ASNT2112-KMF
ASNT2112-KMF
    ADSANTEC(先进科技)
    CFlatPack64
    28G CDR DMUX W/ PAM4 CLOCK REC.
ASNT2112-KMF 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT2112-KMF Programmable CDR DMUX 1-to-2 1:2 demultiplexer (DMUX) with integrated full-rate CDR  CDR range from 22.2GHz to 28.2GHz covered by 3 selectable VCOs  Digital operational mode with DC to 28.2GHz external clock  RZ and NRZ input data formats  Adjustable time of data sampling point for optimum BER performance  CML compliant differential input and output high-speed data and clock interfaces  LVDS compliant input reference clock interface  Full rate clock and retimed data output for 1:1 CDR operation  Half rate data outputs with toggle synchronization functionality  Signal inversion and muting capabilities in all output buffers  Single +3.3V or -3.3V power supply  Low power consumption of 1.6W at 25Gbps  Industrial temperature range  Custom CQFP 64-pin package vee vcc dop vcc don vcc ondo pol tog onco vcc c2p vcc c2n vcc vee  ASNT2112 vee vcc q0p vcc q0n vcc ond2o lolp icph icpl vcc q1p vcc q1n vcc vee vee vcc cep vcc cen vcc vcos1 ftr is vcos0 vcc c32p vcc c32n vcc vee vee vee pkdtp pkdtn dcinp vcc vcc dp vcc dn vcc vcc dcinn phshft vee vee Rev.2.4.2 1 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION ondo ce ond2o d dcinp dcinn pkdt c32 HS CIB DOB D Data IB DMX 1:2 CDR CLK IB do D2OB x2 q1 C2 lolp fltp phshft icph icpl vcos0 vcos1 tog pol onco q0 COB c2 Fig. 1. Functional Block Diagram ASNT2112-KMF is a 1:2 demultiplexer (DMUX) with full-rate integrated clock and data recovery (CDR). The IC shown in Fig. 1 can function in CDR mode covering a wide range of input data rates (fbit) by utilizing its three on-chip VCOs (voltage-controlled oscillators), or in a broadband digital mode. Selection of the desired working data rate and mode is accomplished through pins vcos0 and vcos1 (see Table 1). An external low speed system clock c32p/c32n running at 1/32 the frequency of the active VCO must be applied to the low-speed LVDS clock input buffer (CLK IB) in CDR mode. An external full-rate clock cep/cen must be applied to the high speed CML clock input buffer (HS CIB) for digital operation. The main function of the chip is to convert RZ or NRZ input data signal dp/dn with a bit rate of fbit accepted by CML buffer (Data IB) into 2 parallel NRZ data signals q0p/q0n and q1p/q1n running at bit rates of bit/2 and delivered to the outputs by CML data output buffers (D2OBx2). The clock and data are recovered from the input data stream by CDR. The phase of the clock recovered by CDR can be adjusted externally through pin phshft to locate the optimum data sampling point to achieve the lowest system bit error rate (BER). A full rate retimed NRZ data output signal dop/don is also available through the CML data output buffer (DOB) allowing the part to be used as a 1:1 CDR. Half rate clock c2p/c2n delivered through the CML clock output buffer (COB) has tight phase alignment to demultiplexed data output signals q0p/q0n and q1p/q1n. Rev.2.4.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Data IB can operate with differential or single-ended input signals. It includes tuning pins dcinp/dcinn for DC offset of the input signals in case of AC termination. When the buffer is operating with DC-terminated single ended input signal, a correct threshold voltage should be applied to the unused input pin. A peak detector is also included to provide means of demodulating AM components with the frequency up to a few hundred KHz carried by input data. The peak detector’s output signal is delivered to differential port pkdtp/pkdtn. All CML I/Os provide on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). Output buffers DOB, COB, and D2OBx2 can be individually disabled through pins ondo, onco, and ond2o to save power. Utilizing pin pol, the deserializer can invert the polarity of the three output data signals. Pin tog flips the order of q0p/q0n and q1p/q1n signals thus simplifying the interface between the DMUX and a following ASIC. It also allows for synchronization of the bit