MC74HC139A
Dual 1-of-4 Decoder/
Demultiplexer
High–Performance Silicon–Gate CMOS
The MC74HC139A is identical in pinout to the LS139. The device
inputs are compatible with standard CMOS outputs; with pull–up
resistors, they are compatible with LSTTL outputs.
This device consists of two independent 1–of–4 decoders, each of
which decodes a two–bit Address to one–of–four active–low outputs.
Active–low Selects are provided to facilitate the demultiplexing and
cascading functions. The demultiplexing function is accomplished by
using the Address inputs to select the desired device output, and
utilizing the Select as a data input.
Output Drive Capability: 10 LSTTL Loads
Outputs Directly Interface to CMOS, NMOS and TTL
Operating Voltage Range: 2.0 to 6.0 V
Low Input Current: 1.0 µA
High Noise Immunity Characteristic of CMOS Devices
In Compliance with the Requirements Defined by JEDEC Standard
No. 7A
Chip Complexity: 100 FETs or 25 Equivalent Gates
SELECTa
1
16
VCC
A0a
2
15
SELECTb
A1a
3
14
Y0a
4
13
A0b
A1b
Y1a
5
12
Y0b
Y2a
6
11
Y1b
Y3a
7
10
Y2b
GND
8
9
Y3b
http://onsemi.com
MARKING
DIAGRAMS
16
16
MC74HC139AN
AWLYYWW
1
PDIP–16
N SUFFIX
CASE 648
1
16
16
HC139A
AWLYWW
1
SO–16
D SUFFIX
CASE 751B
1
16
16
HC
139A
ALYW
1
TSSOP–16
DT SUFFIX
CASE 948F
Figure 1. Pin Assignment
A
L, WL
Y, YY
W, WW
1
= Assembly Location
= Wafer Lot
= Year
= Work Week
FUNCTION TABLE
Inputs
Outputs
Select
A1
A0
Y0
Y1 Y2
Y3
H
L
L
L
L
X
L
L
H
H
X
L
H
L
H
H
L
H
H
H
H
H
L
H
H
H
H
H
H
L
H
H
H
L
H
ORDERING INFORMATION
Device
Semiconductor Components Industries, LLC, 2001
June, 2001 – Rev. 8
1
Shipping
MC74HC139AN
PDIP–16
2000/Box
MC74HC139AD
SOIC–16
48/Rail
SOIC–16
2500/Reel
MC74HC139ADR2
X = don’t care
Package
MC74HC139ADT
TSSOP–16
96/Rail
MC74HC139ADTR2
TSSOP–16
2500/Reel
Publication Order Number:
MC74HC139A/D
MC74HC139A
ADDRESS
INPUTS
A0a
A1a
2
4
3
5
6
7
SELECTa
ADDRESS
INPUTS
A0b
A1b
Y1a
Y2a
ACTIVE–LOW
OUTPUTS
Y3a
PIN 16 = VCC
PIN 8 = GND
1
14
12
13
11
10
9
SELECTb
Y0a
Y0b
Y1b
Y2b
Y3b
15
Figure 2. Logic Diagram
http://onsemi.com
2
ACTIVE–LOW
OUTPUTS
MC74HC139A
MAXIMUM RATINGS (Note 1)
Symbol
Parameter
Value
Unit
VCC
DC Supply Voltage
(Referenced to GND)
0.5 to 7.0
V
VIN
DC Input Voltage
(Referenced to GND)
1.5 to VCC 1.5
V
VOUT
DC Output Voltage
0.5 to VCC 0.5
V
IIN
DC Input Current, per Pin
mA
IOUT
DC Output Current, per Pin
25
mA
ICC
DC Supply Current, VCC Pin
50
mA
IGND
DC Ground Current per Ground Pin
50
mA
TSTG
Storage Temperature Range
65 to 150
C
TL
Lead Temperature, 1 mm from Case for 10 Seconds
260
C
TJ
Junction Temperature Under Bias
150
C
JA
Thermal Resistance
PDIP
SOIC
TSSOP
78
112
148
C/W
PD
Power Dissipation in Still Air at 85C
PDIP
SOIC
TSSOP
750
500
450
mW
MSL
Moisture Sensitivity
FR
Flammability Rating
VESD
ESD Withstand Voltage
Human Body Model (Note 3)
Machine Model (Note 4)
Charged Device Model (Note 5)
2000
200
1000
V
ILATCH–UP
Latch–Up Performance
Above VCC and Below GND at 85C (Note 6)
300
mA
(Referenced to GND) (Note 2)
Level 1
Oxygen Index: 30% – 35%
UL–94–VO (0.125 in)
1. Absolute maximum continuous ratings are those values beyond which damage to the device may occur. Extended exposure to these
conditions or conditions beyond those indicated may adversely affect device reliability. Functional operation under absolute maximum–rated
conditions is not implied.
