S-5855ADDB-I4T1U
S-5855ADDB-I4T1U
    ABLIC(艾普凌科)
    SMD4
    SENSOR DIGITAL -40C-55C SNT-4A
S-5855ADDB-I4T1U 数据手册
S-5855A Series PWM OUTPUT TEMPERATURE SENSOR IC www.ablicinc.com N Rev.1.3_01 DE SI G © ABLIC Inc., 2010-2017 W The S-5855A Series, developed by CMOS technology, is a 1-wire PWM output temperature sensor IC of low current consumption that itself changes the duty ratio according to temperature. The duty ratio decreases from 100% if exceeding the temperature set by user, and this decrease is linear against the temperature rise. The output form is selectable from CMOS output and Nch open-drain output. Its small packages SNT-4A and SOT-23-5 enable high-density mounting.  Features FO R NE : 1-wire PWM interface : 3.0C : Selectable from 40C to 80C in 10C step : Selectable from 1 %/C to 4 %/C in 1 %/C step : 50 A typ. (Ta = 25C) : 1.65 V to 5.5 V : Ta = 40C to 125C  Application DE  Temperature compensation for LED instruments D  PWM output  Temperature accuracy  Duty ratio change-start temperature  Duty ratio temperature sensitivity  Low current consumption  Low power supply voltage  Wide range of operation temperature  Lead-free (Sn 100%), halogen-free MM EN  Packages NO T RE CO  SNT-4A  SOT-23-5 1 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Block Diagrams CMOS output product DE SI G N 1. VDD Temperature sensor  Triangle wave NE generator DOUT W  CFREQ D CF FO R VSS Nch open-drain output product MM EN 2. DE Figure 1 VDD NO T VSS sensor Triangle wave generator CF CFREQ Figure 2 2 DOUT  RE CO Temperature  PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Product Name Structure Product name A x x x  xxxx U DE SI G S-5855 N 1. Environmental code U :Lead-free (Sn 100%), halogen-free Package name (abbreviation) and packing specifications*1 I4T1 :SNT-4A, Tape M5T1 :SOT-23-5, Tape NE W Output form A :CMOS output B :Nch open-drain output FO R Duty ratio temperature sensitivity A :1 %/C B :2 %/C C :3 %/C D :4 %/C Packages Drawing Code Tape Reel PF004-A-C-SD PF004-A-R-SD MP005-A-C-SD MP005-A-R-SD Land PF004-A-L-SD  RE SNT-4A SOT-23-5 Package PF004-A-P-SD MP005-A-P-SD CO Package Name NO T 2. MM EN *1. Refer to the tape drawing. DE D Duty ratio change-start temperature A :40C B :50C C :60C D :70C E :80C 3 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series 3. Rev.1.3_01 Product name list (1) SNT-4A S-5855AACA-I4T1U Duty ratio change-start temperature TS*1 [C] 40 Duty ratio temperature sensitivity Ddt(s)*2 [%/C] 3 S-5855AEAA-I4T1U 80 S-5855AECA-I4T1U 80 TEM5*4 [C] CMOS output 45 60 1 CMOS output 85 125 3 CMOS output 85 100 W Duty ratio change-start temperature set by user Duty ratio temperature sensitivity set by user Temperature 5C higher than duty ratio change-start temperature TS (Refer to Table 12 for details) Higher temperature when measuring duty ratio temperature sensitivity (Refer to Table 12 for details) NE *1. TS : *2. Ddt(s) : *3. TSP5 : *4. TEM5 : *3 TSP5 [C] Output form DE SI G Product name N Table 1 (2) SOT-23-5 Table 2 R Remark Please contact our sales office for products other than those specified above. Duty ratio temperature sensitivity Ddt(s)*2 [%/C] 1 S-5855AAAB-M5T1U 40 1 S-5855AADA-M5T1U 40 4 CMOS output D DE Product name FO S-5855AAAA-M5T1U Duty ratio change-start temperature TS*1 [C] 40 Output form *3 TSP5 [C] TEM5*4 [C] CMOS output 45 115 Nch open-drain output 45 115 45 55 MM EN Duty ratio change-start temperature set by user *1. TS : *2. Ddt(s) : Duty ratio temperature sensitivity set by user *3. TSP5 : Temperature 5C higher than duty ratio change-start temperature TS (Refer to Table 12 for details) *4. TEM5 : Higher temperature when measuring duty ratio temperature sensitivity (Refer to Table 12 for details) NO T RE CO Remark Please contact our sales office for products other than those specified above. 