S-5852ABCBC-A8T1U4
S-5852ABCBC-A8T1U4
    ABLIC(艾普凌科)
    SMD-8P
    SENSOR DIGITAL 0C-65C HSNT8-A
S-5852ABCBC-A8T1U4 数据手册
S-5852A Series www.ablic.com www.ablicinc.com HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION © ABLIC Inc., 2015-2016 Rev.1.2_01 The S-5852A Series is a high-accuracy digital temperature sensor with thermostat function, which operates in 1.7 V to 3.6 V 2 voltage ranges. The S-5852A Series interfaces with exteriors via I C-bus and operates at 1.0 MHz maximum. The 2 temperature detection signal is output by using the thermostat function which can be set by the I C-bus. Moreover, a 2 substantial reduction in current consumption may be achieved by using the shutdown mode which can be set by the I C-bus. The operation of the S-5852A Series is explained in the user's manual. Contact our sales office for more information. Caution This product is intended to use in general electronic devices such as consumer electronics, office equipment, and communications devices. Before using the product in medical equipment or automobile equipment including car audio, keyless entry and engine control unit, contact to ABLIC Inc. is indispensable.  Features  Temperature accuracy, high-accuracy temperature range*1: 0.5°C typ. / 1.0°C max. (Ta = 0°C to 65°C) 0.5°C typ. / 1.0°C max. (Ta = 75°C to 95°C)  Temperature resolution: 0.5°C, 0.25°C, 0.125°C, 0.0625°C (Selectable by the resolution register)  Temperature sample rate: 7 samples / s min.  Hysteresis width: No hysteresis, 1.5°C, 3.0°C, 6.0°C (Selectable by the configuration register)  Current consumption: Shutdown mode at serial bus non-active: IDD3 = 0.3 A typ., IDD3 = 3.0 A max. Active mode at serial bus non-active: IDD1 = 40.0 A typ., IDD1 = 100.0 A max.  Operation voltage range: 1.7 V to 3.6 V  Operation frequency: 1.0 MHz max. (VDD = 2.2 V to 3.6 V) 400 kHz max. (VDD = 1.7 V to 2.2 V)  Thermostat function: Dual trip mode, single trip mode (Selectable by the configuration register)  Noise suppression: Schmitt trigger and noise filter on input pins (SCL, SDA)  Operation temperature range: Ta = 40°C to 125°C  Lead-free (Sn 100%), halogen-free *1. The option of the high-accuracy temperature range can be selected.  Applications      Solid state drive Hard disk drive Notebook PC, tablet PC Refrigerator Air conditioning system    Package  HSNT-8(2030) 1 HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  Block Diagram A0 A1 Power-on reset A2 SCL SDA VSS Pointer register Serial interface circuit Temperature sensor register Capabilities register Configuration register Dual trip HIGH limit register Dual trip LOW limit register Single trip HIGH limit register Temperature sensor  A/D converter Ambient temperature register Resolution register Figure 1 2 VDD Thermostat circuit TMS HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  Product Name Structure 1. Product name S-5852A B C x C - A8T1 U 4 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 A8T1: HSNT-8(2030), Tape Operation temperature range C: Ta = 40°C to 125°C High-accuracy temperature range A: Ta = 75°C to 95°C B: Ta = 0°C to 65°C Temperature accuracy C: 0.5°C typ. / 1.0°C max. Operation voltage B: VDD = 1.7 V min. *1. Refer to the tape drawing. 