2. IO absolute maximum rating must be observed.
3. Tested to EIA/JESD22–A114–A.
4. Tested to EIA/JESD22–A115–A.
5. Tested to JESD22–C101–A.
6. Tested to EIA/JESD78.
7. For high frequency or heavy load considerations, see Chapter 2the ON Semiconductor High–Speed CMOS Data Book (DL129/D).
RECOMMENDED OPERATING CONDITIONS
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎ
ÎÎÎÎ
ÎÎÎ
Symbol
Parameter
Min
Max
Unit
VCC
DC Supply Voltage
(Referenced to GND)
2.0
6.0
V
VIN, VOUT
DC Input Voltage, Output Voltage
(Referenced to GND)
VCC
V
TA
Operating Temperature, All Package Types
55
125
C
tr, tf
Input Rise and Fall Time
(Figure 3)
500
400
ns
VCC = 2.0 V
VCC = 4.5 V
VCC = 6.0 V
8. Unused inputs may not be left open. All inputs must be tied to a high–logic voltage level or a low–logic input voltage level.
http://onsemi.com
3
MC74HC139A
DC ELECTRICAL CHARACTERISTICS (Voltages Referenced to GND)
VCC
Guaranteed Limit
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎÎ
Symbol
Parameter
Test Conditions
V
55C to 25C
85C
125C
Unit
VIH
Minimum High–Level Input
Voltage
VOUT = 0.1 V or VCC 0.1 V
|IOUT| 20 A
2.0
4.5
6.0
1.5
3.15
4.2
1.5
3.15
4.2
1.5
3.15
4.2
V
VIL
Maximum Low–Level Input
Voltage
|IOUT| 20 A
2.0
4.5
6.0
0.5
1.35
1.8
0.5
1.35
1.8
0.5
1.35
1.8
V
VOH
Minimum High–Level Output
Voltage
VIN = VIH or VIL
|IOUT| 20 A
2.0
4.5
6.0
1.9
4.4
5.9
1.9
4.4
5.9
1.9
4.4
5.9
V
4.5
6.0
3.98
5.48
3.84
5.34
3.70
5.20
2.0
4.5
6.0
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
4.5
6.0
0.26
0.26
0.33
0.33
0.40
0.40
VIN = VIH or VIL
VOL
Maximum Low–Level Output
Voltage
|IOUT| 4.0 mA
|IOUT| 5.2 mA
VIN = VIH or VIL
|IOUT| 20 A
VIN = VIH or VIL
|IOUT| 4.0 mA
|IOUT| 5.2 mA
V
IIN
Maximum Input Leakage
Current
VIN = VCC or GND
6.0
0.1
1.0
1.0
A
ICC
Maximum Quiescent Supply
Current (per Package)