order of two or more DMUXes working in parallel. Loss of lock CMOS alarm signal lolp is generated by CDR to indicate its locking state. Off chip passive filter is required by CDR and should be connected to pin ftr (see CDR). The deserializer is characterized for operation from 0°C to 125°C of junction temperature. The package temperature resistance is 15°C /W. Data IB The Data Input Buffer (Data IB) can process input CML data signal dp/dn in either the RZ or NRZ format due to its high analog bandwidth. It provides on-chip single-ended termination of 50Ohm to vcc for each input line. The buffer can also accept a single-ended signal to one of its input ports dp or dn with a threshold voltage applied to the unused pin in case of DC termination. In case of AC termination, tuning pins dcinn or dcinp allow for the data common mode adjustment. The tuning pins have 1KOhm terminations to vcc and allow the user to change the slicing level before the data is sampled by the recovered clock. Tuning voltages from vcc to vee deliver 150mV of DC voltage shift. Also included in Data IB is an input signal peak detector that delivers its response through the output differential signal pkdtp/pkdtn. The detector can demodulate AM component(s) in the frequency range of up to a few hundred kHz carried by the input data. The detector’s output impedance is 4KOhm single ended to vcc. HS CIB The High-Speed Clock Input Buffer (HS CIB) can process either differential or single-ended external CML clock signals cep/cen. In the single-ended mode, the clock is applied to one of the pins with a threshold voltage applied to the unused pin. The buffer utilizes on-chip single-ended termination of 50Ohm to vcc for each input line. Rev.2.4.2 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com CLK IB The Clock Input Buffer (CLK IB) consists of a proprietary universal input buffer (UIB) that exceeds the LVDS standards IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995. UIB is designed to accept differential signals with the speed up to 1Gb/s, DC common mode voltage variation between vcc and vee, and AC common mode noise with a frequency up to 5MHz and voltage levels ranging from 0 to 2.4V. It can also receive a DC-terminated single-ended signal with a threshold voltage between vcc and vee applied to the unused pin. The input termination impedance is set to 100Ohm differential. CDR The Clock and Data Recovery Block (CDR) contains both a phase and frequency acquisition loop. The frequency loop works in concert with low-speed clock c32p/c32n while the phase loop utilizes data signal dp/dn. The CDR requires a single off-chip filter shown in Fig. 2 to be connected to the pin ftr. 200Ohm ftr 100pF 1nF Fig. 2. External Loop Filter The main function of CDR is to frequency-lock the selected on-chip VCO to the input data signal (clock recovery) while phase-aligning it to latch in the incoming data with minimal error (data recovery). By default, CDR aligns the recovered clock’s working edge in the middle of the incoming data bits. DC voltage from vee to vcc applied to in phshft can be utilized to shift this position from one edge of the data bit to the other in order to locate the optimum sampling point that provides the lowest system BER. The recovered clock is divided down in frequency by two (C2) and utilized by DMX 1:2 for demultiplexation of the recovered data. By utilizing the 2.5V CMOS control pins vcos0 and vcos1, the desired working frequency of CDR can be selected in accordance with Table 1 below. Table 1. CDR Mode Selection vcos0 vcos1 VCO Center Frequency (GHz) “0” (0V) “0” (0V) 23.0 “0” (0V) ”1” (2.5V) 25.0 ”1” (2.5V) “0” (0V) 27.0 ”1” (2.5V) ”1” (2.5V) Digital Mode, default state The loop gain can be adjusted by two 2.5V CMOS control pins icph and icpl that control the charge pump current as shown in Table 2. Rev.2.4.2 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Table 2. Charge Pump Current Control icph icpl Charge Pump current, mA “0” (0V) “0” (0V) Imax “0” (0V) ”1” (2.5V) Imax-0.04 ”1” (2.5V) “0” (0V) Imax-0.27 ”1” (2.5V) ”1” (2.5V) Imax-0.31 