UM2268
UM2268
    UNION(英联)
    UFQFN10
UM2268 数据手册
UM2268 0.4Ω Ultra Low ON-Resistance, Dual, SPDT Analog Switch UM2268 QFN10 1.8×1.4 General Description The UM2268 is a dual, low-power single-pole/double-throw (SPDT) analog switch that operates from a single +1.8V to +4.4V supply. The UM2268 features guaranteed on-resistance matching (0.04Ω TYP) between switches and guaranteed on resistance flatness over the signal range (0.08Ω TYP), as well as high off-isolation and low crosstalk. This ensures excellent linearity and low distortion when switching audio signals. The UM2268 is available in Pb-free QFN10 package (1.8mm×1.4mm×0.55mm). Applications Features z z z z z z z z z z z z z z z z z Portable Instrumentation Battery-Operated Equipment Computer Peripherals Speaker and Earphone Switching Medical Equipment Audio and Video Switching Pin Configurations VCC Operating Range: +1.8V to +4.4V Low On-Resistance: 0.4Ω (TYP) @ +4.4V On-Resistance Matching: 0.04Ω (TYP) On-Resistance Flatness: 0.08Ω (TYP) -3dB Bandwidth: 80MHz Low Off-Isolation: -78dB (100kHz) Low Crosstalk: -93dB (100kHz) TTL/CMOS Compatible Break-Before-Make Switching Rail-to-Rail Input and Output Operation Lead (Pb)-Free QFN10 Package Top View (Top View) M: Month Code UM2268 QFN10 1.8×1.4 Ordering Information Part Number Packaging Type Marking Code UM2268 QFN10 1.8×1.4 AE Shipping Qty 3000pcs/7 Inch Tape & Reel ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 1/10 UM2268 Pin Description Pin Number 1, 3 10, 2 4 8, 5 Pin Name NO1, NO2 NC1, NC2 GND COM1, COM2 7, 6 IN1, IN2 9 V+ Function Normally-Open Terminal Normally-Closed Terminal Ground Common Terminal Digital Control Pin to Connect the COM Terminal to the NO or NC Terminals Power Supply Function Table LOGIC 0 1 NO OFF ON NC ON OFF Absolute Maximum Ratings Symbol V+ VIS VIN ID IP TO TSTG ESD Parameter Supply Voltage Analog Switch Input Voltage Digital Select Input Voltage Continuous DC Current Peak Current Operating Temperature Range Storage Temperature Range HBM Limit 0 to +4.6 -0.3 to (VCC+0.3) 0 to +4.6 250 350 -40 to +85 -65 to +150 4000 Unit V mA mA °C V ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 2/10 UM2268 Electrical Characteristics V+=+4.4V, GND=0V, TA=-40°C to +85°C, unless otherwise noted. Symbol V+ ICC IIN IOFF Parameter Power Supply Range Quiescent Supply Current Input Leakage Current Power Off Leakage Current ION Channel ON Leakage Current RON On-Resistance (Note 2) ΔRON RFLAT On Resistance Match Between Channels (Note 2, 3, 4) On Resistance Flatness (Note 2, 3, 5) Test Conditions Vcc (V) Limits (-40°C to 85°C) Temp Min Full Typ (Note 1) 1.8 Unit Max 4.4 V VIN=V+ or 0 4.4 Full 1.0 μA VIN=0V/4.4V 4.4 Full 1.0 μA 4.4 Full 1.0 μA 4.4 Full 1.0 μA VNO,VNC or VCOM=1.0V, ICOM=-100mA 4.4 Room Full 0.4 0.75 0.85 Ω VNO,VNC or VCOM=1.0V, ICOM=-100mA 4.4 Room Full 0.04 0.15 0.20 Ω VNO,VNC or VCOM=1.0V, 2.5V ICOM=-100mA 4.4 Room Full 0.08 0.12 0.20 Ω VNO/VNC=3.3V/0.3V, VCOM=0.3V/3.3V