IS32LT3177-STLA3-TR
IS32LT3177-STLA3-TR
    LUMISSIL
    SOT23-6
    10 TO 150MA CONSTANT CURRENT REG
IS32LT3177-STLA3-TR 数据手册
IS32LT3177/78 10-TO-200MA CONSTANT-CURRENT LED DRIVER FOR AUTOMOTIVE September 2020 GENERAL DESCRIPTION FEATURES The IS32LT3177 and IS32LT3178 are adjustable linear current devices with excellent temperature stability. A single resistor is all that is required to set the operating current from 10mA to 200mA. The devices can operate from an input voltage from 2.9V to 40V with a minimal voltage headroom of 1.0V (Typ.) at 150mA. Designed with a low dropout voltage; the device can drive LED strings close to the supply voltage without switch capacitors or inductors.  The IS32LT3177/78 simplifies designs by providing a stable current without the additional requirement of inductors, FETs or diodes. The complete constant current driver requires only a current set resistor and a small PCB area making designs both efficient and cost effective. The EN Pin of the IS32LT3177 can be tied to VBAT or PSM (Power Supply Modulation) signal for high side dimming. The EN Pin of the IS32LT3178 can function as the PWM signal input used for MCU PWM dimming. As a current sink it is ideal for LED lighting applications or current limiter for power supplies. The device is provided in a lead (Pb) free, SOT23-6 and SOP-8-EP packages. Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020          Low-side current sink - Adjustable from 10mA to 150mA (SOT236)/200mA (SOP-8-EP) with external resistor selection Wide input voltage range from - 2.9V to 40V (IS32LT3178) - 5V to 40V (IS32LT3177) with a low dropout of typical 1.0V at 150mA Up to 1kHz PWM input (IS32LT3178 only) Protection features: - 0.6%/K current roll off at high temp over 145°C for thermal protection - Output current limit - Thermal shutdown Up to 0.77W (SOT23-6)/2.32W (SOP-8-EP) power dissipation in a small package RoHS compliant (Pb-free) package AEC-Q100 Qualified APPLICATIONS     Automotive and avionic lighting Stop/tail light Turn light Retail lighting in fridge, freezer case and vending machines   1  IS32LT3177/78 TYPICAL APPLICATION CIRCUIT VBAT or PSM VBAT CIN 0.1µF 1 6 EN GND 2.9V~5.5V or 2, 4, 5 IS32LT3177 (SOT23-6) PWM 6 ISET OUT RISET 1 3 Optional COUT 1nF EN GND 2, 4, 5 IS32LT3178 (SOT23-6) ISET OUT RISET VBAT or PSM CIN 0.1µF 3 Optional COUT 1nF VBAT CIN 0.1µF 3 4 RISET EN GND 2.9V~5.5V or 5~8 IS32LT3177 (SOP-8-EP) 3 PWM 4 ISET OUT 1,2 RISET EN GND CIN 0.1µF 5~8 IS32LT3178 (SOP-8-EP) ISET OUT 1,2 Optional COUT 1nF Optional COUT 1nF Figure 1 Typical Application Circuit Note 1: All GND pins must be connected to ground. Note 2: CIN must be placed close to IC. If no PSM dimming requirement, please use larger value for CIN. Note 3: COUT is optional. When the LED connection wire is long, the COUT should be placed close to OUT pin to avoid EMI interference. Note 4: RISET MUST be placed close to ISET and GND pins to improve the Electro-Magnetic Susceptibility (EMS) performance. Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      2  IS32LT3177/78 PIN CONFIGURATION Package Pin Configuration (Top View) SOT23-6 SOP-8-EP PIN DESCRIPTION No. SOT23-6 SOP-8-EP Pin Description 3 1, 2 OUT Current sink. 1 3 EN Enable pin (PWM input IS32LT3178 only). 6 4 ISET Output current setting pin. Connect a resistor between this pin and GND to set the maximum output current. 2, 4, 5 5~8 GND Ground pin. All GND pins must be connected to supply ground. - Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      3  IS32LT3177/78 ORDERING INFORMATION Automotive Range: -40°C to +125°C Order Part No. Package QTY/Reel IS32LT3177-STLA3-TR IS32LT3178-STLA3-TR SOT23-6, Lead-free 3000 IS32LT3177-GRLA3-TR IS32LT3178-GRLA3-TR SOP-8-EP, Lead-free 2500 Copyright  ©  2020  Lumissil  Microsystems.  All  rights  reserved.  Lumissil Microsystems reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use  in such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances  Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      4  IS32LT3177/78 ABSOLUTE MAXIMUM RATINGS (Note 5) Maximum enable voltage, VEN(MAX) only for IS32LT3177 VEN(MAX) only for IS32LT3178 Maximum output current, IOUT(MAX) Maximum output voltage, VOUT(MAX) Reverse voltage between all terminals, VR Power dissipation, PD(MAX) (Note 6) Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA=TJ Package thermal resistance, junction to ambient (4 layer standard test PCB based on JESD 51-2A), θJA Package thermal resistance, junction to thermal PAD (4 layer standard test PCB based on JESD 51-8), θJP ESD (HBM) ESD (CDM) 44V 6.0V 250mA 44V 0.5V 0.77W (SOT23-6) 2.32W (SOP-8-EP) +150°C -65°C ~ +150°C -40°C ~ +125°C 130°C/W (SOT23-6) 43.1°C/W (SOP-8-EP) 1.41°C/W (SOP-8-EP) ±2kV ±750V Note 5: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 6: Detail information please refer to package thermal de-rating curve on Page 16. ELECTRICAL CHARACTERISTICS “●” This symbol in the table means these parameters are for IS32LT3177. “○” This symbol in the table means these parameters are for IS32LT3178. “♦” This symbol in the table means these limits are guaranteed at room temp TA= TJ= 25°C. “◊” This symbol in the table means these limits are guaranteed at full temp range TA= TJ= -40°C~125°C. Test condition is TA= TJ= -40°C~+125°C, unless otherwise specified. (Note 7) Symbol Parameter VBD_OUT OUT pin breakdown voltage IEN VISET Enable current Condition VEN= 0V Max. 40 0.5 1.00 VEN= 3.3V, RISET=16kΩ ○ 0.5 1.00 1.0 ● VOUT= 0.8V, VEN= 3.3V, RISET= 160kΩ ○ VOUT> 1.0V, VEN= 12V, RISET= 16kΩ, SOP-8-EP ● VOUT> 1.0V, VEN= 3.3V, RISET= 16kΩ, SOP-8-EP ○ VOUT> 1.0V, VEN= 12V, RISET= 16kΩ, SOT23-6 ● VOUT> 1.0V, VEN= 3.3V, RISET= 16kΩ, SOT23-6 ○ Unit V ● Current setting reference voltage Output current Typ. VEN= 12V, RISET=16kΩ VOUT= 0.8V, VEN= 12V, RISET= 160kΩ IOUT Min. ♦ 10 ◊ 10 ♦ 10 ◊ 10 mA V mA ♦ 97 100 103 ◊ 95 100 105 ♦ 97 100 103 ◊ 95 100 105 ♦ 96.5 100 103.5 ◊ 94 100 106 ♦ 96.5 100 103.5 ◊ 94 100 106 mA   Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      5  IS32LT3177/78 ELECTRICAL CHARACTERISTICS (CONTINUE) Symbol Parameter Condition VOUT> 1.5V, VEN= 12V, RISET= 10.6kΩ, SOT23-6 IOUT Output current ● VOUT> 1.5V, VEN= 