4 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Pin Configurations SNT-4A Table 3 1 4 2 3 Symbol 1 VSS 2 CF 3 VDD 4 DOUT Pin Description GND pin Connection pin for frequency control capacitor Power supply pin Output pin Table 4 SOT-23-5 Symbol 1 CF 2 VSS Connection pin for frequency control capacitor GND pin 3 NC*1 No connection 4 5 3 DOUT VDD Pin Description Output pin Power supply pin *1. The NC pin is electrically open. The NC pin can be connected to VDD pin or VSS pin. D 2 NE Pin No. R 4 FO Top view 1 W Figure 3 5 N Pin No. DE SI G Top view NO T RE CO MM EN DE Figure 4 5 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Absolute Maximum Ratings Table 5 Item Power supply voltage Output voltage DE SI G N (Ta = 25C, VSS = 0 V, unless otherwise specified) Symbol Absolute Maximum Rating Unit VSS 0.3 to VSS 7.0 VDD CMOS output product VOUT Nch open-drain output product V VSS 0.3 to VDD 0.3 V VSS 0.3 to VSS 7.0 V CF voltage VCF VSS 0.3 to VDD 0.3 V Output current IOUT 13 to 13 300*1 mA mW 600*1 mW SNT-4A Topr Storage temperature Tstg *1. When mounted on board [Mounted board] (1) Board size: 114.3 mm × 76.2 mm × t1.6 mm (2) Name: JEDEC STANDARD51-7 40 to 125 C 65 to 150 C NE Operating ambient temperature W PD SOT-23-5 R Power dissipation NO T RE CO MM EN DE D FO Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. 6 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Electrical Characteristics Common items N 1. Table 6 Symbol Power supply voltage VDD Current consumption IDD  Ta = TSP5 Ta = 25C (Duty ratio 100%) Nch open-drain output product VOUT = 5.5 V, Ta = 25C CMOS output product VOUT = VDD  0.3 V VOUT = VSS  0.3 V W Output leakage current ILEAK No load at output pin DE SI G Item (Ta = TSP5, VDD = 3.0 V, VSS = 0 V, unless otherwise specified) Test Condition Min. Typ. Max. Unit circuit ISOURCE Output sink current ISINK Fall time tF Nch open-drain output product CL = 100 pF, RL = 10 k VOUT = 0.8  VDD to 0.2  VDD CMOS output product tR Nch open-drain output product CL = 15 pF, RL = 10 k VOUT = 0.2  VDD to 0.8  VDD CMOS output product CL = 100 pF, RL = 10 k VOUT = 0.2  VDD to 0.8  VDD R FO  5.5 V 1   200 A 1  50  A 1   1 A 3 0.8   mA 3 3   mA 3  20  ns 5  20  ns 4  300  ns 5  50  ns 4 NO T RE CO MM EN DE D Rise time NE Output source current 1.65 7 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01 Product with duty ratio temperature sensitivity Ddt(s) = 1 %/C 2. Table 7 Duty ratio accuracy Dsp5 Duty ratio temperature Ddt(E)*1 sensitivity Oscillation frequency 3. W Ddt(E): Actual duty ratio temperature sensitivity TSP5: Temperature 5C higher than duty ratio change-start temperature TS (Refer to Table 12 for details) TEM5: Higher temperature when measuring duty ratio temperature sensitivity (Refer to Table 12 for details) NE *1. *2. *3. fOSC (Ta = TSP5, VDD = 3.0 V , VSS = 0 V, CFREQ = 2.2 nF, unless otherwise specified) Condition Min. Typ. Max. Unit Test circuit VDD = 3.0 V 92.0 95.0 98.0 % 2 VDD = 1.65 V to 5.5 V 91.0 95.0 99.0 % 2 1.2 1.0 0.8 %/C 2 Ta = TSP5*2, VDD = 3.0 V TEM5*3 VDD = 1.65 V to 5.5 V 1.26 1.0 0.76 %/C 2 VDD = 3.0 V 1950 2300 2650 Hz 2 Ta = TSP5 VDD = 1.65 V to 5.5 V 1860 2300 2780 Hz 2 Ta = TEM5 VDD = 3.0 V 1670 2300 3040 Hz 2 N Symbol DE SI G Item Product with duty ratio temperature sensitivity Ddt(s) = 2 %/C Duty ratio accuracy Dsp5 Oscillation frequency MM EN Ddt(E): Actual duty ratio temperature sensitivity TSP5: Temperature 5C higher than duty ratio change-start temperature TS (Refer to Table 12 for details) TEM5: Higher temperature when measuring duty ratio temperature sensitivity (Refer to Table 12 for details) NO T RE CO *1. *2. *3. fOSC DE Duty ratio temperature Ddt(E)*1 sensitivity (Ta = TSP5, VDD = 3.0 V , VSS = 0 V, CFREQ = 4.7 nF, unless otherwise specified) Conditions Min. Typ. Max. Unit Test circuit VDD = 3.0 V 84.0 90.0 96.0 % 2 VDD = 1.65 V to 5.5 V 82.0 90.0 98.0 % 2 2.4 2.0 1.6 %/C 2 Ta = TSP5*2, VDD = 3.0 V TEM5*3 VDD = 1.65 V to 5.5 V 2.52 2.0 1.52 %/C 2 VDD = 3.0 V 1840 2160 2740 Hz 2 Ta = TSP5 VDD = 1.65 V to 5.5 V 1750 2160 2600 Hz 2 Ta = TEM5 VDD = 3.0 V 1560 2160 2850 Hz 2 8 FO Symbol D Item R Table 8 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01 4. Product with duty ratio temperature sensitivity Ddt(s) = 3 %/C Table 9 Duty ratio accuracy Dsp5 Duty ratio temperature Ddt(E)*1 sensitivity Oscillation frequency 5. W Ddt(E): Actual duty ratio temperature sensitivity TSP5: Temperature 5C higher than duty ratio change-start temperature TS (Refer to Table 12 for details) TEm5: Higher temperature when measuring duty ratio temperature sensitivity (Refer to Table 12 for details) NE *1. *2. *3. fOSC (Ta = TSP5, VDD = 3.0 V , VSS = 0 V, CFREQ = 6.8 nF, unless otherwise specified) Conditions Min. Typ. Max. Unit Test circuit VDD = 3.0 V 76.0 85.0 94.0 % 2 VDD = 1.65 V to 5.5 V 73.0 85.0 97.0 % 2 3.6 3.0 2.4 %/C 2 Ta = TSP5*2, VDD = 3.0 V TEM5*3 VDD = 1.65 V to 5.5 V 3.78 3.0 2.28 %/C 2 VDD = 3.0 V 1900 2240 2570 Hz 2 Ta = TSP5 VDD = 1.65 V to 5.5 V 1810 2240 2700 Hz 2 Ta = TEM5 VDD = 3.0 V 1620 2240 2950 Hz 2 N Symbol DE SI G Items Product with duty ratio temperature sensitivity Ddt(s) = 4 %/C Duty ratio accuracy Dsp5 Oscillation frequency fOSC RE CO MM EN Ddt(E): Actual duty ratio temperature sensitivity TSP5: Temperature 5C higher than duty ratio change-start temperature TS (Refer to Table 12 for details) TEM5: Higher temperature when measuring duty ratio temperature sensitivity (Refer to Table 12 for details) NO T *1. *2. *3. DE Duty ratio temperature Ddt(E)*1 sensitivity (Ta = TSP5, VDD = 3.0 V , VSS = 0 V, CFREQ = 10 nF, unless otherwise specified) Conditions Min. Typ. Max. Unit Test circuit VDD = 3.0 V 68.0 80.0 92.0 % 2 VDD = 1.65 V to 5.5 V 64.0 80.0 96.0 % 2 4.8 4.0 3.2 %/C 2 Ta = TSP5*2, VDD = 3.0 V TEM5*3 VDD = 1.65 V to 5.5 V 5.05 4.0 3.04 %/C 2 VDD = 3.0 V 1730 2030 2330 Hz 2 Ta = TSP5 VDD = 1.65 V to 5.5 V 1640 2030 2440 Hz 2 Ta = TEM5 VDD = 3.0 V 1470 2030 2680 Hz 2 FO Symbol D Items R Table 10 9 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01 1. N  Test Circuits CIN DE SI G A VDD CF V S-5855A DOUT Series Open VSS W CFREQ NE Figure 5 *1 R 10 k CIN S-5855A CF Series DOUT VSS D V Oscilloscope FO VDD R 2. DE CFREQ MM EN *1. Resistor (R) is unnecessary for the CMOS output product. Figure 6 3. CIN VDD CO S-5855A CF Series DOUT VSS V RE NO T 10 A