Q50BU
Q50BU
    BANNER(邦纳)
    Module
Q50BU 数据手册
L-GAGE® Q50 Series with Analog Output Datasheet LED-Based Linear Displacement Sensor with Analog Output and TEACH-Method Configuration • • • • • • • • • • • • Fast, easy-to-use integrated push button TEACH-method configuration; no potentiometer adjustments Selectable output response speeds: 4 milliseconds or 64 milliseconds Teach a sensing window size and position, or set-point threshold centered within a 100 mm window Two sensing ranges, depending on model: 100 mm to 300 mm (visible red beam models) and 100 mm to 400 mm (infrared beam models) Sensor linearity is better than 3 mm Banner's patented scalable analog output1 automatically distributes the output signal over the width of configured sensing window Analog output slope is either positive or negative, depending upon which window limit is configured first Two bicolor Status LEDs Choose 2 m (6.6 ft) or 9 m (29.5 ft) unterminated cable, or swivel 5-pin Euro-style quick-disconnect connector Rugged construction withstands demanding sensing environments; rated IEC IP67, NEMA 6 Select models with either visible red or infrared beam Select models with either a 0 V to 10 V or 4 mA to 20 mA output WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or deenergized (off) output condition. Models Model Number Sensing Range Cable2 100 mm to 300 mm (3.9 in to 11.8 in) 5-pin Euro-style quick-disconnect Q50BVI Q50BVIQ Q50BVU Q50BUQ 5-wire, 2 m (6.5 in) cable 100 mm to 400 mm (3.9 in to 15.7 in) 5-pin Euro-style quick-disconnect 5-wire, 2 m (6.5 in) cable 5-pin Euro-style quick-disconnect Output 4 mA to 20 mA Visible Red LED 5-wire, 2 m (6.5 in) cable 5-pin Euro-style quick-disconnect Q50BI Q50BU Beam 5-wire, 2 m (6.5 in) cable Q50BVUQ Q50BIQ Supply Voltage 0 V to 10 V 15 V DC to 30 V DC 4 mA to 20 mA Infrared LED 0 V to 10 V 1 U.S. patent #6,122,039 2 To order the 9 m (30 ft) PVC cable model, add the suffix "W/30" to the cabled model number. Models with a quick disconnect require a mating cordset. Original Document 64323 Rev B 11 February 2020 64323 L-GAGE® Q50 Series with Analog Output Overview Teach/Output Indicator LED (yellow or red) Programming Push Button Range Indicator LED (red or green) The Q50 is an easy-to-use triangulation sensor which provides a sophisticated, yet cost-effective solution for demanding measurement applications. Q50 series sensors feature compact, all-in-one design and require no separate controller. Near and far sensing window limits are set quickly using simple push-button or remote signal TEACH-method configuration. The analog output has the option of being set with a sensing distance centered within a 100 mm window. The sensor features Banner's patented digital signal processing algorithm3, which automatically distributes the 0 V DC to 10 V DC (or 4 mA to 20 mA) output signal over the width of the configured window. QD fitting rotates for wiring in any direction Figure 1. L-GAGE Q50 sensor features Indicator Status Conditions Indicator Status Range LED (green/red) Green – Target is within sensing range (either 100 mm to 300 mm for visiblebeam models, or 100 mm to 400 mm for infrared beam models) Red – Target is outside sensing range OFF – Sensor Power OFF Teach/Output LED (amber/red) Amber – Target is within taught window limits OFF – Target is outside taught window limits Red – Sensor is in TEACH configuration 3 2 U.S. patent #6,122,039 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 64323 Rev B L-GAGE® Q50 Series with Analog Output Optical Triangulation PSD Receiver Element R Signal Conditioning Circuitry Lenses Near Limit Far Limit Target Movement Microprocessor Output Circuitry Emitter Circuitry E Laser Emitter The function of the Q50 sensor is based on optical triangulation. The emitter circuitry and optics create a light source which is directed toward a target. The light source bounces off the target, scattering some of its light through another lens to the sensor's position-sensitive device (PSD) receiver element. The target's distance from the receiver determines the light's angle to the receiver element. This angle determines where the returned light will fall along the PSD receiver element. The position of the light on the PSD receiver element is processed through analog and digital electronics and analyzed by the microprocessor, which calculates the appropriate output value. The analog output provides either a current or voltage output, or a variable signal proportional to the target's position within the user-configured analog window limits. Programmed Sensing Window Figure 2. Using optical triangulation to determine sensing distance Installation Notes Some targets pose specific problems for sensing distances. Examples include those with a stepped plan facing the sensor, a boundary line, or rounded targets. For such applications see Figure 3 on p. 3 and Figure 4 on p. 3 for suggested mounting orientations. Figure 3. Sensor orientations for typical targets: recommended Figure 4. Sensor orientations for typical targets: not recommended P/N 64323 Rev B www.bannerengineering.com - Tel: + 1 888 373 6767 3 