2. Package Table 1 Package Drawing Codes Package Name HSNT-8(2030) Dimension Tape Reel Land PP008-A-P-SD PP008-A-C-SD PP008-A-R-SD PP008-A-L-SD High-accuracy Temperature Range Operation Temperature Range 3. Product name list Table 2 Product Name S-5852ABCAC-A8T1U4 S-5852ABCBC-A8T1U4 Operation Voltage 1.7 V min. 1.7 V min. Temperature Accuracy 0.5°C typ. / 1.0°C max. Ta = 75°C to 95°C 0.5°C typ. / 1.0°C max. Ta = 0°C to 65°C Ta = 40°C to 125°C Ta = 40°C to 125°C 3 HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  Pin Configuration 1. HSNT-8(2030) Top view Table 3 1 8 4 5 Bottom view 8 1 5 4 *1 Pin No. 1 2 3 4 5 6 7 8 Symbol A0 A1 A2 VSS SDA*2 *2 SCL _______ TMS VDD Description Slave address input pin Slave address input pin Slave address input pin GND pin Serial data I/O pin Serial clock input pin Temperature switch output (Thermostat output) pin Power supply pin Figure 2 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential open or GND. However, do not use it as the function of electrode. *2. Do not use it in "High-Z". 4 HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  Absolute Maximum Ratings Table 4 Item Power supply voltage Input voltage (SCL, A0, A1, A2) I/O voltage (SDA) _______ Output voltage (TMS) Symbol Absolute Maximum Rating Unit 0.3 to 4.3 0.3 to 4.3 0.3 to 4.3 V V V VDD VIN VIO VOUT 0.3 to 4.3 Operation ambient temperature Topr 40 to 125 Storage temperature Tstg 65 to 150 Caution The absolute maximum ratings are rated values exceeding which the product could physical damage. These values must therefore not be exceeded under any conditions. V °C °C suffer  Recommended Operation Conditions Table 5 Item Power supply voltage Operation ambient temperature High level input voltage Low level input voltage Symbol VDD Topr VIH VIL Min. Max. Unit 1.7 40 0.7  VDD 0.3 3.6 125 3.6 0.3  VDD V °C V V  Pin Capacitance Table 6 (Ta = 25°C, fSCL = 1.0 MHz, VDD = 2.5 V) Item Input capacitance I/O capacitance Output capacitance Symbol CIN CI/O COUT Condition VIN = 0 V (SCL, A0, A1, A2) VI/O = 0 V (SDA) _______ VOUT = 0 V (TMS) Min.    Max. 6 8 8 Unit pF pF pF 5 HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  DC Electrical Characteristics Table 7 Item Current consumption at active mode Current consumption at shutdown mode Symbol IDD1 IDD2 IDD3 IDD4 Condition Min. Typ. Max. Unit Active mode at serial bus non-active Active mode at serial bus active Shutdown mode at serial bus non-active Shutdown mode at serial bus active     40.0  0.3  100.0 400.0 3.0 400.0 A A A A Table 8 Symbol Item 6 Input leakage current ILI Output leakage current ILO Input current 1 IIL Input current 2 IIH Input impedance 1 ZIL Input impedance 2 ZIH Low level output voltage VOL Low level output current 1 IOL1 Low level output current 2 IOL2 Condition SCL, SDA VIN = V_______ SS to VDD SDA, TMS VOUT = VSS to