VCOM=0.3V/3.3V VNO or VNC=0.3V/3.3V, or Floating VIH Input High Voltage 4.4 Full VIL Input Low Voltage 4.4 Full tON Turn On Time 4.4 Room 88 ns tOFF Turn Off Time 4.4 Room 16 ns tBBM Break Before Make Time (Note 6) 4.4 Room 6 ns OIRR Off Isolation (Note 7) VBIAS=2.1V, Signal=0dBm, Test Circuit 3 100kHz Room -78 dB Room -58 dB Crosstalk VBIAS=2.1V, Signal=0dBm, Test Circuit 4 100kHz Room -93 dB Room -90 dB Room 80 MHz XTALK BW -3dB Bandwidth VIN=2.1V to 0V, RL=50Ω, CL=35pF, VNO1 or VNC1=VNO2 or VNC2=2.1V, Test Circuit 1 VIN=2.1V to 0V, RL=50Ω, CL=35pF, VNO1 or VNC1=VNO2 or VNC2=2.1V, Test Circuit 1 VIN=2.1V to 0V, RL=50Ω, CL=35pF, VNO1 or VNC1=VNO2 or VNC2=2.1V, Test Circuit 2 4.4 1MHz 4.4 1MHz VBIAS=2.1V, Signal=0dBm, Test Circuit 5 4.4 2.0 V 0.5 V Charge Injection VG=0V, RS=0Ω, Select Input to 4.4 Room 4.0 pC CL=1.0nF, Test Circuit 6 Common I/O HSD+ HSD- ON CON Capacitance 4.4 Room 56 pF (Note 8) Note 1: Typically values are at V+=4.4V and TA=+25°C. Note 2: Guaranteed by design. Resistance measurements do not include test circuit or package resistance. Note 3: Parameter is characterized but not tested in production. Note 4: ΔRON=︱RON (NO1/NC1) – RON(NO2/NC2)︱measured at identical VCC, temperature and voltage levels. Note 5: Flatness is defined as the difference between the maximum and minimum value of On Resistance over the specified range of conditions. Note 6: Guaranteed by design. Note 7: Off Isolation=20 log10 [VCOM/VNO/NC]. Note 8: TA=+25°C, f=1MHz, Capacitance is characterized but not tested in production. Q ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 3/10 UM2268 Electrical Characteristics V+=+2.7V to +3.6V, TA=-40°C to +85°C, unless otherwise noted. Symbol VNO, VNC, VCOM IIN IOFF Parameter Analog Signal Range Input Leakage Current Power Off Leakage Current ION Channel ON Leakage Current RON On-Resistance (Note 2) ΔRON RFLAT On Resistance Match Between Channels (Note 2, 3, 4) On Resistance Flatness (Note 2, 3, 5) Test Conditions Vcc (V) Limits (-40°C to 85°C) Temp Min Full VIN=0V/2.7V Typ (Note 1) 0 Unit Max V+ V 2.7 Full 1.0 μA 3.6 Full 1.0 μA 3.6 Full 1.0 μA VNO,VNC or VCOM=1.0V, ICOM=-100mA 2.7 Room Full 0.75 1.10 1.20 Ω VNO,VNC or VCOM=1.0V, ICOM=-100mA 2.7 Room Full 0.03 0.15 0.20 Ω VNO,VNC or VCOM=1.0V, 2.5V ICOM=-100mA 2.7 Room Full 0.10 0.18 0.20 Ω VNO/VNC=3.3V/0.3V, VCOM=0.3V/3.3V VCOM=0.3V/3.3V VNO or VNC=0.3V/3.3V, or Floating VIH Input High Voltage 3.0 Full VIL Input Low Voltage 3.0 Full tON Turn On Time 3.0 Room 100 ns tOFF Turn Off Time 3.0 Room 20 ns tBBM Break Before Make Time (Note 6) 3.0 Room 9.2 ns Off Isolation (Note 7) VBIAS=2.1V, Signal=0dBm, Test Circuit 3 100kHz Room -78 dB OIRR Room -58 dB VBIAS=2.1V, Signal=0dBm, Test Circuit 4 100kHz Room -93 dB Crosstalk Room -90 dB Room 80 MHz XTALK BW -3dB Bandwidth VIN=1.5V to 0V, RL=50Ω, CL=35pF, VNO1 or VNC1=VNO2 or VNC2=1.5V, Test Circuit 1 VIN=1.5V to 0V, RL=50Ω, CL=35pF, VNO1 or VNC1=VNO2 or VNC2=1.5V, Test