S-13D1D2828-M6T1U3
S-13D1D2828-M6T1U3
    ABLIC(艾普凌科)
    SOT23-6
    IC REG LIN 2.8V/2.8V 150MA SOT23
S-13D1D2828-M6T1U3 数据手册
S-13D1 Series 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION www.ablic.com Rev.1.4_00 © ABLIC Inc., 2012-2018 The S-13D1 Series, developed by using the CMOS technology, is a 2-channel positive voltage regulator IC which has low dropout voltage, high accuracy output voltage and low current consumption. A 0.22 μF small ceramic capacitor can be used, and the S-13D1 Series includes a load current protection circuit that prevents the output current from exceeding the current capacity of the output transistor and a thermal shutdown circuit that prevents damage due to overheating. Also, C / F type in the S-13D1 Series has a built-in delay function that sets the difference of rising time between channels.  Features • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Current consumption: • Output current: • Input and output capacitors: • Ripple rejection: • Delay function is selectable. • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in ON / OFF circuit: • Operation temperature range: • Lead-free (Sn 100%), halogen-free 1.0 V to 3.6 V, selectable in 0.05 V step 1.5 V to 5.5 V ±1.0% (1.0 V to 1.45 V output product : ±15 mV) 80 mV typ. (2.8 V output product, IOUT = 100 mA) During operation: 39 μA typ., 58 μA max. (per circuit) During power-off: 0.1 μA typ., 1.0 μA max. Possible to output 150 mA (VIN ≥ VOUT(S) + 1.0 V)*1 (per circuit) A ceramic capacitor of 0.22 μF or more can be used. 70 dB typ. (3.6 V output product, f = 1.0 kHz) Limits overcurrent of output transistor. Prevents damage caused by heat. Ensures long battery life Discharge shunt function "available" / "unavailable" is selectable. Pull-down function "available" / "unavailable" is selectable. Ta = −40°C to +85°C *1. Attention should be paid to the power dissipation of the package when the output current is large.  Applications • Constant-voltage power supply for digital camera • Constant-voltage power supply for mobile phone • Constant-voltage power supply for portable equipment  Packages • SOT-23-6 • HSNT-6 (1212) 1 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Block Diagrams 1. S-13D1 Series A type *1 ON / OFF1 VOUT1 Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit + − Function ON / OFF logic Discharge shunt function Constant current source pull-down Delay function Status Active "H" Unavailable Available Unavailable Reference voltage circuit VIN VSS *1 Overcurrent protection circuit + − ON / OFF circuit Reference voltage circuit ON / OFF2 *1. VOUT2 Parasitic diode Figure 1 2. S-13D1 Series B type *1 VOUT1 ON / OFF1 Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit + − *1 Reference voltage circuit VIN VSS *1 Overcurrent protection circuit ON / OFF circuit + − *1 Reference voltage circuit VOUT2 ON / OFF2 *1. Parasitic diode Figure 2 2 Function ON / OFF logic Discharge shunt function Constant current source pull-down Delay function Status Active "H" Available Available Unavailable 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 3. S-13D1 Series C type *1 ON / OFF1 VOUT1 Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit + − *1 Function ON / OFF logic Discharge shunt function Constant current source pull-down Delay function Status Active "H" Available Available Available Reference voltage circuit VIN VSS *1 Overcurrent protection circuit ON / OFF circuit Delay circuit + − *1 Reference voltage circuit VOUT2 ON / OFF2 *1. Parasitic diode Figure 3 4. S-13D1 Series D type *1 ON / OFF1 VOUT1 Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit + − Function ON / OFF logic Discharge shunt function Constant current source pull-down Delay function Status Active "H" Unavailable Unavailable Unavailable Reference voltage circuit VIN VSS *1 Overcurrent protection circuit ON / OFF circuit + − Reference voltage circuit ON / OFF2 *1. VOUT2 Parasitic diode Figure 4 3 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 5. S-13D1 Series E type *1 VOUT1 ON / OFF1 Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit + − *1 Function ON / OFF logic Discharge shunt function Constant current source pull-down Delay function Status Active "H" Available Unavailable Unavailable Reference voltage circuit VIN VSS *1 Overcurrent protection circuit ON / OFF circuit + − *1 Reference voltage circuit ON / OFF2 *1. VOUT2 Parasitic diode Figure 5 6. S-13D1 Series F type *1 VOUT1 ON / OFF1 Overcurrent protection circuit Thermal shutdown circuit ON / OFF circuit + − *1 Reference voltage circuit VIN VSS *1 Overcurrent protection circuit ON / OFF circuit Delay circuit + − *1 Reference voltage circuit ON / OFF2 *1. VOUT2 Parasitic diode Figure 6 4 Function ON / OFF logic Discharge shunt function Constant current source pull-down Delay function Status Active "H" Available Unavailable Available 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Product Name Structure Users can select the product type, output voltage, and package type for the S-13D1 Series. Refer to "1. Product name" regarding the contents of product name, "2. Function list of product types" regarding the product type, "3. Packages" regarding the package drawings, "4. Product name list" regarding details of the product name. 1. Product name S-13D1 x xx xx - xxxx U 3 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 M6T1: SOT-23-6, Tape A6T2: HSNT-6 (1212), Tape Output voltage of voltage regulator 2*2 10 to 36 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) Output voltage of voltage regulator 1*2 10 to 36 (e.g., when the output voltage is 1.0 V, it is expressed as 10.) *3 Product type A to F *1. *2. *3. 