TS19376CY5 RMG
TS19376CY5 RMG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-89-3
    TS19376CY5 RMG
TS19376CY5 RMG 数据手册
TS19376 1A Step-down High Brightness LED Driver SOT-89-5L Pin Definition: 1. SW 2. GND 3. DIM 4. CSN 5. VIN General Description The TS19376 is a continuous conduction mode inductive step-down converter, designed for driving single or multiple series connected LED efficiently from a voltage source higher than the total LED chain voltage. The device operates from an input supply between 8V and 32V and provides an externally adjustable output current of up to 1A. Depending upon the supply voltage and external components, the TS19376 can provide more than 15 watts of output power. The TS19376 includes the power switch and a high-side output current sensing circuit, which uses an external resistor to set the nominal average output current, and a dedicated DIM input accepts a wide range of pulsed dimming. Applying a voltage of 0.3V or lower to the DIM pin turns the output off and switches the device into a low current standby state Features Application ● Wide input voltage range: 8V to 32V ● White LED Backlighting ● Up to 1A output current ● High Power LED Application ● 5000:1 Dimming ● LED Lighting Equipment ● Single pin on/off and brightness control using PWM ● Up to 1MHz switching frequency ● Typical 5% output current accuracy ● High-Side Current Sense ● Hysteretic Control: No Compensation ● Adjustable Constant LED Current Ordering Information Part No. Package Packing TS19376CY5 RMG SOT-89-5L 1Kpcs / 7” Reel Note: “G” denotes Halogen Free Product. Absolute Maximum Rating Parameter Symbol Limit Unit VIN -0.3 to 40 V Supply Voltage Driver output Voltage SW -0.3 to 40 V Current sense input (Respect to VIN) CSN +0.3 to (-6.0) V Logic level dimming input DIM -0.3 to +6 V Switch output current ISW 1.0 A PDMAX 1.5 W TJ -40 to 125 °C TSTG -55 to 150 °C Thermal Resistance from Junction to case θJC 15 °C/W Thermal Resistance from Junction to ambient θJA 50 Power Dissipation Operation Junction Temperature Range Storage Temperature °C/W 2 Note: θJA is measured with the PCB copper area (need connect to Exposed Pad) of approximately 1 in (Multi-layer). 1/8 Version: A12 TS19376 1A Step-down High Brightness LED Driver Electrical Specifications (VIN=12V, TA =25oC, unless otherwise noted) Characteristics Input voltage Under voltage lock out UVLO Hysterisis Max. Switching Frequency Symbol Conditions VIN Min Typ Max Units 8 -- 32 V VUVLO VIN rising -- 7 -- V VUVLO_hys VIN falling -- 1000 -- mV -- -- 1 MHZ 120 130 140 mV -- ±15 -- % -- 0.5 -- µA FSW Current Sense Mean current sense threshold voltage Sense threshold hysteresis CSN Pin Input Current VCSN VIN–VCSN VCSN_hys ICSN VIN–VCSN = 50mV DIM Input DIM input voltage High VDIM_H 2.0 -- -- V DIM input voltage Low VDIM_L -- -- 0.3 V -- -- 50 kHZ 0.02% -- 1 -- 5000:1 -- 4% -- 1 -- 25:1 -- -- 300 -- KΩ Max. DIM Frequency Duty cycle range of low frequency dimming Brightness control range Duty cycle range of high frequency dimming Brightness control range DIM pull up resistor to Internal supply voltage fDIM DPWM_LF DPWM_HF fOSC = 500kHz fDIM = 100Hz fDIM = 20kHz RDIM IDIM_L VDIM = 0 -- 70 -- µA Saturation Voltage VSAT IOUT = 0.3A -- 0.8 1.0 V Saturation Voltage VSAT IOUT = 0.8A -- 1.0 1.2 V ISWmean -- -- 1.0 A ILEAK -- 0.5 5 µA Thermal Shutdown Threshold TSD -- 150 -- °C Thermal Shutdown hysteresis TSD-hys -- 35 -- °C DIM input leakage low Output Switch Continuous SW Current SW Leakage Current Thermal Shutdown 2/8 Version: A12 TS19376 1A Step-down High Brightness LED Driver Block Diagram V25 VIN SW CS - COMPARATOR + CSN 130mV 2.5V 70µ GATE DRIVER Driver + UVLO COMPARATOR GND DIM DIM BUFFER Pin Function Description: Pin Name Description 1 SW Switch Output. SW is the output of the internal driver switch. 2 GND Signal and power ground. Connect directly to ground plane. Logic level dimming input. Drive DIM low to turn off the current regulator. 3 DIM Drive DIM high to enable the current regulator. 