NJM2734V-TE1
NJM2734V-TE1
    JRC(⽇本无线)
    LSSOP14
    IC OPAMP GP 4 CIRCUIT 14SSOP
NJM2734V-TE1 数据手册
NJM2734 Rail-to-Rail Input/Output Quad Operational Amplifier ■ GENERAL DESCRIPTION NJM2734 is a Rail-to-Rail Input/Output quad operational amplifier featuring Low power, low noise and operation from 1.8V. Rail-to-Rail Input/Output provides wide dynamic range, is from ground to power supply level. In addition to ground sensing applications, NJM2734 enable to be applied to Hi-side sensing applications. The features are low noise and low operating voltage for battery management, portable audio applications, and others. ■ PACKAGE OUTLINE NJM2734D NJM2734V NJM2734M ■ FEATURES ●Operating Voltage ●Rail-to-Rail Input ●Rail-to-Rail Output ●Load Drivability ●Offset Voltage ●Slew Rate ●Low Input Voltage Noise ●Adequate phase margin ●Bipolar Technology ●Package Outline NJM2734SCC 1.8 to 6.0V VICM= 0 to 5.0V, at V+=5V VOH≥4.9V/ VOL≤0.1V, at V+=5V, RL=20kΩ VOH≥4.75V/ VOL≤0.25V, at V+=5V, RL=2kΩ 5mV max. 0.4V/μs typ. 10nV/√Hz typ. ΦM=75deg. typ., at RL=2kΩ DIP14 , DMP14 , SSOP14 , PCSP20-CC ■ PIN CONFIGURATION ○NJM2734D,NJM2734V,NJM2734M 14 PIN FUNCTION 13 1. A OUTPUT 8. C OUTPUT 3 12 2. A -INPUT 9. C -INPUT 4 11 3. A +INPUT 10. C +INPUT 1 A 2 D + - - + − + 5 10 + C - + B 6 9 7 8 4. V 11. GND(V ) 5. B +INPUT 12. D +INPUT 6. B –INPUT 13. D –INPUT 7. B OUTPUT 14. D OUTPUT ○NJM2734SCC 20 19 18 17 16 16 1 17 18 19 PIN FUNCTION 20 15 15 1 14 14 2 3 13 13 3 4 12 12 4 11 11 5 A B 2 C D 5 6 7 8 9 10 PAD 10 9 8 7 6 1. NC 9. D +INPUT 17. A +INPUT 2. B OUTPUT 10. D –INPUT 18. V 3. NC 11. NC 19. B +INPUT 4. C OUTPUT 12. D OUTPUT 20. B –INPUT 5. NC 13. NC 6. C –INPUT 14. A OUTPUT 7. C +INPUT 15. NC − 8. GND(V ) + 16. A –INPUT (Note1) The NC pin and the PAD should connect with a GND terminal. (Note2) The NC pin is electrically not connected to the die in a package. (Note3) The PAD is electrically not connected to the backside of the die. The PAD cannot be used as GND pin. Ver.2016-8-9 -1- NJM2734 ■ ABSOLUTE MAXIMUM RATINGS (Ta=25˚C) PARAMETER Supply Voltage Differential Input Voltage Range Common Mode Input Voltage Range SYMBOL + V VID VIC Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS 7.0 ±1.0 (Note4) 0 ~ 7.0 (Note4) (DIP14) 700 (DMP14) 520 (Note5) (SSOP14) 450 (Note5) (PCSP20−CC)400(Note5) -40~+85 -40~+125 UNIT V V V mW ˚C ˚C (Note4) For supply voltage less than 7V, the absolute