2. Refer to the tape drawing. If you request the product which has 0.05 V step, contact our sales office. Refer to "2. Function list of product types". Function list of product types Table 1 Product Type A B C D E F 3. Constant Current Source Pull-down ON / OFF Logic Discharge Shunt Function Active "H" Active "H" Active "H" Active "H" Active "H" Active "H" Unavailable Available Available Unavailable Available Available Available Available Available Unavailable Unavailable Unavailable Table 2 Package Drawing Codes Delay Function Unavailable Unavailable Available Unavailable Unavailable Available Packages Package Name SOT-23-6 HSNT-6 (1212) Dimension MP006-A-P-SD PM006-A-P-SD Tape MP006-A-C-SD PM006-A-C-SD Reel MP006-A-R-SD PM006-A-R-SD Land − PM006-A-L-SD 5 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 4. Product name list 4. 1 S-13D1 Series B type ON / OFF logic: Constant current source pull-down: Active "H" Available Discharge shunt function: Delay function: Available Unavailable Table 3 Voltage Regulator 1 Voltage Regulator 2 SOT-23-6 HSNT-6 (1212) Output Voltage Output Voltage S-13D1B1218-A6T2U3 1.2 V ± 15 mV 1.8 V ± 1.0% S-13D1B1218-M6T1U3 S-13D1B1528-A6T2U3 1.5 V ± 1.0% 2.8 V ± 1.0% S-13D1B1528-M6T1U3 S-13D1B1812-A6T2U3 1.8 V ± 1.0% 1.2 V ± 15 mV S-13D1B1812-M6T1U3 S-13D1B1815-A6T2U3 1.8 V ± 1.0% 1.5 V ± 1.0% S-13D1B1815-M6T1U3 S-13D1B1818-A6T2U3 1.8 V ± 1.0% 1.8 V ± 1.0% S-13D1B1818-M6T1U3 S-13D1B1828-A6T2U3 1.8 V ± 1.0% 2.8 V ± 1.0% S-13D1B1828-M6T1U3 S-13D1B1833-A6T2U3 1.8 V ± 1.0% 3.3 V ± 1.0% S-13D1B1833-M6T1U3 S-13D1B2518-A6T2U3 2.5 V ± 1.0% 1.8 V ± 1.0% S-13D1B2518-M6T1U3 S-13D1B2818-A6T2U3 2.8 V ± 1.0% 1.8 V ± 1.0% S-13D1B2818-M6T1U3 S-13D1B2828-A6T2U3 2.8 V ± 1.0% 2.8 V ± 1.0% S-13D1B2828-M6T1U3 S-13D1B2833-A6T2U3 2.8 V ± 1.0% 3.3 V ± 1.0% S-13D1B2833-M6T1U3 S-13D1B2J2J-A6T2U3 2.85 V ± 1.0% 2.85 V ± 1.0% S-13D1B2J2J-M6T1U3 S-13D1B3018-A6T2U3 3.0 V ± 1.0% 1.8 V ± 1.0% S-13D1B3018-M6T1U3 S-13D1B3130-A6T2U3 3.1 V ± 1.0% 3.0 V ± 1.0% S-13D1B3130-M6T1U3 S-13D1B3330-A6T2U3 3.3 V ± 1.0% 3.0 V ± 1.0% S-13D1B3330-M6T1U3 S-13D1B3333-A6T2U3 3.3 V ± 1.0% 3.3 V ± 1.0% S-13D1B3333-M6T1U3 Remark Please contact our sales office for products with specifications other than the above. 4. 2 S-13D1 Series C type ON / OFF logic: Constant current source pull-down: Active "H" Available Discharge shunt function: Delay function: Available Available Table 4 Voltage Regulator 1 Voltage Regulator 2 SOT-23-6 HSNT-6 (1212) Output Voltage Output Voltage S-13D1C1218-M6T1U3 S-13D1C1218-A6T2U3 1.2 V ± 15 mV 1.8 V ± 1.0% S-13D1C1528-M6T1U3 S-13D1C1528-A6T2U3 1.5 V ± 1.0% 2.8 V ± 1.0% S-13D1C1818-M6T1U3 S-13D1C1818-A6T2U3 1.8 V ± 1.0% 1.8 V ± 1.0% S-13D1C1828-M6T1U3 S-13D1C1828-A6T2U3 1.8 V ± 1.0% 2.8 V ± 1.0% S-13D1C1833-M6T1U3 S-13D1C1833-A6T2U3 1.8 V ± 1.0% 3.3 V ± 1.0% S-13D1C2828-M6T1U3 S-13D1C2828-A6T2U3 2.8 V ± 1.0% 2.8 V ± 1.0% S-13D1C2833-M6T1U3 S-13D1C2833-A6T2U3 2.8 V ± 1.0% 3.3 V ± 1.0% S-13D1C2J2J-M6T1U3 S-13D1C2J2J-A6T2U3 2.85 V ± 1.0% 2.85 V ± 1.0% S-13D1C3636-M6T1U3 S-13D1C3636-A6T2U3 3.6 V ± 1.0% 3.6 V ± 1.0% Remark Please contact our sales office for products with specifications other than the above. 6 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 4. 3 S-13D1 Series D type ON / OFF logic: Constant current source pull-down: Active "H" Unavailable Discharge shunt function: Delay function: Unavailable Unavailable Table 5 Voltage Regulator 1 Voltage Regulator 2 SOT-23-6 HSNT-6 (1212) Output Voltage Output Voltage S-13D1D1218-M6T1U3 S-13D1D1218-A6T2U3 1.2 V ± 15 mV 1.8 V ± 1.0% S-13D1D1528-M6T1U3 S-13D1D1528-A6T2U3 1.5 V ± 1.0% 2.8 V ± 1.0% S-13D1D1818-M6T1U3 S-13D1D1818-A6T2U3 1.8 V ± 1.0% 1.8 V ± 1.0% S-13D1D1828-M6T1U3 S-13D1D1828-A6T2U3 1.8 V ± 1.0% 2.8 V ± 1.0% S-13D1D1833-M6T1U3 S-13D1D1833-A6T2U3 1.8 V ± 1.0% 3.3 V ± 1.0% S-13D1D2828-M6T1U3 S-13D1D2828-A6T2U3 2.8 V ± 1.0% 2.8 V ± 1.0% S-13D1D2833-M6T1U3 S-13D1D2833-A6T2U3 2.8 V ± 1.0% 3.3 V ± 1.0% S-13D1D2J2J-M6T1U3 S-13D1D2J2J-A6T2U3 2.85 V ± 1.0% 2.85 V ± 1.0% Remark Please contact our sales office for products with specifications other than the above. 7 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Pin Configurations 1. SOT-23-6 Table 6 Top view 6 5 4 1 2 3 Pin No. 1 2 3 4 5 6 Symbol ON / OFF1 VIN ON / OFF2 VOUT2 VSS VOUT1 Pin No. 1 2 3 4 5 6 Symbol VOUT1 VOUT2 VSS ON / OFF2 VIN ON / OFF1 Description ON / OFF 1 pin Input voltage pin ON / OFF 2 pin Output voltage 2 pin GND pin Output voltage 1 pin Figure 7 2. HSNT-6 (1212) Table 7 Top view 1 2 3 6 5 4 Bottom view 6 5 4 1 2 3 Description Output voltage 1 pin Output voltage 2 pin GND pin ON / OFF 2 pin Input voltage pin ON / OFF 1 pin *1 Figure 8 *1. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. 8 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Absolute Maximum Ratings Table 8 Item Symbol VIN VON / OFF1, VON / OFF2 VOUT1, VOUT2 IOUT1, IOUT2 Input voltage Output voltage Output current SOT-23-6 PD HSNT-6 (1212) Operation ambient temperature Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Name: JEDEC STANDARD51-7 Power dissipation VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VSS + 6.0 VSS − 0.3 to VIN + 0.3 200 650*1 480*1 −40 to +85 −40 to +125 V V V mA mW mW °C °C The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 1200 Power Dissipation (PD) [mW] Caution (Ta = +25°C unless otherwise specified) Absolute Maximum Rating Unit 1000 HSNT-6 (1212) 800 SOT-23-6 600 400 200 0 0 Figure 9 150 100 50 Ambient Temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) 9 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Power Dissipation of HSNT-6 (1212) (Reference) Power dissipation of package differs depending on the mounting conditions. Consider the power dissipation characteristics under the following conditions as reference. [Mounted board] (1) Board size: (2) Board material: (3) Wiring ratio: (4) Test conditions: (5) Land pattern: 40 mm × 40 mm × t0.8 mm Glass epoxy resin (four layers) 50% When mounted on board (wind speed: 0 m/s) Refer to the recommended land pattern (drawing code: PM006-A-L-SD) Power Dissipation (PD) [mW] 1200 1000 800 600 400 200 0 0 Figure 10 150 100 50 Ambient Temperature (Ta) [°C] Power Dissipation of Package (When Mounted on Board) Table 9 Condition HSNT-6 (1212) (When mounted on board) 10 Power Dissipation (Reference) 1000 mW Thermal Resistance Value (θj−a) 100°C/W 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Electrical Characteristics (per Circuit) Table 10 (1 / 2) Item Symbol Output voltage*1 Output current *2 VOUT(E) IOUT Condition 1.0 V ≤ VOUT(S) < 1.5 V VIN = VOUT(S) + 1.0 V, IOUT = 30 mA 1.5 V ≤ VOUT(S) ≤ 3.6 V VIN ≥ VOUT(S) + 1.0 V 1.0 V ≤ VOUT(S) < 1.1 V 1.1 V ≤ VOUT(S) < 1.2 V 1.2 V ≤ VOUT(S) < 1.3 V 1.3 V ≤ VOUT(S) < 1.4 V 1.4 V ≤ VOUT(S) < 1.5 V 1.5 V ≤ VOUT(S) < 1.7 V 1.7 V ≤ VOUT(S) < 2.1 V 2.1 V ≤ VOUT(S) < 2.5 V 2.5 V ≤ VOUT(S) < 2.8 V 2.8 V ≤ VOUT(S) ≤ 3.6 V Dropout voltage*3 Vdrop Line regulation ΔVOUT1 VOUT(S) + 0.5 V ≤ VIN ≤ 5.5 V, IOUT = 30 mA ΔVIN • VOUT Load regulation ΔVOUT2 Output voltage temperature coefficient*4 Current consumption during operation (2 circuits) Current consumption during operation (per circuit) Current consumption during power-off Input voltage ON / OFF pin input voltage "H" ON / OFF pin input voltage "L" ON / OFF pin input current "H" ON / OFF pin input current "L" Ripple rejection Short-circuit current IOUT = 100 mA (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit VOUT(S) VOUT(S) V V 1, 2 − 0.015 OUT(S) + 0.015 VOUT(S) VOUT(S) VOUT(S) V 1, 2 × 0.99 × 1.01 *5 mA 4, 5 150 − − 0.5 0.52 0.54 V 1, 2 − 0.42 0.44 V 1, 2 − 0.32 0.34 V 1, 2 − 0.22 0.24 V 1, 2 − 0.15 0.22 V 1, 2 − 0.14 0.21 V 1, 2 − 0.12 0.19 V 1, 2 − 0.10 0.16 V 1, 2 − 0.09 0.14 V 1, 2 − 0.08 0.13 V 1, 2 − 0.02 0.2 %/V 1, 2 VIN = VOUT(S) + 1.0 V, 1 mA ≤ IOUT ≤ 150 mA − 15 40 mV 1, 2 ΔVOUT ΔTa • VOUT VIN = VOUT(S) + 1.0 V, IOUT = 30 mA, −40°C ≤ Ta ≤ + 85°C − ±100 − ppm/°C 1, 2 ISS VIN = 5.5 V, ON / OFF pin = ON, no load − 78 116 μA 3 ISS1 VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, no load − 39 58 μA 3 − 0.1 1.0 μA 3 VIN VIN = VOUT(S) + 1.0 V, ON / OFF pin = OFF, no load − 1.5 − 5.5 V − VSH VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ 1.0 − − V 6, 7 VSL VIN = VOUT(S) + 1.0 V, RL = 1.0 kΩ − − 0.25 V 6, 7 0.15 0.30 0.60 μA 6, 7 −0.1 − 0.1 μA 6, 7 −0.1 − 0.1 μA 6, 7 1.0 V ≤ VOUT(S) ≤ 2.0 V − 75 − dB 8, 9 2.0 V < VOUT(S) ≤ 3.0 V − 72 − dB 8, 9 3.0 V < VOUT(S) ≤ 3.6 V − 70 − dB 8, 9 − 40 − mA 4, 5 ISS2 ISH ISL RR Ishort VIN = 5.5 V, VON / OFF = 5.5 V A / B / C type (with constant current source pull-down) D / E / F type (without constant current source pull-down) VIN = 5.5 V, VON / OFF = 0 V VIN = VOUT(S) + 1.0 V, f = 1.0 kHz, ΔVrip = 0.5 Vrms, IOUT = 30 mA VIN = VOUT(S) + 1.0 V, ON / OFF pin = ON, VOUT = 0 V 11 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Table 10 (2 / 2) Item Thermal shutdown detection temperature Thermal shutdown release temperature Symbol Condition (Ta = +25°C unless otherwise specified) Test Min. Typ. Max. Unit Circuit TSD Junction temperature − 160 − °C − TSR Junction temperature − 130 − °C − VOUT2 pin of C / F type (with delay function) VIN = 5.5 V, VOUT1 pin of C / F type VOUT = 0.1 V (with delay function) B / E type (without delay function) VIN ≥ VOUT(S) + 1.0 V, ON / OFF1 pin and ON / OFF2 pin are set to ON simultaneously, RL = 1.0 kΩ, CL1, CL2 = 0.22 μF − 12 − Ω 4, 5 − 50 − Ω 4, 5 50 100 − μs 10 Discharge shunt resistance during power-off (With discharge shunt function) RLOW Delay time*6 (C / F type only) tDELAY *1. VOUT(S): Set output voltage VOUT(E): Actual output voltage Output voltage when fixing IOUT (= 30 mA) and inputting VOUT(S) + 1.0 V *2. The output current at which the output voltage becomes 95% of VOUT(E) after gradually increasing the output current. *3. Vdrop = VIN1 − (VOUT3 × 0.98) VOUT3 is the output voltage when VIN = VOUT(S) + 1.0 V and IOUT = 100 mA. VIN1 is the input voltage at which the output voltage becomes 98% of VOUT3 after gradually decreasing the input voltage. *4. A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient *5. The output current can be at least this value. Due to restrictions on the package power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation of the package when the output current is large. This specification is guaranteed by design. *6. Delay time shows the time period from when VOUT1 pin voltage reaches 50% of the set output voltage until VOUT2 pin voltage reaches 50% of the set output voltage, when the ON / OFF1 pin and the ON / OFF2 pin are set to ON simultaneously. Refer to "8. Delay function (S-13D1 Series C / F type)" in " Operation" for details. 12 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Test Circuits + A + V VIN VOUT2 *1 VOUT1 ON / OFF2 ON / OFF1 VSS *2 *1. Set to OFF *2. Set to ON Figure 11 A Test Circuit 1 + VIN VOUT2 + V *1 VOUT1 ON / OFF2 ON / OFF1 VSS *2 *1. Set to ON *2. Set to OFF (set to ON in case of C / F type) Figure 12 + Test Circuit 2 A VIN VOUT2 *1 *1. VOUT1 ON / OFF2 ON / OFF1 VSS *1 Set to VIN or GND Figure 13 Test Circuit 3 VIN VOUT2 *1 A VOUT1 ON / OFF2 ON / OFF1 VSS *2 + V *1. Set to OFF *2. Set to VIN or GND Figure 14 Test Circuit 4 13 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series VIN A VOUT2 + V *1. *2. *1 VOUT1 ON / OFF2 ON / OFF1 VSS *2 Set to VIN or GND Set to OFF (set to ON in case of C / F type) Figure 15 Test Circuit 5 VIN VOUT2 *1 *1. VOUT1 A ON / OFF2 ON / OFF1 VSS + + V RL Set to OFF Figure 16 Test Circuit 6 VIN RL *1. + + VOUT2 A V VOUT1 ON / OFF2 ON / OFF1 VSS *1 Set to OFF (set to ON in case of C / F type) Figure 17 Test Circuit 7 VIN VOUT2 *1 *1. *2. 