HI5828IN
HI5828IN
    L3HARRIS
    LQFP48
    DAC, 2 FUNC, PARALLEL INPUT
HI5828IN 数据手册
HI5828 TM Data Sheet April 2001 12-Bit, 130MSPS, Dual High Speed CMOS D/A (2.7V-5.5V) The HI5828 is a Dual 12-bit, 130MSPS (Mega Samples Per Second), high speed, low power, D/A converter which is implemented in an advanced CMOS process. Operating from a single +3V to +5V supply, the converter provides 20mA of full scale output current and includes edge-triggered CMOS input data latches. Low glitch energy and excellent frequency domain performance is achieved by the HI5828’s segmented current source architecture. This device complements the HI5x60 and HI5x28 family of high speed converters, which includes 8, 10, 12, and 14-bit devices. HI5828IN PACKAGE -40 to 85 48 Ld LQFP 25 • Integral Linearity Error . . . . . . . . . . . . . . . . . . . ±0.75 LSB (Typ) • Adjustable Full Scale Output Current . . . . . . 2mA to 20mA • Internal 1.2V Bandgap Voltage Reference • Single or Dual Power Supply from +3V to +5V • Power Down Mode • Basestations (Cellular, WLL) Q48.7x7A 130MSPS Evaluation Platform 130MSPS • Quadrature Modulation • Wireless Communications Systems • Direct Digital Frequency Synthesis • Signal Reconstruction • High Resolution Imaging Systems QD3 • Arbitrary Waveform Generators QD1 QD2 QD0 (LSB) N.C. N.C. ID11 (MSB) ID8 ID9 ID10 ID7 ID6 • Medical/Test Instrumentation ID5 1 48 47 46 45 44 43 42 41 40 39 38 37 36 QD4 ID4 2 35 QD5 ID3 ID2 3 34 QD6 4 33 ID1 5 32 (LSB) ID0 6 7 31 QD7 QD8 QD9 30 QD10 N.C. 8 29 SLEEP DVDD 9 28 QD11 (MSB) CLK 10 27 DGND 11 12 26 AGND QCOMP2 AVDD QCOMP1 QOUTB QOUTA AGND FSADJ REFIO 1 REFLO IOUTA IOUTB AVDD 25 13 14 15 16 17 18 19 20 21 22 23 24 ICOMP1 ICOMP2 • Low Power . . . . .312mW at 5V, 46mW at 3V (at 60MSPS) Applications CLOCK SPEED PKG. NO. HI5828 (LQFP) TOP VIEW AGND • Throughput Rate . . . . . . . . . . . . . . . . . . . . . . . . 130MSPS • Excellent Spurious Free Dynamic Range (76dBc, f S = 50MSPS, fOUT = 2.51MHz) Pinout N.C. Features • Excellent Multitone Intermodulation Distortion TEMP. RANGE (oC) HI5828EVAL2 4658.3 • CMOS Compatible Inputs Ordering Information PART NUMBER File Number CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 321-724-7143 | Intersil and Design is a trademark of Intersil Americas Inc. Copyright © Intersil Americas Inc. 2001, All Rights Reserved HI5828 Functional Block Diagram (LSB) QD0 QD1 QD2 QD3 QD4 QD5 QD6 QD7 QD8 QD9 QD10 (MSB) QD11 7 SLAVE LATCH MASTER LATCH 5 THERMOMETER DECODER 38 SWITCH DRIVERS 38 QOUTA CURRENT CELLS 7 LSBs 31 + QOUTB 31 MSB SEGMENTS QCOMP1 BIAS GENERATION (LSB) ID0 ID1 ID2 ID3 ID4 ID5 ID6 ID7 ID8 ID9 ID10 (MSB) ID11 QCOMP2 7 38 SLAVE LATCH MASTER LATCH 5 THERMOMETER DECODER SWITCH DRIVERS 38 CURRENT CELLS 7 LSBs + 31 IOUTA IOUTB 31 MSB SEGMENTS CLK BIAS GENERATION ICOMP2 DVDD DGND AVDD AGND AVDD BANDGAP VOLTAGE REFERENCE SLEEP - ICOMP1 + REFLO REFIO 2 FSADJ HI5828 48 47 46 45 44 43 42 41 40 39 38 37 36 1 35 2 34 3 33 4 32 5 31 6 30 7 N.C. 29 8 N.C. CLK 28 9 DGND 27 10 DVDD AGND 26 11 AGND 25 12 13 14 15 16 17 18 19 20 21 22 23 24 QD4 QD5 QD6 QD7 QD8 QD9 QD10 QD11 (MSB) N.C. N.C. ID5 ID4 ID3 ID2 ID1 ID0 (LSB) REFIO REFLO AGND FSADJ SLEEP DVPP C1 0.1µF QD0 (LSB) QD1 QD2 QD3 ID6 ID7 ID8 ID9 ID10 ID11 (MSB) Typical Applications Circuit ICOMP2 C2 0.1µF AVDD AVPP ICOMP1 QCOMP1 R2 R3 50Ω 50Ω CONN 1 (IOUTA) AVPP C5 0.1µF C6 0.1µF C7 0.1µF AVPP C3 0.1µF AVDD C4 0.1µF R1 50Ω QCOMP2 RSET 1.91kΩ CONN2 (IOUTB) R5 R4 50Ω 50Ω CONN 3 (QOUTB) C8 0.1µF AVPP CONN 4 (QOUTA) BEAD FERRITE + C11 10µF L1 10µH DVP-P (DIGITAL POWER PLANE) C9 0.1µF C10 1µF C12 0.1µF C13 1µF +5V OR +3V POWER SOURCE FERRITE BEAD + C14 10µF L2 10µH AVP-P (ANALOG POWER PLANE) NOTE: Separate analog and digital grounds should be used, in which case the grounds should be tied together at a single point near the device. The analog and digital grounds should be connected together by a thin single trace and never connected together by an inductor. 