MK5306
MK5306
    IFM(易福门)
    Module
MK5306 数据手册
MK5306 C-slot cylinder sensor MKC3028-ANKG/G/ZH 1 2 fastening clamp Sensing face Product characteristics Electrical design NPN Output function normally open Dimensions [mm] 17.5 x 2.8 x 7.7 Electrical data Operating voltage Current consumption [V] [mA] Protection class < 10 III Reverse polarity protection Max. power-on delay time 10...30 DC; ("supply class 2" to cULus) yes [ms] 30 Outputs Electrical design NPN Output function normally open Max. voltage drop switching output DC [V] 2.5 Permanent current rating of switching output DC [mA] 100 Switching frequency DC [Hz] 10000 Short-circuit protection yes Overload protection yes Detection zone Response sensitivity [mT] 2.8 Travel speed [m/s] > 10 Hysteresis [mm] 1.5 Repeatability [mm] < 0.2 Accuracy / deviations ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MK5306-03 — 12.11.2020 — MK5306 C-slot cylinder sensor MKC3028-ANKG/G/ZH Operating conditions Ambient temperature [°C] -25...85 Protection IP 65; IP 67 Tests / approvals EMC MTTF EN 61000-4-2 ESD - CD / 8 kV AD EN 61000-4-3 HF radiated 10 V/m EN 61000-4-4 Burst 2 kV EN 61000-4-6 HF conducted 10 V EN 55011 class B [years] UL approval 3694 UL Approval no. C008 Mechanical data Weight [g] 18.3 Mounting non-flush mountable Cylinder type C-slot cylinders Dimensions [mm] Materials 17.5 x 2.8 x 7.7 housing: PA; fastening clamp: stainless steel Displays / operating elements Display switching status 1 x LED, yellow Remarks Pack quantity 1 pcs. Electrical connection Cable: 2 m, PUR; 3 x 0.08 mm² Connection Core colours : BK = black BN = brown BU = blue ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — MK5306-03 — 12.11.2020 —
MK5306 价格&库存
很抱歉,暂时无法提供与“MK5306”相匹配的价格&库存,您可以联系我们找货
