74CBTLV3125BQ-Q10X
74CBTLV3125BQ-Q10X
    NEXPERIA(安世)
    VFQFN14
    IC BUS SWITCH 1 X 1:1 14DHVQFN
74CBTLV3125BQ-Q10X 数据手册
74CBTLV3125-Q100 4-bit bus switch Rev. 4 — 23 September 2020 Product data sheet 1. General description The 74CBTLV3125-Q100 provides a 4-bit high-speed bus switch with separate output enable inputs (1OE to 4OE). The low on-state resistance of the switch allows connections to be made with minimal propagation delay. The switch is disabled (high-impedance OFF-state) when the output enable (nOE) input is HIGH. To ensure the high-impedance OFF-state during power-up or power-down, nOE should be tied to the VCC through a pull-up resistor. The minimum value of the resistor is determined by the current-sinking capability of the driver. Schmitt trigger action at control input makes the circuit tolerant to slower input rise and fall times across the entire VCC range from 2.3 V to 3.6 V. This device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing the damaging backflow current through the device when it is powered down. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Supply voltage range from 2.3 V to 3.6 V High noise immunity Complies with JEDEC standard: • JESD8-5 (2.3 V to 2.7 V) • JESD8-B/JESD36 (2.7 V to 3.6 V) ESD protection: • MIL-STD-883, method 3015 exceeds 2000 V • HBM JESD22-A114F: exceeds 2000 V • CDM AEC-Q100-011 revision B exceeds 1000 V 5 Ω switch connection between two ports Rail to rail switching on data I/O ports CMOS low power consumption Latch-up performance exceeds 250 mA per JESD78B Class I level A IOFF circuitry provides partial Power-down mode operation DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of solder joints 74CBTLV3125-Q100 Nexperia 4-bit bus switch 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74CBTLV3125PW-Q100 -40 °C to +125 °C TSSOP14 74CBTLV3125BQ-Q100 -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal SOT762-1 enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm 4. Functional diagram 1OE 1A 1B 2OE 2A 2B 3OE 3A 3B nA nB 4OE 4A 4B nOE 001aak856 Fig. 1. Logic symbol 74CBTLV3125_Q100 Product data sheet Fig. 2. 001aak863 Logic diagram (one switch) All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 2 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 5. Pinning information 5.1. Pinning 1 terminal 1 index area 14 VCC 13 4OE 1B 3 12 4A 2OE 4 11 4B 2A 5 10 3OE 2B 6 9 3A GND 7 8 3B Pin configuration SOT402-1 (TSSOP14) 5 2B 6 11 4B GND(1) 10 3OE 9 3A 001aak859 Transparent top view (1) This is not a ground pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to GND. 001aak858 Fig. 3. 4 2A 8 1A 2 2OE 13 4OE 12 4A 3B 1 3 7 1OE 2 1B GND 74CBTLV3125 1A 14 VCC 1OE 74CBTLV3125 Fig. 4. Pin configuration SOT762-1 (DHVQFN14) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE, 3OE, 4OE 1, 4, 10, 13 output enable input 1A, 2A, 3A, 4A, 2, 5, 9, 12 A input/output 1B, 2B, 3B, 4B 3, 6, 8, 11 B output/input GND 7 ground (0 V) VCC 14 positive supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level. Output enable input OE Function switch L ON-state H OFF-state 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 3 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +4.6 V +4.6 V VCC supply voltage VI input voltage control inputs [1] -0.5 VSW switch voltage enable and disable mode [2] -0.5 IIK input clamping current VI < -0.5 V -50 - mA ISK switch clamping current VI < -0.5 V -50 - mA ISW switch current VSW = 0 V to VCC - ±128 mA ICC supply current - +100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW Table 5. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC supply voltage 2.3 3.6 V VI input voltage control inputs 0 3.6 V VSW switch voltage enable and disable mode 0 VCC V Tamb ambient temperature -40 +125 °C Δt/ΔV input transition rise and fall rate 0 200 ns/V [1] [2] [3] Tamb = -40 °C to +125 °C [3] VCC + 0.5 V The minimum input voltage rating may be exceeded if the input clamping current ratings are observed. The switch voltage ratings may be exceeded if switch clamping current ratings are observed For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C. 8. Recommended operating conditions 74CBTLV3125_Q100 Product data sheet pin nOE; VCC = 2.3 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 4 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 9. Static characteristics Table 6. Static characteristics At recommended operating conditions voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Typ [1] Max Min Max Unit HIGH-level input voltage VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 3.0 V to 3.6 V 2.0 - - 2.0 - V LOW-level input voltage VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 3.0 V to 3.6 V - - 0.9 - 0.9 V II input leakage current pin nOE; VI = GND to VCC; VCC = 3.6 V - - ±1.0 - ±20 μA