L-GAGE® Q50 Series with Analog Output Using the Q50 Analog Output Sensor Response Speed To control the response speed, connect the black wire as follows: • Fast Speed (4 ms): Connect black wire to +5 V DC to 30 V DC • Slow Speed (64 ms): Connect black wire to 0 V DC to +2 V DC (or open connection) Window Limits Window limits may be taught to the sensor either remotely (using the gray wire) or by using the sensor's Teach button. The Q50 sensor operates in two modes: TEACH (or configuration mode) and Run mode. Note: All LED indicators momentarily turn OFF when the sensor changes state between Run mode and TEACH configuration. Configuration Instructions Push-Button Procedure 1. Press the Teach button until the Teach LED turns red (hold button in for about 2 seconds). This indicates the sensor is waiting for the first window limit. 2. Configure the first limit. a) Position the target for the first limit The Range LED should be green, indicating a valid target. b) Briefly press the Teach button. The first limit is configured. The Teach LED flashes red at 2 Hz to acknowledge receiving the first window limit. It is now waiting for the second limit. 3. Configure the second limit. a) Position the target for the second limit. The Range LED should be green, indicating a valid target. b) Press the Teach button again. The second limit is configured. The Teach LED will turn either amber or OFF as the sensor returns to RUN mode. Remote Configuration Configure the sensor remotely or disable/enable the push button using the gray wire. This is accomplished via the gray wire. Disabling the push button prevents unauthorized or accidental changes to the configuration settings. Connect the gray wire of the Q50 Gauging Sensor to +5 V DC to 30 V DC, with a remote configuration switch connected between them. Note: The impedance of the remote teach input is 15 kΩ. To configure, pulse the wire as illustrated in Figure 5 on p. 4. The duration of each button click or remote input pulse is defined as T, where T is: 0.04 s < T < 0.8 s. > 0.8 sec T Remote T each Window Limits T Teach First Window Limit T T Teach Second Window Limit T T T Push Button Lockout T T Push Button Lockout 0.04 sec < T < 0.8 sec Figure 5. Timing for remote TEACH configuration 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 64323 Rev B L-GAGE® Q50 Series with Analog Output Analog Output The Q50 gauging sensor may be configured for either a positive or a negative output slope; see Figure 6 on p. 5. If the near limit is taught first, the slope will be positive; if the far limit is taught first the slope will be negative. Banner's patented scalable analog output automatically distributes the output signal over the width of the programmed sensing window. (Output is either 0 V to 10 V or 4 mA to 20 mA, depending on the model.) Current Models 20 10 Positive Slope Positive Slope Analog Output (mA) Analog Voltage Output (V dc) Voltage Models 0 4 Near Window Far Window Target Position Figure 6. Analog voltage output as a function of target position (loss of signal – 0 V) Near Window Target Position Far Window Figure 7. Analog current output as a function of target position (loss of signal – 3.6 mA) Teaching Analog Limits Using a Fixed 100 mm Window For some analog applications, a sensing distance set point centered within a sensing window is required. The TEACH procedure is simple: teaching the same limit twice causes the sensor to configure a window centered on the position taught. This window is 100 mm wide (taught position ±50 mm). Wiring Diagrams Quick disconnect wiring diagrams are functionally identical. 1 + 15-30V dc – 3 2 5-30V dc (fast response) 0-2V dc (slow response) 4 5 Teach Key 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray + 5-30V dc Bare P/N 64323 Rev B www.bannerengineering.com - Tel: + 1 888 373 6767 5 L-GAGE® Q50 Series with Analog Output Specifications Sensing Range Q50BV: 100 mm to 300 mm (3.9 in to 11.8 in) Q50B: 100 mm to 400 mm (3.9 in to 15.7 in) Remote and Speed Input Impedance 15 kΩ Supply Voltage 15 V DC to 30 V DC (10% maximum ripple); 70 mA max. (exclusive of load) Supply Protection Circuitry Protected against reverse polarity and transient overvoltages Remote Teach Input To Teach: Connect gray wire to +5 V DC to 30 V DC To Disable: Connect gray wire to 0 V DC to +2 V DC (or open connection) Response Speed Fast Speed: Connect black wire to +5 V DC to 30 V DC Slow Speed: Connect black wire to 0 V DC to +2 V DC (or open connection) Delay at Power-up 2 seconds Sensing Beam Q50BV: Visible red, 685 nm (typical); 20 mm dia. (max.) beam size Q50B: Infrared, 880 nm (typical); 20 mm diameter (maximum) beam size Output Configuration Depending on model 4 mA to 20 mA current sourcing models: 1 kΩ max. load at 24 V dc. Max. load = [(VCC-4.5)/0.02]Ω; loss of signal or target outside of sensor range: 3.6 mA 0 V to 10 V voltage sourcing models: 15 mA max.; loss of signal or target outside of sensor range: 0 V Minimum Taught Window Target distance at 300 mm: 50 mm window Target distance at 125 mm: 10 mm window Ambient Light Immunity
Q50BU 价格&库存
很抱歉,暂时无法提供与“Q50BU”相匹配的价格&库存,您可以联系我们找货