The lock detect circuitry signals an alarm through 2.5V CMOS signal lolp when a frequency difference exists between applied system reference clock c32p/c32n and recovered full rate clock divided-by-32 that is greater than ±1000ppm. Another feature included in CDR is the ability to simultaneously invert the polarity of all three data outputs through 2.5V CMOS input pin pol (pol = “1” (default): direct; pol = “0”: inverted). The order of the half-rate output data streams can be inverted by using 2.5V CMOS input pin tog, which provides means to synchronize two adjacent DMUXes operating in parallel. The synchronization process may be accomplished by the “blind” toggling in one of the chips and leaving the task of recognizing the “right” position to downstream components (e.g. FEC chip). DMX1:2 The 1 to 2 Demultiplexer (DMX1:2) latches in the retimed data stream D from CDR on both edges of the half rate clock signal C2. The high speed data signal is subsequently demultiplexed into two half rate NRZ data signals and delivered to D2OBx2 in parallel fashion as 2-bit wide words with the order defined by tog signal. DOB The Data Output Buffer (DOB) receives the full rate retimed serial data stream D from CDR and converts it into the CML output signal dop/don. This CML buffer requires 50Ohm external termination resistors connected between vcc and each output. The buffer can be enabled or disabled by the external 2.5V CMOS control signal ondo (ondo = “1” (default): enabled; ondo = “0”: disabled). D2OBx2 The Half Rate Data Output Buffer (D2OBx2) receives two half rate data signals from DMX1:2 and converts them into CML output signals q0p/q0n and q1p/q1n. The buffer requires 50Ohm external termination resistors connected between vcc and each output. The buffer can be enabled or disabled by external 2.5V CMOS control signal ond2o (ond2o = “1” (default): enabled; ond2o = “0”: disabled). COB The Clock Output Buffer (COB) receives a half rate clock signal from DMX1:2 and converts it into CML output signal c2p/c2n. The buffer requires 50Ohm external termination resistors connected between vcc and each output. The buffer can be enabled or disabled by external 2.5V CMOS control signal onco (onco = “1” (default): enabled; onco = “0”: disabled). The negative edge of c2p signal is aligned to the half rate output data crossing points. Rev.2.4.2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com POWER SUPPLY CONFIGURATION The ASNT2112-KMF can operate with either a negative supply (vcc = 0.0V = ground, and vee = -3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 3.3V and vee = 0V (external ground). ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 3 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 3. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max +3.8 1.6 1.0 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS Name vcc vee Supply and Termination Voltages Description Pin Number Positive power supply (+3.3V) 2, 4, 6, 11, 13, 15, 18, 20, 22, 27, 29, 31, 34, 36, 38, 43, 45, 47, 54, 55, 57, 59, 60 Negative power supply (GND or 0V) 1, 16, 17, 32, 33, 48, 49, 50, 63, 64 Rev.2.4.2 6 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL Name No. Type cep cen q1p q1n q0p q0n c2p c2n dop don dp dn 3 5 21 19 30 28 37 35 46 44 56 58 c32p c32n pkdtp pkdtn 12 14 51 52 Input Output Output Output Input Input Output DESCRIPTION High-Speed I/Os CML differential full rate clock inputs with internal SE 50Ohm termination to vcc CML differential half rate data outputs. Require external SE 50Ohm termination to vcc CML differential half rate clock outputs. Require external SE 50Ohm termination to vcc CML differential full rate data outputs. Require external SE 50Ohm termination to vcc CML differential data inputs with internal SE 50Ohm termination to vcc Low-Speed I/Os LVDS clock input with internal differential 100Ohm termination Peak detector outputs Controls CDR operational mode selection, see Table 1 vcos1 vcos0 is icpl icph ond2o 7 LS In., 2.5V CMOS 10 9 VCO current control (high, default: higher current; low: lower current) 23 