Circuit 1 VIN=1.5V to 0V, RL=50Ω, CL=35pF, VNO1 or VNC1=VNO2 or VNC2=1.5V, Test Circuit 2 1.5 V 0.4 V 3.0 1MHz 3.0 1MHz VBIAS=2.1V, Signal=0dBm, Test Circuit 5 3.0 Charge Injection VG=0V, RS=0Ω, Select Input to 3.0 Room 3.0 pC CL=1.0nF, Test Circuit 6 Common I/O HSD+ HSD- ON CON Capacitance 3.0 Room 56 pF (Note 8) Note 1: TA=+25°C. Note 2: Guaranteed by design. Resistance measurements do not include test circuit or package resistance. Note 3: Parameter is characterized but not tested in production. Note 4: ΔRON=︱RON (NO1/NC1) – RON(NO2/NC2)︱measured at identical VCC, temperature and voltage levels. Note 5: Flatness is defined as the difference between the maximum and minimum value of On Resistance over the specified range of conditions. Note 6: Guaranteed by design. Note 7: Off Isolation=20 log10 [VCOM/VNO/NC]. Note 8: TA=+25°C, f=1MHz, Capacitance is characterized but not tested in production. Q ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 4/10 UM2268 Typical Operating Characteristics (TA=+25°C, unless otherwise noted. ) NC RDSONON NC RDS NO NORDS RDSON ON 2.7 2.7 VVCC=1.8V CC=1.8V VVCC=2.7V CC=2.7V VVCC=3.6V CC=3.6V VVCC=4.2V CC=4.2V VCC=4.4V 2.4 2.1 2.1 1.8 VCC=4.4V RDS ON (Ω) RDS ON (Ω) 1.8 VVCC=1.8V CC=1.8V VVCC=2.7V CC=2.7V VVCC=3.6V CC=3.6V VVCC=4.2V CC=4.2V VVCC=4.4V CC=4.4V 2.4 1.5 1.2 1.5 1.2 0.9 0.9 0.6 0.6 0.3 0.3 0.0 0.0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 0 0.5 1 1.5 2 VCOM (V) 1.0 1.0 0.9 0.9 0.8 0.8 0.7 0.7 0.6 0.6 RON (Ω) RON (Ω) 3 3.5 4 4.5 NO NO RONRON vs.vs.VVCOM (Temp) COM (Temp) NCNC RON (Temp) R ONvs. vs. V VCOM COM(Temp) 0.5 0.5 0.4 0.4 0.3 0.3 VCC=3.6V,-40℃ VCC=3.6V, -40°C 0.2 VCC=3.6V,-40℃ VCC=3.6V, -40°C 0.2 VCC=3.6V,25℃ VCC=3.6V, 25°C 0.1 VCC=3.6V, 25°C VCC=3.6V,25℃ 0.1 VCC=3.6V, 85°C VCC=3.6V,85℃ 0.0 VCC=3.6V, 85°C VCC=3.6V,85℃ 0.0 0 0.6 1.2 1.8 VCOM (V) 2.4 3 3.6 0 0.6 1.2 1.8 VCOM (V) 2.4 3 3.6 NONO RON (Temp) R ONvs. vs. V VCOM COM (Temp) NCNC RON (Temp) RONvs. vs.V VCOM COM (Temp) 1.0 1.0 0.9 0.9 0.8 0.8 0.7 0.7 0.6 0.6 RON (Ω) RON (Ω) 2.5 VCOM (V) 0.5 0.5 0.4 0.4 0.3 0.3 VCC=4.2V,-40℃ VCC=4.2V, -40°C 0.2 0.1 VCC=4.2V,-40℃ V =4.2V, -40°C 0.2 VCC=4.2V,25℃ VCC=4.2V, 25°C CC VCC=4.2V,25℃ VCC=4.2V, 25°C 0.1 VCC=4.2V, 85°C VCC=4.2V,85℃ VCC=4.2V, 85°C VCC=4.2V,85℃ 0.0 0.0 0 0.5 1 1.5 2 2.5 VCOM (V) 3 3.5 4 4.5 0 0.5 1 1.5 2 2.5 VCOM (V) 3 3.5 4 4.5 ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 5/10 UM2268 Typical Operating Characteristics (Continued) (TA=+25°C, unless otherwise noted. ) 1.0 0.9 0.9 0.8 0.8 0.7 0.7 0.6 0.6 RON (Ω) RON (Ω) NCNC RON (Temp) RONvs. vs.V VCOM COM (Temp) 1.0 0.5 0.5 0.4 0.4 0.3 0.3 0.2 VCC=4.4V,-40℃ VCC=4.4V, -40°C 0.1 VCC=4.4V, 25°C VCC=4.4V,25℃ VCC=4.4V, 85°C VCC=4.4V,85℃ NONO RON vs. (Temp) RON vs.VVCOM COM (Temp) VCC=4.4V,-40℃ 0.2 VCC=4.4V, -40°C VCC=4.4V,25℃ VCC=4.4V, 25°C 0.1 VCC=4.4V, 85°C VCC=4.4V,85℃ 0.0 0.0 0 0.5 1 1.5 2 2.5 VCOM (V) 3 3.5 4 4.5 0 0.5 1 1.5 2 2.5 VCOM (V) 3 3.5 4 Bandwidth Logic