3.3V, RISET= 10.6kΩ, SOT23-6 ○ VOUT> 1.5V, VEN= 12V, RISET= 8kΩ, SOP-8-EP ● VOUT> 1.5V, VEN= 3.3V, RISET= 8kΩ, SOP-8-EP ○ Min. Typ. Max. ♦ 145.5 150 154.5 ◊ 142.5 150 157.5 ♦ 145.5 150 154.5 ◊ 142.5 150 157.5 ♦ 194 200 206 ◊ 190 200 210 ♦ 194 200 206 ◊ 190 200 210 Typ. Max. Unit mA mA DC CHARACTERISTICS WITH STABILIZED LED LOAD “●” This symbol in the table means these parameters are for IS32LT3177. “○” This symbol in the table means these parameters are for IS32LT3178. Test condition is TA= TJ= -40°C~+125°C, unless otherwise specified. (Note 7) Symbol IOUT_LIMIT VUVLO Parameter Output current limit EN pin undervoltage lockout threshold Condition RISET= GND, VEN= 12V ● 295 RISET= GND, VEN= 3.3V ○ 295 ● 3.1 3.6 ○ 1.9 2.4 VEN rising VEN falling 10mA≤IOUT≤200mA, VOUT=2V VEN Sufficient supply voltage on EN pin 10mA≤IOUT≤150mA, VOUT=2V, SOT23-6 150mA < IOUT ≤ 200mA, VOUT=2V, SOP-8-EP VHR tON Minimum required headroom voltage on OUT pin EN pin enabling time Min. mA ● 2.4 2.9 ○ 1.2 1.7 ● 5 40 2.9 5.5 3.1 5.5 V V ○ IOUT=150mA, SOT23-6 ● 1.2 IOUT= 150mA, SOT23-6 ○ 1.2 IOUT= 200mA, SOP-8-EP ● 1.5 IOUT= 200mA, SOP-8-EP ○ 1.5 VOUT > 1.5V, VEN = 5V, RISET= 16kΩ VOUT > 1.5V, VEN = 3.3V, RISET= 16kΩ Unit V ● 10 ○ 10 μs TRO Thermal roll off threshold Current decreasing slope rate: -0.6%/°C (Note 8) 145 °C TSD Thermal shutdown threshold Temperature rising (Note 8) 170 °C TSD_HY Thermal shutdown hysteresis Temperature falling (Note 8) 30 °C Note 7: Production testing of the device is performed at 25°C. Functional operation of the device and parameters specified over -40°C to +125°C temperature range, are guaranteed by design and characterization. Note 8: Guaranteed by design. Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      6  IS32LT3177/78 FUNCTIONAL BLOCK DIAGRAM IS32LT3177 IS32LT3178 Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      7  IS32LT3177/78 TYPICAL PERFORMANCE CHARACTERISTICS IS32LT3177 120 250 100 200 150 100 50 80 60 40 20 TJ = -40°C 0 TJ = 25°C, 125°C VOUT = 2V RISET = 16kΩ TJ = 25°C, 125°C Output Current (mA) Output Current (mA) VOUT = 2V RISET = 8kΩ 0 10 20 30 TJ = -40°C 0 40 42 0 10 20 40 42 30 40 42 VEN (V) VEN (V) Figure 3 Output Current vs. VEN Figure 2 Output Current vs. VEN 12 60 TJ = 25°C, 125°C VOUT = 2V RISET = 32kΩ VOUT = 2V RISET = 160kΩ 10 Output Current (mA) 50 Output Current (mA) 30 40 30 20 8 6 4 TJ = 25°C, 125°C 2 10 0 TJ = -40°C 0 10 20 30 TJ = -40°C 0 40 42 0 10 20 VEN (V) VEN (V) Figure 4 Output Current vs. VEN 120 VEN = 12V RISET = 8kΩ SOP-8-EP 200 100 150 TA = 125°C 100 50 0 VEN = 12V RISET = 16kΩ SOP-8-EP TA = -40°C, 25°C Output Current (mA) Output Current (mA) 250 Figure 5 Output Current vs. VEN TA = -40°C, 25°C TA = 125°C 80 60 40 20 0 2 4 6 8 10 12 Headroom Voltage (V) 0 2 4 6 8 10 12 Headroom Voltage (V) Figure 6 Output Current vs. Headroom Voltage Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020  0 Figure 7 Output Current vs. Headroom Voltage     8  IS32LT3177/78 15 60 VEN = 12V RISET = 32kΩ TA = -40°C, 25°C VEN = 12V RISET = 160kΩ Output Current (mA) Output Current (mA) 50 TA = 125°C 40 30 20 TA = -40°C, 