N76E885AT28
N76E885AT28
    NUVOTON(新唐)
    TSSOP-28
    N76E885AT28
N76E885AT28 数据手册
N76E885 Datasheet Nuvoton 1T 8051-based Microcontroller N76E885 Datasheet Jan. 27, 2018 Page 1 of 205 Rev. 1.02 N76E885 Datasheet TABLE OF CONTENTS 1. GENERAL DESCRIPTION ............................................................................................................................... 5 2. FEATURES ....................................................................................................................................................... 6 3. BLOCK DIAGRAM ............................................................................................................................................ 9 4. PIN CONFIGURATION ................................................................................................................................... 10 5. MEMORY ORGANIZATION ........................................................................................................................... 15 5.1 Program Memory .................................................................................................................................... 15 5.2 Data Memory .......................................................................................................................................... 17 5.3 On-Chip XRAM ....................................................................................................................................... 18 5.4 Non-Volatile Data Storage ...................................................................................................................... 19 6. SPECIAL FUNCTION REGISTER (SFR) ....................................................................................................... 20 7. GENERAL 80C51 SYSTEM CONTROL......................................................................................................... 26 8. I/O PORT STRUCTURE AND OPERATION .................................................................................................. 29 8.1 Quasi-Bidirectional Mode ........................................................................................................................ 29 8.2 Push-Pull Mode....................................................................................................................................... 30 8.3 Input-Only Mode ..................................................................................................................................... 31 8.4 Open-Drain Mode ................................................................................................................................... 31 8.5 Read-Modify-Write Instructions .............................................................................................................. 32 8.6 Control Registers of I/O Ports ................................................................................................................. 32 8.6.1 Input and Output Data Control ..................................................................................................... 33 8.6.2 Output Mode Control .................................................................................................................... 34 8.6.3 Input Type and Sink Current Control ........................................................................................... 36 8.6.4 Output Slew Rate Control ............................................................................................................ 38 9. TIMER/COUNTER 0 AND 1 ............................................................................................................................ 40 9.1 Mode 0 (13-Bit Timer) ............................................................................................................................. 44 9.2 Mode 1 (16-Bit Timer) ............................................................................................................................. 45 9.3 Mode 2 (8-Bit Auto-Reload Timer) .......................................................................................................... 45 9.4 Mode 3 (Two Separate 8-Bit Timers)...................................................................................................... 46 10. TIMER 2 AND INPUT CAPTURE ................................................................................................................. 48 10.1 Auto-Reload Mode ................................................................................................................................ 50 10.2 Compare Mode ..................................................................................................................................... 51 10.3 Input Capture Module ........................................................................................................................... 52 11. TIMER 3 ........................................................................................................................................................ 56 12. WATCHDOG TIMER (WDT) ......................................................................................................................... 58 12.1 Time-Out Reset Timer .......................................................................................................................... 60 12.2 General Purpose Timer ........................................................................................................................ 61 13. SELF WAKE-UP TIMER (WKT) ................................................................................................................... 64 14. SERIAL PORT (UART) ................................................................................................................................. 66 14.1 Mode 0 .................................................................................................................................................. 71 14.2 Mode 1 .................................................................................................................................................. 72 14.3 Mode 2 .................................................................................................................................................. 73 14.4 Mode 3 .................................................................................................................................................. 74 14.5 Baud Rate ............................................................................................................................................. 74 14.6 Framing Error Detection ....................................................................................................................... 76 14.7 Multiprocessor Communication ............................................................................................................ 77 14.8 Automatic Address Recognition ............................................................................................................ 78 15. SERIAL PERIPHERAL INTERFACE (SPI) .................................................................................................. 82 15.1 Functional Description .......................................................................................................................... 82 15.2 Operating Modes .................................................................................................................................. 87 Jan. 27, 2018 Page 2 of 205 Rev. 1.02 N76E885 Datasheet 15.2.1 Master Mode .............................................................................................................................. 87 15.2.2 Slave Mode ................................................................................................................................ 87 15.3 Clock Formats and Data Transfer......................................................................................................... 88 15.4 Slave Select Pin Configuration ............................................................................................................. 90 15.5 Mode Fault Detection ............................................................................................................................ 91 15.6 Write Collision Error .............................................................................................................................. 91 15.7 Overrun Error ........................................................................................................................................ 91 15.8 SPI Interrupt .......................................................................................................................................... 92 2 16. INTER-INTEGRATED CIRCUIT (I C) ........................................................................................................... 93 16.1 Functional Description .......................................................................................................................... 93 16.1.1 START and STOP Condition ..................................................................................................... 94 16.1.2 7-Bit Address with Data Format ................................................................................................. 95 16.1.3 Acknowledge .............................................................................................................................. 96 16.1.4 Arbitration ................................................................................................................................... 96 2 16.2 Control Registers of I C ........................................................................................................................ 97 16.3 Operating Modes ................................................................................................................................ 101 16.3.1 Master Transmitter Mode ......................................................................................................... 101 16.3.2 Master Receiver Mode ............................................................................................................. 102 16.3.3 Slave Receiver Mode ............................................................................................................... 103 16.3.4 Slave Transmitter Mode ........................................................................................................... 104 16.3.5 General Call ............................................................................................................................. 105 16.3.6 Miscellaneous States ............................................................................................................... 106 2 16.4 Typical Structure of I C Interrupt Service Routine .............................................................................. 107 2 16.5 I C Time-Out ....................................................................................................................................... 110 2 16.6 I C Interrupt ......................................................................................................................................... 111 17. PIN INTERRUPT ......................................................................................................................................... 112 18. PULSE WIDTH MODULATED (PWM) ....................................................................................................... 115 18.1 Functional Description ........................................................................................................................ 115 18.1.1 PWM Generator ....................................................................................................................... 115 18.1.2 PWM Types.............................................................................................................................. 122 18.1.3 Operation Modes ..................................................................................................................... 124 18.1.4 Mask Output Control ................................................................................................................ 127 18.1.5 Fault Brake ............................................................................................................................... 128 18.1.6 Polarity Control ........................................................................................................................ 129 18.2 PWM Interrupt ..................................................................................................................................... 130 19. 10-BIT ANALOG-TO-DIGITAL CONVERTER (ADC) ................................................................................ 132 19.1 Functional Description ........................................................................................................................ 132 19.1.1 ADC Operation ......................................................................................................................... 132 19.1.2 ADC Conversion Triggered by External Source ...................................................................... 134 19.1.3 ADC Conversion Result Comparator ....................................................................................... 134 19.2 Control Registers of ADC ................................................................................................................... 135 20. TIMED ACCESS PROTECTION (TA) ........................................................................................................ 140 21. INTERRUPT SYSTEM ................................................................................................................................ 142 21.1 Interrupt Overview............................................................................................................................... 142 21.2 Enabling Interrupts .............................................................................................................................. 142 21.3 Interrupt Priorities................................................................................................................................ 145 21.4 Interrupt Service.................................................................................................................................. 149 21.5 Interrupt Latency ................................................................................................................................. 150 21.6 External Interrupt Pins ........................................................................................................................ 150 Jan. 27, 2018 Page 3 of 205 Rev. 1.02 N76E885 Datasheet 22. IN-APPLICATION-PROGRAMMING (IAP) ................................................................................................ 152 22.1 IAP Commands ................................................................................................................................... 155 22.2 IAP User Guide ................................................................................................................................... 156 22.3 Using Flash Memory as Data Storage ................................................................................................ 156 22.4 In-System-Programming (ISP) ............................................................................................................ 158 23. POWER MANAGEMENT ............................................................................................................................ 163 23.1 Idle Mode ............................................................................................................................................ 164 23.2 Power-Down Mode ............................................................................................................................. 164 24. CLOCK SYSTEM ........................................................................................................................................ 166 24.1 System Clock Sources ........................................................................................................................ 166 24.1.1 Internal Oscillators ................................................................................................................... 167 24.1.2 External Crystal/Resonator or Clock Input ............................................................................... 167 24.2 System Clock Switching ..................................................................................................................... 167 24.3 System Clock Divider .......................................................................................................................... 170 24.4 System Clock Output .......................................................................................................................... 170 25. POWER MONITORING .............................................................................................................................. 172 25.1 Power-On Reset (POR) ...................................................................................................................... 172 25.2 Brown-Out Detection (BOD) ............................................................................................................... 172 26. RESET ......................................................................................................................................................... 177 26.1 Power-On Reset ................................................................................................................................. 177 26.2 Brown-Out Reset ................................................................................................................................ 177 26.3 External Reset .................................................................................................................................... 178 26.4 Watchdog Timer Reset ....................................................................................................................... 179 26.5 Software Reset ................................................................................................................................... 179 26.6 Boot Select.......................................................................................................................................... 180 26.7 Reset State ......................................................................................................................................... 181 27. AUXILIARY FEATURES ............................................................................................................................. 182 27.1 Dual DPTRs ........................................................................................................................................ 182 27.2 96-Bit Unique Code ............................................................................................................................ 183 28. ON-CHIP-DEBUGGER (OCD) .................................................................................................................... 184 28.1 Functional Description ........................................................................................................................ 184 28.2 Limitation of OCD................................................................................................................................ 184 29. CONFIG BYTES.......................................................................................................................................... 186 30. IN-CIRCUIT-PROGRAMMING (ICP) .......................................................................................................... 189 31. INSTRUCTION SET .................................................................................................................................... 190 32. ELECTRICAL CHARACTERISTICS .......................................................................................................... 194 32.1 Absolute Maximum Ratings ................................................................................................................ 194 32.2 D.C. Electrical Characteristics ............................................................................................................ 194 32.3 A.C. Electrical Characteristics ............................................................................................................ 196 32.4 Analog Electrical Characteristics ........................................................................................................ 197 33. PACKAGE DIMENSIONS ........................................................................................................................... 200 33.1 28 pin TSSOP 28 – 4.4 X 9.7 mm ...................................................................................................... 200 33.2 28-pin SOP - 300 mil .......................................................................................................................... 201 33.3 20 pin TSSOP20 – 4.4 X 6.5 mm ....................................................................................................... 202 33.4 20 pin QFN – 4.0 X 4.0 mm ................................................................................................................ 203 34. DOCUMENT REVISION HISTORY ............................................................................................................ 204 Jan. 27, 2018 Page 4 of 205 Rev. 1.02 N76E885 Datasheet 1. GENERAL DESCRIPTION The N76E885 is an embedded flash type, 8-bit high performance 1T 8051-based microcontroller. The instruction set is fully compatible with the standard 80C51 and performance enhanced. The N76E885 contains a up to 18K Bytes of main Flash called APROM, in which the contents of User Code resides. The N76E885 Flash supports In-Application-Programming (IAP) function, which enables on-chip firmware updates. IAP also makes it possible to configure any block of User Code array to be used as non-volatile data storage, which is written by IAP and read by IAP or MOVC instruction. There is an additional Flash called LDROM, in which the Boot Code normally resides for carrying out In-System-Programming (ISP). The LDROM size is configurable with a maximum of 4K Bytes. To facilitate programming and verification, the Flash allows to be programmed and read electronically by parallel Writer or In-Circuit-Programming (ICP). Once the code is confirmed, user can lock the code for security. The N76E885 provides rich peripherals including 256 Bytes of SRAM, 256 Bytes of auxiliary RAM (XRAM), Up to 26 general purpose I/O, two 16-bit Timers/Counters 0/1, one 16-bit Timer2 with threechannel input capture module, one Watchdog Timer (WDT), one Self Wake-up Timer (WKT), one 16bit auto-reload Timer3 for general purpose or baud rate generator, two UARTs with frame error 2 detection and automatic address recognition, one SPI, one I C, four pairs of enhanced PWM output channels, eight-channel shared pin interrupt for all I/O, and one 10-bit ADC. The peripherals are equipped with 18 sources with 4-level-priority interrupts capability. The N76E885 is equipped with five clock sources and supports switching on-the-fly via software. The four clock sources include 2 MHz to 25 MHz high-speed external crystal/resonator, 32.768 kHz lowspeed external crystal/resonator, external clock input, 10 kHz internal oscillator, and one 22.118 MHz internal precise oscillator that is factory trimmed to ±1% at room temperature. The N76E885 provides additional power monitoring detection such as power-on reset and 8-level brown-out detection, which stabilizes the power-on/off sequence for a high reliability system design. The N76E885 microcontroller operation consumes a very low power with two economic power modes to reduce power consumption - Idle and Power-down mode, which are software selectable. Idle mode turns off the CPU clock but allows continuing peripheral operation. Power-down mode stops the whole system clock for minimum power consumption. The system clock of the N76E885 can also be slowed down by software clock divider, which allows for a flexibility between execution performance and power consumption. With high performance CPU core and rich well-designed peripherals, the N76E885 benefits to meet a general purpose, home appliances, or motor control system accomplishment. Jan. 27, 2018 Page 5 of 205 Rev. 1.02 N76E885 Datasheet 2. FEATURES  CPU: – Fully static design 8-bit high performance 1T 8051-based CMOS microcontroller. – Instruction set fully compatible with MCS-51. – 4-priority-level interrupts capability. – Dual Data Pointers (DPTRs).  Operating: – Wide supply voltage from 2.4V to 5.5V. – Wide operating frequency up to 25 MHz. – Industrial temperature grade: -40℃ to +105℃.  Memory: – Up to 18K Bytes of APROM for User Code. – Configurable 4K/3K/2K/1K/0K Bytes of LDROM, which provides flexibility to user developed Boot Code. – Flash Memory accumulated with pages of 128 Bytes each. – Built-in In-Application-Programmable (IAP). – Flash Memory 100,000 writing cycle endurance, greater than 10 years data retention. – Code lock for security. – 256 Bytes on-chip RAM. – Additional 256 Bytes on-chip auxiliary RAM (XRAM) accessed by MOVX instruction.  Clock sources: – 22.118 MHz high-speed internal oscillator trimmed to ±1% when VDD 5.0V, ±2% in all conditions. – 10 kHz low-speed internal oscillator. – 2 MHz to 25 MHz high-speed external crystal/resonator. – 32.768 kHz low-speed external crystal/resonator. – External clock input. – On-the-fly clock source switch via software. – Programmable system clock divider up to 1/512. Jan. 27, 2018 Page 6 of 205 Rev. 1.02 N76E885 Datasheet  Peripherals: – Up to 25 general purpose I/O pins and one input-only pin. All output pins have individual 2-level slew rate control. Five pins provide normal/high sink current selected via software. – Standard interrupt pins ̅̅̅̅̅̅̅ and ̅̅̅̅̅̅̅. – Two 16-bit Timers/Counters 0 and 1 compatible with standard 8051. – One 16-bit Timer 2 with three-channel input capture module. – One 16-bit auto-reload Timer 3, which can be the baud rate clock source of UARTs. – One programmable Watchdog Timer (WDT) clocked by dedicated 10 kHz internal source. – One dedicated Self Wake-up Timer (WKT) for self-timed wake-up for power reduced modes. – Two full-duplex UART ports with frame error detection and automatic address recognition. Up to 781.25 kbps when system clock is 25 MHz. TXD and RXD pins of UART0 exchangeable via software. – One SPI port with master and slave modes, up to 6.25 Mbps when system clock is 25 MHz. 2 – One I C bus with master and slave modes, up to 400 kbps data rate. – Four pairs, eight channels of pulse width modulator (PWM) output, up to 12-bit resolution, with different modes and Fault Brake function for motor control. – Eight channels of pin interrupt, shared for all I/O ports, with variable configuration of edge/level detection. – One 10-bit ADC with external VREF input available, up to 300 ksps converting rate, hardware triggered and conversion result compare facilitating motor control.  Power management: – Two power reduced modes: Idle and Power-down mode.  Power monitor: – Brown-out detection (BOD) with low power mode available, 8-level selection, interrupt or reset options. – Power-on reset (POR).  Strong ESD and EFT immunity.  Development Tools: – Nuvoton On-Chip-Debugger (OCD) with KEIL TM development environment. – Nuvoton In-Circuit-Programmer (ICP). – Nuvoton In-System-Programming (ISP) via UART. Jan. 27, 2018 Page 7 of 205 Rev. 1.02 N76E885 Datasheet  Part numbers and packages: Part Number APROM LDROM N76E885AT28 Package TSSOP 28 N76E885AS28 SOP28 18K Bytes shared with LDROM Up to 4K Bytes N76E885AT20 TSSOP 20 N76E885AQ20 QFN 20 Jan. 27, 2018 Page 8 of 205 Rev. 1.02 N76E885 Datasheet 3. BLOCK DIAGRAM Figure 3.1 shows the N76E885 functional block diagram and gives the outline of the device. User can find all the peripheral functions of the device in the diagram. Power-on Reset and Brown-out Detection VDD GND RST [1] 1T High Performance 8051 Core Max. 18K Bytes APROM Flash Timer 0/1 T0 (P2.0) T1 (P2.1) Max. 4K Bytes LDROM Flash Timer 2 with Input Capture IC0 (P2.0) IC1 (P2.1) IC2 (P2.2) Timer 3 256 Bytes XRAM (Auxiliary RAM) P0[7:0] P1[1:0] P1.2 P2[6:0] 8 2 P0 Self Wake-up Timer 8-bit Internal Bus 256 Bytes Internal RAM [1] P1 7 TXD (P0.3 or P2.0) RXD (P2.0 or P1.3) TXD_1 (P2.5) RXD_1 (P2.4) Serial Ports (UARTs) I2C SDA (P2.3) SCL (P0.6) SPI MOSI (P2.1) MISO (P2.2) SS (P0.4) SPCLK (P0.5) 8 P2 PWM PWM0~PWM7 (P1.0, P1.1, P0.2, P0.3, P0[5:7], P2.6) FB (P2.3) P3[7:0] 8 P3 INT0 (P0.0) INT1 (P0.1) External Interrupt Pin Interrupt 8 Any Port Watchdog Timer 10 10-bit ADC AIN0~9 (P0[0:7], P2.6, P2.0) VREF (P0.0) STADC (P2.3) System Clock Power Managment [1] XIN [1] XOUT 2~25 MHz/32 kHz Oscillator Circuit Clock Divider 22.118 MHz/10 kHz Internal RC Oscillator [1] P0.0 and P0.1 are shared with XIN and XOUT. P1.2 is shared with RST. Figure 3.1. Functional Block Diagram Jan. 27, 2018 Page 9 of 205 Rev. 1.02 N76E885 Datasheet 4. PIN CONFIGURATION GND 1 28 VDD PWM0/XIN/P1.0 2 27 P0.0/AIN0/VREF/INT0/ICPDA/OCDDA PWM1/XOUT/P1.1 3 26 P0.1/AIN1/INT1/ICPCK/OCDCK RST/P1.2 4 25 P0.2/AIN2/PWM2 RXD/T0/IC0/AIN9/P2.0 5 24 P0.3/AIN3/PWM3/TXD MOSI/T1/IC1/P2.1 6 23 P0.4/AIN4/SS MISO/IC2/P2.2 7 22 P0.5/AIN5/PWM4/SPCLK N76E885AT28 STADC/FB/SDA/P2.3 8 21 P0.6/AIN6/PWM5/SCL RXD_1/P2.4 9 20 P0.7/AIN7/PWM6 TXD_1/P2.5 10 19 P2.6/AIN8/PWM7/CLO P3.0 11 18 P3.7 P3.1 12 17 P3.6 P3.2 13 16 P3.5 P3.3 14 15 P3.4 Figure 4.1. Pin Assignment of TSSOP 28 Package GND 1 28 VDD PWM0/XIN/P1.0 2 27 P0.0/AIN0/VREF/INT0/ICPDA/OCDDA PWM1/XOUT/P1.1 3 26 P0.1/AIN1/INT1/ICPCK/OCDCK RST/P1.2 4 25 P0.2/AIN2/PWM2 RXD/T0/IC0/AIN9/P2.0 5 24 P0.3/AIN3/PWM3/TXD MOSI/T1/IC1/P2.1 6 23 P0.4/AIN4/SS MISO/IC2/P2.2 7 22 P0.5/AIN5/PWM4/SPCLK N76E885AS28 STADC/FB/SDA/P2.3 8 21 P0.6/AIN6/PWM5/SCL RXD_1/P2.4 9 20 P0.7/AIN7/PWM6 TXD_1/P2.5 10 19 P2.6/AIN8/PWM7/CLO P3.0 11 18 P3.7 P3.1 12 17 P3.6 P3.2 13 16 P3.5 P3.3 14 15 P3.4 Figure 4.2. Pin Assignment of SOP 28 Package Jan. 27, 2018 Page 10 of 205 Rev. 1.02 N76E885 Datasheet GND 1 20 VDD PWM0/XIN/P1.0 2 19 P0.0/AIN0/VREF/INT0/ICPDA/OCDDA PWM1/XOUT/P1.1 3 18 P0.1/AIN1/INT1/ICPCK/OCDCK RST/P1.2 4 17 P0.2/AIN2/PWM2 RXD/T0/IC0/AIN9/P2.0 5 16 P0.3/AIN3/PWM3/TXD N76E885AT20 MOSI/T1/IC1/P2.1 6 15 P0.4/AIN4/SS MISO/IC2/P2.2 7 14 P0.5/AIN5/PWM4/SPCLK STADC/FB/SDA/P2.3 8 13 P0.6/AIN6/PWM5/SCL RXD_1/P2.4 9 12 P0.7/AIN7/PWM6 TXD_1/P2.5 10 11 P2.6/AIN8/PWM7/CLO P2.6/AIN8/PWM7/CLO P0.7/AIN7/PWM6 P0.6/AIN6/PWM5/SCL P0.5/AIN5/PWM4/SPCLK P0.4/AIN4/SS Figure 4.3. Pin Assignment of TSSOP 20 Package 15 14 13 12 11 TXD/PWM3/AIN3/P0.3 16 10 P2.5/TXD_1 PWM2/AIN2/P0.2 17 9 P2.4/RXD_1 OCDCK/ICPCK/INT1/AIN1/P0.1 18 8 P2.3/FB/STADC/SDA OCDDA/ICPDA/INT0/VREF/AIN0/P0.0 19 7 P2.2/IC2/MISO VDD 20 6 P2.1/IC1/T1/MOSI 3 GND PWM1/XOUT/P1.1 4 5 RST/P1.2 2 RXD/T0/IC0/AIN9/P2.0 1 PWN/XIN/P1.0 N76E885AQ20 Figure 4.4 Pin Assignment of QFN 20 Package Jan. 27, 2018 Page 11 of 205 Rev. 1.02 N76E885 Datasheet Table 4–1. Pin Description Pin Number SOP 28 TSSOP 20 QFN 20 28 1 28 1 20 1 20 1 VDD GND 27 27 19 19 P0.0/AIN0/VREF/ ̅̅̅̅̅̅̅/ICPDA/ OCDDA 26 26 18 18 P0.1/AIN1/̅̅̅̅̅̅̅/ ICPCK/OCDCK 25 25 17 17 P0.2/AIN2/PWM2 24 24 16 16 P0.3/AIN3/ PWM3/TXD 23 23 15 15 P0.4/AIN4/̅̅̅̅ 22 22 14 14 P0.5/AIN5/ PWM4/SPCLK 21 21 13 13 P0.6/AIN6/ PWM5/SCL P0[7:0] 20 20 12 12 P0.7/AIN7/PWM6 2 2 2 2 P1.0/XIN/PWM0 3 3 3 3 P1.1/XOUT/PWM1 P1[2:0] Jan. 27, 2018 Multi-Function Description[1] Symbol TSSOP 28 POWER SUPPLY: Supply voltage VDD for operation. GROUND: Ground potential. PORT0: Port 0 is a bit-addressable, 8-bit I/O port. After reset, all pins are in input-only mode. P0.0: Port 0 bit 0. AIN0: ADC input channel 0. VREF: ADC VREF voltage input. ̅̅̅̅̅̅̅: External interrupt 0 input. ICPDA: ICP data input or output. OCDDA: OCD data input or output. P0.1: Port 0 bit 1. AIN1: ADC input channel 1. ̅̅̅̅̅̅̅: External interrupt 1 input. ICPCK: ICP clock input. OCDCK: OCD clock input. P0.2: Port 0 bit 2. AIN2: ADC input channel 2. PWM2: PWM output channel 2. P0.3: Port 0 bit 3. AIN3: ADC input channel 3. PWM3: PWM output channel 3. TXD[2]: Serial port 0 transmit data output. P0.4: Port 0 bit 4. AIN4: ADC input channel 4. ̅̅̅̅: SPI slave select input. P0.5: Port 0 bit 5. AIN5: ADC input channel 5. PWM4: PWM output channel 4. SPCLK: SPI clock. P0.6: Port 0 bit 6. AIN6: ADC input channel 6. PWM5: PWM output channel 5. 2 SCL: I C clock. P0.7: Port 0 bit 7. AIN7: ADC input channel 7. PWM6: PWM output channel 6. PORT1: Port 1 is a bit-addressable, maximum 3-bit I/O port. P1.2 is a dedicate input-only pin if available. P1.0: Port 1 bit 0 available when the internal oscillator is used as the system clock. XIN: If HXT or LXT is used, XIN is the input pin to the internal inverting amplifier. If the ECLK mode is enabled, XIN is the external clock input pin. PWM0: PWM output channel 0. P1.1: Port 1 bit 1 available when the internal oscillator or the external clock input is used as the system clock. XOUT: If HXT or LXT is used, XOUT is the output pin from the internal inverting amplifier. It emits the inverted signal of XIN. Page 12 of 205 Rev. 1.02 N76E885 Datasheet Table 4–1. Pin Description Pin Number TSSOP 28 SOP 28 TSSOP 20 QFN 20 Multi-Function Description[1] Symbol 4 4 4 P1.2/̅̅̅̅̅̅ 5 5 5 5 P2.0/AIN9/IC0/ T0/RXD 6 6 6 6 P2.1/IC1/T1/MOSI 7 7 7 7 P2.2/IC2/MISO 8 8 8 8 P2.3/SDA/FB/ STADC 9 9 9 9 P2.4/RXD_1 10 10 10 10 P2.5/TXD_1 19 19 11 11 P2.6/AIN8/ PWM7/CLO 4 P2[6:0] Jan. 27, 2018 PWM1: PWM output channel 1. P1.2: Port 1 bit 2 input pin available when RPD (CONFIG0.2) is programmed as 0. ̅̅̅̅̅̅: ̅̅̅̅̅̅ pin is a Schmitt trigger input pin for hardware device reset. A low on this pin resets the device. ̅̅̅̅̅̅ pin has an internal pull-up resistor allowing power-on reset by simply connecting an external capacitor to GND. PORT2: Port 2 is a bit-addressable, 7-bit I/O port. After reset, all pins are in input-only mode. P2.0: Port 2 bit 0. AIN9: ADC input channel 9. IC0: Input capture channel 0. T0: External count input to Timer/Counter 0 or its toggle output. RXD[2]: Serial port 0 receive input. P2.1: Port 2 bit 1. IC1: Input capture channel 1. T1: External count input to Timer/Counter 1 or its toggle output. MOSI: SPI master output/slave input. P2.2: Port 2 bit 2. IC2: Input capture channel 2. MISO: SPI master input/slave output. P2.3: Port 2 bit 3. 2 SDA: I C data. FB: Fault Brake input. STADC: External start ADC trigger. P2.4: Port 2 bit 4. RXD_1: Serial port 1 receive input. P2.5: Port 2 bit 5. TXD_1: Serial port 1 transmit data output. P2.6: Port 2 bit 6. AIN8: ADC input channel 8. PWM7: PWM output channel 7. CLO: System clock output. Page 13 of 205 Rev. 1.02 N76E885 Datasheet Table 4–1. Pin Description Pin Number TSSOP 28 SOP 28 TSSOP 20 QFN 20 Multi-Function Description[1] Symbol P3[7:0] PORT3: Port 3 is a bit-addressable, 8-bit I/O port. After reset, all pins are in input-only mode. P3.0: Port 3 bit 0. 11 11 P3.0 P3.1: Port 3 bit 1. 12 12 P3.1 P3.2: Port 3 bit 2. 13 13 P3.2 P3.3: Port 3 bit 3. 14 14 P3.3 P3.4: Port 3 bit 4. 15 15 P3.4 P3.5: Port 3 bit 5. 16 16 P3.5 P3.6: Port 3 bit 6. 17 17 P3.6 P3.7: Port 3 bit 7. 18 18 P3.7 [1] All I/O pins can be configured as a interrupt pin. This feature is not listed in multi-function description. See Section 17. “Pin Interrupt” on page 112. [2] TXD and RXD pins of UART0 are software exchangeable by UART0PX (AUXR1.2). VDD VDD 0.1μF 0.1μF C1 XIN 10μF as close to MCU as possible R XOUT VSS GND C2 N76E885 Crystal Frequency R 32.768 kHz Without 2 MHz to 25 MHz Without as close to the power source as possible C1 C2 Depending on crystal specifications Figure 4.5. Application Circuit with External Crystal Jan. 27, 2018 Page 14 of 205 Rev. 1.02 N76E885 Datasheet 5. MEMORY ORGANIZATION A standard 80C51 based microcontroller divides the memory into two different sections, Program Memory and Data Memory. The Program Memory is used to store the instruction codes, whereas the Data Memory is used to store data or variations during the program execution. The Data Memory occupies a separate address space from Program Memory. In N76E885, there are 256 Bytes of internal scratch-pad RAM. For many applications those need more internal RAM, the N76E885 provides another on-chip 256 Bytes of RAM, which is called XRAM, accessed by MOVX instruction. The whole embedded flash, functioning as Program Memory, is divided into three blocks: Application ROM (APROM) normally for User Code, Loader ROM (LDROM) normally for Boot Code, and CONFIG bytes for hardware initialization. Actually, APROM and LDROM function in the same way but have different size. Each block is accumulated page by page and the page size is 128 Bytes. The flash control unit supports Erase, Program, and Read modes. The external writer tools though specific I/O pins, In-Application-Programming (IAP), or In-System-Programming (ISP) can both perform these modes. 5.1 Program Memory The Program Memory stores the program codes to execute as shown in Figure 5.1. After any reset, the CPU begins execution from location 0000H. To service the interrupts, the interrupt service locations (called interrupt vectors) should be located in the Program Memory. Each interrupt is assigned with a fixed location in the Program Memory. The interrupt causes the CPU to jump to that location with where it commences execution of the interrupt service routine (ISR). External Interrupt 0, for example, is assigned to location 0003H. If External Interrupt 0 is going to be used, its service routine should begin at location 0003H. If the interrupt is not going to be used, its service location is available as general purpose Program Memory. The interrupt service locations are spaced at an interval of eight Bytes: 0003H for External Interrupt 0, 000BH for Timer 0, 0013H for External Interrupt 1, 001BH for Timer 1, etc. If an interrupt service routine is short enough (as is often the case in control applications), it can reside entirely within the 8Byte interval. However longer service routines should use a JMP instruction to skip over subsequent interrupt locations if other interrupts are in use. The N76E885 provides two internal Program Memory blocks APROM and LDROM. Although they both behave the same as the standard 8051 Program Memory, they play different rules according to Jan. 27, 2018 Page 15 of 205 Rev. 1.02 N76E885 Datasheet their ROM size. The APROM on N76E885 can be up to 18K Bytes. User Code is normally put inside. CPU fetches instructions here for execution. The MOVC instruction can also read this region. The other individual Program Memory block is called LDROM. The normal function of LDROM is to store the Boot Code for ISP. It can update APROM space and CONFIG bytes. The code in APROM can also re-program LDROM. For ISP details and configuration bit setting related with APROM and LDROM, see Section 22.4 “In-System-Programming (ISP)” on page 158. Note that APROM and LDROM are hardware individual blocks, consequently if CPU re-boots from LDROM, CPU will automatically re-vector Program Counter 0000H to the LDROM start address. Therefore, CPU accounts the LDROM as an independent Program Memory and all interrupt vectors are independent from APROM. CONFIG1 7 - Bit 2:0 6 - 5 - 4 - 3 - 2 1 0 LDSIZE[2:0] R/W Factory default value: 1111 1111b Name Description LDSIZE[2:0] LDROM size select This field selects the size of LDROM. 111 = No LDROM. APROM is 18K Bytes. 110 = LDROM is 1K Bytes. APROM is 17K Bytes. 101 = LDROM is 2K Bytes. APROM is 16K Bytes. 100 = LDROM is 3K Bytes. APROM is 15K Bytes. 0xx = LDROM is 4K Bytes. APROM is 14K Bytes. 37FFH/ 3BFFH/ 3FFFH/ 43FFH/ 47FFH[1] APROM 0FFFH/ 0BFFH/ 07FFH/ 03FFH/ 0000H[1] LDROM 0000H 0000H BS = 0 BS = 1 [1] The logic boundary addresses of APROM and LDROM are defined by CONFIG1[2:0]. Figure 5.1. N76E885 Program Memory Map Jan. 27, 2018 Page 16 of 205 Rev. 1.02 N76E885 Datasheet 5.2 Data Memory Figure 5.2 shows the internal Data Memory spaces available on N76E885. Internal Data Memory occupies a separate address space from Program Memory. The internal Data Memory can be divided into three blocks. They are the lower 128 Bytes of RAM, the upper 128 Bytes of RAM, and the 128 Bytes of SFR space. Internal Data Memory addresses are always 8-bit wide, which implies an address space of only 256 Bytes. Direct addressing higher than 7FH will access the special function registers (SFRs) space and indirect addressing higher than 7FH will access the upper 128 Bytes of RAM. Although the SFR space and the upper 128 Bytes of RAM share the same logic address, 80H through FFH, actually they are physically separate entities. Direct addressing to distinguish with the higher 128 Bytes of RAM can only access these SFRs. Sixteen addresses in SFR space are either byteaddressable or bit-addressable. The bit-addressable SFRs are those whose addresses end in 0H or 8H. The lower 128 Bytes of internal RAM are present in all 80C51 devices. The lowest 32 Bytes as general purpose registers are grouped into 4 banks of 8 registers. Program instructions call these registers as R0 to R7. Two bits RS0 and RS1 in the Program Status Word (PSW[3:4]) select which Register Bank is used. It benefits more efficiency of code space, since register instructions are shorter than instructions that use direct addressing. The next 16 Bytes above the general purpose registers (byte-address 20H through 2FH) form a block of bit-addressable memory space (bit-address 00H through 7FH). The 80C51 instruction set includes a wide selection of single-bit instructions, and the 128 bits in this area can be directly addressed by these instructions. The bit addresses in this area are 00H through 7FH. Either direct or indirect addressing can access the lower 128 Bytes space. But the upper 128 Bytes can only be accessed by indirect addressing. Another application implemented with the whole block of internal 256 Bytes RAM is used for the stack. This area is selected by the Stack Pointer (SP), which stores the address of the top of the stack. Whenever a JMP, CALL or interrupt is invoked, the return address is placed on the stack. There is no restriction as to where the stack can begin in the RAM. By default however, the Stack Pointer contains 07H at reset. User can then change this to any value desired. The SP will point to the last used value. Therefore, the SP will be incremented and then address saved onto the stack. Conversely, while popping from the stack the contents will be read first, and then the SP is decreased. Jan. 27, 2018 Page 17 of 205 Rev. 1.02 N76E885 Datasheet FFH 80H 7FH 00H Upper 128 Bytes SFR internal RAM (direct addressing) (indirect addressing) Lower 128 Bytes internal RAM (direct or indirect addressing) 00FFH 256 Bytes XRAM (MOVX addressing) 0000H Figure 5.2. Data Memory Map FFH FFH Indirect Accessing RAM 80H 7FH Direct or Indirect Accessing RAM 30H 2FH 2EH 2DH 2CH 2BH 2AH 29H 28H 27H 26H 25H 24H 23H 22H 21H 20H 1FH 18H 17H General Purpose Registers 10H 0FH 08H 07H 7F 77 6F 67 5F 57 4F 47 3F 37 2F 27 1F 17 0F 07 7E 76 6E 66 5E 56 4E 46 3E 36 2E 26 1E 16 0E 06 7D 75 6D 65 5D 55 4D 45 3D 35 2D 25 1D 15 0D 05 7C 74 6C 64 5C 54 4C 44 3C 34 2C 24 1C 14 0C 04 7B 73 6B 63 5B 53 4B 43 3B 33 2B 23 1B 13 0B 03 7A 72 6A 62 5A 52 4A 42 3A 32 2A 22 1A 12 0A 02 79 71 69 61 59 51 49 41 39 31 29 21 19 11 09 01 78 70 68 60 58 50 48 40 38 30 28 20 18 10 08 00 Bit-addressable Register Bank 3 Register Bank 2 General Purpose Registers Register Bank 1 Register Bank 0 00H 00H Figure 5.3. Internal 256 Bytes RAM Addressing 5.3 On-Chip XRAM The N76E885 provides additional on-chip 256 bytes auxiliary RAM called XRAM to enlarge the RAM space. It occupies the address space from 00H through FFH. The 256 bytes of XRAM are indirectly accessed by move external instruction MOVX @DPTR or MOVX @Ri. (See the demo code below.) Note that the stack pointer cannot be located in any part of XRAM. Jan. 27, 2018 Page 18 of 205 Rev. 1.02 N76E885 Datasheet XRAM demo code: MOV MOV MOVX MOV MOVX MOV MOV MOVX MOV MOVX R0,#23H A,#5AH @R0,A R1,#23H A,@R1 DPTR,#0023H A,#5BH @DPTR,A DPTR,#0023H A,@DPTR ;write #5AH to XRAM with address @23H ;read from XRAM with address @23H ;write #5BH to XRAM with address @0023H ;read from XRAM with address @0023H 5.4 Non-Volatile Data Storage By applying IAP, any page of APROM or LDROM can be used as non-volatile data storage. For IAP details, please see Section 22. “In-Application-Programming (IAP)” on page 152. Jan. 27, 2018 Page 19 of 205 Rev. 1.02 N76E885 Datasheet 6. SPECIAL FUNCTION REGISTER (SFR) The N76E885 uses Special Function Registers (SFRs) to control and monitor peripherals and their modes. The SFRs reside in the register locations 80 to FFH and are accessed by direct addressing only. SFRs those end their addresses as 0H or 8H are bit-addressable. It is very useful in cases where user would like to modify a particular bit directly without changing other bits via bit-field instructions. All other SFRs are byte-addressable only. The N76E885 contains all the SFRs presenting in the standard 8051. However some additional SFRs are built in. Therefore, some of unused bytes in the original 8051 have been given new functions. The SFRs are listed below. To accommodate more than 128 SFRs in the 0x80 to 0xFF address space, SFR paging has been implemented. By default, all SFR accesses target SFR page 0. During device initialization, some SFRs located on SFR page 1 may need to be accessed. The register SFRS is used to switch SFR addressing page. Note that this register has TA write protection. Most of SFRs are available on both SFR page 0 and 1. SFRS – SFR Page Selection (TA protected) 7 6 5 4 Address: 91H Bit 0 3 - Name Description SFRPAGE SFR page select 0 = Instructions access SFR page 0. 