3 HI5828 Pin Descriptions PIN NO. PIN NAME 11, 19, 26 AGND Analog Ground. 13, 24 AVDD Analog Supply (+2.7V to +5.5V). 28 CLK Clock Input. The master and slave latches shown in the functional block diagram are simple D-latches. Input data to the DAC passes through the “master” latches when the clock is low and is latched into the “master” latches when the clock is high. Data presented to the “slave” latch passes through when the clock is logic high and is latched into the “slave” latches when the clock is logic low. Adequate setup time must be allowed for the MSBs to pass through the thermometer decoder before the clock goes high. This master-slave arrangement comprises an edge-triggered flip-flop, with the DAC being updated on the rising clock edge. It is recommended that the clock edge be skewed such that setup time is larger than hold time for optimum spectral performance. 27 DGND Connect to Digital Ground. 10 DVDD Digital Supply (+2.7V to +5.5V). 20 FSADJ Full Scale Current Adjust. Use a resistor to analog ground to adjust full scale output current. Full Scale Output Current = 32 x VFSADJ/RSET. Where VFSADJ is the voltage at this pin. VFSADJ tracks the voltage on the REFIO pin (refer to the functional block diagram); which is typically 1.2V if the internal reference is used. 14, 23 ICOMP1, QCOMP1 Compensation Pin for Use in Reducing Bandwidth/Noise. Each pin should be individually decoupled to AVDD with a 0.1µF capacitor. To minimize crosstalk, the part was designed so that these pins must be connected externally, ideally directly under the device packaging. The voltage on these pins is used to drive the gates of the PMOS devices that make up the current cells. Only the ICOMP1 pin is driven and therefore QCOMP1 needs to be connected to ICOMP1, but de-coupled separately to minimize crosstalk. If placed equally close to both pins, then only one decoupling capacitor might be necessary. 12, 25 ICOMP2, QCOMP2 Compensation Pin for Internal Bias Generation. Each pin should be individually decoupled to AGND with a 0.1µF capacitor. The voltage generated at these pins represents the voltage used to supply power to the switch drivers (refer to the functional block diagram) which is 2.0V nominal. This arrangement helps to minimize clock feedthrough to the current cell transistors for reduced glitch energy and improved spectral performance. 43-48, 1-6, 29-40 PIN DESCRIPTION ID11-ID0, QD11-QD0 Digital Data Input Ports. Bit 11 is Most Significant Bit (MSB) and bit 0 is the Least Significant Bit (LSB). 15, 22 IOUTA, QOUTA Current Outputs of the Device. Full scale output current is achieved when all input bits are set to binary 1. 16, 21 IOUTB, QOUTB Complementary Current Outputs of the Device. Full scale output current is achieved on the complementary outputs when all input bits are set to binary 0. 7, 8, 41, 42 N.C. 17 REFIO Reference voltage input if Internal reference is disabled. The internal reference is not intended to drive an external load. Use 0.1µF cap to ground when internal reference is enabled. 