4 CSN Current sense input 5 VIN Input Supply Pin. Must be locally bypassed. Typical Application Circuit ILED = VCSN 0.130 = = 0.325A RS 0.4 3/8 Version: A12 TS19376 1A Step-down High Brightness LED Driver Application Information Operation Description The device, in conjunction with the coil (L1) and current sense resistor (RS), forms a self oscillating continuousmode buck converter. When input voltage VIN is first applied, the initial current in L1 and RS is zero and there is no output from the current sense circuit. Under this condition, the output of CS comparator is high. This turns on an internal switch and switches the SW pin low, causing current to flow from VIN to ground, via RS, L1 and the LED(s). The current rises at a rate determined by VIN and L1 to produce a voltage ramp (VCSN) across RS. When (VIN-VCSN) > 150mV, the output of CS comparator switches low and the switch turns off. The current flowing on the RS decreases at another rate. When (VIN-VCSN) < 110mV, the switch turns on again and the mean current on the LED is determined by ( 110 + 150 mV) / RS= 130mV / RS. 2 The high-side current-sensing scheme and on-board current-setting circuitry minimize the number of external components while delivering LED current with ±5% accuracy, using a 1% sense resistor. The TS19376 allow dimming with a PWM signal at the DIM input. A logic level below 0.3V at DIM forces TS19376 to turn off the LED and the logic level at DIM must be at least 2.0V to turn on the full LED current. The frequency of PWM dimming ranges from 100Hz to more than 20 kHz. The DIM pin is pulled high current approximately 70µA. It can be floated at normal working. When a voltage applied to DIM falls below the threshold (0.3V nom.), the output switch is turned off. The internal regulator and voltage reference remain powered during shutdown to provide the reference for the shutdown circuit. Additionally, to ensure the reliability, the TS19376 is built with a thermal shutdown (TSD) protection and a thermal pad. The TSD protests the IC from over temperature (150°C). Also the thermal pad enhances power dissip ation. As a result, the TS19376 can handle a large amount of current safely. Setting nominal average output current with external resistor RS The nominal average output current in the LED(s) is determined by the value of the external current sense resistor (RS) connected between VIN and CSN and is given by: IOUT = 0.130/RS (RS ≧ 0.16Ω) This equation is valid when DIM pin is float. Actually, RS sets the maximum average current which can be adjusted to a less one by dimming. Output current adjustment by PWM control A Pulse Width Modulated (PWM) signal with duty cycle PWM can be applied to the DIM pin, as shown below, to adjust the output current to a value below the nominal average value set by resistor RS: IOUT = 0.1× D RS (0≦D≦100%, 0.3V<Vpulse<2.5V) PWM dimming provides reduced brightness by modulating the LED’s forward current between 0% and 100%. The LED brightness is controlled by adjusting the relative ratios of the on time to the off time. A 25% brightness level is achieved by turning the LED on at full current for 25% of one cycle. To ensure this switching process between on and off state is invisible by human eyes, the switching frequency must be greater than 100 Hz. Above 100 Hz, the human eyes average the on and off times, seeing only an effective brightness that is proportional to the LED’s ontime duty cycle. The advantage of PWM dimming is that the forward current is always constant; therefore the LED color does not vary with brightness as it does with analog dimming. Pulsing the current provides precise brightness control while preserving the color purity. The dimming frequency of TS19376 can be as high as 20 kHz. 4/8 Version: A12 TS19376 1A Step-down High Brightness LED Driver Application Information (Continue) Shutdown mode Taking the DIM pin to a voltage below 0.3V will turn off the output and the supply current will fall to a low standby level of 70µA nominal. Capacitor selection A low ESR capacitor should be used for input decoupling, as the ESR of this capacitor appears in series with the supply source impedance and lowers overall efficiency. This capacitor has to supply the relatively high peak current to the coil and smooth the current ripple on the input supply. A minimum value of 4.7uF is acceptable if the input source is close to the device, but higher values will improve performance at lower input voltages, especially when the source impedance is high. The input capacitor should be placed as close as possible to the IC. For maximum stability over temperature and voltage, capacitors with X7R, X5R, or better dielectric are recommended. Capacitors with Y5V dielectric are not suitable for decoupling in this application