maximum input voltage is equal to the supply voltage. (Note5) On the PCB “ EIA/JEDEC (76.2×114.3×1.6mm, two layers, FR-4) “ ■ RECOMMENDED OPERATING CONDITION (Ta=25˚C) PARAMETER Supply Voltage SYMBOL + V RATING 1.8 to 6.0 UNIT V ■ ELECTRICAL CHARACTERISTICS (V+=5V, Ta=25˚C) ●DC CHARACTERISTICS PARAMETER Operating Current Input Offset Voltage Input Bias Current Input Offset Current Large Signal Voltage Gain Common Mode Rejection Ratio SYMBOL ICC VIO IB IIO AV CMR Supply Voltage Rejection Ratio Maximum Output Voltage 1 SVR VOH1 VOL1 VOH2 VOL2 VICM Maximum Output Voltage 2 Input Common Mode Voltage Range (Note6) TEST CONDITION No signal applied RL=2kΩ to 2.5V CMR+: 2.5V≤VCM ≤5V (Note6) CMR -: 0V≤VCM≤2.5V (Note6) + V /V =±2.0V ~ ±3.0V RL=20kΩ to 2.5V RL=20kΩ to 2.5V RL=2kΩ to 2.5V RL=2kΩ to 2.5V CMR≥55dB (V+=5V, Ta=25˚C) MIN. 60 55 TYP. 1.2 1 50 5 85 70 MAX. 1.8 5 250 100 - UNIT mA mV nA nA dB dB 70 4.9 4.75 0 85 4.95 0.05 4.85 0.15 - 0.1 0.25 5 dB V V V V V CMR is represented by either CMR+ or CMR- has lower value. CMR+ is measured with 2.5V≤VCM≤5.0 and CMR- is measured with 0V≤VCM≤2.5V. (V+=5V, Ta=25˚C) ●AC CHARACTERISTICS PARAMETER Unity Gain Bandwidth Phase Margin Equivalent Input Noise Voltage Amp to Amp Separation SYMBOL GB ΦM VNI CS TEST CONDITION RL=2kΩ to 2.5V RL=2kΩ to 2.5V f=1kHz f=1kHz RL=2kΩ to 2.5V, Vo=1.2Vrms MIN. - TYP. 1 75 10 133 PARAMETER -2- SYMBOL SR UNIT MHz Deg nV/√Hz dB (V+=5V, Ta=25˚C) ●TRANSIENT CHARACTERISTICS Slew Rate MAX. - TEST CONDITION RL=2kΩ to 2.5V MIN. - TYP. 0.4 MAX. - UNIT V/μs Ver.2016-8-9 NJM2734 ■ ELECTRICAL CHARACTERISTICS (V+=3V, Ta=25˚C) ●DC CHARACTERISTICS PARAMETER Operating Current Input Offset Voltage Input Bias Current Input Offset Current Large Signal Voltage Gain Common Mode Rejection Ratio SYMBOL ICC VIO IB IIO AV CMR Supply Voltage Rejection Ratio Maximum Output Voltage 1 SVR VOH1 VOL1 VOH2 VOL2 VICM Maximum Output Voltage 2 Input Common Mode Voltage Range (Note7) TEST CONDITION No signal applied RL=2kΩ to 1.5V CMR+: 1.5V≤VCM≤3V (Note7) CMR -: 0V≤VCM≤1.5V (Note7) + V /V =±1.2V ~ ±2.0V RL=20kΩ to 1.5V RL=20kΩ to 1.5V RL=2kΩ to 1.5V RL=2kΩ to 1.5V CMR≥48dB (V+=3V, Ta=25˚C) MIN. 60 48 TYP. 1 1 50 5 84 63 MAX. 1.8 5 250 100 - UNIT mA mV nA nA dB dB 68 2.9 2.75 0 83 2.95 0.05 2.85 0.15 - 0.1 0.25 3 dB V V V V V CMR is represented by either CMR+ or CMR-has lower value. CMR+ is measured with 1.5V≤VCM≤3.0 and