25°C 9 TA = 125°C 6 3 10 0 12 0 2 4 6 8 10 0 12 0 2 4 12 350 600 RISET = 16kΩ TJ = -40°C, 25°C, 85°C, 125°C Output Current (mA) 400 300 200 100 0 0 VEN = 12V VOUT = 2V 300 500 250 200 150 100 50 5 10 15 20 25 30 0 40 42 35 0 20 40 60 80 100 120 140 160 180 RISET (kΩ) VEN (V) Figure 11 Output Current vs. RISET Figure 10 IEN vs. VEN 280 250 VEN = 12V VOUT = 2V 278 Output Current Limit (mA) RISET = 8kΩ 200 Output Current (mA) 10 Figure 9 Output Current vs. Headroom Voltage Figure 8 Output Current vs. Headroom Voltage 150 RISET = 16kΩ 100 RISET = 33kΩ 50 RISET = 160kΩ 0 8 Headroom Voltage (V) Headroom Voltage (V) IEN (µA) 6 -40 -25 -10 5 20 35 50 65 276 VEN = 12V VOUT = 2V RISET = 5.1kΩ 274 272 270 268 266 264 262 80 95 110 125 -10 5 20 35 50 65 80 95 110 125 Temperature (°C) Temperature (°C) Figure 12 Output Current vs. Temperature Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020  260 -40 -25 Figure 13 Output Current Limit vs. Temperature     9  IS32LT3177/78 120 120 Output Current (mA) 100 RISET = 16kΩ Output Current (mA) VEN = 12V VOUT = 1V 80 RISET = 33kΩ 60 40 VOUT = 2V RISET = 16kΩ fPSM = 100Hz,500Hz,1kHz TJ = -40°C 100 80 60 40 20 20 0 100 110 120 130 140 150 160 170 0 180 0 20 VOUT = 2V RISET = 16kΩ fPSM = 100Hz,500Hz,1kHz TJ = 25°C 100 Output Current (mA) Output Current (mA) 100 120 120 80 60 40 VOUT = 2V RISET = 16kΩ fPSM = 100Hz,500Hz,1kHz TJ = 125°C 100 80 60 40 20 20 0 20 40 60 80 0 100 0 20 40 60 80 100 PSM Duty Cycle (%) PSM Duty Cycle (%) Figure 17 Output Current vs. PSM Duty Cycle Figure 16 Output Current vs. PSM Duty Cycle 12 12 VOUT = 2V RISET = 160kΩ fPSM = 100Hz,500Hz,1kHz TJ = -40°C 10 Output Current (mA) Output Current (mA) 80 Figure 15 Output Current vs. PSM Duty Cycle Figure 14 Output Current vs. Temperature (Thermal Roll Off) 8 6 4 2 0 60 PSM Duty Cycle (%) Temperature (°C) 0 40 VOUT = 2V RISET = 160kΩ fPSM = 100Hz,500Hz,1kHz TJ = 25°C 10 8 6 4 2 0 20 40 60 80 100 PSM Duty Cycle (%) 0 20 40 60 80 100 PSM Duty Cycle (%) Figure 18 Output Current vs. PSM Duty Cycle Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020  0 Figure 19 Output Current vs. PSM Duty Cycle     10  IS32LT3177/78 Output Current (mA) 12 VOUT = 2V RISET = 16kΩ VOUT = 2V RISET = 160kΩ fPSM = 100Hz,500Hz,1kHz TJ = 125°C 10 8 VEN 2V/Div 6 4 2 0 IOUT 50mA/Div 0 20 40 60 80 100 PSM Duty Cycle (%) Time (2µs/Div) Figure 21 Start Up Figure 20 Output Current vs. PSM Duty Cycle VOUT = 2V RISET = 16kΩ VEN 2V/Div IOUT 50mA/Div Time (100ns/Div) Figure 22 Shut Down Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      11  IS32LT3177/78 IS32LT3178 250 120 150 100 0 80 TJ = 125°C 60 TJ = 25°C 40 TJ = -40°C TJ = 25°C TJ = 125°C 50 VOUT = 2V RISET = 16kΩ 100 200 Output Current (mA) Output Current (mA) VOUT = 2V RISET = 8kΩ 20 TJ = -40°C 1 2 3 4 0 5 1 2 3 VOUT = 2V RISET = 32kΩ TJ = 125°C 40 VOUT = 2V RISET = 160kΩ 10 Output Current (mA) 50 Output Current (mA) 5 12 60 TJ = 25°C 30 20 TJ = 125°C 8 TJ = 25°C 6 4 TJ = -40°C TJ = -40°C 2 10 1 2 3 4 0 5 1 2 3 VEN (V) VEN (V) Figure 26 Output Current vs. VEN Figure 25 Output Current vs. VEN 120 VEN = 5V RISET = 8kΩ SOP-8-EP 