1 = Instructions access SFR page 1. 2 - 1 0 SFRPAGE R/W Reset value: 0000 0000b Switch SFR page demo code: MOV MOV ORL TA,#0AAH TA,#55H SFRS,#01H ;switch to SFR page 1 MOV MOV ANL TA,#0AAH TA,#55H SFRS,#0FEH ;switch to SFR page 0 Jan. 27, 2018 Page 20 of 205 Rev. 1.02 N76E885 Datasheet Table 6–1. SFR Memory Map SFR Page 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 Addr 0/8 1/9 2/A 3/B 4/C 5/D 6/E 7/F F8 SCON_1 PDTEN PDTCNT PMEN PMD - EIP1 - EIPH1 - F0 B - ADCAQT SPCR SPSR SPDR P0DIDS EIPH E8 ADCCON0 PICON PINEN PIPEN PIF C2L C2H EIP E0 ACC ADCCON1 ADCCON2 ADCDLY C0L C0H C1L C1H D8 PWMCON0 PWMPL PWM01L PWM23L PWM67L PWM45L PIO PWMCON1 D0 PSW PWMPH PWM01H PWM23H PWM67H PWM45H PNP FBD C8 T2CON T2MOD RCMP2L RCMP2H TL2 TH2 ADCMPL ADCMPH C0 I2CON I2ADDR ADCRL ADCRH T3CON RL3 RH3 TA B8 IP SADEN SADEN_1 SADDR_1 I2DAT I2STAT I2CLK I2TOC B0 P3 P0M1 P0S P0M2 P0SR P1M1 P1S IPH IE SADDR WDCON BODCON1 P2M1 P2S P3M2 P3SR P2M2 P2SR A8 P1M2 P1SR P3M1 P3S IAPFD IAPCN A0 P2 - AUXR1 BODCON0 IAPTRG IAPUEN IAPAL IAPAH 98 SCON SBUF SBUF_1 EIE EIE1 - - CHPCON 90 P1 SFRS CAPCON0 CAPCON1 CAPCON2 CKDIV CKSWT CKEN 88 TCON TMOD TL0 TL1 TH0 TH1 CKCON WKCON 80 P0 SP DPL DPH - - RWK PCON Unoccupied addresses in the SFR space marked in “-“ are reserved for future use. Accessing these areas will have an indeterminate effect and should be avoided. Jan. 27, 2018 Page 21 of 205 Rev. 1.02 N76E885 Datasheet Table 6–2. SFR Definitions and Reset Values Symbol EIPH1 EIP1 PMD PMEN [4] PDTCNT PDTEN [4] SCON_1 Definition Extensive interrupt FFH/(0) priority high 1 Extensive interrupt FEH/(0) priority 1 PWM mask data FCH PWM mask enable FBH PWM dead-time counter FAH PWM dead-time enable F9H Serial port 1 control F8H P0DIDS SPDR SPSR SPCR ADCAQT Extensive interrupt priority high P0 digital input disable SPI data SPI status SPI control ADC acquisition time B B register EIPH Address /(Page) F7H F6H F5H F4H F3H F2H F0H PICON Extensive interrupt priority Input capture 2 high byte Input capture 2 low byte Pin interrupt flag Pin interrupt high level/rising edge enable Pin interrupt low level/falling edge enable Pin interrupt control ADCCON0 ADC control 0 E8H C1H C1L C0H C0L ADCDLY ADCCON2 ADCCON1 Input capture 1 high byte Input capture 1 low byte Input capture 0 high byte Input capture 0 low byte ADC trigger delay ADC control 2 ADC control 1 E7H E6H E5H E4H E3H E2H E1H ACC Accumulator E0H PWMCON1 PIO PWM45L PWM67L PWM23L PWM01L PWMPL PWM control 1 PWM I/O switch PWM4/5 duty low byte PWM6/7 duty low byte PWM2/3 duty low byte PWM0/1 duty low byte PWM period low byte DFH DEH DDH DCH DBH DAH D9H PWMCON0 PWM control 0 D8H FBD PNP PWM45H PWM67H PWM23H PWM01H PWMPH Brake data PWM negative polarity PWM4/5 duty high byte PWM6/7 duty high byte PWM2/3 duty high byte PWM0/1 duty high byte PWM period high byte D7H D6H D5H D4H D3H D2H D1H PSW Program status word D0H ADCMPH ADCMPL TH2 TL2 ADC compare high byte ADC compare low byte Timer 2 high byte Timer 2 low byte Timer 2 compare high byte Timer 2 compare low byte Timer 2 mode EIP C2H C2L PIF PIPEN PINEN RCMP2H RCMP2L T2MOD Jan. 27, 2018 EFH MSB - LSB - - - - - PMD7 PMEN7 PMD6 PMEN6 PMD5 PMEN5 (FF) SM0_1/ FE_1 (FE) (FD) SM1_1 SM2_1 PT2H PSPIH PFBH - - PWKTH - - PWKT PMD2 PMEN2 PMD4 PMD3 PMEN4 PMEN3 PDTCNT[7:0] PT3H [1] PSH_1 0000 0000b PT3 PS_1 0000 0000b PMD1 PMEN1 PMD0 PMEN0 0000 0000b 0000 0000b 0000 0000b PDTCNT.8 PDT67EN PDT45EN PDT23EN PDT01EN 0 0 0 0 0 0 0 0 b (FC) (FB) (FA) (F9) (F8) 0000 0000b REN_1 TB8_1 RB8_1 TI_1 RI_1 PWDTH PPWMH PCAPH PPIH PI2CH P07DIDS P06DIDS P05DIDS P04DIDS P03DIDS P02DIDS P01DIDS P00DIDS SPDR[7:0] SPIF WCOL SPIOVF MODF DISMODF SSOE SPIEN LSBFE MSTR CPOL CPHA SPR[1:0] ADCAQT[7:0] (F7) (F6) (F5) (F4) (F3) (F2) (F1) (F0) B.7 B.6 B.5 B.4 B.3 B.2 B.1 B.0 PT2 PSPI PFB [2] Reset Value PWDT PPWM C2H[7:0] C2L[7:0] PIF4 PIF3 PCAP PPI 0000 0000b 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000 0000b PI2C 0000 0000b PIF1 PIF0 0000 0000b 0000 0000b 0000 0000b PIPEN1 PIPEN0 0000 0000b EEH EDH ECH PIF7 PIF6 PIF5 PIF2 EBH PIPEN7 PIPEN6 PIPEN5 PIPEN4 PIPEN3 PIPEN2 EAH PINEN7 PINEN6 PINEN5 PINEN4 PINEN3 PINEN2 PINEN1 PINEN0 0 0 0 0 0 0 0 0 b E9H PIT67 (EF) ADCF PIT45 (EE) ADCS 0000 0000b CFH CEH CDH CCH PIT3 PIT2 PIT1 PIT0 PIPS[1:0] (ED) (EC) (EB) (EA) (E9) (E8) ETGSEL1 ETGSEL0 ADCHS3 ADCHS2 ADCHS1 ADCHS0 C1H[7:0] C1L[7:0] C0H[7:0] C0L[7:0] ADCDLY[7:0] ADFBEN ADCMPOP ADCMPEN ADCMPO P26DIDS P20DIDS ADCDLY.8 VREFSEL ADCDIV[2:0] ETGTYP[1:0] ADCEX ADCEN (E7) (E6) (E5) (E4) (E3) (E2) (E1) (E0) ACC.7 ACC.6 ACC.5 ACC.4 ACC.3 ACC.2 ACC.1 ACC.0 PWMMOD[1:0] GP PWMTYP FBINEN PWMDIV[2:0] PIO7 PIO6 PIO5 PIO4 PIO3 PIO2 PIO1 PIO0 PWM45[7:0] PWM67[7:0] PWM23[7:0] PWM01[7:0] PWMP[7:0] (DF) (DE) (DD) (DC) (DB) (DA) (D9) (D8) PWMRUN LOAD PWMF CLRPWM INTTYP1 INTTYP0 INTSEL1 INTSEL0 FBF FBINLS FBD5 FBD4 FBD3 FBD2 FBD1 FBD0 PNP7 PNP6 PNP5 PNP4 PNP3 PNP2 PNP1 PNP0 PWM45[11:8] PWM67[11:8] PWM23[11:8] PWM01[11:8] PWMP[11:8] (D7) (D6) (D5) (D4) (D3) (D2) (D1) (D0) CY AC F0 RS1 RS0 OV P ADCMP[9:2] ADCMP[1:0] TH2[7:0] TL2[7:0] CBH RCMP2H[7:0] 0000 0000b CAH RCMP2L[7:0] 0000 0000b C9H LDEN T2DIV[2:0] Page 22 of 205 CAPCR CMPCR LDTS[1:0] 0000 0000b 0000 0000 0000 0000 0000 0000 0010 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000 0000b Rev. 1.02 N76E885 Datasheet Table 6–2. SFR Definitions and Reset Values Symbol Definition Address /(Page) MSB (CF) TF2 T2CON Timer 2 control C8H TA RH3 RL3 T3CON ADCRH ADCRL I2ADDR Timed access protection Timer 3 reload high byte Timer 3 reload low byte Timer 3 control ADC result high byte ADC result low byte 2 I C own slave address C7H C6H C5H C4H C3H C2H C1H I2CON I C control 2 2 C0H I2TOC I2CLK I2STAT I2DAT SADDR_1 SADEN_1 SADEN I C time-out counter 2 I C clock 2 I C status 2 I C data Slave 1 address Slave 1 address mask Slave 0 address mask BFH BEH BDH BCH BBH BAH B9H IP Interrupt priority B8H IPH P2SR P2M2 P2S P2M1 P1SR P1M2 P1S P1M1 P0SR P0M2 P0S P0M1 Interrupt priority high P2 slew rate P2 mode select 2 P2 Schmitt trigger input P2 mode select 1 P1 slew rate P1 mode select 2 P1 Schmitt trigger input P1 mode select 1 P0 slew rate P0 mode select 2 P0 Schmitt trigger input P0 mode select 1 P3 Port 3 IAPCN IAPFD P3SR P3M2 P3S P3M1 IAP control IAP flash data P3 slew rate P3 mode select 2 P3 Schmitt trigger input P3 mode select 1 B7H B6H/(1) B6H/(0) B5H/(1) B5H/(0) B4H/(1) B4H/(0) B3H/(1) B3H/(0) B2H/(1) B2H/(0) B1H/(1) B1H/(0) B0H LSB (CC) (CB) TA[7:0] RH3[7:0] RL3[7:0] TF3 TR3 SMOD_1 SMOD0_1 BRCK ADCR[9:2] I2ADDR[7:1] (C7) (C6) (C4) (C4) (C3) I2CEN STA STO SI I2CLK[7:0] I2STAT[7:3] I2DAT[7:0] SADDR_1[7:0] SADEN_1[7:0] SADEN[7:0] (BF) (BE) (BD) (BC) (BB) PADC PBOD PS PT1 PADCH PBODH PSH PT1H P2SR.6 P2SR.5 P2SR.4 P2SR.3 P2M2.6 P2M2.5 P2M2.4 P2M2.3 P2S.6 P2S.5 P2S.4 P2S.3 P2M1.6 P2M1.5 P2M1.4 P2M1.3 CLOEN P21SNK P20SNK P03SNK P02SNK P01SNK T1OE P0SR.7 P0SR.6 P0SR.5 P0SR.4 P0SR.3 P0M2.7 P0M2.6 P0M2.5 P0M2.4 P0M2.3 P0S.7 P0S.6 P0S.5 P0S.4 P0S.3 P0M1.7 P0M1.6 P0M1.5 P0M1.4 P0M1.3 (B7) P3.7 (CE) - (B6) P3.6 (B5) P3.5 (B3) P3.3 P3SR.7 P3M2.7 P3S.7 P3M1.7 P3SR.6 P3M2.6 P3S.6 P3M1.6 P3SR.5 P3M2.5 P3S.5 P3M1.5 Brown-out detection control 1 ABH - - - - - WDCON Watchdog Timer control AAH WDTEN WDCLR WDTF WIDPD WDTRF SADDR Slave 0 address A9H IE Interrupt enable A8H (AF) EA (AE) EADC (AD) EBOD IAPAH IAPAL [4] IAPUEN IAP address high byte IAP address low byte IAP update enable A7H A6H A5H - - - IAP trigger A4H - - - [4] [4] [4] IAPTRG Jan. 27, 2018 FOEN (B4) P3.4 AFH AEH ADH/(1) ADH/(0) ACH/(1) ACH/(0) BODCON1 IAPA[17:16] (CD) - FCEN IAPFD[7:0] P3SR.4 P3SR.3 P3M2.4 P3M2.3 P3S.4 P3S.3 P3M1.4 P3M1.3 SADDR[7:0] (AC) (AB) ES ET1 IAPA[15:8] IAPA[7:0] - Page 23 of 205 - (CA) TR2 (C2) AA I2TOCEN [1] [2] Reset Value (C9) - (C8) ̅̅̅̅̅̅ 0 0 0 0 0 0 0 0 b T3PS[2:0] 0000 0000 0000 0000 0000 0000 0000 ADCR[1:0] GC (C1) (C0) DIV I2TOF 0 0 0 (BA) PX1 PX1H P2SR.2 P2M2.2 P2S.2 P2M1.2 P12UP P1S.2 T0OE P0SR.2 P0M2.2 P0S.2 P0M1.2 (B9) PT0 PT0H P2SR.1 P2M2.1 P2S.1 P2M1.1 P1SR.1 P1M2.1 P1S.1 P1M1.1 P0SR.1 P0M2.1 P0S.1 P0M1.1 (B8) PX0 PX0H P2SR.0 P2M2.0 P2S.0 P2M1.0 P1SR.0 P1M2.0 P1S.0 P1M1.0 P0SR.0 P0M2.0 P0S.0 P0M1.0 - - IAPGO 0000b 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000 1111 0000 0000 0000 0000 0000b 1110b 1000b 0000b 0000b 0000b 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0111 1111b 0000 0000b 0000 0000b 0000 0000b 0000 0011b 0000 0000b 0000 0000b 0000 0000b 1111 1111b Output latch, 1111 1111b (B2) (B1) (B0) Input, P3.2 P3.1 P3.0 [3] XXXX XXXXb FCTRL[3:0] 0011 0000b 0000 0000b P3SR.2 P3SR.1 P3SR.0 0 0 0 0 0 0 0 0 b P3M2.2 P3M2.1 P3M2.0 0 0 0 0 0 0 0 0 b P3S.2 P3S.1 P3S.0 0 0 0 0 0 0 0 0 b P3M1.2 P3M1.1 P3M1.0 1 1 1 1 1 1 1 1 b POR, 0000 0001b LPBOD[1:0] BODFLT Others, 0000 0UUUb POR, 0000 0111b WDT, WDPS[2:0] 0000 1UUUb Others, 0 0 00 U U U U b 0000 0000b (AA) (A9) (A8) 0000 0000b EX1 ET0 EX0 0000 0000b 0000 0000b CFUEN LDUEN APUEN 0 0 0 0 0 0 0 0 b 0000 0000b Rev. 1.02 N76E885 Datasheet Table 6–2. SFR Definitions and Reset Values Symbol Definition Address /(Page) MSB LSB [1] [2] Reset Value POR, CCCC XC0Xb BOD, UUUU XU1Xb Others, UUUU XUUXb POR, 0000 0000b Software, 1U00 0000b ̅̅̅̅̅̅ pin, U100 0000b Others, UU00 0000b Output latch, 0111 1111b Input, [3] 0XXX XXXXb Software, 0000 00U0b Others, 0000 00C0b BODCON0 Brown-out detection control 0 A3H BODEN AUXR1 Auxiliary register 1 A2H SWRF RSTPINF T1LXTM T0LXTM GF2 UART0PX 0 DPS P2 Port 2 A0H (A7) 0 (A6) P2.6 (A5) P2.5 (A4) P2.4 (A3) P2.3 (A2) P2.2 (A1) P2.1 (A0) P2.0 Chip control 9FH SWRST IAPFF - - - - 9CH - - - - - EWKT ET3 ES_1 0000 0000b 9BH ET2 ESPI EFB EWDT EPWM ECAP EPI EI2C 0000 0000b [4] CHPCON [4] SBUF_1 SBUF Extensive interrupt enable 1 Extensive interrupt enable Serial port 1 data buffer Serial port 0 data buffer SCON Serial port 0 control 98H EIE1 EIE [4] [5] BOV[2:0] [5] 9AH 99H (9D) SM2 HIRCEN HXTST LXTST HIRCST - ENF2 CAPEN2 (96) 0 (95) 0 (94) 0 (93) 0 WKTF WKTR Clock enable 97H Clock switch Clock divider Input capture control 2 Input capture control 1 Input capture control 0 SFR page selection 96H 95H 94H 93H 92H 91H P1 Port 1 90H (97) 0 8FH - - WKTCK CKCON TH1 TH0 TL1 TL0 TMOD Self Wake-up Timer control Clock control Timer 1 high byte Timer 0 high byte Timer 1 low byte Timer 0 low byte Timer 0 and 1 mode 8EH 8DH 8CH 8BH 8AH 89H - PWMCKS - TCON Timer 0 and 1control 88H GATE (8F) TF1 (8E) TR1 M1 (8D) TF0 PCON Power control 87H SMOD SMOD0 - [4] WKCON DPH DPL SP Self Wake-up Timer reload byte Data pointer high byte Data pointer low byte Stack pointer P0 Port 0 RWK SBUF_1[7:0] SBUF[7:0] (9C) (9B) REN TB8 - (9F) (9E) SM0/FE SM1 EXTEN[1:0] CKSWT CKDIV CAPCON2 CAPCON1 CAPCON0 [4] SFRS CKEN [6] BOF ̅ BORST [5] BORF BS [5] BOS [7] IAPEN 0000 0000b 0000 0000b (9A) RB8 - (99) TI - (98) 0000 0000b RI CKSWTF 0 0 1 1 0 0 0 0 b ECLKST OSC[1:0] CKDIV[7:0] ENF1 ENF0 CAP2LS[1:0] CAP1LS[1:0] CAP0LS[1:0] CAPEN1 CAPEN0 CAPF2 CAPF1 CAPF0 SFRPSEL T1M T0M TH1[7:0] TH0[7:0] TL1[7:0] TL0[7:0] M0 GATE (8C) (8B) TR0 IE1 POF GF1 (92) P1.2 (91) P1.1 (90) P1.0 WKPS[2:0] - 0000 0000b - - (8A) IT1 M1 (89) IE0 M0 (88) IT0 GF0 PD IDL ̅ 0011 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b 0000 0000b Output latch, 0000 0111b Input, [3] 0000 0XXXb 0000 0000 0000 0000 0000 0000 0000b 0000b 0000b 0000b 0000b 0000b 0000 0000b POR, 0001 0000b Others, 000U 0000b 86H RWK[7:0] 0000 0000b 83H 82H 81H DPTR[15:8] DPTR[7:0] SP[7:0] 0000 0000b 0000 0000b 0000 0111b Output latch, 1111 1111b Input, [3] XXXX XXXXb 80H (87) P0.7 (86) P0.6 (85) P0.5 (84) P0.4 (83) P0.3 (82) P0.2 (81) P0.1 (80) P0.0 [1] ( ) item means the bit address in bit-addressable SFRs. [2] Reset value symbol description. 0: logic 0; 1: logic 1; U: unchanged; C: see [5]; X: see [3], [6], and [7]. [3] All I/O pins are default input-only mode (floating) after reset. Reading back P1.2 is always 0 if RPD (CONFIG0.2) remains un-programmed 1. Jan. 27, 2018 Page 24 of 205 Rev. 1.02 N76E885 Datasheet [4] These SFRs have TA protected writing. [5] These SFRs have bits those are initialized according to CONFIG values after specified resets. See Section 29. “CONFIG Bytes” on page 186 for details. [6] BOF reset value depends on different setting of CONFIG2 and V DD voltage level. Please check Table 25–1. [7] BOS is a read-only flag decided by VDD level while brown-out detection is enabled. Bits marked in “-“ are reserved for future use. They must be kept in their own initial states. Accessing these bits may cause an unpredictable effect. Jan. 27, 2018 Page 25 of 205 Rev. 1.02 N76E885 Datasheet 7. GENERAL 80C51 SYSTEM CONTROL A or ACC – Accumulator (Bit-addressable) 7 6 5 4 ACC.7 ACC.6 ACC.5 ACC.4 R/W R/W R/W R/W Address: E0H Bit 7:0 7:0 2 ACC.2 R/W 1 0 ACC.1 ACC.0 R/W R/W Reset value: 0000 0000b Name Description ACC[7:0] Accumulator The A or ACC register is the standard 80C51 accumulator for arithmetic operation. B – B Register (Bit-addressable) 7 6 5 B.7 B.6 B.5 R/W R/W R/W Address: F0H Bit 3 ACC.3 R/W Name B[7:0] 4 B.4 R/W 3 B.3 R/W 2 B.2 R/W 1 0 B.1 B.0 R/W R/W Reset value: 0000 0000b Description B register The B register is the other accumulator of the standard 80C51 .It is used mainly for MUL and DIV instructions. SP – Stack Pointer 7 6 5 4 3 2 1 0 SP[7:0] R/W Address: 81H Bit 7:0 Reset value: 0000 0111b Name SP[7:0] Description Stack pointer The Stack Pointer stores the scratch-pad RAM address where the stack begins. It is incremented before data is stored during PUSH or CALL instructions. Note that the default value of SP is 07H. This causes the stack to begin at location 08H. DPL – Data Pointer Low Byte 7 6 5 4 3 2 1 0 DPL[7:0] R/W Address: 82H Bit 7:0 Jan. 27, 2018 Reset value: 0000 0000b Name Description DPL[7:0] Data pointer low byte This is the low byte of 16-bit data pointer. DPL combined with DPH serve as a 16bit data pointer DPTR to access indirect addressed RAM or Program Memory. DPS (AUXR1.0) bit decides which data pointer, DPTR or DPTR1, is activated. Page 26 of 205 Rev. 1.02 N76E885 Datasheet DPH – Data Pointer High Byte 7 6 5 4 3 2 1 0 DPH[7:0] R/W Address: 83H Bit 7:0 Reset value: 0000 0000b Name Description DPH[7:0] Data pointer high byte This is the high byte of 16-bit data pointer. DPH combined with DPL serve as a 16-bit data pointer DPTR to access indirect addressed RAM or Program Memory. DPS (AUXR1.0) bit decides which data pointer, DPTR or DPTR1, is activated. PSW – Program Status Word (Bit-addressable) 7 6 5 4 CY AC F0 RS1 R/W R/W R/W R/W Address: D0H Bit Name 3 RS0 R/W 2 OV R/W 1 0 F1 P R/W R Reset value: 0000 0000b Description 7 CY Carry flag For a adding or subtracting operation, CY will be set when the previous operation resulted in a carry-out from or a borrow-in to the Most Significant bit, otherwise cleared. If the previous operation is MUL or DIV, CY is always 0. CY is affected by DA A instruction, which indicates that if the original BCD sum is greater than 100. For a CJNE branch, CY will be set if the first unsigned integer value is less than the second one. Otherwise, CY will be cleared. 6 AC Auxiliary carry Set when the previous operation resulted in a carry-out from or a borrow-in to the 4th bit of the low order nibble, otherwise cleared. 5 F0 User flag 0 The general purpose flag that can be set or cleared by user. 4 RS1 3 RS0 Jan. 27, 2018 Register bank selection bits These two bits select one of four banks in which R0 to R7 locate. RS1 RS0 Register Bank RAM Address 0 0 0 00H to 07H 0 1 1 08H to 0FH 1 0 2 10H to 17H 1 1 3 18H to 1FH Page 27 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 2 OV Overflow flag OV is used for a signed character operands. For a ADD or ADDC instruction, OV will be set if there is a carry out of bit 6 but not out of bit 7, or a carry out of bit 7 but not bit 6. Otherwise, OV is cleared. OV indicates a negative number produced as the sum of two positive operands or a positive sum from two negative operands. For a SUBB, OV is set if a borrow is needed into bit6 but not into bit 7, or into bit7 but not bit 6. Otherwise, OV is cleared. OV indicates a negative number produced when a negative value is subtracted from a positive value, or a positive result when a positive number is subtracted from a negative number. For a MUL, if the product is greater than 255 (00FFH), OV will be set. Otherwise, it is cleared. For a DIV, it is normally 0. However, if B had originally contained 00H, the values returned in A and B will be undefined. Meanwhile, the OV will be set. 1 F1 User flag 1 The general purpose flag that can be set or cleared by user via software. 0 P Parity flag Set to 1 to indicate an odd number of ones in the accumulator. Cleared for an even number of ones. It performs even parity check. Table 7–1. Instructions That Affect Flag Settings Instruction CY OV AC X[1] X X CLR C 0 ADDC X X X CPL C X SUBB X X X ANL C, bit X MUL 0 X ANL C, /bit X DIV 0 X ORL C, bit X DA A X ORL C, /bit X RRC A X MOV C, bit X RLC A X CJNE X SETB C 1 ADD Instruction CY OV AC [1] X indicates the modification depends on the result of the instruction. PCON – Power Control 7 6 SMOD SMOD0 R/W R/W Address: 87H Bit Name 5 - 4 3 2 1 0 POF GF1 GF0 PD IDL R/W R/W R/W R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description 3 GF1 General purpose flag 1 The general purpose flag that can be set or cleared by user via software. 2 GF0 General purpose flag 0 The general purpose flag that can be set or cleared by user via software. Jan. 27, 2018 Page 28 of 205 Rev. 1.02 N76E885 Datasheet 8. I/O PORT STRUCTURE AND OPERATION The N76E885 has a maximum of 26 bit-addressable general I/O pins grouped as 4 ports, P0 to P3. Each port has its port control register (Px register). The writing and reading of a port control register have different meanings. A write to port control register sets the port output latch logic value, whereas a read gets the port pin logic state. All I/O pins except P1.2 can be configured individually as one of four I/O modes by software. These four modes are quasi-bidirectional (standard 8051 port structure), push-pull, input-only, and open-drain modes. Each port spends two special function registers PxM1 and PxM2 to select the I/O mode of port Px. The list below illustrates how to select the I/O mode of Px.n. Note that the default configuration of is input-only (high-impedance) after any reset. Table 8–1. Configuration for Different I/O Modes PxM1.n PxM2.n I/O Type 0 0 Quasi-bidirectional 0 1 Push-pull 1 0 Input-only (high-impedance) 1 1 Open-drain All I/O pins can be selected as TTL level inputs or Schmitt triggered inputs by selecting corresponding bit in PxS register. Schmitt triggered input has better glitch suppression capability. All I/O pins also have bit-controllable, slew rate select ability via software. The control registers are PxSR. By default, the slew rate is slow. If user would like to increase the I/O output speed, setting the corresponding bit in PxSR, the slew rate is selected in a faster level. There are five I/O pins those support high sink current including P0.1, P0.2, P0.3, P2.0, and P2.1. By default they have the same sink capability as other I/O pins. By setting PxnSNK, their independent bits in P1S register, they can be individually configured as high sink capability. It is suitable to drive LED or large loading without BJT devices. Note that setting PxnSNK bit only increases the sink capability but the source capability remains the same. P1.2 is configured as an input-only pin when programming RPD (CONFIG0.2) as 0. Meanwhile, P1.2 is permanent in input-only mode and Schmitt triggered type. P1.2 also has an internal pull-up enabled by P12UP (P1M2.2). If RPD remains un-programmed, P1.2 pin functions as an external reset pin and P1.2 is not available. A read of P1.2 bit is always 0. Meanwhile, the internal pull-up is always enabled. 8.1 Quasi-Bidirectional Mode The quasi-bidirectional mode, as the standard 8051 I/O structure, can rule as both input and output. When the port outputs a logic high, it is weakly driven, allowing an external device to pull the pin low. Jan. 27, 2018 Page 29 of 205 Rev. 1.02 N76E885 Datasheet When the pin is pulled low, it is driven strongly and able to sink a large current. In the quasibidirectional I/O structure, there are three pull-high transistors. Each of them serves different purposes. One of these pull-highs, called the “very weak” pull-high, is turned on whenever the port latch contains logic 1. he “very weak” pull-high sources a very small current that will pull the pin high if it is left floating. A second pull-high, called the “weak” pull-high, is turned on when the outside port pin itself is at logic 1 level. This pull-high provides the primary source current for a quasi-bidirectional pin that is outputting 1. If a pin which has logic 1 on it is pulled low by an external device, the “weak” pull-high turns off, and only the “very weak” pull-high remains on. To pull the pin low under these conditions, the external device has to sink enough current (larger than ITL) to overcome the “weak” pull-high and make the voltage on the port pin below its input threshold (lower than VIL). The third pull-high is the “strong” pull-high. This pull-high is used to speed up 0-to-1 transitions on a quasi-bidirectional port pin when the port latch changes from logic 0 to logic 1. When this occurs, the strong pull-high turns on for two-CPU-clock time to pull the port pin high quickly. Then it turns off and “weak” and “very weak” pull-highs continue remaining the port pin high. The quasi-bidirectional port structure is shown below. VDD 2-CPU-clock delay P Strong P Very Weak P Weak Port Pin Port Latch N Input Figure 8.1. Quasi-Bidirectional Mode Structure 8.2 Push-Pull Mode The push-pull mode has the same pull-low structure as the quasi-bidirectional mode, but provides a continuous strong pull-high when the port latch is written by logic 1. The push-pull mode is generally used as output pin when more source current is needed for an output driving. Jan. 27, 2018 Page 30 of 205 Rev. 1.02 N76E885 Datasheet VDD P Strong Port Pin N Port Latch Input Figure 8.2. Push-Pull Mode Structure 8.3 Input-Only Mode Input-only mode provides true high-impedance input path. Although a quasi-bidirectional mode I/O can also be an input pin, but it requires relative strong input source. Input-only mode also benefits to power consumption reduction for logic 0 input always consumes current from VDD if in quasi-bidirectional mode. User needs to take care that an input-only mode pin should be given with a determined voltage level by external devices or resistors. A floating pin will induce leakage current especially in Powerdown mode. Input Port Pin Figure 8.3. Input-Only Mode Structure 8.4 Open-Drain Mode The open-drain mode turns off all pull-high transistors and only drives the pull-low of the port pin when the port latch is given by logic 0. If the port latch is logic 1, it behaves as if in input-only mode. To be 2 used as an output pin generally as I C lines, an open-drain pin should add an external pull-high, typically a resistor tied to VDD. User needs to take care that an open-drain pin with its port latch as logic 1 should be given with a determined voltage level by external devices or resistors. A floating pin will induce leakage current especially in Power-down mode. Jan. 27, 2018 Page 31 of 205 Rev. 1.02 N76E885 Datasheet Port Pin N Port Latch Input Figure 8.4. Open-Drain Mode Structure 8.5 Read-Modify-Write Instructions nstructions that read a byte from F or internal A , modify it, and rewrite it back, are called “ ead- Modify-Write” instructions. When the destination is an O port or a port bit, these instructions read the internal output latch rather than the external pin state. This kind of instructions read the port SFR value, modify it and write back to the port SFR. All “Read-Modify-Write” instructions are listed as follows. Instruction Description ANL Logical AND. (ANL direct, A and ANL direct, #data) ORL Logical OR. (ORL direct, A and ORL direct, #data) XRL Logical exclusive OR. (XRL direct, A and XRL direct, #data) JBC Jump if bit = 1 and clear it. (JBC bit, rel) CPL Complement bit. (CPL bit) INC Increment. (INC direct) DEC Decrement. (DEC direct) DJNZ Decrement and jump if not zero. (DJNZ direct, rel) MOV bit, C Move carry to bit. (MOV bit, C) CLR bit Clear bit. (CLR bit) SETB bit Set bit. (SETB bit) The last three seem not obviously “ ead-Modify-Write” instructions but actually they are. They read the entire port latch value, modify the changed bit, and then write the new value back to the port latch. 8.6 Control Registers of I/O Ports The N76E885 has a lot of I/O control registers to provide flexibility in all kinds of applications. The SFRs related with I/O ports can be categorized into four groups: input and output control, output mode control, input type and sink current control, and output slew rate control. All of SFRs are listed as follows. Jan. 27, 2018 Page 32 of 205 Rev. 1.02 N76E885 Datasheet 8.6.1 Input and Output Data Control These registers are I/O input and output data buffers. Reading gets the I/O input data. Writing forces the data output. All of these registers are bit-addressable. P0 – Port 0 (Bit-addressable) 7 6 5 P0.7 P0.6 P0.5 R/W R/W R/W Address: 80H Bit Name 7:0 P0[7:0] Name 3 P0.3 R/W 2 P0.2 R/W 1 0 P0.1 P0.0 R/W R/W Reset value: 1111 1111b Description Port 0 Port 0 is an maximum 8-bit general purpose I/O port. P1 – Port 1 (Bit-addressable) 7 6 0 0 R R Address: 90H Bit 4 P0.4 R/W 5 0 R 4 0 R 3 0 R 2 P1.2 R 1 0 P1.1 P1.0 R/W R/W Reset value: 1111 1111b Description Reserved The bits are always read as 0. 7:3 0 2 P1.2 Port 1 bit 2 P1.2 is an input-only pin when RPD (CONFIG0.2) is programmed as 0. When leaving RPD un-programmed, P1.2 is always read as 0. 1 P1.1 Port 1 bit 1 P1.1 is available when the internal oscillator or the external clock input is used as the system clock. At this moment, P1.1 functions as a general purpose I/O. If the system clock is selected as the external crystal, P1.1 pin functions as XOUT. A write to P1.1 is invalid and P1.1 is always read as 0. 0 P1.0 Port 1 bit 0 P1.0 is available only when the internal oscillator is used as the system clock. At this moment, P1.0 functions as a general purpose I/O. If the system clock is not selected as the internal oscillator, P1.0 pin functions as XIN. A write to P1.1 is invalid and P1.1 is always read as 0. P2 – Port 2 (Bit-addressable) 7 6 5 0 P2.6 P2.5 R R/W R/W Address: A0H Bit Name 7 Jan. 27, 2018 0 4 P2.4 R/W 3 P2.3 R/W 2 P2.2 R/W 1 0 P2.1 P2.0 R/W R/W Reset value: 1111 1111b Description Reserved The bits are always read as 0. Page 33 of 205 Rev. 1.02 N76E885 Datasheet Bit 6:0 Name P2[7:0] Description Port 2 Port 2 is an maximum 7-bit general purpose I/O port. P3 – Port 3 (Bit-addressable) 7 6 5 P3.7 P3.6 P3.5 R/W R/W R/W Address: B0H Bit 7:0 Name P3[7:0] 4 P3.4 R/W 3 P3.3 R/W 2 P3.2 R/W 1 0 P3.1 P3.0 R/W R/W Reset value: 1111 1111b Description Port 3 Port 3 is an 8-bit general purpose I/O port only available on 28-pin package. 8.6.2 Output Mode Control These registers control output mode which is configurable among four modes: input-only, quasibidirectional, push-pull, or open-drain. Each pin can be configured individually. There is also a pull-up control for P1.2 in P1M2.2. P0M1 – Port 0 Mode Select 1[1] 7 6 5 P0M1.7 P0M1.6 P0M1.5 R/W R/W R/W Address: B1H, Page: 0 Bit 7:0 Name Description P0M1[7:0] Port 0 mode select 1 P0M2 – Port 0 Mode Select 2[1] 7 6 5 P0M2.7 P0M2.6 P0M2.5 R/W R/W R/W Address: B2H, Page: 0 Bit 4 P0M1.4 R/W Name 4 P0M2.4 R/W 3 P0M1.3 R/W 2 P0M1.2 R/W 1 0 P0M1.1 P0M1.0 R/W R/W Reset value: 1111 1111b 3 P0M2.3 R/W 2 P0M2.2 R/W 1 0 P0M2.1 P0M2.0 R/W R/W Reset value: 0000 0000b Description 7:0 P0M2[7:0] Port 0 mode select 2 [1] P0M1 and P0M2 are used in combination to determine the I/O mode of each pin of P0. See Table 8–1. Configuration for Different I/O Modes. Jan. 27, 2018 Page 34 of 205 Rev. 1.02 N76E885 Datasheet P1M1 – Port 1 Mode Select 1 7 6 Address: B3H, Page: 0 Bit 1:0 Description P0M1[1:0] Port 1 mode select 1 Name 2 4 - Name P1M2 – Port 1 Mode Select 2 7 6 Address: B4H, Page: 0 Bit 5 - P12UP 5 - 4 - 3 T1OE R/W 2 T0OE R/W 1 0 P1M1.1[2] P1M1.0[2] R/W R/W Reset value: 0000 0011b 3 CLOEN R/W 2 P12UP R/W 1 0 P1M2.1[2] P1M2.0[2] R/W R/W Reset value: 0000 0000b Description P1.2 pull-up enable 0 = P1.2 pull-up Disabled. 1 = P1.2 pull-up Enabled. This bit is valid only when RPD (CONFIG0.2) is programmed as 0. When selecting as a ̅̅̅̅̅̅ pin, the pull-up is always enabled. 1:0 P0M2[1:0] Port 1 mode select 2. [2] P1M1 and P1M2 are used in combination to determine the I/O mode of each pin of P1. See Table 8–1. Configuration for Different I/O Modes. P2M1 – Port 2 Mode Select 1[3] 7 6 5 P2M1.6 P2M1.5 R/W R/W Address: B5H, Page: 0 Bit 6:0 Name Description P2M1[6:0] Port 2 mode select 1 P2M2 – Port 2 Mode Select 2[3] 7 6 5 P2M2.6 P2M2.5 R/W R/W Address: B6H, Page: 0 Bit 4 P2M1.4 R/W Name 4 P2M2.4 R/W 3 P2M1.3 R/W 2 P2M1.2 R/W 1 0 P2M1.1 P2M1.0 R/W R/W Reset value: 0111 1111b 3 P2M2.3 R/W 2 P2M2.2 R/W 1 0 P2M2.1 P2M2.0 R/W R/W Reset value: 0000 0000b Description 6:0 P2M2[6:0] Port 2 mode select 2 [3] P2M1 and P2M2 are used in combination to determine the I/O mode of each pin of P2. See Table 8–1. Configuration for Different I/O Modes. Jan. 27, 2018 Page 35 of 205 Rev. 1.02 N76E885 Datasheet P3M1 – Port 3 Mode Select 1[4] 7 6 5 P3M1.7 P3M1.6 P3M1.5 R/W R/W R/W Address: ACH, Page: 0 Bit 7:0 Name Description P3M1[7:0] Port 3 mode select 1 P3M2 – Port 3 Mode Select 2[4] 7 6 5 P3M2.7 P3M2.6 P3M2.5 R/W R/W R/W Address: ADH, Page: 0 Bit 4 P3M1.4 R/W Name 4 P3M2.4 R/W 3 P3M1.3 R/W 2 P3M1.2 R/W 1 0 P3M1.1 P3M1.0 R/W R/W Reset value: 1111 1111b 3 P3M2.3 R/W 2 P3M2.2 R/W 1 0 P3M2.1 P3M2.0 R/W R/W Reset value: 0000 0000b Description 7:0 P3M2[7:0] Port 3 mode select 2 [4] P3M1 and P3M2 are used in combination to determine the I/O mode of each pin of P3. See Table 8–1. Configuration for Different I/O Modes. 8.6.3 Input Type and Sink Current Control Each I/O pin can be configured individually as TTL input or Schmitt triggered input. P1S[7:3] bits are for sink current control of P0.1, P0.2, P0.3, P2.0, and P2.1. These five pins support extra-large sink current capability. Note that all of PxS registers are accessible by switching SFR page to page 1. P0S – Port 0 Schmitt Triggered Input 7 6 5 P0S.7 P0S.6 P0S.5 R/W R/W R/W Address: B1H, Page: 1 Bit Name n Jan. 27, 2018 P0S.n 4 P0S.4 R/W 3 P0S.3 R/W 2 P0S.2 R/W 1 0 P0S.1 P0S.0 R/W R/W Reset value: 0000 0000b Description P0.n Schmitt triggered input 0 = TTL level input of P0.n. 1 = Schmitt triggered input of P0.n. Page 36 of 205 Rev. 1.02 N76E885 Datasheet P1S – Port 1 Schmitt Triggered Input 7 6 5 P21SNK P20SNK P03SNK R/W R/W R/W Address: B3H, Page: 1 Bit Name 4 P02SNK R/W 3 P01SNK R/W P21SNK P2.1 sink strength selection 0 = P2.1 output has normal sink current strength. 1 = P2.1 output has large sink current strength. 6 P20SNK P2.0 sink strength selection 0 = P2.0 output has normal sink current strength. 1 = P2.0 output has large sink current strength. 5 P03SNK P0.3 sink strength selection 0 = P0.3 output has normal sink current strength. 1 = P0.3 output has large sink current strength. 4 P02SNK P0.2 sink strength selection 0 = P0.2 output has normal sink current strength. 1 = P0.2 output has large sink current strength. 3 P01SNK P0.1 sink strength selection 0 = P0.1 output has normal sink current strength. 1 = P0.1 output has large sink current strength. 2 P1S.2 P1.2 Schmitt triggered input 0 = TTL level input of P1.2. 1 = Schmitt triggered input of P1.2. 1 P1S.1 P1.1 Schmitt triggered input 0 = TTL level input of P1.1. 1 = Schmitt triggered input of P1.1. 0 P1S.0 P1.0 Schmitt triggered input 0 = TTL level input of P1.0. 1 = Schmitt triggered input of P1.0. P2S – Port 2 Schmitt Triggered Input 7 6 5 P2S.6 P2S.5 R/W R/W Address: B5H, Page: 1 Name n Jan. 27, 2018 P2S.n 1 0 P1S.1 P1S.0 R/W R/W Reset value: 0000 0000b 2 P2S.2 R/W 1 0 P2S.1 P2S.0 R/W R/W Reset value: 0000 0000b Description 7 Bit 2 P1S.2 R/W 4 P2S.4 R/W 3 P2S.3 R/W Description P2.n Schmitt triggered input 0 = TTL level input of P2.n. 1 = Schmitt triggered input of P2.n. Page 37 of 205 Rev. 1.02 N76E885 Datasheet P3S – Port 3 Schmitt Triggered Input 7 6 5 P3S.7 P3S.6 P3S.5 R/W R/W R/W Address: ACH, Page: 1 Bit Name n P3S.n 4 P3S.4 R/W 3 P3S.3 R/W 2 P3S.2 R/W 1 0 P3S.1 P3S.0 R/W R/W Reset value: 0000 0000b Description P3.n Schmitt triggered input 0 = TTL level input of P3.n. 1 = Schmitt triggered input of P3.n. 8.6.4 Output Slew Rate Control Slew rate for each I/O pin is configurable individually. By default, each pin is in normal slew rate mode. User can set each control register bit to enable high-speed slew rate for the corresponding I/O pin. Note that all PxSR registers are accessible by switching SFR page to page 1. P0SR – Port 0 Slew Rate 7 6 P0SR.7 P0SR.6 R/W R/W Address: B2H, Page: 1 Bit Name n P0SR.n P1SR – Port 1 Slew Rate 7 6 Address: B4H, Page: 1 Bit Name n Jan. 27, 2018 P1SR.n 5 P0SR.5 R/W 4 P0SR.4 R/W 3 P0SR.3 R/W 2 P0SR.2 R/W 1 0 P0SR.1 P0SR.0 R/W R/W Reset value: 0000 0000b 2 - 1 0 P1SR.1 P1SR.0 R/W R/W Reset value: 0000 0000b Description P0.n slew rate 0 = P0.n normal output slew rate. 1 = P0.n high-speed output slew rate. 5 - 4 - 3 - Description P1.n slew rate 0 = P1.n normal output slew rate. 1 = P1.n high-speed output slew rate. Page 38 of 205 Rev. 1.02 N76E885 Datasheet P2SR – Port 2 Slew Rate 7 6 P2SR.6 R/W Address: B6H, Page: 1 Bit Name n P2SR.n P3SR – Port 3 Slew Rate 7 6 P3SR.7 P3SR.6 R/W R/W Address: ADH, Page: 1 Bit Name n Jan. 27, 2018 P3SR.n 5 P2SR.5 R/W 4 P2SR.4 R/W 3 P2SR.3 R/W 2 P2SR.2 R/W 1 0 P2SR.1 P2SR.0 R/W R/W Reset value: 0000 0000b 2 P3SR.2 R/W 1 0 P3SR.1 P3SR.0 R/W R/W Reset value: 0000 0000b Description P2.n slew rate 0 = P2.n normal output slew rate. 1 = P2.n high-speed output slew rate. 5 P3SR.5 R/W 4 P3SR.4 R/W 3 P3SR.3 R/W Description P3.n slew rate 0 = P3.n normal output slew rate. 1 = P3.n high-speed output slew rate. Page 39 of 205 Rev. 1.02 N76E885 Datasheet 9. TIMER/COUNTER 0 AND 1 Timer/Counter 0 and 1 on N76E885 are two 16-bit Timers/Counters. Each of them has two 8-bit registers those form the 16-bit counting register. For Timer/Counter 0 they are TH0, the upper 8-bit register, and TL0, the lower 8-bit register. Similarly Timer/Counter 1 has two 8-bit registers, TH1 and TL1. TCON and TMOD can configure modes of Timer/Counter 0 and 1. The Timer or Counter function is selected by the ̅ bit in TMOD. Each Timer/Counter has its own selection bit. TMOD.2 selects the function for Timer/Counter 0 and TMOD.6 selects the function for Timer/Counter 1 When configured as a "Timer", the timer counts the system clock cycles. The timer clock is 1/12 of the system clock (FSYS) for standard 8051 capability or direct the system clock for enhancement, which is selected by T0M (CKCON.3) bit for Timer 0 and T1M (CKCON.4) bit for Timer 1. In the "Counter" mode, the countering register increases on the falling edge of the external input pin T0. If the sampled value is high in one clock cycle and low in the next, a valid 1-to-0 transition is recognized on T0 or T1 pin. The N76E885 supports the low-speed external 32.768 kHz crystal/resonator input mode when T0LXTM (T1LXTM) is set. It provides a constant overflow rate no matter how the system clock switches. In addition, each Timer/Counter can be set to operate in any one of four possible modes. Bits M0 and M1 in TMOD do the mode selection. The Timers 0 and 1 can be configured to automatically toggle a port output whenever a timer overflow occurs. The same device pins that are used for the T0 and T1 count inputs are also used for the timer toggle outputs. This function is enabled by control bits T0OE and T1OE in the P1M1 register, and apply to Timer 0 and Timer 1 respectively. The port outputs will be logic 1 prior to the first timer overflow when this mode is turned on. In order for this mode to function, the ̅ bit should be cleared selecting the system clock as the clock source for the timer. Note that the TH0 (TH1) and TL0 (TL1) are accessed separately. It is strongly recommended that in mode 0 or 1, user should stop Timer temporally by clearing TR0 (TR1) bit before reading from or writing to TH0 (TH1) and TL0 (TL1). The free-running reading or writing may cause unpredictable result. Jan. 27, 2018 Page 40 of 205 Rev. 1.02 N76E885 Datasheet TMOD – Timer 0 and 1 Mode 7 6 ̅ GATE R/W Address: 89H Bit R/W Name 7 GATE 6 ̅ 5 M1 4 M0 3 GATE 2 ̅ 1 M1 0 M0 5 M1 4 M0 3 GATE 2 ̅ R/W R/W R/W R/W R/W R/W Reset value: 0000 0000b Timer 1 gate control 0 = Timer 1 will clock when TR1 is 1 regardless of ̅̅̅̅̅̅̅ logic level. 1 = Timer 1 will clock only when TR1 is 1 and ̅̅̅̅̅̅̅ is logic 1. Timer 1 Counter/Timer select 0 = Timer 1 is incremented by internal system clock. 1 = Timer 1 is incremented by the falling edge of the external pin T1. Timer 1 mode select M1 M0 Timer 1 Mode 0 0 Mode 0: 13-bit Timer/Counter 0 1 Mode 1: 16-bit Timer/Counter 1 0 Mode 2: 8-bit Timer/Counter with auto-reload from TH1 1 1 Mode 3: Timer 1 halted Timer 0 gate control 0 = Timer 0 will clock when TR0 is 1 regardless of ̅̅̅̅̅̅̅ logic level. 1 = Timer 0 will clock only when TR0 is 1 and ̅̅̅̅̅̅̅ is logic 1. Timer 0 Counter/Timer select 0 = Timer 0 is incremented by internal system clock. 1 = Timer 0 is incremented by the falling edge of the external pin T0. Timer 0 mode select M1 M0 Timer 0 Mode 0 0 Mode 0: 13-bit Timer/Counter 0 1 Mode 1: 16-bit Timer/Counter 1 0 Mode 2: 8-bit Timer/Counter with auto-reload from TH0 1 1 Mode 3: TL0 as a 8-bit Timer/Counter and TH0 as a 8-bit Timer R/W R/W Name Description R/W 3 IE1 R (level) R/W (edge) Address: 88H Bit 0 M0 Description TCON – Timer 0 and 1 Control (Bit-addressable) 7 6 5 4 TF1 TR1 TF0 TR0 R/W 1 M1 2 IT1 R/W 1 0 IE0 IT0 R (level) R/W R/W (edge) Reset value: 0000 0000b 7 TF1 Timer 1 overflow flag This bit is set when Timer 1 overflows. It is automatically cleared by hardware when the program executes the Timer 1 interrupt service routine. This bit can be set or cleared by software. 6 TR1 Timer 1 run control 0 = Timer 1 Disabled. Clearing this bit will halt Timer 1 and the current count will be preserved in TH1 and TL1. 1 = Timer 1 Enabled. Jan. 27, 2018 Page 41 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 5 TF0 Timer 0 overflow flag This bit is set when Timer 0 overflows. It is automatically cleared via hardware when the program executes the Timer 0 interrupt service routine. This bit can be set or cleared by software. 4 TR0 Timer 0 run control 0 = Timer 0 Disabled. Clearing this bit will halt Timer 0 and the current count will be preserved in TH0 and TL0. 1 = Timer 0 Enabled. TL0 – Timer 0 Low Byte 7 6 5 4 3 2 1 0 TL0[7:0] R/W Address: 8AH Bit 7:0 Reset value: 0000 0000b Name TL0[7:0] TH0 – Timer 0 High Byte 7 6 Description Timer 0 low byte The TL0 register is the low byte of the 16-bit counting register of Timer 0. 5 4 3 2 1 0 TH0[7:0] R/W Address: 8CH Bit 7:0 Reset value: 0000 0000b Name Description TH0[7:0] Timer 0 high byte The TH0 register is the high byte of the 16-bit counting register of Timer 0. TL1 – Timer 1 Low Byte 7 6 5 4 3 2 1 0 TL1[7:0] R/W Address: 8BH Bit 7:0 Jan. 27, 2018 Reset value: 0000 0000b Name TL1[7:0] Description Timer 1 low byte The TL1 register is the low byte of the 16-bit counting register of Timer 1. Page 42 of 205 Rev. 1.02 N76E885 Datasheet TH1 – Timer 1 High Byte 7 6 5 4 3 2 1 0 TH1[7:0] R/W Address: 8DH Bit 7:0 Reset value: 0000 0000b Name Description TH1[7:0] Timer 1 high byte The TH1 register is the high byte of the 16-bit counting register of Timer 1. CKCON – Clock Control 7 6 PWMCKS R/W Address: 8EH Bit Name 5 - 4 T1M R/W 3 T0M R/W 2 - 1 0 Reset value: 0000 0000b Description 4 T1M Timer 1 clock mode select 0 = The clock source of Timer 1 is the system clock divided by 12. It maintains standard 8051 compatibility. 1 = The clock source of Timer 1 is direct the system clock. 3 T0M Timer 0 clock mode select 0 = The clock source of Timer 0 is the system clock divided by 12. It maintains standard 8051 compatibility. 1 = The clock source of Timer 0 is direct the system clock. AUXR1 – Auxiliary Register 1 7 6 5 SWRF RSTPINF T1LXTM R/W R/W R/W Address: A2H Bit 4 3 2 1 0 T0LXTM GF2 UART0PX 0 DPS R/W R/W R/W R R/W reset value: see Table 6–2. SFR Definitions and Reset Values Name Description 5 T1LXTM Timer 1 LXT input mode 0 = Timer 1 counts the clock selected by 1 = Timer 1 counts the LXT clock. ̅ (TMOD.6) and T1M (CKCON.4). 4 T0LXTM Timer 0 LXT input mode 0 = Timer 0 counts the clock selected by 1 = Timer 0 counts the LXT clock. ̅ (TMOD.2) and T0M (CKCON.3). Jan. 27, 2018 Page 43 of 205 Rev. 1.02 N76E885 Datasheet P1M1 – Port 1 Mode Select 1 7 6 Address: B3H Bit Name 5 - 4 - 3 T1OE R/W 2 T0OE R/W 1 0 P1M1.1 P1M1.0 R/W R/W Reset value: 0000 0011b Description 3 T1OE Timer 1 output enable 0 = Timer 1 output Disabled. 1 = Timer 1 output Enabled from T1 pin. Note that Timer 1 output should be enabled only when operating in its “Timer” mode. 2 T0OE Timer 0 output enable 0 = Timer 0 output Disabled. 1 = Timer 0 output Enabled from T0 pin. Note that Timer 0 output should be enabled only when operating in its “Timer” mode. 9.1 Mode 0 (13-Bit Timer) In Mode 0, the Timer/Counter is a 13-bit counter. The 13-bit counter consists of TH0 (TH1) and the five lower bits of TL0 (TL1). The upper three bits of TL0 (TL1) are ignored. The Timer/Counter is enabled when TR0 (TR1) is set and either GATE is 0 or ̅̅̅̅̅̅̅ (̅̅̅̅̅̅̅) is 1. Gate setting as 1 allows the Timer to calculate the pulse width on external input pin ̅̅̅̅̅̅̅ (̅̅̅̅̅̅̅). When the 13-bit value moves from 1FFFH to 0000H, the Timer overflow flag TF0 (TF1) is set and an interrupt occurs if enabled. 1/12 FSYS T0M (CKCON.3) (T1M (CKCON.4)) 0 1 C/T 0 1 T0 (T1) pin 32.768 kHz XTAL TR0 (TR1) 0 1 0 TL0 (TL1) 4 7 T0LXTM (AUXR1.4) (T1LXTM (AUXR1.5)) 0 TF0 (TF1) 7 TH0 (TH1) GATE Timer Interrupt T0OE (P1M1.2) (T1OE(P1M1.3)) INT0 (INT1) pin T0 (T1) pin Figure 9.1. Timer/Counters 0 and 1 in Mode 0 Jan. 27, 2018 Page 44 of 205 Rev. 1.02 N76E885 Datasheet 9.2 Mode 1 (16-Bit Timer) Mode 1 is similar to Mode 0 except that the counting registers are fully used as a 16-bit counter. Rollover occurs when a count moves FFFFH to 0000H. The Timer overflow flag TF0 (TF1) of the relevant Timer/Counter is set and an interrupt will occurs if enabled. 