18 REFLO Reference Low Select. When the internal reference is enabled, this pin serves as the precision ground reference point for the internal voltage reference circuitry and therefore needs to have a good connection to analog ground to enable internal 1.2V reference. To disable the internal reference circuitry this pin should be connected to AVDD. 9 SLEEP Control Pin for Power-Down Mode. Sleep Mode is active high; connect to ground for Normal Mode. The Sleep pin has internal 25µA (nominal) active pulldown current. No Connection. Future LSBs for dual 14-bit DAC. 4 HI5828 Absolute Maximum Ratings Thermal Information Digital Supply Voltage DVDD to DGND . . . . . . . . . . . . . . . . . . +5.5V Analog Supply Voltage AVDD to AGND . . . . . . . . . . . . . . . . . . +5.5V Grounds, AGND TO DGND . . . . . . . . . . . . . . . . . . . . -0.3V to +0.3V Digital Input Voltages (D11-D0, CLK, SLEEP). . . . . . . DVDD + 0.3V Reference Input Voltage Range . . . . . . . . . . . . . . . . . . .AVDD + 0.3V Analog Output Current (IOUTA/B, QOUTA/B) . . . . . . . . . . . . . 24mA Thermal Resistance (Typical, Note 1) θJA(oC/W) LQFP Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70 Maximum Junction Temperature . . . . . . . . . . . . . . . . . . . . . . .150oC Maximum Storage Temperature Range . . . . . . . . . . -65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . .300oC (LQFP - Lead Tips Only) Operating Conditions Temperature Range . . . . . . . . . . . . . . . . . . . . . . . . . . -40oC to 85oC CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. θJA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief TB379 for details. Electrical Specifications AVDD = DVDD = +5V (except where otherwise noted), VREF = Internal 1.2V, IOUTFS = 20mA, TA = 25oC for All Typical Values TA = -40oC TO 85oC PARAMETER TEST CONDITIONS MIN TYP MAX UNITS 12 - - Bits SYSTEM PERFORMANCE Resolution Integral Linearity Error, INL “Best Fit” Straight Line (Note 8) -2.0 ±0.75 +2.0 LSB Differential Linearity Error, DNL (Note 8) -1.0 ±0.5 +1.0 LSB Offset Error, IOS (Note 8) -0.025 - +0.025 % FSR Offset Drift Coefficient (Note 8) - 0.1 - ppm FSR/oC Full Scale Gain Error, FSE With External Reference (Notes 2, 8) -10 ±2 +10 % FSR With Internal Reference (Notes 2, 8) -10 ±1 +10 % FSR With External Reference (Note 8) - ±50 - ppm FSR/oC With Internal Reference (Note 8) - ±100 - ppm FSR/oC 2 - 20 mA fCLK = 100MSPS, fOUT = 10MHz - 85 - dB fCLK = 100MSPS, fOUT = 40MHz - 64 - dB Gain Matching Between Channels (DC Measurement) As a percentage of Full Scale Range -5 - +5 % FSR -0.445 - +0.420 dB FSR Output Voltage Compliance Range (Note 3, 8) -0.3 - 1.25 V Maximum Clock Rate, fCLK (Note 3) 130 - - MHz Output Settling Time, (tSETT) ±0.05% (±2 LSB) (Note 8) - 35 - ns Singlet Glitch Area (Peak Glitch) RL = 25Ω (Note 8) - 5 - pV•s Output Rise Time Full Scale Step - 2.5 - ns Output Fall Time Full Scale Step - 2.5 - ns - 10 - pF Full Scale Gain Drift Full Scale Output Current, IFS Crosstalk In dB Full Scale Range DYNAMIC CHARACTERISTICS Output Capacitance 5 HI5828 Electrical Specifications AVDD = DVDD = +5V (except where otherwise noted), VREF = Internal 1.2V, IOUTFS = 20mA, TA = 25oC for All Typical Values (Continued) TA = -40oC TO 85oC PARAMETER TEST CONDITIONS Output Noise MIN TYP MAX UNITS IOUTFS = 20mA - 50 - pA/√Hz IOUTFS = 2mA - 30 - pA/√Hz fCLK = 100MSPS, fOUT = 20.2MHz, 30MHz Span (Notes 4, 8) - 77 - dBc fCLK = 100MSPS, fOUT = 5.04MHz, 8MHz Span (Notes 4, 8) - 93 - dBc fCLK = 50MSPS, fOUT = 5.02MHz, 8MHz Span (Notes 4, 8) - 93 - dBc fCLK = 100MSPS, fOUT = 4.0MHz (Notes 4, 8) - -72 - dB fCLK = 50MSPS, fOUT = 2.0MHz (Notes 4, 8) - -74 - dB fCLK = 25MSPS, fOUT = 1.0MHz (Notes 4, 8) - -73 - dB fCLK = 130MSPS, fOUT = 40.4MHz (Notes 4, 8) - 55 - dBc fCLK = 130MSPS, fOUT = 10.1MHz (Notes 4, 8) - 66 - dBc 66 72 - dBc 66 - - dBc fCLK = 100MSPS, fOUT = 40.4MHz (Notes 4, 8) - 54 - dBc fCLK = 100MSPS, fOUT = 20.2MHz (Notes 4, 8) - 62 - dBc fCLK = 100MSPS, fOUT = 5.04MHz, T = 25oC (Notes 4, 8) 66 72 - dBc fCLK = 100MSPS, fOUT = 5.04MHz, T = Min to Max (Notes 4, 8) 66 - - dBc fCLK = 100MSPS, fOUT = 2.51MHz (Notes 4, 8) - 75 - dBc fCLK = 50MSPS, fOUT = 20.2MHz (Notes 4, 8) - 64 - dBc fCLK = 50MSPS, fOUT = 5.02MHz, T = 25oC (Notes 4, 8) 66 72 - dBc fCLK = 50MSPS, fOUT = 5.02MHz, T = Min to Max (Notes 4, 8) 66 - - dBc fCLK = 50MSPS, fOUT = 2.51MHz (Notes 4, 8) - 76 - dBc fCLK = 50MSPS, fOUT = 1.00MHz (Notes 4, 8) - 78 - dBc fCLK = 25MSPS, fOUT = 1.0MHz (Notes 4, 8) - 77 - dBc fCLK = 20MSPS, fOUT = 2.0MHz to 2.99MHz, 8 Tones at 110kHz Spacing (Notes 4, 8) - 76 - dBc fCLK = 100MSPS, fOUT = 10MHz to 14.95MHz, 8 Tones at 530kHz Spacing (Notes 4, 8) - 76 - dBc fCLK = 100MSPS, fOUT = 20.2MHz, 30MHz Span (Notes 4, 8) - 73 - dBc fCLK = 100MSPS, fOUT = 5.04MHz, 8MHz Span (Notes 4, 8) - 91 - dBc fCLK = 50MSPS, fOUT = 5.02MHz, 8MHz Span (Notes 4, 8) - 91 - dBc fCLK = 100MSPS, fOUT = 4.0MHz (Notes 4, 8) - -71 - dB fCLK = 50MSPS, fOUT = 2.0MHz (Notes 4, 8) - -75 - dB fCLK = 25MSPS, fOUT = 1.0MHz (Notes 4, 8) - -74 - dB AC CHARACTERISTICS +5V Power Supply Spurious Free Dynamic Range, SFDR Within a Window +5V Power Supply Total Harmonic Distortion (THD) to Nyquist +5V Power Supply Spurious Free Dynamic Range, SFDR to Nyquist (fCLK/2) fCLK = 130MSPS, fOUT = 5.02MHz, T = 25oC (Notes 4, 8) fCLK = 130MSPS, fOUT = 5.02MHz, T = Min to Max (Notes 4, 8) +5V Power Supply Multitone Power Ratio +3V Power Supply Spurious Free Dynamic Range, SFDR Within a Window +3V Power Supply Total Harmonic Distortion (THD) to Nyquist 6 HI5828 Electrical Specifications AVDD = DVDD = +5V (except where otherwise noted), VREF = Internal 1.2V, IOUTFS = 20mA, TA = 25oC for All Typical Values (Continued) TA = -40oC TO 85oC PARAMETER TEST CONDITIONS MIN TYP MAX UNITS fCLK = 130MSPS, fOUT = 40.4MHz (Notes 4, 8) - 47 - dBc fCLK = 130MSPS, fOUT = 10.1MHz (Notes 4, 8) - 66 - dBc fCLK = 130MSPS, fOUT = 5.02MHz (Notes 4, 8) - 73 - dBc fCLK = 100MSPS, fOUT = 40.4MHz (Notes 4, 8) - 48 - dBc fCLK = 100MSPS, fOUT = 20.2MHz (Notes 4, 8) - 58 - dBc fCLK = 100MSPS, fOUT = 5.04MHz (Notes 4, 8) - 72 - dBc fCLK = 100MSPS, fOUT = 2.51MHz (Notes 4, 8) - 76 - dBc fCLK = 50MSPS, fOUT = 20.2MHz (Notes 4, 8) - 53 - dBc 68 73 - dBc 66 - - dBc fCLK = 50MSPS, fOUT = 2.51MHz (Notes 4, 8) - 76 - dBc fCLK = 50MSPS, fOUT = 1.00MHz(Notes 4, 8) - 76 - dBc fCLK = 25MSPS, fOUT = 1.0MHz (Notes 4, 8) - 76 - dBc fCLK = 20MSPS, fOUT = 2.0MHz to 2.99MHz, 8 Tones at 110kHz Spacing (Notes 4, 8) - 76 - dBc fCLK = 100MSPS, fOUT = 10MHz to 14.95MHz, 8 Tones at 530kHz Spacing (Notes 4, 8) - 76 - dBc 1.15 1.22 1.29 V Internal Reference Voltage Drift - ±10 - ppm/oC Internal Reference Output Current Sink/Source Capability - ±100 - nA Reference Input Impedance - 1 - MΩ Reference Input Multiplying Bandwidth (Note 8) - 1.4 - MHz +3V Power Supply Spurious Free Dynamic Range, SFDR to Nyquist (fCLK/2) fCLK = 50MSPS, fOUT = 5.02MHz, T = 25oC (Notes 4, 8) fCLK = 50MSPS, fOUT = 5.02MHz, T = Min to Max (Notes 4, 8) +3V Power Supply Multitone Power Ratio VOLTAGE REFERENCE Internal Reference Voltage, VFSADJ DIGITAL INPUTS Pin 18 Voltage with Internal Reference D11-D0, CLK Input Logic High Voltage with 5V Supply, VIH (Note 3) 3.5 5 - V Input Logic High Voltage with 3V Supply, VIH (Note 3) 2.1 3 - V Input Logic Low Voltage with 5V Supply, VIL (Note 3) - 0 1.3 V Input Logic Low Voltage with 3V Supply, VIL (Note 3) - 0 0.9 V Input Sleep Current, IIH -25 - +25 µA Input Logic Current, IIH -10 - +10 µA Input Logic Current, IIL -10 - +10 µA - 5 - pF Digital Input Capacitance, CIN 7 HI5828 Electrical Specifications AVDD = DVDD = +5V (except where otherwise noted), VREF = Internal 1.2V, IOUTFS = 20mA, TA = 25oC for All Typical Values (Continued) TA = -40oC TO 85oC PARAMETER TEST CONDITIONS MIN TYP MAX UNITS TIMING CHARACTERISTICS Data Setup Time, tSU See Figure 4 (Note 3) - 1.5 - ns Data Hold Time, tHLD See Figure 4 (Note 3) - 1.2 - ns Propagation Delay Time, tPD See Figure 4 - 2.5 - ns CLK Pulse Width, tPW1 , tPW2 See Figure 4 (Note 3) 4 - - ns POWER SUPPLY CHARACTERISTICS AVDD Power Supply (Note 9) 2.7 5.0 5.5 V DVDD Power Supply (Note 9) 2.7 5.0 5.5 V Analog Supply Current (IAVDD) 5V or 3V, IOUTFS = 20mA (Note 7) - 44 50 mA 5V or 3V, IOUTFS = 2mA - 7 - mA 5V (Note 5) - 12 - mA 5V (Note 6) - 17.6 - mA 5V (Note 7) - 29 38 mA 3V (Note 5) - 4 - mA 3V (Note 6) - 8.2 - mA 3V (Note 7) - 9.6 12 mA Supply Current (IAVDD) Sleep Mode 5V or 3V, IOUTFS = Don’t Care - 2.7 - mA Power Dissipation 5V, IOUTFS = 20mA (Note 5) - 280 - mW 5V, IOUTFS = 20mA (Note 6) - 312 - mW 5V, IOUTFS = 20mA (Note 7) - 365 440 mW 5V, IOUTFS = 2mA (Note 6) - 137 - mW 3V, IOUTFS = 20mA (Note 5) - 144 - mW 3V, IOUTFS = 20mA (Note 6) - 158 3V, IOUTFS = 20mA (Note 7) - 161 177 mW 3V, IOUTFS = 2mA (Note 6) - 46 - mW -0.2 - +0.2 % FSR/V Digital Supply Current (IDVDD) Power Supply Rejection Single Supply (Note 8) mW NOTES: 2. Gain Error measured as the error in the ratio between the full scale output current and the current through RSET (typically 625µA). Ideally the ratio should be 32. 3. Parameter guaranteed by design or characterization and not production tested. 4. Spectral measurements made with differential transformer coupled output and no external filtering. 5. Measured with the clock at 60MSPS and the output frequency at 10MHz. 6. Measured with the clock at 100MSPS and the output frequency at 40MHz. 7. Measured with the clock at 130MSPS and the output frequency at 5MHz. 8. See “Definition of Specifications”. 9. It is recommended that the output current be reduced to 12mA or less to maintain optimum performance for operation below 3V. DVDD and AVDD do not have to be equal. 8 HI5828 Definition of Specifications Differential Linearity Error, DNL, is the measure of the step size output deviation from code to code. Ideally the step size should be 1 LSB. A DNL specification of 1 LSB or less guarantees monotonicity. by using a sinusoidal waveform as the external reference with the digital inputs set to all 1’s. The frequency is increased until the amplitude of the output waveform is 0.707 (-3dB) of its original value. Full Scale Gain Drift, is measured by setting the data inputs to be all logic high (all 1s) and measuring the output voltage through a known resistance as the temperature is varied from TMIN to TMAX . It is defined as the maximum deviation from the value measured at room temperature to the value measured at either TMIN or TMAX . The units are ppm of FSR (full scale range) per oC. Singlet Glitch Area, is the switching transient appearing on the output during a code transition. It is measured as the area under the overshoot portion of the curve and is expressed as a Volt-Time specification. This is tested using a single code transition across a major current source. Full Scale Gain Error, is the error from an ideal ratio of 32 between the output current and the full scale adjust current (through RSET). Integral Linearity Error, INL, is the measure of the worst case point that deviates from a best fit straight line of data values along the transfer curve. Internal Reference Voltage Drift, is defined as the maximum deviation from the value measured at room temperature to the value measured at either TMIN or TMAX . The units are ppm per