CMR- is measured with 0V≤VCM≤1.5V. (V+=3V, Ta=25˚C) ●AC CHARACTERISTICS PARAMETER Unity Gain Bandwidth Phase Margin Equivalent Input Noise Voltage Amp to Amp Separation SYMBOL GB ΦM VNI CS TEST CONDITION RL=2kΩ to 1.5V RL=2kΩ to 1.5V f=1kHz f=1kHz RL=2kΩ to 1.5V, Vo=0.7Vrms MIN. - TYP. 1 75 10 130 PARAMETER Ver.2016-8-9 SYMBOL SR UNIT MHz Deg nV/√Hz dB (V+=3V, Ta=25˚C) ●TRANSIENT CHARACTERISTICS Slew Rate MAX. - TEST CONDITION RL=2kΩ to 1.5V MIN. - TYP. 0.35 MAX. - UNIT V/μs -3- NJM2734 ■ ELECTRICAL CHARACTERISTICS (V+=1.8V, Ta=25˚C) ●DC CHARACTERISTICS PARAMETER Operating Current Input Offset Voltage Input Bias Current Input Offset Current Large Signal Voltage Gain Common Mode Rejection Ratio SYMBOL ICC VIO IB IIO AV CMR Supply Voltage Rejection Ratio Maximum Output Voltage 1 SVR VOH1 VOL1 VOH2 VOL2 VICM Maximum Output Voltage 2 Input Common Mode Voltage Range (Note8) TEST CONDITION No signal applied RL=2kΩ to 0.9V CMR+: 0.9≤VCM≤1.8V (Note8) CMR-:0V≤VCM≤0.9V (Note8) + V /V =±0.9V ~ ±1.2V RL=20kΩ to 0.9V RL=20kΩ to 0.9V RL=2kΩ to 0.9V RL=2kΩ to 0.9V CMR≥40dB (V+=1.8V, Ta=25˚C) MIN. 60 40 TYP. 0.9 1 50 5 83 55 MAX. 1.6 5 250 100 - UNIT mA mV nA nA dB dB 65 1.7 1.55 0 80 1.75 0.05 1.65 0.15 - 0.1 0.25 1.8 dB V V V V V CMR is represented by either CMR+ or CMR-has lower value. CMR+ is measured with 0.9V≤VCM≤1.8 and CMR- is measured with 0V≤VCM≤0.9V. (V+=1.8V, Ta=25˚C) ●AC CHARACTERISTICS PARAMETER Unity Gain Bandwidth Phase Margin Equivalent Input Noise Voltage Amp to Amp Separation SYMBOL GB ΦM VNI CS TEST CONDITION RL=2kΩ t o 0.9V RL=2kΩ to 0.9V f=1kHz f=1kHz RL=2kΩ to 0.9V, Vo=0.4Vrms MIN. - TYP. 1 75 10 125 PARAMETER -4- SYMBOL SR UNIT MHz Deg nV/√Hz dB (V+=1.8V, Ta=25˚C) ●TRANSIENT CHARACTERISTICS Slew Rate MAX. - TEST CONDITION RL=2kΩ to 0.9V MIN. - TYP. 0.3 MAX. - UNIT V/μs Ver.2016-8-9 NJM2734 ■ Typical Characteristics Operating Current vs. Supply Voltage Operating Current vs. Ambient Temperature (Ambient Temperature) GV=0dB GV=0dB 1.6 1.6 Ta=85oC 1.4 Ta=25oC Operating Current [mA] Operating Current [mA] 1.4 Ta=125oC 1.2 1 0.8 Ta=-50oC 0.6 Ta=-40oC 0.4 0.2 1.2 1 0.8 0.6 + V =1.8V 0.4 0.2 0 0 0 1 2 3 4 5 Supply Voltage [V] 6 7 -50 -25 0 25 50 75 100 Ambient Temperature [oC] (Ambient Temperature) -0.2 Ta=85oC o Ta=125 C 3 Input Offset Voltage [mV] Input Offset Voltage [mV] GV=0dB GV=0dB 0 o Ta=25 C -0.4 -0.6 o Ta=-50 C o Ta=-40 C -0.8 -1 2 1 V+=3V + V =5V 0 -1 V+=1.8V -2 -3 0 1 2 3 4 5 Supply Voltage [V] 6 7 -50 Input Offset Current vs. Ambient Temperature -25 0 25 50 75 100 Ambient Temperature [oC] 125 Input Bias Current vs. Ambient Temperature GV=0dB GV=0dB 100 12 8 + 4 V =1.8V Input Bias Current [nA] Input Offset Current [nA] 125 Input Offset Voltage vs. Ambient Temperature Input Offset Voltage vs. Supply Voltage + V =3V 0 -4 V+=5V -8 -12 80 + V =5V + V =3V 60 40 V+=1.8V 20 0 -50 Ver.2016-8-9 V+=3V V+=5V -25 0 25 50 75 100 Ambient Temperature [oC] 125 -50 -25 0 25 50 75 100 Ambient Temperature [oC] 125 -5- NJM2734 ■ Typical Characteristics Common Mode Rejection Ratio vs. Ambient Temperature Supply Voltage Rejection Ratio vs. Ambient Temperature V+/2VICMV+ GV=0dB 90 Common Mode Rejection Ratio [dB] Supply Voltage Rejection Ratio [dB] 100 + V =4V to 6V 95 90 85 80 75 + V =2.4V to 4V 70 V+=1.8V to 2.4V 65 85 V+=5V 80 75 70 V+=1.8V 65 + V =3V 60 55 50 60 -50 -25 0 25 50 75 100 Ambient Temperature [oC] -50 125 1.0 0.5 85 80 + V =3V 75 + V =5V 70 65 60 + 0.0 o Ta=+85 C -0.5 o Ta=+25 C -1.0 -1.5 -2.0 Ta=-40oC V =1.8V -2.5 55 50 -3.0 -50 -25 0 25 50 75 100 Ambient Temperature [oC] 125 -1.5 Input Offset Voltage vs. Common Mode Input Voltage + -1 -0.5 0 0.5 1 Common Mode Input Voltage [V] - V+/V-=±2.5V V /V =±1.5V 1.0 0.5 Input Offset Voltage [mV] 0.5 Input Offset Voltage [mV] 1.5 Input Offset Voltage vs. Common Mode Input Voltage 1.0 o Ta=+85 C 0.0 -0.5 -1.0 o Ta=+25 C -1.5 Ta=-40oC -2.0 -2.5 0.0 Ta=+85oC -0.5 o -1.0 Ta=+25 C -1.5 Ta=-40 C o -2.0 -2.5 -3.0 -3.0 -3 -6- 125 V+/V-=±0.9V 0VVICMV+/2 Input Offset Voltage [mV] Common Mode Rejection Ratio [dB] 0 25 50 75 100 Ambient Temperature [oC] Input Offset Voltage vs. Common Mode Input Voltage Common Mode Rejection ratio vs. Ambient Temperature 90 -25 -2 -1 0 1 2 Common Mode Input Voltage [V] 3 -3 -2 -1 0 1 2 Common Mode Input Voltage [V] 3 Ver.2016-8-9 NJM2734 ■ Typical Characteristics Maximum Output Voltage vs. Load Resistance Input bias Current vs. Common Mode Input Voltage (Ambient Temperature) o Ta=+25 C 200 3 V+=1.8V, G V=OPEN, R L to 1/2V + + Maximum Output Voltage [V] Input Bias Current [nA] 150 - V /V =±2.5V 100 50 0 + - V /V =±0.9V -50 + - V /V =±1.5V -100 -150 -2 -1 0 1 2 Common Mode Input Voltage [V] 1 3 Maximum Output Voltage vs. Load Resistance Maximum Output Voltage [V] Maximum Output Voltage [V] 5 2 o Ta=+85 C Ta=+25 oC o Ta=-40 C Ver.2016-8-9 0.1 1 10 