TMR2001S
TMR2001S
    MDT(多维)
    SC74A
    TMR SENSOR MAG FIELD 8MV/V/OE
TMR2001S 数据手册
Datasheet V1.0a TMR2001 TMR Linear Sensor General Description The TMR2001 linear sensor utilizes a unique push-pull Wheatstone bridge composed of four TMR sensor elements. The TMR2001 is available in a 3 mm X 3 mm X 1.45 mm SOT23-5 package. Features and Benefits  Tunneling Magneto resistance (TMR) Technology  High Sensitivity  Low Power Consumption  Excellent Thermal Stability  Compatible with Wide Range of Supply Voltages  No need for set/reset calibration Applications  Weak Magnetic Field Sensing  Current Sensors TMR2001  Position and Displacement Sensing Transfer Curve The following figure shows the response of the TMR2001 to an applied magnetic field in the range of ±5 Oe and ±200 Oe when the TMR2001 is biased at 1V. 1/4 Datasheet V1.0a Pin Configuration (Arrow indicates direction of applied field that generates a positive output voltage.) Pin No. Pin Name Pin Function VCC 1 Supply Voltage NA 2 Not connected V+ 3 Analog Differential Output 1 Gnd 4 Ground V- 5 Analog Differential Output 2 Top View Absolute Maximum Ratings Parameter Symbol Limit Unit Supply Voltage VCC 7 V Reverse Supply Voltage VRCC 7 V Max Exposed Field HE 4000 Oe ESD Voltage VESD 4000 V Operating Temperature TA -40~125 °C Storage Temperature Tstg -50 ~150 °C (1) Specification (VCC=1.0V, TA=25°C, Differential Output) Parameter Symbol Conditions Supply Voltage VCC Operating Min Output Open Typ Max Unit 1 7 V 16 (2) μA Supply Current ICC Resistance R Sensitivity SEN Saturation Field Hsat Non-Linearity NONL Offset Voltage Voffset Hysteresis Hys Fit @±5Oe 0.4 Oe Temperature Coefficient of Resistance TCR H = 0 Oe -560 PPM/°C Temperature Coefficient of Sensitivity TCS -1160 PPM/°C Fit @±5Oe 63 kOhm 8 mV/V/Oe -25 Fit @±5Oe 40 1.2 -30 Notes: (1) 1 Oe (Oersted) = 1 Gauss in air = 0.1 millitesla = 79.8 A/m. (2) Custom sensor resistance may be available upon request. 2/4 Oe %FS 30 mV/V Datasheet V1.0a Package Information SOT23-5L package TMR Sensor Position Top view and side view(unit: mm) 3/4 Datasheet V1.0a MultiDimension Technology Co., Ltd. Address:No.7 Guangdong Road, Zhangjiagang Free Trade Zone, Jiangsu, 215634, China Web: www.dowaytech.com/en Email: info@dowaytech.com The information provided herein by MultiDimension Technology Co., Ltd. (hereinafter MultiDimension) is believed to be accurate and reliable. Publication neither conveys nor implies any license under patent or other industrial or intellectual property rights. MultiDimension reserves the right to make changes to product specifications for the purpose of improving product quality, reliability, and functionality. MultiDimension does not assume any liability arising out of the application and use of its products. MultiDimension’s customers using or selling this product for use in appliances, devices, or systems where malfunction can reasonably be expected to result in personal injury do so at their own risk and agree to fully indemnify MultiDimension for any damages resulting from such applications. 4/4
TMR2001S 价格&库存
很抱歉,暂时无法提供与“TMR2001S”相匹配的价格&库存,您可以联系我们找货