IS(OFF) OFF-state leakage VCC = 3.6 V; see Fig. 5 current - - ±1 - ±20 μA IS(ON) ON-state leakage current - - ±1 - ±20 μA IOFF power-off leakage VI or VO = 0 V to 3.6 V; VCC = 0 V current - - ±10 - ±50 μA ICC supply current VI = GND or VCC; IO = 0 A; VSW = GND or VCC; VCC = 3.6 V - - 10 - 50 μA ΔICC additional supply current pin nOE; VI = VCC - 0.6 V; VSW = GND or VCC; VCC = 3.6 V - - 300 - 2000 μA CI input capacitance pin nOE; VCC = 3.3 V; VI = 0 V to 3.3 V - 0.9 - - - pF CS(OFF) OFF-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 5.2 - - - pF CS(ON) ON-state capacitance VCC = 3.3 V; VI = 0 V to 3.3 V - 14.3 - - - pF VIH VIL [1] [2] VCC = 3.6 V; see Fig. 6 [2] All typical values are measured at Tamb = 25 °C. One input at 3 V, other inputs at VCC or GND. 9.1. Test circuits VCC VCC nOE VIH A VI IS nB nA nOE VIL IS A A GND VI VO IS nA nB GND VO 001aak865 001aak864 VI = VCC or GND and VO = GND or VCC. Fig. 5. Test circuit for measuring OFF-state leakage current (one switch) 74CBTLV3125_Q100 Product data sheet VI = VCC or GND and VO = open circuit. Fig. 6. Test circuit for measuring ON-state leakage current (one switch) All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 5 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 9.2. ON resistance Table 7. Resistance RON At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7. Symbol Parameter RON Conditions Tamb = -40 °C to +85 °C Unit Min Typ [1] Max Min Max ISW = 64 mA; VI = 0 V - 4.2 8.0 - 15.0 Ω ISW = 24 mA; VI = 0 V - 4.2 8.0 - 15.0 Ω ISW = 15 mA; VI = 1.7 V - 8.4 40.0 - 60.0 Ω ISW = 64 mA; VI = 0 V - 4.0 7.0 - 11.0 Ω ISW = 24 mA; VI = 0 V - 4.0 7.0 - 11.0 Ω ISW = 15 mA; VI = 2.4 V - 6.2 15.0 - 25.5 Ω VCC = 2.3 V to 2.7 V; see Fig. 8 to Fig. 10 ON resistance Tamb = -40 °C to +125 °C [2] VCC = 3.0 V to 3.6 V; see Fig. 11 to Fig. 13 [1] [2] Typical values are measured at Tamb = 25 °C and nominal VCC. Measured by the voltage drop between the A and B terminals at the indicated current through the switch. ON-state resistance is determined by the lower of the voltages of the two (A or B) terminals. 9.3. ON resistance test circuit and graphs 001aai109 11 RON (Ω) 9 7 VSW V (1) 5 VCC (3) nOE VIL nA VI (4) 3 nB GND ISW RON = VSW / ISW Test circuit for measuring ON resistance (one switch) 74CBTLV3125_Q100 Product data sheet 0 0.5 1.0 1.5 2.0 VI (V) 2.5 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C 001aak866 Fig. 7. (2) Fig. 8. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 15 mA All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 6 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 001aai110 11 RON (Ω) 001aai111 11 RON (Ω) 9 9 7 7 (1) (1) (2) 5 (2) 5 (3) (3) (4) 3 0 (4) 0.5 1.0 1.5 2.0 VI (V) 3 2.5 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C Fig. 9. 0 0.5 1.0 1.5 2.0 VI (V) 2.5 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 24 mA Fig. 10. ON resistance as a function of input voltage; VCC = 2.5 V; ISW = 64 mA 001aai105 8 RON (Ω) 001aai106 8 RON (Ω) 6 6 (1) (1) (2) (2) (3) 4 (3) 4 (4) 2 0 (4) 1 2 3 VI (V) 4 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C Product data sheet 0 1 2 3 VI (V) 4 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C Fig. 11. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 15 mA 74CBTLV3125_Q100 2 Fig. 12. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 24 mA All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 7 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 001aai107 7.5 RON (Ω) 6.5 5.5 (1) (2) 4.5 (3) 3.5 2.5 (4) 0 1 2 3 4 VI (V) (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C Fig. 13. ON resistance as a function of input voltage; VCC = 3.3 V; ISW = 64 mA 10. Dynamic characteristics Table 8. Dynamic characteristics GND = 0 V; for test circuit see Fig. 16 Symbol Parameter tpd ten propagation delay enable time Conditions Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Typ[1] Max Min Max VCC = 2.3 V to 2.7 V - - 0.13 - 0.20 ns VCC = 3.0 V to 3.6 V - - 0.20 - 0.31 ns 1.0 2.7 4.6 1.0 6.0 ns 1.0 2.4 4.4 1.0 6.0 ns VCC = 2.3 V to 2.7 V 1.0 2.2 3.9 1.0 5.5 ns VCC = 3.0 V to 3.6 V 1.0 2.9 4.2 1.0 5.5 ns nA to nB or nB to nA; see Fig. 14 [2] [3] nOE to nA or nB; see Fig. 15 [4] VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V tdis [1] [2] [3] [4] [5] disable time Unit nOE to nA or nB; see Fig. 15 [5] All typical values are measured at Tamb = 25 °C and at nominal VCC. The propagation delay is the calculated RC time constant of the typical on-state resistance of the switch and the load capacitance, when driven by an ideal voltage source (zero output impedance). tpd is the same as tPLH and tPHL. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 8 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 10.1. Waveforms and test circuit VI input VM VM 0V tPHL tPLH VOH VM output VM VOL 001aai367 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 14. The data input (nA or nB) to output (nB or nA) propagation delays VI nOE input VM GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VX VOL tPHZ VOH output HIGH-to-OFF OFF-to-HIGH tPZH VY VM GND switch enabled switch disabled switch enabled 001aak860 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig. 15. Enable and disable times Table 9. Measurement points Supply voltage Input Output VCC VM VI tr = tf VM VX VY 2.3 V to 2.7 V 0.5VCC VCC ≤ 2.0 ns 0.5VCC VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V 0.5VCC VCC ≤ 2.0 ns 0.5VCC VOL + 0.3 V VOH - 0.3 V 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 9 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to the output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 16. Test circuit for measuring switching times Table 10. Test data Supply voltage Load VCC CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ 2.3 V to 2.7 V 30 pF 500 Ω open GND 2VCC 3.0 V to 3.6 V 50 pF 500 Ω open GND 2VCC 74CBTLV3125_Q100 Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 10 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 10.2. Additional dynamic characteristics Table 11. Additional dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter f(-3dB) -3 dB frequency response Conditions Tamb = 25 °C VI = GND or VCC; tr = tf ≤ 2.5 ns; VCC = 3.3 V; RL = 50 Ω; see Fig. 17 VCC Typ Max - 406 - MHz RL nB fi Min 0.5 VCC nOE VIL Unit nA GND dB aaa-025604 nOE connected to GND; fi is biased at 0.5VCC; Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads -3 dB. Fig. 17. Test circuit for measuring the frequency response when channel is in ON-state 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 11 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 11. Package outline TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 18. Package outline SOT402-1 (TSSOP14) 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 12 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 19. Package outline SOT762-1 (DHVQFN14) 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 13 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch 12. Abbreviations Table 12. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military 13. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74CBTLV3125_Q100 v.4 20200923 Product data sheet - 74CBTLV3125_Q100 v.3 Modifications: • 74CBTLV3125_Q100 v.3 20191023 - 74CBTLV3125_Q100 v.2 Modifications: • • 74CBTLV3125_Q100 v.2 20181008 Modifications: • • 74CBTLV3125_Q100 v.1 74CBTLV3125_Q100 Product data sheet Section 2 updated. Product data sheet Type number 74CBTLV3125BQ-Q100 (SOT762-1/DHVQFN14) added. Table 4: Derating values for Ptot total power dissipation updated. Product data sheet - 74CBTLV3125_Q100 v.1 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. 20170105 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 - © Nexperia B.V. 2020. All rights reserved 14 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 14. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 15 / 16 74CBTLV3125-Q100 Nexperia 4-bit bus switch Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................2 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 3 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 9.1. Test circuits..................................................................5 9.2. ON resistance..............................................................6 9.3. ON resistance test circuit and graphs..........................6 10. Dynamic characteristics............................................ 8 10.1. Waveforms and test circuit........................................ 9 10.2. Additional dynamic characteristics...........................11 11. Package outline........................................................ 12 12. Abbreviations............................................................ 14 13. Revision history........................................................14 14. Legal information......................................................15 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 September 2020 74CBTLV3125_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 23 September 2020 © Nexperia B.V. 2020. All rights reserved 16 / 16
74CBTLV3125BQ-Q10X 价格&库存
很抱歉,暂时无法提供与“74CBTLV3125BQ-Q10X”相匹配的价格&库存,您可以联系我们找货
74CBTLV3125BQ-Q10X
  • 1+4.381501+0.52367
  • 10+3.0928910+0.36966
  • 25+2.7619625+0.33011
  • 100+2.39928100+0.28676
  • 250+2.22680250+0.26615
  • 500+2.12270500+0.25370
  • 1000+2.037081000+0.24347
库存:5925
74CBTLV3125BQ-Q10X
  • 3000+1.931243000+0.23082
  • 6000+1.879476000+0.22463
  • 9000+1.853559000+0.22154
  • 15000+1.8248215000+0.21810
  • 21000+1.8080221000+0.21609
  • 30000+1.7918830000+0.21417
库存:5925