14 ON / OFF2 ON / OFF1 VSS Set to OFF Set to ON Figure 18 VOUT1 Test Circuit 8 *2 + V RL 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series VIN VOUT2 + V RL *1. *2. *1 VOUT1 ON / OFF2 ON / OFF1 VSS *2 Set to ON Set to OFF (set to ON in case of C / F type) Figure 19 Test Circuit 9 Oscilloscope Oscilloscope VIN VOUT2 VOUT1 ON / OFF2 ON / OFF1 VSS RL Figure 20 RL Test Circuit 10  Standard Circuit Input VIN ON / OFF1 CIN*1 Output1 VOUT1 CL1 *2 ON / OFF2 VOUT2 *2 CL2 VSS Output2 GND Single GND *1. *2. CIN is a capacitor for stabilizing the input. A ceramic capacitor of 0.22 μF or more can be used as CL1 and CL2. Figure 21 Caution The above connection diagram and constants will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constants. 15 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Condition of Application 0.22 μF or more Input capacitor (CIN): Output capacitors (CL1, CL2): 0.22 μF or more Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the application for which the above capacitors are used.  Selection of Input and Output Capacitors (CIN, CL1, CL2) The S-13D1 Series requires an output capacitor between the VOUT pin and the VSS pin for phase compensation. Operation is stabilized by a ceramic capacitor with an output capacitance of 0.22 μF or more over the entire temperature range. When using an OS capacitor, a tantalum capacitor, or an aluminum electrolytic capacitor, the capacitance must be 0.22 μF or more. The value of the output overshoot or undershoot transient response varies depending on the value of the output capacitor. The required capacitance of the input capacitor differs depending on the application. The recommended capacitance for an application is CIN ≥ 0.22 μF, CL1 ≥ 0.22 μF, CL2 ≥ 0.22 μF; however, when selecting the output capacitor, perform sufficient evaluation, including evaluation of temperature characteristics, on the actual device.  Explanation of Terms 1. Low dropout voltage regulator This voltage regulator has the low dropout voltage due to its built-in low on-resistance transistor. 2. Output voltage (VOUT) The accuracy of the output voltage is ensured at ±1.0% or ±15 mV*1 under the specified conditions of fixed input voltage*2, fixed output current, and fixed temperature. *1. *2. When VOUT < 1.5 V: ±15 mV, When VOUT ≥ 1.5 V: ±1.0% Differs depending on the product. Caution 3. If the above conditions change, the output voltage value may vary and exceed the accuracy range of the output voltage. Refer to " Electrical Characteristics (per Circuit)" and " Characteristics (Typical Data) (per Circuit)" for details. ΔVOUT1  Line regulation  ΔVIN•VOUT  Indicates the dependency of the output voltage on the input voltage. That is, the values show how much the output voltage changes due to a change in the input voltage with the output current remaining unchanged. 4. Load regulation (ΔVOUT2) Indicates the dependency of the output voltage on the output current. That is, the values show how much the output voltage changes due to a change in the output current with the input voltage remaining unchanged. 5. Dropout voltage (Vdrop) Indicates the difference between input voltage (VIN1) and the output voltage when; decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3), which is at VIN = VOUT(S) + 1.0 V. Vdrop = VIN1 − (VOUT3 × 0.98) 16 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 6. ΔVOUT  Output voltage temperature coefficient  ΔTa•VOUT  The shaded area in Figure 22 is the range where VOUT varies in the operation temperature range when the output voltage temperature coefficient is ±100 ppm/°C. Example of S-13D1B3333 typ. product VOUT [V] +0.33 mV/°C *1 VOUT(E) −0.33mV/°C −40 *1. +25 +85 Ta [°C] VOUT(E) is the value of the output voltage measured at Ta = +25°C. Figure 22 A change in the temperature of the output voltage [mV/°C] is calculated using the following equation. ΔVOUT ΔVOUT [mV/°C]*1 = VOUT(S) [V]*2 × ΔTa•V [ppm/°C]*3 ÷ 1000 ΔTa OUT *1. Change in temperature of output voltage *2. Set output voltage *3. Output voltage temperature coefficient 17 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Operation 1. Basic operation Figure 23 shows the block diagram of the S-13D1 Series. The error amplifier compares the reference voltage (Vref) with feedback voltage (Vfb), which is the output voltage resistance-divided by feedback resistors (Rs and Rf). It supplies the gate voltage necessary to maintain the constant output voltage which is not influenced by the input voltage and temperature change, to the output transistor. VIN *1 Current supply Error amplifier Vref VOUT − Rf + Vfb Reference voltage circuit Rs VSS *1. Parasitic diode Figure 23 2. Output transistor In the S-13D1 Series, a low on-resistance P-channel MOS FET is used as the output transistor. Be sure that VOUT does not exceed VIN + 0.3 V to prevent the voltage regulator from being damaged due to reverse current flowing from the VOUT pin through a parasitic diode to the VIN pin, when the potential of VOUT became higher than VIN. 18 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 3. ON / OFF pin This pin starts and stops the regulator. When the ON / OFF pin is set to OFF level, the entire internal circuit stops operating, and the built-in P-channel MOS FET output transistor between the VIN pin and the VOUT pin is turned off, reducing current consumption significantly. Note that the current consumption increases when a voltage of 0.3 V to VIN − 0.3 V is applied to the ON / OFF pin. The ON / OFF pin is configured as shown in Figure 24 and Figure 25. 3. 1 S-13D1 Series A / B / C type The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. 3. 