1/12 FSYS T0M (CKCON.3) (T1M (CKCON.4)) 0 1 C/T 0 1 T0 (T1) pin 32.768 kHz XTAL TL0 (TL1) 0 1 0 7 0 7 T0LXTM (AUXR1.4) (T1LXTM (AUXR1.5)) TR0 (TR1) TF0 (TF1) TH0 (TH1) GATE Timer Interrupt T0OE (P1M1.2) (T1OE(P1M1.3)) INT0 (INT1) pin T0 (T1) pin Figure 9.2. Timer/Counters 0 and 1 in Mode 1 9.3 Mode 2 (8-Bit Auto-Reload Timer) In Mode 2, the Timer/Counter is in auto-reload mode. In this mode, TL0 (TL1) acts as an 8-bit count register whereas TH0 (TH1) holds the reload value. When the TL0 (TL1) register overflow, the TF0 (TF1) bit in TCON is set and TL0 (TL1) is reloaded with the contents of TH0 (TH1) and the counting process continues from here. The reload operation leaves the contents of the TH0 (TH1) register unchanged. This feature is best suitable for UART baud rate generator for it runs without continuous software intervention. Note that only Timer1 can be the baud rate source for UART. Counting is enabled by setting the TR0 (TR1) bit as 1 and proper setting of GATE and ̅̅̅̅̅̅̅ (̅̅̅̅̅̅̅) pins. The functions of GATE and ̅̅̅̅̅̅̅ (̅̅̅̅̅̅̅) pins are just the same as Mode 0 and 1. Jan. 27, 2018 Page 45 of 205 Rev. 1.02 N76E885 Datasheet 1/12 FSYS T0M (CKCON.3) (T1M (CKCON.4)) 0 1 C/T 0 1 32.786 kHz XTAL TL0 (TL1) 0 T0 (T1) pin 0 1 T0LXTM (AUXR1.4) (T1LXTM (AUXR1.5)) TR0 (TR1) 0 GATE TF0 (TF1) 7 7 Timer Interrupt T0OE (P1M1.2) (T1OE(P1M1.3)) T0 (T1) pin TH0 (TH1) INT0 (INT1) pin Figure 9.3. Timer/Counters 0 and 1 in Mode 2 9.4 Mode 3 (Two Separate 8-Bit Timers) Mode 3 has different operating methods for Timer 0 and Timer 1. For Timer/Counter 1, Mode 3 simply freezes the counter. Timer/Counter 0, however, configures TL0 and TH0 as two separate 8 bit count registers in this mode. TL0 uses the Timer/Counter 0 control bits ̅, GATE, TR0, ̅̅̅̅̅̅̅, and TF0. The TL0 also can be used as a 1-to-0 transition counter on pin T0 as determined by ̅ (TMOD.2). TH0 is forced as a clock cycle counter and takes over the usage of TR1 and TF1 from Timer/Counter 1. Mode 3 is used in case that an extra 8 bit timer is needed. If Timer/Counter 0 is configured in Mode 3, Timer/Counter 1 can be turned on or off by switching it out of or into its own Mode 3. It can still be used in Modes 0, 1 and 2 although its flexibility is restricted. It no longer has control over its overflow flag TF1 and the enable bit TR1. However Timer 1 can still be used as a Timer/Counter and retains the use of GATE, ̅̅̅̅̅̅̅ pin, T1M, and T1LXTM. It can be used as a baud rate generator for the serial port or other application not requiring an interrupt. 1/12 FSYS T0M (CKCON.3) 0 1 C/T 0 1 T0 pin 32.768 kHz XTAL TL0 0 1 0 7 T0LXTM (AUXR1.4) TF0 T0OE (P1M1.2) TR0 Timer 0 Interrupt T0 pin GATE TH0 INT0 pin TR1 0 7 TF1 T1OE(P1M1.3) Jan. 27, 2018 Page 46 of 205 Timer 1 Interrupt T1 pin Rev. 1.02 N76E885 Datasheet Figure 9.4. Timer/Counter 0 in Mode 3 Jan. 27, 2018 Page 47 of 205 Rev. 1.02 N76E885 Datasheet 10. TIMER 2 AND INPUT CAPTURE Timer 2 is a 16-bit up counter cascaded with TH2, the upper 8 bits register, and TL2, the lower 8 bit register. Equipped with RCMP2H and RCMP2L, Timer 2 can operate under compare mode and autoreload mode selected by ̅̅̅̅̅̅ (T2CON.0). An 3-channel input capture module makes Timer 2 detect and measure the width or period of input pulses. The results of 3 input captures are stores in C0H and C0L, C1H and C1L, C2H and C2L individually. The clock source of Timer 2 is from the system clock pre-scaled by a clock divider with 8 different scales for wide field application. The clock is enabled when TR2 (T2CON.2) is 1, and disabled when TR2 is 0. The following registers are related to Timer 2 function. T2CON – Timer 2 Control 7 6 TF2 R/W Address: C8H Bit Name 5 - 4 - 3 - 2 TR2 R/W 1 0 ̅̅̅̅̅̅ R/W Reset value: 0000 0000b Description 7 TF2 Timer 2 overflow flag This bit is set when Timer 2 overflows or a compare match occurs. If the Timer 2 interrupt and the global interrupt are enable, setting this bit will make CPU execute Timer 2 interrupt service routine. This bit is not automatically cleared via hardware and should be cleared via software. 2 TR2 Timer 2 run control 0 = Timer 2 Disabled. Clearing this bit will halt Timer 2 and the current count will be preserved in TH2 and TL2. 1 = Timer 2 Enabled. 0 ̅̅̅̅̅̅ T2MOD – Timer 2 Mode 7 6 LDEN R/W Address: C9H Bit Name 7 Jan. 27, 2018 LDEN Timer 2 compare or auto-reload mode select This bit selects Timer 2 functioning mode. 0 = Auto-reload mode. 1 = Compare mode. 5 T2DIV[2:0] R/W 4 3 CAPCR R/W 2 CMPCR R/W 1 0 LDTS[1:0] R/W Reset value: 0000 0000b Description Enable auto-reload 0 = Reloading RCMP2H and RCMP2L to TH2 and TL2 Disabled. 1 = Reloading RCMP2H and RCMP2L to TH2 and TL2 Enabled. Page 48 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 6:4 T2DIV[2:0] Timer 2 clock divider 000 = Timer 2 clock divider is 1/1. 001 = Timer 2 clock divider is 1/4. 010 = Timer 2 clock divider is 1/16. 011 = Timer 2 clock divider is 1/32. 100 = Timer 2 clock divider is 1/64. 101 = Timer 2 clock divider is 1/128. 110 = Timer 2 clock divider is 1/256. 111 = Timer 2 clock divider is 1/512. 3 CAPCR Capture auto-clear This bit is valid only under Timer 2 auto-reload mode. It enables hardware autoclearing TH2 and TL2 counter registers after they have been transferred in to RCMP2H and RCMP2L while a capture event occurs. 0 = Timer 2 continues counting when a capture event occurs. 1 = Timer 2 value is auto-cleared as 0000H when a capture event occurs. 2 CMPCR Compare match auto-clear This bit is valid only under Timer 2 compare mode. It enables hardware autoclearing TH2 and TL2 counter registers after a compare match occurs. 0 = Timer 2 continues counting when a compare match occurs. 1 = Timer 2 value is auto-cleared as 0000H when a compare match occurs. 1:0 LDTS[1:0] Auto-reload trigger select These bits select the reload trigger event. 00 = Reload when Timer 2 overflows. 01 = Reload when input capture 0 event occurs. 10 = Reload when input capture 1 event occurs. 11 = Reload when input capture 2 event occurs. RCMP2L – Timer 2 Reload/Compare Low Byte 7 6 5 4 3 RCMP2L[7:0] R/W Address: CAH Bit 7:0 Name RCMP2L[7:0] 7:0 Jan. 27, 2018 Name RCMP2H[7:0] 1 0 Reset value: 0000 0000b Description Timer 2 reload/compare low byte This register stores the low byte of compare value when Timer 2 is configured in compare mode. Also it holds the low byte of the reload value in auto-reload mode. RCMP2H – Timer 2 Reload/Compare High Byte 7 6 5 4 3 RCMP2H[7:0] R/W Address: CBH Bit 2 2 1 0 Reset value: 0000 0000b Description Timer 2 reload/compare high byte This register stores the high byte of compare value when Timer 2 is configured in compare mode. Also it holds the high byte of the reload value in auto-reload mode. Page 49 of 205 Rev. 1.02 N76E885 Datasheet TL2 – Timer 2 Low Byte 7 6 5 4 3 2 1 0 TL2[7:0] R/W Address: CCH Bit 7:0 Reset value: 0000 0000b Name TL2[7:0] Description Timer 2 low byte The TL2 register is the low byte of the 16-bit counting register of Timer 2. TH2 – Timer 2 High Byte 7 6 5 4 3 2 1 0 TH2[7:0] R/W Address: CDH Bit 7:0 Reset value: 0000 0000b Name Description TH2[7:0] Timer 2 high byte The TH2 register is the high byte of the 16-bit counting register of Timer 2. Note that the TH2 and TL2 are accessed separately. It is strongly recommended that user stops Timer 2 temporally by clearing TR2 bit before reading from or writing to TH2 and TL2. The free-running reading or writing may cause unpredictable result. 10.1 Auto-Reload Mode The Timer 2 is configured as auto-reload mode by clearing ̅̅̅̅̅̅ . In this mode RCMP2H and RCMP2L registers store the reload value. The contents in RCMP2H and RCMP2L transfer into TH2 and TL2 once the auto-reload event occurs if setting LDEN bit. The event can be the Timer 2 overflow or one of the triggering event on any of enabled input capture channel depending on the LDTS[1:0] (T2MOD[1:0]) selection. Note that once CAPCR (T2MOD.3) is set, an input capture event only clears TH2 and TL2 without reloading RCMP2H and RCMP2L contents. Jan. 27, 2018 Page 50 of 205 Rev. 1.02 N76E885 Datasheet C0L Noise Filter CAPF0 CAPF0 [00] IC0 (P2.0) IC1 (P2.1) IC2 (P2.2) C0H CAPF1 ENF0 (CAPCON2.4) [10] Input Capture Interrupt CAPF2 [01] or CAPEN0 (CAPCON0.4) CAP0LS[1:0] (CAPCON1[1:0]) Input Capture 0 Module Input Capture 1 Module Input Capture Flags CAPF[2:0] Input Capture 2 Module CAPF0 CAPF1 CAPF2 FSYS Clear Timer 2 Pre-scalar T2DIV[2:0] (T2MOD[6:4]) TL2 TH2 RCMP2L RCMP2H CAPCR[1] (T2MOD.3) TF2 Timer 2 Interrupt TR2 (T2CON.2) CAPF0 CAPF1 CAPF2 00 01 10 11 LDTS[1:0] (T2MOD[1:0]) LDEN[1] (T2MOD.7) Timer 2 Module [1] Once CAPCR and LDEN are both set, an input capture event only clears TH2 and TL2 without reloading RCMP2H and RCMP2L contents. Figure 10.1. Timer 2 Auto-Reload Mode and Input Capture Module Functional Block Diagram 10.2 Compare Mode Timer 2 can also be configured as the compare mode by setting ̅̅̅̅̅̅. In this mode RCMP2H and RCMP2L registers serve as the compare value registers. As Timer 2 up counting, TH2 and TL2 match RCMP2H and RCMP2L, TF2 (T2CON.7) will be set by hardware to indicate a compare match event. Setting CMPCR (T2MOD.2) makes the hardware to clear Timer 2 counter as 0000H automatically after a compare match has occurred. Jan. 27, 2018 Page 51 of 205 Rev. 1.02 N76E885 Datasheet C0L Noise Filter CAPF0 CAPF0 [00] IC0 (P2.0) IC1 (P2.1) IC2 (P2.2) C0H CAPF1 ENF0 (CAPCON2.4) [10] Input Capture Interrupt CAPF2 [01] or CAP0LS[1:0] (CAPCON1[1:0]) CAPEN0 (CAPCON0.4) Input Capture 0 Module Input Capture 1 Module Input Capture 2 Module CMPCR (T2MOD.2) FSYS Pre-scalar T2DIV[2:0] (T2MOD[6:4]) Clear Timer 2 TL2 TR2 (T2CON.2) TH2 = RCMP2L TF2 Timer 2 Interrupt RCMP2H Timer 2 Module Figure 10.2. Timer 2 Compare Mode and Input Capture Module Functional Block Diagram 10.3 Input Capture Module The input capture module along with Timer 2 implements the input capture function. The input capture module is configured through CAPCON0~2 registers. The input capture module supports 3-channel inputs (IC0, IC1, and IC2 pins) that share I/O pin P2.0 to P2.2. Each input channel consists its own noise filter, which is enabled via setting ENF0~2 (CAPCON2[6:4]). It filters input glitches smaller than four system clock cycles. Input capture channels has their own independent edge detector but share the unique Timer 2. Each trigger edge detector is selected individually by setting corresponding bits in CAPCON1. It supports positive edge capture, negative edge capture, or any edge capture. Each input capture channel has to set its own enabling bit CAPEN0~2 (CAPCON0[6:4]) before use. While input capture channel is enabled and the selected edge trigger occurs, the content of the free running Timer 2 counter, TH2 and TL2, will be captured, transferred, and stored into the capture registers CnH and CnL. The edge triggering also causes CAPFn (CAPCON0.n) set by hardware. The interrupt will also generate if the ECAP (EIE.2) and EA bit are both set. For three input capture flags share the same interrupt vector, user should check CAPFn to confirm which channel comes the input capture edge. These flags should be cleared by software. Jan. 27, 2018 Page 52 of 205 Rev. 1.02 N76E885 Datasheet The bit CAPCR (CAPCON2.3) benefits the implement of period calculation. Setting CAPCR makes the hardware clear Timer 2 as 0000H automatically after the value of TH2 and TL2 have been captured after an input capture edge event occurs. It eliminates the routine software overhead of writing 16-bit counter or an arithmetic subtraction. CAPCON0 – Input Capture Control 0 7 6 5 CAPEN2 CAPEN1 R/W R/W Address: 92H Bit 4 CAPEN0 R/W 3 - 2 CAPF2 R/W 1 0 CAPF1 CAPF0 R/W R/W Reset value: 0000 0000b Name Description 6 CAPEN2 Input capture 2 enable 0 = Input capture channel 2 Disabled. 1 = Input capture channel 2 Enabled. 5 CAPEN1 Input capture 1 enable 0 = Input capture channel 1 Disabled. 1 = Input capture channel 1 Enabled. 4 CAPEN0 Input capture 0 enable 0 = Input capture channel 0 Disabled. 1 = Input capture channel 0 Enabled. 2 CAPF2 Input capture 2 flag This bit is set by hardware if the determined edge of input capture 2 occurs. This bit should cleared by software. 1 CAPF1 Input capture 1 flag This bit is set by hardware if the determined edge of input capture 1 occurs. This bit should cleared by software. 0 CAPF0 Input capture 0 flag This bit is set by hardware if the determined edge of input capture 0 occurs. This bit should cleared by software. CAPCON1 – Input Capture Control 1 7 6 5 4 CAP2LS[1:0] R/W Address: 93H Bit Name 3 2 CAP1LS[1:0] R/W Description 5:4 CAP2LS[1:0] Input capture 2 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. 3:2 CAP1LS[1:0] Input capture 1 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. Jan. 27, 2018 1 0 CAP0LS[1:0] R/W Reset value: 0000 0000b Page 53 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 1:0 Description CAP0LS[1:0] Input capture 0 level select 00 = Falling edge. 01 = Rising edge. 10 = Either Rising or falling edge. 11 = Reserved. CAPCON2 – Input Capture Control 2 7 6 5 ENF2 ENF1 R/W R/W Address: 94H Bit Name 4 ENF0 R/W 3 - 2 - 1 0 Reset value: 0000 0000b Description 6 ENF2 Enable noise filer on input capture 2 0 = Noise filter on input capture channel 2 Disabled. 1 = Noise filter on input capture channel 2 Enabled. 5 ENF1 Enable noise filer on input capture 1 0 = Noise filter on input capture channel 1 Disabled. 1 = Noise filter on input capture channel 1 Enabled. 4 ENF0 Enable noise filer on input capture 0 0 = Noise filter on input capture channel 0 Disabled. 1 = Noise filter on input capture channel 0 Enabled. C0L – Capture 0 Low Byte 7 6 5 4 3 2 1 0 C0L[7:0] R/W Address: E4H Bit 7:0 Reset value: 0000 0000b Name C0L[7:0] Description Input capture 0 result low byte The C0L register is the low byte of the 16-bit result captured by input capture 0. C0H – Capture 0 High Byte 7 6 5 4 3 2 1 0 C0H[7:0] R/W Address: E5H Bit 7:0 Jan. 27, 2018 Reset value: 0000 0000b Name Description C0H[7:0] Input capture 0 result high byte The C0H register is the high byte of the 16-bit result captured by input capture 0. Page 54 of 205 Rev. 1.02 N76E885 Datasheet C1L – Capture 1 Low Byte 7 6 5 4 3 2 1 0 C1L[7:0] R/W Address: E6H Bit 7:0 Reset value: 0000 0000b Name C1L[7:0] Description Input capture 1 result low byte The C1L register is the low byte of the 16-bit result captured by input capture 1. C1H – Capture 1 High Byte 7 6 5 4 3 2 1 0 C1H[7:0] R/W Address: E7H Bit 7:0 Reset value: 0000 0000b Name Description C1H[7:0] Input capture 1 result high byte The C1H register is the high byte of the 16-bit result captured by input capture 1. C2L – Capture 2 Low Byte 7 6 5 4 3 2 1 0 C2L[7:0] R/W Address: EDH Bit 7:0 Reset value: 0000 0000b Name C2L[7:0] Description Input capture 2 result low byte The C2L register is the low byte of the 16-bit result captured by input capture 2. C2H – Capture 2 High Byte 7 6 5 4 3 2 1 0 C2H[7:0] R/W Address: EEH Bit 7:0 Jan. 27, 2018 Reset value: 0000 0000b Name Description C2H[7:0] Input capture 2 result high byte The C2H register is the high byte of the 16-bit result captured by input capture 2. Page 55 of 205 Rev. 1.02 N76E885 Datasheet 11. TIMER 3 Timer 3 is implemented simply as a 16-bit auto-reload, up-counting timer. The user can select the prescale with T3PS[2:0] (T3CON[2:0]) and fill the reload value into RH3 and RL3 registers to determine its overflow rate. User then can set TR3 (T3CON.3) to start counting. When the counter rolls over FFFFH, TF3 (T3CON.4) is set as 1 and a reload is generated and causes the contents of the RH3 and RL3 registers to be reloaded into the internal 16-bit counter. If ET3 (EIE1.1) is set as 1, Timer 3 interrupt service routine will be served. TF3 is auto-cleared by hardware after entering its interrupt service routine. Timer 3 can also be the baud rate clock source of both UARTs. For details, please see Section 14.5 “Baud Rate” on page 74. FSYS Pre-scalar (1/1~1/128) TR3 (T3CON.3) T3PS[2:0] (T3CON[2:0]) Timer 3 Overflow Internal 16-bit Counter 0 7 0 RL3 TF3 (T3CON.4) Timer 3 Interrupt 7 RH3 Figure 11.1. Timer 3 Block Diagram T3CON – Timer 3 Control 7 6 _ SMOD 1 SMOD0_1 R/W R/W Address: C4H 5 BRCK R/W 4 TF3 R/W 3 TR3 R/W 2 1 0 T3PS[2:0] R/W Reset value: 0000 0000b Bit Name 4 TF3 Timer 3 overflow flag This bit is set when Timer 3 overflows. It is automatically cleared by hardware when the program executes the Timer 3 interrupt service routine. This bit can be set or cleared by software. 3 TR3 Timer 3 run control 0 = Timer 3 is halted. 1 = Timer 3 starts running. Note that the reload registers RH3 and RL3 can only be written when Timer 3 is halted (TR3 bit is 0). If any of RH3 or RL3 is written if TR3 is 1, result is unpredictable. Jan. 27, 2018 Description Page 56 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 2:0 T3PS[2:0] Description Timer 3 pre-scalar These bits determine the scale of the clock divider for Timer 3. 000 = 1/1. 001 = 1/2. 010 = 1/4. 011 = 1/8. 100 = 1/16. 101 = 1/32. 110 = 1/64. 111 = 1/128. RL3 – Timer 3 Reload Low Byte 7 6 5 4 3 2 1 0 RL3[7:0] R/W Address: C5H Reset value: 0000 0000b Bit Name 7:0 RL3[7:0] Description Timer 3 reload low byte It holds the low byte of the reload value of Timer 3. RH3 – Timer 3 Reload High Byte 7 6 5 4 3 2 1 0 RH3[7:0] R/W Address: C6H Reset value: 0000 0000b Bit Name 7:0 RH3[7:0] Jan. 27, 2018 Description Timer 3 reload high byte It holds the high byte of the reload value of Time 3. Page 57 of 205 Rev. 1.02 N76E885 Datasheet 12. WATCHDOG TIMER (WDT) The N76E885 provides one Watchdog Timer (WDT). It can be configured as a time-out reset timer to reset whole device. Once the device runs in an abnormal status or hangs up by outward interference, a WDT reset recover the system. It provides a system monitor, which improves the reliability of the system. Therefore, WDT is especially useful for system that is susceptible to noise, power glitches, or electrostatic discharge. The WDT also can be configured as a general purpose timer, of which the periodic interrupt serves as an event timer or a durational system supervisor in a monitoring system, which is able to operate during Idle or Power-down mode. WDTEN[3:0] (CONFIG4[7:4]) initialize the WDT to operate as a time-out reset timer or a general purpose timer. CONFIG4 7 6 5 WDTEN[3:0] R/W Bit 7:4 4 3 - 2 1 0 Factory default value: 1111 1111b Name Description WDTEN[3:0] WDT enable This field configures the WDT behavior after MCU execution. 1111 = WDT is Disabled. WDT can be used as a general purpose timer via software control. 0101 = WDT is Enabled as a time-out reset timer and it stops running during Idle or Power-down mode. Others = WDT is Enabled as a time-out reset timer and it keeps running during Idle or Power-down mode. The WDT is implemented with a set of divider that divides the low-speed internal oscillator clock nominal 10 kHz. The divider output is selectable and determines the time-out interval. When the timeout interval is fulfilled, it will wake the system up from Idle or Power-down mode and an interrupt event will occur if WDT interrupt is enabled. If WDT is initialized as a time-out reset timer, a system reset will occur after a period of delay if without any software action. WDCON – Watchdog Timer Control (TA protected) 7 6 5 4 3 2 1 0 WDTR WDCLR WDTF WIDPD WDTRF[1] WDPS[2:0][2] R/W R/W R/W R/W R/W R/W Address: AAH Reset value: see Table 6–2. SFR Definitions and Reset Values Bit Name 7 Jan. 27, 2018 WDTR Description WDT run This bit is valid only when control bits in WDTEN[3:0] (CONFIG4[7:4]) are all 1. At this time, WDT works as a general purpose timer. 0 = WDT Disabled. 1 = WDT Enabled. The WDT counter starts running. Page 58 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 6 WDCLR WDT clear Setting this bit will reset the WDT count to 00H. It puts the counter in a known state and prohibit the system from unpredictable reset. The meaning of writing and reading WDCLR bit is different. Writing: 0 = No effect. 1 = Clearing WDT counter. Reading: 0 = WDT counter is completely cleared. 1 = WDT counter is not yet cleared. 5 WDTF WDT time-out flag This bit indicates an overflow of WDT counter. This flag should be cleared by software. 4 WIDPD WDT running in Idle or Power-down mode This bit is valid only when control bits in WDTEN[3:0] (CONFIG4[7:4]) are all 1. It decides whether WDT runs in Idle or Power-down mode when WDT works as a general purpose timer. 0 = WDT stops running during Idle or Power-down mode. 1 = WDT keeps running during Idle or Power-down mode. 3 WDTRF WDT reset flag When the CPU is reset by WDT time-out event, this bit will be set via hardware. This flag is recommended to be cleared via software after reset. 2:0 WDPS[2:0] WDT clock pre-scalar select These bits determine the pre-scale of WDT clock from 1/1 through 1/256. See Table 12–1. The default is the maximum pre-scale value. [1] WDTRF will be cleared after power-on reset, be set after WDT reset, and remains unchanged after any other resets. [2] WDPS[2:0] are all set after power-on reset and keep unchanged after any reset other than power-on reset. The Watchdog time-out interval is determined by the formula 1 × 64 , where FLIRC × clock dividerscalar FLIRC is the frequency of internal 10 kHz oscillator. The following table shows an example of the Watchdog time-out interval with different pre-scales. Jan. 27, 2018 Page 59 of 205 Rev. 1.02 N76E885 Datasheet Table 12–1. Watchdog Timer-out Interval Under Different Pre-scalars Clock Divider Scale Watchdog Time-out Interval (FLIRC ~= 10 kHz) WDPS.2 WDPS.1 WDPS.0 0 0 0 1/1 6.40 ms 0 0 1 1/4 25.60 ms 0 1 0 1/8 51.20 ms 0 1 1 1/16 102.40 ms 1 0 0 1/32 204.80 ms 1 0 1 1/64 409.60 ms 1 1 0 1/128 819.20 ms 1 1 1 1/256 1.638 s 12.1 Time-Out Reset Timer When the CONFIG bits WDTEN[3:0] (CONFIG4[7:4]) is not FH, the WDT is initialized as a time-out reset timer. If WDTEN[3:0] is not 5H, the WDT is allowed to continue running after the system enters Idle or Power-down mode. Note that when WDT is initialized as a time-out reset timer, WDTR and WIDPD has no function. 10 kHz Internal Oscillator FLIRC Pre-scalar (1/1~1/256) WDT counter (6-bit) clear WDPS[2:0] overflow 512-clock Delay WDTRF WDT Reset clear WDCLR WDTF WDT Interrupt Figure 12.1. WDT as A Time-Out Reset Timer After the device is powered and it starts to execute software code, the WDT starts counting simultaneously. The time-out interval is selected by the three bits WDPS[2:0] (WDCON[2:0]). When the selected time-out occurs, the WDT will set the interrupt flag WDTF (WDCON.5). If the WDT interrupt enable bit EWDT (EIE.4) and global interrupt enable EA are both set, the WDT interrupt routine will be executed. Meanwhile, an additional 512 clocks of the low-speed internal oscillator delays to expect a counter clearing by setting WDCLR to avoid the system reset by WDT if the device operates normally. If no counter reset by writing 1 to WDCLR during this 512-clock period, a WDT reset will happen. Setting WDCLR bit is used to clear the counter of the WDT. This bit is self-cleared for user monitoring it. Once a reset due to WDT occurs, the WDT reset flag WDTRF (WDCON.3) will be set. This bit keeps unchanged after any reset other than a power-on reset. User may clear WDTRF via software. Note that all bits in WDCON require timed access writing. Jan. 27, 2018 Page 60 of 205 Rev. 1.02 N76E885 Datasheet NOTICE: WDT counter has been specially taken care. The hardware automatically clears WDT counter and pre-scalar value after : (1) Entering into or being woken-up from Idle or Power Down mode (2) Any resets. It prevents unconscious system reset. The main application of the WDT with time-out reset enabling is for the system monitor. This is important in real-time control applications. In case of some power glitches or electro-magnetic interference, CPU may begin to execute erroneous codes and operate in an unpredictable state. If this is left unchecked the entire system may crash. Using the WDT during software development requires user to select proper “Feeding Dog” time by clearing the WD counter. By inserting the instruction of setting WDCLR, it allows the code to run without any WDT reset. However If any erroneous code executes by any interference, the instructions to clear the WDT counter will not be executed at the required instants. Thus the WDT reset will occur to reset the system state from an erroneously executing condition and recover the system. 12.2 General Purpose Timer There is another application of the WDT, which is used as a simple, long period timer. When the CONFIG bits WDTEN[3:0] (CONFIG4[7:4]) is FH, the WDT is initialized as a general purpose timer. In this mode, WDTR and WIDPD are fully accessed via software. 10 kHz Internal Oscillator FLIRC WDT counter (6-bit) overflow WDTF WDT Interrupt clear IDL (PCON.0) PD (PCON.1) WIDPD Pre-scalar (1/1~1/256) WDPS[2:0] WDCLR WDTR Figure 12.2. Watchdog Timer Block Diagram The WDT starts running by setting WDTR as 1 and halts by clearing WDTR as 0. The WDTF flag will be set while the WDT completes the selected time interval. The software polls the WDTF flag to detect a time-out. An interrupt will occur if the individual interrupt EWDT (EIE.4) and global interrupt enable EA is set. WDT will continue counting. User should clear WDTF and wait for the next overflow by polling WDTF flag or waiting for the interrupt occurrence. In some application of low power consumption, the CPU usually stays in Idle mode when nothing needs to be served to save power consumption. After a while the CPU will be woken up to check if anything needs to be served at an interval of programmed period implemented by Timer 0~3. However, the current consumption of dle mode still keeps at a “mA” level. current consumption to “μA” level, the Jan. 27, 2018 o further reducing the PU should stay in Power-down mode when nothing needs to Page 61 of 205 Rev. 1.02 N76E885 Datasheet be served, and has the ability of waking up at a programmable interval. The N76E885 is equipped with this useful function by WDT waking up. It provides a very low power internal oscillator 10 kHz as the clock source of the WDT. It is also able to count under Power-down mode and wake CPU up. The demo code to accomplish this feature is shown below. Jan. 27, 2018 Page 62 of 205 Rev. 1.02 N76E885 Datasheet ORG LJMP 0000H START ORG LJMP 0053H WDT_ISR ORG 0100H ;******************************************************************** ;WDT interrupt service routine ;******************************************************************** WDT_ISR: CLR EA MOV TA,#0AAH MOV TA,#55H ANL WDCON,#11011111B ;clear WDT interrupt flag SETB EA RETI ;******************************************************************** ;Start here ;******************************************************************** START: MOV TA,#0AAH MOV TA,#55H ORL WDCON,#00010111B ;choose interval length and enable during ;Power-down SETB EWDT ;enable WDT interrupt SETB EA MOV MOV ORL TA,#0AAH TA,#55H WDCON,#10000000B WDT running ; WDT run ;******************************************************************** ;Enter Power-down mode ;******************************************************************** LOOP: ORL PCON,#02H LJMP LOOP Jan. 27, 2018 Page 63 of 205 Rev. 1.02 N76E885 Datasheet 13. SELF WAKE-UP TIMER (WKT) The N76E885 has a dedicated Self Wake-up Timer (WKT), which serves for a periodic wake-up timer in low power mode or for general purpose timer. WKT remains counting in Idle or Power-down mode. When WKT is being used as a wake-up timer, a start of WKT can occur just prior to entering a power management mode. WKT has two clock sources, internal 10 kHz or external 32 kHz oscillator, determined by WKTCK (WKCON.5) bit. Note that the system clock frequency must be twice over WKT clock. If WKT starts counting, the selected clock source will remain active once the device enters Idle or Power-down mode. Note that the selected clock source of WKT will not automatically enabled along with WKT configuration. User should manually enable the selected clock source and waiting for stability to ensure a proper operation. The WKT is implemented simply as a 8-bit auto-reload, up-counting timer with pre-scale 1/1 to 1/512 selected by WKPS[2:0] (WKCON[2:0]). User fills the reload value into RWK register to determine its overflow rate. The WKTR (WKCON.3) can be set to start counting. When the counter rolls over FFH, WKTF (WKCON.4) is set as 1 and a reload is generated and causes the contents of the RWK register to be reloaded into the internal 8-bit counter. If EWKT (EIE1.2) is set as 1, WKT interrupt service routine will be served. 10 kHz Internal Oscillator FLIRC 0 32 kHz External Oscillator 1 FLXT WKTCK (WKCON.5) WKTR (WKCON.3) Pre-scalar (1/1~1/2048) Internal 8-bit Counter WKPS[2:0] (WKCON[2:0]) 0 WKT Overflow WKTF (WKCON.4) WKT Interrupt 7 RWK Figure 13.1. Self Wake-Up Timer Block Diagram WKCON – Self Wake-up Timer Control 7 6 5 WKTCK R/W Address: 8FH Bit Name 5 WKTCK Jan. 27, 2018 4 WKTF R/W 3 WKTR R/W 2 1 0 WKPS[2:0] R/W Reset value: 0000 0000b Description WKT clock source 0 = Internal 10 kHz oscillator. 1 = External 32 kHz oscillator. Note that this bit cannot be switched on-the-fly when WKT is running. It must be selected before WKTR is set as 1. Page 64 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 4 WKTF WKT overflow flag This bit is set when WKT overflows. If the WKT interrupt and the global interrupt are enabled, setting this bit will make CPU execute WKT interrupt service routine. This bit is not automatically cleared via hardware and should be cleared via software. 3 WKTR WKT run control 0 = WKT is halted. 1 = WKT starts running. Note that the reload register RWK can only be written when WKT is halted (WKTR bit is 0). If WKT is written while WKTR is 1, result is unpredictable. 2:0 WKPS[2:0] WKT pre-scalar These bits determine the pre-scale of WKT clock. 000 = 1/1. 001 = 1/4. 010 = 1/16. 011 = 1/64. 100 = 1/256. 101 = 1/512. 110 = 1/1024. 111 = 1/2048. RWK – Self Wake-up Timer Reload Byte 7 6 5 4 3 2 1 0 RWK[7:0] R/W Address: 86H Reset value: 0000 0000b Bit Name 7:0 RWK[7:0] Jan. 27, 2018 Description WKT reload byte It holds the 8-bit reload value of WKT. Note that RWK should not be FFH if the pre-scale is 1/1 for implement limitation. Page 65 of 205 Rev. 1.02 N76E885 Datasheet 14. SERIAL PORT (UART) The N76E885 includes two enhanced full duplex serial ports enhanced with automatic address recognition and framing error detection. As control bits of these two serial ports are implemented the same, the bit names (including interrupt enabling or priority setting bits) end with “ _ ” (e.g. O _1) to indicate serial port 1 control bits for making a distinction between these two serial ports. Generally speaking, in the following contents, there will not be any reference to serial port 1, but only to serial port 0. Each serial port supports one synchronous communication mode, Mode 0, and three modes of full duplex UART (Universal Asynchronous Receiver and Transmitter), Mode 1, 2, and 3. This means it can transmit and receive simultaneously. The serial port is also receiving-buffered, meaning it can commence reception of a second byte before a previously received byte has been read from the register. The receiving and transmitting registers are both accessed at SBUF. Writing to SBUF loads the transmitting register, and reading SBUF accesses a physically separate receiving register. There are four operation modes in serial port. In all four modes, transmission initiates by any instruction that uses SBUF as a destination register. Note that before serial port function works, the port latch bits of P2.0 and P0.3 (for RXD and TXD pins) or P2.4 and P2.5 (for RXD_1 and TXD_1 pins) have to be set to 1. For application flexibility, TXD and RXD pins of serial port 0 can be exchanged by UART0PX (AUXR1.2). SCON – Serial Port Control (Bit-addressable) 7 6 5 4 SM0/FE SM1 SM2 REN R/W R/W R/W R/W Address: 98H Bit Name 7 SM0/FE 6 SM1 3 TB8 R/W 2 RB8 R/W 1 0 TI RI R/W R/W Reset value: 0000 0000b Description Serial port mode select SMOD0 (PCON.6) = 0: See Table 14–1. Serial Port 0 Mode Description for details. SMOD0 (PCON.6) = 1: SM0/FE bit is used as frame error (FE) status flag. It is cleared by software. 0 = Frame error (FE) did not occur. 1 = Frame error (FE) occurred and detected. Jan. 27, 2018 Page 66 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 5 SM2 Description Multiprocessor communication mode enable The function of this bit is dependent on the serial port 0 mode. Mode 0: This bit select the baud rate between FSYS/12 and FSYS/2. 0 = The clock runs at FSYS/12 baud rate. It maintains standard 8051 compatibility. 1 = The clock runs at FSYS/2 baud rate for faster serial communication. Mode 1: This bit checks valid stop bit. 0 = Reception is always valid no matter the logic level of stop bit. 1 = Reception is valid only when the received stop bit is logic 1 and the received data matches “Given” or “Broadcast” address. Mode 2 or 3: For multiprocessor communication. 0 = Reception is always valid no matter the logic level of the 9th bit. 1 = Reception is valid only when the received 9th bit is logic 1 and the received data matches “Given” or “Broadcast” address. 4 REN Receiving enable 0 = Serial port 0 reception Disabled. 1 = Serial port 0 reception Enabled in Mode 1,2, or 3. In Mode 0, reception is initiated by the condition REN = 1 and RI = 0. 3 TB8 9th transmitted bit This bit defines the state of the 9th transmission bit in serial port 0 Mode 2 or 3. It is not used in Mode 0 or 1. 2 RB8 9th received bit The bit identifies the logic level of the 9th received bit in serial port 0 Mode 2 or 3. In Mode 1, RB8 is the logic level of the received stop bit. SM2 bit as logic 1 has restriction for exception. RB8 is not used in Mode 0. 1 TI Transmission interrupt flag This flag is set by hardware when a data frame has been transmitted by the serial port 0 after the 8th bit in Mode 0 or the last data bit in other modes. When the serial port 0 interrupt is enabled, setting this bit causes the CPU to execute the serial port 0 interrupt service routine. This bit should be cleared manually via software. 0 RI Receiving interrupt flag This flag is set via hardware when a data frame has been received by the serial port 0 after the 8th bit in Mode 0 or after sampling the stop bit in Mode 1, 2, or 3. SM2 bit as logic 1 has restriction for exception. When the serial port 0 interrupt is enabled, setting this bit causes the CPU to execute to the serial port 0 interrupt service routine. This bit should be cleared manually via software. Jan. 27, 2018 Page 67 of 205 Rev. 1.02 N76E885 Datasheet SCON_1 – Serial Port 1 Control (bit-addressable) 7 6 5 4 SM0_1/FE_1 SM1_1 SM2_1 REN_1 R/W R/W R/W R/W Address: F8H Bit Name 7 SM0_1/FE_1 6 SM1_1 3 TB8_1 R/W 2 RB8_1 R/W 1 0 TI_1 RI_1 R/W R/W Reset value: 0000 0000b Description Serial port 1 mode select SMOD0_1 (T3CON.6) = 0: See Table 14–2. Serial Port 1 Mode Description for details. SMOD0_1 (T3CON.6) = 1: SM0_1/FE_1 bit is used as frame error (FE) status flag. It is cleared by software. 0 = Frame error (FE) did not occur. 1 = Frame error (FE) occurred and detected. 5 SM2_1 Multiprocessor communication mode enable The function of this bit is dependent on the serial port 1 mode. Mode 0: No effect. Mode 1: This bit checks valid stop bit. 0 = Reception is always valid no matter the logic level of stop bit. 1 = Reception is valid only when the received stop bit is logic 1 and the received data matches “Given” or “Broadcast” address. Mode 2 or 3: For multiprocessor communication. 0 = Reception is always valid no matter the logic level of the 9th bit. 1 = Reception is valid only when the received 9th bit is logic 1 and the received data matches “Given” or “Broadcast” address. 4 REN_1 Receiving enable 0 = Serial port 1 reception Disabled. 1 = Serial port 1 reception Enabled in Mode 1,2, or 3. In Mode 0, reception is initiated by the condition REN_1 = 1 and RI_1 = 0. 3 TB8_1 9th transmitted bit This bit defines the state of the 9th transmission bit in serial port 1 Mode 2 or 3. It is not used in Mode 0 or 1. 2 RB8_1 9th received bit The bit identifies the logic level of the 9th received bit in serial port 1 Mode 2 or 3. In Mode 1, RB8_1 is the logic level of the received stop bit. SM2 _1 bit as logic 1 has restriction for exception. RB8_1 is not used in Mode 0. 1 TI_1 Jan. 27, 2018 Transmission interrupt flag This flag is set by hardware when a data frame has been transmitted by the serial port 1 after the 8th bit in Mode 0 or the last data bit in other modes. When the serial port 1 interrupt is enabled, setting this bit causes the CPU to execute the serial port 1 interrupt service routine. This bit must be cleared manually via software. Page 68 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 0 RI_1 Receiving interrupt flag This flag is set via hardware when a data frame has been received by the serial port 1 after the 8th bit in Mode 0 or after sampling the stop bit in Mode 1, 2, or 3. SM2_1 bit as logic 1 has restriction for exception. When the serial port 1 interrupt is enabled, setting this bit causes the CPU to execute to the serial port 1 interrupt service routine. This bit must be cleared manually via software. PCON – Power Control 7 6 SMOD SMOD0 R/W R/W Address: 87H Bit Name 5 - 4 3 2 1 0 POF GF1 GF0 PD IDL R/W R/W R/W R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description 7 SMOD Serial port 0 double baud rate enable Setting this bit doubles the serial port baud rate when UART0 is in Mode 2 or when Timer 1 overflow is used as the baud rate source of UART0 Mode 1 or 3. See Table 14–1. Serial Port 0 Mode Description for details. 6 SMOD0 Serial port 0 framing error flag access enable 0 = SCON.7 accesses to SM0 bit. 1 = SCON.7 accesses to FE bit. T3CON – Timer 3 Control 7 6 SMOD_1 SMOD0_1 R/W R/W Address: C4H 5 BRCK R/W 4 TF3 R/W 3 TR3 R/W 2 1 0 T3PS[2:0] R/W Reset value: 0000 0000b Bit Name Description 7 SMOD_1 Serial port 1 double baud rate enable Setting this bit doubles the serial port baud rate when UART1 is in Mode 2. See Table 14–2. Serial Port 1 Mode Description for details. 6 SMOD0_1 Serial port 1 framing error access enable 0 = SCON_1.7 accesses to SM0_1 bit. 1 = SCON_1.7 accesses to FE_1 bit. Table 14–1. Serial Port 0 Mode Description Mode SM0 SM1 Description Frame Bits Baud Rate 0 0 0 Synchronous 8 FSYS divided by 12 or by 2[1] 1 0 1 Asynchronous 10 Timer 1/Timer 3 overflow rate divided by 32 or divided by 16[2] 2 1 0 Asynchronous 11 FSYS divided by 32 or 64[2] 3 1 1 Asynchronous 11 Timer 1/Timer 3 overflow rate divided by 32 or divided by 16[2] [1] While SM2 (SCON.5) is logic 1. [2] While SMOD (PCON.7) is logic 1. Jan. 27, 2018 Page 69 of 205 Rev. 1.02 N76E885 Datasheet Table 14–2. Serial Port 1 Mode Description Mode SM0 SM1 Description Frame Bits Baud Rate 0 0 0 Synchronous 8 FSYS divided by 12 or by 2[1] 1 0 1 Asynchronous 10 Timer 3 overflow rate divided by 16 2 1 0 Asynchronous 11 FSYS divided by 32 or 64[2] 3 1 1 Asynchronous 11 Timer 3 overflow rate divided by 16 [1] While SM2_1 (SCON_1.5) is logic 1. [2] While SMOD_1 (T3CON.7) is logic 1. SBUF – Serial Port 0 Data Buffer 7 6 5 4 3 2 1 0 SBUF[7:0] R/W Address: 99H Bit 7:0 Reset value: 0000 0000b Name Description SBUF[7:0] Serial port 0 data buffer This byte actually consists two separate registers. One is the receiving resister, and the other is the transmitting buffer. When data is moved to SBUF, it goes to the transmitting buffer and is shifted for serial transmission. When data is moved from SBUF, it comes from the receiving register. The transmission is initiated through giving data to SBUF. SBUF_1 – Serial Port 1 Data Buffer 7 6 5 4 3 SBUF_1[7:0] R/W Address: 9AH Bit 7:0 Jan. 27, 2018 2 1 0 Reset value: 0000 0000b Name Description SBUF_1[7:0] Serial port 1 data buffer This byte actually consists two separate registers. One is the receiving resister, and the other is the transmitting buffer. When data is moved to SBUF_1, it goes to the transmitting buffer and is shifted for serial transmission. When data is moved from SBUF_1, it comes from the receiving register. The transmission is initiated through giving data to SBUF_1. Page 70 of 205 Rev. 1.02 N76E885 Datasheet AUXR1 – Auxiliary Register 1 7 6 5 SWRF RSTPINF T1LXTM R/W R/W R/W Address: A2H Bit 2 4 3 2 1 0 T0LXTM GF2 UART0PX 0 DPS R/W R/W R/W R R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Name Description UART0PX Serial port 0 pin exchange 0 = Assign RXD to P2.0 and TXD to P0.3 by default. 1 = Exchange RXD to P0.3 and TXD to P2.0. Note that TXD and RXD will exchange immediately once setting or clearing this bit. User should take care of not exchanging pins during transmission or receiving. Or it may cause unpredictable situation and no warning alarms. 14.1 Mode 0 Mode 0 provides synchronous communication with external devices. Serial data enters and exits through RXD pin. TXD outputs the shift clocks. 8-bit frame of data are transmitted or received. Mode 0 therefore provides half-duplex communication because the transmitting or receiving data is via the same data line RXD. The baud rate is enhanced to be selected as F SYS/12 if SM2 (SCON.5) is 0 or as FSYS/2 if SM2 is 1. Note that whenever transmitting or receiving, the serial clock is always generated by the MCU. Thus any device on the serial port in Mode 0 should accept the MCU as the master. Figure 14.1 shows the associated timing of the serial port in Mode 0. Figure 14.1. Serial Port Mode 0 Timing Diagram As shown there is one bi-directional data line (RXD) and one shift clock line (TXD). The shift clocks are used to shift data in or out of the serial port controller bit by bit for a serial communication. Data bits enter or emit LSB first. The band rate is equal to the shift clock frequency. Jan. 27, 2018 Page 71 of 205 Rev. 1.02 N76E885 Datasheet Transmission is initiated by any instruction writes to SBUF. The control block will then shift out the clocks and begin to transfer data until all 8 bits are complete. Then the transmitted flag TI (SCON.1) will be set 1 to indicate one byte transmitting complete. Reception is initiated by the condition REN (SCON.4) = 1 and RI (SCON.0) = 0. This condition tells the serial port controller that there is data to be shifted in. This process will continue until 8 bits have been received. Then the received flag RI will be set as 1. User can clear RI to triggering the next byte reception. 14.2 Mode 1 Mode 1 supports asynchronous, full duplex serial communication. The asynchronous mode is commonly used for communication with PCs, modems or other similar interfaces. In Mode 1, 10 bits are transmitted through TXD or received through RXD including a start bit (logic 0), 8 data bits (LSB first) and a stop bit (logic 1). The baud rate is determined by the Timer 1. SMOD (PCON.7) setting 1 makes the baud rate double. Figure 14.2 shows the associated timings of the serial port in Mode 1 for transmitting and receiving. Figure 14.2. Serial Port Mode 1 Timing Diagram Transmission is initiated by any writing instructions to SBUF. Transmission takes place on TXD pin. First the start bit comes out, the 8-bit data follows to be shifted out and then ends with a stop bit. After the stop bit appears, TI (SCON.1) will be set to indicate one byte transmission complete. All bits are shifted out depending on the rate determined by the baud rate generator. Once the baud rate generator is activated and REN (SCON.4) is 1, the reception can begin at any time. Reception is initiated by a detected 1-to-0 transition at RXD. Data will be sampled and shifted in Jan. 27, 2018 Page 72 of 205 Rev. 1.02 N76E885 Datasheet at the selected baud rate. In the midst of the stop bit, certain conditions should be met to load SBUF with the received data: 1. RI (SCON.0) = 0, and 2. Either SM2 (SCON.5) = 0, or the received stop bit = 1 while SM2 = 1 and the received data matches “Given” or “Broadcast” address. (For enhancement function, see 14.7 “Multiprocessor Communication” and 14.8 “Automatic Address Recognition”.) If these conditions are met, then the SBUF will be loaded with the received data, the RB8 (SCON.2) with stop bit, and RI will be set. If these conditions fail, there will be no data loaded and RI will remain 0. After above receiving progress, the serial control will look forward another 1-to-0 transition on RXD pin to start next data reception. 