Charge pump current control, see Table 2 24 26 D2OBx2 control (high, default: buffer is on; low: buffer is disabled) onco 39 COB control (high, default: buffer is on; low: buffer is disabled) tog pol 40 41 ondo lolp 42 25 Inversion of output data signals order (default: high) Data output signal polarity (high, default: inverted data outputs; low: direct data outputs) DOB control (high, default: buffer is on; low: buffer is disabled) CDR lock indicator (high: no lock; low: locked) dcinp dcinn phshft ftr LS out, 2.5V CMOS 53 LS IN Input data common mode voltage adjustment 61 62 LS IN CDR sampling point adjustment 8 I/O External CDR filter connection Rev.2.4.2 7 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN TYP MAX UNIT COMMENTS General Parameters +3.0 +3.3 +3.6 V ±9% vcc 0.0 V vee Ivcc 490 mA All functions “ON” Power Consumption 1.6 W Junction Temperature -25 50 125 °C HS Input Data (dp/dn) Data Rate DC 28.2 Gbps RZ or NRZ Swing p-p (Diff or SE) 0.05 0.6 V CM Voltage Level vcc-0.8 vcc V LS Input Reference Clock (c32p/c32n) Frequency 693.75 881.25 MHz Swing p-p (Diff or SE) 0.06 0.8 V CM Voltage Level V vee vcc Duty Cycle 40 50 60 % HS Output Full Rate Data (dop/don) Data Rate DC 28.2 Gbps NRZ Logic “1” level V vcc Logic “0” level vcc -0.4 V Jitter 8 ps p-p @ 25.6Gbps HS Output Half Rate Data (q0p/q0n, q1p/q1n) Data Rate DC 14.1 Gbps NRZ Logic “1” level V vcc Logic “0” level vcc -0.4 V Jitter 7 ps p-p @ 12.8Gbps HS Output Half Rate Clock (CDR Mode) (c2p/c2n) Data Rate 11.1 14.1 GHz Logic “1” level V vcc Logic “0” level vcc -0.4 V Jitter 5 ps p-p @ 12.8GHz Input Data Common Mode Control (dcinp/dcinn) Input DC Voltage V vee vcc Input Data Voltage Shift 0 -150 mV Referenced to vcc Output of Peak Detector (pkdtp/pkdtn) Swing p-p (Diff) -1 1 V Over full input range CM Voltage Level vcc-1.0 V Data Sampling Point Adjustment (phshft) Input DC Voltage vcc-1.0 NC vcc V NC=Not Connected Phase Shift -15 0 +15 ps Shift Stability -2 2 ps From 0°C to 125°C Bandwidth 0.0 100 MHz Rev.2.4.2 8 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Logic “1” level Logic “0” level c2p/c2n to q0p/q0n & q1p/q1n delay variation CMOS Control Inputs/Outputs 2.1 2.5 V vee+0.4 V Timing Parameters 2 ps Over the full temperature range PACKAGE INFORMATION The chip die is housed in a custom 64-pin CQFP package. The dimensioned drawings are shown in Fig. 3. Fig. 3. Package Drawing Rev.2.4.2 9 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The package’s leads will be trimmed to a length of 1.0mm. After trimming, the package’s leads will be further processed as follows: 1. The lead’s gold plating will be removed per the following sections of J-STD-001D: 3.9.1 Solderability 3.2.2 Solder Purity Maintenance 3.9.2 Solderability Maintenance 3.9.3 Gold Removal 2. The leads will be tinned with Sn63Pb37 solder The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT2112-KMF. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev.2.4.2 10 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 2.4.2 2.3.2 2.2.2 2.2.1 Date 05-2020 10-2019 07-2019 05-2015 2.1.1 10-2012 2.0 05-2012 1.6 06-2010 1.5 1.4 04-2010 02-2010 1.3 12-2009 1.2 04-2009 1.1 02-2009 Rev.2.4.2 Changes Updated Package Information Corrected VCO central frequencies Updated Letterhead Revised description Corrected Absolute Maximum Ratings section Revised packaging information section Corrected format Added supply current Corrected format Corrected description Added pin out drawing Added loop filter schematic Added description of is, icph, icpl pins Added additional packaging information Changed package mechanical drawing Added case temperature Added absolute maximums rating table Replaced TBDs with values Added RoHS compliancy Added revision history table Revised VCO table Added packaging diagram Adjusted block diagram Updated center frequencies in VCO table Updated external filter pin assignments Revised packaging information section Updated center frequencies in VCO table Updated power consumption value Initial release 11 May 2020
ASNT2112-KMF 价格&库存
很抱歉,暂时无法提供与“ASNT2112-KMF”相匹配的价格&库存,您可以联系我们找货
