AMR3013P
AMR3013P
    MDT(多维)
    SOP-8
    AMR SENSOR ANGLE DUAL 180DEG
AMR3013P 数据手册
AMR Angle Sensor AMR3013P AMR3013P AMR Angle Sensor Features and Benefits       Anisotropy of magnetoresistance (AMR) Technology Compatible with Wide Range of Supply Voltages Wide Airgap Tolerance Excellent Thermal Stability Very Low Hysteresis Compact Package Applications      Rotary Position Sensors Rotary Encoders Contactless Potentiometers Valve Position Sensors Knob Position Sensors General Description The output voltage of the AMR3013P AMR angle sensor is proportional to the sine or cosine functions of two times of the angle – sin(2α) and cos(2α) – of a magnetic field applied parallel to the surface of the sensor, which can be provided by a small magnet positioned above the device. The AMR3013P includes two Wheatstone bridges, which can be configured to output sine and cosine functions respectively. Each bridge includes four AMR sensor elements in a push-pull arrangement to produce a peak-to-peak signal at 2.6% of the supply voltage. Additionally, the unique AMR Wheatstone bridge technology accurately compensates the output against changes in ambient temperature. This sensor is assembled in a compact SOP8 package Operation A small magnet, placed above the AMR3013P, can be used to provide a magnetic field in any desired orientation parallel to the plane of the AMR3013P package. The following chart show a typical sensor output as a function of the angle within 0~180 of the applied magnetic field using a 6 mm diameter, 2.5 mm thick magnet and at 1 V supply. MultiDimension Technology Co., Ltd. Ver. 1.2 Web: www.dowaytech.com/en, Email: info@dowaytech.com No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, P.R. China Page 1 of 4 MDT AMR3013P AMR Angle Sensor AMR3013P Pin Out 8 1 7 2 6 3 5 Pin No. Pin Name Pin Function 1 X- Analog Differential Output2(direction X) 2 Y- Analog Differential Output2(direction Y) 3 VccY Supply Voltage(direction Y) 4 VccX Supply Voltage(direction X) 5 X+ Analog Differential Output1(direction X) 6 Y+ Analog Differential Output1(direction Y) 7 GNDY Ground(direction Y) 8 GNDX Ground(direction X) 4 Absolute Maximum Ratings Parameter Supply Voltage Storage Temperature Symbol VCC Tstg Notes TJ=25℃ - Limit 18 -40~150 Unit V ℃ Min -2 - Typ 5 4200 2700 0.04 13 -4500 Max 18 2 - Unit V Ohm PPM/℃ mV/V mV/V/℃ mV/V PPM/℃ - +/-0.1 - º -40 - 125 ℃ - 99.8 - % Specification (Differential Output) Parameter Supply Voltage Resistance of Single Bridge TC of Resistance Offset Voltage TC of Offset Voltage Peak Voltage TC of Peak Voltage Symbol VCC Rbridge TCR Voffset TCO Vpeak TCVpeak Angular Inaccuracy Δα Operating Temperature TA Amplitude Synchronism k Conditions Operating TJ=25℃, H=0 Oe TJ=-40℃~125℃ TJ=25℃ TJ=-40℃~125℃ TJ=25℃ TJ=-40℃~125℃ 0~180, TJ=25℃ H=200 Oe Operating 0~180, TJ=25℃ H=200 Oe Notes: (1) 1 Oe (Oersted) = 1 Gauss in air = 0.1 millitesla = 79.8 A/m. (2) Offset voltage=(Vo(max)-Vo(min))/2 (3) Peak voltage=|Vo(max)-offset|, Periodicity of Vpeask: sin(2ɑ) and cos(2ɑ), respectively. MultiDimension Technology Co., Ltd. Ver. 1.2 Web: www.dowaytech.com/en, Email: info@dowaytech.com No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, P.R. China Page 2 of 4 MDT AMR3013P AMR Angle Sensor AMR3013P Characteristic Curves Package Information MultiDimension Technology Co., Ltd. Ver. 1.2 Web: www.dowaytech.com/en, Email: info@dowaytech.com No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, P.R. China Page 3 of 4 MDT AMR3013P AMR Angle Sensor AMR3013P AMR Sensor Position Top view and side view (unit: mm) The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. “MultiDimension”, “MultiDimension Sensing the Future”, and “MDT” are registered trademarks of MultiDimension Technology Co., Ltd. MultiDimension Technology Co., Ltd. Ver. 1.2 Web: www.dowaytech.com/en, Email: info@dowaytech.com No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, P.R. China Page 4 of 4 MDT AMR3013P
AMR3013P 价格&库存
很抱歉,暂时无法提供与“AMR3013P”相匹配的价格&库存,您可以联系我们找货