14.3 Mode 2 Mode 2 supports asynchronous, full duplex serial communication. Different from Mode1, there are 11 bits to be transmitted or received. They are a start bit (logic 0), 8 data bits (LSB first), a programmable 9th bit TB8 or RB8 bit and a stop bit (logic 1). The most common use of 9th bit is to put the parity bit in it or to label address or data frame for multiprocessor communication. The baud rate is fixed as 1/32 or 1/64 the system clock frequency depending on SMOD (PCON.7) bit. Figure 14.3 shows the associated timings of the serial port in Mode 2 for transmitting and receiving. Figure 14.3. Serial Port Mode 2 and 3 Timing Diagram Jan. 27, 2018 Page 73 of 205 Rev. 1.02 N76E885 Datasheet Transmission is initiated by any writing instructions to SBUF. Transmission takes place on TXD pin. First the start bit comes out, the 8-bit data and bit TB8 (SCON.3) follows to be shifted out and then ends with a stop bit. After the stop bit appears, TI will be set to indicate the transmission complete. While REN is set, the reception is allowed at any time. A falling edge of a start bit on RXD will initiate the reception progress. Data will be sampled and shifted in at the selected baud rate. In the midst of the stop bit, certain conditions should be met to load SBUF with the received data: 1. RI (SCON.0) = 0, and 2. Either SM2 (SCON.5) = 0, or the received 9th bit = 1 while SM2 = 1 and the received data matches “Given” or “Broadcast” address. (For enhancement function, see 14.7 “Multiprocessor Communication” and 14.8 “Automatic Address Recognition”.) If these conditions are met, the SBUF will be loaded with the received data, the RB8(SCON.2) with the received 9th bit and RI will be set. If these conditions fail, there will be no data loaded and RI will remain 0. After above receiving progress, the serial control will look forward another 1-to-0 transition on RXD pin to start next data reception. 14.4 Mode 3 Mode 3 has the same operation as Mode 2, except its baud rate clock source uses Timer 1 overflows as its baud rate clocks. See Figure 14.3 for timing diagram of Mode 3. It has no difference from Mode 2. 14.5 Baud Rate The baud rate source and speed for different modes of serial port is quite different from one another. All cases are listed in Table 14–3. The user should calculate the baud rate according to their system configuration. In Mode 1 or 3, the baud rate clock source of UART0 can be selected from Timer 1 or Timer 3. User can select the baud rate clock source by BRCK (T3CON.5). For UART1, its baud rate clock comes only from Timer 3 as its unique clock source. Jan. 27, 2018 Page 74 of 205 Rev. 1.02 N76E885 Datasheet T3CON – Timer 3 Control 7 6 SMOD_1 SMOD0_1 R/W R/W Address: C4H Bit Name 5 BRCK 5 BRCK R/W 4 TF3 R/W 3 TR3 R/W 2 1 0 T3PS[2:0] R/W Reset value: 0000 0000b Description Serial port 0 baud rate clock source This bit selects which Timer is used as the baud rate clock source when serial port 0 is in Mode 1 or 3. 0 = Timer 1. 1 = Timer 3. When using Timer 1 as the baud rate clock source, note that the Timer 1 interrupt should be disabled. Timer 1 itself can be configured for either “ imer” or “ ounter” operation. It can be in any of its three running modes. However, in the most typical applications, it is configured for “ imer” operation, in the auto-reload mode (Mode 2). If using Timer 3 as the baud rate generator, its interrupt should also be disabled. Table 14–3. UART Baud Rate Formulas UART Mode Baud Rate Clock Source Baud Rate 0 System clock FSYS / 12 or FSYS / 2 [1] 2 System clock FSYS / 64 or FSYS / 32 [2] 2SMOD Timer 1 (only for UART0) 1 or 3 [3] Timer 3 (for UART0) 32 2SMOD 32 1 Timer 3 (for UART1) × × × FSYS 12 × (256 - TH1) or 2SMOD 32 × FSYS [4] 256 - TH1 FSYS [5] Pr e - scale× (65536 - {RH3, RL3}) FSYS [5] 16 Pr e - scale× (65536 - {RH3, RL3}) [1] SM2 (SCON.5) or SM2_1(SCON_1.5) is set as logic 1. [2] SMOD (PCON.7) or SMOD_1(T3CON.7) is set as logic 1. [3] Timer 1 is configured as a timer in auto-reload mode (Mode 2). [4] T1M (CKCON.4) is set as logic 1. While SMOD is 1, TH1 should not be FFH. [5] {RH3,RL3} in the formula means 256 × RH3 + RL3 . While SMOD is 1 and pre-scale is 1/1, {RH3,RL3} should not be FFFFH. Table 14–4 lists various commonly used baud rates and how they can be obtained with Timer 1. In this mode, Timer 1 operates as an auto-reload Timer with SMOD (PCON.7) is 0 and T1M (CKCON.4) is 0. Table 14–5 is related to UART0 for Timer 3. This table illustrates that when SMOD is 0 the same setting doubles the baud rate for UART1. Jan. 27, 2018 Page 75 of 205 Rev. 1.02 N76E885 Datasheet Table 14–4. Commonly Used Baud Rates by Timer 1 Oscillator Frequency (MHz) Baud Rate (bps) 3.6864 11.0592 14.7456 18.432 22.1184 TH1 reload value 57600 - - - - FFH 38400 - - FFH - - 19200 - - FEH - FDH 9600 FFH FDH FCH FBH FAH 4800 FEH FAH F8H F6H F4H 2400 FCH F4H F0H ECH E8H 1200 F8H E8H E0H D8H D0H 300 E0H A0H 80H 60H 40H 18.432 22.1184 Table 14–5. Commonly Used Baud Rates by Timer 3 Oscillator Frequency (MHz) Baud Rate (bps) 3.6864 11.0592 14.7456 {RH3,RL3} Reload Value 115200 FFFFH FFFDH FFFCH FFFBH FFFAH 57600 FFFEH FFFAH FFF8H FFF6H FFF4H 38400 FFFDH FFF7H FFF4H FFF1H FFEEH 19200 FFFAH FFEEH FFE8H FFE2H FFDCH 9600 FFF4H FFDCH FFD0H FFC4H FFB8H 4800 FFE8H FFB8H FFA0H FF88H FF70H 2400 FFD0H FF70H FF40H FF10H FEE0H 1200 FFA0H FEE0H FE80H FE20H FDC0H 300 FE80H FB80H FA00H F880H F700H 14.6 Framing Error Detection Framing error detection is provided for asynchronous modes. (Mode 1, 2, or 3.) The framing error occurs when a valid stop bit is not detected due to the bus noise or contention. The UART can detect a framing error and notify the software. The framing error bit, FE, is located in SCON.7. This bit normally serves as SM0. While the framing error accessing enable bit SMOD0 (PCON.6) is set 1, it serves as FE flag. Actually, SM0 and FE locate in different registers. Jan. 27, 2018 Page 76 of 205 Rev. 1.02 N76E885 Datasheet The FE bit will be set 1 via hardware while a framing error occurs. FE can be checked in UART interrupt service routine if necessary. Note that SMOD0 should be 1 while reading or writing to FE. If FE is set, any following frames received without frame error will not clear the FE flag. The clearing has to be done via software. 14.7 Multiprocessor Communication The N76E885 multiprocessor communication feature lets a master device send a multiple frame serial message to a slave device in a multi-slave configuration. It does this without interrupting other slave devices that may be on the same serial line. This feature can be used only in UART Mode 2 or 3. User can enable this function by setting SM2 (SCON.5) as logic 1 so that when a byte of frame is received, the serial interrupt will be generated only if the 9th bit is 1. (For Mode 2, the 9th bit is the stop bit.) When the SM2 bit is 1, serial data frames that are received with the 9th bit as 0 do not generate an interrupt. In this case, the 9th bit simply separates the slave address from the serial data. When the master device wants to transmit a block of data to one of several slaves on a serial line, it first sends out an address byte to identify the target slave. Note that in this case, an address byte differs from a data byte. In an address byte, the 9th bit is 1 and in a data byte, it is 0. The address byte interrupts all slaves so that each slave can examine the received byte and see if it is addressed by its own slave address. The addressed slave then clears its SM2 bit and prepares to receive incoming data bytes. The SM2 bits of slaves that were not addressed remain set, and they continue operating normally while ignoring the incoming data bytes. Follow the steps below to configure multiprocessor communications: 1. Set all devices (masters and slaves) to UART Mode 2 or 3. 2. Write the SM2 bit of all the slave devices to 1. 3. The master device's transmission protocol is: – First byte: the address, identifying the target slave device, (9th bit = 1). – Next bytes: data, (9th bit = 0). 4. When the target slave receives the first byte, all of the slaves are interrupted because the 9th data bit is 1. The targeted slave compares the address byte to its own address and then clears its SM2 bit to receiving incoming data. The other slaves continue operating normally. 5. After all data bytes have been received, set SM2 back to 1 to wait for next address. Jan. 27, 2018 Page 77 of 205 Rev. 1.02 N76E885 Datasheet SM2 has no effect in Mode 0, and in Mode 1 can be used to check the validity of the stop bit. For Mode 1 reception, if SM2 is 1, the receiving interrupt will not be issue unless a valid stop bit is received. 14.8 Automatic Address Recognition The automatic address recognition is a feature, which enhances the multiprocessor communication feature by allowing the UART to recognize certain addresses in the serial bit stream by using hardware to make the comparisons. This feature saves a great deal of software overhead by eliminating the need for the software to examine every serial address, which passes by the serial port. Only when the serial port recognizes its own address, the receiver sets RI bit to request an interrupt. The automatic address recognition feature is enabled when the multiprocessor communication feature is enabled, SM2 is set. If desired, user may enable the automatic address recognition feature in Mode 1. In this configuration, the stop bit takes the place of the ninth data bit. RI is set only when the received command frame address matches the device’s address and is terminated by a valid stop bit. Using the automatic address recognition feature allows a master to selectively communicate with one or more slaves by invoking the “Given” slave address or addresses. All of the slaves may be contacted by using the “Broadcast” address. wo F s are used to define the slave address, ADD , and the slave address mask, SADEN. SADEN is used to define which bits in the SADDR are to be used and which bits are “don’t care”. he ADE mask can be logically A Ded with the ADD to create the “Given” address, which the master will use for addressing each of the slaves. Use of the “Given” address allows multiple slaves to be recognized while excluding others. SADDR – Slave 0 Address 7 6 5 4 3 2 1 0 SADDR[7:0] R/W Address: A9H Bit 7:0 Jan. 27, 2018 Reset value: 0000 0000b Name Description SADDR[7:0] Slave 0 address his byte specifies the microcontroller’s own slave address for UATR0 multiprocessor communication. Page 78 of 205 Rev. 1.02 N76E885 Datasheet SADEN – Slave 0 Address Mask 7 6 5 4 3 2 1 0 SADEN[7:0] R/W Address: B9H Bit 7:0 Reset value: 0000 0000b Name Description SADEN[7:0] Slave 0 address mask This byte is a mask byte of UART0 that contains “don’t-care” bits (defined by zeros) to form the device’s “Given” address. The don’t-care bits provide the flexibility to address one or more slaves at a time. SADDR_1 – Slave 1 Address 7 6 5 4 3 SADDR_1[7:0] R/W 2 Address: BBH Bit 7:0 Name Description SADDR_1[7:0] Slave 1 address his byte specifies the microcontroller’s own slave address for UART1 multiprocessor communication. 4 3 SADEN_1[7:0] R/W Address: BAH 7:0 0 Reset value: 0000 0000b SADEN_1 – Slave 1 Address Mask 7 6 5 Bit 1 2 1 0 Reset value: 0000 0000b Name Description SADEN_1[7:0] Slave 1 address mask This byte is a mask byte of UART1 that contains “don’t-care” bits (defined by zeros) to form the device’s “Given” address. The don’t-care bits provide the flexibility to address one or more slaves at a time. The following examples will help to show the versatility of this scheme. Example 1, slave 0: SADDR = 11000000b SADEN = 11111101b Given = 110000X0b Example 2, slave 1: SADDR = 11000000b SADEN = 11111110b Given = 1100000Xb Jan. 27, 2018 Page 79 of 205 Rev. 1.02 N76E885 Datasheet In the above example SADDR is the same and the SADEN data is used to differentiate between the two slaves. Slave 0 requires 0 in bit 0 and it ignores bit 1. Slave 1 requires 0 in bit 1 and bit 0 is ignored. A unique address for Slave 0 would be 1100 0010 since slave 1 requires 0 in bit 1. A unique address for slave 1 would be 11000001b since 1 in bit 0 will exclude slave 0. Both slaves can be selected at the same time by an address, which has bit 0 = 0 (for slave 0) and bit 1 = 0 (for slave 1). hus, both could be addressed with b as their “Broadcast” address. In a more complex system the following could be used to select slaves 1 and 2 while excluding slave 0: Example 1, slave 0: SADDR = 11000000b SADEN = 11111001b Given = 11000XX0b Example 2, slave 1: SADDR = 11100000b SADEN = 11111010b Given = 11100X0Xb Example 3, slave 2: SADDR = 11000000b SADEN = 11111100b Given = 110000XXb In the above example the differentiation among the 3 slaves is in the lower 3 address bits. Slave 0 requires that bit 0 = 0 and it can be uniquely addressed by 11100110b. Slave 1 requires that bit 1 = 0 and it can be uniquely addressed by 11100101b. Slave 2 requires that bit 2 = 0 and its unique address is 11100011b. To select Slaves 0 and 1 and exclude Slave 2 use address 11100100b, since it is necessary to make bit 2 = 1 to exclude slave 2. he “Broadcast” address for each slave is created by taking the logical O of ADD and ADE . Zeros in this result are treated as “don’t-cares”, e.g.: SADDR = 01010110b SADEN = 11111100b Broadcast = 1111111Xb he use of don’t-care bits provides flexibility in defining the Broadcast address, however in most applications, interpreting the “don’t-cares” as all ones, the broadcast address will be FFH. On reset, SADDR and ADE are initialized to H. his produces a “Given” address of all “don’t cares” as well as a “Broadcast” address of all XXXXXXXXb (all “don’t care” bits). his ensures that the Jan. 27, 2018 Page 80 of 205 Rev. 1.02 N76E885 Datasheet serial port will reply to any address, and so that it is backwards compatible with the standard 80C51 microcontrollers that do not support automatic address recognition. Jan. 27, 2018 Page 81 of 205 Rev. 1.02 N76E885 Datasheet 15. SERIAL PERIPHERAL INTERFACE (SPI) The N76E885 provides a Serial Peripheral Interface (SPI) block to support high-speed serial communication. SPI is a full-duplex, high-speed, synchronous communication bus between microcontrollers or other peripheral devices such as serial EEPROM, LCD driver, or D/A converter. It provides either Master or Slave mode, high-speed rate up to FSYS/4, transfer complete and write collision flag. For a multi-master system, SPI supports Master Mode Fault to protect a multi-master conflict. 15.1 Functional Description FSYS S M MSB Select M S CLOCK SPR0 SPR1 LSB 8-bit Shift Register Read Data Buffer MISO MOSI Pin Contorl Logic Divider /4, /8, /16, /32 Clock Logic SPCLK SSOE DISMODF SPIEN MSTR SS MSTR SPI Status Register SPI Interrupt SPR1 SPR0 CPHA CPOL LSBFE MSTR SSOE SPIEN SPIEN DISMODF MODF SPIOVF WCOL SPIF SPI Status Control Logic SPI Control Register Internal Data Bus Figure 15.1. SPI Block Diagram Table 15–1 shows SPI block diagram. It provides an overview of SPI architecture in this device. The main blocks of SPI are the SPI control register logic, SPI status logic, clock rate control logic, and pin control logic. For a serial data transfer or receiving, The SPI block exists a shift register and a read Jan. 27, 2018 Page 82 of 205 Rev. 1.02 N76E885 Datasheet data buffer. It is single buffered in the transmit direction and double buffered in the receiving direction. Transmit data cannot be written to the shifter until the previous transfer is complete. Receiving logic consists of parallel read data buffer so the shift register is free to accept a second data, as the first received data will be transferred to the read data buffer. The four pins of SPI interface are Master-In/Slave-Out (MISO), Master-Out/Slave-In (MOSI), Shift Clock (SPCLK), and Slave Select ( ̅̅̅̅). The MOSI pin is used to transfer a 8-bit data in series from the Master to the Slave. Therefore, MOSI is an output pin for Master device and an input for Slave. Respectively, the MISO is used to receive a serial data from the Slave to the Master. The SPCLK pin is the clock output in Master mode, but is the clock input in Slave mode. The shift clock is used to synchronize the data movement both in and out of the devices through their MOSI and MISO pins. The shift clock is driven by the Master mode device for eight clock cycles. Eight clocks exchange one byte data on the serial lines. For the shift clock is always produced out of the Master device, the system should never exist more than one device in Master mode for avoiding device conflict. Each Slave peripheral is selected by one Slave Select pin ( ̅̅̅̅). The signal should stay low for any Slave access. When ̅̅̅̅ is driven high, the Slave device will be inactivated. If the system is multislave, there should be only one Slave device selected at the same time. In the Master mode MCU, the ̅̅̅̅ pin does not function and it can be configured as a general purpose I/O. However, ̅̅̅̅ can be used as Master Mode Fault detection (see Section 15.5 “Mode Fault Detection” on page 91) via software setting if multi-master environment exists. The N76E885 also provides auto-activating function to toggle ̅̅̅̅ between each byte-transfer. Master/Slave MCU1 Master/Slave MCU2 MISO MISO MOSI MOSI SPCLK Slave device 1 Jan. 27, 2018 Slave device 2 I/O PORT SO SI SCK SS SO SI SCK SS 0 1 2 3 SO 0 1 2 3 SI SS SCK SS SS I/O PORT SPCLK Slave device 3 Page 83 of 205 Rev. 1.02 N76E885 Datasheet Figure 15.2. SPI Multi-Master, Multi-Slave Interconnection Figure 15.2 shows a typical interconnection of SPI devices. The bus generally connects devices together through three signal wires, MOSI to MOSI, MISO to MISO, and SPCLK to SPCLK. The Master devices select the individual Slave devices by using four pins of a parallel port to control the four ̅̅̅̅ pins. MCU1 and MCU2 play either Master or Slave mode. The ̅̅̅̅ should be configured as Master Mode Fault detection to avoid multi-master conflict. MOSI MOSI MISO MISO SPI shift register 7 6 5 4 3 2 1 0 SPI shift register 7 6 5 4 3 2 1 0 SPCLK SPCLK SPI clock generator SS Master MCU * SS GND Slave MCU * SS configuration follows DISMODF and SSOE bits. Figure 15.3. SPI Single-Master, Single-Slave Interconnection Figure 15.3 shows the simplest SPI system interconnection, single-master and signal-slave. During a transfer, the Master shifts data out to the Slave via MOSI line. While simultaneously, the Master shifts data in from the Slave via MISO line. The two shift registers in the Master MCU and the Slave MCU can be considered as one 16-bit circular shift register. Therefore, while a transfer data pushed from Master into Slave, the data in Slave will also be pulled in Master device respectively. The transfer effectively exchanges the data, which was in the SPI shift registers of the two MCUs. By default, SPI data is transferred MSB first. If the LSBFE (SPCR.5) is set, SPI data shifts LSB first. This bit does not affect the position of the MSB and LSB in the data register. Note that all the following description and figures are under the condition of LSBFE logic 0. MSB is transmitted and received first. There are three SPI registers to support its operations, including SPI control register (SPCR), SPI status register (SPSR), and SPI data register (SPDR). These registers provide control, status, data storage functions, and clock rate selection. The following registers relate to SPI function. Jan. 27, 2018 Page 84 of 205 Rev. 1.02 N76E885 Datasheet SPCR – Serial Peripheral Control Register 7 6 5 4 SSOE SPIEN LSBFE MSTR R/W R/W R/W R/W Address: F3H Bit Name 3 CPOL R/W 2 CPHA R/W 1 0 SPR1 SPR0 R/W R/W Reset value: 0000 0000b Description 7 SSOE Slave select output enable This bit is used in combination with the DISMODF (SPSR.3) bit to determine the feature of ̅̅̅̅ pin as shown in Table 15–1. Slave Select Pin Configurations. This bit takes effect only under MSTR = 1 and DISMODF = 1 condition. 0 = ̅̅̅̅ functions as a general purpose I/O pin. 1 = ̅̅̅̅ automatically goes low for each transmission when selecting external Slave device and goes high during each idle state to de-select the Slave device. 6 SPIEN SPI enable 0 = SPI function Disabled. 1 = SPI function Enabled. 5 LSBFE LSB first enable 0 = The SPI data is transferred MSB first. 1 = The SPI data is transferred LSB first. 4 MSTR Master mode enable This bit switches the SPI operating between Master and Slave modes. 0 = The SPI is configured as Slave mode. 1 = The SPI is configured as Master mode. 3 CPOL SPI clock polarity select CPOL bit determines the idle state level of the SPI clock. See Figure 15.4. SPI Clock Formats. 0 = The SPI clock is low in idle state. 1 = The SPI clock is high in idle state. 2 CPHA SPI clock phase select CPHA bit determines the data sampling edge of the SPI clock. See Figure 15.4. SPI Clock Formats. 0 = The data is sampled on the first edge of the SPI clock. 1 = The data is sampled on the second edge of the SPI clock. 1:0 SPR[1:0] Jan. 27, 2018 SPI clock rate select These two bits select four grades of SPI clock divider. The clock rates below are illustrated under FSYS = 24 MHz condition. SPR1 SPR0 Divider SPI clock rate 0 0 4 6M bit/s 0 1 8 3M bit/s 1 0 16 1.5M bit/s 1 1 32 750k bit/s SPR[1:0] are valid only under Master mode (MSTR = 1). If under Slave mode, the clock will automatically synchronize with the external clock on SPICLK pin from Master device up to FSYS/4 communication speed. Page 85 of 205 Rev. 1.02 N76E885 Datasheet Table 15–1. Slave Select Pin Configurations DISMODF SSOE Master Mode (MSTR = 1) 0 X ̅̅̅̅ input for Mode Fault 1 0 General purpose I/O 1 1 Automatic ̅̅̅̅ output Slave Mode (MSTR = 0) ̅̅̅̅ Input for Slave select SPSR – Serial Peripheral Status Register 7 6 5 4 SPIF WCOL SPIOVF MODF R/W R/W R/W R/W Address: F4H Bit Name 3 DISMODF R/W 2 - 1 0 Reset value: 0000 0000b Description 7 SPIF SPI complete flag This bit is set to logic 1 via hardware while an SPI data transfer is complete or an receiving data has been moved into the SPI read buffer. If ESPI (EIE .0) and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. Attempting to write to SPDR is inhibited if SPIF is set. 6 WCOL Write collision error flag This bit indicates a write collision event. Once a write collision event occurs, this bit will be set. It should be cleared via software. 5 SPIOVF SPI overrun error flag This bit indicates an overrun event. Once an overrun event occurs, this bit will be set. If ESPI and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. 4 MODF Mode Fault error flag This bit indicates a Mode Fault error event. If ̅̅̅̅ pin is configured as Mode Fault input (MSTR = 1 and DISMODF = 0) and ̅̅̅̅ is pulled low by external devices, a Mode Fault error occurs. Instantly MODF will be set as logic 1. If ESPI and EA are enabled, an SPI interrupt will be required. This bit should be cleared via software. 3 DISMODF Jan. 27, 2018 Disable Mode Fault error detection This bit is used in combination with the SSOE (SPCR.7) bit to determine the feature of ̅̅̅̅ pin as shown in Table 15–1. Slave Select Pin Configurations. DISMODF is valid only in Master mode (MSTR = 1). 0 = Mode Fault detection Enabled. ̅̅̅̅ serves as input pin for Mode Fault detection disregard of SSOE. 1 = Mode Fault detection Disabled. The feature of ̅̅̅̅ follows SSOE bit. Page 86 of 205 Rev. 1.02 N76E885 Datasheet SPDR – Serial Peripheral Data Register 7 6 5 4 3 2 1 0 SPDR[7:0] R/W Address: F5H Bit 7:0 Reset value: 0000 0000b Name Description SPDR[7:0] Serial peripheral data This byte is used for transmitting or receiving data on SPI bus. A write of this byte is a write to the shift register. A read of this byte is actually a read of the read data buffer. In Master mode, a write to this register initiates transmission and reception of a byte simultaneously. 15.2 Operating Modes 15.2.1 Master Mode The SPI can operate in Master mode while MSTR (SPCR.4) is set as 1. Only one Master SPI device can initiate transmissions. A transmission always begins by Master through writing to SPDR. The byte written to SPDR begins shifting out on MOSI pin under the control of SPCLK. Simultaneously, another byte shifts in from the Slave on the MISO pin. After 8-bit data transfer complete, SPIF (SPSR.7) will automatically set via hardware to indicate one byte data transfer complete. At the same time, the data received from the Slave is also transferred in SPDR. User can clear SPIF and read data out of SPDR. 15.2.2 Slave Mode When MSTR is 0, the SPI operates in Slave mode. The SPCLK pin becomes input and it will be clocked by another Master SPI device. The ̅̅̅̅̅ pin also becomes input. The Master device cannot exchange data with the Slave device until the ̅̅̅̅̅ pin of the Slave device is externally pulled low. Before data transmissions occurs, the ̅̅̅̅̅ of the Slave device should be pulled and remain low until the transmission is complete. If ̅̅̅̅̅ goes high, the SPI is forced into idle state. If the ̅̅̅̅̅ is forced to high at the middle of transmission, the transmission will be aborted and the rest bits of the receiving shifter buffer will be high and goes into idle state. In Slave mode, data flows from the Master to the Slave on MOSI pin and flows from the Slave to the Master on MISO pin. The data enters the shift register under the control of the SPCLK from the Master device. After one byte is received in the shift register, it is immediately moved into the read data buffer and the SPIF bit is set. A read of the SPDR is actually a read of the read data buffer. To prevent an overrun and the loss of the byte that caused by the overrun, the Slave should read SPDR out and the first SPIF should be cleared before a second transfer of data from the Master device comes in the read data buffer. Jan. 27, 2018 Page 87 of 205 Rev. 1.02 N76E885 Datasheet 15.3 Clock Formats and Data Transfer To accommodate a wide variety of synchronous serial peripherals, the SPI has a clock polarity bit CPOL (SPCR.3) and a clock phase bit CPHA (SPCR.2). Figure 15.4. SPI Clock Formats shows that CPOL and CPHA compose four different clock formats. The CPOL bit denotes the SPCLK line level in its idle state. The CPHA bit defines the edge on which the MOSI and MISO lines are sampled. The CPOL and CPHA should be identical for the Master and Slave devices on the same system. To Communicate in different data formats with one another will result undetermined result. Clock Phase (CPHA) CPOL = 0 CPHA = 1 sample sample sample sample CPOL = 1 Clock Polarity (CPOH) CPHA = 0 Figure 15.4. SPI Clock Formats In SPI, a Master device always initiates the transfer. If SPI is selected as Master mode (MSTR = 1) and enabled (SPIEN = 1), writing to the SPI data register (SPDR) by the Master device starts the SPI clock and data transfer. After shifting one byte out and receiving one byte in, the SPI clock stops and SPIF (SPSR.7) is set in both Master and Slave. If SPI interrupt enable bit ESPI (EIE.0) is set 1 and global interrupt is enabled (EA = 1), the interrupt service routine (ISR) of SPI will be executed. Concerning the Slave mode, the ̅̅̅̅̅ signal needs to be taken care. As shown in Figure 15.4. SPI Clock Formats, when CPHA = 0, the first SPCLK edge is the sampling strobe of MSB (for an example of LSBFE = 0, MSB first). Therefore, the Slave should shift its MSB data before the first SPCLK edge. The falling edge of ̅̅̅̅̅ is used for preparing the MSB on MISO line. The ̅̅̅̅̅ pin therefore should toggle high and then low between each successive serial byte. Furthermore, if the slave writes data to the SPI data register (SPDR) while ̅̅̅̅̅ is low, a write collision error occurs. When CPHA = 1, the sampling edge thus locates on the second edge of SPCLK clock. The Slave uses the first SPCLK clock to shift MSB out rather than the ̅̅̅̅̅ falling edge. Therefore, the ̅̅̅̅̅ line can remain low between successive transfers. This format may be preferred in systems having single fixed Jan. 27, 2018 Page 88 of 205 Rev. 1.02 N76E885 Datasheet Master and single fixed Slave. The ̅̅̅̅̅ line of the unique Slave device can be tied to GND as long as only CPHA = 1 clock mode is used. The SPI should be configured before it is enabled (SPIEN = 1), or a change of LSBFE, MSTR, CPOL, CPHA and SPR[1:0] will abort a transmission in progress and force the SPI system into idle state. Prior to any configuration bit changed, SPIEN must be disabled first. SPCLK Cycles 1 SPCLK Cycles 2 3 4 5 6 7 8 SPCLK (CPOL=0) SPCLK (CPOL=1) Transfer Progress[1] (internal signal) MOSI MISO MSB MSB 6 5 4 3 2 1 6 5 4 3 2 1 LSB LSB Input to Slave SS SS output of Master[2] SPIF (Master) SPIF (Slave) [1] Transfer progress starts by a writing SPDR of Master MCU. [2] SS automatic output affects when MSTR = DISMODF = SSOE = 1. Figure 15.5. SPI Clock and Data Format with CPHA = 0 Jan. 27, 2018 Page 89 of 205 Rev. 1.02 N76E885 Datasheet SPCLK Cycles SPCLK Cycles 1 2 3 4 5 6 7 8 MSB 6 5 4 3 2 1 LSB 6 5 4 3 2 1 SPCLK (CPOL=0) SPCLK (CPOL=1) Transfer Progress[1] (internal signal) MOSI MSB MISO LSB [3] [4] Input to Slave SS SS output of Master[2] SPIF (Master) SPIF (Slave) [1] Transfer progress starts by a writing SPDR of Master MCU. [2] SS automatic output affects when DISMODF = SSOE = MSTR = 1. [3] If SS of Slave is low, the MISO will be the LSB of previous data. Otherwise, MISO will be high. [4] While SS stays low, the LSB will last its state. Once SS is released to high, MISO will switch to high level. Figure 15.6. SPI Clock and Data Format with CPHA = 1 15.4 Slave Select Pin Configuration The N76E885 SPI gives a flexible ̅̅̅̅̅ pin feature for different system requirements. When the SPI operates as a Slave, ̅̅̅̅̅ pin always rules as Slave select input. When the Master mode is enabled, ̅̅̅̅̅ has three different functions according to DISMODF (SPSR.3) and SSOE (SPCR.7). By default, DISMODF is 0. It means that the Mode Fault detection activates. ̅̅̅̅̅ is configured as a input pin to check if the Mode Fault appears. On the contrary, if DISMODF is 1, Mode Fault is inactivated and the SSOE bit takes over to control the function of the ̅̅̅̅̅ pin. While SSOE is 1, it means the Slave select signal will generate automatically to select a Slave device. The ̅̅̅̅̅ as output pin of the Master usually connects with the ̅̅̅̅̅ input pin of the Slave device. The ̅̅̅̅̅ output automatically goes low for each transmission when selecting external Slave device and goes high during each idle state to de-select the Slave device. While SSOE is 0 and DISMODF is 1, ̅̅̅̅̅ is no more used by the SPI and reverts to be a general purpose I/O pin. Jan. 27, 2018 Page 90 of 205 Rev. 1.02 N76E885 Datasheet 15.5 Mode Fault Detection The Mode Fault detection is useful in a system where more than one SPI devices might become Masters at the same time. It may induce data contention. When the SPI device is configured as a Master and the ̅̅̅̅̅ input line is configured for Mode Fault input depending on Table 15–1. Slave Select Pin Configurations, a Mode Fault error occurs once the ̅̅̅̅̅ is pulled low by others. It indicates that some other SPI device is trying to address this Master as if it is a Slave. Instantly the MSTR and SPIEN control bits in the SPCR are cleared via hardware to disable SPI, Mode Fault flag MODF (SPSR.4) is set and an interrupt is generated if ESPI (EIE .0) and EA are enabled. 15.6 Write Collision Error The SPI is signal buffered in the transfer direction and double buffered in the receiving direction. New data for transmission cannot be written to the shift register until the previous transaction is complete. Write collision occurs while an attempt was made to write data to the SPDR while a transfer was in progress. SPDR is not double buffered in the transmit direction. Any writing to SPDR cause data to be written directly into the SPI shift register. Once a write collision error is generated, WCOL (SPSR.6) will be set as 1 via hardware to indicate a write collision. In this case, the current transferring data continues its transmission. However the new data that caused the collision will be lost. Although the SPI logic can detect write collisions in both Master and Slave modes, a write collision is normally a Slave error because a Slave has no indicator when a Master initiates a transfer. During the receiving of Slave, a write to SPDR causes a write collision in Slave mode. WCOL flag needs to be cleared via software. 15.7 Overrun Error For receiving data, the SPI is double buffered in the receiving direction. The received data is transferred into a parallel read data buffer so the shifter is free to accept a second serial byte. However, the received data should be read from SPDR before the next data has been completely shifted in. As long as the first byte is read out of the read data buffer and SPIF is cleared before the next byte is ready to be transferred, no overrun error condition occurs. Otherwise the overrun error occurs. In this condition, the second byte data will not be successfully received into the read data register and the previous data will remains. If overrun occur, SPIOVF (SPSR.5) will be set via hardware. An SPIOVF setting will also require an interrupt if enabled. Figure 15.7. SPI Overrun Waveform shows the relationship between the data receiving and the overrun error. Jan. 27, 2018 Page 91 of 205 Rev. 1.02 N76E885 Datasheet Data[n] Receiving Begins Shift Register Data[n+1] Receiving Begins Shifting Data[n] in SPIF Data[n+2] Receiveing Begins Shifting Data[n+1] in Shifting Data[n+2] in [1] [3] Read Data Buffer Data[n] SPIOVF [4] Data[n] [2] Data[n+2] [3] [1] When Data[n] is received, the SPIF will be set. [2] If SPIF is not clear before Data[n+1] progress done, the SPIOVF will be set. Data[n] will be kept in read data buffer but Data [n+1] will be lost. [3] SPIF and SPIOVF must be cleared by software. [4] When Data[n+2] is received, the SPIF will be set again. Figure 15.7. SPI Overrun Waveform 15.8 SPI Interrupt Three SPI status flags, SPIF, MODF, and SPIOVF, can generate an SPI event interrupt requests. All of them locate in SPSR. SPIF will be set after completion of data transfer with external device or a new data have been received and copied to SPDR. MODF becomes set to indicate a low level on ̅̅̅̅̅ causing the Mode Fault state. SPIOVF denotes a receiving overrun error. If SPI interrupt mask is enabled via setting ESPI (EIE.6) and EA is 1, CPU will executes the SPI interrupt service routine once any of these three flags is set. User needs to check flags to determine what event caused the interrupt. These three flags are software cleared. SPIF SPIOVF SS MSTR DISMODF Mode MODF Fault Detection SPI Interrupt ESPI (EIE.6) EA Figure 15.8. SPI Interrupt Request Jan. 27, 2018 Page 92 of 205 Rev. 1.02 N76E885 Datasheet 2 16. INTER-INTEGRATED CIRCUIT (I C) 2 The Inter-Integrated Circuit (I C) bus serves as an serial interface between the microcontrollers and 2 2 the I C devices such as EEPROM, LCD module, temperature sensor, and so on. The I C bus used two wires design (a serial data line SDA and a serial clock line SCL) to transfer information between devices. 2 The I C bus uses bi-directional data transfer between masters and slaves. There is no central master and the multi-master system is allowed by arbitration between simultaneously transmitting masters. The serial clock synchronization allows devices with different bit rates to communicate via one serial 2 bus. The I C bus supports four transfer modes including master transmitter, master receiver, slave 2 receiver, and slave transmitter. The I C interface only supports 7-bit addressing mode. A special mode 2 General Call is also available. The I C can meet both standard (up to 100kbps) and fast (up to 400k bps) speeds. 16.1 Functional Description For a bi-directional transfer operation, the SDA and SCL pins should be open-drain pads. This implements a wired-AND function, which is essential to the operation of the interface. A low level on a 2 2 I C bus line is generated when one or more I C devices output a “ ”. A high level is generated when 2 all I C devices output “ ”, allowing the pull-up resistors to pull the line high. In N76E885, user should 2 set output latches of P2.3 and P0.6. as logic 1 before enabling the I C function by setting I2CEN (I2CON.6). VDD RUP RUP SDA SCL SDA SDA SCL SCL Other MCU N76E885 SDA SCL Slave Device 2 Figure 16.1. I C Bus Interconnection 2 The I C is considered free when both lines are high. Meanwhile, any device, which can operate as a master can occupy the bus and generate one transfer after generating a START condition. The bus now is considered busy before the transfer ends by sending a STOP condition. The master generates Jan. 27, 2018 Page 93 of 205 Rev. 1.02 N76E885 Datasheet all of the serial clock pulses and the START and STOP condition. However if there is no START condition on the bus, all devices serve as not addressed slave. The hardware looks for its own slave address or a General Call address. (The General Call address detection may be enabled or disabled by GC (I2ADDR.0).) If the matched address is received, an interrupt is requested. 2 Every transaction on the I C bus is 9 bits long, consisting of 8 data bits (MSB first) and a single acknowledge bit. The number of bytes per transfer (defined as the time between a valid START and STOP condition) is unrestricted but each byte has to be followed by an acknowledge bit. The master device generates 8 clock pulse to send the 8-bit data. After the 8th falling edge of the SCL line, the device outputting data on the SDA changes that pin to an input and reads in an acknowledge value on the 9th clock pulse. After 9th clock pulse, the data receiving device can hold SCL line stretched low if next receiving is not prepared ready. It forces the next byte transaction suspended. The data transaction continues when the receiver releases the SCL line. SDA MSB LSB ACK 8 9 SCL 1 2 START condition STOP condition 2 Figure 16.2. I C Bus Protocol 16.1.1 START and STOP Condition 2 The protocol of the I C bus defines two states to begin and end a transfer, START (S) and STOP (P) conditions. A START condition is defined as a high-to-low transition on the SDA line while SCL line is high. The STOP condition is defined as a low-to-high transition on the SDA line while SCL line is high. 2 A START or a STOP condition is always generated by the master and I C bus is considered busy after a START condition and free after a STOP condition. After issuing the STOP condition successful, the original master device will release the control authority and turn back as a not addressed slave. 2 Consequently, the original addressed slave will become a not addressed slave. The I C bus is free and listens to next START condition of next transfer. A data transfer is always terminated by a STOP condition generated by the master. However, if a master still wishes to communicate on the bus, it can generate a repeated START (Sr) condition and address the pervious or another slave without first generating a STOP condition. Various combinations of read/write formats are then possible within such a transfer. Jan. 27, 2018 Page 94 of 205 Rev. 1.02 N76E885 Datasheet SDA SCL START Repeated START START STOP STOP Figure 16.3. START, Repeated START, and STOP Conditions 16.1.2 7-Bit Address with Data Format Following the START condition is generated, one byte of special data should be transmitted by the master. It includes a 7-bit long slave address (SLA) following by an 8th bit, which is a data direction bit (R/W), to address the target slave device and determine the direction of data flow. If R/W bit is 0, it indicates that the master will write information to a selected slave. Also, if R/W bit is 1, it indicates that the master will read information from the addressed slave. An address packet consisting of a slave address and a read (R) or a write (W) bit is called SLA+R or SLA+W, respectively. A transmission basically consists of a START condition, a SLA+W/R, one or more data packets and a STOP condition. After the specified slave is addressed by SLA+W/R, the second and following 8-bit data bytes issue by the master or the slave devices according to the R/W bit configuration. There is an exception called “General all” address, which can address all devices by giving the first byte of data all 0. A General Call is used when a master wishes to transmit the same message to several slaves in the system. When this address is used, other devices may respond with an acknowledge or ignore it according to individual software configuration. If a device response the General Call, it operates as like in the slave-receiver mode. Note that the address 0x00 is reserved for 2 General Call and cannot be used as a slave address, therefore, in theory, a 7-bit addressing I C bus accepts 127 devices with their slave addresses 1 to 127. SDA SCL S 1-7 8 9 ADDRESS W/R ACK 1-7 8 DATA 9 1-7 ACK 8 DATA 9 ACK P 2 Figure 16.4. Data Format of One I C Transfer During the data transaction period, the data on the SDA line should be stable during the high period of the clock, and the data line can only change when SCL is low. Jan. 27, 2018 Page 95 of 205 Rev. 1.02 N76E885 Datasheet 16.1.3 Acknowledge The 9th SCL pulse for any transferred byte is dedicated as an Acknowledge (ACK). It allows receiving devices (which can be the master or slave) to respond back to the transmitter (which also can be the master or slave) by pulling the SDA line low. The acknowledge-related clock pulse is generated by the master. The transmitter should release control of SDA line during the acknowledge clock pulse. The ACK is an active-low signal, pulling the SDA line low during the clock pulse high duty, indicates to the transmitter that the device has received the transmitted data. Commonly, a receiver, which has been addressed is requested to generate an ACK after each byte has been received. When a slave receiver does not acknowledge (NACK) the slave address, the SDA line should be left high by the slave so that the mater can generate a STOP or a repeated START condition. If a slave-receiver does acknowledge the slave address, it switches itself to not addressed slave mode and cannot receive any more data bytes. This slave leaves the SDA line high. The master should generate a STOP or a repeated START condition. If a master-receiver is involved in a transfer, because the master controls the number of bytes in the transfer, it should signal the end of data to the slave-transmitter by not generating an acknowledge on the last byte. The slave-transmitter then switches to not addressed mode and releases the SDA line to allow the master to generate a STOP or a repeated START condition. SDA output by transmitter SDA output by receiver SDA = 0, acknowledge (ACK) SDA = 1, not acknowledge (NACK) SCL from master 1 2 8 9 Clock pulse for acknowledge bit START condition Figure 16.5. Acknowledge Bit 16.1.4 Arbitration A master may start a transfer only if the bus is free. It is possible for two or more masters to generate a START condition. In these situations, an arbitration scheme takes place on the SDA line, while SCL is high. During arbitration, the first of the competing master devices to place a '1' (high) on SDA while another master transmits a '0' (low) switches off its data output stage because the level on the bus does not match its own level. The arbitration lost master switches to the not addressed slave immediately to detect its own slave address in the same serial transfer whether it is being addressed Jan. 27, 2018 Page 96 of 205 Rev. 1.02 N76E885 Datasheet by the winning master. It also releases SDA line to high level for not affecting the data transfer continued by the winning master. However, the arbitration lost master continues generating clock pulses on SCL line until the end of the byte in which it loses the arbitration. Arbitration is carried out by all masters continuously monitoring the SDA line after outputting data. If the value read from the SDA line does not match the value that the master has to output, it has lost the arbitration. Note that a master can only lose arbitration when it outputs a high SDA value while another master outputs a low value. Arbitration will continue until only one master remains, and this may take many bits. Its first stage is a comparison of address bits, and if both masters are trying to address the same device, arbitration continues on to the comparison of data bits or acknowledge bit. DATA 1 from master 1 Master 1 loses arbitration for DATA 1 ≠ SDA It immediately switches to not addressed slave and outputs high level DATA 2 from master 2 SDA line SCL line START condition Figure 16.6. Arbitration Procedure of Two Masters 2 Since control of the I C bus is decided solely on the address or master code and data sent by competing masters, there is no central master, nor any order of priority on the bus. Slaves are not involved in the arbitration procedure. 