ASNT5051-KMC
ASNT5051-KMC
    ADSANTEC(先进科技)
    CQFlatPack24
    17G HIGH-ISOLATION SWITCH 1-OF-2
ASNT5051-KMC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5051-KMC DC-to-32Gbps High-Isolation Selector/Switch 1 of 2  Ideal for high speed proof-of-concept prototyping  Fully differential CML input interface  Fully differential CML output interface with 550mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 287mW  Fabricated in SiGe for high performance, yield, and reliability  Standard CQFP 24-pin package vee DC to 1.0GHz analog bandwidth for control input vcc  d1n Exhibits low jitter and limited temperature variation over industrial temperature range vcc  d1p High-speed broadband switch with high isolation for selecting one of two inputs vcc  vee vcc vcc d0p qp ASNT5051 vcc vcc d0n qn vcc vcc Rev. 1.1.2 1 vcc cn vcc cp vcc vee vee May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION d1p d1n 50 50 50 50 d0p 1 of 2 Sel Core d0n outp outn 50 50 50 50 cp cn Fig. 1. Functional Block Diagram The temperature stable and broadband ASNT5051-KMC SiGe IC can be utilized as a high isolation selector switch and is intended for use in high-speed measurement / test equipment. When The IC shown in Fig. 1 can route one of its differential data input signals (d0p/d0n or d1p/d1n) to its differential output (outp/outn) while effectively blocking the other data input with high isolation. Selection of a specific data input is achieved through appropriate external DC biasing of the selector signal inputs (cp/cn). It is also possible to apply an up to 1GHz AC signal to the selector signal inputs. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. POWER SUPPLY CONFIGURATION The part can operate with either a negative supply (vcc = 0.0V = ground and vee = −3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. Rev. 1.1.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vcc). Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.31 1.0 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type d0p d0n d1p d1n cp cn outp outn Name vcc vee Rev. 1.1.2 DESCRIPTION High-Speed I/Os 21 CML Differential data input signals with internal SE 50Ohm termination input to vcc 23 17 CML Differential data input signals with internal SE 50Ohm termination input to vcc 15 3 CML Differential select inputs with internal SE 50Ohm termination to input vcc 5 11 CML Differential data output signals with internal SE 50Ohm termination output to vcc. Also require external SE 50Ohm termination to vcc 9 Supply And Termination Voltages Description Pin Number Positive power supply (+3.3V or 0) 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 Negative power supply (0V or -3.3V) 1, 7, 13, 19 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vee vcc Ivee Power consumption Junction temperature Data rate/Frequency Swing CM Voltage Level Frequency Swing CM Voltage Level Duty cycle Data rate/Frequency Logic “1” level Logic “0” level Rise/Fall times Output Jitter MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% 0.0 V External ground 87 mA 287 mW -25 50 125 °C HS Input Data (d0p/d0n,d1p/d1n) DC 32/17 Gbps/GHz 40 800 mV Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs HS Input Clock (cp/cn) DC 1 GHz 40 800 V Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs 40 50 56 % HS Output Data (outp/outn) DC 32/17 Gbps/GHz V vcc vcc-0.55 V With external 50Ohm DC termination 15 19 ps 20%-80% 1 ps Peak-to-peak PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFP package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5051-KMC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 1.1.2 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. CQFP 24-Pin Package Drawing (All Dimensions in mm) Rev. 1.1.2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision Date 1.1.2 05-2020 Updated Package Information 1.0.2 07-2019 Updated Letterhead 1.0.1 07-2015 Initial Release Rev. 1.1.2 6 Changes May 2020
ASNT5051-KMC 价格&库存
很抱歉,暂时无法提供与“ASNT5051-KMC”相匹配的价格&库存,您可以联系我们找货