2 S-13D1 Series D / E / F type The ON / OFF pin is not internally pulled down to the VSS pin, so do not use it in the floating status. When not using the ON / OFF pin, connect the pin to the VIN pin. Product Type A/B/C/D/E/F A/B/C/D/E/F ON / OFF Pin "H": ON "L": OFF Table 11 Internal Circuit Operate Stop VOUT Pin Voltage Set value VSS level Current Consumption ISS1*1 ISS2 *1. Note that the IC's current consumption increases as much as current flows into the constant current of 0.3 μA typ. when the ON / OFF pin is connected to VIN pin and the S-13D1 Series A / B / C type is operating (refer to Figure 24). VIN ON / OFF VIN ON / OFF VSS Figure 24 S-13D1 Series A / B / C Type VSS Figure 25 S-13D1 Series D / E / F Type 19 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 4. Discharge shunt function (S-13D1 Series B / C / E / F type) The S-13D1 Series B / C / E / F type has a built-in discharge shunt circuit to discharge the output capacitance. The output capacitance is discharged as follows so that the VOUT pin reaches the VSS level. (1) The ON / OFF pin is set to OFF level. (2) The output transistor is turned off. (3) The discharge shunt circuit is turned on. (4) The output capacitor discharges. Since the S-13D1 Series A / D type does not have a discharge shunt circuit, the VOUT pin is set to the VSS level through several hundred kΩ internal divided resistors between the VOUT pin and the VSS pin. The S-13D1 Series B / C / E / F type allows the VOUT pin to reach the VSS level rapidly due to the discharge shunt circuit. S-13D1 Series Output transistor: OFF *1 VOUT VIN Discharge shunt circuit : ON *1 ON / OFF ON / OFF circuit Output capacitor (CL) ON / OFF pin: OFF Current flow GND VSS *1. Parasitic diode Figure 26 20 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Moreover, C / F type in the S-13D1 Series, if the ON / OFF1 pin and the ON / OFF2 pin are set to OFF simultaneously, the discharge shunt on-resistance connected with the VOUT2 pin is reduced in order to make it easy for VOUT2 pin voltage to fall previously. Table 12 Product Type VOUT2 pin of C / F type VOUT1 pin of C / F type, and B / E type Discharge Shunt ON-resistance (VIN = 5.5 V, VOUT = 0.1 V) 12 Ω 50 Ω ON / OFF1, ON / OFF2 VOUT1 VOUT2 Figure 27 50 Ω Discharge 12 Ω Discharge Discharge Shunt Function of S-13D1 Series C / F Type 21 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 5. Constant current source pull-down (S-13D1 Series A / B / C type) The ON / OFF pin is internally pulled down to the VSS pin in the floating status, so the VOUT pin is set to the VSS level. Note that the IC's current consumption increases as much as current flows into the constant current of 0.3 μA typ. when the ON / OFF pin is connected to the VIN pin and the S-13D1 Series A / B / C type is operating. 6. Overcurrent protection circuit The S-13D1 Series includes an overcurrent protection circuit which has the characteristics shown in "1. Output voltage vs. Output current (When load current increases) (Ta = +25°C)" in " Characteristics (Typical Data) (per Circuit)", in order to protect the output transistor against an excessive output current and short circuiting between the VOUT pin and the VSS pin. The current when the output pin is short-circuited (Ishort) is internally set at approx. 40 mA typ., and the normal value is restored for the output voltage, if releasing a short circuit once. Caution This overcurrent protection circuit does not work as for thermal protection. If this IC long keeps short circuiting inside, pay attention to the conditions of input voltage and load current so that, under the usage conditions including short circuit, the loss of the IC will not exceed power dissipation of the package. 7. Thermal shutdown circuit The S-13D1 Series has a thermal shutdown circuit to protect the device from damage due to overheat. When the junction temperature rises to 160°C typ., the thermal shutdown circuit operates to stop regulating. When the junction temperature drops to 130°C typ., the thermal shutdown circuit is released to restart regulating. Due to self-heating of the S-13D1 Series, if the thermal shutdown circuit starts operating, it stops regulating so that the output voltage drops. When regulation stops, the S-13D1 Series does not itself generate heat and the IC's temperature drops. When the temperature drops, the thermal shutdown circuit is released to restart regulating, thus the S-13D1 Series generates heat again. Repeating this procedure makes the waveform of the output voltage into a pulse-like form. Stop or restart of regulation continues unless decreasing either or both of the input voltage and the output current in order to reduce the internal power consumption, or decreasing the ambient temperature. Table 13 Thermal Shutdown Circuit Operate: 160°C typ.*1 Release: 130°C typ.*1 *1. Junction temperature 22 VOUT Pin Voltage VSS level Set value 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 8. Delay function (S-13D1 Series C / F type) C / F type in the S-13D1 Series has a built-in delay function that sets the difference of rising time between channels. If the ON / OFF1 pin and the ON / OFF2 pin are set to ON simultaneously, VOUT2 pin voltage rises after the delay time (tDELAY = 100 μs typ.). ON / OFF1, ON / OFF2 50% of the set output voltage tDELAY = 100 μs typ. VOUT1 50% of the set output voltage VOUT2 Figure 28 8. 1 In case ON / OFF2 pin is set to ON later The VOUT1 pin voltage rises simultaneously when the ON / OFF1 pin is set to ON. After the ON / OFF2 pin is set to ON, VOUT2 pin voltage rises in 100 μs typ. ON / OFF1 ON / OFF2 VOUT1 100 μs typ. VOUT2 Figure 29 8. 2 In case ON / OFF2 pin is set to ON previously VOUT2 pin voltage does no rise even if the ON / OFF2 pin is set to ON. VOUT1 pin voltage rises if the ON / OFF1 pin is set to ON. After VOUT1 pin voltage rises, VOUT2 pin voltage rises in 100 μs typ. Current comsumption < 10 μA ON / OFF1 ON / OFF2 VOUT1 100 μs typ. VOUT2 Figure 30 Caution Note that the current consumption of less than 10 μA flows during the time period from when the ON / OFF2 pin is set to ON until the ON / OFF1 pin is set to ON. 23 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting the output capacitors between the VOUT pin and the VSS pin (CL1, CL2) and a capacitor for stabilizing the input between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (1.0 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output driver when a series regulator is used at high temperature. • Note that the output voltage may increase due to the leakage current from an output driver even if the ON / OFF pin is at OFF level when a series regulator is used at a high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-13D1 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to "6. Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C)" in " Reference Data (per Circuit)" for the equivalent series resistance (RESR) of the output capacitors. Input capacitor (CIN): Output capacitors (CL1, CL2): 0.22 μF or more 0.22 μF or more • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • If the output capacitance is small, power supply's fluctuation and the characteristics of load fluctuation become worse. Sufficiently evaluate the output voltage's fluctuation with the actual device. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at power-on with the actual device. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the package power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 10 in " Electrical Characteristics (per Circuit)" and footnote *5 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 24 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Characteristics (Typical Data) (per Circuit) Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 1 VOUT = 1.0 V 1. 2 1.2 1.0 VOUT [V] 0.8 2.5 VIN = 2.0 V VIN = 3.0 V VIN = 5.5 V VIN = 1.3 V 0.6 0.4 0.2 1.0 100 200 300 IOUT [mA] 400 500 0 100 200 300 IOUT [mA] 400 500 VOUT = 3.6 V 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT [V] 1.5 0 0 VIN = 4.6 V VIN = 5.5 V VIN = 3.9 V VIN = 4.1 V 0 100 200 300 IOUT [mA] 400 Remark In determining the output current, attention should be paid to the following. 1. The minimum output current value and footnote *5 in Table 10 in " Electrical Characteristics (per Circuit)" 2. The package power dissipation 500 Output voltage vs. Input voltage (Ta = +25°C) VOUT [V] 2. 1 VOUT = 1.0 V 2. 2 3.0 1.0 2.5 0.8 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 0.6 0.4 0.2 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 1.5 1.0 0 0 VOUT [V] 2.0 0.5 0 2. 3 VOUT = 2.5 V 1.2 VOUT [V] 2. VIN = 3.5 V VIN = 4.5 V VIN = 5.5 V VIN = 2.8 V VIN = 3.0 V 2.0 0.5 0 1. 3 VOUT = 2.5 V 3.0 VIN = 1.5 V VOUT [V] 1. 1 2 3 VIN [V] 4 5 6 0 1 2 3 VIN [V] 4 5 6 VOUT = 3.6 V 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 IOUT = 1 mA IOUT = 30 mA IOUT = 50 mA IOUT = 100 mA 0 1 2 3 VIN [V] 4 5 6 25 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Dropout voltage vs. Output current Vdrop [V] 3. 1 VOUT = 1.0 V 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 Ta = +85°C Ta = +25°C Ta = −40°C 0 25 50 100 75 IOUT [mA] 125 150 125 150 VOUT = 3.6 V Vdrop [V] Ta = +85°C Ta = +25°C Ta = −40°C 0.10 0.05 0 0 Vdrop [V] 0.10 0.05 0.15 25 50 100 75 IOUT [mA] Dropout voltage vs. Set output voltage (Ta = +25°C) 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 IOUT = 150 mA IOUT = 100 mA IOUT = 50 mA IOUT = 30 mA IOUT = 10 mA IOUT = 1 mA 1.0 26 Ta = +85°C Ta = +25°C Ta = −40°C 0.15 0.20 4. VOUT = 2.5 V 0.20 0 3. 3 3. 2 Vdrop [V] 3. 1.5 2.0 2.5 3.0 VOUT(S) [V] 3.5 4.0 0 25 50 100 75 IOUT [mA] 125 150 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Output voltage vs. Ambient temperature 5. 1 VOUT = 1.0 V VOUT [V] 1.05 1.04 1.03 1.02 1.01 1.00 0.99 0.98 0.97 0.96 0.95 −40 −25 5. 3 0 25 Ta [°C] 50 75 85 0 25 Ta [°C] 50 75 85 VOUT = 2.5 V 2.55 2.54 2.53 2.52 2.51 2.50 2.49 2.48 2.47 2.46 2.45 −40 −25 0 25 Ta [°C] 75 85 50 VOUT = 3.6 V VOUT [V] 3.65 3.64 3.63 3.62 3.61 3.60 3.59 3.58 3.57 3.56 3.55 −40 −25 Current consumption vs. Input voltage ISS1 [μA] 6. 1 VOUT = 1.0 V 6. 2 60 50 50 40 Ta = −40°C Ta = +25°C Ta = +85°C 30 20 10 40 Ta = −40°C Ta = +25°C Ta = +85°C 30 20 10 0 0 0 6. 3 VOUT = 2.5 V 60 ISS1 [μA] 6. 5. 2 VOUT [V] 5. 1 2 3 VIN [V] 4 5 6 4 5 6 0 1 2 3 VIN [V] 4 5 6 VOUT = 3.6 V 60 ISS1 [μA] 50 Ta = −40°C Ta = +25°C Ta = +85°C 40 30 20 10 0 0 1 2 3 VIN [V] 27 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 7. Ripple rejection (Ta = +25°C) 7. 1 VOUT = 1.0 V 7. 2 VOUT = 2.5 V 120 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 40 20 0 10 7. 3 100 1k 10k 100k Frequency [Hz] VIN = 3.5 V, CLn = 0.22 μF Ripple Rejection [dB] Ripple Rejection [dB] VIN = 2.0 V, CLn = 0.22 μF 120 100 80 60 20 0 1M VOUT = 3.6 V Ripple Rejection [dB] VIN = 4.6 V, CLn = 0.22 μF 120 100 80 60 IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 40 20 0 10 Remark 28 100 1k 10k 100k Frequency [Hz] IOUT = 1 mA IOUT = 30 mA IOUT = 100 mA 40 1M CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 10 100 1k 10k 100k Frequency [Hz] 1M 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Reference Data (per Circuit) Transient response characteristics when input (Ta = +25°C) 1. 1 VOUT = 1.0 V 1. 2 VOUT = 2.5 V IOUT = 30 mA, CLn = 0.22 μF, VIN = 3.5 V ↔ 4.5 V, tr = tf = 5.0 μs VOUT −40 −20 0 1. 3 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 VOUT [V] VIN 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 −0.5 −1.0 VIN [V] 1.14 1.12 1.10 1.08 1.06 1.04 1.02 1.00 0.98 0.96 0.94 VIN [V] VOUT [V] IOUT = 30 mA, CIN = CLn = 0.22 μF, VIN = 2.0 V ↔ 3.0 V, tr = tf = 5.0 μs 2.65 2.63 2.61 2.59 2.57 2.55 2.53 2.51 2.49 2.47 2.45 VIN VOUT −40 −20 0 20 40 60 80 100 120 140 t [μs] 6.0 5.5 5.0 4.5 4.0 3.5 3.0 2.5 2.0 1.5 1.0 20 40 60 80 100 120 140 t [μs] VOUT = 3.6 V VOUT [V] IOUT = 30 mA, CLn = 0.22 μF, VIN = 4.6 V ↔ 5.5 V, tr = tf = 5.0 μs 3.75 3.73 3.71 3.69 3.67 3.65 3.63 3.61 3.59 3.57 3.55 VIN VOUT −40 −20 0 Remark 20 40 60 80 100 120 140 t [μs] CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 29 VIN [V] 1. 