2 16.2 Control Registers of I C 2 There are five control registers to interface the I C bus including I2CON, I2STAT, I2DAT, I2ADDR, and I2CLK. These registers provide protocol control, status, data transmitting and receiving functions, and 2 clock rate configuration. The following registers relate to I C function. Jan. 27, 2018 Page 97 of 205 Rev. 1.02 N76E885 Datasheet 2 I2CON – I C Control (Bit-addressable) 7 6 5 I2CEN STA R/W R/W Address: C0H Bit Name 4 STO R/W 3 SI R/W 2 AA R/W 1 0 Reset value: 0000 0000b Description 7 - 6 I2CEN 5 STA START flag 2 When STA is set, the I C generates a START condition if the bus is free. If the bus 2 is busy, the I C waits for a STOP condition and generates a START condition following. 2 If STA is set while the I C is already in the master mode and one or more bytes 2 have been transmitted or received, the I C generates a repeated START condition. Note that STA can be set anytime even in a slave mode, but STA is not hardware automatically cleared after START or repeated START condition has been detected. User should take care of it by clearing STA manually. 4 STO STOP flag 2 When STO is set if the I C is in the master mode, a STOP condition is transmitted to the bus. STO is automatically cleared by hardware once the STOP condition has been detected on the bus. 2 The STO flag setting is also used to recover the I C device from the bus error 2 state (I2STAT as 00H). In this case, no STOP condition is transmitted to the I C bus. If the STA and STO bits are both set and the device is original in the master 2 mode, the I C bus will generate a STOP condition and immediately follow a START condition. If the device is in slave mode, STA and STO simultaneous 2 setting should be avoid from issuing illegal I C frames. 3 SI I C interrupt flag 2 SI flag is set by hardware when one of 26 possible I C status (besides F8H status) is entered. After SI is set, the software should read I2STAT register to determine which step has been passed and take actions for next step. SI is cleared by software. Before the SI is cleared, the low period of SCL line is stretched. The transaction is suspended. It is useful for the slave device to deal with previous data bytes until ready for receiving the next byte. The serial transaction is suspended until SI is cleared by software. After SI is 2 cleared, I C bus will continue to generate START or repeated START condition, STOP condition, 8-bit data, or so on depending on the software configuration of controlling byte or bits. Therefore, user should take care of it by preparing suitable setting of registers before SI is software cleared. Jan. 27, 2018 Reserved 2 I C bus enable 2 0 = I C bus Disabled. 2 1 = I C bus Enabled. 2 Before enabling the I C, P2.3 and P0.6 port latches should be set to logic 1. 2 Page 98 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 2 AA 1:0 - Description Acknowledge assert flag If the AA flag is set, an ACK (low level on SDA) will be returned during the 2 acknowledge clock pulse of the SCL line while the I C device is a receiver or an own-address-matching slave. If the AA flag is cleared, a NACK (high level on SDA) will be returned during the 2 acknowledge clock pulse of the SCL line while the I C device is a receiver or an own-address-matching slave. A device with its own AA flag cleared will ignore its own salve address and the General Call. Consequently, SI will note be asserted and no interrupt is requested. Note that if an addressed slave does not return an ACK under slave receiver mode or not receive an ACK under slave transmitter mode, the slave device will become a not addressed slave. It cannot receive any data until its AA flag is set and a master addresses it again. There is a special case of I2STAT value C8H occurs under slave transmitter mode. Before the slave device transmit the last data byte to the master, AA flag can be cleared as 0. Then after the last data byte transmitted, the slave device will actively switch to not addressed slave mode of disconnecting with the master. The further reading by the master will be all FFH. Reserved 2 I2STAT – I C Status 7 6 5 I2STAT[7:3] R 4 3 Address: BDH Bit 2 0 R 1 0 0 0 R R Reset value: 1111 1000b Name Description 7:3 I2STAT[7:3] I C status code The MSB five bits of I2STAT contains the status code. There are 27 possible status codes. When I2STAT is F8H, no relevant state information is available 2 and SI flag keeps 0. All other 26 status codes correspond to the I C states. When each of these status is entered, SI will be set as logic 1 and a interrupt is requested. 2:0 0 Jan. 27, 2018 2 Reserved The least significant three bits of I2STAT are always read as 0. Page 99 of 205 Rev. 1.02 N76E885 Datasheet 2 I2DAT – I C Data 7 6 5 4 3 2 1 0 I2DAT[7:0] R/W Address: BCH Bit Reset value: 0000 0000b Name 7:0 I2DAT[7:0] Description 2 I C data 2 I2DAT contains a byte of the I C data to be transmitted or a byte, which has just received. Data in I2DAT remains as long as SI is logic 1. The result of reading 2 or writing I2DAT during I C transceiving progress is unpredicted. While data in I2DAT is shifted out, data on the bus is simultaneously being shifted in to update I2DAT. I2DAT always shows the last byte that presented on 2 the I C bus. Thus the event of lost arbitration, the original value of I2DAT changes after the transaction. 2 I2ADDR – I C Own Slave Address 7 6 5 4 I2ADDR[7:1] R/W 3 Address: C1H Bit Name 7:1 I2ADDR[7:1] 2 1 0 GC R/W Reset value: 0000 0000b Description 2 I C device’s own slave address In master mode: These bits have no effect. In slave mode: 2 These 7 bits define the slave address of this I C device by user. The master 2 should address I C device by sending the same address in the first byte data 2 after a START or a repeated START condition. If the AA flag is set, this I C device will acknowledge the master after receiving its own address and become an addressed slave. Otherwise, the addressing from the master will be ignored. Note that I2ADDR[7:1] should not remain its default value of all 0, because address 0x00 is reserved for General Call. 6 GC General Call bit In master mode: This bit has no effect. In slave mode: 0 = The General Call is always ignored. 1 = The General Call is recognized if AA flag is 1; otherwise, it is ignored if AA is 0. Jan. 27, 2018 Page 100 of 205 Rev. 1.02 N76E885 Datasheet 2 I2CLK – I C Clock 7 6 5 4 3 2 1 0 I2CLK[7:0] R/W Address: BEH Bit 7:0 Reset value: 0000 1110b Name Description I2CLK[7:0] I C clock setting In master mode: 2 This register determines the clock rate of I C bus when the device is in a master mode. The clock rate follows the equation, FSYS 4 × (I2CLK + 1) . 2 The default value will make the clock rate of I C bus 400k bps if the peripheral clock is 24 MHz. Note that the I2CLK value of 00H and 01H are not valid. This is an implement limitation. 2 In slave mode: 2 This byte has no effect. In slave mode, the I C device will automatically synchronize with any given clock rate up to 400k bps. 16.3 Operating Modes 2 In I C protocol definition, there are four operating modes including master transmitter, master receiver, slave receiver, and slave transmitter. There is also a special mode called General Call. Its operating is similar to master transmitter mode. 16.3.1 Master Transmitter Mode In the master transmitter mode, several bytes of data are transmitted to a slave receiver. The master should prepare by setting desired clock rate in I2CLK. The master transmitter mode may now be entered by setting STA (I2CON.5) bit as 1. The hardware will test the bus and generate a START condition as soon as the bus becomes free. After a START condition is successfully produced, the SI flag (I2CON.3) will be set and the status code in I2STAT show 08H. The progress is continued by loading I2DAT with the target slave address and the data direction bit “write” ( A+W). he bit should then be cleared to commence SLA+W transaction. After the SLA+W byte has been transmitted and an acknowledge (ACK) has been returned by the addressed slave device, the SI flag is set again and I2STAT is read as 18H. The appropriate action to be taken follows user defined communication protocol by sending data continuously. After all data is transmitted, the master can send a STOP condition by setting STO (I2CON.4) and then clearing SI to terminate the transmission. A repeated START condition can also be generated without sending STOP condition to immediately initial another transmission. Jan. 27, 2018 Page 101 of 205 Rev. 1.02 N76E885 Datasheet (STA,STO,SI,AA) = (1,0,0,X) A START will be transmitted Normal Arbitration lost 08H A START has been transmitted (STA,STO,SI,AA) = (X,0,0,X) I2DAT = SLA+W SLA+W will be transmitted (STA,STO,SI,AA) = (X,0,0,1) I2DAT = SLA+W SLA+W will be transmitted MT 68H 18H SLA+W has been transmitted ACK has been received OR 20H SLA+W has been transmitted NACK has been received 78H or Arbitration lost and addressed as slave receiver ACK has been transmitted OR B0H Arbitration lost and addressed as slave transmitter ACK has been transmitted to corresponding slave mode (STA,STO,SI,AA)=(0,0,0,X) I2DAT = Data Byte Data byte will be transmitted (STA,STO,SI,AA)=(1,0,0,X) A repeated START will be transmitted 28H 10H Data byte has been transmitted ACK has been received or A repeated START has been transmitted (STA,STO,SI,AA)=(0,1,0,X) A STOP will be transmitted (STA,STO,SI,AA)=(1,1,0,X) A STOP followed by a START will be transmitted A STOP has been transmitted A STOP has been transmitted 30H Data byte has been transmitted NACK has been received 38H Arbitration lost in SLA+W or Data byte (STA,STO,SI,AA) =(0,0,0,X) I2DAT = SLA+R SLA+R will be transmitted (STA,STO,SI,AA)=(0,0,0,X) Not addressed slave will be entered (STA,STO,SI,AA)=(1,0,0,X) A START will be transmitted when the bus becomes free MR to master receiver Figure 16.7. Flow and Status of Master Transmitter Mode 16.3.2 Master Receiver Mode In the master receiver mode, several bytes of data are received from a slave transmitter. The transaction is initialized just as the master transmitter mode. Following the START condition, I2DAT should be loaded with the target slave address and the data direction bit “read” ( A+ ). After the SLA+R byte is transmitted and an acknowledge bit has been returned, the SI flag is set again and I2STAT is read as 40H. SI flag then should be cleared to receive data from the slave transmitter. If AA flag (I2CON.2) is set, the master receiver will acknowledge the slave transmitter. If AA is cleared, the master receiver will not acknowledge the slave and release the slave transmitter as a not addressed Jan. 27, 2018 Page 102 of 205 Rev. 1.02 N76E885 Datasheet slave. After that, the master can generate a STOP condition or a repeated START condition to terminate the transmission or initial another one. (STA,STO,SI,AA) = (1,0,0,X) A START will be transmitted Normal Arbitration lost 08H A START has been transmitted (STA,STO,SI,AA) = (X,0,0,X) I2DAT = SLA+R SLA+R will be transmitted (STA,STO,SI,AA) = (X,0,0,1) I2DAT = SLA+R SLA+R will be transmitted 40H or Arbitration lost and addressed as slave receiver ACK has been transmitted OR MR 68H SLA+R has been transmitted ACK has been received OR 48H 78H B0H SLA+R has been transmitted NACK has been received Arbitration lost and addressed as slave transmitter ACK has been transmitted to corresponding slave mode (STA,STO,SI,AA)=(0,0,0,0) Data byte will be received NACK will be transmitted (STA,STO,SI,AA)=(0,0,0,1) Data byte will be received ACK will be transmitted (STA,STO,SI,AA)=(1,0,0,X) A repeated START will be transmitted 58H 50H 10H Data byte has been received NACK has been transmitted I2DAT = Data Byte Data byte has been received ACK has been transmitted I2DAT = Data Byte A repeated START has been transmitted (STA,STO,SI,AA)=(0,1,0,X) A STOP will be transmitted (STA,STO,SI,AA)=(1,1,0,X) A STOP followed by a START will be transmitted A STOP has been transmitted A STOP has been transmitted 38H Arbitration lost in NACK bit (STA,STO,SI,AA) =(0,0,0,X) I2DAT = SLA+W SLA+W will be transmitted (STA,STO,SI,AA)=(0,0,0,X) Not addressed slave will be entered (STA,STO,SI,AA)=(1,0,0,X) A START will be transmitted when the bus becomes free MT to master transmitter Figure 16.8. Flow and Status of Master Receiver Mode 16.3.3 Slave Receiver Mode In the slave receiver mode, several bytes of data are received form a master transmitter. Before a transmission is commenced, I2ADDR should be loaded with the address to which the device will respond when addressed by a master. I2CLK does not affect in slave mode. The AA bit should be set 2 to enable acknowledging its own slave address. After the initialization above, the I C idles until it is Jan. 27, 2018 Page 103 of 205 Rev. 1.02 N76E885 Datasheet addressed by its own address with the data direction bit “write” ( A+W). he slave receiver mode may also be entered if arbitration is lost. After the slave is addressed by SLA+W, it should clear its SI flag to receive the data from the master transmitter. If the AA bit is 0 during a transaction, the slave will return a non-acknowledge after the next received data byte. The slave will also become not addressed and isolate with the master. It cannot receive any byte of data with I2DAT remaining the previous byte of data, which is just received. (STA,STO,SI,AA) = (0,0,0,1) If own SLA+W is received, ACK will be transmitted 60H Own SLA+W has been received ACK has been transmitted I2DAT = own SLA+W OR 68H Arbitration lost and own SLA+W has been received ACK has been transmitted I2DAT = own SLA+W (STA,STO,SI,AA)=(X,0,0,1) Data byte will be received ACK will be transmitted (STA,STO,SI,AA)=(X,0,0,0) Data byte will be received NACK will be transmitted (STA,STO,SI,AA)=(X,0,0,X) A STOP or repeated START will be received 80H 88H A0H Data byte has been received ACK has been transmitted I2DAT = Data Byte Data byte has been received NACK has been transmitted I2DAT = Data Byte A STOP or repeated START has been received (STA,STO,SI,AA)=(0,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1 (STA,STO,SI,AA)=(1,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call; A START will be transmitted when the bus becomes free (STA,STO,SI,AA)=(0,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call (STA,STO,SI,AA)=(1,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1; A START will be transmitted when the bus becomes free Figure 16.9. Flow and Status of Slave Receiver Mode 16.3.4 Slave Transmitter Mode In the slave transmitter mode, several bytes of data are transmitted to a master receiver. After 2 I2ADDR and I2CON values are given, the I C wait until it is addressed by its own address with the data direction bit “read” ( A+ ). he slave transmitter mode may also be entered if arbitration is lost. After the slave is addressed by SLA+R, it should clear its SI flag to transmit the data to the master receiver. Normally the master receiver will return an acknowledge after every byte of data is transmitted by the slave. f the acknowledge is not received, it will transmit all “ ” data if it continues the transaction. It becomes a not addressed slave. If the AA flag is cleared during a transaction, the Jan. 27, 2018 Page 104 of 205 Rev. 1.02 N76E885 Datasheet slave transmits the last byte of data. he next transmitting data will be all “ ” and the slave becomes not addressed. (STA,STO,SI,AA) = (0,0,0,1) If own SLA+R is received, ACK will be transmitted A8H Own SLA+R has been received ACK has been transmitted I2DAT = own SLA+R OR B0H Arbitration lost and own SLA+R has been received ACK has been transmitted I2DAT = own SLA+R (STA,STO,SI,AA)=(X,0,0,1) I2DAT = Data Byte Data byte will be transmitted ACK will be received (STA,STO,SI,AA)=(X,0,0,X) I2DAT = Data Byte Data byte will be transmitted NACK will be received (STA,STO,SI,AA)=(X,0,0,0) I2DAT = Last Data Byte Last data byte will be transmitted ACK will be received (STA,STO,SI,AA)=(X,0,0,X) A STOP or repeated START will be received B8H C0H C8H A0H Data byte has been transmitted ACK has been received Data byte has been transmitted NACK has been received Last Data byte has been transmitted ACK has been received A STOP or repeated START has been received * (STA,STO,SI,AA)=(0,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call (STA,STO,SI,AA)=(0,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1 (STA,STO,SI,AA)=(1,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call; A START will be transmitted when the bus becomes free flow is not recommended. If the MSB of next byte which the Slave is going to transmit is 0, it * This will hold SDA line. The STOP or repeated START cannot be successfully generated by Master. (STA,STO,SI,AA)=(1,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1; A START will be transmitted when the bus becomes free Figure 16.10. Flow and Status of Slave Transmitter Mode 16.3.5 General Call he General all is a special condition of slave receiver mode by been addressed with all “ ” data in slave address with data direction bit. Both GC (I2ADDR.0) bit and AA bit should be set as 1 to enable acknowledging General Calls. The slave addressed by a General Call has different status code in I2STAT with normal slave receiver mode. The General Call may also be produced if arbitration is lost. Jan. 27, 2018 Page 105 of 205 Rev. 1.02 N76E885 Datasheet (STA,STO,SI,AA) = (0,0,0,1) GC = 1 If General Call is received, ACK will be transmitted 70H General Call has been received ACK has been transmitted I2DAT = 00H OR 78H Arbitration lost and General Call has been received ACK has been transmitted I2DAT = 00H (STA,STO,SI,AA)=(X,0,0,1) Data byte will be received ACK will be transmitted (STA,STO,SI,AA)=(X,0,0,0) Data byte will be received NACK will be transmitted (STA,STO,SI,AA)=(X,0,0,X) A STOP or repeated START will be received 90H 98H A0H Data byte has been received ACK has been transmitted I2DAT = Data Byte Data byte has been received NACK has been transmitted I2DAT = Data Byte A STOP or repeated START has been received (STA,STO,SI,AA)=(0,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1 (STA,STO,SI,AA)=(1,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call; A START will be transmitted when the bus becomes free (STA,STO,SI,AA)=(0,0,0,0) Not addressed slave will be entered; no recognition of own SLA or General Call (STA,STO,SI,AA)=(1,0,0,1) Not addressed slave will be entered; own SLA will be recognized; General Call will be recognized if GC = 1; A START will be transmitted when the bus becomes free Figure 16.11. Flow and Status of General Call Mode 16.3.6 Miscellaneous States There are two I2STAT status codes that do not correspond to the 25 defined states, which are mentioned in previous sections. These are F8H and 00H states. The first status code F8H indicates that no relevant information is available during each transaction. 2 Meanwhile, the SI flag is 0 and no I C interrupt is required. The other status code 00H means a bus error has occurred during a transaction. A bus error is caused by a START or STOP condition appearing temporally at an illegal position such as the second through eighth bits of an address or a data byte, and the acknowledge bit. When a bus error occurs, the SI flag 2 is set immediately. When a bus error is detected on the I C bus, the operating device immediately switches to the not addressed salve mode, releases SDA and SCL lines, sets the SI flag, and loads I2STAT as 00H. To recover from a bus error, the STO bit should be set and then SI should be cleared. 2 After that, STO is cleared by hardware and release the I C bus without issuing a real STOP condition 2 waveform on I C bus. Jan. 27, 2018 Page 106 of 205 Rev. 1.02 N76E885 Datasheet There is a special case if a START or a repeated START condition is not successfully generated for 2 I C bus is obstructed by a low level on SDA line e.g. a slave device out of bit synchronization, the 2 problem can be solved by transmitting additional clock pulses on the SCL line. The I C hardware transmits additional clock pulses when the STA bit is set, but no START condition can be generated because the SDA line is pulled low. When the SDA line is eventually released, a normal START condition is transmitted, state 08H is entered, and the serial transaction continues. If a repeated 2 START condition is transmitted while SDA is obstructed low, the I C hardware also performs the same action as above. In this case, state 08H is entered instead of 10H after a successful START condition is transmitted. Note that the software is not involved in solving these bus problems. 2 16.4 Typical Structure of I C Interrupt Service Routine The following software example in C language for KEIL TM C51 compiler shows the typical structure of 2 the I C interrupt service routine including the 26 state service routines and may be used as a base for user applications. User can follow or modify it for their own application. If one or more of the five modes are not used, the associated state service routines may be removed, but care should be taken that a deleted routine can never be invoked. void I2C_ISR (void) interrupt 6 { switch (I2STAT) { //=============================================== //Bus Error, always put in ISR for noise handling //=============================================== case 0x00: /*00H, bus error occurs*/ STO = 1; //recover from bus error break; //=========== //Master Mode //=========== case 0x08: /*08H, a START transmitted*/ STA = 0; //STA bit should be cleared by software I2DAT = SLA_ADDR1; //load SLA+W/R break; case 0x10: /*10H, a repeated START transmitted*/ STA = 0; I2DAT = SLA_ADDR2; break; //======================= //Master Transmitter Mode //======================= case 0x18: /*18H, SLA+W transmitted, ACK received*/ I2DAT = NEXT_SEND_DATA1; //load DATA break; Jan. 27, 2018 Page 107 of 205 Rev. 1.02 N76E885 Datasheet case 0x20: /*20H, SLA+W transmitted, NACK received*/ STO = 1; AA = 1; //transmit STOP //ready for ACK own SLA+W/R or General Call break; case 0x28: /*28H, DATA transmitted, ACK received*/ if (Conti_TX_Data) //if continuing to send DATA I2DAT = NEXT_SEND_DATA2; else //if no DATA to be sent { STO = 1; AA = 1; } break; case 0x30: /*30H, DATA transmitted, NACK received*/ STO = 1; AA = 1; break; //=========== //Master Mode //=========== case 0x38: STA = 1; break; //==================== //Master Receiver Mode //==================== case 0x40: /*38H, arbitration lost*/ //retry to transmit START if bus free /*40H, SLA+R transmitted, ACK received*/ AA = 1; break; case 0x48: //ACK next received DATA /*48H, SLA+R transmitted, NACK received*/ STO = 1; AA = 1; break; case 0x50: /*50H, DATA received, ACK transmitted*/ DATA_RECEIVED1 = I2DAT; if (To_RX_Last_Data1) AA = 0; else AA = 1; break; case 0x58: //store received DATA //if last DATA will be received //not ACK next received DATA //if continuing receiving DATA /*58H, DATA received, NACK transmitted*/ DATA_RECEIVED_LAST1 = I2DAT; STO = 1; AA = 1; break; //==================================== //Slave Receiver and General Call Mode //==================================== case 0x60: /*60H, own SLA+W received, ACK returned*/ AA = 1; break; Jan. 27, 2018 Page 108 of 205 Rev. 1.02 N76E885 Datasheet case 0x68: /*68H, arbitration lost in SLA+W/R own SLA+W received, ACK returned */ //not ACK next received DATA after //arbitration lost //retry to transmit START if bus free AA = 0; STA = 1; break; case 0x70: /*70H, General Call received, ACK returned */ AA = 1; break; case 0x78: /*78H, arbitration lost in SLA+W/R General Call received, ACK returned*/ AA = 0; STA = 1; break; case 0x80: /*80H, previous own SLA+W, DATA own SLA+W, DATA received, ACK returned*/ DATA_RECEIVED2 = I2DAT; if (To_RX_Last_Data2) AA = 0; else AA = 1; break; case 0x88: /*88H, previous received, NACK returned, not addressed SLAVE mode entered*/ DATA_RECEIVED_LAST2 = I2DAT; AA = 1; //wait for ACK next Master addressing break; case 0x90: /*90H, previous General Call, DATA received, ACK returned*/ DATA_RECEIVED3 = I2DAT; if (To_RX_Last_Data3) AA = 0; else AA = 1; break; case 0x98: /*98H, previous General Call, DATA received, NACK returned, not addressed SLAVE mode entered*/ DATA_RECEIVED_LAST3 = I2DAT; AA = 1; break; //========== //Slave Mode //========== case 0xA0: /*A0H, STOP or repeated received while still addressed SLAVE mode*/ AA = 1; break; Jan. 27, 2018 Page 109 of 205 START Rev. 1.02 N76E885 Datasheet //====================== //Slave Transmitter Mode //====================== case 0xA8: /*A8H, own SLA+R received, ACK returned*/ I2DAT = NEXT_SEND_DATA3; AA = 1; break; case 0xB0: //when AA is “1”, not last data to be //transmitted /*B0H, arbitration lost in SLA+W/R own SLA+R received, ACK returned */ I2DAT = DUMMY_DATA; AA = 0; STA = 1; break; case 0xB8: //when AA is “0”, last data to be //transmitted //retry to transmit START if bus free /*B8H, previous own SLA+R, DATA transmitted, ACK received*/ I2DAT = NEXT_SEND_DATA4; if (To_TX_Last_Data) AA = 0; else AA = 1; break; case 0xC0: //if last DATA will be transmitted /*C0H, previous own SLA+R, DATA transmitted, NACK received, not addressed SLAVE mode entered*/ AA = 1; break; case 0xC8: /*C8H, previous own SLA+R, last DATA transmitted, ACK received, not addressed SLAVE AA = 1; break; }//end of switch (I2STAT) SI = 0; I2C ISR while(STO); error mode entered*/ //SI should be the last command of //wait for STOP transmitted or bus //free, STO is cleared by hardware }//end of I2C_ISR 2 16.5 I C Time-Out 2 There is a 14-bit time-out counter, which can be used to deal with the I C bus hang-up. If the time-out counter is enabled, the counter starts up counting until it overflows. Meanwhile I2TOF will be set by 2 hardware and requests I C interrupt. When time-out counter is enabled, setting flag SI to high will 2 reset counter and restart counting up after SI is cleared. If the I C bus hangs up, it causes the SI flag not set for a period. The 14-bit time-out counter will overflow and require the interrupt service. Jan. 27, 2018 Page 110 of 205 Rev. 1.02 N76E885 Datasheet 0 FSYS 1/4 14-bit I2C Time-out Counter 1 I2TOF Clear Counter DIV I2CEN I2TOCEN SI 2 Figure 16.12. I C Time-Out Counter 2 I2TOC – I C Time-out Counter 7 6 Address: BFH Bit 5 - 4 - Name Description 2 I2TOCEN I C time-out counter enable 2 0 = I C time-out counter Disabled. 2 1 = I C time-out counter Enabled. 1 DIV 0 I2TOF 3 - 2 I2TOCEN R/W 1 0 DIV I2TOF R/W R/W Reset value: 0000 0000b 2 2 I C time-out counter clock divider 2 0 = The clock of I C time-out counter is FSYS/1. 2 1 = The clock of I C time-out counter is FSYS/4. 2 I C time-out flag 2 This flag is set by hardware if 14-bit I C time-out counter overflows. It is cleared by software. 2 16.6 I C Interrupt 2 2 There are two I C flags, SI and I2TOF. Both of them can generate an I C event interrupt requests. If 2 2 I C interrupt mask is enabled via setting EI2C (EIE.0) and EA as 1, CPU will execute the I C interrupt service routine once any of these two flags is set. User needs to check flags to determine what event 2 caused the interrupt. Both of I C flags are cleared by software. Jan. 27, 2018 Page 111 of 205 Rev. 1.02 N76E885 Datasheet 17. PIN INTERRUPT The N76E885 provides pin interrupt input for each I/O pin to detect pin state if button or keypad set is used. A maximum 8-channel pin interrupt detection can be assigned by I/O port sharing. The pin interrupt is generated when any key is pressed on a keyboard or keypad, which produces an edge or level triggering event. Pin interrupt may be used to wake the CPU up from Idle or Power-down mode. Each channel of pin interrupt can be enabled and polarity controlled independently by PIPEN and PINEN register. PICON selects which port that the pin interrupt is active. It also defines which type of pin interrupt is used - level detect or edge detect. Each channel also has its own interrupt flag. There are total eight pin interrupt flags located in PIF register. The respective flags for each pin interrupt channel allow the interrupt service routine to poll on which channel on which the interrupt event occurs. All flags in PIF register are set by hardware and should be cleared by software. PIPS[1:0] (PICON[1:0]) P0.0 P1.0 P2.0 P3.0 00 01 10 11 0 PIT0 PIF0 1 PINEN0 Pin Interrupt Channel 0 P0.1 P1.1 P2.1 P3.1 PIPEN0 00 01 10 11 0 PIT1 PIF1 1 PINEN1 Pin Interrupt Channel 1 PIPEN1 Pin Interrupt P0.7 Reserved Reserved P3.7 00 01 10 11 0 PIT67 PIF7 1 PINEN7 Pin Interrupt Channel 7 PIPEN7 Figure 17.1. Pin Interface Block Diagram Jan. 27, 2018 Page 112 of 205 Rev. 1.02 N76E885 Datasheet Pin interrupt is generally used to detect an edge transient from peripheral devices like keyboard or keypad. During idle state, the system prefers to enter Power-down mode to minimize power consumption and waits for event trigger. Pin interrupt can wake up the device from Power-down mode. PICON – Pin Interrupt Control 7 6 5 PIT67 PIT45 PIT3 R/W R/W R/W Address: E9H Bit Name 4 PIT2 R/W 3 PIT1 R/W 2 PIT0 R/W 1 0 PIPS[1:0] R/W Reset value: 0000 0000b Description 7 PIT67 Pin interrupt channel 6 and 7 type select This bit selects which type that pin interrupt channel 6 and 7 is triggered. 0 = Level triggered. 1 = Edge triggered. 6 PIT45 Pin interrupt channel 4 and 5 type select This bit selects which type that pin interrupt channel 4 and 5 is triggered. 0 = Level triggered. 1 = Edge triggered. 5 PIT3 Pin interrupt channel 3 type select This bit selects which type that pin interrupt channel 3 is triggered. 0 = Level triggered. 1 = Edge triggered. 4 PIT2 Pin interrupt channel 2 type select This bit selects which type that pin interrupt channel 2 is triggered. 0 = Level triggered. 1 = Edge triggered. 3 PIT1 Pin interrupt channel 1 type select This bit selects which type that pin interrupt channel 1 is triggered. 0 = Level triggered. 1 = Edge triggered. 2 PIT0 Pin interrupt channel 0 type select This bit selects which type that pin interrupt channel 0 is triggered. 0 = Level triggered. 1 = Edge triggered. 1:0 PIPS[:0] Jan. 27, 2018 Pin interrupt port select This field selects which port is active as the 8-channel of pin interrupt. 00 = Port 0. 01 = Port 1. 10 = Port 2. 11 = Port 3. Page 113 of 205 Rev. 1.02 N76E885 Datasheet PINEN – Pin Interrupt Negative Polarity Enable. 7 6 5 4 PINEN7 PINEN6 PINEN5 PINEN4 R/W R/W R/W R/W Address: EAH Bit Name n PINENn Name n PIPENn PIF – Pin Interrupt Flags 7 6 PIF7 PIF6 R (level) R (level) R/W (edge) R/W (edge) Address: ECH Bit Name n Jan. 27, 2018 PIFn 2 PINEN2 R/W 1 0 PINEN1 PINEN0 R/W R/W Reset value: 0000 0000b Description Pin interrupt channel n negative polarity enable This bit enables low-level/falling edge triggering pin interrupt channel n. The level or edge triggered selection depends on each control bit PITn in PICON. 0 = Low-level/falling edge detect Disabled. 1 = Low-level/falling edge detect Enabled. PIPEN – Pin Interrupt Positive Polarity Enable. 7 6 5 4 PIPEN7 PIPEN6 PIPEN5 PIPEN4 R/W R/W R/W R/W Address: EBH Bit 3 PINEN3 R/W 3 PIPEN3 R/W 2 PIPEN2 R/W 1 0 PIPEN1 PIPEN0 R/W R/W Reset value: 0000 0000b Description Pin interrupt channel n positive polarity enable This bit enables high-level/rising edge triggering pin interrupt channel n. The level or edge triggered selection depends on each control bit PITn in PICON. 0 = High-level/rising edge detect Disabled. 1 = High-level/rising edge detect Enabled. 5 PIF5 R (level) R/W (edge) 4 PIF4 R (level) R/W (edge) 3 PIF3 R (level) R/W (edge) 2 PIF2 R (level) R/W (edge) 1 0 PIF1 PIF0 R (level) R (level) R/W (edge) R/W (edge) Reset value: 0000 0000b Description Pin interrupt channel n flag If the edge trigger is selected, this flag will be set by hardware if the channel n of pin interrupt detects an enabled edge trigger. This flag should be cleared by software. f the level trigger is selected, this flag follows the inverse of the input signal’s logic level on the channel n of pin interrupt. Software cannot control it. Page 114 of 205 Rev. 1.02 N76E885 Datasheet 18. PULSE WIDTH MODULATED (PWM) The PWM (Pulse Width Modulation) signal is a useful control solution in wide application field. It can used on motor driving, fan control, backlight brightness tuning, LED light dimming, or simulating as a simple digital to analog converter output through a low pass filter circuit. The N76E885 PWM is especially designed for motor control by providing four pairs, maximum 12-bit resolution of PWM output with programmable period and duty. The architecture makes user easy to drive the one-phase or three-phase brushless DC motor (BLDC), or three-phase AC induction motor. Each of four PWM pair can be configured as one of independent mode, complementary mode, or synchronous mode. If the complementary mode is used, a programmable dead-time insertion is available to protect MOS turn-on simultaneously. The PWM waveform can be edge-aligned or centeraligned with variable interrupt points. 18.1 Functional Description 18.1.1 PWM Generator The PWM generator is clocked by the system clock or Timer 1 overflow divided by a PWM clock prescalar selectable from 1/1~1/128. The PWM period is defined by effective 12-bit period registers, {PWMPH, PWMPL}. The period is the same for all PWM channels for they share the same 12-bit period counter. The duty of each PWM pair is determined independently by the value of duty registers {PWM01H, PWM01L}, {PWM23H, PWM23L}, {PWM45H, PWM45L}, and {PWM67H, PWM67L}. With four duty registers, four pairs of PWM output can be generated independently with different duty cycles. The interval and duty of PWM signal is generated by a 12-bit counter comparing with the period and duty registers. To facilitate the three-phase motor control, a group mode can be used by setting GP (PWMCON1.5), which makes {PWM01H, PWM01L} duty register decide duties of the first three-pair PWM outputs. In a three-phase motor control application, three-pair PWM outputs generally are given the same duty cycle. When the group mode is enabled, {PWM23H, PWM23L} and {PWM45H, PWM45L} registers have no effect. Note that enabling PWM does not configure the I/O pins into their output mode automatically. User should configure I/O output mode via software manually. Jan. 27, 2018 Page 115 of 205 Rev. 1.02 N76E885 Datasheet 12-bit PWMP registers 0-to-1 LOAD (PWMCON0.6) PWMP buffer PWMRUN (PWMCON0.7) FPWM INTSEL[1:0], INTTYP[1:0] (PWMCON0[3:0]) CLRPWM (PWMCON0.4) 12-bit up/down counter edge/center Counter matching (edge aligned)/ underflow (center aligned) Interrupt select/type PWMF PWM interrupt clear counter PWMTYP (PWMCON1.4) FSYS Timer 1 overflow 0 1 Pre-scalar PWMDIV[2:0] PWMCKS (PWMCON1[2:0]) (CKCON.6) PG01 = PWM0/P1.0 PWM1/P1.1 PWM01 buffer PWM01 registers = 12-bit 0 PWM and Fault Brake output control PWM23 buffer PWM23 registers = 12-bit 0 PWM2/P0.2 PG23 1 PWM3/P0.3 PWM4/P0.5 PG45 1 PWM5/P0.6 PWM45 buffer GP (PWMCON1.5) PWM45 registers = 12-bit PWM6/P0.7 PG67 PWM7/P2.6 PWM67 buffer Brake event PWM67 registers 12-bit Figure 18.1. PWM Block Diagram The PWM counter generates four PWM signals called PG01, PG23, PG45, and PG67. These signals will go through the PWM and Fault Brake output control circuit. It generates real PWM outputs on I/O pins. The output control circuit determines the PWM mode, dead-time insertion, mask output, Fault Brake control, and PWM polarity. The last stage is a multiplexer of PWM output or I/O function. User should set the PIOn bit to make the corresponding pin function as PWM output. Meanwhile, the general purpose I/O function can be used. Jan. 27, 2018 Page 116 of 205 Rev. 1.02 N76E885 Datasheet PWM and Fault Brake output control PWM mode select Dead time insertion PG0 PG01 PWM0/1 mode PG1 Mask output PG0_DT PMD0 PWM0/1 dead time Brake control 0 1 PMEN0 FBD0 PWM nagative polarity 0 0 1 1 PNP0 PG1_DT PMD1 0 1 PMEN1 FBD1 0 PG2 PWM2/3 mode PG45 PWM4/5 mode PG3 PG4 PG5 PG6 PG67 PWM6/7 mode PG7 PWM2/3 dead time PWM4/5 dead time PWM6/7 dead time 0 1 1 0 PWM0 1 P1.1 0 PWM1 1 PIO1 PG2_DT PWM2 PWM3 PG3_DT PG4_DT PG5_DT FBD5 PWM4 PWM5 0 1 PG6_DT PG7_DT PMD7 0 0 1 1 PMEN7 PWMMOD[1:0] (PWMCON1[7:6]) P1.0 PIO0 PNP1 PG23 PWM I/O switch PNP7 P2.6 PWM6 PWM7 0 1 PIO7 PDTEN, PDTCNT Brake event Figure 18.2. PWM and Fault Brake Output Control Block Diagram User should follow the initialization steps below to start generating the PWM signal output. In the first step by setting CLRPWM (PWMCON0.4), it ensures the 12-bit up counter reset for the accuracy of the first duration. After initialization and setting {PWMPH, PWMPL} and all {PWMnH, PWMnL} registers, PWMRUN (PWMCON0.7) can be set as logic 1 to trigger the 12-bit counter running. PWM starts to generate waveform on its output pins. The hardware for all period and duty control registers are double buffered designed. Therefore, {PWMPH, PWMPL} and all {PWMnH, PWMnL} registers can be written to at any time, but the period and duty cycle of PWM will not be updated immediately until the Load (PWMCON0.6) is set and previous period is complete. This prevents glitches when updating the PWM period or duty. A loading of new period and duty by setting LOAD should be ensured complete by monitoring it and waiting for a hardware automatic clearing LOAD bit. Any updating of PWM control registers during LOAD bit as logic 1 will cause unpredictable output. Jan. 27, 2018 Page 117 of 205 Rev. 1.02 N76E885 Datasheet PWMCON0 – PWM Control 0 (Bit-addressable) 7 6 5 4 PWMRUN LOAD PWMF CLRPWM R/W R/W R/W R/W Address: D8H Bit Name 7 PWMRUN 6 LOAD 3 INTTYP1 R/W 2 INTTYP0 R/W 1 0 INTSEL1 INTSEL0 R/W R/W Reset value: 0000 0000b Description PWM run enable 0 = PWM stays in idle. 1 = PWM starts running. PWM new period and duty load This bit is used to load period and duty control registers in their buffer if new period or duty value needs to be updated. The loading will act while a PWM period is completed. The new period and duty affect on the next PWM cycle. After the loading is complete, LOAD will be automatically cleared via hardware. The meaning of writing and reading LOAD bit is different. Writing: 0 = No effect. 1 = Load new period and duty in their buffers while a PWM period is completed. Reading: 0 = A loading of new period and duty is finished. 1 = A loading of new period and duty is not yet finished. 5 PWMF 4 CLRPWM PWM flag This flag is set according to definitions of INTSEL[1:0] and INTTYP[1:0] in PWMCON1. This bit is cleared by software. Clear PWM counter Setting this bit clears the value of PWM 12-bit counter for resetting to 000H. After the counter value is cleared, CLRPWM will be automatically cleared via hardware. The meaning of writing and reading CLRPWM bit is different. Writing: 0 = No effect. 1 = Clearing PWM 12-bit counter. Reading: 0 = PWM 12-bit counter is completely cleared. 1 = PWM 12-bit counter is not yet cleared. PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit Name 5 Jan. 27, 2018 GP 4 PWMTYP R/W 3 FBINEN R/W 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Description Group mode enable This bit enables the group mode. If enabled, the duty of first three pairs of PWM are decided by PWM01H and PWM01L rather than their original duty control registers. 0 = Group mode Disabled. 1 = Group mode Enabled. Page 118 of 205 Rev. 1.02 N76E885 Datasheet Bit 2:0 Name Description PWMDIV[2:0] PWM clock divider This field decides the pre-scale of PWM clock source. 000 = 1/1. 001 = 1/2 010 = 1/4. 011 = 1/8. 100 = 1/16. 101 = 1/32. 110 = 1/64. 111 = 1/128. CKCON – Clock Control 7 6 PWMCKS R/W Address: 8EH Bit 6 5 - 4 T1M R/W 3 T0M R/W 2 - Name Description PWMCKS PWM clock source select 0 = The clock source of PWM is the system clock FSYS. 1 = The clock source of PWM is the overflow of Timer 1. PWMPL – PWM Period Low Byte 7 6 5 4 3 2 1 0 Reset value: 0000 0000b 1 0 PWMP[7:0] R/W Address: D9H Bit 7:0 reset value: 0000 0000b Name PWMP[7:0] Description PWM period low byte This byte with PWMPH controls the period of the PWM generator signal. PWMPH – PWM Period High Byte 7 6 5 Address: D1H Bit 3:0 Jan. 27, 2018 4 - 3 2 1 0 PWMP[11:8] R/W reset value: 0000 0000b Name Description PWMP[11:8] PWM period high byte This byte with PWMPL controls the period of the PWM generator signal. Page 119 of 205 Rev. 1.02 N76E885 Datasheet PWM01L – PWM0/1 Duty Low Byte 7 6 5 4 3 2 1 0 PWM01[7:0] R/W Address: DAH Bit 7:0 reset value: 0000 0000b Name Description PWM01[7:0] PWM0/1 duty low byte This byte with PWM01H controls the duty of the output signal PG01 from PWM generator. PWM01H – PWM0/1 Duty High Byte 7 6 5 Address: D2H Bit 3:0 4 - 3 2 1 0 PWM01[11:8] R/W reset value: 0000 0000b Name Description PWM01[11:8] PWM0/1 duty high byte This byte with PWM01L controls the duty of the output signal PG01 from PWM generator. PWM23L – PWM2/3 Duty Low Byte 7 6 5 4 3 2 1 0 PWM23[7:0] R/W Address: DBH Bit 7:0 reset value: 0000 0000b Name Description PWM23[7:0] PWM2/3 duty low byte This byte with PWM23H controls the duty of the output signal PG23 from PWM generator. PWM23H – PWM2/3 Duty High Byte 7 6 5 Address: D3H Bit 3:0 Jan. 27, 2018 4 - 3 2 1 0 PWM23[11:8] R/W reset value: 0000 0000b Name Description PWM23[11:8] PWM2/3 duty high byte This byte with PWM23L controls the duty of the output signal PG23 from PWM generator. Page 120 of 205 Rev. 1.02 N76E885 Datasheet PWM45L – PWM4/5 Duty Low Byte 7 6 5 4 3 2 1 0 PWM45[7:0] R/W Address: DDH Bit 7:0 reset value: 0000 0000b Name Description PWM45[7:0] PWM4/5 duty low byte This byte with PWM45H controls the duty of the output signal PG45 from PWM generator. PWM45H – PWM4/5 Duty High Byte 7 6 5 Address: D5H Bit 3:0 4 - 3 2 1 0 PWM45[11:8] R/W reset value: 0000 0000b Name Description PWM45[11:8] PWM4/5 duty high byte This byte with PWM45L controls the duty of the output signal PG45 from PWM generator. PWM67L – PWM6/7 Duty Low Byte 7 6 5 4 3 2 1 0 PWM67[7:0] R/W Address: DCH Bit 7:0 reset value: 0000 0000b Name Description PWM67[7:0] PWM6/7 duty low byte This byte with PWM67H controls the duty of the output signal PG67 from PWM generator. PWM67H – PWM6/7 Duty High Byte 7 6 5 Address: D4H Bit 3:0 Jan. 27, 2018 4 - 3 2 1 0 PWM67[11:8] R/W reset value: 0000 0000b Name Description PWM67[11:8] PWM6/7 duty high byte This byte with PWM67L controls the duty of the output signal PG67 from PWM generator. Page 121 of 205 Rev. 1.02 N76E885 Datasheet PIO – PWM or I/O Select 7 6 PIO7 PIO6 R/W R/W Address: DEH Bit Name 5 PIO5 R/W 4 PIO4 R/W 3 PIO3 R/W 2 PIO2 R/W 1 0 PIO1 PIO0 R/W R/W Reset value: 0000 0000b Description 7 PIO7 P2.6/PWM7 pin function select 0 = P2.6/PWM7 pin functions as P2.6. 1 = P2.6/PWM7 pin functions as PWM7 output. 6 PIO6 P0.7/PWM6 pin function select 0 = P0.7/PWM6 pin functions as P0.7. 1 = P0.7/PWM6 pin functions as PWM6 output. 5 PIO5 P0.6/PWM5 pin function select 0 = P0.6/PWM5 pin functions as P0.6. 1 = P0.6/PWM5 pin functions as PWM5 output. 4 PIO4 P0.5/PWM4 pin function select 0 = P0.5/PWM4 pin functions as P0.5. 1 = P0.5/PWM4 pin functions as PWM4 output. 3 PIO3 P0.3/PWM3 pin function select 0 = P0.3/PWM3 pin functions as P0.3. 1 = P0.3/PWM3 pin functions as PWM3 output. 2 PIO2 P0.2/PWM2 pin function select 0 = P0.2/PWM2 pin functions as P0.2. 1 = P0.2/PWM2 pin functions as PWM2 output. 