and should not be used. Inductor selection Recommended inductor values for the TS19376 are in the range 47uH to 120uH. Higher values of inductance are recommended at lower output current in order to minimize errors due to switching delays, which result in increased ripple and lower efficiency. Higher values of inductance also result in a smaller change in output current over the supply voltage range. The inductor should be mounted as close to the device as possible with low resistance connections to the SW and VIN pins. Diode selection For maximum efficiency and performance, the rectifier (D1) should be a fast low capacitance Schottky diode with low reverse leakage at the maximum operating voltage and temperature. They also provide better efficiency than silicon diodes, due to a combination of lower forward voltage and reduced recovery time. It is important to select parts with a peak current rating above the peak coil current and a continuous current rating higher than the maximum output load current. It is very important to consider the reverse leakage of the diode when operating above 85°C. Excess leakage will incr ease the power dissipation in the device and if close to the load may create a thermal runaway condition. The higher forward voltage and overshoot due to reverse recovery time in silicon diodes will increase the peak voltage on the SW output. If a silicon diode is used, care should be taken to ensure that the total voltage appearing on the SW pin including supply ripple, does not exceed the specified maximum value. Reducing output ripple Peak to peak ripple current in the LED(s) can be reduced, if required, by shunting a capacitor CLED across the LED(s) as shown below: A value of 1uF will reduce the supply ripple current by a factor three (approx.). Proportionally lower ripple can be achieved with higher capacitor values. Note that the capacitor will not affect operating frequency or efficiency, but it will increase start-up delay and reduce the frequency of dimming, by reducing the rate of rise of LED voltage. By adding this capacitor the current waveform through the LED(s) changes from a triangular ramp to a more sinusoidal version without altering the mean current value. 5/8 Version: A12 TS19376 1A Step-down High Brightness LED Driver Application Information (Continue) Operation at low supply voltage The internal regulator disables the drive to the switch until the supply has risen above the startup threshold (VUVLO). Above this threshold, the device will start to for this reason, the temperature coefficients of the operating. However, with the supply voltage below the specified minimum value, the switch duty cycle will be high and the device power dissipation will be at a maximum. Care should be taken to avoid operating the device under such conditions in the application, in order to minimize the risk of exceeding the maximum allowed die temperature. (See next section on thermal considerations). The drive to the switch is turned off when the supply voltage falls below the under-voltage threshold (VUVLO-1V). This prevents the switch working with excessive 'on' resistance under conditions where the duty cycle is high. Thermal shutdown protection To ensure the reliability, the TS19376 is built with a thermal shutdown (TSD) protection function. The TSD protests the IC from over temperature (150°C). When the chip temperature decreases (115°C), the IC recovers aga in. 6/8 Version: A12 TS19376 1A Step-down High Brightness LED Driver SOT-89-5L Mechanical Drawing DIM A B C D E F G H I J 7/8 SOT-89-5L DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 4.40 4.60 0.17 0.18 4.05 4.25 0.16 0.17 1.50 1.70 0.06 0.07 0.35 0.41 0.01 0.02 2.40 2.60 0.09 0.10 0.80 -0.03 -3.00(typ) 0.12(typ) 1.50(typ) 0.06(typ) 0.40 0.52 0.01 0.02 1.40 1.60 0.05 0.06 Version: A12 TS19376 1A Step-down High Brightness LED Driver Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8/8 Version: A12
TS19376CY5 RMG 价格&库存
很抱歉,暂时无法提供与“TS19376CY5 RMG”相匹配的价格&库存,您可以联系我们找货
TS19376CY5 RMG
  • 1000+3.631611000+0.46849
  • 2000+3.516952000+0.45370
  • 3000+3.459553000+0.44629
  • 5000+3.395915000+0.43809
  • 7000+3.358757000+0.43329
  • 10000+3.3229810000+0.42868
库存:32604
TS19376CY5 RMG
  • 1+7.521411+0.97028
  • 10+5.3441610+0.68941
  • 25+4.8094325+0.62043
  • 100+4.22119100+0.54455
  • 250+3.94002250+0.50828
  • 500+3.77087500+0.48646
库存:32604
