NCT3720S TR
NCT3720S TR
    NUVOTON(新唐)
    SOP8_150MIL_EP
    IC REG LINEAR POS ADJ 2A 8SOP
NCT3720S TR 数据手册
NCT3720S/ S-L Nuvoton Maximum 2A, Ultra Low Dropout Regulator NCT3720S/ NCT3720S-L I Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L - Table of Contents – 1. GENERAL DESCRIPTION ......................................................................................................... 1 2. FEATURES ................................................................................................................................. 1 3. APPLICATIONS .......................................................................................................................... 1 4. PIN CONFIGURATION AND DESCRIPTION ............................................................................ 2 5. TYPICAL APPLICATION CIRCUIT............................................................................................. 2 6. BLOCK DIAGRAM ...................................................................................................................... 3 7. FUNCTIONAL DESCRIPTION ................................................................................................... 3 8. ELECTRICAL CHARACTERISTIC ............................................................................................. 6 9. TYPICAL OPERATING WAVEFORMS ...................................................................................... 9 10. PACKAGE DIMENSION ........................................................................................................... 11 11. ORDERING INFORMATION .................................................................................................... 12 12. TOP MARKING SPECIFICATION ............................................................................................ 12 13. REVISION HISTORY ................................................................................................................ 13 II Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 1. GENERAL DESCRIPTION The NCT3720S/S-L is a high performance positive voltage regulator which designed for use in applications requiring very low input voltage and very low dropout voltage up to 2A(peak) current rating. It operates with a VIN as low as 1.0V and control voltage 3V with output voltage programmable as low as 0.8V. The significant feature includes ultra low dropout, ideal for applications where VOUT is very close to VIN. Additionally, there is an enable pin to further reduce power dissipation while shutdown. The NCT3720S/S-L provides excellent regulation over variations in line, load and temperature, and provides a Power Good indicator to indicate if the voltage level of output voltage reaches 90% of its rating value. 2. FEATURES  Maximum 2A Ultra Low-Dropout Voltage Regulator  High Accuracy Output Voltage ±1.5%  Adjustable Output from 0.8V  Typically 150mV Dropout at 2A  Input Voltage as low as 1.0V  Power Good Indicator  Thermal and Over Current Protection  EN internal Pull High (NCT3720S) and Internal Pull Low Available (NCT3720S-L)  SOP-8 150mil with Exposed Pad Package  Lead Free (ROHS Compliant) and Halogen Free Package 3. APPLICATIONS  Desktop PCs, Notebooks, and Workstations  Graphics Card  Set Top Boxes, Digital TVs and Printers  Portable instruments  uP/ASIC/DSP/FPGA Core and I/O Supplies - 1 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 4. PIN CONFIGURATION AND DESCRIPTION PIN NO. PIN NAME I/O FUNCTION 1 PG O Power Good indicator. This is an open drain output. Connect it with a resistor to power source. 2 EN I Chip Enable Input. It is high active. 3 VIN P Supply Input Voltage. 