oC. Offset Drift, is measured by setting the data inputs to all logic low (all 0’s) and measuring the output voltage through a known resistance as the temperature is varied from TMIN to TMAX . It is defined as the maximum deviation from the value measured at room temperature to the value measured at either TMIN or TMAX . The units are ppm of FSR (full scale range) per degree oC. Offset Error, is measured by setting the data inputs to all logic low (all 0’s) and measuring the output voltage through a known resistance. Offset error is defined as the maximum deviation of the output current from a value of 0mA. Output Settling Time, is the time required for the output voltage to settle to within a specified error band measured from the beginning of the output transition. The measurement is done by switching quarter scale. Termination impedance was 25Ω due to the parallel resistance of the 50Ω loading on the output and the oscilloscope’s 50Ω input. This also aids the ability to resolve the specified error band without overdriving the oscilloscope. Output Voltage Compliance Range, is the voltage limit imposed on the output. The output impedance should be chosen such that the voltage developed does not violate the compliance range. Power Supply Rejection, is measured using a single power supply. The supply’s nominal +5V is varied ±10% and the change in the DAC full scale output is noted. Reference Input Multiplying Bandwidth, is defined as the 3dB bandwidth of the voltage reference input. It is measured 9 Spurious Free Dynamic Range, SFDR, is the amplitude difference from the fundamental signal to the largest harmonically or non-harmonically related spur within the specified frequency window. Total Harmonic Distortion, THD, is the ratio of the RMS value of the fundamental output signal to the RMS sum of the first five harmonic components. Detailed Description The HI5828 is a dual 12-bit, current out, CMOS, digital to analog converter. Its maximum update rate is 130MSPS and can be powered by either single or dual power supplies in the recommended range of +3V to +5V. Operation with clock rates higher than 130MSPS is possible; please contact the factory for more information. It consumes 370mW of power when using a +5V supply with the data switching at 130MSPS. The architecture is based on a segmented current source arrangement that reduces glitch by reducing the amount of current switching at any one time. In previous architectures that contained all binary weighted current sources or a binary weighted resistor ladder, the converter might have a substantially larger amount of current turning on and off at certain, worst-case transition points such as midscale and quarter scale transitions. By greatly reducing the amount of current switching at certain ‘major’ transitions, the overall glitch of the converter is dramatically reduced, improving settling time, transient problems, and accuracy. Digital Inputs and Termination The HI5828 digital inputs are guaranteed to CMOS levels. However, TTL compatibility can be achieved by lowering the supply voltage to 3V due to the digital threshold of the input buffer being approximately half of the supply voltage. The internal register is updated on the rising edge of the clock. To minimize reflections, proper termination should be implemented. If the lines driving the clock and the digital inputs are long 50Ω lines, then 50Ω termination resistors should be placed as close to the converter inputs as possible connected to the digital ground plane (if separate grounds are used). These termination resistors are not likely needed as long as the digital waveform