MOTOROLA
MC33285
SEMICONDUCTOR
TECHNICAL DATA
Product Preview
HIGH SIDE
TMOS DRIVER
Automotive Dual High
Side TMOS Driver
SILICON MONOLITHIC
INTEGRATED CIRCUIT
The MC33285 is a dual high side TMOS driver designed for use in
the harsh automotive switching applications.
The purpose of the MC33285 is to drive two power n-channel FETs in
a high side application with an inductive load. The application in an
automotive environment requires the capability of withstanding high
voltages and load dump transients. The MC33285 is able to withstand
reverse battery conditions at selected pins.
It protects the n-channel power FET on OUT1 under over current
condition. This device has one input to control both stages on or off.
•Temperature Range from -40°C to +125°C
•PWM Capability
•Power TMOS # 1 Over-Current and Short-Circuit Protection
•Voltage Range 7V to 40V
•Extended Temperature Range from -40°C to 125°C
•Load Dump Protected
•Over Voltage Detection and Activation of OUT2 during Overvoltage
•Single Input Control for both Output Stages
•Capacitor Value of 100nF Connected to Pin CP
•Analog Input Control Measurement Detection
•OUT1 LOAD leakage measurement detection
PIN CONNECTIONS
SRC
1
8
IN
OUT1
2
7
GND
DRN
3
6
VCC
OUT2
4
5
CP
ORDERING INFORMATION
Device
Temperature
Range
Package
MC33285D
-40°C to +125°C
SO8
Block Diagram And Typical Application
V IGN
VREF
S
R
CP
Charge
pump
Oscillator
and
Divider
tLDdet
Kl.30
C CP
VCC
DRN
Bandgap
Rthr
ION2
ION1
Load Dump
Detection
OUT2
tOUT2ect
IN
V OUT2-V DRN > V TH2
R Q
THRIN2
OUT2 Activation
Time
S
IOUTN2
THRIN1
OUT1
V OUT1-V SRC > V TH1
IOUTN1
GND
R Q
S
OC Detection
M
tOCdet
SRC
OCPC
start tOCdet
This document contains information on a new product under development. Motorola reserves the Motorola,Inc 1999
right to change or discontinue this product without notice.
Rev 2.4
MC33285
MAXIMUM RATING
Rating
Maximum voltage at pins OUT1 OUT2
Maximum voltage at pin CP
Symbol
Value
Unit
VO U T
VVCC + 20
V
VCP
50
V
Input voltage V i at DRN
VDRN
-2 ; 40
V
Input voltage V i at SRC
VSRC
-5 ; 40
V
Input voltage at pin VCC
VCC
-2 to 40
V
Input Voltage at pin IN. Condition : -2V
很抱歉,暂时无法提供与“MC33285D”相匹配的价格&库存,您可以联系我们找货