Figure 7 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01 4. N CIN VSS RL V DE SI G VDD S-5855A CF Series DOUT CL W Figure 8 5. NE RL CIN VDD NO T RE CO MM EN DE Figure 9 CL D V FO VSS R S-5855A CF Series DOUT 11 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01 VDD CF S-5855A DOUT Series VSS Figure 10 W *1. CIN is a capacitor for stabilization. *2. CFREQ is a capacitor for oscillation frequency. *3. Resistor (R) is unnecessary for the CMOS output product. NE CFREQ *2 DE SI G R*3 10 k *1 CIN N  Standard Circuit NO T RE CO MM EN DE D FO R Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 12 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Operation Duty ratio N 1. DE SI G The following equation is the definition of duty ratio. Duty ratio = PW / T  100 [%] The definitions of PW and T are shown in Figure 11. W PW Figure 11 2. Oscillation frequency NE T FO R The oscillation frequency is set by the capacitance value of the capacitor CFREQ for the oscillation frequency. The relationship between the CFREQ capacitance value of each duty ratio temperature sensitivity and the center value of the oscillation frequency are shown in Table 11. Table 11 Center value of oscillation frequency [Hz] 2.2 4.7 6.8 10.0 2300 2160 2240 2030 DE D CFREQ capacitance value [nF] NO T RE CO MM EN Duty ratio temperature sensitivity Ddt(s) [%/°C] 1 2 3 4 13 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Explanation of Terms Duty ratio accuracy (Dsp5) N 1. DE SI G Dsp5 shows duty ratio in temperature TSP5 5C higher than duty ratio change-start temperature TS. 100 % Dsp5 5°C Ta [°C] FO 2. Duty ratio temperature sensitivity (Ddt(E)) R Figure 12 NE TS TSP5 W Duty ratio [%] MM EN DE Ddt(E) = (Dem5  Dsp5) / (TEM5  TSP5) [%/C] D Duty ratio temperature sensitivity (Ddt(E)) is the temperature coefficient of duty ratio calculated from the output duty ratio at Ta = TSP5 and Ta = TEM5. TEM5 is the temperature decided for each product shown in Table 11, and Dem5 is the output duty ratio at Ta = TEM5. Ddt(E) is calculated using the following formula. 100% Ddt(E) Dsp5 14 TS TSP5 Ta [°C] Selectable from 1 %/°C to 4 %/°C in 1 %/°C step NO T *1. RE CO Duty ratio [%] Dem5 Figure 13 TEM5 *1 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01 TEM5 [C] R 115 75 60 55 125 85 70 65 125 95 80 75 125 105 90 85 125 115 100 95 NO T RE CO MM EN DE D FO TSP5 [C] 45 45 45 45 55 55 55 55 65 65 65 65 75 75 75 75 85 85 85 85 DE SI G W 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 1 2 3 4 NE 40 40 40 40 50 50 50 50 60 60 60 60 70 70 70 70 80 80 80 80 N Table 12 TSP5 and TEM5 in Each Product Duty ratio change-start temperature TS [C] Duty ratio temperature sensitivity Ddt(s) [%/C] 15 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Precaution DE SI G N  Note that this IC may itself heat depending on a connected load to the output pin, resulting in error in measuring temperature.  Set a capacitor (CIN) of approx. 0.1 F between the VDD pin and VSS pin for stabilization as close to IC as possible.  Connect a capacitor CFREQ for oscillation frequency as close to IC as possible.  Leakage current applied on the CF pin may cause error in the output duty ratio. Do not connect other components than CFREQ. W  Since the error of the output duty ratio may become large depending on an application circuit or the design of a board pattern on this IC, perform thorough evaluation with the actually mounted model in the case of use. NE  The application conditions for the input voltage, output voltage, and load current should not exceed the package power dissipation.