TS9011PCY RMG
TS9011PCY RMG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO243AA
TS9011PCY RMG 数据手册
TS9011 Taiwan Semiconductor 250mA Low Quiescent Current CMOS LDO DESCRIPTION FEATURES TS9011 is a positive voltage regulator developed ● Dropout Voltage 0.4V (typ.) @ Io=250mA utilizing CMOS technology featured very low power ● Output Current up to 250mA consumption, low dropout voltage and high output ● Low Power Consumption, 2µA (typ.) voltage accuracy. Built in low on-resistor provides ● Output Voltage ± 2% low dropout voltage and large output current. A 1µF ● Internal Current Limit or greater can be used as an output capacitor. ● ● Thermal Shutdown Protection Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC. Halogen-free according to IEC 61249-2-21 TS9011 are prevented device failure under the worst operation condition with both thermal shutdown and ● current fold-back. These series are recommended for configuring portable devices and large current APPLICATION application, respectively. ● Battery-operated systems ● Microprocessor reset circuitry ● Memory battery back-up circuits ● Power-on reset circuits ● Power failure detection ● System battery life and charge voltage monitors SOT-23 SOT-89 Pin Definition: 1. Ground 2. Output 3. Input Pin Definition: 1. Ground 2. Input 3. Output Notes: Moisture sensitivity level: level 3. Per J-STD-020 TYPICAL APPLICATION CIRCUIT *Tantalum capacitor for Input & Output capacitor are recommended. 1 Version: H1608 TS9011 Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise specified) (Note 1) PARAMETER SYMBOL LIMIT UNIT VIN IOUT V mA TOPR TJ TSTG 12 250 0.30 0.50 -40 ~ +85 -40 ~ +150 -65 ~ +150 SYMBOL LIMIT UNIT Input Supply Voltage Output Current SOT-23 SOT-89 Power Dissipation PD Operating Ambient Temperature Junction Temperature Range Storage Temperature Range W o C C o C o THERMAL PERFORMANCE PARAMETER SOT-23 Thermal Resistance - Junction to Ambient SOT-89 333 RӨJA o C/W 200 Note: Measured with FR4 4-layer board having thermal via holes ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise specified) PARAMETER CONDITION TS90115 MIN TYP MAX 4.90 5.0 5.10 TS9011S 3.23 3.3 3.36 TS9011P 2.94 3.0 3.06 TS9011K 2.45 2.5 2.55 TS9011D 1.76 1.8 1.83 250 -- -- mA % VIN=VO + 1V, IO =40mA, Output Voltage Maximum Output Current VIN=VO+1V, Input Stability VO+1V ≤ VIN ≤ VO+2V, IO=1mA -- 0.2 0.3 VIN=VO+1V, 1mA≤IL≤100mA -- 40 80 Load Regulation Dropout Voltage (Note1) (Note 2) UNIT V TS90115 TS9011S TS9011P VIN=VO+1V, 1mA≤IL≤80mA TS9011K IO=250mA mV -- 40 90 TS90115 -- 400 600 IO=200mA TS9011S -- 400 650 IO=160mA TS9011P -- 400 700 IO=160mA TS9011K -- 400 700 IO=120mA TS9011D -- 400 750 TS9011D mV Quiescent Current VIN=VO+1V, IO=0A -- 2 5 µA Output Current Limit VOUT < 0.4V -- 400 -- mA Power Supply Rejection Ratio Output Voltage Temperature (Note 3) Coefficient At f=100kHz, IO=10mA, -- 30 -- dB -- 100 -- ppm/ C o Note: 1. Regulation is measured at constant junction temperature, using pulsed ON time. 2. Dropout is measured at constant junction temperature, using pulsed ON time, and the criterion is VOUT inside target value +/-2%. 3. Guaranteed by design. 2 Version: H1608 TS9011 Taiwan Semiconductor ORDERING INFORMATION OUTPUT VOLTAGE 1.8V 2.5V 3.0V 3.3V 5V PART NO. PACKAGE PACKING TS9011DCX RFG SOT-23 3,000pcs / 7” Reel TS9011DCY RMG SOT-89 1,000pcs / 7” Reel TS9011KCX RFG SOT-23 3,000pcs / 7” Reel TS9011KCY RMG SOT-89 1,000pcs / 7” Reel TS9011PCY RMG SOT-89 1,000pcs / 7” Reel TS9011SCX RFG SOT-23 3,000pcs / 7” Reel TS9011SCY RMG SOT-89 1,000pcs / 7” Reel TS90115CX RFG SOT-23 3,000pcs / 7” Reel TS90115CY RMG SOT-89 1,000pcs / 7” Reel FUNCTION BLOCK DIAGRAM 3 Version: H1608 TS9011 Taiwan Semiconductor ELECTRICAL CHARACTERICS CURVES (TA=25oC, unless otherwise noted) Figure 1. Output Voltage vs. Output Current Figure 2. Output Voltage vs. Input Voltage Figure 3. Quiescent Current vs. Input Voltage Figure 4. Short Circuit Current vs. Input Voltage 4 Version: H1608 TS9011 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) SOT-23 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM E = Product Code Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr ` S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) X = Fixed Output Voltage Code A=1.5V, D=1.8V, K=2.5V, P=3.0V, S=3.3V, 5=5.0V. 5 Version: H1608 TS9011 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) SOT-89 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr ` S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) X = Fixed Output Voltage Code A=1.5V, D=1.8V, K=2.5V, P=3.0V, S=3.3V, 5=5.0V. 6 Version: H1608 TS9011 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: H1608
TS9011PCY RMG 价格&库存
很抱歉,暂时无法提供与“TS9011PCY RMG”相匹配的价格&库存,您可以联系我们找货
TS9011PCY RMG
  • 1+8.54031
  • 5+5.77100
  • 25+4.03060
  • 100+3.63652
  • 1000+2.88550
TS9011PCY RMG
  • 1+7.447731+0.96841
  • 5+4.997025+0.64975
  • 25+3.4935725+0.45426
  • 100+3.15464100+0.41019
  • 1000+2.502861000+0.32544
TS9011PCY RMG
  • 1+5.118391+0.66554
  • 10+3.5796810+0.46546
  • 25+3.2096625+0.41735
  • 100+2.79443100+0.36336
  • 250+2.59639250+0.33761
  • 500+2.47752500+0.32215
库存:805