Load Resistance [kΩ] 0.1 1 10 Load Resistance [kΩ] 100 (Ambient Temperature) 3 0 0.01 o Ta=+25 C Maximum Output Voltage vs. Load Resistance (Ambient Temperature) V+=3V, G V=OPEN, R L to 1/2V + 1 Ta=+85 oC Ta=-40 oC 0 0.01 -200 -3 2 100 V+=5V, G V=OPEN, R L to 1/2V + 4 3 2 Ta=+85 oC o Ta=+25 C 1 0 0.01 o Ta=-40 C 0.1 1 10 Load Resistance [kΩ] 100 -7- NJM2734 ■ Typical Characteristics Voltage Gain/Phase vs. Frequency Voltage Gain/Phase vs. Frequency (Capacitive Load) + (Ambient Temperature) - o V /V =±2.5V, GV=40dB, RL=2kΩ, Ta=+25 C 60 180 60 120 40 V+/V-=±2.5V, GV=40dB, RL=2kΩ, CL=10pF Gain 40 Gain o 180 120 Ta=-40 C Phase 0 0 -20 -60 -40 CL=1000pF 1k 10k 1M 100k 1000k Frequency [Hz] 60 -120 -40 -120 -180 10M 10000k -60 1k 10k -180 10M 10000k 1M 100k 1000k Frequency [Hz] Voltage Gain/Phase vs. Frequency (Capacitive Load) (Ambient Temperature) V+/V-=±1.5V, GV=40dB, RL=2kΩ, Ta=+25oC V+/V-=±1.5V, GV=40dB, RL=2kΩ, CL=10pF 180 60 180 gain Gain 60 CL=10pF Phase 0 -20 -60 Ta=+25oC 20 60 Phase 0 o Ta=+85 C 0 -20 -60 -120 -40 -120 -180 10M 10000k -60 CL=220pF -40 120 CL=470pF Phase [deg] 20 Ta=-40oC 40 Voltage Gain [dB] 120 Phase [deg] Voltage Gain [dB] 0 -60 40 0 Ta=+85 C Phase 0 Voltage Gain/Phase vs. Frequency 60 o -20 CL=220pF CL=470pF -60 20 Phase [deg] 60 CL=10pF Voltage Gain [dB] 20 Phase [deg] Voltage Gain [dB] o Ta=+25 C CL=1000pF -60 1k 10k 1M 100k 1000k Frequency [Hz] 1k Voltage gain/Phase vs. Frequency 10k -180 10M 10000k 1M 100k 1000k Frequency [Hz] Voltage Gain/Phase vs. Frequency (Capacitive Load) (Ambient Temperature) V+/V-=±0.9V, GV=40dB, RL=2kΩ, CL=10pF V+/V-=±0.9V, GV=40dB, RL=2kΩ, Ta=+25oC 60 180 60 180 Gain Gain 40 120 Ta=-40oC 40 120 o Phase 0 0 -20 -60 CL=220pF -40 CL=470pF 20 60 Phase o Ta=+85 C 0 0 -20 -60 -120 -40 -120 -180 10M 10000k -60 CL=1000pF -60 1k -8- 10k 1M 100k 1000k Frequency [Hz] 1k 10k 1M 100k 1000k Frequency [Hz] -180 10M 10000k Ver.2016-8-9 Phase [deg] 60 CL=10pF Voltage Gain [dB] 20 Phase [deg] Voltage Gain [dB] Ta=+25 C NJM2734 ■ Typical Characteristics Voltage Gain vs. Frequency Voltage Gain vs. Frequency (Voltage Follower, Capacitive Load) (Voltage Follower, Ambient Temperature) V+/V-=±2.5V, GV=0dB, RL=2kΩ, Ta=+25oC V+/V-=±2.5V, GV=0dB, RL=2kΩ, CL=10pF 15 15 10 10 Voltage Gain [dB] Voltage Gain [dB] CL=1000pF CL=470pF 5 CL=220pF 0 CL=10pF -5 -10 5 Ta=-40oC 0 Ta=+25oC -5 Ta=+85oC -10 -15 10k M 100k M 1M 10M Frequency [Hz] -15 