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. NO T RE CO MM EN DE D FO R  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products, including this IC, of patents owned by a third party. 16 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Characteristics (Typical Data) 4.0 3.0 VDD [V] 2.0 6.0 NE Output source current (ISOURCE) vs. Power supply voltage (VDD) +25°C −40°C 5.00 4.00 3.00 R ISOURCE [mA] +25°C 5.0 6.00 +65°C 2.00 +125°C 1.00 0.00 1 3 5 7 −40°C 10.00 8.00 6.00 4.00 MM EN Output sink current (ISINK) vs. Power supply voltage (VDD) 12.00 +25°C +125°C 1 3 5 CO 2.00 0.00 +65°C 7 RE VDD [V] NO T ISINK [mA] DE VDD [V] 3. DE SI G +65°C −40°C 1.0 N +125°C W 55 50 45 40 35 30 25 20 FO 2. Current consumption (IDD) vs. Power supply voltage (VDD) D IDD [μA] 1. 17 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series 4. Rev.1.3_01 Fall time (tF) vs. Power supply voltage (VDD) dependency N 50 DE SI G tF [ns] 40 30 25 10 5 6 Rise time (tR) vs.Power supply voltage (VDD) dependency 6. R 200 100 4 3 VDD [V] 2 1 5 0 6 Duty ratio accuracy MM EN 6.1 Product with Ta = TSP5, Ddt(s) = 1 %/C 25 20 Ratio [%] 300 FO tR [ns] 400 NE 500 15 10 5 92 93 CO 0 94 95 1 D 140 120 100 80 60 40 20 0 5.2 Nch open-drain output product 96 97 6 15 10 5 0 76 78 80 82 84 86 88 90 92 94 Duty accuracy [%] RE Oscillation frequency 7.2 Oscillation frequency (fOSC) vs. Temperature(Ta) NO T 2300 2300 Ddt(s) = −3%/°C 2250 2200 Ddt(s) = −1%/°C 2150 2100 1 2 Ddt(s) = −3%/°C 2250 fOSC [Hz] fOSC [Hz] 5 20 98 7.1 Oscillation frequency (fOSC) vs. Power supply voltage (VDD) 18 4 3 VDD [V] 6.2 Product with Ta = TSP5, Ddt(s) = 3 %/C 25 Duty accuracy [%] 7. 2 DE tR [ns] 5.1 CMOS output product Ratio [%] 5. 4 3 VDD [V] 2 1 W 0 4 3 VDD [V] 5 2150 2100 6 Ddt(s) = −1%/°C 2200 50 75 100 Ta [°C] 125 PWM OUTPUT TEMPERATURE SENSOR IC S-5855A Series Rev.1.3_01  Marking Specifications SNT-4A Top view (1) to (3) : DE SI G N (1) SNT-4A Product code (Refer to Product name vs. Product code.) 4 1 (1) (2) (3) 3 W 2 Product name vs. Product code (2) SOT-23-5 SOT-23-5 Top view 2 MM EN (1) (2) (3) (4) 1 Product code (refer to Product name vs. Product code) Lot number D (1) to (3) : (4) : 4 DE 5 R FO S-5855AACA-I4T1U S-5855AEAA-I4T1U S-5855AECA-I4T1U NE Product Code (1) (2) (3) V Q C V Q Y V Q 3 Product Name 3 CO Product name vs. Product code Product Name NO T RE S-5855AAAA-M5T1U S-5855AAAB-M5T1U S-5855AADA-M5T1U Product Code (1) (2) (3) V Q A V R A V Q D 19 1.2±0.04 W DE SI G N 3 4 +0.05 0.08 -0.02 1 NE 2 0.65 MM EN 0.2±0.05 DE D FO R 0.48±0.02 NO T RE CO No. PF004-A-P-SD-6.0 TITLE SNT-4A-A-PKG Dimensions No. PF004-A-P-SD-6.0 ANGLE UNIT mm ABLIC Inc. N +0.1 ø1.5 -0 4.0±0.1 0.25±0.05 +0.1 4.0±0.1 0.65±0.05 3 4 DE 1 MM EN 2 D FO R 1.45±0.1 ø0.5 -0 NE W DE SI G 2.0±0.05 CO Feed direction NO T RE No. PF004-A-C-SD-2.0 TITLE SNT-4A-A-Carrier Tape No. PF004-A-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. FO R NE W DE SI G N 12.5max. D 9.0±0.3 DE Enlarged drawing in the central part MM EN ø13±0.2 (60°) No. PF004-A-R-SD-1.0 NO T RE CO (60°) TITLE SNT-4A-A-Reel No. PF004-A-R-SD-1.0 QTY. ANGLE UNIT mm ABLIC Inc. 5,000 2 0.3 1 FO R 0.35 NE W 0.52 DE SI G 1.16 N 0.52 (0.25 mm min. / 0.30 mm typ.) (1.10 mm ~ 1.20 mm) 0.03 mm DE D 1. 