VDD A0, A1, A2 VIN  0.3  VDD A0, A1, A2 VIN  0.7  VDD A0, A1, A2 VIN = 0.3  VDD A0, A1, A2 VIN = 0.7 V _______ DD SDA, TMS IOL = 3.0 mA _______ SDA, TMS V, 2.2 V  VDD  3.6 V VOL = 0.4 _______ SDA, TMS VOL = 0.6 V, 1.7 V  VDD  2.2 V Min. Max. Unit  1.0 A  1.0 A  50.0 A  2.0 A 30  k 800  k  0.4 V 20  mA 6  mA HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  AC Electrical Characteristics Table 9 Measurement Conditions Input pulse voltage Input pulse rising / falling time Output reference voltage Output load Input pulse voltage 0.2  VDD to 0.8  VDD 20 ns or less 0.3  VDD to 0.7  VDD 100 pF  1 kpull-up reisitance Output reference voltage 0.8  VDD 0.7  VDD 0.3  VDD 0.2  VDD Figure 3 Input / Output Waveform during AC Measurement Table 10 Item Symbol VDD = 1.7 V to 3.6 V VDD = 2.2 V to 3.6 V Min. Max. Min. Max. Unit SCL clock frequency fSCL 0 400 0 1000 kHz SCL clock time "L" tLOW 1.3  0.5  s SCL clock time "H" tHIGH 0.6  0.26  s SDA output delay time tAA 0.1 0.9 0.1 0.45 s SDA output hold time tDH 50  50  ns SCL, SDA rising time tR 0.02 0.3  0.12 s SCL, SDA falling time tF  0.12 s tSU.DAT 0.02 100 0.3 Data input setup time  50  ns Data input hold time tHD.DAT 0  ns tSU.STA 0 0.6  Start condition setup time  0.26  s Start condition hold time tHD.STA 0.6  0.26  s Stop condition setup time tSU.STO 0.6  0.26  s Bus release time tBUF 1.3  0.5  s Noise suppression time tI  50  50 ns tHIGH tF tLOW tR SCL tHD.STA tHD.DAT tSU.STA tSU.DAT tSU.STO SDA (Input) tAA tDH tBUF SDA (Output) Figure 4 Bus Timing 7 HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  Temperature Characteristics Table 11 Item Temperature accuracy*1 Temperature resolution Symbol Condition Min. Typ. Max. Unit TACC1 Ta = 0°C to 65°C  0.5 1.0 °C TACC2 Ta = 40°C to 125°C   3.0 °C TRES Default value  0.25  °C   35 ms   70 ms   140 ms   140 ms tCONV1 tCONV2 Temperature conversion time tCONV3 tCONV4 TRES[1:0] = "00" setting LSB = 0.5°C TRES[1:0] = "01" setting LSB = 0.25°C TRES[1:0] = "10" setting LSB = 0.125°C TRES[1:0] = "11" setting LSB = 0.0625°C *1. TRES[1:0] = "11" setting  Precautions  Do not operate these ICs in excess of the absolute maximum ratings. Attention should be paid to the power supply voltage, especially. The surge voltage which exceeds the absolute maximum ratings can cause latch-up and malfunction. Perform operations after confirming the detailed operation condition in the datasheet.  Operations with moisture on this IC's pins may occur malfunction by short-circuit between pins. Especially, in occasions like picking this IC up from low temperature tank during the evaluation. Be sure that there is no frost on this IC's pins to prevent malfunction by short-circuit. Also attention should be paid in using on environment, which is easy to dew for the same reason.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  ABLIC Inc. claims no responsibility for any and all disputes arising out of or in connection with any infringement of the products including this IC upon patents owned by a third party. 