ICL7667CBA
ICL7667CBA
    L3HARRIS
    SOIC-8
    DUAL POWER MOSFET DRIVER
ICL7667CBA 数据手册
Datasheet ICL7667 Dual Power MOSFET Driver The ICL7667 is a dual monolithic high-speed driver designed to convert TTL level signals into high current outputs at voltages up to 15V. Its high speed and current output enable it to drive large capacitive loads with high slew rates and low propagation delays. With an output voltage swing only millivolts less than the supply voltage and a maximum supply voltage of 15V, the ICL7667 is well suited for driving power MOSFETs in high frequency switched­mode power converters. The ICL7667s high current outputs minimize power losses in the power MOSFETs by rapidly charging and discharging the gate capacitance. The ICL7667s input are TTL compatible and can be directly driven by common pulse-width modulation control ICs. Rochester Electronics Manufactured Components Rochester branded components are manufactured using either die/wafers purchased from the original suppliers or Rochester wafers recreated from the original IP. All re-creations are done with the approval of the Original Component Manufacturer (OCM). Parts are tested using original factory test programs or Rochester developed test solutions to guarantee product meets or exceeds the OCM data sheet. Quality Overview • ISO-9001 • AS9120 certification • Qualified Manufacturers List (QML) MIL-PRF-35835 • Class Q Military • Class V Space Level • Qualified Suppliers List of Distributors (QSLD) • Rochester is a critical supplier to DLA and meets all industry and DLA standards. Rochester Electronics, LLC is committed to supplying products that satisfy customer expectations for quality and are equal to those originally supplied by industry manufacturers. The original manufacturer’s datasheet accompanying this document reflects the performance and specifications of the Rochester manufactured version of this device. Rochester Electronics guarantees the performance of its semiconductor products to the original OCM specifications. ‘Typical’ values are for reference purposes only. Certain minimum or maximum ratings may be based on product characterization, design, simulation, or sample testing. FOR REFERENCE ONLY © 2019 Rochester Electronics, LLC. All Rights Reserved 05062019 To learn more, please visit www.rocelec.com
ICL7667CBA 价格&库存
很抱歉,暂时无法提供与“ICL7667CBA”相匹配的价格&库存,您可以联系我们找货