Threshold SupplyVoltage Voltage Logic Thresholdvs. vs. Supply 2.0 VTH+ VTH+ VTHVTH- Logic Threshold (V) 1.8 1.6 1.4 1.2 1.0 0.8 0.6 1.5 2 2.5 3 3.5 Supply Voltage (V) Crosstalk 4 4.5 Off Isolation ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 6/10 4.5 UM2268 Test Circuits Test Circuit 1. Switching Timing (tON, tOFF) Test Circuit 2. Break-Before-Make Timing Network Analyzer RS COM VIN IN=0V/VCC RT VS GND Vsel NO/NC GND GND VOUT GND GND Off-isolation=20Log(VOUT/VIN) RT GND Test Circuit 3. Off-Isolation ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 7/10 UM2268 Test Circuit 4. Channel-to-Channel Crosstalk Network Analyzer RS COM VIN IN=0V/VCC VS GND Vsel GND NC/NO GND VOUT GND RT GND Test Circuit 5. Bandwidth Test Circuit 6. Charge Injection Test ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 8/10 UM2268 Package Information UM2268 QFN10 1.8×1.4 Outline Drawing DIMENSIONS Symbol Typ Max Min Typ A 0.50 0.55 0.60 0.020 0.022 0.024 A1 0.00 - 0.05 0.000 - 0.002 A3 A 0.15REF A3 Max 0.006REF b 0.15 0.20 0.25 0.006 0.008 0.010 D 1.35 1.40 1.45 0.053 0.055 0.057 E 1.75 1.80 1.85 0.069 0.071 0.073 e A1 INCHES Min L e E MILLIMETERS 0.40BSC 0.016BSC L 0.30 0.40 0.50 0.012 0.016 0.020 L1 0.40 0.50 0.60 0.016 0.020 0.024 Land Pattern NOTES: 1. Compound dimension: 1.80×1.40; 2. Unit: mm 3. General tolerance ±0.05mm unless otherwise specified; 4. The layout is just for reference. Tape and Reel Orientation ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 9/10 UM2268 GREEN COMPLIANCE Union Semiconductor is committed to environmental excellence in all aspects of its operations including meeting or exceeding regulatory requirements with respect to the use of hazardous substances. Numerous successful programs have been implemented to reduce the use of hazardous substances and/or emissions. All Union components are compliant with the RoHS directive, which helps to support customers in their compliance with environmental directives. For more green compliance information, please visit: http://www.union-ic.com/index.aspx?cat_code=RoHSDeclaration IMPORTANT NOTICE The information in this document has been carefully reviewed and is believed to be accurate. Nonetheless, this document is subject to change without notice. Union assumes no responsibility for any inaccuracies that may be contained in this document, and makes no commitment to update or to keep current the contained information, or to notify a person or organization of any update. Union reserves the right to make changes, at any time, in order to improve reliability, function or design and to attempt to supply the best product possible. Union Semiconductor, Inc Add: Unit 606, No.570 Shengxia Road, Shanghai 201210 Tel: 021-51093966 Fax: 021-51026018 Website: www.union-ic.com ________________________________________________________________________ http://www.union-ic.com Rev.11 Sep.2016 10/10
UM2268 价格&库存
很抱歉,暂时无法提供与“UM2268”相匹配的价格&库存,您可以联系我们找货