8 HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series  Characteristics (Typical Data) 1. Current consumption at active mode (IDD1) vs. Temperature (Ta) 100 IDD1 [A] 80 VDD = 3.6 V VDD = 2.5 V 60 40 20 VDD = 1.7 V 0 40 25 0 25 50 75 100 125 Ta [C] 2. Current consumption at shutdown mode (IDD3) vs. Temperature (Ta) 3.0 IDD3 [A] 2.5 2.0 VDD = 3.6 V VDD = 2.5 V VDD = 1.7 V 1.5 1.0 0.5 0.0 40 25 0 25 50 75 100 125 Ta [C] 3. Current consumption at active mode (IDD2) vs. SCL clock frequency (fSCL) Ta = 25°C 400 IDD2 [A] 300 VDD = 3.6 V VDD = 2.5 V VDD = 1.7 V 200 100 0 0 200 400 600 800 1000 fSCL [kHz] 4. Low level output current (IOLn) vs. Low level output voltage (VOL) Ta = 25°C IOLn [mA] 40 VDD = 3.6 V 30 20 VDD = 1.7 V 10 0 VDD = 2.5 V 0 0.1 0.2 0.3 0.4 0.5 0.6 VOL [V] Remark n = 1, 2 9 HIGH-ACCURACY DIGITAL TEMPERATURE SENSOR WITH THERMOSTAT FUNCTION Rev.1.2_01 S-5852A Series TRES[1:0] = "11" setting 4.0 3.0 2.0 1.0 0.0 1.0 2.0 3.0 4.0 40 25 TACCn max. VDD = 1.7 V VDD = 2.5 V VDD = 3.6 V VDD = 2.5 V, TRES[1:0] = "11" setting, number of measurement = 100 pieces 0.50 TACCn [C] TACCn [C] 5. Temperature accuracy (TACCn) vs. Temperature (Ta) Average 6 0.25 25 50 75 100 125 0.25 0.50 Average 6 0 Ta [C] Remark Average 0.00 TACCn min. 0 Average 3 10 20 Average 3 30 40 50 60 65 Ta [C] n = 1, 2 6. Temperature conversion time (tCONV4) vs. Temperature (Ta) TRES [1:0] = "11" setting 150 VDD = 3.6 V tCONV4 [ms] 125 100 75 50 VDD = 2.5 V VDD = 1.7 V 25 0 40 25 0 25 50 75 100 125 Ta [C] 7. Thermal response time (Temperature vs. Time) When HSNT-8(2030) mounted on the evaluation board is put into the liquid of 100C from the air of 25C. VDD = 3.0 V Temperature [°C] 100 90 80 70 60 50 40 30 20 2 0 2 4 6 8 10 12 14 16 18 20 22 24 26 Time [s] Remark Evaluation board Dimensions: 22 mm21 mm Thickness: 1.6 mm 10 2.0±0.1 8 5 (1.70) 1 4 +0.05 0.08 -0.02 0.5 0.23±0.1 No. PP008-A-P-SD-2.0 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. TITLE DFN-8/HSNT-8-A-PKG Dimensions No. PP008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 2.0±0.05 4.0±0.1 0.25±0.05 +0.1 ø1.0 -0 0.60±0.05 4.0±0.1 2.3±0.05 4 321 5 6 78 Feed direction No. PP008-A-C-SD-1.0 TITLE DFN-8/HSNT-8-A-Carrier Tape No. PP008-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PP008-A-R-SD-1.0 TITLE DFN-8/HSNT-8-A-Reel No. PP008-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 1.6 0.30 0.50 No. PP008-A-L-SD-1.0 TITLE No. DFN-8/HSNT-8-A -Land Recommendation PP008-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-5852ABCBC-A8T1U4
1. 物料型号:S-5852A Series,这是一款高精度数字温度传感器,具备恒温器功能。
2. 器件简介:S-5852A系列能够在1.7 V至3.6 V的电压范围内工作,通过I2C总线与外部接口,最高工作频率为1.0 MHz。该传感器使用恒温器功能输出温度检测信号,且可通过I2C总线设置。同时,通过I2C总线设置的关闭模式可以大幅降低功耗。
3. 引脚分配:包括VDD(电源引脚)、GND(地线)、SDA和SCL(串行数据和时钟输入引脚)、TMS(温度开关输出引脚,即恒温器输出引脚)等。
4. 参数特性:包括高精度的温度范围、温度分辨率(0.5°C至0.0625°C可调)、温度样本率、滞后宽度、工作电压范围、操作频率等。
5. 功能详解:提供了详细的电气特性表、绝对最大额定值、推荐操作条件、引脚电容、直流和交流电气特性等。
6. 应用信息:适用于固态硬盘、硬盘驱动器、笔记本电脑、平板电脑、冰箱和空调系统等。
7. 封装信息:封装类型为HSNT-8(2030)。
S-5852ABCBC-A8T1U4 价格&库存
很抱歉,暂时无法提供与“S-5852ABCBC-A8T1U4”相匹配的价格&库存,您可以联系我们找货