10k M 100M 100k M 1M 10M Frequency [Hz] Voltage Gain vs. Frequency Voltage Gain vs. Frequency (Voltage Follower, Capacitive Load) (Voltage Follower, Ambient Temperature) V+/V-=±1.5V, GV=0dB, RL=2kΩ, Ta=+25oC 100M V+/V-=±1.5V, GV=0dB, RL=2kΩ, CL=10pF 15 15 10 10 Voltage Gain [dB] Voltage Gain [dB] CL=1000pF CL=470pF 5 CL=220pF 0 CL=10pF -5 -10 5 Ta=-40oC 0 Ta=+25oC -5 o Ta=+85 C -10 -15 10k M 100k M 1M 10M Frequency [Hz] -15 10k M 100M 100k M 1M 10M Frequency [Hz] Voltage Gain vs. Frequency Voltage Gain vs. Frequency (Voltage Follower, Capacitive Load) (Voltage Follower, Ambient Temperature) + - o V /V =±0.9V, GV=0dB, RL=2kΩ, Ta=+25 C 100M V+/V-=±0.9V, GV=0dB, RL=2kΩ, CL=10pF 15 15 10 10 Voltage Gain [dB] Voltage Gain [dB] CL=1000pF CL=470pF 5 CL=220pF 0 CL=10pF -5 -10 o Ta=-40 C 0 Ta=+25oC -5 o Ta=+85 C -10 -15 -15 10k M Ver.2016-8-9 5 100k M 1M 10M Frequency [Hz] 100M 10k M 100k M 1M 10M Frequency [Hz] 100M -9- NJM2734 ■ Typical Characteristics Pulse Response (Ambient Temperature) Pulse Response (Ambient Temperature) V+=5V, AV=0dB, VIN=1VPP RL=2kΩ to V+/2, CL=10pF V+=5V, AV=0dB, VIN=1VPP RL=2kΩ to V+/2, CL=1000pF 5.0 3.5 2.5 4.0 2.0 3.5 1.5 3.0 1.0 2.5 Ta=-40ºC Ta=25ºC Ta=+85ºC 0.5 Input Voltage [V] 4.5 Output Voltage [V] 2.0 3.0 4.5 2.5 4.0 2.0 3.5 1.5 3.0 1.0 0.5 0.0 1.5 5 10 15 Time [μsec] 20 0.0 25 1.5 -5 20 V+=3V, AV=0dB, VIN=1VPP RL=2kΩ to V+/2, CL=1000pF 2.5 4.0 4.0 1.5 3.0 1.0 2.5 0.5 2.0 0.0 1.5 Ta=-40ºC Ta=25ºC Ta=+85ºC 2.0 3.5 1.5 3.0 1.0 2.5 0.5 2.0 0.0 1.5 Ta=-40ºC Ta=25ºC Ta=+85ºC -0.5 1.0 OUTPUT 1.0 OUTPUT -1.0 -1.0 0.5 0 5 10 15 Time [μsec] 20 0.5 -5 25 0 5 10 15 Time [μsec] 20 Pulse Response (Ambient Temperature) Pulse Response (Ambient Temperature) V+=1.8V, AV=0dB, VIN=1VPP RL=2kΩ to V+/2, CL=10pF V+=1.8V, AV=0dB, VIN=1VPP RL=2kΩ to V+/2, CL=1000pF 2.0 Output Voltage [V] 3.5 Input Voltage [V] 2.0 -5 25 INPUT Output Voltage [V] Input Voltage [V] 10 15 Time [μsec] Pulse Response (Ambient Temperature) -0.5 2.0 3.0 INPUT 25 3.0 INPUT 1.5 1.5 1.0 2.0 0.5 1.5 0.0 Ta=-40ºC 1.0 -0.5 Ta=25ºC Ta=+85ºC -1.0 Input Voltage [V] 2.5 Output Voltage [V] Input Voltage [V] 5 V+=3V, AV=0dB, VIN=1VPP RL=2kΩ to V+/2, CL=10pF INPUT 2.5 1.0 2.0 0.5 1.5 0.0 Ta=-40ºC -0.5 0.5 -1.0 0.0 -1.5 0 1.0 Ta=25ºC Ta=+85ºC OUTPUT 0.5 OUTPUT -1.5 - 10 - 0 Pulse Response (Ambient Temperature) 2.5 -5 2.0 OUTPUT OUTPUT 0 2.5 Ta=-40ºC Ta=25ºC Ta=+85ºC 5 10 15 Time [μsec] 20 