source is within a few inches of the DAC. HI5828 Ground Planes Outputs Separate digital and analog ground planes should be used. All of the digital functions of the device and their corresponding components should be located over the digital ground plane and terminated to the digital ground plane. The same is true for the analog components and the analog ground plane. Consult Application Note AN9855. The 5 MSBs for each DAC on the HI5828 drive a thermometer decoder, which is a digital decoder that has an N-bit (5 bits for the HI5828) binary coded input word with 2N-1 (31 for the HI5828) output bits, where the number of output bits that are active correlate directly to the input binary word. The HI5828 uses a thermometer decoder to significantly minimize the output glitch energy for each DAC. I/QOUTA and I/QOUTB are complementary current outputs. The sum of the two currents is always equal to the full scale output current minus one LSB. If single ended use is desired, a load resistor can be used to convert the output current to a voltage. It is recommended that the unused output be either grounded or equally terminated. The voltage developed at the output must not violate the output voltage compliance range of -0.3V to 1.25V. RLOAD (the impedance loading each current output) should be chosen so that the desired output voltage is produced in conjunction with the output full scale current. If a known line impedance is to be driven, then the output load resistor should be chosen to match this impedance. The output voltage equation is: Noise Reduction To minimize power supply noise, 0.1µF capacitors should be placed as close as possible to the converter’s power supply pins, AVDD and DVDD. Also, the layout should be designed using separate digital and analog ground planes and these capacitors should be terminated to the digital ground for DVDD and to the analog ground for AVDD. Additional filtering of the power supplies on the board is recommended. Voltage Reference The internal voltage reference of the device has a nominal value of + 1.2V with a ±10ppm/ oC drift coefficient over the full temperature range of the converter. It is recommended that a 0.1µF capacitor be placed as close as possible to the REFIO pin, connected to the analog ground. The REFLO pin (18) selects the reference. The internal reference can be selected if pin 18 is tied low (ground). If an external reference is desired, then pin 18 should be tied high (the analog supply voltage) and the external reference driven into REFIO, pin 17. The full scale output current of the converter is a function of the voltage reference used and the value of RSET. IOUT should be within the 2mA to 20mA range, though operation below 2mA is possible, with performance degradation. VFSADJ and VREFIO will be equivalent except for a small offset voltage. If the internal reference is used, VFSADJ will equal approximately 1.2V on the FSADJ pin (20). If an external reference is used, VFSADJ will equal the external reference. The calculation for IOUT(Full Scale) is: VOUT = IOUT X RLOAD. These outputs can be used in a differential-to-single-ended arrangement to achieve better harmonic rejection. The SFDR measurements in this data sheet were performed with a 1:1 transformer on the output of the DAC (see Figure 1). With the center tap grounded, the output swing of pins 15/22 and 16/21 will be biased at zero volts. The loading as shown in Figure 1 will result in a 500mV signal at the output of the transformer if the full scale output current of the DAC is set to 20mA. VOUT = 2 x IOUT x REQ, where REQ is ~12.5Ω. REQ IS THE IMPEDANCE LOADING EACH OUTPUT. 