ANST2011-KMA
ANST2011-KMA
    ADSANTEC(先进科技)
    CQFP100
    1:16 BROADBAND DIG DEMULTIPLEXER
ANST2011-KMA 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT2011-KMA DC-to-17Gbps Digital Demultiplexer 1:16 / Deserializer        Broadband digital deserializer 1-to-16 Low-power LVDS output data buffers with a proprietary architecture Clock-divided-by-16 LVDS output buffer with 90°-step phase selection Single +3.3V power supply Industrial temperature range Low power consumption of 730mW at 17Gbps Custom 100-pin CQFP package (13mm x 13mm) Rev. 3.5.2 1 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION bitordn q00 d Data IB DMX 1:16 16 LVDS DOB x16 q15 LVDS COB ce HS CIB cls CLK Proc /16 phs1 phs2 Fig. 1. Functional Block Diagram ASNT2011-KMA is a low power and high-speed digital 1 to 16 demultiplexer / deserializer IC. The IC shown in Fig. 1 can function seamlessly over input data rates (fbit) ranging from DC to 17Gbps. The main function of ASNT2011-KMA is to demultiplex a serial input data channel dp/dn running at a bit rate of fbit into 16 parallel data channels q00p/q00n-q15p/q15n running at a bit rate of fbit/16. The high sensitivity data input buffer (Data IB) ensures accurate operation at low input data signal amplitudes. It provides on-chip 50Ohm termination to vcc and is designed to be driven by devices with 50Ohm source impedance. During normal operation, the received serial input data is latched into the tree-type demultiplexer DMX1:16 and subsequently deserialized and delivered to the demultiplexer’s output as 16-bit wide low-speed parallel words. The output MSB corresponds to q00p/q00n when bitordn = 0 (default), or to q15p/q15n when bitordn = 1. A full rate clock must be provided by an external source cep/cen to the high-speed clock input buffer HS CIB where it is routed to the internal divider-by-16 (/16). The divider provides signaling for DMX1:16 and produces a full rate clock divided-by-16 C16 for the low speed LVDS compliant clock output buffer LVDS COB. The phase of clsp/clsn can be modified by 90° increments by utilizing pins phs1 and phs2 and the clock processing block CLK Proc. Sixteen proprietary low-power LVDS output data buffers LVDS DOBx16 are used to deliver the 16 data output signals q00p/q00n-q15p/q15n while a similar LVDS clock output buffer LVDS COB outputs the low-speed clock signal clsp/clsn. The deserializer uses a single +3.3V power supply and is characterized for operation from −25°C to 125°C of junction temperature. Rev. 3.5.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Data IB The Data Input Buffer (Data IB) can process an input CML data signal dp/dn with bit rates from DC to fbit. It can also accept a single-ended signal to one of its pins with a threshold voltage applied to the unused pin. Data IB can handle a wide range of input signal amplitudes. The buffer utilizes on-chip single-ended termination of 50Ohm to vcc for each input line. HS CIB The High-Speed Clock Input Buffer (HS CIB) can process an external CML clock signal cep/cen with frequencies from DC to fbit. It can also accept a single-ended signal to one of its pins with a threshold voltage applied to the unused pin. HS CIB can handle a wide range of input signal amplitudes. The buffer utilizes onchip single-ended termination of 50Ohm to vcc for each input line. /16 The Divider-by-16 (/16) includes 4 divide-by-2 circuits connected in series. The high-speed clock delivered by HS CIB is fed into the first divide-by-2 where its output is routed internally to the next divide-by-two circuit and outside of the block to DMX1:16. Other divided down clock signals are formed and routed to DMX1:16 in similar fashion. A full rate clock divided-by-16 C16 is passed on to CLK Proc for additional phase adjustment. DMX1:16 The 1 to 16 Demultiplexer (DMX1:16) utilizes a tree type architecture that latches in the data stream from Data IB on both edges of a half-rate clock signal supplied by the divider (/16). The high speed data signal is subsequently demultiplexed down and delivered to LVDS DOBx16 in parallel fashion as 16-bit wide words running at a data rate up to fbit/16. CLK Proc By utilizing the CMOS control pins phs1 and phs2, the phase of clsp/clsn can be altered as shown in Table 1. Table 1. Output Clock Phase Selection phs1 phs2 C16S phase vee (default) vee (default) 270° 180° vee vcc 90° vcc vee 0° vcc vcc LVDS DOBx16 The LVDS Data Output Buffer (LVDS DOBx16) accepts 16-bit wide words from DMX1:16 and converts them into LVDS output signals. Each proprietary low-power LVDS output buffer utilizes a special architecture that ensures operation at bit rates up to 2Gb/s with a nominal output current of 3.5mA. The buffer satisfies all the requirements of the IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995 standards. The output MSB corresponds to q00p/q00n when bitordn = 0 (default), or to q15p/q15n when bitordn = 1. LVDS COB The LVDS Clock Output Buffer (LVDS COB) receives C16 from CLK Proc and converts it into the LVDS output signal clsp/clsn. The proprietary low-power LVDS output buffer utilizes a special architecture that Rev. 3.5.2 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ensures operation at frequencies up to 2.0GHz with a nominal output current of 3.5mA. The buffer satisfies all the requirements of the IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995 standards. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 2 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 2. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max +3.6 0.8 1.2 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS Name vcc vee nc Supply And Termination Voltages Description Pin Number Positive power supply 5, 8, 11, 14, 25, 26, 29, 32, 35, 38, 41, 44, 47, 52, 55, (+3.3V) 59, 62, 65, 68, 71, 76, 79, 82, 85, 88, 91, 94, 97, 100 Negative power 1, 15, 17, 18, 23, 30, 36, 37, 50, 51, 58, 75 supply (GND or 0V) Not connected pins 2, 19, 20, 21, 22, 24, 27, 28, 31, 42, 43, 45, 46, 48, 49, 53, 54, 74 TERMINAL Name No. Type Rev. 3.5.2 dp dn cep cen 40 39 34 33 phs1 phs2 bitordr 57 56 16 DESCRIPTION High-Speed I/Os CML differential data inputs with internal SE 50Ohm termination to vcc Input CML differential clock inputs with internal SE 50Ohm termination to vcc Controls LS In., Low-speed output clock phase selection (default: both low) CMOS LS In., Output bit order selection (active: high, q15p/q15n is MSB; CMOS default: low, q00p/q00n is MSB) Input 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL Name No. Type DESCRIPTION Low-Speed I/Os q00n q00p q01n q01p q02n q02p q03n q03p q04n q04p q05n q05p q06n q06p q07n q07p q08n q08p q09n q09p q10n q10p q11n q11p q12n q12p q13n q13p q14n q14p q15n q15p clsp clsn Rev. 3.5.2 10 9 7 6 4 3 99 98 96 95 93 92 90 89 87 86 84 83 81 80 78 77 73 72 70 69 67 66 64 63 61 60 12 13 Output LVDS data outputs Output LVDS clock outputs. Can transmit four different clock phases as defined by phs1 and phs2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN TYP MAX UNIT COMMENTS General Parameters +3.14 +3.3 +3.47 V ±5% vcc 0.0 V External ground vee Ivcc 221 mA Power consumption 730 mW Junction temperature -25 50 125 °C HS Input Data (dp/dn) Data Rate 0 17 18 Gbps Swing p-p (Diff or SE) 0.04 0.8 V Peak-to-peak CM Voltage Level vcc -0.8 vcc V HS Input Clock (cep/cen) Frequency 0.0 17 18 GHz Swing p-p (Diff or SE) 0.2 0.8 V Peak-to-peak CM Voltage Level vcc -0.8 vcc V Duty Cycle 40 50 60 % LS Output Data (q00p/q00n-q15p/q15n) Data Rate 0.0 1063 1125 Mbps Interface LVDS Meets the IEEE Std. 1596.3-1996 LS Output Clock (clsp/clsn) Frequency 0.0 1063 1125 MHz Interface LVDS Meets the IEEE Std. 1596.3-1996 CMOS Control Inputs/Outputs Logic “1” level vcc -0.4 V Logic “0” level vee+0.4 V Timing Parameters clsp/clsn to ±2.5% Over the full temperature range q00p/q00n-q15p/q15n delay variation Rev. 3.5.2 6 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PACKAGE INFORMATION Fig. 2. Package Drawing Rev. 3.5.2 7 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The chip die is housed in a custom 100-pin CQFP package shown in Fig. 2. The package’s leads will be trimmed to a length of 1.0mm. After trimming, the package’s leads will be further processed as follows: 1. The lead’s gold plating will be removed per the following sections of J-STD-001D: 3.9.1 Solderability 3.2.2 Solder Purity Maintenance 3.9.2 Solderability Maintenance 3.9.3 Gold Removal 2. The leads will be tinned with Sn63Pb37 solder The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is power for a positive supply. The part’s identification label is ASNT2011-KMA. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. REVISION HISTORY Revision 3.5.2 3.4.2 3.4.1 Date 05-2020 07-2019 05-2015 3.3.1 09-2012 3.2 3.1 06-2012 02-2012 3.0 01-2012 2.0 02-2009 1.0 01-2009 Rev. 3.5.2 Changes Updated Package Information Updated Letterhead Corrected Absolute Maximum Ratings section Revised Package Information section Updated format Corrected input voltage range Corrected format Corrected package dimensions Revised Description section Revised Package Information section Added Absolute Maximums Rating table Revised Electrical Characteristics section Revised Package Information section Revised Electrical Characteristics section Revised Package Information section First release 8 May 2020
ANST2011-KMA 价格&库存
很抱歉,暂时无法提供与“ANST2011-KMA”相匹配的价格&库存,您可以联系我们找货