25 0.0 -5 0 5 10 15 Time [μsec] 20 25 Ver.2016-8-9 Output Voltage [V] Input Voltage [V] 3.0 -5 5.0 INPUT INPUT Output Voltage [V] 3.5 NJM2734 ■ Typical Characteristics Unity Gain Frequency vs. Capacitive Load Phase Margin vs. Capacitive Load o GV=40dB, RF=2kΩ, RG=20Ω, RS=50Ω, Ta=+25 C o GV=40dB, RF=2kΩ, RG=20Ω, RS=50Ω, Ta=+25 C 90 1.4 V+/V-=±1.5V + 0.8 - V /V =±0.9V 0.6 0.4 60 + - V /V =±0.9V 50 40 30 20 0.2 10 0 0 10 100 1000 Capacitive Load [pF] 10000 10 100 1000 Capacitive Load [pF] Amp to Amp Separation vs. Frequency Amp to Amp Separation vs. Frequency V+/V-=±2.5V, GV=40dB, RL=2kΩ to 0V, RF=100kΩ, V /V =±0.9V, GV=40dB, RL=2kΩ to 0V, RF=100kΩ, + o VIN=Ach, Vo=3VPP, Ta=25 C VIN=Ach, Vo=1VPP, Ta=25 C -60 Amp to Amp Separation [dB] Amp to Amp Separation [dB] -60 -80 -100 ACHCCH ACHBCH -120 ACHDCH -140 -160 0.01 0.1 1 10 Frequency [kHz] -80 -100 ACHCCH -140 -160 0.01 100 + 0.1 1 10 Frequency [kHz] 100 Amp to Amp Separation vs. Frequency + - V /V =±0.9V, GV=40dB, RL=2kΩ to 0V, RF=100kΩ, - V /V =±2.5V, GV=40dB, RL=2kΩ to 0V, RF=100kΩ, o o VIN=Cch, Vo=1VPP, Ta=25 C VIN=Cch, Vo=3VPP, Ta=25 C -60 Amp to Amp Separation [dB] -60 -80 -100 CCHACH CCHBCH -120 -140 Ver.2016-8-9 ACHDCH ACHBCH -120 Amp to Amp Separation vs. Frequency -160 0.01 10000 - o Amp to Amp Separation [dB] - V /V =±2.5V 70 1 + V+/V-=±1.5V 80 Phase Margin [deg] Unity Gain Frequency [MHz] V+/V-=±2.5V 1.2 CCHDCH 0.1 1 10 Frequency [kHz] -80 CCHBCH -100 -120 CCHDCH -140 CCHACH 100 -160 0.01 0.1 1 10 Frequency [kHz] 100 - 11 - NJM2734 ■ Typical Characteristics Total Harmonic Distortion vs. Output Voltage Sine Wave Response V+/V-=±1.5V, AV=0dB, VIN=3VPP RL=2kΩ to 0V, f=10kHz, Ta=25°C + 3 INPUT 2 0 1 -1 0 -2 -1 OUTPUT -3 -100 -50 0 Time [μsec] 50 -2 100 Output Voltage [V] Input Voltage [V] 1 Total Harmonic Distortion (THD+N) [%] 2 - V /V =±1.5V, AV=+2, RL=2kΩ to 0V, CL=0pF, Ta=25°C 10 1 BPF 100Hz : 22Hz to 30kHz 1kHz : 400Hz to 30kHz 10kHz : 400Hz to 80kHz 10kHz 1kHz 0.1 0.01 100Hz 0.001 0.001 0.01 0.1 1 Output Voltage [Vrms] 10 Equivalent Input Noise Voltage vs. Frequency Equivalent Input Noise Voltage [nV/Hz] GV=40dB, RL=2kΩ to 0V, CL=10pF, Ta=25oC 30 25 20 V+/V-=±0.9V 15 10 V+/V-=±1.5V 5 V+/V-=±2.5V 0 k1 10 k 100 k 1k 10k Frequency [Hz] [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. - 12 - Ver.2016-8-9
NJM2734V-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2734V-TE1”相匹配的价格&库存,您可以联系我们找货