2. MM EN 1. Pay attention to the land pattern width (0.25 mm min. / 0.30 mm typ.). 2. Do not widen the land pattern to the center of the package (1.10 mm to 1.20 mm). Caution 1. Do not do silkscreen printing and solder printing under the mold resin of the package. 2. The thickness of the solder resist on the wire pattern under the package should be 0.03 mm or less from the land pattern surface. 3. Match the mask aperture size and aperture position with the land pattern. 4. Refer to "SNT Package User's Guide" for details. CO (0.25 mm min. / 0.30 mm typ.) (1.10 mm ~ 1.20 mm) NO T RE 1. 2. No. PF004-A-L-SD-4.1 TITLE SNT-4A-A -Land Recommendation PF004-A-L-SD-4.1 No. ANGLE UNIT mm ABLIC Inc. N 2.9±0.2 DE SI G 1.9±0.2 4 2 3 +0.1 0.16 -0.06 D 0.95±0.1 FO R NE 1 W 5 MM EN DE 0.4±0.1 NO T RE CO No. MP005-A-P-SD-1.3 TITLE SOT235-A-PKG Dimensions No. MP005-A-P-SD-1.3 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) +0.1 2.0±0.05 0.25±0.1 +0.2 W DE SI G N ø1.5 -0 4.0±0.1 1.4±0.2 R NE ø1.0 -0 5 Feed direction CO 4 MM EN 3 2 1 DE D FO 3.2±0.2 NO T RE No. MP005-A-C-SD-2.1 TITLE SOT235-A-Carrier Tape No. MP005-A-C-SD-2.1 ANGLE UNIT mm ABLIC Inc. D FO R NE W DE SI G N 12.5max. 9.0±0.3 DE MM EN Enlarged drawing in the central part (60°) CO (60°) ø13±0.2 NO T RE No. MP005-A-R-SD-1.1 SOT235-A-Reel TITLE No. MP005-A-R-SD-1.1 ANGLE QTY. UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not responsible for damages caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not responsible for damages caused by the incorrect information described herein. 4. Be careful to use the products within their specified ranges. Pay special attention to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not responsible for damages caused by failures and / or accidents, etc. that occur due to the use of the products outside their specified ranges. 5. When using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products must not be used or provided (exported) for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not responsible for any provision (export) to those whose purpose is to develop, manufacture, use or store nuclear, biological or chemical weapons, missiles, or other military use. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses. Do not apply the products to the above listed devices and equipments without prior written permission by ABLIC Inc. Especially, the products cannot be used for life support devices, devices implanted in the human body and devices that directly affect human life, etc. Prior consultation with our sales office is required when considering the above uses. ABLIC Inc. is not responsible for damages caused by unauthorized or unspecified use of our products. 9. Semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system must be sufficiently evaluated and applied on customer's own responsibility. MM EN DE D FO R NE W DE SI G N 1. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. CO 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. RE 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party without the express permission of ABLIC Inc. is strictly prohibited. NO T 14. For more details on the information described herein, contact our sales office. 2.0-2018.01 www.ablicinc.com
S-5855ADDB-I4T1U 价格&库存
很抱歉,暂时无法提供与“S-5855ADDB-I4T1U”相匹配的价格&库存,您可以联系我们找货