200 TA = -40°C, 25°C TA = -40°C, 25°C 100 150 Output Current (mA) 250 Output Current (mA) 4 Figure 24 Output Current vs. VEN Figure 23 Output Current vs. VEN TA = 125°C 100 50 0 5 VEN (V) VEN (V) 0 4 TA = 125°C 80 60 40 20 0 0 2 4 6 8 10 12 0 2 4 6 8 10 12 Headroom Voltage (V) Headroom Voltage (V) Figure 28 Output Current vs. Headroom Voltage Figure 27 Output Current vs. Headroom Voltage Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020  VEN = 5V RISET = 16kΩ SOP-8-EP     12  IS32LT3177/78 12 60 VEN = 5V RISET = 32kΩ TA = -40°C, 25°C 10 Output Current (mA) Output Current (mA) 50 TA = 125°C 40 30 20 TA = 125°C 8 6 4 2 10 0 TA = -40°C, 25°C VEN = 5V RISET = 160kΩ 0 2 4 6 8 10 0 12 0 2 4 Headroom Voltage (V) 12 350 RISET = 16kΩ Output Current (mA) TJ = 85°C 400 TJ = 25°C TJ = 125°C 300 200 250 200 150 100 TJ = -40°C 100 0 0.5 VEN = 5V VOUT = 2V 300 500 50 1 1.5 2 2.5 3 3.5 4 4.5 0 5 0 20 40 60 VEN (V) 80 100 120 140 160 180 RISET (kΩ) Figure 31 IEN vs. VEN Figure 32 Output Current vs. RISET 290 250 VEN = 5V VOUT = 2V Output Current Limit (mA) RISET = 8kΩ 200 Output Current (mA) 10 Figure 30 Output Current vs. Headroom Voltage 600 150 RISET = 16kΩ 100 RISET = 33kΩ 50 -40 -25 -10 5 20 35 50 65 285 VEN = 5V VOUT = 2V RISET = 5.1kΩ 280 275 270 265 RISET = 160kΩ 0 8 Headroom Voltage (V) Figure 29 Output Current vs. Headroom Voltage IEN (µA) 6 80 95 110 125 Temperature (°C) -40 -25 -10 5 20 35 50 65 80 95 110 125 Temperature (°C) Figure 33 Output Current vs. Temperature Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020  260 Figure 34 Output Current Limit vs. Temperature     13  IS32LT3177/78 120 120 Output Current (mA) 100 Output Current (mA) RISET = 16kΩ VEN = 5V VOUT = 1V 80 RISET = 32kΩ 60 40 20 VOUT = 2V RISET = 16kΩ fPWM = 100Hz, 500Hz, 1kHz TJ = -40°C 100 80 60 40 20 0 100 110 120 130 140 150 160 170 0 180 0 20 Temperature (°C) 100 Output Current (mA) Output Current (mA) 100 120 VOUT = 2V RISET = 16kΩ fPWM = 100Hz, 500Hz, 1kHz TJ = 25°C 80 60 40 20 VOUT = 2V RISET = 16kΩ fPWM = 100Hz, 500Hz, 1kHz TJ = 125°C 100 80 60 40 20 0 20 40 60 80 0 100 0 20 PWM Duty Cycle (%) 40 60 80 100 PWM Duty Cycle (%) Figure 37 Output Current vs. PWM Duty Cycle Figure 38 Output Current vs. PWM Duty Cycle 12 12 VOUT = 2V RISET = 160kΩ fPWM = 100Hz, 500Hz, 1kHz TJ = -40°C 10 Output Current (mA) Output Current (mA) 80 Figure 36 Output Current vs. PWM Duty Cycle 120 8 6 4 2 0 60 PWM Duty Cycle (%) Figure 35 Output Current vs. Temperature (Thermal Roll Off) 0 40 VOUT = 2V RISET = 160kΩ fPWM = 100Hz, 500Hz, 1kHz TJ = 25°C 10 8 6 4 2 0 20 40 60 80 100 PWM Duty Cycle (%) 0 20 40 60 80 100 PWM Duty Cycle (%) Figure 39 Output Current vs. PWM Duty Cycle Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020  0 Figure 40 Output Current vs. PWM Duty Cycle     14  IS32LT3177/78 Output Current (mA) 12 VOUT = 2V RISET = 16kΩ VOUT = 2V RISET = 160kΩ fPWM = 100Hz, 500Hz, 1kHz TJ = 125°C 10 8 VEN 2V/Div 6 4 2 0 IOUT 50mA/Div 0 20 40 60 80 100 PWM Duty Cycle (%) Time (2µs/Div) Figure 42 Start Up Figure 41 Output Current vs. PWM Duty Cycle VOUT = 2V RISET = 16kΩ VEN 2V/Div IOUT 