VIN = VCC or GND
IOUT = 0 A
6.0
4
40
160
A
9. Information on typical parametric values can be found in the ON Semiconductor High–Speed CMOS Data Book (DL129/D).
AC ELECTRICAL CHARACTERISTICS (CL = 50 pF, Input tr = tf = 6.0 ns)
VCC
Guaranteed Limit
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
ÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎÎÎ
ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎÎ
ÎÎÎ
ÎÎÎÎ
ÎÎ
Symbol
Parameter
V
55C to 25C
85C
125C
Unit
tPLH,
tPHL
Maximum Propagation Delay, Select to Output Y
(Figures 1 and 3)
2.0
4.5
6.0
115
23
29
25
175
35
30
ns
tPLH,
tPHL
Maximum Propagation Delay, Input A to Output Y
(Figures 2 and 3)
2.0
4.5
6.0
115
23
29
25
175
35
30
ns
tTLH,
tTHL
Maximum Output Transition Time, Any Output
(Figures 1 and 3)
2.0
4.5
6.0
75
15
13
95
19
16
110
22
19
ns
Cin
Maximum Input Capacitance
10
10
10
pF
10. For propagation delays with loads other than 50 pF, and information on typical parametric values, see the ON Semiconductor High–Speed
Typical @ 25°C, VCC = 5.0 V
CPD
Power Dissipation Capacitance (Per Decoder) (Note 11)
55
pF
11. Used to determine the no–load dynamic power consumption: P D = C PD V CC 2 f I CC V CC . For load considerations, see the ON
http://onsemi.com
4
MC74HC139A
tr
tf
VALID
VCC
INPUT A
GND
tPHL
90%
50%
10%
OUTPUT Y
VALID
VCC
90%
50%
SELECT
10%
50%
GND
tPLH
tPHL
tPLH
50%
OUTPUT Y
tTLH
tTHL
Figure 3. Switching Waveform
Figure 4. Switching Waveform
TEST POINT
OUTPUT
DEVICE
UNDER
TEST
CL*
* Includes all probe and jig capacitance
Figure 5. Test Circuit
http://onsemi.com
5
MC74HC139A
PIN DESCRIPTIONS
ADDRESS INPUTS
inputs. A high level on this input forces all outputs to a high
level.
A0a, A1a, A0b, A1b (Pins 2, 3, 14, 13)
OUTPUTS
Address inputs. These inputs, when the respective 1–of–4
decoder is enabled, determine which of its four active–low
outputs is selected.
Y0a – Y3a, Y0b – Y3b (Pins 4 – 7, 12, 11, 10, 9)
Active–low outputs. These outputs assume a low level
when addressed and the appropriate Select input is active.
These outputs remain high when not addressed or the
appropriate Select input is inactive.
CONTROL INPUTS
Selecta, Selectb (Pins 1, 15)
Active–low select inputs. For a low level on this input, the
outputs for that particular decoder follow the Address
SELECT
Y0
Y1
A0
Y2
Y3
A1
Figure 6. Expanded Logic Diagram
(1/2 of Device)
http://onsemi.com
6
MC74HC139A
PACKAGE DIMENSIONS
PDIP–16
N SUFFIX
CASE 648–08
ISSUE R
NOTES:
1. DIMENSIONING AND TOLERANCING PER ANSI
Y14.5M, 1982.
2. CONTROLLING DIMENSION: INCH.
3. DIMENSION L TO CENTER OF LEADS WHEN
FORMED PARALLEL.
4. DIMENSION B DOES NOT INCLUDE MOLD FLASH.
5. ROUNDED CORNERS OPTIONAL.
–A–
16
9
1
8
B
F
C
DIM
A
B
C
D
F
G
H
J
K
L
M
S
L
S
–T–
SEATING
PLANE
K
H
G
D
M
J
16 PL
0.25 (0.010)
T A
M
M
INCHES
MIN
MAX
0.740
0.770
0.250
0.270
0.145
0.175
0.015
0.021
0.040
0.70
0.100 BSC
0.050 BSC
0.008
0.015
0.110
0.130
0.295
0.305
0.020
0.040
MILLIMETERS
MIN
MAX
18.80
19.55
6.35
6.85
3.69
4.44
0.39
0.53
1.02
1.77
2.54 BSC
1.27 BSC
0.21
0.38
2.80
3.30
7.50
7.74
0.51
1.01
SOIC–16
D SUFFIX
CASE 751B–05
ISSUE J
–A–
16
NOTES:
Y14.5M, 1982.
2. CONTROLLING DIMENSION: MILLIMETER.
3. DIMENSIONS A AND B DO NOT INCLUDE
MOLD PROTRUSION.
4. MAXIMUM MOLD PROTRUSION 0.15 (0.006)
PER SIDE.
5. DIMENSION D DOES NOT INCLUDE DAMBAR
PROTRUSION. ALLOWABLE DAMBAR
PROTRUSION SHALL BE 0.127 (0.005) TOTAL
IN EXCESS OF THE D DIMENSION AT
MAXIMUM MATERIAL CONDITION.