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Transient response characteristics of load (Ta = +25°C) 2. 1 VOUT = 1.0 V 2. 2 VOUT = 2.5 V VOUT −40 −20 0 2. 3 140 120 100 80 60 40 20 0 −20 −40 −60 VOUT [V] IOUT 140 120 100 80 60 40 20 0 −20 −40 −60 IOUT [mA] VOUT [V] 1.35 1.30 1.25 1.20 1.15 1.10 1.05 1.00 0.95 0.90 0.85 VIN = 3.5 V, CIN = CLn = 0.22 μF, IOUT = 50 mA ↔ 100 mA IOUT [mA] VIN = 2.0 V, CIN = CLn = 0.22 μF, IOUT = 50 mA ↔ 100 mA 2.90 2.85 2.80 2.75 2.70 2.65 2.60 2.55 2.50 2.45 2.40 IOUT VOUT −40 −20 0 20 40 60 80 100 120 140 t [μs] VOUT = 3.6 V VOUT [V] VIN = 4.6 V, CIN = CLn = 0.22 μF, IOUT = 50 mA ↔ 100 mA 4.00 3.95 3.90 3.85 3.80 3.75 3.70 3.65 3.60 3.55 3.50 IOUT VOUT −40 −20 0 Remark 30 140 120 100 80 60 40 20 0 −20 −40 −60 20 40 60 80 100 120 140 t [μs] CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 20 40 60 80 100 120 140 t [μs] IOUT [mA] 2. 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Transient response characteristics of load’s mutual interference (Ta = +25°C) VOUT1 = VOUT2 = 1.0 V VOUT1 [V] VOUT2 [V] VOUT1 = VOUT2 = 2.5 V VIN = 3.5 V, CIN = CLn = 0.22 μF, IOUT2 = 50 mA ↔ 100 mA 120 100 IOUT2 80 60 40 2.60 2.55 VOUT2 2.50 2.45 2.40 2.60 2.55 2.50 VOUT1 2.45 2.40 2.35 −40 −20 0 20 40 60 80 100 120 140 t [μs] VOUT2 [V] VOUT2 [V] VOUT1 [V] VOUT1 [V] IOUT1 [mA] VIN = 3.5 V, CIN = CLn = 0.22 μF, IOUT1 = 50 mA ↔ 100 mA 120 100 IOUT1 80 60 40 2.60 2.55 VOUT2 2.50 2.45 2.40 2.60 2.55 2.50 VOUT1 2.45 2.40 2.35 −40 −20 0 20 40 60 80 100 120 140 t [μs] 3. 3 VOUT1 = VOUT2 = 3.6 V IOUT2 [mA] 3. 2 VIN = 2.0 V, CIN = CLn = 0.22 μF, IOUT2 = 50 mA ↔ 100 mA 120 100 IOUT2 80 60 40 1.10 1.05 VOUT2 1.00 0.95 0.90 1.10 1.05 1.00 VOUT1 0.95 0.90 0.85 −40 −20 0 20 40 60 80 100 120 140 t [μs] IOUT2 [mA] IOUT1 [mA] VIN = 2.0 V, CIN = CLn = 0.22 μF, IOUT1 = 50 mA ↔ 100 mA 120 100 IOUT1 80 60 40 1.10 1.05 VOUT2 1.00 0.95 0.90 1.10 1.05 1.00 VOUT1 0.95 0.90 0.85 −40 −20 0 20 40 60 80 100 120 140 t [μs] VOUT2 [V] 3. 1 VOUT1 [V] 3. IOUT1 [mA] IOUT2 [mA] VOUT2 [V] VOUT2 [V] VOUT1 [V] Remark VIN = 4.6 V, CIN = CLn = 0.22 μF, IOUT2 = 50 mA ↔ 100 mA 120 100 IOUT2 80 60 40 3.70 3.65 VOUT2 3.60 3.55 3.50 3.70 3.65 3.60 VOUT1 3.55 3.50 3.45 −40 −20 0 20 40 60 80 100 120 140 t [μs] VOUT1 [V] VIN = 4.6 V, CIN = CLn = 0.22 μF, IOUT1 = 50 mA ↔ 100 mA 120 100 IOUT1 80 60 40 3.70 3.65 VOUT2 3.60 3.55 3.50 3.70 3.65 3.60 VOUT1 3.55 3.50 3.45 −40 −20 0 20 40 60 80 100 120 140 t [μs] CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 31 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Transient response characteristics of ON / OFF pin (Ta = +25°C) 4. 1 S-13D1 Series A / B / D / E type (without delay function) 4. 1. 1 VOUT = 1.0 V 4. 1. 2 VIN = 3.5 V, CIN = CLn = 0.22 μF, IOUT = 30 mA, VON / OFF = 0 V → 3.5 V, tr = 1.0 μs 6 6 2.0 4 5 VON / OFF 1.6 VOUT 1.2 2 0 1 −4 0 −40 80 120 160 200 240 t [μs] VOUT = 3.6 V VIN = 4.6 V, CIN = CLn = 0.22 μF, IOUT = 30 mA, VON / OFF = 0 V → 4.6 V, tr = 1.0 μs 7.2 6 VON / OFF 4.8 2 3.6 VOUT 2.4 0 −2 −4 1.2 −6 0 −40 Remark 32 4 VON / OFF [V] VOUT [V] 6.0 0 40 0 −6 0 4. 1. 3 2 VOUT 3 −4 0.4 40 4 4 −2 −2 0 6 VON / OFF 2 0.8 −40 VOUT [V] 2.4 VON / OFF [V] VOUT [V] VIN = 2.0 V, CIN = CLn = 0.22 μF, IOUT = 30 mA, VON / OFF = 0 V → 2.0 V, tr = 1.0 μs VOUT = 2.5 V 80 120 160 200 240 t [μs] CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) −6 0 40 80 120 160 200 240 t [μs] VON / OFF [V] 4. 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series S-13D1 Series C / F type (with delay function, when VON / OFF1 and VON / OFF2 are raised simultaneously) VOUT1 = VOUT2 = 1.0 V (2) VOUT2 (1) VOUT1 VIN = 2.0 V, CIN = CL2 = 0.22 μF, IOUT = 30 mA, VON / OFF2 = 0 V → 2.0 V, tr = 1.0 μs 2.4 4 2.0 VON / OFF1 1.6 VOUT1 1.2 2 0 0.8 −2 0.4 −4 −6 0 −40 4. 2. 2 0 40 1.2 −2 0.4 −4 −6 0 −40 0 40 80 120 160 200 240 t [μs] 4 6 6 4 5 2 VOUT1 3 0 2 −2 1 −4 VOUT2 [V] VON / OFF1 VIN = 3.5 V, CIN = CL2 = 0.22 μF, IOUT = 30 mA, VON / OFF2 = 0 V → 3.5 V, tr = 1.0 μs VON / OFF1 [V] VOUT1 [V] 0 (2) VOUT2 5 −6 0 0 40 6 VON / OFF2 4 4 2 3 VOUT2 0 2 −2 1 −4 −6 0 −40 80 120 160 200 240 t [μs] 0 40 80 120 160 200 240 t [μs] VOUT1 = VOUT2 = 3.6 V (2) VOUT2 (1) VOUT1 VIN = 4.6 V, CIN = CL1 = 0.22 μF, IOUT = 30 mA, VON / OFF1 = 0 V → 4.6 V, tr = 1.0 μs VIN = 4.6 V, CIN = CL2 = 0.22 μF, IOUT = 30 mA, VON / OFF2 = 0 V → 4.6 V, tr = 1.0 μs 6 7.2 6.0 4 6.0 VON / OFF1 4.8 2 3.6 VOUT1 2.4 0 −2 −4 1.2 −6 0 0 40 80 120 160 200 240 t [μs] VOUT2 [V] 7.2 VON / OFF1 [V] VOUT1 [V] 2 VOUT1 = VOUT2 = 2.5 V 6 −40 VOUT2 4 0.8 VIN = 3.5 V, CIN = CL1 = 0.22 μF, IOUT = 30 mA, VON / OFF1 = 0 V → 3.5 V, tr = 1.0 μs 4. 2. 3 VON / OFF2 1.6 80 120 160 200 240 t [μs] (1) VOUT1 −40 6 VON / OFF2 [V] 6 2.0 VOUT2 [V] 2.4 VON / OFF1 [V] VOUT1 [V] VIN = 2.0 V, CIN = CL1 = 0.22 μF, IOUT = 30 mA, VON / OFF1 = 0 V → 2.0 V, tr = 1.0 μs VON / OFF2 [V] 4. 2. 1 6 VON / OFF2 4.8 4 2 3.6 VOUT2 2.4 0 −2 −4 1.2 −6 0 −40 VON / OFF2 [V] 4. 2 0 40 80 120 160 200 240 t [μs] 33 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 5. Output capacitance vs. Characteristics of discharge time (Ta = +25°C) 5. 1 S-13D1 Series B / E type (with discharge shunt function, without delay funciton) 5. 1. 1 VOUT VIN = VOUT + 1.0 V, IOUT = no load, VON / OFF = VOUT + 1.0 V → VSS, tf = 1.0 μs tDSC [ms] 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT(S) = 1.0 V VOUT(S) = 2.5 V VOUT(S) = 3.6 V 0 2 4 6 8 CLn [μF] 10 12 Figure 31 5. 2 S-13D1 Series C / F type (with discharge shunt function, with delay funciton) 5. 2. 1 VOUT1 5. 2. 