C-SD-1.0 TITLE HSOP8A-Z-Carrier Tape No. FH008-Z-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.5 +0.1 -0 0.25±0.02 +0.25 ø1.5 -0 8.0±0.1 2.1±0.1 6.4±0.1 1 8 4 5 Feed direction No. FH008-Z-C-S1-1.0 TITLE HSOP8A-Z-Carrier Tape No. FH008-Z-C-S1-1.0 ANGLE UNIT mm ABLIC Inc. 17.4±1.0 13.4±1.0 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FH008-Z-R-SD-1.0 TITLE HSOP8A-Z-Reel FH008-Z-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 4,000 0.76 3.2 1.27 1.27 1.27 No. FH008-Z-L-SD-1.0 TITLE HSOP8A-Z -Land Recommendation No. FH008-Z-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. 5.02±0.2 6 1 0.4±0.05 5 4 2 3 0.20±0.05 1.67±0.05 1.91 1.91 No. FH006-A-P-SD-2.1 TITLE HSOP6-A-PKG Dimensions No. FH006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.55±0.05 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 6 3 4 Feed direction No. FH006-A-C-SD-2.0 TITLE HSOP6-A-Carrier Tape No. FH006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 60° 2±0.5 13.5±0.5 Enlarged drawing in the central part ø21±0.8 2±0.5 ø13±0.2 No. FH006-A-R-S1-1.0 TITLE HSOP6-A-Reel No. FH006-A-R-S1-1.0 ANGLE UNIT QTY. mm ABLIC Inc. 4,000 2.03 0.76 1.91 1.91 No. FH006-A-L-SD-2.0 TITLE HSOP6-A -Land Recommendation No. FH006-A-L-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.5±0.1 1.5±0.1 1.6±0.2 5 4 0.3 45° 1 2 3 1.5±0.1 1.5±0.1 0.4±0.05 0.4±0.1 0.4±0.1 0.45±0.1 No. UP005-A-P-SD-2.0 TITLE SOT895-A-PKG Dimensions No. UP005-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches : 40.0±0.2) ø1.5 +0.1 -0 2.0±0.05 +0.1 ø1.5 -0 0.3±0.05 8.0±0.1 2.0±0.1 4.75±0.1 3 2 1 4 5 Feed direction No. UP005-A-C-SD-2.0 TITLE SOT895-A-Carrier Tape UP005-A-C-SD-2.0 No. ANGLE UNIT mm ABLIC Inc. 16.5max. 13.0±0.3 Enlarged drawing in the central part (60°) (60°) No. UP005-A-R-SD-1.1 TITLE SOT895-A-Reel No. UP005-A-R-SD-1.1 ANGLE UNIT QTY. mm ABLIC Inc. 1,000 1.96±0.05 1.78±0.05 6 1 5 0.5 4 2 3 0.5 0.5 0.12±0.04 0.48±0.02 0.22±0.05 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. No. PJ006-A-P-SD-3.1 TITLE HSNT-6A-A-PKG Dimensions No. PJ006-A-P-SD-3.1 ANGLE UNIT mm ABLIC Inc. +0.1 4.0±0.1 2.0±0.05 ø1.5 -0 ø0.5±0.1 2.25±0.05 0.25±0.05 0.65±0.05 4.0±0.1 3 21 0.5 0.5 0.5 0.5 0.5 0.5 4 5 6 Feed direction No. PJ006-A-C-SD-2.0 TITLE HSNT-6A-A-Carrier Tape No. PJ006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PJ006-A-R-SD-1.0 TITLE HSNT-6A-A-Reel No. PJ006-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 Land Recommendation 0.5 0.7 0.7 0.35 0.35 0.3 1.4 2.1 Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Stencil Opening 0.5 0.2 0.8 0.8 0.3 0.2 1.6 2.0 TITLE HSNT-6A-A -Land &Stencil Opening PJ006-A-LM-SD-1.1 No. ANGLE No. PJ006-A-LM-SD-1.1 UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-13A1H30-U5T1U3
物料型号:S-13A1系列
器件简介: S-13A1系列是一款基于CMOS技术开发的正电压调节器,具有低 dropout 电压、高精度输出电压和低电流消耗的特点。该系列包括内置晶体管以提供较小的dropout电压和较大的输出电流。此外,S-13A1系列还具备负载电流保护电路和热关断电路,以防止输出电流超出晶体管的电流容量和因过热而损坏。
引脚分配: - HSOP-8A、HSOP-6、SOT-89-5和HSNT-6A封装的引脚分配在文档中有详细的图表说明,包括VOUT(输出电压引脚)、ON/OFF(控制开关引脚)、VSS(地线)、VIN(输入电压引脚)等。
参数特性: - 输出电压:内部设定范围1.0V至3.5V,步进0.05V;外部设定范围1.05V至5.0V。 - 输入电压:1.5V至5.5V。 - 输出电压精度:±1.0%(内部设定,1.0V至1.45V输出产品:±15mV)。 - Dropout电压:典型值70mV。 - 工作电流:典型值60μA,最大90μA。 - 关闭时电流:典型值0.1μA,最大1.0μA。 - 输出电流:可达1000mA。
功能详解: - 内置过流保护电路、热关断电路和开机时的突波电流限制电路。 - 某些型号可通过外部电阻设置输出电压。 - 具有ON/OFF控制功能,可选择是否启用放电旁路功能和下拉功能。
应用信息: 适用于电池供电设备的恒压电源、电视、笔记本电脑和家用电器的恒压电源以及便携设备的恒压电源。
封装信息: 提供多种封装类型,包括HSOP-8A、HSOP-6、SOT-89-5和HSNT-6A,以适应不同的安装需求和密度。
S-13A1H30-U5T1U3 价格&库存
很抱歉,暂时无法提供与“S-13A1H30-U5T1U3”相匹配的价格&库存,您可以联系我们找货