9
–B–
1
P
8 PL
0.25 (0.010)
8
M
B
S
G
R
K
F
X 45
C
–T–
SEATING
PLANE
J
M
D
16 PL
0.25 (0.010)
M
T B
S
A
S
http://onsemi.com
7
DIM
A
B
C
D
F
G
J
K
M
P
R
MILLIMETERS
MIN
MAX
9.80
10.00
3.80
4.00
1.35
1.75
0.35
0.49
0.40
1.25
1.27 BSC
0.19
0.25
0.10
0.25
5.80
6.20
0.25
0.50
INCHES
MIN
MAX
0.386
0.393
0.150
0.157
0.054
0.068
0.014
0.019
0.016
0.049
0.050 BSC
0.008
0.009
0.004
0.009
0.229
0.244
0.010
0.019
MC74HC139A
PACKAGE DIMENSIONS
TSSOP–16
DT SUFFIX
CASE 948F–01
ISSUE O
16X K REF
0.10 (0.004)
0.15 (0.006) T U
M
T U
V
S
S
S
K
ÉÉÉ
ÇÇÇ
ÇÇÇ
ÉÉÉ
K1
2X
L/2
16
9
J1
B
–U–
L
SECTION N–N
J
PIN 1
IDENT.
8
1
N
0.15 (0.006) T U
S
0.25 (0.010)
A
–V–
M
NOTES:
Y14.5M, 1982.
3. DIMENSION A DOES NOT INCLUDE MOLD FLASH.
PROTRUSIONS OR GATE BURRS. MOLD FLASH OR
GATE BURRS SHALL NOT EXCEED 0.15 (0.006) PER
SIDE.
4. DIMENSION B DOES NOT INCLUDE INTERLEAD
FLASH OR PROTRUSION. INTERLEAD FLASH OR
PROTRUSION SHALL NOT EXCEED
0.25 (0.010) PER SIDE.
5. DIMENSION K DOES NOT INCLUDE DAMBAR
PROTRUSION. ALLOWABLE DAMBAR PROTRUSION
SHALL BE 0.08 (0.003) TOTAL IN EXCESS OF THE K
DIMENSION AT MAXIMUM MATERIAL CONDITION.
6. TERMINAL NUMBERS ARE SHOWN FOR
REFERENCE ONLY.
7. DIMENSION A AND B ARE TO BE DETERMINED AT
DATUM PLANE -W-.
N
F
DETAIL E
–W–
C
0.10 (0.004)
–T– SEATING
PLANE
DETAIL E
H
D
DIM
A
B
C
D
F
G
H
J
J1
K
K1
L
M
MILLIMETERS
MIN
MAX
4.90
5.10
4.30
4.50
--1.20
0.05
0.15
0.50
0.75
0.65 BSC
0.18
0.28
0.09
0.20
0.09
0.16
0.19
0.30
0.19
0.25
6.40 BSC
INCHES
MIN
MAX
0.193
0.200
0.169
0.177
--0.047
0.002
0.006
0.020
0.030
0.026 BSC
0.007
0.011
0.004
0.008
0.004
0.006
0.007
0.012
0.007
0.010
0.252 BSC
G
ON Semiconductor and
are trademarks of Semiconductor Components Industries, LLC (SCILLC). SCILLC reserves the right to make changes
without further notice to any products herein. SCILLC makes no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does SCILLC assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability,
including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in SCILLC data sheets and/or
specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. SCILLC does not convey any license under its patent rights nor the rights of others.
SCILLC products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications
intended to support or sustain life, or for any other application in which the failure of the SCILLC product could create a situation where personal injury or
death may occur. Should Buyer purchase or use SCILLC products for any such unintended or unauthorized application, Buyer shall indemnify and hold
SCILLC and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable
attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim
alleges that SCILLC was negligent regarding the design or manufacture of the part. SCILLC is an Equal Opportunity/Affirmative Action Employer.
PUBLICATION ORDERING INFORMATION
Literature Fulfillment:
Literature Distribution Center for ON Semiconductor
P.O. Box 5163, Denver, Colorado 80217 USA
Phone: 303–675–2175 or 800–344–3860 Toll Free USA/Canada
Fax: 303–675–2176 or 800–344–3867 Toll Free USA/Canada
Email: ONlit@hibbertco.com
JAPAN: ON Semiconductor, Japan Customer Focus Center
4–32–1 Nishi–Gotanda, Shinagawa–ku, Tokyo, Japan 141–0031
Phone: 81–3–5740–2700
Email: r14525@onsemi.com
ON Semiconductor Website: http://onsemi.com
For additional information, please contact your local
Sales Representative.
N. American Technical Support: 800–282–9855 Toll Free USA/Canada
http://onsemi.com
8
MC74HC139A/D
