ASNT5050-KMC
ASNT5050-KMC
    ADSANTEC(先进科技)
    CQFlatPack24
    32GB 2:1 DIG. MULTIPLEXER/SWITCH
ASNT5050-KMC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5050-KMC DC-32Gbps Broadband Digital 2:1 Multiplexer/Selector  Ideal for high speed proof-of-concept prototyping  Fully differential CML input interfaces  Fully differential CML output interface with 400mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 450mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFP 24-pin package vee Ideal for use as a high isolation selector switch or as a high speed 2-to-1 serializer vcc  d1n Exhibits low jitter and limited temperature variation over industrial temperature range vcc  d1p High speed broadband 2:1 Multiplexer/Selector (MUX) vcc  vee vcc vcc d0p outp ASNT5050 vcc vcc d0n outn vcc vcc Rev. 2.2.2 1 vcc cn vcc cp vcc vee vee May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION d1p d1n 50 50 50 50 d0p outp 2:1 MUX Core d0n 50 outn 50 50 50 cp cn Fig. 1. Functional Block Diagram The temperature stable ASNT5050-KMC SiGe IC can be utilized as either a high isolation selector switch or a high speed 2:1 serializer, and is intended for use in high-speed measurement / test equipment. When employed as a selector switch, the IC shown in Fig. 1 can route one of its differential data input signals d0p/d0n or d1p/d1n to its differential output outp/outn while effectively blocking the other data input. Selection of a specific data input is achieved through an appropriate external DC biasing of the selector signal inputs cp/cn. The logic is shown in Table 1. Table 1. Truth Table c d0 d1 out 0 X 0 0 0 X 1 1 1 0 X 0 1 1 X 1 As a 2:1 serializer, the IC can receive high speed input data signals into d0p/d0n and d1p/d1n and effectively multiplex them into a double frequency rate NRZ output data signal to its differential output outp/outn by using a high speed input clock signal on its selector signal inputs cp/cn. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. Rev. 2.2.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.3V), or positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground. Table 2. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.5 1.0 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type d0p d0n d1p d1n cp cn outp outn Name vcc vee Rev. 2.2.2 DESCRIPTION High-Speed I/Os 21 CML Differential data input signals with internal SE 50Ohm termination to input vcc 23 17 CML Differential data input signals with internal SE 50Ohm termination to input vcc 15 3 CML Differential clock input signals with internal SE 50Ohm termination input to vcc 5 11 CML Differential data output signals with internal SE 50Ohm termination output to vcc. Also require external SE 50Ohm termination to vcc 9 Supply and Termination Voltages Description Pin Number Positive power supply 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 (+3.3V or 0) Negative power supply 1, 7, 13, 19 (0V or -3.3V) 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% vee 0.0 V External ground vcc Ivee 135 mA Power consumption 450 mW Junction temperature -40 25 125 °C HS Input Data (d0p/d0n, d1p/d1n) Data rate / Frequency DC 32/16 Gbps/GHz When used as a selector Data rate DC 16 Gbps When used as a multiplexer Swing 0.05 1.0 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs HS Input Clock (cp/cn) Frequency DC 16 GHz Swing 0.05 1.0 V Differential or SE, p-p CM Voltage Level vcc-0.8 vcc V Must match for both inputs Duty cycle 45 50 55 % HS Output Data (outp/outn) Data rate / Frequency DC 32/16 Gbps/GHz When used as a selector Data rate DC 32 Gbps When used as a multiplexer Logic “1” level V vcc Logic “0” level vcc-0.4 V With external 50Ohm DC termination Rise/Fall times 12 13 14 ps 20%-80% Output Jitter 2 ps Peak-to-peak PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5050-KMC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 2.2.2 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. CQFP 24-Pin Package Drawing (All Dimensions in mm) Rev. 2.2.2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 2.2.2 2.1.2 2.1.1 Date 05-2020 07-2019 02-2019 2.0.1 02-2012 1.0 10-2008 Rev. 2.2.2 Changes Updated Package Information Updated Letterhead Added truth table Revised package information section Format correction Revised title Added pinout drawing Revised functional block diagram Revised description section Added power supply configuration section Added absolute maximum ratings table Revised electrical characteristics section Revised package information section Added package mechanical drawing First release 6 May 2020
ASNT5050-KMC 价格&库存
很抱歉,暂时无法提供与“ASNT5050-KMC”相匹配的价格&库存,您可以联系我们找货