50mA/Div Time (200ns/Div) Figure 43 Shut Down Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      15  IS32LT3177/78 APPLICATIONS INFORMATION IS32LT3177/78 provides an easy constant current sink solution for LED lighting applications. It uses an external resistor to adjust the LED current from 10mA to 150mA (SOT23-6)/200mA (SOP-8-EP). The LED current can be determined by the external resistor RISET as Equation (1): RISET  VISET  1600 I SET (1) 10.6kΩ≤RISET≤160kΩ for SOT23-6 package, and 8kΩ≤RISET≤160kΩ for SOP-8-EP package. Where RISET is in Ω, ISET is desired LED current in Amp and VISET = 1.0V (Typ.) RISET must be a 1% accuracy resistor with good temperature characteristics in order to ensure stable output current. The device limits the maximum output current to IOUT_LIMIT to protect itself from an output overcurrent condition caused by a low value. Do not leave ISET pin floating. HIGH INPUT VOLTAGE APPLICATION When driving a long string of LEDs whose total forward voltage drop exceeds the IS32LT3177 VBD_OUT limit of 40V, it is possible to stack several LEDs (such as 2 LEDs) between the EN pin and the OUT pins, and so the voltage on the EN pin is higher than 5V. The remaining string of LEDs can then be placed between power supply +VS and EN pin, (Figure 44). The number of LEDs required to stack at EN pin will depend on the LED’s forward voltage drop (VF) and the +VS value. +VS > 40V THERMAL PROTECTION AND DISSIPATION The IS32LT3177/78 implements thermal roll off protection to reduce the LED current when the package’s thermal dissipation is exceeded and prevent “thermal runaway”. The thermal roll off begins from 145°C, and linearly decreases following the junction temp to 85% of the set current value at TSD (170°C). Please see Figure 14 and 35. In the event that the junction temperature exceeds 170°C, the device will go into shutdown mode. At this point, the IC begins to cool off and will resume operation once the junction temperature goes below 140°C. When operating the chip at high ambient temperatures, or when driving maximum load current, care must be taken to avoid exceeding the package power dissipation limits. Exceeding the package dissipation will cause the device to enter thermal protection mode. The maximum package power dissipation can be calculated using the following Equation (2): PD ( MAX )  TJ ( MAX )  TA (2)  JA Where TJ(MAX) is the maximum junction temperature, TA is the ambient temperature, and θJA is the junction to ambient thermal resistance; a metric for the relative thermal performance of a package. The recommended maximum operating junction temperature, TJ(MAX), is 125°C and so the maximum ambient temperature is determined by the package parameter; θJA. The θJA for the IS32LT3177/78 SOT23-6 package is 130°C/W and SOP-8-EP package is 43.1°C/W. Therefore the maximum power dissipation at TA= 25°C is: PD ( MAX )  3 EN OUT PD ( MAX )  1,2 ISET GND 125C  25C  2.32W (SOP-8-EP) 43.1C / W The actual power dissipation PD is: IS32LT3177 4 125C  25C  0.77W (SOT23-6) 130C / W PD  VOUT  I OUT  VEN  I EN 8 RISET Figure 44 High Input Voltage Application Circuit Note: when operating the IS32LT3177 at voltages exceeding the device operating limits, care needs to be taken to keep the EN pin and OUT pin voltage below 40V. Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020    (3) To ensure optimum performance, the die temperature (TJ) of the IS32LT3177/78 should not exceed 125°C. The graph below gives details for the package power derating.   16  IS32LT3177/78 1 printed circuit board (PCB) with a grounded copper area of a few square inches on each side of the board under the IS32LT3177/78. Multiple thermal solid vias (not web or spoke type), as shown in Figure 46, help to conduct heat from the exposed pad of the IS32LT3177/78 to the grounded copper area on each side of the board. The recommended via diameter is 0.5mm with spacing of 1mm. The thermal resistance can be further reduced by using a metal-clad PCB or by adding a heatsink. Power Dissipation (W) SOT23-6 0.8 0.6 0.4 0.2 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 Temperature (°C) 3.5 Power Dissipation (W) SOP-8-EP 3   2.5 2 1.5 1 0.5 0 -40 -25 -10 5 20 35 50 65 80 95 110 125 Temperature (°C) Figure 45 PD vs. TA A lower thermal resistance is achieved by mounting the IS32LT3177/78 on a standard FR4 double-sided Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020    Figure 46 Board Via Layout For Thermal Dissipation   17  IS32LT3177/78 CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak 150°C Temperature min (Tsmin) 200°C Temperature max (Tsmax) 60-120 seconds Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) 217°C Time at liquidous (tL) 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified Max 30 seconds classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 47 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      18  IS32LT3177/78 PACKAGE INFORMATION SOP-8-EP Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      19  IS32LT3177/78 SOT-23-6 Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      20  IS32LT3177/78 RECOMMENDED LAND PATTERN SOP-8-EP SOT-23-6 Note: 1. Land pattern complies to IPC-7851. 2. All dimensions in MM. 3. This document (including dimensions, notes & specs) is a recommendation based on typical circuit board manufacturing parameters. Since land pattern design depends on many factors unknown (eg. User’s board manufacturing specs), user must determine suitability for use. Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      21  IS32LT3177/78 REVISION HISTORY Revision Detail Information Date 0A Initial release 2018.08.06 0B 1. Update FEATURES information 2. Update SOP-8-EP POD 3. Update VEN value 2018.11.20 A 1. Add note 4 for Figure 1 2. Update EC table 2019.04.03 B Revise IOUT_LIMIT typical value to 295mA 2020.09.25 Lumissil Microsystems – www.lumissil.com Rev. B, 09/25/2020      22
IS32LT3177-STLA3-TR 价格&库存
很抱歉,暂时无法提供与“IS32LT3177-STLA3-TR”相匹配的价格&库存,您可以联系我们找货
IS32LT3177-STLA3-TR
  • 3000+1.964533000+0.25381
  • 6000+1.911686000+0.24698
  • 9000+1.885199000+0.24356
  • 15000+1.8558615000+0.23977
  • 21000+1.8387121000+0.23755
  • 30000+1.8222330000+0.23542
库存:2990
