Product Brief
MPC565PB/D
Rev. 3, 2/2003
MPC565/MPC566
Product Brief
This document provides an overview of the MPC565/MPC566 microcontrollers, including a
block diagram showing the major modular components, sections that list the major features,
and differences between the MPC565/MPC566 and the MPC555. The MPC565 and MPC566
devices are members of the Motorola MPC500 RISC Microcontroller family. The parts herein
will be referred to only as MPC565 unless specific parts need to be referenced.
Table 1. MPC565/MPC566 Features
1
Device
Flash
Code Compression
MPC565
1 Mbyte
Code compression not supported
MPC566
1 Mbyte
Code compression supported
Introduction
The MPC565 device offers the following features:
PowerPC™ core with a floating point unit (FPU) and a burst buffer controller (BBC)
Unified system integration unit (USIU), a flexible memory controller, and improved
interrupt controller
1 Mbyte of Flash memory (UC3F)
— Typical endurance of 100,000 write/erase cycles @ 25ºC
— Typical data retention of 100 years @ 25ºC
36 Kbytes of static RAM (two CALRAM modules)
— 8 Kbytes of normal access or overlay access (sixteen 512-byte regions)
— 4 Kbytes in CALRAM A, 4 Kbytes in CALRAM B
Three time processor units (TPU3)
— TPU3 A and TPU3 B are connected to DPTRAM AB (6 Kbytes)
— TPU3 C is connected to DPTRAM C (4 Kbytes)
A 22-timer channel modular I/O system (MIOS14)
— Same as MIOS1 plus a real-time clock sub-module (MRTCSM), 4 counter
sub-modules (MCSM), and 4 PWM sub-modules (MPWMSM)
Three TouCAN modules (TouCAN_A, TouCAN_B, and TouCAN_C)
Two enhanced queued analog to digital converters (QADC64E A, QADC64E B)
with analog multiplexers (AMUX) for 40 total analog channels. These modules are
configured so each module can access all 40 of the analog inputs to the part.
Block Diagram
Two queued serial multi-channel modules (QSMCM A, QSMCM B), each of which contains a
queued serial peripheral interface (QSPI) and two serial controller interfaces (SCI/UART)
-40°C – 125°C ambient temperature, -40°C – 85°C for suffix C devices, -55°C– 125°C for
suffix A devices
Debug features:
— A J1850 (DLCMD2) communications module
— A Nexus debug port (class 3) – IEEE-ISTO 5001-1999
— JTAG and background debug mode (BDM)
1.1
Packaging and Electrical
Block Diagram
Figure 1 is a block diagram of the MPC565.
JTAG
Burst
Buffer
Controller 2
512 Kbytes
Flash
512 Kbytes
Flash
U-Bus
DECRAM
(4Kbytes)
PowerPC
4 Kbyte CALRAM B
Core
FP
E-Bus
USIU
READI
4 Kbyte Overlay
L2U
L-Bus
32 Kbyte CALRAM A
28 Kbytes SRAM
No Overlay
4 Kbyte Overlay
QADC64E
w/AMUX
QADC64E
w/AMUX
QSMCM
UIMB
I/F
QSMCM
DLCMD2
IMB3
TPU3
6 Kbytes
DPTRAM
TPU3
TPU3
4 Kbytes
DPTRAM
Tou
CAN
Tou
CAN
Tou
CAN
MIOS14
Figure 1. MPC565 Block Diagram
2
MPC565/MPC566 Product Brief
MOTOROLA
Detailed Feature List
1.2
The MPC565 key features are explained in the following sections.
1.2.1
1.2.2
1.2.3
1.2.4
High Performance CPU System
Fully static design
Four major power saving modes
— On, doze, sleep, deep-sleep and power-down
RISC MCU Central Processing Unit (RCPU)
High-performance core
— PowerPC single issue integer core
— Precise exception model
— Floating point
— Code compression (MPC566 only)
– Compression reduces usage of internal or external Flash memory
– Compression optimized for automotive (non-cached) applications
– New compression scheme decreases code size to 40% –50% of source
MPC500 System Interface (USIU)
MPC500 system interface (USIU, BBC, L2U)
Periodic interrupt timer, bus monitor, clocks, decrementer and time base
Clock synthesizer, power management, reset controller
External bus tolerates 5-V inputs, provides 2.6-V outputs
Enhanced interrupt controller supports a separate interrupt vector for up to eight external and 40
internal interrupts
IEEE 1149.1 JTAG test access port
Bus supports multiple master designs
USIU supports dual-mapping of Flash to move part of internal Flash memory to external bus for
development
External bus, supporting non-wraparound burst for instruction fetches, with up to 8 instructions
per memory cycle
Burst Buffer Controller (BBC) Module
Exception vector table relocation features allow exception table to be relocated to following
locations:
— 0x0000 0000 - 0x0000 1FFF (normal MPC500 exception table location)
— 0x0001 0000 - 0x0001 1FFF (0 + 64 Kbytes; second page of internal Flash)
— Second internal Flash module
— Internal SRAM
— 0x0FFF_0100 (external memory space; normal MPC500 exception table location)
MOTOROLA
3
1.2.5
1.2.6
1.2.7
Flexible Memory Protection Unit
Flexible memory protection units in BBC (IMPU) and L2U (DMPU)
Default attributes available in one global entry
Attribute support for speculative accesses
Memory Controller
Flexible chip selects via memory controller
24-bit address and 32-bit data buses
4- to 16-Mbyte (data) or 4-Gbyte (instruction) region size support
Four-beat transfer bursts, two-clock minimum bus transactions
Use with SRAM, EPROM, Flash and other peripherals
Byte selects or write enables
32-bit address decodes with bit masks
Four instruction regions
Four data regions
1 Mbyte of CDR3 Flash EEPROM Memory (UC3F)
1 Mbyte Flash
— Two UC3F modules, 512 Kbytes each
Page mode read
Block (64-Kbyte) erasable
External 4.75- to 5.25-V VPP program and erase power supply
1.2.8
36-Kbyte Static RAM (CALRAM)
36-Kbyte static calibration RAM
— Composed of 4-Kbyte and 32-Kbyte CALRAM modules
Fast access: one clock
Keep-alive power
Soft defect detection (SDD)
4 Kbyte calibration (overlay) RAM per module (8 Kbytes total)
Eight 512-byte overlay regions per module (16 regions total)
1.2.9
4
General Purpose I/O Support (GPIO)
General-purpose I/O support
Address (24) and data (32) pins can be used as GPIO in single-chip mode
16 GPIO in MIOS14
Many peripheral pins can be used as GPIO when not used as primary functions
5-V outputs with slew rate control
MOTOROLA
1.2.10 Debug Features
Extensive system debug support
On-chip watchpoints and breakpoints
Program flow tracking
Background debug mode (BDM)
1.2.10.1 Nexus Debug Port (Class 3)
Nexus/IEEE – ISTO 5001-1999 debug port (Class 3)
Nine- or 16-pin interface
1.2.10.2 Message Data Link Controller (DLCMD2) Module
Two pins muxed with QSMCMB pins. Muxing controlled by QSMCMB PCS3 pin assignment
register
SAE J1850 Class B data communications network interface compatible and ISO compatible for
low-speed (
很抱歉,暂时无法提供与“MPC565CZP40”相匹配的价格&库存,您可以联系我们找货