1 PIO1 P1.1/PWM1 pin function select 0 = P1.1/PWM1 pin functions as P1.1. 1 = P1.1/PWM1 pin functions as PWM1 output. 0 PIO0 P1.0/PWM0 pin function select 0 = P1.0/PWM0 pin functions as P1.0. 1 = P1.0/PWM0 pin functions as PWM0 output. 18.1.2 PWM Types The PWM generator provides two PWM types: edge-aligned or center-aligned. PWM type is selected by PWMTYP (PWMCON1.4). PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit Name 4 Jan. 27, 2018 PWMTYP 4 PWMTYP R/W 3 FBINEN R/W 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Description PWM type select 0 = Edge-aligned PWM. 1 = Center-aligned PWM. Page 122 of 205 Rev. 1.02 N76E885 Datasheet 18.1.2.1 Edge-Aligned Type In edge-aligned mode, the 12-bit counter uses single slop operation by counting up from 000H to {PWMPH, PWMPL} and then starting from 000H. The PWM generator signal (PGn before PWM and Fault Brake output control) is cleared on the compare match of 12-bit counter and the duty register {PWMnH, PWMnL} and set at the 12-bit counter is 000H. The result PWM output waveform is leftedge aligned. PWMP (2nd) PWMP (1st) 12-bit counter PWM01 (2nd) PWM01 (1st) PWM01 (2nd) duty valid PG01 output PWMP (2nd) period valid Load PWM01 (2nd) Load PWMP (2nd) Figure 18.3. PWM Edge-aligned Type Waveform The output frequency and duty cycle for edge-aligned PWM are given by following equations: PWM frequency = FPWM (FPWM is the PWM clock source frequency divided by {PWMPH,PWMPL}  1 PWMDIV). PWM high level duty = {PWMnH,PWMnL} . {PWMPH,PWMPL}  1 18.1.2.2 Center-Aligned Type In center-aligned mode, the 12-bit counter use dual slop operation by counting up from 000H to {PWMPH, PWMPL} and then counting down from {PWMPH, PWMPL} to 000H. The PGn signal is cleared on the up-count compare match of 12-bit counter and the duty register {PWMnH, PWMnL} and set on the down-count compare match. Center-aligned PWM may be used to generate nonoverlapping waveforms. Jan. 27, 2018 Page 123 of 205 Rev. 1.02 N76E885 Datasheet PWMP (2nd) PWMP (1st) 12-bit counter PWM01 (2nd) PWM01 (1st) PWM01 (2nd) duty valid PG01 output PWMP (2nd) period valid Load PWM01 (2nd) Load PWMP (2nd) Figure 18.4. PWM Center-aligned Type Waveform The output frequency and duty cycle for center-aligned PWM are given by following equations: PWM frequency = FPWM (FPWM is the PWM clock source frequency divided by 2 × {PWMPH,PWMPL} PWMDIV). PWM high level duty = {PWMnH,PWMnL} . {PWMPH,PWMPL} 18.1.3 Operation Modes After PGn signals pass through the first stage of the PWM and Fault Brake output control circuit. The PWM mode selection circuit generates different kind of PWM output modes with eight-channel, fourpair signal PG0~PG7 . It supports independent mode, complementary mode, and synchronous mode. Jan. 27, 2018 Page 124 of 205 Rev. 1.02 N76E885 Datasheet PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit 7:6 4 PWMTYP R/W 3 FBINEN R/W Name Description PWMMOD[1:0] PWM mode select 00 = Independent mode. 01 = Complementary mode. 10 = Synchronized mode. 11 = Reserved. 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b 18.1.3.1 Independent Mode Independent mode is enabled when PWMMOD[1:0] (PWMCON1[7:6]) is [0:0]. It is the default mode of PWM. PG0/2/4/6 output PWM signals and PG1/3/5/7 remains high state level. 18.1.3.2 Complementary Mode with Dead-Time Insertion Complementary mode is enabled when PWMMOD[1:0] = [0:1]. In this mode, PG0/2/4/6 output PWM signals the same as the independent mode. However, PG1/3/5/7 output the out-phase PWM signals of PG0/2/4/6 correspondingly. This mode makes PG0/PG1 a PWM complementary pair and so on PG2/PG3, PG4/PG5, andPG6/PG7. n a real motor application, a complementary PW output always has a need of “dead-time” insertion to prevent damage of the power switching device like GPIBs due to being active on simultaneously of the upper and lower switches of the half bridge, even in a “μs” duration. For a power switch device physically cannot switch on/off instantly. For the N76E885 PWM, each PWM pair share a 9-bit deadtime down-counter PDTCNT used to produce the off time between two PWM signals in the same pair. On implementation, a 0-to-1 signal edge delays after PDTCNT timer underflows. The timing diagram illustrates the complementary mode with dead-time insertion of PG0/PG1 pair. Pairs of PG2/PG3, PG4/PG5, and PG6/PG7 have the same dead-time circuit. Each pair has its own dead-time enabling bit in the field of PDTEN[3:0]. Note that the PDTCNT and PDTEN registers are all TA write protection. The dead-time control are also valid only when the PWM is configured in its complementary mode. Jan. 27, 2018 Page 125 of 205 Rev. 1.02 N76E885 Datasheet PG0 PG1 PG0_DT PG1_DT Figure 18.5. PWM Complementary Mode with Dead-time Insertion PDTEN – PWM Dead-time Enable (TA protected) 7 6 5 4 PDTCNT.8 R/W Address: F9H Bit 3 PDT67EN R/W 2 PDT45EN R/W 1 0 PDT23EN PDT01EN R/W R/W Reset value: 0000 0000b Name Description 4 PDTCNT.8 PWM dead-time counter bit 8 See PDTCNT register. 3 PDT67EN PWM6/7 pair dead-time insertion enable This bit is valid only when PWM6/7 is under complementary mode. 0 = No delay on GP6/GP7 pair signals. 1 = Insert dead-time delay on the rising edge of GP6/GP7 pair signals. 2 PDT45EN PWM4/5 pair dead-time insertion enable This bit is valid only when PWM4/5 is under complementary mode. 0 = No delay on GP4/GP5 pair signals. 1 = Insert dead-time delay on the rising edge of GP4/GP5 pair signals. 1 PDT23EN PWM2/3 pair dead-time insertion enable This bit is valid only when PWM2/3 is under complementary mode. 0 = No delay on GP2/GP3 pair signals. 1 = Insert dead-time delay on the rising edge of GP2/GP3 pair signals. 0 PDT01EN PWM0/1 pair dead-time insertion enable This bit is valid only when PWM0/1 is under complementary mode. 0 = No delay on GP0/GP1 pair signals. 1 = Insert dead-time delay on the rising edge of GP0/GP1 pair signals. Jan. 27, 2018 Page 126 of 205 Rev. 1.02 N76E885 Datasheet PDTCNT – PWM Dead-time Counter (TA protected) 7 6 5 4 3 PDTCNT[7:0] R/W Address: FAH Bit 7:0 2 1 0 Reset value: 0000 0000b Name Description PDTCNT[7:0] PWM dead-time counter low byte This 8-bit field combined with PDTEN.4 forms a 9-bit PWM dead-time counter PDTCNT. This counter is valid only when PWM is under complementary mode and the correspond PDTEN bit for PWM pair is set. PDTCNT  1 PWM dead-time = . FSYS Note that user should not modify PDTCNT during PWM run time. 18.1.3.3 Synchronous Mode Synchronous mode is enabled when PWMMOD[1:0] = [1:0]. In this mode, PG0/2/4/6 output PWM signals the same as the independent mode. PG1/3/5/7 output just the same in-phase PWM signals of PG02/4/6 correspondingly. 18.1.4 Mask Output Control Each PWM signal can be software masked by driving a specified level of PWM signal. The PWM mask output function is quite useful when controlling Electrical Commutation Motor like a BLDC. PMEN contains six bits, those determine which channel of PWM signal will be masked. PMD set the individual mask level of each PWM channel. The default value of PMEN is 00H, which makes all outputs of PWM channels follow signals from PWM generator. Note that the masked level is reversed or not by PNP setting on PWM output pins. PMEN – PWM Mask Enable 7 6 5 PMEN7 PMEN6 PMEN5 R/W R/W R/W Address: FBH Bit Name n Jan. 27, 2018 PMENn 4 PMEN4 R/W 3 PMEN3 R/W 2 PMEN2 R/W 1 0 PMEN1 PMEN0 R/W R/W Reset value: 0000 0000b Description PWMn mask enable 0 = PWMn signal outputs from its PWM generator. 1 = PWMn signal is masked by PMDn. Page 127 of 205 Rev. 1.02 N76E885 Datasheet PMD – PWM Mask Data 7 6 PMD7 PMD6 R/W R/W Address: FCH Bit 5 PMD5 R/W Name n 4 PMD4 R/W 3 PMD3 R/W 2 PMD2 R/W 1 0 PMD1 PMD0 R/W R/W Reset value: 0000 0000b Description PWMn mask data The PWMn signal outputs mask data once its corresponding PMENn is set. 0 = PWMn signal is masked by 0. 1 = PWMn signal is masked by 1. PMDn 18.1.5 Fault Brake The Fault Brake function is usually implemented in conjunction with an enhanced PWM circuit. It rules as a fault detection input to protect the motor system from damage. Fault Brake pin input (FB) is valid when FBINEN (PWMCON1.3) is set. When Fault Brake is asserted PWM signals will be individually overwritten by FBD corresponding bits. PWMRUN (PWMCON0.7) will also be automatically cleared by hardware to stop PWM generating. The PWM 12-bit counter will also be reset as 000H. A indicating flag FBF will be set by hardware to assert a Fault Brake interrupt if enabled. FBD data output remains even after the FBF is cleared by software. User should resume the PWM output only by setting PWMRUN again. Meanwhile the Fault Brake state will be released and PWM waveform outputs on pins as usual. Fault Brake input has a polarity selection by FBINLS (FBD.6) bit. Note that the Fault Brake signal feed in FB pin should be longer than eight-system-clock time for FB pin input has a permanent 8/FSYS de-bouncing, which avoids fake Fault Brake event by input noise. The other path to trigger a Fault Brake event is the ADC compare event. It asserts the Fault Brake behavior just the same as FB pin input. See 19.1.3 “ADC Conversion Result Comparator” on 134. Note that PWM6 and PWM7 do not have Fault Brake data setting. PWM6 and PWM7 output states keep unchanged on the moment of a Fault Brake event occurrence. User should take care of its output state via software if PWM6 and PWM7 constant outputs violate the hardware system. 0 FB (P2.3) De-bounce 1 FBINLS FBINEN ADC comparator Fault Brake event FBF Fault Brake interrupt ADC compare event Figure 18.6. Fault Brake Function Block Diagram Jan. 27, 2018 Page 128 of 205 Rev. 1.02 N76E885 Datasheet PWMCON1 – PWM Control 1 7 6 5 PWMMOD[1:0] GP R/W R/W Address: DFH Bit Name 3 FBINEN Name 7 FBF 6 FBINLS n FBDn 3 FBINEN R/W 2 1 0 PWMDIV[2:0] R/W Reset value: 0000 0000b Description FB pin input enable 0 = PWM output Fault Braked by FB pin input Disabled. 1 = PWM output Fault Braked by FB pin input Enabled. Once an edge, which matches FBINLS (FBD.6) selection, occurs on FB pin, PWM0~5 output Fault Brake data in FBD register and PWM6/7 remains their states. PWMRUN (PWMCON0.7) will also be automatically cleared by hardware. The PWM output resumes when PWMRUN is set again. FBD – PWM Fault Brake Data 7 6 5 FBF FBINLS FBD5 R/W R/W R/W Address: D7H Bit 4 PWMTYP R/W 4 FBD4 R/W 3 FBD3 R/W 2 FBD2 R/W 1 0 FBD1 FBD0 R/W R/W Reset value: 0000 0000b Description Fault Brake flag This flag is set when FBINEN is set as 1 and FB pin detects an edge, which matches FBINLS (FBD.6) selection. This bit is cleared by software. After FBF is cleared, Fault Brake data output will not be released until PWMRUN (PWMCON0.0) is set. FB pin input level selection 0 = Falling edge. 1 = Rising edge. PWMn Fault Brake data 0 = PWMn signal is overwritten by 0 once Fault Brake asserted. 1 = PWMn signal is overwritten by 1 once Fault Brake asserted. 18.1.6 Polarity Control Each PWM output channel has its independent polarity control bit, PNP0~PNP7. The default is high active level on all control fields implemented with positive logic. It means the power switch is ON when PWM outputs high level and OFF when low level. User can easily configure all setting with positive logic and then set PNP bit to make PWM actually outputs according to the negative logic. Jan. 27, 2018 Page 129 of 205 Rev. 1.02 N76E885 Datasheet PNP – PWM Negative Polarity 7 6 5 PNP7 PNP6 PNP5 R/W R/W R/W Address: D6H Bit Name n PNPn 4 PNP4 R/W 3 PNP3 R/W 2 PNP2 R/W 1 0 PNP1 PNP0 R/W R/W Reset value: 0000 0000b Description PWMn negative polarity output enable 0 = PWMn signal outputs directly on PWMn pin. 1 = PWMn signal outputs inversely on PWMn pin. 18.2 PWM Interrupt The PWM module has a flag PWMF (PWMCON0.5) to indicate certain point of each complete PWM period. The indicating PWM channel and point can be selected by INTSEL[1:0] and INTTYP[1:0] (PWMCON0[1:0] and [3:2]). Note that the center point and the end point interrupts are only available when PWM operates in its center-aligned type. PWMF is cleared by software. PWMCON0 – PWM Control 0 (Bit-addressable) 7 6 5 4 PWMRUN LOAD PWMF CLRPWM R/W R/W R/W R/W Address: D8H Bit Name 3 INTTYP1 R/W 2 INTTYP0 R/W 1 0 INTSEL1 INTSEL0 R/W R/W Reset value: 0000 0000b Description 3:2 INTTYP[1:0] PWM interrupt type select These bit select PWM interrupt type. 00 = Falling edge on PWM0/2/4/6 pin. 01 = Rising edge on PWM0/2/4/6 pin. 10 = Central point of a PWM period. 11 = End point of a PWM period. Note that the central point interrupt or the end point interrupt is only available while PWM operates in center-aligned type. 1:0 INTSEL[1:0] PWM interrupt pair select These bits select which PWM channel asserts PWM interrupt when PWM interrupt type is selected as falling or rising edge on PWM0/2/4 pin.. 00 = PWM0. 01 = PWM2. 10 = PWM4. 11 = PWM6. The PWM interrupt related with PWM waveform is shown as figure below. Jan. 27, 2018 Page 130 of 205 Rev. 1.02 N76E885 Datasheet Edge-aligned PWM Center-aligned PWM Central point 12-bit PWM counter End point Dead time PWM0/2/4 pin output PWMF (falling edge) (INTTYP[1:0] = [0:0]) Software clear PWMF (rising edge) (INTTYP[1:0] = [0:1]) PWMF (central point) (INTTYP[1:0] = [1:0]) Reserved PWMF (end point) (INTTYP[1:0] = [1:1]) Reserved Figure 18.7. PWM Interrupt Type Fault Brake event requests another interrupt, Fault Brake interrupt. It has different interrupt vector from PWM interrupt. When either Fault Brake pin input event or ADC compare event occurs, FBF (FBD.7) will be set by hardware. It generates Fault Brake interrupt if enabled. The Fault Brake interrupt enable bit is EFB (EIE.5). FBF Is cleared via software. Jan. 27, 2018 Page 131 of 205 Rev. 1.02 N76E885 Datasheet 19. 10-BIT ANALOG-TO-DIGITAL CONVERTER (ADC) The N76E885 is embedded with a 10-bit SAR ADC. The ADC (analog-to-digital converter) allows conversion of an analog input signal to a 10-bit binary representation of that signal. The N76E885 is selected as 10-channel inputs in single end mode. The internal band-gap voltage 1.22V also can be the internal ADC input (To use internal band-gap as ADC input must enable BOD module by setting BODEN(BODCON0.7) = 1 first.) The analog input, multiplexed into one sample and hold circuit, charges a sample and hold capacitor. The output of the sample and hold capacitor is the input into the converter. The converter then generates a digital result of this analog level via successive approximation and stores the result in the result registers. 19.1 Functional Description 19.1.1 ADC Operation 0 VDD 1 VREFSEL VREF/AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 AIN8 AIN9 Internal band-gap (BODEN=1) VREF 0000 0001 0010 ADCF 0011 0100 10-bit SAR ADC 0101 0100 10 ADC clock input 1000 1001 1111 A/D convertion start 0111 ADCEN ADCRH ADC Clock Divider FADC ADCDIV[2:0] External triggering circuit External Trigger ADCRL ADC result comparator ADCHS[3:0] FSYS ADC interrupt ADCS ADCEX NOTE: Since the design limitation. To use internal band-gap as ADC input, must enable BOD module first. Figure 19.1. 10-bit ADC Block Diagram Jan. 27, 2018 Page 132 of 205 Rev. 1.02 N76E885 Datasheet Before ADC operation, the ADC circuit should be enabled by setting ADCEN (ADCCON1.0). This makes ADC circuit active. It consume extra power. Once ADC is not used, clearing ADCEN to turn off ADC circuit saves power. The VREF voltage input source can be selected from the internal VDD or the external AIN0/VREF pin by VREFSEL (ADCCON1.7) bit. The ADC analog input pin should be specially considered. ADCHS[3:0] are channel selection bits that control which channel is connected to the sample and hold circuit. User needs to configure selected ADC input pins as input-only (high impedance) mode via respective bits in PxMn registers. This configuration disconnects the digital output circuit of each selected ADC input pin. But the digital input circuit still works. Digital input may cause the input buffer to induce leakage current. To disable the digital input buffer, the respective bits in P0DIDS and ADCCON2 should be set. Configuration above makes selected ADC analog input pins pure analog inputs to allow external feeding of the analog voltage signals. Also, the ADC clock rate needs to be considered carefully. The ADC maximum clock frequency is listed in Table 32–10. Clock above the maximum clock frequency degrades ADC performance unpredictably. An A/D conversion is initiated by setting the ADCS bit (ADCCON0.6). When the conversion is complete, the hardware will clear ADCS automatically, set ADCF (ADCCON0.7) and generate an interrupt if enabled. The new conversion result will also be stored in ADCRH (most significant 8 bits) 1023× and ADCRL (least significant 2 bits). The 10-bit ADC result value is VAIN VREF . The ADC acquisition time is programmable, which provides a range of 6 (6 + 0) to 261 (6 + 255) ADC clock cycles, by configuring ADCAQT register. It is useful to preserve the accuracy of ADC result especially when the input impedance of the analog input source is not ideally low. The programmable acquisition time overcomes the high impedance of an analog input source. By the way, digital circuitry inside and outside the device generates noise which might affect the accuracy of ADC measurements. If conversion accuracy is critical, the noise level can be reduced by applying the following techniques: 1. Keep analog signal paths as short as possible. Make sure to run analog signals tracks well away from high-speed digital tracks. 2. Place the device in Idle mode during a conversion. 3. If any AIN pins are used as digital outputs, it is essential that these do not switch while a conversion is in progress. Jan. 27, 2018 Page 133 of 205 Rev. 1.02 N76E885 Datasheet 19.1.2 ADC Conversion Triggered by External Source Besides setting ADCS via software, the N76E885 is enhanced by supporting hardware triggering method to start an A/D conversion. If ADCEX (ADCCON1.1) is set, edges or period points on selected PWM channel or edges of STADC pin will automatically trigger an A/D conversion. (The hardware trigger also sets ADCS by hardware.) The effective condition is selected by ETGSEL (ADCCON0[5:4]) and ETGTYP (ADCCON1[3:2]). A trigger delay can also be inserted between external trigger point and A/D conversion. The external trigging ADC hardware with controllable trigger delay makes the N76E885 feasible for high performance motor control. Note that during ADC is busy in converting (ADCS = 1), any conversion triggered by software or hardware will be ignored and there is no warning presented. [00] PWM0 PWM2 PWM4 STADC 00 [01] 01 ADCDLY 10 External Trigger [10] 11 [11] PTRGSEL[1:0] (ADCCON0[5:4]) PTRGTYP[1:0] (ADCCON1[3:2]) Figure 19.2. External Triggering ADC Circuit 19.1.3 ADC Conversion Result Comparator The N76E885 ADC has a digital comparator, which compares the A/D conversion result with a 10-bit constant value given in ACMPH and ACMPL registers. The ADC comparator is enabled by setting ADCMPEN (ADCCON2.5) and each compare will be done on every A/D conversion complete moment. ADCMPO (ADCCON2.4) shows the compare result according to its output polarity setting bit ADCMPOP (ADCCON2.6). The ADC comparing result can trigger a PWM Fault Brake output directly. This function is enabled when ADFBEN (ADCCON2.7). When ADCMPO is set, it generates a ADC compare event and asserts Fault Brake. Please also see Sector 18.1.5 “Fault Brake” on page 128. Jan. 27, 2018 Page 134 of 205 Rev. 1.02 N76E885 Datasheet ADCR[9:0] + 0 ADCMP[9:0] - 1 ADCMPO (ADCCON2.4) ADFBEN (ADCCON2.7) ADC compare event ADCMPOP (ADCCON2.6) ADCMPEN (ADCCON2.5) Figure 19.3. ADC Result Comparator 19.2 Control Registers of ADC ADCCON0 – ADC Control 0 (Bit-addressable) 7 6 5 4 ADCF ADCS ETGSEL1 ETGSEL0 R/W R/W R/W R/W Address: E8H Bit Name 3 ADCHS3 R/W 2 ADCHS2 R/W 1 0 ADCHS1 ADCHS0 R/W R/W Reset value: 0000 0000b Description 7 ADCF ADC flag This flag is set when an A/D conversion is completed. The ADC result can be read. While this flag is 1, ADC cannot start a new converting. This bit is cleared by software. 6 ADCS A/D converting software start trigger Setting this bit 1 triggers an A/D conversion. This bit remains logic 1 during A/D converting time and is automatically cleared via hardware right after conversion complete. The meaning of writing and reading ADCS bit is different. Writing: 0 = No effect. 1 = Start an A/D converting. Reading: 0 = ADC is in idle state. 1 = ADC is busy in converting. 5:4 Jan. 27, 2018 ETGSEL[1:0] External trigger source select When ADCEX (ADCCON1.1) is set, these bits select which pin output triggers ADC conversion. 00 = PWM0. 01 = PWM2. 10 = PWM4. 11 = STADC pin. Page 135 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 3:0 ADCHS[3:0] Description A/D converting channel select This filed selects the activating analog input source of ADC. If ADCEN is 0, all inputs are disconnected. 0000 = AIN0. 0001 = AIN1. 0010 = AIN2. 0011 = AIN3. 0100 = AIN4. 0101 = AIN5. 0110 = AIN6. 0111 = AIN7. 1000 = AIN8. 1001 = AIN9. 1111 = Internal band-gap voltage 1.22V. (Enable BODEN=1 first) Others = Reserved. ADCCON1 – ADC Control 1 7 6 5 VREFSEL ADCDIV[2:0] R/W R/W Address: E1H Bit Name 4 3 2 ETGTYP[1:0] R/W 1 0 ADCEX ADCEN R/W R/W Reset value: 0010 0000b Description VREF source select 0 = Internal VDD. 1 = External AIN0/VREF pin. 7 VREFSEL 6:4 ADCDIV[2:0] ADC clock divider 000 = FADC is FSYS/1. 001 = FADC is FSYS/2. 010 = FADC is FSYS/4. (By default.) 011 = FADC is FSYS/8. 100 = FADC is FSYS/16. 101 = FADC is FSYS/32. 110 = FADC is FSYS/64. 111 = FADC is FSYS/128. 3:2 ETGTYP[1:0] External trigger type select When ADCEX (ADCCON1.1) is set, these bits select which condition triggers ADC conversion. 00 = Falling edge on PWM0/2/4 or STADC pin. 01 = Rising edge on PWM0/2/4 or STADC pin. 10 = Central point of a PWM period. 11 = End point of a PWM period. Note that the central point interrupt or the period point interrupt is only available for PWM center-aligned type. 1 ADCEX ADC external conversion trigger select This bit select the methods of triggering an A/D conversion. 0 = A/D conversion is started only via setting ADCS bit. 1 = A/D conversion is started via setting ADCS bit or by external trigger source depending on ETGSEL[1:0] and ETGTYP[1:0]. Note that while ADCS is 1 (busy in converting), the ADC will ignore the following external trigger until ADCS is hardware cleared. Jan. 27, 2018 Page 136 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 0 ADCEN Description ADC enable 0 = ADC circuit off. 1 = ADC circuit on. ADCCON2 – ADC Control 2 7 6 5 ADFBEN ADCMPOP ADCMPEN R/W R/W R/W Address: E2H Bit Name 4 ADCMPO R 3 P26DIDS R/W 2 P20DIDS R/W 1 0 ADCDLY.8 R/W Reset value: 0000 0000b Description ADC compare result asserting Fault Brake enable 0 = ADC asserting Fault Brake Disabled. 1 = ADC asserting Fault Brake Enabled. Fault Brake is asserted once its compare result ADCMPO is 1. Meanwhile, PWM channels output Fault Brake data. PWMRUN (PWMCON0.7) will also be automatically cleared by hardware. The PWM output resumes when PWMRUN is set again. 7 ADFBEN 6 ADCMPOP ADC comparator output polarity 0 = ADCMPO is 1 if ADCR[9:0] is greater than or equal to ADCMP[9:0]. 1 = ADCMPO is 1 if ADCR[9:0] is less than ADCMP[9:0]. 5 ADCMPEN ADC result comparator enable 0 = ADC result comparator Disabled. 1 = ADC result comparator Enabled. 4 ADCMPO ADC comparator output value This bit is the output value of ADC result comparator based on the setting of ACMPOP. This bit updates after every A/D conversion complete. 3 P26DIDS P2.6 digital input disable 0 = P2.6 digital input Enabled. 1 = P2.6 digital input Disabled. P2.6 is read always 0. 2 P20DIDS P2.0 digital input disable 0 = P2.0 digital input Enabled. 1 = P2.0 digital input Disabled. P2.0 is read always 0. 0 ADCDLY.8 Jan. 27, 2018 ADC external trigger delay counter bit 8 See ADCDLY register. Page 137 of 205 Rev. 1.02 N76E885 Datasheet ADCAQT – ADC Acquisition Time 7 6 5 4 3 ADCAQT[7:0] R/W 2 Address: F2H Bit 7:0 Name Description ADCAQT[7:0] ADC acquisition time This 8-bit field decides the acquisition time for ADC sampling, following by equation below: 6 + ADCAQT ADC acquisition time = . FADC The default and minimum acquisition time is 6 ADC clock cycles. Note that this field should not be changed when ADC is in converting. Name n P0nDIDS 4 P04DIDS R/W 3 P03DIDS R/W 1 0 P01DIDS P00DIDS R/W R/W Reset value: 0000 0000b P0.n digital input disable 0 = P0.n digital input Enabled. 1 = P0.n digital input Disabled. P0.n is read always 0. 4 3 ADCDLY[7:0] R/W Address: E3H 7:0 2 P02DIDS R/W Description ADCDLY – ADC Trigger Delay Counter 7 6 5 Bit 0 Reset value: 0000 0000b P0DIDS – P0 Digital Input Disconnect 7 6 5 P07DIDS P06DIDS P05DIDS R/W R/W R/W Address: F6H Bit 1 2 1 0 Reset value: 0000 0000b Name Description ADCDLY[7:0] ADC external trigger delay counter low byte This 8-bit field combined with ADCCON2.0 forms a 9-bit counter. This counter inserts a delay after detecting the external trigger. An A/D converting starts after this period of delay. ADCDLY External trigger delay time = . FADC Note that this field is valid only when ADCEX (ADCCON1.1) is set. User should not modify ADCDLY during PWM run time if selecting PWM output as the external ADC trigger source. Jan. 27, 2018 Page 138 of 205 Rev. 1.02 N76E885 Datasheet ADCRH – ADC Result High Byte 7 6 5 4 3 2 1 0 ADCR[9:2] R Address: C3H Bit 7:0 Reset value: 0000 0000b Name ADCR[9:2] Description ADC result high byte The most significant 8 bits of the ADC result stored in this register. ADCRL – ADC Result Low Byte 7 6 5 Address: C2H Bit 1:0 Name ADCR[1:0] 4 - 3 - 2 - 1 0 ADCR[1:0] R Reset value: 0000 0000b Description ADC result low byte The least significant 2 bits of the ADC result stored in this register. ADCMPH – ADC Compare High Byte 7 6 5 4 3 2 1 0 ADCMP[9:2] W/R Address: CFH Bit 7:0 Reset value: 0000 0000b Name Description ADCMP[9:2] ADC compare high byte The most significant 8 bits of the ADC compare value stores in this register. ADCMPL – ADC Compare Low Byte 7 6 5 Address: CEH Bit 1:0 Jan. 27, 2018 4 - 3 - 2 - 1 0 ADCMP[1:0] W/R Reset value: 0000 0000b Name Description ADCMP[1:0] ADC compare low byte The least significant 2 bits of the ADC compare value stores in this register. Page 139 of 205 Rev. 1.02 N76E885 Datasheet 20. TIMED ACCESS PROTECTION (TA) The N76E885 has several features such as WDT and Brown-out detection that are crucial to proper operation of the system. If leaving these control registers unprotected, errant code may write undetermined value into them and results in incorrect operation and loss of control. To prevent this risk, the N76E885 has a protection scheme, which limits the write access to critical SFRs. This protection scheme is implemented using a timed access (TA). The following registers are related to the TA process. TA – Timed Access 7 6 5 4 3 2 1 0 TA[7:0] W Address: C7H Bit 7:0 Reset value: 0000 0000b Name TA[7:0] Description Timed access The timed access register controls the access to protected SFRs. To access protected bits, user should first write AAH to the TA and immediately followed by a write of 55H to TA. After these two steps, a writing permission window is opened for 4 clock cycles during this period that user may write to protected SFRs. In timed access method, the bits, which are protected, have a timed write enable window. A write is successful only if this window is active, otherwise the write will be discarded. When the software writes AAH to TA, a counter is started. This counter waits for 3 clock cycles looking for a write of 55H to TA. If the second write of 55H occurs within 3 clock cycles of the first write of AAH, then the timed access window is opened. It remains open for 4 clock cycles during which user may write to the protected bits. After 4 clock cycles, this window automatically closes. Once the window closes, the procedure should be repeated to write another protected bits. Not that the TA protected SFRs are required timed access for writing but reading is not protected. User may read TA protected SFR without giving AAH and 55H to TA register. The suggestion code for opening the timed access window is shown below. (CLR EA) ;if any interrupt is enabled, disable temporally MOV TA,#0AAH MOV TA,#55H (Instruction that writes a TA protected register) (SETB EA) ;resume interrupts enabled Any enabled interrupt should be disabled during this procedure to avoid delay between these three writings. If there is no interrupt enabled, the CLR EA and SETB EA instructions can be left out. Jan. 27, 2018 Page 140 of 205 Rev. 1.02 N76E885 Datasheet Examples of timed assess are shown to illustrate correct or incorrect writing process. Example 1, MOV MOV ORL TA,#0AAH TA,#55H WDCON,#data ;3 clock cycles ;3 clock cycles ;4 clock cycles TA,#0AAH TA,#55H BODCON0,#data ;3 ;3 ;1 ;4 TA,#0AAH TA,#55H WDCON,#data1 BODCON0,#data2 ;3 clock cycles ;3 clock cycles ;3 clock cycles ;4 clock cycles TA,#0AAH ;3 ;1 ;3 ;4 Example 2, MOV MOV NOP ANL clock clock clock clock cycles cycles cycle cycles Example 3, MOV MOV MOV ORL Example 4, MOV NOP MOV ANL TA,#55H BODCON0,#data clock clock clock clock cycles cycle cycles cycles In the first example, the writing to the protected bits is done before the 3-clock-cycle window closes. In example 2, however, the writing to BODCON0 does not complete during the window opening, there will be no change of the value of BODCON0. In example 3, the WDCON is successful written but the BODCON0 write is out of the 3-clock-cycle window. Therefore, the BODCON0 value will not change either. In Example 4, the second write 55H to TA completes after 3 clock cycles of the first write TA of AAH, and thus the timed access window is not opened at all, and the write to the protected byte affects nothing. Jan. 27, 2018 Page 141 of 205 Rev. 1.02 N76E885 Datasheet 21. INTERRUPT SYSTEM 21.1 Interrupt Overview The purpose of the interrupt is to make the software deal with unscheduled or asynchronous events. The N76E885 has a four-priority-level interrupt structure with 18 interrupt sources. Each of the interrupt sources has an individual priority setting bits, interrupt vector and enable bit. In addition, the interrupts can be globally enabled or disabled. When an interrupt occurs, the CPU is expected to service the interrupt. This service is specified as an Interrupt Service Routine (ISR). The ISR resides at a predetermined address as shown in Table 21–1. Interrupt Vectors. When the interrupt occurs if enabled, the CPU will vector to the respective location depending on interrupt source, execute the code at this location, stay in an interrupt service state until the ISR is done. Once an ISR has begun, it can be interrupted only by a higher priority interrupt. The ISR should be terminated by a return from interrupt instruction RETI. This instruction will force the CPU return to the instruction that would have been next when the interrupt occurred. Table 21–1. Interrupt Vectors Vector Address Vector Number Vector Address Vector Number Reset 0000H - SPI interrupt 004BH 9 External interrupt 0 0003H 0 WDT interrupt 0053H 10 Timer 0 overflow 000BH 1 ADC interrupt 005BH 11 External interrupt 1 0013H 2 Input capture interrupt 0063H 12 Timer 1 overflow 001BH 3 PWM interrupt 006BH 13 Serial port 0 interrupt 0023H 4 Fault Brake interrupt 0073H 14 Timer 2 event 002BH 5 Serial port 1 interrupt 007BH 15 I C status/timer-out interrupt 0033H 6 Timer 3 overflow 0083H 16 Pin interrupt 003BH 7 Self Wake-up Timer interrupt 008BH 17 Brown-out detection interrupt 0043H 8 Source 2 Source 21.2 Enabling Interrupts Each of individual interrupt sources can be enabled or disabled through the use of an associated interrupt enable bit in the IE and EIE SFRs. There is also a global enable bit EA bit (IE.7), which can be cleared to disable all the interrupts at once. It is set to enable all individually enabled interrupts. Setting the EA bit to logic 0 disables all interrupt sources regardless of the individual interrupt-enable settings. Note that interrupts which occur when the EA bit is set to logic 0 will be held in a pending Jan. 27, 2018 Page 142 of 205 Rev. 1.02 N76E885 Datasheet state, and will not be serviced until the EA bit is set back to logic 1. All interrupt flags that generate interrupts can also be set via software. Thereby software initiated interrupts can be generated. Note that every interrupts, if enabled, is generated by a setting as logic 1 of its interrupt flag no matter by hardware or software. User should take care of each interrupt flag in its own interrupt service routine (ISR). Most of interrupt flags should be cleared by writing it as logic 0 via software to avoid recursive interrupt requests. IE – Interrupt Enable (Bit-addressable) 7 6 5 EA EADC EBOD R/W R/W R/W Address: A8H Bit Name 4 ES R/W 3 ET1 R/W 2 EX1 R/W 1 0 ET0 EX0 R/W R/W Reset value: 0000 0000b Description Enable all interrupt This bit globally enables/disables all interrupts that are individually enabled. 0 = All interrupt sources Disabled. 1 = Each interrupt Enabled depending on its individual mask setting. Individual interrupts will occur if enabled. 7 EA 6 EADC Enable ADC interrupt 0 = ADC interrupt Disabled. 1 = Interrupt generated by ADCF (ADCCON0.7) Enabled. 5 EBOD Enable brown-out interrupt 0 = Brown-out detection interrupt Disabled. 1 = Interrupt generated by BOF (BODCON0.3) Enabled. 4 ES Enable serial port 0 interrupt 0 = Serial port 0 interrupt Disabled. 1 = Interrupt generated by TI (SCON.1) or RI (SCON.0) Enabled. 3 ET1 Enable Timer 1 interrupt 0 = Timer 1 interrupt Disabled. 1 = Interrupt generated by TF1 (TCON.7) Enabled. 2 EX1 Enable external interrupt 1 0 = External interrupt 1 Disabled. 1 = Interrupt generated by ̅̅̅̅̅̅̅ pin (P0.1) Enabled. 1 ET0 Enable Timer 0 interrupt 0 = Timer 0 interrupt Disabled. 1 = Interrupt generated by TF0 (TCON.5) Enabled. 0 EX0 Enable external interrupt 0 0 = External interrupt 0 Disabled. 1 = Interrupt generated by ̅̅̅̅̅̅̅ pin (P0.0) Enabled. Jan. 27, 2018 Page 143 of 205 Rev. 1.02 N76E885 Datasheet EIE – Extensive Interrupt Enable 7 6 5 ET2 ESPI EFB R/W R/W R/W Address: 9BH Bit Name 4 EWDT R/W 3 EPWM R/W 2 ECAP R/W 1 0 EPI EI2C R/W R/W Reset value: 0000 0000b Description 7 ET2 Enable Timer 2 interrupt 0 = Timer 2 interrupt Disabled. 1 = Interrupt generated by TF2 (T2CON.7) Enabled. 6 ESPI Enable SPI interrupt 0 = SPI interrupt Disabled. 1 = Interrupt generated by SPIF (SPSR.7), SPIOVF (SPSR.5), or MODF (SPSR.4) Enable. 5 EFB Enable Fault Brake interrupt 0 = Fault Brake interrupt Disabled. 1 = Interrupt generated by FBF (FBD.7) Enabled. 4 EWDT Enable WDT interrupt 0 = WDT interrupt Disabled. 1 = Interrupt generated by WDTF (WDCON.5) Enabled. 3 EPWM Enable PWM interrupt 0 = PWM interrupt Disabled. 1 = Interrupt generated by PWMF (PWMCON0.5) Enabled. 2 ECAP Enable input capture interrupt 0 = Input capture interrupt Disabled. 1 = Interrupt generated by any flags of CAPF[2:0] (CAPCON0[2:0]) Enabled. 1 EPI 0 EI2C Enable pin interrupt 0 = Pin interrupt Disabled. 1 = Interrupt generated by any flags in PIF register Enabled. 2 Enable I C interrupt 2 0 = I C interrupt Disabled. 1 = Interrupt generated by SI (I2CON.3) or I2TOF (I2TOC.0) Enabled. EIE1 – Extensive Interrupt Enable 1 7 6 5 Address: 9CH Bit Name 4 - 3 - 2 EWKT R/W 1 0 ET3 ES_1 R/W R/W Reset value: 0000 0000b Description Enable WKT interrupt 0 = WKT interrupt Disabled. 1 = Interrupt generated by WKTF (WKCON.4) Enabled. 2 EWKT 1 ET3 Enable Timer 3 interrupt 0 = Timer 3 interrupt Disabled. 1 = Interrupt generated by TF3 (T3CON.4) Enabled. 0 ES_1 Enable serial port 1 interrupt 0 = Serial port 1 interrupt Disabled. 1 = Interrupt generated by TI_1 (SCON_1.1) or RI_1 (SCON_1.0) Enabled. Jan. 27, 2018 Page 144 of 205 Rev. 1.02 N76E885 Datasheet 21.3 Interrupt Priorities There are four priority levels for all interrupts. They are level highest, high, low, and lowest; and they are represented by level 3, level 2, level 1, and level 0. The interrupt sources can be individually set to one of four priority levels by setting their own priority bits. Table 21–2 lists four priority setting. Naturally, a low level priority interrupt can itself be interrupted by a high level priority interrupt, but not by any same level interrupt or lower level. In addition, there exists a pre-defined natural priority among the interrupts themselves. The natural priority comes into play when the interrupt controller has to resolve simultaneous requests having the same priority level. In case of multiple interrupts, the following rules apply: 1. While a low priority interrupt handler is running, if a high priority interrupt arrives, the handler will be interrupted and the high priority handler will run. When the high priority handler does “ E ”, the low priority handler will resume. When this handler does “ E ”, control is passed back to the main program. 2. If a high priority interrupt is running, it cannot be interrupted by any other source – even if it is a high priority interrupt which is higher in natural priority. 3. A low-priority interrupt handler will be invoked only if no other interrupt is already executing. Again, the low priority interrupt cannot preempt another low priority interrupt, even if the later one is higher in natural priority. 4. If two interrupts occur at the same time, the interrupt with higher priority will execute first. If both interrupts are of the same priority, the interrupt which is higher in natural priority will be executed first. This is the only context in which the natural priority matters. This natural priority is defined as shown on Table 21–3. It also summarizes the interrupt sources, flag bits, vector addresses, enable bits, priority bits, natural priority and the permission to wake up the CPU from Power-down mode. For details of waking CPU up from Power-down mode, please see Section 23.2 “Power-Down Mode” on page 164. Jan. 27, 2018 Page 145 of 205 Rev. 1.02 N76E885 Datasheet Table 21–2. Interrupt Priority Level Setting Interrupt Priority Control Bits Interrupt Priority Level IPH / EIPH / EIPH1 IP / EIP / EIP2 0 0 Level 0 (lowest) 0 1 Level 1 1 0 Level 2 1 1 Level 3 (highest) Table 21–3. Characteristics of Each Interrupt Source Interrupt Source Vector Address Interrupt Flag(s) Natural Priority Enable Bit Priority Control Bits Power-down Wake-up Reset 0000H - Always Enabled Highest - Yes External interrupt 0 0003H IE0[1] EX0 1 PX0, PX0H Yes Brown-out 0043H BOF (BODCON0.3) EBOD 2 PBOD, PBODH Yes Watchdog Timer 0053H WDTF (WDCON.5) EWDT 3 PWDT, PWDTH Yes ET0 4 PT0, PT0H No Timer 0 [2] 000BH TF0 I C status/time-out 0033h SI + I2TOF (I2TOC.0) EI2C 5 PI2C, PI2CH No ADC 005Bh ADCF EADC 6 PADC, PADCH No EX1 7 PX1, PX1H Yes EPI 8 PPI, PPIH Yes ET1 9 PT1, PT1H No 2 [1] External interrupt 1 0013H IE1 Pin interrupt 003BH PIF0 to PIF7 (PIF)[3] [2] Timer 1 001BH TF1 Serial port 0 0023H RI + TI ES 10 PS, PSH No Fault Brake event 0073h FBF (FBD.7) EFB 11 PFB, PFBH No SPI 004Bh SPIF (SPSR.7) + MODF (SPSR.4) + SPIOVF (SPSR.5) ESPI 12 PSPI, PSPIH No Timer 2 002BH TF2[2] ET2 13 PT2, PT2H No Input capture 0063H CAPF[2:0] (CAPCON0[2:0]) ECAP 14 PCAP, PCAPH No PWM interrupt 006BH PWMF EPWM 15 PPWM, PPWMH No Serial port 1 007BH RI_1 + TI_1 ES_1 16 PS_1, PSH_1 No Timer 3 0083H TF3[2] (T3CON.4) ET3 17 PT3, PT3H No Self Wake-up Timer 008BH WKTF (WKCON.4) EWKT 18 PWKT, PWKTH Yes [1] While the external interrupt pin is set as edge triggered (ITx = 1), its own flag IEx will be automatically cleared if the interrupt service routine (ISR) is executed. While as level triggered (ITx = 0), IEx follows the inverse of respective pin state. It is not controlled via software. [2] TF0, TF1, or TF3 is automatically cleared if the interrupt service routine (ISR) is executed. On the contrary, be aware that TF2 is not. [3] If level triggered is selected for pin interrupt channel n, PIFn flag reflects the respective channel state. It is not controlled via software. Jan. 27, 2018 Page 146 of 205 Rev. 1.02 N76E885 Datasheet IP – Interrupt Priority (Bit-addressable)[1] 7 6 5 PADC PBOD R/W R/W Address: B8H Bit Name 4 PS R/W 3 PT1 R/W 2 PX1 R/W 1 0 PT0 PX0 R/W R/W Reset value: 0000 0000b Description 6 PADC ADC interrupt priority low bit 5 PBOD Brown-out detection interrupt priority low bit 4 PS Serial port 0 interrupt priority low bit 3 PT1 Timer 1 interrupt priority low bit 2 PX1 External interrupt 1 priority low bit 1 PT0 Timer 0 interrupt priority low bit External interrupt 0 priority low bit 0 PX0 [1] IP is used in combination with the IPH to determine the priority of each interrupt source. See Table 21–2. Interrupt Priority Level Setting for correct interrupt priority configuration. IPH – Interrupt Priority High[2] 7 6 5 PADCH PBODH R/W R/W Address: B7H Bit Name 4 PSH R/W 3 PT1H R/W 2 PX1H R/W 1 0 PT0H PX0H R/W R/W Reset value: 0000 0000b Description 6 PADC ADC interrupt priority high bit 5 PBOD Brown-out detection interrupt priority high bit 4 PSH Serial port 0 interrupt priority high bit 3 PT1H Timer 1 interrupt priority high bit 2 PX1H External interrupt 1 priority high bit 1 PT0H Timer 0 interrupt priority high bit External interrupt 0 priority high bit 0 PX0H [2] IPH is used in combination with the IP respectively to determine the priority of each interrupt source. See Table 21–2. Interrupt Priority Level Setting for correct interrupt priority configuration. EIP – Extensive Interrupt Priority[3] 7 6 5 PT2 PSPI PFB R/W R/W R/W Address: EFH Bit Name 7 Jan. 27, 2018 PT2 4 PWDT R/W 3 PPWM R/W 2 PCAP R/W 1 0 PPI PI2C R/W R/W Reset value: 0000 0000b Description Timer 2 interrupt priority low bit Page 147 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 6 PSPI SPI interrupt priority low bit 5 PFB Fault Brake interrupt priority low bit 4 PWDT WDT interrupt priority low bit 3 PPWM PWM interrupt priority low bit 2 PCAP Input capture interrupt priority low bit 1 PPI 0 PI2C Pin interrupt priority low bit 2 I C interrupt priority low bit [3] EIP is used in combination with the EIPH to determine the priority of each interrupt source. See Table 21–2. Interrupt Priority Level Setting for correct interrupt priority configuration. EIPH – Extensive Interrupt Priority High[4] 7 6 5 4 PT2H PSPIH PFBH PWDTH R/W R/W R/W R/W Address: F7H Bit Name 3 PPWMH R/W 2 PCAPH R/W 1 0 PPIH PI2CH R/W R/W Reset value: 0000 0000b Description 7 PT2H Timer 2 interrupt priority high bit 6 PSPIH SPI interrupt priority high bit 5 PFBH Fault Brake interrupt priority high bit 4 PWDTH WDT interrupt priority high bit 3 PPWMH PWM interrupt priority high bit 2 PCAPH Input capture interrupt priority high bit 1 PPIH 0 PI2CH Pin interrupt priority high bit 2 I C interrupt priority high bit [4] EIPH is used in combination with the EIP to determine the priority of each interrupt source. See Table 21–2. Interrupt Priority Level Setting for correct interrupt priority configuration. EIP1 – Extensive Interrupt Priority 1[5] 7 6 5 Address: FEH, Page: 0 Bit Name 2 PWKT 1 PT3 4 - 3 - 2 PWKT R/W 1 0 PT3 PS_1 R/W R/W Reset value: 0000 0000b Description WKT interrupt priority low bit Timer 3 interrupt priority low bit Serial port 1 interrupt priority low bit PS_1 [5] EIP1 is used in combination with the EIPH1 to determine the priority of each interrupt source. See Table 21–2. Interrupt Priority Level Setting for correct interrupt priority configuration. 0 Jan. 27, 2018 Page 148 of 205 Rev. 1.02 N76E885 Datasheet EIPH1 – Extensive Interrupt Priority High 1[6] 7 6 5 4 Address: FFH, Page: 0 Bit Name 2 PWKTH 1 PT3H 3 - 2 PWKTH R/W 1 0 PT3H PSH_1 R/W R/W Reset value: 0000 0000b Description WKT interrupt priority high bit Timer 3 interrupt priority high bit Serial port 1 interrupt priority high bit PSH_1 [6] EIPH1 is used in combination with the EIP1 to determine the priority of each interrupt source. See Table 21–2. Interrupt Priority Level Setting for correct interrupt priority configuration. 0 21.4 Interrupt Service The interrupt flags are sampled every system clock cycle. In the same cycle, the sampled interrupts are polled and their priority is resolved. If certain conditions are met then the hardware will execute an internally generated LCALL instruction, which will vector the process to the appropriate interrupt vector address. The conditions for generating the LCALL are, 1. An interrupt of equal or higher priority is not currently being serviced. 