50Ω IOUT(Full Scale) = (VFSADJ/RSET) X 32. PIN 15/22 If the full scale output current is set to 20mA by using the internal voltage reference (1.2V) and a 1.91kΩ RSET resistor, then the input coding to output current will resemble the following: PIN 16/21 100Ω TABLE 1. INPUT CODING vs OUTPUT CURRENT INPUT CODE (D11-D0) I/QOUTA (mA) I/QOUTB (mA) 11 11111 11111 20 0 10 00000 00000 10 10 00 00000 00000 0 20 10 HI5828 VOUT = (2 x IOUT x REQ )V I/QOUTA 50Ω I/QOUTB 50Ω 50Ω REPRESENTS THE SPECTRUM ANALYZER FIGURE 1. Allowing the center tap to float will result in identical transformer output, however the output pins of the DAC will have positive DC offset. Since the DAC’s output voltage compliance range is -0.3V to +1.25V, the center tap may need to be left floating or DC offset in order to increase the amount of signal swing available. The 50Ω load on the output of the transformer represents the spectrum analyzer’s input impedance. HI5828 Timing Diagrams 50% CLK D11-D0 GLITCH AREA = 1/2 (H x W) V 1/ LSB ERROR BAND 2 HEIGHT (H) IOUT t(ps) WIDTH (W) tSETT tPD FIGURE 2. OUTPUT SETTLING TIME DIAGRAM tPW1 FIGURE 3. PEAK GLITCH AREA (SINGLET) MEASUREMENT METHOD tPW2 50% CLK tSU tSU tHLD tSU tHLD tHLD D11-D0 tPD tSETT IOUT tPD tSETT tPD tSETT FIGURE 4. PROPAGATION DELAY, SETUP TIME, HOLD TIME AND MINIMUM PULSE WIDTH DIAGRAM 11 HI5828 Thin Plastic Quad Flatpack Packages (LQFP) Q48.7x7A (JEDEC MS-026BBC ISSUE B) 48 LEAD THIN PLASTIC QUAD FLATPACK PACKAGE D D1 -D- INCHES -A- -B- E E1 e PIN 1 SEATING A PLANE -H- 0.08 0.003 -C- MILLIMETERS SYMBOL MIN MAX MIN MAX NOTES A - 0.062 - 1.60 - A1 0.002 0.005 0.05 0.15 - A2 0.054 0.057 1.35 1.45 - b 0.007 0.010 0.17 0.27 6 b1 0.007 0.009 0.17 0.23 - D 0.350 0.358 8.90 9.10 3 D1 0.272 0.280 6.90 7.10 4, 5 E 0.350 0.358 8.90 9.10 3 E1 0.272 0.280 6.90 7.10 4, 5 L 0.018 0.029 0.45 0.75 N 48 48 e 0.020 BSC 0.50 BSC 7 Rev. 2 1/99 NOTES: 1. Controlling dimension: MILLIMETER. Converted inch dimensions are not necessarily exact. 2. All dimensions and tolerances per ANSI Y14.5M-1982. 3. Dimensions D and E to be determined at seating plane -C- . 0.08 0.003 M C A-B S b 11o-13o 0.020 0.008 MIN b1 0o MIN A2 A1 GAGE PLANE 0.25 0.010 11o-13o 4. Dimensions D1 and E1 to be determined at datum plane -H- . 5. Dimensions D1 and E1 do not include mold protrusion. Allowable protrusion is 0.25mm (0.010 inch) per side. 6. Dimension b does not include dambar protrusion. Allowable dambar protrusion shall not cause the lead width to exceed the maximum b dimension by more than 0.08mm (0.003 inch). 0.09/0.16 0.004/0.006 BASE METAL WITH PLATING L 0o-7o D S 7. “N” is the number of terminal positions. 0.09/0.20 0.004/0.008 All Intersil products are manufactured, assembled and tested utilizing ISO9000 quality systems. Intersil Corporation’s quality certifications can be viewed at website www.intersil.com/design/quality Intersil products are sold by description only. Intersil Corporation reserves the right to make changes in circuit design and/or specifications at any time without notice. Accordingly, the reader is cautioned to verify that data sheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see web site www.intersil.com Sales Office Headquarters NORTH AMERICA Intersil Corporation 2401 Palm Bay Rd., Mail Stop 53-204 Palm Bay, FL 32905 TEL: (321) 724-7000 FAX: (321) 724-7240 12 EUROPE Intersil SA Mercure Center 100, Rue de la Fusee 1130 Brussels, Belgium TEL: (32) 2.724.2111 FAX: (32) 2.724.22.05 ASIA Intersil Ltd. 8F-2, 96, Sec. 1, Chien-kuo North, Taipei, Taiwan 104 Republic of China TEL: 886-2-2515-8508 FAX: 886-2-2515-8369
HI5828IN 价格&库存
很抱歉,暂时无法提供与“HI5828IN”相匹配的价格&库存,您可以联系我们找货