2 4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0 VOUT(S) = 1.0 V VOUT(S) = 2.5 V VOUT(S) = 3.6 V 0 2 4 6 8 CL1 [μF] tDSC [ms] tDSC [ms] VIN = VOUT1 + 1.0 V, IOUT1 = no load, VON / OFF1 = VOUT1 + 1.0 V → VSS, tf = 1.0 μs 10 12 VIN = VOUT2 + 1.0 V, IOUT2 = no load, VON / OFF2 = VOUT2 + 1.0 V → VSS, tf = 1.0 μs 4.0 3.5 3.0 2.5 2.0 VOUT(S) = 1.0 V 1.5 VOUT(S) = 2.5 V 1.0 VOUT(S) = 3.6 V 0.5 0 0 2 4 6 8 10 12 CL2 [μF] Figure 32 Figure 33 1 μs VON / OFF VSS tDSC VOUT VOUT × 10% VIN = VOUT + 1.0 V VON / OFF = VOUT + 1.0 V → VSS Figure 34 Remark 34 VOUT2 Measurement Condition of Discharge Time CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series Example of equivalent series resistance vs. Output current characteristics (Ta = +25°C) 6. CIN = CLn = 0.22 μF 100 RESR [Ω] VIN CIN Stable VOUT S-13D1 Series CLn ON / OFF 0 0.1 VSS 200 *1 RESR IOUT [mA] *1. CLn: TDK Corporation C2012X7R1H224K (0.22 μF) Figure 35 Remark Figure 36 CLn: Output capacitor set to the VOUTn pin externally (n = 1, 2) 35 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series  Marking Specifications 1. SOT-23-6 Top view 6 5 4 (1) to (3): (4): Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) 1 2 3 Product name vs. Product code 1. 1 S-13D1 Series B type Product Name S-13D1B1218-M6T1U3 S-13D1B1528-M6T1U3 S-13D1B1812-M6T1U3 S-13D1B1815-M6T1U3 S-13D1B1818-M6T1U3 S-13D1B1828-M6T1U3 S-13D1B1833-M6T1U3 S-13D1B2518-M6T1U3 S-13D1B2818-M6T1U3 S-13D1B2828-M6T1U3 S-13D1B2833-M6T1U3 S-13D1B2J2J-M6T1U3 S-13D1B3018-M6T1U3 S-13D1B3130-M6T1U3 S-13D1B3330-M6T1U3 S-13D1B3333-M6T1U3 1. 3 S-13D1 Series D type Product Name S-13D1D1218-M6T1U3 S-13D1D1528-M6T1U3 S-13D1D1818-M6T1U3 S-13D1D1828-M6T1U3 S-13D1D1833-M6T1U3 S-13D1D2828-M6T1U3 S-13D1D2833-M6T1U3 S-13D1D2J2J-M6T1U3 36 1. 2 Product Code (1) (2) (3) 1 5 K 1 6 B 1 5 G 1 5 H 1 5 L 1 5 N 1 6 A 1 5 J 1 5 F 1 5 O 1 5 P 1 5 Q 1 5 A 1 5 D 1 5 C 1 5 B (1) 1 1 1 1 1 1 1 1 Product Code (2) (3) 7 A 7 H 7 B 7 C 7 G 7 D 7 E 7 F S-13D1 Series C type Product Name S-13D1C1218-M6T1U3 S-13D1C1528-M6T1U3 S-13D1C1818-M6T1U3 S-13D1C1828-M6T1U3 S-13D1C1833-M6T1U3 S-13D1C2828-M6T1U3 S-13D1C2833-M6T1U3 S-13D1C2J2J-M6T1U3 S-13D1C3636-M6T1U3 (1) 1 1 1 1 1 1 1 1 1 Product Code (2) (3) 5 U 5 3 5 V 5 X 5 2 5 Y 5 Z 5 1 5 S 5.5 V INPUT, 150 mA, 2-CIRCUIT VOLTAGE REGULATOR WITH DELAY FUNCTION Rev.1.4_00 S-13D1 Series 2. HSNT-6 (1212) Top view 6 5 4 (1) to (3): (4), (5): Product code (Refer to Product name vs. Product code) Lot number (1) (2) (3) (4) (5) 1 2 3 Product name vs. Product code 2. 1 S-13D1 Series B type Product Name S-13D1B1218-A6T2U3 S-13D1B1528-A6T2U3 S-13D1B1812-A6T2U3 S-13D1B1815-A6T2U3 S-13D1B1818-A6T2U3 S-13D1B1828-A6T2U3 S-13D1B1833-A6T2U3 S-13D1B2518-A6T2U3 S-13D1B2818-A6T2U3 S-13D1B2828-A6T2U3 S-13D1B2833-A6T2U3 S-13D1B2J2J-A6T2U3 S-13D1B3018-A6T2U3 S-13D1B3130-A6T2U3 S-13D1B3330-A6T2U3 S-13D1B3333-A6T2U3 2. 3 2. 2 (1) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Product Code (2) (3) 5 K 6 B 5 G 5 H 5 L 5 N 6 A 5 J 5 F 5 O 5 P 5 Q 5 A 5 D 5 C 5 B S-13D1 Series C type Product Name S-13D1C1218-A6T2U3 S-13D1C1528-A6T2U3 S-13D1C1818-A6T2U3 S-13D1C1828-A6T2U3 S-13D1C1833-A6T2U3 S-13D1C2828-A6T2U3 S-13D1C2833-A6T2U3 S-13D1C2J2J-A6T2U3 S-13D1C3636-A6T2U3 (1) 1 1 1 1 1 1 1 1 1 Product Code (2) (3) 5 U 5 3 5 V 5 X 5 2 5 Y 5 Z 5 1 5 S S-13D1 Series D type Product Name S-13D1D1218-A6T2U3 S-13D1D1528-A6T2U3 S-13D1D1818-A6T2U3 S-13D1D1828-A6T2U3 S-13D1D1833-A6T2U3 S-13D1D2828-A6T2U3 S-13D1D2833-A6T2U3 S-13D1D2J2J-A6T2U3 Product Code (1) (2) (3) 1 7 A 1 7 H 1 7 B 1 7 C 1 7 G 1 7 D 1 7 E 1 7 F 37 2.9±0.2 1.9±0.2 6 0.95 4 5 1 2 3 +0.1 0.15 -0.05 0.95 0.35±0.15 No. MP006-A-P-SD-2.1 TITLE SOT236-A-PKG Dimensions No. MP006-A-P-SD-2.1 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 ø1.5 -0 +0.2 ø1.0 -0 2.0±0.05 0.25±0.1 4.0±0.1 1.4±0.2 3.2±0.2 3 2 1 4 5 6 Feed direction No. MP006-A-C-SD-3.1 TITLE SOT236-A-Carrier Tape No. MP006-A-C-SD-3.1 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.0±0.3 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. MP006-A-R-SD-2.1 TITLE SOT236-A-Reel No. MP006-A-R-SD-2.1 ANGLE QTY UNIT mm ABLIC Inc. 3,000 0.40 1.00±0.05 0.38±0.02 0.40 4 6 3 1 +0.05 0.08 -0.02 1.20±0.04 The heat sink of back side has different electric potential depending on the product. Confirm specifications of each product. Do not use it as the function of electrode. 0.20±0.05 No. PM006-A-P-SD-1.1 TITLE HSNT-6-B-PKG Dimensions No. PM006-A-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. 2.0±0.05 +0.1 ø1.5 -0 4.0±0.1 0.25±0.05 +0.1 ø0.5 -0 0.50±0.05 4.0±0.1 1.32±0.05 3 1 4 6 Feed direction No. PM006-A-C-SD-2.0 TITLE HSNT-6-B-C a r r i e r Tape No. PM006-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. +1.0 9.0 - 0.0 11.4±1.0 Enlarged drawing in the central part ø13±0.2 (60°) (60°) No. PM006-A-R-SD-1.0 TITLE HSNT-6-B-Reel No. PM006-A-R-SD-1.0 ANGLE UNIT QTY. mm ABLIC Inc. 5,000 1.04min. Land Pattern 0.24min. 1.02 0.40±0.02 0.40±0.02 (1.22) Caution It is recommended to solder the heat sink to a board in order to ensure the heat radiation. PKG Metal Mask Pattern Aperture ratio Aperture ratio Caution Mask aperture ratio of the lead mounting part is 100%. Mask aperture ratio of the heat sink mounting part is 40%. Mask thickness: t0.10mm to 0.12 mm 100% 40% t0.10mm ~ 0.12 mm TITLE HSNT-6-B -Land Recommendation PM006-A-L-SD-2.0 No. ANGLE No. PM006-A-L-SD-2.0 UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-13D1D2828-M6T1U3
物料型号:S-13D1 Series,由ABLIC公司开发,是一款5.5V输入、150mA输出电流的双路电压调节器,具备延时功能。
器件简介:S-13D1系列采用CMOS技术开发,具有低 dropout 电压、高准确度输出电压和低电流消耗的特点。该系列包含过流保护电路和热关断电路,以防止输出电流超出晶体管的电流容量或因过热而损坏。C/F型号还内置了延时功能,可以设置通道间的上升时间差异。
引脚分配: - SOT-23-6封装:1号引脚为ON/OFF1,2号引脚为VIN,3号引脚为ON/OFF2,4号引脚为VOUT2,5号引脚为VSS,6号引脚为VOUT1。 - HSNT-6 (1212)封装:1号引脚为VOUT1,2号引脚为VOUT2,3号引脚为VSS,4号引脚为ON/OFF2,5号引脚为VIN,6号引脚为ON/OFF1。
参数特性: - 输出电压:1.0V至3.6V,以0.05V步进可调。 - 输入电压:1.5V至5.5V。 - 输出电压精度:±1.0%(1.0V至1.45V输出产品:±15mV)。 - dropout电压:典型值80mV。 - 工作电流:典型值39μA,最大值58μA(每路)。 - 关闭时电流:典型值0.1μA,最大值1.0μA。 - 输出电流:每路可达150mA(VIN ≥ VOUT(S) + 1.0V)。
功能详解: - 内置过流保护电路和热关断电路。 - C/F型号具有延时功能,可以设置通道间的上升时间差异。 - 内置ON/OFF电路,确保长电池寿命。 - 可选择是否启用放电分流功能和下拉功能。
应用信息: - 数码相机的恒压电源。 - 移动电话的恒压电源。 - 便携设备的恒压电源。
封装信息:SOT-23-6和HSNT-6 (1212)两种封装类型。
S-13D1D2828-M6T1U3 价格&库存
很抱歉,暂时无法提供与“S-13D1D2828-M6T1U3”相匹配的价格&库存,您可以联系我们找货