4 VCNTL P Supply Input Voltage for Control Circuit. 5 NC N/A 6 VOUT P Output Voltage. Vout = 0.8*(1+R1/R2) 7 FB I Feedback Input. 8 GND P Ground. 9(Exposed pad) -- -- The exposed pad must be soldered to a large PCB and connected to GND for maximum power dissipation. No Internal Connection. 5. TYPICAL APPLICATION CIRCUIT VCNTL CNTL VOUT VOUT C(optional) 1uF R1 10uF FB Enable Singal EN R2 PG VIN PG VIN GND 100k 10uF VOUT - 2 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 6. BLOCK DIAGRAM GND EN CNTL VIN POR OTP Softstart & Control Logic FB OCP Driver 0.8V VOUT PG 0.72V 7. FUNCTIONAL DESCRIPTION The NCT3720S/S-L is intended for applications where high current capability and very low dropout voltage are required. It provides a very simple, low cost solution that uses very little pcb real estate. Additional features include an enable pin to allow for a very low power consumption at disable, and a fully adjustable output. Output Voltage Selection The output voltage of NCT3720S/S-L is adjustable from 0.8V to (VIN-VDROP) by external voltage divider resisters as shown in Typical Application Circuit. The value of resisters R1 and R2 should be more than 10kΩ to reduce the power loss. The VCNTL must be greater than (VOUT + 1.5V). Input capacitor - 3 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L A minimum of 10uF ceramic capacitor is recommended to be placed directly next to the VIN pin. This allows for the device being some distance from any bulk capacitance on the rail. Additionally, bulk capacitance of about ≧10uF may be added closely to the input supply pin of the NCT3720S/S-L to ensure that VIN does not sag, improving load transient response. Output capacitor A minmum bulk capacitance of ≧ 10uF, along with a 0.1uF ceramic decoupling capacitor is recommended. Increaseing the bulk capacitance will improve the overall transient response. The use of multiple lower value ceramic capacitors in parallel to achieve the desired bulk capacitance will not cause stability issues. Although designed for use with ceramic output capacitors, the NCT3720S/S-L is extremely tolerant of output capacitor ESR values and thus will also work comfortably with tantalum output capacitors. Noise immunity In very electrically noisy environments, it is recommended that 0.1uF ceramic capacitors be placed from VIN to GND and VOUT to GND as close to device pins as possible. Power Good The power good function is an open-drain output. Connects 100kΩ pull up resistor to VOUT to obtain an output voltage. The PG pin will output high immediately after the output voltage arrives 90% of normal output voltage. The PG pin will output high with typical 4ms delay time. Enable The NCT3720S/S-L goes into shutdown mode when the EN pin is in the logic low condition. During this condition, the pass transistor, error amplifier, and band gap are turned off, reducing the supply current to 10uA typical. If the EN pin is floating, NCT3720S and NCT3720S-L operating behaviors are different. For NCT3720S, the EN pin function pulls high level internally. So the regulator will be turn on when EN pin is floating. As for NCT3720S-L, the EN pin function pulls low level internally. So the regulator will be turn off when EN pin is floating. Current Limit The NCT3720S/S-L contains an independent current limit and the short circuit current protection to prevent unexpected applications. The current limit monitors and controls the pass transistor’s gate voltage, limiting the output current while higher than 3A typical. When the output voltage is less than 0.25V, the short circuit current protection starts the current fold back function