2. The current polling cycle is the last cycle of the instruction currently being executed. 3. The current instruction does not involve a write to any enabling or priority setting bits and is not a RETI. If any of these conditions are not met, then the LCALL will not be generated. The polling cycle is repeated every system clock cycle. If an interrupt flag is active in one cycle but not responded to for the above conditions are not met, if the flag is not still active when the blocking condition is removed, the denied interrupt will not be serviced. This means that the interrupt flag, which was once active but not serviced is not remembered. Every polling cycle is new. The processor responds to a valid interrupt by executing an LCALL instruction to the appropriate service routine. This action may or may not clear the flag, which caused the interrupt according to different interrupt source. The hardware LCALL behaves exactly like the software LCALL instruction. This instruction saves the Program Counter contents onto the Stack RAM but does not save the Program Status Word (PSW). The PC is reloaded with the vector address of that interrupt, which caused the LCALL. Execution continues from the vectored address until an RETI instruction is executed. On execution of the RETI instruction, the processor pops the Stack and loads the PC with the contents at the top of the stack. User should take care that the status of the stack. The processor does not notice anything if the stack contents are modified and will proceed with execution from the Jan. 27, 2018 Page 149 of 205 Rev. 1.02 N76E885 Datasheet address put back into PC. Note that a simple RET instruction would perform exactly the same process as a RETI instruction, but it would not inform the Interrupt controller that the interrupt service routine is completed. RET would leave the controller still thinking that the service routine is underway, making future interrupts impossible. 21.5 Interrupt Latency The response time for each interrupt source depends on several factors, such as the nature of the interrupt and the instruction underway. Each interrupt flags are polled and priority decoded each system clock cycle. If a request is active and all three previous conditions are met, then the hardware generated LCALL is executed. This LCALL itself takes 4 clock cycles to be completed. Thus, there is a minimum reaction time of 5 clock cycles between the interrupt flag being set and the interrupt service routine being executed. A longer response time should be anticipated if any of the three conditions are not met. If a higher or equal priority is being serviced, then the interrupt latency time obviously depends on the nature of the service routine currently being executed. If the polling cycle is not the last clock cycle of the instruction being executed, then an additional delay is introduced. The maximum response time (if no other interrupt is currently being serviced or the new interrupt is of greater priority) occurs if the device is performing a RETI, and then executes a longest 6-clock-cycle instruction as the next instruction. From the time an interrupt source is activated (not detected), the longest reaction time is 16 clock cycles. This period includes 5 clock cycles to complete RETI, 6 clock cycles to complete the longest instruction, 1 clock cycle to detect the interrupt, and 4 clock cycles to complete the hardware LCALL to the interrupt vector location. Thus in a single-interrupt system the interrupt response time will always be more than 5 clock cycles and not more than 16 clock cycles. 21.6 External Interrupt Pins The external interrupt ̅̅̅̅̅̅̅ and ̅̅̅̅̅̅̅ can be used as interrupt sources. They are selectable to be either edge or level triggered depending on bits IT0 (TCON.0) and IT1 (TCON.2). The bits IE0 (TCON.1) and IE1 (TCON.3) are the flags those are checked to generate the interrupt. In the edge triggered mode, the ̅̅̅̅̅̅̅ or ̅̅̅̅̅̅̅ inputs are sampled every system clock cycle. If the sample is high in one cycle and low in the next, then a high to low transition is detected and the interrupts request flag IE0 or IE1 will be set. Since the external interrupts are sampled every system clock, they have to be held high or low for at least one system clock cycle. The IE0 and IE1 are automatically cleared when the interrupt service routine is called. If the level triggered mode is selected, then the requesting source has to hold the pin low till the interrupt is serviced. The IE0 and IE1 will not be cleared by the Jan. 27, 2018 Page 150 of 205 Rev. 1.02 N76E885 Datasheet hardware on entering the service routine. In the level triggered mode, IE0 and IE1 follows the inverse value of ̅̅̅̅̅̅̅ and ̅̅̅̅̅̅̅ pins. If interrupt pins continue to be held low even after the service routine is completed, the processor will acknowledge another interrupt request from the same source. Both ̅̅̅̅̅̅̅ and ̅̅̅̅̅̅̅ can wake up the device from the Power-down mode. TCON – Timer 0 and 1 Control (Bit-addressable) 7 6 5 4 TF1 TR1 TF0 TR0 R/W R/W R/W Name Description R/W 3 IE1 R (level) R/W (edge) 2 IT1 R/W Address: 88H Bit 1 0 IE0 IT0 R (level) R/W R/W (edge) Reset value: 0000 0000b 3 IE1 External interrupt 1 edge flag If IT1 = 1 (falling edge trigger), this flag will be set by hardware when a falling edge is detected. It remain set until cleared via software or cleared by hardware in the beginning of its interrupt service routine. If IT1 = 0 (low level trigger), this flag follows the inverse of the ̅̅̅̅̅̅̅ input signal's logic level. Software cannot control it. 2 IT1 External interrupt 1 type select This bit selects by which type that ̅̅̅̅̅̅̅ is triggered. 0 = ̅̅̅̅̅̅̅ is low level triggered. 1 = ̅̅̅̅̅̅̅ is falling edge triggered. 1 IE0 External interrupt 0 edge flag If IT0 = 1 (falling edge trigger), this flag will be set by hardware when a falling edge is detected. It remain set until cleared via software or cleared by hardware in the beginning of its interrupt service routine. If IT0 = 0 (low level trigger), this flag follows the inverse of the ̅̅̅̅̅̅̅ input signal's logic level. Software cannot control it. 0 IT0 External interrupt 0 type select This bit selects by which type that ̅̅̅̅̅̅̅ is triggered. 0 = ̅̅̅̅̅̅̅ is low level triggered. 1 = ̅̅̅̅̅̅̅ is falling edge triggered. Jan. 27, 2018 Page 151 of 205 Rev. 1.02 N76E885 Datasheet 22. IN-APPLICATION-PROGRAMMING (IAP) Unlike A ’s real-time operation, to update flash data often takes long time. Furthermore, it is a quite complex timing procedure to erase, program, or read flash data. The N76E885 carried out the flash operation with convenient mechanism to help user re-programming the flash content by In-ApplicationProgramming (IAP). IAP is an in-circuit electrical erasure and programming method through software. After IAP enabling by setting IAPEN (CHPCON.0 with TA protected) and setting the enable bit in IAPUEN that allows the target block to be updated, user can easily fill the 16-bit target address in IAPAH and IAPAL, data in IAPFD, and command in IAPCN. Then the IAP is ready to begin by setting a triggering bit IAPGO (IAPTRG.0). Note that IAPTRG is also TA protected. At this moment, the CPU holds the Program Counter and the built-in IAP automation takes over to control the internal chargepump for high voltage and the detail signal timing. The erase and program time is internally controlled disregard of the operating voltage and frequency. Nominally, a page-erase time is 5 ms and a byteprogram time is 23.5 μs. After IAP action completed, the Program Counter continues to run the following instructions. The IAPGO bit will be automatically cleared. An IAP failure flag, IAPFF (CHPCON.6), can be check whether the previous IAP operation was successful or not. Through this progress, user can easily erase, program, and verify the Flash Memory by just taking care of pure software. The following registers are related to IAP processing. CONFIG2 7 CBODEN R/W Bit 6 Name 3 BOIAP 5 CBOV[2:0] R/W Name 6 Jan. 27, 2018 IAPFF 3 BOIAP R/W 2 1 0 CBORST R/W Factory default value: 1111 1111b Description Brown-out inhibiting IAP This bit decide whether IAP erasing or programming is inhibited by brown-out status. This bit is valid only when brown-out detection is enabled. 1 = IAP erasing or programming is inhibited if VDD is lower than VBOD. 0 = IAP erasing or programming is allowed under any workable VDD. CHPCON – Chip Control (TA protected) 7 6 5 SWRST IAPFF W R/W Address: 9FH Bit 4 4 3 2 1 0 BS IAPEN R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description IAP fault flag Page 152 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description The hardware will set this bit after IAPGO (ISPTRG.0) is set if any of the following condition is met: (1) The accessing address is oversize. (2) IAPCN command is invalid. (3) IAP erases or programs updating un-enabled block. (4) IAP erasing or programming operates under VBOD while BOIAP (CONFIG2.5) remains un-programmed 1 with BODEN (BODCON0.7) as 1 and BORST (BODCON0.2) as 0. This bit should be cleared via software. 0 IAPEN IAP enable 0 = IAP function Disabled. 1 = IAP function Enabled. Once enabling IAP function, the HIRC will be turned on for timing control. To clear IAPEN should always be the last instruction after IAP operation to stop internal oscillator if reducing power consumption is concerned. IAPUEN – IAP Updating Enable (TA protected) 7 6 5 4 Address: A5H Bit Name 3 - 2 CFUEN R/W Description 2 CFUEN CONFIG bytes updated enable 0 = Inhibit erasing or programming CONFIG bytes by IAP. 1 = Allow erasing or programming CONFIG bytes by IAP. 1 LDUEN LDROM updated enable 0 = Inhibit erasing or programming LDROM by IAP. 1 = Allow erasing or programming LDROM by IAP. 0 APUEN APROM updated enable 0 = Inhibit erasing or programming APROM by IAP. 1 = Allow erasing or programming APROM by IAP. IAPCN – IAP Control 7 6 IAPB[1:0] R/W Address: AFH Bit Name 7:6 IAPB[1:0] 5 FOEN 4 FCEN 3:0 FCTRL[3:0] Jan. 27, 2018 1 0 LDUEN APUEN R/W R/W Reset value: 0000 0000b 5 FOEN R/W 4 FCEN R/W 3 2 1 0 FCTRL[3:0] R/W Reset value: 0011 0000b Description IAP control This byte is used for IAP command. For details, see Table 22–1. IAP Modes and Command Codes. Page 153 of 205 Rev. 1.02 N76E885 Datasheet IAPAH – IAP Address High Byte 7 6 5 4 3 2 1 0 IAPA[15:8] R/W Address: A7H Bit 7:0 Reset value: 0000 0000b Name Description IAPA[15:8] IAP address high byte IAPAH contains address IAPA[15:8] for IAP operations. IAPAL – IAP Address Low Byte 7 6 5 4 3 2 1 0 IAPA[7:0] R/W Address: A6H Bit 7:0 Reset value: 0000 0000b Name IAPA[7:0] IAPFD – IAP Flash Data 7 6 Description IAP address low byte IAPAL contains address IAPA[7:0] for IAP operations. 5 4 3 2 1 0 IAPFD[7:0] R/W Address: AEH Bit 7:0 Jan. 27, 2018 Reset value: 0000 0000b Name Description IAPFD[7:0] IAP flash data This byte contains flash data, which is read from or is going to be written to the Flash Memory. User should write data into IAPFD for program mode before triggering IAP processing and read data from IAPFD for read/verify mode after IAP processing is finished. Page 154 of 205 Rev. 1.02 N76E885 Datasheet IAPTRG – IAP Trigger (TA protected) 7 6 5 Address: A4H Bit Name 0 IAPGO 4 - 3 - 2 - 1 0 IAPGO W Reset value: 0000 0000b Description IAP go IAP begins by setting this bit as logic 1. After this instruction, the CPU holds the Program Counter (PC) and the IAP hardware automation takes over to control the progress. After IAP action completed, the Program Counter continues to run the following instruction. The IAPGO bit will be automatically cleared and always read as logic 0. Before triggering an IAP action, interrupts (if enabled) should be temporary disabled for hardware limitation. The program process should follows below. CLR EA MOV TA,#0AAH MOV TA,#55H ORL IAPTRG,#01H (SETB EA) 22.1 IAP Commands The N76E885 provides a wide range of applications to perform IAP to APROM, LDROM, or CONFIG bytes. The IAP action mode and the destination of the flash block are defined by IAP control register IAPCN. Table 22–1. IAP Modes and Command Codes IAPCN IAP Mode IAPB[1:0] FOEN FCEN FCTRL[3:0] IAPA[15:0] {IAPAH, IAPAL} IAPFD[7:0] XX[1] 0 0 1011 X DAH Device ID read XX 0 0 1100 Low-byte DID: 0000H High-byte DID: 0001H Low-byte DID: 50H High-byte DID: 21H 96-bit Unique Code read XX 0 0 0100 0000H to 000BH Data out Company ID read [2] FFH APROM page-erase 00 1 0 0010 Address in LDROM page-erase 01 1 0 0010 Address in[2] FFH APROM byte-program 00 1 0 0001 Address in Data in LDROM byte-program 01 1 0 0001 Address in Data in APROM byte-read 00 0 0 0000 Address in Data out LDROM byte-read 01 0 0 0000 Address in Data out All CONFIG bytes erase 11 1 0 0010 0000H FFH CONFIG byte-program 11 1 0 0001 CONFIG0: 0000H CONFIG1: 0001H CONFIG2: 0002H CONFIG4: 0004H Data in Jan. 27, 2018 Page 155 of 205 Rev. 1.02 N76E885 Datasheet IAPCN IAP Mode IAPB[1:0] FOEN FCEN FCTRL[3:0] CONFIG byte-read 11 0 0 0000 IAPA[15:0] {IAPAH, IAPAL} CONFIG0: 0000H CONFIG1: 0001H CONFIG2: 0002H CONFIG4: 0004H IAPFD[7:0] Data out [1] “X” means “don’t care”. [2] Each page is 128 Bytes size. Therefore, the address should be the address pointed to the target page. 22.2 IAP User Guide IAP facilitates the updating flash contents in a convenient way; however, user should follow some restricted laws in order that the IAP operates correctly. Without noticing warnings will possible cause undetermined results even serious damages of devices. Furthermore, this paragraph will also support useful suggestions during IAP procedures. (1) If no more IAP operation is needed, user should clear IAPEN (CHPCON.0). It will make the system void to trigger IAP unaware. Furthermore, IAP requires the HIRC running. If the external clock source is selected, disabling IAP will stop the HIRC for saving power consumption. Note that a write to IAPEN is TA protected. (2) When the LOCK bit (CONFIG0.1) is activated, IAP reading, writing, or erasing can still be valid. During IAP progress, interrupts (if enabled) should be disabled temporally by clearing EA bit for implement limitation. Do not attempt to erase or program to a page that the code is currently executing. This will cause unpredictable program behavior and may corrupt program data. 22.3 Using Flash Memory as Data Storage In general application, there is a need of data storage, which is non-volatile so that it remains its content even after the power is off. Therefore, in general application user can read back or update the data, which rules as parameters or constants for system control. The Flash Memory array of the N76E885 supports IAP function and any byte in the Flash Memory array may be read using the MOVC instruction and thus is suitable for use as non-volatile data storage. IAP provides erase and program function that makes it easy for one or more bytes within a page to be erased and programmed in a routine. IAP performs in the application under the control of the microcontroller’s firmware. Be aware of Flash Memory writing endurance of 100,000 cycles. A demo is illustrated as follows. Assembly demo code: Jan. 27, 2018 Page 156 of 205 Rev. 1.02 N76E885 Datasheet ;****************************************************************************** ; This code illustrates how to use IAP to make APROM 201h as a byte of ; Data Flash when user code is executed in APROM. ;****************************************************************************** PAGE_ERASE_AP EQU 00100010b BYTE_PROGRAM_AP EQU 00100001b ORG 0000h MOV MOV ORL TA,#0AAh TA,#55h CHPCON,#00000001b ;CHPCON is TA protected MOV MOV ORL TA,#0AAh TA,#55h IAPUEN,#00000001b ;IAPUEN is TA protected MOV MOV MOV MOV MOV MOV ORL MOV MOV MOV MOV MOV MOV ORL IAPCN,#PAGE_ERASE_AP IAPAH,#02h IAPAL,#00h IAPFD,#0FFh TA,#0AAh TA,#55h IAPTRG,#00000001b IAPCN,#BYTE_PROGRAM_AP IAPAH,#02h IAPAL,#01h IAPFD,#55h TA,#0AAh TA,#55h IAPTRG,#00000001b ;Erase page 200h~27Fh MOV MOV ANL TA,#0AAh TA,#55h IAPUEN,#11111110b ;APUEN = 0, disable APROM update MOV MOV ANL TA,#0AAh TA,#55h CHPCON,#11111110b ;IAPEN = 0, disable IAP mode MOV CLR MOVC MOV DPTR,#201h A A,@A+DPTR P0,A SJMP $ Jan. 27, 2018 ;IAPEN = 1, enable IAP mode ;APUEN = 1, enable APROM update ;IAPTRG is TA protected ;write ‘1’ to IAPGO to trigger IAP process ;Program 201h with 55h ;Read content of address 201h Page 157 of 205 Rev. 1.02 N76E885 Datasheet C language demo code: //****************************************************************************** // This code illustrates how to use IAP to make APROM 201h as a byte of // Data Flash when user code is executed in APROM. //****************************************************************************** #define PAGE_ERASE_AP 0x22 #define BYTE_PROGRAM_AP 0x21 /*Data Flash, as part of APROM, is read by MOVC. Data Flash can be defined as 128-element array in “code” area from absolute address 0x0200 */ volatile unsigned char code Data_Flash[128] _at_ 0x0200; Main (void) { TA = 0xAA; TA = 0x55; CHPCON |= 0x01; //CHPCON is TA protected //IAPEN = 1, enable IAP mode TA = 0xAA; TA = 0x55; IAPUEN |= 0x01; //IAPUEN is TA protected IAPCN = PAGE_ERASE_AP; IAPAH = 0x02; IAPAL = 0x00; IAPFD = 0xFF; TA = 0xAA; TA = 0x55; IAPTRG |= 0x01; //Erase page 200h~27Fh IAPCN = BYTE_PROGRAM_AP; IAPAH = 0x02; IAPAL = 0x01; IAPFD = 0x55; TA = 0xAA; TA = 0x55; IAPTRG |= 0x01; // Program 201h with 55h TA = 0xAA; TA = 0x55; IAPUEN &= ~0x01; //IAPUEN is TA protected TA = 0xAA; TA = 0x55; CHPCON &= ~0x01; //CHPCON is TA protected P0 = Data_Flash[1]; //Read content of address 200h+1 //APUEN = 1, enable APROM update //IAPTRG is TA protected //write ‘1’ to IAPGO to trigger IAP process //write ‘1’ to IAPGO to trigger IAP process //APUEN = 0, disable APROM update //IAPEN = 0, disable IAP mode while(1); } 22.4 In-System-Programming (ISP) The Flash Memory supports both hardware programming and In-Application-Programming (IAP). Hardware programming mode uses gang-writers to reduce programming costs and time to market while the products enter the mass production state. However, if the product is just under development Jan. 27, 2018 Page 158 of 205 Rev. 1.02 N76E885 Datasheet or the end product needs firmware updating in the hand of an end user, the hardware programming mode will make repeated programming difficult and inconvenient. In-System-Programming (ISP) makes it easy and possible. ISP performs Flash Memory updating without removing the microcontroller from the system. It allows a device to be re-programmed under software control. Furthermore, the capability to update the application firmware makes wide range of applications possible. User can develop a custom Boot Code that resides in LDROM. The maximum size of LDROM is 4K Bytes. User developed Boot Code can be re-programmed by parallel writer or In-Circuit-Programming (ICP) tool. General speaking, an ISP is carried out by a communication between PC and MCU. PC transfers the new User Code to MCU through serial port. Then Boot Code receives it and re-programs into User Code through IAP commands. Nuvoton provides ISP firmware and PC application for N76E885. It makes user quite easy perform ISP through UART port. Please visit Nuvoton 8-bit Microcontroller website: Nuvoton 80C51 Microcontroller Technical Support. A simple ISP demo code is given below. Assembly demo code: ;****************************************************************************** ; This code illustrates how to do APROM and CONFIG IAP from LDROM. ; APROM are re-programmed by the code to output P1 as 55h and P2 as AAh. ; The CONFIG2 is also updated to disable BOD reset. ; User needs to configure CONFIG0 = 0x7F, CONFIG1 = 0xFE, CONFIG2 = 0xFF. ;****************************************************************************** PAGE_ERASE_AP EQU 00100010b BYTE_PROGRAM_AP EQU 00100001b BYTE_READ_AP EQU 00000000b ALL_ERASE_CONFIG EQU 11100010b BYTE_PROGRAM_CONFIG EQU 11100001b BYTE_READ_CONFIG EQU 11000000b ORG 0000h CLR CALL EA Enable_IAP CALL CALL CALL CALL CALL Enable_AP_Update Erase_AP Program_AP Disable_AP_Update Program_AP_Verify CALL CALL CALL CALL CALL CALL Read_CONFIG Enable_CONFIG_Update Erase_CONFIG Program_CONFIG Disable_CONFIG_Update Program_CONFIG_Verify CALL Disable_IAP Jan. 27, 2018 ;disable all interrupts ;erase AP data ;programming AP data ;verify Programmed AP data ;read back CONFIG2 ;erase CONFIG bytes ;programming CONFIG2 with new data ;verify Programmed CONFIG2 Page 159 of 205 Rev. 1.02 N76E885 Datasheet MOV MOV ANL MOV MOV ORL TA,#0AAh TA,#55h CHPCON,#11111101b TA,#0AAh TA,#55h CHPCON,#80h SJMP $ ;TA protection ; ;BS = 0, reset to APROM ;software reset and reboot from APROM ;******************************************************************** ; IAP Subroutine ;******************************************************************** Enable_IAP: MOV TA,#0AAh ;CHPCON is TA protected MOV TA,#55h ORL CHPCON,#00000001b ;IAPEN = 1, enable IAP mode RET Disable_IAP: MOV TA,#0AAh MOV TA,#55h ANL CHPCON,#11111110b RET Enable_AP_Update: MOV TA,#0AAh MOV TA,#55h ORL IAPUEN,#00000001b RET Disable_AP_Update: MOV TA,#0AAh MOV TA,#55h ANL IAPUEN,#11111110b RET Enable_CONFIG_Update: MOV TA,#0AAh MOV TA,#55h ORL IAPUEN,#00000100b RET Disable_CONFIG_Update: MOV TA,#0AAh MOV TA,#55h ANL IAPUEN,#11111011b RET Trigger_IAP: MOV TA,#0AAh MOV TA,#55h ORL IAPTRG,#00000001b RET ;IAPEN = 0, disable IAP mode ;IAPUEN is TA protected ;APUEN = 1, enable APROM update ;APUEN = 0, disable APROM update ;CFUEN = 1, enable CONFIG update ;CFUEN = 0, disable CONFIG update ;IAPTRG is TA protected ;write ‘1’ to IAPGO to trigger IAP process ;******************************************************************** ; IAP APROM Function ;******************************************************************** Erase_AP: MOV IAPCN,#PAGE_ERASE_AP MOV IAPFD,#0FFh MOV R0,#00h Erase_AP_Loop: Jan. 27, 2018 Page 160 of 205 Rev. 1.02 N76E885 Datasheet MOV MOV CALL MOV CALL INC CJNE RET IAPAH,R0 IAPAL,#00h Trigger_IAP IAPAL,#80h Trigger_IAP R0 R0,#44h,Erase_AP_Loop Program_AP: MOV IAPCN,#BYTE_PROGRAM_AP MOV IAPAH,#00h MOV IAPAL,#00h MOV DPTR,#AP_code Program_AP_Loop: CLR A MOVC A,@A+DPTR MOV IAPFD,A CALL Trigger_IAP INC DPTR INC IAPAL MOV A,IAPAL CJNE A,#14,Program_AP_Loop RET Program_AP_Verify: MOV IAPCN,#BYTE_READ_AP MOV IAPAH,#00h MOV IAPAL,#00h MOV DPTR,#AP_code Program_AP_Verify_Loop: CALL Trigger_IAP CLR A MOVC A,@A+DPTR MOV B,A MOV A,IAPFD CJNE A,B,Program_AP_Verify_Error INC DPTR INC IAPAL MOV A,IAPAL CJNE A,#14,Program_AP_Verify_Loop RET Program_AP_Verify_Error: CALL Disable_IAP MOV P0,#00h SJMP $ ;******************************************************************** ; IAP CONFIG Function ;******************************************************************** Erase_CONFIG: MOV IAPCN,#ALL_ERASE_CONFIG MOV IAPAH,#00h MOV IAPAL,#00h MOV IAPFD,#0FFh CALL Trigger_IAP RET Read_CONFIG: MOV IAPCN,#BYTE_READ_CONFIG MOV IAPAH,#00h Jan. 27, 2018 Page 161 of 205 Rev. 1.02 N76E885 Datasheet MOV CALL MOV RET IAPAL,#02h Trigger_IAP R7,IAPFD Program_CONFIG: MOV IAPCN,#BYTE_PROGRAM_CONFIG MOV IAPAH,#00h MOV IAPAL,#02h MOV A,R7 ANL A,#11111011b MOV IAPFD,A ;disable BOD reset MOV R6,A ;temp data CALL Trigger_IAP RET Program_CONFIG_Verify: MOV IAPCN,#BYTE_READ_CONFIG MOV IAPAH,#00h MOV IAPAL,#02h CALL Trigger_IAP MOV B,R6 MOV A,IAPFD CJNE A,B,Program_CONFIG_Verify_Error RET Program_CONFIG_Verify_Error: CALL Disable_IAP MOV P0,#00h SJMP $ ;******************************************************************** ; APROM code ;******************************************************************** AP_code: DB 75h,0B1h, 00h ;OPCODEs of “MOV P0M1,#0” DB 75h,0ACh, 00h ;OPCODEs of “MOV P3M1,#0” DB 75h, 90h, 55h ;OPCODEs of “MOV P1,#55h” DB 75h,0A0h,0AAh ;OPCODEs of “MOV P2,#0AAh” DB 80h,0FEh ;OPCODEs of “SJMP $” END Jan. 27, 2018 Page 162 of 205 Rev. 1.02 N76E885 Datasheet 23. POWER MANAGEMENT The N76E885 has several features that help user to control the power consumption of the device. The power reduced feature has two option modes: Idle mode and Power-down mode, to save the power consumption. For a stable current consumption, the state and mode of each pin should be taken care of. The minimum power consumption can be attained by giving the pin state just the same as the external pulls for example output 1 if pull-high is used or output 0 if pull-low. If the I/O pin is floating, user is recommended to leave it as quasi-bidirectional mode. If P1.2 is configured as a input-only pin, it should have an external pull-up or pull-low, or enable its internal pull-up by setting P12UP (P1M2.2). PCON – Power Control 7 6 SMOD SMOD0 R/W R/W Address: 87H Bit Name 5 - 4 3 2 1 0 POF GF1 GF0 PD IDL R/W R/W R/W R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description 1 PD Power-down mode Setting this bit puts CPU into Power-down mode. Under this mode, both CPU and peripheral clocks stop and Program Counter (PC) suspends. It provides the lowest power consumption. After CPU is woken up from Power-down, this bit will be automatically cleared via hardware and the program continue executing the interrupt service routine (ISR) of the very interrupt source that woke the system up before. After return from the ISR, the device continues execution at the instruction, which follows the instruction that put the system into Power-down mode. Note that If IDL bit and PD bit are set simultaneously, CPU will enter Power-down mode. Then it does not go to Idle mode after exiting Power-down. 0 IDL Idle mode Setting this bit puts CPU into Idle mode. Under this mode, the CPU clock stops and Program Counter (PC) suspends but all peripherals keep activated. After CPU is woken up from Idle, this bit will be automatically cleared via hardware and the program continue executing the ISR of the very interrupt source that woke the system up before. After return from the ISR, the device continues execution at the instruction which follows the instruction that put the system into Idle mode. P1M2 – Port 1 Mode Select 2 7 6 Address: B4H Bit Name 2 Jan. 27, 2018 P12UP 5 - 4 - 3 CLOEN R/W 2 P12UP R/W 1 0 P1M2.1 P1M2.0 R/W R/W Reset value: 0000 0000b Description P1.2 pull-up enable 0 = P1.2 pull-up Disabled. 1 = P1.2 pull-up Enabled. This bit is valid only when RPD (CONFIG0.2) is programmed as 0. When selecting as a ̅̅̅̅̅̅ pin, the pull-up is always enabled. Page 163 of 205 Rev. 1.02 N76E885 Datasheet 23.1 Idle Mode Idle mode suspends CPU processing by holding the Program Counter. No program code are fetched and run in Idle mode. It forces the CPU state to be frozen. The Program Counter (PC), Stack Pointer (SP), Program Status Word (PSW), Accumulator (ACC), and the other registers hold their contents during Idle mode. The port pins hold the logical states they had at the time Idle was activated. Generally, it saves considerable power of typical half of the full operating power. Since the clock provided for peripheral function logic circuit like timer or serial port still remain in Idle mode, the CPU can be released from the Idle mode with any of enabled interrupt sources. User can put the device into Idle mode by writing 1 to the bit IDL (PCON.0). The instruction that sets the IDL bit is the last instruction that will be executed before the device enters Idle mode. The Idle mode can be terminated in two ways. First, as mentioned, any enabled interrupt will cause an exit. It will automatically clear the IDL bit, terminate Idle mode, and the interrupt service routine (ISR) will be executed. After using the RETI instruction to jump out of the ISR, execution of the program will be the one following the instruction, which put the CPU into Idle mode. The second way to terminate Idle mode is with any reset other than software reset. Remember that if Watchdog reset is used to exit Idle mode, the WIDPD (WDCON.4) needs to be set 1 to let WDT keep running in Idle mode. 23.2 Power-Down Mode Power-down mode is the lowest power state that the N76E885 can enter. It remain the power consumption as a ”μA” level by stopping the system clock source. Both of PU and peripheral functions like Timers or UART are frozen. Flash memory is put into its stop mode. All activity is completely stopped and the power consumption is reduced to the lowest possible value. The device can be put into Power-down mode by writing 1 to bit PD (PCON.1). The instruction that does this action will be the last instruction to be executed before the device enters Power-down mode. In the Power-down mode, RAM maintains its content. The port pins output the values held by their own state before Power-down respectively. There are several ways to exit the N76E885 from the Power-down mode. The first is with all resets except software reset. Brown-out reset will also wake up CPU from Power-down mode. Be sure that brown-out detection is enabled before the system enters Power-down. However, for least power consumption, it is recommended to enable low power BOD in Power-down mode. Of course the external pin reset and power-on reset will remove the Power-down status. After the external reset or power-on reset. The CPU is initialized and start executing program code from the beginning. Jan. 27, 2018 Page 164 of 205 Rev. 1.02 N76E885 Datasheet The second way to wake the N76E885 up from the Power-down mode is by an enabled external interrupt. The trigger on the external pin will asynchronously restart the system clock. After oscillator is stable, the device executes the interrupt service routine (ISR) for the corresponding external interrupt. After the ISR is completed, the program execution returns to the instruction after the one, which puts the device into Power-down mode and continues. Interrupts that allows to wake up CPU from Powerdown mode includes external interrupt ̅̅̅̅̅̅̅ and ̅̅̅̅̅̅̅, pin interrupt, WDT interrupt, WKT interrupt, and brown-out interrupt. Jan. 27, 2018 Page 165 of 205 Rev. 1.02 N76E885 Datasheet 24. CLOCK SYSTEM The N76E885 has a wide variety of clock sources and selection features that allow it to be used in a wide range of applications while maximizing performance and minimizing power consumption. The N76E885 provides five options of the system clock sources including internal oscillator, crystal/resonator, or external clock from XIN pin via software. The N76E885 is embedded with two internal oscillators: one 10 kHz low-speed and one 22.118 MHz high-speed, which is factory trimmed to ±2% under all conditions. If the clock source is from the crystal/resonator, the frequency supports two ranges: 2 MHz to 25 MHz high-speed and 32.768 kHz low-speed. A clock divider CKDIV is also available on N76E885 for adjustment of the flexibility between power consumption and operating performance. 32.768 kHz Oscillating Circuit FLXT 01 2~25 MHz Oscillating Circuit XOUT XIN 22.118 MHz Internal [1] Oscillator 10 kHz Internal Oscillator FHXT FECLK FHIRC Flash Memory 10 11 EXTEN[1:0] (CKEN[7:6]) 10 01 Clock Filter FOSC Clock FSYS Divider CPU 00 CKDIV FLIRC OSC[1:0] (CKSWT[2:1]) Watchdog Timer 0 1 [1] Default system clock source after power-on WKTCK (WKCON.5) Self Wake-up Timer Peripherals CLOEN (P1M2.3) CLO (P2.6) Figure 24.1 Clock System Block Diagram 24.1 System Clock Sources There are a total of five system clock sources selectable in the N76E885 including high-speed internal oscillator, low-speed internal oscillator, high-speed external crystal/resonator, low-speed external crystal/resonator, and external clock input. Each of them can be the system clock source in the N76E885. Different active system clock sources also affect multi-function of P1.0/XIN and P1.1/XOUT pins. Jan. 27, 2018 Page 166 of 205 Rev. 1.02 N76E885 Datasheet 24.1.1 Internal Oscillators There are two internal oscillators in the N76E885 – one 22.118 MHz high-speed internal oscillator (HIRC) and one 10 kHz low-speed (LIRC). Both of them can be selected as the system clock. HIRC can be enabled by setting HIRCEN (CKEN.5). LIRC is enabled after device is powered up. User can set OSC[1:0] (CKSWT [2:1]) as [1,1] or [0,0] to select the HIRC as the system clock. By setting OSC[1:0] as [1,0], LIRC will be selected as the system clock. Note that after the N76E885 is powered, HIRC and LIRC will be both enabled and HIRC is default selected as the system clock source. While using internal oscillators, XIN and XOUT automatically switch as two general purpose I/O P1.0 and P1.1 to expend the numbers of general purpose I/O. The I/O output mode of P1.0 and P1.1 can be selected by configuring P1M1 and P1M2 registers. 24.1.2 External Crystal/Resonator or Clock Input There are three possible clock source options of external clock sources – 2 MHz to 25 MHz highspeed crystal/resonator (HXT), 32.768 kHz low-speed crystal/resonator (LXT), and the external clock input (ECLK) through XIN pin. They are exclusively enabled by giving proper EXTEN[1:0] (CKEN[7:6]) value. User can change OSC[1:0] value as [0,1] to select the enabled external clock source as the system clock. When HXT or LXT is used as the system clock, XIN and XOUT are the input and output, respectively, of an internal inverting amplifier. A crystal or resonator should be connected between XIN and XOUT pins. When enabling and selecting ECLK as the system clock source, the system clock is supplied via the XIN pin. The common application is to drive X IN with an active oscillator or clocks from another host device. When ECLK is selected, XOUT pin automatically switches as a general purpose I/O P1.1. The I/O output mode of P1.1 can be selected by configuring P1M1 and P1M2 registers. Be aware that user should never feed any clock signal larger than voltage 1.8V to X IN and give a DC voltage to XOUT pin which value is half of XIN, when ECLK mode is selected. Otherwise, it may break the device. 24.2 System Clock Switching The N76E885 supports clock source switching on-the-fly by controlling CKSWT and CKEN registers via software. It provides a wide flexibility in application. Note that these SFRs are writing TA protected for precaution. With this clock source control, the clock source can be switched between the external clock source and the internal oscillator, even between the high and low-speed internal oscillator. However, during clock source switching, the device requires some amount of warm-up period for an original disabled clock source. Therefore, use should follow steps below to ensure a complete clock source switching. User can enable the target clock source by writing proper value into CKEN register, wait for the clock source stable by polling its status bit in CKSWT register, and switch to the target Jan. 27, 2018 Page 167 of 205 Rev. 1.02 N76E885 Datasheet clock source by changing OSC[1:0] (CKSWT[2:1]). After these step, the clock source switching is successful and then user can also disable the original clock source if power consumption is concerned. Note that if not following the steps above, the hardware will take certain actions to deal with such illegal operations as follows. 1. If user tries to disable the current clock source by changing CKEN value, the device will ignore this action. The system clock will remain the original one and CKEN will remain the original value. 2. If user tries to switch the system clock source to a disabled one by changing OSC[1:0] value, OSC[1:0] value will be updated right away. But the system clock will remain the original one and CKSWTF (CLKEN.0) flag will be set by hardware. 3. Once user switches the system clock source to an enabled but still instable one, the hardware will wait for stabilization of the target clock source and then switch to it in the background. During this waiting period, the device will continue executing the program with the original clock source and CKSWTF will be set as 1. After the stable flag of the target clock source (see CKSWT[7:3]) is set and the clock source switches successfully, CKSWTF will be cleared as 0 automatically by hardware. Here is an illustration of switching the clock source from HIRC source to HXT. MOV MOV ORL TA,#0AAh TA,#55h CKEN,#10000000b ;TA protection ; ;Enable the HXT ;******Polling can be ignored if not disabling the original clock source****** Polling_HXT_stable: ;Waiting for the HXT stable MOV A,CKSWT JNB ACC.7, Polling_HXT_stable ;***************************************************************************** MOV MOV MOV TA,#0AAh TA,#55h CKSWT,#02h ;TA protection ; ;switch the clock source to the HXT ;******Disable the original HIRC clock source, for example****** MOV TA,#0AAh ;TA protection MOV TA,#55h ; ANL CKEN,#11011111b ;Disable the IHRC ;*************************************************************** Jan. 27, 2018 Page 168 of 205 Rev. 1.02 N76E885 Datasheet CKSWT – Clock Switch (TA protected) 7 6 5 HXTST LXTST HIRCST R R R Address: 96H Bit Name 4 - 3 ECLKST R 2 1 0 OSC[1:0] W Reset value: 0011 0000b Description 7 HXTST High-speed external crystal/resonator 2 MHz to 25 MHz status 0 = High-speed external crystal/resonator is not stable or disabled. 1 = High-speed external crystal/resonator is enabled and stable. 6 LXTST Low-speed external crystal/resonator 32.768 kHz status 0 = Low-speed external crystal/resonator is not stable or disabled. 1 = Low-speed external crystal/resonator is enabled and stable. 5 HIRCST 4 - 3 ECLKST External clock input status 0 = External clock input is not stable or disabled. 1 = External clock input is enabled and stable. 2:1 OSC[1:0] Oscillator selection bits This field selects the system clock source. 00 = Internal 22.118 MHz oscillator. 01 = External clock source according to EXTEN[1:0] (CKEN[7:6]) setting. 10 = Internal 10 kHz oscillator. 11 = Reserved. Note that this field is write only. The read back value of this field may not correspond to the present system clock source. 0 - High-speed internal oscillator 22.118 MHz status 0 = High-speed internal oscillator is not stable or disabled. 1 = High-speed internal oscillator is enabled and stable. Reserved Reserved CKEN – Clock Enable (TA protected) 7 6 5 EXTEN[1:0] HIRCEN R/W R/W Address: 97H Bit 7:6 Jan. 27, 2018 4 - 3 - 2 - 1 0 CKSWTF R Reset value: 0011 0000b Name Description EXTEN[1:0] External clock source enable This field enables one of the external clock sources. It also selects the enabled external clock as the system clock source once OSC[1:0] is [0,1]. 00 = None of the external clock sources is enabled. P1.0 and P1.1 work as general purpose I/O. 01 = Low-speed external crystal/resonator 32.768 kHz Enabled. 10 = High-speed external crystal/resonator 2 MHz to 25 MHz Enabled. 11 = External clock input via XIN Enabled. Page 169 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 5 HIRCEN 4:1 - 0 CKSWTF Description High-speed internal oscillator 22.118 MHz enable 0 = The high-speed internal oscillator Disabled. 1 = The high-speed internal oscillator Enabled. Note that once IAP is enabled by setting IAPEN (CHPCON.0), the high-speed internal 22.118 MHz oscillator will be enabled automatically. The hardware will also set HIRCEN and HIRCST bits. After IAPEN is cleared, HIRCEN and EHRCST resume the original values. Reserved Clock switch fault flag 0 = The previous system clock source switch was successful. 1 = User tried to switch to an instable or disabled clock source at the previous system clock source switch. If switching to an instable clock source, this bit remains 1 until the clock source is stable and switching is successful. 24.3 System Clock Divider The oscillator frequency (FOSC) can be divided down, by an integer, up to 1/510 by configuring a dividing register, CKDIV, to provide the system clock (FSYS). This feature makes it possible to temporarily run the MCU at a lower rate, reducing power consumption. By dividing the clock, the MCU can retain the ability to respond to events other than those that can cause interrupts (i.e. events that allow exiting the Idle mode) by executing its normal program at a lower rate. This can often result in lower power consumption than in Idle mode. This can allow bypassing the oscillator start-up time in cases where Power-down mode would otherwise be used. The value of CKDIV may be changed by the program at any time without interrupting code execution. CKDIV – Clock Divider 7 6 5 4 3 2 1 0 CKDIV[7:0] R/W Address: 95H Bit 7:0 Reset value: 0000 0000b Name CKDIV[7:0] Description Clock divider The system clock frequency FSYS follows the equation below according to CKDIV value. FSYS = FOSC , while CKDIV = 00H, and FSYS = FOSC 2 × CKDIV , while CKDIV = 01H to FFH. 24.4 System Clock Output The N76E885 provides a CLO pin (P2.6) that outputs the system clock. Its frequency is the same as FSYS. The output enable bit is CLOEN (P1M2.3). CLO output stops when device is put in its Power- Jan. 27, 2018 Page 170 of 205 Rev. 1.02 N76E885 Datasheet down mode because the system clock is turned off. Note that when noise problem or power consumption is important issue, user had better not enable CLO output. P1M2 – Port 1 Mode Select 2 7 6 Address: B4H Bit Name 3 Jan. 27, 2018 CLOEN 5 - 4 - 3 CLOEN R/W 2 P12UP R/W 1 0 P1M2.1 P1M2.0 R/W R/W Reset value: 0000 0000b Description System clock output enable 0 = System clock output Disabled. 1 = System clock output Enabled from CLO pin (P2.6). Page 171 of 205 Rev. 1.02 N76E885 Datasheet 25. POWER MONITORING To prevent incorrect execution during power up and power drop, The N76E885 provide two power monitor functions, power-on detection and brown-out detection. 25.1 Power-On Reset (POR) The power-on detection function is designed for detecting power up after power voltage reaches to a level where system can work. After power-on detected, the POF (PCON.4) will be set 1 to indicate a cold reset, a power-on reset complete. The POF flag can be cleared via software. PCON – Power Control 7 6 SMOD SMOD0 R/W R/W Address: 87H Bit Name 4 POF 5 - 4 3 2 1 0 POF GF1 GF0 PD IDL R/W R/W R/W R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description Power-on reset flag This bit will be set as 1 after a power-on reset. It indicates a cold reset, a power-on reset complete. This bit remains its value after any other resets. This flag is recommended to be cleared via software. 25.2 Brown-Out Detection (BOD) The other power monitoring function brown-out detection (BOD) circuit is used for monitoring the VDD level during execution. There are eight CONFIG selectable brown-out trigger levels available for wide voltage applications. These eight nominal levels are 1.7V, 2.0V, 2.2V, 2.4V, 2.7V, 3.0V, 3.7V, and 4.3V selected via setting CBOV[2:0] (CONFIG2[6:4]). BOD level can also be changed by setting BOV[2:0] (BODCON0[6:4]) after power-on. When VDD drops to the selected brown-out trigger level (VBOD), the BOD logic will either reset the MCU or request a brown-out interrupt. User may decide to being reset or generating a brown-out interrupt according to different applications. VBOD also can be set by software after power-on. Note that BOD output is not available until 2~3 LIRC clocks after software enabling. The BOD will request the interrupt while VDD drops below VBOD while BORST (BODCON0.2) is 0. In this case, BOF (BODCON0.3) will be set as 1. After user cleared this flag whereas VDD remains below VBOD, BOF will not set again. BOF just acknowledge user a power drop occurs. The BOF will also be set as 1 after VDD goes higher than VBOD to indicate a power resuming. The BOD circuit provides an useful status indicator BOS (BODCON0.0), which is helpful to tell a brown-out event or power resuming event occurrence. If the BORST bit is set as 1, this will enable brown-out reset function. After a brown-out reset, BORF (BODCON0.1) will be set as 1 via hardware. It will not be altered by Jan. 27, 2018 Page 172 of 205 Rev. 1.02 N76E885 Datasheet reset other than power-on. This bit can be cleared by software. Note that all bits in BODCON0 is writing protected by timed access (TA). The N76E885 provides low power BOD mode for saving current consumption and remaining BOD functionality with limited detection response. By setting LPBOD[1:0] (BODCON1[2:1]), the BOD circuit can be periodically enabled to sense the power voltage nominally every 1.6 ms, 6.4 ms, or 25.6 ms. It saves much power but also provides low-speed power voltage sensing. Note that the hysteresis feature will disappear in low power BOD mode. For a noise sensitive system, the N76E885 has a BOD filter which filters the power noise to avoid BOD event triggering unconsciously. The BOD filter is enabled by default and can be disabled by setting BODFLT (BODCON1.0) as 0 if user requires a rapid BOD response. The minimum brown-out detect pulse width is listed in Table 25–2. VDD Brownout Detection BOF or - BOD Filter + VBOD Voltage Select BOV[2:0] BOS BORF Brown-out Interrupt Brown-out Reset BORST BODFLT LPBOD[1:0] BODEN Figure 25.1. Brown-out Detection Block Diagram CONFIG2 7 CBODEN R/W Bit 6 Name 5 CBOV[2:0] R/W 4 3 BOIAP R/W Description 7 CBODEN CONFIG brown-out detect enable 1 = Brown-out detection circuit on. 0 = Brown-out detection circuit off. 6:4 CBOV[1:0] CONFIG brown-out voltage select 111 = VBOD is 1.7V. 110 = VBOD is 2.0V. 101 = VBOD is 2.2V. 100 = VBOD is 2.4V. 011 = VBOD is 2.7V. 010 = VBOD is 3.0V. 001 = VBOD is 3.7V. 000 = VBOD is 4.3V. Jan. 27, 2018 2 1 0 CBORST R/W Factory default value: 1111 1111b Page 173 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 2 CBORST Description CONFIG brown-out reset enable This bit decides whether a brown-out reset is caused by a power drop below VBOD. 1 = Brown-out reset Enabled. 