and - 4 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L maintains the loading current 1.5A. The output can be shorted to ground indefinitely without damaging the part. Thermal Consideration The NCT3720S/S-L has a thermal shutdown circuitry to limit the junction temperature. When the junction temperature exceeds 150C, the thermal shutdown circuit disables the output, allowing the device to cool down. The output circuitry is enabled again after the junction temperature cools down by 30C, resulting in a pulsed output during continuous thermal overload conditions. The thermal protection is designed to protect the IC in the event of over temperature conditions. For reliabile operation, the junction temperature cannot exceed 125C. The definition of power dissipation in chip is as following equation: PD = (VIN - VOUT) x IOUT + VIN x IQ PD represents the power dissipation. The power dissipation depends on the thermal resistance of chip package, PCB layout, the airflow and temperature difference between junction and ambient. Refers to JEDEC51-1, The power dissipation can be calculated by following equation: PD(MAX) = (TJ(MAX) - TA) / θJA Where TJ(MAX) is the maximum operation junction temperature 125 ℃ , TA is the ambient temperature and theθJA is the junction to ambient thermal resistance. θJA for ESOP-8 package is 75℃/W on JEDEC51-7 (4 layers, 2S2P) thermal test board with minimum copper area. The maximum power dissipation at TA = 25℃ can be calculated as: PD(MAX) = (125℃ - 25℃) / 75℃/W = 1.33W θJA highly depends on IC package, PCB layout, the aireflow. Thermal resistanceθJA can be improved by adding copper under the exposed pad of ESOP-8 while the IC package is fixed. The copper under the exposed pad of ESOP-8 is an effective heatsink and is useful for improving thermal conductivity. Figure show the relationship between thermal resistance θJA vs. copper area on a standard JEDEC 51-7 (4 layers, 2S2P) thermal test board at TA = 25℃, PCB copper thickness = 2oz. The 70mm2 copper plane reduceθJA from 75℃/W to 45℃/W and increases maximum power disspation from 1.33W to 2.22W. - 5 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 70mm2 copper area 30mm2 copper area Minimum copper area Figure01. Thermal Resistance θJA vs. Copper Area of ESOP Packages Figure02. Power dissipation vs. ambient temperature 8. ELECTRICAL CHARACTERISTIC 8.1 Absolute Maximum Ratings PARAMETER RATING UNIT Input Supply Voltage, VCNTL and VIN -0.3 to 6V V Other Pins -0.3 to 6V V Internal Limited W 75 ℃/W Storage Temperature -50 to 150 ℃ Junction Temperature 150 ℃ 2 kV Machine Mode 200 V Latch-up 100 mA Power Dissipation, PD @ TA=25℃ Package Thermal Resistance, SOP8-EP, θJA Human Body Mode ESD Protection Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. - 6 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 8.2 Recommended Operating Conditions PARAMETER RATING UNIT 3.0 to 5.5 V 1.0 to VCNTL V 0 to 2 A Operating Temperature -40 to 85 ℃ Junction Temperature -40 to 125 ℃ CNTL Voltage, VCNTL Supply Voltage, VIN Output Current, IOUT 8.3 DC Electrical Characteristics (VIN = VOUT + 500mV, VEN = VIN = 5V, CIN = COUT = 10uF, TA = TJ = 25 C, unless otherwise specified) PARAMETER SYMBOL CONDITIONS MIN VCNTL VOUT = VREF 3.0 TYP MAX UNIT 5.5 V Supply voltage Control Input Voltage POR Threshold VCNTL Rising 2.7 POR Hysteresis V 0.2 Power Input Voltage VIN VOUT = VREF Control Input Current in shutdown ICNTL_SD VCNTL = VIN = 5.0V, IOUT = 0A, VOUT = VREF Control Input Current ICNTL Quiescent Current 1.0 5.5 V 20 30 uA VCNTL = VIN = VEN = 5.0V, IOUT = 0A, VOUT = VREF 0.4 0.6 mA IQ VCNTL = VIN = VEN = 5.0V, IOUT = 0A, VOUT = VREF 0.6 1 mA Reference Voltage VFB VCNTL = VIN = VEN = 5.0V, IOUT = 0A, VOUT = VREF 0.8 0.812 V Feedback Input Current IFB Feedback Voltage 0.788 20 nA VIN Line Regulation 1.2V < VIN < 5.0V, VCNTL = VEN = 5.0V, IOUT = 0A, VOUT = VREF 0.01 0.1 %/V VCNTL Line Regulation 3.0V < VCNTL < 5.0V, VIN = 1.2V, IOUT = 0A, VOUT = VREF 0.2 0.6 %/V Load Regulation 0A < ILOAD < 2A, VCNTL = VIN = VEN = 5.0V, VOUT = VREF 0.8 1.5 %/A Load Regulation over Temperature 0mA < ILOAD < 2A, VCNTL = VIN = VEN = 5.0V, VOUT = VREF, -40 < TJ < 125, by design 1.4 3 % IOUT = 2.0A, VCNTL = VEN = 5.0V, VOUT = VREF 150 250 mV VCNTL = VIN = 5.0V, VEN = 0V 90 Dropout Voltage VOUT Pull Low Resistance VDROP Ω Enable - 7 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L PARAMETER SYMBOL Enable High Level VEN Enable Low Level VSD Enable Current IEN CONDITIONS MIN TYP MAX 1.4 V 0.4 VEN = 0V, VCNTL = 5.0V Softstart Time 1.5 UNIT V 12 20 uA 3.0 4.5 ms PG FB Power OK Threshold VPOKTH IOUT = 0A, VCNTL = VIN = VEN = 5.0V, VOUT = VREF 92 % Power OK Hysteresis VPOKHYS IOUT = 0A, VCNTL = VIN = VEN = 5.0V, VOUT = VREF 8 % PG sink Capability IPG = 10mA 0.2 POK Delay Time From VOUT >92% VNOM to POK rising 3 ms VCNTL = VIN = VEN = 5.0V, VOUT = VREF 4 A VCNTL = VIN = VEN = 5.0V, VOUT = 0V 1.5 A 0.4 V Overcurrent Protection OCP Threshold Level IOCP Averaged Output Short Circuit Current Thermal Protection Themal Shutdown Temperature TSD IOUT = 0A, VCNTL = VIN = VEN = 5.0V, VOUT = VREF 150 ℃ Thermal Shutdown Hysteresis TSDHYS IOUT = 0A, VCNTL = VIN = VEN = 5.0V, VOUT = VREF 50 ℃ Note1. The dropout voltage is defined as VIN – VOUT, which is measured when VOUT is VOUT(normal) – 100mV. Note2. The device is not guaranteed to function ouside its operating conditions. - 8 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 9. TYPICAL OPERATING WAVEFORMS (VIN = VOUT + 0.5V, VCNTL = VEN = 5V, CIN = COUT=10uF, CVCNTL = 1uF, TA = 25℃ ) Power On Power Off Enable Disable Transient Response UVLO - 9 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L - 10 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 10. PACKAGE DIMENSION SOP8-EP (150mil) SYMBOLS A A1 b c D E e He Y L θ D1 E1 Dimensions In Millimeters Min Max 1.35 1.75 0.05 0.25 0.31 0.51 0.1 0.25 4.7 5.10 3.8 4.00 1.27 BASIC 5.8 6.20 0.10 0.4 1.27 0° 10° 3.10 3.50 2.20 2.60 - 11 - Dimensions In Inched Min Max 0.05 0.07 0.00 0.01 0.01 0.02 0.00 0.01 0.19 0.2 0.15 0.16 0.05 BASIC 0.23 0.24 0.00 0.02 0.05 0° 10° 0.12 0.14 0.09 0.10 Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 10.1 Taping Specification SOP8-EP Package 11. 12. ORDERING INFORMATION Part Number Package Type Supplied as Production Flow NCT3720S SOP8-EP (Green Package) 2,500 units/T&R Commercial, -40℃ to 85℃ NCT3720S-L SOP8-EP (Green Package) 2,500 units/T&R Commercial, -40℃ to 85℃ TOP MARKING SPECIFICATION 3720S 952AX 3720L 952AX Pin 1 index Pin 1 index 1st Line: Nuvoton logo 2nd Line: 3720S (Part number NCT3720S); 3720L (Part number NCT3720S-L) 3rd line: Tracking code  952:  A: assembly house ID  X: internal use only packages assembled in Year 2009, week 52 - 12 - Publication Release Date: Jan, 2011 Version: A3 NCT3720S/ S-L 13. REVISION HISTORY VERSION DATE PAGE DESCRIPTION A0 09/30/2010 All New Create A1 11/26/2010 All Add NCT3720S-L part number and relative data. A2 01/18/2011 P12 & P13 A3 01/20/2011 P1, P9, P10, P12 & P13 Added part numbers and relative data. Added waveform and revised some description. Removed part numbers and relative data. Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. - 13 - Publication Release Date: Jan, 2011 Version: A3
NCT3720S TR 价格&库存
很抱歉,暂时无法提供与“NCT3720S TR”相匹配的价格&库存,您可以联系我们找货