0 = Brown-out reset Disabled. BODCON0 – Brown-out Detection Control 0 (TA protected) 7 6 5 4 3 2 1 0 [1] [1] [2] [1] BODEN BOV[2:0] BOF BORST BORF BOS R/W R/W R/W R/W R/W R Address: A3H Reset value: see Table 6–2. SFR Definitions and Reset Values Bit Name Description 7 BODEN Brown-out detection enable 0 = Brown-out detection circuit off. 1 = Brown-out detection circuit on. Note that BOD output is not available until 2~3 LIRC clocks after enabling. 6:4 BOV[2:0] Brown-out voltage select 000 = VBOD is 4.3V. 001 = VBOD is 3.7V. 010 = VBOD is 3.0V. 011 = VBOD is 2.7V. 100 = VBOD is 2.4V. 101 = VBOD is 2.2V. 110 = VBOD is 2.0V. 111 = VBOD is 1.7V. 3 BOF Brown-out interrupt flag This flag will be set as logic 1 via hardware after a VDD dropping below or rising above VBOD event occurs. If both EBOD (EIE.2) and EA (IE.7) are set, a brown-out interrupt requirement will be generated. This bit should be cleared via software. 2 BORST Brown-out reset enable This bit decides whether a brown-out reset is caused by a power drop below VBOD. 0 = Brown-out reset when VDD drops below VBOD Disabled. 1 = Brown-out reset when VDD drops below VBOD Enabled. 1 BORF Brown-out reset flag When the MCU is reset by brown-out event, this bit will be set via hardware. This flag is recommended to be cleared via software. Brown-out status This bit indicates the VDD voltage level comparing with VBOD while BOD circuit is enabled. It keeps 0 if BOD is not enabled. 0 = VDD voltage level is higher than VBOD or BOD is disabled. 1 = VDD voltage level is lower than VBOD. Note that this bit is read-only. [1] BODEN, BOV[2:0], and BORST are initialized by being directly loaded from CONFIG0 bit 7, [6:4], and 2 after all resets. [2] BOF reset value depends on different setting of CONFIG2 and V DD voltage level. Please check Table 25–1. 0 Jan. 27, 2018 BOS Page 174 of 205 Rev. 1.02 N76E885 Datasheet Table 25–1. BOF Reset Value CBODEN (CONFIG2.7) CBORST (CONFIG2.2) VDD Level BOF 1 1 > VBOD always 0 1 0 < VBOD 1 1 0 > VBOD 0 0 X X 0 BODCON1 – Brown-out Detection Control 1 (TA protected) 7 6 5 4 3 2 1 0 LPBOD[1:0] BODFLT R/W R/W Address: ABH Reset value: see Table 6–2. SFR Definitions and Reset Values Bit Name 7:3 - 2:1 LPBOD[1:0] 0 BODFLT Jan. 27, 2018 Description Reserved Low power BOD enable 00 = BOD normal mode. BOD circuit is always enabled. 01 = BOD low power mode 1 by turning on BOD circuit every 1.6 ms periodically. 10 = BOD low power mode 2 by turning on BOD circuit every 6.4 ms periodically. 11 = BOD low power mode 3 by turning on BOD circuit every 25.6 ms periodically. BOD filter control BOD has a filter which counts 32 clocks of FSYS to filter the power noise when MCU runs with HIRC, HXT, or ECLK as the system clock and BOD does not operates in its low power mode (LPBOD[1:0] = [0, 0]). In other conditions, the filter counts 2 clocks of LIRC. Note that when CPU is halted in Power-down mode. The BOD output is permanently filtered by 2 clocks of LIRC. The BOD filter avoids the power noise to trigger BOD event. This bit controls BOD filter enabled or disabled. 0 = BOD filter Disabled. 1 = BOD filter Enabled. (Power-on reset default value.) Page 175 of 205 Rev. 1.02 N76E885 Datasheet Table 25–2. Minimum Brown-out Detect Pulse Width BODFLT (BODCON1.1) 0 BOD Operation Mode System Clock Source Minimum Brown-out Detect Pulse Width Normal mode (LPBOD[1:0] = [0,0]) Any clock source Typ. 1μs Low power mode 1 (LPBOD[1:0] = [0,1]) Any clock source 16 (1/FLIRC) Low power mode 2 (LPBOD[1:0] = [1,0]) Any clock source 64 (1/FLIRC) Low power mode 3 (LPBOD[1:0] = [1,1]) Any clock source 256 (1/ FLIRC) HIRC/HXT/ECLK Normal operation: 32 (1/FSYS) Idle mode: 32 (1/FSYS) Power-down mode: 2 (1/FLIRC) LIRC/LXT 2 (1/FLIRC) Low power mode 1 (LPBOD[1:0] = [0,1]) Any clock source 18 (1/FLIRC) Low power mode 2 (LPBOD[1:0] = [1,0]) Any clock source 66 (1/FLIRC) Low power mode 3 (LPBOD[1:0] = [1,1]) Any clock source 258 (1/ FLIRC) 1 Normal mode (LPBOD[1:0] = [0,0]) Jan. 27, 2018 Page 176 of 205 Rev. 1.02 N76E885 Datasheet 26. RESET The N76E885 has several options to place device in reset condition. It also offers the software flags to indicate the source, which causes a reset. In general, most SFRs go to their Reset value irrespective of the reset condition, but there are several reset source indicating flags whose state depends on the source of reset. User can read back these flags to determine the cause of reset using software. There are five ways of putting the device into reset state. They are power-on reset, brown-out reset, external reset, WDT reset, and software reset. 26.1 Power-On Reset The N76E885 incorporates an internal power-on reset. During a power-on process of rising power supply voltage VDD, the power-on reset will hold the MCU in reset mode when VDD is lower than the voltage reference threshold. This design makes CPU not access program flash while the V DD is not adequate performing the flash reading. If an undetermined operating code is read from the program flash and executed, this will put CPU and even the whole system in to an erroneous state. After a while, VDD rises above the threshold where the system can work, the selected oscillator will start and then program code will execute from 0000H. At the same time, a power-on flag POF (PCON.4) will be set 1 to indicate a cold reset, a power-on reset complete. Note that the contents of internal RAM will be undetermined after a power-on. It is recommended that user gives initial values for the RAM block. The POF is recommended to be cleared to 0 via software to check if a cold reset or warm reset performed after the next reset occurs. If a cold reset caused by power off and on, POF will be set 1 again. If the reset is a warm reset caused by other reset sources, POF will remain 0. User may take a different course to check other reset flags and deal with the warm reset event. PCON – Power Control 7 6 SMOD SMOD0 R/W R/W Address: 87H Bit Name 4 POF 5 - 4 3 2 1 0 POF GF1 GF0 PD IDL R/W R/W R/W R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description Power-on reset flag This bit will be set as 1 after a power-on reset. It indicates a cold reset, a power-on reset complete. This bit remains its value after any other resets. It is recommended that the flag be cleared via software. 26.2 Brown-Out Reset The brown-out detection circuit is used for monitoring the VDD level during execution. When VDD drops to the selected brown-out trigger level (VBOD), the brown-out detection logic will reset the MCU if Jan. 27, 2018 Page 177 of 205 Rev. 1.02 N76E885 Datasheet BORST (BODCON0.2) setting 1. After a brown-out reset, BORF (BODCON0.1) will be set as 1 via hardware. BORF will not be altered by any reset other than a power-on reset or brown-out reset itself. This bit can be set or cleared by software. BODCON0 – Brown-out Detection Control 0 (TA protected) 7 6 5 4 3 2 1 0 BODEN BOV[2:0] BOF BORST BORF BOS R/W R/W R/W R/W R/W R Address: A3H Reset value: see Table 6–2. SFR Definitions and Reset Values Bit Name 1 BORF Description Brown-out reset flag When the MCU is reset by brown-out event, this bit will be set via hardware. This flag is recommended to be cleared via software. 26.3 External Reset The external reset pin ̅̅̅̅̅̅ is an input with a Schmitt trigger. An external reset is accomplished by holding the ̅̅̅̅̅̅ pin low for at least 24 system clock cycles to ensure detection of a valid hardware reset signal. The reset circuitry then synchronously applies the internal reset signal. Thus, the reset is a synchronous operation and requires the clock to be running to cause an external reset. Once the device is in reset condition, it will remain as long as ̅̅̅̅̅̅ pin is low. After the ̅̅̅̅̅̅ high is removed, the MCU will exit the reset state and begin code executing from address 0000H. If an external reset applies while CPU is in Power-down mode, the way to trigger a hardware reset is slightly different. Since the Power-down mode stops system clock, the reset signal will asynchronously cause the system clock resuming. After the system clock is stable, MCU will enter the reset state. There is a RSTPINF (AUXR1.6) flag, which indicates an external reset took place. After the external reset, this bit will be set as 1 via hardware. RSTPINF will not change after any reset other than a power-on reset or the external reset itself. This bit can be cleared via software. AUXR1 – Auxiliary Register 1 7 6 5 SWRF RSTPINF T1LXTM R/W R/W R/W Address: A2H Bit 6 Jan. 27, 2018 4 3 2 1 0 T0LXTM GF2 UART0PX 0 DPS R/W R/W R/W R R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Name Description RSTPINF External reset flag When the MCU is reset by the external reset, this bit will be set via hardware. It is recommended that the flag be cleared via software. Page 178 of 205 Rev. 1.02 N76E885 Datasheet 26.4 Watchdog Timer Reset The WDT is a free running timer with programmable time-out intervals and a dedicated internal clock source. User can clear the WDT at any time, causing it to restart the counter. When the selected timeout occurs but no software response taking place for a while, the WDT will reset the system directly and CPU will begin execution from 0000H. Once a reset due to WDT occurs, the WDT reset flag WDTRF (WDCON.3) will be set. This bit keeps unchanged after any reset other than a power-on reset or WDT reset itself. User can clear WDTRF via software. WDCON – Watchdog Timer Control (TA protected) 7 6 5 4 3 2 1 0 WDTEN WDCLR WDTF WIDPD WDTRF WDPS[2:0] R/W R/W R/W R/W R/W R/W Address: AAH Reset value: see Table 6–2. SFR Definitions and Reset Values Bit Name 3 WDTRF Description WDT reset flag When the MCU is reset by WDT time-out event, this bit will be set via hardware. It is recommended that the flag be cleared via software. 26.5 Software Reset The N76E885 provides a software reset, which allows the software to reset the whole system just similar to an external reset, initializing the MCU as it reset state. The software reset is quite useful in the end of an ISP progress. For example, if an ISP of Boot Code updating User Code finishes, a software reset can be asserted to re-boot CPU to execute new User Code immediately. Writing 1 to SWRST (CHPCON.7) will trigger a software reset. Note that this bit is writing TA protection. The instruction that sets the SWRST bit is the last instruction that will be executed before the device reset. See demo code below. If a software reset occurs, SWRF (AUXR1.7) will be automatically set by hardware. User can check it as the reset source indicator. SWRF keeps unchanged after any reset other than a power-on reset or software reset itself. SWRF can be cleared via software. Jan. 27, 2018 Page 179 of 205 Rev. 1.02 N76E885 Datasheet CHPCON – Chip Control (TA protected) 7 6 5 SWRST IAPFF W R/W Address: 9FH Bit Name 7 SWRST Description Software reset To set this bit as logic 1 will cause a software reset. It will automatically be cleared via hardware after reset is finished. AUXR1 – Auxiliary Register 1 7 6 5 SWRF RSTPINF T1LXTM R/W R/W R/W Address: A2H Bit Name 7 SWRF 4 3 2 1 0 BS IAPEN R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values 4 3 2 1 0 T0LXTM GF2 UART0PX 0 DPS R/W R/W R/W R R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description Software reset flag When the MCU is reset via software reset, this bit will be set via hardware. It is recommended that the flag be cleared via software. The software demo code is listed below. ANL ... ... CLR MOV MOV ORL AUXR1,#01111111b ;software reset flag clear EA TA,#0AAh TA,#55h CHPCON,#10000000b ;software reset 26.6 Boot Select CONFIG0.7 CHPCON.1 CBS BS Load Power-on reset Watchgod Timer reset Brown-out reset RST pin reset Reset and boot from APROM BS = 0 BS = 1 Reset and boot from LDROM Software reset Figure 26.1. Boot Selecting Diagram The N76E885 provides user a flexible boot selection for variant application. The SFR bit BS in CHPCON.1 determines MCU booting from APROM or LDROM after any source of reset. If reset occurs and BS is 0, MCU will reboot from address 0000H of APROM. Else, the CPU will reboot from Jan. 27, 2018 Page 180 of 205 Rev. 1.02 N76E885 Datasheet address 0000H of LDROM. Note that BS is loaded from the inverted value of CBS bit in CONFIG0.7 after all resets except software reset. CONFIG0 7 CBS R/W 6 - Bit Name 7 CBS 5 OCDPWM R/W Name 3 - 2 1 0 RPD LOCK R/W R/W Factory default value: 1111 1111b Description CONFIG boot select This bit defines from which block that MCU re-boots after resets except software reset. 1 = MCU will re-boot from APROM after resets except software reset. 0 = MCU will re-boot from LDROM after resets except software reset. CHPCON – Chip Control (TA protected) 7 6 5 SWRST IAPFF W R/W Address: 9FH Bit 4 OCDEN R/W 4 3 2 1 0 BS[1] IAPEN R/W R/W Reset value: see Table 6–2. SFR Definitions and Reset Values Description Boot select This bit defines from which block that MCU re-boots after all resets. 0 = MCU will re-boot from APROM after all resets. 1 = MCU will re-boot from LDROM after all resets. [1] BS is initialized by being loaded from the inverted value of CBS bit in CONFIG0.7 after resets except software reset. It keeps unchanged after software reset. 1 BS After the MCU is released from reset state, the hardware will always check the BS bit instead of the CBS bit to determine from which block that the device reboots. 26.7 Reset State The reset state besides power-on reset does not affect the on-chip RAM. The data in the RAM will be preserved during the reset. After the power-on reset the RAM contents will be indeterminate. After a reset, most of SFRs go to their initial values except bits, which are affected by different reset events. See the notes of Table 6–2. SFR Definitions and Reset Values. The Program Counter is forced to 0000H and held as long as the reset condition is applied. Note that the Stack Pointer is also reset to 07H and thus the stack contents may be effectively lost during the reset event even though the RAM contents are not altered. After a reset, all peripherals and interrupts are disabled. The I/O port latches resumes FFH and I/O mode input-only. Jan. 27, 2018 Page 181 of 205 Rev. 1.02 N76E885 Datasheet 27. AUXILIARY FEATURES 27.1 Dual DPTRs The original 8051 contains one DPTR (data pointer) only. With single DPTR, it is difficult to move data form one address to another with wasting code size and low performance. The N76E885 provides two data pointers. Thus, software can load both a source and a destination address when doing a block move. Once loading, the software simply switches between DPTR and DPTR1 by the active data pointer selection DPS (AUXR1.0) bit. An example of 64 bytes block move with dual DPTRs is illustrated below. By giving source and destination addresses in data pointers and activating cyclic makes block RAM data move more simple and efficient than only one DPTR. The INC AUXR1 instruction is the shortest (2 bytes) instruction to accomplish DPTR toggling rather than ORL or ANL. For AUXR1.1 contains a hard-wired 0, it allows toggling of the DPS bit by incrementing AUXR1 without interfering with other bits in the register. MOV MOV INC MOV R0,#64 DPTR,#D_Addr AUXR1 DPTR,#S_Addr ;number of bytes to move ;load destination address ;change active DPTR ;load source address MOVX INC MOVX INC INC INC DJNZ INC A,@DPTR AUXR1 @DPTR,A DPTR AUXR1 DPTR R0,LOOP AUXR1 ;read source data byte ;change DPTR to destination ;write data to destination ;next destination address ;change DPTR to source ;next source address LOOP: ;(optional) restore DPS AUXR1 also contains a general purpose flag GF2 in its bit 3 that can be set or cleared by the user via software. DPL – Data Pointer Low Byte 7 6 5 4 3 2 1 0 DPL[7:0] R/W Address: 82H Bit 7:0 Jan. 27, 2018 reset value: 0000 0000b Name Description DPL[7:0] Data pointer low byte This is the low byte of 16-bit data pointer. DPL combined with DPH serve as a 16bit data pointer DPTR to address non-scratch-pad memory or Program Memory. DPS (DPS.0) bit decides which data pointer, DPTR or DPTR1, is activated. Page 182 of 205 Rev. 1.02 N76E885 Datasheet DPH – Data Pointer High Byte 7 6 5 4 3 2 1 0 DPH[7:0] R/W Address: 83H Bit 7:0 reset value: 0000 0000b Name Description DPH[7:0] Data pointer high byte This is the high byte of 16-bit data pointer. DPH combined with DPL serve as a 16-bit data pointer DPTR to address non-scratch-pad memory or Program Memory. DPS (DPS.0) bit decides which data pointer, DPTR or DPTR1, is activated. AUXR1 – Auxiliary Register 1 7 6 5 SWRF RSTPINF T1LXTM R/W R/W R/W Address: A2H Bit Name 3 GF2 1 0 0 DPS 4 3 2 1 0 T0LXTM GF2 UART0PX 0 DPS R/W R/W R/W R R/W reset value: see Table 6–2. SFR Definitions and Reset Values Description General purpose flag 2 The general purpose flag that can be set or cleared by the user via software. Reserved This bit is always read as 0. Data pointer select 0 = Data pointer 0 (DPTR) is active by default. 1 = Data pointer 1 (DPTR1) is active. After DPS switches the activated data pointer, the previous inactivated data pointer remains its original value unchanged. 27.2 96-Bit Unique Code Before shipping out, each N76E885 chip was factory pre-programmed with a 96-bit width serial number, which is guaranteed to be unique. The serial number is called Unique Code. The user can read the Unique Code only by IAP command. Please see Section 22.1 “IAP Commands” on page 155. Jan. 27, 2018 Page 183 of 205 Rev. 1.02 N76E885 Datasheet 28. ON-CHIP-DEBUGGER (OCD) 28.1 Functional Description The N76E885 is embedded in an on-chip-debugger (OCD) providing developers with a low cost method for debugging user code, which is available on each package. The OCD gives debug capability of complete program flow control with eight hardware address breakpoints, single step, free running, and non-intrusive commands for memory access. The OCD system does not occupy any locations in the memory map and does not share any on-chip peripherals. When the OCDEN (CONFIG0.4) is programmed as 0 and LOCK (CONFIG0.1) remains unprogrammed as 1, the OCD is activated. The OCD cannot operate if chip is locked. The OCD system uses a two-wire serial interface, OCDDA and OCDCK, to establish communication between the target device and the controlling debugger host. OCDDA is an input/output pin for debug data transfer and OCDCK is an input pin for synchronization with OCDDA data. The P1.2/̅̅̅̅̅̅ pin is also necessary for OCD mode entry and exit. The N76E885 supports OCD with Flash Memory control path by ICP writer mode, which shares the same three pins of OCD interface. The N76E885 uses OCDDA, OCDCK, and P1.2/̅̅̅̅̅̅ pins to interface with the OCD system. When designing a system where OCD will be used, the following restrictions must be considered for correct operation: 1. If P1.2/̅̅̅̅̅̅ is configured as external reset pin, it cannot be connected directly to VDD and any external capacitors connected must be removed. 2. If P1.2/̅̅̅̅̅̅ is configured as input pin P1.2, any external input source must be isolated. 3. All external reset sources must be disconnected. 4. Any external component connected on OCDDA and OCDCK must be isolated. 28.2 Limitation of OCD The N76E885 is a fully-featured microcontroller that multiplexes several functions on its limited I/O pins. Some device functionality must be sacrificed to provide resources for OCD system. The OCD has the following limitations: 1. The P1.2/̅̅̅̅̅̅ pin needs to be used for OCD mode selection. Therefore, neither P1.2 input nor an external reset source can be emulated. Jan. 27, 2018 Page 184 of 205 Rev. 1.02 N76E885 Datasheet 2. The OCDDA pin is physically located on the same pin as P0.0. Therefore, neither its I/O function nor shared multi-functions can be emulated. 3. The OCDCK pin is physically located on the same pin as P0.1. Therefore, neither its I/O function nor shared multi-functions can be emulated. 4. When the system is in Idle or Power-down mode, it is invalid to perform any accesses because parts of the device may not be clocked. A read access could return garbage or a write access might not succeed. 5. HIRC cannot be turned off because OCD uses this clock to monitor its internal status. The instruction that turns off HIRC affects nothing if executing under debug mode. When CPU enters its Power-down mode under debug mode, HIRC keeps turning on. The N76E885 OCD system has another limitation that non-intrusive commands cannot be executed at any time while the user’s program is running. Non-intrusive commands allow a user to read or write MCU memory locations or access status and control registers with the debug controller. A reading or writing memory or control register space is allowed only when MCU is under halt condition after a matching of the hardware address breakpoint or a single step running. CONFIG0 7 CBS R/W 6 - Bit Name 5 OCDPWM 4 OCDEN Jan. 27, 2018 5 OCDPWM R/W 4 OCDEN R/W 3 - 2 1 0 RPD LOCK R/W R/W Factory default value: 1111 1111b Description PWM output state under OCD halts CPU This bit decides the output state of PWM when OCD halts CPU. 1 = Tri-state pins those are used as PWM outputs. 0 = PWM continues. OCD enable 1 = OCD Disabled. 0 = OCD Enabled. Page 185 of 205 Rev. 1.02 N76E885 Datasheet 29. CONFIG BYTES The N76E885 has several hardware configuration bytes, called CONFIG, those are used to configure the hardware options such as the security bits, system clock source, and so on. These hardware options can be re-configured through the parallel Writer, In-Circuit-Programming (ICP), or InApplication-Programming (IAP). Several functions, which are defined by certain CONFIG bits are also available to be re-configured by SFR. Therefore, there is a need to load such CONFIG bits into respective SFR bits. Such loading will occur after resets. These SFR bits can be continuously controlled via user’s software. CONFIG bits marked as “-“ should always keep un-programmed. CONFIG0 7 CBS R/W 6 - Bit 5 OCDPWM R/W Name 4 OCDEN R/W 3 - 2 1 0 RPD LOCK R/W R/W Factory default value: 1111 1111b Description 7 CBS CONFIG boot select This bit defines from which block that MCU re-boots after resets except software reset. 1 = MCU will re-boot from APROM after resets except software reset. 0 = MCU will re-boot from LDROM after resets except software reset. 5 OCDPWM PWM output state under OCD halt This bit decides the output state of PWM when OCD halts CPU. 1 = Tri-state pins those are used as PWM outputs. 0 = PWM continues. Note that this bit is valid only when the corresponding PIO bit of PWM channel is set as 1. 4 OCDEN 3 - 2 RPD Jan. 27, 2018 OCD enable 1 = OCD Disabled. 0 = OCD Enabled. Reserved Reset pin disable 1 = The reset function of P1.2/̅̅̅̅̅̅ pin Enabled. P1.2/̅̅̅̅̅̅ functions as the external reset pin. 0 = The reset function of P1.2/̅̅̅̅̅̅ pin Disabled. P1.2/̅̅̅̅̅̅ functions as an input-only pin P1.2. Page 186 of 205 Rev. 1.02 N76E885 Datasheet Bit Name 1 Description Chip lock enable 1 = Chip is unlocked. Flash Memory is not locked. Their contents can be read out through a parallel Writer/ICP programmer. 0 = Chip is locked. Whole Flash Memory is locked. Their contents read through a parallel Writer or ICP programmer will be all blank (FFH). Programming to Flash Memory is invalid. Note that CONFIG bytes are always unlocked and can be read. Hence, once the chip is locked, the CONFIG bytes cannot be erased or programmed individually. The only way to disable chip lock is execute “whole chip erase”. However, all data within the Flash Memory and CONFIG bits will be erased when this procedure is executed. If the chip is locked, it does not alter the IAP function. LOCK CONFIG0 7 6 5 4 3 2 1 0 CBS - OCDPWM OCDEN - RPD LOCK - Software reset does not reload 7 6 5 4 3 2 1 0 SWRST IAPFF - - - - BS IAPEN CHPCON Figure 29.1. CONFIG0 Any Reset Reloading CONFIG1 7 - 6 - Bit 2:0 CONFIG2 7 CBODEN R/W Bit Jan. 27, 2018 4 - 3 - 2 1 0 LDSIZE[2:0] R/W Factory default value: 1111 1111b Name Description LDSIZE[2:0] LDROM size select This field selects the size of LDROM. 111 = No LDROM. APROM is 18K Bytes. 110 = LDROM is 1K Bytes. APROM is 17K Bytes. 101 = LDROM is 2K Bytes. APROM is 16K Bytes. 100 = LDROM is 3K Bytes. APROM is 15K Bytes. 0xx = LDROM is 4K Bytes. APROM is 14K Bytes. 6 Name 7 5 - CBODEN 5 CBOV[2:0] R/W 4 3 BOIAP R/W 2 1 0 CBORST R/W Factory default value: 1111 1111b Description CONFIG brown-out detect enable 1 = Brown-out detection circuit on. 0 = Brown-out detection circuit off. Page 187 of 205 Rev. 1.02 N76E885 Datasheet Bit Name Description 6:4 CBOV[1:0] CONFIG brown-out voltage select 111 = VBOD is 1.7V. 110 = VBOD is 2.0V. 101 = VBOD is 2.2V. 100 = VBOD is 2.4V. 011 = VBOD is 2.7V. 010 = VBOD is 3.0V. 001 = VBOD is 3.7V. 000 = VBOD is 4.3V. 3 BOIAP Brown-out inhibiting IAP This bit decide whether IAP erasing or programming is inhibited by brown-out status. This bit is valid only when brown-out detection is enabled. 1 = IAP erasing or programming is inhibited if VDD is lower than VBOD. 0 = IAP erasing or programming is allowed under any workable V DD. 2 CBORST CONFIG brown-out reset enable This bit decides whether a brown-out reset is caused by a power drop below VBOD. 1 = Brown-out reset Enabled. 0 = Brown-out reset Disabled. CONFIG2 7 6 CBODEN 7 BODCON0 5 4 CBOV[2:0] 6 BODEN 5 3 2 1 0 BOIAP CBORST - - 4 BOV[2:0] 3 2 1 0 BOF BORST BORF BOS Figure 29.2. CONFIG2 Power-On Reset Reloading CONFIG4 7 Bit 6 5 WDTEN[3:0] R/W 4 3 - 2 1 0 Factory default value: 1111 1111b Name Description 7:4 WDTEN[3:0] WDT enable This field configures the WDT behavior after MCU execution. 1111 = WDT is Disabled. WDT can be used as a general purpose timer via software control. 0101 = WDT is Enabled as a time-out reset timer and it stops running during Idle or Power-down mode. Others = WDT is Enabled as a time-out reset timer and it keeps running during Idle or Power-down mode. 3:0 - Jan. 27, 2018 Reserved Page 188 of 205 Rev. 1.02 N76E885 Datasheet 30. IN-CIRCUIT-PROGRAMMING (ICP) The Flash Memory can be programmed by “ n-Circuit-Programming” ( P). In general, hardware programming mode uses gang-writers to reduce programming costs and time to market while the products enter the mass production state. However, if the product is just under development or the end product needs firmware updating in the hand of an end customer, the hardware programming mode will make repeated programming difficult and inconvenient. ICP method makes it easy and possible without removing the microcontroller from the system. ICP mode also allows customers to manufacture circuit boards with un-programmed devices. Programming can be done after the assembly process allowing the device to be programmed with the most recent firmware or a customized firmware. There are three signal pins, ̅̅̅̅̅̅, ICPDA, and ICPCK, involved in ICP function. ̅̅̅̅̅̅ is used to enter or exit ICP mode. ICPDA is the data input and output pin. ICPCK is the clock input pin, which synchronizes the data shifted in to or out from MCU under programming. User should leave these three pins plus VDD and GND pins on the circuit board to make ICP possible. Nuvoton provides ICP tool for N76E885, which enables user to easily perform ICP through Nuvoton ICP programmer. The ICP programmer developed by Nuvoton has been optimized according to the electric characteristics of MCU. It also satisfies the stability and efficiency during production progress. For more details, please visit Nuvoton 8-bit Microcontroller website: Nuvoton 80C51 Microcontroller Technical Support. Jan. 27, 2018 Page 189 of 205 Rev. 1.02 N76E885 Datasheet 31. INSTRUCTION SET The N76E885 executes all the instructions of the standard 80C51 family fully compatible with MCS-51. However, the timing of each instruction is different for it uses high performance 1T 8051 core. The architecture eliminates redundant bus states and implements parallel execution of fetching, decode, and execution phases. The N76E885 uses one clock per machine-cycle. It leads to performance improvement of rate 8.1 (in terms of MIPS) with respect to traditional 12T 80C81 device working at the same clock frequency. However, the real speed improvement seen in any system will depend on the instruction mix. All instructions are coded within an 8-bit field called an OPCODE. This single byte should be fetched from Program Memory. The OPCODE is decoded by the CPU. It determines what action the CPU will take and whether more operation data is needed from memory. If no other data is needed, then only one byte was required. Thus the instruction is called a one byte instruction. In some cases, more data is needed, which is two or three byte instructions. Table 31–1 lists all instructions for details. The note of the instruction set and addressing modes are shown below. Rn (n = 0~7) direct location Register R0 to R7 of the currently selected Register Bank. 8-bit internal data location’s address. It could be an internal data RAM (00H to 7FH) or an SFR (80H to FFH). @Ri (i = 0, 1) through 8-bit internal data RAM location (00H to FFH) addressed indirectly register R0 or R1. #data 8-bit constant included in the instruction. #data16 16-bit constant included in the instruction. addr16 16-bit destination address. Used by LCALL and LJMP. A branch can anywhere within the Program Memory address space. addr11 11-bit destination address. Used by ACALL and AJMP. The branch will be be within the same 2K-Byte page of Program Memory as the first byte of following instruction. the rel conditional igned ( ’s complement) 8-bit offset Byte. Used by SJMP and all branches. The range is -128 to +127 Bytes relative to first byte of the following instruction. bit Jan. 27, 2018 Direct addressed bit in internal data RAM or SFR. Page 190 of 205 Rev. 1.02 N76E885 Datasheet Table 31–1. Instruction Set Instruction NOP OPCODE N76E885 V.S. Tradition 80C51 Speed Ratio Bytes Clock Cycles 00 1 1 12 ADD A, Rn 28~2F 1 2 6 ADD A, direct 25 2 3 4 ADD A, @Ri 26, 27 1 4 3 ADD A, #data 24 2 2 6 ADDC A, Rn 38~3F 1 2 6 ADDC A, direct 35 2 3 4 ADDC A, @Ri 36, 37 1 4 3 ADDC A, #data 34 2 2 6 SUBB A, Rn 98~9F 1 2 6 SUBB A, direct 95 2 3 4 SUBB A, @Ri 96, 97 1 4 3 SUBB A, #data 94 2 2 6 INC A 04 1 1 12 INC Rn 08~0F 1 3 4 INC direct 05 2 4 3 INC @Ri 06, 07 1 5 2.4 INC DPTR A3 1 1 24 DEC A 14 1 1 12 DEC Rn 18~1F 1 3 4 DEC direct 15 2 4 3 DEC @Ri 16, 17 1 5 MUL AB A4 1 4 12 DIV AB 84 1 4 12 DA A D4 1 1 12 ANL A, Rn 58~5F 1 2 6 ANL A, direct 55 2 3 4 ANL A, @Ri 56, 57 1 4 3 ANL A, #data 54 2 2 6 ANL direct, A 52 2 4 3 ANL direct, #data 53 3 4 6 ORL A, Rn 48~4F 1 2 6 ORL A, direct 45 2 3 4 ORL A, @Ri 46, 47 1 4 3 ORL A, #data 44 2 2 6 ORL direct, A 42 2 4 3 ORL direct, #data 43 3 4 6 XRL A, Rn 68~6F 1 2 6 XRL A, direct 65 2 3 4 XRL A, @Ri 66, 67 1 4 3 Jan. 27, 2018 Page 191 of 205 2.4 Rev. 1.02 N76E885 Datasheet Table 31–1. Instruction Set Instruction OPCODE Bytes Clock Cycles N76E885 V.S. Tradition 80C51 Speed Ratio XRL A, #data 64 2 2 6 XRL direct, A 62 2 4 3 XRL direct, #data 63 3 4 6 CLR A E4 1 1 12 CPL A F4 1 1 12 RL A 23 1 1 12 RLC A 33 1 1 12 RR A 03 1 1 12 RRC A 13 1 1 12 SWAP A C4 1 1 12 MOV A, Rn E8~EF 1 1 12 MOV A, direct E5 2 3 4 MOV A, @Ri E6, E7 1 4 3 MOV A, #data 74 2 2 6 MOV Rn, A F8~FF 1 1 12 MOV Rn, direct A8~AF 2 4 6 MOV Rn, #data 78~7F 2 2 6 MOV direct, A F5 2 2 6 MOV direct, Rn 88~8F 2 3 8 MOV direct, direct 85 3 4 6 MOV direct, @Ri 86, 87 2 5 4.8 MOV direct, #data 75 3 3 8 MOV @Ri, A F6, F7 1 3 4 MOV @Ri, direct A6, A7 2 4 6 MOV @Ri, #data 76, 77 2 3 6 MOV DPTR, #data16 90 3 3 8 MOVC A, @A+DPTR 93 1 4 6 MOVC A, @A+PC 83 1 4 6 E2, E3 1 5 4.8 E0 1 4 6 [1] MOVX A, @Ri MOVX A, @DPTR[1] [1] MOVX @Ri, A F2, F3 1 6 4 MOVX @DPTR, A[1] F0 1 5 4.8 PUSH direct C0 2 4 6 POP direct D0 2 3 8 XCH A, Rn C8~CF 1 2 6 XCH A, direct C5 2 3 4 XCH A, @Ri C6, C7 1 4 3 XCHD A, @Ri D6, D7 1 5 2.4 CLR C C3 1 1 12 CLR bit C2 2 4 3 Jan. 27, 2018 Page 192 of 205 Rev. 1.02 N76E885 Datasheet Table 31–1. Instruction Set Instruction OPCODE Bytes Clock Cycles N76E885 V.S. Tradition 80C51 Speed Ratio SETB C D3 1 1 12 SETB bit D2 2 4 3 CPL C B3 1 1 12 CPL bit B2 2 4 3 ANL C, bit 82 2 3 8 ANL C, /bit B0 2 3 8 ORL C, bit 72 2 3 8 ORL C, /bit A0 2 3 8 MOV C, bit A2 2 3 4 MOV bit, C 92 2 4 6 ACALL addr11 11, 31, 51, 71, 91, B1, D1, F1[2] 2 4 6 LCALL addr16 12 3 4 6 RET 22 1 5 4.8 RETI 32 1 5 4.8 AJMP addr11 01, 21, 41, 61, 81, A1, C1, E1[3] 2 3 8 LJMP addr16 02 3 4 6 SJMP rel 80 2 3 8 JMP @A+DPTR 73 1 3 8 JZ rel 60 2 3 8 JNZ rel 70 2 3 8 JC rel 40 2 3 8 JNC rel 50 2 3 8 JB bit, rel 20 3 5 4.8 JNB bit, rel 30 3 5 4.8 JBC bit, rel 10 3 5 4.8 CJNE A, direct, rel B5 3 5 4.8 CJNE A, #data, rel B4 3 4 6 CJNE Rn, #data, rel B8~BF 3 4 6 CJNE @Ri, #data, rel B6, B7 3 6 4 DJNZ Rn, rel D8~DF 2 4 6 DJNZ direct, rel D5 3 5 4.8 [1] The N76E885 does not have external memory bus. MOVX instructions are used to access internal XRAM. [2] The most three significant bits in the 11-bit address [A10:A8] decide the ACALL hex code. The code will be [A10,A9,A8,1,0,0,0,1]. [3] The most three significant bits in the 11-bit address [A10:A8] decide the AJMP hex code. The code will be [A10,A9,A8,0,0,0,0,1]. Jan. 27, 2018 Page 193 of 205 Rev. 1.02 N76E885 Datasheet 32. ELECTRICAL CHARACTERISTICS 32.1 Absolute Maximum Ratings Parameter Rating Unit Operating temperature under bias (TA) -40 to +105 C Storage temperature range -55 to +150 C Voltage on VDD pin to GND pin -0.3 to +6.3 V -0.3 to (VDD+0.3) V Voltage on any other pin to GND pin tresses at or above those listed under “Absolute aximum atings” may cause permanent damage to the device. It is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions may affect device reliability. 32.2 D.C. Electrical Characteristics Table 32–1. D.C. Electrical Characteristics Symbol Parameter Condition Min. Typ. Max. Unit 2.4 - 5.5 V Supply voltage VDD Operating voltage F = 0 to 25 MHz I/O VIL Input low voltage (I/O with TTL input) Vss-0.3 - 0.2VDD-0.1 V VIL1 Input low voltage (I/O with Schmitt trigger input, ̅̅̅̅̅̅, and XIN) Vss-0.3 - 0.3VDD V VIH Input high voltage (I/O with TTL input) 0.2VDD+0.9 - VDD+0.3 V VIH1 Input high voltage (I/O with Schmitt trigger input and XIN) 0.7VDD - VDD+0.3 V VIH2 Input high voltage (̅̅̅̅̅̅) 0.8VDD - VDD+0.3 V VOL Output low voltage (Normal sink current strength, all modes except input-only) VDD = 4.5V, IOL = 16mA - - 0.4 V VDD = 3.0V, IOL = 13mA - - 0.4 VDD = 2.4V, IOL = 7mA - - 0.4 VDD = 4.5V, IOL = 32mA - - 0.4 VDD = 3.0V, IOL = 24mA - - 0.4 VDD = 2.4V, IOL = 11mA - - 0.4 VOL1 [1] [1] Output low voltage (P0.1~P0.3, P2.0~P2.1 with large sink current strength, all modes except input-only) Jan. 27, 2018 Page 194 of 205 V Rev. 1.02 N76E885 Datasheet Symbol VOH VOH1 Parameter Condition Output high voltage (quasi-bidirectional mode) Output high voltage (push-pull mode) Min. Typ. Max. Unit VDD = 4.5V, IOH = -38 μA 2.4 - - V VDD = 3.0V, IOH = -100μA 2.4 - - VDD = 2.4V, IOH = -40μA 2.0 - - VDD = 4.5V, IOH = -16mA 2.4 - - VDD = 3.0V, IOH = -4.5 mA 2.4 - - VDD = 2.4V, IOH = -2mA 2.0 - - VDD = 5.5V, VIN = 0.4V - - -50 μA VDD = 5.5V -- - -650 μA V IIL Logical 0 input current (quasi-bidirectional mode) ITL Logical 1-to-0 transition current (quasi-bidirectional mode) ILI Input leakage current (open-drain or input-only mode) - 1 ±10 μA RRST ̅̅̅̅̅̅ pin internal pull-low resistor 50 - 600 kΩ [2] Supply current IDD IIDL [3] Normal operating current Idle mode current HXT, XTGS[1:0] = [1,1] - HIRC - 3.9 4.3 mA LXT, XTGS[1:0] = [0,1] - 220 280 μA LIRC - 190 250 μA HXT, XTGS[1:0] = [1,1] - HIRC IPD IPD1 0.12F+0.7 0.13F+0.9 0.07F+0.5 0.07F+0.7 mA mA 2.6 2.8 mA LXT, XTGS[1:0] = [0,1] - 180 250 μA LIRC - 170 240 μA Power-down mode current (BOD off, LXT off) TA = 25℃ - 1.3 2.5 μA TA = -40℃ to +105℃ - - 20 μA Power-down mode current (BOD off, LXT on, XTGS[1:0] = [0,1]) TA = 25℃ - 2.3 4.0 μA TA = -40℃ to +105℃ - - 23 μA [1] Under steady state (non-transient) conditions, IOL must be externally limited as follows, Maximum IOL per port pin: 40mA Maximum total IOL for all outputs: 120mA [2] Pins of all ports in quasi-bidirectional mode source a transition current when they are being externally driven from 1 to 0. The transition current reaches its maximum value when V IN is approximately 2V. [3] It is measured while MCU keeps in running “SJMP $” loop continuously. All pins of ports are configured as quasi-bidirectional mode. Jan. 27, 2018 Page 195 of 205 Rev. 1.02 N76E885 Datasheet 32.3 A.C. Electrical Characteristics Table 32–2. System Clock A.C. Electrical Characteristics Symbol 1/ tCLCL Parameter Min. Typ. Max. Unit External clock input frequency (ECLK) 0 - 25 MHz High-speed crystal/resonator frequency (HXT) 2 - 25 Low-speed crystal/resonator frequency (LXT) - 32.768 - kHz tCHCX External clock input high time 30 - - ns tCLCX External clock input low time 30 - - ns tCLCH External clock input rise time - - 10 ns tCHCL External clock input fall time - - 10 ns Figure 32.1. External Clock Input Timing Table 32–3. I/O Slew Rate A.C. Electrical Characteristics PxSR.n bit value Symbol 0 FOUT TR TF 1 FOUT TR Jan. 27, 2018 Parameter Maximum output frequency Condition [1] Output low to high rising time Output high to low falling time Maximum output frequency [1] Output low to high rising time Min. Typ. Max. Unit VDD = 5.0V, CL = 30pF - 34 - MHz VDD = 3.3V, CL = 30pF - 22.5 - VDD = 2.4V, CL = 30pF - 12.8 - VDD = 5.0V, CL = 30pF - 7.4 - VDD = 3.3V, CL = 30pF - 11 - VDD = 2.4V, CL = 30pF - 18 - VDD = 5.0V, CL = 30pF - 7.2 - VDD = 3.3V, CL = 30pF - 11.2 - VDD = 2.4V, CL = 30pF - 21 - VDD = 5.0V, CL = 30pF - 39 - VDD = 3.3V, CL = 30pF - 27.5 - VDD = 2.4V, CL = 30pF - 17 - VDD = 5.0V, CL = 30pF - 7 - VDD = 3.3V, CL = 30pF - 10 - VDD = 2.4V, CL = 30pF - 16 - Page 196 of 205 ns ns MHz ns Rev. 1.02 N76E885 Datasheet PxSR.n bit value Symbol TF Parameter Condition Output high to low falling time Min. Typ. Max. Unit VDD = 5.0V, CL = 30pF - 4.8 - ns VDD = 3.3V, CL = 30pF - 7 - VDD = 2.4V, CL = 30pF - 11.8 - [1] Maximum output frequency is achieved if ((TR + TF) ≤ 1/2) T and if the duty cycle is 45% to 55%. See figure below. 90% 90% 10% 10% TR TF T = 1/FOUT Figure 32.2. I/O A.C. Characteristics Definition Table 32–4. Internal Oscillator A.C. Electrical Characteristics Symbol FHIRC FLIRC Frequency Deviation Min. Typ. Max. Unit TA = -10℃ to +70℃ 1% 21.897 22.118 22.340 MHz TA = -40℃ to +105℃ 2% 21.676 35% 6.5 10 13.5 kHz Min. Typ. Max. Unit HIRC - 60 - μs HXT, F = 25MHz - 500 - Min. Typ. Max. Unit - 24/FSYS 450 μs Min. Typ. Max. Unit 1.3 1.4 1.5 V - 4 - ms Parameter High-speed 22.118 MHz oscillator frequency (HIRC) Condition Low-speed 10 kHz oscillator frequency (LIRC) 22.560 Table 32–5. Power-Down Wake-Up A.C. Electrical Characteristics Symbol TPDWK Parameter Power-down wake-up time Condition Table 32–6. External Reset Pin A.C. Electrical Characteristics Symbol TRST Parameter Condition ̅̅̅̅̅̅ pin detect pulse width 32.4 Analog Electrical Characteristics Table 32–7. POR Electrical Characteristics Symbol VPOR Parameter Condition Power-on reset voltage TPORRD Power-on reset release delay Jan. 27, 2018 Page 197 of 205 Rev. 1.02 N76E885 Datasheet Table 32–8. BOD Electrical Characteristics Symbol Parameter Condition Min. Typ. Max. Unit VBOD0 Brown-out threshold 4.3V BOV[2:0] = [0,0,0] 4.15 4.3 4.45 V VBOD1 Brown-out threshold 3.7V BOV[2:0] = [0,0,1] 3.55 3.7 3.85 V VBOD2 Brown-out threshold 3.0V BOV[2:0] = [0,1,0] 2.85 3.0 3.15 V VBOD3 Brown-out threshold 2.7V BOV[2:0] = [0,1,1] 2.6 2.7 2.8 V VBOD4 Brown-out threshold 2.4V BOV[2:0] = [1,0,0] 2.3 2.4 2.5 V VBOD5 Brown-out threshold 2.2V BOV[2:0] = [1,0,1] 2.1 2.2 2.3 V VBOD6 Brown-out threshold 2.0V BOV[2:0] = [1,1,0] 1.9 2.0 2.1 V VBOD7 Brown-out threshold 1.7V BOV[2:0] = [1,1,1] 1.6 1.7 1.8 V LPBOD[1:0] = [0,0] only 50 65 80 mV VDD = 5V, LPBOD[1:0] = [0,0] - 55 70 μA VDD = 5V, LPBOD[1:0] = [0,1] - 14 16 VDD = 5V, LPBOD[1:0] = [1,0] - 4 6 VDD = 5V, LPBOD[1:0] = [1,1] - 1.5 2.5 VBODHYS Brown-out hysteresis IBOD TBOD TBODEN Brown-out quiescent current Brown-out detect pulse width See Table 25–2 Brown-out enable time - 2 - 3 1/FLIRC Min. Typ. Max. Unit 1.16 1.22 1.28 V 1 - 2 1/FLIRC Min. Typ. Max. Unit 2.4 - 5.5 V - 160 220 μA 1.8 - VAVDD V 0 - VVREF V Table 32–9. Band-gap Electrical Characteristics Symbol VBG TBGEN Parameter Condition Band-gap voltage Band-gap enable time Table 32–10. ADC Electrical Characteristics Symbol Parameter VAVDD ADC operating voltage IAVDD ADC power supply current VVREF Analog reference voltage VAIN Analog input voltage NR Resolution Condition VAVDD = 5V, VREFSEL = 0 10 bit DNL Differential non-linearity error - +1.5 +2 LSB INL Integral non-linearity error - ±1 ±2 LSB OE Offset error - +2 +3 LSB Jan. 27, 2018 Page 198 of 205 Rev. 1.02 N76E885 Datasheet Symbol FE TUE FADC TS Parameter Condition Min. Typ. Max. Unit Full scale error - +1.5 +2.5 LSB Total un-adjust error - +3.5 +4 LSB Monotonicity ADC clock frequency Guaranteed VVREF = 3.0V to 5.5V 0.01 - 6 VVREF = 2.4V to 5.5V 0.01 - 3 6 - 261 Sampling time (software adjust) TCONV Total conversion time TADCEN ADC enable time RIN ADC input equivalent resistor CIN ADC input equivalent capacitor Jan. 27, 2018 - - Page 199 of 205 MHz 1/FADC TS + 12 1/FADC 32 1/FADC - 7 kΩ 10 12 pF Rev. 1.02 N76E885 Datasheet 33. PACKAGE DIMENSIONS 33.1 28 pin TSSOP 28 – 4.4 X 9.7 mm Figure 33.1. TSSOP-28 Package Dimension Jan. 27, 2018 Page 200 of 205 Rev. 1.02 N76E885 Datasheet 33.2 28-pin SOP - 300 mil 15 28 E 14 1 Control demensions are in milmeters . E  Jan. 27, 2018 Page 201 of 205 Rev. 1.02 N76E885 Datasheet 33.3 20 pin TSSOP20 – 4.4 X 6.5 mm Figure 33.2. TSSOP-20 Package Dimension Jan. 27, 2018 Page 202 of 205 Rev. 1.02 N76E885 Datasheet 33.4 20 pin QFN – 4.0 X 4.0 mm Figure 33.3. QFN 20 Package Dimension Jan. 27, 2018 Page 203 of 205 Rev. 1.02 N76E885 Datasheet 34. DOCUMENT REVISION HISTORY Revision Date Description 1.00 2015/2/26 Initial release. 1.01 2015/12/21 Modified ECLK 1.8v Domain Modified data retention guarantee years Modified TSSOP 28 package dimension Y value Modified RAM access description Modified VIL and VIL1 description Removed AUXR Modified band-gap description with BODEN 1.02 2018/1/27 Added QFN20 package information in Chapter 4 and 33 Added notice for WDT counter auto clear condition in Chapter 12.1 Added SOP 28 package pin assignment and pin description table in Chapter 4 and 34. Jan. 27, 2018 Page 204 of 205 Rev. 1.02 N76E885 Datasheet Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “ nsecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All nsecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to uvoton as a result of customer’s nsecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Jan. 27, 2018 Page 205 of 205 Rev. 1.02
N76E885AT28 价格&库存
很抱歉,暂时无法提供与“N76E885AT28”相匹配的价格&库存,您可以联系我们找货
N76E885AT28
    • 4000+3.39900
    库存:20725
    N76E885AT28
    • 1+4.91700
    • 100+4.10300
    • 1000+3.80600
    • 2000+3.61900
    • 4000+3.47600
    库存:3476
    N76E885AT28
    • 1+8.12160
    • 10+6.95520
    • 50+6.15600
    库存:12
